[PATCH] test: Alphabetize dm Makefile
Recently, tests have been added primarily to the end of the dm Makefile. This results in merge conflicts when two people add new tests at the same time. To reduce these conflicts, alphabetize the makefile.
Signed-off-by: Sean Anderson sean.anderson@seco.com ---
test/dm/Makefile | 64 ++++++++++++++++++++++++------------------------ 1 file changed, 32 insertions(+), 32 deletions(-)
diff --git a/test/dm/Makefile b/test/dm/Makefile index 100e7701d2..52a8c932b8 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -21,26 +21,39 @@ ifneq ($(CONFIG_SANDBOX),) obj-$(CONFIG_ACPIGEN) += acpi.o obj-$(CONFIG_ACPIGEN) += acpigen.o obj-$(CONFIG_ACPIGEN) += acpi_dp.o +obj-$(CONFIG_ADC) += adc.o obj-$(CONFIG_SOUND) += audio.o +obj-$(CONFIG_AXI) += axi.o obj-$(CONFIG_BLK) += blk.o obj-$(CONFIG_BUTTON) += button.o obj-$(CONFIG_DM_BOOTCOUNT) += bootcount.o obj-$(CONFIG_CLK) += clk.o clk_ccf.o +obj-$(CONFIG_CPU) += cpu.o obj-$(CONFIG_CROS_EC) += cros_ec.o obj-$(CONFIG_DEVRES) += devres.o +obj-$(CONFIG_DMA) += dma.o obj-$(CONFIG_VIDEO_MIPI_DSI) += dsi_host.o obj-$(CONFIG_DM_DSA) += dsa.o obj-$(CONFIG_DM_ETH) += eth.o +ifneq ($(CONFIG_EFI_PARTITION),) +obj-$(CONFIG_FASTBOOT_FLASH_MMC) += fastboot.o +endif obj-$(CONFIG_FIRMWARE) += firmware.o obj-$(CONFIG_DM_GPIO) += gpio.o obj-$(CONFIG_DM_HWSPINLOCK) += hwspinlock.o obj-$(CONFIG_DM_I2C) += i2c.o obj-$(CONFIG_SOUND) += i2s.o obj-y += irq.o +obj-$(CONFIG_CLK_K210_SET_RATE) += k210_pll.o obj-$(CONFIG_LED) += led.o obj-$(CONFIG_DM_MAILBOX) += mailbox.o +obj-$(CONFIG_DM_MDIO) += mdio.o +obj-$(CONFIG_DM_MDIO_MUX) += mdio_mux.o +obj-$(CONFIG_MISC) += misc.o obj-$(CONFIG_DM_MMC) += mmc.o obj-$(CONFIG_CMD_MUX) += mux-cmd.o +obj-$(CONFIG_MULTIPLEXER) += mux-emul.o +obj-$(CONFIG_MUX_MMIO) += mux-mmio.o obj-y += fdtdec.o obj-$(CONFIG_UT_DM) += nop.o obj-y += ofnode.o @@ -53,53 +66,40 @@ obj-$(CONFIG_P2SB) += p2sb.o obj-$(CONFIG_PCI_ENDPOINT) += pci_ep.o obj-$(CONFIG_PCH) += pch.o obj-$(CONFIG_PHY) += phy.o +ifneq ($(CONFIG_PINMUX),) +obj-$(CONFIG_PINCONF) += pinmux.o +endif obj-$(CONFIG_POWER_DOMAIN) += power-domain.o obj-$(CONFIG_ACPI_PMC) += pmc.o +obj-$(CONFIG_DM_PMIC) += pmic.o obj-$(CONFIG_DM_PWM) += pwm.o +obj-$(CONFIG_QFW) += qfw.o obj-$(CONFIG_RAM) += ram.o obj-y += regmap.o obj-$(CONFIG_REMOTEPROC) += remoteproc.o obj-$(CONFIG_DM_RESET) += reset.o obj-$(CONFIG_SYSRESET) += sysreset.o +obj-$(CONFIG_DM_REGULATOR) += regulator.o +obj-$(CONFIG_DM_RNG) += rng.o obj-$(CONFIG_DM_RTC) += rtc.o +obj-$(CONFIG_SCMI_FIRMWARE) += scmi.o +obj-$(CONFIG_DM_SERIAL) += serial.o obj-$(CONFIG_DM_SPI_FLASH) += sf.o +obj-$(CONFIG_SIMPLE_BUS) += simple-bus.o +obj-$(CONFIG_SIMPLE_PM_BUS) += simple-pm-bus.o obj-$(CONFIG_SMEM) += smem.o -obj-$(CONFIG_DM_SPI) += spi.o -obj-y += syscon.o -obj-$(CONFIG_MUX_MMIO) += mux-mmio.o -obj-$(CONFIG_MULTIPLEXER) += mux-emul.o -obj-$(CONFIG_DM_USB) += usb.o -obj-$(CONFIG_DM_PMIC) += pmic.o -obj-$(CONFIG_DM_REGULATOR) += regulator.o -obj-$(CONFIG_TIMER) += timer.o -obj-$(CONFIG_DM_VIDEO) += video.o -obj-$(CONFIG_ADC) += adc.o -obj-$(CONFIG_SPMI) += spmi.o -obj-$(CONFIG_WDT) += wdt.o -obj-$(CONFIG_AXI) += axi.o -obj-$(CONFIG_MISC) += misc.o -obj-$(CONFIG_DM_SERIAL) += serial.o -obj-$(CONFIG_CPU) += cpu.o obj-$(CONFIG_SOC_DEVICE) += soc.o obj-$(CONFIG_SOUND) += sound.o +obj-$(CONFIG_DM_SPI) += spi.o +obj-$(CONFIG_SPMI) += spmi.o +obj-y += syscon.o +obj-$(CONFIG_RESET_SYSCON) += syscon-reset.o obj-$(CONFIG_SYSINFO) += sysinfo.o obj-$(CONFIG_TEE) += tee.o +obj-$(CONFIG_TIMER) += timer.o +obj-$(CONFIG_DM_USB) += usb.o +obj-$(CONFIG_DM_VIDEO) += video.o obj-$(CONFIG_VIRTIO_SANDBOX) += virtio.o -obj-$(CONFIG_DMA) += dma.o -obj-$(CONFIG_DM_MDIO) += mdio.o -obj-$(CONFIG_DM_MDIO_MUX) += mdio_mux.o -obj-$(CONFIG_DM_RNG) += rng.o -obj-$(CONFIG_CLK_K210_SET_RATE) += k210_pll.o -obj-$(CONFIG_SIMPLE_BUS) += simple-bus.o -obj-$(CONFIG_SIMPLE_PM_BUS) += simple-pm-bus.o -obj-$(CONFIG_RESET_SYSCON) += syscon-reset.o -obj-$(CONFIG_SCMI_FIRMWARE) += scmi.o -ifneq ($(CONFIG_PINMUX),) -obj-$(CONFIG_PINCONF) += pinmux.o -endif -ifneq ($(CONFIG_EFI_PARTITION),) -obj-$(CONFIG_FASTBOOT_FLASH_MMC) += fastboot.o -endif -obj-$(CONFIG_QFW) += qfw.o +obj-$(CONFIG_WDT) += wdt.o endif endif # !SPL
Sean Anderson
