[U-Boot-Users] [PATCH 06/25] include/configs: Use new CONFIG_CMD_* in various 5200 board config files.
Signed-off-by: Jon Loeliger jdl@freescale.com --- include/configs/TB5200.h | 70 +++++++++++++++++++----------------------- include/configs/TOP5200.h | 70 +++++++++++++++++------------------------- include/configs/Total5200.h | 55 ++++++++++++++------------------- include/configs/cpci5200.h | 53 +++++++++++++++------------------ include/configs/mecp5200.h | 39 +++++++++++------------- include/configs/pf5200.h | 36 +++++++++++----------- include/configs/r5200.h | 16 +++++++-- 7 files changed, 155 insertions(+), 184 deletions(-)
diff --git a/include/configs/TB5200.h b/include/configs/TB5200.h index 712668a..f64c522 100644 --- a/include/configs/TB5200.h +++ b/include/configs/TB5200.h @@ -42,11 +42,6 @@ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#define CFG_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) -# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - /* * Serial console configuration */ @@ -72,12 +67,6 @@ #define CFG_CONSOLE_IS_IN_ENV #endif
-#ifdef CONFIG_VIDEO -#define ADD_BMP_CMD CFG_CMD_BMP -#else -#define ADD_BMP_CMD 0 -#endif - /* Partitions */ #define CONFIG_MAC_PARTITION #define CONFIG_DOS_PARTITION @@ -85,7 +74,6 @@
/* USB */ #define CONFIG_USB_OHCI -#define ADD_USB_CMD CFG_CMD_USB | CFG_CMD_FAT #define CONFIG_USB_STORAGE
/* POST support */ @@ -101,34 +89,35 @@ #define CFG_CMD_POST_DIAG 0 #endif
-/* IDE */ -#define ADD_IDE_CMD (CFG_CMD_IDE | CFG_CMD_FAT | CFG_CMD_EXT2)
/* - * Supported commands + * Command line configuration. */ -#define CONFIG_COMMANDS (CONFIG_CMD_DFL | \ - ADD_BMP_CMD | \ - ADD_IDE_CMD | \ - ADD_PCI_CMD | \ - ADD_USB_CMD | \ - CFG_CMD_ASKENV | \ - CFG_CMD_DATE | \ - CFG_CMD_DHCP | \ - CFG_CMD_ECHO | \ - CFG_CMD_EEPROM | \ - CFG_CMD_I2C | \ - CFG_CMD_JFFS2 | \ - CFG_CMD_MII | \ - CFG_CMD_NFS | \ - CFG_CMD_PING | \ - CFG_CMD_POST_DIAG | \ - CFG_CMD_REGINFO | \ - CFG_CMD_SNTP | \ - CFG_CMD_BSP) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +#include <config_cmd_default.h> + +#ifdef CONFIG_VIDEO +#define CONFIG_CMD_BMP +#endif + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ECHO +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IDE +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_MII +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PING +#define CONFIG_CMD_POST_DIAG +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_SNTP +#define CONFIG_CMD_BSP +#define CONFIG_CMD_USB +
#define CONFIG_TIMESTAMP /* display image timestamps */
@@ -394,7 +383,7 @@ */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -403,6 +392,11 @@ #define CFG_MAXARGS 16 /* max number of command args */ #define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */
+#define CFG_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ +#if defined(CONFIG_CMD_KGDB) +# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ +#endif + /* Enable an alternate, more extensive memory test */ #define CFG_ALT_MEMTEST
diff --git a/include/configs/TOP5200.h b/include/configs/TOP5200.h index 1cc9ce9..73d25ea 100644 --- a/include/configs/TOP5200.h +++ b/include/configs/TOP5200.h @@ -50,11 +50,6 @@ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#define CFG_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) -# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - /* * Serial console configuration */ @@ -81,12 +76,6 @@ # define CONFIG_PCI_IO_PHYS CONFIG_PCI_IO_BUS # define CONFIG_PCI_IO_SIZE 0x01000000
-# define ADD_PCI_CMD CFG_CMD_PCI - -#else /* no Evaluation board */ - -# define ADD_PCI_CMD 0 /* no CFG_CMD_PCI */ - #endif
/* USB */ @@ -99,49 +88,40 @@ # else # define CONFIG_USB_CONFIG 0x00001000 # endif -# define ADD_USB_CMD CFG_CMD_USB | CFG_CMD_FAT # define CONFIG_DOS_PARTITION # define CONFIG_USB_STORAGE
-#else - -# define ADD_USB_CMD 0 - #endif
/* IDE */ #if defined (CONFIG_EVAL5200) || defined (CONFIG_LITE5200) - -# define ADD_IDE_CMD CFG_CMD_IDE | CFG_CMD_FAT # define CONFIG_DOS_PARTITION +#endif
-#else
-# define ADD_IDE_CMD 0 +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_BEDBUG +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_ELF +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IMMAP +#define CONFIG_CMD_MII +#define CONFIG_CMD_REGINFO
+#if defined (CONFIG_EVAL5200) || defined (CONFIG_LITE5200) +#define CONFIG_CMD_FAT +#define CONFIG_CMD_IDE +#define CONFIG_CMD_USB +#define CONFIG_CMD_PCI #endif
-/* - * Supported commands - */ -#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - ADD_PCI_CMD | \ - ADD_USB_CMD | \ - ADD_IDE_CMD | \ - CFG_CMD_ASKENV | \ - CFG_CMD_DATE | \ - CFG_CMD_DHCP | \ - CFG_CMD_I2C | \ - CFG_CMD_EEPROM | \ - CFG_CMD_REGINFO | \ - CFG_CMD_IMMAP | \ - CFG_CMD_ELF | \ - CFG_CMD_MII | \ - CFG_CMD_BEDBUG \ - ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h>
/* * MUST be low boot - HIGHBOOT is not supported anymore @@ -336,7 +316,7 @@ */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) # define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else # define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -352,6 +332,12 @@
#define CFG_HZ 1000 /* decrementer freq: 1 ms ticks */
+#define CFG_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ +#if defined(CONFIG_CMD_KGDB) +# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ +#endif + + #ifdef CONFIG_EVAL5200 /* M48T08 is available with the Evaluation board only */ #define CONFIG_RTC_MK48T59 1 /* use M48T08 on EVAL5200 */ #define RTC(reg) (0xf0010000+reg) diff --git a/include/configs/Total5200.h b/include/configs/Total5200.h index d8686dd..ba2daf7 100644 --- a/include/configs/Total5200.h +++ b/include/configs/Total5200.h @@ -48,11 +48,6 @@ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#define CFG_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) -# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - /* * Serial console configuration */ @@ -63,7 +58,6 @@ /* * Video console */ -#if 1 #define CONFIG_VIDEO #define CONFIG_VIDEO_SED13806 #define CONFIG_VIDEO_SED13806_16BPP @@ -76,10 +70,6 @@ #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN
-#define ADD_VIDEO_CMD CFG_CMD_BMP -#else -#define ADD_VIDEO_CMD 0 -#endif
#ifdef CONFIG_MPC5200 /* MGT5100 PCI is not supported yet. */ /* @@ -105,12 +95,9 @@ #define CFG_RX_ETH_BUFFER 8 /* use 8 rx buffer on eepro100 */ #define CONFIG_NS8382X 1
-#define ADD_PCI_CMD CFG_CMD_PCI - #else /* MGT5100 */
#define CONFIG_MII 1 -#define ADD_PCI_CMD 0 /* no CFG_CMD_PCI */
#endif
@@ -119,29 +106,27 @@ #define CONFIG_DOS_PARTITION
/* USB */ -#if 1 #define CONFIG_USB_OHCI -#define ADD_USB_CMD CFG_CMD_USB | CFG_CMD_FAT #define CONFIG_USB_STORAGE -#else -#define ADD_USB_CMD 0 -#endif +
/* - * Supported commands + * Command line configuration. */ -#define CONFIG_COMMANDS (CONFIG_CMD_DFL | \ - CFG_CMD_PING | \ - CFG_CMD_I2C | \ - CFG_CMD_EEPROM | \ - CFG_CMD_FAT | \ - CFG_CMD_IDE | \ - ADD_VIDEO_CMD | \ - ADD_PCI_CMD | \ - ADD_USB_CMD) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +#include <config_cmd_default.h> + +#if definded(CONFIG_MPC5200) + #define CONFIG_CMD_PCI +#endif + +#define CONFIG_CMD_BMP +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_FAT +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IDE +#define CONFIG_CMD_PING +#define CONFIG_CMD_USB +
#if (TEXT_BASE == 0xFE000000) /* Boot low */ # define CFG_LOWBOOT 1 @@ -303,7 +288,7 @@ */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -319,6 +304,12 @@
+#define CFG_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ +#if defined(CONFIG_CMD_KGDB) +# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ +#endif + + /* * Various low-level settings */ diff --git a/include/configs/cpci5200.h b/include/configs/cpci5200.h index f5efcd9..efb89bf 100644 --- a/include/configs/cpci5200.h +++ b/include/configs/cpci5200.h @@ -50,11 +50,6 @@ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#define CFG_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) -# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - /* * Serial console configuration */ @@ -92,12 +87,6 @@ #define CONFIG_NS8382X 1 #endif
-#define ADD_PCI_CMD CFG_CMD_PCI - -#else /* MPC5100 */ - -#define ADD_PCI_CMD 0 /* no CFG_CMD_PCI */ - #endif
/* Partitions */ @@ -107,28 +96,29 @@ /* USB */ #if 0 #define CONFIG_USB_OHCI -#define ADD_USB_CMD CFG_CMD_USB | CFG_CMD_FAT #define CONFIG_USB_STORAGE -#else -#define ADD_USB_CMD 0 #endif
+ /* - * Supported commands + * Command line configuration. */ -#define CONFIG_COMMANDS (CONFIG_CMD_DFL | \ - CFG_CMD_EEPROM | \ - CFG_CMD_FAT | \ - CFG_CMD_IDE | \ - CFG_CMD_I2C | \ - CFG_CMD_BSP | \ - CFG_CMD_ELF | \ - CFG_CMD_EXT2 | \ - CFG_CMD_DATE | \ - ADD_PCI_CMD ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +#include <config_cmd_default.h> + +#if defined(CONFIG_PCI) +#define CONFIG_CMD_PCI +#endif + +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_FAT +#define CONFIG_CMD_IDE +#define CONFIG_CMD_I2C +#define CONFIG_CMD_BSP +#define CONFIG_CMD_ELF +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_DATE + +
#if (TEXT_BASE == 0xFF000000) /* Boot low with 16 MB Flash */ # define CFG_LOWBOOT 1 @@ -277,7 +267,7 @@ */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -295,6 +285,11 @@
#define CFG_VXWORKS_MAC_PTR 0x00000000 /* Pass Ethernet MAC to VxWorks */
+#define CFG_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ +#if defined(CONFIG_CMD_KGDB) +# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ +#endif + /* * Various low-level settings */ diff --git a/include/configs/mecp5200.h b/include/configs/mecp5200.h index 0c10294..6f0d497 100644 --- a/include/configs/mecp5200.h +++ b/include/configs/mecp5200.h @@ -50,11 +50,6 @@ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#define CFG_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) -# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - /* * Serial console configuration */ @@ -88,26 +83,23 @@ /* USB */ #if 0 #define CONFIG_USB_OHCI -#define ADD_USB_CMD CFG_CMD_USB | CFG_CMD_FAT #define CONFIG_USB_STORAGE -#else -#define ADD_USB_CMD 0 #endif
+ /* - * Supported commands + * Command line configuration. */ -#define CONFIG_COMMANDS (CONFIG_CMD_DFL | \ - CFG_CMD_EEPROM | \ - CFG_CMD_FAT | \ - CFG_CMD_EXT2 | \ - CFG_CMD_I2C | \ - CFG_CMD_IDE | \ - CFG_CMD_BSP | \ - CFG_CMD_ELF) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +#include <config_cmd_default.h> + +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IDE +#define CONFIG_CMD_BSP +#define CONFIG_CMD_ELF +
#if (TEXT_BASE == 0xFF000000) /* Boot low with 16 MB Flash */ # define CFG_LOWBOOT 1 @@ -258,7 +250,7 @@ */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -276,6 +268,11 @@
+#define CFG_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ +#if defined(CONFIG_CMD_KGDB) +# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ +#endif + /* * Various low-level settings */ diff --git a/include/configs/pf5200.h b/include/configs/pf5200.h index 7151a9e..3e72c65 100644 --- a/include/configs/pf5200.h +++ b/include/configs/pf5200.h @@ -49,11 +49,6 @@ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#define CFG_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) -# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - /* * Serial console configuration */ @@ -112,20 +107,20 @@ #define ADD_USB_CMD 0 #endif
+ /* - * Supported commands + * Command line configuration. */ -#define CONFIG_COMMANDS (CONFIG_CMD_DFL | \ - CFG_CMD_EEPROM | \ - CFG_CMD_FAT | \ - CFG_CMD_I2C | \ - CFG_CMD_IDE | \ - CFG_CMD_BSP | \ - CFG_CMD_ELF | \ - ADD_PCI_CMD ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +#include <config_cmd_default.h> + +#define CONFIG_CMD_BSP +#define CONFIG_PCI_CMD +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_ELF +#define CONFIG_CMD_FAT +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IDE +
#if (TEXT_BASE == 0xFF000000) /* Boot low with 16 MB Flash */ # define CFG_LOWBOOT 1 @@ -263,7 +258,7 @@ */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -281,6 +276,11 @@
+#define CFG_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ +#if defined(CONFIG_CMD_KGDB) +# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ +#endif + /* * Various low-level settings */ diff --git a/include/configs/r5200.h b/include/configs/r5200.h index e1e406b..0ed20cd 100644 --- a/include/configs/r5200.h +++ b/include/configs/r5200.h @@ -66,10 +66,18 @@ #define CFG_ENV_IS_IN_FLASH 1 #endif
-#define CONFIG_COMMANDS ((CONFIG_CMD_DFL | CFG_CMD_PING | CFG_CMD_NET ) & ~(CFG_CMD_LOADS | CFG_CMD_LOADB))
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_PING +#define CONFIG_CMD_NET + +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_LOADB +
/* Note: We only copy one sectors worth of application code from location * 10200000 for speed purposes. Increase the size if necessary */ @@ -79,7 +87,7 @@ #define CFG_PROMPT "u-boot> " #define CFG_LONGHELP /* undef to save memory */
Jon Loeliger
