[U-Boot] [PATCH] arm: Remove OMAP2420H4 and all omap24xx support
The omap2420H4 was the only mainline omap24xx board. Prior to being fixed by Jon Hunter in time for v2013.04 it had been functionally broken for a very long time. Remove this board as there's not been interest in it in U-Boot for quite a long time.
Signed-off-by: Tom Rini trini@ti.com --- MAINTAINERS | 4 - arch/arm/cpu/arm1136/start.S | 18 - arch/arm/include/asm/arch-omap24xx/bits.h | 48 -- arch/arm/include/asm/arch-omap24xx/clocks.h | 112 --- arch/arm/include/asm/arch-omap24xx/i2c.h | 68 -- arch/arm/include/asm/arch-omap24xx/mem.h | 156 ----- arch/arm/include/asm/arch-omap24xx/mux.h | 176 ----- arch/arm/include/asm/arch-omap24xx/omap2420.h | 236 ------- arch/arm/include/asm/arch-omap24xx/sys_info.h | 82 --- arch/arm/include/asm/arch-omap24xx/sys_proto.h | 54 -- arch/arm/lib/cache.c | 2 +- board/ti/omap2420h4/Makefile | 45 -- board/ti/omap2420h4/config.mk | 28 - board/ti/omap2420h4/lowlevel_init.S | 185 ----- board/ti/omap2420h4/mem.c | 362 ---------- board/ti/omap2420h4/omap2420h4.c | 867 ------------------------ board/ti/omap2420h4/sys_info.c | 387 ----------- boards.cfg | 2 - doc/README.scrapyard | 1 + drivers/serial/ns16550.c | 5 - drivers/serial/serial_ns16550.c | 5 - include/configs/omap2420h4.h | 264 -------- 22 files changed, 2 insertions(+), 3105 deletions(-) delete mode 100644 arch/arm/include/asm/arch-omap24xx/bits.h delete mode 100644 arch/arm/include/asm/arch-omap24xx/clocks.h delete mode 100644 arch/arm/include/asm/arch-omap24xx/i2c.h delete mode 100644 arch/arm/include/asm/arch-omap24xx/mem.h delete mode 100644 arch/arm/include/asm/arch-omap24xx/mux.h delete mode 100644 arch/arm/include/asm/arch-omap24xx/omap2420.h delete mode 100644 arch/arm/include/asm/arch-omap24xx/sys_info.h delete mode 100644 arch/arm/include/asm/arch-omap24xx/sys_proto.h delete mode 100644 board/ti/omap2420h4/Makefile delete mode 100644 board/ti/omap2420h4/config.mk delete mode 100644 board/ti/omap2420h4/lowlevel_init.S delete mode 100644 board/ti/omap2420h4/mem.c delete mode 100644 board/ti/omap2420h4/omap2420h4.c delete mode 100644 board/ti/omap2420h4/sys_info.c delete mode 100644 include/configs/omap2420h4.h
diff --git a/MAINTAINERS b/MAINTAINERS index 14075af..2044236 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1025,10 +1025,6 @@ Matthias Weisser weisserm@arcor.de jadecpu ARM926EJS (MB86R01 SoC) zmx25 ARM926EJS (imx25 SoC)
-Richard Woodruff r-woodruff2@ti.com - - omap2420h4 ARM1136EJS - Josh Wu josh.wu@atmel.com at91sam9n12ek ARM926EJS (AT91SAM9N12 SoC)
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index edf249d..a7e0c28 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -142,24 +142,6 @@ reset: orr r0,r0,#0xd3 msr cpsr,r0
-#ifdef CONFIG_OMAP2420H4 - /* Copy vectors to mask ROM indirect addr */ - adr r0, _start /* r0 <- current position of code */ - add r0, r0, #4 /* skip reset vector */ - mov r2, #64 /* r2 <- size to copy */ - add r2, r0, r2 /* r2 <- source end address */ - mov r1, #SRAM_OFFSET0 /* build vect addr */ - mov r3, #SRAM_OFFSET1 - add r1, r1, r3 - mov r3, #SRAM_OFFSET2 - add r1, r1, r3 -next: - ldmia r0!, {r3-r10} /* copy from source address [r0] */ - stmia r1!, {r3-r10} /* copy to target address [r1] */ - cmp r0, r2 /* until source end address [r2] */ - bne next /* loop until equal */ - bl cpy_clk_code /* put dpll adjust code behind vectors */ -#endif /* the mask ROM code should have PLL and others stable */ #ifndef CONFIG_SKIP_LOWLEVEL_INIT bl cpu_init_crit diff --git a/arch/arm/include/asm/arch-omap24xx/bits.h b/arch/arm/include/asm/arch-omap24xx/bits.h deleted file mode 100644 index 8522335..0000000 --- a/arch/arm/include/asm/arch-omap24xx/bits.h +++ /dev/null @@ -1,48 +0,0 @@ -/* bits.h - * Copyright (c) 2004 Texas Instruments - * - * This package is free software; you can redistribute it and/or - * modify it under the terms of the license found in the file - * named COPYING that should have accompanied this file. - * - * THIS PACKAGE IS PROVIDED ``AS IS'' AND WITHOUT ANY EXPRESS OR - * IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED - * WARRANTIES OF MERCHANTIBILITY AND FITNESS FOR A PARTICULAR PURPOSE. - */ -#ifndef __bits_h -#define __bits_h 1 - -#define BIT0 (1<<0) -#define BIT1 (1<<1) -#define BIT2 (1<<2) -#define BIT3 (1<<3) -#define BIT4 (1<<4) -#define BIT5 (1<<5) -#define BIT6 (1<<6) -#define BIT7 (1<<7) -#define BIT8 (1<<8) -#define BIT9 (1<<9) -#define BIT10 (1<<10) -#define BIT11 (1<<11) -#define BIT12 (1<<12) -#define BIT13 (1<<13) -#define BIT14 (1<<14) -#define BIT15 (1<<15) -#define BIT16 (1<<16) -#define BIT17 (1<<17) -#define BIT18 (1<<18) -#define BIT19 (1<<19) -#define BIT20 (1<<20) -#define BIT21 (1<<21) -#define BIT22 (1<<22) -#define BIT23 (1<<23) -#define BIT24 (1<<24) -#define BIT25 (1<<25) -#define BIT26 (1<<26) -#define BIT27 (1<<27) -#define BIT28 (1<<28) -#define BIT29 (1<<29) -#define BIT30 (1<<30) -#define BIT31 (1<<31) - -#endif diff --git a/arch/arm/include/asm/arch-omap24xx/clocks.h b/arch/arm/include/asm/arch-omap24xx/clocks.h deleted file mode 100644 index 2e92569..0000000 --- a/arch/arm/include/asm/arch-omap24xx/clocks.h +++ /dev/null @@ -1,112 +0,0 @@ -/* - * (C) Copyright 2004 - * Texas Instruments, <www.ti.com> - * Richard Woodruff r-woodruff2@ti.com - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR /PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ -#ifndef _OMAP24XX_CLOCKS_H_ -#define _OMAP24XX_CLOCKS_H_ - -#define COMMIT_DIVIDERS 0x1 - -#define MODE_BYPASS_FAST 0x2 -#define APLL_LOCK 0xc -#ifdef CONFIG_APTIX -#define DPLL_LOCK 0x1 /* stay in bypass mode */ -#else -#define DPLL_LOCK 0x3 /* DPLL lock */ -#endif - -/****************************************************************************; -; PRCM Scheme II -; -; Enable clocks and DPLL for: -; DPLL=300, DPLLout=600 M=1,N=50 CM_CLKSEL1_PLL[21:8] 12/2*50 -; Core=600 (core domain) DPLLx2 CM_CLKSEL2_PLL[1:0] -; MPUF=300 (mpu domain) 2 CM_CLKSEL_MPU[4:0] -; DSPF=200 (dsp domain) 3 CM_CLKSEL_DSP[4:0] -; DSPI=100 6 CM_CLKSEL_DSP[6:5] -; DSP_S bypass CM_CLKSEL_DSP[7] -; IVAF=200 (dsp domain) 3 CM_CLKSEL_DSP[12:8] -; IVAF=100 auto -; IVAI auto -; IVA_MPU auto -; IVA_S bypass CM_CLKSEL_DSP[13] -; GFXF=50 (gfx domain) 12 CM_CLKSEL_FGX[2:0] -; SSI_SSRF=200 3 CM_CLKSEL1_CORE[24:20] -; SSI_SSTF=100 auto -; L3=100Mhz (sdram) 6 CM_CLKSEL1_CORE[4:0] -; L4=100Mhz 6 -; C_L4_USB=50 12 CM_CLKSEL1_CORE[6:5] -***************************************************************************/ -#define II_DPLL_OUT_X2 0x2 /* x2 core out */ -#define II_MPU_DIV 0x2 /* mpu = core/2 */ -#define II_DSP_DIV 0x343 /* dsp & iva divider */ -#define II_GFX_DIV 0x2 -#define II_BUS_DIV 0x04601026 -#define II_DPLL_300 0x01832100 - -/****************************************************************************; -; PRCM Scheme III -; -; Enable clocks and DPLL for: -; DPLL=266, DPLLout=532 M=5+1,N=133 CM_CLKSEL1_PLL[21:8] 12/6*133=266 -; Core=532 (core domain) DPLLx2 CM_CLKSEL2_PLL[1:0] -; MPUF=266 (mpu domain) /2 CM_CLKSEL_MPU[4:0] -; DSPF=177.3 (dsp domain) /3 CM_CLKSEL_DSP[4:0] -; DSPI=88.67 /6 CM_CLKSEL_DSP[6:5] -; DSP_S ACTIVATED CM_CLKSEL_DSP[7] -; IVAF=88.67 (dsp domain) /3 CM_CLKSEL_DSP[12:8] -; IVAF=88.67 auto -; IVAI auto -; IVA_MPU auto -; IVA_S ACTIVATED CM_CLKSEL_DSP[13] -; GFXF=66.5 (gfx domain) /8 CM_CLKSEL_FGX[2:0]: -; SSI_SSRF=177.3 /3 CM_CLKSEL1_CORE[24:20] -; SSI_SSTF=88.67 auto -; L3=133Mhz (sdram) /4 CM_CLKSEL1_CORE[4:0] -; L4=66.5Mhz /8 -; C_L4_USB=33.25 /16 CM_CLKSEL1_CORE[6:5] -***************************************************************************/ -#define III_DPLL_OUT_X2 0x2 /* x2 core out */ -#define III_MPU_DIV 0x2 /* mpu = core/2 */ -#define III_DSP_DIV 0x23C3 /* dsp & iva divider sych enabled*/ -#define III_GFX_DIV 0x2 -#define III_BUS_DIV 0x08301044 -#define III_DPLL_266 0x01885500 - -/* set defaults for boot up */ -#ifdef PRCM_CONFIG_II -# define DPLL_OUT II_DPLL_OUT_X2 -# define MPU_DIV II_MPU_DIV -# define DSP_DIV II_DSP_DIV -# define GFX_DIV II_GFX_DIV -# define BUS_DIV II_BUS_DIV -# define DPLL_VAL II_DPLL_300 -#elif PRCM_CONFIG_III -# define DPLL_OUT III_DPLL_OUT_X2 -# define MPU_DIV III_MPU_DIV -# define DSP_DIV III_DSP_DIV -# define GFX_DIV III_GFX_DIV -# define BUS_DIV III_BUS_DIV -# define DPLL_VAL III_DPLL_266 -#endif - -/* lock delay time out */ -#define LDELAY 12000000 - -#endif diff --git a/arch/arm/include/asm/arch-omap24xx/i2c.h b/arch/arm/include/asm/arch-omap24xx/i2c.h deleted file mode 100644 index 6f64519..0000000 --- a/arch/arm/include/asm/arch-omap24xx/i2c.h +++ /dev/null @@ -1,68 +0,0 @@ -/* - * (C) Copyright 2004 - * Texas Instruments, <www.ti.com> - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ -#ifndef _OMAP24XX_I2C_H_ -#define _OMAP24XX_I2C_H_ - -#define I2C_BASE1 0x48070000 -#define I2C_BASE2 0x48072000 /* nothing hooked up on h4 */ - -#define I2C_DEFAULT_BASE I2C_BASE1 - -struct i2c { - unsigned short rev; /* 0x00 */ - unsigned short res1; - unsigned short ie; /* 0x04 */ - unsigned short res2; - unsigned short stat; /* 0x08 */ - unsigned short res3; - unsigned short iv; /* 0x0C */ - unsigned short res4; - unsigned short syss; /* 0x10 */ - unsigned short res4p1; - unsigned short buf; /* 0x14 */ - unsigned short res5; - unsigned short cnt; /* 0x18 */ - unsigned short res6; - unsigned short data; /* 0x1C */ - unsigned short res7; - unsigned short sysc; /* 0x20 */ - unsigned short res8; - unsigned short con; /* 0x24 */ - unsigned short res9; - unsigned short oa; /* 0x28 */ - unsigned short res10; - unsigned short sa; /* 0x2C */ - unsigned short res11; - unsigned short psc; /* 0x30 */ - unsigned short res12; - unsigned short scll; /* 0x34 */ - unsigned short res13; - unsigned short sclh; /* 0x38 */ - unsigned short res14; - unsigned short systest; /* 0x3c */ - unsigned short res15; -}; - -#define I2C_BUS_MAX 2 - -#endif diff --git a/arch/arm/include/asm/arch-omap24xx/mem.h b/arch/arm/include/asm/arch-omap24xx/mem.h deleted file mode 100644 index 42e8ab2..0000000 --- a/arch/arm/include/asm/arch-omap24xx/mem.h +++ /dev/null @@ -1,156 +0,0 @@ -/* - * (C) Copyright 2004 - * Texas Instruments, <www.ti.com> - * Richard Woodruff r-woodruff2@ti.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef _OMAP24XX_MEM_H_ -#define _OMAP24XX_MEM_H_ - -#define SDRC_CS0_OSET 0x0 -#define SDRC_CS1_OSET 0x30 /* mirror CS1 regs appear offset 0x30 from CS0 */ - -#ifndef __ASSEMBLY__ -/* struct's for holding data tables for current boards, they are getting used - early in init when NO global access are there */ -struct sdrc_data_s { - u32 sdrc_sharing; - u32 sdrc_mdcfg_0_ddr; - u32 sdrc_mdcfg_0_sdr; - u32 sdrc_actim_ctrla_0; - u32 sdrc_actim_ctrlb_0; - u32 sdrc_rfr_ctrl; - u32 sdrc_mr_0_ddr; - u32 sdrc_mr_0_sdr; - u32 sdrc_dllab_ctrl; -} /*__attribute__ ((packed))*/; -typedef struct sdrc_data_s sdrc_data_t; - -typedef enum { - STACKED = 0, - IP_DDR = 1, - COMBO_DDR = 2, - IP_SDR = 3, -} mem_t; - -#endif - -/* Slower full frequency range default timings for x32 operation*/ -#define H4_2420_SDRC_SHARING 0x00000100 -#define H4_2420_SDRC_MDCFG_0_SDR 0x00D04010 /* discrete sdr module */ -#define H4_2420_SDRC_MR_0_SDR 0x00000031 -#define H4_2420_SDRC_MDCFG_0_DDR 0x01702011 /* descrite ddr module */ -#define H4_2420_COMBO_MDCFG_0_DDR 0x00801011 /* combo module */ -#define H4_2420_SDRC_MR_0_DDR 0x00000032 - -#define H4_2422_SDRC_SHARING 0x00004b00 -#define H4_2422_SDRC_MDCFG_0_DDR 0x00801011 /* stacked ddr on 2422 */ -#define H4_2422_SDRC_MR_0_DDR 0x00000032 - -/* ES1 work around timings */ -#define H4_242x_SDRC_ACTIM_CTRLA_0_ES1 0x9bead909 /* 165Mhz for use with 100/133 */ -#define H4_242x_SDRC_ACTIM_CTRLB_0_ES1 0x00000020 -#define H4_242x_SDRC_RFR_CTRL_ES1 0x00002401 /* use over refresh for ES1 */ - -/* optimized timings good for current shipping parts */ -#define H4_242X_SDRC_ACTIM_CTRLA_0_100MHz 0x5A59B485 -#define H4_242X_SDRC_ACTIM_CTRLB_0_100MHz 0x0000000e -#define H4_242X_SDRC_ACTIM_CTRLA_0_133MHz 0x8BA6E6C8 /* temp warn 0 settings */ -#define H4_242X_SDRC_ACTIM_CTRLB_0_133MHz 0x00000010 /* temp warn 0 settings */ -#define H4_242X_SDRC_RFR_CTRL_100MHz 0x0002da01 -#define H4_242X_SDRC_RFR_CTRL_133MHz 0x0003de01 -#define H4_242x_SDRC_DLLAB_CTRL_100MHz 0x0000980E /* 72deg, allow DPLLout*1 to work (combo)*/ -#define H4_242x_SDRC_DLLAB_CTRL_133MHz 0x0000690E /* 72deg, for ES2 */ - -#ifdef PRCM_CONFIG_II -# define H4_2420_SDRC_ACTIM_CTRLA_0 H4_242X_SDRC_ACTIM_CTRLA_0_100MHz -# define H4_2420_SDRC_ACTIM_CTRLB_0 H4_242X_SDRC_ACTIM_CTRLB_0_100MHz -# define H4_2420_SDRC_RFR_CTRL H4_242X_SDRC_RFR_CTRL_100MHz -# define H4_2420_SDRC_DLLAB_CTRL H4_242x_SDRC_DLLAB_CTRL_100MHz -# define H4_2422_SDRC_ACTIM_CTRLA_0 H4_242X_SDRC_ACTIM_CTRLA_0_100MHz -# define H4_2422_SDRC_ACTIM_CTRLB_0 H4_242X_SDRC_ACTIM_CTRLB_0_100MHz -# define H4_2422_SDRC_RFR_CTRL H4_242X_SDRC_RFR_CTRL_100MHz -# define H4_2422_SDRC_DLLAB_CTRL H4_242x_SDRC_DLLAB_CTRL_100MHz -#elif PRCM_CONFIG_III -# define H4_2420_SDRC_ACTIM_CTRLA_0 H4_242X_SDRC_ACTIM_CTRLA_0_133MHz -# define H4_2420_SDRC_ACTIM_CTRLB_0 H4_242X_SDRC_ACTIM_CTRLB_0_133MHz -# define H4_2420_SDRC_RFR_CTRL H4_242X_SDRC_RFR_CTRL_133MHz -# define H4_2420_SDRC_DLLAB_CTRL H4_242x_SDRC_DLLAB_CTRL_133MHz -# define H4_2422_SDRC_ACTIM_CTRLA_0 H4_242X_SDRC_ACTIM_CTRLA_0_100MHz -# define H4_2422_SDRC_ACTIM_CTRLB_0 H4_242X_SDRC_ACTIM_CTRLB_0_100MHz -# define H4_2422_SDRC_RFR_CTRL H4_242X_SDRC_RFR_CTRL_100MHz -# define H4_2422_SDRC_DLLAB_CTRL H4_242x_SDRC_DLLAB_CTRL_100MHz -#endif - - -/* GPMC settings */ -#ifdef PRCM_CONFIG_II /* L3 at 100MHz */ -# ifdef CONFIG_SYS_NAND_BOOT -# define H4_24XX_GPMC_CONFIG1_0 0x0 -# define H4_24XX_GPMC_CONFIG2_0 0x00141400 -# define H4_24XX_GPMC_CONFIG3_0 0x00141400 -# define H4_24XX_GPMC_CONFIG4_0 0x0F010F01 -# define H4_24XX_GPMC_CONFIG5_0 0x010C1414 -# define H4_24XX_GPMC_CONFIG6_0 0x00000A80 -# else /* else NOR */ -# define H4_24XX_GPMC_CONFIG1_0 0x3 -# define H4_24XX_GPMC_CONFIG2_0 0x000f0f01 -# define H4_24XX_GPMC_CONFIG3_0 0x00050502 -# define H4_24XX_GPMC_CONFIG4_0 0x0C060C06 -# define H4_24XX_GPMC_CONFIG5_0 0x01131F1F -# endif /* endif CONFIG_SYS_NAND_BOOT */ -# define H4_24XX_GPMC_CONFIG7_0 (0x00000C40|(H4_CS0_BASE >> 24)) -# define H4_24XX_GPMC_CONFIG1_1 0x00011000 -# define H4_24XX_GPMC_CONFIG2_1 0x001F1F00 -# define H4_24XX_GPMC_CONFIG3_1 0x00080802 -# define H4_24XX_GPMC_CONFIG4_1 0x1C091C09 -# define H4_24XX_GPMC_CONFIG5_1 0x031A1F1F -# define H4_24XX_GPMC_CONFIG6_1 0x000003C2 -# define H4_24XX_GPMC_CONFIG7_1 (0x00000F40|(H4_CS1_BASE >> 24)) -#endif /* endif PRCM_CONFIG_II */ - -#ifdef PRCM_CONFIG_III /* L3 at 133MHz */ -# ifdef CONFIG_SYS_NAND_BOOT -# define H4_24XX_GPMC_CONFIG1_0 0x0 -# define H4_24XX_GPMC_CONFIG2_0 0x00141400 -# define H4_24XX_GPMC_CONFIG3_0 0x00141400 -# define H4_24XX_GPMC_CONFIG4_0 0x0F010F01 -# define H4_24XX_GPMC_CONFIG5_0 0x010C1414 -# define H4_24XX_GPMC_CONFIG6_0 0x00000A80 -# else /* NOR boot */ -# define H4_24XX_GPMC_CONFIG1_0 0x3 -# define H4_24XX_GPMC_CONFIG2_0 0x00151501 -# define H4_24XX_GPMC_CONFIG3_0 0x00060602 -# define H4_24XX_GPMC_CONFIG4_0 0x10081008 -# define H4_24XX_GPMC_CONFIG5_0 0x01131F1F -# define H4_24XX_GPMC_CONFIG6_0 0x000004c4 -# endif /* endif CONFIG_SYS_NAND_BOOT */ -# define H4_24XX_GPMC_CONFIG7_0 (0x00000C40|(H4_CS0_BASE >> 24)) -# define H4_24XX_GPMC_CONFIG1_1 0x00011000 -# define H4_24XX_GPMC_CONFIG2_1 0x001f1f01 -# define H4_24XX_GPMC_CONFIG3_1 0x00080803 -# define H4_24XX_GPMC_CONFIG4_1 0x1C091C09 -# define H4_24XX_GPMC_CONFIG5_1 0x041f1F1F -# define H4_24XX_GPMC_CONFIG6_1 0x000004C4 -# define H4_24XX_GPMC_CONFIG7_1 (0x00000F40|(H4_CS1_BASE >> 24)) -#endif /* endif CONFIG_SYS_PRCM_III */ - -#endif /* endif _OMAP24XX_MEM_H_ */ diff --git a/arch/arm/include/asm/arch-omap24xx/mux.h b/arch/arm/include/asm/arch-omap24xx/mux.h deleted file mode 100644 index 4fdb9c6..0000000 --- a/arch/arm/include/asm/arch-omap24xx/mux.h +++ /dev/null @@ -1,176 +0,0 @@ -/* - * (C) Copyright 2004 - * Texas Instruments, <www.ti.com> - * Richard Woodruff r-woodruff2@ti.com - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ -#ifndef _OMAP2420_MUX_H_ -#define _OMAP2420_MUX_H_ - -#ifndef __ASSEMBLY__ -typedef unsigned char uint8; -typedef unsigned int uint32; - -void muxSetupSDRC(void); -void muxSetupGPMC(void); -void muxSetupUsb0(void); -void muxSetupUsbHost(void); -void muxSetupUart3(void); -void muxSetupI2C1(void); -void muxSetupUART1(void); -void muxSetupLCD(void); -void muxSetupCamera(void); -void muxSetupMMCSD(void) ; -void muxSetupTouchScreen(void) ; -void muxSetupHDQ(void); -#endif - -#define USB_OTG_CTRL ((volatile uint32 *)0x4805E30C) - -/* Pin Muxing registers used for HDQ (Smart battery) */ -#define CONTROL_PADCONF_HDQ_SIO ((volatile unsigned char *)0x48000115) - -/* Pin Muxing registers used for GPMC */ -#define CONTROL_PADCONF_GPMC_D2_BYTE0 ((volatile unsigned char *)0x48000088) -#define CONTROL_PADCONF_GPMC_D2_BYTE1 ((volatile unsigned char *)0x48000089) -#define CONTROL_PADCONF_GPMC_D2_BYTE2 ((volatile unsigned char *)0x4800008A) -#define CONTROL_PADCONF_GPMC_D2_BYTE3 ((volatile unsigned char *)0x4800008B) - -#define CONTROL_PADCONF_GPMC_NCS0_BYTE0 ((volatile unsigned char *)0x4800008C) -#define CONTROL_PADCONF_GPMC_NCS0_BYTE1 ((volatile unsigned char *)0x4800008D) -#define CONTROL_PADCONF_GPMC_NCS0_BYTE2 ((volatile unsigned char *)0x4800008E) -#define CONTROL_PADCONF_GPMC_NCS0_BYTE3 ((volatile unsigned char *)0x4800008F) -#define CONTROL_PADCONF_GPMC_NCS0_BYTE4 (0x48000090) -#define CONTROL_PADCONF_GPMC_NCS0_BYTE5 (0x48000091) -#define CONTROL_PADCONF_GPMC_NCS0_BYTE6 (0x48000092) -#define CONTROL_PADCONF_GPMC_NCS0_BYTE7 (0x48000093) - -/* Pin Muxing registers used for SDRC */ -#define CONTROL_PADCONF_SDRC_NCS0_BYTE0 ((volatile unsigned char *)0x480000A0) -#define CONTROL_PADCONF_SDRC_NCS0_BYTE1 ((volatile unsigned char *)0x480000A1) -#define CONTROL_PADCONF_SDRC_NCS0_BYTE2 ((volatile unsigned char *)0x480000A2) -#define CONTROL_PADCONF_SDRC_NCS0_BYTE3 ((volatile unsigned char *)0x480000A3) - -#define CONTROL_PADCONF_SDRC_A14_BYTE0 ((volatile unsigned char *)0x48000030) -#define CONTROL_PADCONF_SDRC_A14_BYTE1 ((volatile unsigned char *)0x48000031) -#define CONTROL_PADCONF_SDRC_A14_BYTE2 ((volatile unsigned char *)0x48000032) -#define CONTROL_PADCONF_SDRC_A14_BYTE3 ((volatile unsigned char *)0x48000033) - -/* Pin Muxing registers used for Touch Screen (SPI) */ -#define CONTROL_PADCONF_SPI1_CLK ((volatile unsigned char *)0x480000FF) -#define CONTROL_PADCONF_SPI1_SIMO ((volatile unsigned char *)0x48000100) -#define CONTROL_PADCONF_SPI1_SOMI ((volatile unsigned char *)0x48000101) -#define CONTROL_PADCONF_SPI1_NCS0 ((volatile unsigned char *)0x48000102) -#define CONTROL_PADCONF_SPI1_NCS1 (0x48000103) - -#define CONTROL_PADCONF_MCBSP1_FSR ((volatile unsigned char *)0x4800010B) - -/* Pin Muxing registers used for MMCSD */ -#define CONTROL_PADCONF_MMC_CLKI ((volatile unsigned char *)0x480000FE) -#define CONTROL_PADCONF_MMC_CLKO ((volatile unsigned char *)0x480000F3) -#define CONTROL_PADCONF_MMC_CMD ((volatile unsigned char *)0x480000F4) -#define CONTROL_PADCONF_MMC_DAT0 ((volatile unsigned char *)0x480000F5) -#define CONTROL_PADCONF_MMC_DAT1 ((volatile unsigned char *)0x480000F6) -#define CONTROL_PADCONF_MMC_DAT2 ((volatile unsigned char *)0x480000F7) -#define CONTROL_PADCONF_MMC_DAT3 ((volatile unsigned char *)0x480000F8) -#define CONTROL_PADCONF_MMC_DAT_DIR0 ((volatile unsigned char *)0x480000F9) -#define CONTROL_PADCONF_MMC_DAT_DIR1 ((volatile unsigned char *)0x480000FA) -#define CONTROL_PADCONF_MMC_DAT_DIR2 ((volatile unsigned char *)0x480000FB) -#define CONTROL_PADCONF_MMC_DAT_DIR3 ((volatile unsigned char *)0x480000FC) -#define CONTROL_PADCONF_MMC_CMD_DIR ((volatile unsigned char *)0x480000FD) - -#define CONTROL_PADCONF_SDRC_A14 ((volatile unsigned char *)0x48000030) -#define CONTROL_PADCONF_SDRC_A13 ((volatile unsigned char *)0x48000031) - -/* Pin Muxing registers used for CAMERA */ -#define CONTROL_PADCONF_SYS_NRESWARM ((volatile unsigned char *)0x4800012B) - -#define CONTROL_PADCONF_CAM_XCLK ((volatile unsigned char *)0x480000DC) -#define CONTROL_PADCONF_CAM_LCLK ((volatile unsigned char *)0x480000DB) -#define CONTROL_PADCONF_CAM_VS ((volatile unsigned char *)0x480000DA) -#define CONTROL_PADCONF_CAM_HS ((volatile unsigned char *)0x480000D9) -#define CONTROL_PADCONF_CAM_D0 ((volatile unsigned char *)0x480000D8) -#define CONTROL_PADCONF_CAM_D1 ((volatile unsigned char *)0x480000D7) -#define CONTROL_PADCONF_CAM_D2 ((volatile unsigned char *)0x480000D6) -#define CONTROL_PADCONF_CAM_D3 ((volatile unsigned char *)0x480000D5) -#define CONTROL_PADCONF_CAM_D4 ((volatile unsigned char *)0x480000D4) -#define CONTROL_PADCONF_CAM_D5 ((volatile unsigned char *)0x480000D3) -#define CONTROL_PADCONF_CAM_D6 ((volatile unsigned char *)0x480000D2) -#define CONTROL_PADCONF_CAM_D7 ((volatile unsigned char *)0x480000D1) -#define CONTROL_PADCONF_CAM_D8 ((volatile unsigned char *)0x480000D0) -#define CONTROL_PADCONF_CAM_D9 ((volatile unsigned char *)0x480000CF) - -/* Pin Muxing registers used for LCD */ -#define CONTROL_PADCONF_DSS_D0 ((volatile unsigned char *)0x480000B3) -#define CONTROL_PADCONF_DSS_D1 ((volatile unsigned char *)0x480000B4) -#define CONTROL_PADCONF_DSS_D2 ((volatile unsigned char *)0x480000B5) -#define CONTROL_PADCONF_DSS_D3 ((volatile unsigned char *)0x480000B6) -#define CONTROL_PADCONF_DSS_D4 ((volatile unsigned char *)0x480000B7) -#define CONTROL_PADCONF_DSS_D5 ((volatile unsigned char *)0x480000B8) -#define CONTROL_PADCONF_DSS_D6 ((volatile unsigned char *)0x480000B9) -#define CONTROL_PADCONF_DSS_D7 ((volatile unsigned char *)0x480000BA) -#define CONTROL_PADCONF_DSS_D8 ((volatile unsigned char *)0x480000BB) -#define CONTROL_PADCONF_DSS_D9 ((volatile unsigned char *)0x480000BC) -#define CONTROL_PADCONF_DSS_D10 ((volatile unsigned char *)0x480000BD) -#define CONTROL_PADCONF_DSS_D11 ((volatile unsigned char *)0x480000BE) -#define CONTROL_PADCONF_DSS_D12 ((volatile unsigned char *)0x480000BF) -#define CONTROL_PADCONF_DSS_D13 ((volatile unsigned char *)0x480000C0) -#define CONTROL_PADCONF_DSS_D14 ((volatile unsigned char *)0x480000C1) -#define CONTROL_PADCONF_DSS_D15 ((volatile unsigned char *)0x480000C2) -#define CONTROL_PADCONF_DSS_D16 ((volatile unsigned char *)0x480000C3) -#define CONTROL_PADCONF_DSS_D17 ((volatile unsigned char *)0x480000C4) -#define CONTROL_PADCONF_DSS_PCLK ((volatile unsigned char *)0x480000CB) -#define CONTROL_PADCONF_DSS_VSYNC ((volatile unsigned char *)0x480000CC) -#define CONTROL_PADCONF_DSS_HSYNC ((volatile unsigned char *)0x480000CD) -#define CONTROL_PADCONF_DSS_ACBIAS ((volatile unsigned char *)0x480000CE) - -/* Pin Muxing registers used for UART1 */ -#define CONTROL_PADCONF_UART1_CTS ((volatile unsigned char *)0x480000C5) -#define CONTROL_PADCONF_UART1_RTS ((volatile unsigned char *)0x480000C6) -#define CONTROL_PADCONF_UART1_TX ((volatile unsigned char *)0x480000C7) -#define CONTROL_PADCONF_UART1_RX ((volatile unsigned char *)0x480000C8) - -/* Pin Muxing registers used for I2C1 */ -#define CONTROL_PADCONF_I2C1_SCL ((volatile unsigned char *)0x48000111) -#define CONTROL_PADCONF_I2C1_SDA ((volatile unsigned char *)0x48000112) - -/* Pin Muxing registres used for USB0. */ -#define CONTROL_PADCONF_USB0_PUEN ((volatile uint8 *)0x4800011D) -#define CONTROL_PADCONF_USB0_VP ((volatile uint8 *)0x4800011E) -#define CONTROL_PADCONF_USB0_VM ((volatile uint8 *)0x4800011F) -#define CONTROL_PADCONF_USB0_RCV ((volatile uint8 *)0x48000120) -#define CONTROL_PADCONF_USB0_TXEN ((volatile uint8 *)0x48000121) -#define CONTROL_PADCONF_USB0_SE0 ((volatile uint8 *)0x48000122) -#define CONTROL_PADCONF_USB0_DAT ((volatile uint8 *)0x48000123) - -/* Pin Muxing registres used for USB1. */ -#define CONTROL_PADCONF_USB1_RCV (0x480000EB) -#define CONTROL_PADCONF_USB1_TXEN (0x480000EC) - -/* Pin Muxing registers used for UART3/IRDA */ -#define CONTROL_PADCONF_UART3_TX_IRTX ((volatile uint8 *)0x48000118) -#define CONTROL_PADCONF_UART3_RX_IRRX ((volatile uint8 *)0x48000119) - -/* Pin Muxing registers used for GPIO */ -#define CONTROL_PADCONF_GPIO69 (0x480000ED) -#define CONTROL_PADCONF_GPIO70 (0x480000EE) -#define CONTROL_PADCONF_GPIO102 (0x48000116) -#define CONTROL_PADCONF_GPIO103 (0x48000117) -#define CONTROL_PADCONF_GPIO104 (0x48000118) -#define CONTROL_PADCONF_GPIO105 (0x48000119) - -#endif diff --git a/arch/arm/include/asm/arch-omap24xx/omap2420.h b/arch/arm/include/asm/arch-omap24xx/omap2420.h deleted file mode 100644 index 5724f5d..0000000 --- a/arch/arm/include/asm/arch-omap24xx/omap2420.h +++ /dev/null @@ -1,236 +0,0 @@ -/* - * (C) Copyright 2004 - * Texas Instruments, <www.ti.com> - * Richard Woodruff r-woodruff2@ti.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef _OMAP2420_SYS_H_ -#define _OMAP2420_SYS_H_ - -#include <asm/sizes.h> - -/* - * 2420 specific Section - */ - -/* L3 Firewall */ -#define A_REQINFOPERM0 0x68005048 -#define A_READPERM0 0x68005050 -#define A_WRITEPERM0 0x68005058 -/* #define GP_DEVICE (BIT8|BIT9) FIXME -- commented out to make compile -- FIXME */ - -/* L3 Firewall */ -#define A_REQINFOPERM0 0x68005048 -#define A_READPERM0 0x68005050 -#define A_WRITEPERM0 0x68005058 - -/* CONTROL */ -#define OMAP2420_CTRL_BASE (0x48000000) -#define CONTROL_STATUS (OMAP2420_CTRL_BASE + 0x2F8) - -/* device type */ -#define TST_DEVICE 0x0 -#define EMU_DEVICE 0x1 -#define HS_DEVICE 0x2 -#define GP_DEVICE 0x3 - -/* TAP information */ -#define OMAP2420_TAP_BASE (0x48014000) -#define TAP_IDCODE_REG (OMAP2420_TAP_BASE+0x204) -#define PRODUCTION_ID (OMAP2420_TAP_BASE+0x208) - -/* GPMC */ -#define OMAP2420_GPMC_BASE (0x6800A000) -#define GPMC_SYSCONFIG (OMAP2420_GPMC_BASE+0x10) -#define GPMC_IRQENABLE (OMAP2420_GPMC_BASE+0x1C) -#define GPMC_TIMEOUT_CONTROL (OMAP2420_GPMC_BASE+0x40) -#define GPMC_CONFIG (OMAP2420_GPMC_BASE+0x50) -#define GPMC_CONFIG1_0 (OMAP2420_GPMC_BASE+0x60) -#define GPMC_CONFIG2_0 (OMAP2420_GPMC_BASE+0x64) -#define GPMC_CONFIG3_0 (OMAP2420_GPMC_BASE+0x68) -#define GPMC_CONFIG4_0 (OMAP2420_GPMC_BASE+0x6C) -#define GPMC_CONFIG5_0 (OMAP2420_GPMC_BASE+0x70) -#define GPMC_CONFIG6_0 (OMAP2420_GPMC_BASE+0x74) -#define GPMC_CONFIG7_0 (OMAP2420_GPMC_BASE+0x78) -#define GPMC_CONFIG1_1 (OMAP2420_GPMC_BASE+0x90) -#define GPMC_CONFIG2_1 (OMAP2420_GPMC_BASE+0x94) -#define GPMC_CONFIG3_1 (OMAP2420_GPMC_BASE+0x98) -#define GPMC_CONFIG4_1 (OMAP2420_GPMC_BASE+0x9C) -#define GPMC_CONFIG5_1 (OMAP2420_GPMC_BASE+0xA0) -#define GPMC_CONFIG6_1 (OMAP2420_GPMC_BASE+0xA4) -#define GPMC_CONFIG7_1 (OMAP2420_GPMC_BASE+0xA8) -#define GPMC_CONFIG1_2 (OMAP2420_GPMC_BASE+0xC0) -#define GPMC_CONFIG2_2 (OMAP2420_GPMC_BASE+0xC4) -#define GPMC_CONFIG3_2 (OMAP2420_GPMC_BASE+0xC8) -#define GPMC_CONFIG4_2 (OMAP2420_GPMC_BASE+0xCC) -#define GPMC_CONFIG5_2 (OMAP2420_GPMC_BASE+0xD0) -#define GPMC_CONFIG6_2 (OMAP2420_GPMC_BASE+0xD4) -#define GPMC_CONFIG7_2 (OMAP2420_GPMC_BASE+0xD8) -#define GPMC_CONFIG1_3 (OMAP2420_GPMC_BASE+0xF0) -#define GPMC_CONFIG2_3 (OMAP2420_GPMC_BASE+0xF4) -#define GPMC_CONFIG3_3 (OMAP2420_GPMC_BASE+0xF8) -#define GPMC_CONFIG4_3 (OMAP2420_GPMC_BASE+0xFC) -#define GPMC_CONFIG5_3 (OMAP2420_GPMC_BASE+0x100) -#define GPMC_CONFIG6_3 (OMAP2420_GPMC_BASE+0x104) -#define GPMC_CONFIG7_3 (OMAP2420_GPMC_BASE+0x108) - -/* SMS */ -#define OMAP2420_SMS_BASE 0x68008000 -#define SMS_SYSCONFIG (OMAP2420_SMS_BASE+0x10) -#define SMS_CLASS_ARB0 (OMAP2420_SMS_BASE+0xD0) -# define BURSTCOMPLETE_GROUP7 BIT31 - -/* SDRC */ -#define OMAP2420_SDRC_BASE 0x68009000 -#define SDRC_SYSCONFIG (OMAP2420_SDRC_BASE+0x10) -#define SDRC_STATUS (OMAP2420_SDRC_BASE+0x14) -#define SDRC_CS_CFG (OMAP2420_SDRC_BASE+0x40) -#define SDRC_SHARING (OMAP2420_SDRC_BASE+0x44) -#define SDRC_DLLA_CTRL (OMAP2420_SDRC_BASE+0x60) -#define SDRC_DLLB_CTRL (OMAP2420_SDRC_BASE+0x68) -#define SDRC_POWER (OMAP2420_SDRC_BASE+0x70) -#define SDRC_MCFG_0 (OMAP2420_SDRC_BASE+0x80) -#define SDRC_MR_0 (OMAP2420_SDRC_BASE+0x84) -#define SDRC_ACTIM_CTRLA_0 (OMAP2420_SDRC_BASE+0x9C) -#define SDRC_ACTIM_CTRLB_0 (OMAP2420_SDRC_BASE+0xA0) -#define SDRC_ACTIM_CTRLA_1 (OMAP2420_SDRC_BASE+0xC4) -#define SDRC_ACTIM_CTRLB_1 (OMAP2420_SDRC_BASE+0xC8) -#define SDRC_RFR_CTRL (OMAP2420_SDRC_BASE+0xA4) -#define SDRC_MANUAL_0 (OMAP2420_SDRC_BASE+0xA8) -#define OMAP2420_SDRC_CS0 0x80000000 -#define OMAP2420_SDRC_CS1 0xA0000000 -#define CMD_NOP 0x0 -#define CMD_PRECHARGE 0x1 -#define CMD_AUTOREFRESH 0x2 -#define CMD_ENTR_PWRDOWN 0x3 -#define CMD_EXIT_PWRDOWN 0x4 -#define CMD_ENTR_SRFRSH 0x5 -#define CMD_CKE_HIGH 0x6 -#define CMD_CKE_LOW 0x7 -#define SOFTRESET BIT1 -#define SMART_IDLE (0x2 << 3) -#define REF_ON_IDLE (0x1 << 6) - - -/* UART */ -#define OMAP2420_UART1 0x4806A000 -#define OMAP2420_UART2 0x4806C000 -#define OMAP2420_UART3 0x4806E000 - -/* General Purpose Timers */ -#define OMAP2420_GPT1 0x48028000 -#define OMAP2420_GPT2 0x4802A000 -#define OMAP2420_GPT3 0x48078000 -#define OMAP2420_GPT4 0x4807A000 -#define OMAP2420_GPT5 0x4807C000 -#define OMAP2420_GPT6 0x4807E000 -#define OMAP2420_GPT7 0x48080000 -#define OMAP2420_GPT8 0x48082000 -#define OMAP2420_GPT9 0x48084000 -#define OMAP2420_GPT10 0x48086000 -#define OMAP2420_GPT11 0x48088000 -#define OMAP2420_GPT12 0x4808A000 - -/* timer regs offsets (32 bit regs) */ -#define TIDR 0x0 /* r */ -#define TIOCP_CFG 0x10 /* rw */ -#define TISTAT 0x14 /* r */ -#define TISR 0x18 /* rw */ -#define TIER 0x1C /* rw */ -#define TWER 0x20 /* rw */ -#define TCLR 0x24 /* rw */ -#define TCRR 0x28 /* rw */ -#define TLDR 0x2C /* rw */ -#define TTGR 0x30 /* rw */ -#define TWPS 0x34 /* r */ -#define TMAR 0x38 /* rw */ -#define TCAR1 0x3c /* r */ -#define TSICR 0x40 /* rw */ -#define TCAR2 0x44 /* r */ - -/* WatchDog Timers (1 secure, 3 GP) */ -#define WD1_BASE 0x48020000 -#define WD2_BASE 0x48022000 -#define WD3_BASE 0x48024000 -#define WD4_BASE 0x48026000 -#define WWPS 0x34 /* r */ -#define WSPR 0x48 /* rw */ -#define WD_UNLOCK1 0xAAAA -#define WD_UNLOCK2 0x5555 - -/* PRCM */ -#define OMAP2420_CM_BASE 0x48008000 -#define PRCM_CLKCFG_CTRL (OMAP2420_CM_BASE+0x080) -#define CM_CLKSEL_MPU (OMAP2420_CM_BASE+0x140) -#define CM_FCLKEN1_CORE (OMAP2420_CM_BASE+0x200) -#define CM_FCLKEN2_CORE (OMAP2420_CM_BASE+0x204) -#define CM_ICLKEN1_CORE (OMAP2420_CM_BASE+0x210) -#define CM_ICLKEN2_CORE (OMAP2420_CM_BASE+0x214) -#define CM_CLKSEL1_CORE (OMAP2420_CM_BASE+0x240) -#define CM_CLKSEL_WKUP (OMAP2420_CM_BASE+0x440) -#define CM_CLKSEL2_CORE (OMAP2420_CM_BASE+0x244) -#define CM_CLKSEL_GFX (OMAP2420_CM_BASE+0x340) -#define PM_RSTCTRL_WKUP (OMAP2420_CM_BASE+0x450) -#define CM_CLKEN_PLL (OMAP2420_CM_BASE+0x500) -#define CM_IDLEST_CKGEN (OMAP2420_CM_BASE+0x520) -#define CM_CLKSEL1_PLL (OMAP2420_CM_BASE+0x540) -#define CM_CLKSEL2_PLL (OMAP2420_CM_BASE+0x544) -#define CM_CLKSEL_DSP (OMAP2420_CM_BASE+0x840) - -/* - * H4 specific Section - */ - -/* - * The 2420's chip selects are programmable. The mask ROM - * does configure CS0 to 0x08000000 before dispatch. So, if - * you want your code to live below that address, you have to - * be prepared to jump though hoops, to reset the base address. - */ -#if defined(CONFIG_OMAP2420H4) -/* GPMC */ -#ifdef CONFIG_VIRTIO_A /* Pre version B */ -# define H4_CS0_BASE 0x08000000 /* flash (64 Meg aligned) */ -# define H4_CS1_BASE 0x04000000 /* debug board */ -# define H4_CS2_BASE 0x0A000000 /* wifi board */ -#else -# define H4_CS0_BASE 0x08000000 /* flash (64 Meg aligned) */ -# define H4_CS1_BASE 0x04000000 /* debug board */ -# define H4_CS2_BASE 0x0C000000 /* wifi board */ -#endif - -/* base address for indirect vectors (internal boot mode) */ -#define SRAM_OFFSET0 0x40000000 -#define SRAM_OFFSET1 0x00200000 -#define SRAM_OFFSET2 0x0000F800 -#define SRAM_VECT_CODE (SRAM_OFFSET0|SRAM_OFFSET1|SRAM_OFFSET2) - -/* FPGA on Debug board.*/ -#define ETH_CONTROL_REG (H4_CS1_BASE+0x30b) -#define LAN_RESET_REGISTER (H4_CS1_BASE+0x1c) -#endif /* endif CONFIG_2420H4 */ - -/* Common */ -#define LOW_LEVEL_SRAM_STACK 0x4020FFFC - -#define PERIFERAL_PORT_BASE 0x480FE003 - -#endif diff --git a/arch/arm/include/asm/arch-omap24xx/sys_info.h b/arch/arm/include/asm/arch-omap24xx/sys_info.h deleted file mode 100644 index 53c231a..0000000 --- a/arch/arm/include/asm/arch-omap24xx/sys_info.h +++ /dev/null @@ -1,82 +0,0 @@ -/* - * (C) Copyright 2004 - * Texas Instruments, <www.ti.com> - * Richard Woodruff r-woodruff2@ti.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef _OMAP24XX_SYS_INFO_H_ -#define _OMAP24XX_SYS_INFO_H_ - -typedef struct h4_system_data { - /* base board info */ - u32 base_b_rev; /* rev from base board i2c */ - /* cpu board info */ - u32 cpu_b_rev; /* rev from cpu board i2c */ - u32 cpu_b_mux; /* mux type on daughter board */ - u32 cpu_b_ddr_type; /* mem type */ - u32 cpu_b_ddr_speed; /* ddr speed rating */ - u32 cpu_b_switches; /* boot ctrl switch settings */ - /* cpu info */ - u32 cpu_type; /* type of cpu; 2420, 2422, 2430,...*/ - u32 cpu_rev; /* rev of given cpu; ES1, ES2,...*/ -} h4_sys_data; - -#define XDR_POP 5 /* package on package part */ -#define SDR_DISCRETE 4 /* 128M memory SDR module*/ -#define DDR_STACKED 3 /* stacked part on 2422 */ -#define DDR_COMBO 2 /* combo part on cpu daughter card (menalaeus) */ -#define DDR_DISCRETE 1 /* 2x16 parts on daughter card */ - -#define DDR_100 100 /* type found on most mem d-boards */ -#define DDR_111 111 /* some combo parts */ -#define DDR_133 133 /* most combo, some mem d-boards */ -#define DDR_165 165 /* future parts */ - -#define CPU_2420 0x2420 -#define CPU_2422 0x2422 /* 2420 + 64M stacked */ -#define CPU_2423 0x2423 /* 2420 + 96M stacked */ - -#define CPU_2422_ES1 1 -#define CPU_2422_ES2 2 -#define CPU_2420_ES1 1 -#define CPU_2420_ES2 2 -#define CPU_2420_2422_ES1 1 - -#define CPU_2420_CHIPID 0x0B5D9000 -#define CPU_24XX_ID_MASK 0x0FFFF000 -#define CPU_242X_REV_MASK 0xF0000000 -#define CPU_242X_PID_MASK 0x000F0000 - -#define BOARD_H4_MENELAUS 1 -#define BOARD_H4_SDP 2 - -#define GPMC_MUXED 1 -#define GPMC_NONMUXED 0 - -#define TYPE_NAND 0x800 /* bit pos for nand in gpmc reg */ -#define TYPE_NOR 0x000 - -#define WIDTH_8BIT 0x0000 -#define WIDTH_16BIT 0x1000 /* bit pos for 16 bit in gpmc */ - -#define I2C_MENELAUS 0x72 /* i2c id for companion chip */ - -#endif diff --git a/arch/arm/include/asm/arch-omap24xx/sys_proto.h b/arch/arm/include/asm/arch-omap24xx/sys_proto.h deleted file mode 100644 index 9d8e5b2..0000000 --- a/arch/arm/include/asm/arch-omap24xx/sys_proto.h +++ /dev/null @@ -1,54 +0,0 @@ -/* - * (C) Copyright 2004 - * Texas Instruments, <www.ti.com> - * Richard Woodruff r-woodruff2@ti.com - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR /PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ -#ifndef _OMAP24XX_SYS_PROTO_H_ -#define _OMAP24XX_SYS_PROTO_H_ - -void prcm_init(void); -void memif_init(void); -void sdrc_init(void); -void do_sdrc_init(u32,u32); -void gpmc_init(void); - -void ether_init(void); -void watchdog_init(void); -void set_muxconf_regs(void); -void peripheral_enable(void); - -u32 get_cpu_type(void); -u32 get_cpu_rev(void); -u32 get_mem_type(void); -u32 get_sysboot_value(void); -u32 get_gpmc0_base(void); -u32 is_gpmc_muxed(void); -u32 get_gpmc0_type(void); -u32 get_gpmc0_width(void); -u32 wait_on_value(u32 read_bit_mask, u32 match_value, u32 read_addr, u32 bound); -u32 get_board_type(void); -void display_board_info(u32); -void update_mux(u32,u32); -u32 get_sdr_cs_size(u32 offset); - -u32 running_in_sdram(void); -u32 running_in_sram(void); -u32 running_in_flash(void); -u32 running_from_internal_boot(void); -u32 get_device_type(void); -#endif diff --git a/arch/arm/lib/cache.c b/arch/arm/lib/cache.c index b545fb7..8b1c8ed 100644 --- a/arch/arm/lib/cache.c +++ b/arch/arm/lib/cache.c @@ -27,7 +27,7 @@
void __flush_cache(unsigned long start, unsigned long size) { -#if defined(CONFIG_OMAP2420) || defined(CONFIG_ARM1136) +#if defined(CONFIG_ARM1136) void arm1136_cache_flush(void);
arm1136_cache_flush(); diff --git a/board/ti/omap2420h4/Makefile b/board/ti/omap2420h4/Makefile deleted file mode 100644 index cddd7e6..0000000 --- a/board/ti/omap2420h4/Makefile +++ /dev/null @@ -1,45 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := omap2420h4.o mem.o sys_info.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/ti/omap2420h4/config.mk b/board/ti/omap2420h4/config.mk deleted file mode 100644 index e5dff69..0000000 --- a/board/ti/omap2420h4/config.mk +++ /dev/null @@ -1,28 +0,0 @@ -# -# (C) Copyright 2004 -# Texas Instruments, <www.ti.com> -# -# TI H4 board with OMAP2420 (ARM1136) cpu -# see http://www.ti.com/ for more information on Texas Instruments -# -# H4 has 1 bank of 32MB or 64MB mDDR-SDRAM on CS0 -# H4 has 1 bank of 32MB or 00MB mDDR-SDRAM on CS1 -# Physical Address: -# 8000'0000 (bank0) -# A000/0000 (bank1) ES2 will be configurable -# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 -# (mem base + reserved) - -# For use with external or internal boots. -#CONFIG_SYS_TEXT_BASE = 0x80e80000 - -# Used with full SRAM boot. -# This is either with a GP system or a signed boot image. -# easiest, and safest way to go if you can. -#CONFIG_SYS_TEXT_BASE = 0x40270000 - - -# Handy to get symbols to debug ROM version. -#CONFIG_SYS_TEXT_BASE = 0x0 -CONFIG_SYS_TEXT_BASE = 0x08000000 -#CONFIG_SYS_TEXT_BASE = 0x04000000 diff --git a/board/ti/omap2420h4/lowlevel_init.S b/board/ti/omap2420h4/lowlevel_init.S deleted file mode 100644 index 731c552..0000000 --- a/board/ti/omap2420h4/lowlevel_init.S +++ /dev/null @@ -1,185 +0,0 @@ -/* - * Board specific setup info - * - * (C) Copyright 2004 - * Texas Instruments, <www.ti.com> - * Richard Woodruff r-woodruff2@ti.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <version.h> -#include <asm/arch/omap2420.h> -#include <asm/arch/mem.h> -#include <asm/arch/clocks.h> - -_TEXT_BASE: - .word CONFIG_SYS_TEXT_BASE /* sdram load addr from config.mk */ - -/************************************************************************** - * cpy_clk_code: relocates clock code into SRAM where its safer to execute - * R1 = SRAM destination address. - *************************************************************************/ -.global cpy_clk_code - cpy_clk_code: - /* Copy DPLL code into SRAM */ - adr r0, go_to_speed /* get addr of clock setting code */ - mov r2, #384 /* r2 size to copy (div by 32 bytes) */ - mov r1, r1 /* r1 <- dest address (passed in) */ - add r2, r2, r0 /* r2 <- source end address */ -next2: - ldmia r0!, {r3-r10} /* copy from source address [r0] */ - stmia r1!, {r3-r10} /* copy to target address [r1] */ - cmp r0, r2 /* until source end address [r2] */ - bne next2 - mov pc, lr /* back to caller */ - -/* **************************************************************************** - * go_to_speed: -Moves to bypass, -Commits clock dividers, -puts dpll at speed - * -executed from SRAM. - * R0 = PRCM_CLKCFG_CTRL - addr of valid reg - * R1 = CM_CLKEN_PLL - addr dpll ctlr reg - * R2 = dpll value - * R3 = CM_IDLEST_CKGEN - addr dpll lock wait - ******************************************************************************/ -.global go_to_speed - go_to_speed: - sub sp, sp, #0x4 /* get some stack space */ - str r4, [sp] /* save r4's value */ - - /* move into fast relock bypass */ - ldr r8, pll_ctl_add - mov r4, #0x2 - str r4, [r8] - ldr r4, pll_stat -block: - ldr r8, [r4] /* wait for bypass to take effect */ - and r8, r8, #0x3 - cmp r8, #0x1 - bne block - - /* set new dpll dividers _after_ in bypass */ - ldr r4, pll_div_add - ldr r8, pll_div_val - str r8, [r4] - - /* now prepare GPMC (flash) for new dpll speed */ - /* flash needs to be stable when we jump back to it */ - ldr r4, cfg3_0_addr - ldr r8, cfg3_0_val - str r8, [r4] - ldr r4, cfg4_0_addr - ldr r8, cfg4_0_val - str r8, [r4] - ldr r4, cfg1_0_addr - ldr r8, [r4] - orr r8, r8, #0x3 /* up gpmc divider */ - str r8, [r4] - - /* setup to 2x loop though code. The first loop pre-loads the - * icache, the 2nd commits the prcm config, and locks the dpll - */ - mov r4, #0x1000 /* spin spin spin */ - mov r8, #0x4 /* first pass condition & set registers */ - cmp r8, #0x4 -2: - ldrne r8, [r3] /* DPLL lock check */ - and r8, r8, #0x7 - cmp r8, #0x2 - beq 4f -3: - subeq r8, r8, #0x1 - streq r8, [r0] /* commit dividers (2nd time) */ - nop -lloop1: - sub r4, r4, #0x1 /* Loop currently necessary else bad jumps */ - nop - cmp r4, #0x0 - bne lloop1 - mov r4, #0x40000 - cmp r8, #0x1 - nop - streq r2, [r1] /* lock dpll (2nd time) */ - nop -lloop2: - sub r4, r4, #0x1 /* loop currently necessary else bad jumps */ - nop - cmp r4, #0x0 - bne lloop2 - mov r4, #0x40000 - cmp r8, #0x1 - nop - ldreq r8, [r3] /* get lock condition for dpll */ - cmp r8, #0x4 /* first time though? */ - bne 2b - moveq r8, #0x2 /* set to dpll check condition. */ - beq 3b /* if condition not true branch */ -4: - ldr r4, [sp] - add sp, sp, #0x4 /* return stack space */ - mov pc, lr /* back to caller, locked */ - -_go_to_speed: .word go_to_speed - -/* these constants need to be close for PIC code */ -cfg3_0_addr: - .word GPMC_CONFIG3_0 -cfg3_0_val: - .word H4_24XX_GPMC_CONFIG3_0 -cfg4_0_addr: - .word GPMC_CONFIG4_0 -cfg4_0_val: - .word H4_24XX_GPMC_CONFIG4_0 -cfg1_0_addr: - .word GPMC_CONFIG1_0 -pll_ctl_add: - .word CM_CLKEN_PLL -pll_stat: - .word CM_IDLEST_CKGEN -pll_div_add: - .word CM_CLKSEL1_PLL -pll_div_val: - .word DPLL_VAL /* DPLL setting (300MHz default) */ - -.globl lowlevel_init -lowlevel_init: - ldr sp, SRAM_STACK - str ip, [sp] /* stash old link register */ - mov ip, lr /* save link reg across call */ - bl s_init /* go setup pll,mux,memory */ - ldr ip, [sp] /* restore save ip */ - mov lr, ip /* restore link reg */ - - /* map interrupt controller */ - ldr r0, VAL_INTH_SETUP - mcr p15, 0, r0, c15, c2, 4 - - /* back to arch calling code */ - mov pc, lr - - /* the literal pools origin */ - .ltorg - -REG_CONTROL_STATUS: - .word CONTROL_STATUS -VAL_INTH_SETUP: - .word PERIFERAL_PORT_BASE -SRAM_STACK: - .word LOW_LEVEL_SRAM_STACK diff --git a/board/ti/omap2420h4/mem.c b/board/ti/omap2420h4/mem.c deleted file mode 100644 index ba3f12a..0000000 --- a/board/ti/omap2420h4/mem.c +++ /dev/null @@ -1,362 +0,0 @@ -/* - * (C) Copyright 2004 - * Texas Instruments, <www.ti.com> - * Richard Woodruff r-woodruff2@ti.com - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/arch/omap2420.h> -#include <asm/io.h> -#include <asm/arch/bits.h> -#include <asm/arch/mux.h> -#include <asm/arch/mem.h> -#include <asm/arch/clocks.h> -#include <asm/arch/sys_proto.h> -#include <asm/arch/sys_info.h> - -/************************************************************ - * sdelay() - simple spin loop. Will be constant time as - * its generally used in 12MHz bypass conditions only. This - * is necessary until timers are accessible. - * - * not inline to increase chances its in cache when called - *************************************************************/ -void sdelay (unsigned long loops) -{ - __asm__ volatile ("1:\n" "subs %0, %1, #1\n" - "bne 1b":"=r" (loops):"0" (loops)); -} - -/********************************************************************************* - * prcm_init() - inits clocks for PRCM as defined in clocks.h (config II default). - * -- called from SRAM, or Flash (using temp SRAM stack). - *********************************************************************************/ -void prcm_init(void) -{ - u32 div; - void (*f_lock_pll) (u32, u32, u32, u32); - extern void *_end_vect, *_start; - - f_lock_pll = (void *)((u32)&_end_vect - (u32)&_start + SRAM_VECT_CODE); - - __raw_writel(0, CM_FCLKEN1_CORE); /* stop all clocks to reduce ringing */ - __raw_writel(0, CM_FCLKEN2_CORE); /* may not be necessary */ - __raw_writel(0, CM_ICLKEN1_CORE); - __raw_writel(0, CM_ICLKEN2_CORE); - - __raw_writel(DPLL_OUT, CM_CLKSEL2_PLL); /* set DPLL out */ - __raw_writel(MPU_DIV, CM_CLKSEL_MPU); /* set MPU divider */ - __raw_writel(DSP_DIV, CM_CLKSEL_DSP); /* set dsp and iva dividers */ - __raw_writel(GFX_DIV, CM_CLKSEL_GFX); /* set gfx dividers */ - - div = BUS_DIV; - __raw_writel(div, CM_CLKSEL1_CORE);/* set L3/L4/USB/Display/Vlnc/SSi dividers */ - sdelay(1000); - - if(running_in_sram()){ - /* If running fully from SRAM this is OK. The Flash bus drops out for just a little. - * but then comes back. If running from Flash this sequence kills you, thus you need - * to run it using CONFIG_PARTIAL_SRAM. - */ - __raw_writel(MODE_BYPASS_FAST, CM_CLKEN_PLL); /* go to bypass, fast relock */ - wait_on_value(BIT0|BIT1, BIT0, CM_IDLEST_CKGEN, LDELAY); /* wait till in bypass */ - sdelay(1000); - /* set clock selection and dpll dividers. */ - __raw_writel(DPLL_VAL, CM_CLKSEL1_PLL); /* set pll for target rate */ - __raw_writel(COMMIT_DIVIDERS, PRCM_CLKCFG_CTRL); /* commit dividers */ - sdelay(10000); - __raw_writel(DPLL_LOCK, CM_CLKEN_PLL); /* enable dpll */ - sdelay(10000); - wait_on_value(BIT0|BIT1, BIT1, CM_IDLEST_CKGEN, LDELAY); /*wait for dpll lock */ - }else if(running_in_flash()){ - /* if running from flash, need to jump to small relocated code area in SRAM. - * This is the only safe spot to do configurations from. - */ - (*f_lock_pll)(PRCM_CLKCFG_CTRL, CM_CLKEN_PLL, DPLL_LOCK, CM_IDLEST_CKGEN); - } - - __raw_writel(DPLL_LOCK|APLL_LOCK, CM_CLKEN_PLL); /* enable apll */ - wait_on_value(BIT8, BIT8, CM_IDLEST_CKGEN, LDELAY); /* wait for apll lock */ - sdelay(1000); -} - -/************************************************************************** - * make_cs1_contiguous() - for es2 and above remap cs1 behind cs0 to allow - * command line mem=xyz use all memory with out discontigious support - * compiled in. Could do it at the ATAG, but there really is two banks... - * Called as part of 2nd phase DDR init. - **************************************************************************/ -void make_cs1_contiguous(void) -{ - u32 size, a_add_low, a_add_high; - - size = get_sdr_cs_size(SDRC_CS0_OSET); - size /= SZ_32M; /* find size to offset CS1 */ - a_add_high = (size & 3) << 8; /* set up low field */ - a_add_low = (size & 0x3C) >> 2; /* set up high field */ - __raw_writel((a_add_high|a_add_low),SDRC_CS_CFG); - -} - -/******************************************************** - * mem_ok() - test used to see if timings are correct - * for a part. Helps in gussing which part - * we are currently using. - *******************************************************/ -u32 mem_ok(void) -{ - u32 val1, val2; - u32 pattern = 0x12345678; - - __raw_writel(0x0,OMAP2420_SDRC_CS0+0x400); /* clear pos A */ - __raw_writel(pattern, OMAP2420_SDRC_CS0); /* pattern to pos B */ - __raw_writel(0x0,OMAP2420_SDRC_CS0+4); /* remove pattern off the bus */ - val1 = __raw_readl(OMAP2420_SDRC_CS0+0x400); /* get pos A value */ - val2 = __raw_readl(OMAP2420_SDRC_CS0); /* get val2 */ - - if ((val1 != 0) || (val2 != pattern)) /* see if pos A value changed*/ - return(0); - else - return(1); -} - - -/******************************************************** - * sdrc_init() - init the sdrc chip selects CS0 and CS1 - * - early init routines, called from flash or - * SRAM. - *******************************************************/ -void sdrc_init(void) -{ - #define EARLY_INIT 1 - do_sdrc_init(SDRC_CS0_OSET, EARLY_INIT); /* only init up first bank here */ -} - -/************************************************************************* - * do_sdrc_init(): initialize the SDRAM for use. - * -called from low level code with stack only. - * -code sets up SDRAM timing and muxing for 2422 or 2420. - * -optimal settings can be placed here, or redone after i2c - * inspection of board info - * - * This is a bit ugly, but should handle all memory moduels - * used with the H4. The first time though this code from s_init() - * we configure the first chip select. Later on we come back and - * will configure the 2nd chip select if it exists. - * - **************************************************************************/ -void do_sdrc_init(u32 offset, u32 early) -{ - u32 cpu, dllen=0, rev, common=0, cs0=0, pmask=0, pass_type, mtype; - sdrc_data_t *sdata; /* do not change type */ - u32 a, b, r; - - static const sdrc_data_t sdrc_2422 = - { - H4_2422_SDRC_SHARING, H4_2422_SDRC_MDCFG_0_DDR, 0 , H4_2422_SDRC_ACTIM_CTRLA_0, - H4_2422_SDRC_ACTIM_CTRLB_0, H4_2422_SDRC_RFR_CTRL, H4_2422_SDRC_MR_0_DDR, - 0, H4_2422_SDRC_DLLAB_CTRL - }; - static const sdrc_data_t sdrc_2420 = - { - H4_2420_SDRC_SHARING, H4_2420_SDRC_MDCFG_0_DDR, H4_2420_SDRC_MDCFG_0_SDR, - H4_2420_SDRC_ACTIM_CTRLA_0, H4_2420_SDRC_ACTIM_CTRLB_0, - H4_2420_SDRC_RFR_CTRL, H4_2420_SDRC_MR_0_DDR, H4_2420_SDRC_MR_0_SDR, - H4_2420_SDRC_DLLAB_CTRL - }; - - if (offset == SDRC_CS0_OSET) - cs0 = common = 1; /* int regs shared between both chip select */ - - cpu = get_cpu_type(); - rev = get_cpu_rev(); - - /* warning generated, though code generation is correct. this may bite later, - * but is ok for now. there is only so much C code you can do on stack only - * operation. - */ - if (cpu == CPU_2422){ - sdata = (sdrc_data_t *)&sdrc_2422; - pass_type = STACKED; - } else{ - sdata = (sdrc_data_t *)&sdrc_2420; - pass_type = IP_DDR; - } - - __asm__ __volatile__("": : :"memory"); /* limit compiler scope */ - - if (!early && (((mtype = get_mem_type()) == DDR_COMBO)||(mtype == DDR_STACKED))) { - if(mtype == DDR_COMBO){ - pmask = BIT2;/* combo part has a shared CKE signal, can't use feature */ - pass_type = COMBO_DDR; /* CS1 config */ - __raw_writel((__raw_readl(SDRC_POWER)) & ~pmask, SDRC_POWER); - } - if(rev != CPU_2420_2422_ES1) /* for es2 and above smooth things out */ - make_cs1_contiguous(); - } - -next_mem_type: - if (common) { /* do a SDRC reset between types to clear regs*/ - __raw_writel(SOFTRESET, SDRC_SYSCONFIG); /* reset sdrc */ - wait_on_value(BIT0, BIT0, SDRC_STATUS, 12000000);/* wait till reset done set */ - __raw_writel(0, SDRC_SYSCONFIG); /* clear soft reset */ - __raw_writel(sdata->sdrc_sharing, SDRC_SHARING); -#ifdef POWER_SAVE - __raw_writel(__raw_readl(SMS_SYSCONFIG)|SMART_IDLE, SMS_SYSCONFIG); - __raw_writel(sdata->sdrc_sharing|SMART_IDLE, SDRC_SHARING); - __raw_writel((__raw_readl(SDRC_POWER)|BIT6), SDRC_POWER); -#endif - } - - if ((pass_type == IP_DDR) || (pass_type == STACKED)) /* (IP ddr-CS0),(2422-CS0/CS1) */ - __raw_writel(sdata->sdrc_mdcfg_0_ddr, SDRC_MCFG_0+offset); - else if (pass_type == COMBO_DDR){ /* (combo-CS0/CS1) */ - __raw_writel(H4_2420_COMBO_MDCFG_0_DDR,SDRC_MCFG_0+offset); - } else if (pass_type == IP_SDR){ /* ip sdr-CS0 */ - __raw_writel(sdata->sdrc_mdcfg_0_sdr, SDRC_MCFG_0+offset); - } - - a = sdata->sdrc_actim_ctrla_0; - b = sdata->sdrc_actim_ctrlb_0; - r = sdata->sdrc_dllab_ctrl; - - /* work around ES1 DDR issues */ - if((pass_type != IP_SDR) && (rev == CPU_2420_2422_ES1)){ - a = H4_242x_SDRC_ACTIM_CTRLA_0_ES1; - b = H4_242x_SDRC_ACTIM_CTRLB_0_ES1; - r = H4_242x_SDRC_RFR_CTRL_ES1; - } - - if (cs0) { - __raw_writel(a, SDRC_ACTIM_CTRLA_0); - __raw_writel(b, SDRC_ACTIM_CTRLB_0); - } else { - __raw_writel(a, SDRC_ACTIM_CTRLA_1); - __raw_writel(b, SDRC_ACTIM_CTRLB_1); - } - __raw_writel(r, SDRC_RFR_CTRL+offset); - - /* init sequence for mDDR/mSDR using manual commands (DDR is a bit different) */ - __raw_writel(CMD_NOP, SDRC_MANUAL_0+offset); - sdelay(5000); /* susposed to be 100us per design spec for mddr/msdr */ - __raw_writel(CMD_PRECHARGE, SDRC_MANUAL_0+offset); - __raw_writel(CMD_AUTOREFRESH, SDRC_MANUAL_0+offset); - __raw_writel(CMD_AUTOREFRESH, SDRC_MANUAL_0+offset); - - /* - * CSx SDRC Mode Register - * Burst length = (4 - DDR) (2-SDR) - * Serial mode - * CAS latency = x - */ - if(pass_type == IP_SDR) - __raw_writel(sdata->sdrc_mr_0_sdr, SDRC_MR_0+offset); - else - __raw_writel(sdata->sdrc_mr_0_ddr, SDRC_MR_0+offset); - - /* NOTE: ES1 242x _BUG_ DLL + External Bandwidth fix*/ - if (rev == CPU_2420_2422_ES1){ - dllen = (BIT0|BIT3); /* es1 clear both bit0 and bit3 */ - __raw_writel((__raw_readl(SMS_CLASS_ARB0)|BURSTCOMPLETE_GROUP7) - ,SMS_CLASS_ARB0);/* enable bust complete for lcd */ - } - else - dllen = BIT0|BIT1; /* es2, clear bit0, and 1 (set phase to 72) */ - - /* enable & load up DLL with good value for 75MHz, and set phase to 90 - * ES1 recommends 90 phase, ES2 recommends 72 phase. - */ - if (common && (pass_type != IP_SDR)) { - __raw_writel(sdata->sdrc_dllab_ctrl, SDRC_DLLA_CTRL); - __raw_writel(sdata->sdrc_dllab_ctrl & ~(BIT2|dllen), SDRC_DLLA_CTRL); - __raw_writel(sdata->sdrc_dllab_ctrl, SDRC_DLLB_CTRL); - __raw_writel(sdata->sdrc_dllab_ctrl & ~(BIT2|dllen) , SDRC_DLLB_CTRL); - } - sdelay(90000); - - if(mem_ok()) - return; /* STACKED, other configued type */ - ++pass_type; /* IPDDR->COMBODDR->IPSDR for CS0 */ - goto next_mem_type; -} - -/***************************************************** - * gpmc_init(): init gpmc bus - * Init GPMC for x16, MuxMode (SDRAM in x32). - * This code can only be executed from SRAM or SDRAM. - *****************************************************/ -void gpmc_init(void) -{ - u32 mux=0, mtype, mwidth, rev, tval; - - rev = get_cpu_rev(); - if (rev == CPU_2420_2422_ES1) - tval = 1; - else - tval = 0; /* disable bit switched meaning */ - - /* global settings */ - __raw_writel(0x10, GPMC_SYSCONFIG); /* smart idle */ - __raw_writel(0x0, GPMC_IRQENABLE); /* isr's sources masked */ - __raw_writel(tval, GPMC_TIMEOUT_CONTROL);/* timeout disable */ -#ifdef CONFIG_SYS_NAND_BOOT - __raw_writel(0x001, GPMC_CONFIG); /* set nWP, disable limited addr */ -#else - __raw_writel(0x111, GPMC_CONFIG); /* set nWP, disable limited addr */ -#endif - - /* discover bus connection from sysboot */ - if (is_gpmc_muxed() == GPMC_MUXED) - mux = BIT9; - mtype = get_gpmc0_type(); - mwidth = get_gpmc0_width(); - - /* setup cs0 */ - __raw_writel(0x0, GPMC_CONFIG7_0); /* disable current map */ - sdelay(1000); - -#ifdef CONFIG_SYS_NAND_BOOT - __raw_writel(H4_24XX_GPMC_CONFIG1_0|mtype|mwidth, GPMC_CONFIG1_0); -#else - __raw_writel(H4_24XX_GPMC_CONFIG1_0|mux|mtype|mwidth, GPMC_CONFIG1_0); -#endif - -#ifdef PRCM_CONFIG_III - __raw_writel(H4_24XX_GPMC_CONFIG2_0, GPMC_CONFIG2_0); -#endif - __raw_writel(H4_24XX_GPMC_CONFIG3_0, GPMC_CONFIG3_0); - __raw_writel(H4_24XX_GPMC_CONFIG4_0, GPMC_CONFIG4_0); -#ifdef PRCM_CONFIG_III - __raw_writel(H4_24XX_GPMC_CONFIG5_0, GPMC_CONFIG5_0); - __raw_writel(H4_24XX_GPMC_CONFIG6_0, GPMC_CONFIG6_0); -#endif - __raw_writel(H4_24XX_GPMC_CONFIG7_0, GPMC_CONFIG7_0);/* enable new mapping */ - sdelay(2000); - - /* setup cs1 */ - __raw_writel(0, GPMC_CONFIG7_1); /* disable any mapping */ - sdelay(1000); - __raw_writel(H4_24XX_GPMC_CONFIG1_1|mux, GPMC_CONFIG1_1); - __raw_writel(H4_24XX_GPMC_CONFIG2_1, GPMC_CONFIG2_1); - __raw_writel(H4_24XX_GPMC_CONFIG3_1, GPMC_CONFIG3_1); - __raw_writel(H4_24XX_GPMC_CONFIG4_1, GPMC_CONFIG4_1); - __raw_writel(H4_24XX_GPMC_CONFIG5_1, GPMC_CONFIG5_1); - __raw_writel(H4_24XX_GPMC_CONFIG6_1, GPMC_CONFIG6_1); - __raw_writel(H4_24XX_GPMC_CONFIG7_1, GPMC_CONFIG7_1); /* enable mapping */ - sdelay(2000); -} diff --git a/board/ti/omap2420h4/omap2420h4.c b/board/ti/omap2420h4/omap2420h4.c deleted file mode 100644 index 532e989..0000000 --- a/board/ti/omap2420h4/omap2420h4.c +++ /dev/null @@ -1,867 +0,0 @@ -/* - * (C) Copyright 2004 - * Texas Instruments, <www.ti.com> - * Richard Woodruff r-woodruff2@ti.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ -#include <common.h> -#include <netdev.h> -#include <asm/arch/omap2420.h> -#include <asm/io.h> -#include <asm/arch/bits.h> -#include <asm/arch/mux.h> -#include <asm/arch/sys_proto.h> -#include <asm/arch/sys_info.h> -#include <asm/arch/mem.h> -#include <i2c.h> -#include <asm/mach-types.h> - -DECLARE_GLOBAL_DATA_PTR; - -void wait_for_command_complete(unsigned int wd_base); - -/******************************************************* - * Routine: delay - * Description: spinning delay to use before udelay works - ******************************************************/ -static inline void delay (unsigned long loops) -{ - __asm__ volatile ("1:\n" "subs %0, %1, #1\n" - "bne 1b":"=r" (loops):"0" (loops)); -} - -/***************************************** - * Routine: board_init - * Description: Early hardware init. - *****************************************/ -int board_init (void) -{ - gpmc_init(); /* in SRAM or SDRM, finish GPMC */ - - gd->bd->bi_arch_number = MACH_TYPE_OMAP_H4; /* board id for linux */ - gd->bd->bi_boot_params = (OMAP2420_SDRC_CS0+0x100); /* adress of boot parameters */ - - return 0; -} - -/********************************************************** - * Routine: try_unlock_sram() - * Description: If chip is GP type, unlock the SRAM for - * general use. - ***********************************************************/ -void try_unlock_sram(void) -{ - /* if GP device unlock device SRAM for general use */ - if (get_device_type() == GP_DEVICE) { - __raw_writel(0xFF, A_REQINFOPERM0); - __raw_writel(0xCFDE, A_READPERM0); - __raw_writel(0xCFDE, A_WRITEPERM0); - } -} - -/********************************************************** - * Routine: s_init - * Description: Does early system init of muxing and clocks. - * - Called path is with sram stack. - **********************************************************/ -void s_init(void) -{ - int in_sdram = running_in_sdram(); - - watchdog_init(); - set_muxconf_regs(); - delay(100); - try_unlock_sram(); - - if(!in_sdram) - prcm_init(); - - peripheral_enable(); - icache_enable(); - if (!in_sdram) - sdrc_init(); -} - -/******************************************************* - * Routine: misc_init_r - * Description: Init ethernet (done here so udelay works) - ********************************************************/ -int misc_init_r (void) -{ - ether_init(); /* better done here so timers are init'ed */ - return(0); -} - -/**************************************** - * Routine: watchdog_init - * Description: Shut down watch dogs - *****************************************/ -void watchdog_init(void) -{ - /* There are 4 watch dogs. 1 secure, and 3 general purpose. - * The ROM takes care of the secure one. Of the 3 GP ones, - * 1 can reset us directly, the other 2 only generate MPU interrupts. - */ - __raw_writel(WD_UNLOCK1 ,WD2_BASE+WSPR); - wait_for_command_complete(WD2_BASE); - __raw_writel(WD_UNLOCK2 ,WD2_BASE+WSPR); - -#if MPU_WD_CLOCKED /* value 0x10 stick on aptix, BIT4 polarity seems oppsite*/ - __raw_writel(WD_UNLOCK1 ,WD3_BASE+WSPR); - wait_for_command_complete(WD3_BASE); - __raw_writel(WD_UNLOCK2 ,WD3_BASE+WSPR); - - __raw_writel(WD_UNLOCK1 ,WD4_BASE+WSPR); - wait_for_command_complete(WD4_BASE); - __raw_writel(WD_UNLOCK2 ,WD4_BASE+WSPR); -#endif -} - -/****************************************************** - * Routine: wait_for_command_complete - * Description: Wait for posting to finish on watchdog - ******************************************************/ -void wait_for_command_complete(unsigned int wd_base) -{ - int pending = 1; - do { - pending = __raw_readl(wd_base+WWPS); - } while (pending); -} - -/******************************************************************* - * Routine:ether_init - * Description: take the Ethernet controller out of reset and wait - * for the EEPROM load to complete. - ******************************************************************/ -void ether_init (void) -{ -#ifdef CONFIG_LAN91C96 - int cnt = 20; - - __raw_writeb(0x3,OMAP2420_CTRL_BASE+0x10a); /*protect->gpio95 */ - - __raw_writew(0x0, LAN_RESET_REGISTER); - do { - __raw_writew(0x1, LAN_RESET_REGISTER); - udelay (100); - if (cnt == 0) - goto h4reset_err_out; - --cnt; - } while (__raw_readw(LAN_RESET_REGISTER) != 0x1); - - cnt = 20; - - do { - __raw_writew(0x0, LAN_RESET_REGISTER); - udelay (100); - if (cnt == 0) - goto h4reset_err_out; - --cnt; - } while (__raw_readw(LAN_RESET_REGISTER) != 0x0000); - udelay (1000); - - *((volatile unsigned char *) ETH_CONTROL_REG) &= ~0x01; - udelay (1000); - - h4reset_err_out: - return; -#endif -} - -/********************************************** - * Routine: dram_init - * Description: sets uboots idea of sdram size - **********************************************/ -int dram_init(void) -{ - unsigned int size0=0,size1=0; - u32 mtype, btype; - u8 chg_on = 0x5; /* enable charge of back up battery */ - u8 vmode_on = 0x8C; - #define NOT_EARLY 0 - - i2c_init (CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); /* need this a bit early */ - - btype = get_board_type(); - mtype = get_mem_type(); - - display_board_info(btype); - if (btype == BOARD_H4_MENELAUS){ - update_mux(btype,mtype); /* combo part on menelaus */ - i2c_write(I2C_MENELAUS, 0x20, 1, &chg_on, 1); /*fix POR reset bug */ - i2c_write(I2C_MENELAUS, 0x2, 1, &vmode_on, 1); /* VCORE change on VMODE */ - } - - if ((mtype == DDR_COMBO) || (mtype == DDR_STACKED)) { - do_sdrc_init(SDRC_CS1_OSET, NOT_EARLY); /* init other chip select */ - } - size0 = get_sdr_cs_size(SDRC_CS0_OSET); - size1 = get_sdr_cs_size(SDRC_CS1_OSET); - - gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, size0 + size1); - - return 0; -} - -void dram_init_banksize(void) -{ - unsigned int size0, size1; - u32 rev; - - rev = get_cpu_rev(); - size0 = get_sdr_cs_size(SDRC_CS0_OSET); - size1 = get_sdr_cs_size(SDRC_CS1_OSET); - - if(rev == CPU_2420_2422_ES1) /* ES1's 128MB remap granularity isn't worth doing */ - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - else /* ES2 and above can remap at 32MB granularity */ - gd->bd->bi_dram[1].start = PHYS_SDRAM_1+size0; - gd->bd->bi_dram[1].size = size1; - - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = size0; -} - -/********************************************************** - * Routine: set_muxconf_regs - * Description: Setting up the configuration Mux registers - * specific to the hardware - *********************************************************/ -void set_muxconf_regs (void) -{ - muxSetupSDRC(); - muxSetupGPMC(); - muxSetupUsb0(); - muxSetupUart3(); - muxSetupI2C1(); - muxSetupUART1(); - muxSetupLCD(); - muxSetupCamera(); - muxSetupMMCSD(); - muxSetupTouchScreen(); - muxSetupHDQ(); -} - -/***************************************************************** - * Routine: peripheral_enable - * Description: Enable the clks & power for perifs (GPT2, UART1,...) - ******************************************************************/ -void peripheral_enable(void) -{ - unsigned int v, if_clks=0, func_clks=0; - - /* Enable GP2 timer.*/ - if_clks |= BIT4; - func_clks |= BIT4; - v = __raw_readl(CM_CLKSEL2_CORE) | 0x4; /* Sys_clk input OMAP2420_GPT2 */ - __raw_writel(v, CM_CLKSEL2_CORE); - __raw_writel(0x1, CM_CLKSEL_WKUP); - -#ifdef CONFIG_SYS_NS16550 - /* Enable UART1 clock */ - func_clks |= BIT21; - if_clks |= BIT21; -#endif - v = __raw_readl(CM_ICLKEN1_CORE) | if_clks; /* Interface clocks on */ - __raw_writel(v,CM_ICLKEN1_CORE ); - v = __raw_readl(CM_FCLKEN1_CORE) | func_clks; /* Functional Clocks on */ - __raw_writel(v, CM_FCLKEN1_CORE); - delay(1000); - -#ifndef KERNEL_UPDATED - { -#define V1 0xffffffff -#define V2 0x00000007 - - __raw_writel(V1, CM_FCLKEN1_CORE); - __raw_writel(V2, CM_FCLKEN2_CORE); - __raw_writel(V1, CM_ICLKEN1_CORE); - __raw_writel(V1, CM_ICLKEN2_CORE); - } -#endif -} - -/**************************************** - * Routine: muxSetupUsb0 (ostboot) - * Description: Setup usb muxing - *****************************************/ -void muxSetupUsb0(void) -{ - volatile uint8 *MuxConfigReg; - volatile uint32 *otgCtrlReg; - - MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB0_PUEN; - *MuxConfigReg &= (uint8)(~0x1F); - - MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB0_VP; - *MuxConfigReg &= (uint8)(~0x1F); - - MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB0_VM; - *MuxConfigReg &= (uint8)(~0x1F); - - MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB0_RCV; - *MuxConfigReg &= (uint8)(~0x1F); - - MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB0_TXEN; - *MuxConfigReg &= (uint8)(~0x1F); - - MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB0_SE0; - *MuxConfigReg &= (uint8)(~0x1F); - - MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB0_DAT; - *MuxConfigReg &= (uint8)(~0x1F); - - /* setup for USB VBus detection */ - otgCtrlReg = (volatile uint32 *)USB_OTG_CTRL; - *otgCtrlReg |= 0x00040000; /* bit 18 */ -} - -/**************************************** - * Routine: muxSetupUart3 (ostboot) - * Description: Setup uart3 muxing - *****************************************/ -void muxSetupUart3(void) -{ - volatile uint8 *MuxConfigReg; - - MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_UART3_TX_IRTX; - *MuxConfigReg &= (uint8)(~0x1F); - - MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_UART3_RX_IRRX; - *MuxConfigReg &= (uint8)(~0x1F); -} - -/**************************************** - * Routine: muxSetupI2C1 (ostboot) - * Description: Setup i2c muxing - *****************************************/ -void muxSetupI2C1(void) -{ - volatile unsigned char *MuxConfigReg; - - /* I2C1 Clock pin configuration, PIN = M19 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_I2C1_SCL; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* I2C1 Data pin configuration, PIN = L15 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_I2C1_SDA; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* Pull-up required on data line */ - /* external pull-up already present. */ - /* *MuxConfigReg |= 0x18 ;*/ /* Mode = 0, PullTypeSel=PU, PullUDEnable=Enabled */ -} - -/**************************************** - * Routine: muxSetupUART1 (ostboot) - * Description: Set up uart1 muxing - *****************************************/ -void muxSetupUART1(void) -{ - volatile unsigned char *MuxConfigReg; - - /* UART1_CTS pin configuration, PIN = D21 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_UART1_CTS; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* UART1_RTS pin configuration, PIN = H21 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_UART1_RTS; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* UART1_TX pin configuration, PIN = L20 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_UART1_TX; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* UART1_RX pin configuration, PIN = T21 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_UART1_RX; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ -} - -/**************************************** - * Routine: muxSetupLCD (ostboot) - * Description: Setup lcd muxing - *****************************************/ -void muxSetupLCD(void) -{ - volatile unsigned char *MuxConfigReg; - - /* LCD_D0 pin configuration, PIN = Y7 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D0; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* LCD_D1 pin configuration, PIN = P10 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D1; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* LCD_D2 pin configuration, PIN = V8 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D2; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* LCD_D3 pin configuration, PIN = Y8 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D3; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* LCD_D4 pin configuration, PIN = W8 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D4; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* LCD_D5 pin configuration, PIN = R10 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D5; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* LCD_D6 pin configuration, PIN = Y9 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D6; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* LCD_D7 pin configuration, PIN = V9 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D7; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* LCD_D8 pin configuration, PIN = W9 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D8; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* LCD_D9 pin configuration, PIN = P11 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D9; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* LCD_D10 pin configuration, PIN = V10 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D10; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* LCD_D11 pin configuration, PIN = Y10 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D11; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* LCD_D12 pin configuration, PIN = W10 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D12; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* LCD_D13 pin configuration, PIN = R11 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D13; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* LCD_D14 pin configuration, PIN = V11 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D14; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* LCD_D15 pin configuration, PIN = W11 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D15; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* LCD_D16 pin configuration, PIN = P12 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D16; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* LCD_D17 pin configuration, PIN = R12 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D17; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* LCD_PCLK pin configuration, PIN = W6 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_PCLK; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* LCD_VSYNC pin configuration, PIN = V7 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_VSYNC; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* LCD_HSYNC pin configuration, PIN = Y6 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_HSYNC; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* LCD_ACBIAS pin configuration, PIN = W7 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_ACBIAS; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ -} - -/**************************************** - * Routine: muxSetupCamera (ostboot) - * Description: Setup camera muxing - *****************************************/ -void muxSetupCamera(void) -{ - volatile unsigned char *MuxConfigReg; - - /* CAMERA_RSTZ pin configuration, PIN = Y16 */ - /* CAM_RST is connected through the I2C IO expander.*/ - /* MuxConfigReg = (volatile unsigned char *), CONTROL_PADCONF_SYS_NRESWARM*/ - /* *MuxConfigReg = 0x00 ; / * Mode = 0, PUPD=Disabled */ - - /* CAMERA_XCLK pin configuration, PIN = U3 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_CAM_XCLK; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* CAMERA_LCLK pin configuration, PIN = V5 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_CAM_LCLK; - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* CAMERA_VSYNC pin configuration, PIN = U2 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_CAM_VS, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* CAMERA_HSYNC pin configuration, PIN = T3 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_CAM_HS, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* CAMERA_DAT0 pin configuration, PIN = T4 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_CAM_D0, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* CAMERA_DAT1 pin configuration, PIN = V2 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_CAM_D1, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* CAMERA_DAT2 pin configuration, PIN = V3 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_CAM_D2, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* CAMERA_DAT3 pin configuration, PIN = U4 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_CAM_D3, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* CAMERA_DAT4 pin configuration, PIN = W2 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_CAM_D4, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* CAMERA_DAT5 pin configuration, PIN = V4 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_CAM_D5, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* CAMERA_DAT6 pin configuration, PIN = W3 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_CAM_D6, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* CAMERA_DAT7 pin configuration, PIN = Y2 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_CAM_D7, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* CAMERA_DAT8 pin configuration, PIN = Y4 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_CAM_D8, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* CAMERA_DAT9 pin configuration, PIN = V6 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_CAM_D9, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ -} - -/**************************************** - * Routine: muxSetupMMCSD (ostboot) - * Description: set up MMC muxing - *****************************************/ -void muxSetupMMCSD(void) -{ - volatile unsigned char *MuxConfigReg; - - /* SDMMC_CLKI pin configuration, PIN = H15 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_CLKI, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* SDMMC_CLKO pin configuration, PIN = G19 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_CLKO, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* SDMMC_CMD pin configuration, PIN = H18 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_CMD, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - /* External pull-ups are present. */ - /* *MuxConfigReg |= 0x18 ; #/ PullUDEnable=Enabled, PullTypeSel=PU */ - - /* SDMMC_DAT0 pin configuration, PIN = F20 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_DAT0, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - /* External pull-ups are present. */ - /* *MuxConfigReg |= 0x18 ; #/ PullUDEnable=Enabled, PullTypeSel=PU */ - - /* SDMMC_DAT1 pin configuration, PIN = H14 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_DAT1, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - /* External pull-ups are present. */ - /* *MuxConfigReg |= 0x18 ; #/ PullUDEnable=Enabled, PullTypeSel=PU */ - - /* SDMMC_DAT2 pin configuration, PIN = E19 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_DAT2, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - /* External pull-ups are present. */ - /* *MuxConfigReg |= 0x18 ; #/ PullUDEnable=Enabled, PullTypeSel=PU */ - - /* SDMMC_DAT3 pin configuration, PIN = D19 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_DAT3, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - /* External pull-ups are present. */ - /* *MuxConfigReg |= 0x18 ; #/ PullUDEnable=Enabled, PullTypeSel=PU */ - - /* SDMMC_DDIR0 pin configuration, PIN = F19 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_DAT_DIR0, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* SDMMC_DDIR1 pin configuration, PIN = E20 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_DAT_DIR1, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* SDMMC_DDIR2 pin configuration, PIN = F18 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_DAT_DIR2, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* SDMMC_DDIR3 pin configuration, PIN = E18 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_DAT_DIR3, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* SDMMC_CDIR pin configuration, PIN = G18 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_CMD_DIR, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* MMC_CD pin configuration, PIN = B3 ---2420IP ONLY---*/ - /* MMC_CD for 2422IP=K1 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_SDRC_A14, - *MuxConfigReg = 0x03 ; /* Mode = 3, PUPD=Disabled */ - - /* MMC_WP pin configuration, PIN = B4 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_SDRC_A13, - *MuxConfigReg = 0x03 ; /* Mode = 3, PUPD=Disabled */ -} - -/****************************************** - * Routine: muxSetupTouchScreen (ostboot) - * Description: Set up touch screen muxing - *******************************************/ -void muxSetupTouchScreen(void) -{ - volatile unsigned char *MuxConfigReg; - - /* SPI1_CLK pin configuration, PIN = U18 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_SPI1_CLK, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* SPI1_MOSI pin configuration, PIN = V20 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_SPI1_SIMO, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* SPI1_MISO pin configuration, PIN = T18 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_SPI1_SOMI, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* SPI1_nCS0 pin configuration, PIN = U19 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_SPI1_NCS0, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ - - /* PEN_IRQ pin configuration, PIN = P20 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MCBSP1_FSR, - *MuxConfigReg = 0x03 ; /* Mode = 3, PUPD=Disabled */ -} - -/**************************************** - * Routine: muxSetupHDQ (ostboot) - * Description: setup 1wire mux - *****************************************/ -void muxSetupHDQ(void) -{ - volatile unsigned char *MuxConfigReg; - - /* HDQ_SIO pin configuration, PIN = N18 */ - MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_HDQ_SIO, - *MuxConfigReg = 0x00 ; /* Mode = 0, PUPD=Disabled */ -} - -/*************************************************************** - * Routine: muxSetupGPMC (ostboot) - * Description: Configures balls which cam up in protected mode - ***************************************************************/ -void muxSetupGPMC(void) -{ - volatile uint8 *MuxConfigReg; - volatile unsigned int *MCR = (volatile unsigned int *)0x4800008C; - - /* gpmc_io_dir */ - *MCR = 0x19000000; - - /* NOR FLASH CS0 */ - /* signal - Gpmc_clk; pin - J4; offset - 0x0088; mode - 0; Byte-3 Pull/up - N/A */ - MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_GPMC_D2_BYTE3, - *MuxConfigReg = 0x00 ; - - /* signal - Gpmc_iodir; pin - n2; offset - 0x008C; mode - 1; Byte-3 Pull/up - N/A */ - MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_GPMC_NCS0_BYTE3, - *MuxConfigReg = 0x01 ; - - /* MPDB(Multi Port Debug Port) CS1 */ - /* signal - gpmc_ncs1; pin - N8; offset - 0x008C; mode - 0; Byte-1 Pull/up - N/A */ - MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_GPMC_NCS0_BYTE1, - *MuxConfigReg = 0x00 ; - - /* signal - Gpmc_ncs2; pin - E2; offset - 0x008C; mode - 0; Byte-2 Pull/up - N/A */ - MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_GPMC_NCS0_BYTE2, - *MuxConfigReg = 0x00 ; -} - -/**************************************************************** - * Routine: muxSetupSDRC (ostboot) - * Description: Configures balls which come up in protected mode - ****************************************************************/ -void muxSetupSDRC(void) -{ - volatile uint8 *MuxConfigReg; - - /* signal - sdrc_ncs1; pin - C12; offset - 0x00A0; mode - 0; Byte-1 Pull/up - N/A */ - MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_SDRC_NCS0_BYTE1, - *MuxConfigReg = 0x00 ; - - /* signal - sdrc_a12; pin - D11; offset - 0x0030; mode - 0; Byte-2 Pull/up - N/A */ - MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_SDRC_A14_BYTE2, - *MuxConfigReg = 0x00 ; - - /* signal - sdrc_cke1; pin - B13; offset - 0x00A0; mode - 0; Byte-3 Pull/up - N/A */ - MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_SDRC_NCS0_BYTE3, - *MuxConfigReg = 0x00; - - if (get_cpu_type() == CPU_2422) { - MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_SDRC_A14_BYTE0, - *MuxConfigReg = 0x1b; - } -} - -/***************************************************************************** - * Routine: update_mux() - * Description: Update balls which are different beween boards. All should be - * updated to match functionaly. However, I'm only updating ones - * which I'll be using for now. When power comes into play they - * all need updating. - *****************************************************************************/ -void update_mux(u32 btype,u32 mtype) -{ - u32 cpu, base = OMAP2420_CTRL_BASE; - cpu = get_cpu_type(); - - if (btype == BOARD_H4_MENELAUS) { - if (cpu == CPU_2420) { - /* PIN = B3, GPIO.0->KBR5, mode 3, (pun?),-DO-*/ - __raw_writeb(0x3, base+0x30); - /* PIN = B13, GPIO.38->KBC6, mode 3, (pun?)-DO-*/ - __raw_writeb(0x3, base+0xa3); - /* PIN = F1, GPIO.25->HSUSBxx mode 3, (for external HS USB)*/ - /* PIN = H1, GPIO.26->HSUSBxx mode 3, (for external HS USB)*/ - /* PIN = K1, GPMC_ncs6 mode 0, (on board nand access)*/ - /* PIN = L2, GPMC_ncs67 mode 0, (for external HS USB)*/ - /* PIN = M1 (HSUSBOTG) */ - /* PIN = P1, GPIO.35->MEN_POK mode 3, (menelaus powerok)-DO-*/ - __raw_writeb(0x3, base+0x9d); - /* PIN = U32, (WLAN_CLKREQ) */ - /* PIN = Y11, WLAN */ - /* PIN = AA4, GPIO.15->KBC2, mode 3, -DO- */ - __raw_writeb(0x3, base+0xe7); - /* PIN = AA8, mDOC */ - /* PIN = AA10, BT */ - /* PIN = AA13, WLAN */ - /* PIN = M18 GPIO.96->MMC2_WP mode 3 -DO- */ - __raw_writeb(0x3, base+0x10e); - /* PIN = N19 GPIO.98->WLAN_INT mode 3 -DO- */ - __raw_writeb(0x3, base+0x110); - /* PIN = J15 HHUSB */ - /* PIN = H19 HSUSB */ - /* PIN = W13, P13, R13, W16 ... */ - /* PIN = V12 GPIO.25->I2C_CAMEN mode 3 -DO- */ - __raw_writeb(0x3, base+0xde); - /* PIN = W19 sys_nirq->MENELAUS_INT mode 0 -DO- */ - __raw_writeb(0x0, base+0x12c); - /* PIN = AA17->sys_clkreq mode 0 -DO- */ - __raw_writeb(0x0, base+0x136); - } else if (cpu == CPU_2422) { - /* PIN = B3, GPIO.0->nc, mode 3, set above (pun?)*/ - /* PIN = B13, GPIO.cke1->nc, mode 0, set above, (pun?)*/ - /* PIN = F1, GPIO.25->HSUSBxx mode 3, (for external HS USB)*/ - /* PIN = H1, GPIO.26->HSUSBxx mode 3, (for external HS USB)*/ - /* PIN = K1, GPMC_ncs6 mode 0, (on board nand access)*/ - __raw_writeb(0x0, base+0x92); - /* PIN = L2, GPMC_ncs67 mode 0, (for external HS USB)*/ - /* PIN = M1 (HSUSBOTG) */ - /* PIN = P1, GPIO.35->MEN_POK mode 3, (menelaus powerok)-DO-*/ - __raw_writeb(0x3, base+0x10c); - /* PIN = U32, (WLAN_CLKREQ) */ - /* PIN = AA4, GPIO.15->KBC2, mode 3, -DO- */ - __raw_writeb(0x3, base+0x30); - /* PIN = AA8, mDOC */ - /* PIN = AA10, BT */ - /* PIN = AA12, WLAN */ - /* PIN = M18 GPIO.96->MMC2_WP mode 3 -DO- */ - __raw_writeb(0x3, base+0x10e); - /* PIN = N19 GPIO.98->WLAN_INT mode 3 -DO- */ - __raw_writeb(0x3, base+0x110); - /* PIN = J15 HHUSB */ - /* PIN = H19 HSUSB */ - /* PIN = W13, P13, R13, W16 ... */ - /* PIN = V12 GPIO.25->I2C_CAMEN mode 3 -DO- */ - __raw_writeb(0x3, base+0xde); - /* PIN = W19 sys_nirq->MENELAUS_INT mode 0 -DO- */ - __raw_writeb(0x0, base+0x12c); - /* PIN = AA17->sys_clkreq mode 0 -DO- */ - __raw_writeb(0x0, base+0x136); - } - - } else if (btype == BOARD_H4_SDP) { - if (cpu == CPU_2420) { - /* PIN = B3, GPIO.0->nc mode 3, set above (pun?)*/ - /* PIN = B13, GPIO.cke1->nc, mode 0, set above, (pun?)*/ - /* Pin = Y11 VLNQ */ - /* Pin = AA4 VLNQ */ - /* Pin = AA6 VLNQ */ - /* Pin = AA8 VLNQ */ - /* Pin = AA10 VLNQ */ - /* Pin = AA12 VLNQ */ - /* PIN = M18 GPIO.96->KBR5 mode 3 -DO- */ - __raw_writeb(0x3, base+0x10e); - /* PIN = N19 GPIO.98->KBC6 mode 3 -DO- */ - __raw_writeb(0x3, base+0x110); - /* PIN = J15 MDOC_nDMAREQ */ - /* PIN = H19 GPIO.100->KBC2 mode 3 -DO- */ - __raw_writeb(0x3, base+0x114); - /* PIN = W13, V12, P13, R13, W19, W16 ... */ - /* PIN = AA17 sys_clkreq->bt_clk_req mode 0 */ - } else if (cpu == CPU_2422) { - /* PIN = B3, GPIO.0->MMC_CD, mode 3, set above */ - /* PIN = B13, GPIO.38->wlan_int, mode 3, (pun?)*/ - /* Pin = Y11 VLNQ */ - /* Pin = AA4 VLNQ */ - /* Pin = AA6 VLNQ */ - /* Pin = AA8 VLNQ */ - /* Pin = AA10 VLNQ */ - /* Pin = AA12 VLNQ */ - /* PIN = M18 GPIO.96->KBR5 mode 3 -DO- */ - __raw_writeb(0x3, base+0x10e); - /* PIN = N19 GPIO.98->KBC6 mode 3 -DO- */ - __raw_writeb(0x3, base+0x110); - /* PIN = J15 MDOC_nDMAREQ */ - /* PIN = H19 GPIO.100->KBC2 mode 3 -DO- */ - __raw_writeb(0x3, base+0x114); - /* PIN = W13, V12, P13, R13, W19, W16 ... */ - /* PIN = AA17 sys_clkreq->bt_clk_req mode 0 */ - } - } -} - -#ifdef CONFIG_CMD_NET -int board_eth_init(bd_t *bis) -{ - int rc = 0; -#ifdef CONFIG_LAN91C96 - rc = lan91c96_initialize(0, CONFIG_LAN91C96_BASE); -#endif - return rc; -} -#endif diff --git a/board/ti/omap2420h4/sys_info.c b/board/ti/omap2420h4/sys_info.c deleted file mode 100644 index b12011e..0000000 --- a/board/ti/omap2420h4/sys_info.c +++ /dev/null @@ -1,387 +0,0 @@ -/* - * (C) Copyright 2004 - * Texas Instruments, <www.ti.com> - * Richard Woodruff r-woodruff2@ti.com - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR /PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/arch/omap2420.h> -#include <asm/io.h> -#include <asm/arch/bits.h> -#include <asm/arch/mem.h> /* get mem tables */ -#include <asm/arch/sys_proto.h> -#include <asm/arch/sys_info.h> -#include <i2c.h> - -/************************************************************************** - * get_prod_id() - get id info from chips - ***************************************************************************/ -static u32 get_prod_id(void) -{ - u32 p; - p = __raw_readl(PRODUCTION_ID); /* get production ID */ - return((p & CPU_242X_PID_MASK) >> 16); -} - -/************************************************************************** - * get_cpu_type() - low level get cpu type - * - no C globals yet. - * - just looking to say if this is a 2422 or 2420 or ... - * - to start with we will look at switch settings.. - * - 2422 id's same as 2420 for ES1 will rely on H4 board characteristics - * (mux for 2420, non-mux for 2422). - ***************************************************************************/ -u32 get_cpu_type(void) -{ - u32 v; - - switch(get_prod_id()){ - case 1:;/* 2420 */ - case 2: return(CPU_2420); break; /* 2420 pop */ - case 4: return(CPU_2422); break; - case 8: return(CPU_2423); break; - default: break; /* early 2420/2422's unmarked */ - } - - v = __raw_readl(TAP_IDCODE_REG); - v &= CPU_24XX_ID_MASK; - if (v == CPU_2420_CHIPID) { /* currently 2420 and 2422 have same id */ - if (is_gpmc_muxed() == GPMC_MUXED) /* if mux'ed */ - return(CPU_2420); - else - return(CPU_2422); - } else - return(CPU_2420); /* don't know, say 2420 */ -} - -/****************************************** - * get_cpu_rev(void) - extract version info - ******************************************/ -u32 get_cpu_rev(void) -{ - u32 v; - v = __raw_readl(TAP_IDCODE_REG); - v = v >> 28; - return(v+1); /* currently 2422 and 2420 match up */ -} -/**************************************************** - * is_mem_sdr() - return 1 if mem type in use is SDR - ****************************************************/ -u32 is_mem_sdr(void) -{ - volatile u32 *burst = (volatile u32 *)(SDRC_MR_0+SDRC_CS0_OSET); - if(*burst == H4_2420_SDRC_MR_0_SDR) - return(1); - return(0); -} - -/*********************************************************** - * get_mem_type() - identify type of mDDR part used. - * 2422 uses stacked DDR, 2 parts CS0/CS1. - * 2420 may have 1 or 2, no good way to know...only init 1... - * when eeprom data is up we can select 1 more. - *************************************************************/ -u32 get_mem_type(void) -{ - u32 cpu, sdr = is_mem_sdr(); - - cpu = get_cpu_type(); - if (cpu == CPU_2422 || cpu == CPU_2423) - return(DDR_STACKED); - - if(get_prod_id() == 0x2) - return(XDR_POP); - - if (get_board_type() == BOARD_H4_MENELAUS) - if(sdr) - return(SDR_DISCRETE); - else - return(DDR_COMBO); - else - if(sdr) /* SDP + SDR kit */ - return(SDR_DISCRETE); - else - return(DDR_DISCRETE); /* origional SDP */ -} - -/*********************************************************************** - * get_cs0_size() - get size of chip select 0/1 - ************************************************************************/ -u32 get_sdr_cs_size(u32 offset) -{ - u32 size; - size = __raw_readl(SDRC_MCFG_0+offset) >> 8; /* get ram size field */ - size &= 0x2FF; /* remove unwanted bits */ - size *= SZ_2M; /* find size in MB */ - return(size); -} - -/*********************************************************************** - * get_board_type() - get board type based on current production stats. - * --- NOTE: 2 I2C EEPROMs will someday be populated with proper info. - * when they are available we can get info from there. This should - * be correct of all known boards up until today. - ************************************************************************/ -u32 get_board_type(void) -{ - if (i2c_probe(I2C_MENELAUS) == 0) - return(BOARD_H4_MENELAUS); - else - return(BOARD_H4_SDP); -} - -/****************************************************************** - * get_sysboot_value() - get init word settings (dip switch on h4) - ******************************************************************/ -inline u32 get_sysboot_value(void) -{ - return(0x00000FFF & __raw_readl(CONTROL_STATUS)); -} - -/*************************************************************************** - * get_gpmc0_base() - Return current address hardware will be - * fetching from. The below effectively gives what is correct, its a bit - * mis-leading compared to the TRM. For the most general case the mask - * needs to be also taken into account this does work in practice. - * - for u-boot we currently map: - * -- 0 to nothing, - * -- 4 to flash - * -- 8 to enent - * -- c to wifi - ****************************************************************************/ -u32 get_gpmc0_base(void) -{ - u32 b; - - b = __raw_readl(GPMC_CONFIG7_0); - b &= 0x1F; /* keep base [5:0] */ - b = b << 24; /* ret 0x0b000000 */ - return(b); -} - -/***************************************************************** - * is_gpmc_muxed() - tells if address/data lines are multiplexed - *****************************************************************/ -u32 is_gpmc_muxed(void) -{ - u32 mux; - mux = get_sysboot_value(); - if ((mux & (BIT0 | BIT1 | BIT2 | BIT3)) == (BIT0 | BIT2 | BIT3)) - return(GPMC_MUXED); /* NAND Boot mode */ - if (mux & BIT1) /* if mux'ed */ - return(GPMC_MUXED); - else - return(GPMC_NONMUXED); -} - -/************************************************************************ - * get_gpmc0_type() - read sysboot lines to see type of memory attached - ************************************************************************/ -u32 get_gpmc0_type(void) -{ - u32 type; - type = get_sysboot_value(); - if ((type & (BIT3|BIT2)) == (BIT3|BIT2)) - return(TYPE_NAND); - else - return(TYPE_NOR); -} - -/******************************************************************* - * get_gpmc0_width() - See if bus is in x8 or x16 (mainly for nand) - *******************************************************************/ -u32 get_gpmc0_width(void) -{ - u32 width; - width = get_sysboot_value(); - if ((width & 0xF) == (BIT3|BIT2)) - return(WIDTH_8BIT); - else - return(WIDTH_16BIT); -} - -/********************************************************************* - * wait_on_value() - common routine to allow waiting for changes in - * volatile regs. - *********************************************************************/ -u32 wait_on_value(u32 read_bit_mask, u32 match_value, u32 read_addr, u32 bound) -{ - u32 i = 0, val; - do { - ++i; - val = __raw_readl(read_addr) & read_bit_mask; - if (val == match_value) - return(1); - if (i==bound) - return(0); - } while (1); -} - -/********************************************************************* - * display_board_info() - print banner with board info. - *********************************************************************/ -void display_board_info(u32 btype) -{ - static const char cpu_2420 [] = "2420"; /* cpu type */ - static const char cpu_2422 [] = "2422"; - static const char cpu_2423 [] = "2423"; - static const char db_men [] = "Menelaus"; /* board type */ - static const char db_ip [] = "IP"; - static const char mem_sdr [] = "mSDR"; /* memory type */ - static const char mem_ddr [] = "mDDR"; - static const char t_tst [] = "TST"; /* security level */ - static const char t_emu [] = "EMU"; - static const char t_hs [] = "HS"; - static const char t_gp [] = "GP"; - static const char unk [] = "?"; - - const char *cpu_s, *db_s, *mem_s, *sec_s; - u32 cpu, rev, sec; - - rev = get_cpu_rev(); - cpu = get_cpu_type(); - sec = get_device_type(); - - if(is_mem_sdr()) - mem_s = mem_sdr; - else - mem_s = mem_ddr; - - if(cpu == CPU_2423) - cpu_s = cpu_2423; - else if (cpu == CPU_2422) - cpu_s = cpu_2422; - else - cpu_s = cpu_2420; - - if(btype == BOARD_H4_MENELAUS) - db_s = db_men; - else - db_s = db_ip; - - switch(sec){ - case TST_DEVICE: sec_s = t_tst; break; - case EMU_DEVICE: sec_s = t_emu; break; - case HS_DEVICE: sec_s = t_hs; break; - case GP_DEVICE: sec_s = t_gp; break; - default: sec_s = unk; - } - - printf("OMAP%s-%s revision %d\n", cpu_s, sec_s, rev-1); - printf("TI H4 SDP Base Board + %s Daughter Board + %s \n", db_s, mem_s); -} - -/************************************************************************* - * get_board_rev() - setup to pass kernel board revision information - * 0 = 242x IP platform (first 2xx boards) - * 1 = 242x Menelaus platfrom. - *************************************************************************/ -u32 get_board_rev(void) -{ - u32 rev = 0; - u32 btype = get_board_type(); - - if (btype == BOARD_H4_MENELAUS){ - rev = 1; - } - return(rev); -} - -/******************************************************** - * get_base(); get upper addr of current execution - *******************************************************/ -u32 get_base(void) -{ - u32 val; - __asm__ __volatile__("mov %0, pc \n" : "=r" (val) : : "memory"); - val &= 0xF0000000; - val >>= 28; - return(val); -} - -/******************************************************** - * get_base2(); get 2upper addr of current execution - *******************************************************/ -u32 get_base2(void) -{ - u32 val; - __asm__ __volatile__("mov %0, pc \n" : "=r" (val) : : "memory"); - val &= 0xFF000000; - val >>= 24; - return(val); -} - -/******************************************************** - * running_in_flash() - tell if currently running in - * flash. - *******************************************************/ -u32 running_in_flash(void) -{ - if (get_base() < 4) - return(1); /* in flash */ - return(0); /* running in SRAM or SDRAM */ -} - -/******************************************************** - * running_in_sram() - tell if currently running in - * sram. - *******************************************************/ -u32 running_in_sram(void) -{ - if (get_base() == 4) - return(1); /* in SRAM */ - return(0); /* running in FLASH or SDRAM */ -} -/******************************************************** - * running_in_sdram() - tell if currently running in - * flash. - *******************************************************/ -u32 running_in_sdram(void) -{ - if (get_base() > 4) - return(1); /* in sdram */ - return(0); /* running in SRAM or FLASH */ -} - -/************************************************************* - * running_from_internal_boot() - am I a signed NOR image. - *************************************************************/ -u32 running_from_internal_boot(void) -{ - u32 v, base; - - v = get_sysboot_value() & BIT3; - base = get_base2(); - /* if running at mask rom flash address and - * sysboot3 says this was an internal boot - */ - if ((base == 0x08) && v) - return(1); - else - return(0); -} - -/************************************************************* - * get_device_type(): tell if GP/HS/EMU/TST - *************************************************************/ -u32 get_device_type(void) -{ - int mode; - mode = __raw_readl(CONTROL_STATUS) & (BIT10|BIT9|BIT8); - return(mode >>= 8); -} diff --git a/boards.cfg b/boards.cfg index e2a8d42..627db1f 100644 --- a/boards.cfg +++ b/boards.cfg @@ -52,8 +52,6 @@ flea3 arm arm1136 - CarMedi mx35pdk arm arm1136 - freescale mx35 woodburn arm arm1136 - - mx35 woodburn_sd arm arm1136 woodburn - mx35 woodburn_sd:IMX_CONFIG=board/woodburn/imximage.cfg -omap2420h4 arm arm1136 - ti omap24xx -tnetv107x_evm arm arm1176 tnetv107xevm ti tnetv107x rpi_b arm arm1176 rpi_b raspberrypi bcm2835 integratorap_cm720t arm arm720t integrator armltd - integratorap:CM720T integratorap_cm920t arm arm920t integrator armltd - integratorap:CM920T diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 9223f6e..a0f1fa3 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -96,3 +96,4 @@ R5200 ColdFire - 48ead7a 2008-03-31 Zachary P. L CPCI440 powerpc 440GP b568fd2 2007-12-27 Matthias Fuchs matthias.fuchs@esd-electronics.com PCIPPC2 powerpc MPC740/MPC750 7c9e89b 2013-02-07 Wolfgang Denk wd@denx.de PCIPPC6 powerpc MPC740/MPC750 - - Wolfgang Denk wd@denx.de +omap2420h4 arm omap24xx - 2013-06-04 Richard Woodruff r-woodruff2@ti.com diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index 7f013ab..d77c25f 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -74,13 +74,8 @@ void NS16550_init(NS16550_t com_port, int baud_divisor) defined(CONFIG_AM33XX) || defined(CONFIG_SOC_DA8XX) || \ defined(CONFIG_TI814X)
-#if defined(CONFIG_APTIX) - /* /13 mode so Aptix 6MHz can hit 115200 */ - serial_out(3, &com_port->mdr1); -#else /* /16 is proper to hit 115200 with 48MHz */ serial_out(0, &com_port->mdr1); -#endif #endif /* CONFIG_OMAP */ }
diff --git a/drivers/serial/serial_ns16550.c b/drivers/serial/serial_ns16550.c index b92eef4..3c07da3 100644 --- a/drivers/serial/serial_ns16550.c +++ b/drivers/serial/serial_ns16550.c @@ -151,12 +151,7 @@ static int calc_divisor (NS16550_t port) } #endif
-#ifdef CONFIG_APTIX -#define MODE_X_DIV 13 -#else #define MODE_X_DIV 16 -#endif - /* Compute divisor value. Normally, we should simply return: * CONFIG_SYS_NS16550_CLK) / MODE_X_DIV / gd->baudrate * but we need to round that value by adding 0.5. diff --git a/include/configs/omap2420h4.h b/include/configs/omap2420h4.h deleted file mode 100644 index 04e8d3a..0000000 --- a/include/configs/omap2420h4.h +++ /dev/null @@ -1,264 +0,0 @@ -/* - * (C) Copyright 2004 - * Texas Instruments. - * Richard Woodruff r-woodruff2@ti.com - * Kshitij Gupta kshitij@ti.com - * - * Configuration settings for the 242x TI H4 board. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - */ -#define CONFIG_ARM1136 1 /* This is an arm1136 CPU core */ -#define CONFIG_OMAP 1 /* in a TI OMAP core */ -#define CONFIG_OMAP2420 1 /* which is in a 2420 */ -#define CONFIG_OMAP2420H4 1 /* and on a H4 board */ -/*#define CONFIG_APTIX 1 #* define if on APTIX test chip */ -/*#define CONFIG_VIRTIO 1 #* Using Virtio simulator */ - -#define CONFIG_STANDALONE_LOAD_ADDR 0x80300000 - -/* Clock config to target*/ -#define PRCM_CONFIG_II 1 -/* #define PRCM_CONFIG_III 1 */ - -#include <asm/arch/omap2420.h> /* get chip and board defs */ - -/* On H4, NOR and NAND flash are mutual exclusive. - Define this if you want to use NAND - */ -/*#define CONFIG_SYS_NAND_BOOT */ - -#ifdef CONFIG_APTIX -#define V_SCLK 1500000 -#else -#define V_SCLK 12000000 -#endif - -/* input clock of PLL */ -/* the OMAP2420 H4 has 12MHz, 13MHz, or 19.2Mhz crystal input */ -#define CONFIG_SYS_CLK_FREQ V_SCLK - -#define CONFIG_MISC_INIT_R - -#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ -#define CONFIG_SETUP_MEMORY_TAGS 1 -#define CONFIG_INITRD_TAG 1 -#define CONFIG_REVISION_TAG 1 -#define CONFIG_OF_LIBFDT - -/* - * Size of malloc() pool - */ -#define CONFIG_ENV_SIZE SZ_128K /* Total Size of Environment Sector */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + SZ_128K) - -/* - * Hardware drivers - */ - -/* - * SMC91c96 Etherent - */ -#define CONFIG_LAN91C96 -#define CONFIG_LAN91C96_BASE (H4_CS1_BASE+0x300) -#define CONFIG_LAN91C96_EXT_PHY - -/* - * NS16550 Configuration - */ -#ifdef CONFIG_APTIX -#define V_NS16550_CLK (6000000) /* 6MHz in current MaxSet */ -#else -#define V_NS16550_CLK (48000000) /* 48MHz (APLL96/2) */ -#endif - -#define CONFIG_SYS_NS16550 -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE (-4) -#define CONFIG_SYS_NS16550_CLK V_NS16550_CLK /* 3MHz (1.5MHz*2) */ -#define CONFIG_SYS_NS16550_COM1 OMAP2420_UART1 - -/* - * select serial console configuration - */ -#define CONFIG_SERIAL1 1 /* UART1 on H4 */ - - /* - * I2C configuration - */ -#define CONFIG_HARD_I2C -#define CONFIG_SYS_I2C_SPEED 100000 -#define CONFIG_SYS_I2C_SLAVE 1 -#define CONFIG_DRIVER_OMAP24XX_I2C - -/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE -#define CONFIG_CONS_INDEX 1 -#define CONFIG_BAUDRATE 115200 - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#ifdef CONFIG_SYS_NAND_BOOT - #define CONFIG_CMD_DHCP - #define CONFIG_CMD_I2C - #define CONFIG_CMD_NAND - #define CONFIG_CMD_JFFS2 -#else - #define CONFIG_CMD_DHCP - #define CONFIG_CMD_I2C - #define CONFIG_CMD_JFFS2 - - #undef CONFIG_CMD_SOURCE -#endif - - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH - -#define CONFIG_BOOTDELAY 3 - -#ifdef NFS_BOOT_DEFAULTS -#define CONFIG_BOOTARGS "mem=32M console=ttyS0,115200n8 noinitrd root=/dev/nfs rw nfsroot=128.247.77.158:/home/a0384864/wtbu/rootfs ip=dhcp" -#else -#define CONFIG_BOOTARGS "root=/dev/ram0 rw mem=32M console=ttyS0,115200n8 initrd=0x80600000,8M ramdisk_size=8192" -#endif - -#define CONFIG_NETMASK 255.255.254.0 -#define CONFIG_IPADDR 128.247.77.90 -#define CONFIG_SERVERIP 128.247.77.158 -#define CONFIG_BOOTFILE "uImage" - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#ifdef CONFIG_APTIX -# define CONFIG_SYS_PROMPT "OMAP2420 Aptix # " -#else -# define CONFIG_SYS_PROMPT "OMAP242x H4 # " -#endif -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START (OMAP2420_SDRC_CS0) /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END (OMAP2420_SDRC_CS0+SZ_31M) - -#define CONFIG_SYS_LOAD_ADDR (OMAP2420_SDRC_CS0) /* default load address */ - -/* The 2420 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) or by - * 32KHz clk, or from external sig. This rate is divided by a local divisor. - */ -#ifdef CONFIG_APTIX -#define V_PTV 3 -#else -#define V_PTV 7 /* use with 12MHz/128 */ -#endif - -#define CONFIG_SYS_TIMERBASE OMAP2420_GPT2 -#define CONFIG_SYS_PTV V_PTV /* 2^(PTV+1) */ -#define CONFIG_SYS_HZ 1000 - -/*----------------------------------------------------------------------- - * Physical Memory Map - */ -#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ -#define PHYS_SDRAM_1 OMAP2420_SDRC_CS0 -#define PHYS_SDRAM_1_SIZE SZ_32M /* at least 32 meg */ -#define PHYS_SDRAM_2 OMAP2420_SDRC_CS1 - -#define PHYS_FLASH_SECT_SIZE SZ_128K -#define PHYS_FLASH_1 H4_CS0_BASE /* Flash Bank #1 */ -#define PHYS_FLASH_SIZE_1 SZ_32M -#define PHYS_FLASH_2 (H4_CS0_BASE+SZ_32M) /* same cs, 2 chips in series */ -#define PHYS_FLASH_SIZE_2 SZ_32M - -#define PHYS_SRAM 0x4020F800 -/*----------------------------------------------------------------------- - * FLASH and environment organization - */ -#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT (259) /* max number of sectors on one chip */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE /* Monitor at beginning of flash */ -#define CONFIG_SYS_MONITOR_LEN SZ_128K /* Reserve 1 sector */ -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE + PHYS_FLASH_SIZE_1 } - -#ifdef CONFIG_SYS_NAND_BOOT -#define CONFIG_ENV_IS_IN_NAND 1 -#define CONFIG_ENV_OFFSET 0x80000 /* environment starts here */ -#else -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + SZ_256K) -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_SECT_SIZE PHYS_FLASH_SECT_SIZE -#define CONFIG_ENV_OFFSET ( CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN ) /* Environment after Monitor */ -#endif - -/*----------------------------------------------------------------------- - * CFI FLASH driver setup - */ -#define CONFIG_SYS_FLASH_CFI 1 /* Flash memory is CFI compliant */ -#define CONFIG_FLASH_CFI_DRIVER 1 /* Use drivers/mtd/cfi_flash.c */ -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 /* Use buffered writes (~10x faster) */ -#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use hardware sector protection */ - -/* timeout values are in ticks */ -#define CONFIG_SYS_FLASH_ERASE_TOUT (100*CONFIG_SYS_HZ) /* Timeout for Flash Erase */ -#define CONFIG_SYS_FLASH_WRITE_TOUT (100*CONFIG_SYS_HZ) /* Timeout for Flash Write */ - -#define CONFIG_SYS_JFFS2_MEM_NAND - -/* - * JFFS2 partitions - */ -/* No command line, one static partition, whole device */ -#undef CONFIG_CMD_MTDPARTS -#define CONFIG_JFFS2_DEV "nor1" -#define CONFIG_JFFS2_PART_SIZE 0xFFFFFFFF -#define CONFIG_JFFS2_PART_OFFSET 0x00000000 - -/* mtdparts command line support */ -/* Note: fake mtd_id used, no linux mtd map file */ -/* -#define CONFIG_CMD_MTDPARTS -#define MTDIDS_DEFAULT "nor1=omap2420-1" -#define MTDPARTS_DEFAULT "mtdparts=omap2420-1:-(jffs2)" -*/ - -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_SP_ADDR PHYS_SRAM - -#endif /* __CONFIG_H */
