[U-Boot] [patch] Convert DM9000 driver for CONFIG_NET_MULTI
All drivers need to be converted to CONFIG_NET_MULTI. This patch converts the dm9000 driver.
Signed-off-by: Thomas Smits ts.smits@gmail.com Signed-off-by: Remy Bohmer linux@bohmer.net --- board/atmel/at91sam9261ek/at91sam9261ek.c | 7 ++++ board/freescale/m5253demo/m5253demo.c | 9 +++++ board/scb9328/scb9328.c | 8 +++++ board/trizepsiv/conxs.c | 8 +++++ drivers/net/dm9000x.c | 47 +++++++++++++++++++----------- include/configs/M5253DEMO.h | 1 include/configs/at91sam9261ek.h | 1 include/configs/scb9328.h | 1 include/configs/trizepsiv.h | 1 include/netdev.h | 1 10 files changed, 67 insertions(+), 17 deletions(-)
Index: u-boot-usb.tmp/board/atmel/at91sam9261ek/at91sam9261ek.c =================================================================== --- u-boot-usb.tmp.orig/board/atmel/at91sam9261ek/at91sam9261ek.c 2009-05-02 21:43:42.000000000 +0200 +++ u-boot-usb.tmp/board/atmel/at91sam9261ek/at91sam9261ek.c 2009-05-02 21:46:50.000000000 +0200 @@ -36,6 +36,7 @@ #include <atmel_lcdc.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_DRIVER_DM9000) #include <net.h> +#include <netdev.h> #endif
DECLARE_GLOBAL_DATA_PTR; @@ -227,6 +228,12 @@ int board_init(void) return 0; }
+#ifdef CONFIG_DRIVER_DM9000 + int board_eth_init(bd_t *bis) + { + return dm9000_initialize(bis); + } + #endif int dram_init(void) { gd->bd->bi_dram[0].start = PHYS_SDRAM; Index: u-boot-usb.tmp/board/freescale/m5253demo/m5253demo.c =================================================================== --- u-boot-usb.tmp.orig/board/freescale/m5253demo/m5253demo.c 2009-05-02 21:43:42.000000000 +0200 +++ u-boot-usb.tmp/board/freescale/m5253demo/m5253demo.c 2009-05-02 21:46:50.000000000 +0200 @@ -26,6 +26,7 @@
#include <common.h> #include <asm/immap.h> +#include <netdev.h>
int checkboard(void) { @@ -138,3 +139,11 @@ void ide_set_reset(int idereset) } } #endif /* CONFIG_CMD_IDE */ + + +#ifdef CONFIG_DRIVER_DM9000 +int board_eth_init(bd_t *bis) +{ + return dm9000_initialize(bis); +} +#endif Index: u-boot-usb.tmp/board/scb9328/scb9328.c =================================================================== --- u-boot-usb.tmp.orig/board/scb9328/scb9328.c 2009-05-02 21:43:42.000000000 +0200 +++ u-boot-usb.tmp/board/scb9328/scb9328.c 2009-05-02 21:46:50.000000000 +0200 @@ -19,6 +19,7 @@ */
#include <common.h> +#include <netdev.h>
@@ -70,3 +71,10 @@ void show_boot_progress (int status) { return; } + +#ifdef CONFIG_DRIVER_DM9000 +int board_eth_init(bd_t *bis) +{ + return dm9000_initialize(bis); +} +#endif Index: u-boot-usb.tmp/board/trizepsiv/conxs.c =================================================================== --- u-boot-usb.tmp.orig/board/trizepsiv/conxs.c 2009-05-02 21:43:42.000000000 +0200 +++ u-boot-usb.tmp/board/trizepsiv/conxs.c 2009-05-02 21:46:50.000000000 +0200 @@ -33,6 +33,7 @@
#include <common.h> #include <asm/arch/pxa-regs.h> +#include <netdev.h>
@@ -144,3 +145,10 @@ int dram_init (void)
return 0; } + +#ifdef CONFIG_DRIVER_DM9000 +int board_eth_init(bd_t *bis) +{ + return dm9000_initialize(bis); +} +#endif Index: u-boot-usb.tmp/drivers/net/dm9000x.c =================================================================== --- u-boot-usb.tmp.orig/drivers/net/dm9000x.c 2009-05-02 21:43:41.000000000 +0200 +++ u-boot-usb.tmp/drivers/net/dm9000x.c 2009-05-02 21:46:50.000000000 +0200 @@ -54,6 +54,9 @@ v1.2 03/18/2003 Weilun Huang <we - some minor code cleanups These changes are tested with DM9000{A,EP,E} together with a 200MHz Atmel AT91SAM92161 core + 06/10/2008 Thomas Smits ts.smits@gmail.com + - moved to funtion ptr based API +
TODO: external MII is not functional, only internal at the moment. */ @@ -102,14 +105,12 @@ typedef struct board_info { void (*outblk)(volatile void *data_ptr, int count); void (*inblk)(void *data_ptr, int count); void (*rx_status)(u16 *RxStatus, u16 *RxLen); + struct eth_device netdev; } board_info_t; static board_info_t dm9000_info;
+ /* function declaration ------------------------------------- */ -int eth_init(bd_t * bd); -int eth_send(volatile void *, int); -int eth_rx(void); -void eth_halt(void); static int dm9000_probe(void); static u16 phy_read(int); static void phy_write(int, u16); @@ -279,17 +280,16 @@ dm9000_reset(void) printf("ERROR: resetting DM9000 -> not responding\n"); }
-/* Initilize dm9000 board +/* Initialize dm9000 board */ -int -eth_init(bd_t * bd) +static int dm9000_init(struct eth_device *dev, bd_t *bd) { int i, oft, lnk; u8 io_mode; struct board_info *db = &dm9000_info; uchar enetaddr[6];
- DM9000_DBG("eth_init()\n"); + DM9000_DBG("%s\n", __func__);
/* RESET device */ dm9000_reset(); @@ -411,13 +411,13 @@ eth_init(bd_t * bd) Hardware start transmission. Send a packet to media from the upper layer. */ -int -eth_send(volatile void *packet, int length) +static int dm9000_send(struct eth_device *netdev, volatile void *packet, + int length) { int tmo; struct board_info *db = &dm9000_info;
- DM9000_DMP_PACKET("eth_send", packet, length); + DM9000_DMP_PACKET(__func__ , packet, length);
DM9000_iow(DM9000_ISR, IMR_PTM); /* Clear Tx bit in ISR */
@@ -453,10 +453,9 @@ eth_send(volatile void *packet, int leng Stop the interface. The interface is stopped when it is brought. */ -void -eth_halt(void) +static void dm9000_halt(struct eth_device *netdev) { - DM9000_DBG("eth_halt\n"); + DM9000_DBG("%s\n", __func__);
/* RESET devie */ phy_write(0, 0x8000); /* PHY RESET */ @@ -468,8 +467,7 @@ eth_halt(void) /* Received a packet and pass to upper layer */ -int -eth_rx(void) +static int dm9000_rx(struct eth_device *netdev) { u8 rxbyte, *rdptr = (u8 *) NetRxPackets[0]; u16 RxStatus, RxLen = 0; @@ -529,7 +527,7 @@ eth_rx(void) dm9000_reset(); } } else { - DM9000_DMP_PACKET("eth_rx", rdptr, RxLen); + DM9000_DMP_PACKET(__func__ , rdptr, RxLen);
DM9000_DBG("passing packet to upper layer\n"); NetReceive(NetRxPackets[0], RxLen); @@ -621,3 +619,18 @@ phy_write(int reg, u16 value) DM9000_iow(DM9000_EPCR, 0x0); /* Clear phyxcer write command */ DM9000_DBG("phy_write(reg:0x%x, value:0x%x)\n", reg, value); } + +int dm9000_initialize(bd_t *bis) +{ + struct eth_device *dev = &(dm9000_info.netdev); + + dev->init = dm9000_init; + dev->halt = dm9000_halt; + dev->send = dm9000_send; + dev->recv = dm9000_rx; + sprintf(dev->name, "dm9000"); + + eth_register(dev); + + return 0; +} Index: u-boot-usb.tmp/include/configs/M5253DEMO.h =================================================================== --- u-boot-usb.tmp.orig/include/configs/M5253DEMO.h 2009-05-02 21:43:41.000000000 +0200 +++ u-boot-usb.tmp/include/configs/M5253DEMO.h 2009-05-02 21:46:50.000000000 +0200 @@ -88,6 +88,7 @@ # define _IO_BASE 0 #endif
+#define CONFIG_NET_MULTI 1 #define CONFIG_DRIVER_DM9000 #ifdef CONFIG_DRIVER_DM9000 # define CONFIG_DM9000_BASE (CONFIG_SYS_CS1_BASE | 0x300) Index: u-boot-usb.tmp/include/configs/at91sam9261ek.h =================================================================== --- u-boot-usb.tmp.orig/include/configs/at91sam9261ek.h 2009-05-02 21:43:41.000000000 +0200 +++ u-boot-usb.tmp/include/configs/at91sam9261ek.h 2009-05-02 21:46:50.000000000 +0200 @@ -132,6 +132,7 @@ #define CONFIG_SYS_NO_FLASH 1
/* Ethernet */ +#define CONFIG_NET_MULTI 1 #define CONFIG_DRIVER_DM9000 1 #define CONFIG_DM9000_BASE 0x30000000 #define DM9000_IO CONFIG_DM9000_BASE Index: u-boot-usb.tmp/include/configs/scb9328.h =================================================================== --- u-boot-usb.tmp.orig/include/configs/scb9328.h 2009-05-02 21:43:41.000000000 +0200 +++ u-boot-usb.tmp/include/configs/scb9328.h 2009-05-02 21:46:50.000000000 +0200 @@ -255,6 +255,7 @@ #define CONFIG_SYS_CS5U_VAL 0x00008400 #define CONFIG_SYS_CS5L_VAL 0x00000D03
+#define CONFIG_NET_MULTI 1 #define CONFIG_DRIVER_DM9000 1 #define CONFIG_DM9000_BASE 0x16000000 #define DM9000_IO CONFIG_DM9000_BASE Index: u-boot-usb.tmp/include/configs/trizepsiv.h =================================================================== --- u-boot-usb.tmp.orig/include/configs/trizepsiv.h 2009-05-02 21:43:41.000000000 +0200 +++ u-boot-usb.tmp/include/configs/trizepsiv.h 2009-05-02 21:46:50.000000000 +0200 @@ -277,6 +277,7 @@ #define CONFIG_SYS_MCIO0_VAL 0x00008407 #define CONFIG_SYS_MCIO1_VAL 0x0000c108
+#define CONFIG_NET_MULTI 1 #define CONFIG_DRIVER_DM9000 1 #define CONFIG_DM9000_BASE 0x08000000 #define DM9000_IO CONFIG_DM9000_BASE Index: u-boot-usb.tmp/include/netdev.h =================================================================== --- u-boot-usb.tmp.orig/include/netdev.h 2009-05-02 21:43:42.000000000 +0200 +++ u-boot-usb.tmp/include/netdev.h 2009-05-02 21:46:50.000000000 +0200 @@ -73,6 +73,7 @@ int tsi108_eth_initialize(bd_t *bis); int uec_initialize(int index); int uli526x_initialize(bd_t *bis); int sh_eth_initialize(bd_t *bis); +int dm9000_initialize(bd_t *bis);
/* Boards with PCI network controllers can call this from their board_eth_init() * function to initialize whatever's on board.
Hi Remy,
Thanks so much for doing this! I'll look it over very soon and will provide feedback. I'm sure the driver is find, but I just want to be sure that all the board_eth_init() calls are correct.
regards, Ben
Dear Ben,
In message f8328f7c0905021953x494fff2aof44a9b3dc4194004@mail.gmail.com you wrote:
What's the state of this patch, then?
Ben Warren
Remy Bohmer
