[U-Boot] [PATCH] dataflash: fix a problem with the last partition
This patch fix the problem that only the [NB_DATAFLASH_AREA -1] dataflash partition can be defined to use the area to the end of dataflash size. Now it is possible to have only one dataflash partition from 0 to the end of of dataflash size.
Signed-off-by: Ilko Iliev iliev@ronetix.at --- drivers/mtd/dataflash.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/dataflash.c b/drivers/mtd/dataflash.c index 201e518..43746e7 100644 --- a/drivers/mtd/dataflash.c +++ b/drivers/mtd/dataflash.c @@ -131,7 +131,7 @@ int AT91F_DataflashInit (void) break; } /* set the last area end to the dataflash size*/ - area_list[NB_DATAFLASH_AREA -1].end = + dataflash_info[i].end_address = (dataflash_info[i].Device.pages_number * dataflash_info[i].Device.pages_size)-1;
@@ -146,7 +146,7 @@ int AT91F_DataflashInit (void) if(area_list[part].end == 0xffffffff) { dataflash_info[i].Device.area_list[j].end = dataflash_info[i].end_address + - dataflash_info [i].logical_address; + dataflash_info[i].logical_address; last_part = 1; } else { dataflash_info[i].Device.area_list[j].end =
Who is supposed to handle this one?
Stefan is it you?
Best Regards, J.
Stefan is it you?
I don't feel responsible for dataflash. I think it would be best if this would go in via Wolfgang directly.
Wolfgang, what do you think?
Best regards, Stefan
Dear Stefan Roese,
Stefan is it you?
I tend to use a broad view summarizing all types of flash based storage devices (NAND, OneNAND, Dataflash, etc.). As such, I would see this on Scott's desk...
Stefan is it you?
I barely have enough time to keep up with NAND, I know nothing about dataflash and have no hardware to test anything on, and there's no shared code. As such, I'm not sure that there's any point in routing the patches through me.
-Scott
Dear Scott Wood,
Me too.
Is there anybody around volunteering to become custodian for Dataflash support?
On 17:05 Fri 31 Oct , Wolfgang Denk wrote:
Dear Scott Wood,
Me too.
If we can keep it with AT91?
Nearly all at91 ref board had dataflash
Best Regards, J.
Dear Jean-Christophe PLAGNIOL-VILLARD,
Does that mean you want to take that duty as part of the AT91 custodianship? In addition to al what you already have heaped on your plate?
Now that you claimed responsibility for dataflash code, could you please add it and/or provide feedback to the submitter?
I'll hope when can found a MMC/SD/DATAFLASH Maintainer
Best Regards, J.
please limit to 80 Chars
please spit in 2 one for coding style fix and one for modification and btw maybe fix all coding style violation? as space before and after '-' & co, etc...
Best Regards, J.
This patch fix some coding style violations.
Signed-off-by: Ilko Iliev iliev@ronetix.at --- drivers/mtd/dataflash.c | 25 ++++++++++++------------- 1 files changed, 12 insertions(+), 13 deletions(-)
diff --git a/drivers/mtd/dataflash.c b/drivers/mtd/dataflash.c index 201e518..58be182 100644 --- a/drivers/mtd/dataflash.c +++ b/drivers/mtd/dataflash.c @@ -131,14 +131,14 @@ int AT91F_DataflashInit (void) break; } /* set the last area end to the dataflash size*/ - area_list[NB_DATAFLASH_AREA -1].end = + area_list[NB_DATAFLASH_AREA - 1].end = (dataflash_info[i].Device.pages_number * - dataflash_info[i].Device.pages_size)-1; + dataflash_info[i].Device.pages_size) - 1;
part = 0; last_part = 0; /* set the area addresses */ - for(j = 0; j<NB_DATAFLASH_AREA; j++) { + for(j = 0; j < NB_DATAFLASH_AREA; j++) { if(found[i]!=0) { dataflash_info[i].Device.area_list[j].start = area_list[part].start + @@ -146,7 +146,7 @@ int AT91F_DataflashInit (void) if(area_list[part].end == 0xffffffff) { dataflash_info[i].Device.area_list[j].end = dataflash_info[i].end_address + - dataflash_info [i].logical_address; + dataflash_info[i].logical_address; last_part = 1; } else { dataflash_info[i].Device.area_list[j].end = @@ -180,12 +180,11 @@ void AT91F_DataflashSetEnv (void) unsigned long start;
for (i = 0, part= 0; i < CONFIG_SYS_MAX_DATAFLASH_BANKS; i++) { - for(j = 0; j<NB_DATAFLASH_AREA; j++) { + for(j = 0; j < NB_DATAFLASH_AREA; j++) { env = area_list[part].setenv; /* Set the environment according to the label...*/ if((env & FLAG_SETENV) == FLAG_SETENV) { - start = - dataflash_info[i].Device.area_list[j].start; + start = dataflash_info[i].Device.area_list[j].start; sprintf((char*) s,"%lX",start); setenv((char*) area_list[part].label,(char*) s); } @@ -230,7 +229,7 @@ void dataflash_print_info (void) (unsigned int) dataflash_info[i].Device.pages_number * dataflash_info[i].Device.pages_size, (unsigned int) dataflash_info[i].logical_address); - for (j=0; j< NB_DATAFLASH_AREA; j++) { + for (j = 0; j < NB_DATAFLASH_AREA; j++) { switch(dataflash_info[i].Device.area_list[j].protected) { case FLAG_PROTECT_SET: case FLAG_PROTECT_CLEAR: @@ -322,7 +321,7 @@ int prot_dataflash (AT91PS_DataFlash pdataFlash, unsigned long addr) int area;
/* find area */ - for (area=0; area < NB_DATAFLASH_AREA; area++) { + for (area = 0; area < NB_DATAFLASH_AREA; area++) { if ((addr >= pdataFlash->pDevice->area_list[area].start) && (addr < pdataFlash->pDevice->area_list[area].end)) break; @@ -360,13 +359,13 @@ int dataflash_real_protect (int flag, unsigned long start_addr, return -1; } /* find start area */ - for (area1=0; area1 < NB_DATAFLASH_AREA; area1++) { + for (area1 = 0; area1 < NB_DATAFLASH_AREA; area1++) { if (start_addr == dataflash_info[i].Device.area_list[area1].start) break; } if (area1 == NB_DATAFLASH_AREA) return -1; /* find end area */ - for (area2=0; area2 < NB_DATAFLASH_AREA; area2++) { + for (area2 = 0; area2 < NB_DATAFLASH_AREA; area2++) { if (end_addr == dataflash_info[i].Device.area_list[area2].end) break; } @@ -374,7 +373,7 @@ int dataflash_real_protect (int flag, unsigned long start_addr, return -1;
/*set protection value*/ - for(j = area1; j < area2+1 ; j++) + for(j = area1; j < area2 + 1 ; j++) if(dataflash_info[i].Device.area_list[j].protected != FLAG_PROTECT_INVALID) { if (flag == 0) { @@ -386,7 +385,7 @@ int dataflash_real_protect (int flag, unsigned long start_addr, } }
- return (area2-area1+1); + return (area2 - area1 + 1); }
Applied to u-boot-at91
Best Regards, J.
This patch fix the problem that only the [NB_DATAFLASH_AREA - 1] dataflash partition can be defined to use the area to the end of dataflash size. Now it is possible to have only one dataflash partition from 0 to the end of of dataflash size.
Signed-off-by: Ilko Iliev iliev@ronetix.at --- drivers/mtd/dataflash.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/drivers/mtd/dataflash.c b/drivers/mtd/dataflash.c index 58be182..96cd395 100644 --- a/drivers/mtd/dataflash.c +++ b/drivers/mtd/dataflash.c @@ -131,7 +131,7 @@ int AT91F_DataflashInit (void) break; } /* set the last area end to the dataflash size*/ - area_list[NB_DATAFLASH_AREA - 1].end = + dataflash_info[i].end_address = (dataflash_info[i].Device.pages_number * dataflash_info[i].Device.pages_size) - 1;
Best Regards, J.
participants (5)
Ilko Iliev
Scott Wood
Stefan Roese
