[PATCH v2] dts: Makefile: add support to build dedicated devicetree
The devicetree described by the DEVICE_TREE variable was not build. It was only use to test if it has been built then, happen the right devicetree to U-boot binary.
This patch add support to build the devicetree describe by the DEVICE_TREE variable. This avoid adding the devicetree declaration to the related Makefile.
The use case is to ease the management of external devicetree when U-boot is built by a build system.
Signed-off-by: Kory Maincent kory.maincent@bootlin.com ---
Change since v1: Use the DEVICE_TREE U-boot environment variable to select the devicetree build rather than appending the devicetree as an option of the make command.
dts/Makefile | 11 +++++++++-- 1 file changed, 9 insertions(+), 2 deletions(-)
diff --git a/dts/Makefile b/dts/Makefile index cb31113829..e3de63d847 100644 --- a/dts/Makefile +++ b/dts/Makefile @@ -10,9 +10,13 @@ ifeq ($(DEVICE_TREE),) DEVICE_TREE := unset endif
+BUILD_DTBS := arch-dtbs ifneq ($(EXT_DTB),) DTB := $(EXT_DTB) else +ifneq ($(DEVICE_TREE),unset) +BUILD_DTBS += target-dtb +endif DTB := arch/$(ARCH)/dts/$(DEVICE_TREE).dtb endif
@@ -30,7 +34,7 @@ endif
targets += dt.dtb
-$(DTB): arch-dtbs +$(DTB): $(BUILD_DTBS) $(Q)test -e $@ || ( \ echo >&2; \ echo >&2 "Device Tree Source ($@) is not correctly specified."; \ @@ -39,10 +43,13 @@ $(DTB): arch-dtbs echo >&2; \ /bin/false)
-PHONY += arch-dtbs +PHONY += arch-dtbs target-dtb arch-dtbs: $(Q)$(MAKE) $(build)=arch/$(ARCH)/dts dtbs
+target-dtb: + $(Q)$(MAKE) $(build)=arch/$(ARCH)/dts $(DTB) + ifeq ($(CONFIG_SPL_BUILD),y) obj-$(CONFIG_OF_EMBED) := dt-spl.dtb.o # support "out-of-tree" build for dtb-spl
Kory Maincent
