[U-Boot] [PATCH v2] add Armada XP SATA support
This patch initializes the SATA address windows on Armada XP and allows it to work with the existing mvsata_ide driver. It also adds the necessary configuration for the db-mv784mp-gp board.
Changes v2: - add second bus offset - only allow one device per bus - enable CONFIG_CMD_IDE per default
Signed-off-by: Anton Schubert anton.schubert@gmx.de Cc: Stefan Roese sr@denx.de Cc: Luka Perkov luka.perkov@sartura.hr --- arch/arm/mach-mvebu/include/mach/soc.h | 1 + drivers/block/mvsata_ide.c | 41 ++++++++++++++++++++++++++++++++++ include/configs/db-mv784mp-gp.h | 29 ++++++++++++++++++++++++ 3 files changed, 71 insertions(+)
diff --git a/arch/arm/mach-mvebu/include/mach/soc.h b/arch/arm/mach-mvebu/include/mach/soc.h index 1aaea67..619bc7e 100644 --- a/arch/arm/mach-mvebu/include/mach/soc.h +++ b/arch/arm/mach-mvebu/include/mach/soc.h @@ -52,6 +52,7 @@ #define MVEBU_USB20_BASE (MVEBU_REGISTER(0x58000)) #define MVEBU_EGIGA0_BASE (MVEBU_REGISTER(0x70000)) #define MVEBU_EGIGA1_BASE (MVEBU_REGISTER(0x74000)) +#define MVEBU_AXP_SATA_BASE (MVEBU_REGISTER(0xa0000)) #define MVEBU_SATA0_BASE (MVEBU_REGISTER(0xa8000)) #define MVEBU_SDIO_BASE (MVEBU_REGISTER(0xd8000))
diff --git a/drivers/block/mvsata_ide.c b/drivers/block/mvsata_ide.c index e54d564..52c1602 100644 --- a/drivers/block/mvsata_ide.c +++ b/drivers/block/mvsata_ide.c @@ -13,6 +13,8 @@ #include <asm/arch/orion5x.h> #elif defined(CONFIG_KIRKWOOD) #include <asm/arch/soc.h> +#elif defined(CONFIG_ARMADA_XP) +#include <linux/mbus.h> #endif
/* SATA port registers */ @@ -90,6 +92,41 @@ struct mvsata_port_registers { #define MVSATA_STATUS_TIMEOUT -1
/* + * Registers for SATA MBUS memory windows + */ + +#define MVSATA_WIN_CONTROL(w) (MVEBU_AXP_SATA_BASE + 0x30 + ((w) << 4)) +#define MVSATA_WIN_BASE(w) (MVEBU_AXP_SATA_BASE + 0x34 + ((w) << 4)) + +/* + * Initialize SATA memory windows for Armada XP + */ + +#ifdef CONFIG_ARMADA_XP +static void mvsata_ide_conf_mbus_windows(void) +{ + const struct mbus_dram_target_info *dram; + int i; + + dram = mvebu_mbus_dram_info(); + + /* Disable windows, Set Size/Base to 0 */ + for (i = 0; i < 4; i++) { + writel(0, MVSATA_WIN_CONTROL(i)); + writel(0, MVSATA_WIN_BASE(i)); + } + + for (i = 0; i < dram->num_cs; i++) { + const struct mbus_dram_window *cs = dram->cs + i; + writel(((cs->size - 1) & 0xffff0000) | (cs->mbus_attr << 8) | + (dram->mbus_dram_target_id << 4) | 1, + MVSATA_WIN_CONTROL(i)); + writel(cs->base & 0xffff0000, MVSATA_WIN_BASE(i)); + } +} +#endif + +/* * Initialize one MVSATAHC port: set SControl's IPM to "always active" * and DET to "reset", then wait for SStatus's DET to become "device and * comm ok" (or time out after 50 us if no device), then set SControl's @@ -137,6 +174,10 @@ int ide_preinit(void) int ret = MVSATA_STATUS_TIMEOUT; int status;
+#ifdef CONFIG_ARMADA_XP + mvsata_ide_conf_mbus_windows(); +#endif + /* Enable ATA port 0 (could be SATA port 0 or 1) if declared */ #if defined(CONFIG_SYS_ATA_IDE0_OFFSET) status = mvsata_ide_initialize_port( diff --git a/include/configs/db-mv784mp-gp.h b/include/configs/db-mv784mp-gp.h index c33a588..0fdf3a5 100644 --- a/include/configs/db-mv784mp-gp.h +++ b/include/configs/db-mv784mp-gp.h @@ -32,6 +32,7 @@ #define CONFIG_CMD_SPI #define CONFIG_CMD_TFTPPUT #define CONFIG_CMD_TIME +#define CONFIG_CMD_IDE
/* I2C */ #define CONFIG_SYS_I2C @@ -60,6 +61,34 @@ #define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup */ #define CONFIG_SYS_ALT_MEMTEST
+/* SATA support */ +#ifdef CONFIG_CMD_IDE +#define __io +#define CONFIG_IDE_PREINIT +#define CONFIG_MVSATA_IDE + +/* Needs byte-swapping for ATA data register */ +#define CONFIG_IDE_SWAP_IO + +#define CONFIG_SYS_ATA_REG_OFFSET 0x0100 /* Offset for normal register accesses*/ +#define CONFIG_SYS_ATA_DATA_OFFSET 0x0100 /* Offset for data I/O */ +#define CONFIG_SYS_ATA_ALT_OFFSET 0x0100 + +/* Each 8-bit ATA register is aligned to a 4-bytes address */ +#define CONFIG_SYS_ATA_STRIDE 4 + +/* CONFIG_CMD_IDE requires some #defines for ATA registers */ +#define CONFIG_SYS_IDE_MAXBUS 2 +#define CONFIG_SYS_IDE_MAXDEVICE CONFIG_SYS_IDE_MAXBUS + +/* ATA registers base is at SATA controller base */ +#define CONFIG_SYS_ATA_BASE_ADDR MVEBU_AXP_SATA_BASE +#define CONFIG_SYS_ATA_IDE0_OFFSET 0x2000 +#define CONFIG_SYS_ATA_IDE1_OFFSET 0x4000 + +#define CONFIG_DOS_PARTITION +#endif /* CONFIG_CMD_IDE */ + /* * mv-common.h should be defined after CMD configs since it used them * to enable certain macros
Hi Anton,
Changes v2:
Thanks, this looks much better. The device is now listed only once. Only some nitpicking comments left. Otherwise you can add my:
Tested-by: Stefan Roese sr@denx.de
to the next patch version.
The first minor comment is, to better move the patch history (Changes in v2:...) below this line "---". The revision comments will then not be added to the git repository. This is common practice.
- Registers for SATA MBUS memory windows
- Initialize SATA memory windows for Armada XP
- const struct mbus_dram_target_info *dram;
- int i;
- dram = mvebu_mbus_dram_info();
- /* Disable windows, Set Size/Base to 0 */
- for (i = 0; i < 4; i++) {
- for (i = 0; i < dram->num_cs; i++) {
+} +#endif
- Initialize one MVSATAHC port: set SControl's IPM to "always active"
- and DET to "reset", then wait for SStatus's DET to become "device and
- comm ok" (or time out after 50 us if no device), then set SControl's
- mvsata_ide_conf_mbus_windows();
- /* Enable ATA port 0 (could be SATA port 0 or 1) if declared */ #if defined(CONFIG_SYS_ATA_IDE0_OFFSET) status = mvsata_ide_initialize_port(
Please keep the list sorted.
This comment breaks the 80 chars rule. Please use the checkpatch tool for such issues. Either make the comment shorter, or move it to a separate line. And please a space before the "*/".
Thanks, Stefan
Hi Anton,
I would also like to add please add again the prefix from v1 "arm: mvebu:" in v3 as well.
Thanks, Luka
Anton Schubert
Luka Perkov
Stefan Roese
