[U-Boot] [PATCH 0/8] zmx25: Add hardware support
This patchset is the result of the "[PATCH 3/4] zmx25: Add extended support for the cpu and base boards" (http://patchwork.ozlabs.org/patch/341717/). I split the patch up as Stefano Babic recommended.
Thomas Diener (8): imx25: Add new hardware registers drivers: Add polytouch touch sensor controller mxc_i2c: Use the 3th i2c channel for imx25 input: Add support for FMA1125 touch controller input: Add support for MPR121 touch controller zmx25: Extended support for cpu and base boards imx25: Add new registers defines video: imx25lcdc: add board_video_init() call
arch/arm/include/asm/arch-mx25/imx-regs.h | 271 ++++++- arch/arm/include/asm/arch-mx25/iomux-mx25.h | 25 +- arch/arm/include/asm/imx-common/iomux-v3.h | 13 +- arch/arm/lib/asm-offsets.c | 9 + board/syteco/zmx25/lowlevel_init.S | 21 + board/syteco/zmx25/zmx25.c | 1052 +++++++++++++++++++++++++-- drivers/i2c/mxc_i2c.c | 2 +- drivers/input/Makefile | 3 + drivers/input/fma1125.c | 47 ++ drivers/input/mpr121.c | 67 ++ drivers/input/polytouch.c | 138 ++++ drivers/video/imx25lcdc.c | 19 + include/configs/zmx25.h | 66 +- include/fma1125.h | 140 ++++ include/mpr121.h | 158 ++++ include/polytouch.h | 35 + 16 files changed, 1976 insertions(+), 90 deletions(-) create mode 100644 drivers/input/fma1125.c create mode 100644 drivers/input/mpr121.c create mode 100644 drivers/input/polytouch.c create mode 100644 include/fma1125.h create mode 100644 include/mpr121.h create mode 100644 include/polytouch.h
Signed-off-by: Thomas Diener dietho@gmx.de --- arch/arm/include/asm/arch-mx25/iomux-mx25.h | 25 +++++++++++++++++++------ arch/arm/include/asm/imx-common/iomux-v3.h | 13 ++++++++++++- arch/arm/lib/asm-offsets.c | 9 +++++++++ 3 files changed, 40 insertions(+), 7 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx25/iomux-mx25.h b/arch/arm/include/asm/arch-mx25/iomux-mx25.h index 220cf4e..e403eb9 100644 --- a/arch/arm/include/asm/arch-mx25/iomux-mx25.h +++ b/arch/arm/include/asm/arch-mx25/iomux-mx25.h @@ -287,15 +287,19 @@ enum {
MX25_PAD_CSI_D6__CSI_D6 = IOMUX_PAD(0x328, 0x130, 0x10, 0, 0, NO_PAD_CTRL), MX25_PAD_CSI_D6__GPIO_1_31 = IOMUX_PAD(0x328, 0x130, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D6__CSPI3_SS0 = IOMUX_PAD(0x328, 0x130, 0x17, 0, 1, NO_PAD_CTRL),
MX25_PAD_CSI_D7__CSI_D7 = IOMUX_PAD(0x32c, 0x134, 0x10, 0, 0, NO_PAD_CTRL), MX25_PAD_CSI_D7__GPIO_1_6 = IOMUX_PAD(0x32c, 0x134, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D7__CSPI3_SS1 = IOMUX_PAD(0x32c, 0x134, 0x17, 0, 1, NO_PAD_CTRL),
MX25_PAD_CSI_D8__CSI_D8 = IOMUX_PAD(0x330, 0x138, 0x10, 0, 0, NO_PAD_CTRL), MX25_PAD_CSI_D8__GPIO_1_7 = IOMUX_PAD(0x330, 0x138, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D8__CSPI3_SS2 = IOMUX_PAD(0x330, 0x138, 0x17, 0, 0, NO_PAD_CTRL),
MX25_PAD_CSI_D9__CSI_D9 = IOMUX_PAD(0x334, 0x13c, 0x10, 0, 0, NO_PAD_CTRL), MX25_PAD_CSI_D9__GPIO_4_21 = IOMUX_PAD(0x334, 0x13c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D9__CSPI3_SS3 = IOMUX_PAD(0x334, 0x13c, 0x17, 0, 0, NO_PAD_CTRL),
MX25_PAD_CSI_MCLK__CSI_MCLK = IOMUX_PAD(0x338, 0x140, 0x10, 0, 0, NO_PAD_CTRL), MX25_PAD_CSI_MCLK__GPIO_1_8 = IOMUX_PAD(0x338, 0x140, 0x15, 0, 0, NO_PAD_CTRL), @@ -315,16 +319,18 @@ enum { MX25_PAD_I2C1_DAT__I2C1_DAT = IOMUX_PAD(0x34c, 0x154, 0x10, 0, 0, NO_PAD_CTRL), MX25_PAD_I2C1_DAT__GPIO_1_13 = IOMUX_PAD(0x34c, 0x154, 0x15, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSPI1_MOSI__CSPI1_MOSI = IOMUX_PAD(0x350, 0x158, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_MOSI__CSPI1_MOSI = IOMUX_PAD(0x350, 0x158, 0x10, 0x568, 0, NO_PAD_CTRL), MX25_PAD_CSPI1_MOSI__GPIO_1_14 = IOMUX_PAD(0x350, 0x158, 0x15, 0, 0, NO_PAD_CTRL),
MX25_PAD_CSPI1_MISO__CSPI1_MISO = IOMUX_PAD(0x354, 0x15c, 0x10, 0, 0, NO_PAD_CTRL), MX25_PAD_CSPI1_MISO__GPIO_1_15 = IOMUX_PAD(0x354, 0x15c, 0x15, 0, 0, NO_PAD_CTRL),
MX25_PAD_CSPI1_SS0__CSPI1_SS0 = IOMUX_PAD(0x358, 0x160, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_SS0__LD16 = IOMUX_PAD(0x358, 0x160, 0x11, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_SS0__PWM2_PWMO = IOMUX_PAD(0x358, 0x160, 0x14, 0, 0, 0), MX25_PAD_CSPI1_SS0__GPIO_1_16 = IOMUX_PAD(0x358, 0x160, 0x15, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSPI1_SS1__CSPI1_SS1 = IOMUX_PAD(0x35c, 0x164, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_SS1__CSPI1_SS1 = IOMUX_PAD(0x35c, 0x164, 0x10, 0x564, 0, NO_PAD_CTRL), MX25_PAD_CSPI1_SS1__I2C3_DAT = IOMUX_PAD(0x35c, 0x164, 0x11, 0x528, 1, NO_PAD_CTRL), MX25_PAD_CSPI1_SS1__GPIO_1_17 = IOMUX_PAD(0x35c, 0x164, 0x15, 0, 0, NO_PAD_CTRL),
@@ -341,6 +347,7 @@ enum { MX25_PAD_UART1_TXD__GPIO_4_23 = IOMUX_PAD(0x36c, 0x174, 0x15, 0, 0, NO_PAD_CTRL),
MX25_PAD_UART1_RTS__UART1_RTS = IOMUX_PAD(0x370, 0x178, 0x10, 0, 0, PAD_CTL_PUS_100K_UP), + MX25_PAD_UART1_RTS__GPT3_CAPIN1 = IOMUX_PAD(0x370, 0x178, 0x12, 0, 0, NO_PAD_CTRL), MX25_PAD_UART1_RTS__CSI_D0 = IOMUX_PAD(0x370, 0x178, 0x11, 0x488, 1, NO_PAD_CTRL), MX25_PAD_UART1_RTS__GPIO_4_24 = IOMUX_PAD(0x370, 0x178, 0x15, 0, 0, NO_PAD_CTRL),
@@ -356,6 +363,7 @@ enum {
MX25_PAD_UART2_RTS__UART2_RTS = IOMUX_PAD(0x380, 0x188, 0x10, 0, 0, NO_PAD_CTRL), MX25_PAD_UART2_RTS__FEC_COL = IOMUX_PAD(0x380, 0x188, 0x12, 0x504, 2, NO_PAD_CTRL), + MX25_PAD_UART2_RTS__GPT1_CAPIN1 = IOMUX_PAD(0x380, 0x188, 0x13, 0x504, 2, NO_PAD_CTRL), MX25_PAD_UART2_RTS__GPIO_4_28 = IOMUX_PAD(0x380, 0x188, 0x15, 0, 0, NO_PAD_CTRL),
MX25_PAD_UART2_CTS__FEC_RX_ER = IOMUX_PAD(0x384, 0x18c, 0x12, 0x518, 2, NO_PAD_CTRL), @@ -385,17 +393,21 @@ enum { MX25_PAD_SD1_DATA3__FEC_CRS = IOMUX_PAD(0x39c, 0x1a4, 0x10, 0x508, 2, NO_PAD_CTRL), MX25_PAD_SD1_DATA3__GPIO_2_28 = IOMUX_PAD(0x39c, 0x1a4, 0x15, 0, 0, NO_PAD_CTRL),
- MX25_PAD_KPP_ROW0__KPP_ROW0 = IOMUX_PAD(0x3a0, 0x1a8, 0x10, 0, 0, MX25_KPP_ROW_PAD_CTRL), + MX25_PAD_KPP_ROW0__KPP_ROW0 = IOMUX_PAD(0x3a0, 0x1a8, 0x10, 0x568, 1, MX25_KPP_ROW_PAD_CTRL), + MX25_PAD_KPP_ROW0__UART3_RXD = IOMUX_PAD(0x3a0, 0x1a8, 0x01, 0, 0, NO_PAD_CTRL), MX25_PAD_KPP_ROW0__GPIO_2_29 = IOMUX_PAD(0x3a0, 0x1a8, 0x15, 0, 0, NO_PAD_CTRL),
MX25_PAD_KPP_ROW1__KPP_ROW1 = IOMUX_PAD(0x3a4, 0x1ac, 0x10, 0, 0, MX25_KPP_ROW_PAD_CTRL), + MX25_PAD_KPP_ROW1__UART3_TXD = IOMUX_PAD(0x3a4, 0x1ac, 0x01, 0, 0, NO_PAD_CTRL), MX25_PAD_KPP_ROW1__GPIO_2_30 = IOMUX_PAD(0x3a4, 0x1ac, 0x15, 0, 0, NO_PAD_CTRL),
- MX25_PAD_KPP_ROW2__KPP_ROW2 = IOMUX_PAD(0x3a8, 0x1b0, 0x10, 0, 0, MX25_KPP_ROW_PAD_CTRL), + MX25_PAD_KPP_ROW2__KPP_ROW2 = IOMUX_PAD(0x3a8, 0x1b0, 0x10, 0x564, 0, MX25_KPP_ROW_PAD_CTRL), + MX25_PAD_KPP_ROW2__UART3_RTS = IOMUX_PAD(0x3a8, 0x1b0, 0x01, 0, 1, NO_PAD_CTRL), MX25_PAD_KPP_ROW2__CSI_D0 = IOMUX_PAD(0x3a8, 0x1b0, 0x13, 0x488, 2, NO_PAD_CTRL), MX25_PAD_KPP_ROW2__GPIO_2_31 = IOMUX_PAD(0x3a8, 0x1b0, 0x15, 0, 0, NO_PAD_CTRL),
MX25_PAD_KPP_ROW3__KPP_ROW3 = IOMUX_PAD(0x3ac, 0x1b4, 0x10, 0, 0, MX25_KPP_ROW_PAD_CTRL), + MX25_PAD_KPP_ROW3__UART3_CTS = IOMUX_PAD(0x3ac, 0x1b4, 0x01, 0, 0, NO_PAD_CTRL), MX25_PAD_KPP_ROW3__CSI_LD1 = IOMUX_PAD(0x3ac, 0x1b4, 0x13, 0x48c, 2, NO_PAD_CTRL), MX25_PAD_KPP_ROW3__GPIO_3_0 = IOMUX_PAD(0x3ac, 0x1b4, 0x15, 0, 0, NO_PAD_CTRL),
@@ -471,15 +483,15 @@ enum { MX25_PAD_GPIO_C__CAN2_TX = IOMUX_PAD(0x3f8, 0x1fc, 0x16, 0, 0, PAD_CTL_PUS_22K_UP),
MX25_PAD_GPIO_D__GPIO_D = IOMUX_PAD(0x3fc, 0x200, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_GPIO_E__LD16 = IOMUX_PAD(0x400, 0x204, 0x02, 0, 0, PAD_CTL_SRE_FAST), MX25_PAD_GPIO_D__CAN2_RX = IOMUX_PAD(0x3fc, 0x200, 0x16, 0x484, 1, PAD_CTL_PUS_22K_UP),
MX25_PAD_GPIO_E__GPIO_E = IOMUX_PAD(0x400, 0x204, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_GPIO_F__LD17 = IOMUX_PAD(0x404, 0x208, 0x02, 0, 0, PAD_CTL_SRE_FAST), MX25_PAD_GPIO_E__I2C3_CLK = IOMUX_PAD(0x400, 0x204, 0x11, 0x524, 2, NO_PAD_CTRL), + MX25_PAD_GPIO_E__LD16 = IOMUX_PAD(0x400, 0x204, 0x02, 0, 0, PAD_CTL_SRE_FAST), MX25_PAD_GPIO_E__AUD7_TXD = IOMUX_PAD(0x400, 0x204, 0x14, 0, 0, NO_PAD_CTRL),
MX25_PAD_GPIO_F__GPIO_F = IOMUX_PAD(0x404, 0x208, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_F__LD17 = IOMUX_PAD(0x404, 0x208, 0x02, 0, 0, PAD_CTL_SRE_FAST), MX25_PAD_GPIO_F__AUD7_TXC = IOMUX_PAD(0x404, 0x208, 0x14, 0, 0, NO_PAD_CTRL),
MX25_PAD_EXT_ARMCLK__EXT_ARMCLK = IOMUX_PAD(0x000, 0x20c, 0x10, 0, 0, NO_PAD_CTRL), @@ -492,6 +504,7 @@ enum { MX25_PAD_VSTBY_REQ__AUD7_TXFS = IOMUX_PAD(0x408, 0x214, 0x14, 0, 0, NO_PAD_CTRL), MX25_PAD_VSTBY_REQ__GPIO_3_17 = IOMUX_PAD(0x408, 0x214, 0x15, 0, 0, NO_PAD_CTRL), MX25_PAD_VSTBY_ACK__VSTBY_ACK = IOMUX_PAD(0x40c, 0x218, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_VSTBY_ACK__EPIT1_EPITO = IOMUX_PAD(0x40c, 0x218, 0x13, 0, 0, NO_PAD_CTRL), MX25_PAD_VSTBY_ACK__GPIO_3_18 = IOMUX_PAD(0x40c, 0x218, 0x15, 0, 0, NO_PAD_CTRL),
MX25_PAD_POWER_FAIL__POWER_FAIL = IOMUX_PAD(0x410, 0x21c, 0x10, 0, 0, NO_PAD_CTRL), diff --git a/arch/arm/include/asm/imx-common/iomux-v3.h b/arch/arm/include/asm/imx-common/iomux-v3.h index dec11a1..d71d676 100644 --- a/arch/arm/include/asm/imx-common/iomux-v3.h +++ b/arch/arm/include/asm/imx-common/iomux-v3.h @@ -58,14 +58,18 @@ typedef u64 iomux_v3_cfg_t;
#define MUX_MODE_SHIFT 36 #define MUX_MODE_MASK ((iomux_v3_cfg_t)0x1f << MUX_MODE_SHIFT) +#define MUX_MODE_SION_SHIFT 40 +#define MUX_MODE_SION_MASK ((iomux_v3_cfg_t)0x1 << MUX_MODE_SION_SHIFT) #define MUX_PAD_CTRL_SHIFT 41 #define MUX_PAD_CTRL_MASK ((iomux_v3_cfg_t)0x3ffff << MUX_PAD_CTRL_SHIFT) #define MUX_SEL_INPUT_SHIFT 59 #define MUX_SEL_INPUT_MASK ((iomux_v3_cfg_t)0xf << MUX_SEL_INPUT_SHIFT)
#define MUX_MODE_SION ((iomux_v3_cfg_t)IOMUX_CONFIG_SION << \ - MUX_MODE_SHIFT) + MUX_MODE_SHIFT) #define MUX_PAD_CTRL(x) ((iomux_v3_cfg_t)(x) << MUX_PAD_CTRL_SHIFT) +#define MUX_SEL_INPUT(x) ((iomux_v3_cfg_t)(x) << MUX_SEL_INPUT_SHIFT) +
#define IOMUX_PAD(pad_ctrl_ofs, mux_ctrl_ofs, mux_mode, sel_input_ofs, \ sel_input, pad_ctrl) \ @@ -79,6 +83,13 @@ typedef u64 iomux_v3_cfg_t; #define NEW_PAD_CTRL(cfg, pad) (((cfg) & ~MUX_PAD_CTRL_MASK) | \ MUX_PAD_CTRL(pad))
+#define NEW_SEL_INPUT(cfg, input) (((cfg) & ~MUX_SEL_INPUT_MASK) | \ + MUX_SEL_INPUT(input)) + +#define SET_MODE_SION(cfg) (((cfg) | MUX_MODE_SION_MASK)) + +#define CLEAR_MODE_SION(cfg) (((cfg) & ~MUX_MODE_SION_MASK)) + #define __NA_ 0x000 #define NO_MUX_I 0 #define NO_PAD_I 0 diff --git a/arch/arm/lib/asm-offsets.c b/arch/arm/lib/asm-offsets.c index b0c26e5..987cc8d 100644 --- a/arch/arm/lib/asm-offsets.c +++ b/arch/arm/lib/asm-offsets.c @@ -115,6 +115,15 @@ int main(void) /* AHB <-> IP-Bus Interface */ DEFINE(AIPS_MPR_0_7, offsetof(struct aips_regs, mpr_0_7)); DEFINE(AIPS_MPR_8_15, offsetof(struct aips_regs, mpr_8_15)); + + /* M3IF */ + DEFINE(M3IF_CTL, offsetof(struct m3if_regs, ctl)); + + /* WEIM */ + DEFINE(WEIM_CSCR0U, offsetof(struct weim_regs, cscr0u)); + DEFINE(WEIM_CSCR0L, offsetof(struct weim_regs, cscr0l)); + DEFINE(WEIM_CSCR0A, offsetof(struct weim_regs, cscr0a)); + #endif
#if defined(CONFIG_MX27)
.Dear Thomas Diener,
MUX_MODE_SHIFT)
MUX_MODE_SHIFT)
If you need these additions, it just means that iomux-mx25.h is broken, so please fix it and change nothing here.
For SION, the rules are: - iomux-mx25.h should never set it, except for pin modes that can not work without it. E.g., SION should not be set for MX25_PAD_UPLL_BYPCLK__GPIO_3_16. - If a board needs it for a pin, e.g. for an output GPIO that needs to be sensed, then MUX_MODE_SION should be OR-ed to the pad used in the initialization, e.g. "MX25_PAD_UPLL_BYPCLK__GPIO_3_16 | MUX_MODE_SION".
For the input paths, a unique pad definition should exist in iomux-mx25.h. E.g. MX25_PAD_CSI_D2__CSPI3_MOSI in iomux-mx25.h has neither an input selection register nor an input path, which does not make sense according to the reference manual, so this should just be fixed. Your NEW_SEL_INPUT() in 6/8 would also fail here with the lack of input selection register.
Best regards, Benoît
Signed-off-by: Thomas Diener dietho@gmx.de --- drivers/input/Makefile | 1 + drivers/input/polytouch.c | 138 +++++++++++++++++++++++++++++++++++++++++++++ include/polytouch.h | 35 ++++++++++++ 3 files changed, 174 insertions(+) create mode 100644 drivers/input/polytouch.c create mode 100644 include/polytouch.h
diff --git a/drivers/input/Makefile b/drivers/input/Makefile index a8e9be2..65c40ba 100644 --- a/drivers/input/Makefile +++ b/drivers/input/Makefile @@ -14,3 +14,4 @@ obj-$(CONFIG_PS2MULT) += ps2mult.o ps2ser.o endif obj-y += input.o obj-$(CONFIG_OF_CONTROL) += key_matrix.o +obj-$(CONFIG_POLYTOUCH) += polytouch.o \ No newline at end of file diff --git a/drivers/input/polytouch.c b/drivers/input/polytouch.c new file mode 100644 index 0000000..9f1f38f --- /dev/null +++ b/drivers/input/polytouch.c @@ -0,0 +1,138 @@ +/* + * (c) 2013 Graf-Syteco, Matthias Weisser + * weisserm@arcor.de + * + * polytouch.c - EDT PolyTouch capacitive touch sensor controller + * + * SPDX-License-Identifier: GPL-2.0+ + * + */ + +#include <common.h> +#include <polytouch.h> +#include <i2c.h> + + +#define POLYTOUCH_CMD_GETVERSION 0xBB +#define POLYTOUCH_CMD_GETTOUCH 0xF9 +#define POLYTOUCH_CMD_SETREG 0xFC +#define POLYTOUCH_CMD_GETREG 0xFC + +#define POLYTOUCH_REG_THRESHOLD 0x00 +#define POLYTOUCH_REG_MONITORTIME 0x07 +#define POLYTOUCH_REG_REPORTRATE 0x08 +#define POLYTOUCH_REG_GAIN 0x30 +#define POLYTOUCH_REG_OFFSET 0x31 +#define POLYTOUCH_REG_XRES 0x33 +#define POLYTOUCH_REG_YRES 0x34 +#define POLYTOUCH_REG_HIBERNATE 0x3A + +#define POLYTOUCH_PACKET_LENGTH 26 + +static int xres; +static int yres; + +static int32_t polytouch_set_reg(uint32_t reg, uint32_t val) +{ + uint8_t buf[3]; + int r; + + buf[0] = reg; + buf[1] = val; + buf[2] = POLYTOUCH_CMD_SETREG ^ buf[0] ^ buf[1]; + + r = i2c_write(POLYTOUCH_SA, POLYTOUCH_CMD_SETREG, 1, buf, 3); + + if (0 != r) + printf("i2c_write failed with %d\n", r); + + return r; +} + +static int32_t polytouch_get_reg(uint32_t reg) +{ + uint8_t buf; + + if (i2c_read(POLYTOUCH_SA, (POLYTOUCH_CMD_GETREG<<8) + + ((reg + 0x40)<<0), 2, &buf, 1) == 0) + return buf; + + return -1; +} + +int polytouch_init(void) +{ + char buf[32]; + + if (!i2c_probe(POLYTOUCH_SA)) { + if (i2c_read(POLYTOUCH_SA, POLYTOUCH_CMD_GETVERSION, 1, + (uint8_t *)buf, 22) == 0) { + uint32_t gain = 7; + uint32_t threshold = 40; + uint32_t offset = 0; + + buf[22] = '\0'; + + xres = polytouch_get_reg(POLYTOUCH_REG_XRES) * 64; + yres = polytouch_get_reg(POLYTOUCH_REG_YRES) * 64; + + if (0 != strstr(buf, "EP035")) { + gain = 3; + threshold = 25; + offset = 34; + } else if (0 != strstr(buf, "EP043")) { + gain = 5; + threshold = 35; + offset = 34; + } else if (0 != strstr(buf, "EP057")) { + gain = 2; + threshold = 25; + offset = 34; + } else if (0 != strstr(buf, "EP070")) { + gain = 2; + threshold = 27; + offset = 34; + } + + polytouch_set_reg(POLYTOUCH_REG_GAIN, gain); + polytouch_set_reg(POLYTOUCH_REG_THRESHOLD, threshold); + polytouch_set_reg(POLYTOUCH_REG_OFFSET, offset); + polytouch_set_reg(POLYTOUCH_REG_REPORTRATE, 8); + polytouch_set_reg(POLYTOUCH_REG_MONITORTIME, 0xC8); + + return 1; + } + } + return 0; +} + +void polytouch_get_resolution(struct polytouch_resolution *res) +{ + if (NULL != res) { + res->x = xres; + res->y = yres; + } +} + +int polytouch_is_touched(struct polytouch_area *area) +{ + if (NULL != area) { + uint8_t buf[POLYTOUCH_PACKET_LENGTH]; + if (0 == i2c_read(POLYTOUCH_SA, POLYTOUCH_CMD_GETTOUCH, 1, buf, + POLYTOUCH_PACKET_LENGTH)) { + if ((buf[0] == 0xAA) && (buf[1] == 0xAA) && + (buf[2] == 0x1A) && (buf[3] == 0x01)) { + uint16_t x; + uint16_t y; + + x = ((buf[5] & 0x0F) << 8) + buf[6]; + y = ((buf[7] & 0x0F) << 8) + buf[8]; + + if ((x > area->x1) && (x < area->x2) && + (y > area->y1) && (x < area->y2)) + return 1; + } + } + } + return 0; +} diff --git a/include/polytouch.h b/include/polytouch.h new file mode 100644 index 0000000..f906bbe --- /dev/null +++ b/include/polytouch.h @@ -0,0 +1,35 @@ +/* + * (c) 2012 Graf-Syteco, Matthias Weisser + * weisserm@arcor.de + * + * polytouch.h - EDT PolyTouch capacitive touch sensor controller + * + * SPDX-License-Identifier: GPL-2.0+ + * + */ + +#ifndef __POLYTOUCH_H +#define __POLYTOUCH_H + +#define POLYTOUCH_SA 0x38 /* I2C slave address of PolyTouch */ + + +struct polytouch_resolution { + uint x; + uint y; +}; + +struct polytouch_area { + uint x1; /* Start position x */ + uint y1; /* Start position y */ + uint x2; /* End position x */ + uint y2; /* End position y */ +}; + + +int polytouch_init(void); +void polytouch_get_resolution(struct polytouch_resolution *res); +int polytouch_is_touched(struct polytouch_area *area); + +#endif +
Signed-off-by: Thomas Diener dietho@gmx.de --- drivers/i2c/mxc_i2c.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index 595019b..96cc739 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -540,7 +540,7 @@ U_BOOT_I2C_ADAP_COMPLETE(mxc1, mxc_i2c_init, mxc_i2c_probe, mxc_i2c_set_bus_speed, CONFIG_SYS_MXC_I2C2_SPEED, CONFIG_SYS_MXC_I2C2_SLAVE, 1) -#if defined(CONFIG_MX31) || defined(CONFIG_MX35) ||\ +#if defined(CONFIG_MX25) || defined(CONFIG_MX31) || defined(CONFIG_MX35) ||\ defined(CONFIG_MX51) || defined(CONFIG_MX53) ||\ defined(CONFIG_MX6) U_BOOT_I2C_ADAP_COMPLETE(mxc2, mxc_i2c_init, mxc_i2c_probe,
Hello Thomas,
Am 15.05.2014 16:34, schrieb dietho@gmx.de:
Signed-off-by: Thomas Dienerdietho@gmx.de
as this I think goes through the imx tree:
Acked-by: Heiko Schocher hs@denx.de
bye, Heiko
Signed-off-by: Thomas Diener dietho@gmx.de --- drivers/input/Makefile | 3 +- drivers/input/fma1125.c | 47 ++++++++++++++++ include/fma1125.h | 140 +++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 189 insertions(+), 1 deletion(-) create mode 100644 drivers/input/fma1125.c create mode 100644 include/fma1125.h
diff --git a/drivers/input/Makefile b/drivers/input/Makefile index 65c40ba..203a311 100644 --- a/drivers/input/Makefile +++ b/drivers/input/Makefile @@ -14,4 +14,5 @@ obj-$(CONFIG_PS2MULT) += ps2mult.o ps2ser.o endif obj-y += input.o obj-$(CONFIG_OF_CONTROL) += key_matrix.o -obj-$(CONFIG_POLYTOUCH) += polytouch.o \ No newline at end of file +obj-$(CONFIG_POLYTOUCH) += polytouch.o +obj-$(CONFIG_FMA1125) += fma1125.o \ No newline at end of file diff --git a/drivers/input/fma1125.c b/drivers/input/fma1125.c new file mode 100644 index 0000000..8241371 --- /dev/null +++ b/drivers/input/fma1125.c @@ -0,0 +1,47 @@ +/* + * (c) 2012 Graf-Syteco, Matthias Weisser + * weisserm@arcor.de + * + * fma1125.c - FUJITSU FMA1125 Touch Sensor Controller + * + * SPDX-License-Identifier: GPL-2.0+ + * + */ + +#include <common.h> +#include <fma1125.h> +#include <i2c.h> + +int fma1125_init(int id, const struct fma1125_register_tbl *lu, uint16_t num) +{ + const struct fma1125_register_tbl *p; + int res = 0; + + if (NULL == lu) + return res; + + if (!i2c_probe(FMA1125_SA)) { + int i; + + p = lu; + + for (i = 0; i < num; i++) { + i2c_reg_write(id, p->addr, p->value); + p++; + } + + res = 1; + } + return res; +} + +int fma1125_get_touch_bits(void) +{ + uint8_t res = i2c_reg_read(FMA1125_SA, FMA1125_PA_TOUCH_BYTE); + return res; +} + +void fma1125_set_gpio_out(uint8_t value) +{ + i2c_reg_write(FMA1125_SA, FMA1125_GPIO_DATA_OUT, value); +} diff --git a/include/fma1125.h b/include/fma1125.h new file mode 100644 index 0000000..322cff5 --- /dev/null +++ b/include/fma1125.h @@ -0,0 +1,140 @@ +/* + * (c) 2012 Graf-Syteco, Matthias Weisser + * weisserm@arcor.de + * + * fma1125.h - FUJITSU FMA1125 Touch Sensor Controller + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __FMA1125_H +#define __FMA1125_H + + +#define FMA1125_SA 0x68 + +#define FMA1125_PA0_ALPHA 0x00 +#define FMA1125_PA1_ALPHA 0x01 +#define FMA1125_PA2_ALPHA 0x02 +#define FMA1125_PA3_ALPHA 0x03 +#define FMA1125_PA4_ALPHA 0x04 +#define FMA1125_PA5_ALPHA 0x05 +#define FMA1125_PA6_ALPHA 0x06 +#define FMA1125_PA7_ALPHA 0x07 +#define FMA1125_REFERENCE_DELAY 0x08 +#define FMA1125_BETA 0x09 +#define FMA1125_AIC_WAIT_TIME 0x0A +#define FMA1125_PA0_STRENGTH_THRESHOLD 0x0B +#define FMA1125_PA1_STRENGTH_THRESHOLD 0x0C +#define FMA1125_PA2_STRENGTH_THRESHOLD 0x0D +#define FMA1125_PA3_STRENGTH_THRESHOLD 0x0E +#define FMA1125_PA4_STRENGTH_THRESHOLD 0x0F +#define FMA1125_PA5_STRENGTH_THRESHOLD 0x10 +#define FMA1125_PA6_STRENGTH_THRESHOLD 0x11 +#define FMA1125_PA7_STRENGTH_THRESHOLD 0x12 +#define FMA1125_FEATURE_SELECT 0x13 +#define FMA1125_INTEGRATION_TIME 0x14 +#define FMA1125_IDLE_STATE_ENTER_TIME 0x15 +#define FMA1125_CONTROL_1 0x16 +#define FMA1125_CONTROL_2 0x17 +#define FMA1125_PA_DATA_OUT 0x18 +#define FMA1125_GPIO_DATA_OUT 0x19 +#define FMA1125_PA_DIRECTION 0x1A +#define FMA1125_GPIO_DIRECTION 0x1B +#define FMA1125_PA_CONFIGURATION 0x1C +#define FMA1125_GPIO_CONFIGURATION 0x1D +#define FMA1125_CALIBRATION_INTERVAL 0x1E +#define FMA1125_GINT_INTERRUPT_MASK 0x1F +#define FMA1125_GINT_INTERRUPT_CLEAR 0x20 +#define FMA1125_PA_EINT_ENABLE 0x21 +#define FMA1125_GPIO_EINT_ENABLE 0x22 +#define FMA1125_FILTER_PERIOD 0x23 +#define FMA1125_FILTER_THRESHOLD 0x24 +#define FMA1125_CONTROL_3 0x25 +#define FMA1125_GINT_INTERRUPT_EDGE_EN 0x26 +#define FMA1125_GPIO_INPUT_BOUNCE_PERIOD 0x27 +#define FMA1125_REGISTER_CHECK 0x28 +#define FMA1125_PA03_RESISTOR_SELECT 0x29 +#define FMA1125_PA47_RESISTOR_SELECT 0x2A +#define FMA1125_REFERENCE_RESISTOR_SELECT 0x2B +#define FMA1125_BETA_DISABLE 0x2C +#define FMA1125_GPIO01_DIM_UNIT_PERIOD 0x2D +#define FMA1125_GPIO23_DIM_UNIT_PERIOD 0x2E +#define FMA1125_PA01_DIM_UNIT_PERIOD 0x2F +#define FMA1125_PA23_DIM_UNIT_PERIOD 0x30 +#define FMA1125_GPIO0_DIMMING_CONTROL 0x31 +#define FMA1125_GPIO1_DIMMING_CONTROL 0x32 +#define FMA1125_GPIO2_DIMMING_CONTROL 0x33 +#define FMA1125_GPIO3_DIMMING_CONTROL 0x34 +#define FMA1125_PA0_DIMMING_CONTROL 0x35 +#define FMA1125_PA1_DIMMING_CONTROL 0x36 +#define FMA1125_PA2_DIMMING_CONTROL 0x37 +#define FMA1125_PA3_DIMMING_CONTROL 0x38 +#define FMA1125_GPIO03_DIMMING_MODE 0x39 +#define FMA1125_PA03_DIMMING_MODE 0x3A +#define FMA1125_DIMMING_START 0x3B +#define FMA1125_DIMMING_ENABLE 0x3C +#define FMA1125_PA0_STRENGTH 0x50 +#define FMA1125_PA1_STRENGTH 0x51 +#define FMA1125_PA2_STRENGTH 0x52 +#define FMA1125_PA3_STRENGTH 0x53 +#define FMA1125_PA4_STRENGTH 0x54 +#define FMA1125_PA5_STRENGTH 0x55 +#define FMA1125_PA6_STRENGTH 0x56 +#define FMA1125_PA7_STRENGTH 0x57 +#define FMA1125_PA0_IMPEDANCE 0x58 +#define FMA1125_PA1_IMPEDANCE 0x59 +#define FMA1125_PA2_IMPEDANCE 0x5A +#define FMA1125_PA3_IMPEDANCE 0x5B +#define FMA1125_PA4_IMPEDANCE 0x5C +#define FMA1125_PA5_IMPEDANCE 0x5D +#define FMA1125_PA6_IMPEDANCE 0x5E +#define FMA1125_PA7_IMPEDANCE 0x5F +#define FMA1125_PA0_REF_IMPEDANCE 0x60 +#define FMA1125_PA1_REF_IMPEDANCE 0x61 +#define FMA1125_PA2_REF_IMPEDANCE 0x62 +#define FMA1125_PA3_REF_IMPEDANCE 0x63 +#define FMA1125_PA4_REF_IMPEDANCE 0x64 +#define FMA1125_PA5_REF_IMPEDANCE 0x65 +#define FMA1125_PA6_REF_IMPEDANCE 0x66 +#define FMA1125_PA7_REF_IMPEDANCE 0x67 +#define FMA1125_PA_TOUCH_BYTE 0x68 +#define FMA1125_GINT_INTERRUPT_PENDING 0x69 +#define FMA1125_PA_INPUT_DATA 0x6A +#define FMA1125_GPIO_INPUT_DATA 0x6B +#define FMA1125_PA_INPUT_BCU_DATA 0x6C +#define FMA1125_GPIO_INPUT_BCU_DATA 0x6D +#define FMA1125_PA_INPUT_FIFO_DATA 0x6E +#define FMA1125_GPIO_INPUT_FIFO_DATA 0x6F +#define FMA1125_CLK_EXTERNAL 0xF7 +#define FMA1125_CLK_INTERNAL 0xF8 +#define FMA1125_BIAS_OFF 0xF9 +#define FMA1125_BIAS_ON 0xFA +#define FMA1125_LTB_ENABLE 0xFB +#define FMA1125_WAKEUP_SLEEP 0xFC +#define FMA1125_ENTER_SLEEP 0xFD +#define FMA1125_COLD_RESET 0xFE +#define FMA1125_WARM_RESET 0xFF + + +#define FMA1125_PA7_R_SEL(x) (((x) & 0x3) << 6) +#define FMA1125_PA6_R_SEL(x) (((x) & 0x3) << 4) +#define FMA1125_PA5_R_SEL(x) (((x) & 0x3) << 2) +#define FMA1125_PA4_R_SEL(x) (((x) & 0x3) << 0) + +#define FMA1125_PA3_R_SEL(x) (((x) & 0x3) << 6) +#define FMA1125_PA2_R_SEL(x) (((x) & 0x3) << 4) +#define FMA1125_PA1_R_SEL(x) (((x) & 0x3) << 2) +#define FMA1125_PA0_R_SEL(x) (((x) & 0x3) << 0) + + +struct fma1125_register_tbl { + uint8_t addr; + uint8_t value; +}; + +int fma1125_init(int id, const struct fma1125_register_tbl *lu, uint16_t num); +int fma1125_get_touch_bits(void); +void fma1125_set_gpio_out(uint8_t value); + +#endif
It doesn't look right.
Thanks, Michal
Signed-off-by: Thomas Diener dietho@gmx.de --- drivers/input/Makefile | 3 +- drivers/input/mpr121.c | 67 ++++++++++++++++++++ include/mpr121.h | 158 ++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 227 insertions(+), 1 deletion(-) create mode 100644 drivers/input/mpr121.c create mode 100644 include/mpr121.h
diff --git a/drivers/input/Makefile b/drivers/input/Makefile index 203a311..a9fe157 100644 --- a/drivers/input/Makefile +++ b/drivers/input/Makefile @@ -15,4 +15,5 @@ endif obj-y += input.o obj-$(CONFIG_OF_CONTROL) += key_matrix.o obj-$(CONFIG_POLYTOUCH) += polytouch.o -obj-$(CONFIG_FMA1125) += fma1125.o \ No newline at end of file +obj-$(CONFIG_FMA1125) += fma1125.o +obj-$(CONFIG_MPR121) += mpr121.o diff --git a/drivers/input/mpr121.c b/drivers/input/mpr121.c new file mode 100644 index 0000000..66fcb2e --- /dev/null +++ b/drivers/input/mpr121.c @@ -0,0 +1,67 @@ +/* + * (c) 2012 Graf-Syteco, Matthias Weisser + * weisserm@arcor.de + * + * mpr121.c - Freescale Semiconductor capacitive touch sensor controller + * + * SPDX-License-Identifier: GPL-2.0+ + * + */ + +#include <common.h> +#include <i2c.h> +#include <mpr121.h> + +int mpr121_init(const struct mpr121_register_tbl *lu, uint16_t num) +{ + int addr = 0; + + if (NULL == lu) + return 0; + + if (!i2c_probe(MPR121_SA_0)) + addr = MPR121_SA_0; + else if (!i2c_probe(MPR121_SA_1)) + addr = MPR121_SA_1; + + if (addr == MPR121_SA_0 || addr == MPR121_SA_1) { + const struct mpr121_register_tbl *p; + int i; + + p = lu; + + for (i = 0; i < num; i++) { + i2c_reg_write(addr, p->addr, p->value); + p++; + } + + return addr; + } + return 0; +} + +int mpr121_get_touch_bits(u8 sa) +{ + int res; + + res = i2c_reg_read(sa, MPR121_ELE0_7_TOUCH); + res += i2c_reg_read(sa, MPR121_ELE8_11_TOUCH) * 256; + + return res; +} + +void mpr121_set_leds_on(void) +{ + i2c_reg_write(0x62, 0x00 | 0x80, 0x00); + + i2c_reg_write(0x62, 0x1C | 0x80, 0xFF); + + i2c_reg_write(0x62, 0x14 | 0x80, 0xaa); + i2c_reg_write(0x62, 0x15 | 0x80, 0xaa); + i2c_reg_write(0x62, 0x16 | 0x80, 0xaa); + i2c_reg_write(0x62, 0x17 | 0x80, 0xaa); + + i2c_reg_write(0x62, 0x02 | 0x80, 0xff); + i2c_reg_write(0x62, 0x06 | 0x80, 0xff); +} + diff --git a/include/mpr121.h b/include/mpr121.h new file mode 100644 index 0000000..1dadf00 --- /dev/null +++ b/include/mpr121.h @@ -0,0 +1,158 @@ +/* + * (c) 2012 Graf-Syteco, Matthias Weisser + * weisserm@arcor.de + * + * mpr121.h - Freescale Semiconductor capacitive touch sensor controller + * + * SPDX-License-Identifier: GPL-2.0+ + * + */ + +#ifndef __MPR121_H +#define __MPR121_H + +#define MPR121_SA_0 0x5a +#define MPR121_SA_1 0x5b +#define MPR121_SA_2 0x5c +#define MPR121_SA_3 0x5d + +#define MPR121_ELE0_7_TOUCH 0x00 /* Touch Status */ +#define MPR121_ELE8_11_TOUCH 0x01 /* ELEPROX Touch Status */ +#define MPR121_ELE0_7_OOR 0x02 /* OOR Status */ +#define MPR121_ELE8_11_OOR 0x03 /* ELEPROX OOR Status */ +#define MPR121_ELE0_L 0x04 /* Electrode Filtered Data LSB */ +#define MPR121_ELE0_H 0x05 /* Electrode Filtered Data MSB */ +#define MPR121_ELE1_L 0x06 /* Electrode Filtered Data LSB */ +#define MPR121_ELE1_H 0x07 /* Electrode Filtered Data MSB */ +#define MPR121_ELE2_L 0x08 /* Electrode Filtered Data LSB */ +#define MPR121_ELE2_H 0x09 /* Electrode Filtered Data MSB */ +#define MPR121_ELE3_L 0x0A /* Electrode Filtered Data LSB */ +#define MPR121_ELE3_H 0x0B /* Electrode Filtered Data MSB */ +#define MPR121_ELE4_L 0x0C /* Electrode Filtered Data LSB */ +#define MPR121_ELE4_H 0x0D /* Electrode Filtered Data MSB */ +#define MPR121_ELE5_L 0x0E /* Electrode Filtered Data LSB */ +#define MPR121_ELE5_H 0x0F /* Electrode Filtered Data MSB */ +#define MPR121_ELE6_L 0x10 /* Electrode Filtered Data LSB */ +#define MPR121_ELE6_H 0x11 /* Electrode Filtered Data MSB */ +#define MPR121_ELE7_L 0x12 /* Electrode Filtered Data LSB */ +#define MPR121_ELE7_H 0x13 /* Electrode Filtered Data MSB */ +#define MPR121_ELE8_L 0x14 /* Electrode Filtered Data LSB */ +#define MPR121_ELE8_H 0x15 /* Electrode Filtered Data MSB */ +#define MPR121_ELE9_L 0x16 /* Electrode Filtered Data LSB */ +#define MPR121_ELE9_H 0x17 /* Electrode Filtered Data MSB */ +#define MPR121_ELE10_L 0x18 /* Electrode Filtered Data LSB */ +#define MPR121_ELE10_H 0x19 /* Electrode Filtered Data MSB */ +#define MPR121_ELE11_L 0x1A /* Electrode Filtered Data LSB */ +#define MPR121_ELE11_H 0x1B /* Electrode Filtered Data MSB */ +#define MPR121_ELEPROX_L 0x1C /* Electrode Filtered Data LSB */ +#define MPR121_ELEPROX_H 0x1D /* Electrode Filtered Data MSB */ +#define MPR121_ELE0_BASELINE 0x1E /* Baseline Value */ +#define MPR121_ELE1_BASELINE 0x1F /* Baseline Value */ +#define MPR121_ELE2_BASELINE 0x20 /* Baseline Value */ +#define MPR121_ELE3_BASELINE 0x21 /* Baseline Value */ +#define MPR121_ELE4_BASELINE 0x22 /* Baseline Value */ +#define MPR121_ELE5_BASELINE 0x23 /* Baseline Value */ +#define MPR121_ELE6_BASELINE 0x24 /* Baseline Value */ +#define MPR121_ELE7_BASELINE 0x25 /* Baseline Value */ +#define MPR121_ELE8_BASELINE 0x26 /* Baseline Value */ +#define MPR121_ELE9_BASELINE 0x27 /* Baseline Value */ +#define MPR121_ELE10_BASELINE 0x28 /* Baseline Value */ +#define MPR121_ELE11_BASELINE 0x29 /* Baseline Value */ +#define MPR121_ELEPROX 0x2A /* Baseline Value */ +#define MPR121_MHD_RIS 0x2B /* Rising */ +#define MPR121_NHD_RIS 0x2C /* Amount Rising */ +#define MPR121_NCL_RIS 0x2D /* Rising */ +#define MPR121_FDL_RIS 0x2E /* Rising */ +#define MPR121_MHD_FALL 0x2F /* Falling */ +#define MPR121_NHD_FALL 0x30 /* Amount Falling */ +#define MPR121_NCL_FALL 0x31 /* Falling */ +#define MPR121_FDL_FALL 0x32 /* Falling */ +#define MPR121_NHD_TOUCH 0x33 /* Amount Touched */ +#define MPR121_NCL_TOUCH 0x34 /* Touched */ +#define MPR121_FDL_TOUCH 0x35 /* Touched */ +#define MPR121_ELEPROX_MHD_RIS 0x36 /* Rising */ +#define MPR121_ELEPROX_NHD_RIS 0x37 /* Amount Rising */ +#define MPR121_ELEPROX_NCL_RIS 0x38 /* Rising */ +#define MPR121_ELEPROX_FDL_RIS 0x39 /* Rising */ +#define MPR121_ELEPROX_MHD_FALL 0x3A /* Falling */ +#define MPR121_ELEPROX_NHD_FALL 0x3B /* Amount Falling */ +#define MPR121_ELEPROX_NCL_FALL 0x3C /* Falling */ +#define MPR121_ELEPROX_FDL_FALL 0x3D /* Falling */ +#define MPR121_ELEPROX_NHD_TOUCH 0x3E /* Amount Touched */ +#define MPR121_ELEPROX_NCL_TOUCH 0x3F /* Touched */ +#define MPR121_ELEPROX_FDL_TOUCH 0x40 /* Touched */ +#define MPR121_ELE0_THRESH_TOUCH 0x41 /* Touch Threshold */ +#define MPR121_ELE0_THRESH_REL 0x42 /* Release Threshold */ +#define MPR121_ELE1_THRESH_TOUCH 0x43 /* Touch Threshold */ +#define MPR121_ELE1_THRESH_REL 0x44 /* Release Threshold */ +#define MPR121_ELE2_THRESH_TOUCH 0x45 /* Touch Threshold */ +#define MPR121_ELE2_THRESH_REL 0x46 /* Release Threshold */ +#define MPR121_ELE3_THRESH_TOUCH 0x47 /* Touch Threshold */ +#define MPR121_ELE3_THRESH_REL 0x48 /* Release Threshold */ +#define MPR121_ELE4_THRESH_TOUCH 0x49 /* Touch Threshold */ +#define MPR121_ELE4_THRESH_REL 0x4A /* Release Threshold */ +#define MPR121_ELE5_THRESH_TOUCH 0x4B /* Touch Threshold */ +#define MPR121_ELE5_THRESH_REL 0x4C /* Release Threshold */ +#define MPR121_ELE6_THRESH_TOUCH 0x4D /* Touch Threshold */ +#define MPR121_ELE6_THRESH_REL 0x4E /* Release Threshold */ +#define MPR121_ELE7_THRESH_TOUCH 0x4F /* Touch Threshold */ +#define MPR121_ELE7_THRESH_REL 0x50 /* Release Threshold */ +#define MPR121_ELE8_THRESH_TOUCH 0x51 /* Touch Threshold */ +#define MPR121_ELE8_THRESH_REL 0x52 /* Release Threshold */ +#define MPR121_ELE9_THRESH_TOUCH 0x53 /* Touch Threshold */ +#define MPR121_ELE9_THRESH_REL 0x54 /* Release Threshold */ +#define MPR121_ELE10_THRESH_TOUCH 0x55 /* Touch Threshold */ +#define MPR121_ELE10_THRESH_REL 0x56 /* Release Threshold */ +#define MPR121_ELE11_THRESH_TOUCH 0x57 /* Touch Threshold */ +#define MPR121_ELE11_THRESH_REL 0x58 /* Release Threshold */ +#define MPR121_ELEPROX_THRESH_TOUCH 0x59 /* Touch Threshold */ +#define MPR121_ELEPROX_THRESH_REL 0x5A /* Release Threshold */ +#define MPR121_DBC 0x5B /* Debounce Touch & Release */ +#define MPR121_FILT_CDC 0x5C /* Filter CDC Configuration */ +#define MPR121_FILT_CDT 0x5D /* Filter CDT Configuration */ +#define MPR121_ECR 0x5E /* Electrode Configuration */ +#define MPR121_ELE0_CURRENT 0x5F /* Electrode Current */ +#define MPR121_ELE1_CURRENT 0x60 /* Electrode Current */ +#define MPR121_ELE2_CURRENT 0x61 /* Electrode Current */ +#define MPR121_ELE3_CURRENT 0x62 /* Electrode Current */ +#define MPR121_ELE4_CURRENT 0x63 /* Electrode Current */ +#define MPR121_ELE5_CURRENT 0x64 /* Electrode Current */ +#define MPR121_ELE6_CURRENT 0x65 /* Electrode Current */ +#define MPR121_ELE7_CURRENT 0x66 /* Electrode Current */ +#define MPR121_ELE8_CURRENT 0x67 /* Electrode Current */ +#define MPR121_ELE9_CURRENT 0x68 /* Electrode Current */ +#define MPR121_ELE10_CURRENT 0x69 /* Electrode Current */ +#define MPR121_ELE11_CURRENT 0x6A /* Electrode Current */ +#define MPR121_ELEPROX_CURRENT 0x6B /* Electrode Current */ +#define MPR121_ELE0_1_CHARGE 0x6C /* Charge Time */ +#define MPR121_ELE2_3_CHARGE 0x6D /* Charge Time */ +#define MPR121_ELE4_5_CHARGE 0x6E /* Charge Time */ +#define MPR121_ELE6_7_CHARGE 0x6F /* Charge Time */ +#define MPR121_ELE8_9_CHARGE 0x70 /* Charge Time */ +#define MPR121_ELE10_11_CHARGE 0x71 /* Charge Time */ +#define MPR121_ELEPROX_CHARGE 0x72 /* Charge Time */ +#define MPR121_GPIO_CTRL0 0x73 /* Control Register 0 */ +#define MPR121_GPIO_CTRL1 0x74 /* Control Register 1 */ +#define MPR121_GPIO_DATA 0x75 /* Data Register */ +#define MPR121_GPIO_DIR 0x76 /* Direction Register */ +#define MPR121_GPIO_EN 0x77 /* Enable Register */ +#define MPR121_GPIO_SET 0x78 /* Data Set Register */ +#define MPR121_GPIO_CLR 0x79 /* Data Clear Register */ +#define MPR121_GPIO_TOG 0x7A /* Data Toggle Register */ +#define MPR121_AUTO_CONFIG_CTRL0 0x7B /* Control Register 0 */ +#define MPR121_AUTO_CONFIG_CTRL1 0x7C /* Control Register 1 */ +#define MPR121_AUTO_CONFIG_USL 0x7D /* USL Register */ +#define MPR121_AUTO_CONFIG_LSL 0x7E /* LSL Register */ +#define MPR121_AUTO_CONFIG_TLR 0x7F /* Target Level Register */ +#define MPR121_SRST 0x80 /* Soft Reset Register */ + +struct mpr121_register_tbl { + uint8_t addr; + uint8_t value; +}; + +int mpr121_init(const struct mpr121_register_tbl *lu, uint16_t num); +int mpr121_get_touch_bits(u8 sa); +void mpr121_set_leds_on(void); + +#endif
Added support for additional hardware variants.
We don't use a linux kernel and have to do the complete hardware setup in the boot loader.
board/syteco/zmx25/lowlevel_init.S | 21 + board/syteco/zmx25/zmx25.c | 1052 +++++++++++++++++++++++++++++++++--- include/configs/zmx25.h | 66 ++- 3 files changed, 1064 insertions(+), 75 deletions(-)
diff --git a/board/syteco/zmx25/lowlevel_init.S b/board/syteco/zmx25/lowlevel_init.S index 5eccf09..aa38459 100644 --- a/board/syteco/zmx25/lowlevel_init.S +++ b/board/syteco/zmx25/lowlevel_init.S @@ -92,6 +92,27 @@ lowlevel_init: init_aips init_max + + /* Setup of NOR flash CS */ + write32 IMX_WEIM_CTRL_BASE + WEIM_CSCR0U, \ + (WEIM_CSCR_U_WSC(14) | WEIM_CSCR_U_EDC(2)) + write32 IMX_WEIM_CTRL_BASE + WEIM_CSCR0L, \ + (WEIM_CSCR_L_OAE(1) | WEIM_CSCR_L_OEN(1) | \ + WEIM_CSCR_L_DSZ(5)| WEIM_CSCR_L_CS_EN) + write32 IMX_WEIM_CTRL_BASE + WEIM_CSCR0A, \ + (WEIM_CSCR_A_RWA(1) | WEIM_CSCR_A_RWN(1)) + + /* Set some memory access priorities */ + write32 IMX_M3IF_CTRL_BASE + M3IF_CTL, M3IF_CTL_MRRP(1) + write32 IMX_MAX_BASE + MAX_MGPCR0, MAX_MGPCR_AULB(0x4) + write32 IMX_MAX_BASE + MAX_MGPCR1, MAX_MGPCR_AULB(0x4) + write32 IMX_MAX_BASE + MAX_MGPCR2, MAX_MGPCR_AULB(0x4) + write32 IMX_MAX_BASE + MAX_MGPCR3, MAX_MGPCR_AULB(0x4) + write32 IMX_MAX_BASE + MAX_MGPCR4, MAX_MGPCR_AULB(0x4) + + /* Need this early for voltage sequence on G305 */ + write32 IMX_IOPADMUX_BASE + 0x38c, 5 //Offset 0x38C IOPADMUX_SD1_CLK + init_clocks init_lpddr mov pc, lr diff --git a/board/syteco/zmx25/zmx25.c b/board/syteco/zmx25/zmx25.c index bdbf02a..f6c018d 100644 --- a/board/syteco/zmx25/zmx25.c +++ b/board/syteco/zmx25/zmx25.c @@ -1,4 +1,7 @@ /* + * (c) 2014 Graf-Syteco, Thomas Diener + * dietho@gmx.de + * * (c) 2011 Graf-Syteco, Matthias Weisser * weisserm@arcor.de * @@ -14,63 +17,705 @@ * * SPDX-License-Identifier: GPL-2.0+ */ + #include <common.h> -#include <asm/gpio.h> +#include <i2c.h> +#include <spi.h> +#include <video.h> +#include <netdev.h> +#include <mpr121.h> +#include <fma1125.h> +#include <polytouch.h> + #include <asm/io.h> +#include <asm/gpio.h> #include <asm/arch/imx-regs.h> #include <asm/arch/iomux-mx25.h> +#include <asm/imx-common/mxc_i2c.h> + + +#define ZMX25_CPU_BOARD_TYPE_UNKNOWN 0 +#define ZMX25_CPU_BOARD_TYPE_G282A0 1 +#define ZMX25_CPU_BOARD_TYPE_G282A1 2 +#define ZMX25_CPU_BOARD_TYPE_G292 3 +#define ZMX25_CPU_BOARD_TYPE_G305 4 + +#define ZMX25_IO_BOARD_TYPE_NONE 0 +#define ZMX25_IO_BOARD_TYPE_UNKNOWN 1 +#define ZMX25_IO_BOARD_TYPE_G283 2 +#define ZMX25_IO_BOARD_TYPE_G297 3 + +#define ZMX25_FIXED_EEPROM_ADDR_APP 0x80 +#define ZMX25_FIXED_EEPROM_ADDR_BI1 0xA0 +#define ZMX25_FIXED_EEPROM_ADDR_BI2 0xC0 + +#define ZMX25_BOOT_MODE_SLOW 0x55AAAA55 +#define ZMX25_BOOT_MODE_FAST 0xAA5555AA
DECLARE_GLOBAL_DATA_PTR;
-int board_init() +static inline u32 hw_setup_common(void); + +static inline void hw_setup_cpu_g282g292(void); +static inline void hw_setup_cpu_g282(void); +static inline void hw_setup_cpu_g282a1(void); +static inline void hw_setup_cpu_g292(void); +static inline void hw_setup_cpu_g305(void); + +static inline void hw_setup_io_g283(void); +static inline void hw_setup_io_g297(void); + +static const iomux_v3_cfg_t can_pads[] = { + CLEAR_MODE_SION(NEW_PAD_CTRL(MX25_PAD_GPIO_A__CAN1_TX, 0)), + CLEAR_MODE_SION(NEW_PAD_CTRL(MX25_PAD_GPIO_B__CAN1_RX, + PAD_CTL_PUS_100K_DOWN)), + CLEAR_MODE_SION(NEW_PAD_CTRL(MX25_PAD_GPIO_C__CAN2_TX, 0)), + CLEAR_MODE_SION(NEW_PAD_CTRL(MX25_PAD_GPIO_D__CAN2_RX, 0)), +}; + +static const struct fma1125_register_tbl fma1125_config[] = { + { FMA1125_COLD_RESET, 0x00 }, /* cold reset */ + { FMA1125_REGISTER_CHECK, 0xFF }, /* register check */ + { FMA1125_GINT_INTERRUPT_MASK, 0xFE }, /* Mask all interrupts */ + { FMA1125_GINT_INTERRUPT_CLEAR, 0xFF }, /* Mask all interrupts */ + { FMA1125_GPIO_DIRECTION, 0x00 }, /* All GPIOs are output */ + { FMA1125_GPIO_CONFIGURATION, 0x0f }, /* All GPIOs are GPIOs */ + { FMA1125_GPIO_DATA_OUT, 0x03 }, /* Switch the LEDs off */ + + /* P0A - PA7 Alpha; sensitivity of each sensor input*/ + { FMA1125_PA0_ALPHA, 0x0A }, + { FMA1125_PA1_ALPHA, 0x0A }, + { FMA1125_PA2_ALPHA, 0x0A }, + { FMA1125_PA3_ALPHA, 0x0A }, + { FMA1125_PA4_ALPHA, 0x0A }, + { FMA1125_PA5_ALPHA, 0x0A }, + { FMA1125_PA6_ALPHA, 0x0A }, + { FMA1125_PA7_ALPHA, 0x0A }, + + { FMA1125_REFERENCE_DELAY, 0x50 }, /* Reference delay */ + { FMA1125_BETA, 4 }, /* Beta */ + { FMA1125_AIC_WAIT_TIME, 0x27 }, /* AIC wait time */ + + /* PA0 - PA7 Strength threshold to 2/10 of integration time */ + { FMA1125_PA0_STRENGTH_THRESHOLD, 0x28 }, + { FMA1125_PA1_STRENGTH_THRESHOLD, 0x28 }, + { FMA1125_PA2_STRENGTH_THRESHOLD, 0x28 }, + { FMA1125_PA3_STRENGTH_THRESHOLD, 0x28 }, + { FMA1125_PA4_STRENGTH_THRESHOLD, 0x28 }, + { FMA1125_PA5_STRENGTH_THRESHOLD, 0x28 }, + { FMA1125_PA6_STRENGTH_THRESHOLD, 0x28 }, + { FMA1125_PA7_STRENGTH_THRESHOLD, 0x28 }, + + { FMA1125_INTEGRATION_TIME, 0xC8 }, /* Integration time 200 */ + { FMA1125_FEATURE_SELECT, 0x04 }, /* Enable APIS mode 2 */ + { FMA1125_CONTROL_1, 0xA0 }, /* Enable ACTIVE mode, LED dimming) */ + { FMA1125_CONTROL_2, 0x02 }, /* Interrupt Polarity falling edge */ + { FMA1125_PA_CONFIGURATION, 0x00 }, /* PA0-PA7 sensor input pins */ + { FMA1125_PA03_RESISTOR_SELECT, FMA1125_PA3_R_SEL(3) | + FMA1125_PA2_R_SEL(1) | + FMA1125_PA1_R_SEL(1) | + FMA1125_PA0_R_SEL(1) }, + { FMA1125_PA47_RESISTOR_SELECT, FMA1125_PA7_R_SEL(3) | + FMA1125_PA6_R_SEL(1) | + FMA1125_PA5_R_SEL(1) | + FMA1125_PA4_R_SEL(1) }, + { FMA1125_WARM_RESET, 0x00 }, /* Perform a warm reset */ +}; + +static const struct mpr121_register_tbl mpr121_config[] = { + /* Soft reset */ + { MPR121_ECR, 0x00 }, + { MPR121_SRST, 0x63 }, + + /* Settings according to AN3944 */ + { MPR121_MHD_RIS, 0x01 }, + { MPR121_NHD_RIS, 0x01 }, + { MPR121_NCL_RIS, 0x00 }, + { MPR121_FDL_RIS, 0x00 }, + + { MPR121_MHD_FALL, 0x01 }, + { MPR121_NHD_FALL, 0x01 }, + { MPR121_NCL_FALL, 0xff }, + { MPR121_FDL_FALL, 0x02 }, + + { MPR121_ELE0_THRESH_TOUCH, 0x04 }, + { MPR121_ELE0_THRESH_REL, 0x02 }, + { MPR121_ELE1_THRESH_TOUCH, 0x04 }, + { MPR121_ELE1_THRESH_REL, 0x02 }, + { MPR121_ELE2_THRESH_TOUCH, 0x04 }, + { MPR121_ELE2_THRESH_REL, 0x02 }, + { MPR121_ELE3_THRESH_TOUCH, 0x04 }, + { MPR121_ELE3_THRESH_REL, 0x02 }, + { MPR121_ELE4_THRESH_TOUCH, 0x04 }, + { MPR121_ELE4_THRESH_REL, 0x02 }, + { MPR121_ELE5_THRESH_TOUCH, 0x04 }, + { MPR121_ELE5_THRESH_REL, 0x02 }, + { MPR121_ELE6_THRESH_TOUCH, 0x04 }, + { MPR121_ELE6_THRESH_REL, 0x02 }, + { MPR121_ELE7_THRESH_TOUCH, 0x04 }, + { MPR121_ELE7_THRESH_REL, 0x02 }, + { MPR121_ELE8_THRESH_TOUCH, 0x04 }, + { MPR121_ELE8_THRESH_REL, 0x02 }, + { MPR121_ELE9_THRESH_TOUCH, 0x04 }, + { MPR121_ELE9_THRESH_REL, 0x02 }, + { MPR121_ELE10_THRESH_TOUCH, 0x04 }, + { MPR121_ELE10_THRESH_REL, 0x02 }, + { MPR121_ELE11_THRESH_TOUCH, 0x04 }, + { MPR121_ELE11_THRESH_REL, 0x02 }, + + { MPR121_FILT_CDT, 0x04 }, + + { MPR121_ELE0_CURRENT, 0x12 }, + { MPR121_ELE1_CURRENT, 0x12 }, + { MPR121_ELE2_CURRENT, 0x22 }, + { MPR121_ELE3_CURRENT, 0x20 }, + { MPR121_ELE4_CURRENT, 0x1e }, + { MPR121_ELE5_CURRENT, 0x1b }, + { MPR121_ELE6_CURRENT, 0x19 }, + { MPR121_ELE7_CURRENT, 0x18 }, + { MPR121_ELE8_CURRENT, 0x1a }, + { MPR121_ELE9_CURRENT, 0x1e }, + { MPR121_ELE10_CURRENT, 0x22 }, + { MPR121_ELE11_CURRENT, 0x23 }, + + { MPR121_ELE0_1_CHARGE, 0x22 }, + { MPR121_ELE2_3_CHARGE, 0x22 }, + { MPR121_ELE4_5_CHARGE, 0x22 }, + { MPR121_ELE6_7_CHARGE, 0x22 }, + { MPR121_ELE8_9_CHARGE, 0x22 }, + { MPR121_ELE10_11_CHARGE, 0x22 }, + + { MPR121_ECR, 0xCC }, +}; + +static u32 cpu_board_type; +static u32 io_board_type; +static u32 have_touch_display; + +static inline u16 hw_g297_xfer_srio(u16 value) { + /* Set LCD PWR CTRL and release RESET */ + + struct spi_slave *spi; + u8 spi_in[2]; + u8 spi_out[2]; + + writeb((WEIM_CSCR_U_EDC(5) | WEIM_CSCR_U_WWS(4)), IMX_WEIM_CS4); + + spi_out[0] = value >> 8; + spi_out[1] = value; + + spi = spi_setup_slave(2, 0, 1000000, 0); + spi_claim_bus(spi); + spi_xfer(spi, 16, spi_out, spi_in, SPI_XFER_BEGIN | SPI_XFER_END); + spi_release_bus(spi); + spi_free_slave(spi); + + writeb((WEIM_CSCR_U_EDC(3) | WEIM_CSCR_U_WWS(4)), IMX_WEIM_CS4); + udelay(1000); + writeb((WEIM_CSCR_U_EDC(5) | WEIM_CSCR_U_WWS(4)), IMX_WEIM_CS4); + + return spi_in[0] | (spi_in[1] << 8); +} + +static inline u32 hw_setup_common(void) +{ + struct ccm_regs *ccm; + u32 bt_uart_src; + u32 res; + + ccm = (struct ccm_regs *)IMX_CCM_BASE; + + have_touch_display = 0; + + /* Setup of CAN1 signals */ + imx_iomux_v3_setup_multiple_pads(can_pads, ARRAY_SIZE(can_pads)); + + /* Set CPU clock to 399MHz */ + writel(((CCM_CCTL_AHB_DIV(2)) | + (CCM_CCTL_USB_DIV(3)) | + (CCM_CCTL_ARM_SRC)), &ccm->cctl); + + /* + * We decide on which board we are running according to BT_UART_SRC + * bits in CRDR register of CCM. 0 -> G292, 1 -> G282 + */ + bt_uart_src = (readl(&ccm->crdr) >> CCM_CRDR_BT_UART_SRC_SHIFT) & + CCM_CRDR_BT_UART_SRC_MASK; + + /* Setup of cpu board */ + if (bt_uart_src == 0) { + res = ZMX25_CPU_BOARD_TYPE_G292; + hw_setup_cpu_g282g292(); + hw_setup_cpu_g292(); + puts("zmx25: G292\n"); + } else if (bt_uart_src == 1) { + res = ZMX25_CPU_BOARD_TYPE_G282A0; + hw_setup_cpu_g282g292(); + hw_setup_cpu_g282(); + puts("zmx25: G282A0\n"); + } else if (bt_uart_src == 2) { + res = ZMX25_CPU_BOARD_TYPE_G282A1; + hw_setup_cpu_g282g292(); + hw_setup_cpu_g282(); + hw_setup_cpu_g282a1(); + puts("zmx25: G282A1\n"); + } else if (bt_uart_src == 4) { + res = ZMX25_CPU_BOARD_TYPE_G305; + hw_setup_cpu_g305(); + puts("zmx25: G305\n"); + } else { + res = ZMX25_CPU_BOARD_TYPE_UNKNOWN; + puts("zmx25: UNKNOWN\n"); + } + + /* Setup of io board */ + if (io_board_type == ZMX25_IO_BOARD_TYPE_G283) { + hw_setup_io_g283(); + puts("zmx25: IO->G283\n"); + } else if (io_board_type == ZMX25_IO_BOARD_TYPE_G297) { + hw_setup_io_g297(); + puts("zmx25: IO->G297\n"); + } else if (io_board_type == ZMX25_IO_BOARD_TYPE_UNKNOWN) { + puts("zmx25: IO->UNKNOWN\n"); + } + + return res; +} + +static inline void hw_setup_cpu_g282g292(void) +{ + static const iomux_v3_cfg_t i2c3_pads[] = { + CLEAR_MODE_SION(MX25_PAD_CSPI1_SS1__I2C3_DAT), + CLEAR_MODE_SION(MX25_PAD_GPIO_E__I2C3_CLK), + }; + static const iomux_v3_cfg_t sdhc1_pads[] = { NEW_PAD_CTRL(MX25_PAD_SD1_CMD__SD1_CMD, NO_PAD_CTRL), - NEW_PAD_CTRL(MX25_PAD_SD1_CLK__SD1_CLK, NO_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_SD1_CLK__SD1_CLK, + PAD_CTL_PUS_47K_UP | PAD_CTL_SRE_FAST), NEW_PAD_CTRL(MX25_PAD_SD1_DATA0__SD1_DATA0, NO_PAD_CTRL), NEW_PAD_CTRL(MX25_PAD_SD1_DATA1__SD1_DATA1, NO_PAD_CTRL), NEW_PAD_CTRL(MX25_PAD_SD1_DATA2__SD1_DATA2, NO_PAD_CTRL), NEW_PAD_CTRL(MX25_PAD_SD1_DATA3__SD1_DATA3, NO_PAD_CTRL), };
- static const iomux_v3_cfg_t dig_out_pads[] = { - MX25_PAD_CSI_D8__GPIO_1_7, /* Ouput 1 Ctrl */ - MX25_PAD_CSI_D7__GPIO_1_6, /* Ouput 2 Ctrl */ - NEW_PAD_CTRL(MX25_PAD_CSI_D6__GPIO_1_31, 0), /* Ouput 1 Stat */ - NEW_PAD_CTRL(MX25_PAD_CSI_D5__GPIO_1_30, 0), /* Ouput 2 Stat */ + /* Setup of core voltage selection pin to run at 1.4V */ + imx_iomux_v3_setup_pad(CLEAR_MODE_SION(MX25_PAD_EXT_ARMCLK__GPIO_3_15)); + gpio_direction_output(IMX_GPIO_NR(3, 15), 1); + + /* Setup of input daisy chains for SD card pins */ + imx_iomux_v3_setup_multiple_pads(sdhc1_pads, ARRAY_SIZE(sdhc1_pads)); + + /* Setup of I2C3 signals */ + imx_iomux_v3_setup_multiple_pads(i2c3_pads, ARRAY_SIZE(i2c3_pads)); +} + +static inline void hw_setup_cpu_g282(void) +{ + /* GPIO1[26] -> LCD_PWR */ + imx_iomux_v3_setup_pad(NEW_PAD_CTRL( + CLEAR_MODE_SION(MX25_PAD_PWM__GPIO_1_26), + PAD_CTL_PUS_100K_UP)); + udelay(1000); + + /* GPIO3[19] -> Used as power fail interrupt */ + imx_iomux_v3_setup_pad(CLEAR_MODE_SION(MX25_PAD_POWER_FAIL__GPIO_3_19)); + gpio_direction_input(IMX_GPIO_NR(3, 19)); + + if (!gpio_get_value(IMX_GPIO_NR(1, 26))) + io_board_type = ZMX25_IO_BOARD_TYPE_G297; + else + io_board_type = ZMX25_IO_BOARD_TYPE_G283; +} + +static inline void hw_setup_cpu_g282a1(void) +{ + struct ccm_regs *ccm; + struct weim_regs *weim; + + static const iomux_v3_cfg_t fpga_pads[] = { + CLEAR_MODE_SION(MX25_PAD_CSI_MCLK__GPIO_1_8), /* TMS */ + CLEAR_MODE_SION(MX25_PAD_CSI_VSYNC__GPIO_1_9), /* TCK */ + CLEAR_MODE_SION(MX25_PAD_CSI_HSYNC__GPIO_1_10),/* TDI */ + CLEAR_MODE_SION(NEW_PAD_CTRL(MX25_PAD_CSI_PIXCLK__GPIO_1_11, + PAD_CTL_PUS_100K_UP | PAD_CTL_HYS)), /* TDO */ + CLEAR_MODE_SION(MX25_PAD_KPP_COL2__GPIO_3_3), /* Program */ + CLEAR_MODE_SION(MX25_PAD_KPP_COL3__GPIO_3_4), /* JTAGENB */ + }; + + ccm = (struct ccm_regs *)IMX_CCM_BASE; + weim = (struct weim_regs *)IMX_WEIM_CTRL_BASE; + + /* --- Setup of FPGA program pins --- */ + imx_iomux_v3_setup_multiple_pads(fpga_pads, ARRAY_SIZE(fpga_pads)); + + gpio_direction_output(IMX_GPIO_NR(1, 8), 0); + gpio_direction_output(IMX_GPIO_NR(1, 9), 0); + gpio_direction_output(IMX_GPIO_NR(1, 10), 0); + + gpio_direction_input(IMX_GPIO_NR(1, 11)); + gpio_direction_input(IMX_GPIO_NR(3, 3)); + gpio_direction_input(IMX_GPIO_NR(3, 4)); + + /* --- Clock output (33,25MHz) --- */ + writel((1<<CCM_CCTL_ARM_DIV_SHIFT) | + (1<<CCM_CCTL_LP_CTL_SHIFT) | + (1<<CCM_CCTL_MPLL_BYP_SHIFT), &ccm->mcr); + + /* --- Setup of FPGA CS --- */ + writel(WEIM_CSCR_U_CNC(3) | WEIM_CSCR_U_WSC(20), + &weim->cscr5u); + writel((WEIM_CSCR_L_OAE(6) | WEIM_CSCR_L_OEN(12) | WEIM_CSCR_L_EBWA(4) | + WEIM_CSCR_L_EBWN(10) | WEIM_CSCR_L_EBC | WEIM_CSCR_L_DSZ(3) | + WEIM_CSCR_L_CSN(8) | WEIM_CSCR_L_CS_EN), &weim->cscr5l); + writel((WEIM_CSCR_A_RWA(6) | WEIM_CSCR_A_RWN(12) | WEIM_CSCR_A_LBN(4)), + &weim->cscr5a); +} + +static inline void hw_setup_cpu_g292(void) +{ + struct ccm_regs *ccm; + struct weim_regs *weim; + + static const iomux_v3_cfg_t uart3_pads[] = { + MX25_PAD_KPP_ROW0__UART3_RXD, + MX25_PAD_KPP_ROW1__UART3_TXD, + MX25_PAD_KPP_ROW2__UART3_RTS, + MX25_PAD_KPP_ROW3__UART3_CTS, + }; + + static const iomux_v3_cfg_t lcd_pads[] = { + CLEAR_MODE_SION(MX25_PAD_CSPI1_SS0__LD16), + NEW_PAD_CTRL(MX25_PAD_GPIO_F__LD17, 0), + /* reset active */ + CLEAR_MODE_SION(MX25_PAD_CSI_MCLK__GPIO_1_8), + CLEAR_MODE_SION(MX25_PAD_UART2_RTS__GPIO_4_28),/* low power */ + CLEAR_MODE_SION(MX25_PAD_CSI_VSYNC__GPIO_1_9), /* on */ + }; + + static const iomux_v3_cfg_t detect_touchscreen_pads[] = { + NEW_PAD_CTRL(CLEAR_MODE_SION(MX25_PAD_CSI_D8__GPIO_1_7), + PAD_CTL_PUS_22K_UP), + NEW_PAD_CTRL(CLEAR_MODE_SION(MX25_PAD_CSPI1_SCLK__GPIO_1_18), + PAD_CTL_PUS_22K_UP), + }; + + static const iomux_v3_cfg_t touchscreen_pads[] = { + CLEAR_MODE_SION(MX25_PAD_CSI_HSYNC__GPIO_1_10),/* Touch Int */ + CLEAR_MODE_SION(MX25_PAD_CSPI1_MISO__GPIO_1_15),/* Touch SCK */ + CLEAR_MODE_SION(MX25_PAD_CSPI1_RDY__GPIO_2_22),/* Touch MISO */ + }; + + static const iomux_v3_cfg_t touch_keys_pads[] = { + /* Motor */ + NEW_PAD_CTRL(CLEAR_MODE_SION(MX25_PAD_KPP_COL1__GPIO_3_2), 0), + /* Reset */ + NEW_PAD_CTRL(CLEAR_MODE_SION(MX25_PAD_KPP_COL2__GPIO_3_3), 0), + /* GINT */ + NEW_PAD_CTRL(CLEAR_MODE_SION(MX25_PAD_KPP_COL3__GPIO_3_4), 0), + }; + + static const iomux_v3_cfg_t fpga_pads[] = { + /* TMS */ + CLEAR_MODE_SION(MX25_PAD_CSI_D5__GPIO_1_30), + /* TCK */ + NEW_PAD_CTRL(CLEAR_MODE_SION(MX25_PAD_KPP_COL0__GPIO_3_1), 0), + /* TDI */ + CLEAR_MODE_SION(MX25_PAD_CSI_D7__GPIO_1_6), + /* TDO */ + NEW_PAD_CTRL(CLEAR_MODE_SION(MX25_PAD_CSI_PIXCLK__GPIO_1_11), + PAD_CTL_PUS_100K_UP | PAD_CTL_HYS), };
+ static const iomux_v3_cfg_t acc_sensor_pads[] = { + CLEAR_MODE_SION(MX25_PAD_CSI_D7__GPIO_1_6), /* INT1 */ + CLEAR_MODE_SION(MX25_PAD_CSI_D4__GPIO_1_29), /* INT2 */ + }; + + ccm = (struct ccm_regs *)IMX_CCM_BASE; + weim = (struct weim_regs *)IMX_WEIM_CTRL_BASE; + + /* Setup of CAN2 signals */ + imx_iomux_v3_setup_multiple_pads(can_pads, ARRAY_SIZE(can_pads)); + + /* Setup of UART3 signals */ + imx_iomux_v3_setup_multiple_pads(uart3_pads, ARRAY_SIZE(uart3_pads)); + + /* Setup of LCD signals */ + imx_iomux_v3_setup_multiple_pads(lcd_pads, ARRAY_SIZE(lcd_pads)); + gpio_direction_output(IMX_GPIO_NR(1, 8), 0); + gpio_direction_output(IMX_GPIO_NR(4, 28), 0); + gpio_direction_output(IMX_GPIO_NR(1, 9), 1); + + /* --- Setup of touch display related pins --- */ + imx_iomux_v3_setup_multiple_pads(detect_touchscreen_pads, + ARRAY_SIZE(detect_touchscreen_pads)); + gpio_direction_input(IMX_GPIO_NR(1, 7)); + gpio_direction_input(IMX_GPIO_NR(1, 18)); + + udelay(5000); + + /* If GPIO1[7] and GPIO1[18] are high -> touch display */ + if ((gpio_get_value(IMX_GPIO_NR(1, 7))) && + (gpio_get_value(IMX_GPIO_NR(1, 18)))) { + have_touch_display = 1; + + /* Set reset to output and assert reset */ + imx_iomux_v3_setup_multiple_pads(touchscreen_pads, + ARRAY_SIZE(touchscreen_pads)); + gpio_direction_output(IMX_GPIO_NR(1, 7), 0); + gpio_direction_input(IMX_GPIO_NR(1, 10)); + gpio_direction_output(IMX_GPIO_NR(1, 15), 1); + gpio_direction_input(IMX_GPIO_NR(2, 22)); + + } else { + /* Without touch we disable the pullups */ + imx_iomux_v3_setup_pad(NEW_PAD_CTRL(CLEAR_MODE_SION(MX25_PAD_CSI_D8__GPIO_1_7), 0)); + imx_iomux_v3_setup_pad(NEW_PAD_CTRL(CLEAR_MODE_SION(MX25_PAD_CSPI1_SCLK__GPIO_1_18), 0)); + } + + /* --- Setup of touch keys related pins --- */ + imx_iomux_v3_setup_multiple_pads(touch_keys_pads, + ARRAY_SIZE(touch_keys_pads)); + gpio_direction_output(IMX_GPIO_NR(3, 2), 0); + gpio_direction_output(IMX_GPIO_NR(3, 3), 0); + gpio_direction_input(IMX_GPIO_NR(3, 4)); + + /* --- Setup of FPGA program pins --- */ + imx_iomux_v3_setup_multiple_pads(fpga_pads, ARRAY_SIZE(fpga_pads)); + + /* --- Setup of FPGA CS --- */ + writel(WEIM_CSCR_U_CNC(3) | WEIM_CSCR_U_WSC(20), &weim->cscr5u); + writel((WEIM_CSCR_L_OAE(6) | WEIM_CSCR_L_OEN(12) | WEIM_CSCR_L_EBWA(4) | + WEIM_CSCR_L_EBWN(10) | WEIM_CSCR_L_EBC | WEIM_CSCR_L_DSZ(3) | + WEIM_CSCR_L_CSN(8) | WEIM_CSCR_L_CS_EN), &weim->cscr5l); + writel((WEIM_CSCR_A_RWA(6) | WEIM_CSCR_A_RWN(12) | WEIM_CSCR_A_LBN(4)), + &weim->cscr5a); + + /* --- Clock output (33,25MHz) --- */ + writel((1<<CCM_CCTL_ARM_DIV_SHIFT) | + (1<<CCM_CCTL_LP_CTL_SHIFT) | + (1<<CCM_CCTL_MPLL_BYP_SHIFT), &ccm->mcr); + + /* --- Setup of SD card detection pin --- */ + /* GPIO1[14] -> SD_DET */ + imx_iomux_v3_setup_pad(CLEAR_MODE_SION(MX25_PAD_CSPI1_MOSI__GPIO_1_14)); + gpio_direction_input(IMX_GPIO_NR(1, 14)); + + /* --- Setup of INT pins of acceleration sensor --- */ + imx_iomux_v3_setup_multiple_pads(acc_sensor_pads, + ARRAY_SIZE(acc_sensor_pads)); + gpio_direction_input(IMX_GPIO_NR(1, 6)); + gpio_direction_input(IMX_GPIO_NR(1, 29)); + + /* GPIO3[19] -> Used as power fail interrupt */ + imx_iomux_v3_setup_pad(CLEAR_MODE_SION(MX25_PAD_POWER_FAIL__GPIO_3_19)); + gpio_direction_input(IMX_GPIO_NR(3, 19)); + + io_board_type = ZMX25_IO_BOARD_TYPE_NONE; +} + +static inline void hw_setup_cpu_g305(void) +{ + struct pwm_regs *pwm1; + struct pwm_regs *pwm2; + struct epit_regs *epit1; + static const iomux_v3_cfg_t led_pads[] = { - MX25_PAD_CSI_D9__GPIO_4_21, - MX25_PAD_CSI_D4__GPIO_1_29, + MX25_PAD_NFCLE__GPIO_3_29, /* LED CAN0 */ + MX25_PAD_NFALE__GPIO_3_28, /* LED CAN1 */ + MX25_PAD_NFWE_B__GPIO_3_26, /* LED STOP */ + MX25_PAD_NFWP_B__GPIO_3_30, /* LED STATUS */ };
- static const iomux_v3_cfg_t can_pads[] = { - NEW_PAD_CTRL(MX25_PAD_GPIO_A__CAN1_TX, NO_PAD_CTRL), - NEW_PAD_CTRL(MX25_PAD_GPIO_B__CAN1_RX, NO_PAD_CTRL), - NEW_PAD_CTRL(MX25_PAD_GPIO_C__CAN2_TX, NO_PAD_CTRL), - NEW_PAD_CTRL(MX25_PAD_GPIO_D__CAN2_RX, NO_PAD_CTRL), + static const iomux_v3_cfg_t digital_outputs_pads[] = { + MX25_PAD_KPP_ROW1__GPIO_2_30, /* OUT9 */ + MX25_PAD_KPP_ROW0__GPIO_2_29, /* OUT8 */ + CLEAR_MODE_SION(MX25_PAD_CSI_D2__GPIO_1_27), /* OUT7 */ + CLEAR_MODE_SION(MX25_PAD_CSI_D3__GPIO_1_28), /* OUT6 */ + CLEAR_MODE_SION(MX25_PAD_CSI_D4__GPIO_1_29), /* OUT5 */ + CLEAR_MODE_SION(MX25_PAD_CSI_D5__GPIO_1_30), /* OUT4 */ + CLEAR_MODE_SION(MX25_PAD_CSI_D6__GPIO_1_31), /* OUT3 */ + CLEAR_MODE_SION(MX25_PAD_CSI_D7__GPIO_1_6), /* OUT2 */ + CLEAR_MODE_SION(MX25_PAD_CSI_D8__GPIO_1_7), /* OUT1 */ + CLEAR_MODE_SION(MX25_PAD_CSI_D9__GPIO_4_21), /* OUT0 */ };
- static const iomux_v3_cfg_t i2c3_pads[] = { - MX25_PAD_CSPI1_SS1__I2C3_DAT, - MX25_PAD_GPIO_E__I2C3_CLK, + static const iomux_v3_cfg_t digital_inputs_pads[] = { + MX25_PAD_UART1_RTS__GPT3_CAPIN1,/* 0 */ + MX25_PAD_UART2_RTS__GPT1_CAPIN1,/* 1 */ + MX25_PAD_UART1_CTS__GPIO_4_25, /* 2 */ + MX25_PAD_UART1_TXD__GPIO_4_23, /* 3 */ + MX25_PAD_UART1_RXD__GPIO_4_22, /* 4 */ + CLEAR_MODE_SION(MX25_PAD_CSPI1_RDY__GPIO_2_22), /* 5 */ + CLEAR_MODE_SION(MX25_PAD_CSPI1_SCLK__GPIO_1_18),/* 6 */ + MX25_PAD_CSPI1_SS1__GPIO_1_17, /* 7 */ + CLEAR_MODE_SION(MX25_PAD_CSPI1_MISO__GPIO_1_15),/* 8 */ + CLEAR_MODE_SION(MX25_PAD_CSPI1_MOSI__GPIO_1_14),/* 9 */ + MX25_PAD_SD1_DATA2__GPIO_2_27, /* 10 */ + MX25_PAD_SD1_DATA1__GPIO_2_26, /* 11 */ + MX25_PAD_SD1_DATA0__GPIO_2_25, /* 14 */ + MX25_PAD_SD1_CMD__GPIO_2_23, /* 15 */ };
- icache_enable(); + pwm1 = (struct pwm_regs *)IMX_PWM1_BASE; + pwm2 = (struct pwm_regs *)IMX_PWM2_BASE; + epit1 = (struct epit_regs *)IMX_EPIT1_BASE;
- /* Setup of core voltage selection pin to run at 1.4V */ - imx_iomux_v3_setup_pad(MX25_PAD_EXT_ARMCLK__GPIO_3_15); /* VCORE */ - gpio_direction_output(IMX_GPIO_NR(3, 15), 1); + /* Setup of CAN1 and CAN2 signals */ + imx_iomux_v3_setup_multiple_pads(can_pads, ARRAY_SIZE(can_pads));
- /* Setup of SD card pins*/ - imx_iomux_v3_setup_multiple_pads(sdhc1_pads, ARRAY_SIZE(sdhc1_pads)); + /* EPIT1O -> Buzzer */ + imx_iomux_v3_setup_pad(MX25_PAD_VSTBY_ACK__EPIT1_EPITO); + + /* Switch the buzzer on */ + writel((EPIT_CR_EN | EPIT_CR_RLD | EPIT_CR_IOVW | EPIT_CR_OM(1) | + EPIT_CR_CLKSRC(1)), &epit1->cr); + writel(EPIT_LR(10000), &epit1->lr); + writel(EPIT_CMPR(5000), &epit1->cmpr); + + /* --- Display --- */ + /* LCD_PWRCTRL GPIO3[15] -> low power */ + imx_iomux_v3_setup_pad(CLEAR_MODE_SION(MX25_PAD_EXT_ARMCLK__GPIO_3_15)); + gpio_direction_output(IMX_GPIO_NR(3, 15), 0); + + /* GPIO3[16] */ + /* LCD_RESET GPIO3[0] -> reset active */ + imx_iomux_v3_setup_pad(MX25_PAD_KPP_ROW3__GPIO_3_0); + gpio_direction_input(IMX_GPIO_NR(3, 0)); + udelay(1000); + if (gpio_get_value(IMX_GPIO_NR(3, 0))) { + have_touch_display = 1; + + /* --- Touch --- */ + /* TOUCH_WAKE GPIO3[16] */ + imx_iomux_v3_setup_pad(CLEAR_MODE_SION(MX25_PAD_UPLL_BYPCLK__GPIO_3_16)); + gpio_direction_output(IMX_GPIO_NR(3, 16), 1); + + /* TOUCH_INT GPIO3[27] */ + imx_iomux_v3_setup_pad(MX25_PAD_NFRE_B__GPIO_3_27); + gpio_direction_input(IMX_GPIO_NR(3, 27)); + } + gpio_direction_output(IMX_GPIO_NR(3, 0), 0); + + /* LCD_BL_EN GPIO3[31] -> off */ + imx_iomux_v3_setup_pad(MX25_PAD_NFRB__GPIO_3_31); + gpio_direction_output(IMX_GPIO_NR(3, 31), 0); + + imx_iomux_v3_setup_pad(NEW_PAD_CTRL(MX25_PAD_GPIO_E__LD16, 0)); + imx_iomux_v3_setup_pad(NEW_PAD_CTRL(MX25_PAD_GPIO_F__LD17, 0)); + + /* --- Misc --- */ + imx_iomux_v3_setup_multiple_pads(led_pads, ARRAY_SIZE(led_pads)); + gpio_direction_output(IMX_GPIO_NR(3, 29), 0); + gpio_direction_output(IMX_GPIO_NR(3, 28), 0); + gpio_direction_output(IMX_GPIO_NR(3, 26), 0); + gpio_direction_output(IMX_GPIO_NR(3, 30), 0); + + /* GPIO3[19] -> POWER FAIL */ + imx_iomux_v3_setup_pad(CLEAR_MODE_SION(MX25_PAD_POWER_FAIL__GPIO_3_19)); + gpio_direction_input(IMX_GPIO_NR(3, 19)); + + /* --- Incremental encoder inputs --- */ + /* GPIO1[9] -> A */ + imx_iomux_v3_setup_pad(CLEAR_MODE_SION(MX25_PAD_CSI_VSYNC__GPIO_1_9)); + gpio_direction_input(IMX_GPIO_NR(1, 9)); + + /* GPIO1[10] -> B */ + imx_iomux_v3_setup_pad(CLEAR_MODE_SION(MX25_PAD_CSI_HSYNC__GPIO_1_10)); + gpio_direction_input(IMX_GPIO_NR(1, 10)); + + /* GPIO1[11] -> T */ + imx_iomux_v3_setup_pad(CLEAR_MODE_SION(MX25_PAD_CSI_PIXCLK__GPIO_1_11)); + gpio_direction_input(IMX_GPIO_NR(1, 11));
- /* Setup of digital output for USB power and OC */ - imx_iomux_v3_setup_pad(MX25_PAD_CSI_D3__GPIO_1_28); /* USB Power */ + /* --- Digital outputs --- */ + imx_iomux_v3_setup_multiple_pads(digital_outputs_pads, + ARRAY_SIZE(digital_outputs_pads)); + gpio_direction_output(IMX_GPIO_NR(2, 30), 0); + gpio_direction_output(IMX_GPIO_NR(2, 29), 0); + gpio_direction_output(IMX_GPIO_NR(1, 27), 1); gpio_direction_output(IMX_GPIO_NR(1, 28), 1); + gpio_direction_output(IMX_GPIO_NR(1, 29), 1); + gpio_direction_output(IMX_GPIO_NR(1, 30), 1); + gpio_direction_output(IMX_GPIO_NR(1, 31), 1); + gpio_direction_output(IMX_GPIO_NR(1, 6), 1); + gpio_direction_output(IMX_GPIO_NR(1, 7), 1); + gpio_direction_output(IMX_GPIO_NR(4, 21), 1);
- imx_iomux_v3_setup_pad(MX25_PAD_CSI_D2__GPIO_1_27); /* USB OC */ + /* Status input */ + imx_iomux_v3_setup_pad(MX25_PAD_SD1_DATA3__GPIO_2_28); + gpio_direction_input(IMX_GPIO_NR(2, 28)); + + /* --- PWM outputs --- */ + imx_iomux_v3_setup_pad(MX25_PAD_PWM__PWM); /* PWM0 */ + imx_iomux_v3_setup_pad(MX25_PAD_CSPI1_SS0__PWM2_PWMO); /* PWM1 */ + writel((PWM_CR_EN | PWM_CR_CLKSRC(1) | PWM_CR_POUTC(1)), &pwm1->cr); + writel((PWM_CR_EN | PWM_CR_CLKSRC(1) | PWM_CR_POUTC(1)), &pwm2->cr); + + /* --- Digital inputs --- */ + imx_iomux_v3_setup_multiple_pads(digital_inputs_pads, + ARRAY_SIZE(digital_inputs_pads)); + gpio_direction_input(IMX_GPIO_NR(4, 25)); + gpio_direction_input(IMX_GPIO_NR(4, 23)); + gpio_direction_input(IMX_GPIO_NR(4, 22)); + gpio_direction_input(IMX_GPIO_NR(2, 22)); + gpio_direction_input(IMX_GPIO_NR(1, 18)); + gpio_direction_input(IMX_GPIO_NR(1, 17)); + gpio_direction_input(IMX_GPIO_NR(1, 15)); + gpio_direction_input(IMX_GPIO_NR(1, 14)); + gpio_direction_input(IMX_GPIO_NR(2, 27)); + gpio_direction_input(IMX_GPIO_NR(2, 26)); + gpio_direction_input(IMX_GPIO_NR(2, 25)); + gpio_direction_input(IMX_GPIO_NR(2, 23)); + + /* --- Analog/digital input selection --- */ + imx_iomux_v3_setup_pad(NEW_PAD_CTRL(CLEAR_MODE_SION(MX25_PAD_KPP_COL0__GPIO_3_1), 0)); + gpio_direction_output(IMX_GPIO_NR(3, 1), 0); + imx_iomux_v3_setup_pad(NEW_PAD_CTRL(CLEAR_MODE_SION(MX25_PAD_KPP_COL1__GPIO_3_2), 0)); + gpio_direction_output(IMX_GPIO_NR(3, 2), 0); + + /* --- Analog type selection --- */ + imx_iomux_v3_setup_pad(NEW_PAD_CTRL(CLEAR_MODE_SION(MX25_PAD_KPP_COL2__GPIO_3_3), 0)); + gpio_direction_output(IMX_GPIO_NR(3, 3), 0); + imx_iomux_v3_setup_pad(NEW_PAD_CTRL(CLEAR_MODE_SION(MX25_PAD_KPP_COL3__GPIO_3_4), 0)); + gpio_direction_output(IMX_GPIO_NR(3, 4), 0); + + /* GPIO2[24] -> 5V EN */ + imx_iomux_v3_setup_pad(MX25_PAD_SD1_CLK__GPIO_2_24); + gpio_direction_output(IMX_GPIO_NR(2, 24), 0); + + io_board_type = ZMX25_IO_BOARD_TYPE_NONE; +} + +static inline void hw_setup_io_g283(void) +{ + static const iomux_v3_cfg_t dig_out_pads[] = { + /* Output 1 Ctrl */ + CLEAR_MODE_SION(MX25_PAD_CSI_D8__GPIO_1_7), + /* Output 2 Ctrl */ + CLEAR_MODE_SION(MX25_PAD_CSI_D7__GPIO_1_6), + /* Output 1 Stat */ + CLEAR_MODE_SION(NEW_PAD_CTRL(MX25_PAD_CSI_D6__GPIO_1_31, 0)), + /* Output 2 Stat */ + CLEAR_MODE_SION(NEW_PAD_CTRL(MX25_PAD_CSI_D5__GPIO_1_30, 0)), + }; + + static const iomux_v3_cfg_t led_pads[] = { + CLEAR_MODE_SION(MX25_PAD_CSI_D9__GPIO_4_21), + CLEAR_MODE_SION(MX25_PAD_CSI_D4__GPIO_1_29), + }; + + /* Setup of CAN1 and CAN2 signals */ + imx_iomux_v3_setup_multiple_pads(can_pads, ARRAY_SIZE(can_pads)); + + /* Setup of digital output for USB power */ + imx_iomux_v3_setup_pad(CLEAR_MODE_SION(MX25_PAD_CSI_D3__GPIO_1_28)); + gpio_direction_output(IMX_GPIO_NR(1, 28), 1); + + /* Setup of digital output for OC */ + imx_iomux_v3_setup_pad(CLEAR_MODE_SION(MX25_PAD_CSI_D2__GPIO_1_27)); gpio_direction_input(IMX_GPIO_NR(1, 18));
/* Setup of digital output control pins */ @@ -91,77 +736,346 @@ int board_init() /* Switch both LEDs off */ gpio_direction_output(IMX_GPIO_NR(4, 21), 0); gpio_direction_output(IMX_GPIO_NR(1, 29), 0); +}
- /* Setup of CAN1 and CAN2 signals */ - imx_iomux_v3_setup_multiple_pads(can_pads, ARRAY_SIZE(can_pads)); +static inline void hw_setup_io_g297(void) +{ + struct weim_regs *weim;
- /* Setup of I2C3 signals */ - imx_iomux_v3_setup_multiple_pads(i2c3_pads, ARRAY_SIZE(i2c3_pads)); + static const iomux_v3_cfg_t cspi3_pads[] = { + NEW_SEL_INPUT(CLEAR_MODE_SION(MX25_PAD_CSI_D2__CSPI3_MOSI), 1), + CLEAR_MODE_SION(MX25_PAD_CSI_D3__CSPI3_MISO), + NEW_SEL_INPUT(CLEAR_MODE_SION(MX25_PAD_CSI_D4__CSPI3_SCLK), 1), + NEW_PAD_CTRL(CLEAR_MODE_SION(MX25_PAD_CSI_D6__CSPI3_SS0), + PAD_CTL_PUS_22K_UP), + NEW_PAD_CTRL(CLEAR_MODE_SION(MX25_PAD_CSI_D7__CSPI3_SS1), + PAD_CTL_PUS_22K_UP), + NEW_PAD_CTRL(CLEAR_MODE_SION(MX25_PAD_CSI_D8__CSPI3_SS2), + PAD_CTL_PUS_22K_UP), + NEW_PAD_CTRL(CLEAR_MODE_SION(MX25_PAD_CSI_D9__CSPI3_SS3), + PAD_CTL_PUS_22K_UP), + };
- gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + weim = (struct weim_regs *)IMX_WEIM_CTRL_BASE;
- return 0; + /* --- Setup of IO CS --- */ + writel(WEIM_CSCR_U_CNC(3) | WEIM_CSCR_U_WSC(20), + &weim->cscr4u); + writel((WEIM_CSCR_L_OAE(6) | WEIM_CSCR_L_OEN(12) | WEIM_CSCR_L_EBWA(4) | + WEIM_CSCR_L_EBWN(10) | WEIM_CSCR_L_EBC | WEIM_CSCR_L_DSZ(3) | + WEIM_CSCR_L_CSN(8) | WEIM_CSCR_L_CS_EN), &weim->cscr4l); + writel((WEIM_CSCR_A_RWA(6) | WEIM_CSCR_A_RWN(12) | WEIM_CSCR_A_LBN(4)), + &weim->cscr4a); + + /* GPIO1[26] -> LCD_PWR -> off */ + imx_iomux_v3_setup_pad(CLEAR_MODE_SION(MX25_PAD_PWM__GPIO_1_26)); + gpio_direction_output(IMX_GPIO_NR(1, 26), 0); + + /* Setup of CSPI3 pins */ + imx_iomux_v3_setup_multiple_pads(cspi3_pads, ARRAY_SIZE(cspi3_pads)); + + imx_iomux_v3_setup_pad(CLEAR_MODE_SION(MX25_PAD_CSPI1_SS0__LD16)); + imx_iomux_v3_setup_pad(NEW_PAD_CTRL(MX25_PAD_GPIO_F__LD17, 0)); }
-int board_late_init(void) +#ifdef CONFIG_FEC_MXC +int board_eth_init(bd_t *bis) { - const char *e; + struct ccm_regs *ccm;
-#ifdef CONFIG_FEC_MXC -/* - * FIXME: need to revisit this - * The original code enabled PUE and 100-k pull-down without PKE, so the right - * value here is likely: - * 0 for no pull - * or: - * PAD_CTL_PUS_100K_DOWN for 100-k pull-down - */ -#define FEC_OUT_PAD_CTRL 0 + #define FEC_OUT_PAD_CTRL 0
static const iomux_v3_cfg_t fec_pads[] = { - MX25_PAD_FEC_TX_CLK__FEC_TX_CLK, - MX25_PAD_FEC_RX_DV__FEC_RX_DV, - MX25_PAD_FEC_RDATA0__FEC_RDATA0, - NEW_PAD_CTRL(MX25_PAD_FEC_TDATA0__FEC_TDATA0, FEC_OUT_PAD_CTRL), - NEW_PAD_CTRL(MX25_PAD_FEC_TX_EN__FEC_TX_EN, FEC_OUT_PAD_CTRL), - NEW_PAD_CTRL(MX25_PAD_FEC_MDC__FEC_MDC, FEC_OUT_PAD_CTRL), - MX25_PAD_FEC_MDIO__FEC_MDIO, - MX25_PAD_FEC_RDATA1__FEC_RDATA1, - NEW_PAD_CTRL(MX25_PAD_FEC_TDATA1__FEC_TDATA1, FEC_OUT_PAD_CTRL), + CLEAR_MODE_SION(MX25_PAD_FEC_TX_CLK__FEC_TX_CLK), + CLEAR_MODE_SION(MX25_PAD_FEC_RX_DV__FEC_RX_DV), + CLEAR_MODE_SION(MX25_PAD_FEC_RDATA0__FEC_RDATA0), + NEW_PAD_CTRL(CLEAR_MODE_SION(MX25_PAD_FEC_TDATA0__FEC_TDATA0), + FEC_OUT_PAD_CTRL), + NEW_PAD_CTRL(CLEAR_MODE_SION(MX25_PAD_FEC_TX_EN__FEC_TX_EN), + FEC_OUT_PAD_CTRL), + NEW_PAD_CTRL(CLEAR_MODE_SION(MX25_PAD_FEC_MDC__FEC_MDC), + FEC_OUT_PAD_CTRL), + CLEAR_MODE_SION(MX25_PAD_FEC_MDIO__FEC_MDIO), + CLEAR_MODE_SION(MX25_PAD_FEC_RDATA1__FEC_RDATA1), + CLEAR_MODE_SION(NEW_PAD_CTRL(MX25_PAD_FEC_TDATA1__FEC_TDATA1, + FEC_OUT_PAD_CTRL)),
- MX25_PAD_UPLL_BYPCLK__GPIO_3_16, /* LAN-RESET */ - MX25_PAD_UART2_CTS__FEC_RX_ER, /* FEC_RX_ERR */ + CLEAR_MODE_SION(MX25_PAD_UPLL_BYPCLK__GPIO_3_16),/* LAN-RESET */ + CLEAR_MODE_SION(MX25_PAD_UART2_CTS__FEC_RX_ER), /* FEC_RX_ERR */ };
+ /* + * Set up LAN-RESET and FEC_RX_ERR + * + * LAN-RESET: GPIO3[16] is ALT 5 mode of pin U20 + * FEC_RX_ERR: FEC_RX_ERR is ALT 2 mode of pin R2 + */ + ccm = (struct ccm_regs *)IMX_CCM_BASE; + + if (cpu_board_type == ZMX25_CPU_BOARD_TYPE_G305) { + /* --- Clock output (25MHz) --- */ + /* UPLL output to 250MHz */ + writel((CCM_UPCTL_PD(1) | CCM_UPCTL_MFD(11) | + CCM_UPCTL_MFI(10) | CCM_UPCTL_MFN(5)), &ccm->upctl); + + /* Reset UPLL */ + writel(readl(&ccm->cctl) | CCM_UPCTL_PD(1), &ccm->cctl); + + /* Wait until PLL locked */ + while ((readl(&ccm->upctl) & CCM_PLL_LOCK) == 0) + udelay(1000); + + /* Enable clock output for UPLL at DIV = 10 */ + writel((CCM_MCR_CLKO_EN | CCM_MCR_CLKO_DIV(9) | + CCM_MCR_CLKO_SEL(6)), &ccm->mcr); + } + imx_iomux_v3_setup_multiple_pads(fec_pads, ARRAY_SIZE(fec_pads));
+ if (cpu_board_type == ZMX25_CPU_BOARD_TYPE_G305) + imx_iomux_v3_setup_pad(MX25_PAD_KPP_ROW2__GPIO_2_31); + else + imx_iomux_v3_setup_pad(CLEAR_MODE_SION(MX25_PAD_UPLL_BYPCLK__GPIO_3_16)); + + imx_iomux_v3_setup_pad(CLEAR_MODE_SION(MX25_PAD_UART2_CTS__FEC_RX_ER)); + /* assert PHY reset (low) */ - gpio_direction_output(IMX_GPIO_NR(3, 16), 0); + if (cpu_board_type == ZMX25_CPU_BOARD_TYPE_G305) + gpio_direction_output(IMX_GPIO_NR(2, 31), 0); + else + gpio_direction_output(IMX_GPIO_NR(3, 16), 0);
udelay(5000);
/* deassert PHY reset */ - gpio_set_value(IMX_GPIO_NR(3, 16), 1); + if (cpu_board_type == ZMX25_CPU_BOARD_TYPE_G305) + gpio_set_value(IMX_GPIO_NR(2, 31), 1); + else + gpio_set_value(IMX_GPIO_NR(3, 16), 1);
udelay(5000); + + return cpu_eth_init(bis); +} #endif
- e = getenv("gs_base_board"); - if (e != NULL) { - if (strcmp(e, "G283") == 0) { - int key = gpio_get_value(IMX_GPIO_NR(2, 29)); +#ifdef CONFIG_VIDEO +int board_video_init(void) +{ + if (cpu_board_type == ZMX25_CPU_BOARD_TYPE_G305) { + /* LCD power on */ + gpio_direction_output(IMX_GPIO_NR(3, 31), 1); + udelay(1000); + + /* LCD reset off */ + gpio_direction_output(IMX_GPIO_NR(3, 0), 1); + udelay(100000); + + /* LCD pwr ctrl off */ + gpio_direction_output(IMX_GPIO_NR(3, 15), 1); + + return 1; + } else if ((cpu_board_type == ZMX25_CPU_BOARD_TYPE_G282A1) && + (io_board_type == ZMX25_IO_BOARD_TYPE_G297)) { + /* LCD power on */ + gpio_set_value(IMX_GPIO_NR(1, 26), 1); + + /* Set LCD PWR CTRL and release RESET */ + hw_g297_xfer_srio(0x0011); + + return 1; + } else { + /* LCD reset off */ + gpio_direction_output(IMX_GPIO_NR(1, 8), 1); + udelay(20000); + + /* LCD pwr ctrl off */ + gpio_direction_output(IMX_GPIO_NR(4, 28), 1); + + return 1; + } + + return 0; +} +#endif + + +int board_init(void) +{ + cpu_board_type = hw_setup_common(); + + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + return 0; +} + +int board_late_init(void) +{ + int have_fma1125; + int have_mpr121; + int slow_boot = 0; + const char *e; + struct epit_regs *epit1; + + epit1 = (struct epit_regs *)IMX_EPIT1_BASE; + have_fma1125 = 0; + have_mpr121 = 0; + + if (cpu_board_type == ZMX25_CPU_BOARD_TYPE_G292) { + int delay = 0;
- if (key) { - /* Switch on both LEDs to inidcate boot mode */ - gpio_set_value(IMX_GPIO_NR(1, 29), 0); - gpio_set_value(IMX_GPIO_NR(4, 21), 0); + /* Release touch display reset */ + if (have_touch_display) + gpio_set_value(IMX_GPIO_NR(1, 7), 1);
- setenv("preboot", "run gs_slow_boot"); - } else - setenv("preboot", "run gs_fast_boot"); + /* Release touch key reset */ + gpio_set_value(IMX_GPIO_NR(3, 3), 1); + udelay(10000); + + i2c_set_bus_num(2); + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); + udelay(10000); + + have_mpr121 = mpr121_init(mpr121_config, + ARRAY_SIZE(mpr121_config)); + if (have_mpr121) { + delay = 100000; + } else { + have_fma1125 = fma1125_init(FMA1125_SA, fma1125_config, + ARRAY_SIZE(fma1125_config)); + if (have_fma1125) + delay = 25000; + } + + if (have_touch_display && polytouch_init()) + delay = 300000; + + udelay(delay); + } + + /* Disable buzzer */ + if (cpu_board_type == ZMX25_CPU_BOARD_TYPE_G305) + writel(0, &epit1->cr); + + if (io_board_type == ZMX25_IO_BOARD_TYPE_G283) { + int key = gpio_get_value(IMX_GPIO_NR(2, 29)); + + if (key) { + /* Switch on both LEDs to indicate boot mode */ + gpio_set_value(IMX_GPIO_NR(1, 29), 0); + gpio_set_value(IMX_GPIO_NR(4, 21), 0); + + setenv("preboot", "run gs_slow_boot"); + } else { + setenv("preboot", "run gs_fast_boot"); + } + } else if (cpu_board_type == ZMX25_CPU_BOARD_TYPE_G292) { + int key = 0; + + if (have_mpr121) + key = mpr121_get_touch_bits(have_mpr121) & 0xFFC; + if (have_fma1125) + key = fma1125_get_touch_bits() & 0x3C; + if (have_touch_display) + if (!gpio_get_value(IMX_GPIO_NR(1, 10))) { + struct polytouch_resolution res; + struct polytouch_area area; + + polytouch_get_resolution(&res); + + /* check the lower left area */ + area.x1 = 0; + area.x2 = res.x / 4; + area.y1 = res.y - res.y / 4; + area.y2 = res.y; + + key = polytouch_is_touched(&area); + } + + if (key) { + /* Switch on key LEDs to indicate boot mode */ + if (have_mpr121) + mpr121_set_leds_on(); + if (have_fma1125) + fma1125_set_gpio_out(0x09); + slow_boot = 1; + setenv("stdout", "vga"); + } + } else if (io_board_type == ZMX25_IO_BOARD_TYPE_G297) { + u16 srdata; + + /* Key is connected to SRIO + * -> check for press + */ + srdata = hw_g297_xfer_srio(0x0011); + if (srdata & (1<<3)) { + slow_boot = 1; + setenv("stdout", "vga"); } + } else { + slow_boot = 1; }
+ if ((cpu_board_type == ZMX25_CPU_BOARD_TYPE_G305) && + (getenv("gs_print_infos"))) { + const char *fw = "UNKNOWN"; + const char *sn = ""; + char stdout_old[32]; + u8 buffer[256]; + char app[33]; + char bi1[33]; + char bi2[33]; + + e = getenv("gs_firmware_info"); + if (NULL != e) + fw = e; + + e = getenv("gs_dev_serialno"); + if (NULL != e) + sn = e; + + memset(app, 0, sizeof(app)); + memset(bi1, 0, sizeof(bi1)); + memset(bi2, 0, sizeof(bi2)); + + i2c_set_bus_num(1); + + /* Read device information from fixed eeprom locations */ + if ((i2c_read(0x50, 8192 - 256, 2, buffer, 256) == 0) || + (i2c_read(0x50, 8192 - 256, 2, buffer, 256) == 0)) { + memcpy(app, buffer + ZMX25_FIXED_EEPROM_ADDR_APP, 32); + memcpy(bi1, buffer + ZMX25_FIXED_EEPROM_ADDR_BI1, 32); + memcpy(bi2, buffer + ZMX25_FIXED_EEPROM_ADDR_BI2, 32); + } + + strcpy(stdout_old, getenv("stdout")); + setenv("stdout", "vga"); + + /* + * move the courser to the bottom according to + * the display resolution + */ + if (video_get_pixel_height() == 480) + printf("\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n"); + else + printf("\n\n\n\n\n\n\n\n\n"); + printf(" FW : %s\n", fw); + printf(" SN : %s\n", sn); + printf(" APP : %s\n", app); + printf(" BI1 : %s\n", bi1); + printf(" BI2 : %s\n", bi2); + + setenv("stdout", stdout_old); + } + + /* setup magic for boot mode used by the os */ + if (slow_boot) { + writel(ZMX25_BOOT_MODE_SLOW, (void *)IMX_RAM_BASE); + setenv("preboot", "run gs_slow_boot"); + } else { + writel(ZMX25_BOOT_MODE_FAST, (void *)IMX_RAM_BASE); + setenv("preboot", "run gs_fast_boot"); + } return 0; }
diff --git a/include/configs/zmx25.h b/include/configs/zmx25.h index 8ffe6f1..3c04df8 100644 --- a/include/configs/zmx25.h +++ b/include/configs/zmx25.h @@ -12,9 +12,10 @@
-#define CONFIG_ARM926EJS /* arm926ejs CPU core */ +#define CONFIG_ARM926EJS /* arm926ejs CPU core */ #define CONFIG_MX25 #define CONFIG_SYS_TEXT_BASE 0xA0000000 +#define CONFIG_USE_PRIVATE_LIBGCC
#define CONFIG_SYS_TIMER_RATE 32768 #define CONFIG_SYS_TIMER_COUNTER \ @@ -24,17 +25,19 @@ /* * Environment settings */ +#define CONFIG_SYS_GENERIC_BOARD #define CONFIG_EXTRA_ENV_SETTINGS \ "gs_fast_boot=setenv bootdelay 5\0" \ "gs_slow_boot=setenv bootdelay 10\0" \ "bootcmd=dcache off; mw.l 0x81000000 0 1024; usb start;" \ - "fatls usb 0; fatload usb 0 0x81000000 zmx25-init.bin;" \ - "bootm 0x81000000; bootelf 0x81000000\0" + "fatls usb 0; fatload usb 0 0x81000000 zmx25-init.bin;" \ + "bootm 0x81000000; bootelf 0x81000000\0"
#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG #define CONFIG_BOARD_LATE_INIT +#define CONFIG_SYS_GENERIC_BOARD
/* * Compressions @@ -51,6 +54,11 @@ #define CONFIG_MXC_GPIO
/* + * SPI + */ +#define CONFIG_MXC_SPI + +/* * Serial */ #define CONFIG_MXC_UART @@ -59,6 +67,18 @@ #define CONFIG_BAUDRATE 115200 /* Default baud rate */
/* + * I2C + */ +#define MXC_IPG_PERCLK MXC_I2C_CLK +#define CONFIG_HARD_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_BASE IMX_I2C3_BASE +#define CONFIG_SYS_I2C_SPEED 400000 +#define CONFIG_SYS_I2C_SLAVE 0xfe + +/* * Ethernet */ #define CONFIG_FEC_MXC @@ -66,7 +86,28 @@ #define CONFIG_MII
/* - * BOOTP options + * Video + */ +#define CONFIG_VIDEO +#define CONFIG_VIDEO_IMX25LCDC +#define CONFIG_SYS_WHITE_ON_BLACK +#define CONFIG_CFB_CONSOLE +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_SYS_CONSOLE_ENV_OVERWRITE +#define CONFIG_SYS_CONSOLE_BG_COL 0xff +#define CONFIG_SYS_CONSOLE_FG_COL 0x00 +#define CONFIG_VIDEO_LOGO +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_VIDEO_BMP_LOGO +#define CONFIG_VIDEO_BMP_GZIP +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (800*480 + 256*4 + 10*1024) +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define VIDEO_FB_16BPP_WORD_SWAP + +/* +* BOOTP options */ #define CONFIG_BOOTP_BOOTFILESIZE #define CONFIG_BOOTP_BOOTPATH @@ -88,6 +129,11 @@ #define CONFIG_CMD_ELF #define CONFIG_CMD_FAT #define CONFIG_CMD_USB +#define CONFIG_CMD_I2C +#define CONFIG_CMD_BMP +#define CONFIG_CMD_GPIO +#define CONFIG_CMD_SPI +#define CONFIG_CMD_BOOTZ
#define CONFIG_SYS_HUSH_PARSER
@@ -114,6 +160,7 @@
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM #define CONFIG_SYS_INIT_SP_ADDR 0x78020000 /* end of internal SRAM */ +#define CONFIG_SYS_MEM_TOP_HIDE (4 << 20)
/* * FLASH and environment organization @@ -147,7 +194,7 @@ #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING
-#define CONFIG_PREBOOT "" +#define CONFIG_PREBOOT ""
#define CONFIG_BOOTDELAY 5 #define CONFIG_AUTOBOOT_KEYED @@ -158,6 +205,13 @@ /* * Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (0x400000 - 0x8000) +#define CONFIG_SYS_MALLOC_LEN (0x400000 - 0x8000) + +/* + * Touch screen drivers + */ +#define CONFIG_FMA1125 +#define CONFIG_MPR121 +#define CONFIG_POLYTOUCH
#endif /* __CONFIG_H */
Signed-off-by: Thomas Diener dietho@gmx.de --- arch/arm/include/asm/arch-mx25/imx-regs.h | 271 ++++++++++++++++++++++++++++- 1 file changed, 264 insertions(+), 7 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx25/imx-regs.h b/arch/arm/include/asm/arch-mx25/imx-regs.h index a17f828..dc9a298 100644 --- a/arch/arm/include/asm/arch-mx25/imx-regs.h +++ b/arch/arm/include/asm/arch-mx25/imx-regs.h @@ -161,6 +161,126 @@ struct aips_regs { u32 mpr_0_7; u32 mpr_8_15; }; +/* LCD controller registers */ +struct lcdc_regs { + u32 lssar; /* Screen Start Address */ + u32 lsr; /* Size */ + u32 lvpwr; /* Virtual Page Width */ + u32 lcpr; /* Cursor Position */ + u32 lcwhb; /* Cursor Width Height and Blink */ + u32 lccmr; /* Color Cursor Mapping */ + u32 lpcr; /* Panel Configuration */ + u32 lhcr; /* Horizontal Configuration */ + u32 lvcr; /* Vertical Configuration */ + u32 lpor; /* Panning Offset */ + u32 lscr; /* Sharp Configuration */ + u32 lpccr; /* PWM Contrast Control */ + u32 ldcr; /* DMA Control */ + u32 lrmcr; /* Refresh Mode Control */ + u32 licr; /* Interrupt Configuration */ + u32 lier; /* Interrupt Enable */ + u32 lisr; /* Interrupt Status */ + u32 res0[3]; + u32 lgwsar; /* Graphic Window Start Address */ + u32 lgwsr; /* Graphic Window Size */ + u32 lgwvpwr; /* Graphic Window Virtual Page Width Regist */ + u32 lgwpor; /* Graphic Window Panning Offset */ + u32 lgwpr; /* Graphic Window Position */ + u32 lgwcr; /* Graphic Window Control */ + u32 lgwdcr; /* Graphic Window DMA Control */ + u32 res1[5]; + u32 lauscr; /* AUS Mode Control */ + u32 lausccr; /* AUS mode Cursor Control */ + u32 res2[31 + 64*7]; + u32 bglut; /* Background Lookup Table */ + u32 gwlut; /* Graphic Window Lookup Table */ +}; + +/* Wireless External Interface Module Registers */ +struct weim_regs { + u32 cscr0u; /* Chip Select 0 Upper Register */ + u32 cscr0l; /* Chip Select 0 Lower Register */ + u32 cscr0a; /* Chip Select 0 Addition Register */ + u32 pad0; + u32 cscr1u; /* Chip Select 1 Upper Register */ + u32 cscr1l; /* Chip Select 1 Lower Register */ + u32 cscr1a; /* Chip Select 1 Addition Register */ + u32 pad1; + u32 cscr2u; /* Chip Select 2 Upper Register */ + u32 cscr2l; /* Chip Select 2 Lower Register */ + u32 cscr2a; /* Chip Select 2 Addition Register */ + u32 pad2; + u32 cscr3u; /* Chip Select 3 Upper Register */ + u32 cscr3l; /* Chip Select 3 Lower Register */ + u32 cscr3a; /* Chip Select 3 Addition Register */ + u32 pad3; + u32 cscr4u; /* Chip Select 4 Upper Register */ + u32 cscr4l; /* Chip Select 4 Lower Register */ + u32 cscr4a; /* Chip Select 4 Addition Register */ + u32 pad4; + u32 cscr5u; /* Chip Select 5 Upper Register */ + u32 cscr5l; /* Chip Select 5 Lower Register */ + u32 cscr5a; /* Chip Select 5 Addition Register */ + u32 pad5; + u32 wcr; /* WEIM Configuration Register */ +}; + +/* Multi-Master Memory Interface */ +struct m3if_regs { + u32 ctl; /* Control Register */ + u32 wcfg0; /* Watermark Configuration Register 0 */ + u32 wcfg1; /* Watermark Configuration Register1 */ + u32 wcfg2; /* Watermark Configuration Register2 */ + u32 wcfg3; /* Watermark Configuration Register 3 */ + u32 wcfg4; /* Watermark Configuration Register 4 */ + u32 wcfg5; /* Watermark Configuration Register 5 */ + u32 wcfg6; /* Watermark Configuration Register 6 */ + u32 wcfg7; /* Watermark Configuration Register 7 */ + u32 wcsr; /* Watermark Control and Status Register */ + u32 scfg0; /* Snooping Configuration Register 0 */ + u32 scfg1; /* Snooping Configuration Register 1 */ + u32 scfg2; /* Snooping Configuration Register 2 */ + u32 ssr0; /* Snooping Status Register 0 */ + u32 ssr1; /* Snooping Status Register 1 */ + u32 res0; + u32 mlwe0; /* Master Lock WEIM CS0 Register */ + u32 mlwe1; /* Master Lock WEIM CS1 Register */ + u32 mlwe2; /* Master Lock WEIM CS2 Register */ + u32 mlwe3; /* Master Lock WEIM CS3 Register */ + u32 mlwe4; /* Master Lock WEIM CS4 Register */ + u32 mlwe5; /* Master Lock WEIM CS5 Register */ +}; + +/* Pulse width modulation */ +struct pwm_regs { + u32 cr; /* Control Register */ + u32 sr; /* Status Register */ + u32 ir; /* Interrupt Register */ + u32 sar; /* Sample Register */ + u32 pr; /* Period Register */ + u32 cnr; /* Counter Register */ +}; + +/* Enhanced Periodic Interrupt Timer */ +struct epit_regs { + u32 cr; /* Control register */ + u32 sr; /* Status register */ + u32 lr; /* Load register */ + u32 cmpr; /* Compare register */ + u32 cnr; /* Counter register */ +}; + +/* CSPI registers */ +struct cspi_regs { + u32 rxdata; + u32 txdata; + u32 ctrl; + u32 intr; + u32 dma; + u32 stat; + u32 period; + u32 test; +};
#endif
@@ -255,6 +375,7 @@ struct aips_regs { #define IMX_SDRAM_BANK0_BASE (0x80000000) #define IMX_SDRAM_BANK1_BASE (0x90000000)
+/* WEIM Memory Space */ #define IMX_WEIM_CS0 (0xA0000000) #define IMX_WEIM_CS1 (0xA8000000) #define IMX_WEIM_CS2 (0xB0000000) @@ -270,25 +391,69 @@ struct aips_regs { #define NFC_BASE_ADDR IMX_NFC_BASE
/* CCM bitfields */ +#define CCM_PLL_PD_SHIFT 26 +#define CCM_PLL_PD_MASK 0xf +#define CCM_PLL_PD(x) (((x) & CCM_PLL_PD_MASK) << CCM_PLL_PD_SHIFT) +#define CCM_PLL_MFD_SHIFT 16 +#define CCM_PLL_MFD_MASK 0x3ff +#define CCM_PLL_MFD(x) (((x) & CCM_PLL_MFD_MASK) << CCM_PLL_MFD_SHIFT) +#define CCM_PLL_LOCK (1 << 15) #define CCM_PLL_MFI_SHIFT 10 #define CCM_PLL_MFI_MASK 0xf +#define CCM_PLL_MFI(x) (((x) & CCM_PLL_MFI_MASK) << CCM_PLL_MFI_SHIFT) #define CCM_PLL_MFN_SHIFT 0 #define CCM_PLL_MFN_MASK 0x3ff -#define CCM_PLL_MFD_SHIFT 16 -#define CCM_PLL_MFD_MASK 0x3ff -#define CCM_PLL_PD_SHIFT 26 -#define CCM_PLL_PD_MASK 0xf +#define CCM_PLL_MFN(x) (((x) & CCM_PLL_MFN_MASK) << CCM_PLL_MFN_SHIFT) + +#define CCM_UPCTL_PD_SHIFT 26 +#define CCM_UPCTL_PD_MASK 0xf +#define CCM_UPCTL_PD(x) (((x) & CCM_PLL_PD_MASK) << CCM_PLL_PD_SHIFT) +#define CCM_UPCTL_MFD_SHIFT 16 +#define CCM_UPCTL_MFD_MASK 0x3ff +#define CCM_UPCTL_MFD(x) (((x) & CCM_PLL_MFD_MASK) << CCM_PLL_MFD_SHIFT) +#define CCM_UPCTL_LOCK (1 << 15) +#define CCM_UPCTL_MFI_SHIFT 10 +#define CCM_UPCTL_MFI_MASK 0xf +#define CCM_UPCTL_MFI(x) (((x) & CCM_PLL_MFI_MASK) << CCM_PLL_MFI_SHIFT) +#define CCM_UPCTL_MFN_SHIFT 0 +#define CCM_UPCTL_MFN_MASK 0x3ff +#define CCM_UPCTL_MFN(x) (((x) & CCM_PLL_MFN_MASK) << CCM_PLL_MFN_SHIFT) + #define CCM_CCTL_ARM_DIV_SHIFT 30 -#define CCM_CCTL_ARM_DIV_MASK 3 +#define CCM_CCTL_ARM_DIV_MASK 0x3 #define CCM_CCTL_AHB_DIV_SHIFT 28 -#define CCM_CCTL_AHB_DIV_MASK 3 -#define CCM_CCTL_ARM_SRC (1 << 14) +#define CCM_CCTL_AHB_DIV_MASK 0x3 +#define CCM_CCTL_AHB_DIV(x) (((x) & CCM_CCTL_AHB_DIV_MASK) << \ + CCM_CCTL_AHB_DIV_SHIFT) +#define CCM_CCTL_MPLL_RST_SHIFT 27 +#define CCM_CCTL_MPLL_RST_MASK 0x1 +#define CCM_CCTL_UPLL_RST_SHIFT 26 +#define CCM_CCTL_UPLL_RST_MASK 0x1 +#define CCM_CCTL_LP_CTL_SHIFT 24 +#define CCM_CCTL_LP_CTL_MASK 0x3 + +#define CCM_CCTL_MPLL_BYP_SHIFT 22 +#define CCM_CCTL_MPLL_BYP_MASK 0x1 +#define CCM_CCTL_USB_DIV_SHIFT 16 +#define CCM_CCTL_USB_DIV_MASK 0x3f +#define CCM_CCTL_USB_DIV(x) (((x) & CCM_CCTL_USB_DIV_MASK) << \ + CCM_CCTL_USB_DIV_SHIFT) +#define CCM_CCTL_ARM_SRC_SHIFT 14 +#define CCM_CCTL_ARM_SRC_MASK 1 +#define CCM_CCTL_ARM_SRC (1 << CCM_CCTL_ARM_SRC_SHIFT) #define CCM_CGR1_GPT1 (1 << 19) #define CCM_PERCLK_REG(clk) (clk / 4) #define CCM_PERCLK_SHIFT(clk) (8 * (clk % 4)) #define CCM_PERCLK_MASK 0x3f #define CCM_RCSR_NF_16BIT_SEL (1 << 14) #define CCM_RCSR_NF_PS(v) ((v >> 26) & 3) +#define CCM_CRDR_BT_UART_SRC_SHIFT 29 +#define CCM_CRDR_BT_UART_SRC_MASK 7 + +#define CCM_MCR_CLKO_SEL(x) (((x) & 0xf) << 20) +#define CCM_MCR_CLKO_DIV(x) (((x) & 0x3f) << 24) +#define CCM_MCR_CLKO_EN (1 << 30) +
/* ESDRAM Controller register bitfields */ #define ESDCTL_PRCT(x) (((x) & 0x3f) << 0) @@ -345,14 +510,106 @@ struct aips_regs { #define WSR_UNLOCK1 0x5555 #define WSR_UNLOCK2 0xAAAA
+/* MAX bits */ +#define MAX_MGPCR_AULB(x) (((x) & 0x7) << 0) + +/* M3IF bits */ +#define M3IF_CTL_MRRP(x) (((x) & 0xff) << 0) + +/* WEIM bits */ +/* The upper CS control register */ +#define WEIM_CSCR_U_SP (1 << 31) +#define WEIM_CSCR_U_WP (1 << 30) +#define WEIM_CSCR_U_BCD(x) (((x) & 0x3) << 28) +#define WEIM_CSCR_U_BCS(x) (((x) & 0xf) << 24) +#define WEIM_CSCR_U_PSZ(x) (((x) & 0x3) << 22) +#define WEIM_CSCR_U_PME (1 << 21) +#define WEIM_CSCR_U_SYNC (1 << 20) +#define WEIM_CSCR_U_DOL(x) (((x) & 0xf) << 16) +#define WEIM_CSCR_U_CNC(x) (((x) & 0x3) << 14) +#define WEIM_CSCR_U_WSC(x) (((x) & 0x3f) << 8) +#define WEIM_CSCR_U_EW (1 << 7) +#define WEIM_CSCR_U_WWS(x) (((x) & 0x7) << 4) +#define WEIM_CSCR_U_EDC(x) (((x) & 0xf) << 0) + +/* The lower CS control register */ +#define WEIM_CSCR_L_OAE(x) (((x) & 0xf) << 28) +#define WEIM_CSCR_L_OEN(x) (((x) & 0xf) << 24) +#define WEIM_CSCR_L_EBWA(x) (((x) & 0xf) << 20) +#define WEIM_CSCR_L_EBWN(x) (((x) & 0xf) << 16) +#define WEIM_CSCR_L_CSA(x) (((x) & 0xf) << 12) +#define WEIM_CSCR_L_EBC (1 << 11) +#define WEIM_CSCR_L_DSZ(x) (((x) & 0x7) << 8) +#define WEIM_CSCR_L_CSN(x) (((x) & 0xf) << 4) +#define WEIM_CSCR_L_PSR (1 << 3) +#define WEIM_CSCR_L_CRE (1 << 2) +#define WEIM_CSCR_L_WRAP (1 << 1) +#define WEIM_CSCR_L_CS_EN (1 << 0) + +/* The additional CS control register */ +#define WEIM_CSCR_A_EBRA(x) (((x) & 0xf) << 28) +#define WEIM_CSCR_A_EBRN(x) (((x) & 0xf) << 24) +#define WEIM_CSCR_A_RWA(x) (((x) & 0xf) << 20) +#define WEIM_CSCR_A_RWN(x) (((x) & 0xf) << 16) +#define WEIM_CSCR_A_MUM (1 << 15) +#define WEIM_CSCR_A_LAH(x) (((x) & 0x3) << 13) +#define WEIM_CSCR_A_LBN(x) (((x) & 0x7) << 10) +#define WEIM_CSCR_A_LBA(x) (((x) & 0x3) << 8) +#define WEIM_CSCR_A_DWW(x) (((x) & 0x3) << 6) +#define WEIM_CSCR_A_DCT(x) (((x) & 0x3) << 4) +#define WEIM_CSCR_A_WWU (1 << 3) +#define WEIM_CSCR_A_AGE (1 << 2) +#define WEIM_CSCR_A_CNC2 (1 << 1) +#define WEIM_CSCR_A_FCE (1 << 0) + /* Names used in GPIO driver */ #define GPIO1_BASE_ADDR IMX_GPIO1_BASE #define GPIO2_BASE_ADDR IMX_GPIO2_BASE #define GPIO3_BASE_ADDR IMX_GPIO3_BASE #define GPIO4_BASE_ADDR IMX_GPIO4_BASE
+/* + * CSPI register definitions + */ +#define MXC_CSPI +#define MXC_CSPICTRL_EN (1 << 0) +#define MXC_CSPICTRL_MODE (1 << 1) +#define MXC_CSPICTRL_XCH (1 << 2) +#define MXC_CSPICTRL_SMC (1 << 3) +#define MXC_CSPICTRL_POL (1 << 4) +#define MXC_CSPICTRL_PHA (1 << 5) +#define MXC_CSPICTRL_SSCTL (1 << 6) +#define MXC_CSPICTRL_SSPOL (1 << 7) +#define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 12) +#define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0xfff) << 20) +#define MXC_CSPICTRL_DATARATE(x) (((x) & 0x7) << 16) +#define MXC_CSPICTRL_TC (1 << 7) +#define MXC_CSPICTRL_RXOVF (1 << 6) +#define MXC_CSPICTRL_MAXBITS 0xfff +#define MXC_CSPIPERIOD_32KHZ (1 << 15) +#define MAX_SPI_BYTES 4 + +#define MXC_SPI_BASE_ADDRESSES \ + IMX_CSPI1_BASE, \ + IMX_CSPI2_BASE, \ + IMX_CSPI3_BASE + #define CHIP_REV_1_0 0x10 #define CHIP_REV_1_1 0x11 #define CHIP_REV_1_2 0x12
+/* EPIT bitfields */ +#define EPIT_CR_EN (1 << 0) +#define EPIT_CR_RLD (1 << 3) +#define EPIT_CR_IOVW (1 << 17) +#define EPIT_CR_OM(x) (((x) & 0x3) << 22) +#define EPIT_CR_CLKSRC(x) (((x) & 0x3) << 24) +#define EPIT_LR(x) (((x) & 0xFFFFFFFF) << 0) +#define EPIT_CMPR(x) (((x) & 0xFFFFFFFF) << 0) + +/* PWM bitfields */ +#define PWM_CR_EN (1 << 0) +#define PWM_CR_CLKSRC(x) (((x) & 0x3) << 16) +#define PWM_CR_POUTC(x) (((x) & 0x3) << 18) + #endif /* _IMX_REGS_H */
Signed-off-by: Thomas Diener dietho@gmx.de --- drivers/video/imx25lcdc.c | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/drivers/video/imx25lcdc.c b/drivers/video/imx25lcdc.c index 3b45472..94ef033 100644 --- a/drivers/video/imx25lcdc.c +++ b/drivers/video/imx25lcdc.c @@ -23,6 +23,19 @@ #define FB_SYNC_CLK_INV (1<<16) /* pixel clock inverted */
/* + * We do not enforce board code to provide empty/unused + * functions for this driver and define weak default + * functions here. + */ +unsigned int __board_video_init (void) +{ + return 0; +} + +unsigned int board_video_init (void) + __attribute__((weak, alias("__board_video_init"))); + +/* * Graphic Device */ static GraphicDevice imx25fb; @@ -117,6 +130,12 @@ void *video_hw_init(void) writel(readl(&ccm->cgr1) | (1<<29), &ccm->cgr1); }
+ /* + * Initialization of the access to the graphic chipset Retreive base + * address of the chipset (see board/RPXClassic/eccx.c) + */ + board_video_init(); + return pGD; }
Hello Thomas,
- We do not enforce board code to provide empty/unused
- functions for this driver and define weak default
- functions here.
Cosmetic remark. You can merge these with a single __weak.
Regards, Jeroen
Hi folks, do you have any comments or statements for this patches? Thanks and best regards, Thomas
Am 15.05.2014 um 16:34 schrieb dietho@gmx.de:
This patchset is the result of the "[PATCH 3/4] zmx25: Add extended support for the cpu and base boards" (http://patchwork.ozlabs.org/patch/341717/). I split the patch up as Stefano Babic recommended.
Thomas Diener (8): imx25: Add new hardware registers drivers: Add polytouch touch sensor controller mxc_i2c: Use the 3th i2c channel for imx25 input: Add support for FMA1125 touch controller input: Add support for MPR121 touch controller zmx25: Extended support for cpu and base boards imx25: Add new registers defines video: imx25lcdc: add board_video_init() call
arch/arm/include/asm/arch-mx25/imx-regs.h | 271 ++++++- arch/arm/include/asm/arch-mx25/iomux-mx25.h | 25 +- arch/arm/include/asm/imx-common/iomux-v3.h | 13 +- arch/arm/lib/asm-offsets.c | 9 + board/syteco/zmx25/lowlevel_init.S | 21 + board/syteco/zmx25/zmx25.c | 1052 +++++++++++++++++++++++++-- drivers/i2c/mxc_i2c.c | 2 +- drivers/input/Makefile | 3 + drivers/input/fma1125.c | 47 ++ drivers/input/mpr121.c | 67 ++ drivers/input/polytouch.c | 138 ++++ drivers/video/imx25lcdc.c | 19 + include/configs/zmx25.h | 66 +- include/fma1125.h | 140 ++++ include/mpr121.h | 158 ++++ include/polytouch.h | 35 + 16 files changed, 1976 insertions(+), 90 deletions(-) create mode 100644 drivers/input/fma1125.c create mode 100644 drivers/input/mpr121.c create mode 100644 drivers/input/polytouch.c create mode 100644 include/fma1125.h create mode 100644 include/mpr121.h create mode 100644 include/polytouch.h
Hi Thomas,
You already have received replies to 1, 3, 4 and 8 / 8 in May: http://lists.denx.de/pipermail/u-boot/2014-May/179759.html http://lists.denx.de/pipermail/u-boot/2014-May/179654.html http://lists.denx.de/pipermail/u-boot/2014-May/180530.html http://lists.denx.de/pipermail/u-boot/2014-May/179731.html
Best regards, Benoît
participants (6)
Benoît Thébaudeau
dietho@gmx.de
Heiko Schocher
Jeroen Hofstee
Michal Simek
Thomas Diener
