[U-Boot] [PATCH v2 1/1] mtd: nand: fix bug writing 1 byte less than page size
nand_do_write_ops() determines if it is writing a partial page with the formula: part_pagewr = (column || writelen < (mtd->writesize - 1))
When 'writelen' is exactly 1 byte less than the NAND page size the formula equates to zero, so the code doesn't process it as a partial write, although it should. As a consequence the function remains in the while(1) loop with 'writelen' becoming 0xffffffff and iterating until the watchdog timeout triggers.
To reproduce the issue on a NAND with 2K page (0x800): => nand erase.part <partition> => nand write $loadaddr <partition> 7ff
Signed-off-by: Hector Palacios hector.palacios@digi.com --- Changes in v2 - v1 was wronly generated over U-Boot v2015.04
drivers/mtd/nand/nand_base.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index 689716753ae6..8280288a5ea1 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -2411,7 +2411,7 @@ static int nand_do_write_ops(struct mtd_info *mtd, loff_t to, int cached = writelen > bytes && page != blockmask; uint8_t *wbuf = buf; int use_bufpoi; - int part_pagewr = (column || writelen < (mtd->writesize - 1)); + int part_pagewr = (column || writelen < mtd->writesize);
if (part_pagewr) use_bufpoi = 1;
Hector Palacios
