[U-Boot] [PATCH] clk: Allow clock defaults to be set during re-reloc state for SPL only
In commit e5e06b65ad65 ("clk: Allow clock defaults to be set also during re-reloc state") the earlier guard against setting clock defaults in pre-reloc state was removed. While it is easy to filter 'assigned-clocks' properties for SPL using CONFIG_OF_SPL_REMOVE_PROPS, no such mechanism exists for the pre-reloc stage of the full U-Boot.
With the default defconfig for the RK3399-Q7 (which filter the 'assigned-clocks' property for the DTS used by SPL anyway), this caused a pause during startup of the full U-Boot stage that lasted for almost 10s (due to the CPU not having been clocked up yet).
This reintroduces the guard from commit f4fcba5c5baa ("clk: Allow clock defaults to be set also during re-reloc state") and extends it to only apply outside of a TPL/SPL build: i.e. clk_set_defaults will now run in pre-reloc state for SPL, but only after reloc for the full U-Boot.
References: commit f4fcba5c5baa ("clk: implement clk_set_defaults()") References: commit e5e06b65ad65 ("clk: Allow clock defaults to be set also during re-reloc state") Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
drivers/clk/clk-uclass.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/clk/clk-uclass.c b/drivers/clk/clk-uclass.c index 04b369a..6d7a514 100644 --- a/drivers/clk/clk-uclass.c +++ b/drivers/clk/clk-uclass.c @@ -243,6 +243,10 @@ int clk_set_defaults(struct udevice *dev) { int ret;
+ /* If this not in SPL and pre-reloc state, don't take any action. */ + if (!(IS_ENABLED(CONFIG_SPL_BUILD) || (gd->flags & GD_FLG_RELOC))) + return 0; + debug("%s(%s)\n", __func__, dev_read_name(dev));
ret = clk_set_default_parents(dev);
Philipp Tomsich
