[u-boot-test-hooks PATCH] travis-ci: Add SiFive Unleashed QEMU targets
Add support for testing sifive_unleashed_defconfig via QEMU. QEMU supports booting exact the same images as used on the real hardware out of the box, that U-Boot SPL loads U-Boot proper from either an SD card or the SPI NOR flash, hence we can easily set up CI to cover these 2 boot flows of SiFive Unleashed board.
Signed-off-by: Bin Meng bmeng.cn@gmail.com
bin/travis-ci/conf.sifive_unleashed_sdcard_qemu | 11 +++++++++++ bin/travis-ci/conf.sifive_unleashed_spi-nor_qemu | 11 +++++++++++ .../u_boot_boardenv_sifive_unleashed_sdcard_qemu.py | 10 ++++++++++ .../u_boot_boardenv_sifive_unleashed_spi-nor_qemu.py | 10 ++++++++++ 4 files changed, 42 insertions(+) create mode 100644 bin/travis-ci/conf.sifive_unleashed_sdcard_qemu create mode 100644 bin/travis-ci/conf.sifive_unleashed_spi-nor_qemu create mode 100644 py/travis-ci/u_boot_boardenv_sifive_unleashed_sdcard_qemu.py create mode 100644 py/travis-ci/u_boot_boardenv_sifive_unleashed_spi-nor_qemu.py
diff --git a/bin/travis-ci/conf.sifive_unleashed_sdcard_qemu b/bin/travis-ci/conf.sifive_unleashed_sdcard_qemu new file mode 100644 index 0000000..f3c3da1 --- /dev/null +++ b/bin/travis-ci/conf.sifive_unleashed_sdcard_qemu @@ -0,0 +1,11 @@ +# SPDX-License-Identifier: MIT +# +# Copyright (c) 2021 Bin Meng bmeng.cn@gmail.com + +console_impl=qemu +qemu_machine="sifive_u,msel=11" +qemu_binary="qemu-system-riscv64" +qemu_extra_args="-smp 5 -m 8G -nographic -nic user,tftp=${UBOOT_TRAVIS_BUILD_DIR}" +qemu_kernel_args="-bios ${U_BOOT_BUILD_DIR}/spl/u-boot-spl.bin -drive file=${U_BOOT_BUILD_DIR}/sdcard.img,if=sd" +reset_impl=none +flash_impl=none diff --git a/bin/travis-ci/conf.sifive_unleashed_spi-nor_qemu b/bin/travis-ci/conf.sifive_unleashed_spi-nor_qemu new file mode 100644 index 0000000..e28bfc4 --- /dev/null +++ b/bin/travis-ci/conf.sifive_unleashed_spi-nor_qemu @@ -0,0 +1,11 @@ +# SPDX-License-Identifier: MIT +# +# Copyright (c) 2021 Bin Meng bmeng.cn@gmail.com + +console_impl=qemu +qemu_machine="sifive_u,msel=6" +qemu_binary="qemu-system-riscv64" +qemu_extra_args="-smp 5 -m 8G -nographic -nic user,tftp=${UBOOT_TRAVIS_BUILD_DIR}" +qemu_kernel_args="-bios ${U_BOOT_BUILD_DIR}/spl/u-boot-spl.bin -drive file=${U_BOOT_BUILD_DIR}/spi-nor.img,if=mtd" +reset_impl=none +flash_impl=none diff --git a/py/travis-ci/u_boot_boardenv_sifive_unleashed_sdcard_qemu.py b/py/travis-ci/u_boot_boardenv_sifive_unleashed_sdcard_qemu.py new file mode 100644 index 0000000..a86e0bd --- /dev/null +++ b/py/travis-ci/u_boot_boardenv_sifive_unleashed_sdcard_qemu.py @@ -0,0 +1,10 @@ +import os +import travis_tftp + +env__net_dhcp_server = True +env__net_tftp_readable_file = travis_tftp.file2env('u-boot') +env__efi_loader_helloworld_file = travis_tftp.file2env('lib/efi_loader/helloworld.efi') +env__efi_loader_grub_file = travis_tftp.file2env('grub_riscv64.efi') +env__efi_fit_tftp_file = { + "dn" : os.environ['UBOOT_TRAVIS_BUILD_DIR'], +} diff --git a/py/travis-ci/u_boot_boardenv_sifive_unleashed_spi-nor_qemu.py b/py/travis-ci/u_boot_boardenv_sifive_unleashed_spi-nor_qemu.py new file mode 100644 index 0000000..a86e0bd --- /dev/null +++ b/py/travis-ci/u_boot_boardenv_sifive_unleashed_spi-nor_qemu.py @@ -0,0 +1,10 @@ +import os +import travis_tftp + +env__net_dhcp_server = True +env__net_tftp_readable_file = travis_tftp.file2env('u-boot') +env__efi_loader_helloworld_file = travis_tftp.file2env('lib/efi_loader/helloworld.efi') +env__efi_loader_grub_file = travis_tftp.file2env('grub_riscv64.efi') +env__efi_fit_tftp_file = { + "dn" : os.environ['UBOOT_TRAVIS_BUILD_DIR'], +}
Applied to u-boot-test-hooks/master, thanks!
Bin Meng
