[U-Boot] [PATCH v2] tools/env: fix environment alignment tests for block devices
commit 183923d3e412500bdc597d1745e2fb6f7f679ec7 enforces that the environment must start at an erase block boundary.
For block devices the sample fw_env.config does not mandate a erase block size for block devices. A missing setting defaults to the full env size.
Depending on the environment location the alignment check now errors out for perfectly legal settings.
Fix this by defaulting to the standard blocksize of 0x200 for environments stored in a block device. That keeps the fw_env.config files for block devices working even with that new check.
Signed-off-by: Max Krummenacher max.krummenacher@toradex.com
Changes in v2: - move default value handling from parse_config(), get_config() to check_device_config(), so that !defined(CONFIG_FILE) is covered also. - use DIV_ROUND_UP instead of doing this manually - move the check after the setting of default values in check_device_config(). - use 0 as the marker for default values to be used.
tools/env/fw_env.c | 60 ++++++++++++++++++++++++++++++------------------------ 1 file changed, 33 insertions(+), 27 deletions(-)
diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index 3dc0d53..862a0b1 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -1291,18 +1291,6 @@ static int check_device_config(int dev) struct stat st; int fd, rc = 0;
- if (DEVOFFSET(dev) % DEVESIZE(dev) != 0) { - fprintf(stderr, "Environment does not start on (erase) block boundary\n"); - errno = EINVAL; - return -1; - } - - if (ENVSIZE(dev) > ENVSECTORS(dev) * DEVESIZE(dev)) { - fprintf(stderr, "Environment does not fit into available sectors\n"); - errno = EINVAL; - return -1; - } - fd = open(DEVNAME(dev), O_RDONLY); if (fd < 0) { fprintf(stderr, @@ -1335,9 +1323,15 @@ static int check_device_config(int dev) goto err; } DEVTYPE(dev) = mtdinfo.type; + if (DEVESIZE(dev) == 0) + /* Assume the erase size is the same as the env-size */ + DEVESIZE(dev) = ENVSIZE(dev); } else { uint64_t size; DEVTYPE(dev) = MTD_ABSENT; + if (DEVESIZE(dev) == 0) + /* Assume the erase size to be 512 bytes */ + DEVESIZE(dev) = 0x200;
/* * Check for negative offsets, treat it as backwards offset @@ -1359,6 +1353,22 @@ static int check_device_config(int dev) } }
+ if (ENVSECTORS(dev) == 0) + /* Assume enough sectors to cover the environment */ + ENVSECTORS(dev) = DIV_ROUND_UP(ENVSIZE(dev), DEVESIZE(dev)); + + if (DEVOFFSET(dev) % DEVESIZE(dev) != 0) { + fprintf(stderr, "Environment does not start on (erase) block boundary\n"); + errno = EINVAL; + return -1; + } + + if (ENVSIZE(dev) > ENVSECTORS(dev) * DEVESIZE(dev)) { + fprintf(stderr, "Environment does not fit into available sectors\n"); + errno = EINVAL; + return -1; + } + err: close(fd); return rc; @@ -1382,10 +1392,10 @@ static int parse_config(struct env_opts *opts) DEVNAME (0) = DEVICE1_NAME; DEVOFFSET (0) = DEVICE1_OFFSET; ENVSIZE (0) = ENV1_SIZE; - /* Default values are: erase-size=env-size */ - DEVESIZE (0) = ENVSIZE (0); - /* #sectors=env-size/erase-size (rounded up) */ - ENVSECTORS (0) = (ENVSIZE(0) + DEVESIZE(0) - 1) / DEVESIZE(0); + + /* Set defaults for DEVESIZE, ENVSECTORS later once we + * know DEVTYPE + */ #ifdef DEVICE1_ESIZE DEVESIZE (0) = DEVICE1_ESIZE; #endif @@ -1397,10 +1407,10 @@ static int parse_config(struct env_opts *opts) DEVNAME (1) = DEVICE2_NAME; DEVOFFSET (1) = DEVICE2_OFFSET; ENVSIZE (1) = ENV2_SIZE; - /* Default values are: erase-size=env-size */ - DEVESIZE (1) = ENVSIZE (1); - /* #sectors=env-size/erase-size (rounded up) */ - ENVSECTORS (1) = (ENVSIZE(1) + DEVESIZE(1) - 1) / DEVESIZE(1); + + /* Set defaults for DEVESIZE, ENVSECTORS later once we + * know DEVTYPE + */ #ifdef DEVICE2_ESIZE DEVESIZE (1) = DEVICE2_ESIZE; #endif @@ -1466,13 +1476,9 @@ static int get_config (char *fname)
DEVNAME(i) = devname;
- if (rc < 4) - /* Assume the erase size is the same as the env-size */ - DEVESIZE(i) = ENVSIZE(i); - - if (rc < 5) - /* Assume enough env sectors to cover the environment */ - ENVSECTORS (i) = (ENVSIZE(i) + DEVESIZE(i) - 1) / DEVESIZE(i); + /* Set defaults for DEVESIZE, ENVSECTORS later once we + * know DEVTYPE + */
i++; }
Hi
Any news on this? The env utility is currently broken for block devices. Alternatively we could also revert commit 183923d3e412500bdc597d1745e2fb6f7f679ec7.
Regards Max
Hi Max,
LGTM, see one nit below, can fixed later
Changes in v2:
errno = EINVAL;
return -1;
errno = EINVAL;
return -1;
Since we already checked for character devices, we could use the mtdinfo.erasesize. I guess we can relay on mtdinfo on new kernels, and if not there is still the fallback to specify it in fw_env.config.
It doesn't even matter. In case of MTD_ABSENT, erasize is never used itself, only the tuple (DEVESIZE * ENVSECTORS) matters.
- if (ENVSECTORS(dev) == 0)
errno = EINVAL;
return -1;
errno = EINVAL;
return -1;
- err: close(fd); return rc;
- /* Set defaults for DEVESIZE, ENVSECTORS later once we
* know DEVTYPE
#ifdef DEVICE1_ESIZE DEVESIZE (0) = DEVICE1_ESIZE; #endif*/
* know DEVTYPE
#ifdef DEVICE2_ESIZE DEVESIZE (1) = DEVICE2_ESIZE; #endif*/
if (rc < 4)
if (rc < 5)
* know DEVTYPE
i++; }
Hi Andreas
2016-11-28 10:47 GMT+01:00 Andreas Fenkart andreas.fenkart@digitalstrom.com:
Hi Max,
env-size */
Agreed, however since that changes functionallity I think this must go into a follow up patch. Also, since the config file skeleton mandates a erase size I don't see a pressing need.
That is not true. with the test for DEVOFFSET being aligned to DEVESIZE the previous used default broke env with certain legal config files. Other than this new test I agree.
Max
Andreas Fenkart
Max Krummenacher
