[U-Boot] [PATCH 1/2] usb: kbd: don't fail with iomux
stdin might not be set, which would cause iomux_doenv() to fail therefore causing probe_usb_keyboard() to fail. Furthermore if we do have iomux enabled, the sensible thing (in terms of user experience) would be to simply add ourselves to the list of stdin devices.
Signed-off-by: Rob Clark robdclark@gmail.com --- v2: address Bin Meng's comments common/usb_kbd.c | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/common/usb_kbd.c b/common/usb_kbd.c index d2d29cc98f..72cf78abd4 100644 --- a/common/usb_kbd.c +++ b/common/usb_kbd.c @@ -517,7 +517,21 @@ static int probe_usb_keyboard(struct usb_device *dev)
stdinname = getenv("stdin"); #if CONFIG_IS_ENABLED(CONSOLE_MUX) + char *devname = DEVNAME; + /* stdin might not be set yet.. either way, with console-mux the + * sensible thing to do is add ourselves to the list of stdio + * devices: + */ + if (stdinname) { + char *newstdin = malloc(strlen(stdinname) + strlen(","DEVNAME) + 1); + sprintf(newstdin, "%s,"DEVNAME, stdinname); + stdinname = newstdin; + } else { + stdinname = devname; + } error = iomux_doenv(stdin, stdinname); + if (stdinname != devname) + free(stdinname); if (error) return error; #else
Hi Rob,
Is this intended to fix a bug? What board do you see this on, and under what circumstances?
/* * stdin might not be
* devices:
if (stdinname) {
} else {
#else
2.13.0
On Thu, Aug 3, 2017 at 2:25 PM, Simon Glass sjg@chromium.org wrote:
Hi Rob,
yes, db410c w/ distro-bootcmd + usb keyboard.. stdin is not set.
- stdin might not be
hmm, somehow I screwed up and re-sent the wrong patch, rather than the one that *actually* addressed Bin's comments (this was one of them)
BR, -R
* devices:
if (stdinname) {
} else {
#else
2.13.0
Hi Rob,
Hi Rob,
OK I see. Can you please add that to the commit message also? It provides motivation for anyone looking at it later.
BR, -R
* devices:
if (stdinname) {
} else {
#else
2.13.0
Rob Clark
