[U-Boot] [PATCH v2] ARM: at91 series: increase size for u-boot and change bootargs
As to more features are added into the u-boot, which cause the u-boot size larger than 0x40000 (256KiB), so increase the size for u-boot through move offset of the u-boot environment. Or else, when execute saveenv command, which will erase the end of the u-boot causing it can not boot up again.
Also, the linux kernel image is bigger than 2MiB, so change the bootcmd as the same time.
Signed-off-by: Bo Shen voice.shen@atmel.com --- Change since v1: change the bootargs as to the size of mainline linux kernel image size --- include/configs/at91sam9260ek.h | 17 ++++++++--------- include/configs/at91sam9261ek.h | 17 ++++++++--------- include/configs/at91sam9263ek.h | 15 ++++++++------- include/configs/at91sam9m10g45ek.h | 15 +++++++-------- 4 files changed, 31 insertions(+), 33 deletions(-)
diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index f921fac..905d5c5 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -210,16 +210,15 @@
/* bootstrap + u-boot + env + linux in nandflash */ #define CONFIG_ENV_IS_IN_NAND 1 -#define CONFIG_ENV_OFFSET 0x60000 -#define CONFIG_ENV_OFFSET_REDUND 0x80000 +#define CONFIG_ENV_OFFSET 0xc0000 +#define CONFIG_ENV_OFFSET_REDUND 0x100000 #define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ -#define CONFIG_BOOTCOMMAND "nand read 0x22000000 0xA0000 0x200000; bootm" -#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ - "root=/dev/mtdblock5 " \ - "mtdparts=atmel_nand:128k(bootstrap)ro," \ - "256k(uboot)ro,128k(env1)ro," \ - "128k(env2)ro,2M(linux),-(root) " \ - "rw rootfstype=jffs2" +#define CONFIG_BOOTCOMMAND "nand read 0x22000000 0x200000 0x300000; bootm" +#define CONFIG_BOOTARGS \ + "console=ttyS0,115200 earlyprintk " \ + "mtdparts=atmel_nand:" \ + "8M(bootstrap/uboot/kernel)ro,-(rootfs) " \ + "root=/dev/mtdblock1 rw rootfstype=jffs2"
#endif
diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 611e3e2..fc7643b 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -212,16 +212,15 @@
/* bootstrap + u-boot + env + linux in nandflash */ #define CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_OFFSET 0x60000 -#define CONFIG_ENV_OFFSET_REDUND 0x80000 +#define CONFIG_ENV_OFFSET 0xc0000 +#define CONFIG_ENV_OFFSET_REDUND 0x100000 #define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ -#define CONFIG_BOOTCOMMAND "nand read 0x22000000 0xA0000 0x200000; bootm" -#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ - "root=/dev/mtdblock5 " \ - "mtdparts=atmel_nand:128k(bootstrap)ro," \ - "256k(uboot)ro,128k(env1)ro," \ - "128k(env2)ro,2M(linux),-(root) " \ - "rw rootfstype=jffs2" +#define CONFIG_BOOTCOMMAND "nand read 0x22000000 0x200000 0x300000; bootm" +#define CONFIG_BOOTARGS \ + "console=ttyS0,115200 earlyprintk " \ + "mtdparts=atmel_nand:" \ + "8M(bootstrap/uboot/kernel)ro,-(rootfs) " \ + "root=/dev/mtdblock1 rw rootfstype=jffs2"
#endif
diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 3503822..fb94bc7 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -324,14 +324,15 @@
/* bootstrap + u-boot + env + linux in nandflash */ #define CONFIG_ENV_IS_IN_NAND 1 -#define CONFIG_ENV_OFFSET 0x60000 -#define CONFIG_ENV_OFFSET_REDUND 0x80000 +#define CONFIG_ENV_OFFSET 0xc0000 +#define CONFIG_ENV_OFFSET_REDUND 0x100000 #define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ -#define CONFIG_BOOTCOMMAND "nand read 0x22000000 0xA0000 0x200000; bootm" -#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ - "root=/dev/mtdblock5 " \ - "mtdparts=atmel_nand:128k(bootstrap)ro,256k(uboot)ro,128k(env1)ro,128k(env2)ro,2M(linux),-(root) " \ - "rw rootfstype=jffs2" +#define CONFIG_BOOTCOMMAND "nand read 0x22000000 0x200000 0x300000; bootm" +#define CONFIG_BOOTARGS \ + "console=ttyS0,115200 earlyprintk " \ + "mtdparts=atmel_nand:" \ + "8M(bootstrap/uboot/kernel)ro,-(rootfs) " \ + "root=/dev/mtdblock1 rw rootfstype=jffs2"
#endif
diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index e988d81..a09acd1 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -149,19 +149,18 @@
/* bootstrap + u-boot + env in nandflash */ #define CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_OFFSET 0x60000 -#define CONFIG_ENV_OFFSET_REDUND 0x80000 +#define CONFIG_ENV_OFFSET 0xc0000 +#define CONFIG_ENV_OFFSET_REDUND 0x100000 #define CONFIG_ENV_SIZE 0x20000
-#define CONFIG_BOOTCOMMAND "nand read 0x70000000 0x100000 0x200000;" \ +#define CONFIG_BOOTCOMMAND \ + "nand read 0x70000000 0x200000 0x300000;" \ "bootm 0x70000000" #define CONFIG_BOOTARGS \ "console=ttyS0,115200 earlyprintk " \ - "root=/dev/mtdblock5 " \ - "mtdparts=atmel_nand:128k(bootstrap)ro," \ - "256k(uboot)ro,128k(env1)ro,128k(env2)ro," \ - "2M@1M(linux),-(root) " \ - "rw rootfstype=jffs2" + "mtdparts=atmel_nand:" \ + "8M(bootstrap/uboot/kernel)ro,-(rootfs) " \ + "root=/dev/mtdblock1 rw rootfstype=jffs2"
#define CONFIG_BAUDRATE 115200
Dear Bo Shen,
- "console=ttyS0,115200 earlyprintk " \
- "mtdparts=atmel_nand:" \
- "8M(bootstrap/uboot/kernel)ro,-(rootfs) " \
- "root=/dev/mtdblock1 rw rootfstype=jffs2"
I personally prefer to change bootlaoder related stuff also from linux. With this change you can not access the env partition from linux therefore you can never use tools like fw_pritnenv/fw_setenv. Can you please change this to a reasonable configuration. I think current setups will require about 1 sector for bootstrap, 1 or 2 sectors for each env, about 4 to 6 sectors for u-boot, another bunch of sectors for linux and maybe some place to store a configuration blob (think of 'Falcon mode' or FDT).
Best regards
Andreas Bießmann
Hi Andreas,
On 11/26/2012 18:59, Andreas Bießmann wrote:
Dear Bo Shen,
Ok, I will consider this and prepare for the next version. Thanks.
Best Regards, Bo Shen
Andreas Bießmann
Bo Shen
