[RFC PATCH v1 0/9] Renesas RZ/N1 SoC initial support
The RZ/N1 is a family of SoC devices from Renesas [1], featuring ARM Cortex-A7 and/or Cortex-M3 CPU, industrial ethernet protocols, integrated Ethernet switch, and numerous peripherals.
This is a first step in upstreaming support for the RZ/N1 family. Currently it contains just enough to boot to the u-boot prompt. Additional patches will follow to support flash, SD, USB, Ethernet, etc.
At this point, I am looking for general feedback about the overall direction and structure. I'm aware of several checkpatch warnings, and some TODO/FIXME items, which will be addressed.
This work is based on a vendor-supplied u-boot 2017.01 tree [2], which supports several eval boards, none of which I have access to. Instead development has been done on a Schneider LCES2 board, which is fairly similar to the Renesas RZ/N1D-DB Demo board.
The patches are currently against v2022.10-rc2.
[1] https://www.renesas.com/us/en/products/microcontrollers-microprocessors/rz-m... [2] https://github.com/renesas-rz/rzn1_u-boot/tree/rzn1-stable
Michel Pollet (1): tools: Add tool to create Renesas SPKG images
Ralph Siemsen (8): ARM: armv7: add non-SPL enable for Cortex SMPEN clk: renesas: prepare for non-RCAR clock drivers clk: renesas: add R906G032 driver pinctrl: renesas: add R906G032 driver ram: cadence: add driver for Cadence EDAC dts: basic devicetree for Renesas RZ/N1 SoC ARM: rzn1: basic support for Renesas RZ/N1 SoC board: schneider: add LCES board support
arch/arm/Kconfig | 17 + arch/arm/Makefile | 1 + arch/arm/cpu/armv7/Kconfig | 5 + arch/arm/dts/r9a06g032-rzn1d400-lces.dts | 50 ++ arch/arm/dts/r9a06g032.dtsi | 225 ++++++ arch/arm/mach-rzn1/Kconfig | 32 + arch/arm/mach-rzn1/Makefile | 3 + arch/arm/mach-rzn1/cpu_info.c | 20 + board/schneider/lces/Kconfig | 12 + board/schneider/lces/Makefile | 3 + board/schneider/lces/ddr_timing.c | 140 ++++ .../lces/jedec_ddr3_2g_x16_1333h_500_cl8.h | 399 ++++++++++ board/schneider/lces/lces.c | 41 + configs/lces_defconfig | 26 + drivers/clk/renesas/Kconfig | 8 +- drivers/clk/renesas/Makefile | 6 +- drivers/clk/renesas/r9a06g032-clocks.c | 734 ++++++++++++++++++ drivers/pinctrl/Makefile | 1 + drivers/pinctrl/renesas/Kconfig | 7 + drivers/pinctrl/renesas/Makefile | 1 + drivers/pinctrl/renesas/pinctrl-rzn1.c | 398 ++++++++++ drivers/ram/Kconfig | 1 + drivers/ram/Makefile | 2 + drivers/ram/cadence/Kconfig | 24 + drivers/ram/cadence/Makefile | 1 + drivers/ram/cadence/ddr_async.c | 295 +++++++ drivers/ram/cadence/ddr_ctrl.c | 414 ++++++++++ drivers/ram/cadence/ddr_ctrl.h | 172 ++++ include/configs/lces.h | 22 + include/dt-bindings/clock/r9a06g032-sysctrl.h | 148 ++++ include/dt-bindings/pinctrl/rzn1-pinctrl.h | 141 ++++ tools/Makefile | 2 + tools/spkg_header.h | 49 ++ tools/spkg_utility.c | 306 ++++++++ 34 files changed, 3702 insertions(+), 4 deletions(-) create mode 100644 arch/arm/dts/r9a06g032-rzn1d400-lces.dts create mode 100644 arch/arm/dts/r9a06g032.dtsi create mode 100644 arch/arm/mach-rzn1/Kconfig create mode 100644 arch/arm/mach-rzn1/Makefile create mode 100644 arch/arm/mach-rzn1/cpu_info.c create mode 100644 board/schneider/lces/Kconfig create mode 100644 board/schneider/lces/Makefile create mode 100644 board/schneider/lces/ddr_timing.c create mode 100644 board/schneider/lces/jedec_ddr3_2g_x16_1333h_500_cl8.h create mode 100644 board/schneider/lces/lces.c create mode 100644 configs/lces_defconfig create mode 100644 drivers/clk/renesas/r9a06g032-clocks.c create mode 100644 drivers/pinctrl/renesas/pinctrl-rzn1.c create mode 100644 drivers/ram/cadence/Kconfig create mode 100644 drivers/ram/cadence/Makefile create mode 100644 drivers/ram/cadence/ddr_async.c create mode 100644 drivers/ram/cadence/ddr_ctrl.c create mode 100644 drivers/ram/cadence/ddr_ctrl.h create mode 100644 include/configs/lces.h create mode 100644 include/dt-bindings/clock/r9a06g032-sysctrl.h create mode 100644 include/dt-bindings/pinctrl/rzn1-pinctrl.h create mode 100644 tools/spkg_header.h create mode 100644 tools/spkg_utility.c
Commit 2564fce7eea3 ("sunxi: move Cortex SMPEN setting into start.S") added SPL_ARMV7_SET_CORTEX_SMPEN to enable setting SMP bit. For platforms not using SPL boot, add the corresponding non-SPL config, so that CONFIG_IS_ENABLED(ARMV7_SET_CORTEX_SMPEN) works as expected.
Signed-off-by: Ralph Siemsen ralph.siemsen@linaro.org --- This will be used by the following commit that adds ARCH_RZN1.
arch/arm/cpu/armv7/Kconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/cpu/armv7/Kconfig b/arch/arm/cpu/armv7/Kconfig index f1e4e26b8f..e33e53636a 100644 --- a/arch/arm/cpu/armv7/Kconfig +++ b/arch/arm/cpu/armv7/Kconfig @@ -107,6 +107,11 @@ config ARMV7_LPAE Say Y here to use the long descriptor page table format. This is required if U-Boot runs in HYP mode.
+config ARMV7_SET_CORTEX_SMPEN + bool + help + Enable the ARM Cortex ACTLR.SMP enable bit in U-boot. + config SPL_ARMV7_SET_CORTEX_SMPEN bool help
Allow CONFIG_CLK_RENESAS to be set without bringing in RCAR-GEN2/3 code.
CONFIG_RENESAS is used in drivers/clk/Makefile to control recursion into the drivers/clk/renesas subdirectory. It also controls compilation of renesas-cpg-mssr.c support code for the RCAR-GEN2 and RCAR-GEN3 devices.
The support code contains platform specific hardware access (TMU_BASE), and it is not needed for other Renesas devices such as RZ/N1. Therefore, alter Makefile to build renesas-cpg-mssr.c only for RCAR-GEN2 and RCAR-GEN3.
drivers/clk/renesas/Kconfig | 2 +- drivers/clk/renesas/Makefile | 5 ++--- 2 files changed, 3 insertions(+), 4 deletions(-)
diff --git a/drivers/clk/renesas/Kconfig b/drivers/clk/renesas/Kconfig index f4d6ef9f93..c53ff3ce01 100644 --- a/drivers/clk/renesas/Kconfig +++ b/drivers/clk/renesas/Kconfig @@ -1,6 +1,6 @@ config CLK_RENESAS bool "Renesas clock drivers" - depends on CLK && ARCH_RMOBILE + depends on CLK && (ARCH_RMOBILE || ARCH_RZN1) help Enable support for clock present on Renesas RCar SoCs.
diff --git a/drivers/clk/renesas/Makefile b/drivers/clk/renesas/Makefile index 36a5ca65f4..2cd2c69f68 100644 --- a/drivers/clk/renesas/Makefile +++ b/drivers/clk/renesas/Makefile @@ -1,5 +1,4 @@ -obj-$(CONFIG_CLK_RENESAS) += renesas-cpg-mssr.o -obj-$(CONFIG_CLK_RCAR_GEN2) += clk-rcar-gen2.o +obj-$(CONFIG_CLK_RCAR_GEN2) += clk-rcar-gen2.o renesas-cpg-mssr.o obj-$(CONFIG_CLK_R8A774A1) += r8a774a1-cpg-mssr.o obj-$(CONFIG_CLK_R8A774B1) += r8a774b1-cpg-mssr.o obj-$(CONFIG_CLK_R8A774C0) += r8a774c0-cpg-mssr.o @@ -9,7 +8,7 @@ obj-$(CONFIG_CLK_R8A7791) += r8a7791-cpg-mssr.o obj-$(CONFIG_CLK_R8A7792) += r8a7792-cpg-mssr.o obj-$(CONFIG_CLK_R8A7793) += r8a7791-cpg-mssr.o obj-$(CONFIG_CLK_R8A7794) += r8a7794-cpg-mssr.o -obj-$(CONFIG_CLK_RCAR_GEN3) += clk-rcar-gen3.o +obj-$(CONFIG_CLK_RCAR_GEN3) += clk-rcar-gen3.o renesas-cpg-mssr.o obj-$(CONFIG_CLK_R8A7795) += r8a7795-cpg-mssr.o obj-$(CONFIG_CLK_R8A7796) += r8a7796-cpg-mssr.o obj-$(CONFIG_CLK_R8A77965) += r8a77965-cpg-mssr.o
- depends on CLK && (ARCH_RMOBILE || ARCH_RZN1) help Enable support for clock present on Renesas RCar SoCs.
Reviewed-by: Sean Anderson seanga2@gmail.com
Clock driver for the Renesas RZ/N1 SoC family. This is based on the Linux kernel drivers/clk/renesas/r9a06g032-clocks.c.
Notable difference: this version avoids allocating a 'struct clk' for each clock source, as this is problematic before relocation. Instead, it uses the same approach as existing Renesas RCAR2/3 clock drivers, using a temporary structure filled on-the-fly.
Signed-off-by: Ralph Siemsen ralph.siemsen@linaro.org --- - TODO: add support for div_table
drivers/clk/renesas/Kconfig | 6 + drivers/clk/renesas/Makefile | 1 + drivers/clk/renesas/r9a06g032-clocks.c | 734 +++++++++++++++++++++++++ 3 files changed, 741 insertions(+) create mode 100644 drivers/clk/renesas/r9a06g032-clocks.c
diff --git a/drivers/clk/renesas/Kconfig b/drivers/clk/renesas/Kconfig index c53ff3ce01..e2f72fc04f 100644 --- a/drivers/clk/renesas/Kconfig +++ b/drivers/clk/renesas/Kconfig @@ -120,3 +120,9 @@ config CLK_R8A779A0 depends on CLK_RCAR_GEN3 help Enable this to support the clocks on Renesas R8A779A0 SoC. + +config CLK_R9A06G032 + bool "Renesas R9A06G032 clock driver" + depends on CLK_RENESAS + help + Enable this to support the clocks on Renesas R9A06G032 SoC. diff --git a/drivers/clk/renesas/Makefile b/drivers/clk/renesas/Makefile index 2cd2c69f68..9981f1a0bc 100644 --- a/drivers/clk/renesas/Makefile +++ b/drivers/clk/renesas/Makefile @@ -17,3 +17,4 @@ obj-$(CONFIG_CLK_R8A77980) += r8a77980-cpg-mssr.o obj-$(CONFIG_CLK_R8A77990) += r8a77990-cpg-mssr.o obj-$(CONFIG_CLK_R8A77995) += r8a77995-cpg-mssr.o obj-$(CONFIG_CLK_R8A779A0) += r8a779a0-cpg-mssr.o +obj-$(CONFIG_CLK_R9A06G032) += r9a06g032-clocks.o diff --git a/drivers/clk/renesas/r9a06g032-clocks.c b/drivers/clk/renesas/r9a06g032-clocks.c new file mode 100644 index 0000000000..9c8f51eb96 --- /dev/null +++ b/drivers/clk/renesas/r9a06g032-clocks.c @@ -0,0 +1,734 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * R9A06G032 clock driver + * + * Copyright (C) 2018 Renesas Electronics Europe Limited + * + * Michel Pollet michel.pollet@bp.renesas.com, buserror@gmail.com + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <regmap.h> +#include <syscon.h> +#include <linux/bitops.h> +#include <linux/clk-provider.h> +#include <linux/delay.h> +#include <asm/io.h> + +#include <dt-bindings/clock/r9a06g032-sysctrl.h> + +struct r9a06g032_gate { + u16 gate, reset, ready, midle, + scon, mirack, mistat; +}; + +/* This is used to describe a clock for instantiation */ +struct r9a06g032_clkdesc { + const char *name; + uint32_t managed: 1; + uint32_t type: 3; + uint32_t index: 8; + uint32_t source : 8; /* source index + 1 (0 == none) */ + /* these are used to populate the bitsel struct */ + union { + struct r9a06g032_gate gate; + /* for dividers */ + struct { + unsigned int div_min : 10, div_max : 10, reg: 10; + u16 div_table[4]; + }; + /* For fixed-factor ones */ + struct { + u16 div, mul; + }; + /* for dual gate */ + struct { + uint16_t group : 1; + u16 sel, g1, r1, g2, r2; + } dual; + }; +}; + +#define I_GATE(_clk, _rst, _rdy, _midle, _scon, _mirack, _mistat) \ + { .gate = _clk, .reset = _rst, \ + .ready = _rdy, .midle = _midle, \ + .scon = _scon, .mirack = _mirack, .mistat = _mistat } +#define D_GATE(_idx, _n, _src, ...) \ + { .type = K_GATE, .index = R9A06G032_##_idx, \ + .source = 1 + R9A06G032_##_src, .name = _n, \ + .gate = I_GATE(__VA_ARGS__) } +#define D_MODULE(_idx, _n, _src, ...) \ + { .type = K_GATE, .index = R9A06G032_##_idx, \ + .source = 1 + R9A06G032_##_src, .name = _n, \ + .managed = 1, .gate = I_GATE(__VA_ARGS__) } +#define D_ROOT(_idx, _n, _mul, _div) \ + { .type = K_FFC, .index = R9A06G032_##_idx, .name = _n, \ + .div = _div, .mul = _mul } +#define D_FFC(_idx, _n, _src, _div) \ + { .type = K_FFC, .index = R9A06G032_##_idx, \ + .source = 1 + R9A06G032_##_src, .name = _n, \ + .div = _div, .mul = 1} +#define D_DIV(_idx, _n, _src, _reg, _min, _max, ...) \ + { .type = K_DIV, .index = R9A06G032_##_idx, \ + .source = 1 + R9A06G032_##_src, .name = _n, \ + .reg = _reg, .div_min = _min, .div_max = _max, \ + .div_table = { __VA_ARGS__ } } +#define D_UGATE(_idx, _n, _src, _g, _g1, _r1, _g2, _r2) \ + { .type = K_DUALGATE, .index = R9A06G032_##_idx, \ + .source = 1 + R9A06G032_##_src, .name = _n, \ + .dual = { .group = _g, \ + .g1 = _g1, .r1 = _r1, .g2 = _g2, .r2 = _r2 }, } + +enum { K_GATE = 0, K_FFC, K_DIV, K_BITSEL, K_DUALGATE }; + +/* Internal clock IDs */ +#define R9A06G032_CLKOUT 0 +#define R9A06G032_CLKOUT_D10 2 +#define R9A06G032_CLKOUT_D16 3 +#define R9A06G032_CLKOUT_D160 4 +#define R9A06G032_CLKOUT_D1OR2 5 +#define R9A06G032_CLKOUT_D20 6 +#define R9A06G032_CLKOUT_D40 7 +#define R9A06G032_CLKOUT_D5 8 +#define R9A06G032_CLKOUT_D8 9 +#define R9A06G032_DIV_ADC 10 +#define R9A06G032_DIV_I2C 11 +#define R9A06G032_DIV_NAND 12 +#define R9A06G032_DIV_P1_PG 13 +#define R9A06G032_DIV_P2_PG 14 +#define R9A06G032_DIV_P3_PG 15 +#define R9A06G032_DIV_P4_PG 16 +#define R9A06G032_DIV_P5_PG 17 +#define R9A06G032_DIV_P6_PG 18 +#define R9A06G032_DIV_QSPI0 19 +#define R9A06G032_DIV_QSPI1 20 +#define R9A06G032_DIV_REF_SYNC 21 +#define R9A06G032_DIV_SDIO0 22 +#define R9A06G032_DIV_SDIO1 23 +#define R9A06G032_DIV_SWITCH 24 +#define R9A06G032_DIV_UART 25 +#define R9A06G032_DIV_MOTOR 64 +#define R9A06G032_CLK_DDRPHY_PLLCLK_D4 78 +#define R9A06G032_CLK_ECAT100_D4 79 +#define R9A06G032_CLK_HSR100_D2 80 +#define R9A06G032_CLK_REF_SYNC_D4 81 +#define R9A06G032_CLK_REF_SYNC_D8 82 +#define R9A06G032_CLK_SERCOS100_D2 83 +#define R9A06G032_DIV_CA7 84 + +#define R9A06G032_UART_GROUP_012 154 +#define R9A06G032_UART_GROUP_34567 155 + +#define R9A06G032_CLOCK_COUNT (R9A06G032_UART_GROUP_34567 + 1) + +static const struct r9a06g032_clkdesc r9a06g032_clocks[] = { + D_ROOT(CLKOUT, "clkout", 25, 1), + D_ROOT(CLK_PLL_USB, "clk_pll_usb", 12, 10), + D_FFC(CLKOUT_D10, "clkout_d10", CLKOUT, 10), + D_FFC(CLKOUT_D16, "clkout_d16", CLKOUT, 16), + D_FFC(CLKOUT_D160, "clkout_d160", CLKOUT, 160), + D_DIV(CLKOUT_D1OR2, "clkout_d1or2", CLKOUT, 0, 1, 2), + D_FFC(CLKOUT_D20, "clkout_d20", CLKOUT, 20), + D_FFC(CLKOUT_D40, "clkout_d40", CLKOUT, 40), + D_FFC(CLKOUT_D5, "clkout_d5", CLKOUT, 5), + D_FFC(CLKOUT_D8, "clkout_d8", CLKOUT, 8), + D_DIV(DIV_ADC, "div_adc", CLKOUT, 77, 50, 250), + D_DIV(DIV_I2C, "div_i2c", CLKOUT, 78, 12, 16), + D_DIV(DIV_NAND, "div_nand", CLKOUT, 82, 12, 32), + D_DIV(DIV_P1_PG, "div_p1_pg", CLKOUT, 68, 12, 200), + D_DIV(DIV_P2_PG, "div_p2_pg", CLKOUT, 62, 12, 128), + D_DIV(DIV_P3_PG, "div_p3_pg", CLKOUT, 64, 8, 128), + D_DIV(DIV_P4_PG, "div_p4_pg", CLKOUT, 66, 8, 128), + D_DIV(DIV_P5_PG, "div_p5_pg", CLKOUT, 71, 10, 40), + D_DIV(DIV_P6_PG, "div_p6_pg", CLKOUT, 18, 12, 64), + D_DIV(DIV_QSPI0, "div_qspi0", CLKOUT, 73, 3, 7), + D_DIV(DIV_QSPI1, "div_qspi1", CLKOUT, 25, 3, 7), + D_DIV(DIV_REF_SYNC, "div_ref_sync", CLKOUT, 56, 2, 16, 2, 4, 8, 16), + D_DIV(DIV_SDIO0, "div_sdio0", CLKOUT, 74, 20, 128), + D_DIV(DIV_SDIO1, "div_sdio1", CLKOUT, 75, 20, 128), + D_DIV(DIV_SWITCH, "div_switch", CLKOUT, 37, 5, 40), + D_DIV(DIV_UART, "div_uart", CLKOUT, 79, 12, 128), + D_GATE(CLK_25_PG4, "clk_25_pg4", CLKOUT_D40, 0x749, 0x74a, 0x74b, 0, 0xae3, 0, 0), + D_GATE(CLK_25_PG5, "clk_25_pg5", CLKOUT_D40, 0x74c, 0x74d, 0x74e, 0, 0xae4, 0, 0), + D_GATE(CLK_25_PG6, "clk_25_pg6", CLKOUT_D40, 0x74f, 0x750, 0x751, 0, 0xae5, 0, 0), + D_GATE(CLK_25_PG7, "clk_25_pg7", CLKOUT_D40, 0x752, 0x753, 0x754, 0, 0xae6, 0, 0), + D_GATE(CLK_25_PG8, "clk_25_pg8", CLKOUT_D40, 0x755, 0x756, 0x757, 0, 0xae7, 0, 0), + D_GATE(CLK_ADC, "clk_adc", DIV_ADC, 0x1ea, 0x1eb, 0, 0, 0, 0, 0), + D_GATE(CLK_ECAT100, "clk_ecat100", CLKOUT_D10, 0x405, 0, 0, 0, 0, 0, 0), + D_GATE(CLK_HSR100, "clk_hsr100", CLKOUT_D10, 0x483, 0, 0, 0, 0, 0, 0), + D_GATE(CLK_I2C0, "clk_i2c0", DIV_I2C, 0x1e6, 0x1e7, 0, 0, 0, 0, 0), + D_GATE(CLK_I2C1, "clk_i2c1", DIV_I2C, 0x1e8, 0x1e9, 0, 0, 0, 0, 0), + D_GATE(CLK_MII_REF, "clk_mii_ref", CLKOUT_D40, 0x342, 0, 0, 0, 0, 0, 0), + D_GATE(CLK_NAND, "clk_nand", DIV_NAND, 0x284, 0x285, 0, 0, 0, 0, 0), + D_GATE(CLK_NOUSBP2_PG6, "clk_nousbp2_pg6", DIV_P2_PG, 0x774, 0x775, 0, 0, 0, 0, 0), + D_GATE(CLK_P1_PG2, "clk_p1_pg2", DIV_P1_PG, 0x862, 0x863, 0, 0, 0, 0, 0), + D_GATE(CLK_P1_PG3, "clk_p1_pg3", DIV_P1_PG, 0x864, 0x865, 0, 0, 0, 0, 0), + D_GATE(CLK_P1_PG4, "clk_p1_pg4", DIV_P1_PG, 0x866, 0x867, 0, 0, 0, 0, 0), + D_GATE(CLK_P4_PG3, "clk_p4_pg3", DIV_P4_PG, 0x824, 0x825, 0, 0, 0, 0, 0), + D_GATE(CLK_P4_PG4, "clk_p4_pg4", DIV_P4_PG, 0x826, 0x827, 0, 0, 0, 0, 0), + D_GATE(CLK_P6_PG1, "clk_p6_pg1", DIV_P6_PG, 0x8a0, 0x8a1, 0x8a2, 0, 0xb60, 0, 0), + D_GATE(CLK_P6_PG2, "clk_p6_pg2", DIV_P6_PG, 0x8a3, 0x8a4, 0x8a5, 0, 0xb61, 0, 0), + D_GATE(CLK_P6_PG3, "clk_p6_pg3", DIV_P6_PG, 0x8a6, 0x8a7, 0x8a8, 0, 0xb62, 0, 0), + D_GATE(CLK_P6_PG4, "clk_p6_pg4", DIV_P6_PG, 0x8a9, 0x8aa, 0x8ab, 0, 0xb63, 0, 0), + D_MODULE(CLK_PCI_USB, "clk_pci_usb", CLKOUT_D40, 0xe6, 0, 0, 0, 0, 0, 0), + D_GATE(CLK_QSPI0, "clk_qspi0", DIV_QSPI0, 0x2a4, 0x2a5, 0, 0, 0, 0, 0), + D_GATE(CLK_QSPI1, "clk_qspi1", DIV_QSPI1, 0x484, 0x485, 0, 0, 0, 0, 0), + D_GATE(CLK_RGMII_REF, "clk_rgmii_ref", CLKOUT_D8, 0x340, 0, 0, 0, 0, 0, 0), + D_GATE(CLK_RMII_REF, "clk_rmii_ref", CLKOUT_D20, 0x341, 0, 0, 0, 0, 0, 0), + D_GATE(CLK_SDIO0, "clk_sdio0", DIV_SDIO0, 0x64, 0, 0, 0, 0, 0, 0), + D_GATE(CLK_SDIO1, "clk_sdio1", DIV_SDIO1, 0x644, 0, 0, 0, 0, 0, 0), + D_GATE(CLK_SERCOS100, "clk_sercos100", CLKOUT_D10, 0x425, 0, 0, 0, 0, 0, 0), + D_GATE(CLK_SLCD, "clk_slcd", DIV_P1_PG, 0x860, 0x861, 0, 0, 0, 0, 0), + D_GATE(CLK_SPI0, "clk_spi0", DIV_P3_PG, 0x7e0, 0x7e1, 0, 0, 0, 0, 0), + D_GATE(CLK_SPI1, "clk_spi1", DIV_P3_PG, 0x7e2, 0x7e3, 0, 0, 0, 0, 0), + D_GATE(CLK_SPI2, "clk_spi2", DIV_P3_PG, 0x7e4, 0x7e5, 0, 0, 0, 0, 0), + D_GATE(CLK_SPI3, "clk_spi3", DIV_P3_PG, 0x7e6, 0x7e7, 0, 0, 0, 0, 0), + D_GATE(CLK_SPI4, "clk_spi4", DIV_P4_PG, 0x820, 0x821, 0, 0, 0, 0, 0), + D_GATE(CLK_SPI5, "clk_spi5", DIV_P4_PG, 0x822, 0x823, 0, 0, 0, 0, 0), + D_GATE(CLK_SWITCH, "clk_switch", DIV_SWITCH, 0x982, 0x983, 0, 0, 0, 0, 0), + D_DIV(DIV_MOTOR, "div_motor", CLKOUT_D5, 84, 2, 8), + D_MODULE(HCLK_ECAT125, "hclk_ecat125", CLKOUT_D8, 0x400, 0x401, 0, 0x402, 0, 0x440, 0x441), + D_MODULE(HCLK_PINCONFIG, "hclk_pinconfig", CLKOUT_D40, 0x740, 0x741, 0x742, 0, 0xae0, 0, 0), + D_MODULE(HCLK_SERCOS, "hclk_sercos", CLKOUT_D10, 0x420, 0x422, 0, 0x421, 0, 0x460, 0x461), + D_MODULE(HCLK_SGPIO2, "hclk_sgpio2", DIV_P5_PG, 0x8c3, 0x8c4, 0x8c5, 0, 0xb41, 0, 0), + D_MODULE(HCLK_SGPIO3, "hclk_sgpio3", DIV_P5_PG, 0x8c6, 0x8c7, 0x8c8, 0, 0xb42, 0, 0), + D_MODULE(HCLK_SGPIO4, "hclk_sgpio4", DIV_P5_PG, 0x8c9, 0x8ca, 0x8cb, 0, 0xb43, 0, 0), + D_MODULE(HCLK_TIMER0, "hclk_timer0", CLKOUT_D40, 0x743, 0x744, 0x745, 0, 0xae1, 0, 0), + D_MODULE(HCLK_TIMER1, "hclk_timer1", CLKOUT_D40, 0x746, 0x747, 0x748, 0, 0xae2, 0, 0), + D_MODULE(HCLK_USBF, "hclk_usbf", CLKOUT_D8, 0xe3, 0, 0, 0xe4, 0, 0x102, 0x103), + D_MODULE(HCLK_USBH, "hclk_usbh", CLKOUT_D8, 0xe0, 0xe1, 0, 0xe2, 0, 0x100, 0x101), + D_MODULE(HCLK_USBPM, "hclk_usbpm", CLKOUT_D8, 0xe5, 0, 0, 0, 0, 0, 0), + D_GATE(CLK_48_PG_F, "clk_48_pg_f", CLK_48, 0x78c, 0x78d, 0, 0x78e, 0, 0xb04, 0xb05), + D_GATE(CLK_48_PG4, "clk_48_pg4", CLK_48, 0x789, 0x78a, 0x78b, 0, 0xb03, 0, 0), + D_FFC(CLK_DDRPHY_PLLCLK_D4, "clk_ddrphy_pllclk_d4", CLK_DDRPHY_PLLCLK, 4), + D_FFC(CLK_ECAT100_D4, "clk_ecat100_d4", CLK_ECAT100, 4), + D_FFC(CLK_HSR100_D2, "clk_hsr100_d2", CLK_HSR100, 2), + D_FFC(CLK_REF_SYNC_D4, "clk_ref_sync_d4", CLK_REF_SYNC, 4), + D_FFC(CLK_REF_SYNC_D8, "clk_ref_sync_d8", CLK_REF_SYNC, 8), + D_FFC(CLK_SERCOS100_D2, "clk_sercos100_d2", CLK_SERCOS100, 2), + D_DIV(DIV_CA7, "div_ca7", CLK_REF_SYNC, 57, 1, 4, 1, 2, 4), + D_MODULE(HCLK_CAN0, "hclk_can0", CLK_48, 0x783, 0x784, 0x785, 0, 0xb01, 0, 0), + D_MODULE(HCLK_CAN1, "hclk_can1", CLK_48, 0x786, 0x787, 0x788, 0, 0xb02, 0, 0), + D_MODULE(HCLK_DELTASIGMA, "hclk_deltasigma", DIV_MOTOR, 0x1ef, 0x1f0, 0x1f1, 0, 0, 0, 0), + D_MODULE(HCLK_PWMPTO, "hclk_pwmpto", DIV_MOTOR, 0x1ec, 0x1ed, 0x1ee, 0, 0, 0, 0), + D_MODULE(HCLK_RSV, "hclk_rsv", CLK_48, 0x780, 0x781, 0x782, 0, 0xb00, 0, 0), + D_MODULE(HCLK_SGPIO0, "hclk_sgpio0", DIV_MOTOR, 0x1e0, 0x1e1, 0x1e2, 0, 0, 0, 0), + D_MODULE(HCLK_SGPIO1, "hclk_sgpio1", DIV_MOTOR, 0x1e3, 0x1e4, 0x1e5, 0, 0, 0, 0), + D_DIV(RTOS_MDC, "rtos_mdc", CLK_REF_SYNC, 100, 80, 640, 80, 160, 320, 640), + D_GATE(CLK_CM3, "clk_cm3", CLK_REF_SYNC_D4, 0xba0, 0xba1, 0, 0xba2, 0, 0xbc0, 0xbc1), + D_GATE(CLK_DDRC, "clk_ddrc", CLK_DDRPHY_PLLCLK_D4, 0x323, 0x324, 0, 0, 0, 0, 0), + D_GATE(CLK_ECAT25, "clk_ecat25", CLK_ECAT100_D4, 0x403, 0x404, 0, 0, 0, 0, 0), + D_GATE(CLK_HSR50, "clk_hsr50", CLK_HSR100_D2, 0x484, 0x485, 0, 0, 0, 0, 0), + D_GATE(CLK_HW_RTOS, "clk_hw_rtos", CLK_REF_SYNC_D4, 0xc60, 0xc61, 0, 0, 0, 0, 0), + D_GATE(CLK_SERCOS50, "clk_sercos50", CLK_SERCOS100_D2, 0x424, 0x423, 0, 0, 0, 0, 0), + D_MODULE(HCLK_ADC, "hclk_adc", CLK_REF_SYNC_D8, 0x1af, 0x1b0, 0x1b1, 0, 0, 0, 0), + D_MODULE(HCLK_CM3, "hclk_cm3", CLK_REF_SYNC_D4, 0xc20, 0xc21, 0xc22, 0, 0, 0, 0), + D_MODULE(HCLK_CRYPTO_EIP150, "hclk_crypto_eip150", CLK_REF_SYNC_D4, 0x123, 0x124, 0x125, 0, 0x142, 0, 0), + D_MODULE(HCLK_CRYPTO_EIP93, "hclk_crypto_eip93", CLK_REF_SYNC_D4, 0x120, 0x121, 0, 0x122, 0, 0x140, 0x141), + D_MODULE(HCLK_DDRC, "hclk_ddrc", CLK_REF_SYNC_D4, 0x320, 0x322, 0, 0x321, 0, 0x3a0, 0x3a1), + D_MODULE(HCLK_DMA0, "hclk_dma0", CLK_REF_SYNC_D4, 0x260, 0x261, 0x262, 0x263, 0x2c0, 0x2c1, 0x2c2), + D_MODULE(HCLK_DMA1, "hclk_dma1", CLK_REF_SYNC_D4, 0x264, 0x265, 0x266, 0x267, 0x2c3, 0x2c4, 0x2c5), + D_MODULE(HCLK_GMAC0, "hclk_gmac0", CLK_REF_SYNC_D4, 0x360, 0x361, 0x362, 0x363, 0x3c0, 0x3c1, 0x3c2), + D_MODULE(HCLK_GMAC1, "hclk_gmac1", CLK_REF_SYNC_D4, 0x380, 0x381, 0x382, 0x383, 0x3e0, 0x3e1, 0x3e2), + D_MODULE(HCLK_GPIO0, "hclk_gpio0", CLK_REF_SYNC_D4, 0x212, 0x213, 0x214, 0, 0, 0, 0), + D_MODULE(HCLK_GPIO1, "hclk_gpio1", CLK_REF_SYNC_D4, 0x215, 0x216, 0x217, 0, 0, 0, 0), + D_MODULE(HCLK_GPIO2, "hclk_gpio2", CLK_REF_SYNC_D4, 0x229, 0x22a, 0x22b, 0, 0, 0, 0), + D_MODULE(HCLK_HSR, "hclk_hsr", CLK_HSR100_D2, 0x480, 0x482, 0, 0x481, 0, 0x4c0, 0x4c1), + D_MODULE(HCLK_I2C0, "hclk_i2c0", CLK_REF_SYNC_D8, 0x1a9, 0x1aa, 0x1ab, 0, 0, 0, 0), + D_MODULE(HCLK_I2C1, "hclk_i2c1", CLK_REF_SYNC_D8, 0x1ac, 0x1ad, 0x1ae, 0, 0, 0, 0), + D_MODULE(HCLK_LCD, "hclk_lcd", CLK_REF_SYNC_D4, 0x7a0, 0x7a1, 0x7a2, 0, 0xb20, 0, 0), + D_MODULE(HCLK_MSEBI_M, "hclk_msebi_m", CLK_REF_SYNC_D4, 0x164, 0x165, 0x166, 0, 0x183, 0, 0), + D_MODULE(HCLK_MSEBI_S, "hclk_msebi_s", CLK_REF_SYNC_D4, 0x160, 0x161, 0x162, 0x163, 0x180, 0x181, 0x182), + D_MODULE(HCLK_NAND, "hclk_nand", CLK_REF_SYNC_D4, 0x280, 0x281, 0x282, 0x283, 0x2e0, 0x2e1, 0x2e2), + D_MODULE(HCLK_PG_I, "hclk_pg_i", CLK_REF_SYNC_D4, 0x7ac, 0x7ad, 0, 0x7ae, 0, 0xb24, 0xb25), + D_MODULE(HCLK_PG19, "hclk_pg19", CLK_REF_SYNC_D4, 0x22c, 0x22d, 0x22e, 0, 0, 0, 0), + D_MODULE(HCLK_PG20, "hclk_pg20", CLK_REF_SYNC_D4, 0x22f, 0x230, 0x231, 0, 0, 0, 0), + D_MODULE(HCLK_PG3, "hclk_pg3", CLK_REF_SYNC_D4, 0x7a6, 0x7a7, 0x7a8, 0, 0xb22, 0, 0), + D_MODULE(HCLK_PG4, "hclk_pg4", CLK_REF_SYNC_D4, 0x7a9, 0x7aa, 0x7ab, 0, 0xb23, 0, 0), + D_MODULE(HCLK_QSPI0, "hclk_qspi0", CLK_REF_SYNC_D4, 0x2a0, 0x2a1, 0x2a2, 0x2a3, 0x300, 0x301, 0x302), + D_MODULE(HCLK_QSPI1, "hclk_qspi1", CLK_REF_SYNC_D4, 0x480, 0x481, 0x482, 0x483, 0x4c0, 0x4c1, 0x4c2), + D_MODULE(HCLK_ROM, "hclk_rom", CLK_REF_SYNC_D4, 0xaa0, 0xaa1, 0xaa2, 0, 0xb80, 0, 0), + D_MODULE(HCLK_RTC, "hclk_rtc", CLK_REF_SYNC_D8, 0xa00, 0, 0, 0, 0, 0, 0), + D_MODULE(HCLK_SDIO0, "hclk_sdio0", CLK_REF_SYNC_D4, 0x60, 0x61, 0x62, 0x63, 0x80, 0x81, 0x82), + D_MODULE(HCLK_SDIO1, "hclk_sdio1", CLK_REF_SYNC_D4, 0x640, 0x641, 0x642, 0x643, 0x660, 0x661, 0x662), + D_MODULE(HCLK_SEMAP, "hclk_semap", CLK_REF_SYNC_D4, 0x7a3, 0x7a4, 0x7a5, 0, 0xb21, 0, 0), + D_MODULE(HCLK_SPI0, "hclk_spi0", CLK_REF_SYNC_D4, 0x200, 0x201, 0x202, 0, 0, 0, 0), + D_MODULE(HCLK_SPI1, "hclk_spi1", CLK_REF_SYNC_D4, 0x203, 0x204, 0x205, 0, 0, 0, 0), + D_MODULE(HCLK_SPI2, "hclk_spi2", CLK_REF_SYNC_D4, 0x206, 0x207, 0x208, 0, 0, 0, 0), + D_MODULE(HCLK_SPI3, "hclk_spi3", CLK_REF_SYNC_D4, 0x209, 0x20a, 0x20b, 0, 0, 0, 0), + D_MODULE(HCLK_SPI4, "hclk_spi4", CLK_REF_SYNC_D4, 0x20c, 0x20d, 0x20e, 0, 0, 0, 0), + D_MODULE(HCLK_SPI5, "hclk_spi5", CLK_REF_SYNC_D4, 0x20f, 0x210, 0x211, 0, 0, 0, 0), + D_MODULE(HCLK_SWITCH, "hclk_switch", CLK_REF_SYNC_D4, 0x980, 0, 0x981, 0, 0, 0, 0), + D_MODULE(HCLK_SWITCH_RG, "hclk_switch_rg", CLK_REF_SYNC_D4, 0xc40, 0xc41, 0xc42, 0, 0, 0, 0), + D_MODULE(HCLK_UART0, "hclk_uart0", CLK_REF_SYNC_D8, 0x1a0, 0x1a1, 0x1a2, 0, 0, 0, 0), + D_MODULE(HCLK_UART1, "hclk_uart1", CLK_REF_SYNC_D8, 0x1a3, 0x1a4, 0x1a5, 0, 0, 0, 0), + D_MODULE(HCLK_UART2, "hclk_uart2", CLK_REF_SYNC_D8, 0x1a6, 0x1a7, 0x1a8, 0, 0, 0, 0), + D_MODULE(HCLK_UART3, "hclk_uart3", CLK_REF_SYNC_D4, 0x218, 0x219, 0x21a, 0, 0, 0, 0), + D_MODULE(HCLK_UART4, "hclk_uart4", CLK_REF_SYNC_D4, 0x21b, 0x21c, 0x21d, 0, 0, 0, 0), + D_MODULE(HCLK_UART5, "hclk_uart5", CLK_REF_SYNC_D4, 0x220, 0x221, 0x222, 0, 0, 0, 0), + D_MODULE(HCLK_UART6, "hclk_uart6", CLK_REF_SYNC_D4, 0x223, 0x224, 0x225, 0, 0, 0, 0), + D_MODULE(HCLK_UART7, "hclk_uart7", CLK_REF_SYNC_D4, 0x226, 0x227, 0x228, 0, 0, 0, 0), + /* + * These are not hardware clocks, but are needed to handle the special + * case where we have a 'selector bit' that doesn't just change the + * parent for a clock, but also the gate it's supposed to use. + */ + { + .index = R9A06G032_UART_GROUP_012, + .name = "uart_group_012", + .type = K_BITSEL, + .source = 1 + R9A06G032_DIV_UART, + /* R9A06G032_SYSCTRL_REG_PWRCTRL_PG0_0 */ + .dual.sel = ((0x34 / 4) << 5) | 30, + .dual.group = 0, + }, + { + .index = R9A06G032_UART_GROUP_34567, + .name = "uart_group_34567", + .type = K_BITSEL, + .source = 1 + R9A06G032_DIV_P2_PG, + /* R9A06G032_SYSCTRL_REG_PWRCTRL_PG1_PR2 */ + .dual.sel = ((0xec / 4) << 5) | 24, + .dual.group = 1, + }, + D_UGATE(CLK_UART0, "clk_uart0", UART_GROUP_012, 0, 0x1b2, 0x1b3, 0x1b4, 0x1b5), + D_UGATE(CLK_UART1, "clk_uart1", UART_GROUP_012, 0, 0x1b6, 0x1b7, 0x1b8, 0x1b9), + D_UGATE(CLK_UART2, "clk_uart2", UART_GROUP_012, 0, 0x1ba, 0x1bb, 0x1bc, 0x1bd), + D_UGATE(CLK_UART3, "clk_uart3", UART_GROUP_34567, 1, 0x760, 0x761, 0x762, 0x763), + D_UGATE(CLK_UART4, "clk_uart4", UART_GROUP_34567, 1, 0x764, 0x765, 0x766, 0x767), + D_UGATE(CLK_UART5, "clk_uart5", UART_GROUP_34567, 1, 0x768, 0x769, 0x76a, 0x76b), + D_UGATE(CLK_UART6, "clk_uart6", UART_GROUP_34567, 1, 0x76c, 0x76d, 0x76e, 0x76f), + D_UGATE(CLK_UART7, "clk_uart7", UART_GROUP_34567, 1, 0x770, 0x771, 0x772, 0x773), +}; + +struct r9a06g032_priv { + struct regmap *regmap; + struct clk mclk; +}; + +static const struct r9a06g032_clkdesc *r9a06g032_clk_get(struct clk *clk) +{ + const unsigned long clkid = clk->id & 0xffff; + int i; + + for (i = 0; i < ARRAY_SIZE(r9a06g032_clocks); i++) { + if (r9a06g032_clocks[i].index == clkid) + return &r9a06g032_clocks[i]; + } + + return NULL; +} + +static int r9a06g032_clk_get_parent(struct clk *clk, struct clk *parent) +{ + const struct r9a06g032_clkdesc *desc = r9a06g032_clk_get(clk); + + if (!desc) + return -ENODEV; + + if (desc->source == 0) + parent->id = ~0; /* Top-level clock */ + else + parent->id = desc->source - 1; + + parent->dev = clk->dev; + + return 0; +} + +static ulong r9a06g032_clk_get_parent_rate(struct clk *clk) +{ + struct clk parent; + + if (r9a06g032_clk_get_parent(clk, &parent)) { + debug("Failed to get parent clock for id=%lu\b", clk->id); + return 0; + } + + if (parent.id == ~0) { + struct r9a06g032_priv *clocks = dev_get_priv(clk->dev); + ulong rate = clk_get_rate(&clocks->mclk); + return rate; + } + + return clk_get_rate(&parent); +} + +/* register/bit pairs are encoded as an uint16_t */ +static void +clk_rdesc_set(struct r9a06g032_priv *clocks, + u16 one, unsigned int on) +{ + uint offset = 4 * (one >> 5); + uint mask = 1U << (one & 0x1f); + uint val = ((!!on) << (one & 0x1f)); + + regmap_update_bits(clocks->regmap, offset, mask, val); +} + +static int +clk_rdesc_get(struct r9a06g032_priv *clocks, + uint16_t one) +{ + uint offset = 4 * (one >> 5); + u32 val = 0; + + regmap_read(clocks->regmap, offset, &val); + + return !!(val & (1U << (one & 0x1f))); +} + +/* + * Cheating a little bit here: leverage the existing code to control the + * per-clock reset. It should really be handled by a reset controller instead. + */ +void clk_rzn1_reset_state(struct clk *clk, int on) +{ + struct r9a06g032_priv *clocks = dev_get_priv(clk->dev); + const struct r9a06g032_clkdesc *desc = r9a06g032_clk_get(clk); + assert(desc); + assert(desc->type == K_GATE); + const struct r9a06g032_gate *g = &desc->gate; + assert(g->reset); + + clk_rdesc_set(clocks, g->reset, on); +} + +/* + * This implements the R9A06G032 clock gate 'driver'. We cannot use the system's + * clock gate framework as the gates on the R9A06G032 have a special enabling + * sequence, therefore we use this little proxy. + */ +static int r9a06g032_clk_gate_set(struct clk *clk, int on) +{ + struct r9a06g032_priv *clocks = dev_get_priv(clk->dev); + const struct r9a06g032_clkdesc *desc = r9a06g032_clk_get(clk); + assert(desc); + assert(desc->type == K_GATE); + const struct r9a06g032_gate *g = &desc->gate; + + clk_rdesc_set(clocks, g->gate, on); + /* De-assert reset */ + if (g->reset) + clk_rdesc_set(clocks, g->reset, 1); + + /* Hardware manual recommends 5us delay after enabling clock & reset */ + udelay(5); + + /* If the peripheral is memory mapped (i.e. an AXI slave), there is an + * associated SLVRDY bit in the System Controller that needs to be set + * so that the FlexWAY bus fabric passes on the read/write requests. + */ + if (g->ready || g->midle) { + if (g->ready) + clk_rdesc_set(clocks, g->ready, on); + /* Clear 'Master Idle Request' bit */ + if (g->midle) + clk_rdesc_set(clocks, g->midle, !on); + } + /* Note: We don't wait for FlexWAY Socket Connection signal */ + + return 0; +} + +static int r9a06g032_clk_gate_enable(struct clk *clk) +{ + return r9a06g032_clk_gate_set(clk, 1); +} + +static int r9a06g032_clk_gate_disable(struct clk *clk) +{ + return r9a06g032_clk_gate_set(clk, 0); +} + +/* + * Fixed factor clock + */ +static ulong r9a06g032_ffc_get_rate(struct clk *clk) +{ + const struct r9a06g032_clkdesc *desc = r9a06g032_clk_get(clk); + unsigned long parent_rate = r9a06g032_clk_get_parent_rate(clk); + unsigned long long rate; + + if (parent_rate == 0) { + debug("%s: parent_rate is zero\n", __func__); + return 0; + } + + rate = (unsigned long long)parent_rate * desc->mul; + rate = DIV_ROUND_UP(rate, desc->div); + return (ulong)rate; +} + +/* + * This implements R9A06G032 clock divider 'driver'. This differs from the + * standard clk_divider because the set_rate method must also set b[31] to + * trigger the hardware rate change. In theory it should also wait for this + * bit to clear. + */ +static ulong r9a06g032_div_get_rate(struct clk *clk) +{ + struct r9a06g032_priv *clocks = dev_get_priv(clk->dev); + const struct r9a06g032_clkdesc *desc = r9a06g032_clk_get(clk); + unsigned long parent_rate = r9a06g032_clk_get_parent_rate(clk); + u32 div = 0; + + if (parent_rate == 0) { + debug("%s: parent_rate is zero\n", __func__); + return 0; + } + + regmap_read(clocks->regmap, 4 * desc->reg, &div); + + if (div < desc->div_min) + div = desc->div_min; + else if (div > desc->div_max) + div = desc->div_max; + return DIV_ROUND_UP(parent_rate, div); +} + +static ulong r9a06g032_div_set_rate(struct clk *clk, ulong rate) +{ + struct r9a06g032_priv *clocks = dev_get_priv(clk->dev); + const struct r9a06g032_clkdesc *desc = r9a06g032_clk_get(clk); + unsigned long parent_rate = r9a06g032_clk_get_parent_rate(clk); + + if (parent_rate == 0) { + debug("%s: parent_rate is zero\n", __func__); + return 0; + } + + /* + 1 to cope with rates that have the remainder dropped */ + u32 div = DIV_ROUND_UP(parent_rate, rate + 1); + + /* Clamp to allowable range */ + if (div < desc->div_min) + div = desc->div_min; + else if (div > desc->div_max) + div = desc->div_max; + + /* TODO: use the .div_table if provided */ + if (desc->div_table[0]) + pr_err("ERROR: %s: div_table not implemented\n", __func__); + + pr_devel("%s clkid %lu rate %ld parent %ld div %d\n", __func__, clk->id, + rate, parent_rate, div); + + /* + * Need to write the bit 31 with the divider value to + * latch it. Technically we should wait until it has been + * cleared too. + * TODO: Find whether this callback is sleepable, in case + * the hardware /does/ require some sort of spinloop here. + */ + regmap_write(clocks->regmap, 4 * desc->reg, div | BIT(31)); + + return 0; +} + +/* + * Dual gate. This handles toggling the approprate clock/reset bits, + * which depends on the mux setting above. + */ +static int r9a06g032_clk_dualgate_setenable(struct r9a06g032_priv *clocks, + const struct r9a06g032_clkdesc *desc, + int enable) +{ + u8 sel_bit = clk_rdesc_get(clocks, desc->dual.sel); + u16 gate[2] = { desc->dual.g1, desc->dual.g2 }; + u16 reset[2] = { desc->dual.r1, desc->dual.r2 }; + + /* we always turn off the 'other' gate, regardless */ + clk_rdesc_set(clocks, gate[!sel_bit], 0); + if (reset[!sel_bit]) + clk_rdesc_set(clocks, reset[!sel_bit], 1); + + /* set the gate as requested */ + clk_rdesc_set(clocks, gate[sel_bit], enable); + if (reset[sel_bit]) + clk_rdesc_set(clocks, reset[sel_bit], 1); + + return 0; +} + +static int r9a06g032_clk_dualgate_enable(struct clk *clk) +{ + struct r9a06g032_priv *clocks = dev_get_priv(clk->dev); + const struct r9a06g032_clkdesc *desc = r9a06g032_clk_get(clk); + + return r9a06g032_clk_dualgate_setenable(clocks, desc, 1); +} + +static int r9a06g032_clk_dualgate_disable(struct clk *clk) +{ + struct r9a06g032_priv *clocks = dev_get_priv(clk->dev); + const struct r9a06g032_clkdesc *desc = r9a06g032_clk_get(clk); + + return r9a06g032_clk_dualgate_setenable(clocks, desc, 0); +} + +static int r9a06g032_clk_dualgate_is_enabled(struct clk *clk) +{ + struct r9a06g032_priv *clocks = dev_get_priv(clk->dev); + const struct r9a06g032_clkdesc *desc = r9a06g032_clk_get(clk); + u8 sel_bit = clk_rdesc_get(clocks, desc->dual.sel); + u16 gate[2] = { desc->dual.g1, desc->dual.g2 }; + + return clk_rdesc_get(clocks, gate[sel_bit]); +} + +/* + * Main clock driver + */ +static int r9a06g032_clk_enable(struct clk *clk) +{ + const struct r9a06g032_clkdesc *desc = r9a06g032_clk_get(clk); + + switch (desc->type) { + case K_GATE: + return r9a06g032_clk_gate_enable(clk); + case K_DUALGATE: + return r9a06g032_clk_dualgate_enable(clk); + default: + printf("ERROR: %s:%d unhandled type=%d\n", __func__, __LINE__, desc->type); + break; + } + + return 0; +} + +static int r9a06g032_clk_disable(struct clk *clk) +{ + const struct r9a06g032_clkdesc *desc = r9a06g032_clk_get(clk); + + switch (desc->type) { + case K_GATE: + return r9a06g032_clk_gate_disable(clk); + case K_DUALGATE: + return r9a06g032_clk_dualgate_disable(clk); + default: + printf("ERROR: %s:%d unhandled type=%d\n", __func__, __LINE__, desc->type); + break; + } + + return 0; +} + +static ulong r9a06g032_clk_get_rate(struct clk *clk) +{ + const struct r9a06g032_clkdesc *desc = r9a06g032_clk_get(clk); + ulong ret = 0; + + assert(desc); + + switch (desc->type) { + case K_FFC: + ret = r9a06g032_ffc_get_rate(clk); + break; + case K_GATE: + ret = r9a06g032_clk_get_parent_rate(clk); + break; + case K_DIV: + ret = r9a06g032_div_get_rate(clk); + break; + case K_BITSEL: + /* + * Look at the mux to determine parent. + * 0 means it is coming from UART DIV (group 012 or 34567) + * 1 means it is coming from USB_PLL + */ + if (r9a06g032_clk_dualgate_is_enabled(clk)) { + struct clk clk = { .id = R9A06G032_CLK_PLL_USB }; + ret = r9a06g032_clk_get_parent_rate(&clk); + } + ret = r9a06g032_clk_get_parent_rate(clk); + break; + case K_DUALGATE: + ret = r9a06g032_clk_get_parent_rate(clk); + break; + } + + return ret; +} + +static ulong r9a06g032_clk_set_rate(struct clk *clk, ulong rate) +{ + const struct r9a06g032_clkdesc *desc = r9a06g032_clk_get(clk); + ulong ret = 0; + + assert(desc); + + switch (desc->type) { + case K_DIV: + ret = r9a06g032_div_set_rate(clk, rate); + break; + default: + printf("ERROR: %s:%d not implemented yet\n", __func__, __LINE__); + }; + + return ret; +} + +static int r9a06g032_clk_of_xlate(struct clk *clk, struct ofnode_phandle_args *args) +{ + if (args->args_count != 1) { + debug("Invalid args_count: %d\n", args->args_count); + return -EINVAL; + } + + clk->id = args->args[0]; + + return 0; +} + +static const struct clk_ops r9a06g032_clk_ops = { + .enable = r9a06g032_clk_enable, + .disable = r9a06g032_clk_disable, + .get_rate = r9a06g032_clk_get_rate, + .set_rate = r9a06g032_clk_set_rate, + .of_xlate = r9a06g032_clk_of_xlate, +}; + +static int r9a06g032_clk_probe(struct udevice *dev) +{ + struct r9a06g032_priv *priv = dev_get_priv(dev); + int err; + + priv->regmap = syscon_regmap_lookup_by_phandle(dev, "regmap"); + if (!priv->regmap) { + pr_err("unable to find regmap\n"); + return -ENODEV; + } + + /* Enable S/W reset */ + regmap_write(priv->regmap, 0x120, 0x41); + + err = clk_get_by_name(dev, "mclk", &priv->mclk); + if (err) + return err; + + return 0; +} + +static int r9a06g032_clk_remove(struct udevice *dev) +{ + return 0; +} + +static const struct udevice_id r9a06g032_clk_ids[] = { + { .compatible = "renesas,r9a06g032-sysctrl" }, + { } +}; + +U_BOOT_DRIVER(clk_r9a06g032) = { + .name = "clk_r9a06g032", + .id = UCLASS_CLK, + .of_match = r9a06g032_clk_ids, + .priv_auto = sizeof(struct r9a06g032_priv), + .ops = &r9a06g032_clk_ops, + .probe = &r9a06g032_clk_probe, + .remove = &r9a06g032_clk_remove, + .flags = DM_FLAG_PRE_RELOC, +};
- bool "Renesas R9A06G032 clock driver"
- depends on CLK_RENESAS
- help
nit: on the
- R9A06G032 clock driver
- Copyright (C) 2018 Renesas Electronics Europe Limited
- Michel Pollet michel.pollet@bp.renesas.com, buserror@gmail.com
Can you add some documentation for each of the fields? Same for r9a06g032_clkdesc.
https://www.kernel.org/doc/html/latest/doc-guide/kernel-doc.html
- u16 gate, reset, ready, midle,
What are the scon/mirack/mistat fields for? You define them for a lot of clocks, but I don't see them used in the driver.
- const char *name;
- uint32_t managed: 1;
- uint32_t type: 3;
I wonder if we could define the enum here?
- uint32_t index: 8;
- uint32_t source : 8; /* source index + 1 (0 == none) */
- /* these are used to populate the bitsel struct */
- union {
/* for dividers */
struct {
u16 div_table[4];
struct {
u16 div, mul;
/* for dual gate */
struct {
uint16_t group : 1;
} dual;
- { .gate = _clk, .reset = _rst, \
If these fields have bitfield inside them, then those bitfields should be assigned/constructed separately. That is, if .reset is actually a combined offset/bit, then you need to expose those in the macro. Since you have a lot of these, you might want to do something like
#define BIT_OFFSET GENMASK(15, 5) #define BIT_SHIFT GENMASK(4, 0)
#define PACK_BIT(offset, shift) (FIELD_PREP(BIT_OFFSET, offset) | FIELD_PREP(BIT_SHIFT, shift))
Please put each assignment on a separate line
- { .type = K_GATE, .index = R9A06G032_##_idx, \
- { .type = K_FFC, .index = R9A06G032_##_idx, .name = _n, \
- { .type = K_FFC, .index = R9A06G032_##_idx, \
- { .type = K_DIV, .index = R9A06G032_##_idx, \
- { .type = K_DUALGATE, .index = R9A06G032_##_idx, \
Please put each member on a separate line.
Can you put these in your dt-bindings header? I think that would make it much clearer why there are gaps, and would avoid someone accidentally duplicating a clock id (although I suppose your array initializer below might complain?)
- D_ROOT(CLKOUT, "clkout", 25, 1),
- D_ROOT(CLK_PLL_USB, "clk_pll_usb", 12, 10),
- D_FFC(CLKOUT_D10, "clkout_d10", CLKOUT, 10),
- D_FFC(CLKOUT_D16, "clkout_d16", CLKOUT, 16),
- D_FFC(CLKOUT_D160, "clkout_d160", CLKOUT, 160),
- D_DIV(CLKOUT_D1OR2, "clkout_d1or2", CLKOUT, 0, 1, 2),
- D_FFC(CLKOUT_D20, "clkout_d20", CLKOUT, 20),
- D_FFC(CLKOUT_D40, "clkout_d40", CLKOUT, 40),
- D_FFC(CLKOUT_D5, "clkout_d5", CLKOUT, 5),
- D_FFC(CLKOUT_D8, "clkout_d8", CLKOUT, 8),
- D_DIV(DIV_ADC, "div_adc", CLKOUT, 77, 50, 250),
- D_DIV(DIV_I2C, "div_i2c", CLKOUT, 78, 12, 16),
- D_DIV(DIV_NAND, "div_nand", CLKOUT, 82, 12, 32),
- D_DIV(DIV_P1_PG, "div_p1_pg", CLKOUT, 68, 12, 200),
- D_DIV(DIV_P2_PG, "div_p2_pg", CLKOUT, 62, 12, 128),
- D_DIV(DIV_P3_PG, "div_p3_pg", CLKOUT, 64, 8, 128),
- D_DIV(DIV_P4_PG, "div_p4_pg", CLKOUT, 66, 8, 128),
- D_DIV(DIV_P5_PG, "div_p5_pg", CLKOUT, 71, 10, 40),
- D_DIV(DIV_P6_PG, "div_p6_pg", CLKOUT, 18, 12, 64),
- D_DIV(DIV_QSPI0, "div_qspi0", CLKOUT, 73, 3, 7),
- D_DIV(DIV_QSPI1, "div_qspi1", CLKOUT, 25, 3, 7),
- D_DIV(DIV_REF_SYNC, "div_ref_sync", CLKOUT, 56, 2, 16, 2, 4, 8, 16),
- D_DIV(DIV_SDIO0, "div_sdio0", CLKOUT, 74, 20, 128),
- D_DIV(DIV_SDIO1, "div_sdio1", CLKOUT, 75, 20, 128),
- D_DIV(DIV_SWITCH, "div_switch", CLKOUT, 37, 5, 40),
- D_DIV(DIV_UART, "div_uart", CLKOUT, 79, 12, 128),
- D_GATE(CLK_25_PG4, "clk_25_pg4", CLKOUT_D40, 0x749, 0x74a, 0x74b, 0, 0xae3, 0, 0),
- D_GATE(CLK_25_PG5, "clk_25_pg5", CLKOUT_D40, 0x74c, 0x74d, 0x74e, 0, 0xae4, 0, 0),
- D_GATE(CLK_25_PG6, "clk_25_pg6", CLKOUT_D40, 0x74f, 0x750, 0x751, 0, 0xae5, 0, 0),
- D_GATE(CLK_25_PG7, "clk_25_pg7", CLKOUT_D40, 0x752, 0x753, 0x754, 0, 0xae6, 0, 0),
- D_GATE(CLK_25_PG8, "clk_25_pg8", CLKOUT_D40, 0x755, 0x756, 0x757, 0, 0xae7, 0, 0),
- D_GATE(CLK_ADC, "clk_adc", DIV_ADC, 0x1ea, 0x1eb, 0, 0, 0, 0, 0),
- D_GATE(CLK_ECAT100, "clk_ecat100", CLKOUT_D10, 0x405, 0, 0, 0, 0, 0, 0),
- D_GATE(CLK_HSR100, "clk_hsr100", CLKOUT_D10, 0x483, 0, 0, 0, 0, 0, 0),
- D_GATE(CLK_I2C0, "clk_i2c0", DIV_I2C, 0x1e6, 0x1e7, 0, 0, 0, 0, 0),
- D_GATE(CLK_I2C1, "clk_i2c1", DIV_I2C, 0x1e8, 0x1e9, 0, 0, 0, 0, 0),
- D_GATE(CLK_MII_REF, "clk_mii_ref", CLKOUT_D40, 0x342, 0, 0, 0, 0, 0, 0),
- D_GATE(CLK_NAND, "clk_nand", DIV_NAND, 0x284, 0x285, 0, 0, 0, 0, 0),
- D_GATE(CLK_NOUSBP2_PG6, "clk_nousbp2_pg6", DIV_P2_PG, 0x774, 0x775, 0, 0, 0, 0, 0),
- D_GATE(CLK_P1_PG2, "clk_p1_pg2", DIV_P1_PG, 0x862, 0x863, 0, 0, 0, 0, 0),
- D_GATE(CLK_P1_PG3, "clk_p1_pg3", DIV_P1_PG, 0x864, 0x865, 0, 0, 0, 0, 0),
- D_GATE(CLK_P1_PG4, "clk_p1_pg4", DIV_P1_PG, 0x866, 0x867, 0, 0, 0, 0, 0),
- D_GATE(CLK_P4_PG3, "clk_p4_pg3", DIV_P4_PG, 0x824, 0x825, 0, 0, 0, 0, 0),
- D_GATE(CLK_P4_PG4, "clk_p4_pg4", DIV_P4_PG, 0x826, 0x827, 0, 0, 0, 0, 0),
- D_GATE(CLK_P6_PG1, "clk_p6_pg1", DIV_P6_PG, 0x8a0, 0x8a1, 0x8a2, 0, 0xb60, 0, 0),
- D_GATE(CLK_P6_PG2, "clk_p6_pg2", DIV_P6_PG, 0x8a3, 0x8a4, 0x8a5, 0, 0xb61, 0, 0),
- D_GATE(CLK_P6_PG3, "clk_p6_pg3", DIV_P6_PG, 0x8a6, 0x8a7, 0x8a8, 0, 0xb62, 0, 0),
- D_GATE(CLK_P6_PG4, "clk_p6_pg4", DIV_P6_PG, 0x8a9, 0x8aa, 0x8ab, 0, 0xb63, 0, 0),
- D_MODULE(CLK_PCI_USB, "clk_pci_usb", CLKOUT_D40, 0xe6, 0, 0, 0, 0, 0, 0),
- D_GATE(CLK_QSPI0, "clk_qspi0", DIV_QSPI0, 0x2a4, 0x2a5, 0, 0, 0, 0, 0),
- D_GATE(CLK_QSPI1, "clk_qspi1", DIV_QSPI1, 0x484, 0x485, 0, 0, 0, 0, 0),
- D_GATE(CLK_RGMII_REF, "clk_rgmii_ref", CLKOUT_D8, 0x340, 0, 0, 0, 0, 0, 0),
- D_GATE(CLK_RMII_REF, "clk_rmii_ref", CLKOUT_D20, 0x341, 0, 0, 0, 0, 0, 0),
- D_GATE(CLK_SDIO0, "clk_sdio0", DIV_SDIO0, 0x64, 0, 0, 0, 0, 0, 0),
- D_GATE(CLK_SDIO1, "clk_sdio1", DIV_SDIO1, 0x644, 0, 0, 0, 0, 0, 0),
- D_GATE(CLK_SERCOS100, "clk_sercos100", CLKOUT_D10, 0x425, 0, 0, 0, 0, 0, 0),
- D_GATE(CLK_SLCD, "clk_slcd", DIV_P1_PG, 0x860, 0x861, 0, 0, 0, 0, 0),
- D_GATE(CLK_SPI0, "clk_spi0", DIV_P3_PG, 0x7e0, 0x7e1, 0, 0, 0, 0, 0),
- D_GATE(CLK_SPI1, "clk_spi1", DIV_P3_PG, 0x7e2, 0x7e3, 0, 0, 0, 0, 0),
- D_GATE(CLK_SPI2, "clk_spi2", DIV_P3_PG, 0x7e4, 0x7e5, 0, 0, 0, 0, 0),
- D_GATE(CLK_SPI3, "clk_spi3", DIV_P3_PG, 0x7e6, 0x7e7, 0, 0, 0, 0, 0),
- D_GATE(CLK_SPI4, "clk_spi4", DIV_P4_PG, 0x820, 0x821, 0, 0, 0, 0, 0),
- D_GATE(CLK_SPI5, "clk_spi5", DIV_P4_PG, 0x822, 0x823, 0, 0, 0, 0, 0),
- D_GATE(CLK_SWITCH, "clk_switch", DIV_SWITCH, 0x982, 0x983, 0, 0, 0, 0, 0),
- D_DIV(DIV_MOTOR, "div_motor", CLKOUT_D5, 84, 2, 8),
- D_MODULE(HCLK_ECAT125, "hclk_ecat125", CLKOUT_D8, 0x400, 0x401, 0, 0x402, 0, 0x440, 0x441),
- D_MODULE(HCLK_PINCONFIG, "hclk_pinconfig", CLKOUT_D40, 0x740, 0x741, 0x742, 0, 0xae0, 0, 0),
- D_MODULE(HCLK_SERCOS, "hclk_sercos", CLKOUT_D10, 0x420, 0x422, 0, 0x421, 0, 0x460, 0x461),
- D_MODULE(HCLK_SGPIO2, "hclk_sgpio2", DIV_P5_PG, 0x8c3, 0x8c4, 0x8c5, 0, 0xb41, 0, 0),
- D_MODULE(HCLK_SGPIO3, "hclk_sgpio3", DIV_P5_PG, 0x8c6, 0x8c7, 0x8c8, 0, 0xb42, 0, 0),
- D_MODULE(HCLK_SGPIO4, "hclk_sgpio4", DIV_P5_PG, 0x8c9, 0x8ca, 0x8cb, 0, 0xb43, 0, 0),
- D_MODULE(HCLK_TIMER0, "hclk_timer0", CLKOUT_D40, 0x743, 0x744, 0x745, 0, 0xae1, 0, 0),
- D_MODULE(HCLK_TIMER1, "hclk_timer1", CLKOUT_D40, 0x746, 0x747, 0x748, 0, 0xae2, 0, 0),
- D_MODULE(HCLK_USBF, "hclk_usbf", CLKOUT_D8, 0xe3, 0, 0, 0xe4, 0, 0x102, 0x103),
- D_MODULE(HCLK_USBH, "hclk_usbh", CLKOUT_D8, 0xe0, 0xe1, 0, 0xe2, 0, 0x100, 0x101),
- D_MODULE(HCLK_USBPM, "hclk_usbpm", CLKOUT_D8, 0xe5, 0, 0, 0, 0, 0, 0),
- D_GATE(CLK_48_PG_F, "clk_48_pg_f", CLK_48, 0x78c, 0x78d, 0, 0x78e, 0, 0xb04, 0xb05),
- D_GATE(CLK_48_PG4, "clk_48_pg4", CLK_48, 0x789, 0x78a, 0x78b, 0, 0xb03, 0, 0),
- D_FFC(CLK_DDRPHY_PLLCLK_D4, "clk_ddrphy_pllclk_d4", CLK_DDRPHY_PLLCLK, 4),
- D_FFC(CLK_ECAT100_D4, "clk_ecat100_d4", CLK_ECAT100, 4),
- D_FFC(CLK_HSR100_D2, "clk_hsr100_d2", CLK_HSR100, 2),
- D_FFC(CLK_REF_SYNC_D4, "clk_ref_sync_d4", CLK_REF_SYNC, 4),
- D_FFC(CLK_REF_SYNC_D8, "clk_ref_sync_d8", CLK_REF_SYNC, 8),
- D_FFC(CLK_SERCOS100_D2, "clk_sercos100_d2", CLK_SERCOS100, 2),
- D_DIV(DIV_CA7, "div_ca7", CLK_REF_SYNC, 57, 1, 4, 1, 2, 4),
- D_MODULE(HCLK_CAN0, "hclk_can0", CLK_48, 0x783, 0x784, 0x785, 0, 0xb01, 0, 0),
- D_MODULE(HCLK_CAN1, "hclk_can1", CLK_48, 0x786, 0x787, 0x788, 0, 0xb02, 0, 0),
- D_MODULE(HCLK_DELTASIGMA, "hclk_deltasigma", DIV_MOTOR, 0x1ef, 0x1f0, 0x1f1, 0, 0, 0, 0),
- D_MODULE(HCLK_PWMPTO, "hclk_pwmpto", DIV_MOTOR, 0x1ec, 0x1ed, 0x1ee, 0, 0, 0, 0),
- D_MODULE(HCLK_RSV, "hclk_rsv", CLK_48, 0x780, 0x781, 0x782, 0, 0xb00, 0, 0),
- D_MODULE(HCLK_SGPIO0, "hclk_sgpio0", DIV_MOTOR, 0x1e0, 0x1e1, 0x1e2, 0, 0, 0, 0),
- D_MODULE(HCLK_SGPIO1, "hclk_sgpio1", DIV_MOTOR, 0x1e3, 0x1e4, 0x1e5, 0, 0, 0, 0),
- D_DIV(RTOS_MDC, "rtos_mdc", CLK_REF_SYNC, 100, 80, 640, 80, 160, 320, 640),
- D_GATE(CLK_CM3, "clk_cm3", CLK_REF_SYNC_D4, 0xba0, 0xba1, 0, 0xba2, 0, 0xbc0, 0xbc1),
- D_GATE(CLK_DDRC, "clk_ddrc", CLK_DDRPHY_PLLCLK_D4, 0x323, 0x324, 0, 0, 0, 0, 0),
- D_GATE(CLK_ECAT25, "clk_ecat25", CLK_ECAT100_D4, 0x403, 0x404, 0, 0, 0, 0, 0),
- D_GATE(CLK_HSR50, "clk_hsr50", CLK_HSR100_D2, 0x484, 0x485, 0, 0, 0, 0, 0),
- D_GATE(CLK_HW_RTOS, "clk_hw_rtos", CLK_REF_SYNC_D4, 0xc60, 0xc61, 0, 0, 0, 0, 0),
- D_GATE(CLK_SERCOS50, "clk_sercos50", CLK_SERCOS100_D2, 0x424, 0x423, 0, 0, 0, 0, 0),
- D_MODULE(HCLK_ADC, "hclk_adc", CLK_REF_SYNC_D8, 0x1af, 0x1b0, 0x1b1, 0, 0, 0, 0),
- D_MODULE(HCLK_CM3, "hclk_cm3", CLK_REF_SYNC_D4, 0xc20, 0xc21, 0xc22, 0, 0, 0, 0),
- D_MODULE(HCLK_CRYPTO_EIP150, "hclk_crypto_eip150", CLK_REF_SYNC_D4, 0x123, 0x124, 0x125, 0, 0x142, 0, 0),
- D_MODULE(HCLK_CRYPTO_EIP93, "hclk_crypto_eip93", CLK_REF_SYNC_D4, 0x120, 0x121, 0, 0x122, 0, 0x140, 0x141),
- D_MODULE(HCLK_DDRC, "hclk_ddrc", CLK_REF_SYNC_D4, 0x320, 0x322, 0, 0x321, 0, 0x3a0, 0x3a1),
- D_MODULE(HCLK_DMA0, "hclk_dma0", CLK_REF_SYNC_D4, 0x260, 0x261, 0x262, 0x263, 0x2c0, 0x2c1, 0x2c2),
- D_MODULE(HCLK_DMA1, "hclk_dma1", CLK_REF_SYNC_D4, 0x264, 0x265, 0x266, 0x267, 0x2c3, 0x2c4, 0x2c5),
- D_MODULE(HCLK_GMAC0, "hclk_gmac0", CLK_REF_SYNC_D4, 0x360, 0x361, 0x362, 0x363, 0x3c0, 0x3c1, 0x3c2),
- D_MODULE(HCLK_GMAC1, "hclk_gmac1", CLK_REF_SYNC_D4, 0x380, 0x381, 0x382, 0x383, 0x3e0, 0x3e1, 0x3e2),
- D_MODULE(HCLK_GPIO0, "hclk_gpio0", CLK_REF_SYNC_D4, 0x212, 0x213, 0x214, 0, 0, 0, 0),
- D_MODULE(HCLK_GPIO1, "hclk_gpio1", CLK_REF_SYNC_D4, 0x215, 0x216, 0x217, 0, 0, 0, 0),
- D_MODULE(HCLK_GPIO2, "hclk_gpio2", CLK_REF_SYNC_D4, 0x229, 0x22a, 0x22b, 0, 0, 0, 0),
- D_MODULE(HCLK_HSR, "hclk_hsr", CLK_HSR100_D2, 0x480, 0x482, 0, 0x481, 0, 0x4c0, 0x4c1),
- D_MODULE(HCLK_I2C0, "hclk_i2c0", CLK_REF_SYNC_D8, 0x1a9, 0x1aa, 0x1ab, 0, 0, 0, 0),
- D_MODULE(HCLK_I2C1, "hclk_i2c1", CLK_REF_SYNC_D8, 0x1ac, 0x1ad, 0x1ae, 0, 0, 0, 0),
- D_MODULE(HCLK_LCD, "hclk_lcd", CLK_REF_SYNC_D4, 0x7a0, 0x7a1, 0x7a2, 0, 0xb20, 0, 0),
- D_MODULE(HCLK_MSEBI_M, "hclk_msebi_m", CLK_REF_SYNC_D4, 0x164, 0x165, 0x166, 0, 0x183, 0, 0),
- D_MODULE(HCLK_MSEBI_S, "hclk_msebi_s", CLK_REF_SYNC_D4, 0x160, 0x161, 0x162, 0x163, 0x180, 0x181, 0x182),
- D_MODULE(HCLK_NAND, "hclk_nand", CLK_REF_SYNC_D4, 0x280, 0x281, 0x282, 0x283, 0x2e0, 0x2e1, 0x2e2),
- D_MODULE(HCLK_PG_I, "hclk_pg_i", CLK_REF_SYNC_D4, 0x7ac, 0x7ad, 0, 0x7ae, 0, 0xb24, 0xb25),
- D_MODULE(HCLK_PG19, "hclk_pg19", CLK_REF_SYNC_D4, 0x22c, 0x22d, 0x22e, 0, 0, 0, 0),
- D_MODULE(HCLK_PG20, "hclk_pg20", CLK_REF_SYNC_D4, 0x22f, 0x230, 0x231, 0, 0, 0, 0),
- D_MODULE(HCLK_PG3, "hclk_pg3", CLK_REF_SYNC_D4, 0x7a6, 0x7a7, 0x7a8, 0, 0xb22, 0, 0),
- D_MODULE(HCLK_PG4, "hclk_pg4", CLK_REF_SYNC_D4, 0x7a9, 0x7aa, 0x7ab, 0, 0xb23, 0, 0),
- D_MODULE(HCLK_QSPI0, "hclk_qspi0", CLK_REF_SYNC_D4, 0x2a0, 0x2a1, 0x2a2, 0x2a3, 0x300, 0x301, 0x302),
- D_MODULE(HCLK_QSPI1, "hclk_qspi1", CLK_REF_SYNC_D4, 0x480, 0x481, 0x482, 0x483, 0x4c0, 0x4c1, 0x4c2),
- D_MODULE(HCLK_ROM, "hclk_rom", CLK_REF_SYNC_D4, 0xaa0, 0xaa1, 0xaa2, 0, 0xb80, 0, 0),
- D_MODULE(HCLK_RTC, "hclk_rtc", CLK_REF_SYNC_D8, 0xa00, 0, 0, 0, 0, 0, 0),
- D_MODULE(HCLK_SDIO0, "hclk_sdio0", CLK_REF_SYNC_D4, 0x60, 0x61, 0x62, 0x63, 0x80, 0x81, 0x82),
- D_MODULE(HCLK_SDIO1, "hclk_sdio1", CLK_REF_SYNC_D4, 0x640, 0x641, 0x642, 0x643, 0x660, 0x661, 0x662),
- D_MODULE(HCLK_SEMAP, "hclk_semap", CLK_REF_SYNC_D4, 0x7a3, 0x7a4, 0x7a5, 0, 0xb21, 0, 0),
- D_MODULE(HCLK_SPI0, "hclk_spi0", CLK_REF_SYNC_D4, 0x200, 0x201, 0x202, 0, 0, 0, 0),
- D_MODULE(HCLK_SPI1, "hclk_spi1", CLK_REF_SYNC_D4, 0x203, 0x204, 0x205, 0, 0, 0, 0),
- D_MODULE(HCLK_SPI2, "hclk_spi2", CLK_REF_SYNC_D4, 0x206, 0x207, 0x208, 0, 0, 0, 0),
- D_MODULE(HCLK_SPI3, "hclk_spi3", CLK_REF_SYNC_D4, 0x209, 0x20a, 0x20b, 0, 0, 0, 0),
- D_MODULE(HCLK_SPI4, "hclk_spi4", CLK_REF_SYNC_D4, 0x20c, 0x20d, 0x20e, 0, 0, 0, 0),
- D_MODULE(HCLK_SPI5, "hclk_spi5", CLK_REF_SYNC_D4, 0x20f, 0x210, 0x211, 0, 0, 0, 0),
- D_MODULE(HCLK_SWITCH, "hclk_switch", CLK_REF_SYNC_D4, 0x980, 0, 0x981, 0, 0, 0, 0),
- D_MODULE(HCLK_SWITCH_RG, "hclk_switch_rg", CLK_REF_SYNC_D4, 0xc40, 0xc41, 0xc42, 0, 0, 0, 0),
- D_MODULE(HCLK_UART0, "hclk_uart0", CLK_REF_SYNC_D8, 0x1a0, 0x1a1, 0x1a2, 0, 0, 0, 0),
- D_MODULE(HCLK_UART1, "hclk_uart1", CLK_REF_SYNC_D8, 0x1a3, 0x1a4, 0x1a5, 0, 0, 0, 0),
- D_MODULE(HCLK_UART2, "hclk_uart2", CLK_REF_SYNC_D8, 0x1a6, 0x1a7, 0x1a8, 0, 0, 0, 0),
- D_MODULE(HCLK_UART3, "hclk_uart3", CLK_REF_SYNC_D4, 0x218, 0x219, 0x21a, 0, 0, 0, 0),
- D_MODULE(HCLK_UART4, "hclk_uart4", CLK_REF_SYNC_D4, 0x21b, 0x21c, 0x21d, 0, 0, 0, 0),
- D_MODULE(HCLK_UART5, "hclk_uart5", CLK_REF_SYNC_D4, 0x220, 0x221, 0x222, 0, 0, 0, 0),
- D_MODULE(HCLK_UART6, "hclk_uart6", CLK_REF_SYNC_D4, 0x223, 0x224, 0x225, 0, 0, 0, 0),
- D_MODULE(HCLK_UART7, "hclk_uart7", CLK_REF_SYNC_D4, 0x226, 0x227, 0x228, 0, 0, 0, 0),
.type = K_BITSEL,
.dual.group = 0,
.type = K_BITSEL,
.dual.group = 1,
- D_UGATE(CLK_UART0, "clk_uart0", UART_GROUP_012, 0, 0x1b2, 0x1b3, 0x1b4, 0x1b5),
- D_UGATE(CLK_UART1, "clk_uart1", UART_GROUP_012, 0, 0x1b6, 0x1b7, 0x1b8, 0x1b9),
- D_UGATE(CLK_UART2, "clk_uart2", UART_GROUP_012, 0, 0x1ba, 0x1bb, 0x1bc, 0x1bd),
- D_UGATE(CLK_UART3, "clk_uart3", UART_GROUP_34567, 1, 0x760, 0x761, 0x762, 0x763),
- D_UGATE(CLK_UART4, "clk_uart4", UART_GROUP_34567, 1, 0x764, 0x765, 0x766, 0x767),
- D_UGATE(CLK_UART5, "clk_uart5", UART_GROUP_34567, 1, 0x768, 0x769, 0x76a, 0x76b),
- D_UGATE(CLK_UART6, "clk_uart6", UART_GROUP_34567, 1, 0x76c, 0x76d, 0x76e, 0x76f),
- D_UGATE(CLK_UART7, "clk_uart7", UART_GROUP_34567, 1, 0x770, 0x771, 0x772, 0x773),
- struct regmap *regmap;
- struct clk mclk;
- const unsigned long clkid = clk->id & 0xffff;
- int i;
- for (i = 0; i < ARRAY_SIZE(r9a06g032_clocks); i++) {
- return NULL;
- const struct r9a06g032_clkdesc *desc = r9a06g032_clk_get(clk);
- if (!desc)
return -ENODEV;
ENOENT please
see https://u-boot.readthedocs.io/en/latest/develop/driver-model/design.html#err...
- if (desc->source == 0)
if (!desc->source)
although I would reverse the clauses to make the condition clearer
Can you use a define for this (instead of referring to ~0 everywhere)
- else
- parent->dev = clk->dev;
I think you need to clk_request here.
- struct clk parent;
- if (r9a06g032_clk_get_parent(clk, &parent)) {
dev_dbg please
Return -ENOENT here please. You can check for this with IS_ERR.
- if (parent.id == ~0) {
You need a newline here
return rate;
- return clk_get_rate(&parent);
- uint offset = 4 * (one >> 5);
- uint mask = 1U << (one & 0x1f);
- uint val = ((!!on) << (one & 0x1f));
Please either use bitfields for this, or use FIELD_GET() and friends.
- regmap_update_bits(clocks->regmap, offset, mask, val);
uint16_t one)
I think this all fits on one line?
- u32 val = 0;
- regmap_read(clocks->regmap, offset, &val);
- return !!(val & (1U << (one & 0x1f)));
- Cheating a little bit here: leverage the existing code to control the
- per-clock reset. It should really be handled by a reset controller instead.
- struct r9a06g032_priv *clocks = dev_get_priv(clk->dev);
- assert(desc);
- assert(desc->type == K_GATE);
- const struct r9a06g032_gate *g = &desc->gate;
- assert(g->reset);
Please order declarations all at the beginning. In this case, you will need to do something like
struct r9a06g032_priv *clocks = dev_get_priv(clk->dev); const struct r9a06g032_clkdesc *desc = r9a06g032_clk_get(clk); const struct r9a06g032_gate *g;
assert(desc); assert(desc->type == K_GATE); g = &desc->gate assert(g->reset);
- clk_rdesc_set(clocks, g->reset, on);
- This implements the R9A06G032 clock gate 'driver'. We cannot use the system's
- clock gate framework as the gates on the R9A06G032 have a special enabling
- sequence, therefore we use this little proxy.
- assert(desc);
ditto
- clk_rdesc_set(clocks, g->gate, on);
- /* De-assert reset */
- if (g->reset)
- /* Hardware manual recommends 5us delay after enabling clock & reset */
- udelay(5);
- /* If the peripheral is memory mapped (i.e. an AXI slave), there is an
- if (g->ready || g->midle) {
if (g->ready)
if (g->midle)
- /* Note: We don't wait for FlexWAY Socket Connection signal */
- return r9a06g032_clk_gate_set(clk, 1);
- return r9a06g032_clk_gate_set(clk, 0);
- Fixed factor clock
- unsigned long parent_rate = r9a06g032_clk_get_parent_rate(clk);
- unsigned long long rate;
- if (parent_rate == 0) {
- rate = (unsigned long long)parent_rate * desc->mul;
- rate = DIV_ROUND_UP(rate, desc->div);
- return (ulong)rate;
- This implements R9A06G032 clock divider 'driver'. This differs from the
- standard clk_divider because the set_rate method must also set b[31] to
- trigger the hardware rate change. In theory it should also wait for this
- bit to clear.
- u32 div = 0;
Didn't you already log this?
- regmap_read(clocks->regmap, 4 * desc->reg, &div);
- if (div < desc->div_min)
- else if (div > desc->div_max)
- return DIV_ROUND_UP(parent_rate, div);
DIV_ROUND_CLOSEST?
- /* + 1 to cope with rates that have the remainder dropped */
- u32 div = DIV_ROUND_UP(parent_rate, rate + 1);
- /* Clamp to allowable range */
- /* TODO: use the .div_table if provided */
- if (desc->div_table[0])
dev_err
But can't you just leave out the div_table member?
- pr_devel("%s clkid %lu rate %ld parent %ld div %d\n", __func__, clk->id,
dev_dbg
* cleared too.
- regmap_write(clocks->regmap, 4 * desc->reg, div | BIT(31));
- Dual gate. This handles toggling the approprate clock/reset bits,
- which depends on the mux setting above.
int enable)
- u8 sel_bit = clk_rdesc_get(clocks, desc->dual.sel);
- u16 gate[2] = { desc->dual.g1, desc->dual.g2 };
- u16 reset[2] = { desc->dual.r1, desc->dual.r2 };
- /* we always turn off the 'other' gate, regardless */
- clk_rdesc_set(clocks, gate[!sel_bit], 0);
- if (reset[!sel_bit])
- /* set the gate as requested */
- clk_rdesc_set(clocks, gate[sel_bit], enable);
- if (reset[sel_bit])
- return r9a06g032_clk_dualgate_setenable(clocks, desc, 1);
- return r9a06g032_clk_dualgate_setenable(clocks, desc, 0);
- return clk_rdesc_get(clocks, gate[sel_bit]);
- Main clock driver
- switch (desc->type) {
- case K_GATE:
- case K_DUALGATE:
- default:
Assert or dev_dbg is better here. This is "impossible" so we try and avoid increasing image size in these cases.
break;
- case K_GATE:
- case K_DUALGATE:
- default:
break;
- ulong ret = 0;
- assert(desc);
- case K_FFC:
break;
- case K_GATE:
break;
- case K_DIV:
break;
- case K_BITSEL:
break;
- case K_DUALGATE:
break;
- return ret;
- ulong ret = 0;
- assert(desc);
- case K_DIV:
break;
- default:
- return ret;
- if (args->args_count != 1) {
return -EINVAL;
- clk->id = args->args[0];
- .enable = r9a06g032_clk_enable,
- .disable = r9a06g032_clk_disable,
- .get_rate = r9a06g032_clk_get_rate,
- .set_rate = r9a06g032_clk_set_rate,
- .of_xlate = r9a06g032_clk_of_xlate,
- struct r9a06g032_priv *priv = dev_get_priv(dev);
- int err;
- priv->regmap = syscon_regmap_lookup_by_phandle(dev, "regmap");
- if (!priv->regmap) {
IS_ERR(priv->regmap)
dev_dbg
return -ENODEV;
return ERR_PTR(priv->regmap)
- /* Enable S/W reset */
- regmap_write(priv->regmap, 0x120, 0x41);
- err = clk_get_by_name(dev, "mclk", &priv->mclk);
- if (err)
return err;
Not necessary.
- { .compatible = "renesas,r9a06g032-sysctrl" },
- .name = "clk_r9a06g032",
- .id = UCLASS_CLK,
- .of_match = r9a06g032_clk_ids,
- .priv_auto = sizeof(struct r9a06g032_priv),
- .ops = &r9a06g032_clk_ops,
- .probe = &r9a06g032_clk_probe,
- .remove = &r9a06g032_clk_remove,
- .flags = DM_FLAG_PRE_RELOC,
The overall structure looks good; most of these things you should be able to iron out fairly easily.
--Sean
These came from the Linux driver of the same name. I can only speculate that in turn, the Linux driver definitions were auto-generated from vendor provided XML or similar documentation.
I figured that it would be best to match the Linux kernel clock driver. That way fixes can easily be shared. In fact while doing this work, I found an error in the clock table [1] and I also made some simplifications [2].
Regarding the unused fields (scon, mirack, mistat): I am not really sure what their purpose is. Maybe there is some value in having them. I'll try to find out more information about them. If we do decide to drop them, I would like to keep it synchronised with the Linux driver.
[1] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?i...
[2] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?i...
- const char *name;
- uint32_t type: 3;
This is still part of the code which I've intentionally kept identical to the Linux driver. I do agree that moving the enum seems reasonable, I'll put together a patch for this (and test it) and see if I can get it accepted on the kernel side.
- union {
/* for dividers */
struct {
u16 div_table[4];
struct {
u16 div, mul;
/* for dual gate */
struct {
uint16_t group : 1;
} dual;
I think it happened before I started working on RZ/N1, but there seemed to be quite a few iterations on how to represent the clock tree. At one point there were macros to assign/construct the bitfield values. And then a different way, and eventually the direct hex values you now see in the clock tables.
At the risk of re-opening old wounds (luckily not mine) I decided to just leave this part exactly as-is in the Linux driver.
+/* Internal clock IDs */ +#define R9A06G032_CLKOUT 0 +#define R9A06G032_CLKOUT_D10 2 +#define R9A06G032_CLKOUT_D16 3 +#define R9A06G032_CLKOUT_D160 4 [...] +#define R9A06G032_UART_GROUP_012 154 +#define R9A06G032_UART_GROUP_34567 155
In fact quite a few of them are in the dt-bindings already, see include/dt-bindings/clock/r9a06g032-sysctrl.h
I'm not really sure why some of these are defined in the .C file while others are in the dt-bindings header. Like much of the other bits, this was something I just carried over as-is from the Linux driver.
Yes, that sounds reasonable. My list of fixes (for both Linux driver and the u-boot one) is going to get rather long ;-)
- else
Normally clk_request is called by a driver wishing to use a particular clock. That is not the case here. This is in a helper function used to compute the current rate of a given clock. It only looks at the local table (struct r9a06g032_clkdsc).
Yes, this would be clearer - however as mentioned above, there was already quite a bit of teeth-gnashing about this encoding. I will prepare a patch for the Linux side and see what kind of reply I get.
I would very much prefer to keep both in sync as much as possible.
- bit to clear.
- u32 div = 0;
It is for a different clock type. However I will see if I do something to avoid the duplication.
DIV_ROUND_CLOSEST?
I'm hesitant to change the logic on this, as it could subtly alter the values.
dev_err
Only a few of the clocks have a div_table, but for those, the table specifies the allowable divider values. So right now, the code cannot correctly set such clocks, as it may try programming illegal values (most likely with the result that you don't get the expected rate).
The Linux driver does implement the div_table logic, I simply did not carry it over yet to u-boot. Mostly because I have not yet had need for one of the few clocks which does use the table. I do plan to add it.
- Main clock driver
- case K_GATE:
- case K_DUALGATE:
- default:
Fair enough. Though I have to say I have been bitten by this kind of thing a few times. After having spent time debugging-via-printf, I would then discover an assert or dev_dbg that points out the exact problem. If only I had enabled DEBUG for that file! And yet if I enable DEBUG globally, there is so much noise, that I don't notice the one message that might have been helpful.
I have skipped over a few of the smaller points regarding return values, etc, but I will address them in next version of the patch. Thanks again for your time reviewing this.
Regards, -Ralph
OK, well if you don't use them then perhaps you can just leave them in the macro but remove them from the struct. That way you can add support for them later if you need to, but they don't take up space in the mean time. A comment summarizing your explanation above would be helpful.
Can you link to that discussion? The earliest discussion of that series I could find was [1], and there's no mention of the encoding. This encoding scheme seems to be used only for this SoC, and not for any of the other renesas drivers. I suspect that this just wasn't reviewed in detail the first time around...
[1] https://lore.kernel.org/all/1527154169-32380-6-git-send-email-michel.pollet@...
I think these are "internal" clocks (that is, clocks which don't really exist like intermediate dividers) whereas the others are public-facing clocks. It's up to you, but maybe have a comment noting where the other ids come from.
You call clk_get_rate on it. Any time you "create" a new clock, you must call clk_request.
- bit to clear.
I mean in r9a06g032_clk_get_parent_rate. You can also just do
if (!parent_rate) ...
+ return 0; + }
DIV_ROUND_CLOSEST?
Well if you have 2MHz divided by 3, the resulting rate is closer to 666667 kHz than 666666 Hz.
dev_err
OK
- Main clock driver
I generally stick a `#define DEBUG` at the top of a file any time I get an error with no message. You still return 0, so I suggest returning -EINVAL (or something else uncommon) so you have somewhere to start.
Regards, -Ralph
I did figure out (mostly) what they are for, so I can see some value in keeping at least some of them. But as you said, they are currently unused, so dropping them from the structure make sense.
I have prepared patches for this firstly on the kernel side, and then I will make the same change in this u-boot driver. Stay tuned :-)
That link [1] is the current driver, which uses the packed encoding (with a register offset and bit number stored as a packed uint16_t).
This is based (loosely) on an earlier version of the driver, which you can find in the Schneider kernel repo [2] on the 4.19 and older branch. This version stores clock information is in the device tree [3] and uses _BIT() macro in the clock tables [4]
[2] https://github.com/renesas-rz/rzn1_linux/tree/rzn1-stable-v4.19/drivers/clk/...
[3] https://github.com/renesas-rz/rzn1_linux/blob/rzn1-stable-v4.19/arch/arm/boo...
[4] https://github.com/renesas-rz/rzn1_linux/blob/rzn1-stable-v4.19/drivers/clk/...
Evidently this was not deemed suitable, and thus morphed into the version that did get merged [1]. At least that is my guess, I don't know for sure what transpired.
I have modified the clock table so that the register offset and bitnum are explicit values, rather than packed together. I will run this up the kernel side and see if they agree. Am still trying to test it though...
I guess that is plausible explanation.. I will add a comment...
So the situation here is similar to that on the mediatek patches from Weijie Gao [5], where you made a similar comment. These are not real clocks, they have no ops->request, and the only field used is clk->id. This is done primarily to avoid a bunch of malloc of struct clk, particularly in the early u-boot (before relocation).
[5] https://lore.kernel.org/all/31b0e1313267c8d342e0e3d1c9f15eaa8e666114.camel@m...
I've fixed this (and several similar instances elsewhere).
DIV_ROUND_CLOSEST?
While I can't argue with the math, the linux driver upon which this is based uses DIV_ROUND_UP everywhere. Maybe that is something to also re-consider, but for the time being, I don't want to make the change even more complicated...
Yep, that works fine when developing a driver... but if you are debugging a board, it is often not clear which file(s) should get sprinkled with DEBUG... and turning it on globally is too verbose to be useful in most cases.
Anyhow, thanks for your review, and v3 will be posted eventually, once I get the kernel side sorted.
-Ralph
Hi Sean,
I finally got around to posting v3 of this patch series. I wanted to touch on a few issues you had mentioned in previous review.
On Fri, Aug 26, 2022 at 11:47 AM Ralph Siemsen ralph.siemsen@linaro.org wrote:
So I ended up doing as you suggested: keeping the values in the tables, in case they are needed in the future, but omitting them from the structure to save space.
DIV_ROUND_CLOSEST?
This could result in the chosen clock rate being higher than what was requested. And in turn that could result in violating the spec of a hardware device.
So I have kept the original logic here.
Regards Ralph
Pinctrl/pinconf driver for Renesas RZ/N1 (R906G032) SoC.
This is quite rudimentary right now, and only supports applying a default pin configuration as specified by the device tree.
TODO:
- iterate over subnodes, so we can handle groups of pins with different bias/strength settings
- use the regmap_update_bits for level1/level2 register updates --> does not exist for regmap_ranges, consider adding?
drivers/pinctrl/Makefile | 1 + drivers/pinctrl/renesas/Kconfig | 7 + drivers/pinctrl/renesas/Makefile | 1 + drivers/pinctrl/renesas/pinctrl-rzn1.c | 398 +++++++++++++++++++++ include/dt-bindings/pinctrl/rzn1-pinctrl.h | 141 ++++++++ 5 files changed, 548 insertions(+) create mode 100644 drivers/pinctrl/renesas/pinctrl-rzn1.c create mode 100644 include/dt-bindings/pinctrl/rzn1-pinctrl.h
diff --git a/drivers/pinctrl/Makefile b/drivers/pinctrl/Makefile index 3b167d099f..450267732c 100644 --- a/drivers/pinctrl/Makefile +++ b/drivers/pinctrl/Makefile @@ -14,6 +14,7 @@ obj-$(CONFIG_PINCTRL_INTEL) += intel/ obj-$(CONFIG_ARCH_MTMIPS) += mtmips/ obj-$(CONFIG_ARCH_NPCM) += nuvoton/ obj-$(CONFIG_ARCH_RMOBILE) += renesas/ +obj-$(CONFIG_ARCH_RZN1) += renesas/ obj-$(CONFIG_PINCTRL_SANDBOX) += pinctrl-sandbox.o obj-$(CONFIG_PINCTRL_SUNXI) += sunxi/ obj-$(CONFIG_PINCTRL_UNIPHIER) += uniphier/ diff --git a/drivers/pinctrl/renesas/Kconfig b/drivers/pinctrl/renesas/Kconfig index 1fedf63252..3fbc293e17 100644 --- a/drivers/pinctrl/renesas/Kconfig +++ b/drivers/pinctrl/renesas/Kconfig @@ -121,3 +121,10 @@ config PINCTRL_PFC_R7S72100 Support pin multiplexing control on Renesas RZ/A1 R7S72100 SoCs.
endif + +config PINCTRL_RZN1 + bool "Renesas RZ/N1 R906G032 pin control driver" + depends on ARCH_RZN1 + default y if ARCH_RZN1 + help + Support pin multiplexing control on Renesas RZ/N1 R906G032 SoCs. diff --git a/drivers/pinctrl/renesas/Makefile b/drivers/pinctrl/renesas/Makefile index 1c65505eff..8f26f16098 100644 --- a/drivers/pinctrl/renesas/Makefile +++ b/drivers/pinctrl/renesas/Makefile @@ -17,3 +17,4 @@ obj-$(CONFIG_PINCTRL_PFC_R8A77990) += pfc-r8a77990.o obj-$(CONFIG_PINCTRL_PFC_R8A77995) += pfc-r8a77995.o obj-$(CONFIG_PINCTRL_PFC_R8A779A0) += pfc-r8a779a0.o obj-$(CONFIG_PINCTRL_PFC_R7S72100) += pfc-r7s72100.o +obj-$(CONFIG_PINCTRL_RZN1) += pinctrl-rzn1.o diff --git a/drivers/pinctrl/renesas/pinctrl-rzn1.c b/drivers/pinctrl/renesas/pinctrl-rzn1.c new file mode 100644 index 0000000000..39ff1fa8a1 --- /dev/null +++ b/drivers/pinctrl/renesas/pinctrl-rzn1.c @@ -0,0 +1,398 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2014-2018 Renesas Electronics Europe Limited + * + * Phil Edworthy phil.edworthy@renesas.com + * Based on a driver originally written by Michel Pollet at Renesas. + */ + +#include <dt-bindings/pinctrl/rzn1-pinctrl.h> + +#include <dm/device.h> +#include <dm/device_compat.h> +#include <dm/pinctrl.h> +#include <dm/read.h> +#include <regmap.h> + +/* Field positions and masks in the pinmux registers */ +#define RZN1_L1_PIN_DRIVE_STRENGTH 10 +#define RZN1_L1_PIN_DRIVE_STRENGTH_4MA 0 +#define RZN1_L1_PIN_DRIVE_STRENGTH_6MA 1 +#define RZN1_L1_PIN_DRIVE_STRENGTH_8MA 2 +#define RZN1_L1_PIN_DRIVE_STRENGTH_12MA 3 +#define RZN1_L1_PIN_PULL 8 +#define RZN1_L1_PIN_PULL_NONE 0 +#define RZN1_L1_PIN_PULL_UP 1 +#define RZN1_L1_PIN_PULL_DOWN 3 +#define RZN1_L1_FUNCTION 0 +#define RZN1_L1_FUNC_MASK 0xf +#define RZN1_L1_FUNCTION_L2 0xf + +/* + * The hardware manual describes two levels of multiplexing, but it's more + * logical to think of the hardware as three levels, with level 3 consisting of + * the multiplexing for Ethernet MDIO signals. + * + * Level 1 functions go from 0 to 9, with level 1 function '15' (0xf) specifying + * that level 2 functions are used instead. Level 2 has a lot more options, + * going from 0 to 61. Level 3 allows selection of MDIO functions which can be + * floating, or one of seven internal peripherals. Unfortunately, there are two + * level 2 functions that can select MDIO, and two MDIO channels so we have four + * sets of level 3 functions. + * + * For this driver, we've compounded the numbers together, so: + * 0 to 9 is level 1 + * 10 to 71 is 10 + level 2 number + * 72 to 79 is 72 + MDIO0 source for level 2 MDIO function. + * 80 to 87 is 80 + MDIO0 source for level 2 MDIO_E1 function. + * 88 to 95 is 88 + MDIO1 source for level 2 MDIO function. + * 96 to 103 is 96 + MDIO1 source for level 2 MDIO_E1 function. + * Examples: + * Function 28 corresponds UART0 + * Function 73 corresponds to MDIO0 to GMAC0 + * + * There are 170 configurable pins (called PL_GPIO in the datasheet). + */ + +/* + * Structure detailing the HW registers on the RZ/N1 devices. + * Both the Level 1 mux registers and Level 2 mux registers have the same + * structure. The only difference is that Level 2 has additional MDIO registers + * at the end. + */ +struct rzn1_pinctrl_regs { + u32 conf[170]; + u32 pad0[86]; + u32 status_protect; /* 0x400 */ + /* MDIO mux registers, level2 only */ + u32 l2_mdio[2]; +}; + +#define NUM_CONF ARRAY_SIZE(((struct rzn1_pinctrl_regs *)0)->conf) + +#define level1_write(map, member, val) \ + regmap_range_set(map, 0, struct rzn1_pinctrl_regs, member, val) + +#define level1_read(map, member, valp) \ + regmap_range_get(map, 0, struct rzn1_pinctrl_regs, member, valp) + +#define level2_write(map, member, val) \ + regmap_range_set(map, 1, struct rzn1_pinctrl_regs, member, val) + +#define level2_read(map, member, valp) \ + regmap_range_get(map, 1, struct rzn1_pinctrl_regs, member, valp) + +/** + * struct rzn1_pmx_func - describes rzn1 pinmux functions + * @name: the name of this specific function + * @groups: corresponding pin groups + * @num_groups: the number of groups + */ +struct rzn1_pmx_func { + const char *name; + const char **groups; + unsigned int num_groups; +}; + +/** + * struct rzn1_pin_group - describes an rzn1 pin group + * @name: the name of this specific pin group + * @func: the name of the function selected by this group + * @npins: the number of pins in this group array, i.e. the number of + * elements in .pins so we can iterate over that array + * @pins: array of pins. Needed due to pinctrl_ops.get_group_pins() + * @pin_ids: array of pin_ids, i.e. the value used to select the mux + */ +struct rzn1_pin_group { + const char *name; + const char *func; + unsigned int npins; + unsigned int *pins; + u8 *pin_ids; +}; + +struct rzn1_pinctrl { + struct device *dev; + struct clk *clk; + struct pinctrl_dev *pctl; + u32 lev1_protect_phys; + u32 lev2_protect_phys; + int mdio_func[2]; + + struct rzn1_pin_group *groups; + unsigned int ngroups; + + struct rzn1_pmx_func *functions; + unsigned int nfunctions; +}; + +struct rzn1_pinctrl_priv { + struct regmap *regmap; + u32 lev1_protect_phys; + u32 lev2_protect_phys; + + struct clk *clk; +}; + +enum { + LOCK_LEVEL1 = 0x1, + LOCK_LEVEL2 = 0x2, + LOCK_ALL = LOCK_LEVEL1 | LOCK_LEVEL2, +}; + +static void rzn1_hw_set_lock(struct rzn1_pinctrl_priv *priv, u8 lock, u8 value) +{ + /* + * The pinmux configuration is locked by writing the physical address of + * the status_protect register to itself. It is unlocked by writing the + * address | 1. + */ + if (lock & LOCK_LEVEL1) { + u32 val = priv->lev1_protect_phys | !(value & LOCK_LEVEL1); + + level1_write(priv->regmap, status_protect, val); + } + + if (lock & LOCK_LEVEL2) { + u32 val = priv->lev2_protect_phys | !(value & LOCK_LEVEL2); + + level2_write(priv->regmap, status_protect, val); + } +} + +static void rzn1_pinctrl_mdio_select(struct rzn1_pinctrl_priv *priv, int mdio, + u32 func) +{ + debug("setting mdio%d to %u\n", mdio, func); + + level2_write(priv->regmap, l2_mdio[mdio], func); +} + +/* + * Using a composite pin description, set the hardware pinmux registers + * with the corresponding values. + * Make sure to unlock write protection and reset it afterward. + * + * NOTE: There is no protection for potential concurrency, it is assumed these + * calls are serialized already. + */ +static int rzn1_set_hw_pin_func(struct rzn1_pinctrl_priv *priv, + unsigned int pin, unsigned int func) +{ + u32 l1_cache; + u32 l2_cache; + u32 l1; + u32 l2; + + /* Level 3 MDIO multiplexing */ + if (func >= RZN1_FUNC_MDIO0_HIGHZ && + func <= RZN1_FUNC_MDIO1_E1_SWITCH) { + int mdio_channel; + u32 mdio_func; + + if (func <= RZN1_FUNC_MDIO1_HIGHZ) + mdio_channel = 0; + else + mdio_channel = 1; + + /* Get MDIO func, and convert the func to the level 2 number */ + if (func <= RZN1_FUNC_MDIO0_SWITCH) { + mdio_func = func - RZN1_FUNC_MDIO0_HIGHZ; + func = RZN1_FUNC_ETH_MDIO; + } else if (func <= RZN1_FUNC_MDIO0_E1_SWITCH) { + mdio_func = func - RZN1_FUNC_MDIO0_E1_HIGHZ; + func = RZN1_FUNC_ETH_MDIO_E1; + } else if (func <= RZN1_FUNC_MDIO1_SWITCH) { + mdio_func = func - RZN1_FUNC_MDIO1_HIGHZ; + func = RZN1_FUNC_ETH_MDIO; + } else { + mdio_func = func - RZN1_FUNC_MDIO1_E1_HIGHZ; + func = RZN1_FUNC_ETH_MDIO_E1; + } + rzn1_pinctrl_mdio_select(priv, mdio_channel, mdio_func); + } + + /* Note here, we do not allow anything past the MDIO Mux values */ + if (pin >= NUM_CONF || func >= RZN1_FUNC_MDIO0_HIGHZ) + return -EINVAL; + + level1_read(priv->regmap, conf[pin], &l1); + l1_cache = l1; + level2_read(priv->regmap, conf[pin], &l2); + l2_cache = l2; + + debug("setting func for pin %u to %u\n", pin, func); + + l1 &= ~(RZN1_L1_FUNC_MASK << RZN1_L1_FUNCTION); + + if (func < RZN1_FUNC_L2_OFFSET) { + l1 |= (func << RZN1_L1_FUNCTION); + } else { + l1 |= (RZN1_L1_FUNCTION_L2 << RZN1_L1_FUNCTION); + + l2 = func - RZN1_FUNC_L2_OFFSET; + } + + /* If either configuration changes, we update both anyway */ + if (l1 != l1_cache || l2 != l2_cache) { + level1_write(priv->regmap, conf[pin], l1); + level2_write(priv->regmap, conf[pin], l2); + } + + return 0; +} + +static int rzn1_pinconf_set(struct rzn1_pinctrl_priv *priv, unsigned int pin, + unsigned int bias, unsigned int strength) +{ + u32 l1, l1_cache; + u32 drv = RZN1_L1_PIN_DRIVE_STRENGTH_8MA; + + level1_read(priv->regmap, conf[pin], &l1); + l1_cache = l1; + + switch (bias) { + case PIN_CONFIG_BIAS_PULL_UP: + debug("set pin %d pull up\n", pin); + l1 &= ~(0x3 << RZN1_L1_PIN_PULL); + l1 |= (RZN1_L1_PIN_PULL_UP << RZN1_L1_PIN_PULL); + break; + case PIN_CONFIG_BIAS_PULL_DOWN: + debug("set pin %d pull down\n", pin); + l1 &= ~(0x3 << RZN1_L1_PIN_PULL); + l1 |= (RZN1_L1_PIN_PULL_DOWN << RZN1_L1_PIN_PULL); + break; + case PIN_CONFIG_BIAS_DISABLE: + debug("set pin %d bias off\n", pin); + l1 &= ~(0x3 << RZN1_L1_PIN_PULL); + l1 |= (RZN1_L1_PIN_PULL_NONE << RZN1_L1_PIN_PULL); + break; + } + + switch (strength) { + case 4: + drv = RZN1_L1_PIN_DRIVE_STRENGTH_4MA; + break; + case 6: + drv = RZN1_L1_PIN_DRIVE_STRENGTH_6MA; + break; + case 8: + drv = RZN1_L1_PIN_DRIVE_STRENGTH_8MA; + break; + case 12: + drv = RZN1_L1_PIN_DRIVE_STRENGTH_12MA; + break; + } + + debug("set pin %d drv %umA\n", pin, drv); + + l1 &= ~(0x3 << RZN1_L1_PIN_DRIVE_STRENGTH); + l1 |= (drv << RZN1_L1_PIN_DRIVE_STRENGTH); + + if (l1 != l1_cache) + level1_write(priv->regmap, conf[pin], l1); + + return 0; +} + +static int rzn1_pinctrl_set_state_simple(struct udevice *dev, + struct udevice *periph) +{ + // FIXME this gets called for all device nodes which do not + // have a pinctrl-0 phandle property. If the function is missing + // then a warning gets printed by pinctrl-uclass. + + debug("%s:%d dev=%s periph=%s\n", __func__, __LINE__, dev->name, periph->name); + + return 0; +} + +static int rzn1_pinctrl_set_state(struct udevice *dev, struct udevice *config) +{ + struct rzn1_pinctrl_priv *priv = dev_get_priv(dev); + int size; + int ret; + u32 val; + + /* TODO: need to iterate over subgroups, needed so that it is possible + * to have different bias/strength settings for some pins. Currently + * none of our devices need that. + */ + + /* Pullup/down bias, common to all pins in group */ + u32 bias = PIN_CONFIG_BIAS_PULL_UP; + if (dev_read_bool(config, "bias-disable")) + bias = PIN_CONFIG_BIAS_DISABLE; + else if (dev_read_bool(config, "bias-pull-up")) + bias = PIN_CONFIG_BIAS_PULL_UP; + else if (dev_read_bool(config, "bias-pull-down")) + bias = PIN_CONFIG_BIAS_PULL_DOWN; + + /* Drive strength, common to all pins in group */ + u32 strength = dev_read_u32_default(config, "drive-strength", 8); + + /* Number of pins */ + ret = dev_read_size(config, "pinmux"); + if (ret < 0) + return ret; + + size = ret / sizeof(val); + + for (int i = 0; i < size; i++) { + ret = dev_read_u32_index(config, "pinmux", i, &val); + if (ret) + return ret; + unsigned int pin = val & 0xff; + unsigned int func = val >> 8; + + debug("%s pin %d func %d bias %d strength %d\n", + config->name, pin, func, bias, strength); + + rzn1_hw_set_lock(priv, LOCK_ALL, LOCK_ALL); + rzn1_set_hw_pin_func(priv, pin, func); + rzn1_pinconf_set(priv, pin, bias, strength); + rzn1_hw_set_lock(priv, LOCK_ALL, 0); + } + + return 0; +} + +static struct pinctrl_ops rzn1_pinctrl_ops = { + .set_state = rzn1_pinctrl_set_state, + + .set_state_simple = rzn1_pinctrl_set_state_simple, + +}; + +static int rzn1_pinctrl_probe(struct udevice *dev) +{ + struct rzn1_pinctrl_priv *priv = dev_get_priv(dev); + ofnode node = dev_ofnode(dev); + int ret; + + ret = regmap_init_mem(node, &priv->regmap); + if (ret) + return ret; + + priv->lev1_protect_phys = (u32)regmap_get_range(priv->regmap, 0) + + offsetof(struct rzn1_pinctrl_regs, status_protect); + priv->lev2_protect_phys = (u32)regmap_get_range(priv->regmap, 1) + + offsetof(struct rzn1_pinctrl_regs, status_protect); + + return 0; +} + +static const struct udevice_id rzn1_pinctrl_ids[] = { + { .compatible = "renesas,rzn1-pinctrl", }, + { }, +}; + +U_BOOT_DRIVER(pinctrl_rzn1) = { + .name = "rzn1-pinctrl", + .id = UCLASS_PINCTRL, + .of_match = rzn1_pinctrl_ids, + .priv_auto = sizeof(struct rzn1_pinctrl_priv), + .ops = &rzn1_pinctrl_ops, + .probe = rzn1_pinctrl_probe, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/include/dt-bindings/pinctrl/rzn1-pinctrl.h b/include/dt-bindings/pinctrl/rzn1-pinctrl.h new file mode 100644 index 0000000000..21d6cc4d59 --- /dev/null +++ b/include/dt-bindings/pinctrl/rzn1-pinctrl.h @@ -0,0 +1,141 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Defines macros and constants for Renesas RZ/N1 pin controller pin + * muxing functions. + */ +#ifndef __DT_BINDINGS_RZN1_PINCTRL_H +#define __DT_BINDINGS_RZN1_PINCTRL_H + +#define RZN1_PINMUX(_gpio, _func) \ + (((_func) << 8) | (_gpio)) + +/* + * Given the different levels of muxing on the SoC, it was decided to + * 'linearize' them into one numerical space. So mux level 1, 2 and the MDIO + * muxes are all represented by one single value. + * + * You can derive the hardware value pretty easily too, as + * 0...9 are Level 1 + * 10...71 are Level 2. The Level 2 mux will be set to this + * value - RZN1_FUNC_L2_OFFSET, and the Level 1 mux will be + * set accordingly. + * 72...103 are for the 2 MDIO muxes. + */ +#define RZN1_FUNC_HIGHZ 0 +#define RZN1_FUNC_0L 1 +#define RZN1_FUNC_CLK_ETH_MII_RGMII_RMII 2 +#define RZN1_FUNC_CLK_ETH_NAND 3 +#define RZN1_FUNC_QSPI 4 +#define RZN1_FUNC_SDIO 5 +#define RZN1_FUNC_LCD 6 +#define RZN1_FUNC_LCD_E 7 +#define RZN1_FUNC_MSEBIM 8 +#define RZN1_FUNC_MSEBIS 9 +#define RZN1_FUNC_L2_OFFSET 10 /* I'm Special */ + +#define RZN1_FUNC_HIGHZ1 (RZN1_FUNC_L2_OFFSET + 0) +#define RZN1_FUNC_ETHERCAT (RZN1_FUNC_L2_OFFSET + 1) +#define RZN1_FUNC_SERCOS3 (RZN1_FUNC_L2_OFFSET + 2) +#define RZN1_FUNC_SDIO_E (RZN1_FUNC_L2_OFFSET + 3) +#define RZN1_FUNC_ETH_MDIO (RZN1_FUNC_L2_OFFSET + 4) +#define RZN1_FUNC_ETH_MDIO_E1 (RZN1_FUNC_L2_OFFSET + 5) +#define RZN1_FUNC_USB (RZN1_FUNC_L2_OFFSET + 6) +#define RZN1_FUNC_MSEBIM_E (RZN1_FUNC_L2_OFFSET + 7) +#define RZN1_FUNC_MSEBIS_E (RZN1_FUNC_L2_OFFSET + 8) +#define RZN1_FUNC_RSV (RZN1_FUNC_L2_OFFSET + 9) +#define RZN1_FUNC_RSV_E (RZN1_FUNC_L2_OFFSET + 10) +#define RZN1_FUNC_RSV_E1 (RZN1_FUNC_L2_OFFSET + 11) +#define RZN1_FUNC_UART0_I (RZN1_FUNC_L2_OFFSET + 12) +#define RZN1_FUNC_UART0_I_E (RZN1_FUNC_L2_OFFSET + 13) +#define RZN1_FUNC_UART1_I (RZN1_FUNC_L2_OFFSET + 14) +#define RZN1_FUNC_UART1_I_E (RZN1_FUNC_L2_OFFSET + 15) +#define RZN1_FUNC_UART2_I (RZN1_FUNC_L2_OFFSET + 16) +#define RZN1_FUNC_UART2_I_E (RZN1_FUNC_L2_OFFSET + 17) +#define RZN1_FUNC_UART0 (RZN1_FUNC_L2_OFFSET + 18) +#define RZN1_FUNC_UART0_E (RZN1_FUNC_L2_OFFSET + 19) +#define RZN1_FUNC_UART1 (RZN1_FUNC_L2_OFFSET + 20) +#define RZN1_FUNC_UART1_E (RZN1_FUNC_L2_OFFSET + 21) +#define RZN1_FUNC_UART2 (RZN1_FUNC_L2_OFFSET + 22) +#define RZN1_FUNC_UART2_E (RZN1_FUNC_L2_OFFSET + 23) +#define RZN1_FUNC_UART3 (RZN1_FUNC_L2_OFFSET + 24) +#define RZN1_FUNC_UART3_E (RZN1_FUNC_L2_OFFSET + 25) +#define RZN1_FUNC_UART4 (RZN1_FUNC_L2_OFFSET + 26) +#define RZN1_FUNC_UART4_E (RZN1_FUNC_L2_OFFSET + 27) +#define RZN1_FUNC_UART5 (RZN1_FUNC_L2_OFFSET + 28) +#define RZN1_FUNC_UART5_E (RZN1_FUNC_L2_OFFSET + 29) +#define RZN1_FUNC_UART6 (RZN1_FUNC_L2_OFFSET + 30) +#define RZN1_FUNC_UART6_E (RZN1_FUNC_L2_OFFSET + 31) +#define RZN1_FUNC_UART7 (RZN1_FUNC_L2_OFFSET + 32) +#define RZN1_FUNC_UART7_E (RZN1_FUNC_L2_OFFSET + 33) +#define RZN1_FUNC_SPI0_M (RZN1_FUNC_L2_OFFSET + 34) +#define RZN1_FUNC_SPI0_M_E (RZN1_FUNC_L2_OFFSET + 35) +#define RZN1_FUNC_SPI1_M (RZN1_FUNC_L2_OFFSET + 36) +#define RZN1_FUNC_SPI1_M_E (RZN1_FUNC_L2_OFFSET + 37) +#define RZN1_FUNC_SPI2_M (RZN1_FUNC_L2_OFFSET + 38) +#define RZN1_FUNC_SPI2_M_E (RZN1_FUNC_L2_OFFSET + 39) +#define RZN1_FUNC_SPI3_M (RZN1_FUNC_L2_OFFSET + 40) +#define RZN1_FUNC_SPI3_M_E (RZN1_FUNC_L2_OFFSET + 41) +#define RZN1_FUNC_SPI4_S (RZN1_FUNC_L2_OFFSET + 42) +#define RZN1_FUNC_SPI4_S_E (RZN1_FUNC_L2_OFFSET + 43) +#define RZN1_FUNC_SPI5_S (RZN1_FUNC_L2_OFFSET + 44) +#define RZN1_FUNC_SPI5_S_E (RZN1_FUNC_L2_OFFSET + 45) +#define RZN1_FUNC_SGPIO0_M (RZN1_FUNC_L2_OFFSET + 46) +#define RZN1_FUNC_SGPIO1_M (RZN1_FUNC_L2_OFFSET + 47) +#define RZN1_FUNC_GPIO (RZN1_FUNC_L2_OFFSET + 48) +#define RZN1_FUNC_CAN (RZN1_FUNC_L2_OFFSET + 49) +#define RZN1_FUNC_I2C (RZN1_FUNC_L2_OFFSET + 50) +#define RZN1_FUNC_SAFE (RZN1_FUNC_L2_OFFSET + 51) +#define RZN1_FUNC_PTO_PWM (RZN1_FUNC_L2_OFFSET + 52) +#define RZN1_FUNC_PTO_PWM1 (RZN1_FUNC_L2_OFFSET + 53) +#define RZN1_FUNC_PTO_PWM2 (RZN1_FUNC_L2_OFFSET + 54) +#define RZN1_FUNC_PTO_PWM3 (RZN1_FUNC_L2_OFFSET + 55) +#define RZN1_FUNC_PTO_PWM4 (RZN1_FUNC_L2_OFFSET + 56) +#define RZN1_FUNC_DELTA_SIGMA (RZN1_FUNC_L2_OFFSET + 57) +#define RZN1_FUNC_SGPIO2_M (RZN1_FUNC_L2_OFFSET + 58) +#define RZN1_FUNC_SGPIO3_M (RZN1_FUNC_L2_OFFSET + 59) +#define RZN1_FUNC_SGPIO4_S (RZN1_FUNC_L2_OFFSET + 60) +#define RZN1_FUNC_MAC_MTIP_SWITCH (RZN1_FUNC_L2_OFFSET + 61) + +#define RZN1_FUNC_MDIO_OFFSET (RZN1_FUNC_L2_OFFSET + 62) + +/* These are MDIO0 peripherals for the RZN1_FUNC_ETH_MDIO function */ +#define RZN1_FUNC_MDIO0_HIGHZ (RZN1_FUNC_MDIO_OFFSET + 0) +#define RZN1_FUNC_MDIO0_GMAC0 (RZN1_FUNC_MDIO_OFFSET + 1) +#define RZN1_FUNC_MDIO0_GMAC1 (RZN1_FUNC_MDIO_OFFSET + 2) +#define RZN1_FUNC_MDIO0_ECAT (RZN1_FUNC_MDIO_OFFSET + 3) +#define RZN1_FUNC_MDIO0_S3_MDIO0 (RZN1_FUNC_MDIO_OFFSET + 4) +#define RZN1_FUNC_MDIO0_S3_MDIO1 (RZN1_FUNC_MDIO_OFFSET + 5) +#define RZN1_FUNC_MDIO0_HWRTOS (RZN1_FUNC_MDIO_OFFSET + 6) +#define RZN1_FUNC_MDIO0_SWITCH (RZN1_FUNC_MDIO_OFFSET + 7) +/* These are MDIO0 peripherals for the RZN1_FUNC_ETH_MDIO_E1 function */ +#define RZN1_FUNC_MDIO0_E1_HIGHZ (RZN1_FUNC_MDIO_OFFSET + 8) +#define RZN1_FUNC_MDIO0_E1_GMAC0 (RZN1_FUNC_MDIO_OFFSET + 9) +#define RZN1_FUNC_MDIO0_E1_GMAC1 (RZN1_FUNC_MDIO_OFFSET + 10) +#define RZN1_FUNC_MDIO0_E1_ECAT (RZN1_FUNC_MDIO_OFFSET + 11) +#define RZN1_FUNC_MDIO0_E1_S3_MDIO0 (RZN1_FUNC_MDIO_OFFSET + 12) +#define RZN1_FUNC_MDIO0_E1_S3_MDIO1 (RZN1_FUNC_MDIO_OFFSET + 13) +#define RZN1_FUNC_MDIO0_E1_HWRTOS (RZN1_FUNC_MDIO_OFFSET + 14) +#define RZN1_FUNC_MDIO0_E1_SWITCH (RZN1_FUNC_MDIO_OFFSET + 15) + +/* These are MDIO1 peripherals for the RZN1_FUNC_ETH_MDIO function */ +#define RZN1_FUNC_MDIO1_HIGHZ (RZN1_FUNC_MDIO_OFFSET + 16) +#define RZN1_FUNC_MDIO1_GMAC0 (RZN1_FUNC_MDIO_OFFSET + 17) +#define RZN1_FUNC_MDIO1_GMAC1 (RZN1_FUNC_MDIO_OFFSET + 18) +#define RZN1_FUNC_MDIO1_ECAT (RZN1_FUNC_MDIO_OFFSET + 19) +#define RZN1_FUNC_MDIO1_S3_MDIO0 (RZN1_FUNC_MDIO_OFFSET + 20) +#define RZN1_FUNC_MDIO1_S3_MDIO1 (RZN1_FUNC_MDIO_OFFSET + 21) +#define RZN1_FUNC_MDIO1_HWRTOS (RZN1_FUNC_MDIO_OFFSET + 22) +#define RZN1_FUNC_MDIO1_SWITCH (RZN1_FUNC_MDIO_OFFSET + 23) +/* These are MDIO1 peripherals for the RZN1_FUNC_ETH_MDIO_E1 function */ +#define RZN1_FUNC_MDIO1_E1_HIGHZ (RZN1_FUNC_MDIO_OFFSET + 24) +#define RZN1_FUNC_MDIO1_E1_GMAC0 (RZN1_FUNC_MDIO_OFFSET + 25) +#define RZN1_FUNC_MDIO1_E1_GMAC1 (RZN1_FUNC_MDIO_OFFSET + 26) +#define RZN1_FUNC_MDIO1_E1_ECAT (RZN1_FUNC_MDIO_OFFSET + 27) +#define RZN1_FUNC_MDIO1_E1_S3_MDIO0 (RZN1_FUNC_MDIO_OFFSET + 28) +#define RZN1_FUNC_MDIO1_E1_S3_MDIO1 (RZN1_FUNC_MDIO_OFFSET + 29) +#define RZN1_FUNC_MDIO1_E1_HWRTOS (RZN1_FUNC_MDIO_OFFSET + 30) +#define RZN1_FUNC_MDIO1_E1_SWITCH (RZN1_FUNC_MDIO_OFFSET + 31) + +#define RZN1_FUNC_MAX (RZN1_FUNC_MDIO_OFFSET + 32) + +#endif /* __DT_BINDINGS_RZN1_PINCTRL_H */
Driver for Cadence EDAC DDR controller, as found in the Renesas RZ/N1. Only basic setup, not using the ECC features.
Signed-off-by: Ralph Siemsen ralph.siemsen@linaro.org ---
drivers/ram/Kconfig | 1 + drivers/ram/Makefile | 2 + drivers/ram/cadence/Kconfig | 24 ++ drivers/ram/cadence/Makefile | 1 + drivers/ram/cadence/ddr_async.c | 295 +++++++++++++++++++++++ drivers/ram/cadence/ddr_ctrl.c | 414 ++++++++++++++++++++++++++++++++ drivers/ram/cadence/ddr_ctrl.h | 172 +++++++++++++ 7 files changed, 909 insertions(+) create mode 100644 drivers/ram/cadence/Kconfig create mode 100644 drivers/ram/cadence/Makefile create mode 100644 drivers/ram/cadence/ddr_async.c create mode 100644 drivers/ram/cadence/ddr_ctrl.c create mode 100644 drivers/ram/cadence/ddr_ctrl.h
diff --git a/drivers/ram/Kconfig b/drivers/ram/Kconfig index 86857c0627..ec0ab9ce8a 100644 --- a/drivers/ram/Kconfig +++ b/drivers/ram/Kconfig @@ -97,6 +97,7 @@ config IMXRT_SDRAM This driver is for the sdram memory interface with the SEMC.
source "drivers/ram/aspeed/Kconfig" +source "drivers/ram/cadence/Kconfig" source "drivers/ram/rockchip/Kconfig" source "drivers/ram/sifive/Kconfig" source "drivers/ram/stm32mp1/Kconfig" diff --git a/drivers/ram/Makefile b/drivers/ram/Makefile index 5a39611349..2a015cda48 100644 --- a/drivers/ram/Makefile +++ b/drivers/ram/Makefile @@ -22,3 +22,5 @@ obj-$(CONFIG_IMXRT_SDRAM) += imxrt_sdram.o obj-$(CONFIG_RAM_SIFIVE) += sifive/
obj-$(CONFIG_ARCH_OCTEON) += octeon/ + +obj-$(CONFIG_CADENCE_DDR_CTRL) += cadence/ diff --git a/drivers/ram/cadence/Kconfig b/drivers/ram/cadence/Kconfig new file mode 100644 index 0000000000..864cadfd10 --- /dev/null +++ b/drivers/ram/cadence/Kconfig @@ -0,0 +1,24 @@ +if RAM || SPL_RAM + +config CADENCE_DDR_CTRL + bool "Enable Cadence DDR controller" + depends on DM + help + Enable support for Cadence DDR controller, as found on + the Renesas RZ/N1 SoC. This controller has a large number + of registers which need to be programmed, mostly using values + obtained from Denali SOMA files via a TCL script. + +if CADENCE_DDR_CTRL + +# TODO: convert this to devicetree option +config CADENCE_DDR_CTRL_ENABLE_ECC + bool "Enable ECC support" + +# TODO: conver this to devicetree option +config CADENCE_DDR_CTRL_8BIT_WIDTH + bool "Reduce data width from 16 to 8 bits" + +endif + +endif diff --git a/drivers/ram/cadence/Makefile b/drivers/ram/cadence/Makefile new file mode 100644 index 0000000000..16c7fe8488 --- /dev/null +++ b/drivers/ram/cadence/Makefile @@ -0,0 +1 @@ +obj-$(CONFIG_CADENCE_DDR_CTRL) += ddr_async.o ddr_ctrl.o diff --git a/drivers/ram/cadence/ddr_async.c b/drivers/ram/cadence/ddr_async.c new file mode 100644 index 0000000000..1d6d3bdc79 --- /dev/null +++ b/drivers/ram/cadence/ddr_async.c @@ -0,0 +1,295 @@ +// SPDX-License-Identifier: BSD-2-Clause +/* + * RZ/N1 DDR Controller initialisation + * + * The DDR Controller register values for a specific DDR device, mode and + * frequency are generated using a Cadence tool. + * + * Copyright (C) 2015 Renesas Electronics Europe Ltd + */ +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <ram.h> +#include <asm/io.h> +#include <linux/delay.h> +#include "ddr_ctrl.h" + +void clk_rzn1_reset_state(struct clk *clk, int on); + +extern u32 ddr_00_87_async[]; +extern u32 ddr_350_374_async[]; + +DECLARE_GLOBAL_DATA_PTR; + +struct cadence_ddr_info { + struct udevice *dev; + void __iomem *ddrc; + void __iomem *phy; + struct clk clk_ddrc; + struct clk hclk_ddrc; +}; + +static inline u32 cadence_readl(void __iomem *addr, unsigned int offset) +{ + return readl(addr + offset); +} + +static inline void cadence_writel(void __iomem *addr, unsigned int offset, + u32 data) +{ + debug("%s: addr = 0x%p, value = 0x%08x\n", __func__, addr + offset, data); + writel(data, addr + offset); +} + +#define ddrc_readl(off) cadence_readl(priv->ddrc, off) +#define ddrc_writel(val, off) cadence_writel(priv->ddrc, off, val) + +#define phy_readl(off) cadence_readl(priv->phy, off) +#define phy_writel(val, off) cadence_writel(priv->phy, off, val) + +#define RZN1_DDR3_SINGLE_BANK 3 +#define RZN1_DDR3_DUAL_BANK 32 + +#define FUNCCTRL 0x00 +#define FUNCCTRL_MASKSDLOFS (0x18 << 16) +#define FUNCCTRL_DVDDQ_1_5V (1 << 8) +#define FUNCCTRL_RESET_N (1 << 0) +#define DLLCTRL 0x04 +#define DLLCTRL_ASDLLOCK (1 << 26) +#define DLLCTRL_MFSL_500MHz (2 << 1) +#define DLLCTRL_MDLLSTBY (1 << 0) +#define ZQCALCTRL 0x08 +#define ZQCALCTRL_ZQCALEND (1 << 30) +#define ZQCALCTRL_ZQCALRSTB (1 << 0) +#define ZQODTCTRL 0x0c +#define RDCTRL 0x10 +#define RDTMG 0x14 +#define FIFOINIT 0x18 +#define FIFOINIT_RDPTINITEXE (1 << 8) +#define FIFOINIT_WRPTINITEXE (1 << 0) +#define OUTCTRL 0x1c +#define OUTCTRL_ADCMDOE (1 << 0) +#define WLCTRL1 0x40 +#define WLCTRL1_WLSTR (1 << 24) +#define DQCALOFS1 0xe8 + +/* DDR PHY setup */ +void ddr_phy_init(struct cadence_ddr_info *priv, int ddr_type) +{ + u32 val; + + /* Disable DDR Controller clock and FlexWAY connection */ + clk_disable(&priv->hclk_ddrc); + clk_disable(&priv->clk_ddrc); + + clk_rzn1_reset_state(&priv->hclk_ddrc, 0); + clk_rzn1_reset_state(&priv->clk_ddrc, 0); + + /* Enable DDR Controller clock and FlexWAY connection */ + clk_enable(&priv->clk_ddrc); + clk_enable(&priv->hclk_ddrc); + + /* DDR PHY Soft reset assert */ + ddrc_writel(FUNCCTRL_MASKSDLOFS | FUNCCTRL_DVDDQ_1_5V, FUNCCTRL); + + clk_rzn1_reset_state(&priv->hclk_ddrc, 1); + clk_rzn1_reset_state(&priv->clk_ddrc, 1); + + /* DDR PHY setup */ + phy_writel(DLLCTRL_MFSL_500MHz | DLLCTRL_MDLLSTBY, DLLCTRL); + phy_writel(0x00000182, ZQCALCTRL); + if (ddr_type == RZN1_DDR3_DUAL_BANK) + phy_writel(0xAB330031, ZQODTCTRL); + else if (ddr_type == RZN1_DDR3_SINGLE_BANK) + phy_writel(0xAB320051, ZQODTCTRL); + else /* DDR2 */ + phy_writel(0xAB330071, ZQODTCTRL); + phy_writel(0xB545B544, RDCTRL); + phy_writel(0x000000B0, RDTMG); + phy_writel(0x020A0806, OUTCTRL); + if (ddr_type == RZN1_DDR3_DUAL_BANK) + phy_writel(0x80005556, WLCTRL1); + else + phy_writel(0x80005C5D, WLCTRL1); + phy_writel(0x00000101, FIFOINIT); + phy_writel(0x00004545, DQCALOFS1); + + /* Step 9 MDLL reset release */ + val = phy_readl(DLLCTRL); + val &= ~DLLCTRL_MDLLSTBY; + phy_writel(val, DLLCTRL); + + /* Step 12 Soft reset release */ + val = phy_readl(FUNCCTRL); + val |= FUNCCTRL_RESET_N; + phy_writel(val, FUNCCTRL); + + /* Step 13 FIFO pointer initialize */ + phy_writel(FIFOINIT_RDPTINITEXE | FIFOINIT_WRPTINITEXE, FIFOINIT); + + /* Step 14 Execute ZQ Calibration */ + val = phy_readl(ZQCALCTRL); + val |= ZQCALCTRL_ZQCALRSTB; + phy_writel(val, ZQCALCTRL); + + /* Step 15 Wait for 200us or more, or wait for DFIINITCOMPLETE to be "1" */ + while (!(phy_readl(DLLCTRL) & DLLCTRL_ASDLLOCK)) + ; + while (!(phy_readl(ZQCALCTRL) & ZQCALCTRL_ZQCALEND)) + ; + + /* Step 16 Enable Address and Command output */ + val = phy_readl(OUTCTRL); + val |= OUTCTRL_ADCMDOE; + phy_writel(val, OUTCTRL); + + /* Step 17 Wait for 200us or more(from MRESETB=0) */ + udelay(200); +} + +void ddr_phy_enable_wl(struct cadence_ddr_info *priv) +{ + u32 val; + + /* Step 26 (Set Write Leveling) */ + val = phy_readl(WLCTRL1); + val |= WLCTRL1_WLSTR; + phy_writel(val, WLCTRL1); +} + +#define RZN1_DDR_BASE 0x4000D000 /* RZ/N1D only */ +#define RZN1_V_DDR_BASE 0x80000000 /* RZ/N1D only */ + +void rzn1_ddr3_single_bank(void *ddr_ctrl_base) +{ + /* CS0 */ + cdns_ddr_set_mr1(ddr_ctrl_base, 0, + MR1_ODT_IMPEDANCE_60_OHMS, + MR1_DRIVE_STRENGTH_40_OHMS); + cdns_ddr_set_mr2(ddr_ctrl_base, 0, + MR2_DYNAMIC_ODT_OFF, + MR2_SELF_REFRESH_TEMP_EXT); + + /* ODT_WR_MAP_CS0 = 1, ODT_RD_MAP_CS0 = 0 */ + cdns_ddr_set_odt_map(ddr_ctrl_base, 0, 0x0100); +} + +int rzn1_dram_init(struct cadence_ddr_info *priv) +{ + u32 ddr_start_addr = 0; + + ddr_phy_init(priv, RZN1_DDR3_SINGLE_BANK); + + /* + * Override DDR PHY Interface (DFI) related settings + * DFI is the internal interface between the DDR controller and the DDR PHY. + * These settings are specific to LCES2 and can't be known by the settings + * provided for each DDR model within the generated include. + */ + ddr_350_374_async[351 - 350] = 0x001e0000; + ddr_350_374_async[352 - 350] = 0x1e680000; + ddr_350_374_async[353 - 350] = 0x02000020; + ddr_350_374_async[354 - 350] = 0x02000200; + ddr_350_374_async[355 - 350] = 0x00000c30; + ddr_350_374_async[356 - 350] = 0x00009808; + ddr_350_374_async[357 - 350] = 0x020a0706; + ddr_350_374_async[372 - 350] = 0x01000000; + +#if 0 + /* + * On ES1.0 devices, the DDR start address that the DDR Controller sees + * is the physical address of the DDR. However, later devices changed it + * to be 0 in order to fix an issue with DDR out-of-range detection. + */ + if (sysctrl_readl(RZN1_SYSCTRL_REG_VERSION) == 0x10) + ddr_start_addr = RZN1_V_DDR_BASE; +#endif + + /* DDR Controller is always in ASYNC mode */ + cdns_ddr_ctrl_init((void *)RZN1_DDR_BASE, 1, + ddr_00_87_async, ddr_350_374_async, + ddr_start_addr, CONFIG_SYS_SDRAM_SIZE); + + rzn1_ddr3_single_bank((void *)RZN1_DDR_BASE); + cdns_ddr_set_diff_cs_delays((void *)RZN1_DDR_BASE, 2, 7, 2, 2); + cdns_ddr_set_same_cs_delays((void *)RZN1_DDR_BASE, 0, 7, 0, 0); + cdns_ddr_set_odt_times((void *)RZN1_DDR_BASE, 5, 6, 6, 0, 4); + cdns_ddr_ctrl_start((void *)RZN1_DDR_BASE); + + ddr_phy_enable_wl(priv); + + if (IS_ENABLED(CONFIG_CADENCE_DDR_CTRL_ENABLE_ECC)) { + /* + * Any read before a write will trigger an ECC un-correctable error, + * causing a data abort. However, this is also true for any read with a + * size less than the AXI bus width. So, the only sensible solution is + * to write to all of DDR now and take the hit... + */ + memset((void *)RZN1_V_DDR_BASE, 0xff, CONFIG_SYS_SDRAM_SIZE); + } + + return 0; +} + +static int cadence_ddr_get_info(struct udevice *udev, struct ram_info *info) +{ + info->base = 0; + info->size = gd->ram_size; + + return 0; +} + +static struct ram_ops cadence_ddr_ops = { + .get_info = cadence_ddr_get_info, +}; + +static int cadence_ddr_probe(struct udevice *dev) +{ + struct cadence_ddr_info *priv = dev_get_priv(dev); + int ret; + + priv->ddrc = dev_remap_addr_name(dev, "ddrc"); + if (!priv->ddrc) { + dev_err(dev, "No reg property for Cadence DDR CTRL\n"); + return -EINVAL; + } + + priv->phy = dev_remap_addr_name(dev, "phy"); + if (!priv->phy) { + dev_err(dev, "No reg property for Cadence DDR PHY\n"); + return -EINVAL; + } + + ret = clk_get_by_name(dev, "clk_ddrc", &priv->clk_ddrc); + if (ret) { + dev_err(dev, "No clock for Cadence DDR\n"); + return ret; + } + + ret = clk_get_by_name(dev, "hclk_ddrc", &priv->hclk_ddrc); + if (ret) { + dev_err(dev, "No HCLK for Cadence DDR\n"); + return ret; + } + + rzn1_dram_init(priv); + + return 0; +} + +static const struct udevice_id cadence_ddr_ids[] = { + { .compatible = "cadence,ddr-ctrl" }, + { } +}; + +U_BOOT_DRIVER(cadence_ddr) = { + .name = "cadence_ddr", + .id = UCLASS_RAM, + .of_match = cadence_ddr_ids, + .ops = &cadence_ddr_ops, + .probe = cadence_ddr_probe, + .priv_auto = sizeof(struct cadence_ddr_info), + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/drivers/ram/cadence/ddr_ctrl.c b/drivers/ram/cadence/ddr_ctrl.c new file mode 100644 index 0000000000..833d5d9197 --- /dev/null +++ b/drivers/ram/cadence/ddr_ctrl.c @@ -0,0 +1,414 @@ +// SPDX-License-Identifier: BSD-2-Clause +/* + * Cadence DDR Controller + * + * Copyright (C) 2015 Renesas Electronics Europe Ltd + */ + +/* + * The Cadence DDR Controller has a huge number of registers that principally + * cover two aspects, DDR specific timing information and AXI bus interfacing. + * Cadence's TCL script generates all of the register values for specific + * DDR devices operating at a specific frequency. The TCL script uses Denali + * SOMA files as inputs. The tool also generates the AXI bus register values as + * well, however this driver assumes that users will want to modifiy these to + * meet a specific application's needs. + * Therefore, this driver is passed two arrays containing register values for + * the DDR device specific information, and explicity sets the AXI registers. + * + * AXI bus interfacing: + * The controller has four AXI slaves connections, and each of these can be + * programmed to accept requests from specific AXI masters (using their IDs). + * The regions of DDR that can be accessed by each AXI slave can be set such + * as to isolate DDR used by one AXI master from another. Further, the maximum + * bandwidth allocated to each AXI slave can be set. + */ + +#include <common.h> +#include <linux/delay.h> +#include <linux/sizes.h> +#include <asm/io.h> +#include "ddr_ctrl.h" + +/* avoid warning for real pr_debug in <linux/printk.h> */ +#ifdef pr_debug +#undef pr_debug +#endif + +#ifdef DEBUG + #define pr_debug(fmt, args...) printf(fmt, ##args) + #define pr_debug2(fmt, args...) printf(fmt, ##args) +#else + #define pr_debug(fmt, args...) + #define pr_debug2(fmt, args...) +#endif + +#define DDR_NR_AXI_PORTS 4 +#define DDR_NR_ENTRIES 16 + +#define DDR_START_REG (0) /* DENALI_CTL_00 */ +#define DDR_CS0_MR1_REG (32 * 4) /* DENALI_CTL_32 */ +#define DDR_CS0_MR2_REG (32 * 4 + 2) /* DENALI_CTL_32 */ +#define DDR_CS1_MR1_REG (34 * 4 + 2) /* DENALI_CTL_34 */ +#define DDR_CS1_MR2_REG (35 * 4) /* DENALI_CTL_35 */ +#define DDR_ECC_ENABLE_REG (36 * 4 + 2) /* DENALI_CTL_36 */ +#define DDR_ECC_DISABLE_W_UC_ERR_REG (37 * 4 + 2) /* DENALI_CTL_37 */ +#define DDR_HALF_DATAPATH_REG (54 * 4) /* DENALI_CTL_54 */ +#define DDR_INTERRUPT_STATUS (56 * 4) /* DENALI_CTL_56 */ +#define DDR_INTERRUPT_ACK (57 * 4) /* DENALI_CTL_57 */ +#define DDR_INTERRUPT_MASK (58 * 4) /* DENALI_CTL_58 */ +#define DDR_CS0_ODT_MAP_REG (62 * 4 + 2) /* DENALI_CTL_62 */ +#define DDR_CS1_ODT_MAP_REG (63 * 4) /* DENALI_CTL_63 */ +#define DDR_ODT_TODTL_2CMD (63 * 4 + 2) /* DENALI_CTL_63 */ +#define DDR_ODT_TODTH_WR (63 * 4 + 3) /* DENALI_CTL_63 */ +#define DDR_ODT_TODTH_RD (64 * 4 + 0) /* DENALI_CTL_64 */ +#define DDR_ODT_EN (64 * 4 + 1) /* DENALI_CTL_64 */ +#define DDR_ODT_WR_TO_ODTH (64 * 4 + 2) /* DENALI_CTL_64 */ +#define DDR_ODT_RD_TO_ODTH (64 * 4 + 3) /* DENALI_CTL_64 */ +#define DDR_DIFF_CS_DELAY_REG (66 * 4) /* DENALI_CTL_66 */ +#define DDR_SAME_CS_DELAY_REG (67 * 4) /* DENALI_CTL_67 */ +#define DDR_RW_PRIORITY_REGS (87 * 4 + 2) /* DENALI_CTL_87 */ +#define DDR_RW_FIFO_TYPE_REGS (88 * 4) /* DENALI_CTL_88 */ +#define DDR_AXI_PORT_PROT_ENABLE_REG (90 * 4 + 3) /* DENALI_CTL_90 */ +#define DDR_ADDR_RANGE_REGS (91 * 4) /* DENALI_CTL_91 */ +#define DDR_RANGE_PROT_REGS (218 * 4 + 2) /* DENALI_CTL_218 */ +#define DDR_ARB_CMD_Q_THRESHOLD_REG (346 * 4 + 2) /* DENALI_CTL_346 */ +#define DDR_AXI_PORT_BANDWIDTH_REG (346 * 4 + 3) /* DENALI_CTL_346 */ +#define DDR_OPT_RMODW_REG (372 * 4 + 3) /* DENALI_CTL_372 */ + +static void ddrc_writeb(u8 val, void *p) +{ + pr_debug2("DDR: %p = 0x%02x\n", p, val); + writeb(val, p); +} + +static void ddrc_writew(u16 val, void *p) +{ + pr_debug2("DDR: %p = 0x%04x\n", p, val); + writew(val, p); +} + +static void ddrc_writel(u32 val, void *p) +{ + pr_debug2("DDR: %p = 0x%08x\n", p, val); + writel(val, p); +} + +void cdns_ddr_set_mr1(void *base, int cs, u16 odt_impedance, u16 drive_strength) +{ + void *reg; + u16 tmp; + + if (cs == 0) + reg = (u8 *)base + DDR_CS0_MR1_REG; + else + reg = (u8 *)base + DDR_CS1_MR1_REG; + + tmp = readw(reg); + + tmp &= ~MODE_REGISTER_MASK; + tmp |= MODE_REGISTER_MR1; + + tmp &= ~MR1_ODT_IMPEDANCE_MASK; + tmp |= odt_impedance; + + tmp &= ~MR1_DRIVE_STRENGTH_MASK; + tmp |= drive_strength; + + writew(tmp, reg); +} + +void cdns_ddr_set_mr2(void *base, int cs, u16 dynamic_odt, u16 self_refresh_temp) +{ + void *reg; + u16 tmp; + + if (cs == 0) + reg = (u8 *)base + DDR_CS0_MR2_REG; + else + reg = (u8 *)base + DDR_CS1_MR2_REG; + + tmp = readw(reg); + + tmp &= ~MODE_REGISTER_MASK; + tmp |= MODE_REGISTER_MR2; + + tmp &= ~MR2_DYNAMIC_ODT_MASK; + tmp |= dynamic_odt; + + tmp &= ~MR2_SELF_REFRESH_TEMP_MASK; + tmp |= self_refresh_temp; + + writew(tmp, reg); +} + +void cdns_ddr_set_odt_map(void *base, int cs, u16 odt_map) +{ + void *reg; + + if (cs == 0) + reg = (u8 *)base + DDR_CS0_ODT_MAP_REG; + else + reg = (u8 *)base + DDR_CS1_ODT_MAP_REG; + + writew(odt_map, reg); +} + +void cdns_ddr_set_odt_times(void *base, u8 TODTL_2CMD, u8 TODTH_WR, u8 TODTH_RD, + u8 WR_TO_ODTH, u8 RD_TO_ODTH) +{ + writeb(TODTL_2CMD, (u8 *)base + DDR_ODT_TODTL_2CMD); + writeb(TODTH_WR, (u8 *)base + DDR_ODT_TODTH_WR); + writeb(TODTH_RD, (u8 *)base + DDR_ODT_TODTH_RD); + writeb(1, (u8 *)base + DDR_ODT_EN); + writeb(WR_TO_ODTH, (u8 *)base + DDR_ODT_WR_TO_ODTH); + writeb(RD_TO_ODTH, (u8 *)base + DDR_ODT_RD_TO_ODTH); +} + +void cdns_ddr_set_same_cs_delays(void *base, u8 r2r, u8 r2w, u8 w2r, u8 w2w) +{ + u32 val = (w2w << 24) | (w2r << 16) | (r2w << 8) | r2r; + + writel(val, (u8 *)base + DDR_SAME_CS_DELAY_REG); +} + +void cdns_ddr_set_diff_cs_delays(void *base, u8 r2r, u8 r2w, u8 w2r, u8 w2w) +{ + u32 val = (w2w << 24) | (w2r << 16) | (r2w << 8) | r2r; + + writel(val, (u8 *)base + DDR_DIFF_CS_DELAY_REG); +} + +void cdns_ddr_set_port_rw_priority(void *base, int port, + u8 read_pri, u8 write_pri) +{ + u8 *reg8 = (u8 *)base + DDR_RW_PRIORITY_REGS; + + reg8 += (port * 3); + pr_debug("%s port %d (reg8=%p, DENALI_CTL_%d)\n", + __func__, port, reg8, (reg8 - (u8 *)base) / 4); + + ddrc_writeb(read_pri, reg8++); + ddrc_writeb(write_pri, reg8++); +} + +/* The DDR Controller has 16 entries. Each entry can specify an allowed address + * range (with 16KB resolution) for one of the 4 AXI slave ports. + */ +void cdns_ddr_enable_port_addr_range(void *base, int port, int entry, + u32 addr_start, u32 size) +{ + u32 addr_end; + u32 *reg32 = (u32 *)((u8 *)base + DDR_ADDR_RANGE_REGS); + u32 tmp; + + reg32 += (port * DDR_NR_ENTRIES * 2); + reg32 += (entry * 2); + pr_debug("%s port %d, entry %d (reg32=%p, DENALI_CTL_%d)\n", + __func__, port, entry, reg32, ((u8 *)reg32 - (u8 *)base) / 4); + + /* These registers represent 16KB address blocks */ + addr_start /= SZ_16K; + size /= SZ_16K; + if (size) + addr_end = addr_start + size - 1; + else + addr_end = addr_start; + + ddrc_writel(addr_start, reg32++); + + /* + * end_addr: Ensure we only set the bottom 18-bits as DENALI_CTL_218 + * also contains the AXI0 range protection bits. + */ + tmp = readl(reg32); + tmp &= ~(BIT(18) - 1); + tmp |= addr_end; + ddrc_writel(tmp, reg32); +} + +void cdns_ddr_enable_addr_range(void *base, int entry, + u32 addr_start, u32 size) +{ + int axi; + + for (axi = 0; axi < DDR_NR_AXI_PORTS; axi++) + cdns_ddr_enable_port_addr_range(base, axi, entry, + addr_start, size); +} + +void cdns_ddr_enable_port_prot(void *base, int port, int entry, + enum cdns_ddr_range_prot range_protection_bits, + u16 range_RID_check_bits, + u16 range_WID_check_bits, + u8 range_RID_check_bits_ID_lookup, + u8 range_WID_check_bits_ID_lookup) +{ + /* + * Technically, the offset here points to the byte before the start of + * the range protection registers. However, all entries consist of 8 + * bytes, except the first one (which is missing a padding byte) so we + * work around that subtlely. + */ + u8 *reg8 = (u8 *)base + DDR_RANGE_PROT_REGS; + + reg8 += (port * DDR_NR_ENTRIES * 8); + reg8 += (entry * 8); + pr_debug("%s port %d, entry %d (reg8=%p, DENALI_CTL_%d)\n", + __func__, port, entry, reg8, (reg8 - (u8 *)base) / 4); + + if (port == 0 && entry == 0) + ddrc_writeb(range_protection_bits, reg8 + 1); + else + ddrc_writeb(range_protection_bits, reg8); + + ddrc_writew(range_RID_check_bits, reg8 + 2); + ddrc_writew(range_WID_check_bits, reg8 + 4); + ddrc_writeb(range_RID_check_bits_ID_lookup, reg8 + 6); + ddrc_writeb(range_WID_check_bits_ID_lookup, reg8 + 7); +} + +void cdns_ddr_enable_prot(void *base, int entry, + enum cdns_ddr_range_prot range_protection_bits, + u16 range_RID_check_bits, + u16 range_WID_check_bits, + u8 range_RID_check_bits_ID_lookup, + u8 range_WID_check_bits_ID_lookup) +{ + int axi; + + for (axi = 0; axi < DDR_NR_AXI_PORTS; axi++) + cdns_ddr_enable_port_prot(base, axi, entry, + range_protection_bits, + range_RID_check_bits, + range_WID_check_bits, + range_RID_check_bits_ID_lookup, + range_WID_check_bits_ID_lookup); +} + +void cdns_ddr_set_port_bandwidth(void *base, int port, + u8 max_percent, u8 overflow_ok) +{ + u8 *reg8 = (u8 *)base + DDR_AXI_PORT_BANDWIDTH_REG; + + reg8 += (port * 3); + pr_debug("%s port %d, (reg8=%p, DENALI_CTL_%d)\n", + __func__, port, reg8, (reg8 - (u8 *)base) / 4); + + ddrc_writeb(max_percent, reg8++); /* Maximum bandwidth percentage */ + ddrc_writeb(overflow_ok, reg8++); /* Bandwidth overflow allowed */ +} + +void cdns_ddr_ctrl_init(void *ddr_ctrl_basex, int async, + const u32 *reg0, const u32 *reg350, + u32 ddr_start_addr, u32 ddr_size) +{ + int i, axi, entry; + u32 *ddr_ctrl_base = (u32 *)ddr_ctrl_basex; + u8 *base8 = (u8 *)ddr_ctrl_basex; + + pr_debug("%s\n", __func__); + ddrc_writel(*reg0, ddr_ctrl_base + 0); + /* 1 to 6 are read only */ + for (i = 7; i <= 26; i++) + ddrc_writel(*(reg0 + i), ddr_ctrl_base + i); + /* 27 to 29 are not changed */ + for (i = 30; i <= 87; i++) + ddrc_writel(*(reg0 + i), ddr_ctrl_base + i); + + /* Enable/disable ECC */ + if (IS_ENABLED(CONFIG_CADENCE_DDR_CTRL_ENABLE_ECC)) { + pr_debug("%s enabling ECC\n", __func__); + ddrc_writeb(1, base8 + DDR_ECC_ENABLE_REG); + } else { + ddrc_writeb(0, base8 + DDR_ECC_ENABLE_REG); + } + + /* ECC: Disable corruption for read/modify/write operations */ + ddrc_writeb(1, base8 + DDR_ECC_DISABLE_W_UC_ERR_REG); + + /* Set 8/16-bit data width using reduc bit (enable half datapath)*/ + if (IS_ENABLED(CONFIG_CADENCE_DDR_CTRL_8BIT_WIDTH)) { + pr_debug("%s using 8-bit data\n", __func__); + ddrc_writeb(1, base8 + DDR_HALF_DATAPATH_REG); + } else { + ddrc_writeb(0, base8 + DDR_HALF_DATAPATH_REG); + } + + /* Threshold for command queue */ + ddrc_writeb(4, base8 + DDR_ARB_CMD_Q_THRESHOLD_REG); + + /* AXI port protection => enable */ + ddrc_writeb(0x01, base8 + DDR_AXI_PORT_PROT_ENABLE_REG); + + /* Set port interface type, default port priority and bandwidths */ + for (axi = 0; axi < DDR_NR_AXI_PORTS; axi++) { + /* port interface type: synchronous or asynchronous AXI clock */ + u8 *fifo_reg = base8 + DDR_RW_FIFO_TYPE_REGS + (axi * 3); + + if (async) + ddrc_writeb(0, fifo_reg); + else + ddrc_writeb(3, fifo_reg); + + /* R/W priorities */ + cdns_ddr_set_port_rw_priority(ddr_ctrl_base, axi, 2, 2); + + /* AXI bandwidth */ + cdns_ddr_set_port_bandwidth(ddr_ctrl_base, axi, 50, 1); + } + + /* + * The hardware requires that the valid address ranges must not overlap. + * So, we initialise all address ranges to be above the DDR, length 0. + */ + for (entry = 0; entry < DDR_NR_ENTRIES; entry++) + cdns_ddr_enable_addr_range(ddr_ctrl_base, entry, + ddr_start_addr + ddr_size, 0); + + for (i = 350; i <= 374; i++) + ddrc_writel(*(reg350 - 350 + i), ddr_ctrl_base + i); + + /* Disable optimised read-modify-write logic */ + ddrc_writeb(0, base8 + DDR_OPT_RMODW_REG); + + /* + * Disable all interrupts, we are not handling them. + * For detail of the interrupt mask, ack and status bits, see the + * manual's description of the 'int_status' parameter. + */ + ddrc_writel(0, base8 + DDR_INTERRUPT_MASK); + + /* + * Default settings to enable full access to the entire DDR. + * Users can set different ranges and access rights by calling these + * functions before calling cdns_ddr_ctrl_start(). + */ + cdns_ddr_enable_addr_range(ddr_ctrl_base, 0, + ddr_start_addr, ddr_size); + cdns_ddr_enable_prot(ddr_ctrl_base, 0, CDNS_DDR_RANGE_PROT_BITS_FULL, + 0xffff, 0xffff, 0x0f, 0x0f); +} + +void cdns_ddr_ctrl_start(void *ddr_ctrl_basex) +{ + u32 *ddr_ctrl_base = (u32 *)ddr_ctrl_basex; + u8 *base8 = (u8 *)ddr_ctrl_basex; + + /* Start */ + ddrc_writeb(1, base8 + DDR_START_REG); + + /* Wait for controller to be ready (interrupt status) */ + while (!(readl(base8 + DDR_INTERRUPT_STATUS) & 0x100)) + ; + + /* clear all interrupts */ + ddrc_writel(~0, base8 + DDR_INTERRUPT_ACK); + + /* Step 19 Wait 500us from MRESETB=1 */ + udelay(500); + + /* Step 20 tCKSRX wait (From supply stable clock for MCK) */ + /* DENALI_CTL_19 TREF_ENABLE=0x1(=1), AREFRESH=0x1(=1) */ + ddrc_writel(0x01000100, ddr_ctrl_base + 19); +} diff --git a/drivers/ram/cadence/ddr_ctrl.h b/drivers/ram/cadence/ddr_ctrl.h new file mode 100644 index 0000000000..638d986261 --- /dev/null +++ b/drivers/ram/cadence/ddr_ctrl.h @@ -0,0 +1,172 @@ +/* SPDX-License-Identifier: BSD-2-Clause */ +/* + * Cadence DDR Controller + * + * Copyright (C) 2015 Renesas Electronics Europe Ltd + */ + +#ifndef CADENCE_DDR_CTRL_H +#define CADENCE_DDR_CTRL_H + +enum cdns_ddr_range_prot { + CDNS_DDR_RANGE_PROT_BITS_PRIV_SECURE = 0, + CDNS_DDR_RANGE_PROT_BITS_SECURE = 1, + CDNS_DDR_RANGE_PROT_BITS_PRIV = 2, + CDNS_DDR_RANGE_PROT_BITS_FULL = 3, +}; + +/** + * Initialise the Cadence DDR Controller, but doesn't start it. + * + * It sets up the controller so that all 4 AXI slave ports allow access to all + * of the DDR with the same settings. This means that: + * - Full access permisions. + * - All read/write priorities are set to 2. + * - Bandwidth is set to 50%, overflow is allowed, i.e. it's a soft limit. + * If you want different properties for different ports and/or addr ranges, call + * the other functions before calling cdns_ddr_ctrl_start(). + * + * @ddr_ctrl_base Physical address of the DDR Controller. + * @async 0 if DDR clock is synchronous with the controller clock + * otherwise 1. + * @reg0 Pointer to array of 32-bit values to be written to registers + * 0 to 87. The values are generated by Cadence TCL scripts. + * @reg350 Pointer to array of 32-bit values to be written to registers + * 350 to 374. The values are generated by Cadence TCL scripts. + * @ddr_start_addr Physical address of the start of DDR. + * @ddr_size Size of the DDR in bytes. The controller will set the port + * protection range to match this size. + */ +void cdns_ddr_ctrl_init(void *ddr_ctrl_base, int async, + const u32 *reg0, const u32 *reg350, + u32 ddr_start_addr, u32 ddr_size); + +/** + * Start the Cadence DDR Controller. + * + * @ddr_ctrl_base Physical address of the DDR Controller. + */ +void cdns_ddr_ctrl_start(void *ddr_ctrl_base); + +/** + * Set the priority for read and write operations for a specific AXI slave port. + * + * @base Physical address of the DDR Controller. + * @port Port number. Range is 0 to 3. + * @read_pri Priority for reads. Range is 0 to 3, where 0 is highest priority. + * @write_pri Priority for writes. Range is 0 to 3, where 0 is highest priority. + */ +void cdns_ddr_set_port_rw_priority(void *base, int port, + u8 read_pri, u8 write_pri); + +/** + * Specify address range for a protection entry, for a specific AXI slave port. + * + * @base Physical address of the DDR Controller. + * @port Port number. Range is 0 to 3. + * @entry The protection entry. Range is 0 to 15. + * @start_addr Physical of the address range, must be aligned to 16KB. + * @size Size of the address range, must be multiple of 16KB. + */ +void cdns_ddr_enable_port_addr_range(void *base, int port, int entry, + u32 addr_start, u32 size); + +/** + * Specify address range for a protection entry, for all AXI slave ports. + * + * @base Physical address of the DDR Controller. + * @entry The protection entry. Range is 0 to 15. + * @start_addr Physical of the address range, must be aligned to 16KB. + * @size Size of the address range, must be multiple of 16KB. + */ +void cdns_ddr_enable_addr_range(void *base, int entry, + u32 addr_start, u32 size); + +/** + * Specify protection entry details, for a specific AXI slave port. + * + * See the hardware manual for details of the range check bits. + * + * @base Physical address of the DDR Controller. + * @port Port number. Range is 0 to 3. + * @entry The protection entry. Range is 0 to 15. + */ +void cdns_ddr_enable_port_prot(void *base, int port, int entry, + enum cdns_ddr_range_prot range_protection_bits, + u16 range_RID_check_bits, + u16 range_WID_check_bits, + u8 range_RID_check_bits_ID_lookup, + u8 range_WID_check_bits_ID_lookup); + +/** + * Specify protection entry details, for all AXI slave ports. + * + * See the hardware manual for details of the range check bits. + * + * @base Physical address of the DDR Controller. + * @entry The protection entry. Range is 0 to 15. + */ +void cdns_ddr_enable_prot(void *base, int entry, + enum cdns_ddr_range_prot range_protection_bits, + u16 range_RID_check_bits, + u16 range_WID_check_bits, + u8 range_RID_check_bits_ID_lookup, + u8 range_WID_check_bits_ID_lookup); + +/** + * Specify bandwidth for each AXI port. + * + * See the hardware manual for details of the range check bits. + * + * @base Physical address of the DDR Controller. + * @port Port number. Range is 0 to 3. + * @max_percent 0 to 100. + */ +void cdns_ddr_set_port_bandwidth(void *base, int port, + u8 max_percent, u8 overflow_ok); + +/* Standard JEDEC registers */ +#define MODE_REGISTER_MASK (3 << 14) +#define MODE_REGISTER_MR0 (0 << 14) +#define MODE_REGISTER_MR1 (1 << 14) +#define MODE_REGISTER_MR2 (2 << 14) +#define MODE_REGISTER_MR3 (3 << 14) +#define MR1_DRIVE_STRENGTH_MASK ((1 << 5) | (1 << 1)) +#define MR1_DRIVE_STRENGTH_34_OHMS ((0 << 5) | (1 << 1)) +#define MR1_DRIVE_STRENGTH_40_OHMS ((0 << 5) | (0 << 1)) +#define MR1_ODT_IMPEDANCE_MASK ((1 << 9) | (1 << 6) | (1 << 2)) +#define MR1_ODT_IMPEDANCE_60_OHMS ((0 << 9) | (0 << 6) | (1 << 2)) +#define MR1_ODT_IMPEDANCE_120_OHMS ((0 << 9) | (1 << 6) | (0 << 2)) +#define MR1_ODT_IMPEDANCE_40_OHMS ((0 << 9) | (1 << 6) | (1 << 2)) +#define MR1_ODT_IMPEDANCE_20_OHMS ((1 << 9) | (0 << 6) | (0 << 2)) +#define MR1_ODT_IMPEDANCE_30_OHMS ((1 << 9) | (0 << 6) | (1 << 2)) +#define MR2_DYNAMIC_ODT_MASK (3 << 9) +#define MR2_DYNAMIC_ODT_OFF (0 << 9) +#define MR2_SELF_REFRESH_TEMP_MASK (1 << 7) +#define MR2_SELF_REFRESH_TEMP_EXT (1 << 7) + +/** + * Set certain fields of the JEDEC MR1 register. + */ +void cdns_ddr_set_mr1(void *base, int cs, u16 odt_impedance, u16 drive_strength); + +/** + * Set certain fields of the JEDEC MR2 register. + */ +void cdns_ddr_set_mr2(void *base, int cs, u16 dynamic_odt, u16 self_refresh_temp); + +/** + * Set ODT map of the DDR Controller. + */ +void cdns_ddr_set_odt_map(void *base, int cs, u16 odt_map); + +/** + * Set ODT settings in the DDR Controller. + */ +void cdns_ddr_set_odt_times(void *base, u8 TODTL_2CMD, u8 TODTH_WR, u8 TODTH_RD, + u8 WR_TO_ODTH, u8 RD_TO_ODTH); + +void cdns_ddr_set_same_cs_delays(void *base, u8 r2r, u8 r2w, u8 w2r, u8 w2w); +void cdns_ddr_set_diff_cs_delays(void *base, u8 r2r, u8 r2w, u8 w2r, u8 w2w); + +#endif
This is taken from Linux kernel 5.17, and contains just bare minimum functionality: CPU, UART and system timer.
Additional functionality (from newer kernel versions) will be added later. Note that the Linux side is under active development.
Signed-off-by: Ralph Siemsen ralph.siemsen@linaro.org --- The following changes were made, compared with Linux 5.17:
1) Add node for system controller registers. Declare it as syscon to provide a regmap interface.
2) In the clock controller node (renesas,r9a06g032-sysctrl), replace regs with regmap.
3) Add syscon-reset node, making use of the syscon regmap.
I could not find a way to avoid 1) and 2). Putting "syscon" in the compatible string for the clock controller leads to a catch-22, where the driver fails to initialize, and then boot hangs.
arch/arm/dts/r9a06g032.dtsi | 225 ++++++++++++++++++ include/dt-bindings/clock/r9a06g032-sysctrl.h | 148 ++++++++++++ 2 files changed, 373 insertions(+) create mode 100644 arch/arm/dts/r9a06g032.dtsi create mode 100644 include/dt-bindings/clock/r9a06g032-sysctrl.h
diff --git a/arch/arm/dts/r9a06g032.dtsi b/arch/arm/dts/r9a06g032.dtsi new file mode 100644 index 0000000000..a276a43e72 --- /dev/null +++ b/arch/arm/dts/r9a06g032.dtsi @@ -0,0 +1,225 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Base Device Tree Source for the Renesas RZ/N1D (R9A06G032) + * + * Copyright (C) 2018 Renesas Electronics Europe Limited + * + */ + +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/clock/r9a06g032-sysctrl.h> + +/ { + compatible = "renesas,r9a06g032"; + #address-cells = <1>; + #size-cells = <1>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a7"; + reg = <0>; + clocks = <&sysctrl R9A06G032_CLK_A7MP>; + }; + + cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a7"; + reg = <1>; + clocks = <&sysctrl R9A06G032_CLK_A7MP>; + enable-method = "renesas,r9a06g032-smp"; + cpu-release-addr = <0 0x4000c204>; + }; + }; + + ext_jtag_clk: extjtagclk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <0>; + }; + + ext_mclk: extmclk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <40000000>; + }; + + ext_rgmii_ref: extrgmiiref { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <0>; + }; + + ext_rtc_clk: extrtcclk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <0>; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + interrupt-parent = <&gic>; + ranges; + + plat_regs: system-controller@4000c000 { + compatible = "syscon"; + reg = <0x4000c000 0x1000>; + u-boot,dm-pre-reloc; + }; + + sysctrl: clock { + compatible = "renesas,r9a06g032-sysctrl"; + #clock-cells = <1>; + regmap = <&plat_regs>; + u-boot,dm-pre-reloc; + + clocks = <&ext_mclk>, <&ext_rtc_clk>, + <&ext_jtag_clk>, <&ext_rgmii_ref>; + clock-names = "mclk", "rtc", "jtag", "rgmii_ref_ext"; + }; + + ddrctrl: memory-controller@4000d000 { + compatible = "cadence,ddr-ctrl"; + reg = <0x4000d000 0x1000>, <0x4000e000 0x100>; + reg-names = "ddrc", "phy"; + interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&sysctrl R9A06G032_CLK_DDRC>, <&sysctrl R9A06G032_HCLK_DDRC>; + clock-names = "clk_ddrc", "hclk_ddrc"; + status = "disabled"; + }; + + uart0: serial@40060000 { + compatible = "renesas,r9a06g032-uart", "renesas,rzn1-uart", "snps,dw-apb-uart"; + reg = <0x40060000 0x400>; + interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&sysctrl R9A06G032_CLK_UART0>, <&sysctrl R9A06G032_HCLK_UART0>; + clock-names = "baudclk", "apb_pclk"; + status = "disabled"; + }; + + uart1: serial@40061000 { + compatible = "renesas,r9a06g032-uart", "renesas,rzn1-uart", "snps,dw-apb-uart"; + reg = <0x40061000 0x400>; + interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&sysctrl R9A06G032_CLK_UART1>, <&sysctrl R9A06G032_HCLK_UART1>; + clock-names = "baudclk", "apb_pclk"; + status = "disabled"; + }; + + uart2: serial@40062000 { + compatible = "renesas,r9a06g032-uart", "renesas,rzn1-uart", "snps,dw-apb-uart"; + reg = <0x40062000 0x400>; + interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&sysctrl R9A06G032_CLK_UART2>, <&sysctrl R9A06G032_HCLK_UART2>; + clock-names = "baudclk", "apb_pclk"; + status = "disabled"; + }; + + uart3: serial@50000000 { + compatible = "renesas,r9a06g032-uart", "renesas,rzn1-uart"; + reg = <0x50000000 0x400>; + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&sysctrl R9A06G032_CLK_UART3>, <&sysctrl R9A06G032_HCLK_UART3>; + clock-names = "baudclk", "apb_pclk"; + status = "disabled"; + }; + + uart4: serial@50001000 { + compatible = "renesas,r9a06g032-uart", "renesas,rzn1-uart"; + reg = <0x50001000 0x400>; + interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&sysctrl R9A06G032_CLK_UART4>, <&sysctrl R9A06G032_HCLK_UART4>; + clock-names = "baudclk", "apb_pclk"; + status = "disabled"; + }; + + uart5: serial@50002000 { + compatible = "renesas,r9a06g032-uart", "renesas,rzn1-uart"; + reg = <0x50002000 0x400>; + interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&sysctrl R9A06G032_CLK_UART5>, <&sysctrl R9A06G032_HCLK_UART5>; + clock-names = "baudclk", "apb_pclk"; + status = "disabled"; + }; + + uart6: serial@50003000 { + compatible = "renesas,r9a06g032-uart", "renesas,rzn1-uart"; + reg = <0x50003000 0x400>; + interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&sysctrl R9A06G032_CLK_UART6>, <&sysctrl R9A06G032_HCLK_UART6>; + clock-names = "baudclk", "apb_pclk"; + status = "disabled"; + }; + + uart7: serial@50004000 { + compatible = "renesas,r9a06g032-uart", "renesas,rzn1-uart"; + reg = <0x50004000 0x400>; + interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&sysctrl R9A06G032_CLK_UART7>, <&sysctrl R9A06G032_HCLK_UART7>; + clock-names = "baudclk", "apb_pclk"; + status = "disabled"; + }; + + pinctrl: pinctrl@40067000 { + compatible = "renesas,r9a06g032-pinctrl", "renesas,rzn1-pinctrl"; + reg = <0x40067000 0x1000>, <0x51000000 0x480>; + clocks = <&sysctrl R9A06G032_HCLK_PINCONFIG>; + clock-names = "bus"; + status = "disabled"; + }; + + gic: interrupt-controller@44101000 { + compatible = "arm,gic-400", "arm,cortex-a7-gic"; + interrupt-controller; + #interrupt-cells = <3>; + reg = <0x44101000 0x1000>, /* Distributer */ + <0x44102000 0x2000>, /* CPU interface */ + <0x44104000 0x2000>, /* Virt interface control */ + <0x44106000 0x2000>; /* Virt CPU interface */ + interrupts = + <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_HIGH)>; + }; + }; + + timer { + compatible = "arm,cortex-a7-timer", + "arm,armv7-timer"; + interrupt-parent = <&gic>; + arm,cpu-registers-not-fw-configured; + always-on; + interrupts = + <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; + }; + + reboot { + compatible = "syscon-reboot"; + regmap = <&plat_regs>; + offset = <0x198>; /* sysctrl.RSTEN */ + mask = <0x40>; /* bit 6 = SWRST_REQ */ + value = <0x40>; + }; +}; diff --git a/include/dt-bindings/clock/r9a06g032-sysctrl.h b/include/dt-bindings/clock/r9a06g032-sysctrl.h new file mode 100644 index 0000000000..90c0f3dc1b --- /dev/null +++ b/include/dt-bindings/clock/r9a06g032-sysctrl.h @@ -0,0 +1,148 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * R9A06G032 sysctrl IDs + * + * Copyright (C) 2018 Renesas Electronics Europe Limited + * + * Michel Pollet michel.pollet@bp.renesas.com, buserror@gmail.com + */ + +#ifndef __DT_BINDINGS_R9A06G032_SYSCTRL_H__ +#define __DT_BINDINGS_R9A06G032_SYSCTRL_H__ + +#define R9A06G032_CLK_PLL_USB 1 +#define R9A06G032_CLK_48 1 /* AKA CLK_PLL_USB */ +#define R9A06G032_MSEBIS_CLK 3 /* AKA CLKOUT_D16 */ +#define R9A06G032_MSEBIM_CLK 3 /* AKA CLKOUT_D16 */ +#define R9A06G032_CLK_DDRPHY_PLLCLK 5 /* AKA CLKOUT_D1OR2 */ +#define R9A06G032_CLK50 6 /* AKA CLKOUT_D20 */ +#define R9A06G032_CLK25 7 /* AKA CLKOUT_D40 */ +#define R9A06G032_CLK125 9 /* AKA CLKOUT_D8 */ +#define R9A06G032_CLK_P5_PG1 17 /* AKA DIV_P5_PG */ +#define R9A06G032_CLK_REF_SYNC 21 /* AKA DIV_REF_SYNC */ +#define R9A06G032_CLK_25_PG4 26 +#define R9A06G032_CLK_25_PG5 27 +#define R9A06G032_CLK_25_PG6 28 +#define R9A06G032_CLK_25_PG7 29 +#define R9A06G032_CLK_25_PG8 30 +#define R9A06G032_CLK_ADC 31 +#define R9A06G032_CLK_ECAT100 32 +#define R9A06G032_CLK_HSR100 33 +#define R9A06G032_CLK_I2C0 34 +#define R9A06G032_CLK_I2C1 35 +#define R9A06G032_CLK_MII_REF 36 +#define R9A06G032_CLK_NAND 37 +#define R9A06G032_CLK_NOUSBP2_PG6 38 +#define R9A06G032_CLK_P1_PG2 39 +#define R9A06G032_CLK_P1_PG3 40 +#define R9A06G032_CLK_P1_PG4 41 +#define R9A06G032_CLK_P4_PG3 42 +#define R9A06G032_CLK_P4_PG4 43 +#define R9A06G032_CLK_P6_PG1 44 +#define R9A06G032_CLK_P6_PG2 45 +#define R9A06G032_CLK_P6_PG3 46 +#define R9A06G032_CLK_P6_PG4 47 +#define R9A06G032_CLK_PCI_USB 48 +#define R9A06G032_CLK_QSPI0 49 +#define R9A06G032_CLK_QSPI1 50 +#define R9A06G032_CLK_RGMII_REF 51 +#define R9A06G032_CLK_RMII_REF 52 +#define R9A06G032_CLK_SDIO0 53 +#define R9A06G032_CLK_SDIO1 54 +#define R9A06G032_CLK_SERCOS100 55 +#define R9A06G032_CLK_SLCD 56 +#define R9A06G032_CLK_SPI0 57 +#define R9A06G032_CLK_SPI1 58 +#define R9A06G032_CLK_SPI2 59 +#define R9A06G032_CLK_SPI3 60 +#define R9A06G032_CLK_SPI4 61 +#define R9A06G032_CLK_SPI5 62 +#define R9A06G032_CLK_SWITCH 63 +#define R9A06G032_HCLK_ECAT125 65 +#define R9A06G032_HCLK_PINCONFIG 66 +#define R9A06G032_HCLK_SERCOS 67 +#define R9A06G032_HCLK_SGPIO2 68 +#define R9A06G032_HCLK_SGPIO3 69 +#define R9A06G032_HCLK_SGPIO4 70 +#define R9A06G032_HCLK_TIMER0 71 +#define R9A06G032_HCLK_TIMER1 72 +#define R9A06G032_HCLK_USBF 73 +#define R9A06G032_HCLK_USBH 74 +#define R9A06G032_HCLK_USBPM 75 +#define R9A06G032_CLK_48_PG_F 76 +#define R9A06G032_CLK_48_PG4 77 +#define R9A06G032_CLK_DDRPHY_PCLK 81 /* AKA CLK_REF_SYNC_D4 */ +#define R9A06G032_CLK_FW 81 /* AKA CLK_REF_SYNC_D4 */ +#define R9A06G032_CLK_CRYPTO 81 /* AKA CLK_REF_SYNC_D4 */ +#define R9A06G032_CLK_A7MP 84 /* AKA DIV_CA7 */ +#define R9A06G032_HCLK_CAN0 85 +#define R9A06G032_HCLK_CAN1 86 +#define R9A06G032_HCLK_DELTASIGMA 87 +#define R9A06G032_HCLK_PWMPTO 88 +#define R9A06G032_HCLK_RSV 89 +#define R9A06G032_HCLK_SGPIO0 90 +#define R9A06G032_HCLK_SGPIO1 91 +#define R9A06G032_RTOS_MDC 92 +#define R9A06G032_CLK_CM3 93 +#define R9A06G032_CLK_DDRC 94 +#define R9A06G032_CLK_ECAT25 95 +#define R9A06G032_CLK_HSR50 96 +#define R9A06G032_CLK_HW_RTOS 97 +#define R9A06G032_CLK_SERCOS50 98 +#define R9A06G032_HCLK_ADC 99 +#define R9A06G032_HCLK_CM3 100 +#define R9A06G032_HCLK_CRYPTO_EIP150 101 +#define R9A06G032_HCLK_CRYPTO_EIP93 102 +#define R9A06G032_HCLK_DDRC 103 +#define R9A06G032_HCLK_DMA0 104 +#define R9A06G032_HCLK_DMA1 105 +#define R9A06G032_HCLK_GMAC0 106 +#define R9A06G032_HCLK_GMAC1 107 +#define R9A06G032_HCLK_GPIO0 108 +#define R9A06G032_HCLK_GPIO1 109 +#define R9A06G032_HCLK_GPIO2 110 +#define R9A06G032_HCLK_HSR 111 +#define R9A06G032_HCLK_I2C0 112 +#define R9A06G032_HCLK_I2C1 113 +#define R9A06G032_HCLK_LCD 114 +#define R9A06G032_HCLK_MSEBI_M 115 +#define R9A06G032_HCLK_MSEBI_S 116 +#define R9A06G032_HCLK_NAND 117 +#define R9A06G032_HCLK_PG_I 118 +#define R9A06G032_HCLK_PG19 119 +#define R9A06G032_HCLK_PG20 120 +#define R9A06G032_HCLK_PG3 121 +#define R9A06G032_HCLK_PG4 122 +#define R9A06G032_HCLK_QSPI0 123 +#define R9A06G032_HCLK_QSPI1 124 +#define R9A06G032_HCLK_ROM 125 +#define R9A06G032_HCLK_RTC 126 +#define R9A06G032_HCLK_SDIO0 127 +#define R9A06G032_HCLK_SDIO1 128 +#define R9A06G032_HCLK_SEMAP 129 +#define R9A06G032_HCLK_SPI0 130 +#define R9A06G032_HCLK_SPI1 131 +#define R9A06G032_HCLK_SPI2 132 +#define R9A06G032_HCLK_SPI3 133 +#define R9A06G032_HCLK_SPI4 134 +#define R9A06G032_HCLK_SPI5 135 +#define R9A06G032_HCLK_SWITCH 136 +#define R9A06G032_HCLK_SWITCH_RG 137 +#define R9A06G032_HCLK_UART0 138 +#define R9A06G032_HCLK_UART1 139 +#define R9A06G032_HCLK_UART2 140 +#define R9A06G032_HCLK_UART3 141 +#define R9A06G032_HCLK_UART4 142 +#define R9A06G032_HCLK_UART5 143 +#define R9A06G032_HCLK_UART6 144 +#define R9A06G032_HCLK_UART7 145 +#define R9A06G032_CLK_UART0 146 +#define R9A06G032_CLK_UART1 147 +#define R9A06G032_CLK_UART2 148 +#define R9A06G032_CLK_UART3 149 +#define R9A06G032_CLK_UART4 150 +#define R9A06G032_CLK_UART5 151 +#define R9A06G032_CLK_UART6 152 +#define R9A06G032_CLK_UART7 153 + +#endif /* __DT_BINDINGS_R9A06G032_SYSCTRL_H__ */
The RZ/N1 is a family of SoC devics from Renesas, featuring:
* ARM Cortex-A7 CPU (single/dual core) and/or Cortex-M3 * Integrated SRAM up to 6MB * Integrated gigabit ethernet switch * Optional DDR2/3 controller * I2C, SPI, UART, NAND, QSPI, SDIO, USB, CAN, RTC, LCD
Add basic support in the form of ARCH_RZN1 symbol.
arch/arm/Kconfig | 17 +++++++++++++++++ arch/arm/Makefile | 1 + arch/arm/mach-rzn1/Kconfig | 18 ++++++++++++++++++ arch/arm/mach-rzn1/Makefile | 3 +++ arch/arm/mach-rzn1/cpu_info.c | 20 ++++++++++++++++++++ 5 files changed, 59 insertions(+) create mode 100644 arch/arm/mach-rzn1/Kconfig create mode 100644 arch/arm/mach-rzn1/Makefile create mode 100644 arch/arm/mach-rzn1/cpu_info.c
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 949ebb46ba..e4a4aba4bc 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1083,6 +1083,21 @@ config ARCH_RMOBILE imply SYS_THUMB_BUILD imply ARCH_MISC_INIT if DISPLAY_CPUINFO
+config ARCH_RZN1 + bool "Reneasa RZ/N1 SoC" + select CLK + select CLK_RENESAS + select CLK_R9A06G032 + select DM + select DM_ETH + select DM_SERIAL + select PINCTRL + select PINCONF + select REGMAP + select SYSRESET + select SYSRESET_SYSCON + imply CMD_DM + config ARCH_SNAPDRAGON bool "Qualcomm Snapdragon SoCs" select ARM64 @@ -2243,6 +2258,8 @@ source "arch/arm/mach-owl/Kconfig"
source "arch/arm/mach-rmobile/Kconfig"
+source "arch/arm/mach-rzn1/Kconfig" + source "arch/arm/mach-meson/Kconfig"
source "arch/arm/mach-mediatek/Kconfig" diff --git a/arch/arm/Makefile b/arch/arm/Makefile index 1f4a1d5788..f8b6b35a47 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -76,6 +76,7 @@ machine-$(CONFIG_ARCH_ORION5X) += orion5x machine-$(CONFIG_ARCH_OWL) += owl machine-$(CONFIG_ARCH_RMOBILE) += rmobile machine-$(CONFIG_ARCH_ROCKCHIP) += rockchip +machine-$(CONFIG_ARCH_RZN1) += rzn1 machine-$(CONFIG_ARCH_S5PC1XX) += s5pc1xx machine-$(CONFIG_ARCH_SNAPDRAGON) += snapdragon machine-$(CONFIG_ARCH_SOCFPGA) += socfpga diff --git a/arch/arm/mach-rzn1/Kconfig b/arch/arm/mach-rzn1/Kconfig new file mode 100644 index 0000000000..707895874d --- /dev/null +++ b/arch/arm/mach-rzn1/Kconfig @@ -0,0 +1,18 @@ +if ARCH_RZN1 + +choice + prompt "Target Renesas RZ/N1 SoC select" + default RZN1 + +config RZN1 + bool "Renesas ARM SoCs RZ/N1 (32bit)" + select CPU_V7A + select ARMV7_SET_CORTEX_SMPEN if !SPL + select SPL_ARMV7_SET_CORTEX_SMPEN if SPL + +endchoice + +config SYS_SOC + default "rzn1" + +endif diff --git a/arch/arm/mach-rzn1/Makefile b/arch/arm/mach-rzn1/Makefile new file mode 100644 index 0000000000..b20f845c0f --- /dev/null +++ b/arch/arm/mach-rzn1/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-y = cpu_info.o diff --git a/arch/arm/mach-rzn1/cpu_info.c b/arch/arm/mach-rzn1/cpu_info.c new file mode 100644 index 0000000000..af02a26af8 --- /dev/null +++ b/arch/arm/mach-rzn1/cpu_info.c @@ -0,0 +1,20 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include <cpu_func.h> + +#if !CONFIG_IS_ENABLED(SYS_DCACHE_OFF) +void enable_caches(void) +{ + /* FIXME: when enabled, boot hangs at relocate_code */ + //dcache_enable(); +} +#endif + +#ifdef CONFIG_DISPLAY_CPUINFO +int print_cpuinfo(void) +{ + printf("CPU: Renesas Electronics RZ/N1\n"); + return 0; +} +#endif
Add support for Schneider Electronics LCES1 / LCES2 boards, which are based on the Reneasas RZ/N1 SoC devices.
The intention is to support both boards using a single defconfig, and to handle the differences at runtime.
Signed-off-by: Ralph Siemsen ralph.siemsen@linaro.org --- TODO: remove the debug UART settings from lces_defconfig.
arch/arm/dts/r9a06g032-rzn1d400-lces.dts | 50 +++ arch/arm/mach-rzn1/Kconfig | 14 + board/schneider/lces/Kconfig | 12 + board/schneider/lces/Makefile | 3 + board/schneider/lces/ddr_timing.c | 140 ++++++ .../lces/jedec_ddr3_2g_x16_1333h_500_cl8.h | 399 ++++++++++++++++++ board/schneider/lces/lces.c | 41 ++ configs/lces_defconfig | 26 ++ include/configs/lces.h | 22 + 9 files changed, 707 insertions(+) create mode 100644 arch/arm/dts/r9a06g032-rzn1d400-lces.dts create mode 100644 board/schneider/lces/Kconfig create mode 100644 board/schneider/lces/Makefile create mode 100644 board/schneider/lces/ddr_timing.c create mode 100644 board/schneider/lces/jedec_ddr3_2g_x16_1333h_500_cl8.h create mode 100644 board/schneider/lces/lces.c create mode 100644 configs/lces_defconfig create mode 100644 include/configs/lces.h
diff --git a/arch/arm/dts/r9a06g032-rzn1d400-lces.dts b/arch/arm/dts/r9a06g032-rzn1d400-lces.dts new file mode 100644 index 0000000000..7ba4dedc10 --- /dev/null +++ b/arch/arm/dts/r9a06g032-rzn1d400-lces.dts @@ -0,0 +1,50 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for Schneider LCES Board + * + * Based on r9a06g032-rzn1d400-db.dts + */ + +/dts-v1/; + +#include "r9a06g032.dtsi" +#include <dt-bindings/pinctrl/rzn1-pinctrl.h> + +/ { + model = "Schneider LCES Board"; + compatible = "schneider,rzn1d400-lces", "renesas,r9a06g032"; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + aliases { + serial0 = &uart0; + }; + + /* TODO: (RFS) only RZN1D has DDR */ + memory { + device_type = "memory"; + reg = <0x80000000 0x10000000>; + }; +}; + +&ddrctrl { + status = "okay"; +}; +&pinctrl { + status = "okay"; + + pins_uart0: pins_uart0 { + pinmux = < + RZN1_PINMUX(103, RZN1_FUNC_UART0_I) /* UART0_TXD */ + RZN1_PINMUX(104, RZN1_FUNC_UART0_I) /* UART0_RXD */ + >; + bias-disable; + }; +}; +&uart0 { + pinctrl-0 = <&pins_uart0>; + pinctrl-names = "default"; + status = "okay"; +}; diff --git a/arch/arm/mach-rzn1/Kconfig b/arch/arm/mach-rzn1/Kconfig index 707895874d..9bbafeb6db 100644 --- a/arch/arm/mach-rzn1/Kconfig +++ b/arch/arm/mach-rzn1/Kconfig @@ -15,4 +15,18 @@ endchoice config SYS_SOC default "rzn1"
+choice + prompt "Board select" + default TARGET_SCHNEIDER_LCES + +config TARGET_SCHNEIDER_LCES + bool "Schneider LCES board" + help + Support the Schneider LCES1 and LCES2 boards, which are based + on the Renesas RZ/N1 SoC. + +endchoice + +source "board/schneider/lces/Kconfig" + endif diff --git a/board/schneider/lces/Kconfig b/board/schneider/lces/Kconfig new file mode 100644 index 0000000000..6a1448bbd7 --- /dev/null +++ b/board/schneider/lces/Kconfig @@ -0,0 +1,12 @@ +if TARGET_SCHNEIDER_LCES + +config SYS_BOARD + default "lces" + +config SYS_VENDOR + default "schneider" + +config SYS_CONFIG_NAME + default "lces" + +endif diff --git a/board/schneider/lces/Makefile b/board/schneider/lces/Makefile new file mode 100644 index 0000000000..b8f6a8f53f --- /dev/null +++ b/board/schneider/lces/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-y := lces.o ddr_timing.o diff --git a/board/schneider/lces/ddr_timing.c b/board/schneider/lces/ddr_timing.c new file mode 100644 index 0000000000..8bc3fe7be4 --- /dev/null +++ b/board/schneider/lces/ddr_timing.c @@ -0,0 +1,140 @@ +// SPDX-License-Identifier: GPL-2.0 + +#include <asm/types.h> + +#include "jedec_ddr3_2g_x16_1333h_500_cl8.h" + +u32 ddr_00_87_async[] = { + DENALI_CTL_00_DATA, + DENALI_CTL_01_DATA, + DENALI_CTL_02_DATA, + DENALI_CTL_03_DATA, + DENALI_CTL_04_DATA, + DENALI_CTL_05_DATA, + DENALI_CTL_06_DATA, + DENALI_CTL_07_DATA, + DENALI_CTL_08_DATA, + DENALI_CTL_09_DATA, + + DENALI_CTL_10_DATA, + DENALI_CTL_11_DATA, + DENALI_CTL_12_DATA, + DENALI_CTL_13_DATA, + DENALI_CTL_14_DATA, + DENALI_CTL_15_DATA, + DENALI_CTL_16_DATA, + DENALI_CTL_17_DATA, + DENALI_CTL_18_DATA, + DENALI_CTL_19_DATA, + + DENALI_CTL_20_DATA, + DENALI_CTL_21_DATA, + DENALI_CTL_22_DATA, + DENALI_CTL_23_DATA, + DENALI_CTL_24_DATA, + DENALI_CTL_25_DATA, + DENALI_CTL_26_DATA, + DENALI_CTL_27_DATA, + DENALI_CTL_28_DATA, + DENALI_CTL_29_DATA, + + DENALI_CTL_30_DATA, + DENALI_CTL_31_DATA, + DENALI_CTL_32_DATA, + DENALI_CTL_33_DATA, + DENALI_CTL_34_DATA, + DENALI_CTL_35_DATA, + DENALI_CTL_36_DATA, + DENALI_CTL_37_DATA, + DENALI_CTL_38_DATA, + DENALI_CTL_39_DATA, + + DENALI_CTL_40_DATA, + DENALI_CTL_41_DATA, + DENALI_CTL_42_DATA, + DENALI_CTL_43_DATA, + DENALI_CTL_44_DATA, + DENALI_CTL_45_DATA, + DENALI_CTL_46_DATA, + DENALI_CTL_47_DATA, + DENALI_CTL_48_DATA, + DENALI_CTL_49_DATA, + + DENALI_CTL_50_DATA, + DENALI_CTL_51_DATA, + DENALI_CTL_52_DATA, + DENALI_CTL_53_DATA, + DENALI_CTL_54_DATA, + DENALI_CTL_55_DATA, + DENALI_CTL_56_DATA, + DENALI_CTL_57_DATA, + DENALI_CTL_58_DATA, + DENALI_CTL_59_DATA, + + DENALI_CTL_60_DATA, + DENALI_CTL_61_DATA, + DENALI_CTL_62_DATA, + DENALI_CTL_63_DATA, + DENALI_CTL_64_DATA, + DENALI_CTL_65_DATA, + DENALI_CTL_66_DATA, + DENALI_CTL_67_DATA, + DENALI_CTL_68_DATA, + DENALI_CTL_69_DATA, + + DENALI_CTL_70_DATA, + DENALI_CTL_71_DATA, + DENALI_CTL_72_DATA, + DENALI_CTL_73_DATA, + DENALI_CTL_74_DATA, + DENALI_CTL_75_DATA, + DENALI_CTL_76_DATA, + DENALI_CTL_77_DATA, + DENALI_CTL_78_DATA, + DENALI_CTL_79_DATA, + + DENALI_CTL_80_DATA, + DENALI_CTL_81_DATA, + DENALI_CTL_82_DATA, + DENALI_CTL_83_DATA, + DENALI_CTL_84_DATA, + DENALI_CTL_85_DATA, + DENALI_CTL_86_DATA, + DENALI_CTL_87_DATA, + DENALI_CTL_88_DATA, + DENALI_CTL_89_DATA, + + DENALI_CTL_90_DATA, + DENALI_CTL_91_DATA, + DENALI_CTL_92_DATA, +}; + +u32 ddr_350_374_async[] = { + DENALI_CTL_350_DATA, + DENALI_CTL_351_DATA, + DENALI_CTL_352_DATA, + DENALI_CTL_353_DATA, + DENALI_CTL_354_DATA, + DENALI_CTL_355_DATA, + DENALI_CTL_356_DATA, + DENALI_CTL_357_DATA, + DENALI_CTL_358_DATA, + DENALI_CTL_359_DATA, + + DENALI_CTL_360_DATA, + DENALI_CTL_361_DATA, + DENALI_CTL_362_DATA, + DENALI_CTL_363_DATA, + DENALI_CTL_364_DATA, + DENALI_CTL_365_DATA, + DENALI_CTL_366_DATA, + DENALI_CTL_367_DATA, + DENALI_CTL_368_DATA, + DENALI_CTL_369_DATA, + + DENALI_CTL_370_DATA, + DENALI_CTL_371_DATA, + DENALI_CTL_372_DATA, + DENALI_CTL_373_DATA, + DENALI_CTL_374_DATA, +}; diff --git a/board/schneider/lces/jedec_ddr3_2g_x16_1333h_500_cl8.h b/board/schneider/lces/jedec_ddr3_2g_x16_1333h_500_cl8.h new file mode 100644 index 0000000000..5c55518bc1 --- /dev/null +++ b/board/schneider/lces/jedec_ddr3_2g_x16_1333h_500_cl8.h @@ -0,0 +1,399 @@ + +/* **************************************************************** + * CADENCE Copyright (c) 2001-2011 * + * Cadence Design Systems, Inc. * + * All rights reserved. * + * * + ****************************************************************** + * The values calculated from this script are meant to be * + * representative programmings. The values may not reflect the * + * actual required programming for production use. Please * + * closely review all programmed values for technical accuracy * + * before use in production parts. * + ****************************************************************** + * + * Module: regconfig.h + * Documentation: Register programming header file + * + ****************************************************************** + ****************************************************************** + * WARNING: This file was automatically generated. Manual + * editing may result in undetermined behavior. + ****************************************************************** + ******************************************************************/ + +#define DENALI_CTL_00_DATA 0x00000600 +#define DENALI_CTL_01_DATA 0x00000000 +#define DENALI_CTL_02_DATA 0x00000000 +#define DENALI_CTL_03_DATA 0x00000000 +#define DENALI_CTL_04_DATA 0x00000000 +#define DENALI_CTL_05_DATA 0x00000000 +#define DENALI_CTL_06_DATA 0x00000000 +#define DENALI_CTL_07_DATA 0x00000005 +#define DENALI_CTL_08_DATA 0x000186a0 +#define DENALI_CTL_09_DATA 0x0003d090 +#define DENALI_CTL_10_DATA 0x00000000 +#define DENALI_CTL_11_DATA 0x10000200 +#define DENALI_CTL_12_DATA 0x04040006 +#define DENALI_CTL_13_DATA 0x04121904 +#define DENALI_CTL_14_DATA 0x04041707 +#define DENALI_CTL_15_DATA 0x00891c0c +#define DENALI_CTL_16_DATA 0x07000503 +#define DENALI_CTL_17_DATA 0x01010008 +#define DENALI_CTL_18_DATA 0x0007030f +#define DENALI_CTL_19_DATA 0x01000000 +#define DENALI_CTL_20_DATA 0x0f340050 +#define DENALI_CTL_21_DATA 0x00000005 +#define DENALI_CTL_22_DATA 0x000c0003 +#define DENALI_CTL_23_DATA 0x00000000 +#define DENALI_CTL_24_DATA 0x00550200 +#define DENALI_CTL_25_DATA 0x00010000 +#define DENALI_CTL_26_DATA 0x00050500 +#define DENALI_CTL_27_DATA 0x00000000 +#define DENALI_CTL_28_DATA 0x00000000 +#define DENALI_CTL_29_DATA 0x00000000 +#define DENALI_CTL_30_DATA 0x00000000 +#define DENALI_CTL_31_DATA 0x00084000 +#define DENALI_CTL_32_DATA 0x00080046 +#define DENALI_CTL_33_DATA 0x00000000 +#define DENALI_CTL_34_DATA 0x00460840 +#define DENALI_CTL_35_DATA 0x00000008 +#define DENALI_CTL_36_DATA 0x00010000 +#define DENALI_CTL_37_DATA 0x00000000 +#define DENALI_CTL_38_DATA 0x00000000 +#define DENALI_CTL_39_DATA 0x00000000 +#define DENALI_CTL_40_DATA 0x00000000 +#define DENALI_CTL_41_DATA 0x00000000 +#define DENALI_CTL_42_DATA 0x00000000 +#define DENALI_CTL_43_DATA 0x00000000 +#define DENALI_CTL_44_DATA 0x00000000 +#define DENALI_CTL_45_DATA 0x01000200 +#define DENALI_CTL_46_DATA 0x02000040 +#define DENALI_CTL_47_DATA 0x00000040 +#define DENALI_CTL_48_DATA 0x02000100 +#define DENALI_CTL_49_DATA 0xffff0a01 +#define DENALI_CTL_50_DATA 0x01010101 +#define DENALI_CTL_51_DATA 0x01010101 +#define DENALI_CTL_52_DATA 0x01030101 +#define DENALI_CTL_53_DATA 0x0c030000 +#define DENALI_CTL_54_DATA 0x00000000 +#define DENALI_CTL_55_DATA 0x00000100 +#define DENALI_CTL_56_DATA 0x00000000 +#define DENALI_CTL_57_DATA 0x00000000 +#define DENALI_CTL_58_DATA 0x00000000 +#define DENALI_CTL_59_DATA 0x00000000 +#define DENALI_CTL_60_DATA 0x00000000 +#define DENALI_CTL_61_DATA 0x00000000 +#define DENALI_CTL_62_DATA 0x01020000 +#define DENALI_CTL_63_DATA 0x06050201 +#define DENALI_CTL_64_DATA 0x02000106 +#define DENALI_CTL_65_DATA 0x00000000 +#define DENALI_CTL_66_DATA 0x02020202 +#define DENALI_CTL_67_DATA 0x00000200 +#define DENALI_CTL_68_DATA 0x00000000 +#define DENALI_CTL_69_DATA 0x00000000 +#define DENALI_CTL_70_DATA 0x00000000 +#define DENALI_CTL_71_DATA 0x00280d00 +#define DENALI_CTL_72_DATA 0x00000000 +#define DENALI_CTL_73_DATA 0x00000100 +#define DENALI_CTL_74_DATA 0x00010001 +#define DENALI_CTL_75_DATA 0x00000000 +#define DENALI_CTL_76_DATA 0x00000000 +#define DENALI_CTL_77_DATA 0x00000000 +#define DENALI_CTL_78_DATA 0x00000000 +#define DENALI_CTL_79_DATA 0x00222200 +#define DENALI_CTL_80_DATA 0x00000001 +#define DENALI_CTL_81_DATA 0x00000000 +#define DENALI_CTL_82_DATA 0x00000000 +#define DENALI_CTL_83_DATA 0x00012222 +#define DENALI_CTL_84_DATA 0x00000000 +#define DENALI_CTL_85_DATA 0x00000000 +#define DENALI_CTL_86_DATA 0x00222200 +#define DENALI_CTL_87_DATA 0x02020001 +#define DENALI_CTL_88_DATA 0x00020200 +#define DENALI_CTL_89_DATA 0x02000202 +#define DENALI_CTL_90_DATA 0x01000002 +#define DENALI_CTL_91_DATA 0x00000000 +#define DENALI_CTL_92_DATA 0x0003ffff +#define DENALI_CTL_93_DATA 0x00000000 +#define DENALI_CTL_94_DATA 0x0003ffff +#define DENALI_CTL_95_DATA 0x00000000 +#define DENALI_CTL_96_DATA 0x0003ffff +#define DENALI_CTL_97_DATA 0x00000000 +#define DENALI_CTL_98_DATA 0x0003ffff +#define DENALI_CTL_99_DATA 0x00000000 +#define DENALI_CTL_100_DATA 0x0003ffff +#define DENALI_CTL_101_DATA 0x00000000 +#define DENALI_CTL_102_DATA 0x0003ffff +#define DENALI_CTL_103_DATA 0x00000000 +#define DENALI_CTL_104_DATA 0x0003ffff +#define DENALI_CTL_105_DATA 0x00000000 +#define DENALI_CTL_106_DATA 0x0003ffff +#define DENALI_CTL_107_DATA 0x00000000 +#define DENALI_CTL_108_DATA 0x0003ffff +#define DENALI_CTL_109_DATA 0x00000000 +#define DENALI_CTL_110_DATA 0x0003ffff +#define DENALI_CTL_111_DATA 0x00000000 +#define DENALI_CTL_112_DATA 0x0003ffff +#define DENALI_CTL_113_DATA 0x00000000 +#define DENALI_CTL_114_DATA 0x0003ffff +#define DENALI_CTL_115_DATA 0x00000000 +#define DENALI_CTL_116_DATA 0x0003ffff +#define DENALI_CTL_117_DATA 0x00000000 +#define DENALI_CTL_118_DATA 0x0003ffff +#define DENALI_CTL_119_DATA 0x00000000 +#define DENALI_CTL_120_DATA 0x0003ffff +#define DENALI_CTL_121_DATA 0x00000000 +#define DENALI_CTL_122_DATA 0x0003ffff +#define DENALI_CTL_123_DATA 0x00000000 +#define DENALI_CTL_124_DATA 0x0003ffff +#define DENALI_CTL_125_DATA 0x00000000 +#define DENALI_CTL_126_DATA 0x0003ffff +#define DENALI_CTL_127_DATA 0x00000000 +#define DENALI_CTL_128_DATA 0x0003ffff +#define DENALI_CTL_129_DATA 0x00000000 +#define DENALI_CTL_130_DATA 0x0003ffff +#define DENALI_CTL_131_DATA 0x00000000 +#define DENALI_CTL_132_DATA 0x0003ffff +#define DENALI_CTL_133_DATA 0x00000000 +#define DENALI_CTL_134_DATA 0x0003ffff +#define DENALI_CTL_135_DATA 0x00000000 +#define DENALI_CTL_136_DATA 0x0003ffff +#define DENALI_CTL_137_DATA 0x00000000 +#define DENALI_CTL_138_DATA 0x0003ffff +#define DENALI_CTL_139_DATA 0x00000000 +#define DENALI_CTL_140_DATA 0x0003ffff +#define DENALI_CTL_141_DATA 0x00000000 +#define DENALI_CTL_142_DATA 0x0003ffff +#define DENALI_CTL_143_DATA 0x00000000 +#define DENALI_CTL_144_DATA 0x0003ffff +#define DENALI_CTL_145_DATA 0x00000000 +#define DENALI_CTL_146_DATA 0x0003ffff +#define DENALI_CTL_147_DATA 0x00000000 +#define DENALI_CTL_148_DATA 0x0003ffff +#define DENALI_CTL_149_DATA 0x00000000 +#define DENALI_CTL_150_DATA 0x0003ffff +#define DENALI_CTL_151_DATA 0x00000000 +#define DENALI_CTL_152_DATA 0x0003ffff +#define DENALI_CTL_153_DATA 0x00000000 +#define DENALI_CTL_154_DATA 0x0003ffff +#define DENALI_CTL_155_DATA 0x00000000 +#define DENALI_CTL_156_DATA 0x0003ffff +#define DENALI_CTL_157_DATA 0x00000000 +#define DENALI_CTL_158_DATA 0x0003ffff +#define DENALI_CTL_159_DATA 0x00000000 +#define DENALI_CTL_160_DATA 0x0003ffff +#define DENALI_CTL_161_DATA 0x00000000 +#define DENALI_CTL_162_DATA 0x0003ffff +#define DENALI_CTL_163_DATA 0x00000000 +#define DENALI_CTL_164_DATA 0x0003ffff +#define DENALI_CTL_165_DATA 0x00000000 +#define DENALI_CTL_166_DATA 0x0003ffff +#define DENALI_CTL_167_DATA 0x00000000 +#define DENALI_CTL_168_DATA 0x0003ffff +#define DENALI_CTL_169_DATA 0x00000000 +#define DENALI_CTL_170_DATA 0x0003ffff +#define DENALI_CTL_171_DATA 0x00000000 +#define DENALI_CTL_172_DATA 0x0003ffff +#define DENALI_CTL_173_DATA 0x00000000 +#define DENALI_CTL_174_DATA 0x0003ffff +#define DENALI_CTL_175_DATA 0x00000000 +#define DENALI_CTL_176_DATA 0x0003ffff +#define DENALI_CTL_177_DATA 0x00000000 +#define DENALI_CTL_178_DATA 0x0003ffff +#define DENALI_CTL_179_DATA 0x00000000 +#define DENALI_CTL_180_DATA 0x0003ffff +#define DENALI_CTL_181_DATA 0x00000000 +#define DENALI_CTL_182_DATA 0x0003ffff +#define DENALI_CTL_183_DATA 0x00000000 +#define DENALI_CTL_184_DATA 0x0003ffff +#define DENALI_CTL_185_DATA 0x00000000 +#define DENALI_CTL_186_DATA 0x0003ffff +#define DENALI_CTL_187_DATA 0x00000000 +#define DENALI_CTL_188_DATA 0x0003ffff +#define DENALI_CTL_189_DATA 0x00000000 +#define DENALI_CTL_190_DATA 0x0003ffff +#define DENALI_CTL_191_DATA 0x00000000 +#define DENALI_CTL_192_DATA 0x0003ffff +#define DENALI_CTL_193_DATA 0x00000000 +#define DENALI_CTL_194_DATA 0x0003ffff +#define DENALI_CTL_195_DATA 0x00000000 +#define DENALI_CTL_196_DATA 0x0003ffff +#define DENALI_CTL_197_DATA 0x00000000 +#define DENALI_CTL_198_DATA 0x0003ffff +#define DENALI_CTL_199_DATA 0x00000000 +#define DENALI_CTL_200_DATA 0x0003ffff +#define DENALI_CTL_201_DATA 0x00000000 +#define DENALI_CTL_202_DATA 0x0003ffff +#define DENALI_CTL_203_DATA 0x00000000 +#define DENALI_CTL_204_DATA 0x0003ffff +#define DENALI_CTL_205_DATA 0x00000000 +#define DENALI_CTL_206_DATA 0x0003ffff +#define DENALI_CTL_207_DATA 0x00000000 +#define DENALI_CTL_208_DATA 0x0003ffff +#define DENALI_CTL_209_DATA 0x00000000 +#define DENALI_CTL_210_DATA 0x0003ffff +#define DENALI_CTL_211_DATA 0x00000000 +#define DENALI_CTL_212_DATA 0x0003ffff +#define DENALI_CTL_213_DATA 0x00000000 +#define DENALI_CTL_214_DATA 0x0003ffff +#define DENALI_CTL_215_DATA 0x00000000 +#define DENALI_CTL_216_DATA 0x0003ffff +#define DENALI_CTL_217_DATA 0x00000000 +#define DENALI_CTL_218_DATA 0x0303ffff +#define DENALI_CTL_219_DATA 0xffffffff +#define DENALI_CTL_220_DATA 0x00030f0f +#define DENALI_CTL_221_DATA 0xffffffff +#define DENALI_CTL_222_DATA 0x00030f0f +#define DENALI_CTL_223_DATA 0xffffffff +#define DENALI_CTL_224_DATA 0x00030f0f +#define DENALI_CTL_225_DATA 0xffffffff +#define DENALI_CTL_226_DATA 0x00030f0f +#define DENALI_CTL_227_DATA 0xffffffff +#define DENALI_CTL_228_DATA 0x00030f0f +#define DENALI_CTL_229_DATA 0xffffffff +#define DENALI_CTL_230_DATA 0x00030f0f +#define DENALI_CTL_231_DATA 0xffffffff +#define DENALI_CTL_232_DATA 0x00030f0f +#define DENALI_CTL_233_DATA 0xffffffff +#define DENALI_CTL_234_DATA 0x00030f0f +#define DENALI_CTL_235_DATA 0xffffffff +#define DENALI_CTL_236_DATA 0x00030f0f +#define DENALI_CTL_237_DATA 0xffffffff +#define DENALI_CTL_238_DATA 0x00030f0f +#define DENALI_CTL_239_DATA 0xffffffff +#define DENALI_CTL_240_DATA 0x00030f0f +#define DENALI_CTL_241_DATA 0xffffffff +#define DENALI_CTL_242_DATA 0x00030f0f +#define DENALI_CTL_243_DATA 0xffffffff +#define DENALI_CTL_244_DATA 0x00030f0f +#define DENALI_CTL_245_DATA 0xffffffff +#define DENALI_CTL_246_DATA 0x00030f0f +#define DENALI_CTL_247_DATA 0xffffffff +#define DENALI_CTL_248_DATA 0x00030f0f +#define DENALI_CTL_249_DATA 0xffffffff +#define DENALI_CTL_250_DATA 0x00030f0f +#define DENALI_CTL_251_DATA 0xffffffff +#define DENALI_CTL_252_DATA 0x00030f0f +#define DENALI_CTL_253_DATA 0xffffffff +#define DENALI_CTL_254_DATA 0x00030f0f +#define DENALI_CTL_255_DATA 0xffffffff +#define DENALI_CTL_256_DATA 0x00030f0f +#define DENALI_CTL_257_DATA 0xffffffff +#define DENALI_CTL_258_DATA 0x00030f0f +#define DENALI_CTL_259_DATA 0xffffffff +#define DENALI_CTL_260_DATA 0x00030f0f +#define DENALI_CTL_261_DATA 0xffffffff +#define DENALI_CTL_262_DATA 0x00030f0f +#define DENALI_CTL_263_DATA 0xffffffff +#define DENALI_CTL_264_DATA 0x00030f0f +#define DENALI_CTL_265_DATA 0xffffffff +#define DENALI_CTL_266_DATA 0x00030f0f +#define DENALI_CTL_267_DATA 0xffffffff +#define DENALI_CTL_268_DATA 0x00030f0f +#define DENALI_CTL_269_DATA 0xffffffff +#define DENALI_CTL_270_DATA 0x00030f0f +#define DENALI_CTL_271_DATA 0xffffffff +#define DENALI_CTL_272_DATA 0x00030f0f +#define DENALI_CTL_273_DATA 0xffffffff +#define DENALI_CTL_274_DATA 0x00030f0f +#define DENALI_CTL_275_DATA 0xffffffff +#define DENALI_CTL_276_DATA 0x00030f0f +#define DENALI_CTL_277_DATA 0xffffffff +#define DENALI_CTL_278_DATA 0x00030f0f +#define DENALI_CTL_279_DATA 0xffffffff +#define DENALI_CTL_280_DATA 0x00030f0f +#define DENALI_CTL_281_DATA 0xffffffff +#define DENALI_CTL_282_DATA 0x00030f0f +#define DENALI_CTL_283_DATA 0xffffffff +#define DENALI_CTL_284_DATA 0x00030f0f +#define DENALI_CTL_285_DATA 0xffffffff +#define DENALI_CTL_286_DATA 0x00030f0f +#define DENALI_CTL_287_DATA 0xffffffff +#define DENALI_CTL_288_DATA 0x00030f0f +#define DENALI_CTL_289_DATA 0xffffffff +#define DENALI_CTL_290_DATA 0x00030f0f +#define DENALI_CTL_291_DATA 0xffffffff +#define DENALI_CTL_292_DATA 0x00030f0f +#define DENALI_CTL_293_DATA 0xffffffff +#define DENALI_CTL_294_DATA 0x00030f0f +#define DENALI_CTL_295_DATA 0xffffffff +#define DENALI_CTL_296_DATA 0x00030f0f +#define DENALI_CTL_297_DATA 0xffffffff +#define DENALI_CTL_298_DATA 0x00030f0f +#define DENALI_CTL_299_DATA 0xffffffff +#define DENALI_CTL_300_DATA 0x00030f0f +#define DENALI_CTL_301_DATA 0xffffffff +#define DENALI_CTL_302_DATA 0x00030f0f +#define DENALI_CTL_303_DATA 0xffffffff +#define DENALI_CTL_304_DATA 0x00030f0f +#define DENALI_CTL_305_DATA 0xffffffff +#define DENALI_CTL_306_DATA 0x00030f0f +#define DENALI_CTL_307_DATA 0xffffffff +#define DENALI_CTL_308_DATA 0x00030f0f +#define DENALI_CTL_309_DATA 0xffffffff +#define DENALI_CTL_310_DATA 0x00030f0f +#define DENALI_CTL_311_DATA 0xffffffff +#define DENALI_CTL_312_DATA 0x00030f0f +#define DENALI_CTL_313_DATA 0xffffffff +#define DENALI_CTL_314_DATA 0x00030f0f +#define DENALI_CTL_315_DATA 0xffffffff +#define DENALI_CTL_316_DATA 0x00030f0f +#define DENALI_CTL_317_DATA 0xffffffff +#define DENALI_CTL_318_DATA 0x00030f0f +#define DENALI_CTL_319_DATA 0xffffffff +#define DENALI_CTL_320_DATA 0x00030f0f +#define DENALI_CTL_321_DATA 0xffffffff +#define DENALI_CTL_322_DATA 0x00030f0f +#define DENALI_CTL_323_DATA 0xffffffff +#define DENALI_CTL_324_DATA 0x00030f0f +#define DENALI_CTL_325_DATA 0xffffffff +#define DENALI_CTL_326_DATA 0x00030f0f +#define DENALI_CTL_327_DATA 0xffffffff +#define DENALI_CTL_328_DATA 0x00030f0f +#define DENALI_CTL_329_DATA 0xffffffff +#define DENALI_CTL_330_DATA 0x00030f0f +#define DENALI_CTL_331_DATA 0xffffffff +#define DENALI_CTL_332_DATA 0x00030f0f +#define DENALI_CTL_333_DATA 0xffffffff +#define DENALI_CTL_334_DATA 0x00030f0f +#define DENALI_CTL_335_DATA 0xffffffff +#define DENALI_CTL_336_DATA 0x00030f0f +#define DENALI_CTL_337_DATA 0xffffffff +#define DENALI_CTL_338_DATA 0x00030f0f +#define DENALI_CTL_339_DATA 0xffffffff +#define DENALI_CTL_340_DATA 0x00030f0f +#define DENALI_CTL_341_DATA 0xffffffff +#define DENALI_CTL_342_DATA 0x00030f0f +#define DENALI_CTL_343_DATA 0xffffffff +#define DENALI_CTL_344_DATA 0x00030f0f +#define DENALI_CTL_345_DATA 0xffffffff +#define DENALI_CTL_346_DATA 0x32030f0f +#define DENALI_CTL_347_DATA 0x01320001 +#define DENALI_CTL_348_DATA 0x00013200 +#define DENALI_CTL_349_DATA 0x00000132 +#define DENALI_CTL_350_DATA 0x00000000 +#define DENALI_CTL_351_DATA 0x000d0000 +#define DENALI_CTL_352_DATA 0x1e680000 +#define DENALI_CTL_353_DATA 0x02000200 +#define DENALI_CTL_354_DATA 0x02000200 +#define DENALI_CTL_355_DATA 0x00001e68 +#define DENALI_CTL_356_DATA 0x00009808 +#define DENALI_CTL_357_DATA 0x00020608 +#define DENALI_CTL_358_DATA 0x000a0a01 +#define DENALI_CTL_359_DATA 0x00000000 +#define DENALI_CTL_360_DATA 0x00000000 +#define DENALI_CTL_361_DATA 0x04038000 +#define DENALI_CTL_362_DATA 0x07030a07 +#define DENALI_CTL_363_DATA 0x00ffff22 +#define DENALI_CTL_364_DATA 0x000f0010 +#define DENALI_CTL_365_DATA 0x00000000 +#define DENALI_CTL_366_DATA 0x00000000 +#define DENALI_CTL_367_DATA 0x00000000 +#define DENALI_CTL_368_DATA 0x00000000 +#define DENALI_CTL_369_DATA 0x00000000 +#define DENALI_CTL_370_DATA 0x00000204 +#define DENALI_CTL_371_DATA 0x00000000 +#define DENALI_CTL_372_DATA 0x01000001 +#define DENALI_CTL_373_DATA 0x00000001 +#define DENALI_CTL_374_DATA 0x00000000 diff --git a/board/schneider/lces/lces.c b/board/schneider/lces/lces.c new file mode 100644 index 0000000000..e520b1e9e4 --- /dev/null +++ b/board/schneider/lces/lces.c @@ -0,0 +1,41 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include <dm.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + gd->bd->bi_boot_params = (CONFIG_SYS_SDRAM_BASE + 0x100); + + return 0; +} + +int dram_init(void) +{ + struct udevice *dev; + int err; + + /* This will end up calling cadence_ddr_probe() */ + err = uclass_get_device(UCLASS_RAM, 0, &dev); + if (err) { + debug("DRAM init failed: %d\n", err); + return err; + } + + // FIXME: checkpatch says to use dev_read_... + if (fdtdec_setup_mem_size_base() != 0) + return -EINVAL; + + return 0; +} + +int dram_init_banksize(void) +{ + // FIXME: checkpatch says to use dev_read_... + fdtdec_setup_memory_banksize(); + + return 0; +} diff --git a/configs/lces_defconfig b/configs/lces_defconfig new file mode 100644 index 0000000000..c10f1a2133 --- /dev/null +++ b/configs/lces_defconfig @@ -0,0 +1,26 @@ +CONFIG_ARM=y +CONFIG_SYS_ARCH_TIMER=y +CONFIG_SYS_THUMB_BUILD=y +CONFIG_ARCH_RZN1=y +CONFIG_SYS_TEXT_BASE=0x20040000 +CONFIG_SYS_MALLOC_LEN=0xb0000 +CONFIG_SYS_MALLOC_F_LEN=0x800 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEFAULT_DEVICE_TREE="r9a06g032-rzn1d400-lces" +CONFIG_DEBUG_UART_BASE=0x40060000 +CONFIG_DEBUG_UART_CLOCK=20000000 +CONFIG_SYS_LOAD_ADDR=0x80008000 +CONFIG_DEBUG_UART=y +CONFIG_SYS_MEMTEST_START=0x80000000 +CONFIG_SYS_MEMTEST_END=0x8fffffff +CONFIG_CMD_MEMTEST=y +CONFIG_SYS_ALT_MEMTEST=y +# CONFIG_SYS_ALT_MEMTEST_BITFLIP is not set +CONFIG_CMD_CLK=y +CONFIG_OF_CONTROL=y +CONFIG_RAM=y +CONFIG_CADENCE_DDR_CTRL=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_SYS_NS16550=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/lces.h b/include/configs/lces.h new file mode 100644 index 0000000000..37e9854758 --- /dev/null +++ b/include/configs/lces.h @@ -0,0 +1,22 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Configuration settings for the Schneider LCES board + */ + +#ifndef __LCES_H +#define __LCES_H + +/* Internal RAM */ +#define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 +#define CONFIG_SYS_INIT_RAM_SIZE (1 * 1024 * 1024) + +/* DDR */ +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#define CONFIG_SYS_SDRAM_SIZE (256 * 1024 * 1024) + +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) + +/* Serial port is memory-mapped as 32-bit registers */ +#define CONFIG_SYS_NS16550_MEM32 + +#endif /* __LCES2_H */
Renesas RZ/N1 devices contain BootROM code that loads a custom SPKG image from QSPI, NAND or USB DFU. This tool converts a binary image into an SPKG.
SPKGs can optionally be signed, however this tool does not currently support signed SPKGs.
Signed-off-by: Michel Pollet michel.pollet@bp.renesas.com Signed-off-by: Ralph Siemsen ralph.siemsen@linaro.org --- This tool could possibly be incorporated into mkimage / imagetools. However it is unclear how to handle the extra commandline parameters (NAND ECC settings, etc). So for now it is stand-alone tool.
tools/Makefile | 2 + tools/spkg_header.h | 49 +++++++ tools/spkg_utility.c | 306 +++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 357 insertions(+) create mode 100644 tools/spkg_header.h create mode 100644 tools/spkg_utility.c
diff --git a/tools/Makefile b/tools/Makefile index 005e7362a3..c5dc92a13f 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -68,6 +68,8 @@ HOSTCFLAGS_img2srec.o := -pedantic hostprogs-$(CONFIG_XWAY_SWAP_BYTES) += xway-swap-bytes HOSTCFLAGS_xway-swap-bytes.o := -pedantic
+hostprogs-$(CONFIG_ARCH_RZN1) += spkg_utility + hostprogs-y += mkenvimage mkenvimage-objs := mkenvimage.o os_support.o lib/crc32.o
diff --git a/tools/spkg_header.h b/tools/spkg_header.h new file mode 100644 index 0000000000..029930cbf8 --- /dev/null +++ b/tools/spkg_header.h @@ -0,0 +1,49 @@ +/* SPDX-License-Identifier: BSD-2-Clause */ +/* + * Renesas RZ/N1 Linux tools: Package Table format + * (C) 2015-2016 Renesas Electronics Europe, LTD + * All rights reserved. + */ + +#ifndef _SKGT_HEADER_H_ +#define _SKGT_HEADER_H_ + +#define SPKG_HEADER_SIGNATURE (('R'<<0)|('Z'<<8)|('N'<<16)|('1'<<24)) +#define SPKG_HEADER_COUNT 8 +#define SPKG_BLP_SIZE 264 + +#define SPKG_HEADER_SIZE 24 +#define SPKG_HEADER_SIZE_ALL (SPKG_HEADER_SIZE * SPKG_HEADER_COUNT) +#define SPKG_HEADER_CRC_SIZE 4 + +/* Index into SPKG */ +#define INDEX_BLP_START SPKG_HEADER_SIZE_ALL +#define INDEX_IMAGE_START (INDEX_BLP_START + SPKG_BLP_SIZE) + +/* Flags, not supported by ROM code, only used for U-Boot SPL */ +enum { + SPKG_CODE_NONSEC_BIT = 0, + SPKG_CODE_HYP_BIT, +}; + +/* SPKG header */ +struct spkg_hdr { + uint32_t signature; + uint8_t version; + uint8_t ecc; + uint8_t ecc_scheme; + uint8_t ecc_bytes; + uint32_t payload_length; /* only HIGHER 24 bits */ + uint32_t load_address; + uint32_t execution_offset; + uint32_t crc; /* of this header */ +} __attribute__((packed)); + +struct spkg_file { + struct spkg_hdr header[SPKG_HEADER_COUNT]; + uint8_t blp[SPKG_BLP_SIZE]; + uint8_t data[0]; + /* then the CRC */ +} __attribute__((packed)); + +#endif diff --git a/tools/spkg_utility.c b/tools/spkg_utility.c new file mode 100644 index 0000000000..235e23e0f1 --- /dev/null +++ b/tools/spkg_utility.c @@ -0,0 +1,306 @@ +// SPDX-License-Identifier: BSD-2-Clause +/* + * This is a utility to create a SPKG file. + * It packages the binary code into the SPKG. + * + * (C) Copyright 2016 Renesas Electronics Europe Ltd + */ + +#include <stdio.h> +#include <string.h> +#include <stdlib.h> +#include <stdint.h> +#include <string.h> + +#include "spkg_header.h" + +/* For Windows compatibility */ +#ifndef htole32 +#if __BYTE_ORDER == __LITTLE_ENDIAN + #define htole32(x) (x) +#elif __BYTE_ORDER == __BIG_ENDIAN + #define htole32(x) __builtin_bswap32((uint32_t)(x)) +#endif +#endif + +#define MAX_PATH 300 + +// Note: Order of bit fields is not used, this is purely just holding the SPKG information. +struct spkg_header { + char input[MAX_PATH]; + char output[MAX_PATH + 5]; + unsigned int version:4; + unsigned int ecc_enable:1; + unsigned int ecc_block_size:2; + unsigned int ecc_scheme:3; + unsigned int ecc_bytes:8; + unsigned int dummy_blp_length:10; + unsigned int payload_length:24; + unsigned int spl_nonsec:1; + unsigned int spl_hyp:1; + unsigned int load_address; + unsigned int execution_offset; + uint32_t padding; +}; + +struct spkg_header g_header = { + .version = 1, + .padding = 256, +}; + +int verbose; + +static uint32_t crc32(const uint8_t *message, uint32_t l) +{ + uint32_t crc = ~0; + + while (l--) { + uint32_t byte = *message++; // Get next byte. + + crc = crc ^ byte; + for (int8_t j = 7; j >= 0; j--) { // Do eight times. + uint32_t mask = -(crc & 1); + + crc = (crc >> 1) ^ (0xEDB88320 & mask); + } + } + return ~crc; +} + +static int spkg_write(struct spkg_header *h, FILE *file_input, FILE *file_SPKG) +{ + int i; + uint32_t length_inputfile; + uint32_t length_read; + uint32_t length_written; + uint32_t length_total; + uint32_t padding = 0; + uint8_t *data, *start; + uint32_t crc; + + /* Calculate length of input file */ + fseek(file_input, 0, SEEK_END); // seek to end of file + length_inputfile = ftell(file_input); // get current file pointer + fseek(file_input, 0, SEEK_SET); // seek back to beginning of file + + /* Set payload_length field. */ + h->payload_length = + length_inputfile + h->dummy_blp_length + SPKG_HEADER_CRC_SIZE; + + /* Calculate total length of SPKG */ + length_total = + (SPKG_HEADER_SIZE * SPKG_HEADER_COUNT) + h->dummy_blp_length + + length_inputfile + SPKG_HEADER_CRC_SIZE; + padding = h->padding ? h->padding - (length_total % h->padding) : 0; + length_total += padding; + /* Padding needs to be part of the payload size, otherwise the ROM DFU + * refuses to accept the extra bytes and return and error. + */ + h->payload_length += padding; + + printf("Addr: 0x%08x ", h->load_address); + printf("In: %8d ", length_inputfile); + printf("padding to %3dKB: %6d ", h->padding / 1024, padding); + printf("Total: 0x%08x ", length_total); + printf("%s\n", h->output); + + /* Create and zero array for SPKG */ + data = malloc(length_total); + memset(data, 0, length_total); + + /* Fill the SPKG with the headers */ + { + struct spkg_hdr head = { + .signature = SPKG_HEADER_SIGNATURE, + .version = h->version, + .ecc = (h->ecc_enable << 5) | (h->ecc_block_size << 1), + .ecc_scheme = h->ecc_scheme, + .ecc_bytes = h->ecc_bytes, + .payload_length = htole32((h->payload_length << 8) | + (h->spl_nonsec << SPKG_CODE_NONSEC_BIT) | + (h->spl_hyp << SPKG_CODE_HYP_BIT)), + .load_address = htole32(h->load_address), + .execution_offset = htole32(h->execution_offset), + }; + + head.crc = crc32((uint8_t *)&head, sizeof(head) - SPKG_HEADER_CRC_SIZE); + for (i = 0; i < SPKG_HEADER_COUNT; i++) + ((struct spkg_hdr *)data)[i] = head; + } + + start = data + INDEX_BLP_START; + + /* Fill the SPKG with the Dummy BLp */ + for (i = 0; i < h->dummy_blp_length; i++) + *start++ = 0x88; + /* Fill the SPKG with the data from the code file. */ + length_read = + fread(start, sizeof(char), length_inputfile, + file_input); + + if (length_read != length_inputfile) { + fprintf(stderr, "Error reading %s: ferror=%d, feof=%d\n", + h->input, ferror(file_input), feof(file_input)); + + return -1; + } + /* fill padding with flash friendly one bits */ + memset(start + length_inputfile + SPKG_HEADER_CRC_SIZE, 0xff, padding); + + /* Add Payload CRC */ + crc = crc32(&data[INDEX_BLP_START], + h->dummy_blp_length + length_inputfile + padding); + + start += length_inputfile + padding; + start[0] = crc; + start[1] = crc >> 8; + start[2] = crc >> 16; + start[3] = crc >> 24; + + /* Write the completed SKPG to file */ + length_written = fwrite(data, sizeof(char), length_total, file_SPKG); + + if (length_written != length_total) { + fprintf(stderr, "Error writing to %s\n", h->output); + return -1; + } + + return 0; +} + +const char *usage = + "%s\n" + " [-i <filename>] : input file\n" + " [-o <filename>] : output file\n" + " [--load_address <hex constant>] : code load address\n" + " [--execution_offset <hex constant>] : starting offset\n" + " [--nand_ecc_enable] : Enable nand ECC\n" + " [--nand_ecc_blksize <hex constant>] : Block size code\n" + " 0=256 bytes, 1=512 bytes, 2=1024 bytes\n" + " [--nand_ecc_scheme <hex constant>] : ECC scheme code\n" + " 0=BCH2 1=BCH4 2=BCH8 3=BCH16 4=BCH24 5=BCH32\n" + " [--add_dummy_blp] : Add a passthru BLP\n" + " [--spl_nonsec] : Code package run in NONSEC\n" + " [--spl_hyp] : Code package run in HYP (and NONSEC)\n" + " [--padding <value>[K|M]] : Pass SPKG to <value> size block\n" + ; + +static int spkg_parse_option(struct spkg_header *h, const char *name, + const char *sz, uint32_t value) +{ +// printf("%s %s=%s %08x\n", __func__, name, sz, value); + if (!strcmp("file_input", name) || !strcmp("i", name)) { + strncpy(h->input, sz, sizeof(h->input) - 1); + h->input[sizeof(h->input) - 1] = 0; + } else if (!strcmp("file_output", name) || !strcmp("o", name)) { + strncpy(h->output, sz, sizeof(h->output) - 1); + h->output[sizeof(h->output) - 1] = 0; + } else if (!strcmp("version", name)) { + h->version = value; + } else if (!strcmp("load_address", name)) { + h->load_address = value; + } else if (!strcmp("execution_offset", name)) { + h->execution_offset = value; + } else if (!strcmp("nand_ecc_enable", name)) { + h->ecc_enable = value; + } else if (!strcmp("nand_ecc_blksize", name)) { + h->ecc_block_size = value; + } else if (!strcmp("nand_ecc_scheme", name)) { + h->ecc_scheme = value; + } else if (!strcmp("nand_bytes_per_ecc_block", name)) { + h->ecc_bytes = value; + } else if (!strcmp("add_dummy_blp", name)) { + h->dummy_blp_length = value ? SPKG_BLP_SIZE : 0; + } else if (!strcmp("spl_nonsec", name)) { + h->spl_nonsec = !!value; + } else if (!strcmp("spl_hyp", name)) { + h->spl_hyp = !!value; + } else if (!strcmp("help", name) || !strcmp("h", name)) { + fprintf(stderr, usage, "spkg_utility"); + exit(0); + } else if (!strcmp("padding", name) && sz && value) { + if (strchr(sz, 'K')) + h->padding = value * 1024; + else if (strchr(sz, 'M')) + h->padding = value * 1024 * 1024; + else + h->padding = value; + } else { + return -1; + } + + return 0; +} + +int main(int argc, char *argv[]) +{ + FILE *file_SPKG = NULL; + FILE *file_input = NULL; + int result = -1; + + for (int i = 1; i < argc; i++) { + unsigned long value = 0; + char *name = argv[i]; + char *sz = NULL; + + if (!name || name[0] != '-') { + fprintf(stderr, "%s invalid argument '%s'\n", + argv[0], argv[i]); + return -1; + } + name++; + if (name[0] == '-') + name++; + + if (i < argc - 1 && argv[i + 1][0] != '-') + sz = argv[++i]; + + if (sz) { + if (!sscanf(sz, "0x%lx", &value)) + sscanf(sz, "%lu", &value); + } else { + value = 1; + } + if (spkg_parse_option(&g_header, name, sz, value)) { + fprintf(stderr, "%s Error invalid '%s'\n", + argv[0], argv[i]); + return -1; + } + } + + if (!g_header.input[0]) { + fprintf(stderr, usage, argv[0]); + exit(1); + } + if (!g_header.output[0]) + snprintf(g_header.output, sizeof(g_header.output), + "%s.spkg", g_header.input); + if (verbose) + printf("%s -> %s\n", g_header.input, g_header.output); + + /*NOTE: Using binary mode as this seems necessary if running in Windows */ + file_SPKG = fopen(g_header.output, "wb"); + file_input = fopen(g_header.input, "rb"); + + if (!file_SPKG) + perror(g_header.output); + if (!file_input) + perror(g_header.input); + + if (file_input && file_SPKG) + result = spkg_write(&g_header, file_input, file_SPKG); + + if (file_SPKG) + fclose(file_SPKG); + if (file_input) + fclose(file_input); + + if (result >= 0) { + if (verbose) + printf("%s created\n", g_header.output); + } else { + fprintf(stderr, "ERROR creating %s\n", g_header.output); + } + + return result; +}
Hello! You can use for example config file, like it has kwbimage.c which is integrated into mkimage and has support for NAND ECC settings.
It is really better if BootROM specific image format is included in standard mkimage and dumpimage tools instead of new custom vendor tools.
Or another option could be to extend mkimage tool to accept new argument for specifying NAND settings. As we can see more image formats have support for it, so some abstraction in mkimage makes sense here.
Hi Pali,
Thank you, I was unaware of this config file approach. From a quick look at doc/README.kwbimage it seems quite reasonable for device-specific parameters.
In principle I agree. But practically speaking I see two problems: 1) mkimage already has far too many options 2) covering all possible vendor-specific values/encodings of NAND parameters would be quite a task
So I am inclined to keep it simple for now, and try using a config file.
Ralph
Hello!
On Tuesday 09 August 2022 11:54:30 Ralph Siemsen wrote:
Hi Pali,
This documentation is not probably up-to-date. List of all kwbimage config options can be visible in kwbimage_generate_config() function.
- mkimage already has far too many options
I know. But for nand there can be just --nand suboption1,suboption2,... format. For other non-nand vendor specific option it would be an issue. Maybe something like --vendor option or --image-options ... could be used?
- covering all possible vendor-specific values/encodings of NAND
Yea, it is problematic. But... is not everything related to NAND just common to what can be specified in device tree properties for nand node? And de-facto already known and well-defined?
Because I cannot imagine what else for what there is not already device tree binding, could be required for vendor bootrom. (But maybe I just do not see it...)
Ralph
Keep it simple is the best option!
In the worst case, in the future, some of the options introduced by your config file format, would be possible to specify also via command line arguments. So I do not see any issue with this config file approach.
Just one suggestion: It is a good idea to also implement "verify_header" mkimage callback. Build process then use it to verify that generated image is really correct.
I will check the code as well.
In my case this would work, as there are only 3 parameters for NAND. However in general, it could get pretty messy, I see at least ten different NAND parameters described in the NAND DT binding.
I did have the thought of using device tree. It does have the advantage that it is a known format with defined parameters.
In quite a few cases, the DT parameters are incomplete, or just hints (see "nand-ecc-maximize"), that trigger various run-time decisions about the actual parameters.
Duplicating this logic in mkimage seems difficult, bordering on impossible if it depends on run-time identification of the flash chip, for example.
I'll check it out, thanks!
Ralph
Hi Ralph,
On 8/9/22 11:54 AM, Ralph Siemsen wrote:
Hi Pali,
The traditional way to handle this is to specify a config file with -n. See e.g. mtk_image
--Sean
Thanks Pali and Sean. I have converted this tool to work as part of mkimage, with a config file for the extra parameters. Patch v2 to follow.
Ralph
Renesas RZ/N1 devices contain BootROM code that loads a custom SPKG image from QSPI, NAND or USB DFU. Support this format in mkimage tool.
SPKGs can optionally be signed, however creation of signed SPKG is not currently supported.
Example of how to use it:
tools/mkimage -n board/schneider/lces/spkgimage.cfg \ -T spkgimage -a 0x20040000 -e 0x20040000 \ -d u-boot.bin u-boot.bin.spkg
The config file (spkgimage.cfg in this example) contains additional parameters such as NAND ECC settings.
Changes in v2: - rewrote the stand-alone spkg_utility to integrate into mkimage
board/schneider/lces/spkgimage.cfg | 26 +++ boot/image.c | 1 + include/image.h | 1 + tools/Makefile | 1 + tools/spkgimage.c | 303 +++++++++++++++++++++++++++++ tools/spkgimage.h | 39 ++++ 6 files changed, 371 insertions(+) create mode 100644 board/schneider/lces/spkgimage.cfg create mode 100644 tools/spkgimage.c create mode 100644 tools/spkgimage.h
diff --git a/board/schneider/lces/spkgimage.cfg b/board/schneider/lces/spkgimage.cfg new file mode 100644 index 0000000000..b5faf96b00 --- /dev/null +++ b/board/schneider/lces/spkgimage.cfg @@ -0,0 +1,26 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 Schneider Electric +# +# SPKG image header, for booting on RZ/N1 + +# b[35:32] SPKG version +VERSION 1 + +# b[42:41] ECC Block size: 0=256 bytes, 1=512 bytes, 2=1024 bytes +NAND_ECC_BLOCK_SIZE 1 + +# b[45] NAND enable (boolean) +NAND_ECC_ENABLE 1 + +# b[50:48] ECC Scheme: 0=BCH2 1=BCH4 2=BCH8 3=BCH16 4=BCH24 5=BCH32 +NAND_ECC_SCHEME 3 + +# b[63:56] ECC bytes per block +NAND_BYTES_PER_ECC_BLOCK 28 + +# Provide dummy BLp header (boolean) +ADD_DUMMY_BLP 1 + +# Pad the image to a multiple of +PADDING 64K diff --git a/boot/image.c b/boot/image.c index 5dcb55ba46..7d50d708ab 100644 --- a/boot/image.c +++ b/boot/image.c @@ -179,6 +179,7 @@ static const table_entry_t uimage_type[] = { { IH_TYPE_COPRO, "copro", "Coprocessor Image"}, { IH_TYPE_SUNXI_EGON, "sunxi_egon", "Allwinner eGON Boot Image" }, { IH_TYPE_SUNXI_TOC0, "sunxi_toc0", "Allwinner TOC0 Boot Image" }, + { IH_TYPE_RENESAS_SPKG, "spkgimage", "Renesas SPKG Image" }, { -1, "", "", }, };
diff --git a/include/image.h b/include/image.h index e4c6a50b88..98eaa384f4 100644 --- a/include/image.h +++ b/include/image.h @@ -229,6 +229,7 @@ enum { IH_TYPE_COPRO, /* Coprocessor Image for remoteproc*/ IH_TYPE_SUNXI_EGON, /* Allwinner eGON Boot Image */ IH_TYPE_SUNXI_TOC0, /* Allwinner TOC0 Boot Image */ + IH_TYPE_RENESAS_SPKG, /* Renesas SPKG image */
IH_TYPE_COUNT, /* Number of image types */ }; diff --git a/tools/Makefile b/tools/Makefile index 005e7362a3..7e24f3ecb9 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -131,6 +131,7 @@ dumpimage-mkimage-objs := aisimage.o \ stm32image.o \ $(ROCKCHIP_OBS) \ socfpgaimage.o \ + spkgimage.o \ sunxi_egon.o \ lib/crc16-ccitt.o \ lib/hash-checksum.o \ diff --git a/tools/spkgimage.c b/tools/spkgimage.c new file mode 100644 index 0000000000..2e8c17d94a --- /dev/null +++ b/tools/spkgimage.c @@ -0,0 +1,303 @@ +// SPDX-License-Identifier: BSD-2-Clause +/* + * Generate Renesas RZ/N1 BootROM header (SPKG) + * (C) Copyright 2022 Schneider Electric + * + * Based on spkg_utility.c + * (C) Copyright 2016 Renesas Electronics Europe Ltd + */ + +#include "imagetool.h" +#include <limits.h> +#include <image.h> +#include <stdarg.h> +#include <stdint.h> +#include <u-boot/crc.h> +#include "spkgimage.h" + +static struct spkg_file out_buf; + +static uint32_t padding; + +/* Note: the ordering of the bitfields does not matter */ +static struct config_file { + unsigned int version:1; + unsigned int ecc_block_size:2; + unsigned int ecc_enable:1; + unsigned int ecc_scheme:3; + unsigned int ecc_bytes:8; + unsigned int blp_len; + unsigned int padding; +} conf; + +static int spkgimage_parse_config_line(char *line) +{ + char *saveptr; + char *delim = "\t "; + char *name = strtok_r(line, delim, &saveptr); + char *val_str = strtok_r(NULL, delim, &saveptr); + int value = atoi(val_str); + + if (!strcmp("VERSION", name)) { + conf.version = value; + } else if (!strcmp("NAND_ECC_ENABLE", name)) { + conf.ecc_enable = value; + } else if (!strcmp("NAND_ECC_BLOCK_SIZE", name)) { + conf.ecc_block_size = value; + } else if (!strcmp("NAND_ECC_SCHEME", name)) { + conf.ecc_scheme = value; + } else if (!strcmp("NAND_BYTES_PER_ECC_BLOCK", name)) { + conf.ecc_bytes = value; + } else if (!strcmp("ADD_DUMMY_BLP", name)) { + conf.blp_len = value ? SPKG_BLP_SIZE : 0; + } else if (!strcmp("PADDING", name)) { + if (strrchr(val_str, 'K')) + conf.padding = value * 1024; + else if (strrchr(val_str, 'M')) + conf.padding = value * 1024 * 1024; + else + conf.padding = value; + } else { + fprintf(stderr, "Error: unknown keyword '%s' in config\n", + name); + return -EINVAL; + } + + return 0; +} + +static int spkgimage_parse_config_file(char *filename) +{ + FILE *fcfg; + char line[256]; + size_t len; + + fcfg = fopen(filename, "r"); + if (!fcfg) + return -EINVAL; + + while (fgets(line, sizeof(line), fcfg)) { + /* Skip blank lines and comments */ + if (line[0] == '\n' || line[0] == '#') + continue; + + /* Strip the trailing newline */ + len = strlen(line); + if (line[len - 1] == '\n') + line[--len] = 0; + + /* Parse the line */ + if (spkgimage_parse_config_line(line)) + return -EINVAL; + } + + fclose(fcfg); + + /* Avoid divide-by-zero later on */ + if (conf.padding == 0) + conf.padding = 1; + + return 0; +} + +static int spkgimage_check_params(struct image_tool_params *params) +{ + if (!params->addr) { + fprintf(stderr, "Error: Load Address must be set.\n"); + return -EINVAL; + } + + if (!params->imagename || !params->imagename[0]) { + fprintf(stderr, "Error: Image name must be set.\n"); + return -EINVAL; + } + + if (!params->datafile) { + fprintf(stderr, "Error: Data filename must be set.\n"); + return -EINVAL; + } + + return 0; +} + +static int spkgimage_verify_header(unsigned char *ptr, int size, + struct image_tool_params *param) +{ + struct spkg_file *file = (struct spkg_file *)ptr; + struct spkg_hdr *header = (struct spkg_hdr *)ptr; + char signature[4] = SPKG_HEADER_SIGNATURE; + uint32_t payload_length; + uint32_t crc; + uint8_t *crc_buf; + + /* Check the signature */ + if (memcmp(header->signature, signature, 4)) { + fprintf(stderr, "Error: invalid signature bytes\n"); + return -EINVAL; + } + + /* Check the CRC */ + crc = crc32(0, ptr, SPKG_HEADER_SIZE - SPKG_CRC_SIZE); + if (crc != header->crc) { + fprintf(stderr, "Error: invalid header CRC=\n"); + return -EINVAL; + } + + /* Check all copies of header are the same */ + for (int i = 1; i < SPKG_HEADER_COUNT; i++) { + if (memcmp(&header[0], &header[i], SPKG_HEADER_SIZE)) { + fprintf(stderr, "Error: header %d mismatch\n", i); + return -EINVAL; + } + } + + /* Check the payload CRC */ + payload_length = le32_to_cpu(header->payload_length) >> 8; + crc_buf = file->payload + payload_length - SPKG_CRC_SIZE; + crc = crc32(0, file->payload, payload_length - SPKG_CRC_SIZE); + if (crc_buf[0] != (crc & 0xff) || + crc_buf[1] != (crc >> 8 & 0xff) || + crc_buf[2] != (crc >> 16 & 0xff) || + crc_buf[3] != (crc >> 24 & 0xff)) { + fprintf(stderr, "Error: invalid payload CRC\n"); + return -EINVAL; + } + + return 0; +} + +static void spkgimage_print_header(const void *ptr) +{ + const struct spkg_hdr *h = ptr; + uint32_t offset = le32_to_cpu(h->execution_offset); + + printf("Image type\t: Renesas SPKG Image\n"); + printf("Marker\t\t: %c%c%c%c\n", h->signature[0], h->signature[1], + h->signature[2], h->signature[3]); + printf("Version\t\t: %d\n", h->version); + printf("ECC\t\t: "); + if (h->ecc & 0x20) + printf("Scheme %d, Block size %d, Strength %d\n", + h->ecc_scheme, (h->ecc >> 1) & 3, h->ecc_bytes); + else + printf("Not enabled\n"); + printf("Payload length\t: %d\n", le32_to_cpu(h->payload_length) >> 8); + printf("Load address\t: 0x%08x\n", le32_to_cpu(h->load_address)); + printf("Execution offset: 0x%08x (%s mode)\n", offset & ~1, + offset & 1 ? "THUMB" : "ARM"); + printf("Header checksum\t: 0x%08x\n", le32_to_cpu(h->crc)); +} + +static inline uint32_t roundup(uint32_t x, uint32_t y) +{ + return ((x + y - 1) / y) * y; +} + +static int spkgimage_vrec_header(struct image_tool_params *params, + struct image_type_params *tparams) +{ + struct stat s; + + /* Parse the config file */ + if (spkgimage_parse_config_file(params->imagename)) { + fprintf(stderr, "Error parsing config file\n"); + exit(EXIT_FAILURE); + } + + /* Get size of input data file */ + if (stat(params->datafile, &s)) { + fprintf(stderr, "Could not stat data file: %s: %s\n", + params->datafile, strerror(errno)); + exit(EXIT_FAILURE); + } + params->orig_file_size = s.st_size; + + /* Determine size of resulting SPKG file */ + uint32_t header_len = SPKG_HEADER_SIZE * SPKG_HEADER_COUNT; + uint32_t payload_len = conf.blp_len + s.st_size + SPKG_CRC_SIZE; + uint32_t total_len = header_len + payload_len; + + /* Round up to next multiple of padding size */ + uint32_t padded_len = roundup(total_len, conf.padding); + + /* Number of padding bytes to add */ + padding = padded_len - total_len; + + /* Fixup payload_len to include padding bytes */ + payload_len += padding; + + /* Prepare the header */ + struct spkg_hdr header = { + .signature = SPKG_HEADER_SIGNATURE, + .version = conf.version, + .ecc = (conf.ecc_enable << 5) | (conf.ecc_block_size << 1), + .ecc_scheme = conf.ecc_scheme, + .ecc_bytes = conf.ecc_bytes, + .payload_length = cpu_to_le32(payload_len << 8), + .load_address = cpu_to_le32(params->addr), + .execution_offset = cpu_to_le32(params->ep - params->addr), + }; + header.crc = crc32(0, (uint8_t *)&header, + sizeof(header) - SPKG_CRC_SIZE); + + /* Fill the SPKG with the headers */ + for (int i = 0; i < SPKG_HEADER_COUNT; i++) + memcpy(&out_buf.header[i], &header, sizeof(header)); + + /* Extra bytes to allocate in the output file */ + return conf.blp_len + padding + 4; +} + +static void spkgimage_set_header(void *ptr, struct stat *sbuf, int ifd, + struct image_tool_params *params) +{ + uint8_t *payload = ptr + SPKG_HEADER_SIZE * SPKG_HEADER_COUNT; + uint8_t *file_end = payload + conf.blp_len + params->orig_file_size; + uint8_t *crc_buf = file_end + padding; + uint32_t crc; + + /* Make room for the Dummy BLp header */ + memmove(payload + conf.blp_len, payload, params->orig_file_size); + + /* Fill the SPKG with the Dummy BLp */ + memset(payload, 0x88, conf.blp_len); + + /* + * mkimage copy_file() pads the input file with zeros. + * Replace those zeros with flash friendly one bits. + * The original version skipped the fist 4 bytes, + * probably an oversight, but for consistency we + * keep the same behaviour. + */ + memset(file_end + 4, 0xff, padding - 4); + + /* Add Payload CRC */ + crc = crc32(0, payload, crc_buf - payload); + crc_buf[0] = crc; + crc_buf[1] = crc >> 8; + crc_buf[2] = crc >> 16; + crc_buf[3] = crc >> 24; +} + +static int spkgimage_check_image_types(uint8_t type) +{ + return type == IH_TYPE_RENESAS_SPKG ? 0 : 1; +} + +/* + * spkgimage type parameter definition + */ +U_BOOT_IMAGE_TYPE( + spkgimage, + "Renesas SPKG Image", + sizeof(out_buf), + &out_buf, + spkgimage_check_params, + spkgimage_verify_header, + spkgimage_print_header, + spkgimage_set_header, + NULL, + spkgimage_check_image_types, + NULL, + spkgimage_vrec_header +); diff --git a/tools/spkgimage.h b/tools/spkgimage.h new file mode 100644 index 0000000000..db153bfc3f --- /dev/null +++ b/tools/spkgimage.h @@ -0,0 +1,39 @@ +/* SPDX-License-Identifier: BSD-2-Clause */ +/* + * Renesas RZ/N1 Package Table format + * (C) 2015-2016 Renesas Electronics Europe, LTD + * All rights reserved. + * + * Converted to mkimage plug-in + * (C) Copyright 2022 Schneider Electric + */ + +#ifndef _SPKGIMAGE_H_ +#define _SPKGIMAGE_H_ + +#define SPKG_HEADER_SIGNATURE {'R', 'Z', 'N', '1'} +#define SPKG_HEADER_SIZE 24 +#define SPKG_HEADER_COUNT 8 +#define SPKG_BLP_SIZE 264 +#define SPKG_CRC_SIZE 4 + +/* SPKG header */ +struct spkg_hdr { + uint8_t signature[4]; + uint8_t version; + uint8_t ecc; + uint8_t ecc_scheme; + uint8_t ecc_bytes; + uint32_t payload_length; /* only HIGHER 24 bits */ + uint32_t load_address; + uint32_t execution_offset; + uint32_t crc; /* of this header */ +} __packed; + +struct spkg_file { + struct spkg_hdr header[SPKG_HEADER_COUNT]; + uint8_t payload[0]; + /* then the CRC */ +} __packed; + +#endif
Changes in v2:
Please document your format in doc/mkimage.1
- { IH_TYPE_RENESAS_SPKG, "spkgimage", "Renesas SPKG Image" }, { -1, "", "", }, };
- Generate Renesas RZ/N1 BootROM header (SPKG)
- (C) Copyright 2022 Schneider Electric
- Based on spkg_utility.c
- (C) Copyright 2016 Renesas Electronics Europe Ltd
- unsigned int version:1;
- unsigned int ecc_block_size:2;
- unsigned int ecc_enable:1;
- unsigned int ecc_scheme:3;
- unsigned int ecc_bytes:8;
- unsigned int blp_len;
- unsigned int padding;
+} conf;
I wonder if you could just fill in the header directly. This is for a userspace tool, and this struct will be created at most once. It's OK to use 10 bytes :)
- char *saveptr;
- char *delim = "\t ";
- char *name = strtok_r(line, delim, &saveptr);
- char *val_str = strtok_r(NULL, delim, &saveptr);
- int value = atoi(val_str);
- if (!strcmp("VERSION", name)) {
- } else if (!strcmp("NAND_ECC_ENABLE", name)) {
Can you add some checks for the valid range of values? E.g. NAND_ECC_SCHEME should be 0 <= value <= 5
- } else if (!strcmp("NAND_ECC_BLOCK_SIZE", name)) {
- } else if (!strcmp("NAND_ECC_SCHEME", name)) {
- } else if (!strcmp("NAND_BYTES_PER_ECC_BLOCK", name)) {
- } else if (!strcmp("ADD_DUMMY_BLP", name)) {
- } else if (!strcmp("PADDING", name)) {
else
- } else {
name);
perhaps print the line number?
return -EINVAL;
- FILE *fcfg;
- char line[256];
- size_t len;
- fcfg = fopen(filename, "r");
- if (!fcfg)
return -EINVAL;
- while (fgets(line, sizeof(line), fcfg)) {
continue;
len = strlen(line);
line[--len] = 0;
return -EINVAL;
- fclose(fcfg);
- /* Avoid divide-by-zero later on */
- if (conf.padding == 0)
if (!conf.padding)
conf.padding = 1;
- if (!params->addr) {
return -EINVAL;
- if (!params->imagename || !params->imagename[0]) {
return -EINVAL;
- if (!params->datafile) {
return -EINVAL;
- struct spkg_file *file = (struct spkg_file *)ptr;
- struct spkg_hdr *header = (struct spkg_hdr *)ptr;
- char signature[4] = SPKG_HEADER_SIGNATURE;
If this naming does not come from documentation, I would suggest something like SPKG_HEADER_MAGIC, since this is not a signature, or even a CRC.
- uint32_t payload_length;
- uint32_t crc;
- uint8_t *crc_buf;
- /* Check the signature */
- if (memcmp(header->signature, signature, 4)) {
return -EINVAL;
- /* Check the CRC */
- crc = crc32(0, ptr, SPKG_HEADER_SIZE - SPKG_CRC_SIZE);
- if (crc != header->crc) {
return -EINVAL;
- /* Check all copies of header are the same */
- for (int i = 1; i < SPKG_HEADER_COUNT; i++) {
return -EINVAL;
- /* Check the payload CRC */
- payload_length = le32_to_cpu(header->payload_length) >> 8;
- crc_buf = file->payload + payload_length - SPKG_CRC_SIZE;
- crc = crc32(0, file->payload, payload_length - SPKG_CRC_SIZE);
- if (crc_buf[0] != (crc & 0xff) ||
return -EINVAL;
- const struct spkg_hdr *h = ptr;
- uint32_t offset = le32_to_cpu(h->execution_offset);
- printf("Image type\t: Renesas SPKG Image\n");
- printf("Marker\t\t: %c%c%c%c\n", h->signature[0], h->signature[1],
- printf("Version\t\t: %d\n", h->version);
- printf("ECC\t\t: ");
- if (h->ecc & 0x20)
- else
- printf("Payload length\t: %d\n", le32_to_cpu(h->payload_length) >> 8);
- printf("Load address\t: 0x%08x\n", le32_to_cpu(h->load_address));
- printf("Execution offset: 0x%08x (%s mode)\n", offset & ~1,
- printf("Header checksum\t: 0x%08x\n", le32_to_cpu(h->crc));
- return ((x + y - 1) / y) * y;
- struct stat s;
- /* Parse the config file */
- if (spkgimage_parse_config_file(params->imagename)) {
exit(EXIT_FAILURE);
- /* Get size of input data file */
- if (stat(params->datafile, &s)) {
exit(EXIT_FAILURE);
- params->orig_file_size = s.st_size;
- /* Determine size of resulting SPKG file */
- uint32_t header_len = SPKG_HEADER_SIZE * SPKG_HEADER_COUNT;
- uint32_t payload_len = conf.blp_len + s.st_size + SPKG_CRC_SIZE;
- uint32_t total_len = header_len + payload_len;
- /* Round up to next multiple of padding size */
- uint32_t padded_len = roundup(total_len, conf.padding);
- /* Number of padding bytes to add */
- padding = padded_len - total_len;
- /* Fixup payload_len to include padding bytes */
- payload_len += padding;
- /* Prepare the header */
- struct spkg_hdr header = {
- header.crc = crc32(0, (uint8_t *)&header,
- /* Fill the SPKG with the headers */
- for (int i = 0; i < SPKG_HEADER_COUNT; i++)
- /* Extra bytes to allocate in the output file */
- return conf.blp_len + padding + 4;
- uint8_t *payload = ptr + SPKG_HEADER_SIZE * SPKG_HEADER_COUNT;
- uint8_t *file_end = payload + conf.blp_len + params->orig_file_size;
- uint8_t *crc_buf = file_end + padding;
- uint32_t crc;
- /* Make room for the Dummy BLp header */
- memmove(payload + conf.blp_len, payload, params->orig_file_size);
- /* Fill the SPKG with the Dummy BLp */
- memset(payload, 0x88, conf.blp_len);
nit: first
- memset(file_end + 4, 0xff, padding - 4);
- /* Add Payload CRC */
- crc = crc32(0, payload, crc_buf - payload);
- crc_buf[0] = crc;
- crc_buf[1] = crc >> 8;
- crc_buf[2] = crc >> 16;
- crc_buf[3] = crc >> 24;
- return type == IH_TYPE_RENESAS_SPKG ? 0 : 1;
This function is not necessary if you only support one type.
- spkgimage type parameter definition
+U_BOOT_IMAGE_TYPE(
- spkgimage,
- "Renesas SPKG Image",
- sizeof(out_buf),
- &out_buf,
- spkgimage_check_params,
- spkgimage_verify_header,
- spkgimage_print_header,
- spkgimage_set_header,
- NULL,
- spkgimage_check_image_types,
- NULL,
- spkgimage_vrec_header
- Renesas RZ/N1 Package Table format
- (C) 2015-2016 Renesas Electronics Europe, LTD
- All rights reserved.
- Converted to mkimage plug-in
What are the other 7 headers for? Should you print them out above?
- uint8_t signature[4];
- uint8_t version;
- uint8_t ecc;
- uint8_t ecc_scheme;
- uint8_t ecc_bytes;
- uint32_t payload_length; /* only HIGHER 24 bits */
- uint32_t load_address;
- uint32_t execution_offset;
- uint32_t crc; /* of this header */
+} __packed;
+struct spkg_file {
- struct spkg_hdr header[SPKG_HEADER_COUNT];
- uint8_t payload[0];
- /* then the CRC */
+} __packed;
--Sean
Okay, will be added in the next version.
+} conf;
I could fill the header directly, but I figured it would be cleaner to keep the config file parsing separate from header generation.
As for the use of bitfields, this was not really about saving space, but rather a cheap way to ensure the values from the config file do not exceed their allocated bit-width in the header. The previous stand-alone code has a somewhat similar construct, from which I pinched the idea.
char *saveptr;
Yes, will add some range checks where they make sense. Probably with a helper function.
else
} else {
name);
Good idea, will do.
if (!conf.padding)
Will do.
The name does in fact come from the RZ/N1 documentation. However I agree that SPKG_HEADER_MAGIC would better reflect what these bytes actually are.
nit: first
Well spotted, thanks.
Without this function, mkimage kept telling me that my format (spkgimage) was not supported, and none of my callbacks got invoked. It only complained when trying to generate a header. When listing the supported formats, spkgimage showed up correctly.
I'll take another look on Monday, maybe I missed something obvious.
There are 8 identical copies of the 24-byte header. This is meant to help with NAND booting, where the header is read before ECC settings are known. The BootROM validates the header CRC and will try up to 8 headers before giving up.
Since they are identical, I only printed values from one header. However in the validation function, I do check that all eight copies match.
Thanks for your feedback! -Ralph
Hi Sean,
I've implemented most of the suggestions. I will post an updated series, since it seems that sending v2 of just one patch has confused patchwork.
However so as not to entirely remove confusion, the updated series will be v3, since I already used v2 for the one patch. :-P
On Sat, Aug 13, 2022 at 9:45 PM Ralph Siemsen ralph.siemsen@linaro.org wrote:
Does it seem reasonable to keep these structures separated?
Upon checking the documentation, it turns out they use the term "marker" rather than "signature" for these bytes. So I have switched the code to match.
I have re-checked this: - without the function, mkimage complains that spkgimage is unknown - with a function that unconditionally returns 0, it works fine
If it really is meant to work without the function, then a bug must have crept in elsewhere...
Regards, -Ralph
On 8/16/22 10:33 AM, Ralph Siemsen wrote:
Hi Sean,
Yes, that is fine.
That sounds good.
Huh. I did a quick grep so maybe I missed something. IMO this *should* work without a function, because we have tons of drivers which just have an equality check. In any case, you can just do
return type == IH_TYPE_RENESAS_SPKG ? 0 : -EINVAL;
--Sean
It works fine when I use the following for the function:
static int spkgimage_check_image_types(uint8_t type) { return 0; }
However if no function is provided, i.e. U_BOOT_IMAGE_TYPE has NULL for check_image_type field, then mkimage fails with the error:
tools/mkimage: unsupported type Renesas SPKG Image
Looking at this a bit more, it seems to be due to:
struct image_type_params *imagetool_get_type(int type) { ...snip...
for (curr = start; curr != end; curr++) { if ((*curr)->check_image_type) { if (!(*curr)->check_image_type(type)) return *curr; } } return NULL; }
So the only way to get non-NULL from imagetool_get_type is for there to be a callback function, and it must return zero. And this in turn causes mkimage to bail out quite early in main():
/* set tparams as per input type_id */ tparams = imagetool_get_type(params.type); if (tparams == NULL && !params.lflag) { fprintf (stderr, "%s: unsupported type %s\n", params.cmdname, genimg_get_type_name(params.type)); exit (EXIT_FAILURE); }
Unless I am missing something, it seems I must provide a function.
-Ralph
PS I will post an updated series (v3) eventually. I'm working on making changes to the clock driver on the kernel side, to keep it in sync with the changes you requested in the u-boot side.
Pali Rohár
Ralph Siemsen
Sean Anderson
Sean Anderson
