[U-Boot] [Question] Linux Boot with u-boot 2014.04 on Zynq board
Hi Michal,
I am a user of Zynq ZC-706 board.
On u-boot 2014.01 release, I put Kernel Image, Device Tree, Ramdisk into "fit.itb" and I could successfully boot Linux Kernel.
But I don't know how to boot Kernel on u-boot 2014.04 release. Please help!
The default boot sequence of Zynq on the u-boot-2014.04 release is Falcon boot, right?
I am trying to boot Linux with - U-boot 2014.04 - Linux Kernel 3.14 - SD boot mode - ZC706 board
What I did is roughly like this:
## U-Boot ## [1] Build u-boot [2] Convert spl/u-boot-spl.bin into boot.bin with BootGen tool [3] Copy "boot.bin" to FAT-fomatted SD card.
##Kernel ## [1] Build kernel with multi_v7_defconfig setting [2] Copy uImage to the SD card [3] Rename zynq-zc706.dtb into system.dtb and copy to SD card
Kernel boot failed to mount the root device.
My question is, how to pass an init ramdisk? In which file-name should I copy init ramdisk into SD card?
How should I load the init ramdisk from the SD card?
Best Regards Masahiro Yamada
Hi Masahiro,
On 04/30/2014 11:54 AM, Masahiro Yamada wrote:
Hi Michal,
I personally use SPL->full u-boot -> linux but IRC I have also tested SPL->linux.
- U-boot 2014.04
- Linux Kernel 3.14
- SD boot mode
- ZC706 board
## U-Boot ##
Before you build u-boot you have to copy ps7_init.c/h from your hw design to the u-boot if you want to use SPL.
yes - or if you look at xilinx git u-boot repo we have one simple python script which does this automatically without bootgen.
yes.
I personally use SD boot mode it means boot.bin has just u-boot SPL and u-boot.img on SD stores full u-boot.
Keep in your mind that using U-BOOT SPL is not fully supported flow. Supported flow is fsbl->u-boot->linux.
this step just depend on your configuration.
I am using cpio compiled in directly in the kernel.
Xilinx OSL versions are using initramdisk which you can download here. http://www.wiki.xilinx.com/Zynq+2014.1+Release
And this is the command which OSL version are using.
"sdboot=if mmcinfo; then " \ "run uenvboot; " \ "echo Copying Linux from SD to RAM... && " \ "fatload mmc 0 0x3000000 ${kernel_image} && " \ "fatload mmc 0 0x2A00000 ${devicetree_image} && " \ "fatload mmc 0 0x2000000 ${ramdisk_image} && " \ "bootm 0x3000000 0x2000000 0x2A00000; " \ "fi\0" \
You can probably add ramdisk_image to ITS format too.
Thanks, Michal
Hi Michal.
Thanks for your reply.
Oops, I forgot to mention this. I did that.
I found tools/zynq-boot-bin.py Is this the one you mentioned?
yes.
On u-boot 2014.04 release, I don't know how to use full u-boot either.
Full u-boot image of zynq enables CONFIG_OF_SEPARATE, right? I think u-boot.img does not include device tree.
Should I combine u-boot.img and device tree by myself? Like this?
cat u-boot.img u-boot.dtb > u-boot.img.tmp mv u-boot.img.tmp u-boot.img
Or should I disable CONFIG_OF_SEPARATE?
OK. Maybe I should stick to the old flow.
Yes. I am using this.
Yes. I know this works. But in my understanding, SPL cannot use this command.
My question is how SPL can load the init ramdisk.
It looks like spl_load_image_fat_os() function loads "system.dtb" and "uImage". But I could not find which code loads ramdisk. Not supported yet?
On 04/30/2014 01:31 PM, Masahiro Yamada wrote:
Hi Michal.
ok. Then I expect you are able to see at least u-boot SPL messages.
yes that's the script - if you directly use that repo it is also wired in Makefile that boot.bin is automatically created.
I have this on 2014.04 but I didn't validate this yet.
yes.
This is what I am getting - u-boot.img has full u-boot.
U-Boot SPL 2014.01-00816-ge0c1813-dirty (Jan 22 2014 - 17:56:37) mmc boot reading download.bit design filename = "system.ncd;HW_TIMEOUT=FALSE;UserID=0xFFFFFFFF" part number = "7z020clg484" date = "2013/07/22" time = "17:18:11" bytes in bitstream = 4045564 zynq_load: Align buffer at 100006c to 1000000(swap 1) reading system.dtb spl: error reading image system.dtb, err - -1 reading u-boot.img reading u-boot.img
U-Boot 2014.01 (Mar 19 2014 - 08:12:51)
Memory: ECC disabled DRAM: 1 GiB MMC: zynq_sdhci: 0 SF: Detected N25Q128A with page size 256 Bytes, erase size 64 KiB, total 16 MiB *** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial Net: Gem.e000b000 U-BOOT for zynq-zc702
Gem.e000b000 Waiting for PHY auto negotiation to complete.... done BOOTP broadcast 1 BOOTP broadcast 2
Abort Hit any key to stop autoboot: 0 U-Boot-PetaLinux>
In mainline yes but I am not using it. It is nice for playing but it is fine just to disable it and you don't need to use dts at all. Just disable it in zynq config file.
I am not sure if this will work because img is legacy u-boot format with entry point and load address. That's why this will not work. But OF also support to add DTB to hardcoded address but SPL has to be fixed for that.
That's what I am doing and that's what you can see in our xilinx git repo.
It depends what you want to do. If you want to get just linux run then just use images from wiki and change the kernel.
ok. Then what are you trying to do? Just use latest u-boot?
yes, I think it is not supported. I haven't had a time but Simon mentioned that they have enabled ITS format in SPL and it should be straight forward to do so. Then you can just use full ITS instead of DTB, kernel, ramdisk in separate images.
Thanks, Michal
Hi Michal, Sorry for late reply. (I'm back from my vacations.)
Yes. I can see them.
Thanks! Now I understand how to boot u-boot and Linux.
I am not convinced why unsupported CONFIG_OF_SEPARATE is enabled.
U-boot mainline and u-boot-xlnx diverged with this point. Which way are you going in your future development? U-Boot control with device tree? or without device tree?
Yes. I want to run U-boot and Linux on a Zynq board. I also want to use new features in the U-Boot mainline such as Kbuild.
That is my motivation to try to run u-boot-2014.04 on a zynq board.
This sounds reasonable! I am looking forward to it.
Hi Masahiro,
No problem at all.
That's a great start.
You can run Linux directly from SPL. I have tried that but without FIT it is not so nice.
Jagan has enabled it - don't know why but it is enabled by default.
yes. I have tried OF_SEPARATE and if you copy DTS from the kernel (our repo) you can use it and should work. At least worked when I have tried it.
u-boot should be configured from device-tree. We are pushing a lot of drivers to mainline and we are reviewing the whole binding to ensure that it is correct that's why I haven't pushed any DTS file to u-boot source code for reference boards.
ok. Just disable OF_CONTROL for now and I haven't pushed that SPL fpga feature because it needs to be cleanup.
my too. :-)
thanks, Michal
Hi Masahiro,
Although this is not directed to me, but perhaps I can help you out. I am working on zc702 board.
Can you copy paste the content of your bif file that you use with bootgen to generate BOOT.BIN file?
Thanks and regards,
Heshsham
On 30 April 2014 15:24, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Hi Michal,
- U-boot 2014.04
- Linux Kernel 3.14
- SD boot mode
- ZC706 board
Hi Heshsham, Thanks for your offering help!
On Wed, 30 Apr 2014 15:52:02 +0530 Heshsham Abdul Basit hf.basit@gmail.com wrote:
Hi Masahiro,
My BIF file is super simple. Like this.
image: { [bootloader,load=0x00000000]u-boot/spl/u-boot-spl.bin }
Masahiro Yamada
Michal Simek
