[U-Boot] [PATCH] ARM: dts: uniphier: renumber serial aliases for Gentil/Vodka boards
On these two boards, the serial0 is used for inter-chip connection, so cannot be used for login console. The serial2 is used instead for them, but it is tedious to use because upper level deployment projects must switch login console per board.
[ Linux commit: 2a4a2aadbaad9dffdb564a2895348f3d8e825416 ]
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Signed-off-by: Olof Johansson olof@lixom.net ---
arch/arm/dts/uniphier-proxstream2-gentil.dts | 8 ++++---- arch/arm/dts/uniphier-proxstream2-vodka.dts | 8 ++++---- 2 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/arch/arm/dts/uniphier-proxstream2-gentil.dts b/arch/arm/dts/uniphier-proxstream2-gentil.dts index 61f6164..1175703 100644 --- a/arch/arm/dts/uniphier-proxstream2-gentil.dts +++ b/arch/arm/dts/uniphier-proxstream2-gentil.dts @@ -19,13 +19,13 @@ };
chosen { - stdout-path = "serial2:115200n8"; + stdout-path = "serial0:115200n8"; };
aliases { - serial0 = &serial0; - serial1 = &serial1; - serial2 = &serial2; + serial0 = &serial2; + serial1 = &serial0; + serial2 = &serial1; i2c0 = &i2c0; i2c2 = &i2c2; i2c4 = &i2c4; diff --git a/arch/arm/dts/uniphier-proxstream2-vodka.dts b/arch/arm/dts/uniphier-proxstream2-vodka.dts index 3d5b300..928a092 100644 --- a/arch/arm/dts/uniphier-proxstream2-vodka.dts +++ b/arch/arm/dts/uniphier-proxstream2-vodka.dts @@ -19,13 +19,13 @@ };
aliases { - serial0 = &serial0; - serial1 = &serial1; - serial2 = &serial2; + serial0 = &serial2; + serial1 = &serial0; + serial2 = &serial1; i2c0 = &i2c0; i2c4 = &i2c4; i2c5 = &i2c5;
2016-07-06 19:24 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier/master.
Masahiro Yamada
