Re: [U-Boot] [PATCH] TI DaVinci: Driver for the davinci SPI controller
On 04.01.2010 11:42, Sudhakar Rajashekhara wrote:
Hi Nick,
On Mon, Jan 04, 2010 at 15:17:51, Nick Thompson wrote:
On 23/12/09 07:44, Sudhakar Rajashekhara wrote:
This adds a driver for the SPI controller found on davinci based SoCs from Texas Instruments.
Signed-off-by: Sekhar Norinsekhar@ti.com Signed-off-by: Sudhakar Rajashekharasudhakar.raj@ti.com
drivers/spi/Makefile | 1 + drivers/spi/davinci_spi.c | 205 +++++++++++++++++++++++++++++++++++++++++++++ drivers/spi/davinci_spi.h | 84 ++++++++++++++++++ 3 files changed, 290 insertions(+), 0 deletions(-) create mode 100644 drivers/spi/davinci_spi.c create mode 100644 drivers/spi/davinci_spi.h
diff --git a/drivers/spi/davinci_spi.h b/drivers/spi/davinci_spi.h new file mode 100644 index 0000000..b3bf916 --- /dev/null +++ b/drivers/spi/davinci_spi.h @@ -0,0 +1,84 @@ +/*
- Register definitions for the DaVinci SPI Controller
+/* Register offsets */ +#define DAVINCI_SPI_GCR0 0x0000 +#define DAVINCI_SPI_GCR1 0x0004 +#define DAVINCI_SPI_INT0 0x0008 +#define DAVINCI_SPI_LVL 0x000c +#define DAVINCI_SPI_FLG 0x0010 +#define DAVINCI_SPI_PC0 0x0014 +#define DAVINCI_SPI_PC1 0x0018 +#define DAVINCI_SPI_PC2 0x001c +#define DAVINCI_SPI_PC3 0x0020 +#define DAVINCI_SPI_PC4 0x0024 +#define DAVINCI_SPI_PC5 0x0028 +#define DAVINCI_SPI_DAT0 0x0038 +#define DAVINCI_SPI_DAT1 0x003c +#define DAVINCI_SPI_BUF 0x0040 +#define DAVINCI_SPI_EMU 0x0044 +#define DAVINCI_SPI_DELAY 0x0048 +#define DAVINCI_SPI_DEF 0x004c +#define DAVINCI_SPI_FMT0 0x0050 +#define DAVINCI_SPI_FMT1 0x0054 +#define DAVINCI_SPI_FMT2 0x0058 +#define DAVINCI_SPI_FMT3 0x005c +#define DAVINCI_SPI_INTVEC0 0x0060 +#define DAVINCI_SPI_INTVEC1 0x0064
I think this ought to be a C structure, rather than register offsets?
I see that existing SPI drivers are not using structures for register defines. Off-late is there a shift in u-boot in favor of structures than macros for register definitions?
Yes.
E.g. what I did for OMAP3 SPI driver:
/* OMAP3 McSPI registers */ struct mcspi_channel { unsigned int chconf; /* 0x2C, 0x40, 0x54, 0x68 */ unsigned int chstat; /* 0x30, 0x44, 0x58, 0x6C */ unsigned int chctrl; /* 0x34, 0x48, 0x5C, 0x70 */ unsigned int tx; /* 0x38, 0x4C, 0x60, 0x74 */ unsigned int rx; /* 0x3C, 0x50, 0x64, 0x78 */ };
struct mcspi { unsigned char res1[0x10]; unsigned int sysconfig; /* 0x10 */ unsigned int sysstatus; /* 0x14 */ unsigned int irqstatus; /* 0x18 */ unsigned int irqenable; /* 0x1C */ unsigned int wakeupenable; /* 0x20 */ unsigned int syst; /* 0x24 */ unsigned int modulctrl; /* 0x28 */ struct mcspi_channel channel[4]; }
regs = (struct mcspi *)OMAP3_MCSPI1_BASE;
writel(value, regs->modulctrl);
Best regards
Dirk
i think you mean ®s->modulctrl -mike
Dirk Behme <dirk.behme <at> googlemail.com> writes:
Hi Dirk,
I could not find this code in any of the repositories. Could you share the u-boot omap3 spi driver?
Thanks Mansoor
Hi Mansoor,
On 05.03.2010 07:47, Mansoor wrote:
Dirk Behme<dirk.behme<at> googlemail.com> writes:
Hi Dirk,
I used the SPI driver for DaVinci (which this thread is about) as starting point for an U-Boot OMAP3 driver. The goal was to be able to access SPI ethernet on Zippy expansion board for Beagle. Unfortunately, I never found the time to finalize it.
Please find my latest patch from beginning of January 2010 in attachment.
I really hope it might help to finalize it!
Many thanks for asking and best regards
Dirk
P.S.: You might notice that the patch contains changes for the SPI ethernet, too. This should be moved to a separate patch.
Dirk Behme
Mansoor
Mike Frysinger
