[U-Boot] [PATCH 1/3] qe: add u-qe support to arm board
ls1021 is arm-core and support qe which is u-qe. add u-qe init for arm board.
Signed-off-by: Zhao Qiang B45475@freescale.com --- arch/arm/include/asm/arch-ls102xa/config.h | 4 ++++ arch/arm/include/asm/global_data.h | 8 ++++++++ drivers/Makefile | 1 + drivers/qe/Makefile | 3 ++- drivers/qe/fdt.c | 2 ++ drivers/qe/qe.c | 15 +++++++++++++++ drivers/qe/qe.h | 1 + 7 files changed, 33 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index a500b5b..9c1b520 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -69,6 +69,10 @@
#define DCU_LAYER_MAX_NUM 16
+#define QE_MURAM_SIZE 0x6000UL +#define MAX_QE_RISC 1 +#define QE_NUM_OF_SNUM 28 + #define CONFIG_SYS_FSL_SRDS_1
#ifdef CONFIG_LS102XA diff --git a/arch/arm/include/asm/global_data.h b/arch/arm/include/asm/global_data.h index c69d064..438f128 100644 --- a/arch/arm/include/asm/global_data.h +++ b/arch/arm/include/asm/global_data.h @@ -17,6 +17,14 @@ struct arch_global_data { #if defined(CONFIG_FSL_ESDHC) u32 sdhc_clk; #endif + +#if defined(CONFIG_U_QE) + u32 qe_clk; + u32 brg_clk; + uint mp_alloc_base; + uint mp_alloc_top; +#endif /* CONFIG_U_QE */ + #ifdef CONFIG_AT91FAMILY /* "static data" needed by at91's clock.c */ unsigned long cpu_clk_rate_hz; diff --git a/drivers/Makefile b/drivers/Makefile index d8361d9..5ff3943 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -16,6 +16,7 @@ obj-y += twserial/ obj-y += video/ obj-y += watchdog/ obj-$(CONFIG_QE) += qe/ +obj-$(CONFIG_U_QE) += qe/ obj-y += memory/ obj-y += pwm/ obj-y += input/ diff --git a/drivers/qe/Makefile b/drivers/qe/Makefile index 7f1bd06..8fa4866 100644 --- a/drivers/qe/Makefile +++ b/drivers/qe/Makefile @@ -4,5 +4,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y := qe.o uccf.o uec.o uec_phy.o +obj-$(CONFIG_QE) += qe.o uccf.o uec.o uec_phy.o +obj-$(CONFIG_U_QE) += qe.o obj-$(CONFIG_OF_LIBFDT) += fdt.o diff --git a/drivers/qe/fdt.c b/drivers/qe/fdt.c index d9a7d82..dfae4bf 100644 --- a/drivers/qe/fdt.c +++ b/drivers/qe/fdt.c @@ -12,6 +12,7 @@ #include <fdt_support.h> #include "qe.h"
+#ifdef CONFIG_QE DECLARE_GLOBAL_DATA_PTR;
/* @@ -72,3 +73,4 @@ void ft_qe_setup(void *blob) "clock-frequency", gd->arch.qe_clk / 2, 1); fdt_fixup_qe_firmware(blob); } +#endif diff --git a/drivers/qe/qe.c b/drivers/qe/qe.c index 4358a91..b545ec9 100644 --- a/drivers/qe/qe.c +++ b/drivers/qe/qe.c @@ -40,6 +40,7 @@ void qe_issue_cmd(uint cmd, uint sbc, u8 mcn, u32 cmd_data) return; }
+#ifdef CONFIG_QE uint qe_muram_alloc(uint size, uint align) { uint retloc; @@ -70,6 +71,7 @@ uint qe_muram_alloc(uint size, uint align)
return retloc; } +#endif
void *qe_muram_addr(uint offset) { @@ -180,6 +182,17 @@ void qe_init(uint qe_base) qe_snums_init(); }
+#ifdef CONFIG_U_QE +void u_qe_init(void) +{ + uint qe_base = CONFIG_SYS_IMMR + 0x01400000; /* QE immr base */ + qe_immr = (qe_map_t *)qe_base; + + qe_upload_firmware((const void *)CONFIG_SYS_QE_FW_ADDR); + out_be32(&qe_immr->iram.iready, QE_IRAM_READY); +} +#endif + void qe_reset(void) { qe_issue_cmd(QE_RESET, QE_CR_SUBBLOCK_INVALID, @@ -212,6 +225,7 @@ void qe_assign_page(uint snum, uint para_ram_base)
#define BRG_CLK (gd->arch.brg_clk)
+#ifdef CONFIG_QE int qe_set_brg(uint brg, uint rate) { volatile uint *bp; @@ -239,6 +253,7 @@ int qe_set_brg(uint brg, uint rate)
return 0; } +#endif
/* Set ethernet MII clock master */ diff --git a/drivers/qe/qe.h b/drivers/qe/qe.h index ebb7c5f..30484b8 100644 --- a/drivers/qe/qe.h +++ b/drivers/qe/qe.h @@ -275,6 +275,7 @@ void *qe_muram_addr(uint offset); int qe_get_snum(void); void qe_put_snum(u8 snum); void qe_init(uint qe_base); +void u_qe_init(void); void qe_reset(void); void qe_assign_page(uint snum, uint para_ram_base); int qe_set_brg(uint brg, uint rate);
add qe support MACRO to ls1021aqds head file
Signed-off-by: Zhao Qiang qiang.zhao@freescale.com --- board/freescale/ls1021aqds/ls1021aqds.c | 8 ++++++++ include/configs/ls1021aqds.h | 6 ++++++ 2 files changed, 14 insertions(+)
diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index 12e83f7..3bc4a68 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -16,6 +16,9 @@
#include "../common/qixis.h" #include "ls1021aqds_qixis.h" +#ifdef CONFIG_U_QE +#include "../../../drivers/qe/qe.h" +#endif
@@ -227,6 +230,11 @@ int board_init(void) fsl_serdes_init(); config_serdes_mux(); #endif + +#ifdef CONFIG_U_QE + u_qe_init(); +#endif + return 0; }
diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index bb47813..ee23af4 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -69,6 +69,10 @@ unsigned long get_board_ddr_clk(void);
#define CONFIG_SYS_HAS_SERDES
+#if !defined(CONFIG_SDCARD) && !defined(CONFIG_NAND) && !defined(CONFIG_SPI) +#define CONFIG_U_QE +#endif + /* * IFC Definitions */ @@ -331,6 +335,8 @@ unsigned long get_board_ddr_clk(void);
#define CONFIG_BOOTDELAY 3
+#define CONFIG_SYS_QE_FW_ADDR 0x600c0000 + #define CONFIG_EXTRA_ENV_SETTINGS \ "bootargs=root=/dev/ram0 rw console=ttyS0,115200\0" \ "fdt_high=0xcfffffff\0" \
qe: add qe support MACRO to ls1021a-twr head file
Signed-off-by: Zhao Qiang qiang.zhao@freescale.com --- board/freescale/ls1021atwr/ls1021atwr.c | 7 +++++++ include/configs/ls1021atwr.h | 6 ++++++ 2 files changed, 13 insertions(+)
diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index b522ff2..da09d6e 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -16,6 +16,9 @@ #include <netdev.h> #include <fsl_mdio.h> #include <tsec.h> +#ifdef CONFIG_U_QE +#include "../../../drivers/qe/qe.h" +#endif
@@ -277,6 +280,10 @@ int board_init(void) config_serdes_mux(); #endif
diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 45b2272..c4408b8 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -48,6 +48,10 @@
+#if !defined(CONFIG_SDCARD) && !defined(CONFIG_NAND) && !defined(CONFIG_SPI) +#define CONFIG_U_QE +#endif + /* * IFC Definitions */ @@ -274,6 +278,8 @@
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */
+#define CONFIG_SYS_QE_FW_ADDR 0x600c0000 + /* * Environment */
Zhao Qiang
