Re: [U-Boot-Users] PROBLEM ABOUT PORTING U-BOOT-1.1.4 TO INTEL PXA255 BOARD
19 Jun
2006
19 Jun
'06
4:24 p.m.
Dear Scut Paradise,
Please reply to the list too.
"陈洪宝" scut.paradise@gmail.com writes:
在 06-6-19,Markus Klotzbüchermk@denx.de 写道:
The fact that the "DECLARE_GLOBAL_DATA_PTR" is defined inside board_init indicates that you are not using top of the tree U-Boot. Please switch to current sourcen first of all. The DECLARE_GLOBAL_DATA_PTR statement needs to be defined globally due to gcc misbehaviour.
I don't quite understand the meaning of this paragraph, what should i do?
Use the newest version of U-Boot from the git repository. The version you are using is old.
Regards
Markus Klotzbücher
6897
Markus Klotzbücher
