[U-Boot] [PATCH 1/2] env_nand: remove unused variable.
Remove an unused "total" variable in multiple functions.
Signed-off-by: Guennadi Liakhovetski lg@denx.de --- common/env_nand.c | 10 ---------- 1 files changed, 0 insertions(+), 10 deletions(-)
diff --git a/common/env_nand.c b/common/env_nand.c index 76569da..21bce25 100644 --- a/common/env_nand.c +++ b/common/env_nand.c @@ -103,12 +103,9 @@ uchar env_get_char_spec (int index) int env_init(void) { #if defined(ENV_IS_EMBEDDED) - size_t total; int crc1_ok = 0, crc2_ok = 0; env_t *tmp_env1, *tmp_env2;
- total = CONFIG_ENV_SIZE; - tmp_env1 = env_ptr; tmp_env2 = (env_t *)((ulong)env_ptr + CONFIG_ENV_SIZE);
@@ -183,12 +180,10 @@ int writeenv(size_t offset, u_char *buf) #ifdef CONFIG_ENV_OFFSET_REDUND int saveenv(void) { - size_t total; int ret = 0; nand_erase_options_t nand_erase_options;
env_ptr->flags++; - total = CONFIG_ENV_SIZE;
nand_erase_options.length = CONFIG_ENV_RANGE; nand_erase_options.quiet = 0; @@ -226,7 +221,6 @@ int saveenv(void) #else /* ! CONFIG_ENV_OFFSET_REDUND */ int saveenv(void) { - size_t total; int ret = 0; nand_erase_options_t nand_erase_options;
@@ -243,7 +237,6 @@ int saveenv(void) return 1;
puts ("Writing to Nand... "); - total = CONFIG_ENV_SIZE; if (writeenv(CONFIG_ENV_OFFSET, (u_char *) env_ptr)) { puts("FAILED!\n"); return 1; @@ -287,12 +280,9 @@ int readenv (size_t offset, u_char * buf) void env_relocate_spec (void) { #if !defined(ENV_IS_EMBEDDED) - size_t total; int crc1_ok = 0, crc2_ok = 0; env_t *tmp_env1, *tmp_env2;
- total = CONFIG_ENV_SIZE; - tmp_env1 = (env_t *) malloc(CONFIG_ENV_SIZE); tmp_env2 = (env_t *) malloc(CONFIG_ENV_SIZE);
Applied to u-boot-nand-flash/next
-Scott
Scott Wood
