[U-Boot] [PATCH 1/2] mx6: remove SYS_SOC from board Kconfig
Remove duplicated SYS_SOC Kconfig entry from board Kconfig, because we have this entry in arch/arm/cpu/armv7/mx6/Kconfig.
Signed-off-by: Peng Fan Peng.Fan@freescale.com Cc: Stefano Babic sbabic@denx.de Cc: Heiko Schocher hs@denx.de Cc: Christian Gmeiner christian.gmeiner@gmail.com Cc: Stefan Roese sr@denx.de Cc: Troy Kisky troy.kisky@boundarydevices.com Cc: Nikita Kiryanov nikita@compulab.co.il Cc: "Eric Bénard" eric@eukrea.com Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Tim Harvey tharvey@gateworks.com Cc: Marek Vasut marex@denx.de Cc: Markus Niebel Markus.Niebel@tq-group.com Cc: Otavio Salvador otavio@ossystems.com.br --- board/aristainetos/Kconfig | 9 --------- board/bachmann/ot1200/Kconfig | 3 --- board/barco/platinum/Kconfig | 6 ------ board/barco/titanium/Kconfig | 3 --- board/boundary/nitrogen6x/Kconfig | 3 --- board/compulab/cm_fx6/Kconfig | 3 --- board/congatec/cgtqmx6eval/Kconfig | 3 --- board/embest/mx6boards/Kconfig | 3 --- board/freescale/mx6qarm2/Kconfig | 3 --- board/freescale/mx6qsabreauto/Kconfig | 3 --- board/freescale/mx6sabresd/Kconfig | 3 --- board/freescale/mx6slevk/Kconfig | 3 --- board/freescale/mx6sxsabresd/Kconfig | 3 --- board/freescale/mx6ul_14x14_evk/Kconfig | 3 --- board/gateworks/gw_ventana/Kconfig | 3 --- board/kosagi/novena/Kconfig | 3 --- board/solidrun/mx6cuboxi/Kconfig | 3 --- board/tqc/tqma6/Kconfig | 3 --- board/udoo/Kconfig | 3 --- board/wandboard/Kconfig | 3 --- board/warp/Kconfig | 3 --- 21 files changed, 72 deletions(-)
diff --git a/board/aristainetos/Kconfig b/board/aristainetos/Kconfig index e987f38..e416c9a 100644 --- a/board/aristainetos/Kconfig +++ b/board/aristainetos/Kconfig @@ -3,9 +3,6 @@ if TARGET_ARISTAINETOS config SYS_BOARD default "aristainetos"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "aristainetos"
@@ -16,9 +13,6 @@ if TARGET_ARISTAINETOS2 config SYS_BOARD default "aristainetos"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "aristainetos2"
@@ -29,9 +23,6 @@ if TARGET_ARISTAINETOS2B config SYS_BOARD default "aristainetos"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "aristainetos2b"
diff --git a/board/bachmann/ot1200/Kconfig b/board/bachmann/ot1200/Kconfig index 7f8a6a1..4ccb60a 100644 --- a/board/bachmann/ot1200/Kconfig +++ b/board/bachmann/ot1200/Kconfig @@ -6,9 +6,6 @@ config SYS_BOARD config SYS_VENDOR default "bachmann"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "ot1200"
diff --git a/board/barco/platinum/Kconfig b/board/barco/platinum/Kconfig index 8bbad24..cc0648c 100644 --- a/board/barco/platinum/Kconfig +++ b/board/barco/platinum/Kconfig @@ -6,9 +6,6 @@ config SYS_CPU config SYS_VENDOR default "barco"
-config SYS_SOC - default "mx6" - config SYS_BOARD default "platinum"
@@ -25,9 +22,6 @@ config SYS_CPU config SYS_VENDOR default "barco"
diff --git a/board/barco/titanium/Kconfig b/board/barco/titanium/Kconfig index b6f7c85..21bc36e 100644 --- a/board/barco/titanium/Kconfig +++ b/board/barco/titanium/Kconfig @@ -6,9 +6,6 @@ config SYS_BOARD config SYS_VENDOR default "barco"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "titanium"
diff --git a/board/boundary/nitrogen6x/Kconfig b/board/boundary/nitrogen6x/Kconfig index 03b0f6f..f4db56d 100644 --- a/board/boundary/nitrogen6x/Kconfig +++ b/board/boundary/nitrogen6x/Kconfig @@ -6,9 +6,6 @@ config SYS_BOARD config SYS_VENDOR default "boundary"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "nitrogen6x"
diff --git a/board/compulab/cm_fx6/Kconfig b/board/compulab/cm_fx6/Kconfig index 508c21f..59070c5 100644 --- a/board/compulab/cm_fx6/Kconfig +++ b/board/compulab/cm_fx6/Kconfig @@ -6,9 +6,6 @@ config SYS_BOARD config SYS_VENDOR default "compulab"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "cm_fx6"
diff --git a/board/congatec/cgtqmx6eval/Kconfig b/board/congatec/cgtqmx6eval/Kconfig index 0a837bd..773551b 100644 --- a/board/congatec/cgtqmx6eval/Kconfig +++ b/board/congatec/cgtqmx6eval/Kconfig @@ -6,9 +6,6 @@ config SYS_BOARD config SYS_VENDOR default "congatec"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "cgtqmx6eval"
diff --git a/board/embest/mx6boards/Kconfig b/board/embest/mx6boards/Kconfig index 53a39d3..24d01f2 100644 --- a/board/embest/mx6boards/Kconfig +++ b/board/embest/mx6boards/Kconfig @@ -6,9 +6,6 @@ config SYS_BOARD config SYS_VENDOR default "embest"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "embestmx6boards"
diff --git a/board/freescale/mx6qarm2/Kconfig b/board/freescale/mx6qarm2/Kconfig index 4af33af..8ab8b46 100644 --- a/board/freescale/mx6qarm2/Kconfig +++ b/board/freescale/mx6qarm2/Kconfig @@ -6,9 +6,6 @@ config SYS_BOARD config SYS_VENDOR default "freescale"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "mx6qarm2"
diff --git a/board/freescale/mx6qsabreauto/Kconfig b/board/freescale/mx6qsabreauto/Kconfig index cc2a140..e579c0f 100644 --- a/board/freescale/mx6qsabreauto/Kconfig +++ b/board/freescale/mx6qsabreauto/Kconfig @@ -6,9 +6,6 @@ config SYS_BOARD config SYS_VENDOR default "freescale"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "mx6qsabreauto"
diff --git a/board/freescale/mx6sabresd/Kconfig b/board/freescale/mx6sabresd/Kconfig index fa6ddb2..e87dea0 100644 --- a/board/freescale/mx6sabresd/Kconfig +++ b/board/freescale/mx6sabresd/Kconfig @@ -6,9 +6,6 @@ config SYS_BOARD config SYS_VENDOR default "freescale"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "mx6sabresd"
diff --git a/board/freescale/mx6slevk/Kconfig b/board/freescale/mx6slevk/Kconfig index d32da90..18482b5 100644 --- a/board/freescale/mx6slevk/Kconfig +++ b/board/freescale/mx6slevk/Kconfig @@ -6,9 +6,6 @@ config SYS_BOARD config SYS_VENDOR default "freescale"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "mx6slevk"
diff --git a/board/freescale/mx6sxsabresd/Kconfig b/board/freescale/mx6sxsabresd/Kconfig index 940983e..fcfac0a 100644 --- a/board/freescale/mx6sxsabresd/Kconfig +++ b/board/freescale/mx6sxsabresd/Kconfig @@ -6,9 +6,6 @@ config SYS_BOARD config SYS_VENDOR default "freescale"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "mx6sxsabresd"
diff --git a/board/freescale/mx6ul_14x14_evk/Kconfig b/board/freescale/mx6ul_14x14_evk/Kconfig index eda02c9..8210cd3 100644 --- a/board/freescale/mx6ul_14x14_evk/Kconfig +++ b/board/freescale/mx6ul_14x14_evk/Kconfig @@ -6,9 +6,6 @@ config SYS_BOARD config SYS_VENDOR default "freescale"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "mx6ul_14x14_evk"
diff --git a/board/gateworks/gw_ventana/Kconfig b/board/gateworks/gw_ventana/Kconfig index c233e90..ccce98e 100644 --- a/board/gateworks/gw_ventana/Kconfig +++ b/board/gateworks/gw_ventana/Kconfig @@ -6,9 +6,6 @@ config SYS_BOARD config SYS_VENDOR default "gateworks"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "gw_ventana"
diff --git a/board/kosagi/novena/Kconfig b/board/kosagi/novena/Kconfig index 94f1754..c5cbaab 100644 --- a/board/kosagi/novena/Kconfig +++ b/board/kosagi/novena/Kconfig @@ -6,9 +6,6 @@ config SYS_BOARD config SYS_VENDOR default "kosagi"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "novena"
diff --git a/board/solidrun/mx6cuboxi/Kconfig b/board/solidrun/mx6cuboxi/Kconfig index 31d88b2..741c175 100644 --- a/board/solidrun/mx6cuboxi/Kconfig +++ b/board/solidrun/mx6cuboxi/Kconfig @@ -6,9 +6,6 @@ config SYS_BOARD config SYS_VENDOR default "solidrun"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "mx6cuboxi"
diff --git a/board/tqc/tqma6/Kconfig b/board/tqc/tqma6/Kconfig index dbd8787..5dafa38 100644 --- a/board/tqc/tqma6/Kconfig +++ b/board/tqc/tqma6/Kconfig @@ -6,9 +6,6 @@ config SYS_BOARD config SYS_VENDOR default "tqc"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "tqma6"
diff --git a/board/udoo/Kconfig b/board/udoo/Kconfig index 970f39f..78617a2 100644 --- a/board/udoo/Kconfig +++ b/board/udoo/Kconfig @@ -3,9 +3,6 @@ if TARGET_UDOO config SYS_BOARD default "udoo"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "udoo"
diff --git a/board/wandboard/Kconfig b/board/wandboard/Kconfig index 3928566..def6369 100644 --- a/board/wandboard/Kconfig +++ b/board/wandboard/Kconfig @@ -3,9 +3,6 @@ if TARGET_WANDBOARD config SYS_BOARD default "wandboard"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "wandboard"
diff --git a/board/warp/Kconfig b/board/warp/Kconfig index 7b569cc..dc02636 100644 --- a/board/warp/Kconfig +++ b/board/warp/Kconfig @@ -3,9 +3,6 @@ if TARGET_WARP config SYS_BOARD default "warp"
-config SYS_SOC - default "mx6" - config SYS_CONFIG_NAME default "warp"
Discard the 'select CPU_V7' from Kconfig in arch/arm/cpu/armv7/mx6 for different targets, because ARCH_MX6 selects CPU_V7.
Signed-off-by: Peng Fan Peng.Fan@freescale.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/cpu/armv7/mx6/Kconfig | 24 ------------------------ 1 file changed, 24 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index b3f7eaf..0b02e9e 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -35,19 +35,15 @@ choice
config TARGET_ARISTAINETOS bool "aristainetos" - select CPU_V7
config TARGET_ARISTAINETOS2 bool "aristainetos2" - select CPU_V7
config TARGET_ARISTAINETOS2B bool "Support aristainetos2-revB" - select CPU_V7
config TARGET_CGTQMX6EVAL bool "cgtqmx6eval" - select CPU_V7
config TARGET_CM_FX6 bool "CM-FX6" @@ -58,48 +54,39 @@ config TARGET_CM_FX6
config TARGET_EMBESTMX6BOARDS bool "embestmx6boards" - select CPU_V7
config TARGET_GW_VENTANA bool "gw_ventana" - select CPU_V7 select SUPPORT_SPL
config TARGET_KOSAGI_NOVENA bool "Kosagi Novena" - select CPU_V7 select SUPPORT_SPL
config TARGET_MX6CUBOXI bool "Solid-run mx6 boards" - select CPU_V7 select SUPPORT_SPL
config TARGET_MX6QARM2 bool "mx6qarm2" - select CPU_V7
config TARGET_MX6QSABREAUTO bool "mx6qsabreauto" - select CPU_V7 select DM select DM_THERMAL
config TARGET_MX6SABRESD bool "mx6sabresd" - select CPU_V7 select SUPPORT_SPL select DM select DM_THERMAL
config TARGET_MX6SLEVK bool "mx6slevk" - select CPU_V7 select SUPPORT_SPL
config TARGET_MX6SXSABRESD bool "mx6sxsabresd" - select CPU_V7 select SUPPORT_SPL select DM select DM_THERMAL @@ -107,7 +94,6 @@ config TARGET_MX6SXSABRESD config TARGET_MX6UL_9X9_EVK bool "mx6ul_9x9_evk" select MX6UL - select CPU_V7 select DM select DM_THERMAL select SUPPORT_SPL @@ -115,28 +101,23 @@ config TARGET_MX6UL_9X9_EVK config TARGET_MX6UL_14X14_EVK bool "mx6ul_14x14_evk" select MX6UL - select CPU_V7 select DM select DM_THERMAL select SUPPORT_SPL
config TARGET_NITROGEN6X bool "nitrogen6x" - select CPU_V7
config TARGET_OT1200 bool "Bachmann OT1200" - select CPU_V7 select SUPPORT_SPL
config TARGET_PLATINUM_PICON bool "platinum-picon" - select CPU_V7 select SUPPORT_SPL
config TARGET_PLATINUM_TITANIUM bool "platinum-titanium" - select CPU_V7 select SUPPORT_SPL
config TARGET_SECOMX6 @@ -144,28 +125,23 @@ config TARGET_SECOMX6
config TARGET_TBS2910 bool "TBS2910 Matrix ARM mini PC" - select CPU_V7
config TARGET_TITANIUM bool "titanium" - select CPU_V7
config TARGET_TQMA6 bool "TQ Systems TQMa6 board"
config TARGET_UDOO bool "udoo" - select CPU_V7 select SUPPORT_SPL
config TARGET_WANDBOARD bool "wandboard" - select CPU_V7 select SUPPORT_SPL
config TARGET_WARP bool "WaRP" - select CPU_V7
endchoice
Best regards, Stefano Babic
For the board I maintain:
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
For Novena:
Acked-by: Marek Vasut marex@denx.de
Best regards, Marek Vasut
2015-09-07 8:59 GMT+02:00 Peng Fan Peng.Fan@freescale.com:
For ot1200:
Acked-by: Christian Gmeiner christian.gmeiner@gmail.com
greets -- Christian Gmeiner, MSc
Hello,
Am 07.09.2015 um 08:59 schrieb Peng Fan:
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
-config SYS_SOC
- default "mx6"
for tqma6:
Acked-by: Markus Niebel Markus.Niebel@tq-group.com
For nitrogen6x
Acked-by: Troy Kisky troy.kisky@boundarydevices.com
Acked-by: Igor Grinberg grinberg@compulab.co.il
-config SYS_SOC
- default "mx6"
participants (8)
Christian Gmeiner
Igor Grinberg
Markus Niebel
Peng Fan
Stefan Roese
Stefano Babic
Troy Kisky
