[PATCH 00/22] imx: patches in queue
Hi Stefano,
This patchset is a rebase of your/master-next branch to make these patches in my patchwork queue could apply. I not send them as previous seperated patchset, hope this not matter.
The two patches are not included, since they are just sent out. https://patchwork.ozlabs.org/project/uboot/patch/20220523113828.3837-1-peng.... https://patchwork.ozlabs.org/project/uboot/patch/20220523113828.3837-2-peng....
Thanks, Peng.
Peng Fan (22): imx: drop CONFIG_MXC_UART_BASE imx: imx8m[m/n/p]_venice: Enable SPL_DM_SERIAL imx: imx8m[m/n]_beacon: Enable SPL_DM_SERIAL imx: imx8mm-cl-iot-gate: Enable DM_SERIAL imx: imx8mm_icore: Enable SPL_DM_SERIAL imx: imx8m[m/p]_phycore: Enable DM_SERIAL imx: imx8mn_var_som: enable DM_SERIAL imx: kontron-sl-mx8mm: enable DM_SERIAL configs: drop CONFIG_SPL_ABORT_ON_RAW_IMAGE configs: imx8m: use common imx8m.h for i.MX8MM configs: imx8m: use common imx8m.h for i.MX8MN configs: imx8m: use common imx8m.h for i.MX8MP configs: imx8m: use common imx8m.h for i.MX8MQ imx: imx8mm_beacon: enable pinctrl_wdog in SPL imx: imx8mm-cl-iot-gate: enable pinctrl_wdog in SPL imx: engicam-imx8mm: drop unused macro imx: imx8mm/n/p-venice: enable pinctrl_wdog in SPL imx: imx8mn-beacon: enable pinctrl_wdog in SPL imx: imx8mn_var_som: clean up board watchdog code imx: imx8mp_rsb7320a1: enable wdog driver model in SPL imx: imx8mn-kontron-n801x: enable pinctrl_wdog in SPL imx: phycore_imx8mm/p: clean up board watchdog code
arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi | 4 ++ arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi | 4 ++ arch/arm/dts/imx8mm-kontron-n801x-u-boot.dtsi | 4 ++ arch/arm/dts/imx8mm-venice-u-boot.dtsi | 4 ++ arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi | 4 ++ arch/arm/dts/imx8mn-venice-u-boot.dtsi | 4 ++ arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi | 8 +++ arch/arm/dts/imx8mp-venice-u-boot.dtsi | 4 ++ .../imx8mp_rsb3720a1/imx8mp_rsb3720a1.c | 12 ---- board/beacon/imx8mm/spl.c | 31 +--------- board/beacon/imx8mn/spl.c | 21 +------ board/compulab/imx8mm-cl-iot-gate/spl.c | 31 +--------- board/engicam/imx8mm/spl.c | 16 +----- board/gateworks/venice/spl.c | 29 ---------- board/kontron/sl-mx8mm/spl.c | 30 +--------- board/phytec/phycore_imx8mm/spl.c | 31 +--------- board/phytec/phycore_imx8mp/spl.c | 27 --------- board/variscite/imx8mn_var_som/spl.c | 22 +------ configs/imx8mm-cl-iot-gate-optee_defconfig | 1 + configs/imx8mm-cl-iot-gate_defconfig | 1 + configs/imx8mm-icore-mx8mm-ctouch2_defconfig | 1 - configs/imx8mm-icore-mx8mm-edimm2.2_defconfig | 1 - configs/imx8mm_beacon_defconfig | 1 - configs/imx8mn_beacon_2g_defconfig | 1 - configs/imx8mn_beacon_defconfig | 1 - configs/imx8mn_var_som_defconfig | 1 + configs/kontron-sl-mx8mm_defconfig | 1 + configs/phycore-imx8mm_defconfig | 1 + configs/phycore-imx8mp_defconfig | 1 + include/configs/aristainetos2.h | 2 - include/configs/capricorn-common.h | 1 - include/configs/cgtqmx8.h | 1 - include/configs/imx8m.h | 57 +++++++++++++++++++ include/configs/imx8mm-cl-iot-gate.h | 20 +------ include/configs/imx8mm_beacon.h | 24 +------- include/configs/imx8mm_data_modul_edm_sbc.h | 17 +----- include/configs/imx8mm_evk.h | 24 +------- include/configs/imx8mm_icore_mx8mm.h | 24 +------- include/configs/imx8mm_venice.h | 22 +------ include/configs/imx8mn_beacon.h | 3 - include/configs/imx8mn_bsh_smm_s2_common.h | 19 +------ include/configs/imx8mn_evk.h | 23 +------- include/configs/imx8mn_var_som.h | 17 +----- include/configs/imx8mn_venice.h | 22 +------ include/configs/imx8mp_evk.h | 20 +------ include/configs/imx8mp_rsb3720.h | 17 +----- include/configs/imx8mp_venice.h | 22 +------ include/configs/imx8mq_cm.h | 25 +------- include/configs/imx8mq_evk.h | 20 +------ include/configs/imx8mq_phanbell.h | 20 +------ include/configs/imx8qm_mek.h | 1 - include/configs/imx8qxp_mek.h | 1 - include/configs/imx8ulp_evk.h | 1 - include/configs/kontron-sl-mx8mm.h | 15 +---- include/configs/kontron_pitx_imx8m.h | 20 +------ include/configs/mx7dsabresd.h | 1 - include/configs/phycore_imx8mm.h | 24 +------- include/configs/phycore_imx8mp.h | 20 +------ include/configs/pico-imx8mq.h | 21 +------ include/configs/somlabs_visionsom_6ull.h | 1 - include/configs/tbs2910.h | 3 - include/configs/verdin-imx8mm.h | 24 +------- include/configs/verdin-imx8mp.h | 20 +------ 63 files changed, 142 insertions(+), 707 deletions(-) create mode 100644 include/configs/imx8m.h
Since these boards has CONFIG_DM_SERIAL and/or CONFIG_SPL_DM_SERIAL, the legacy macro no need to be defined.
Reviewed-by: Heiko Schocher hs@denx.de Reviewed-by: Fabio Estevam festevam@denx.de Signed-off-by: Peng Fan peng.fan@nxp.com Acked-by: Soeren Moch smoch@web.de --- include/configs/aristainetos2.h | 2 -- include/configs/imx8mm_evk.h | 2 -- include/configs/imx8mn_bsh_smm_s2_common.h | 2 -- include/configs/imx8mn_evk.h | 2 -- include/configs/imx8mp_evk.h | 2 -- include/configs/mx7dsabresd.h | 1 - include/configs/somlabs_visionsom_6ull.h | 1 - include/configs/tbs2910.h | 3 --- include/configs/verdin-imx8mm.h | 3 --- include/configs/verdin-imx8mp.h | 3 --- 10 files changed, 21 deletions(-)
diff --git a/include/configs/aristainetos2.h b/include/configs/aristainetos2.h index 8ee97f1d4e3..27adae5d6bf 100644 --- a/include/configs/aristainetos2.h +++ b/include/configs/aristainetos2.h @@ -14,10 +14,8 @@ #define CONFIG_HOSTNAME "aristainetos2"
#if (CONFIG_SYS_BOARD_VERSION == 5) -#define CONFIG_MXC_UART_BASE UART2_BASE #define CONSOLE_DEV "ttymxc1" #elif (CONFIG_SYS_BOARD_VERSION == 6) -#define CONFIG_MXC_UART_BASE UART1_BASE #define CONSOLE_DEV "ttymxc0" #endif
diff --git a/include/configs/imx8mm_evk.h b/include/configs/imx8mm_evk.h index 5e8f19c43fb..002b2e68bba 100644 --- a/include/configs/imx8mm_evk.h +++ b/include/configs/imx8mm_evk.h @@ -68,8 +68,6 @@ #define PHYS_SDRAM 0x40000000 #define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */
-#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(2) - /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 2048 #define CONFIG_SYS_MAXARGS 64 diff --git a/include/configs/imx8mn_bsh_smm_s2_common.h b/include/configs/imx8mn_bsh_smm_s2_common.h index 6387576c2da..57be38d9433 100644 --- a/include/configs/imx8mn_bsh_smm_s2_common.h +++ b/include/configs/imx8mn_bsh_smm_s2_common.h @@ -45,8 +45,6 @@ #define CONFIG_SYS_SDRAM_BASE 0x40000000 #define PHYS_SDRAM 0x40000000
-#define CONFIG_MXC_UART_BASE UART4_BASE_ADDR - /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE SZ_2K #define CONFIG_SYS_MAXARGS 64 diff --git a/include/configs/imx8mn_evk.h b/include/configs/imx8mn_evk.h index 805ae2a7518..86be1b8b3be 100644 --- a/include/configs/imx8mn_evk.h +++ b/include/configs/imx8mn_evk.h @@ -75,8 +75,6 @@ #define PHYS_SDRAM 0x40000000 #define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */
-#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(2) - /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 2048 #define CONFIG_SYS_MAXARGS 64 diff --git a/include/configs/imx8mp_evk.h b/include/configs/imx8mp_evk.h index 1e7c44c42a4..373098f10c4 100644 --- a/include/configs/imx8mp_evk.h +++ b/include/configs/imx8mp_evk.h @@ -79,8 +79,6 @@ #define PHYS_SDRAM_2 0x100000000 #define PHYS_SDRAM_2_SIZE 0xC0000000 /* 3 GB */
-#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(2) - /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 2048 #define CONFIG_SYS_MAXARGS 64 diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index aaad232f0e4..62e62c6701f 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -12,7 +12,6 @@
#define PHYS_SDRAM_SIZE SZ_1G
-#define CONFIG_MXC_UART_BASE UART1_IPS_BASE_ADDR
#ifdef CONFIG_IMX_BOOTAUX /* Set to QSPI1 A flash at default */ diff --git a/include/configs/somlabs_visionsom_6ull.h b/include/configs/somlabs_visionsom_6ull.h index d4761296c75..e6aad386efe 100644 --- a/include/configs/somlabs_visionsom_6ull.h +++ b/include/configs/somlabs_visionsom_6ull.h @@ -16,7 +16,6 @@ /* SPL options */ #include "imx6_spl.h"
/* MMC Configs */ #ifdef CONFIG_FSL_USDHC diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index b7a94812f35..5d8cb34ad9a 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -24,9 +24,6 @@
#define CONFIG_SYS_BOOTMAPSZ 0x10000000
-/* Serial console */ -#define CONFIG_MXC_UART_BASE UART1_BASE /* select UART1/UART2 */ - /* Framebuffer */ #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin-imx8mm.h index cd950ad055e..9ed9da043f6 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -83,9 +83,6 @@ #define PHYS_SDRAM 0x40000000 #define PHYS_SDRAM_SIZE SZ_2G /* 2GB DDR */
-/* UART */ -#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(1) - /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE SZ_2K #define CONFIG_SYS_MAXARGS 64 diff --git a/include/configs/verdin-imx8mp.h b/include/configs/verdin-imx8mp.h index 470f64d5a74..20e8473f793 100644 --- a/include/configs/verdin-imx8mp.h +++ b/include/configs/verdin-imx8mp.h @@ -99,9 +99,6 @@ #define PHYS_SDRAM_2 0x100000000 #define PHYS_SDRAM_2_SIZE (SZ_4G + SZ_1G)
-/* UART */ -#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(3) - /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE SZ_2K #define CONFIG_SYS_MAXARGS 64
Enable CONFIG_SPL_DM_SERIAL. uart2 and its pinmux was already marked with u-boot,dm-spl. Move preloader_console_init after spl_early_init to make sure driver model work.
Signed-off-by: Peng Fan peng.fan@nxp.com Acked-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Fabio Estevam festevam@denx.de --- include/configs/imx8mm_venice.h | 3 --- include/configs/imx8mn_venice.h | 3 --- include/configs/imx8mp_venice.h | 3 --- 3 files changed, 9 deletions(-)
diff --git a/include/configs/imx8mm_venice.h b/include/configs/imx8mm_venice.h index 9836d5b73ca..90e8941a254 100644 --- a/include/configs/imx8mm_venice.h +++ b/include/configs/imx8mm_venice.h @@ -101,9 +101,6 @@ #define PHYS_SDRAM_SIZE SZ_4G #define CONFIG_SYS_BOOTM_LEN SZ_256M
-/* UART */ -#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(2) - /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE SZ_2K #define CONFIG_SYS_MAXARGS 64 diff --git a/include/configs/imx8mn_venice.h b/include/configs/imx8mn_venice.h index 3cbe11a9035..6555dd4349c 100644 --- a/include/configs/imx8mn_venice.h +++ b/include/configs/imx8mn_venice.h @@ -97,9 +97,6 @@ #define PHYS_SDRAM_SIZE SZ_4G #define CONFIG_SYS_BOOTM_LEN SZ_256M
-/* UART */ -#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(2) - /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE SZ_2K #define CONFIG_SYS_MAXARGS 64 diff --git a/include/configs/imx8mp_venice.h b/include/configs/imx8mp_venice.h index 4120e4cc6ba..c09a1b4572a 100644 --- a/include/configs/imx8mp_venice.h +++ b/include/configs/imx8mp_venice.h @@ -97,9 +97,6 @@ #define PHYS_SDRAM_SIZE SZ_4G #define CONFIG_SYS_BOOTM_LEN SZ_256M
-/* UART */ -#define CONFIG_MXC_UART_BASE UART2_BASE_ADDR - /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE SZ_2K #define CONFIG_SYS_MAXARGS 64
2.36.0
Thanks Peng,
Tested-By: Tim Harvey tharvey@gateworks.com
Best Regards,
Tim
Enable CONFIG_SPL_DM_SERIAL. uart2 and its pinmux was already marked with u-boot,dm-spl. Move preloader_console_init after spl_init to make sure driver model work.
Signed-off-by: Peng Fan peng.fan@nxp.com Tested-by: Adam Ford aford173@gmail.com #imx8mm_beacon Reviewed-by: Fabio Estevam festevam@denx.de --- board/beacon/imx8mm/spl.c | 12 ++---------- board/beacon/imx8mn/spl.c | 11 ++--------- configs/imx8mm_beacon_defconfig | 1 - configs/imx8mn_beacon_2g_defconfig | 1 - configs/imx8mn_beacon_defconfig | 1 - include/configs/imx8mm_beacon.h | 2 -- include/configs/imx8mn_beacon.h | 2 -- 7 files changed, 4 insertions(+), 26 deletions(-)
diff --git a/board/beacon/imx8mm/spl.c b/board/beacon/imx8mm/spl.c index 12266b22a42..f92b4c3ed0a 100644 --- a/board/beacon/imx8mm/spl.c +++ b/board/beacon/imx8mm/spl.c @@ -59,14 +59,8 @@ int board_fit_config_name_match(const char *name) } #endif
-#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) #define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE)
-static iomux_v3_cfg_t const uart_pads[] = { - IMX8MM_PAD_UART2_RXD_UART2_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - IMX8MM_PAD_UART2_TXD_UART2_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - static iomux_v3_cfg_t const wdog_pads[] = { IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), }; @@ -79,8 +73,6 @@ int board_early_init_f(void)
set_wdog_reset(wdog);
- imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); - return 0; }
@@ -128,8 +120,6 @@ void board_init_f(ulong dummy)
timer_init();
- preloader_console_init(); - /* Clear the BSS. */ memset(__bss_start, 0, __bss_end - __bss_start);
@@ -139,6 +129,8 @@ void board_init_f(ulong dummy) hang(); }
+ preloader_console_init(); + ret = uclass_get_device_by_name(UCLASS_CLK, "clock-controller@30380000", &dev); diff --git a/board/beacon/imx8mn/spl.c b/board/beacon/imx8mn/spl.c index bb51be01c52..4563446db19 100644 --- a/board/beacon/imx8mn/spl.c +++ b/board/beacon/imx8mn/spl.c @@ -68,7 +68,6 @@ int board_fit_config_name_match(const char *name) } #endif
-#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) #define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) #define PWM1_PAD_CTRL (PAD_CTL_FSEL2 | PAD_CTL_DSE6)
@@ -76,11 +75,6 @@ static iomux_v3_cfg_t const pwm_pads[] = { IMX8MN_PAD_GPIO1_IO01__PWM1_OUT | MUX_PAD_CTRL(PWM1_PAD_CTRL), };
-static iomux_v3_cfg_t const uart_pads[] = { - IMX8MN_PAD_UART2_RXD__UART2_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - IMX8MN_PAD_UART2_TXD__UART2_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - static iomux_v3_cfg_t const wdog_pads[] = { IMX8MN_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), }; @@ -95,7 +89,6 @@ int board_early_init_f(void) imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); set_wdog_reset(wdog);
- imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); init_uart_clk(1);
return 0; @@ -114,14 +107,14 @@ void board_init_f(ulong dummy)
timer_init();
- preloader_console_init(); - ret = spl_init(); if (ret) { debug("spl_init() failed: %d\n", ret); hang(); }
+ preloader_console_init(); + enable_tzc380();
/* DDR initialization */ diff --git a/configs/imx8mm_beacon_defconfig b/configs/imx8mm_beacon_defconfig index 9cd8ac97285..a8981975f66 100644 --- a/configs/imx8mm_beacon_defconfig +++ b/configs/imx8mm_beacon_defconfig @@ -112,7 +112,6 @@ CONFIG_SPL_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_CONS_INDEX=2 CONFIG_DM_SERIAL=y -# CONFIG_SPL_DM_SERIAL is not set CONFIG_MXC_UART=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/imx8mn_beacon_2g_defconfig b/configs/imx8mn_beacon_2g_defconfig index 145f96d491d..cf1720725d0 100644 --- a/configs/imx8mn_beacon_2g_defconfig +++ b/configs/imx8mn_beacon_2g_defconfig @@ -114,7 +114,6 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_RESET=y CONFIG_DM_SERIAL=y -# CONFIG_SPL_DM_SERIAL is not set CONFIG_MXC_UART=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/imx8mn_beacon_defconfig b/configs/imx8mn_beacon_defconfig index 9052e68e967..882a6044989 100644 --- a/configs/imx8mn_beacon_defconfig +++ b/configs/imx8mn_beacon_defconfig @@ -118,7 +118,6 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_RESET=y CONFIG_DM_SERIAL=y -# CONFIG_SPL_DM_SERIAL is not set CONFIG_MXC_UART=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/include/configs/imx8mm_beacon.h b/include/configs/imx8mm_beacon.h index 573ddaf2952..4c9b5491f78 100644 --- a/include/configs/imx8mm_beacon.h +++ b/include/configs/imx8mm_beacon.h @@ -91,8 +91,6 @@ #define PHYS_SDRAM 0x40000000 #define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */
-#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(2) - /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 2048 #define CONFIG_SYS_MAXARGS 64 diff --git a/include/configs/imx8mn_beacon.h b/include/configs/imx8mn_beacon.h index 79c6b1076ff..c16dda5e22c 100644 --- a/include/configs/imx8mn_beacon.h +++ b/include/configs/imx8mn_beacon.h @@ -107,8 +107,6 @@ #define PHYS_SDRAM_SIZE 0x40000000 /* 1GB DDR */ #endif
Enable CONFIG_DM_SERIAL. uart3 and its pinmux was already marked with u-boot,dm-spl. Move preloader_console_init after spl_early_init to make sure driver model work.
Signed-off-by: Peng Fan peng.fan@nxp.com Reviewed-by: Fabio Estevam festevam@denx.de --- board/compulab/imx8mm-cl-iot-gate/spl.c | 12 ++---------- configs/imx8mm-cl-iot-gate-optee_defconfig | 1 + configs/imx8mm-cl-iot-gate_defconfig | 1 + include/configs/imx8mm-cl-iot-gate.h | 2 -- 4 files changed, 4 insertions(+), 12 deletions(-)
diff --git a/board/compulab/imx8mm-cl-iot-gate/spl.c b/board/compulab/imx8mm-cl-iot-gate/spl.c index 2dc62d6682e..f183704c9d2 100644 --- a/board/compulab/imx8mm-cl-iot-gate/spl.c +++ b/board/compulab/imx8mm-cl-iot-gate/spl.c @@ -83,14 +83,8 @@ int board_fit_config_name_match(const char *name) } #endif
-static iomux_v3_cfg_t const uart_pads[] = { - IMX8MM_PAD_UART3_RXD_UART3_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - IMX8MM_PAD_UART3_TXD_UART3_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - static iomux_v3_cfg_t const wdog_pads[] = { IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), }; @@ -103,8 +97,6 @@ int board_early_init_f(void)
@@ -155,8 +147,6 @@ void board_init_f(ulong dummy)
timer_init();
@@ -166,6 +156,8 @@ void board_init_f(ulong dummy) hang(); }
+ preloader_console_init(); + ret = uclass_get_device_by_name(UCLASS_CLK, "clock-controller@30380000", &dev); diff --git a/configs/imx8mm-cl-iot-gate-optee_defconfig b/configs/imx8mm-cl-iot-gate-optee_defconfig index 8b3d1b3ef1a..0f0b34fecf9 100644 --- a/configs/imx8mm-cl-iot-gate-optee_defconfig +++ b/configs/imx8mm-cl-iot-gate-optee_defconfig @@ -108,6 +108,7 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_RTC=y CONFIG_RTC_ABX80X=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/imx8mm-cl-iot-gate_defconfig b/configs/imx8mm-cl-iot-gate_defconfig index b418e86248f..7bd5f6540e9 100644 --- a/configs/imx8mm-cl-iot-gate_defconfig +++ b/configs/imx8mm-cl-iot-gate_defconfig @@ -111,6 +111,7 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_RTC=y CONFIG_RTC_ABX80X=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/include/configs/imx8mm-cl-iot-gate.h b/include/configs/imx8mm-cl-iot-gate.h index 8d9212ec64c..f262ab08f04 100644 --- a/include/configs/imx8mm-cl-iot-gate.h +++ b/include/configs/imx8mm-cl-iot-gate.h @@ -145,8 +145,6 @@ #define PHYS_SDRAM 0x40000000 #define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */
-#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(3) - /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 2048 #define CONFIG_SYS_MAXARGS 64
Signed-off-by: Peng Fan peng.fan@nxp.com Reviewed-by: Fabio Estevam festevam@denx.de --- board/engicam/imx8mm/spl.c | 14 +++----------- configs/imx8mm-icore-mx8mm-ctouch2_defconfig | 1 - configs/imx8mm-icore-mx8mm-edimm2.2_defconfig | 1 - include/configs/imx8mm_icore_mx8mm.h | 3 --- 4 files changed, 3 insertions(+), 16 deletions(-)
diff --git a/board/engicam/imx8mm/spl.c b/board/engicam/imx8mm/spl.c index f9be769ec59..f75f2dc634c 100644 --- a/board/engicam/imx8mm/spl.c +++ b/board/engicam/imx8mm/spl.c @@ -54,19 +54,11 @@ int board_fit_config_name_match(const char *name) } #endif
-static iomux_v3_cfg_t const uart_pads[] = { - IMX8MM_PAD_UART2_RXD_UART2_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - IMX8MM_PAD_UART2_TXD_UART2_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - int board_early_init_f(void) { - imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); - - return 0; + return 0; }
void board_init_f(ulong dummy) @@ -81,8 +73,6 @@ void board_init_f(ulong dummy)
timer_init();
@@ -92,6 +82,8 @@ void board_init_f(ulong dummy) hang(); }
/* DDR initialization */ diff --git a/configs/imx8mm-icore-mx8mm-ctouch2_defconfig b/configs/imx8mm-icore-mx8mm-ctouch2_defconfig index 535ff6dcba5..d95a74a7237 100644 --- a/configs/imx8mm-icore-mx8mm-ctouch2_defconfig +++ b/configs/imx8mm-icore-mx8mm-ctouch2_defconfig @@ -74,7 +74,6 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_CONS_INDEX=2 CONFIG_DM_SERIAL=y -# CONFIG_SPL_DM_SERIAL is not set CONFIG_MXC_UART=y CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y diff --git a/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig b/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig index 101d5a00bc7..43c697a39d8 100644 --- a/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig +++ b/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig @@ -74,7 +74,6 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_CONS_INDEX=2 CONFIG_DM_SERIAL=y -# CONFIG_SPL_DM_SERIAL is not set CONFIG_MXC_UART=y CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y diff --git a/include/configs/imx8mm_icore_mx8mm.h b/include/configs/imx8mm_icore_mx8mm.h index b9b24a8c51d..1a439370c09 100644 --- a/include/configs/imx8mm_icore_mx8mm.h +++ b/include/configs/imx8mm_icore_mx8mm.h @@ -65,9 +65,6 @@ #define PHYS_SDRAM_SIZE SZ_2G /* 2GB DDR */ #define CONFIG_SYS_BOOTM_LEN SZ_256M
-/* UART */ -#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(2) - /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 2048 #define CONFIG_SYS_MAXARGS 64
Enable CONFIG_DM_SERIAL. uart and its pinmux was already marked with u-boot,dm-spl. Move preloader_console_init after spl_early_init to make sure driver model work.
Signed-off-by: Peng Fan peng.fan@nxp.com Tested-by: Teresa Remmet t.remmet@phytec.de Reviewed-by: Fabio Estevam festevam@denx.de --- board/phytec/phycore_imx8mm/spl.c | 12 ++---------- board/phytec/phycore_imx8mp/spl.c | 8 -------- configs/phycore-imx8mm_defconfig | 1 + configs/phycore-imx8mp_defconfig | 1 + include/configs/phycore_imx8mm.h | 3 --- include/configs/phycore_imx8mp.h | 3 --- 6 files changed, 4 insertions(+), 24 deletions(-)
diff --git a/board/phytec/phycore_imx8mm/spl.c b/board/phytec/phycore_imx8mm/spl.c index d54145ef995..7f24a3affc8 100644 --- a/board/phytec/phycore_imx8mm/spl.c +++ b/board/phytec/phycore_imx8mm/spl.c @@ -57,14 +57,8 @@ int board_fit_config_name_match(const char *name) return 0; }
-#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) #define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE)
-static iomux_v3_cfg_t const uart_pads[] = { - IMX8MM_PAD_UART3_RXD_UART3_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - IMX8MM_PAD_UART3_TXD_UART3_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - static iomux_v3_cfg_t const wdog_pads[] = { IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), }; @@ -77,8 +71,6 @@ int board_early_init_f(void)
@@ -92,8 +84,6 @@ void board_init_f(ulong dummy)
board_early_init_f();
@@ -103,6 +93,8 @@ void board_init_f(ulong dummy) hang(); }
/* DDR initialization */ diff --git a/board/phytec/phycore_imx8mp/spl.c b/board/phytec/phycore_imx8mp/spl.c index 19c486e5517..38a581bef57 100644 --- a/board/phytec/phycore_imx8mp/spl.c +++ b/board/phytec/phycore_imx8mp/spl.c @@ -89,14 +89,8 @@ int board_fit_config_name_match(const char *name) return 0; }
-static iomux_v3_cfg_t const uart_pads[] = { - MX8MP_PAD_UART1_RXD__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - MX8MP_PAD_UART1_TXD__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - static iomux_v3_cfg_t const wdog_pads[] = { MX8MP_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), }; @@ -109,8 +103,6 @@ int board_early_init_f(void)
diff --git a/configs/phycore-imx8mm_defconfig b/configs/phycore-imx8mm_defconfig index ba5833f7060..9da222afc54 100644 --- a/configs/phycore-imx8mm_defconfig +++ b/configs/phycore-imx8mm_defconfig @@ -107,6 +107,7 @@ CONFIG_PINCTRL_IMX8M=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/phycore-imx8mp_defconfig b/configs/phycore-imx8mp_defconfig index 86d0f4df7f6..a851b1bdccb 100644 --- a/configs/phycore-imx8mp_defconfig +++ b/configs/phycore-imx8mp_defconfig @@ -98,6 +98,7 @@ CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_SPL_POWER_I2C=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y diff --git a/include/configs/phycore_imx8mm.h b/include/configs/phycore_imx8mm.h index 46fadd56106..564b8125ba3 100644 --- a/include/configs/phycore_imx8mm.h +++ b/include/configs/phycore_imx8mm.h @@ -83,9 +83,6 @@ #define PHYS_SDRAM 0x40000000 #define PHYS_SDRAM_SIZE SZ_2G /* 2GB DDR */
-/* UART */ -#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(3) - /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE SZ_2K #define CONFIG_SYS_MAXARGS 64 diff --git a/include/configs/phycore_imx8mp.h b/include/configs/phycore_imx8mp.h index eb92c423392..3e4315f2b81 100644 --- a/include/configs/phycore_imx8mp.h +++ b/include/configs/phycore_imx8mp.h @@ -83,9 +83,6 @@ #define PHYS_SDRAM 0x40000000 #define PHYS_SDRAM_SIZE 0x80000000
Enable CONFIG_DM_SERIAL. uart and its pinmux was already marked with u-boot,dm-spl. Move preloader_console_init after spl_init to make sure driver model work.
Signed-off-by: Peng Fan peng.fan@nxp.com Reviewed-by: Ariel D'Alessandro ariel.dalessandro@collabora.com Reviewed-by: Fabio Estevam festevam@denx.de --- board/variscite/imx8mn_var_som/spl.c | 11 ++--------- configs/imx8mn_var_som_defconfig | 1 + include/configs/imx8mn_var_som.h | 2 -- 3 files changed, 3 insertions(+), 11 deletions(-)
diff --git a/board/variscite/imx8mn_var_som/spl.c b/board/variscite/imx8mn_var_som/spl.c index 32703c5f0b3..1a8b64fc0a9 100644 --- a/board/variscite/imx8mn_var_som/spl.c +++ b/board/variscite/imx8mn_var_som/spl.c @@ -40,14 +40,8 @@ void spl_board_init(void) puts("Failed to find clock node. Check device tree\n"); }
-static const iomux_v3_cfg_t uart_pads[] = { - IMX8MN_PAD_UART4_RXD__UART4_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - IMX8MN_PAD_UART4_TXD__UART4_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - static const iomux_v3_cfg_t wdog_pads[] = { IMX8MN_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), }; @@ -59,7 +53,6 @@ int board_early_init_f(void) imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); set_wdog_reset(wdog);
- imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); init_uart_clk(3);
return 0; @@ -78,14 +71,14 @@ void board_init_f(ulong dummy)
timer_init();
+ preloader_console_init(); + /* DDR initialization */ spl_dram_init();
diff --git a/configs/imx8mn_var_som_defconfig b/configs/imx8mn_var_som_defconfig index 5ec82f2a926..39209f62c46 100644 --- a/configs/imx8mn_var_som_defconfig +++ b/configs/imx8mn_var_som_defconfig @@ -83,6 +83,7 @@ CONFIG_SPL_DM_PMIC_BD71837=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SYSRESET=y CONFIG_SYSRESET_PSCI=y diff --git a/include/configs/imx8mn_var_som.h b/include/configs/imx8mn_var_som.h index 00358892b28..6ce60b0d704 100644 --- a/include/configs/imx8mn_var_som.h +++ b/include/configs/imx8mn_var_som.h @@ -64,8 +64,6 @@ #define PHYS_SDRAM 0x40000000 #define PHYS_SDRAM_SIZE SZ_1G /* 1GB DDR */
-#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(4) - /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE SZ_2K #define CONFIG_SYS_MAXARGS 64
Signed-off-by: Peng Fan peng.fan@nxp.com Acked-by: Frieder Schrempf frieder.schrempf@kontron.de Reviewed-by: Fabio Estevam festevam@denx.de --- board/kontron/sl-mx8mm/spl.c | 12 ++---------- configs/kontron-sl-mx8mm_defconfig | 1 + include/configs/kontron-sl-mx8mm.h | 1 - 3 files changed, 3 insertions(+), 11 deletions(-)
diff --git a/board/kontron/sl-mx8mm/spl.c b/board/kontron/sl-mx8mm/spl.c index 4ef03c8c172..a58a75dc958 100644 --- a/board/kontron/sl-mx8mm/spl.c +++ b/board/kontron/sl-mx8mm/spl.c @@ -32,7 +32,6 @@ enum {
#define GPIO_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) #define I2C_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE) -#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) #define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE)
#define TOUCH_RESET_GPIO IMX_GPIO_NR(3, 23) @@ -51,11 +50,6 @@ static iomux_v3_cfg_t const touch_gpio[] = { IMX8MM_PAD_SAI5_RXD2_GPIO3_IO23 | MUX_PAD_CTRL(GPIO_PAD_CTRL) };
-static iomux_v3_cfg_t const uart_pads[] = { - IMX8MM_PAD_UART3_RXD_UART3_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - IMX8MM_PAD_UART3_TXD_UART3_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - static iomux_v3_cfg_t const wdog_pads[] = { IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), }; @@ -230,8 +224,6 @@ int board_early_init_f(void)
@@ -273,8 +265,6 @@ void board_init_f(ulong dummy)
timer_init();
@@ -284,6 +274,8 @@ void board_init_f(ulong dummy) hang(); }
/* PMIC initialization */ diff --git a/configs/kontron-sl-mx8mm_defconfig b/configs/kontron-sl-mx8mm_defconfig index f07b7890a0c..1abbbf41f5f 100644 --- a/configs/kontron-sl-mx8mm_defconfig +++ b/configs/kontron-sl-mx8mm_defconfig @@ -103,6 +103,7 @@ CONFIG_DM_REGULATOR=y CONFIG_DM_RTC=y CONFIG_RTC_RV8803=y CONFIG_CONS_INDEX=2 +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/include/configs/kontron-sl-mx8mm.h b/include/configs/kontron-sl-mx8mm.h index 231571b05eb..10f06e66836 100644 --- a/include/configs/kontron-sl-mx8mm.h +++ b/include/configs/kontron-sl-mx8mm.h @@ -28,7 +28,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* Board and environment settings */ -#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(3) #define CONFIG_HOSTNAME "kontron-mx8mm"
#ifdef CONFIG_USB_EHCI_HCD
CONFIG_SPL_RAW_IMAGE_SUPPORT default y has been used to replace CONFIG_SPL_ABORT_ON_RAW_IMAGE for quite some time, so drop CONFIG_SPL_ABORT_ON_RAW_IMAGE.
Signed-off-by: Peng Fan peng.fan@nxp.com --- include/configs/capricorn-common.h | 1 - include/configs/cgtqmx8.h | 1 - include/configs/imx8mm-cl-iot-gate.h | 1 - include/configs/imx8mm_beacon.h | 1 - include/configs/imx8mm_data_modul_edm_sbc.h | 1 - include/configs/imx8mm_evk.h | 1 - include/configs/imx8mm_icore_mx8mm.h | 1 - include/configs/imx8mm_venice.h | 1 - include/configs/imx8mn_beacon.h | 1 - include/configs/imx8mn_evk.h | 1 - include/configs/imx8mn_venice.h | 1 - include/configs/imx8mp_evk.h | 1 - include/configs/imx8mp_rsb3720.h | 1 - include/configs/imx8mp_venice.h | 1 - include/configs/imx8mq_cm.h | 1 - include/configs/imx8mq_evk.h | 1 - include/configs/imx8mq_phanbell.h | 1 - include/configs/imx8qm_mek.h | 1 - include/configs/imx8qxp_mek.h | 1 - include/configs/imx8ulp_evk.h | 1 - include/configs/kontron_pitx_imx8m.h | 1 - include/configs/phycore_imx8mm.h | 1 - include/configs/phycore_imx8mp.h | 1 - include/configs/pico-imx8mq.h | 1 - include/configs/verdin-imx8mm.h | 1 - include/configs/verdin-imx8mp.h | 1 - 26 files changed, 26 deletions(-)
diff --git a/include/configs/capricorn-common.h b/include/configs/capricorn-common.h index 364bd50b591..aa4c9818638 100644 --- a/include/configs/capricorn-common.h +++ b/include/configs/capricorn-common.h @@ -26,7 +26,6 @@ #define CONFIG_MALLOC_F_ADDR 0x00120000
#define CONFIG_SPL_RAW_IMAGE_ARM_TRUSTED_FIRMWARE -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
#endif /* CONFIG_SPL_BUILD */
diff --git a/include/configs/cgtqmx8.h b/include/configs/cgtqmx8.h index 4c04bbf6447..eee6e735b1f 100644 --- a/include/configs/cgtqmx8.h +++ b/include/configs/cgtqmx8.h @@ -25,7 +25,6 @@
-#define CONFIG_SPL_ABORT_ON_RAW_IMAGE #endif
/* Flat Device Tree Definitions */ diff --git a/include/configs/imx8mm-cl-iot-gate.h b/include/configs/imx8mm-cl-iot-gate.h index f262ab08f04..cbb27db6be0 100644 --- a/include/configs/imx8mm-cl-iot-gate.h +++ b/include/configs/imx8mm-cl-iot-gate.h @@ -27,7 +27,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x912000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
#endif
diff --git a/include/configs/imx8mm_beacon.h b/include/configs/imx8mm_beacon.h index 4c9b5491f78..a9ca13a9da4 100644 --- a/include/configs/imx8mm_beacon.h +++ b/include/configs/imx8mm_beacon.h @@ -24,7 +24,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x930000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
#endif
diff --git a/include/configs/imx8mm_data_modul_edm_sbc.h b/include/configs/imx8mm_data_modul_edm_sbc.h index 67667dd523d..2f3608835a2 100644 --- a/include/configs/imx8mm_data_modul_edm_sbc.h +++ b/include/configs/imx8mm_data_modul_edm_sbc.h @@ -25,7 +25,6 @@ #define CONFIG_MALLOC_F_ADDR 0x930000
#endif
diff --git a/include/configs/imx8mm_evk.h b/include/configs/imx8mm_evk.h index 002b2e68bba..d216455ebd9 100644 --- a/include/configs/imx8mm_evk.h +++ b/include/configs/imx8mm_evk.h @@ -26,7 +26,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x930000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
#endif
diff --git a/include/configs/imx8mm_icore_mx8mm.h b/include/configs/imx8mm_icore_mx8mm.h index 1a439370c09..34993cafdaf 100644 --- a/include/configs/imx8mm_icore_mx8mm.h +++ b/include/configs/imx8mm_icore_mx8mm.h @@ -25,7 +25,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ # define CONFIG_MALLOC_F_ADDR 0x930000 /* For RAW image gives a error info not panic */ -# define CONFIG_SPL_ABORT_ON_RAW_IMAGE #endif /* CONFIG_SPL_BUILD */
#ifndef CONFIG_SPL_BUILD diff --git a/include/configs/imx8mm_venice.h b/include/configs/imx8mm_venice.h index 90e8941a254..75f7dae8349 100644 --- a/include/configs/imx8mm_venice.h +++ b/include/configs/imx8mm_venice.h @@ -24,7 +24,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x930000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
#endif
diff --git a/include/configs/imx8mn_beacon.h b/include/configs/imx8mn_beacon.h index c16dda5e22c..57b99d5a110 100644 --- a/include/configs/imx8mn_beacon.h +++ b/include/configs/imx8mn_beacon.h @@ -25,7 +25,6 @@ #define CONFIG_MALLOC_F_ADDR 0x184000
diff --git a/include/configs/imx8mn_evk.h b/include/configs/imx8mn_evk.h index 86be1b8b3be..0b2eefa6368 100644 --- a/include/configs/imx8mn_evk.h +++ b/include/configs/imx8mn_evk.h @@ -25,7 +25,6 @@ #define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */
#endif
diff --git a/include/configs/imx8mn_venice.h b/include/configs/imx8mn_venice.h index 6555dd4349c..160ba9648db 100644 --- a/include/configs/imx8mn_venice.h +++ b/include/configs/imx8mn_venice.h @@ -22,7 +22,6 @@ #define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */
/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE #endif
#define MEM_LAYOUT_ENV_SETTINGS \ diff --git a/include/configs/imx8mp_evk.h b/include/configs/imx8mp_evk.h index 373098f10c4..4aac7c81d2e 100644 --- a/include/configs/imx8mp_evk.h +++ b/include/configs/imx8mp_evk.h @@ -24,7 +24,6 @@ #define CONFIG_SYS_SPL_MALLOC_START 0x42200000 #define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */
#define CONFIG_POWER_PCA9450
diff --git a/include/configs/imx8mp_rsb3720.h b/include/configs/imx8mp_rsb3720.h index 52e8ea8f86a..7dcc2e16c71 100644 --- a/include/configs/imx8mp_rsb3720.h +++ b/include/configs/imx8mp_rsb3720.h @@ -39,7 +39,6 @@ * set \ */
#if defined(CONFIG_NAND_BOOT) #define CONFIG_SPL_NAND_MXS diff --git a/include/configs/imx8mp_venice.h b/include/configs/imx8mp_venice.h index c09a1b4572a..17400cffc63 100644 --- a/include/configs/imx8mp_venice.h +++ b/include/configs/imx8mp_venice.h @@ -22,7 +22,6 @@ #define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */
#define MEM_LAYOUT_ENV_SETTINGS \ diff --git a/include/configs/imx8mq_cm.h b/include/configs/imx8mq_cm.h index 6eecfc813a4..7a9dd962ac2 100644 --- a/include/configs/imx8mq_cm.h +++ b/include/configs/imx8mq_cm.h @@ -26,7 +26,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x182000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
#endif
diff --git a/include/configs/imx8mq_evk.h b/include/configs/imx8mq_evk.h index e31f4135ae5..b7294ebef1e 100644 --- a/include/configs/imx8mq_evk.h +++ b/include/configs/imx8mq_evk.h @@ -27,7 +27,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x182000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
#define CONFIG_POWER_PFUZE100 #define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08 diff --git a/include/configs/imx8mq_phanbell.h b/include/configs/imx8mq_phanbell.h index 57e45b0447c..93e531b66fd 100644 --- a/include/configs/imx8mq_phanbell.h +++ b/include/configs/imx8mq_phanbell.h @@ -24,7 +24,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x182000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE #endif
/* ENET Config */ diff --git a/include/configs/imx8qm_mek.h b/include/configs/imx8qm_mek.h index 61d56e269ac..ddcd6cf2319 100644 --- a/include/configs/imx8qm_mek.h +++ b/include/configs/imx8qm_mek.h @@ -26,7 +26,6 @@
#ifdef CONFIG_AHAB_BOOT diff --git a/include/configs/imx8qxp_mek.h b/include/configs/imx8qxp_mek.h index 26dc4ded030..dee6852df4c 100644 --- a/include/configs/imx8qxp_mek.h +++ b/include/configs/imx8qxp_mek.h @@ -24,7 +24,6 @@
#ifdef CONFIG_AHAB_BOOT diff --git a/include/configs/imx8ulp_evk.h b/include/configs/imx8ulp_evk.h index 05df43b39b4..190bbb8c13c 100644 --- a/include/configs/imx8ulp_evk.h +++ b/include/configs/imx8ulp_evk.h @@ -23,7 +23,6 @@
#define CONFIG_MALLOC_F_ADDR 0x22040000
-#define CONFIG_SPL_ABORT_ON_RAW_IMAGE /* For RAW image gives a error info not panic */
#endif
diff --git a/include/configs/kontron_pitx_imx8m.h b/include/configs/kontron_pitx_imx8m.h index 1834991ac3b..9089b76d26e 100644 --- a/include/configs/kontron_pitx_imx8m.h +++ b/include/configs/kontron_pitx_imx8m.h @@ -28,7 +28,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x182000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
#define CONFIG_POWER_PFUZE100 diff --git a/include/configs/phycore_imx8mm.h b/include/configs/phycore_imx8mm.h index 564b8125ba3..b70c31ca633 100644 --- a/include/configs/phycore_imx8mm.h +++ b/include/configs/phycore_imx8mm.h @@ -27,7 +27,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x930000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE #endif
#define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/phycore_imx8mp.h b/include/configs/phycore_imx8mp.h index 3e4315f2b81..95d70bb92d1 100644 --- a/include/configs/phycore_imx8mp.h +++ b/include/configs/phycore_imx8mp.h @@ -24,7 +24,6 @@ #define CONFIG_SYS_SPL_MALLOC_START 0x42200000 #define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K
diff --git a/include/configs/pico-imx8mq.h b/include/configs/pico-imx8mq.h index 1dc7d352590..de035160255 100644 --- a/include/configs/pico-imx8mq.h +++ b/include/configs/pico-imx8mq.h @@ -24,7 +24,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x182000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE #endif
/* ENET Config */ diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin-imx8mm.h index 9ed9da043f6..3f9ddc4eb81 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -26,7 +26,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x930000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE #endif
#define MEM_LAYOUT_ENV_SETTINGS \ diff --git a/include/configs/verdin-imx8mp.h b/include/configs/verdin-imx8mp.h index 20e8473f793..09eac5288ce 100644 --- a/include/configs/verdin-imx8mp.h +++ b/include/configs/verdin-imx8mp.h @@ -25,7 +25,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x184000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
Some SPL definitions could be generalized, so use imx8m.h for that. i.MX8MN/Q/P will follow up.
Signed-off-by: Peng Fan peng.fan@nxp.com Tested-by: Tim Harvey tharvey@gateworks.com #imx8mm-venice-* --- include/configs/imx8m.h | 29 +++++++++++++++++++++ include/configs/imx8mm-cl-iot-gate.h | 17 ++---------- include/configs/imx8mm_beacon.h | 21 +-------------- include/configs/imx8mm_data_modul_edm_sbc.h | 16 +++--------- include/configs/imx8mm_evk.h | 21 +-------------- include/configs/imx8mm_icore_mx8mm.h | 20 +------------- include/configs/imx8mm_venice.h | 18 ++----------- include/configs/kontron-sl-mx8mm.h | 14 +--------- include/configs/phycore_imx8mm.h | 20 +------------- include/configs/verdin-imx8mm.h | 20 +------------- 10 files changed, 42 insertions(+), 154 deletions(-) create mode 100644 include/configs/imx8m.h
diff --git a/include/configs/imx8m.h b/include/configs/imx8m.h new file mode 100644 index 00000000000..cb8ce5689ac --- /dev/null +++ b/include/configs/imx8m.h @@ -0,0 +1,29 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2022 NXP + */ + +#ifndef __IMX8MM_H +#define __IMX8MM_H + +#include <linux/sizes.h> +#include <linux/stringify.h> +#include <asm/arch/imx-regs.h> + +#define CONFIG_SPL_MAX_SIZE (172 * 1024) +#define CONFIG_SYS_MONITOR_LEN SZ_512K +#define CONFIG_SYS_UBOOT_BASE \ + (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_STACK 0x920000 +#define CONFIG_SPL_BSS_START_ADDR 0x910000 +#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K +#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K + +/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ +#define CONFIG_MALLOC_F_ADDR 0x930000 + +#endif +#endif diff --git a/include/configs/imx8mm-cl-iot-gate.h b/include/configs/imx8mm-cl-iot-gate.h index cbb27db6be0..cbf33a76a09 100644 --- a/include/configs/imx8mm-cl-iot-gate.h +++ b/include/configs/imx8mm-cl-iot-gate.h @@ -6,28 +6,15 @@ #ifndef __IMX8MM_CL_IOT_GATE_H #define __IMX8MM_CL_IOT_GATE_H
-#include <linux/sizes.h> -#include <linux/stringify.h> -#include <asm/arch/imx-regs.h> +#include <configs/imx8m.h> #include <config_distro_bootcmd.h>
#define CONFIG_SYS_BOOTM_LEN (32 * SZ_1M) -#define CONFIG_SPL_MAX_SIZE (148 * 1024) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x920000 -#define CONFIG_SPL_BSS_START_ADDR 0x910000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K /* 8 KB */ -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ - +#undef CONFIG_MALLOC_F_ADDR /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x912000 -/* For RAW image gives a error info not panic */ - #endif
/* GUIDs for capsule updatable firmware images */ diff --git a/include/configs/imx8mm_beacon.h b/include/configs/imx8mm_beacon.h index a9ca13a9da4..c73188a16f2 100644 --- a/include/configs/imx8mm_beacon.h +++ b/include/configs/imx8mm_beacon.h @@ -6,26 +6,7 @@ #ifndef __IMX8MM_BEACON_H #define __IMX8MM_BEACON_H
-#include <linux/sizes.h> -#include <asm/arch/imx-regs.h> - -#define CONFIG_SPL_MAX_SIZE (148 * 1024) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) - -#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x920000 -#define CONFIG_SPL_BSS_START_ADDR 0x910000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K /* 8 KB */ -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ - -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ - -#endif +#include <configs/imx8m.h>
/* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/imx8mm_data_modul_edm_sbc.h b/include/configs/imx8mm_data_modul_edm_sbc.h index 2f3608835a2..e098cddf967 100644 --- a/include/configs/imx8mm_data_modul_edm_sbc.h +++ b/include/configs/imx8mm_data_modul_edm_sbc.h @@ -6,26 +6,16 @@ #ifndef __IMX8MM_DATA_MODUL_EDM_SBC_H #define __IMX8MM_DATA_MODUL_EDM_SBC_H
#define CONFIG_SYS_BOOTM_LEN SZ_128M
-#define CONFIG_SPL_MAX_SIZE (148 * 1024) +#undef CONFIG_SYS_MONITOR_LEN #define CONFIG_SYS_MONITOR_LEN SZ_1M
-#define CONFIG_SPL_STACK 0x920000 #ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_BSS_START_ADDR 0x910000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K /* 8 kiB */ -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#undef CONFIG_SYS_SPL_MALLOC_SIZE #define CONFIG_SYS_SPL_MALLOC_SIZE SZ_16M /* 16 MiB */ - -#define CONFIG_MALLOC_F_ADDR 0x930000 - -/* For RAW image gives a error info not panic */ - #endif
/* Link Definitions */ diff --git a/include/configs/imx8mm_evk.h b/include/configs/imx8mm_evk.h index d216455ebd9..3d617f11d5e 100644 --- a/include/configs/imx8mm_evk.h +++ b/include/configs/imx8mm_evk.h @@ -6,28 +6,9 @@ #ifndef __IMX8MM_EVK_H #define __IMX8MM_EVK_H
#define CONFIG_SYS_BOOTM_LEN (64 * SZ_1M) -#define CONFIG_SPL_MAX_SIZE (148 * 1024) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) - -#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x920000 -#define CONFIG_SPL_BSS_START_ADDR 0x910000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K /* 8 KB */ -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ - -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ - -#endif
#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ diff --git a/include/configs/imx8mm_icore_mx8mm.h b/include/configs/imx8mm_icore_mx8mm.h index 34993cafdaf..7d52d43ef13 100644 --- a/include/configs/imx8mm_icore_mx8mm.h +++ b/include/configs/imx8mm_icore_mx8mm.h @@ -7,25 +7,7 @@ #ifndef __IMX8MM_ICORE_MX8MM_H #define __IMX8MM_ICORE_MX8MM_H
-#include <linux/sizes.h> -#include <asm/arch/imx-regs.h> - -#define CONFIG_SPL_MAX_SIZE (148 * 1024) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) - -#ifdef CONFIG_SPL_BUILD -# define CONFIG_SPL_STACK 0x920000 -# define CONFIG_SPL_BSS_START_ADDR 0x910000 -# define CONFIG_SPL_BSS_MAX_SIZE SZ_8K -# define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -# define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K - -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -# define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ -#endif /* CONFIG_SPL_BUILD */ +#include <configs/imx8m.h>
#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ diff --git a/include/configs/imx8mm_venice.h b/include/configs/imx8mm_venice.h index 75f7dae8349..cc6fa9479ae 100644 --- a/include/configs/imx8mm_venice.h +++ b/include/configs/imx8mm_venice.h @@ -6,25 +6,11 @@ #ifndef __IMX8MM_VENICE_H #define __IMX8MM_VENICE_H
-#include <asm/arch/imx-regs.h> -#include <linux/sizes.h> - -#define CONFIG_SPL_MAX_SIZE (148 * 1024) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) +#include <configs/imx8m.h>
#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x920000 -#define CONFIG_SPL_BSS_START_ADDR 0x910000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#undef CONFIG_SYS_SPL_MALLOC_SIZE #define CONFIG_SYS_SPL_MALLOC_SIZE SZ_1M - -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ - #endif
#define MEM_LAYOUT_ENV_SETTINGS \ diff --git a/include/configs/kontron-sl-mx8mm.h b/include/configs/kontron-sl-mx8mm.h index 10f06e66836..b1579097570 100644 --- a/include/configs/kontron-sl-mx8mm.h +++ b/include/configs/kontron-sl-mx8mm.h @@ -7,8 +7,7 @@ #ifndef __KONTRON_MX8MM_CONFIG_H #define __KONTRON_MX8MM_CONFIG_H
-#include <asm/arch/imx-regs.h> -#include <linux/sizes.h> +#include <configs/imx8m.h>
#ifdef CONFIG_SPL_BUILD #include <config.h> @@ -57,17 +56,6 @@ #endif
#define CONFIG_SYS_BOOTM_LEN SZ_64M -#define CONFIG_SPL_MAX_SIZE (148 * SZ_1K) - -#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x91fff0 -#define CONFIG_SPL_BSS_START_ADDR 0x910000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x930000 -#endif
#define ENV_MEM_LAYOUT_SETTINGS \ "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ diff --git a/include/configs/phycore_imx8mm.h b/include/configs/phycore_imx8mm.h index b70c31ca633..7fdb429c79a 100644 --- a/include/configs/phycore_imx8mm.h +++ b/include/configs/phycore_imx8mm.h @@ -7,27 +7,9 @@ #ifndef __PHYCORE_IMX8MM_H #define __PHYCORE_IMX8MM_H
#define CONFIG_SYS_BOOTM_LEN SZ_64M -#define CONFIG_SPL_MAX_SIZE (148 * SZ_1K) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) - -#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x920000 -#define CONFIG_SPL_BSS_START_ADDR 0x910000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K - -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ -#endif
#define CONFIG_EXTRA_ENV_SETTINGS \ "image=Image\0" \ diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin-imx8mm.h index 3f9ddc4eb81..31fff9dbf9d 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -6,28 +6,10 @@ #ifndef __VERDIN_IMX8MM_H #define __VERDIN_IMX8MM_H
-#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x920000 -#define CONFIG_SPL_BSS_START_ADDR 0x910000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K /* 8 KB */ -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ - -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ -#endif - #define MEM_LAYOUT_ENV_SETTINGS \ "fdt_addr_r=0x44000000\0" \ "kernel_addr_r=0x42000000\0" \
Some SPL definitions could be generalized, so use imx8m.h for iMX8MN.
Tested-by: Tim Harvey tharvey@gateworks.com #imx8mn-venice-* Tested-by: Ariel D'Alessandro ariel.dalessandro@collabora.com #i.MX8MN BSH SMM S2 PRO board Signed-off-by: Peng Fan peng.fan@nxp.com --- include/configs/imx8m.h | 10 ++++++++++ include/configs/imx8mn_bsh_smm_s2_common.h | 17 +---------------- include/configs/imx8mn_evk.h | 20 +------------------- include/configs/imx8mn_var_som.h | 15 +-------------- include/configs/imx8mn_venice.h | 18 +----------------- 5 files changed, 14 insertions(+), 66 deletions(-)
diff --git a/include/configs/imx8m.h b/include/configs/imx8m.h index cb8ce5689ac..354a9b9fd0d 100644 --- a/include/configs/imx8m.h +++ b/include/configs/imx8m.h @@ -16,6 +16,8 @@ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
#ifdef CONFIG_SPL_BUILD + +#ifdef CONFIG_IMX8MM #define CONFIG_SPL_STACK 0x920000 #define CONFIG_SPL_BSS_START_ADDR 0x910000 #define CONFIG_SPL_BSS_MAX_SIZE SZ_8K @@ -25,5 +27,13 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x930000
+#elif defined(CONFIG_IMX8MN) +#define CONFIG_SPL_STACK 0x980000 +#define CONFIG_SPL_BSS_START_ADDR 0x950000 +#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K +#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K + +#endif #endif #endif diff --git a/include/configs/imx8mn_bsh_smm_s2_common.h b/include/configs/imx8mn_bsh_smm_s2_common.h index 57be38d9433..eb210dc597b 100644 --- a/include/configs/imx8mn_bsh_smm_s2_common.h +++ b/include/configs/imx8mn_bsh_smm_s2_common.h @@ -6,25 +6,10 @@ #ifndef __IMX8MN_BSH_SMM_S2_COMMON_H #define __IMX8MN_BSH_SMM_S2_COMMON_H
-#define CONFIG_SPL_MAX_SIZE (148 * SZ_1K) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) - -#define CONFIG_SPL_STACK 0x980000 -#define CONFIG_SPL_BSS_START_ADDR 0x950000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K - - - #define MEM_LAYOUT_ENV_SETTINGS \ "scriptaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ diff --git a/include/configs/imx8mn_evk.h b/include/configs/imx8mn_evk.h index 0b2eefa6368..902e0f8434f 100644 --- a/include/configs/imx8mn_evk.h +++ b/include/configs/imx8mn_evk.h @@ -6,28 +6,10 @@ #ifndef __IMX8MN_EVK_H #define __IMX8MN_EVK_H
-#define CONFIG_SPL_MAX_SIZE (148 * 1024) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) - -#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x980000 -#define CONFIG_SPL_BSS_START_ADDR 0x950000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K /* 8 KB */ -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ - -/* For RAW image gives a error info not panic */ - -#endif - #ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ diff --git a/include/configs/imx8mn_var_som.h b/include/configs/imx8mn_var_som.h index 6ce60b0d704..fc9c4ca4530 100644 --- a/include/configs/imx8mn_var_som.h +++ b/include/configs/imx8mn_var_som.h @@ -6,23 +6,10 @@ #ifndef __IMX8MN_VAR_SOM_H #define __IMX8MN_VAR_SOM_H
-#define CONFIG_SPL_MAX_SIZE (148 * SZ_1K) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) - -#define CONFIG_SPL_STACK 0x980000 -#define CONFIG_SPL_BSS_START_ADDR 0x950000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K - #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ func(MMC, mmc, 2) \ diff --git a/include/configs/imx8mn_venice.h b/include/configs/imx8mn_venice.h index 160ba9648db..d122a5a5a79 100644 --- a/include/configs/imx8mn_venice.h +++ b/include/configs/imx8mn_venice.h @@ -6,23 +6,7 @@ #ifndef __IMX8MM_VENICE_H #define __IMX8MM_VENICE_H
-#include <asm/arch/imx-regs.h> -#include <linux/sizes.h> - -#define CONFIG_SPL_MAX_SIZE (148 * 1024) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) - -#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x980000 -#define CONFIG_SPL_BSS_START_ADDR 0x950000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K /* 8 KB */ -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ - -/* For RAW image gives a error info not panic */ -#endif +#include <configs/imx8m.h>
#define MEM_LAYOUT_ENV_SETTINGS \ "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \
Some SPL definitions could be generalized, so use imx8m.h for iMX8MP.
Tested-by: Tim Harvey tharvey@gateworks.com #imx8mp-venice-* Signed-off-by: Peng Fan peng.fan@nxp.com --- include/configs/imx8m.h | 8 ++++++++ include/configs/imx8mp_evk.h | 17 +---------------- include/configs/imx8mp_rsb3720.h | 16 +--------------- include/configs/imx8mp_venice.h | 18 +----------------- include/configs/phycore_imx8mp.h | 16 +--------------- include/configs/verdin-imx8mp.h | 16 +--------------- 6 files changed, 13 insertions(+), 78 deletions(-)
diff --git a/include/configs/imx8m.h b/include/configs/imx8m.h index 354a9b9fd0d..7894a1c1068 100644 --- a/include/configs/imx8m.h +++ b/include/configs/imx8m.h @@ -34,6 +34,14 @@ #define CONFIG_SYS_SPL_MALLOC_START 0x42200000 #define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K
+#elif defined(CONFIG_IMX8MP) +/*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/ +#define CONFIG_SPL_STACK 0x960000 +#define CONFIG_SPL_BSS_START_ADDR 0x0098FC00 +#define CONFIG_SPL_BSS_MAX_SIZE 0x400 +#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K + #endif #endif #endif diff --git a/include/configs/imx8mp_evk.h b/include/configs/imx8mp_evk.h index 4aac7c81d2e..b54b88a8f67 100644 --- a/include/configs/imx8mp_evk.h +++ b/include/configs/imx8mp_evk.h @@ -6,27 +6,12 @@ #ifndef __IMX8MP_EVK_H #define __IMX8MP_EVK_H
-#define CONFIG_SPL_MAX_SIZE (152 * 1024) -#define CONFIG_SYS_MONITOR_LEN (512 * 1024) -#define CONFIG_SYS_UBOOT_BASE (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) - #ifdef CONFIG_SPL_BUILD -/*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/ -#define CONFIG_SPL_STACK 0x960000 -#define CONFIG_SPL_BSS_START_ADDR 0x0098FC00 -#define CONFIG_SPL_BSS_MAX_SIZE 0x400 /* 1 KB */ -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ - - #define CONFIG_POWER_PCA9450 - #endif
#if defined(CONFIG_CMD_NET) diff --git a/include/configs/imx8mp_rsb3720.h b/include/configs/imx8mp_rsb3720.h index 7dcc2e16c71..b498aa5be2b 100644 --- a/include/configs/imx8mp_rsb3720.h +++ b/include/configs/imx8mp_rsb3720.h @@ -7,17 +7,11 @@ #ifndef __IMX8MP_RSB3720_H #define __IMX8MP_RSB3720_H
-#define CONFIG_SPL_MAX_SIZE (152 * 1024) -#define CONFIG_SYS_MONITOR_LEN (512 * 1024) -#define CONFIG_SYS_UBOOT_BASE (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) - /* GUIDs for capsule updatable firmware images */ #define IMX8MP_RSB3720A1_4G_FIT_IMAGE_GUID \ EFI_GUID(0xb1251e89, 0x384a, 0x4635, 0xa8, 0x06, \ @@ -28,18 +22,10 @@ 0x5f, 0xd3, 0x6b, 0x9b, 0xe5, 0xb9)
#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x960000 -#define CONFIG_SPL_BSS_START_ADDR 0x0098FC00 -#define CONFIG_SPL_BSS_MAX_SIZE 0x400 /* 1 KB */ -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ - #define CONFIG_MALLOC_F_ADDR 0x184000 /* malloc f used before \ * GD_FLG_FULL_MALLOC_INIT \ * set \ */ - - #if defined(CONFIG_NAND_BOOT) #define CONFIG_SPL_NAND_MXS #endif diff --git a/include/configs/imx8mp_venice.h b/include/configs/imx8mp_venice.h index 17400cffc63..fb37f5d399c 100644 --- a/include/configs/imx8mp_venice.h +++ b/include/configs/imx8mp_venice.h @@ -6,23 +6,7 @@ #ifndef __IMX8MP_VENICE_H #define __IMX8MP_VENICE_H
-#include <asm/arch/imx-regs.h> -#include <linux/sizes.h> - -#define CONFIG_SPL_MAX_SIZE (152 * 1024) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) - -#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x960000 -#define CONFIG_SPL_BSS_START_ADDR 0x0098FC00 -#define CONFIG_SPL_BSS_MAX_SIZE 0x400 /* 1 KB */ -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ - -/* For RAW image gives a error info not panic */ -#endif +#include <configs/imx8m.h>
#define MEM_LAYOUT_ENV_SETTINGS \ "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ diff --git a/include/configs/phycore_imx8mp.h b/include/configs/phycore_imx8mp.h index 95d70bb92d1..eaa91f66bfd 100644 --- a/include/configs/phycore_imx8mp.h +++ b/include/configs/phycore_imx8mp.h @@ -7,26 +7,12 @@ #ifndef __PHYCORE_IMX8MP_H #define __PHYCORE_IMX8MP_H
-#include <linux/sizes.h> -#include <asm/arch/imx-regs.h> +#include <configs/imx8m.h>
-#define CONFIG_SPL_MAX_SIZE (152 * SZ_1K) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) - #ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x960000 -#define CONFIG_SPL_BSS_START_ADDR 0x98FC00 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_1K -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K - - #define CONFIG_POWER_PCA9450 - #endif
#define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/verdin-imx8mp.h b/include/configs/verdin-imx8mp.h index 09eac5288ce..23bed27e176 100644 --- a/include/configs/verdin-imx8mp.h +++ b/include/configs/verdin-imx8mp.h @@ -6,25 +6,11 @@ #ifndef __VERDIN_IMX8MP_H #define __VERDIN_IMX8MP_H
-#include <asm/arch/imx-regs.h> -#include <linux/sizes.h> - -#define CONFIG_SPL_MAX_SIZE (152 * 1024) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) +#include <configs/imx8m.h>
#ifdef CONFIG_SPL_BUILD -/*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/ -#define CONFIG_SPL_STACK 0x960000 -#define CONFIG_SPL_BSS_START_ADDR 0x0098fc00 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_1K -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K - /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x184000 -/* For RAW image gives a error info not panic */
Some SPL definitions could be gerneralized, so use imx8m.h for iMX8MQ.
Signed-off-by: Peng Fan peng.fan@nxp.com --- include/configs/imx8m.h | 10 ++++++++++ include/configs/imx8mq_cm.h | 24 +----------------------- include/configs/imx8mq_evk.h | 19 +------------------ include/configs/imx8mq_phanbell.h | 19 ++----------------- include/configs/kontron_pitx_imx8m.h | 19 +------------------ include/configs/pico-imx8mq.h | 20 +------------------- 6 files changed, 16 insertions(+), 95 deletions(-)
diff --git a/include/configs/imx8m.h b/include/configs/imx8m.h index 7894a1c1068..e0a030cb67e 100644 --- a/include/configs/imx8m.h +++ b/include/configs/imx8m.h @@ -42,6 +42,16 @@ #define CONFIG_SYS_SPL_MALLOC_START 0x42200000 #define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K
+#elif defined(CONFIG_IMX8MQ) +/*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/ +#define CONFIG_SPL_STACK 0x187FF0 +#define CONFIG_SPL_BSS_START_ADDR 0x00180000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x2000 /* 8 KB */ +#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 /* 512 KB */ +#define CONFIG_SYS_SPL_PTE_RAM_BASE 0x41580000 +/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ +#define CONFIG_MALLOC_F_ADDR 0x182000 #endif #endif #endif diff --git a/include/configs/imx8mq_cm.h b/include/configs/imx8mq_cm.h index 7a9dd962ac2..f8518af83bd 100644 --- a/include/configs/imx8mq_cm.h +++ b/include/configs/imx8mq_cm.h @@ -6,32 +6,10 @@ #ifndef __IMX8M_CM_H #define __IMX8M_CM_H
-#define CONFIG_SPL_MAX_SIZE (124 * 1024) -#define CONFIG_SYS_MONITOR_LEN (512 * 1024) - -#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x187FF0 -#define CONFIG_SPL_BSS_START_ADDR 0x00180000 -#define CONFIG_SPL_BSS_MAX_SIZE 0x2000 /* 8 KB */ -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 /* 512 KB */ -#define CONFIG_SYS_SPL_PTE_RAM_BASE 0x41580000 - -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x182000 -/* For RAW image gives a error info not panic */ - -#endif - -/* ENET Config */ -/* ENET1 */ - #ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ diff --git a/include/configs/imx8mq_evk.h b/include/configs/imx8mq_evk.h index b7294ebef1e..b0c77630f0f 100644 --- a/include/configs/imx8mq_evk.h +++ b/include/configs/imx8mq_evk.h @@ -6,28 +6,11 @@ #ifndef __IMX8M_EVK_H #define __IMX8M_EVK_H
-#define CONFIG_SPL_MAX_SIZE (124 * 1024) -#define CONFIG_SYS_MONITOR_LEN (512 * 1024) - #ifdef CONFIG_SPL_BUILD -/*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/ -#define CONFIG_SPL_STACK 0x187FF0 -#define CONFIG_SPL_BSS_START_ADDR 0x00180000 -#define CONFIG_SPL_BSS_MAX_SIZE 0x2000 /* 8 KB */ -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 /* 512 KB */ -#define CONFIG_SYS_SPL_PTE_RAM_BASE 0x41580000 - -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x182000 -/* For RAW image gives a error info not panic */ - #define CONFIG_POWER_PFUZE100 #define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08 #endif diff --git a/include/configs/imx8mq_phanbell.h b/include/configs/imx8mq_phanbell.h index 93e531b66fd..f9c39aa82c7 100644 --- a/include/configs/imx8mq_phanbell.h +++ b/include/configs/imx8mq_phanbell.h @@ -6,25 +6,10 @@ #ifndef __IMX8M_PHANBELL_H #define __IMX8M_PHANBELL_H
+#undef CONFIG_SPL_MAX_SIZE #define CONFIG_SPL_MAX_SIZE (172 * 1024) -#define CONFIG_SYS_MONITOR_LEN (512 * 1024) - -#ifdef CONFIG_SPL_BUILD -/*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/ -#define CONFIG_SPL_STACK 0x187FF0 -#define CONFIG_SPL_BSS_START_ADDR 0x00180000 -#define CONFIG_SPL_BSS_MAX_SIZE 0x2000 /* 8 KB */ -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 /* 512 KB */ -#define CONFIG_SYS_SPL_PTE_RAM_BASE 0x41580000 - -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x182000 -/* For RAW image gives a error info not panic */ -#endif
/* ENET Config */ /* ENET1 */ diff --git a/include/configs/kontron_pitx_imx8m.h b/include/configs/kontron_pitx_imx8m.h index 9089b76d26e..2abaf07f1a6 100644 --- a/include/configs/kontron_pitx_imx8m.h +++ b/include/configs/kontron_pitx_imx8m.h @@ -3,33 +3,16 @@ #ifndef __KONTRON_PITX_IMX8M_H #define __KONTRON_PITX_IMX8M_H
-#define CONFIG_SPL_MAX_SIZE (124 * SZ_1K) -#define CONFIG_SYS_MONITOR_LEN (512 * SZ_1K) - /* GUID for capsule updatable firmware image */ #define KONTRON_PITX_IMX8M_FIT_IMAGE_GUID \ EFI_GUID(0xc898e959, 0x5b1f, 0x4e6d, 0x88, 0xe0, \ 0x40, 0xd4, 0x5c, 0xca, 0x13, 0x99)
#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x187FF0 -#define CONFIG_SPL_BSS_START_ADDR 0x00180000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K -#define CONFIG_SYS_SPL_PTE_RAM_BASE 0x41580000 - -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x182000 -/* For RAW image gives a error info not panic */ - - #define CONFIG_POWER_PFUZE100 #define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08 #endif diff --git a/include/configs/pico-imx8mq.h b/include/configs/pico-imx8mq.h index de035160255..6460183f5ef 100644 --- a/include/configs/pico-imx8mq.h +++ b/include/configs/pico-imx8mq.h @@ -6,25 +6,7 @@ #ifndef __IMX8M_PICOPI_H #define __IMX8M_PICOPI_H
-#include <linux/sizes.h> -#include <asm/arch/imx-regs.h> - -#define CONFIG_SPL_MAX_SIZE (124 * 1024) -#define CONFIG_SYS_MONITOR_LEN (512 * 1024) - -#ifdef CONFIG_SPL_BUILD -/*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/ -#define CONFIG_SPL_STACK 0x187FF0 -#define CONFIG_SPL_BSS_START_ADDR 0x00180000 -#define CONFIG_SPL_BSS_MAX_SIZE 0x2000 /* 8 KB */ -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 /* 512 KB */ -#define CONFIG_SYS_SPL_PTE_RAM_BASE 0x41580000 - -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x182000 -/* For RAW image gives a error info not panic */ -#endif +#include <configs/imx8m.h>
Mark pinctrl_wdog as u-boot,dm-spl to clean up board code,
The set_wdog_reset() function is not necessary as this is handled by the imx_watchdog.c driver due to the 'fsl,ext-reset-output' property being set.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi | 4 ++++ board/beacon/imx8mm/spl.c | 19 ------------------- 2 files changed, 4 insertions(+), 19 deletions(-)
diff --git a/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi index e33e10ac129..c94b4ffa4c3 100644 --- a/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi @@ -73,6 +73,10 @@ u-boot,dm-spl; };
+&pinctrl_wdog { + u-boot,dm-spl; +}; + &uart2 { u-boot,dm-spl; }; diff --git a/board/beacon/imx8mm/spl.c b/board/beacon/imx8mm/spl.c index f92b4c3ed0a..a93cc938784 100644 --- a/board/beacon/imx8mm/spl.c +++ b/board/beacon/imx8mm/spl.c @@ -59,23 +59,6 @@ int board_fit_config_name_match(const char *name) } #endif
-#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) - -static iomux_v3_cfg_t const wdog_pads[] = { - IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; - -int board_early_init_f(void) -{ - struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; - - imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); - - set_wdog_reset(wdog); - - return 0; -} - static int power_init_board(void) { struct udevice *dev; @@ -116,8 +99,6 @@ void board_init_f(ulong dummy)
init_uart_clk(1);
- board_early_init_f(); - timer_init();
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi | 4 ++++ board/compulab/imx8mm-cl-iot-gate/spl.c | 19 ------------------- 2 files changed, 4 insertions(+), 19 deletions(-)
diff --git a/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi b/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi index 433b02cceee..a7044b63699 100644 --- a/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi @@ -84,6 +84,10 @@ u-boot,dm-spl; };
+&pinctrl_wdog { + u-boot,dm-spl; +}; + &uart3 { u-boot,dm-spl; }; diff --git a/board/compulab/imx8mm-cl-iot-gate/spl.c b/board/compulab/imx8mm-cl-iot-gate/spl.c index f183704c9d2..d2d20269ba0 100644 --- a/board/compulab/imx8mm-cl-iot-gate/spl.c +++ b/board/compulab/imx8mm-cl-iot-gate/spl.c @@ -83,23 +83,6 @@ int board_fit_config_name_match(const char *name) } #endif
-#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) - -static iomux_v3_cfg_t const wdog_pads[] = { - IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; - -int board_early_init_f(void) -{ - struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; - - imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); - - set_wdog_reset(wdog); - - return 0; -} - static int power_init_board(void) { struct udevice *dev; @@ -141,8 +124,6 @@ void board_init_f(ulong dummy)
arch_cpu_init();
- board_early_init_f(); - init_uart_clk(2);
timer_init();
Drop unused WDOG macro
Signed-off-by: Peng Fan peng.fan@nxp.com Reviewed-by: Michael Trimarchi michael@amarulasolutions.com --- board/engicam/imx8mm/spl.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/board/engicam/imx8mm/spl.c b/board/engicam/imx8mm/spl.c index f75f2dc634c..1846134a492 100644 --- a/board/engicam/imx8mm/spl.c +++ b/board/engicam/imx8mm/spl.c @@ -54,8 +54,6 @@ int board_fit_config_name_match(const char *name) } #endif
-#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) - int board_early_init_f(void) { return 0;
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mm-venice-u-boot.dtsi | 4 ++++ arch/arm/dts/imx8mn-venice-u-boot.dtsi | 4 ++++ arch/arm/dts/imx8mp-venice-u-boot.dtsi | 4 ++++ board/gateworks/venice/spl.c | 29 -------------------------- 4 files changed, 12 insertions(+), 29 deletions(-)
diff --git a/arch/arm/dts/imx8mm-venice-u-boot.dtsi b/arch/arm/dts/imx8mm-venice-u-boot.dtsi index c61c6de935f..68978a0413e 100644 --- a/arch/arm/dts/imx8mm-venice-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-venice-u-boot.dtsi @@ -72,3 +72,7 @@ &wdog1 { u-boot,dm-spl; }; + +&pinctrl_wdog { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx8mn-venice-u-boot.dtsi b/arch/arm/dts/imx8mn-venice-u-boot.dtsi index 4f23da35676..35819553879 100644 --- a/arch/arm/dts/imx8mn-venice-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-venice-u-boot.dtsi @@ -110,6 +110,10 @@ u-boot,dm-spl; };
+&pinctrl_wdog { + u-boot,dm-spl; +}; + &binman { u-boot-spl-ddr { align = <4>; diff --git a/arch/arm/dts/imx8mp-venice-u-boot.dtsi b/arch/arm/dts/imx8mp-venice-u-boot.dtsi index 37f3edc9817..96b9fa89cf4 100644 --- a/arch/arm/dts/imx8mp-venice-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-venice-u-boot.dtsi @@ -72,3 +72,7 @@ &wdog1 { u-boot,dm-spl; }; + +&pinctrl_wdog { + u-boot,dm-spl; +}; diff --git a/board/gateworks/venice/spl.c b/board/gateworks/venice/spl.c index 6e6ce015f28..4c0feb4381c 100644 --- a/board/gateworks/venice/spl.c +++ b/board/gateworks/venice/spl.c @@ -87,33 +87,6 @@ static void spl_dram_init(int size) ddr_init(dram_timing); }
-#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) - -#ifdef CONFIG_IMX8MM -static iomux_v3_cfg_t const wdog_pads[] = { - IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; -#elif CONFIG_IMX8MN -static const iomux_v3_cfg_t wdog_pads[] = { - IMX8MN_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; -#elif CONFIG_IMX8MP -static const iomux_v3_cfg_t wdog_pads[] = { - MX8MP_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; -#endif - -int board_early_init_f(void) -{ - struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; - - imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); - - set_wdog_reset(wdog); - - return 0; -} - /* * Model specific PMIC adjustments necessary prior to DRAM init * @@ -253,8 +226,6 @@ void board_init_f(ulong dummy)
init_uart_clk(1);
/* Clear the BSS. */
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi | 4 ++++ board/beacon/imx8mn/spl.c | 10 ---------- 2 files changed, 4 insertions(+), 10 deletions(-)
diff --git a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi index 69fd69c8d02..eb1dd8debba 100644 --- a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi @@ -132,6 +132,10 @@ u-boot,dm-spl; };
+&pinctrl_wdog { + u-boot,dm-spl; +}; + &binman { u-boot-spl-ddr { filename = "u-boot-spl-ddr.bin"; diff --git a/board/beacon/imx8mn/spl.c b/board/beacon/imx8mn/spl.c index 4563446db19..029f71bc995 100644 --- a/board/beacon/imx8mn/spl.c +++ b/board/beacon/imx8mn/spl.c @@ -68,27 +68,17 @@ int board_fit_config_name_match(const char *name) } #endif
-#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) #define PWM1_PAD_CTRL (PAD_CTL_FSEL2 | PAD_CTL_DSE6)
static iomux_v3_cfg_t const pwm_pads[] = { IMX8MN_PAD_GPIO1_IO01__PWM1_OUT | MUX_PAD_CTRL(PWM1_PAD_CTRL), };
-static iomux_v3_cfg_t const wdog_pads[] = { - IMX8MN_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; - int board_early_init_f(void) { - struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; - /* Claiming pwm pins prevents LCD flicker during startup*/ imx_iomux_v3_setup_multiple_pads(pwm_pads, ARRAY_SIZE(pwm_pads));
- imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); - set_wdog_reset(wdog); - init_uart_clk(1);
pinctrl_wdog already marked u-boot,dm-spl, so clean up board code.
Signed-off-by: Peng Fan peng.fan@nxp.com Tested-by: Ariel D'Alessandro ariel.dalessandro@collabora.com --- board/variscite/imx8mn_var_som/spl.c | 11 ----------- 1 file changed, 11 deletions(-)
diff --git a/board/variscite/imx8mn_var_som/spl.c b/board/variscite/imx8mn_var_som/spl.c index 1a8b64fc0a9..41e70505774 100644 --- a/board/variscite/imx8mn_var_som/spl.c +++ b/board/variscite/imx8mn_var_som/spl.c @@ -40,19 +40,8 @@ void spl_board_init(void) puts("Failed to find clock node. Check device tree\n"); }
-#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) - -static const iomux_v3_cfg_t wdog_pads[] = { - IMX8MN_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; - int board_early_init_f(void) { - struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; - - imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); - set_wdog_reset(wdog); - init_uart_clk(3);
Mark wdog1/pinctrl_wdog as u-boot,dm-spl to clean up board code,
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi | 8 ++++++++ board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c | 12 ------------ 2 files changed, 8 insertions(+), 12 deletions(-)
diff --git a/arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi b/arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi index 2848b24f655..4419967ee42 100644 --- a/arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi @@ -89,6 +89,14 @@ u-boot,dm-spl; };
+&wdog1 { + u-boot,dm-spl; +}; + +&pinctrl_wdog { + u-boot,dm-spl; +}; + &pinctrl_i2c1 { u-boot,dm-spl; }; diff --git a/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c b/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c index f129ebd429b..0a1b2c94161 100644 --- a/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c +++ b/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c @@ -28,12 +28,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) - -static const iomux_v3_cfg_t wdog_pads[] = { - MX8MP_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; - #ifdef CONFIG_NAND_MXS static void setup_gpmi_nand(void) { @@ -69,12 +63,6 @@ u8 num_image_type_guids = ARRAY_SIZE(fw_images);
int board_early_init_f(void) { - struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; - - imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); - - set_wdog_reset(wdog); - init_uart_clk(2);
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mm-kontron-n801x-u-boot.dtsi | 4 ++++ board/kontron/sl-mx8mm/spl.c | 18 ------------------ 2 files changed, 4 insertions(+), 18 deletions(-)
diff --git a/arch/arm/dts/imx8mm-kontron-n801x-u-boot.dtsi b/arch/arm/dts/imx8mm-kontron-n801x-u-boot.dtsi index 22d18e6f1cf..6882513f161 100644 --- a/arch/arm/dts/imx8mm-kontron-n801x-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-kontron-n801x-u-boot.dtsi @@ -126,3 +126,7 @@ &wdog1 { u-boot,dm-spl; }; + +&pinctrl_wdog { + u-boot,dm-spl; +}; diff --git a/board/kontron/sl-mx8mm/spl.c b/board/kontron/sl-mx8mm/spl.c index a58a75dc958..63361f1d2ab 100644 --- a/board/kontron/sl-mx8mm/spl.c +++ b/board/kontron/sl-mx8mm/spl.c @@ -32,7 +32,6 @@ enum {
#define GPIO_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) #define I2C_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE) -#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE)
@@ -50,10 +49,6 @@ static iomux_v3_cfg_t const touch_gpio[] = { IMX8MM_PAD_SAI5_RXD2_GPIO3_IO23 | MUX_PAD_CTRL(GPIO_PAD_CTRL) };
-static iomux_v3_cfg_t const wdog_pads[] = { - IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; - int spl_board_boot_device(enum boot_device boot_dev_spl) { switch (boot_dev_spl) { @@ -216,17 +211,6 @@ void spl_board_init(void) printf("Failed to find clock node. Check device tree\n"); }
-int board_early_init_f(void) -{ - struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; - - imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); - - set_wdog_reset(wdog); - - return 0; -} - static int power_init_board(void) { struct udevice *dev; @@ -261,8 +245,6 @@ void board_init_f(ulong dummy)
init_uart_clk(2);
Signed-off-by: Peng Fan peng.fan@nxp.com Tested-by: Teresa Remmet t.remmet@phytec.de --- board/phytec/phycore_imx8mm/spl.c | 19 ------------------- board/phytec/phycore_imx8mp/spl.c | 19 ------------------- 2 files changed, 38 deletions(-)
diff --git a/board/phytec/phycore_imx8mm/spl.c b/board/phytec/phycore_imx8mm/spl.c index 7f24a3affc8..d87ab6d4497 100644 --- a/board/phytec/phycore_imx8mm/spl.c +++ b/board/phytec/phycore_imx8mm/spl.c @@ -57,23 +57,6 @@ int board_fit_config_name_match(const char *name) return 0; }
-#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE) - -static iomux_v3_cfg_t const wdog_pads[] = { - IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; - -int board_early_init_f(void) -{ - struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; - - imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); - - set_wdog_reset(wdog); - - return 0; -} - void board_init_f(ulong dummy) { int ret; @@ -82,8 +65,6 @@ void board_init_f(ulong dummy)
init_uart_clk(2);
- board_early_init_f(); - /* Clear the BSS. */ memset(__bss_start, 0, __bss_end - __bss_start);
diff --git a/board/phytec/phycore_imx8mp/spl.c b/board/phytec/phycore_imx8mp/spl.c index 38a581bef57..faed6fc3b76 100644 --- a/board/phytec/phycore_imx8mp/spl.c +++ b/board/phytec/phycore_imx8mp/spl.c @@ -89,23 +89,6 @@ int board_fit_config_name_match(const char *name) return 0; }
-#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) - -static iomux_v3_cfg_t const wdog_pads[] = { - MX8MP_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; - -int board_early_init_f(void) -{ - struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; - - imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); - - set_wdog_reset(wdog); - - return 0; -} - void board_init_f(ulong dummy) { int ret; @@ -114,8 +97,6 @@ void board_init_f(ulong dummy)
init_uart_clk(0);
- board_early_init_f(); - ret = spl_early_init(); if (ret) { debug("spl_early_init() failed: %d\n", ret);
Peng Fan (OSS)
Tim Harvey
