[PATCH v15 00/10] enable menu-driven UEFI variable maintenance
This series adds the menu-driven UEFI boot variable maintenance through the "eficonfig" new command. This series also adds the removable media support in bootmenu.
Source code can be cloned with: $ git clone https://git.linaro.org/people/masahisa.kojima/u-boot.git -b kojima/eficonfig_upstream_v15
[Major Changes] - rebased to v2022.10-rc3 - there is detailed changelog in each commit
Masahisa Kojima (10): eficonfig: menu-driven addition of UEFI boot option eficonfig: add "Edit Boot Option" menu entry menu: add KEY_PLUS, KEY_MINUS and KEY_SPACE handling eficonfig: add "Delete Boot Option" menu entry bootmenu: add removable media entries eficonfig: scan media device in eficonfig startup eficonfig: add "Change Boot Order" menu entry doc:bootmenu: add description for UEFI boot support doc:eficonfig: add documentation for eficonfig command test: unit test for eficonfig
cmd/Kconfig | 7 + cmd/Makefile | 1 + cmd/bootmenu.c | 22 +- cmd/eficonfig.c | 2462 +++++++++++++++++ common/menu.c | 9 + configs/sandbox_defconfig | 1 + doc/usage/cmd/bootmenu.rst | 74 + doc/usage/cmd/eficonfig.rst | 71 + doc/usage/index.rst | 1 + include/efi_config.h | 98 + include/efi_loader.h | 53 + include/menu.h | 3 + lib/efi_loader/efi_bootmgr.c | 7 + lib/efi_loader/efi_boottime.c | 52 +- lib/efi_loader/efi_console.c | 70 + lib/efi_loader/efi_disk.c | 50 + lib/efi_loader/efi_file.c | 75 +- test/py/tests/test_eficonfig/conftest.py | 40 + .../py/tests/test_eficonfig/test_eficonfig.py | 350 +++ 19 files changed, 3393 insertions(+), 53 deletions(-) create mode 100644 cmd/eficonfig.c create mode 100644 doc/usage/cmd/eficonfig.rst create mode 100644 include/efi_config.h create mode 100644 test/py/tests/test_eficonfig/conftest.py create mode 100644 test/py/tests/test_eficonfig/test_eficonfig.py
This commit add the "eficonfig" command. The "eficonfig" command implements the menu-driven UEFI boot option maintenance feature. This commit implements the addition of new boot option. User can select the block device volume having efi_simple_file_system_protocol and select the file corresponding to the Boot#### variable. User can also enter the description and optional_data of the BOOT#### variable in utf8.
This commit adds "include/efi_config.h", it contains the common definition to be used from other menus such as UEFI Secure Boot key management.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- Changes in v15: - moves the free(entry->data) outside the eficonfig_destroy() function and entry->data is freed explicitly only when needed - expose eficonfig_destroy() for succeeding secure boot key management patch
Changes in v14: - fix the missing initialization - add comment for key handling
No change in v13:
Changes in v12: - add select/clear menu before displaying volume selectio - move function declaration from efi_loader.h to efi_config.h - remove unused declaration - support the boot option does not have file path - correctly handle if optional_data is empty
Changes in v11: - refactor menu entry construction, directly use eficonfig_entry structure - remove reading directory info to calculate the number of entry - fix invalid efi_free_pool() in ill_file_info() - use ANSI_CURSOR_POSITION and ANSI_CLEAR_LINE instead of printf("\n") since current eficonfig implementation does not handle console size correctly. printf("\n") at the outside of console size breaks the console output.
Changes in v10: - add initrd file selection - do refactoring - eficonfig_process_common() use list structure - remove u'/' before copying file_path into current_path - fix typos - check snprintf error
Changes in v9: - move "efi_guid_bootmenu_auto_generated definition" into efi_bootmgr.c to address build error when CMD_EFICONFIG is disabled - fix typos and comment - remove file system information from error message - remove unreachable code in eficonfig_choice_entry() - single printf() call as much as possible - call only getchar() in eficonfig_print_msg() - filter out '.' entry from file selection - update the efi_disk_get_device_name() implementation - add function comment
Changes in v8: - command name is change from "efimenu" to "eficonfig" - function and struct prefixes is changed to "eficonfig" - fix menu header string
Changes in v7: - add "efimenu" command and uefi variable maintenance code moved into cmd/efimenu.c - create include/efimenu.h to define the common definition for the other menu such as UEFI Secure Boot key management - update boot option edit UI, user can select description, file, and optional_data to edit in the same menu like following.
** Edit Boot Option **
Description: debian File: virtio 0:1/EFI\debian\grubaa64.efi Optional Data: test Save Quit
- remove exit parameter from efimenu_process_common() - menu title type is changed from u16 to char - efimenu_process_common() add menu title string - reduce printf/puts function call for displaying the menu - efi_console_get_u16_string() accept 0 length to allow optional_data is empty - efi_console_get_u16_string() the "size" parameter name is changes to "count" - efimenu is now designed to maintain the UEFI variables, remove autoboot related code - remove one empty line before "Quit" entry - efimenu_init() processes only the first time
Changes in v6: - fix typos - modify volume name to match U-Boot syntax - compile in CONFIG_EFI_LOADER=n and CONFIG_CMD_BOOTEFI_BOOTMGR=n - simplify u16_strncmp() usage - support "a\b.efi" file path, use link list to handle filepath - modify length check condition - UEFI related menu items only appears with CONFIG_AUTOBOOT_MENU_SHOW=y
Changes in v5: - remove forward declarations - add const qualifier for menu items - fix the possible unaligned access for directory info access - split into three commit 1)add boot option 2) delete boot option 3)change boot order This commit is 1)add boot option. - fix file name buffer allocation size, it should be EFI_BOOTMENU_FILE_PATH_MAX * sizeof(u16) - fix wrong size checking for file selection
Chanes in v4: - UEFI boot option maintenance menu is integrated into bootmenu - display the simplified volume name(e.g. usb0:1, nvme1:2) for the volume selection - instead of extending lib/efi_loader/efi_bootmgr.c, newly create lib/efi_loader/efi_bootmenu_maintenance.c and implement boot variable maintenance into it.
Changes in RFC v3: not included in v3 series
Changes in RFC v2: - enable utf8 user input for boot option name - create lib/efi_loader/efi_console.c::efi_console_get_u16_string() for utf8 user input handling - use u16_strlcat instead of u16_strcat - remove the EFI_CALLs, and newly create or expose the following xxx_int() functions. efi_locate_handle_buffer_int(), efi_open_volume_int(), efi_file_open_int(), efi_file_close_int(), efi_file_read_int() and efi_file_setpos_int(). Note that EFI_CALLs still exist for EFI_DEVICE_PATH_TO_TEXT_PROTOCOL and EFI_SIMPLE_TEXT_INPUT/OUTPUT_PROTOCOL - use efi_search_protocol() instead of calling locate_protocol() to get the device_path_to_text_protocol interface. - remove unnecessary puts(ANSI_CLEAR_LINE), this patch is still depends on puts(ANSI_CLEAR_CONSOLE) - skip SetVariable() if the bootorder is not changed
cmd/Kconfig | 7 + cmd/Makefile | 1 + cmd/eficonfig.c | 1568 +++++++++++++++++++++++++++++++++ include/efi_config.h | 96 ++ include/efi_loader.h | 37 + lib/efi_loader/efi_bootmgr.c | 3 + lib/efi_loader/efi_boottime.c | 52 +- lib/efi_loader/efi_console.c | 70 ++ lib/efi_loader/efi_disk.c | 50 ++ lib/efi_loader/efi_file.c | 75 +- 10 files changed, 1912 insertions(+), 47 deletions(-) create mode 100644 cmd/eficonfig.c create mode 100644 include/efi_config.h
diff --git a/cmd/Kconfig b/cmd/Kconfig index 211ebe9c87..a1e8613c56 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1928,6 +1928,13 @@ config CMD_EFIDEBUG particularly for managing boot parameters as well as examining various EFI status for debugging.
+config CMD_EFICONFIG + bool "eficonfig - provide menu-driven uefi variables maintenance interface" + depends on CMD_BOOTEFI_BOOTMGR + help + Enable the 'eficonfig' command which provides the menu-driven UEFI + variable maintenance interface. + config CMD_EXCEPTION bool "exception - raise exception" depends on ARM || RISCV || SANDBOX || X86 diff --git a/cmd/Makefile b/cmd/Makefile index 6e87522b62..18f5cb890d 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -63,6 +63,7 @@ obj-$(CONFIG_ENV_IS_IN_EEPROM) += eeprom.o obj-$(CONFIG_CMD_EEPROM) += eeprom.o obj-$(CONFIG_EFI) += efi.o obj-$(CONFIG_CMD_EFIDEBUG) += efidebug.o +obj-$(CONFIG_CMD_EFICONFIG) += eficonfig.o obj-$(CONFIG_CMD_ELF) += elf.o obj-$(CONFIG_CMD_EROFS) += erofs.o obj-$(CONFIG_HUSH_PARSER) += exit.o diff --git a/cmd/eficonfig.c b/cmd/eficonfig.c new file mode 100644 index 0000000000..30ce55d055 --- /dev/null +++ b/cmd/eficonfig.c @@ -0,0 +1,1568 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Menu-driven UEFI Variable maintenance + * + * Copyright (c) 2022 Masahisa Kojima, Linaro Limited + */ + +#include <ansi.h> +#include <common.h> +#include <charset.h> +#include <efi_loader.h> +#include <efi_load_initrd.h> +#include <efi_config.h> +#include <efi_variable.h> +#include <log.h> +#include <malloc.h> +#include <menu.h> +#include <watchdog.h> +#include <asm/unaligned.h> +#include <linux/delay.h> + +static struct efi_simple_text_input_protocol *cin; + +#define EFICONFIG_DESCRIPTION_MAX 32 +#define EFICONFIG_OPTIONAL_DATA_MAX 64 + +/** + * struct eficonfig_filepath_info - structure to be used to store file path + * + * @name: file or directory name + * @list: list structure + */ +struct eficonfig_filepath_info { + u16 *name; + struct list_head list; +}; + +/** + * struct eficonfig_boot_option - structure to be used for updating UEFI boot option + * + * @file_info: user selected file info + * @initrd_info: user selected initrd file info + * @boot_index: index of the boot option + * @description: pointer to the description string + * @optional_data: pointer to the optional_data + * @edit_completed: flag indicates edit complete + */ +struct eficonfig_boot_option { + struct eficonfig_select_file_info file_info; + struct eficonfig_select_file_info initrd_info; + unsigned int boot_index; + u16 *description; + u16 *optional_data; + bool edit_completed; +}; + +/** + * struct eficonfig_volume_entry_data - structure to be used to store volume info + * + * @file_info: pointer to file info structure + * @v: pointer to the protocol interface + * @dp: pointer to the device path + */ +struct eficonfig_volume_entry_data { + struct eficonfig_select_file_info *file_info; + struct efi_simple_file_system_protocol *v; + struct efi_device_path *dp; +}; + +/** + * struct eficonfig_file_entry_data - structure to be used to store file info + * + * @file_info: pointer to file info structure + * @is_directory: flag to identify the directory or file + * @file_name: name of directory or file + */ +struct eficonfig_file_entry_data { + struct eficonfig_select_file_info *file_info; + bool is_directory; + u16 *file_name; +}; + +/** + * eficonfig_print_msg() - print message + * + * display the message to the user, user proceeds the screen + * with any key press. + * + * @items: pointer to the structure of each menu entry + * @count: the number of menu entry + * @menu_header: pointer to the menu header string + * Return: status code + */ +void eficonfig_print_msg(char *msg) +{ + /* Flush input */ + while (tstc()) + getchar(); + + printf(ANSI_CURSOR_HIDE + ANSI_CLEAR_CONSOLE + ANSI_CURSOR_POSITION + "%s\n\n Press any key to continue", 3, 4, msg); + + getchar(); +} + +/** + * eficonfig_print_entry() - print each menu entry + * + * @data: pointer to the data associated with each menu entry + */ +static void eficonfig_print_entry(void *data) +{ + struct eficonfig_entry *entry = data; + int reverse = (entry->efi_menu->active == entry->num); + + /* TODO: support scroll or page for many entries */ + + /* + * Move cursor to line where the entry will be drawn (entry->num) + * First 3 lines(menu header) + 1 empty line + */ + printf(ANSI_CURSOR_POSITION, entry->num + 4, 7); + + if (reverse) + puts(ANSI_COLOR_REVERSE); + + printf("%s", entry->title); + + if (reverse) + puts(ANSI_COLOR_RESET); +} + +/** + * eficonfig_display_statusline() - print status line + * + * @m: pointer to the menu structure + */ +static void eficonfig_display_statusline(struct menu *m) +{ + struct eficonfig_entry *entry; + + if (menu_default_choice(m, (void *)&entry) < 0) + return; + + printf(ANSI_CURSOR_POSITION + "\n%s\n" + ANSI_CURSOR_POSITION ANSI_CLEAR_LINE ANSI_CURSOR_POSITION + " Press UP/DOWN to move, ENTER to select, ESC/CTRL+C to quit" + ANSI_CLEAR_LINE_TO_END ANSI_CURSOR_POSITION ANSI_CLEAR_LINE, + 1, 1, entry->efi_menu->menu_header, entry->efi_menu->count + 5, 1, + entry->efi_menu->count + 6, 1, entry->efi_menu->count + 7, 1); +} + +/** + * eficonfig_choice_entry() - user key input handler + * + * @data: pointer to the efimenu structure + * Return: key string to identify the selected entry + */ +static char *eficonfig_choice_entry(void *data) +{ + int esc = 0; + struct list_head *pos, *n; + struct eficonfig_entry *entry; + enum bootmenu_key key = KEY_NONE; + struct efimenu *efi_menu = data; + + while (1) { + bootmenu_loop((struct bootmenu_data *)efi_menu, &key, &esc); + + switch (key) { + case KEY_UP: + if (efi_menu->active > 0) + --efi_menu->active; + /* no menu key selected, regenerate menu */ + return NULL; + case KEY_DOWN: + if (efi_menu->active < efi_menu->count - 1) + ++efi_menu->active; + /* no menu key selected, regenerate menu */ + return NULL; + case KEY_SELECT: + list_for_each_safe(pos, n, &efi_menu->list) { + entry = list_entry(pos, struct eficonfig_entry, list); + if (entry->num == efi_menu->active) + return entry->key; + } + break; + case KEY_QUIT: + /* Quit by choosing the last entry */ + entry = list_last_entry(&efi_menu->list, struct eficonfig_entry, list); + return entry->key; + default: + /* Pressed key is not valid, no need to regenerate the menu */ + break; + } + } +} + +/** + * eficonfig_destroy() - destroy efimenu + * + * @efi_menu: pointer to the efimenu structure + */ +void eficonfig_destroy(struct efimenu *efi_menu) +{ + struct list_head *pos, *n; + struct eficonfig_entry *entry; + + list_for_each_safe(pos, n, &efi_menu->list) { + entry = list_entry(pos, struct eficonfig_entry, list); + free(entry->title); + list_del(&entry->list); + free(entry); + } + free(efi_menu->menu_header); + free(efi_menu); +} + +/** + * eficonfig_process_quit() - callback function for "Quit" entry + * + * @data: pointer to the data + * Return: status code + */ +efi_status_t eficonfig_process_quit(void *data) +{ + return EFI_ABORTED; +} + +/** + * append_entry() - append menu item + * + * @efi_menu: pointer to the efimenu structure + * @title: pointer to the entry title + * @func: callback of each entry + * @data: pointer to the data to be passed to each entry callback + * Return: status code + */ +static efi_status_t append_entry(struct efimenu *efi_menu, + char *title, eficonfig_entry_func func, void *data) +{ + struct eficonfig_entry *entry; + + if (efi_menu->count >= EFICONFIG_ENTRY_NUM_MAX) + return EFI_OUT_OF_RESOURCES; + + entry = calloc(1, sizeof(struct eficonfig_entry)); + if (!entry) + return EFI_OUT_OF_RESOURCES; + + entry->title = title; + sprintf(entry->key, "%d", efi_menu->count); + entry->efi_menu = efi_menu; + entry->func = func; + entry->data = data; + entry->num = efi_menu->count++; + list_add_tail(&entry->list, &efi_menu->list); + + return EFI_SUCCESS; +} + +/** + * append_quit_entry() - append quit entry + * + * @efi_menu: pointer to the efimenu structure + * Return: status code + */ +static efi_status_t append_quit_entry(struct efimenu *efi_menu) +{ + char *title; + efi_status_t ret; + + title = strdup("Quit"); + if (!title) + return EFI_OUT_OF_RESOURCES; + + ret = append_entry(efi_menu, title, eficonfig_process_quit, NULL); + if (ret != EFI_SUCCESS) + free(title); + + return ret; +} + +/** + * eficonfig_create_fixed_menu() - create fixed entry menu structure + * + * @items: pointer to the menu entry item + * @count: the number of menu entry + * Return: pointer to the efimenu structure + */ +void *eficonfig_create_fixed_menu(const struct eficonfig_item *items, int count) +{ + u32 i; + char *title; + efi_status_t ret; + struct efimenu *efi_menu; + const struct eficonfig_item *iter = items; + + efi_menu = calloc(1, sizeof(struct efimenu)); + if (!efi_menu) + return NULL; + + INIT_LIST_HEAD(&efi_menu->list); + for (i = 0; i < count; i++, iter++) { + title = strdup(iter->title); + if (!title) + goto out; + + ret = append_entry(efi_menu, title, iter->func, iter->data); + if (ret != EFI_SUCCESS) { + free(title); + goto out; + } + } + + return efi_menu; +out: + eficonfig_destroy(efi_menu); + + return NULL; +} + +/** + * eficonfig_process_common() - main handler for UEFI menu + * + * Construct the structures required to show the menu, then handle + * the user input interacting with u-boot menu functions. + * + * @efi_menu: pointer to the efimenu structure + * @menu_header: pointer to the menu header string + * Return: status code + */ +efi_status_t eficonfig_process_common(struct efimenu *efi_menu, char *menu_header) +{ + struct menu *menu; + void *choice = NULL; + struct list_head *pos, *n; + struct eficonfig_entry *entry; + efi_status_t ret = EFI_SUCCESS; + + if (efi_menu->count > EFICONFIG_ENTRY_NUM_MAX) + return EFI_OUT_OF_RESOURCES; + + efi_menu->delay = -1; + efi_menu->active = 0; + + if (menu_header) { + efi_menu->menu_header = strdup(menu_header); + if (!efi_menu->menu_header) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + } + + menu = menu_create(NULL, 0, 1, eficonfig_display_statusline, + eficonfig_print_entry, eficonfig_choice_entry, + efi_menu); + if (!menu) { + ret = EFI_INVALID_PARAMETER; + goto out; + } + + list_for_each_safe(pos, n, &efi_menu->list) { + entry = list_entry(pos, struct eficonfig_entry, list); + if (!menu_item_add(menu, entry->key, entry)) { + ret = EFI_INVALID_PARAMETER; + goto out; + } + } + + entry = list_first_entry_or_null(&efi_menu->list, struct eficonfig_entry, list); + if (entry) + menu_default_set(menu, entry->key); + + printf(ANSI_CURSOR_HIDE + ANSI_CLEAR_CONSOLE + ANSI_CURSOR_POSITION, 1, 1); + + if (menu_get_choice(menu, &choice)) { + entry = choice; + if (entry->func) + ret = entry->func(entry->data); + } +out: + menu_destroy(menu); + + printf(ANSI_CLEAR_CONSOLE + ANSI_CURSOR_POSITION + ANSI_CURSOR_SHOW, 1, 1); + + return ret; +} + +/** + * eficonfig_volume_selected() - handler of volume selection + * + * @data: pointer to the data of selected entry + * Return: status code + */ +static efi_status_t eficonfig_volume_selected(void *data) +{ + struct eficonfig_volume_entry_data *info = data; + + if (info) { + info->file_info->current_volume = info->v; + info->file_info->dp_volume = info->dp; + } + + return EFI_SUCCESS; +} + +/** + * create_selected_device_path() - create device path + * + * @file_info: pointer to the selected file information + * Return: + * device path or NULL. Caller must free the returned value + */ +static +struct efi_device_path *create_selected_device_path(struct eficonfig_select_file_info *file_info) +{ + char *p; + void *buf; + efi_uintn_t fp_size; + struct efi_device_path *dp; + struct efi_device_path_file_path *fp; + + fp_size = sizeof(struct efi_device_path) + + ((u16_strlen(file_info->current_path) + 1) * sizeof(u16)); + buf = calloc(1, fp_size + sizeof(END)); + if (!buf) + return NULL; + + fp = buf; + fp->dp.type = DEVICE_PATH_TYPE_MEDIA_DEVICE, + fp->dp.sub_type = DEVICE_PATH_SUB_TYPE_FILE_PATH, + fp->dp.length = (u16)fp_size; + u16_strcpy(fp->str, file_info->current_path); + + p = buf; + p += fp_size; + *((struct efi_device_path *)p) = END; + + dp = efi_dp_append(file_info->dp_volume, (struct efi_device_path *)buf); + free(buf); + + return dp; +} + +/** + * eficonfig_file_selected() - handler of file selection + * + * @data: pointer to the data of selected entry + * Return: status code + */ +static efi_status_t eficonfig_file_selected(void *data) +{ + struct eficonfig_file_entry_data *info = data; + + if (!info) + return EFI_INVALID_PARAMETER; + + if (u16_strcmp(info->file_name, u".") == 0 && + u16_strlen(info->file_name) == 1) { + /* stay current path */ + } else if (u16_strcmp(info->file_name, u"..") == 0 && + u16_strlen(info->file_name) == 2) { + struct eficonfig_filepath_info *iter; + struct list_head *pos, *n; + int is_last; + + memset(info->file_info->current_path, 0, EFICONFIG_FILE_PATH_BUF_SIZE); + list_for_each_safe(pos, n, &info->file_info->filepath_list) { + iter = list_entry(pos, struct eficonfig_filepath_info, list); + + is_last = list_is_last(&iter->list, &info->file_info->filepath_list); + if (is_last) { + list_del(&iter->list); + free(iter->name); + free(iter); + break; + } + u16_strlcat(info->file_info->current_path, iter->name, + EFICONFIG_FILE_PATH_MAX); + u16_strlcat(info->file_info->current_path, u"\", + EFICONFIG_FILE_PATH_MAX); + } + } else { + size_t new_len; + struct eficonfig_filepath_info *filepath; + + new_len = u16_strlen(info->file_info->current_path) + + u16_strlen(info->file_name); + if (new_len >= EFICONFIG_FILE_PATH_MAX) { + eficonfig_print_msg("File path is too long!"); + return EFI_INVALID_PARAMETER; + } + u16_strlcat(info->file_info->current_path, info->file_name, + EFICONFIG_FILE_PATH_MAX); + + filepath = calloc(1, sizeof(struct eficonfig_filepath_info)); + if (!filepath) + return EFI_OUT_OF_RESOURCES; + + filepath->name = u16_strdup(info->file_name); + if (!filepath->name) { + free(filepath); + return EFI_OUT_OF_RESOURCES; + } + list_add_tail(&filepath->list, &info->file_info->filepath_list); + + if (info->is_directory) { + /* + * Remaining buffer should have enough space to contain u"\" and + * at least one character for file name + */ + if (new_len + 2 >= EFICONFIG_FILE_PATH_MAX) { + eficonfig_print_msg("Directory path is too long!"); + return EFI_INVALID_PARAMETER; + } + u16_strlcat(info->file_info->current_path, u"\", + EFICONFIG_FILE_PATH_MAX); + } else { + info->file_info->file_selected = true; + } + } + return EFI_SUCCESS; +} + +/** + * eficonfig_select_volume() - construct the volume selection menu + * + * @file_info: pointer to the file selection structure + * Return: status code + */ +static efi_status_t eficonfig_select_volume(struct eficonfig_select_file_info *file_info) +{ + u32 i; + efi_status_t ret; + efi_uintn_t count; + struct efimenu *efi_menu; + struct list_head *pos, *n; + struct efi_handler *handler; + struct eficonfig_entry *entry; + struct efi_device_path *device_path; + efi_handle_t *volume_handles = NULL; + struct efi_simple_file_system_protocol *v; + + ret = efi_locate_handle_buffer_int(BY_PROTOCOL, &efi_simple_file_system_protocol_guid, + NULL, &count, (efi_handle_t **)&volume_handles); + if (ret != EFI_SUCCESS) { + eficonfig_print_msg("No block device found!"); + return ret; + } + + efi_menu = calloc(1, sizeof(struct efimenu)); + if (!efi_menu) + return EFI_OUT_OF_RESOURCES; + + INIT_LIST_HEAD(&efi_menu->list); + for (i = 0; i < count; i++) { + char *devname; + struct efi_block_io *block_io; + struct eficonfig_volume_entry_data *info; + + if (efi_menu->count >= EFICONFIG_ENTRY_NUM_MAX - 1) + break; + + ret = efi_search_protocol(volume_handles[i], + &efi_simple_file_system_protocol_guid, &handler); + if (ret != EFI_SUCCESS) + continue; + ret = efi_protocol_open(handler, (void **)&v, efi_root, NULL, + EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) + continue; + + ret = efi_search_protocol(volume_handles[i], &efi_guid_device_path, &handler); + if (ret != EFI_SUCCESS) + continue; + ret = efi_protocol_open(handler, (void **)&device_path, + efi_root, NULL, EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) + continue; + + ret = efi_search_protocol(volume_handles[i], &efi_block_io_guid, &handler); + if (ret != EFI_SUCCESS) + continue; + ret = efi_protocol_open(handler, (void **)&block_io, + efi_root, NULL, EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) + continue; + + info = calloc(1, sizeof(struct eficonfig_volume_entry_data)); + if (!info) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + + devname = calloc(1, BOOTMENU_DEVICE_NAME_MAX); + if (!devname) { + free(info); + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + ret = efi_disk_get_device_name(volume_handles[i], devname, + BOOTMENU_DEVICE_NAME_MAX); + if (ret != EFI_SUCCESS) { + free(info); + goto out; + } + + info->v = v; + info->dp = device_path; + info->file_info = file_info; + ret = append_entry(efi_menu, devname, eficonfig_volume_selected, info); + if (ret != EFI_SUCCESS) { + free(info); + goto out; + } + } + + ret = append_quit_entry(efi_menu); + if (ret != EFI_SUCCESS) + goto out; + + ret = eficonfig_process_common(efi_menu, " ** Select Volume **"); +out: + efi_free_pool(volume_handles); + list_for_each_safe(pos, n, &efi_menu->list) { + entry = list_entry(pos, struct eficonfig_entry, list); + free(entry->data); + } + eficonfig_destroy(efi_menu); + + return ret; +} + +/** + * eficonfig_select_file() - construct the file selection menu + * + * @file_info: pointer to the file selection structure + * @root: pointer to the file handle + * Return: status code + */ +static efi_status_t eficonfig_select_file(struct eficonfig_select_file_info *file_info, + struct efi_file_handle *root) +{ + efi_uintn_t len; + efi_status_t ret; + struct efimenu *efi_menu; + struct efi_file_handle *f; + struct efi_file_info *buf; + struct list_head *pos, *n; + + buf = calloc(1, sizeof(struct efi_file_info) + EFICONFIG_FILE_PATH_BUF_SIZE); + if (!buf) + return EFI_OUT_OF_RESOURCES; + + while (!file_info->file_selected) { + efi_menu = calloc(1, sizeof(struct efimenu)); + if (!efi_menu) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + INIT_LIST_HEAD(&efi_menu->list); + + ret = efi_file_open_int(root, &f, file_info->current_path, EFI_FILE_MODE_READ, 0); + if (ret != EFI_SUCCESS) { + eficonfig_print_msg("Reading volume failed!"); + ret = EFI_ABORTED; + goto out; + } + + /* Read directory and construct menu structure */ + for (;;) { + char *name, *p; + int name_len; + struct eficonfig_file_entry_data *info; + + if (efi_menu->count >= EFICONFIG_ENTRY_NUM_MAX - 1) + break; + + len = sizeof(struct efi_file_info) + EFICONFIG_FILE_PATH_BUF_SIZE; + ret = efi_file_read_int(f, &len, buf); + if (ret != EFI_SUCCESS || len == 0) + break; + + info = calloc(1, sizeof(struct eficonfig_file_entry_data)); + if (!info) { + ret = EFI_OUT_OF_RESOURCES; + goto err; + } + + if (buf->attribute & EFI_FILE_DIRECTORY) { + /* append u'/' at the end of directory name */ + name_len = utf16_utf8_strlen(buf->file_name) + 2; + + /* filter out u'.' */ + if (name_len == 3 && buf->file_name[0] == u'.') { + free(info); + continue; + } + + name = calloc(1, name_len); + if (!name) { + free(info); + ret = EFI_OUT_OF_RESOURCES; + goto err; + } + p = name; + utf16_utf8_strcpy(&p, buf->file_name); + name[u16_strlen(buf->file_name)] = u'/'; + + info->is_directory = true; + } else { + name_len = utf16_utf8_strlen(buf->file_name) + 1; + name = calloc(1, name_len); + if (!name) { + free(info); + ret = EFI_OUT_OF_RESOURCES; + goto err; + } + p = name; + utf16_utf8_strcpy(&p, buf->file_name); + } + + info->file_name = u16_strdup(buf->file_name); + if (!info->file_name) { + free(info); + free(name); + ret = EFI_OUT_OF_RESOURCES; + goto err; + } + + info->file_info = file_info; + ret = append_entry(efi_menu, name, eficonfig_file_selected, info); + if (ret != EFI_SUCCESS) { + free(info); + free(name); + goto err; + } + } + + ret = append_quit_entry(efi_menu); + if (ret != EFI_SUCCESS) + goto err; + + ret = eficonfig_process_common(efi_menu, " ** Select File **"); +err: + efi_file_close_int(f); + list_for_each_safe(pos, n, &efi_menu->list) { + struct eficonfig_entry *entry; + + entry = list_entry(pos, struct eficonfig_entry, list); + /* skip "Quit" */ + if (list_is_last(&entry->list, &efi_menu->list)) + break; + + free(((struct eficonfig_file_entry_data *)(entry->data))->file_name); + free(entry->data); + } + eficonfig_destroy(efi_menu); + if (ret != EFI_SUCCESS) + break; + } + +out: + free(buf); + return ret; +} + +/** + * handle_user_input() - handle user input + * + * @buf: pointer to the buffer + * @buf_size: size of the buffer + * @cursor_col: cursor column for user input + * @msg: pointer to the string to display + * Return: status code + */ +static efi_status_t handle_user_input(u16 *buf, int buf_size, + int cursor_col, char *msg) +{ + u16 *tmp; + efi_status_t ret; + + printf(ANSI_CLEAR_CONSOLE + ANSI_CURSOR_POSITION + "%s" + ANSI_CURSOR_POSITION + " Press ENTER to complete, ESC/CTRL+C to quit", + 0, 1, msg, 8, 1); + + /* tmp is used to accept user cancel */ + tmp = calloc(1, buf_size * sizeof(u16)); + if (!tmp) + return EFI_OUT_OF_RESOURCES; + + ret = efi_console_get_u16_string(cin, tmp, buf_size, NULL, 4, cursor_col); + if (ret == EFI_SUCCESS) + u16_strcpy(buf, tmp); + + free(tmp); + + /* to stay the parent menu */ + ret = (ret == EFI_ABORTED) ? EFI_NOT_READY : ret; + + return ret; +} + +/** + * eficonfig_boot_add_enter_description() - handle user input for description + * + * @data: pointer to the internal boot option structure + * Return: status code + */ +static efi_status_t eficonfig_boot_add_enter_description(void *data) +{ + struct eficonfig_boot_option *bo = data; + + return handle_user_input(bo->description, EFICONFIG_DESCRIPTION_MAX, 22, + "\n ** Edit Description **\n" + "\n" + " enter description: "); +} + +/** + * eficonfig_boot_add_optional_data() - handle user input for optional data + * + * @data: pointer to the internal boot option structure + * Return: status code + */ +static efi_status_t eficonfig_boot_add_optional_data(void *data) +{ + struct eficonfig_boot_option *bo = data; + + return handle_user_input(bo->optional_data, EFICONFIG_OPTIONAL_DATA_MAX, 24, + "\n ** Edit Optional Data **\n" + "\n" + " enter optional data:"); +} + +/** + * eficonfig_boot_edit_save() - handler to save the boot option + * + * @data: pointer to the internal boot option structure + * Return: status code + */ +static efi_status_t eficonfig_boot_edit_save(void *data) +{ + struct eficonfig_boot_option *bo = data; + + if (u16_strlen(bo->description) == 0) { + eficonfig_print_msg("Boot Description is empty!"); + bo->edit_completed = false; + return EFI_NOT_READY; + } + if (u16_strlen(bo->file_info.current_path) == 0) { + eficonfig_print_msg("File is not selected!"); + bo->edit_completed = false; + return EFI_NOT_READY; + } + + bo->edit_completed = true; + + return EFI_SUCCESS; +} + +/** + * eficonfig_process_select_file() - callback function for "Select File" entry + * + * @data: pointer to the data + * Return: status code + */ +efi_status_t eficonfig_process_select_file(void *data) +{ + return EFI_SUCCESS; +} + +/** + * eficonfig_process_clear_file_selection() - callback function for "Clear" entry + * + * @data: pointer to the data + * Return: status code + */ +efi_status_t eficonfig_process_clear_file_selection(void *data) +{ + struct eficonfig_select_file_info *file_info = data; + + /* clear the existing file information */ + file_info->current_volume = NULL; + file_info->current_path[0] = u'\0'; + file_info->dp_volume = NULL; + + return EFI_ABORTED; +} + +static struct eficonfig_item select_file_menu_items[] = { + {"Select File", eficonfig_process_select_file}, + {"Clear", eficonfig_process_clear_file_selection}, + {"Quit", eficonfig_process_quit}, +}; + + +/** + * eficonfig_display_select_file_option() - display select file option + * + * @file_info: pointer to the file information structure + * Return: status code + */ +efi_status_t eficonfig_display_select_file_option(struct eficonfig_select_file_info *file_info) +{ + efi_status_t ret; + struct efimenu *efi_menu; + + select_file_menu_items[1].data = file_info; + efi_menu = eficonfig_create_fixed_menu(select_file_menu_items, + ARRAY_SIZE(select_file_menu_items)); + if (!efi_menu) + return EFI_OUT_OF_RESOURCES; + + ret = eficonfig_process_common(efi_menu, " ** Update File **"); + if (ret != EFI_SUCCESS) /* User selects "Clear" or "Quit" */ + ret = EFI_NOT_READY; + + eficonfig_destroy(efi_menu); + + return ret; +} + +/** + * eficonfig_select_file_handler() - handle user file selection + * + * @data: pointer to the data + * Return: status code + */ +efi_status_t eficonfig_select_file_handler(void *data) +{ + size_t len; + efi_status_t ret; + struct list_head *pos, *n; + struct efi_file_handle *root; + struct eficonfig_filepath_info *item; + struct eficonfig_select_file_info *tmp = NULL; + struct eficonfig_select_file_info *file_info = data; + + ret = eficonfig_display_select_file_option(file_info); + if (ret != EFI_SUCCESS) + return ret; + + tmp = calloc(1, sizeof(struct eficonfig_select_file_info)); + if (!tmp) + return EFI_OUT_OF_RESOURCES; + + tmp->current_path = calloc(1, EFICONFIG_FILE_PATH_BUF_SIZE); + if (!tmp->current_path) { + free(tmp); + return EFI_OUT_OF_RESOURCES; + } + INIT_LIST_HEAD(&tmp->filepath_list); + + while (!tmp->file_selected) { + tmp->current_volume = NULL; + memset(tmp->current_path, 0, EFICONFIG_FILE_PATH_BUF_SIZE); + + ret = eficonfig_select_volume(tmp); + if (ret != EFI_SUCCESS) + goto out; + + if (!tmp->current_volume) + return EFI_INVALID_PARAMETER; + + ret = efi_open_volume_int(tmp->current_volume, &root); + if (ret != EFI_SUCCESS) + goto out; + + ret = eficonfig_select_file(tmp, root); + if (ret == EFI_ABORTED) + continue; + if (ret != EFI_SUCCESS) + goto out; + } + +out: + if (ret == EFI_SUCCESS) { + len = u16_strlen(tmp->current_path); + len = (len >= EFICONFIG_FILE_PATH_MAX) ? (EFICONFIG_FILE_PATH_MAX - 1) : len; + memcpy(file_info->current_path, tmp->current_path, len * sizeof(u16)); + file_info->current_path[len] = u'\0'; + file_info->current_volume = tmp->current_volume; + file_info->dp_volume = tmp->dp_volume; + } + + list_for_each_safe(pos, n, &tmp->filepath_list) { + item = list_entry(pos, struct eficonfig_filepath_info, list); + list_del(&item->list); + free(item->name); + free(item); + } + free(tmp->current_path); + free(tmp); + + /* to stay the parent menu */ + ret = (ret == EFI_ABORTED) ? EFI_NOT_READY : ret; + + return ret; +} + +/** + * eficonfig_get_unused_bootoption() - get unused "Boot####" index + * + * @buf: pointer to the buffer to store boot option variable name + * @buf_size: buffer size + * @index: pointer to store the index in the BootOrder variable + * Return: status code + */ +efi_status_t eficonfig_get_unused_bootoption(u16 *buf, efi_uintn_t buf_size, + unsigned int *index) +{ + u32 i; + efi_status_t ret; + efi_uintn_t size; + + if (buf_size < u16_strsize(u"Boot####")) + return EFI_BUFFER_TOO_SMALL; + + for (i = 0; i <= 0xFFFF; i++) { + size = 0; + efi_create_indexed_name(buf, buf_size, "Boot", i); + ret = efi_get_variable_int(buf, &efi_global_variable_guid, + NULL, &size, NULL, NULL); + if (ret == EFI_BUFFER_TOO_SMALL) + continue; + else + break; + } + + if (i > 0xFFFF) + return EFI_OUT_OF_RESOURCES; + + *index = i; + + return EFI_SUCCESS; +} + +/** + * eficonfig_set_boot_option() - set boot option + * + * @varname: pointer to variable name + * @dp: pointer to device path + * @label: pointer to label string + * @optional_data: pointer to optional data + * Return: status code + */ +static efi_status_t eficonfig_set_boot_option(u16 *varname, struct efi_device_path *dp, + efi_uintn_t dp_size, u16 *label, char *optional_data) +{ + void *p = NULL; + efi_status_t ret; + efi_uintn_t size; + struct efi_load_option lo; + + lo.file_path = dp; + lo.file_path_length = dp_size; + lo.attributes = LOAD_OPTION_ACTIVE; + lo.optional_data = optional_data; + lo.label = label; + + size = efi_serialize_load_option(&lo, (u8 **)&p); + if (!size) + return EFI_INVALID_PARAMETER; + + ret = efi_set_variable_int(varname, &efi_global_variable_guid, + EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + size, p, false); + free(p); + + return ret; +} + +/** + * eficonfig_append_bootorder() - append new boot option in BootOrder variable + * + * @index: "Boot####" index to append to BootOrder variable + * Return: status code + */ +efi_status_t eficonfig_append_bootorder(u16 index) +{ + u16 *bootorder; + efi_status_t ret; + u16 *new_bootorder = NULL; + efi_uintn_t last, size, new_size; + + /* append new boot option */ + bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); + last = size / sizeof(u16); + new_size = size + sizeof(u16); + new_bootorder = calloc(1, new_size); + if (!new_bootorder) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + memcpy(new_bootorder, bootorder, size); + new_bootorder[last] = index; + + ret = efi_set_variable_int(u"BootOrder", &efi_global_variable_guid, + EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + new_size, new_bootorder, false); + if (ret != EFI_SUCCESS) + goto out; + +out: + free(bootorder); + free(new_bootorder); + + return ret; +} + +/** + * create_boot_option_entry() - create boot option entry + * + * @efi_menu: pointer to the efimenu structure + * @title: pointer to the entry title + * @val: pointer to boot option label + * @func: callback of each entry + * @data: pointer to the data to be passed to each entry callback + * Return: status code + */ +static efi_status_t create_boot_option_entry(struct efimenu *efi_menu, char *title, u16 *val, + eficonfig_entry_func func, void *data) +{ + u32 len; + char *p, *buf; + + len = strlen(title) + 1; + if (val) + len += utf16_utf8_strlen(val); + buf = calloc(1, len); + if (!buf) + return EFI_OUT_OF_RESOURCES; + + strcpy(buf, title); + if (val) { + p = buf + strlen(title); + utf16_utf8_strcpy(&p, val); + } + + return append_entry(efi_menu, buf, func, data); +} + +/** + * prepare_file_selection_entry() - prepare file selection entry + * + * @efi_menu: pointer to the efimenu structure + * @title: pointer to the title string + * @file_info: pointer to the file info + * Return: status code + */ +static efi_status_t prepare_file_selection_entry(struct efimenu *efi_menu, char *title, + struct eficonfig_select_file_info *file_info) +{ + u32 len; + efi_status_t ret; + u16 *file_name, *p; + efi_handle_t handle; + char devname[BOOTMENU_DEVICE_NAME_MAX] = {0}; + + /* get the device name only when the user already selected the file path */ + handle = efi_dp_find_obj(file_info->dp_volume, NULL, NULL); + if (handle) { + ret = efi_disk_get_device_name(handle, devname, BOOTMENU_DEVICE_NAME_MAX); + if (ret != EFI_SUCCESS) + return ret; + } + + /* append u'/' to devname, it is just for display purpose. */ + if (file_info->current_path[0] != u'\0' && file_info->current_path[0] != u'/') + strlcat(devname, "/", BOOTMENU_DEVICE_NAME_MAX); + + len = strlen(devname); + len += utf16_utf8_strlen(file_info->current_path) + 1; + file_name = calloc(1, len * sizeof(u16)); + if (!file_name) + return ret; + + p = file_name; + utf8_utf16_strcpy(&p, devname); + u16_strlcat(file_name, file_info->current_path, len); + ret = create_boot_option_entry(efi_menu, title, file_name, + eficonfig_select_file_handler, file_info); + free(file_name); + return ret; +} + +/** + * eficonfig_show_boot_option() - prepare menu entry for editing boot option + * + * Construct the structures to create edit boot option menu + * + * @bo: pointer to the boot option + * @header_str: pointer to the header string + * Return: status code + */ +static efi_status_t eficonfig_show_boot_option(struct eficonfig_boot_option *bo, + char *header_str) +{ + efi_status_t ret; + struct efimenu *efi_menu; + + efi_menu = calloc(1, sizeof(struct efimenu)); + if (!efi_menu) + return EFI_OUT_OF_RESOURCES; + + INIT_LIST_HEAD(&efi_menu->list); + + ret = create_boot_option_entry(efi_menu, "Description: ", bo->description, + eficonfig_boot_add_enter_description, bo); + if (ret != EFI_SUCCESS) + goto out; + + ret = prepare_file_selection_entry(efi_menu, "File: ", &bo->file_info); + if (ret != EFI_SUCCESS) + goto out; + + ret = prepare_file_selection_entry(efi_menu, "Initrd File: ", &bo->initrd_info); + if (ret != EFI_SUCCESS) + goto out; + + ret = create_boot_option_entry(efi_menu, "Optional Data: ", bo->optional_data, + eficonfig_boot_add_optional_data, bo); + if (ret != EFI_SUCCESS) + goto out; + + ret = create_boot_option_entry(efi_menu, "Save", NULL, + eficonfig_boot_edit_save, bo); + if (ret != EFI_SUCCESS) + goto out; + + ret = create_boot_option_entry(efi_menu, "Quit", NULL, + eficonfig_process_quit, NULL); + if (ret != EFI_SUCCESS) + goto out; + + ret = eficonfig_process_common(efi_menu, header_str); +out: + eficonfig_destroy(efi_menu); + + return ret; +} + +/** + * fill_file_info() - fill the file info from efi_device_path structure + * + * @dp: pointer to the device path + * @file_info: pointer to the file info structure + * @device_dp: pointer to the volume device path + */ +static void fill_file_info(struct efi_device_path *dp, + struct eficonfig_select_file_info *file_info, + struct efi_device_path *device_dp) +{ + u16 *file_str, *p; + struct efi_device_path *file_dp = NULL; + + efi_dp_split_file_path(dp, &device_dp, &file_dp); + file_info->dp_volume = device_dp; + + if (file_dp) { + file_str = efi_dp_str(file_dp); + /* + * efi_convert_device_path_to_text() automatically adds u'/' at the + * beginning of file name, remove u'/' before copying to current_path + */ + p = file_str; + if (p[0] == u'/') + p++; + + u16_strcpy(file_info->current_path, p); + efi_free_pool(file_dp); + efi_free_pool(file_str); + } +} + +/** + * eficonfig_edit_boot_option() - prepare boot option structure for editing + * + * Construct the boot option structure and copy the existing value + * + * @varname: pointer to the UEFI variable name + * @bo: pointer to the boot option + * @load_option: pointer to the load option + * @load_option_size: size of the load option + * @header_str: pointer to the header string + * Return : status code + */ +static efi_status_t eficonfig_edit_boot_option(u16 *varname, struct eficonfig_boot_option *bo, + void *load_option, efi_uintn_t load_option_size, + char *header_str) +{ + size_t len; + efi_status_t ret; + char *tmp = NULL, *p; + struct efi_load_option lo = {0}; + efi_uintn_t final_dp_size; + struct efi_device_path *dp = NULL; + efi_uintn_t size = load_option_size; + struct efi_device_path *final_dp = NULL; + struct efi_device_path *device_dp = NULL; + struct efi_device_path *initrd_dp = NULL; + struct efi_device_path *initrd_device_dp = NULL; + + const struct efi_initrd_dp id_dp = { + .vendor = { + { + DEVICE_PATH_TYPE_MEDIA_DEVICE, + DEVICE_PATH_SUB_TYPE_VENDOR_PATH, + sizeof(id_dp.vendor), + }, + EFI_INITRD_MEDIA_GUID, + }, + .end = { + DEVICE_PATH_TYPE_END, + DEVICE_PATH_SUB_TYPE_END, + sizeof(id_dp.end), + } + }; + + bo->file_info.current_path = calloc(1, EFICONFIG_FILE_PATH_BUF_SIZE); + if (!bo->file_info.current_path) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + + bo->initrd_info.current_path = calloc(1, EFICONFIG_FILE_PATH_BUF_SIZE); + if (!bo->file_info.current_path) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + + bo->description = calloc(1, EFICONFIG_DESCRIPTION_MAX * sizeof(u16)); + if (!bo->description) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + + bo->optional_data = calloc(1, EFICONFIG_OPTIONAL_DATA_MAX * sizeof(u16)); + if (!bo->optional_data) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + + /* copy the preset value */ + if (load_option) { + ret = efi_deserialize_load_option(&lo, load_option, &size); + if (ret != EFI_SUCCESS) + goto out; + + if (!lo.label || (lo.label && u16_strlen(lo.label) >= EFICONFIG_DESCRIPTION_MAX)) { + ret = EFI_INVALID_PARAMETER; + goto out; + } + u16_strcpy(bo->description, lo.label); + + /* EFI image file path is a first instance */ + if (lo.file_path) + fill_file_info(lo.file_path, &bo->file_info, device_dp); + + /* Initrd file path(optional) is placed at second instance. */ + initrd_dp = efi_dp_from_lo(&lo, &efi_lf2_initrd_guid); + if (initrd_dp) { + fill_file_info(initrd_dp, &bo->initrd_info, initrd_device_dp); + efi_free_pool(initrd_dp); + } + + if (size > 0) + memcpy(bo->optional_data, lo.optional_data, size); + } + + while (1) { + ret = eficonfig_show_boot_option(bo, header_str); + if (ret == EFI_SUCCESS && bo->edit_completed) + break; + if (ret == EFI_NOT_READY) + continue; + if (ret != EFI_SUCCESS) + goto out; + } + + if (bo->initrd_info.dp_volume) { + dp = create_selected_device_path(&bo->initrd_info); + if (!dp) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + initrd_dp = efi_dp_append((const struct efi_device_path *)&id_dp, dp); + efi_free_pool(dp); + } + + dp = create_selected_device_path(&bo->file_info); + if (!dp) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + final_dp_size = efi_dp_size(dp) + sizeof(END); + if (initrd_dp) { + final_dp = efi_dp_concat(dp, initrd_dp); + final_dp_size += efi_dp_size(initrd_dp) + sizeof(END); + } else { + final_dp = efi_dp_dup(dp); + } + efi_free_pool(dp); + + if (!final_dp) + goto out; + + if (utf16_utf8_strlen(bo->optional_data)) { + len = utf16_utf8_strlen(bo->optional_data) + 1; + tmp = calloc(1, len); + if (!tmp) + goto out; + p = tmp; + utf16_utf8_strncpy(&p, bo->optional_data, u16_strlen(bo->optional_data)); + } + + ret = eficonfig_set_boot_option(varname, final_dp, final_dp_size, bo->description, tmp); + if (ret != EFI_SUCCESS) + goto out; +out: + free(tmp); + free(bo->optional_data); + free(bo->description); + free(bo->file_info.current_path); + free(bo->initrd_info.current_path); + efi_free_pool(device_dp); + efi_free_pool(initrd_device_dp); + efi_free_pool(initrd_dp); + efi_free_pool(final_dp); + + return ret; +} + +/** + * eficonfig_process_add_boot_option() - handler to add boot option + * + * @data: pointer to the data for each entry + * Return: status code + */ +static efi_status_t eficonfig_process_add_boot_option(void *data) +{ + u16 varname[9]; + efi_status_t ret; + struct eficonfig_boot_option *bo = NULL; + + bo = calloc(1, sizeof(struct eficonfig_boot_option)); + if (!bo) + return EFI_OUT_OF_RESOURCES; + + ret = eficonfig_get_unused_bootoption(varname, sizeof(varname), &bo->boot_index); + if (ret != EFI_SUCCESS) + return ret; + + ret = eficonfig_edit_boot_option(varname, bo, NULL, 0, " ** Add Boot Option ** "); + if (ret != EFI_SUCCESS) + goto out; + + ret = eficonfig_append_bootorder((u16)bo->boot_index); + if (ret != EFI_SUCCESS) + goto out; + +out: + free(bo); + + /* to stay the parent menu */ + ret = (ret == EFI_ABORTED) ? EFI_SUCCESS : ret; + + return ret; +} + +/** + * eficonfig_init() - do required initialization for eficonfig command + * + * Return: status code + */ +static efi_status_t eficonfig_init(void) +{ + efi_status_t ret = EFI_SUCCESS; + static bool init; + struct efi_handler *handler; + + if (!init) { + ret = efi_search_protocol(efi_root, &efi_guid_text_input_protocol, &handler); + if (ret != EFI_SUCCESS) + return ret; + + ret = efi_protocol_open(handler, (void **)&cin, efi_root, NULL, + EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) + return ret; + } + + init = true; + + return ret; +} + +static const struct eficonfig_item maintenance_menu_items[] = { + {"Add Boot Option", eficonfig_process_add_boot_option}, + {"Quit", eficonfig_process_quit}, +}; + +/** + * do_eficonfig() - execute `eficonfig` command + * + * @cmdtp: table entry describing command + * @flag: bitmap indicating how the command was invoked + * @argc: number of arguments + * @argv: command line arguments + * Return: status code + */ +static int do_eficonfig(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + efi_status_t ret; + struct efimenu *efi_menu; + + if (argc > 1) + return CMD_RET_USAGE; + + ret = efi_init_obj_list(); + if (ret != EFI_SUCCESS) { + log_err("Error: Cannot initialize UEFI sub-system, r = %lu\n", + ret & ~EFI_ERROR_MASK); + + return CMD_RET_FAILURE; + } + + ret = eficonfig_init(); + if (ret != EFI_SUCCESS) + return CMD_RET_FAILURE; + + while (1) { + efi_menu = eficonfig_create_fixed_menu(maintenance_menu_items, + ARRAY_SIZE(maintenance_menu_items)); + if (!efi_menu) + return CMD_RET_FAILURE; + + ret = eficonfig_process_common(efi_menu, " ** UEFI Maintenance Menu **"); + eficonfig_destroy(efi_menu); + + if (ret == EFI_ABORTED) + break; + } + + return CMD_RET_SUCCESS; +} + +U_BOOT_CMD( + eficonfig, 1, 0, do_eficonfig, + "provide menu-driven UEFI variable maintenance interface", + "" +); diff --git a/include/efi_config.h b/include/efi_config.h new file mode 100644 index 0000000000..ea5bc4e1bf --- /dev/null +++ b/include/efi_config.h @@ -0,0 +1,96 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Menu-driven UEFI Variable maintenance + * + * Copyright (c) 2022 Masahisa Kojima, Linaro Limited + */ + +#ifndef _EFI_CONFIG_H +#define _EFI_CONFIG_H + +#include <efi_loader.h> + +#define EFICONFIG_ENTRY_NUM_MAX 99 +#define EFICONFIG_FILE_PATH_MAX 512 +#define EFICONFIG_FILE_PATH_BUF_SIZE (EFICONFIG_FILE_PATH_MAX * sizeof(u16)) + +typedef efi_status_t (*eficonfig_entry_func)(void *data); + +/** + * struct eficonfig_entry - menu entry structure + * + * @num: menu entry index + * @title: title of entry + * @key: unique key + * @efi_menu: pointer to the menu structure + * @func: callback function to be called when this entry is selected + * @data: data to be passed to the callback function, caller must free() this pointer + * @list: list structure + */ +struct eficonfig_entry { + u32 num; + char *title; + char key[3]; + struct efimenu *efi_menu; + eficonfig_entry_func func; + void *data; + struct list_head list; +}; + +/** + * struct efimenu - efi menu structure + * + * @delay: delay for autoboot + * @active: active menu entry index + * @count: total count of menu entry + * @menu_header: menu header string + * @list: menu entry list structure + */ +struct efimenu { + int delay; + int active; + int count; + char *menu_header; + struct list_head list; +}; + +/** + * struct eficonfig_item - structure to construct eficonfig_entry + * + * @title: title of entry + * @func: callback function to be called when this entry is selected + * @data: data to be passed to the callback function + */ +struct eficonfig_item { + char *title; + eficonfig_entry_func func; + void *data; +}; + +/** + * struct eficonfig_select_file_info - structure to be used for file selection + * + * @current_volume: pointer to the efi_simple_file_system_protocol + * @dp_volume: pointer to device path of the selected device + * @current_path: pointer to the selected file path string + * @filepath_list: list_head structure for file path list + * @file_selectred: flag indicates file selecting status + */ +struct eficonfig_select_file_info { + struct efi_simple_file_system_protocol *current_volume; + struct efi_device_path *dp_volume; + u16 *current_path; + struct list_head filepath_list; + bool file_selected; +}; + +void eficonfig_print_msg(char *msg); +void eficonfig_destroy(struct efimenu *efi_menu); +efi_status_t eficonfig_process_quit(void *data); +efi_status_t eficonfig_process_common(struct efimenu *efi_menu, char *menu_header); +efi_status_t eficonfig_select_file_handler(void *data); +efi_status_t eficonfig_get_unused_bootoption(u16 *buf, + efi_uintn_t buf_size, u32 *index); +efi_status_t eficonfig_append_bootorder(u16 index); + +#endif diff --git a/include/efi_loader.h b/include/efi_loader.h index b0d6fff67c..4461f721e0 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -142,6 +142,11 @@ static inline efi_status_t efi_launch_capsules(void) EFI_GUID(0x63293792, 0xadf5, 0x9325, \ 0xb9, 0x9f, 0x4e, 0x0e, 0x45, 0x5c, 0x1b, 0x1e)
+/* GUID for the auto generated boot menu entry */ +#define EFICONFIG_AUTO_GENERATED_ENTRY_GUID \ + EFI_GUID(0x38c1acc1, 0x9fc0, 0x41f0, \ + 0xb9, 0x01, 0xfa, 0x74, 0xd6, 0xd6, 0xe4, 0xde) + /* Use internal device tree when starting UEFI application */ #define EFI_FDT_USE_INTERNAL NULL
@@ -226,6 +231,9 @@ const char *__efi_nesting_dec(void); #define EFI_CACHELINE_SIZE 128 #endif
+/* max bootmenu title size for volume selection */ +#define BOOTMENU_DEVICE_NAME_MAX 16 + /* Key identifying current memory map */ extern efi_uintn_t efi_memory_map_key;
@@ -249,6 +257,9 @@ extern const struct efi_hii_string_protocol efi_hii_string;
uint16_t *efi_dp_str(struct efi_device_path *dp);
+/* GUID for the auto generated boot menu entry */ +extern const efi_guid_t efi_guid_bootmenu_auto_generated; + /* GUID of the U-Boot root node */ extern const efi_guid_t efi_u_boot_guid; #ifdef CONFIG_SANDBOX @@ -314,6 +325,8 @@ extern const efi_guid_t efi_guid_firmware_management_protocol; extern const efi_guid_t efi_esrt_guid; /* GUID of the SMBIOS table */ extern const efi_guid_t smbios_guid; +/*GUID of console */ +extern const efi_guid_t efi_guid_text_input_protocol;
extern char __efi_runtime_start[], __efi_runtime_stop[]; extern char __efi_runtime_rel_start[], __efi_runtime_rel_stop[]; @@ -1064,4 +1077,28 @@ efi_status_t efi_esrt_populate(void); efi_status_t efi_load_capsule_drivers(void);
efi_status_t platform_get_eventlog(struct udevice *dev, u64 *addr, u32 *sz); + +efi_status_t efi_locate_handle_buffer_int(enum efi_locate_search_type search_type, + const efi_guid_t *protocol, void *search_key, + efi_uintn_t *no_handles, efi_handle_t **buffer); + +efi_status_t efi_open_volume_int(struct efi_simple_file_system_protocol *this, + struct efi_file_handle **root); +efi_status_t efi_file_open_int(struct efi_file_handle *this, + struct efi_file_handle **new_handle, + u16 *file_name, u64 open_mode, + u64 attributes); +efi_status_t efi_file_close_int(struct efi_file_handle *file); +efi_status_t efi_file_read_int(struct efi_file_handle *this, + efi_uintn_t *buffer_size, void *buffer); +efi_status_t efi_file_setpos_int(struct efi_file_handle *file, u64 pos); + +typedef efi_status_t (*efi_console_filter_func)(struct efi_input_key *key); +efi_status_t efi_console_get_u16_string + (struct efi_simple_text_input_protocol *cin, + u16 *buf, efi_uintn_t count, efi_console_filter_func filer_func, + int row, int col); + +efi_status_t efi_disk_get_device_name(const efi_handle_t handle, char *buf, int size); + #endif /* _EFI_LOADER_H */ diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index 234073ecb7..ede9116b3c 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -19,6 +19,9 @@ static const struct efi_boot_services *bs; static const struct efi_runtime_services *rs;
+const efi_guid_t efi_guid_bootmenu_auto_generated = + EFICONFIG_AUTO_GENERATED_ENTRY_GUID; + /* * bootmgr implements the logic of trying to find a payload to boot * based on the BootOrder + BootXXXX variables, and then loading it. diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 4da64b5d29..1233418e77 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -2453,6 +2453,35 @@ static efi_status_t EFIAPI efi_protocols_per_handle( return EFI_EXIT(EFI_SUCCESS); }
+efi_status_t efi_locate_handle_buffer_int(enum efi_locate_search_type search_type, + const efi_guid_t *protocol, void *search_key, + efi_uintn_t *no_handles, efi_handle_t **buffer) +{ + efi_status_t r; + efi_uintn_t buffer_size = 0; + + if (!no_handles || !buffer) { + r = EFI_INVALID_PARAMETER; + goto out; + } + *no_handles = 0; + *buffer = NULL; + r = efi_locate_handle(search_type, protocol, search_key, &buffer_size, + *buffer); + if (r != EFI_BUFFER_TOO_SMALL) + goto out; + r = efi_allocate_pool(EFI_BOOT_SERVICES_DATA, buffer_size, + (void **)buffer); + if (r != EFI_SUCCESS) + goto out; + r = efi_locate_handle(search_type, protocol, search_key, &buffer_size, + *buffer); + if (r == EFI_SUCCESS) + *no_handles = buffer_size / sizeof(efi_handle_t); +out: + return r; +} + /** * efi_locate_handle_buffer() - locate handles implementing a protocol * @search_type: selection criterion @@ -2474,30 +2503,13 @@ efi_status_t EFIAPI efi_locate_handle_buffer( efi_uintn_t *no_handles, efi_handle_t **buffer) { efi_status_t r; - efi_uintn_t buffer_size = 0;
EFI_ENTRY("%d, %pUs, %p, %p, %p", search_type, protocol, search_key, no_handles, buffer);
- if (!no_handles || !buffer) { - r = EFI_INVALID_PARAMETER; - goto out; - } - *no_handles = 0; - *buffer = NULL; - r = efi_locate_handle(search_type, protocol, search_key, &buffer_size, - *buffer); - if (r != EFI_BUFFER_TOO_SMALL) - goto out; - r = efi_allocate_pool(EFI_BOOT_SERVICES_DATA, buffer_size, - (void **)buffer); - if (r != EFI_SUCCESS) - goto out; - r = efi_locate_handle(search_type, protocol, search_key, &buffer_size, - *buffer); - if (r == EFI_SUCCESS) - *no_handles = buffer_size / sizeof(efi_handle_t); -out: + r = efi_locate_handle_buffer_int(search_type, protocol, search_key, + no_handles, buffer); + return EFI_EXIT(r); }
diff --git a/lib/efi_loader/efi_console.c b/lib/efi_loader/efi_console.c index 3164fd484e..5be509f0d6 100644 --- a/lib/efi_loader/efi_console.c +++ b/lib/efi_loader/efi_console.c @@ -7,6 +7,7 @@
#define LOG_CATEGORY LOGC_EFI
+#include <ansi.h> #include <common.h> #include <charset.h> #include <malloc.h> @@ -1318,3 +1319,72 @@ out_of_memory: printf("ERROR: Out of memory\n"); return r; } + +/** + * efi_console_get_u16_string() - get user input string + * + * @cin: protocol interface to EFI_SIMPLE_TEXT_INPUT_PROTOCOL + * @buf: buffer to store user input string in UTF16 + * @count: number of u16 string including NULL terminator that buf has + * @filter_func: callback to filter user input + * @row: row number to locate user input form + * @col: column number to locate user input form + * Return: status code + */ +efi_status_t efi_console_get_u16_string(struct efi_simple_text_input_protocol *cin, + u16 *buf, efi_uintn_t count, + efi_console_filter_func filter_func, + int row, int col) +{ + efi_status_t ret; + efi_uintn_t len = 0; + struct efi_input_key key; + + printf(ANSI_CURSOR_POSITION + ANSI_CLEAR_LINE_TO_END + ANSI_CURSOR_SHOW, row, col); + + ret = EFI_CALL(cin->reset(cin, false)); + if (ret != EFI_SUCCESS) + return ret; + + for (;;) { + do { + ret = EFI_CALL(cin->read_key_stroke(cin, &key)); + mdelay(10); + } while (ret == EFI_NOT_READY); + + if (key.unicode_char == u'\b') { + if (len > 0) + buf[--len] = u'\0'; + + printf(ANSI_CURSOR_POSITION + "%ls" + ANSI_CLEAR_LINE_TO_END, row, col, buf); + continue; + } else if (key.unicode_char == u'\r') { + buf[len] = u'\0'; + return EFI_SUCCESS; + } else if (key.unicode_char == 0x3 || key.scan_code == 23) { + return EFI_ABORTED; + } else if (key.unicode_char < 0x20) { + /* ignore control codes other than Ctrl+C, '\r' and '\b' */ + continue; + } else if (key.scan_code != 0) { + /* only accept single ESC press for cancel */ + continue; + } + + if (filter_func) { + if (filter_func(&key) != EFI_SUCCESS) + continue; + } + + if (len >= (count - 1)) + continue; + + buf[len] = key.unicode_char; + len++; + printf(ANSI_CURSOR_POSITION "%ls", row, col, buf); + } +} diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index f269abf135..a34ca46a11 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -760,3 +760,53 @@ efi_status_t efi_disk_init(void)
return EFI_SUCCESS; } + +/** + * efi_disk_get_device_name() - get U-Boot device name associated with EFI handle + * + * @handle: pointer to the EFI handle + * @buf: pointer to the buffer to store the string + * @size: size of buffer + * Return: status code + */ +efi_status_t efi_disk_get_device_name(const efi_handle_t handle, char *buf, int size) +{ + int count; + int diskid; + enum uclass_id id; + unsigned int part; + struct udevice *dev; + struct blk_desc *desc; + const char *if_typename; + bool is_partition = false; + struct disk_part *part_data; + + if (!handle || !buf || !size) + return EFI_INVALID_PARAMETER; + + dev = handle->dev; + id = device_get_uclass_id(dev); + if (id == UCLASS_BLK) { + desc = dev_get_uclass_plat(dev); + } else if (id == UCLASS_PARTITION) { + desc = dev_get_uclass_plat(dev_get_parent(dev)); + is_partition = true; + } else { + return EFI_INVALID_PARAMETER; + } + if_typename = blk_get_if_type_name(desc->if_type); + diskid = desc->devnum; + + if (is_partition) { + part_data = dev_get_uclass_plat(dev); + part = part_data->partnum; + count = snprintf(buf, size, "%s %d:%d", if_typename, diskid, part); + } else { + count = snprintf(buf, size, "%s %d", if_typename, diskid); + } + + if (count < 0 || (count + 1) > size) + return EFI_INVALID_PARAMETER; + + return EFI_SUCCESS; +} diff --git a/lib/efi_loader/efi_file.c b/lib/efi_loader/efi_file.c index 7a7077e6d0..c96a7f7ca3 100644 --- a/lib/efi_loader/efi_file.c +++ b/lib/efi_loader/efi_file.c @@ -246,10 +246,10 @@ error: return NULL; }
-static efi_status_t efi_file_open_int(struct efi_file_handle *this, - struct efi_file_handle **new_handle, - u16 *file_name, u64 open_mode, - u64 attributes) +efi_status_t efi_file_open_int(struct efi_file_handle *this, + struct efi_file_handle **new_handle, + u16 *file_name, u64 open_mode, + u64 attributes) { struct file_handle *fh = to_fh(this); efi_status_t ret; @@ -369,11 +369,17 @@ static efi_status_t file_close(struct file_handle *fh) return EFI_SUCCESS; }
-static efi_status_t EFIAPI efi_file_close(struct efi_file_handle *file) +efi_status_t efi_file_close_int(struct efi_file_handle *file) { struct file_handle *fh = to_fh(file); + + return file_close(fh); +} + +static efi_status_t EFIAPI efi_file_close(struct efi_file_handle *file) +{ EFI_ENTRY("%p", file); - return EFI_EXIT(file_close(fh)); + return EFI_EXIT(efi_file_close_int(file)); }
static efi_status_t EFIAPI efi_file_delete(struct efi_file_handle *file) @@ -562,8 +568,8 @@ static efi_status_t dir_read(struct file_handle *fh, u64 *buffer_size, return EFI_SUCCESS; }
-static efi_status_t efi_file_read_int(struct efi_file_handle *this, - efi_uintn_t *buffer_size, void *buffer) +efi_status_t efi_file_read_int(struct efi_file_handle *this, + efi_uintn_t *buffer_size, void *buffer) { struct file_handle *fh = to_fh(this); efi_status_t ret = EFI_SUCCESS; @@ -773,24 +779,11 @@ out: return EFI_EXIT(ret); }
-/** - * efi_file_setpos() - set current position in file - * - * This function implements the SetPosition service of the EFI file protocol. - * See the UEFI spec for details. - * - * @file: file handle - * @pos: new file position - * Return: status code - */ -static efi_status_t EFIAPI efi_file_setpos(struct efi_file_handle *file, - u64 pos) +efi_status_t efi_file_setpos_int(struct efi_file_handle *file, u64 pos) { struct file_handle *fh = to_fh(file); efi_status_t ret = EFI_SUCCESS;
- EFI_ENTRY("%p, %llu", file, pos); - if (fh->isdir) { if (pos != 0) { ret = EFI_UNSUPPORTED; @@ -812,6 +805,28 @@ static efi_status_t EFIAPI efi_file_setpos(struct efi_file_handle *file, fh->offset = pos;
error: + return ret; +} + +/** + * efi_file_setpos() - set current position in file + * + * This function implements the SetPosition service of the EFI file protocol. + * See the UEFI spec for details. + * + * @file: file handle + * @pos: new file position + * Return: status code + */ +static efi_status_t EFIAPI efi_file_setpos(struct efi_file_handle *file, + u64 pos) +{ + efi_status_t ret = EFI_SUCCESS; + + EFI_ENTRY("%p, %llu", file, pos); + + ret = efi_file_setpos_int(file, pos); + return EFI_EXIT(ret); }
@@ -1138,17 +1153,23 @@ struct efi_file_handle *efi_file_from_path(struct efi_device_path *fp) return f; }
+efi_status_t efi_open_volume_int(struct efi_simple_file_system_protocol *this, + struct efi_file_handle **root) +{ + struct file_system *fs = to_fs(this); + + *root = file_open(fs, NULL, NULL, 0, 0); + + return EFI_SUCCESS; +} + static efi_status_t EFIAPI efi_open_volume(struct efi_simple_file_system_protocol *this, struct efi_file_handle **root) { - struct file_system *fs = to_fs(this); - EFI_ENTRY("%p, %p", this, root);
- *root = file_open(fs, NULL, NULL, 0, 0); - - return EFI_EXIT(EFI_SUCCESS); + return EFI_EXIT(efi_open_volume_int(this, root)); }
On 9/2/22 16:23, Masahisa Kojima wrote:
This commit add the "eficonfig" command. The "eficonfig" command implements the menu-driven UEFI boot option maintenance feature. This commit implements the addition of new boot option. User can select the block device volume having efi_simple_file_system_protocol and select the file corresponding to the Boot#### variable. User can also enter the description and optional_data of the BOOT#### variable in utf8.
This commit adds "include/efi_config.h", it contains the common definition to be used from other menus such as UEFI Secure Boot key management.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org
Changes in v15:
- moves the free(entry->data) outside the eficonfig_destroy() function and entry->data is freed explicitly only when needed
- expose eficonfig_destroy() for succeeding secure boot key management patch
Changes in v14:
- fix the missing initialization
- add comment for key handling
No change in v13:
Changes in v12:
- add select/clear menu before displaying volume selectio
- move function declaration from efi_loader.h to efi_config.h
- remove unused declaration
- support the boot option does not have file path
- correctly handle if optional_data is empty
Changes in v11:
- refactor menu entry construction, directly use eficonfig_entry structure
- remove reading directory info to calculate the number of entry
- fix invalid efi_free_pool() in ill_file_info()
- use ANSI_CURSOR_POSITION and ANSI_CLEAR_LINE instead of printf("\n") since current eficonfig implementation does not handle console size correctly. printf("\n") at the outside of console size breaks the console output.
Changes in v10:
- add initrd file selection
- do refactoring
- eficonfig_process_common() use list structure
- remove u'/' before copying file_path into current_path
- fix typos
- check snprintf error
Changes in v9:
- move "efi_guid_bootmenu_auto_generated definition" into efi_bootmgr.c to address build error when CMD_EFICONFIG is disabled
- fix typos and comment
- remove file system information from error message
- remove unreachable code in eficonfig_choice_entry()
- single printf() call as much as possible
- call only getchar() in eficonfig_print_msg()
- filter out '.' entry from file selection
- update the efi_disk_get_device_name() implementation
- add function comment
Changes in v8:
- command name is change from "efimenu" to "eficonfig"
- function and struct prefixes is changed to "eficonfig"
- fix menu header string
Changes in v7:
add "efimenu" command and uefi variable maintenance code moved into cmd/efimenu.c
create include/efimenu.h to define the common definition for the other menu such as UEFI Secure Boot key management
update boot option edit UI, user can select description, file, and optional_data to edit in the same menu like following.
** Edit Boot Option **
Description: debian File: virtio 0:1/EFI\debian\grubaa64.efi Optional Data: test Save Quit
remove exit parameter from efimenu_process_common()
menu title type is changed from u16 to char
efimenu_process_common() add menu title string
reduce printf/puts function call for displaying the menu
efi_console_get_u16_string() accept 0 length to allow optional_data is empty
efi_console_get_u16_string() the "size" parameter name is changes to "count"
efimenu is now designed to maintain the UEFI variables, remove autoboot related code
remove one empty line before "Quit" entry
efimenu_init() processes only the first time
Changes in v6:
- fix typos
- modify volume name to match U-Boot syntax
- compile in CONFIG_EFI_LOADER=n and CONFIG_CMD_BOOTEFI_BOOTMGR=n
- simplify u16_strncmp() usage
- support "a\b.efi" file path, use link list to handle filepath
- modify length check condition
- UEFI related menu items only appears with CONFIG_AUTOBOOT_MENU_SHOW=y
Changes in v5:
- remove forward declarations
- add const qualifier for menu items
- fix the possible unaligned access for directory info access
- split into three commit 1)add boot option 2) delete boot option 3)change boot order This commit is 1)add boot option.
- fix file name buffer allocation size, it should be EFI_BOOTMENU_FILE_PATH_MAX * sizeof(u16)
- fix wrong size checking for file selection
Chanes in v4:
- UEFI boot option maintenance menu is integrated into bootmenu
- display the simplified volume name(e.g. usb0:1, nvme1:2) for the volume selection
- instead of extending lib/efi_loader/efi_bootmgr.c, newly create lib/efi_loader/efi_bootmenu_maintenance.c and implement boot variable maintenance into it.
Changes in RFC v3: not included in v3 series
Changes in RFC v2:
enable utf8 user input for boot option name
create lib/efi_loader/efi_console.c::efi_console_get_u16_string() for utf8 user input handling
use u16_strlcat instead of u16_strcat
remove the EFI_CALLs, and newly create or expose the following xxx_int() functions. efi_locate_handle_buffer_int(), efi_open_volume_int(), efi_file_open_int(), efi_file_close_int(), efi_file_read_int() and efi_file_setpos_int(). Note that EFI_CALLs still exist for EFI_DEVICE_PATH_TO_TEXT_PROTOCOL and EFI_SIMPLE_TEXT_INPUT/OUTPUT_PROTOCOL
use efi_search_protocol() instead of calling locate_protocol() to get the device_path_to_text_protocol interface.
remove unnecessary puts(ANSI_CLEAR_LINE), this patch is still depends on puts(ANSI_CLEAR_CONSOLE)
skip SetVariable() if the bootorder is not changed
cmd/Kconfig | 7 + cmd/Makefile | 1 + cmd/eficonfig.c | 1568 +++++++++++++++++++++++++++++++++ include/efi_config.h | 96 ++ include/efi_loader.h | 37 + lib/efi_loader/efi_bootmgr.c | 3 + lib/efi_loader/efi_boottime.c | 52 +- lib/efi_loader/efi_console.c | 70 ++ lib/efi_loader/efi_disk.c | 50 ++ lib/efi_loader/efi_file.c | 75 +- 10 files changed, 1912 insertions(+), 47 deletions(-) create mode 100644 cmd/eficonfig.c create mode 100644 include/efi_config.h
diff --git a/cmd/Kconfig b/cmd/Kconfig index 211ebe9c87..a1e8613c56 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1928,6 +1928,13 @@ config CMD_EFIDEBUG particularly for managing boot parameters as well as examining various EFI status for debugging.
+config CMD_EFICONFIG
- bool "eficonfig - provide menu-driven uefi variables maintenance interface"
- depends on CMD_BOOTEFI_BOOTMGR
- help
Enable the 'eficonfig' command which provides the menu-driven UEFI
variable maintenance interface.
- config CMD_EXCEPTION bool "exception - raise exception" depends on ARM || RISCV || SANDBOX || X86
diff --git a/cmd/Makefile b/cmd/Makefile index 6e87522b62..18f5cb890d 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -63,6 +63,7 @@ obj-$(CONFIG_ENV_IS_IN_EEPROM) += eeprom.o obj-$(CONFIG_CMD_EEPROM) += eeprom.o obj-$(CONFIG_EFI) += efi.o obj-$(CONFIG_CMD_EFIDEBUG) += efidebug.o +obj-$(CONFIG_CMD_EFICONFIG) += eficonfig.o obj-$(CONFIG_CMD_ELF) += elf.o obj-$(CONFIG_CMD_EROFS) += erofs.o obj-$(CONFIG_HUSH_PARSER) += exit.o diff --git a/cmd/eficonfig.c b/cmd/eficonfig.c new file mode 100644 index 0000000000..30ce55d055 --- /dev/null +++ b/cmd/eficonfig.c @@ -0,0 +1,1568 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- Menu-driven UEFI Variable maintenance
- Copyright (c) 2022 Masahisa Kojima, Linaro Limited
+#include <ansi.h> +#include <common.h> +#include <charset.h> +#include <efi_loader.h> +#include <efi_load_initrd.h> +#include <efi_config.h> +#include <efi_variable.h> +#include <log.h> +#include <malloc.h> +#include <menu.h> +#include <watchdog.h> +#include <asm/unaligned.h> +#include <linux/delay.h>
+static struct efi_simple_text_input_protocol *cin;
+#define EFICONFIG_DESCRIPTION_MAX 32 +#define EFICONFIG_OPTIONAL_DATA_MAX 64
- struct eficonfig_filepath_info - structure to be used to store file path
- @name: file or directory name
- @list: list structure
+struct eficonfig_filepath_info {
- u16 *name;
- struct list_head list;
- struct eficonfig_boot_option - structure to be used for updating UEFI boot option
- @file_info: user selected file info
- @initrd_info: user selected initrd file info
- @boot_index: index of the boot option
- @description: pointer to the description string
- @optional_data: pointer to the optional_data
- @edit_completed: flag indicates edit complete
+struct eficonfig_boot_option {
- struct eficonfig_select_file_info file_info;
- struct eficonfig_select_file_info initrd_info;
- unsigned int boot_index;
- u16 *description;
- u16 *optional_data;
- bool edit_completed;
- struct eficonfig_volume_entry_data - structure to be used to store volume info
- @file_info: pointer to file info structure
- @v: pointer to the protocol interface
- @dp: pointer to the device path
+struct eficonfig_volume_entry_data {
- struct eficonfig_select_file_info *file_info;
- struct efi_simple_file_system_protocol *v;
- struct efi_device_path *dp;
- struct eficonfig_file_entry_data - structure to be used to store file info
- @is_directory: flag to identify the directory or file
- @file_name: name of directory or file
+struct eficonfig_file_entry_data {
- bool is_directory;
- u16 *file_name;
- eficonfig_print_msg() - print message
- display the message to the user, user proceeds the screen
- with any key press.
- @items: pointer to the structure of each menu entry
- @count: the number of menu entry
- @menu_header: pointer to the menu header string
- Return: status code
+void eficonfig_print_msg(char *msg) +{
- /* Flush input */
- while (tstc())
getchar();
- printf(ANSI_CURSOR_HIDE
ANSI_CLEAR_CONSOLE
"%s\n\n Press any key to continue", 3, 4, msg);
- getchar();
- eficonfig_print_entry() - print each menu entry
- @data: pointer to the data associated with each menu entry
+static void eficonfig_print_entry(void *data) +{
- struct eficonfig_entry *entry = data;
- int reverse = (entry->efi_menu->active == entry->num);
- /* TODO: support scroll or page for many entries */
* Move cursor to line where the entry will be drawn (entry->num)
* First 3 lines(menu header) + 1 empty line
- printf(ANSI_CURSOR_POSITION, entry->num + 4, 7);
- if (reverse)
puts(ANSI_COLOR_REVERSE);
- printf("%s", entry->title);
- if (reverse)
puts(ANSI_COLOR_RESET);
- eficonfig_display_statusline() - print status line
- @m: pointer to the menu structure
+static void eficonfig_display_statusline(struct menu *m) +{
- struct eficonfig_entry *entry;
- if (menu_default_choice(m, (void *)&entry) < 0)
return;
"\n%s\n"
ANSI_CURSOR_POSITION ANSI_CLEAR_LINE ANSI_CURSOR_POSITION
" Press UP/DOWN to move, ENTER to select, ESC/CTRL+C to quit"
ANSI_CLEAR_LINE_TO_END ANSI_CURSOR_POSITION ANSI_CLEAR_LINE,
1, 1, entry->efi_menu->menu_header, entry->efi_menu->count + 5, 1,
entry->efi_menu->count + 6, 1, entry->efi_menu->count + 7, 1);
- eficonfig_choice_entry() - user key input handler
- @data: pointer to the efimenu structure
- Return: key string to identify the selected entry
+static char *eficonfig_choice_entry(void *data) +{
- int esc = 0;
- struct list_head *pos, *n;
- enum bootmenu_key key = KEY_NONE;
- struct efimenu *efi_menu = data;
- while (1) {
bootmenu_loop((struct bootmenu_data *)efi_menu, &key, &esc);
switch (key) {
case KEY_UP:
if (efi_menu->active > 0)
--efi_menu->active;
/* no menu key selected, regenerate menu */
return NULL;
case KEY_DOWN:
if (efi_menu->active < efi_menu->count - 1)
++efi_menu->active;
return NULL;
case KEY_SELECT:
if (entry->num == efi_menu->active)
return entry->key;
break;
case KEY_QUIT:
/* Quit by choosing the last entry */
entry = list_last_entry(&efi_menu->list, struct eficonfig_entry, list);
return entry->key;
default:
/* Pressed key is not valid, no need to regenerate the menu */
break;
- eficonfig_destroy() - destroy efimenu
- @efi_menu: pointer to the efimenu structure
+void eficonfig_destroy(struct efimenu *efi_menu) +{
- list_for_each_safe(pos, n, &efi_menu->list) {
free(entry->title);
list_del(&entry->list);
free(entry);
- free(efi_menu->menu_header);
- free(efi_menu);
- eficonfig_process_quit() - callback function for "Quit" entry
+efi_status_t eficonfig_process_quit(void *data) +{
- return EFI_ABORTED;
- append_entry() - append menu item
- @title: pointer to the entry title
- @func: callback of each entry
- @data: pointer to the data to be passed to each entry callback
+static efi_status_t append_entry(struct efimenu *efi_menu,
char *title, eficonfig_entry_func func, void *data)
- if (efi_menu->count >= EFICONFIG_ENTRY_NUM_MAX)
- entry = calloc(1, sizeof(struct eficonfig_entry));
- if (!entry)
- entry->title = title;
- sprintf(entry->key, "%d", efi_menu->count);
- entry->efi_menu = efi_menu;
- entry->func = func;
- entry->data = data;
- entry->num = efi_menu->count++;
- list_add_tail(&entry->list, &efi_menu->list);
- return EFI_SUCCESS;
- append_quit_entry() - append quit entry
+static efi_status_t append_quit_entry(struct efimenu *efi_menu) +{
- char *title;
- efi_status_t ret;
- title = strdup("Quit");
- if (!title)
- ret = append_entry(efi_menu, title, eficonfig_process_quit, NULL);
- if (ret != EFI_SUCCESS)
free(title);
- return ret;
- eficonfig_create_fixed_menu() - create fixed entry menu structure
- @items: pointer to the menu entry item
- Return: pointer to the efimenu structure
+void *eficonfig_create_fixed_menu(const struct eficonfig_item *items, int count) +{
- u32 i;
- char *title;
- efi_status_t ret;
- struct efimenu *efi_menu;
- const struct eficonfig_item *iter = items;
- efi_menu = calloc(1, sizeof(struct efimenu));
- if (!efi_menu)
return NULL;
- INIT_LIST_HEAD(&efi_menu->list);
- for (i = 0; i < count; i++, iter++) {
title = strdup(iter->title);
if (!title)
goto out;
ret = append_entry(efi_menu, title, iter->func, iter->data);
free(title);
goto out;
- return efi_menu;
+out:
- eficonfig_destroy(efi_menu);
- return NULL;
- eficonfig_process_common() - main handler for UEFI menu
- Construct the structures required to show the menu, then handle
- the user input interacting with u-boot menu functions.
+efi_status_t eficonfig_process_common(struct efimenu *efi_menu, char *menu_header) +{
- struct menu *menu;
- void *choice = NULL;
- efi_status_t ret = EFI_SUCCESS;
- if (efi_menu->count > EFICONFIG_ENTRY_NUM_MAX)
- efi_menu->delay = -1;
- efi_menu->active = 0;
- if (menu_header) {
efi_menu->menu_header = strdup(menu_header);
This does not build:
+cmd/eficonfig.c:380:7: error: variable 'menu' is used uninitialized whenever 'if' condition is true [-Werror,-Wsometimes-uninitialized] + if (!efi_menu->menu_header) { + ^~~~~~~~~~~~~~~~~~~~~~ +cmd/eficonfig.c:416:15: note: uninitialized use occurs here + menu_destroy(menu); + ^~~~ +cmd/eficonfig.c:380:3: note: remove the 'if' if its condition is always false + ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~ +cmd/eficonfig.c:366:19: note: initialize the variable 'menu' to silence this warning + struct menu *menu; + ^ + = NULL
Best regards
Heinrich
goto out;
- menu = menu_create(NULL, 0, 1, eficonfig_display_statusline,
eficonfig_print_entry, eficonfig_choice_entry,
efi_menu);
- if (!menu) {
goto out;
if (!menu_item_add(menu, entry->key, entry)) {
goto out;
- entry = list_first_entry_or_null(&efi_menu->list, struct eficonfig_entry, list);
- if (entry)
menu_default_set(menu, entry->key);
ANSI_CLEAR_CONSOLE
ANSI_CURSOR_POSITION, 1, 1);
- if (menu_get_choice(menu, &choice)) {
entry = choice;
if (entry->func)
ret = entry->func(entry->data);
+out:
- menu_destroy(menu);
- printf(ANSI_CLEAR_CONSOLE
ANSI_CURSOR_SHOW, 1, 1);
- return ret;
- eficonfig_volume_selected() - handler of volume selection
- @data: pointer to the data of selected entry
+static efi_status_t eficonfig_volume_selected(void *data) +{
- struct eficonfig_volume_entry_data *info = data;
- if (info) {
info->file_info->current_volume = info->v;
info->file_info->dp_volume = info->dp;
- create_selected_device_path() - create device path
- @file_info: pointer to the selected file information
- Return:
- device path or NULL. Caller must free the returned value
+static +struct efi_device_path *create_selected_device_path(struct eficonfig_select_file_info *file_info) +{
- char *p;
- void *buf;
- efi_uintn_t fp_size;
- struct efi_device_path_file_path *fp;
- fp_size = sizeof(struct efi_device_path) +
((u16_strlen(file_info->current_path) + 1) * sizeof(u16));
- buf = calloc(1, fp_size + sizeof(END));
- if (!buf)
return NULL;
- fp = buf;
- fp->dp.type = DEVICE_PATH_TYPE_MEDIA_DEVICE,
- fp->dp.sub_type = DEVICE_PATH_SUB_TYPE_FILE_PATH,
- fp->dp.length = (u16)fp_size;
- u16_strcpy(fp->str, file_info->current_path);
- p = buf;
- p += fp_size;
- *((struct efi_device_path *)p) = END;
- dp = efi_dp_append(file_info->dp_volume, (struct efi_device_path *)buf);
- free(buf);
- return dp;
- eficonfig_file_selected() - handler of file selection
+static efi_status_t eficonfig_file_selected(void *data) +{
- struct eficonfig_file_entry_data *info = data;
- if (!info)
- if (u16_strcmp(info->file_name, u".") == 0 &&
u16_strlen(info->file_name) == 1) {
/* stay current path */
- } else if (u16_strcmp(info->file_name, u"..") == 0 &&
u16_strlen(info->file_name) == 2) {
struct eficonfig_filepath_info *iter;
int is_last;
memset(info->file_info->current_path, 0, EFICONFIG_FILE_PATH_BUF_SIZE);
list_for_each_safe(pos, n, &info->file_info->filepath_list) {
iter = list_entry(pos, struct eficonfig_filepath_info, list);
is_last = list_is_last(&iter->list, &info->file_info->filepath_list);
if (is_last) {
list_del(&iter->list);
free(iter->name);
free(iter);
break;
u16_strlcat(info->file_info->current_path, iter->name,
u16_strlcat(info->file_info->current_path, u"\\",
- } else {
size_t new_len;
struct eficonfig_filepath_info *filepath;
new_len = u16_strlen(info->file_info->current_path) +
u16_strlen(info->file_name);
if (new_len >= EFICONFIG_FILE_PATH_MAX) {
eficonfig_print_msg("File path is too long!");
u16_strlcat(info->file_info->current_path, info->file_name,
filepath = calloc(1, sizeof(struct eficonfig_filepath_info));
if (!filepath)
filepath->name = u16_strdup(info->file_name);
if (!filepath->name) {
free(filepath);
list_add_tail(&filepath->list, &info->file_info->filepath_list);
if (info->is_directory) {
* Remaining buffer should have enough space to contain u"\\" and
} else {
- eficonfig_select_volume() - construct the volume selection menu
- @file_info: pointer to the file selection structure
- u32 i;
- efi_status_t ret;
- efi_uintn_t count;
- struct efi_handler *handler;
- struct efi_device_path *device_path;
- efi_handle_t *volume_handles = NULL;
- ret = efi_locate_handle_buffer_int(BY_PROTOCOL, &efi_simple_file_system_protocol_guid,
- if (ret != EFI_SUCCESS) {
return ret;
- if (!efi_menu)
- for (i = 0; i < count; i++) {
char *devname;
break;
continue;
continue;
continue;
continue;
continue;
continue;
if (!info) {
goto out;
if (!devname) {
free(info);
goto out;
free(info);
goto out;
info->v = v;
free(info);
goto out;
- ret = append_quit_entry(efi_menu);
goto out;
- ret = eficonfig_process_common(efi_menu, " ** Select Volume **");
+out:
- efi_free_pool(volume_handles);
free(entry->data);
- return ret;
- eficonfig_select_file() - construct the file selection menu
- @root: pointer to the file handle
- efi_uintn_t len;
- efi_status_t ret;
- struct efi_file_handle *f;
- struct efi_file_info *buf;
- buf = calloc(1, sizeof(struct efi_file_info) + EFICONFIG_FILE_PATH_BUF_SIZE);
- if (!buf)
- while (!file_info->file_selected) {
if (!efi_menu) {
goto out;
ret = EFI_ABORTED;
goto out;
for (;;) {
char *name, *p;
int name_len;
break;
break;
if (!info) {
goto err;
free(info);
continue;
if (!name) {
free(info);
goto err;
p = name;
} else {
if (!name) {
free(info);
goto err;
p = name;
free(info);
free(name);
goto err;
free(info);
free(name);
goto err;
goto err;
+err:
/* skip "Quit" */
break;
free(entry->data);
break;
+out:
- free(buf);
- return ret;
- handle_user_input() - handle user input
- @buf: pointer to the buffer
- @buf_size: size of the buffer
- @cursor_col: cursor column for user input
- @msg: pointer to the string to display
- u16 *tmp;
- efi_status_t ret;
"%s"
0, 1, msg, 8, 1);
- /* tmp is used to accept user cancel */
- tmp = calloc(1, buf_size * sizeof(u16));
- if (!tmp)
- ret = efi_console_get_u16_string(cin, tmp, buf_size, NULL, 4, cursor_col);
- if (ret == EFI_SUCCESS)
- free(tmp);
- /* to stay the parent menu */
- ret = (ret == EFI_ABORTED) ? EFI_NOT_READY : ret;
- return ret;
- eficonfig_boot_add_enter_description() - handle user input for description
- @data: pointer to the internal boot option structure
- struct eficonfig_boot_option *bo = data;
- return handle_user_input(bo->description, EFICONFIG_DESCRIPTION_MAX, 22,
"\n"
- eficonfig_boot_add_optional_data() - handle user input for optional data
- return handle_user_input(bo->optional_data, EFICONFIG_OPTIONAL_DATA_MAX, 24,
"\n"
- eficonfig_boot_edit_save() - handler to save the boot option
- if (u16_strlen(bo->description) == 0) {
- if (u16_strlen(bo->file_info.current_path) == 0) {
- bo->edit_completed = true;
- eficonfig_process_select_file() - callback function for "Select File" entry
- eficonfig_process_clear_file_selection() - callback function for "Clear" entry
- struct eficonfig_select_file_info *file_info = data;
- /* clear the existing file information */
- file_info->current_volume = NULL;
- file_info->current_path[0] = u'\0';
- file_info->dp_volume = NULL;
- {"Select File", eficonfig_process_select_file},
- {"Clear", eficonfig_process_clear_file_selection},
- {"Quit", eficonfig_process_quit},
- eficonfig_display_select_file_option() - display select file option
- @file_info: pointer to the file information structure
- efi_status_t ret;
- select_file_menu_items[1].data = file_info;
- efi_menu = eficonfig_create_fixed_menu(select_file_menu_items,
- if (!efi_menu)
- ret = eficonfig_process_common(efi_menu, " ** Update File **");
- if (ret != EFI_SUCCESS) /* User selects "Clear" or "Quit" */
- return ret;
- eficonfig_select_file_handler() - handle user file selection
- size_t len;
- efi_status_t ret;
- struct efi_file_handle *root;
- struct eficonfig_filepath_info *item;
- struct eficonfig_select_file_info *tmp = NULL;
- ret = eficonfig_display_select_file_option(file_info);
return ret;
- tmp = calloc(1, sizeof(struct eficonfig_select_file_info));
- if (!tmp)
- tmp->current_path = calloc(1, EFICONFIG_FILE_PATH_BUF_SIZE);
- if (!tmp->current_path) {
free(tmp);
- INIT_LIST_HEAD(&tmp->filepath_list);
- while (!tmp->file_selected) {
goto out;
goto out;
continue;
goto out;
+out:
- if (ret == EFI_SUCCESS) {
- list_for_each_safe(pos, n, &tmp->filepath_list) {
free(item->name);
free(item);
- free(tmp->current_path);
- free(tmp);
- return ret;
- eficonfig_get_unused_bootoption() - get unused "Boot####" index
- @buf: pointer to the buffer to store boot option variable name
- @buf_size: buffer size
- @index: pointer to store the index in the BootOrder variable
- u32 i;
- efi_status_t ret;
- efi_uintn_t size;
- if (buf_size < u16_strsize(u"Boot####"))
- for (i = 0; i <= 0xFFFF; i++) {
size = 0;
continue;
else
break;
- if (i > 0xFFFF)
- *index = i;
- eficonfig_set_boot_option() - set boot option
- @varname: pointer to variable name
- @dp: pointer to device path
- @label: pointer to label string
- @optional_data: pointer to optional data
- void *p = NULL;
- efi_status_t ret;
- efi_uintn_t size;
- struct efi_load_option lo;
- lo.file_path = dp;
- lo.file_path_length = dp_size;
- lo.attributes = LOAD_OPTION_ACTIVE;
- lo.optional_data = optional_data;
- lo.label = label;
- size = efi_serialize_load_option(&lo, (u8 **)&p);
- if (!size)
- ret = efi_set_variable_int(varname, &efi_global_variable_guid,
size, p, false);
- free(p);
- return ret;
- eficonfig_append_bootorder() - append new boot option in BootOrder variable
- @index: "Boot####" index to append to BootOrder variable
- u16 *bootorder;
- efi_status_t ret;
- u16 *new_bootorder = NULL;
- efi_uintn_t last, size, new_size;
- /* append new boot option */
- bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size);
- last = size / sizeof(u16);
- new_size = size + sizeof(u16);
- new_bootorder = calloc(1, new_size);
- if (!new_bootorder) {
goto out;
- memcpy(new_bootorder, bootorder, size);
- new_bootorder[last] = index;
- ret = efi_set_variable_int(u"BootOrder", &efi_global_variable_guid,
goto out;
+out:
- free(bootorder);
- free(new_bootorder);
- return ret;
- create_boot_option_entry() - create boot option entry
- @val: pointer to boot option label
- u32 len;
- char *p, *buf;
- len = strlen(title) + 1;
- if (val)
- buf = calloc(1, len);
- if (!buf)
- strcpy(buf, title);
- if (val) {
- return append_entry(efi_menu, buf, func, data);
- prepare_file_selection_entry() - prepare file selection entry
- @title: pointer to the title string
- u32 len;
- efi_status_t ret;
- u16 *file_name, *p;
- efi_handle_t handle;
- char devname[BOOTMENU_DEVICE_NAME_MAX] = {0};
- /* get the device name only when the user already selected the file path */
- handle = efi_dp_find_obj(file_info->dp_volume, NULL, NULL);
- if (handle) {
return ret;
- /* append u'/' to devname, it is just for display purpose. */
- if (file_info->current_path[0] != u'\0' && file_info->current_path[0] != u'/')
- len = strlen(devname);
- len += utf16_utf8_strlen(file_info->current_path) + 1;
- file_name = calloc(1, len * sizeof(u16));
- if (!file_name)
return ret;
- p = file_name;
- utf8_utf16_strcpy(&p, devname);
- u16_strlcat(file_name, file_info->current_path, len);
- ret = create_boot_option_entry(efi_menu, title, file_name,
- free(file_name);
- return ret;
- eficonfig_show_boot_option() - prepare menu entry for editing boot option
- Construct the structures to create edit boot option menu
- @bo: pointer to the boot option
- @header_str: pointer to the header string
char *header_str)
- efi_status_t ret;
- if (!efi_menu)
- ret = create_boot_option_entry(efi_menu, "Description: ", bo->description,
goto out;
- ret = prepare_file_selection_entry(efi_menu, "File: ", &bo->file_info);
goto out;
- ret = prepare_file_selection_entry(efi_menu, "Initrd File: ", &bo->initrd_info);
goto out;
- ret = create_boot_option_entry(efi_menu, "Optional Data: ", bo->optional_data,
goto out;
- ret = create_boot_option_entry(efi_menu, "Save", NULL,
goto out;
- ret = create_boot_option_entry(efi_menu, "Quit", NULL,
goto out;
- ret = eficonfig_process_common(efi_menu, header_str);
+out:
- return ret;
- fill_file_info() - fill the file info from efi_device_path structure
- @file_info: pointer to the file info structure
- @device_dp: pointer to the volume device path
- u16 *file_str, *p;
- struct efi_device_path *file_dp = NULL;
- efi_dp_split_file_path(dp, &device_dp, &file_dp);
- file_info->dp_volume = device_dp;
- if (file_dp) {
p = file_str;
if (p[0] == u'/')
p++;
- eficonfig_edit_boot_option() - prepare boot option structure for editing
- Construct the boot option structure and copy the existing value
- @varname: pointer to the UEFI variable name
- @load_option: pointer to the load option
- @load_option_size: size of the load option
- Return : status code
char *header_str)
- size_t len;
- efi_status_t ret;
- char *tmp = NULL, *p;
- struct efi_load_option lo = {0};
- efi_uintn_t final_dp_size;
- struct efi_device_path *dp = NULL;
- efi_uintn_t size = load_option_size;
- struct efi_device_path *final_dp = NULL;
- struct efi_device_path *device_dp = NULL;
- struct efi_device_path *initrd_dp = NULL;
- struct efi_device_path *initrd_device_dp = NULL;
- const struct efi_initrd_dp id_dp = {
.vendor = {
.end = {
sizeof(id_dp.end),
- bo->file_info.current_path = calloc(1, EFICONFIG_FILE_PATH_BUF_SIZE);
- if (!bo->file_info.current_path) {
goto out;
- bo->initrd_info.current_path = calloc(1, EFICONFIG_FILE_PATH_BUF_SIZE);
goto out;
- bo->description = calloc(1, EFICONFIG_DESCRIPTION_MAX * sizeof(u16));
- if (!bo->description) {
goto out;
- bo->optional_data = calloc(1, EFICONFIG_OPTIONAL_DATA_MAX * sizeof(u16));
- if (!bo->optional_data) {
goto out;
- /* copy the preset value */
- if (load_option) {
goto out;
goto out;
if (lo.file_path)
if (initrd_dp) {
if (size > 0)
- while (1) {
break;
continue;
goto out;
- if (bo->initrd_info.dp_volume) {
if (!dp) {
goto out;
efi_free_pool(dp);
- dp = create_selected_device_path(&bo->file_info);
- if (!dp) {
goto out;
- final_dp_size = efi_dp_size(dp) + sizeof(END);
- if (initrd_dp) {
- } else {
- efi_free_pool(dp);
- if (!final_dp)
goto out;
- if (utf16_utf8_strlen(bo->optional_data)) {
if (!tmp)
goto out;
p = tmp;
- ret = eficonfig_set_boot_option(varname, final_dp, final_dp_size, bo->description, tmp);
goto out;
+out:
- free(tmp);
- free(bo->optional_data);
- free(bo->description);
- free(bo->file_info.current_path);
- free(bo->initrd_info.current_path);
- efi_free_pool(device_dp);
- efi_free_pool(initrd_device_dp);
- efi_free_pool(initrd_dp);
- efi_free_pool(final_dp);
- return ret;
- eficonfig_process_add_boot_option() - handler to add boot option
- @data: pointer to the data for each entry
- u16 varname[9];
- efi_status_t ret;
- struct eficonfig_boot_option *bo = NULL;
- bo = calloc(1, sizeof(struct eficonfig_boot_option));
- if (!bo)
- ret = eficonfig_get_unused_bootoption(varname, sizeof(varname), &bo->boot_index);
return ret;
- ret = eficonfig_edit_boot_option(varname, bo, NULL, 0, " ** Add Boot Option ** ");
goto out;
- ret = eficonfig_append_bootorder((u16)bo->boot_index);
goto out;
+out:
- free(bo);
- ret = (ret == EFI_ABORTED) ? EFI_SUCCESS : ret;
- return ret;
- eficonfig_init() - do required initialization for eficonfig command
- static bool init;
- if (!init) {
return ret;
return ret;
- init = true;
- return ret;
- {"Add Boot Option", eficonfig_process_add_boot_option},
- do_eficonfig() - execute `eficonfig` command
- @cmdtp: table entry describing command
- @flag: bitmap indicating how the command was invoked
- @argc: number of arguments
- @argv: command line arguments
- efi_status_t ret;
- if (argc > 1)
- ret = efi_init_obj_list();
- ret = eficonfig_init();
- while (1) {
if (!efi_menu)
break;
- return CMD_RET_SUCCESS;
+U_BOOT_CMD(
- eficonfig, 1, 0, do_eficonfig,
- "provide menu-driven UEFI variable maintenance interface",
- struct eficonfig_entry - menu entry structure
- @num: menu entry index
- @title: title of entry
- @key: unique key
- @efi_menu: pointer to the menu structure
- @func: callback function to be called when this entry is selected
- @data: data to be passed to the callback function, caller must free() this pointer
- u32 num;
- char *title;
- char key[3];
- eficonfig_entry_func func;
- void *data;
- struct efimenu - efi menu structure
- @delay: delay for autoboot
- @active: active menu entry index
- @count: total count of menu entry
- @menu_header: menu header string
- @list: menu entry list structure
+struct efimenu {
- int delay;
- int active;
- int count;
- char *menu_header;
- struct eficonfig_item - structure to construct eficonfig_entry
- char *title;
- void *data;
- struct eficonfig_select_file_info - structure to be used for file selection
- @current_volume: pointer to the efi_simple_file_system_protocol
- @dp_volume: pointer to device path of the selected device
- @current_path: pointer to the selected file path string
- @filepath_list: list_head structure for file path list
- @file_selectred: flag indicates file selecting status
- struct efi_simple_file_system_protocol *current_volume;
- struct efi_device_path *dp_volume;
- u16 *current_path;
- struct list_head filepath_list;
- bool file_selected;
- EFI_GUID(0x38c1acc1, 0x9fc0, 0x41f0, \
- /* Use internal device tree when starting UEFI application */ #define EFI_FDT_USE_INTERNAL NULL
- /* Key identifying current memory map */ extern efi_uintn_t efi_memory_map_key;
- /* GUID of the U-Boot root node */ extern const efi_guid_t efi_u_boot_guid; #ifdef CONFIG_SANDBOX
u64 attributes);
int row, int col);
- #endif /* _EFI_LOADER_H */
- bootmgr implements the logic of trying to find a payload to boot
- based on the BootOrder + BootXXXX variables, and then loading it.
- efi_status_t r;
goto out;
- *no_handles = 0;
- *buffer = NULL;
*buffer);
goto out;
(void **)buffer);
goto out;
*buffer);
+out:
- return r;
- efi_locate_handle_buffer() - locate handles implementing a protocol
- @search_type: selection criterion
goto out;
*no_handles = 0;
*buffer = NULL;
*buffer);
goto out;
(void **)buffer);
goto out;
*buffer);
-out:
- r = efi_locate_handle_buffer_int(search_type, protocol, search_key,
- return EFI_EXIT(r); }
- efi_console_get_u16_string() - get user input string
- @cin: protocol interface to EFI_SIMPLE_TEXT_INPUT_PROTOCOL
- @buf: buffer to store user input string in UTF16
- @count: number of u16 string including NULL terminator that buf has
- @filter_func: callback to filter user input
- @row: row number to locate user input form
- @col: column number to locate user input form
int row, int col)
- efi_status_t ret;
- efi_uintn_t len = 0;
- struct efi_input_key key;
- ret = EFI_CALL(cin->reset(cin, false));
return ret;
- for (;;) {
do {
mdelay(10);
if (len > 0)
buf[--len] = u'\0';
"%ls"
continue;
buf[len] = u'\0';
return EFI_SUCCESS;
return EFI_ABORTED;
continue;
continue;
if (filter_func) {
continue;
continue;
len++;
- efi_disk_get_device_name() - get U-Boot device name associated with EFI handle
- @handle: pointer to the EFI handle
- @buf: pointer to the buffer to store the string
- @size: size of buffer
- int count;
- int diskid;
- enum uclass_id id;
- unsigned int part;
- struct udevice *dev;
- struct blk_desc *desc;
- const char *if_typename;
- bool is_partition = false;
- struct disk_part *part_data;
- if (!handle || !buf || !size)
- dev = handle->dev;
- id = device_get_uclass_id(dev);
- if (id == UCLASS_BLK) {
- } else if (id == UCLASS_PARTITION) {
- } else {
- if_typename = blk_get_if_type_name(desc->if_type);
- diskid = desc->devnum;
- if (is_partition) {
- } else {
- if (count < 0 || (count + 1) > size)
u64 attributes)
{ struct file_handle *fh = to_fh(this); efi_status_t ret;u64 attributes)
- return file_close(fh);
{ struct file_handle *fh = to_fh(this); efi_status_t ret = EFI_SUCCESS;efi_uintn_t *buffer_size, void *buffer)
- efi_file_setpos() - set current position in file
- This function implements the SetPosition service of the EFI file protocol.
- See the UEFI spec for details.
- @file: file handle
- @pos: new file position
u64 pos)
error:
- return ret;
u64 pos)
- ret = efi_file_setpos_int(file, pos);
- return EFI_EXIT(ret); }
- static efi_status_t EFIAPI efi_open_volume(struct efi_simple_file_system_protocol *this, struct efi_file_handle **root) {
Hi Heinrich,
Changes in v15:
Changes in v14:
No change in v13:
Changes in v12:
Changes in v11:
Changes in v10:
- do refactoring
- fix typos
Changes in v9:
Changes in v8:
Changes in v7:
Changes in v6:
- fix typos
Changes in v5:
Chanes in v4:
Changes in RFC v2:
help
u16 *name;
u16 *description;
u16 *optional_data;
bool is_directory;
u16 *file_name;
/* Flush input */
while (tstc())
getchar();
ANSI_CLEAR_CONSOLE
getchar();
if (reverse)
if (reverse)
return;
"\n%s\n"
int esc = 0;
while (1) {
switch (key) {
case KEY_UP:
--efi_menu->active;
return NULL;
case KEY_DOWN:
++efi_menu->active;
return NULL;
case KEY_SELECT:
entry = list_entry(pos, struct eficonfig_entry, list);
return entry->key;
break;
case KEY_QUIT:
return entry->key;
default:
break;
free(entry->title);
free(entry);
free(efi_menu);
return EFI_ABORTED;
if (!entry)
entry->func = func;
entry->data = data;
return EFI_SUCCESS;
char *title;
efi_status_t ret;
if (!title)
free(title);
return ret;
u32 i;
char *title;
efi_status_t ret;
if (!efi_menu)
return NULL;
if (!title)
goto out;
free(title);
goto out;
return efi_menu;
+out:
return NULL;
struct menu *menu;
if (menu_header) {
I will fix the issue.
Thanks, Masahisa Kojima
menu_destroy(menu);
struct menu *menu;
= NULL
Best regards
Heinrich
goto out;
efi_menu);
if (!menu) {
goto out;
goto out;
if (entry)
ANSI_CLEAR_CONSOLE
entry = choice;
if (entry->func)
+out:
menu_destroy(menu);
return ret;
if (info) {
return EFI_SUCCESS;
- Return:
char *p;
void *buf;
if (!buf)
return NULL;
fp = buf;
p = buf;
p += fp_size;
free(buf);
return dp;
if (!info)
int is_last;
if (is_last) {
free(iter->name);
free(iter);
break;
EFICONFIG_FILE_PATH_MAX);
} else {
size_t new_len;
if (!filepath)
free(filepath);
* at least one character for file name
if (new_len + 2 >= EFICONFIG_FILE_PATH_MAX) {
eficonfig_print_msg("Directory path is too long!");
} else {
info->file_info->file_selected = true;
return EFI_SUCCESS;
+static efi_status_t eficonfig_select_volume(struct eficonfig_select_file_info *file_info) +{
u32 i;
efi_status_t ret;
efi_uintn_t count;
NULL, &count, (efi_handle_t **)&volume_handles);
eficonfig_print_msg("No block device found!");
return ret;
if (!efi_menu)
char *devname;
struct efi_block_io *block_io;
struct eficonfig_volume_entry_data *info;
if (efi_menu->count >= EFICONFIG_ENTRY_NUM_MAX - 1)
break;
ret = efi_search_protocol(volume_handles[i],
&efi_simple_file_system_protocol_guid, &handler);
continue;
ret = efi_protocol_open(handler, (void **)&v, efi_root, NULL,
continue;
ret = efi_search_protocol(volume_handles[i], &efi_guid_device_path, &handler);
continue;
ret = efi_protocol_open(handler, (void **)&device_path,
efi_root, NULL, EFI_OPEN_PROTOCOL_GET_PROTOCOL);
continue;
ret = efi_search_protocol(volume_handles[i], &efi_block_io_guid, &handler);
continue;
ret = efi_protocol_open(handler, (void **)&block_io,
continue;
info = calloc(1, sizeof(struct eficonfig_volume_entry_data));
if (!info) {
goto out;
devname = calloc(1, BOOTMENU_DEVICE_NAME_MAX);
if (!devname) {
free(info);
goto out;
ret = efi_disk_get_device_name(volume_handles[i], devname,
free(info);
goto out;
info->v = v;
info->dp = device_path;
info->file_info = file_info;
ret = append_entry(efi_menu, devname, eficonfig_volume_selected, info);
free(info);
goto out;
goto out;
+out:
free(entry->data);
return ret;
+static efi_status_t eficonfig_select_file(struct eficonfig_select_file_info *file_info,
struct efi_file_handle *root)
efi_uintn_t len;
efi_status_t ret;
if (!buf)
if (!efi_menu) {
goto out;
ret = efi_file_open_int(root, &f, file_info->current_path, EFI_FILE_MODE_READ, 0);
eficonfig_print_msg("Reading volume failed!");
ret = EFI_ABORTED;
goto out;
/* Read directory and construct menu structure */
for (;;) {
char *name, *p;
int name_len;
struct eficonfig_file_entry_data *info;
break;
len = sizeof(struct efi_file_info) + EFICONFIG_FILE_PATH_BUF_SIZE;
ret = efi_file_read_int(f, &len, buf);
if (ret != EFI_SUCCESS || len == 0)
break;
info = calloc(1, sizeof(struct eficonfig_file_entry_data));
if (!info) {
goto err;
if (buf->attribute & EFI_FILE_DIRECTORY) {
/* append u'/' at the end of directory name */
name_len = utf16_utf8_strlen(buf->file_name) + 2;
/* filter out u'.' */
if (name_len == 3 && buf->file_name[0] == u'.') {
free(info);
continue;
name = calloc(1, name_len);
if (!name) {
free(info);
goto err;
p = name;
utf16_utf8_strcpy(&p, buf->file_name);
name[u16_strlen(buf->file_name)] = u'/';
info->is_directory = true;
} else {
name_len = utf16_utf8_strlen(buf->file_name) + 1;
if (!name) {
free(info);
goto err;
p = name;
info->file_name = u16_strdup(buf->file_name);
if (!info->file_name) {
free(info);
free(name);
goto err;
ret = append_entry(efi_menu, name, eficonfig_file_selected, info);
free(info);
free(name);
goto err;
goto err;
ret = eficonfig_process_common(efi_menu, " ** Select File **");
+err:
efi_file_close_int(f);
/* skip "Quit" */
if (list_is_last(&entry->list, &efi_menu->list))
break;
free(((struct eficonfig_file_entry_data *)(entry->data))->file_name);
free(entry->data);
break;
+out:
free(buf);
return ret;
+static efi_status_t handle_user_input(u16 *buf, int buf_size,
int cursor_col, char *msg)
u16 *tmp;
efi_status_t ret;
"%s"
" Press ENTER to complete, ESC/CTRL+C to quit",
0, 1, msg, 8, 1);
if (!tmp)
u16_strcpy(buf, tmp);
free(tmp);
return ret;
+static efi_status_t eficonfig_boot_add_enter_description(void *data) +{
"\n ** Edit Description **\n"
"\n"
" enter description: ");
+static efi_status_t eficonfig_boot_add_optional_data(void *data) +{
"\n ** Edit Optional Data **\n"
"\n"
" enter optional data:");
+static efi_status_t eficonfig_boot_edit_save(void *data) +{
eficonfig_print_msg("Boot Description is empty!");
bo->edit_completed = false;
return EFI_NOT_READY;
eficonfig_print_msg("File is not selected!");
return EFI_SUCCESS;
+efi_status_t eficonfig_process_select_file(void *data) +{
return EFI_SUCCESS;
+efi_status_t eficonfig_process_clear_file_selection(void *data) +{
return EFI_ABORTED;
+static struct eficonfig_item select_file_menu_items[] = {
+efi_status_t eficonfig_display_select_file_option(struct eficonfig_select_file_info *file_info) +{
efi_status_t ret;
ARRAY_SIZE(select_file_menu_items));
if (!efi_menu)
ret = EFI_NOT_READY;
return ret;
+efi_status_t eficonfig_select_file_handler(void *data) +{
size_t len;
efi_status_t ret;
return ret;
if (!tmp)
free(tmp);
tmp->current_volume = NULL;
memset(tmp->current_path, 0, EFICONFIG_FILE_PATH_BUF_SIZE);
ret = eficonfig_select_volume(tmp);
goto out;
if (!tmp->current_volume)
ret = efi_open_volume_int(tmp->current_volume, &root);
goto out;
ret = eficonfig_select_file(tmp, root);
continue;
goto out;
+out:
len = u16_strlen(tmp->current_path);
len = (len >= EFICONFIG_FILE_PATH_MAX) ? (EFICONFIG_FILE_PATH_MAX - 1) : len;
memcpy(file_info->current_path, tmp->current_path, len * sizeof(u16));
file_info->current_path[len] = u'\0';
file_info->current_volume = tmp->current_volume;
file_info->dp_volume = tmp->dp_volume;
item = list_entry(pos, struct eficonfig_filepath_info, list);
list_del(&item->list);
free(item->name);
free(item);
free(tmp);
return ret;
+efi_status_t eficonfig_get_unused_bootoption(u16 *buf, efi_uintn_t buf_size,
unsigned int *index)
u32 i;
efi_status_t ret;
efi_uintn_t size;
return EFI_BUFFER_TOO_SMALL;
size = 0;
efi_create_indexed_name(buf, buf_size, "Boot", i);
ret = efi_get_variable_int(buf, &efi_global_variable_guid,
NULL, &size, NULL, NULL);
if (ret == EFI_BUFFER_TOO_SMALL)
continue;
else
break;
if (i > 0xFFFF)
*index = i;
return EFI_SUCCESS;
+static efi_status_t eficonfig_set_boot_option(u16 *varname, struct efi_device_path *dp,
efi_uintn_t dp_size, u16 *label, char *optional_data)
void *p = NULL;
efi_status_t ret;
efi_uintn_t size;
lo.file_path = dp;
lo.label = label;
if (!size)
EFI_VARIABLE_NON_VOLATILE |
EFI_VARIABLE_BOOTSERVICE_ACCESS |
EFI_VARIABLE_RUNTIME_ACCESS,
size, p, false);
free(p);
return ret;
+efi_status_t eficonfig_append_bootorder(u16 index) +{
u16 *bootorder;
efi_status_t ret;
ret = EFI_OUT_OF_RESOURCES;
goto out;
new_size, new_bootorder, false);
goto out;
+out:
free(bootorder);
return ret;
+static efi_status_t create_boot_option_entry(struct efimenu *efi_menu, char *title, u16 *val,
u32 len;
char *p, *buf;
if (val)
len += utf16_utf8_strlen(val);
if (!buf)
return EFI_OUT_OF_RESOURCES;
strcpy(buf, title);
if (val) {
p = buf + strlen(title);
utf16_utf8_strcpy(&p, val);
+static efi_status_t prepare_file_selection_entry(struct efimenu *efi_menu, char *title,
u32 len;
efi_status_t ret;
u16 *file_name, *p;
if (handle) {
ret = efi_disk_get_device_name(handle, devname, BOOTMENU_DEVICE_NAME_MAX);
return ret;
strlcat(devname, "/", BOOTMENU_DEVICE_NAME_MAX);
if (!file_name)
return ret;
p = file_name;
eficonfig_select_file_handler, file_info);
free(file_name);
return ret;
+static efi_status_t eficonfig_show_boot_option(struct eficonfig_boot_option *bo,
char *header_str)
efi_status_t ret;
if (!efi_menu)
eficonfig_boot_add_enter_description, bo);
goto out;
goto out;
goto out;
eficonfig_boot_add_optional_data, bo);
goto out;
eficonfig_boot_edit_save, bo);
goto out;
goto out;
+out:
return ret;
+static void fill_file_info(struct efi_device_path *dp,
struct efi_device_path *device_dp)
u16 *file_str, *p;
if (file_dp) {
file_str = efi_dp_str(file_dp);
* efi_convert_device_path_to_text() automatically adds u'/' at the
* beginning of file name, remove u'/' before copying to current_path
p = file_str;
if (p[0] == u'/')
p++;
u16_strcpy(file_info->current_path, p);
efi_free_pool(file_dp);
efi_free_pool(file_str);
+static efi_status_t eficonfig_edit_boot_option(u16 *varname, struct eficonfig_boot_option *bo,
void *load_option, efi_uintn_t load_option_size,
char *header_str)
size_t len;
efi_status_t ret;
.vendor = {
DEVICE_PATH_SUB_TYPE_VENDOR_PATH,
sizeof(id_dp.vendor),
EFI_INITRD_MEDIA_GUID,
.end = {
DEVICE_PATH_TYPE_END,
DEVICE_PATH_SUB_TYPE_END,
sizeof(id_dp.end),
goto out;
goto out;
goto out;
goto out;
if (load_option) {
ret = efi_deserialize_load_option(&lo, load_option, &size);
goto out;
if (!lo.label || (lo.label && u16_strlen(lo.label) >= EFICONFIG_DESCRIPTION_MAX)) {
ret = EFI_INVALID_PARAMETER;
goto out;
u16_strcpy(bo->description, lo.label);
/* EFI image file path is a first instance */
if (lo.file_path)
fill_file_info(lo.file_path, &bo->file_info, device_dp);
/* Initrd file path(optional) is placed at second instance. */
initrd_dp = efi_dp_from_lo(&lo, &efi_lf2_initrd_guid);
if (initrd_dp) {
fill_file_info(initrd_dp, &bo->initrd_info, initrd_device_dp);
if (size > 0)
memcpy(bo->optional_data, lo.optional_data, size);
while (1) {
ret = eficonfig_show_boot_option(bo, header_str);
if (ret == EFI_SUCCESS && bo->edit_completed)
break;
if (ret == EFI_NOT_READY)
continue;
goto out;
dp = create_selected_device_path(&bo->initrd_info);
if (!dp) {
goto out;
initrd_dp = efi_dp_append((const struct efi_device_path *)&id_dp, dp);
efi_free_pool(dp);
if (!dp) {
goto out;
if (initrd_dp) {
final_dp = efi_dp_concat(dp, initrd_dp);
final_dp_size += efi_dp_size(initrd_dp) + sizeof(END);
} else {
final_dp = efi_dp_dup(dp);
efi_free_pool(dp);
if (!final_dp)
goto out;
len = utf16_utf8_strlen(bo->optional_data) + 1;
tmp = calloc(1, len);
if (!tmp)
goto out;
p = tmp;
utf16_utf8_strncpy(&p, bo->optional_data, u16_strlen(bo->optional_data));
goto out;
+out:
free(tmp);
return ret;
+static efi_status_t eficonfig_process_add_boot_option(void *data) +{
u16 varname[9];
efi_status_t ret;
if (!bo)
return ret;
goto out;
goto out;
+out:
free(bo);
return ret;
+static efi_status_t eficonfig_init(void) +{
static bool init;
if (!init) {
ret = efi_search_protocol(efi_root, &efi_guid_text_input_protocol, &handler);
return ret;
ret = efi_protocol_open(handler, (void **)&cin, efi_root, NULL,
return ret;
init = true;
return ret;
+static const struct eficonfig_item maintenance_menu_items[] = {
+static int do_eficonfig(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{
efi_status_t ret;
if (argc > 1)
return CMD_RET_USAGE;
log_err("Error: Cannot initialize UEFI sub-system, r = %lu\n",
ret & ~EFI_ERROR_MASK);
return CMD_RET_FAILURE;
while (1) {
efi_menu = eficonfig_create_fixed_menu(maintenance_menu_items,
ARRAY_SIZE(maintenance_menu_items));
if (!efi_menu)
ret = eficonfig_process_common(efi_menu, " ** UEFI Maintenance Menu **");
if (ret == EFI_ABORTED)
break;
+U_BOOT_CMD(
+); diff --git a/include/efi_config.h b/include/efi_config.h new file mode 100644 index 0000000000..ea5bc4e1bf --- /dev/null +++ b/include/efi_config.h @@ -0,0 +1,96 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
+#ifndef _EFI_CONFIG_H +#define _EFI_CONFIG_H
+#define EFICONFIG_ENTRY_NUM_MAX 99 +#define EFICONFIG_FILE_PATH_MAX 512 +#define EFICONFIG_FILE_PATH_BUF_SIZE (EFICONFIG_FILE_PATH_MAX * sizeof(u16))
+typedef efi_status_t (*eficonfig_entry_func)(void *data);
- @key: unique key
+struct eficonfig_entry {
u32 num;
char *title;
char key[3];
void *data;
+struct efimenu {
int delay;
int active;
int count;
char *menu_header;
+struct eficonfig_item {
char *title;
void *data;
+struct eficonfig_select_file_info {
u16 *current_path;
bool file_selected;
+void eficonfig_print_msg(char *msg); +void eficonfig_destroy(struct efimenu *efi_menu); +efi_status_t eficonfig_process_quit(void *data); +efi_status_t eficonfig_process_common(struct efimenu *efi_menu, char *menu_header); +efi_status_t eficonfig_select_file_handler(void *data); +efi_status_t eficonfig_get_unused_bootoption(u16 *buf,
efi_uintn_t buf_size, u32 *index);
+efi_status_t eficonfig_append_bootorder(u16 index);
+#endif diff --git a/include/efi_loader.h b/include/efi_loader.h index b0d6fff67c..4461f721e0 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -142,6 +142,11 @@ static inline efi_status_t efi_launch_capsules(void) EFI_GUID(0x63293792, 0xadf5, 0x9325, \ 0xb9, 0x9f, 0x4e, 0x0e, 0x45, 0x5c, 0x1b, 0x1e)
+/* GUID for the auto generated boot menu entry */ +#define EFICONFIG_AUTO_GENERATED_ENTRY_GUID \
0xb9, 0x01, 0xfa, 0x74, 0xd6, 0xd6, 0xe4, 0xde)
@@ -226,6 +231,9 @@ const char *__efi_nesting_dec(void); #define EFI_CACHELINE_SIZE 128 #endif
+/* max bootmenu title size for volume selection */ +#define BOOTMENU_DEVICE_NAME_MAX 16
@@ -249,6 +257,9 @@ extern const struct efi_hii_string_protocol efi_hii_string;
uint16_t *efi_dp_str(struct efi_device_path *dp);
+/* GUID for the auto generated boot menu entry */ +extern const efi_guid_t efi_guid_bootmenu_auto_generated;
@@ -314,6 +325,8 @@ extern const efi_guid_t efi_guid_firmware_management_protocol; extern const efi_guid_t efi_esrt_guid; /* GUID of the SMBIOS table */ extern const efi_guid_t smbios_guid; +/*GUID of console */ +extern const efi_guid_t efi_guid_text_input_protocol;
extern char __efi_runtime_start[], __efi_runtime_stop[]; extern char __efi_runtime_rel_start[], __efi_runtime_rel_stop[]; @@ -1064,4 +1077,28 @@ efi_status_t efi_esrt_populate(void); efi_status_t efi_load_capsule_drivers(void);
efi_status_t platform_get_eventlog(struct udevice *dev, u64 *addr, u32 *sz);
u64 attributes);
int row, int col);
efi_status_t r;
goto out;
*no_handles = 0;
*buffer = NULL;
*buffer);
goto out;
(void **)buffer);
goto out;
*buffer);
+out:
return r;
efi_uintn_t buffer_size = 0; EFI_ENTRY("%d, %pUs, %p, %p, %p", search_type, protocol, search_key, no_handles, buffer);
goto out;
*no_handles = 0;
*buffer = NULL;
*buffer);
goto out;
(void **)buffer);
goto out;
*buffer);
-out:
}return EFI_EXIT(r);
int row, int col)
efi_status_t ret;
return ret;
for (;;) {
do {
mdelay(10);
if (len > 0)
buf[--len] = u'\0';
"%ls"
continue;
buf[len] = u'\0';
return EFI_SUCCESS;
return EFI_ABORTED;
continue;
continue;
if (filter_func) {
continue;
continue;
len++;
return EFI_SUCCESS;
int count;
int diskid;
enum uclass_id id;
unsigned int part;
dev = handle->dev;
} else {
if (is_partition) {
} else {
return EFI_SUCCESS;
u64 attributes)
u64 pos)
error:
return ret;
u64 pos)
}return EFI_EXIT(ret);
return EFI_SUCCESS;
This commit adds the menu entry to edit the existing BOOT#### variable contents. User selects the item from the boot option list, then user can edit the description, file path and optional_data.
Note that automatically generated boot option entry by bootmenu to support the removable media device is filtered out and user can not edit the automatically generated entry.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- Changes in v15: - move free entry->data outside the eficonfig_destroy()
Changes in v11: - remove BootOrder variable dependency - change the list load option order 1) in the order of BootOrder 2) remaing load option that is not included in the BootOrder - add check for the number of menu entry exceeds max - truncate the long load option label when user edits - add EFICONFIG_VOLUME_PATH_MAX to display text converted volume device path in case the volume does not exist
Changes in v10: - update eficonfig_edit_boot_option() argument
Changes in v9: - add function comment
Changes in v8: - fix menu header string - fix function and structure prefix to "eficonfig"
Newly created in v7
cmd/eficonfig.c | 281 +++++++++++++++++++++++++++++++++++++++++-- include/efi_config.h | 1 + 2 files changed, 274 insertions(+), 8 deletions(-)
diff --git a/cmd/eficonfig.c b/cmd/eficonfig.c index 30ce55d055..bba83579a3 100644 --- a/cmd/eficonfig.c +++ b/cmd/eficonfig.c @@ -80,6 +80,17 @@ struct eficonfig_file_entry_data { u16 *file_name; };
+/** + * struct eficonfig_boot_selection_data - structure to be used to select the boot option entry + * + * @boot_index: index of the boot option + * @selected: pointer to store the selected index in the BootOrder variable + */ +struct eficonfig_boot_selection_data { + u16 boot_index; + int *selected; +}; + /** * eficonfig_print_msg() - print message * @@ -1169,34 +1180,58 @@ static efi_status_t prepare_file_selection_entry(struct efimenu *efi_menu, char { u32 len; efi_status_t ret; - u16 *file_name, *p; + u16 *file_name = NULL, *p; efi_handle_t handle; - char devname[BOOTMENU_DEVICE_NAME_MAX] = {0}; + char *devname; + + devname = calloc(1, EFICONFIG_VOLUME_PATH_MAX + 1); + if (!devname) + return EFI_OUT_OF_RESOURCES;
/* get the device name only when the user already selected the file path */ handle = efi_dp_find_obj(file_info->dp_volume, NULL, NULL); if (handle) { - ret = efi_disk_get_device_name(handle, devname, BOOTMENU_DEVICE_NAME_MAX); + ret = efi_disk_get_device_name(handle, devname, EFICONFIG_VOLUME_PATH_MAX); if (ret != EFI_SUCCESS) - return ret; + goto out; + } + + /* + * If the preconfigured volume does not exist in the system, display the text + * converted volume device path instead of U-Boot friendly name(e.g. "usb 0:1"). + */ + if (!handle && file_info->dp_volume) { + u16 *dp_str; + char *q = devname; + + dp_str = efi_dp_str(file_info->dp_volume); + if (dp_str) + utf16_utf8_strncpy(&q, dp_str, EFICONFIG_VOLUME_PATH_MAX); + + efi_free_pool(dp_str); }
/* append u'/' to devname, it is just for display purpose. */ if (file_info->current_path[0] != u'\0' && file_info->current_path[0] != u'/') - strlcat(devname, "/", BOOTMENU_DEVICE_NAME_MAX); + strlcat(devname, "/", EFICONFIG_VOLUME_PATH_MAX + 1);
len = strlen(devname); len += utf16_utf8_strlen(file_info->current_path) + 1; file_name = calloc(1, len * sizeof(u16)); - if (!file_name) - return ret; + if (!file_name) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + }
p = file_name; utf8_utf16_strcpy(&p, devname); u16_strlcat(file_name, file_info->current_path, len); ret = create_boot_option_entry(efi_menu, title, file_name, eficonfig_select_file_handler, file_info); +out: + free(devname); free(file_name); + return ret; }
@@ -1363,10 +1398,14 @@ static efi_status_t eficonfig_edit_boot_option(u16 *varname, struct eficonfig_bo if (ret != EFI_SUCCESS) goto out;
- if (!lo.label || (lo.label && u16_strlen(lo.label) >= EFICONFIG_DESCRIPTION_MAX)) { + if (!lo.label) { ret = EFI_INVALID_PARAMETER; goto out; } + /* truncate the long label string */ + if (u16_strlen(lo.label) >= EFICONFIG_DESCRIPTION_MAX) + lo.label[EFICONFIG_DESCRIPTION_MAX - 1] = u'\0'; + u16_strcpy(bo->description, lo.label);
/* EFI image file path is a first instance */ @@ -1484,6 +1523,231 @@ out: return ret; }
+/** + * eficonfig_process_boot_selected() - handler to select boot option entry + * + * @data: pointer to the data for each entry + * Return: status code + */ +static efi_status_t eficonfig_process_boot_selected(void *data) +{ + struct eficonfig_boot_selection_data *info = data; + + if (info) + *info->selected = info->boot_index; + + return EFI_SUCCESS; +} + +/** + * search_bootorder() - search the boot option index in BootOrder + * + * @bootorder: pointer to the BootOrder variable + * @num: number of BootOrder entry + * @target: target boot option index to search + * @index: pointer to store the index of BootOrder variable + * Return: true if exists, false otherwise + */ +static bool search_bootorder(u16 *bootorder, efi_uintn_t num, u32 target, u32 *index) +{ + u32 i; + + for (i = 0; i < num; i++) { + if (target == bootorder[i]) { + if (index) + *index = i; + + return true; + } + } + + return false; +} + +/** + * eficonfig_add_boot_selection_entry() - add boot option menu entry + * + * @efi_menu: pointer to store the efimenu structure + * @boot_index: boot option index to be added + * @selected: pointer to store the selected boot option index + * Return: status code + */ +static efi_status_t eficonfig_add_boot_selection_entry(struct efimenu *efi_menu, + unsigned int boot_index, + unsigned int *selected) +{ + char *buf, *p; + efi_status_t ret; + efi_uintn_t size; + void *load_option; + struct efi_load_option lo; + u16 varname[] = u"Boot####"; + struct eficonfig_boot_selection_data *info; + + efi_create_indexed_name(varname, sizeof(varname), "Boot", boot_index); + load_option = efi_get_var(varname, &efi_global_variable_guid, &size); + if (!load_option) + return EFI_SUCCESS; + + ret = efi_deserialize_load_option(&lo, load_option, &size); + if (ret != EFI_SUCCESS) { + log_warning("Invalid load option for %ls\n", varname); + free(load_option); + return ret; + } + + if (size >= sizeof(efi_guid_t) && + !guidcmp(lo.optional_data, &efi_guid_bootmenu_auto_generated)) { + /* + * auto generated entry has GUID in optional_data, + * skip auto generated entry because it will be generated + * again even if it is edited or deleted. + */ + free(load_option); + return EFI_SUCCESS; + } + + info = calloc(1, sizeof(struct eficonfig_boot_selection_data)); + if (!info) { + free(load_option); + return EFI_OUT_OF_RESOURCES; + } + + buf = calloc(1, utf16_utf8_strlen(lo.label) + 1); + if (!buf) { + free(load_option); + free(info); + return EFI_OUT_OF_RESOURCES; + } + p = buf; + utf16_utf8_strcpy(&p, lo.label); + info->boot_index = boot_index; + info->selected = selected; + ret = append_entry(efi_menu, buf, eficonfig_process_boot_selected, info); + if (ret != EFI_SUCCESS) { + free(load_option); + free(info); + return ret; + } + free(load_option); + + return EFI_SUCCESS; +} + +/** + * eficonfig_show_boot_selection() - construct boot option menu entry + * + * @selected: pointer to store the selected boot option index + * Return: status code + */ +static efi_status_t eficonfig_show_boot_selection(unsigned int *selected) +{ + u32 i; + u16 *bootorder; + efi_status_t ret; + efi_uintn_t num, size; + struct efimenu *efi_menu; + struct list_head *pos, *n; + struct eficonfig_entry *entry; + + efi_menu = calloc(1, sizeof(struct efimenu)); + if (!efi_menu) + return EFI_OUT_OF_RESOURCES; + + bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); + + INIT_LIST_HEAD(&efi_menu->list); + num = size / sizeof(u16); + /* list the load option in the order of BootOrder variable */ + for (i = 0; i < num; i++) { + ret = eficonfig_add_boot_selection_entry(efi_menu, bootorder[i], selected); + if (ret != EFI_SUCCESS) + goto out; + + if (efi_menu->count >= EFICONFIG_ENTRY_NUM_MAX - 1) + break; + } + + /* list the remaining load option not included in the BootOrder */ + for (i = 0; i <= 0xFFFF; i++) { + /* If the index is included in the BootOrder, skip it */ + if (search_bootorder(bootorder, num, i, NULL)) + continue; + + ret = eficonfig_add_boot_selection_entry(efi_menu, i, selected); + if (ret != EFI_SUCCESS) + goto out; + + if (efi_menu->count >= EFICONFIG_ENTRY_NUM_MAX - 1) + break; + } + + ret = append_quit_entry(efi_menu); + if (ret != EFI_SUCCESS) + goto out; + + ret = eficonfig_process_common(efi_menu, " ** Select Boot Option **"); +out: + list_for_each_safe(pos, n, &efi_menu->list) { + entry = list_entry(pos, struct eficonfig_entry, list); + free(entry->data); + } + eficonfig_destroy(efi_menu); + + return ret; +} + +/** + * eficonfig_process_edit_boot_option() - handler to edit boot option + * + * @data: pointer to the data for each entry + * Return: status code + */ +static efi_status_t eficonfig_process_edit_boot_option(void *data) +{ + efi_status_t ret; + efi_uintn_t size; + struct eficonfig_boot_option *bo = NULL; + + while (1) { + unsigned int selected; + void *load_option; + u16 varname[] = u"Boot####"; + + ret = eficonfig_show_boot_selection(&selected); + if (ret != EFI_SUCCESS) + break; + + bo = calloc(1, sizeof(struct eficonfig_boot_option)); + if (!bo) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + + bo->boot_index = selected; + efi_create_indexed_name(varname, sizeof(varname), "Boot", selected); + load_option = efi_get_var(varname, &efi_global_variable_guid, &size); + if (!load_option) { + free(bo); + ret = EFI_NOT_FOUND; + goto out; + } + + ret = eficonfig_edit_boot_option(varname, bo, load_option, size, + " ** Edit Boot Option ** "); + + free(load_option); + free(bo); + if (ret != EFI_SUCCESS && ret != EFI_ABORTED) + break; + } +out: + /* to stay the parent menu */ + ret = (ret == EFI_ABORTED) ? EFI_NOT_READY : ret; + + return ret; +} + /** * eficonfig_init() - do required initialization for eficonfig command * @@ -1513,6 +1777,7 @@ static efi_status_t eficonfig_init(void)
static const struct eficonfig_item maintenance_menu_items[] = { {"Add Boot Option", eficonfig_process_add_boot_option}, + {"Edit Boot Option", eficonfig_process_edit_boot_option}, {"Quit", eficonfig_process_quit}, };
diff --git a/include/efi_config.h b/include/efi_config.h index ea5bc4e1bf..dddffe045e 100644 --- a/include/efi_config.h +++ b/include/efi_config.h @@ -11,6 +11,7 @@ #include <efi_loader.h>
#define EFICONFIG_ENTRY_NUM_MAX 99 +#define EFICONFIG_VOLUME_PATH_MAX 512 #define EFICONFIG_FILE_PATH_MAX 512 #define EFICONFIG_FILE_PATH_BUF_SIZE (EFICONFIG_FILE_PATH_MAX * sizeof(u16))
This is preparation to support menu-driven UEFI BootOrder variable updated by KEY_PLUS, KEY_MINUS and KEY_SPACE.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- No update since v11
Changes in v11: - add SPACE key handling
Newly created in v7
common/menu.c | 9 +++++++++ include/menu.h | 3 +++ 2 files changed, 12 insertions(+)
diff --git a/common/menu.c b/common/menu.c index 3e876b55b3..0d19601cf5 100644 --- a/common/menu.c +++ b/common/menu.c @@ -548,4 +548,13 @@ void bootmenu_loop(struct bootmenu_data *menu, /* ^C was pressed */ if (c == 0x3) *key = KEY_QUIT; + + if (c == '+') + *key = KEY_PLUS; + + if (c == '-') + *key = KEY_MINUS; + + if (c == ' ') + *key = KEY_SPACE; } diff --git a/include/menu.h b/include/menu.h index e74616cae8..702aacb170 100644 --- a/include/menu.h +++ b/include/menu.h @@ -48,6 +48,9 @@ enum bootmenu_key { KEY_DOWN, KEY_SELECT, KEY_QUIT, + KEY_PLUS, + KEY_MINUS, + KEY_SPACE, };
void bootmenu_autoboot_loop(struct bootmenu_data *menu,
This commit adds the menu entry to delete the UEFI boot option. User moves the entry with UP/DOWN key, changes, then presses ENTER key to delete the selected boot option.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- No update since v11
Changes in v11: - update function interface to show boot selection menu - support to delete the load option is not included in BootOrder
No update since v9
Changes in v8: - function and structure prefix is changed to "eficonfig"
Changes in v7: - to stay the boot order list after user delete the entry
no update in v6:
changes in v5:
cmd/eficonfig.c | 71 +++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 71 insertions(+)
diff --git a/cmd/eficonfig.c b/cmd/eficonfig.c index bba83579a3..c9713acdda 100644 --- a/cmd/eficonfig.c +++ b/cmd/eficonfig.c @@ -1748,6 +1748,76 @@ out: return ret; }
+/** + * delete_boot_option() - delete selected boot option + * + * @boot_index: boot option index to delete + * Return: status code + */ +static efi_status_t delete_boot_option(u16 boot_index) +{ + u16 *bootorder; + u16 varname[9]; + efi_status_t ret; + unsigned int index; + efi_uintn_t num, size; + + efi_create_indexed_name(varname, sizeof(varname), + "Boot", boot_index); + ret = efi_set_variable_int(varname, &efi_global_variable_guid, + 0, 0, NULL, false); + if (ret != EFI_SUCCESS) { + log_err("delete boot option(%ls) failed\n", varname); + return ret; + } + + /* update BootOrder if necessary */ + bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); + if (!bootorder) + return EFI_SUCCESS; + + num = size / sizeof(u16); + if (!search_bootorder(bootorder, num, boot_index, &index)) + return EFI_SUCCESS; + + memmove(&bootorder[index], &bootorder[index + 1], + (num - index - 1) * sizeof(u16)); + size -= sizeof(u16); + ret = efi_set_variable_int(u"BootOrder", &efi_global_variable_guid, + EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + size, bootorder, false); + + return ret; +} + +/** + * eficonfig_process_delete_boot_option() - handler to delete boot option + * + * @data: pointer to the data for each entry + * Return: status code + */ +static efi_status_t eficonfig_process_delete_boot_option(void *data) +{ + efi_status_t ret; + unsigned int selected; + + while (1) { + ret = eficonfig_show_boot_selection(&selected); + if (ret == EFI_SUCCESS) + ret = delete_boot_option(selected); + + if (ret != EFI_SUCCESS) + break; + } + + /* to stay the parent menu */ + ret = (ret == EFI_ABORTED) ? EFI_NOT_READY : ret; + + return ret; +} + /** * eficonfig_init() - do required initialization for eficonfig command * @@ -1778,6 +1848,7 @@ static efi_status_t eficonfig_init(void) static const struct eficonfig_item maintenance_menu_items[] = { {"Add Boot Option", eficonfig_process_add_boot_option}, {"Edit Boot Option", eficonfig_process_edit_boot_option}, + {"Delete Boot Option", eficonfig_process_delete_boot_option}, {"Quit", eficonfig_process_quit}, };
UEFI specification requires booting from removal media using a architecture-specific default image name such as BOOTAA64.EFI. This commit adds the removable media entries into bootmenu, so that user can select the removable media and boot with default image.
The bootmenu automatically enumerates the possible bootable media devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL, add it as new UEFI boot option(BOOT####) and update BootOrder variable. This automatically generated UEFI boot option has the dedicated guid in the optional_data to distinguish it from the UEFI boot option user adds manually. This optional_data is removed when the efi bootmgr loads the selected UEFI boot option.
This commit also provides the BOOT#### variable maintenance feature. Depending on the system hardware setup, some devices may not exist at a later system boot, so bootmenu checks the available device in each bootmenu invocation and automatically removes the BOOT#### variable corrensponding to the non-existent media device.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- No update since v14
Changes in v14: - remove invalid free() call
Changes in v13: - remove BootOrder variable dependency
Changes in v12: - move generate_media_device_boot_option into cmd/eficonfig.c and expose it - remove unnecessary include file
Changes in v11: - update delete_boot_option() parameter
Changes in v10: - add function comment - devname dynamic allocation removes, allocate in stack - delete BOOT#### when updating BootOrder fails
Changes in v9: - update efi_disk_get_device_name() parameter to pass efi_handle_t - add function comment
Changes in v7: - rename prepare_media_device_entry() to generate_media_device_boot_option()
Changes in v6: - optional_data size is changed to 16bytes - check the load option size before comparison - remove guid included in optional_data of auto generated entry when loading
Changes in v5: - Return EFI_SUCCESS if there is no BootOrder defined - correctly handle the case if no removable device found - use guid to identify the automatically generated entry by bootmenu
cmd/bootmenu.c | 22 +++- cmd/eficonfig.c | 208 +++++++++++++++++++++++++++++++++++ include/efi_config.h | 1 + include/efi_loader.h | 16 +++ lib/efi_loader/efi_bootmgr.c | 4 + 5 files changed, 245 insertions(+), 6 deletions(-)
diff --git a/cmd/bootmenu.c b/cmd/bootmenu.c index 704d36debe..3340be1632 100644 --- a/cmd/bootmenu.c +++ b/cmd/bootmenu.c @@ -7,7 +7,7 @@ #include <common.h> #include <command.h> #include <ansi.h> -#include <efi_loader.h> +#include <efi_config.h> #include <efi_variable.h> #include <env.h> #include <log.h> @@ -220,7 +220,7 @@ static int prepare_bootmenu_entry(struct bootmenu_data *menu, return 1; }
-#if (CONFIG_IS_ENABLED(CMD_BOOTEFI_BOOTMGR)) +#if (CONFIG_IS_ENABLED(CMD_BOOTEFI_BOOTMGR)) && (CONFIG_IS_ENABLED(CMD_EFICONFIG)) /** * prepare_uefi_bootorder_entry() - generate the uefi bootmenu entries * @@ -340,11 +340,21 @@ static struct bootmenu_data *bootmenu_create(int delay) if (ret < 0) goto cleanup;
-#if (CONFIG_IS_ENABLED(CMD_BOOTEFI_BOOTMGR)) +#if (CONFIG_IS_ENABLED(CMD_BOOTEFI_BOOTMGR)) && (CONFIG_IS_ENABLED(CMD_EFICONFIG)) if (i < MAX_COUNT - 1) { - ret = prepare_uefi_bootorder_entry(menu, &iter, &i); - if (ret < 0 && ret != -ENOENT) - goto cleanup; + efi_status_t efi_ret; + + /* + * UEFI specification requires booting from removal media using + * a architecture-specific default image name such as BOOTAA64.EFI. + */ + efi_ret = eficonfig_generate_media_device_boot_option(); + if (efi_ret != EFI_SUCCESS && efi_ret != EFI_NOT_FOUND) + goto cleanup; + + ret = prepare_uefi_bootorder_entry(menu, &iter, &i); + if (ret < 0 && ret != -ENOENT) + goto cleanup; } #endif
diff --git a/cmd/eficonfig.c b/cmd/eficonfig.c index c9713acdda..21d9bd3e23 100644 --- a/cmd/eficonfig.c +++ b/cmd/eficonfig.c @@ -1818,6 +1818,214 @@ static efi_status_t eficonfig_process_delete_boot_option(void *data) return ret; }
+/** + * eficonfig_enumerate_boot_option() - enumerate the possible bootable media + * + * @opt: pointer to the media boot option structure + * @volume_handles: pointer to the efi handles + * @count: number of efi handle + * Return: status code + */ +efi_status_t eficonfig_enumerate_boot_option(struct eficonfig_media_boot_option *opt, + efi_handle_t *volume_handles, efi_status_t count) +{ + u32 i; + struct efi_handler *handler; + efi_status_t ret = EFI_SUCCESS; + + for (i = 0; i < count; i++) { + u16 *p; + u16 dev_name[BOOTMENU_DEVICE_NAME_MAX]; + char *optional_data; + struct efi_load_option lo; + char buf[BOOTMENU_DEVICE_NAME_MAX]; + struct efi_device_path *device_path; + + ret = efi_search_protocol(volume_handles[i], &efi_guid_device_path, &handler); + if (ret != EFI_SUCCESS) + continue; + ret = efi_protocol_open(handler, (void **)&device_path, + efi_root, NULL, EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) + continue; + + ret = efi_disk_get_device_name(volume_handles[i], buf, BOOTMENU_DEVICE_NAME_MAX); + if (ret != EFI_SUCCESS) + continue; + + p = dev_name; + utf8_utf16_strncpy(&p, buf, strlen(buf)); + + lo.label = dev_name; + lo.attributes = LOAD_OPTION_ACTIVE; + lo.file_path = device_path; + lo.file_path_length = efi_dp_size(device_path) + sizeof(END); + /* + * Set the dedicated guid to optional_data, it is used to identify + * the boot option that automatically generated by the bootmenu. + * efi_serialize_load_option() expects optional_data is null-terminated + * utf8 string, so set the "1234567" string to allocate enough space + * to store guid, instead of realloc the load_option. + */ + lo.optional_data = "1234567"; + opt[i].size = efi_serialize_load_option(&lo, (u8 **)&opt[i].lo); + if (!opt[i].size) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + /* set the guid */ + optional_data = (char *)opt[i].lo + (opt[i].size - u16_strsize(u"1234567")); + memcpy(optional_data, &efi_guid_bootmenu_auto_generated, sizeof(efi_guid_t)); + } + +out: + return ret; +} + +/** + * eficonfig_delete_invalid_boot_option() - delete non-existing boot option + * + * @opt: pointer to the media boot option structure + * @count: number of media boot option structure + * Return: status code + */ +efi_status_t eficonfig_delete_invalid_boot_option(struct eficonfig_media_boot_option *opt, + efi_status_t count) +{ + u32 i, j; + efi_uintn_t size; + efi_status_t ret; + void *load_option; + struct efi_load_option lo; + u16 varname[] = u"Boot####"; + + for (i = 0; i <= 0xFFFF; i++) { + efi_uintn_t tmp; + + efi_create_indexed_name(varname, sizeof(varname), "Boot", i); + load_option = efi_get_var(varname, &efi_global_variable_guid, &size); + if (!load_option) + continue; + + tmp = size; + ret = efi_deserialize_load_option(&lo, load_option, &size); + if (ret != EFI_SUCCESS) + goto next; + + if (size >= sizeof(efi_guid_bootmenu_auto_generated)) { + if (guidcmp(lo.optional_data, &efi_guid_bootmenu_auto_generated) == 0) { + for (j = 0; j < count; j++) { + if (opt[j].size == tmp && + memcmp(opt[j].lo, load_option, tmp) == 0) { + opt[j].exist = true; + break; + } + } + + if (j == count) { + ret = delete_boot_option(i); + if (ret != EFI_SUCCESS) { + free(load_option); + goto out; + } + } + } + } +next: + free(load_option); + } + +out: + return ret; +} + +/** + * eficonfig_generate_media_device_boot_option() - generate the media device boot option + * + * This function enumerates all devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL + * and generate the bootmenu entries. + * This function also provide the BOOT#### variable maintenance for + * the media device entries. + * - Automatically create the BOOT#### variable for the newly detected device, + * this BOOT#### variable is distinguished by the special GUID + * stored in the EFI_LOAD_OPTION.optional_data + * - If the device is not attached to the system, the associated BOOT#### variable + * is automatically deleted. + * + * Return: status code + */ +efi_status_t eficonfig_generate_media_device_boot_option(void) +{ + u32 i; + efi_status_t ret; + efi_uintn_t count; + efi_handle_t *volume_handles = NULL; + struct eficonfig_media_boot_option *opt = NULL; + + ret = efi_locate_handle_buffer_int(BY_PROTOCOL, &efi_simple_file_system_protocol_guid, + NULL, &count, (efi_handle_t **)&volume_handles); + if (ret != EFI_SUCCESS) + return ret; + + opt = calloc(count, sizeof(struct eficonfig_media_boot_option)); + if (!opt) + goto out; + + /* enumerate all devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL */ + ret = eficonfig_enumerate_boot_option(opt, volume_handles, count); + if (ret != EFI_SUCCESS) + goto out; + + /* + * System hardware configuration may vary depending on the user setup. + * The boot option is automatically added by the bootmenu. + * If the device is not attached to the system, the boot option needs + * to be deleted. + */ + ret = eficonfig_delete_invalid_boot_option(opt, count); + if (ret != EFI_SUCCESS) + goto out; + + /* add non-existent boot option */ + for (i = 0; i < count; i++) { + u32 boot_index; + u16 var_name[9]; + + if (!opt[i].exist) { + ret = eficonfig_get_unused_bootoption(var_name, sizeof(var_name), + &boot_index); + if (ret != EFI_SUCCESS) + goto out; + + ret = efi_set_variable_int(var_name, &efi_global_variable_guid, + EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + opt[i].size, opt[i].lo, false); + if (ret != EFI_SUCCESS) + goto out; + + ret = eficonfig_append_bootorder(boot_index); + if (ret != EFI_SUCCESS) { + efi_set_variable_int(var_name, &efi_global_variable_guid, + 0, 0, NULL, false); + goto out; + } + } + } + +out: + if (opt) { + for (i = 0; i < count; i++) + free(opt[i].lo); + } + free(opt); + efi_free_pool(volume_handles); + + return ret; +} + + /** * eficonfig_init() - do required initialization for eficonfig command * diff --git a/include/efi_config.h b/include/efi_config.h index dddffe045e..098cac2115 100644 --- a/include/efi_config.h +++ b/include/efi_config.h @@ -93,5 +93,6 @@ efi_status_t eficonfig_select_file_handler(void *data); efi_status_t eficonfig_get_unused_bootoption(u16 *buf, efi_uintn_t buf_size, u32 *index); efi_status_t eficonfig_append_bootorder(u16 index); +efi_status_t eficonfig_generate_media_device_boot_option(void);
#endif diff --git a/include/efi_loader.h b/include/efi_loader.h index 4461f721e0..6b63ae8dde 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -953,6 +953,22 @@ struct efi_signature_store { struct x509_certificate; struct pkcs7_message;
+/** + * struct eficonfig_media_boot_option - boot option for (removable) media device + * + * This structure is used to enumerate possible boot option + * + * @lo: Serialized load option data + * @size: Size of serialized load option data + * @exist: Flag to indicate the load option already exists + * in Non-volatile load option + */ +struct eficonfig_media_boot_option { + void *lo; + efi_uintn_t size; + bool exist; +}; + bool efi_hash_regions(struct image_region *regs, int count, void **hash, const char *hash_algo, int *len); bool efi_signature_lookup_digest(struct efi_image_regions *regs, diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index ede9116b3c..4b24b41047 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -246,6 +246,10 @@ static efi_status_t try_load_entry(u16 n, efi_handle_t *handle, }
/* Set load options */ + if (size >= sizeof(efi_guid_t) && + !guidcmp(lo.optional_data, &efi_guid_bootmenu_auto_generated)) + size = 0; + if (size) { *load_options = malloc(size); if (!*load_options) {
In eficonfig startup, scan media devices and update the UEFI boot option.
Newly created in v14
cmd/eficonfig.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/cmd/eficonfig.c b/cmd/eficonfig.c index 21d9bd3e23..dda45a8364 100644 --- a/cmd/eficonfig.c +++ b/cmd/eficonfig.c @@ -2089,6 +2089,10 @@ static int do_eficonfig(struct cmd_tbl *cmdtp, int flag, int argc, char *const a if (ret != EFI_SUCCESS) return CMD_RET_FAILURE;
+ ret = eficonfig_generate_media_device_boot_option(); + if (ret != EFI_SUCCESS && ret != EFI_NOT_FOUND) + return ret; + while (1) { efi_menu = eficonfig_create_fixed_menu(maintenance_menu_items, ARRAY_SIZE(maintenance_menu_items));
This commit adds the menu entry to update UEFI BootOrder variable. User moves the entry with UP/DOWN key, changes the order with PLUS/MINUS key, press SPACE to activate or deactivate the entry, then finalizes the order by ENTER key. If the entry is activated, the boot index is added into the BootOrder variable in the order of the list.
The U-Boot menu framework is well designed for static menu, this commit implements the own menu display and key handling for dynamically change the order of menu entry.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- No update since v15
Changes in v14: - remove scan of media device, it is moved into eficonfig startup - add comment in default case for key handling - add missing break in eficonfig_choice_entry
Changes in v12: - enumerate removable media device
Changes in v11: - remove BootOrder variable dependency - use ANSI_CURSOR_POSITION and ANSI_CLEAR_LINE instead of printf("\n") since current eficonfig implementation does not handle console size correctly. printf("\n") at the outside of console size breaks the console output. - add KEY_SPACE to toggle the boot option active status
No update since v9
Changes in v8: - add "Save" and "Quit" entries
Changes in v7: - use UP/DOWN and PLUS/MINUS key to change to order
no update in v6:
cmd/eficonfig.c | 348 +++++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 347 insertions(+), 1 deletion(-)
diff --git a/cmd/eficonfig.c b/cmd/eficonfig.c index dda45a8364..2e1f2bfd8b 100644 --- a/cmd/eficonfig.c +++ b/cmd/eficonfig.c @@ -91,6 +91,23 @@ struct eficonfig_boot_selection_data { int *selected; };
+/** + * struct eficonfig_boot_order - structure to be used to update BootOrder variable + * + * @num: index in the menu entry + * @description: pointer to the description string + * @boot_index: boot option index + * @active: flag to include the boot option into BootOrder variable + * @list: list structure + */ +struct eficonfig_boot_order { + u32 num; + u16 *description; + u32 boot_index; + bool active; + struct list_head list; +}; + /** * eficonfig_print_msg() - print message * @@ -1748,6 +1765,335 @@ out: return ret; }
+/** + * eficonfig_display_change_boot_order() - display the BootOrder list + * + * @efi_menu: pointer to the efimenu structure + * Return: status code + */ +static void eficonfig_display_change_boot_order(struct efimenu *efi_menu) +{ + bool reverse; + struct list_head *pos, *n; + struct eficonfig_boot_order *entry; + + printf(ANSI_CLEAR_CONSOLE ANSI_CURSOR_POSITION + "\n ** Change Boot Order **\n" + ANSI_CURSOR_POSITION + " Press UP/DOWN to move, +/- to change order" + ANSI_CURSOR_POSITION + " Press SPACE to activate or deactivate the entry" + ANSI_CURSOR_POSITION + " Select [Save] to complete, ESC/CTRL+C to quit" + ANSI_CURSOR_POSITION ANSI_CLEAR_LINE, + 1, 1, efi_menu->count + 5, 1, efi_menu->count + 6, 1, + efi_menu->count + 7, 1, efi_menu->count + 8, 1); + + /* draw boot option list */ + list_for_each_safe(pos, n, &efi_menu->list) { + entry = list_entry(pos, struct eficonfig_boot_order, list); + reverse = (entry->num == efi_menu->active); + + printf(ANSI_CURSOR_POSITION, entry->num + 4, 7); + + if (reverse) + puts(ANSI_COLOR_REVERSE); + + if (entry->num < efi_menu->count - 2) { + if (entry->active) + printf("[*] "); + else + printf("[ ] "); + } + + printf("%ls", entry->description); + + if (reverse) + puts(ANSI_COLOR_RESET); + } +} + +/** + * eficonfig_choice_change_boot_order() - handle the BootOrder update + * + * @efi_menu: pointer to the efimenu structure + * Return: status code + */ +static efi_status_t eficonfig_choice_change_boot_order(struct efimenu *efi_menu) +{ + int esc = 0; + struct list_head *pos, *n; + struct eficonfig_boot_order *tmp; + enum bootmenu_key key = KEY_NONE; + struct eficonfig_boot_order *entry; + + while (1) { + bootmenu_loop(NULL, &key, &esc); + + switch (key) { + case KEY_PLUS: + if (efi_menu->active > 0) { + list_for_each_safe(pos, n, &efi_menu->list) { + entry = list_entry(pos, struct eficonfig_boot_order, list); + if (entry->num == efi_menu->active) + break; + } + tmp = list_entry(pos->prev, struct eficonfig_boot_order, list); + entry->num--; + tmp->num++; + list_del(&tmp->list); + list_add(&tmp->list, &entry->list); + } + fallthrough; + case KEY_UP: + if (efi_menu->active > 0) + --efi_menu->active; + return EFI_NOT_READY; + case KEY_MINUS: + if (efi_menu->active < efi_menu->count - 3) { + list_for_each_safe(pos, n, &efi_menu->list) { + entry = list_entry(pos, struct eficonfig_boot_order, list); + if (entry->num == efi_menu->active) + break; + } + tmp = list_entry(pos->next, struct eficonfig_boot_order, list); + entry->num++; + tmp->num--; + list_del(&entry->list); + list_add(&entry->list, &tmp->list); + + ++efi_menu->active; + } + return EFI_NOT_READY; + case KEY_DOWN: + if (efi_menu->active < efi_menu->count - 1) + ++efi_menu->active; + return EFI_NOT_READY; + case KEY_SELECT: + /* "Save" */ + if (efi_menu->active == efi_menu->count - 2) + return EFI_SUCCESS; + + /* "Quit" */ + if (efi_menu->active == efi_menu->count - 1) + return EFI_ABORTED; + + break; + case KEY_SPACE: + if (efi_menu->active < efi_menu->count - 2) { + list_for_each_safe(pos, n, &efi_menu->list) { + entry = list_entry(pos, struct eficonfig_boot_order, list); + if (entry->num == efi_menu->active) { + entry->active = entry->active ? false : true; + return EFI_NOT_READY; + } + } + } + break; + case KEY_QUIT: + return EFI_ABORTED; + default: + /* Pressed key is not valid, no need to regenerate the menu */ + break; + } + } +} + +/** + * eficonfig_add_change_boot_order_entry() - add boot order entry + * + * @efi_menu: pointer to the efimenu structure + * @boot_index: boot option index to be added + * @active: flag to include the boot option into BootOrder + * Return: status code + */ +static efi_status_t eficonfig_add_change_boot_order_entry(struct efimenu *efi_menu, + u32 boot_index, bool active) +{ + efi_status_t ret; + efi_uintn_t size; + void *load_option; + struct efi_load_option lo; + u16 varname[] = u"Boot####"; + struct eficonfig_boot_order *entry; + + efi_create_indexed_name(varname, sizeof(varname), "Boot", boot_index); + load_option = efi_get_var(varname, &efi_global_variable_guid, &size); + if (!load_option) + return EFI_SUCCESS; + + ret = efi_deserialize_load_option(&lo, load_option, &size); + if (ret != EFI_SUCCESS) { + free(load_option); + return ret; + } + + entry = calloc(1, sizeof(struct eficonfig_boot_order)); + if (!entry) { + free(load_option); + return EFI_OUT_OF_RESOURCES; + } + + entry->description = u16_strdup(lo.label); + if (!entry->description) { + free(load_option); + free(entry); + return EFI_OUT_OF_RESOURCES; + } + entry->num = efi_menu->count++; + entry->boot_index = boot_index; + entry->active = active; + list_add_tail(&entry->list, &efi_menu->list); + + free(load_option); + + return EFI_SUCCESS; +} + +/** + * eficonfig_create_change_boot_order_entry() - create boot order entry + * + * @efi_menu: pointer to the efimenu structure + * @bootorder: pointer to the BootOrder variable + * @num: number of BootOrder entry + * Return: status code + */ +static efi_status_t eficonfig_create_change_boot_order_entry(struct efimenu *efi_menu, + u16 *bootorder, efi_uintn_t num) +{ + u32 i; + efi_status_t ret; + struct eficonfig_boot_order *entry; + + /* list the load option in the order of BootOrder variable */ + for (i = 0; i < num; i++) { + if (efi_menu->count >= EFICONFIG_ENTRY_NUM_MAX - 2) + break; + + ret = eficonfig_add_change_boot_order_entry(efi_menu, bootorder[i], true); + if (ret != EFI_SUCCESS) + goto out; + } + + /* list the remaining load option not included in the BootOrder */ + for (i = 0; i < 0xFFFF; i++) { + if (efi_menu->count >= EFICONFIG_ENTRY_NUM_MAX - 2) + break; + + /* If the index is included in the BootOrder, skip it */ + if (search_bootorder(bootorder, num, i, NULL)) + continue; + + ret = eficonfig_add_change_boot_order_entry(efi_menu, i, false); + if (ret != EFI_SUCCESS) + goto out; + } + + /* add "Save" and "Quit" entries */ + entry = calloc(1, sizeof(struct eficonfig_boot_order)); + if (!entry) + goto out; + + entry->num = efi_menu->count++; + entry->description = u16_strdup(u"Save"); + list_add_tail(&entry->list, &efi_menu->list); + + entry = calloc(1, sizeof(struct eficonfig_boot_order)); + if (!entry) + goto out; + + entry->num = efi_menu->count++; + entry->description = u16_strdup(u"Quit"); + list_add_tail(&entry->list, &efi_menu->list); + + efi_menu->active = 0; + + return EFI_SUCCESS; +out: + return EFI_OUT_OF_RESOURCES; +} + +/** + * eficonfig_process_change_boot_order() - handler to change boot order + * + * @data: pointer to the data for each entry + * Return: status code + */ +static efi_status_t eficonfig_process_change_boot_order(void *data) +{ + u32 count; + u16 *bootorder; + efi_status_t ret; + efi_uintn_t num, size; + struct list_head *pos, *n; + struct eficonfig_boot_order *entry; + struct efimenu *efi_menu; + + efi_menu = calloc(1, sizeof(struct efimenu)); + if (!efi_menu) + return EFI_OUT_OF_RESOURCES; + + bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); + + INIT_LIST_HEAD(&efi_menu->list); + num = size / sizeof(u16); + ret = eficonfig_create_change_boot_order_entry(efi_menu, bootorder, num); + if (ret != EFI_SUCCESS) + goto out; + + while (1) { + eficonfig_display_change_boot_order(efi_menu); + + ret = eficonfig_choice_change_boot_order(efi_menu); + if (ret == EFI_SUCCESS) { + u16 *new_bootorder; + + new_bootorder = calloc(1, (efi_menu->count - 2) * sizeof(u16)); + if (!new_bootorder) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + + /* create new BootOrder */ + count = 0; + list_for_each_safe(pos, n, &efi_menu->list) { + entry = list_entry(pos, struct eficonfig_boot_order, list); + if (entry->active) + new_bootorder[count++] = entry->boot_index; + } + + size = count * sizeof(u16); + ret = efi_set_variable_int(u"BootOrder", &efi_global_variable_guid, + EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + size, new_bootorder, false); + + free(new_bootorder); + goto out; + } else if (ret == EFI_NOT_READY) { + continue; + } else { + goto out; + } + } +out: + list_for_each_safe(pos, n, &efi_menu->list) { + entry = list_entry(pos, struct eficonfig_boot_order, list); + list_del(&entry->list); + free(entry->description); + free(entry); + } + + free(bootorder); + free(efi_menu); + + /* to stay the parent menu */ + ret = (ret == EFI_ABORTED) ? EFI_NOT_READY : ret; + + return ret; +} + /** * delete_boot_option() - delete selected boot option * @@ -2025,7 +2371,6 @@ out: return ret; }
- /** * eficonfig_init() - do required initialization for eficonfig command * @@ -2056,6 +2401,7 @@ static efi_status_t eficonfig_init(void) static const struct eficonfig_item maintenance_menu_items[] = { {"Add Boot Option", eficonfig_process_add_boot_option}, {"Edit Boot Option", eficonfig_process_edit_boot_option}, + {"Change Boot Order", eficonfig_process_change_boot_order}, {"Delete Boot Option", eficonfig_process_delete_boot_option}, {"Quit", eficonfig_process_quit}, };
The bootmenu enumerates the UEFI boot options for boot device selection. This commit adds the description how the UEFI boot work in bootmenu. This commit also adds "Synopsis", "Description" and "Configuration" sections to follow the U-Boot command documentation format.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- No update since v10
Changes in v10: - fix typos
Changes in v7: - update the description what bootmenu do for uefi-related boot menu - add default behavior when user exits from bootmenu
Changes in v6: - remove distro boot related contents because the distro boot support in bootmenu is dropped - update uefi entry example - add [delay] argument of bootmenu command - add description to enable uefi boot entry
Changes in v5: - follow the cmd documentation format same as other command, add "Synopsis", "Description" add "Configuration" sections
Newly created in v4
doc/usage/cmd/bootmenu.rst | 74 ++++++++++++++++++++++++++++++++++++++ 1 file changed, 74 insertions(+)
diff --git a/doc/usage/cmd/bootmenu.rst b/doc/usage/cmd/bootmenu.rst index 9430f8c9aa..cb3c8d2f93 100644 --- a/doc/usage/cmd/bootmenu.rst +++ b/doc/usage/cmd/bootmenu.rst @@ -4,6 +4,15 @@ bootmenu command ================
+Synopsis +-------- +:: + + bootmenu [delay] + +Description +----------- + The "bootmenu" command uses U-Boot menu interfaces and provides a simple mechanism for creating menus with different boot items. The cursor keys "Up" and "Down" are used for navigation through @@ -79,6 +88,55 @@ The above example will be rendered as below:: The selected menu entry will be highlighted - it will have inverted background and text colors.
+UEFI boot variable enumeration +'''''''''''''''''''''''''''''' +If enabled, the bootmenu command will automatically generate and add +UEFI-related boot menu entries for the following items. + + * possible bootable media with default file names + * user-defined UEFI boot options + +The bootmenu automatically enumerates the possible bootable +media devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL. +This auto generated entry is named as "<interface> <devnum>:<part>" format. +(e.g. "usb 0:1") + +The bootmenu displays the UEFI-related menu entries in order of "BootOrder". +When the user selects the UEFI boot menu entry, the bootmenu sets +the selected boot variable index to "BootNext" without non-volatile attribute, +then call the uefi boot manager with the command "bootefi bootmgr". + +Example bootmenu is as below:: + + *** U-Boot Boot Menu *** + + mmc 0:1 + mmc 0:2 + debian + nvme 0:1 + ubuntu + nvme 0:2 + usb 0:2 + U-Boot console + +Default behavior when user exits from the bootmenu +~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ +User can exit from bootmenu by selecting the last entry +"U-Boot console"/"Quit" or ESC/CTRL+C key. + +When the CONFIG_BOOTMENU_DISABLE_UBOOT_CONSOLE is disabled, +user exits from the bootmenu and returns to the U-Boot console. + +When the CONFIG_BOOTMENU_DISABLE_UBOOT_CONSOLE is enabled, user can not +enter the U-Boot console. When the user exits from the bootmenu, +the bootmenu invokes the following default behavior. + + * if CONFIG_CMD_BOOTEFI_BOOTMGR is enabled, execute "bootefi bootmgr" command + * "bootefi bootmgr" fails or is not enabled, then execute "run bootcmd" command. + +Configuration +------------- + The "bootmenu" command is enabled by::
CONFIG_CMD_BOOTMENU=y @@ -88,3 +146,19 @@ To run the bootmenu at startup add these additional settings:: CONFIG_AUTOBOOT_KEYED=y CONFIG_BOOTDELAY=30 CONFIG_AUTOBOOT_MENU_SHOW=y + +UEFI boot variable enumeration is enabled by:: + + CONFIG_CMD_BOOTEFI_BOOTMGR=y + +To improve the product security, entering U-Boot console from bootmenu +can be disabled by:: + + CONFIG_BOOTMENU_DISABLE_UBOOT_CONSOLE=y + +To scan the discoverable devices connected to the buses such as +USB and PCIe prior to bootmenu showing up, CONFIG_PREBOOT can be +used to run the command before showing the bootmenu, i.e.:: + + CONFIG_USE_PREBOOT=y + CONFIG_PREBOOT="pci enum; usb start; scsi scan; nvme scan; virtio scan"
Add documentation for eficonfig command.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- No update since v15
Changes in v14: - fix typos
Changes in v13: - describe how to auto boot according to the UEFI Boot option
Changes in v12: - CONFIG_BOOTMENU_DISABLE_UBOOT_CONSOLE condition is added to show newly added boot option
No update since v10
Changes in v10: - describe how to boot system after editting by eficonfig
Changes in v8: - command name is changed from "efimenu" to "eficonfig"
Newly created in v7
doc/usage/cmd/eficonfig.rst | 71 +++++++++++++++++++++++++++++++++++++ doc/usage/index.rst | 1 + 2 files changed, 72 insertions(+) create mode 100644 doc/usage/cmd/eficonfig.rst
diff --git a/doc/usage/cmd/eficonfig.rst b/doc/usage/cmd/eficonfig.rst new file mode 100644 index 0000000000..340ebc80db --- /dev/null +++ b/doc/usage/cmd/eficonfig.rst @@ -0,0 +1,71 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. (C) Copyright 2022, Masahisa Kojima masahisa.kojima@linaro.org + +eficonfig command +================= + +Synopsis +-------- +:: + + eficonfig + +Description +----------- + +The "eficonfig" command uses U-Boot menu interface and provides +a menu-driven UEFI variable maintenance feature. +The "eficonfig" has the following menu entries. + +Add Boot Option + Add new UEFI Boot Option. + User can edit description, file path, and optional_data. + +Edit Boot Option + Edit the existing UEFI Boot Option + User can edit description, file path, and optional_data. + +Change Boot Order + Change the order of UEFI BootOrder variable. + +Delete Boot Option + Delete the UEFI Boot Option + +Configuration +------------- + +The "eficonfig" command is enabled by:: + + CONFIG_CMD_EFICONFIG=y + +If CONFIG_BOOTMENU_DISABLE_UBOOT_CONSOLE is enabled, user can not enter +U-Boot console. In this case, bootmenu can be used to invoke "eficonfig":: + + CONFIG_USE_PREBOOT=y + CONFIG_PREBOOT="setenv bootmenu_0 UEFI Maintenance Menu=eficonfig" + +How to boot the system with newly added UEFI Boot Option +'''''''''''''''''''''''''''''''''''''''''''''''''''''''' + +"eficonfig" command is responsible for configuring the UEFI variables, +not directly handle the system boot. +The new Boot Option added by "eficonfig" is appended at the last entry +of UEFI BootOrder variable, user may want to change the boot order +through "Change Boot Order". +If the bootmenu is enabled, CONFIG_BOOTMENU_DISABLE_UBOOT_CONSOLE is enabled, +and "eficonfig" is configured as preboot command, the newly added Boot Options +are enumerated in the bootmenu when user exits from the eficonfig menu. +User may select the entry in the bootmenu to boot the system, or follow +the U-Boot configuration the system already has. + +Auto boot with the UEFI Boot Option +''''''''''''''''''''''''''''''''''' + +To do auto boot according to the UEFI BootOrder variable, +add "bootefi bootmgr" entry as a default or first bootmenu entry:: + + CONFIG_PREBOOT="setenv bootmenu_0 UEFI Boot Manager=bootefi bootmgr; setenv bootmenu_1 UEFI Maintenance Menu=eficonfig" + +See also +-------- +* :doc:`bootmenu<bootmenu>` provides a simple mechanism for creating menus with different boot items diff --git a/doc/usage/index.rst b/doc/usage/index.rst index 28f9683a3e..09f2928970 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -35,6 +35,7 @@ Shell commands cmd/conitrace cmd/dm cmd/echo + cmd/eficonfig cmd/env cmd/event cmd/exception
Provide a unit test for the eficonfig command.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org Acked-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- No update since v15
Changes in v14: - update to support media device enumeration in eficonfig startup - move no block device test to the last test case
Changes in v12: - update menu handling
Changes in v11: - fix expected result when no BootOrder is defined
Newly added in v10
configs/sandbox_defconfig | 1 + test/py/tests/test_eficonfig/conftest.py | 40 ++ .../py/tests/test_eficonfig/test_eficonfig.py | 350 ++++++++++++++++++ 3 files changed, 391 insertions(+) create mode 100644 test/py/tests/test_eficonfig/conftest.py create mode 100644 test/py/tests/test_eficonfig/test_eficonfig.py
diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index eba7bcbb48..48c60c606d 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -93,6 +93,7 @@ CONFIG_CMD_LINK_LOCAL=y CONFIG_CMD_ETHSW=y CONFIG_CMD_BMP=y CONFIG_CMD_BOOTCOUNT=y +CONFIG_CMD_EFICONFIG=y CONFIG_CMD_EFIDEBUG=y CONFIG_CMD_RTC=y CONFIG_CMD_TIME=y diff --git a/test/py/tests/test_eficonfig/conftest.py b/test/py/tests/test_eficonfig/conftest.py new file mode 100644 index 0000000000..f289df0362 --- /dev/null +++ b/test/py/tests/test_eficonfig/conftest.py @@ -0,0 +1,40 @@ +# SPDX-License-Identifier: GPL-2.0+ + +"""Fixture for UEFI eficonfig test +""" + +import os +import shutil +from subprocess import check_call +import pytest + +@pytest.fixture(scope='session') +def efi_eficonfig_data(u_boot_config): + """Set up a file system to be used in UEFI "eficonfig" command + tests + + Args: + u_boot_config -- U-boot configuration. + + Return: + A path to disk image to be used for testing + """ + mnt_point = u_boot_config.persistent_data_dir + '/test_efi_eficonfig' + image_path = u_boot_config.persistent_data_dir + '/efi_eficonfig.img' + + shutil.rmtree(mnt_point, ignore_errors=True) + os.mkdir(mnt_point, mode = 0o755) + + with open(mnt_point + '/initrd-1.img', 'w', encoding = 'ascii') as file: + file.write("initrd 1") + + with open(mnt_point + '/initrd-2.img', 'w', encoding = 'ascii') as file: + file.write("initrd 2") + + shutil.copyfile(u_boot_config.build_dir + '/lib/efi_loader/initrddump.efi', + mnt_point + '/initrddump.efi') + + check_call(f'virt-make-fs --partition=gpt --size=+1M --type=vfat {mnt_point} {image_path}', + shell=True) + + return image_path diff --git a/test/py/tests/test_eficonfig/test_eficonfig.py b/test/py/tests/test_eficonfig/test_eficonfig.py new file mode 100644 index 0000000000..1c501deb1f --- /dev/null +++ b/test/py/tests/test_eficonfig/test_eficonfig.py @@ -0,0 +1,350 @@ +# SPDX-License-Identifier: GPL-2.0+ +""" Unit test for UEFI menu-driven configuration +""" + +import pytest +import time + +@pytest.mark.boardspec('sandbox') +@pytest.mark.buildconfigspec('cmd_eficonfig') +@pytest.mark.buildconfigspec('cmd_bootefi_bootmgr') +def test_efi_eficonfig(u_boot_console, efi_eficonfig_data): + + def send_user_input_and_wait(user_str, expect_str): + time.sleep(0.1) # TODO: does not work correctly without sleep + u_boot_console.run_command(cmd=user_str, wait_for_prompt=False, + wait_for_echo=True, send_nl=False) + u_boot_console.run_command(cmd='\x0d', wait_for_prompt=False, + wait_for_echo=False, send_nl=False) + if expect_str is not None: + for i in expect_str: + u_boot_console.p.expect([i]) + + def press_up_down_enter_and_wait(up_count, down_count, enter, expect_str): + # press UP key + for i in range(up_count): + u_boot_console.run_command(cmd='\x1b\x5b\x41', wait_for_prompt=False, + wait_for_echo=False, send_nl=False) + # press DOWN key + for i in range(down_count): + u_boot_console.run_command(cmd='\x1b\x5b\x42', wait_for_prompt=False, + wait_for_echo=False, send_nl=False) + # press ENTER if requested + if enter: + u_boot_console.run_command(cmd='\x0d', wait_for_prompt=False, + wait_for_echo=False, send_nl=False) + # wait expected output + if expect_str is not None: + for i in expect_str: + u_boot_console.p.expect([i]) + + def press_escape_key(wait_prompt): + u_boot_console.run_command(cmd='\x1b', wait_for_prompt=wait_prompt, wait_for_echo=False, send_nl=False) + + def press_enter_key(wait_prompt): + u_boot_console.run_command(cmd='\x0d', wait_for_prompt=wait_prompt, + wait_for_echo=False, send_nl=False) + + def check_current_is_maintenance_menu(): + for i in ('UEFI Maintenance Menu', 'Add Boot Option', 'Edit Boot Option', + 'Change Boot Order', 'Delete Boot Option', 'Quit'): + u_boot_console.p.expect([i]) + + """ Unit test for "eficonfig" command + The menu-driven interface is used to set up UEFI load options. + The bootefi bootmgr loads initrddump.efi as a payload. + The crc32 of the loaded initrd.img is checked + + Args: + u_boot_console -- U-Boot console + efi__data -- Path to the disk image used for testing. + Test disk image has following files. + initrd-1.img + initrddump.efi + initrd-2.img + + """ + with u_boot_console.temporary_timeout(500): + # + # Test Case 1: Check the menu is displayed + # + u_boot_console.run_command('eficonfig', wait_for_prompt=False) + for i in ('UEFI Maintenance Menu', 'Add Boot Option', 'Edit Boot Option', + 'Change Boot Order', 'Delete Boot Option', 'Quit'): + u_boot_console.p.expect([i]) + # Select "Add Boot Option" + press_enter_key(False) + for i in ('Add Boot Option', 'Description:', 'File', 'Initrd File', 'Optional Data', + 'Save', 'Quit'): + u_boot_console.p.expect([i]) + press_escape_key(False) + check_current_is_maintenance_menu() + # return to U-Boot console + press_escape_key(True) + + # + # Test Case 2: check auto generated media device entry + # + + # bind the test disk image for succeeding tests + u_boot_console.run_command(cmd = f'host bind 0 {efi_eficonfig_data}') + + u_boot_console.run_command('eficonfig', wait_for_prompt=False) + + # Change the Boot Order + press_up_down_enter_and_wait(0, 2, True, 'Quit') + for i in ('host 0:1', 'Save', 'Quit'): + u_boot_console.p.expect([i]) + # disable auto generated boot option for succeeding test + u_boot_console.run_command(cmd=' ', wait_for_prompt=False, + wait_for_echo=False, send_nl=False) + # Save the BootOrder + press_up_down_enter_and_wait(0, 1, True, None) + check_current_is_maintenance_menu() + + # + # Test Case 3: Add first Boot Option and load it + # + + # Select 'Add Boot Option' + press_up_down_enter_and_wait(0, 0, True, 'Quit') + + # Press the enter key to select 'Description:' entry, then enter Description + press_up_down_enter_and_wait(0, 0, True, 'enter description:') + # Send Description user input, press ENTER key to complete + send_user_input_and_wait('test 1', 'Quit') + + # Set EFI image(initrddump.efi) + press_up_down_enter_and_wait(0, 1, True, 'Quit') + press_up_down_enter_and_wait(0, 0, True, 'host 0:1') + # Select 'host 0:1' + press_up_down_enter_and_wait(0, 0, True, 'Quit') + # Press down key to select "initrddump.efi" entry followed by the enter key + press_up_down_enter_and_wait(0, 1, True, 'Quit') + + # Set Initrd file(initrd-1.img) + press_up_down_enter_and_wait(0, 2, True, 'Quit') + press_up_down_enter_and_wait(0, 0, True, 'host 0:1') + # Select 'host 0:1' + press_up_down_enter_and_wait(0, 0, True, 'Quit') + # Press down key to select "initrd-1.img" entry followed by the enter key + press_up_down_enter_and_wait(0, 0, True, 'Quit') + + # Set optional_data + press_up_down_enter_and_wait(0, 3, True, 'Optional Data:') + # Send Description user input, press ENTER key to complete + send_user_input_and_wait('nocolor', None) + for i in ('Description: test 1', 'File: host 0:1/initrddump.efi', + 'Initrd File: host 0:1/initrd-1.img', 'Optional Data: nocolor', 'Save', 'Quit'): + u_boot_console.p.expect([i]) + + # Save the Boot Option + press_up_down_enter_and_wait(0, 4, True, None) + check_current_is_maintenance_menu() + + # Check the newly added Boot Option is handled correctly + # Return to U-Boot console + press_escape_key(True) + u_boot_console.run_command(cmd = 'bootefi bootmgr') + response = u_boot_console.run_command(cmd = 'load', wait_for_echo=False) + assert 'crc32: 0x181464af' in response + u_boot_console.run_command(cmd = 'exit', wait_for_echo=False) + + # + # Test Case 4: Add second Boot Option and load it + # + u_boot_console.run_command('eficonfig', wait_for_prompt=False) + + # Select 'Add Boot Option' + press_up_down_enter_and_wait(0, 0, True, 'Quit') + + # Press the enter key to select 'Description:' entry, then enter Description + press_up_down_enter_and_wait(0, 0, True, 'enter description:') + # Send Description user input, press ENTER key to complete + send_user_input_and_wait('test 2', 'Quit') + + # Set EFI image(initrddump.efi) + press_up_down_enter_and_wait(0, 1, True, 'Quit') + press_up_down_enter_and_wait(0, 0, True, 'host 0:1') + # Select 'host 0:1' + press_up_down_enter_and_wait(0, 0, True, 'Quit') + # Press down key to select "initrddump.efi" entry followed by the enter key + press_up_down_enter_and_wait(0, 1, True, 'Quit') + + # Set Initrd file(initrd-2.img) + press_up_down_enter_and_wait(0, 2, True, 'Quit') + press_up_down_enter_and_wait(0, 0, True, 'host 0:1') + # Select 'host 0:1' + press_up_down_enter_and_wait(0, 0, True, 'Quit') + # Press down key to select "initrd-2.img" entry followed by the enter key + press_up_down_enter_and_wait(0, 2, True, 'Quit') + + # Set optional_data + press_up_down_enter_and_wait(0, 3, True, 'Optional Data:') + # Send Description user input, press ENTER key to complete + send_user_input_and_wait('nocolor', None) + for i in ('Description: test 2', 'File: host 0:1/initrddump.efi', + 'Initrd File: host 0:1/initrd-2.img', 'Optional Data: nocolor', 'Save', 'Quit'): + u_boot_console.p.expect([i]) + + # Save the Boot Option + press_up_down_enter_and_wait(0, 4, True, 'Quit') + + # Change the Boot Order + press_up_down_enter_and_wait(0, 2, True, 'Quit') + press_up_down_enter_and_wait(0, 1, False, 'Quit') + # move 'test 1' to the second entry + u_boot_console.run_command(cmd='+', wait_for_prompt=False, + wait_for_echo=False, send_nl=False) + for i in ('test 2', 'test 1', 'host 0:1', 'Save', 'Quit'): + u_boot_console.p.expect([i]) + # Save the BootOrder + press_up_down_enter_and_wait(0, 3, True, None) + check_current_is_maintenance_menu() + + # Check the newly added Boot Option is handled correctly + # Return to U-Boot console + press_escape_key(True) + u_boot_console.run_command(cmd = 'bootefi bootmgr') + response = u_boot_console.run_command(cmd = 'load', wait_for_echo=False) + assert 'crc32: 0x811d3515' in response + u_boot_console.run_command(cmd = 'exit', wait_for_echo=False) + + # + # Test Case 5: Change BootOrder and load it + # + u_boot_console.run_command('eficonfig', wait_for_prompt=False) + + # Change the Boot Order + press_up_down_enter_and_wait(0, 2, True, None) + # Check the curren BootOrder + for i in ('test 2', 'test 1', 'host 0:1', 'Save', 'Quit'): + u_boot_console.p.expect([i]) + # move 'test 2' to the second entry + u_boot_console.run_command(cmd='-', wait_for_prompt=False, + wait_for_echo=False, send_nl=False) + for i in ('test 1', 'test 2', 'host 0:1', 'Save', 'Quit'): + u_boot_console.p.expect([i]) + # Save the BootOrder + press_up_down_enter_and_wait(0, 2, True, None) + check_current_is_maintenance_menu() + + # Return to U-Boot console + press_escape_key(True) + u_boot_console.run_command(cmd = 'bootefi bootmgr') + response = u_boot_console.run_command(cmd = 'load', wait_for_echo=False) + assert 'crc32: 0x181464af' in response + u_boot_console.run_command(cmd = 'exit', wait_for_echo=False) + + # + # Test Case 6: Delete Boot Option(label:test 2) + # + u_boot_console.run_command('eficonfig', wait_for_prompt=False) + + # Select 'Delete Boot Option' + press_up_down_enter_and_wait(0, 3, True, None) + # Check the current BootOrder + for i in ('test 1', 'test 2', 'Quit'): + u_boot_console.p.expect([i]) + + # Delete 'test 2' + press_up_down_enter_and_wait(0, 1, True, None) + for i in ('test 1', 'Quit'): + u_boot_console.p.expect([i]) + press_escape_key(False) + check_current_is_maintenance_menu() + # Return to U-Boot console + press_escape_key(True) + + # + # Test Case 7: Edit Boot Option + # + u_boot_console.run_command('eficonfig', wait_for_prompt=False) + # Select 'Edit Boot Option' + press_up_down_enter_and_wait(0, 1, True, None) + # Check the curren BootOrder + for i in ('test 1', 'Quit'): + u_boot_console.p.expect([i]) + press_up_down_enter_and_wait(0, 0, True, None) + for i in ('Description: test 1', 'File: host 0:1/initrddump.efi', + 'Initrd File: host 0:1/initrd-1.img', 'Optional Data: nocolor', 'Save', 'Quit'): + u_boot_console.p.expect([i]) + + # Press the enter key to select 'Description:' entry, then enter Description + press_up_down_enter_and_wait(0, 0, True, 'enter description:') + # Send Description user input, press ENTER key to complete + send_user_input_and_wait('test 3', 'Quit') + + # Set EFI image(initrddump.efi) + press_up_down_enter_and_wait(0, 1, True, 'Quit') + press_up_down_enter_and_wait(0, 0, True, 'host 0:1') + # Select 'host 0:1' + press_up_down_enter_and_wait(0, 0, True, 'Quit') + # Press down key to select "initrddump.efi" entry followed by the enter key + press_up_down_enter_and_wait(0, 1, True, 'Quit') + + # Set Initrd file(initrd-2.img) + press_up_down_enter_and_wait(0, 2, True, 'Quit') + press_up_down_enter_and_wait(0, 0, True, 'host 0:1') + # Select 'host 0:1' + press_up_down_enter_and_wait(0, 0, True, 'Quit') + # Press down key to select "initrd-1.img" entry followed by the enter key + press_up_down_enter_and_wait(0, 2, True, 'Quit') + + # Set optional_data + press_up_down_enter_and_wait(0, 3, True, 'Optional Data:') + # Send Description user input, press ENTER key to complete + send_user_input_and_wait('', None) + for i in ('Description: test 3', 'File: host 0:1/initrddump.efi', + 'Initrd File: host 0:1/initrd-2.img', 'Optional Data:', 'Save', 'Quit'): + u_boot_console.p.expect([i]) + + # Save the Boot Option + press_up_down_enter_and_wait(0, 4, True, 'Quit') + press_escape_key(False) + check_current_is_maintenance_menu() + + # Check the updated Boot Option is handled correctly + # Return to U-Boot console + press_escape_key(True) + u_boot_console.run_command(cmd = 'bootefi bootmgr') + response = u_boot_console.run_command(cmd = 'load', wait_for_echo=False) + assert 'crc32: 0x811d3515' in response + u_boot_console.run_command(cmd = 'exit', wait_for_echo=False) + + # + # Test Case 8: Delete Boot Option(label:test 3) + # + u_boot_console.run_command('eficonfig', wait_for_prompt=False) + + # Select 'Delete Boot Option' + press_up_down_enter_and_wait(0, 3, True, None) + # Check the curren BootOrder + for i in ('test 3', 'Quit'): + u_boot_console.p.expect([i]) + + # Delete 'test 3' + press_up_down_enter_and_wait(0, 0, True, 'Quit') + press_escape_key(False) + check_current_is_maintenance_menu() + # Return to U-Boot console + press_escape_key(True) + + # remove the host device + u_boot_console.run_command(cmd = f'host bind -r 0') + + # + # Test Case 9: No block device found + # + u_boot_console.run_command('eficonfig', wait_for_prompt=False) + + # Select 'Add Boot Option' + press_up_down_enter_and_wait(0, 0, True, 'Quit') + + # Set EFI image + press_up_down_enter_and_wait(0, 1, True, 'Quit') + press_up_down_enter_and_wait(0, 0, True, 'No block device found!') + press_escape_key(False) + check_current_is_maintenance_menu() + # Return to U-Boot console + press_escape_key(True)
No update since v15
Changes in v14:
Changes in v12:
Changes in v11:
Newly added in v10
Your code does not pass the test, see https://source.denx.de/u-boot/custodians/u-boot-efi/-/jobs/491449
test/py/tests/test_eficonfig/test_eficonfig.py:103: in test_efi_eficonfig check_current_is_maintenance_menu() test/py/tests/test_eficonfig/test_eficonfig.py:51: in check_current_is_maintenance_menu u_boot_console.p.expect([i]) test/py/u_boot_spawn.py:193: in expect raise Timeout() E u_boot_spawn.Timeout
Best regards
Heinrich
- """Set up a file system to be used in UEFI "eficonfig" command
tests
- Args:
- Return:
- mnt_point = u_boot_config.persistent_data_dir + '/test_efi_eficonfig'
- image_path = u_boot_config.persistent_data_dir + '/efi_eficonfig.img'
- shutil.rmtree(mnt_point, ignore_errors=True)
- os.mkdir(mnt_point, mode = 0o755)
- with open(mnt_point + '/initrd-1.img', 'w', encoding = 'ascii') as file:
- with open(mnt_point + '/initrd-2.img', 'w', encoding = 'ascii') as file:
- shutil.copyfile(u_boot_config.build_dir + '/lib/efi_loader/initrddump.efi',
- check_call(f'virt-make-fs --partition=gpt --size=+1M --type=vfat {mnt_point} {image_path}',
shell=True)
- return image_path
- def send_user_input_and_wait(user_str, expect_str):
- def press_up_down_enter_and_wait(up_count, down_count, enter, expect_str):
# press UP key
# press DOWN key
if enter:
- def press_escape_key(wait_prompt):
- def press_enter_key(wait_prompt):
- def check_current_is_maintenance_menu():
- """ Unit test for "eficonfig" command
- The menu-driven interface is used to set up UEFI load options.
- The bootefi bootmgr loads initrddump.efi as a payload.
- The crc32 of the loaded initrd.img is checked
- Args:
initrd-1.img
initrddump.efi
initrd-2.img
- with u_boot_console.temporary_timeout(500):
'Save', 'Quit'):
# Select 'host 0:1'
# Select 'host 0:1'
# Set optional_data
# Select 'host 0:1'
# Select 'host 0:1'
# Set optional_data
# Delete 'test 2'
# Select 'host 0:1'
# Select 'host 0:1'
# Set optional_data
# Delete 'test 3'
# Set EFI image
No update since v15
Changes in v14:
Changes in v12:
Changes in v11:
Newly added in v10
The reason for failure is an unexpected boot option from the previous test case. u_boot_console.restart_uboot() must be called at the beginning of eficonfig test.
Thanks, Masahisa Kojima
Best regards
Heinrich
tests
- Args:
- Return:
shell=True)
- return image_path
# press UP key
# press DOWN key
if enter:
- Args:
initrd-1.img
initrddump.efi
initrd-2.img
'Save', 'Quit'):
# Select 'host 0:1'
# Select 'host 0:1'
# Set optional_data
# Select 'host 0:1'
# Select 'host 0:1'
# Set optional_data
# Delete 'test 2'
# Select 'host 0:1'
# Select 'host 0:1'
# Set optional_data
# Delete 'test 3'
# Set EFI image
On Fri, 2 Sept 2022 at 08:22, Masahisa Kojima masahisa.kojima@linaro.org wrote:
No update since v15
Changes in v14:
Changes in v12:
Changes in v11:
Newly added in v10
How come this is written in Python? Shouldn't it be in C?
Hi Simon,
No update since v15
Changes in v14:
Changes in v12:
Changes in v11:
Newly added in v10
Would you give more information why you prefer C to Python?
Hi Masahisa,
On Wed, 7 Sept 2022 at 00:13, Masahisa Kojima masahisa.kojima@linaro.org wrote:
Hi Simon,
No update since v15
Changes in v14:
Changes in v12:
Changes in v11:
Newly added in v10
Please see here:
https://u-boot.readthedocs.io/en/latest/develop/tests_writing.html
Hi all,
On Thu, 8 Sept 2022 at 00:11, Simon Glass sjg@chromium.org wrote:
Hi Masahisa,
Hi Simon,
No update since v15
Changes in v14:
Changes in v12:
Changes in v11:
Newly added in v10
Please see here:
I am not too familiar with all the testing facilities, but isn't selecting menu items (which is what this is testing) easier to do in python? I assumed so since the bootmenu tests, which is what this command using under the hood, are written in python
Regards /Ilias
No update since v15
Changes in v14:
Changes in v12:
Changes in v11:
Newly added in v10
We need to prepare an image for testing and provide it to U-Boot.
This cannot be done with C.
Best regards
Heinrich
Hi Heinrich,
No update since v15
Changes in v14:
Changes in v12:
Changes in v11:
Newly added in v10
We do that now with the bootstd tests. Please see setup_bootflow_image().
It is also pretty easy to do it in a Python test but do the actual checking in C. I'll send a patch showing that if you like.
On 9/8/22 20:18, Simon Glass wrote:
Hi Heinrich,
No update since v15
Changes in v14:
Changes in v12:
Changes in v11:
Newly added in v10
setup_bootflow_image() uses sudo. For security reasons I don't like to provide root privileges to other people's code. Distributions don't like their builders to run with root privileges. Please, use virt-make-fs instead.
Best regards
Heinrich
Hi Heinrich,
Hi Heinrich,
No update since v15
Changes in v14:
Changes in v12:
Changes in v11:
Newly added in v10
I do agree, but then don't we need to chmod a+r the current kernel? Is there a way around that?
On 9/9/22 00:12, Simon Glass wrote:
Hi Heinrich,
Hi Heinrich,
No update since v15
Changes in v14:
Changes in v12:
Changes in v11:
Newly added in v10
This is a Ubuntu specific "feature". Debian does not have that problem.
Just create a file
/etc/initramfs-tools/hooks/vmlinuz (chmod 755) with content
#!/bin/sh echo "chmod a+r vmlinuz-*" chmod a+r /boot/vmlinuz-*
And run
update-initramfs -u
The next time a kernel update is installed the script will be executed automatically.
Best regards
Heinrich
Hi Heinrich,
Hi Heinrich,
Hi Heinrich,
On Fri, 2 Sept 2022 at 08:22, Masahisa Kojima masahisa.kojima@linaro.org wrote: > > Provide a unit test for the eficonfig command. > > Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org > Acked-by: Ilias Apalodimas ilias.apalodimas@linaro.org > --- > No update since v15 > > Changes in v14: > - update to support media device enumeration in eficonfig startup > - move no block device test to the last test case > > Changes in v12: > - update menu handling > > Changes in v11: > - fix expected result when no BootOrder is defined > > Newly added in v10 > > configs/sandbox_defconfig | 1 + > test/py/tests/test_eficonfig/conftest.py | 40 ++ > .../py/tests/test_eficonfig/test_eficonfig.py | 350 ++++++++++++++++++ > 3 files changed, 391 insertions(+) > create mode 100644 test/py/tests/test_eficonfig/conftest.py > create mode 100644 test/py/tests/test_eficonfig/test_eficonfig.py
Just create a file
And run
update-initramfs -u
Thanks for the info.
Can we add this to the docs and print out a message in the test pointing people to this fix?
Ilias Apalodimas
Masahisa Kojima
