[PATCH 0/2] Add ESRT and test ESRT creation
The following 2 commits add the ESRT and provide a test of the functionality.
The first commit adds the ESRT as defined in the UEFI 2.8 specification. An empty ESRT is created during the execution of the efi_init_obj_list(). The ESRT is updated when: 1) a FMP protocol is installed in the system: this will add the corresponding entries to the ESRT. 2) a capsule is installed via UpdateCapsule: this should update entries already present in the ESRT.
This implementation of the ESRT creation takes input from FMP only. It is assumed that the FMP will maintain the following values across reboot: - LastAttemptVersion. - LastAttemptStatus.
The second commit enables testing the ESRT creation in the sandbox platfrom. The test executes from the u-boot shell with "ut lib".
Note: I've removed the RFC tag that was previously used to post this patch.
Patch v1: - reworked the ESRT creation code, allowing table to resize as FMPs are installed. - registered a callback for the FMP protocol install. - Created a unit test running on the sandbox platform.
rfc: initial patch submission
CC: Heinrich Schuchardt xypron.glpk@gmx.de CC: Sughosh Ganu sughosh.ganu@linaro.org CC: AKASHI Takahiro takahiro.akashi@linaro.org CC: Ilias Apalodimas ilias.apalodimas@linaro.org CC: Andre Przywara andre.przywara@arm.com CC: Alexander Graf agraf@csgraf.de CC: nd@arm.com
Jose Marinho (2): efi: Add ESRT to the EFI system table efi: ESRT cration unit test
cmd/efidebug.c | 4 + include/efi_api.h | 21 ++ include/efi_loader.h | 19 ++ lib/efi_loader/Kconfig | 7 + lib/efi_loader/Makefile | 1 + lib/efi_loader/efi_boottime.c | 2 - lib/efi_loader/efi_capsule.c | 7 + lib/efi_loader/efi_esrt.c | 439 ++++++++++++++++++++++++++++++++++ lib/efi_loader/efi_setup.c | 6 + test/lib/Makefile | 1 + test/lib/efi_esrt.c | 188 +++++++++++++++ 11 files changed, 693 insertions(+), 2 deletions(-) create mode 100644 lib/efi_loader/efi_esrt.c create mode 100644 test/lib/efi_esrt.c
The ESRT is initialised during efi_init_objlist after efi_initialize_system_table().
The ESRT is initially created with size for 50 FW image entries. The ESRT is resized when it runs out of space. Every resize adds 50 additional entries. The ESRT is populated from information provided by FMP instances only.
Signed-off-by: Jose Marinho jose.marinho@arm.com
--- cmd/efidebug.c | 4 + include/efi_api.h | 21 ++ include/efi_loader.h | 19 ++ lib/efi_loader/Kconfig | 7 + lib/efi_loader/Makefile | 1 + lib/efi_loader/efi_boottime.c | 2 - lib/efi_loader/efi_capsule.c | 7 + lib/efi_loader/efi_esrt.c | 439 ++++++++++++++++++++++++++++++++++ lib/efi_loader/efi_setup.c | 6 + 9 files changed, 504 insertions(+), 2 deletions(-) create mode 100644 lib/efi_loader/efi_esrt.c
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index 83bc2196a5..4160dde1cf 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -458,6 +458,10 @@ static const struct { "Block IO", EFI_BLOCK_IO_PROTOCOL_GUID, }, + { + "EFI System Resource Table", + EFI_SYSTEM_RESOURCE_TABLE_GUID, + }, { "Simple File System", EFI_SIMPLE_FILE_SYSTEM_PROTOCOL_GUID, diff --git a/include/efi_api.h b/include/efi_api.h index 48e48a6263..7eb15bd44c 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -1722,6 +1722,23 @@ struct efi_load_file_protocol { void *buffer); };
+struct efi_system_resource_entry { + efi_guid_t fw_class; + uint32_t fw_type; + uint32_t fw_version; + uint32_t lowest_supported_fw_version; + uint32_t capsule_flags; + uint32_t last_attempt_version; + uint32_t last_attempt_status; +} __packed; + +struct efi_system_resource_table { + uint32_t fw_resource_count; + uint32_t fw_resource_count_max; + uint64_t fw_resource_version; + struct efi_system_resource_entry entries[]; +} __packed; + /* Boot manager load options */ #define LOAD_OPTION_ACTIVE 0x00000001 #define LOAD_OPTION_FORCE_RECONNECT 0x00000002 @@ -1740,6 +1757,10 @@ struct efi_load_file_protocol { #define ESRT_FW_TYPE_DEVICEFIRMWARE 0x00000002 #define ESRT_FW_TYPE_UEFIDRIVER 0x00000003
+#define EFI_SYSTEM_RESOURCE_TABLE_GUID\ + EFI_GUID(0xb122a263, 0x3661, 0x4f68,\ + 0x99, 0x29, 0x78, 0xf8, 0xb0, 0xd6, 0x21, 0x80 ) + /* Last Attempt Status Values */ #define LAST_ATTEMPT_STATUS_SUCCESS 0x00000000 #define LAST_ATTEMPT_STATUS_ERROR_UNSUCCESSFUL 0x00000001 diff --git a/include/efi_loader.h b/include/efi_loader.h index f470bbd636..c85c540041 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -884,4 +884,23 @@ static inline efi_status_t efi_launch_capsules(void)
#endif /* CONFIG_IS_ENABLED(EFI_LOADER) */
+/* + * Install the ESRT system table. + * + * @return status code + */ +efi_status_t efi_esrt_register(void); + +/** + * efi_esrt_add_from_fmp() - Populates a sequence of ESRT entries from the FW + * images in the FMP. + * + * @fmp: the fmp from which fw images are added to the ESRT + * + * Return: + * - EFI_SUCCESS if all the FW images in the FMP are added to the ESRT + * - Error status otherwise + */ +efi_status_t efi_esrt_add_from_fmp(struct efi_firmware_management_protocol *fmp); + #endif /* _EFI_LOADER_H */ diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index e729f727df..12b29180a0 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -347,4 +347,11 @@ config EFI_SECURE_BOOT it is signed with a trusted key. To do that, you need to install, at least, PK, KEK and db.
+config EFI_ESRT + bool "Enable the UEFI ESRT generation" + depends on EFI_LOADER + default y + help + Enabling this option creates the ESRT UEFI system table. + endif diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index 10b42e8847..dec791b310 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -52,6 +52,7 @@ obj-y += efi_variable.o obj-$(CONFIG_EFI_VARIABLES_PRESEED) += efi_var_seed.o endif obj-y += efi_watchdog.o +obj-y += efi_esrt.o obj-$(CONFIG_LCD) += efi_gop.o obj-$(CONFIG_DM_VIDEO) += efi_gop.o obj-$(CONFIG_PARTITIONS) += efi_disk.o diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index ce658a8e73..9b0b15571a 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -1148,8 +1148,6 @@ efi_status_t efi_add_protocol(const efi_handle_t handle, } }
- if (!guidcmp(&efi_guid_device_path, protocol)) - EFI_PRINT("installed device path '%pD'\n", protocol_interface); return EFI_SUCCESS; }
diff --git a/lib/efi_loader/efi_capsule.c b/lib/efi_loader/efi_capsule.c index 0d5a7b63ec..60703bcdaa 100644 --- a/lib/efi_loader/efi_capsule.c +++ b/lib/efi_loader/efi_capsule.c @@ -404,6 +404,13 @@ static efi_status_t efi_capsule_update_firmware( efi_free_pool(abort_reason); goto out; } + +#ifdef CONFIG_EFI_ESRT + /* Update the ESRT entries corresponding to fmp. */ + ret = efi_esrt_add_from_fmp(fmp); + if (ret != EFI_SUCCESS) + log_warning("EFI Capsule: failed to populate ESRT entry\n"); +#endif }
out: diff --git a/lib/efi_loader/efi_esrt.c b/lib/efi_loader/efi_esrt.c new file mode 100644 index 0000000000..34133346ca --- /dev/null +++ b/lib/efi_loader/efi_esrt.c @@ -0,0 +1,439 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * EFI application ESRT tables support + * + * Copyright (C) 2021 Arm Ltd. + */ + +#include <common.h> +#include <efi_loader.h> +#include <log.h> +#include <efi_api.h> +#include <malloc.h> + +static efi_guid_t esrt_guid = EFI_SYSTEM_RESOURCE_TABLE_GUID; + +struct efi_system_resource_table *esrt; + +#define EFI_ESRT_MIN_RESIZE_ENTIRES 50 +#define EFI_ESRT_VERSION 1 + +/** + * efi_esrt_image_info_to_entry() - copy the information present in a fw image + * descriptor to a ESRT entry. + * + * @img_info: the source image info descriptor + * @entry: pointer to the ESRT entry to be filled + * @desc_version: the version of the elements in img_info + * @image_type: the image type value to be set in the ESRT entry + * @flags: the capsule flags value to be set in the ESRT entry + * + */ +void +efi_esrt_image_info_to_entry(struct efi_firmware_image_descriptor *img_info, + struct efi_system_resource_entry *entry, + u32 desc_version, u32 image_type, u32 flags) +{ + guidcpy(&entry->fw_class, &img_info->image_type_id); + entry->fw_version = img_info->version; + + entry->fw_type = image_type; + entry->capsule_flags = flags; + + /* + * The field lowest_supported_image_version is only present + * on image info structure of version 2 or greater. + * See the EFI_FIRMWARE_IMAGE_DESCRIPTOR definition in UEFI. + */ + if (desc_version >= 2) { + entry->lowest_supported_fw_version = + img_info->lowest_supported_image_version; + } else { + entry->lowest_supported_fw_version = 0; + } + + /* + * The fields last_attempt_version and last_attempt_status + * are only present on image info structure of version 3 or + * greater. + * See the EFI_FIRMWARE_IMAGE_DESCRIPTOR definition in UEFI. + */ + if (desc_version >= 3) { + entry->last_attempt_version = + img_info->last_attempt_version; + + entry->last_attempt_status = + img_info->last_attempt_status; + } else { + entry->last_attempt_version = 0; + entry->last_attempt_status = EFI_SUCCESS; + } +} + +/** + * efi_esrt_entries_to_size() - Obtain the bytes used by an ESRT + * datastructure with @num_entries. + * + * @num_entries: the ESRT which we obtain the filled size in bytes. + * + * Return: the number of bytes an ESRT with @num_entries occupies in memory. + */ +static +inline u32 efi_esrt_entries_to_size(u32 num_entries) +{ + u32 esrt_size = sizeof(struct efi_system_resource_table) + + num_entries * sizeof(struct efi_system_resource_entry); + + return esrt_size; +} + +/** + * efi_esrt_allocate_install() - Allocates @num_entries for the ESRT and + * performs basic ESRT initialization. + * + * @bt : pointer to the boottime services structure. + * @num_entries: the number of entries that the ESRT will hold. + * + * Return: + * - pointer to the ESRT if successful. + * - NULL otherwise. + */ +static +struct efi_system_resource_table *efi_esrt_allocate_install(struct efi_boot_services *bt, + u32 num_entries) +{ + efi_status_t ret; + struct efi_system_resource_table *new_esrt; + u32 size = efi_esrt_entries_to_size(num_entries); + + /* Allocated pages must be on the lower 32bit address space. */ + new_esrt = (struct efi_system_resource_table *)(uintptr_t)U32_MAX; + + /* Reserve num_pages for ESRT */ + ret = EFI_CALL(bt->allocate_pool(EFI_RUNTIME_SERVICES_DATA, + size, + (void **)&new_esrt)); + + if (ret != EFI_SUCCESS) { + EFI_PRINT("ESRT Failed to allocate memory for ESRT with %d entries (%d bytes)\n", + num_entries, efi_esrt_entries_to_size(num_entries)); + + return NULL; + } + + new_esrt->fw_resource_count_max = num_entries; + new_esrt->fw_resource_version = EFI_ESRT_VERSION; + + /* Install the ESRT in the system configuration table. */ + ret = EFI_CALL(bt->install_configuration_table(&esrt_guid, (void *)new_esrt)); + if (ret != EFI_SUCCESS) + EFI_PRINT("ESRT failed to install the ESRT\n"); + + return new_esrt; +} + +/** + * efi_esrt_resize() - Increments the ESRT to hold an addition @inc_entries FW + * image entries. + * + * @inc_entries: the additional number of FW image entries to add to the ESRT. + * + * Return: + * - EFI_SUCCESS if ESRT correctly resized. + * - Error code otherwise. + */ +static efi_status_t efi_esrt_resize(u32 inc_entries) +{ + struct efi_boot_services *bt = systab.boottime; + struct efi_system_resource_table *old_esrt = esrt; + struct efi_system_resource_table *new_esrt; + + u32 old_max_entries = old_esrt->fw_resource_count_max; + u32 old_filled_size; + efi_status_t ret; + + if (!bt) { + EFI_PRINT("ESRT cannot obtain pointer to BS\n"); + return EFI_NOT_READY; + } + + /* Allocate and install the bigger ESRT. */ + new_esrt = efi_esrt_allocate_install(bt, old_max_entries + inc_entries); + if (!esrt) { + EFI_PRINT("ESRT failed to allocate and install resized ESRT\n"); + esrt = old_esrt; + return EFI_OUT_OF_RESOURCES; + } + esrt = new_esrt; + + old_filled_size = efi_esrt_entries_to_size(old_esrt->fw_resource_count_max); + + /* Copy the old ESRT entries onto the new table. */ + memcpy(new_esrt->entries, old_esrt->entries, old_filled_size + - sizeof(struct efi_system_resource_table)); + + new_esrt->fw_resource_count = old_esrt->fw_resource_count; + + ret = EFI_CALL(bt->free_pool(old_esrt)); + if (ret != EFI_SUCCESS) { + /* + * This should never happen. + * + * if ret!= EFI_SUCCESS then old_esrt is invalid. + */ + panic("EFI ESRT: could not deallocate old ESRT at %p\n", old_esrt); + } + + return EFI_SUCCESS; +} + +/** + * esrt_find_entry() - Obtain the ESRT entry for the image with GUID + * @img_fw_class. + * + * If the img_fw_class is not yet present in the ESRT, this function + * reserves the tail element of the current ESRT as the entry for that fw_class. + * The number of elements in the ESRT is updated in that case. + * + * @img_fw_class: the GUID of the FW image which ESRT entry we want to obtain. + * + * Return: + * - a pointer to the ESRT entry for the image with GUID img_fw_class, + * - NULL if: + * - there is no more space in the ESRT, + * - ESRT is not initialized, + * - boot services are not present. + */ +static +struct efi_system_resource_entry *esrt_find_entry(efi_guid_t *img_fw_class) +{ + u32 filled_entries; + u32 max_entries; + struct efi_system_resource_entry *entry; + + if (!esrt) { + EFI_PRINT("ESRT access before initialized\n"); + return NULL; + } + + filled_entries = esrt->fw_resource_count; + entry = esrt->entries; + + /* Check if the image with img_fw_class is already in the ESRT. */ + for (u32 idx = 0; idx < filled_entries; idx++) { + if (!guidcmp(&entry[idx].fw_class, img_fw_class)) { + EFI_PRINT("ESRT found entry for image %pUl at index %d\n", + img_fw_class, idx); + return &entry[idx]; + } + } + + max_entries = esrt->fw_resource_count_max; + /* Since the image with img_fw_class is not present in the ESRT, check + * if ESRT is full before appending the new entry to it. */ + if (filled_entries == max_entries) { + efi_status_t ret; + + /* ESRT is full, attempt to extend the ESRT entries. */ + ret = efi_esrt_resize(EFI_ESRT_MIN_RESIZE_ENTIRES); + if (ret != EFI_SUCCESS) { + EFI_PRINT("ESRT full, failed to resize\n"); + return NULL; + } + + entry = esrt->entries; + EFI_PRINT("ESRT table resized\n"); + } + + /* + * This is a new entry for a fw image, increment the element + * number in the table and set the fw_class field. + */ + esrt->fw_resource_count++; + entry[filled_entries].fw_class = *img_fw_class; + EFI_PRINT("ESRT allocated new entry for image %pUl at index %d\n", + img_fw_class, filled_entries); + + return &entry[filled_entries]; +} + +/** + * efi_esrt_add_from_fmp() - Populates a sequence of ESRT entries from the FW + * images in the FMP. + * + * @fmp: the FMP instance from which FW images are added to the ESRT + * + * Return: + * - EFI_SUCCESS if all the FW images in the FMP are added to the ESRT + * - Error status otherwise + */ +efi_status_t efi_esrt_add_from_fmp(struct efi_firmware_management_protocol *fmp) +{ + struct efi_boot_services *bt = systab.boottime; + struct efi_system_resource_entry *entry = NULL; + size_t info_size = 0; + struct efi_firmware_image_descriptor *img_info = NULL; + u32 desc_version; + u8 desc_count; + size_t desc_size; + efi_status_t ret = EFI_SUCCESS; + + if (!bt) { + EFI_PRINT("ESRT cannot obtain pointer to BS\n"); + return EFI_NOT_READY; + } + + /* + * TODO: set the field image_type depending on the FW image type + * defined in a platform basis. + */ + u32 image_type = ESRT_FW_TYPE_UNKNOWN; + + /* TODO: set the capsule flags as a function of the FW image type. */ + u32 flags = 0; + + ret = fmp->get_image_info(fmp, &info_size, img_info, + &desc_version, &desc_count, + &desc_size, NULL, NULL); + + if (ret != EFI_BUFFER_TOO_SMALL) { + /* + * An input of info_size=0 should always lead + * fmp->get_image_info to return BUFFER_TO_SMALL. + */ + EFI_PRINT("Erroneous FMP implementation\n"); + return EFI_INVALID_PARAMETER; + } + + ret = EFI_CALL(bt->allocate_pool(EFI_BOOT_SERVICES_DATA, info_size, + (void **)&img_info)); + if (ret != EFI_SUCCESS) { + EFI_PRINT("ESRT failed to allocate memory for image info.\n"); + return ret; + } + + ret = fmp->get_image_info(fmp, &info_size, img_info, + &desc_version, &desc_count, + &desc_size, NULL, NULL); + if (ret != EFI_SUCCESS) { + EFI_PRINT("ESRT failed to obtain the FMP image info\n"); + goto out; + } + + /* + * Iterate over all the FW images in the FMP. + */ + for (u32 desc_idx = 0; desc_idx < desc_count; desc_idx++) { + struct efi_firmware_image_descriptor *cur_img_info = + (struct efi_firmware_image_descriptor *) + ((uintptr_t)img_info + desc_idx * desc_size); + + /* + * Obtain the ESRT entry for the FW image with fw_class + * equal to cur_img_info->image_type_id. + */ + entry = esrt_find_entry(&cur_img_info->image_type_id); + + if (entry) { + efi_esrt_image_info_to_entry(cur_img_info, entry, + desc_version, image_type, + flags); + } else { + EFI_PRINT("ESRT failed to add entry for %pUl\n", + &cur_img_info->image_type_id); + continue; + } + } + +out: + EFI_CALL(bt->free_pool(img_info)); + return EFI_SUCCESS; +} + +static void EFIAPI efi_esrt_new_fmp_notify(struct efi_event *event, + void *context) +{ + efi_status_t ret; + efi_handle_t handle = NULL; + struct efi_firmware_management_protocol *fmp; + struct efi_boot_services *bt = systab.boottime; + size_t handle_buff_size = sizeof(handle); + + if (!bt) { + EFI_PRINT("ESRT cannot obtain pointer to BS\n"); + return; + } + + /* Obtain a single handle of the FMP type. */ + ret = EFI_CALL(bt->locate_handle(BY_PROTOCOL, + &efi_guid_firmware_management_protocol, + NULL, + &handle_buff_size, + &handle + )); + if (ret != EFI_SUCCESS) { + EFI_PRINT("ESRT cannot find FMP handle\n"); + return; + } + + /* Translate the received handle to a FMP object. */ + ret = EFI_CALL(bt->handle_protocol(handle, + &efi_guid_firmware_management_protocol, + (void **)&fmp)); + if (ret != EFI_SUCCESS) { + EFI_PRINT(" ESRT cannot obtain FMP\n"); + return; + } + + /* Add all the FW images managed by FMP into the ESRT. */ + ret = efi_esrt_add_from_fmp(fmp); + if (ret != EFI_SUCCESS) { + EFI_PRINT("ESRT failed to populate ESRT entry\n"); + return; + } +} + +/** + * efi_esrt_register() - Install the ESRT system table. + * + * Return: status code + */ +efi_status_t efi_esrt_register(void) +{ + struct efi_boot_services *bt = systab.boottime; + struct efi_event *ev = NULL; + void *registration; + u32 num_entries = EFI_ESRT_MIN_RESIZE_ENTIRES; + efi_status_t ret; + + if (!bt) { + EFI_PRINT("ESRT cannot obtain pointer to BS\n"); + return EFI_NOT_READY; + } + + EFI_PRINT("ESRT creation start\n"); + + esrt = efi_esrt_allocate_install(bt, num_entries); + if (!esrt) { + EFI_PRINT("ESRT failed to initialize ESRT\n"); + return EFI_NOT_READY; + } + + ret = EFI_CALL(bt->create_event(EVT_NOTIFY_SIGNAL, TPL_CALLBACK, + efi_esrt_new_fmp_notify, NULL, &ev)); + if (ret != EFI_SUCCESS) { + EFI_PRINT("ESRT failed to create event\n"); + return ret; + } + + ret = EFI_CALL(bt->register_protocol_notify(&efi_guid_firmware_management_protocol, + ev, ®istration)); + if (ret != EFI_SUCCESS) { + EFI_PRINT("ESRT failed to register FMP callback\n"); + return ret; + } + + EFI_PRINT("ESRT table created\n"); + + return ret; +} diff --git a/lib/efi_loader/efi_setup.c b/lib/efi_loader/efi_setup.c index 5800cbf6d4..0183abd09e 100644 --- a/lib/efi_loader/efi_setup.c +++ b/lib/efi_loader/efi_setup.c @@ -231,6 +231,12 @@ efi_status_t efi_init_obj_list(void) if (ret != EFI_SUCCESS) goto out;
+#ifdef CONFIG_EFI_ESRT + ret = efi_esrt_register(); + if (ret != EFI_SUCCESS) + goto out; +#endif + if (IS_ENABLED(CONFIG_EFI_TCG2_PROTOCOL)) { ret = efi_tcg2_register(); if (ret != EFI_SUCCESS)
Signed-off-by: Jose Marinhojose.marinho@arm.com
<josem> one limitation is, if any FMP instance is installed and then uninstalled during the same boottime flow, the ESRT entries will not be removed <josem> this limitation is because I cannot find a proper UEFI way to hook to a FMP protocol uninstall. <xypron> register an event with RegisterProtocolNotify(). <xypron> EFI_CALL(efi_register_protocol_notify(...)) after exporting the function in /include/efi_loader <xypron> The event can be created with efi_create_event().
RegisterProtocolNotifiy() only tells you that a protocol is newly installed, or reinstalled.
If you open the protocol with EFI_OPEN_PROTOCOL_BY_DRIVER, than EFI_BOOT_SERVICES.UninstallProtocolInterface() will call EFI_BOOT_SERVICES.DisconnectController() for the driver which will end up in calling the Stop() function of the driver binding protocol.
Instead of using RegisterProtocolNotifiy() it would be better if the FMP driver would call ConnectController() after installing its protocol.
This project is gone to show you all delights of EFI driver development.
Best regards
Heinrich
- }, { "Simple File System", EFI_SIMPLE_FILE_SYSTEM_PROTOCOL_GUID,
- efi_guid_t fw_class;
- uint32_t fw_type;
- uint32_t fw_version;
- uint32_t lowest_supported_fw_version;
- uint32_t capsule_flags;
- uint32_t last_attempt_version;
- uint32_t last_attempt_status;
+} __packed;
- uint32_t fw_resource_count;
- uint32_t fw_resource_count_max;
- uint64_t fw_resource_version;
- struct efi_system_resource_entry entries[];
+} __packed;
- EFI_GUID(0xb122a263, 0x3661, 0x4f68,\
Please, run scripts/checkpatch.pl on your patches before submitting.
ERROR: space prohibited before that close parenthesis ')'
- @return status code
- efi_esrt_add_from_fmp() - Populates a sequence of ESRT entries from the FW
- images in the FMP.
- @fmp: the fmp from which fw images are added to the ESRT
- Return:
+config EFI_ESRT
- bool "Enable the UEFI ESRT generation"
- depends on EFI_LOADER
This line is after "if EFI_LOADER".
I assume EFI_ESRT should depend on CONFIG_EFI_HAVE_CAPSULE_SUPPORT.
- default y
- help
This change is unrelated. Why would you want to remove the debug output?
Please, use 'if (IS_ENABLED(CONFIG...))' instead of '#if or #ifdef' where possible.
Why don't you reuse efi_esrt_new_fmp_notify()?
I think the warning can be moved to inside efi_esrt_add_from_fmp().
This would not catch an update via an FMP driver loaded via the bootefi command. Shouldn't the call be add the end of efi_update_capsule()?
- EFI application ESRT tables support
- Copyright (C) 2021 Arm Ltd.
- efi_esrt_image_info_to_entry() - copy the information present in a fw image
- descriptor to a ESRT entry.
- @img_info: the source image info descriptor
- @entry: pointer to the ESRT entry to be filled
- @desc_version: the version of the elements in img_info
- @image_type: the image type value to be set in the ESRT entry
- @flags: the capsule flags value to be set in the ESRT entry
- guidcpy(&entry->fw_class, &img_info->image_type_id);
- entry->fw_version = img_info->version;
- entry->fw_type = image_type;
- entry->capsule_flags = flags;
- if (desc_version >= 2) {
- } else {
* greater.
- if (desc_version >= 3) {
- } else {
This should be LAST_ATTEMPT_STATUS_SUCCESS.
- efi_esrt_entries_to_size() - Obtain the bytes used by an ESRT
- datastructure with @num_entries.
- @num_entries: the ESRT which we obtain the filled size in bytes.
- Return: the number of bytes an ESRT with @num_entries occupies in memory.
- u32 esrt_size = sizeof(struct efi_system_resource_table) +
- return esrt_size;
- efi_esrt_allocate_install() - Allocates @num_entries for the ESRT and
- performs basic ESRT initialization.
- @bt : pointer to the boottime services structure.
- @num_entries: the number of entries that the ESRT will hold.
- Return:
- NULL otherwise.
u32 num_entries)
- efi_status_t ret;
- struct efi_system_resource_table *new_esrt;
- u32 size = efi_esrt_entries_to_size(num_entries);
- /* Allocated pages must be on the lower 32bit address space. */
- new_esrt = (struct efi_system_resource_table *)(uintptr_t)U32_MAX;
- /* Reserve num_pages for ESRT */
- ret = EFI_CALL(bt->allocate_pool(EFI_RUNTIME_SERVICES_DATA,
size,
- if (ret != EFI_SUCCESS) {
return NULL;
- new_esrt->fw_resource_count_max = num_entries;
- new_esrt->fw_resource_version = EFI_ESRT_VERSION;
- /* Install the ESRT in the system configuration table. */
- ret = EFI_CALL(bt->install_configuration_table(&esrt_guid, (void *)new_esrt));
- return new_esrt;
- efi_esrt_resize() - Increments the ESRT to hold an addition @inc_entries FW
- image entries.
- @inc_entries: the additional number of FW image entries to add to the ESRT.
- Return:
- struct efi_boot_services *bt = systab.boottime;
- struct efi_system_resource_table *old_esrt = esrt;
This seems overly complex. Just dispose of the existing table and create a new one if either an FMP protocol is installed or CapsuleUpdate() occurs.
- u32 old_max_entries = old_esrt->fw_resource_count_max;
- u32 old_filled_size;
- efi_status_t ret;
- if (!bt) {
- /* Allocate and install the bigger ESRT. */
- new_esrt = efi_esrt_allocate_install(bt, old_max_entries + inc_entries);
- if (!esrt) {
esrt = old_esrt;
- esrt = new_esrt;
- old_filled_size = efi_esrt_entries_to_size(old_esrt->fw_resource_count_max);
- /* Copy the old ESRT entries onto the new table. */
- memcpy(new_esrt->entries, old_esrt->entries, old_filled_size
- new_esrt->fw_resource_count = old_esrt->fw_resource_count;
- ret = EFI_CALL(bt->free_pool(old_esrt));
- return EFI_SUCCESS;
- esrt_find_entry() - Obtain the ESRT entry for the image with GUID
- @img_fw_class.
- If the img_fw_class is not yet present in the ESRT, this function
- reserves the tail element of the current ESRT as the entry for that fw_class.
- The number of elements in the ESRT is updated in that case.
- @img_fw_class: the GUID of the FW image which ESRT entry we want to obtain.
- Return:
- NULL if:
- u32 filled_entries;
- u32 max_entries;
- struct efi_system_resource_entry *entry;
- if (!esrt) {
return NULL;
- filled_entries = esrt->fw_resource_count;
- entry = esrt->entries;
- /* Check if the image with img_fw_class is already in the ESRT. */
- for (u32 idx = 0; idx < filled_entries; idx++) {
img_fw_class, idx);
return &entry[idx];
- max_entries = esrt->fw_resource_count_max;
- /* Since the image with img_fw_class is not present in the ESRT, check
- if (filled_entries == max_entries) {
efi_status_t ret;
return NULL;
- esrt->fw_resource_count++;
- entry[filled_entries].fw_class = *img_fw_class;
- EFI_PRINT("ESRT allocated new entry for image %pUl at index %d\n",
- return &entry[filled_entries];
- @fmp: the FMP instance from which FW images are added to the ESRT
- Return:
- struct efi_system_resource_entry *entry = NULL;
- size_t info_size = 0;
- struct efi_firmware_image_descriptor *img_info = NULL;
- u32 desc_version;
- u8 desc_count;
- size_t desc_size;
- efi_status_t ret = EFI_SUCCESS;
- if (!bt) {
- u32 image_type = ESRT_FW_TYPE_UNKNOWN;
- /* TODO: set the capsule flags as a function of the FW image type. */
- u32 flags = 0;
- ret = fmp->get_image_info(fmp, &info_size, img_info,
- if (ret != EFI_BUFFER_TOO_SMALL) {
- ret = EFI_CALL(bt->allocate_pool(EFI_BOOT_SERVICES_DATA, info_size,
return ret;
goto out;
- for (u32 desc_idx = 0; desc_idx < desc_count; desc_idx++) {
if (entry) {
flags);
} else {
continue;
+out:
- EFI_CALL(bt->free_pool(img_info));
void *context)
- efi_status_t ret;
- efi_handle_t handle = NULL;
- struct efi_firmware_management_protocol *fmp;
- size_t handle_buff_size = sizeof(handle);
- if (!bt) {
return;
- /* Obtain a single handle of the FMP type. */
- ret = EFI_CALL(bt->locate_handle(BY_PROTOCOL,
NULL,
&handle_buff_size,
&handle
There may be many handles for the FMP protocol. I would expect a handler for EFI_BUFFER_TOO_SMALL here.
It is easier to use LocateHandleBuffer() to get all FMP protocols.
As said is wourd prefer replacing the complete ESRT when efi_esrt_new_fmp_notify() is called instead of incremental changes.
Best regards
Heinrich
return;
- /* Translate the received handle to a FMP object. */
- ret = EFI_CALL(bt->handle_protocol(handle,
(void **)&fmp));
return;
- /* Add all the FW images managed by FMP into the ESRT. */
- ret = efi_esrt_add_from_fmp(fmp);
return;
- efi_esrt_register() - Install the ESRT system table.
- Return: status code
- struct efi_event *ev = NULL;
- void *registration;
- u32 num_entries = EFI_ESRT_MIN_RESIZE_ENTIRES;
- efi_status_t ret;
- if (!bt) {
- EFI_PRINT("ESRT creation start\n");
- esrt = efi_esrt_allocate_install(bt, num_entries);
- if (!esrt) {
- ret = EFI_CALL(bt->create_event(EVT_NOTIFY_SIGNAL, TPL_CALLBACK,
return ret;
- ret = EFI_CALL(bt->register_protocol_notify(&efi_guid_firmware_management_protocol,
ev, ®istration));
return ret;
- EFI_PRINT("ESRT table created\n");
- return ret;
- ret = efi_esrt_register();
Please, add a comment that this function must be called before efi_launch_capsules().
Your code does not work for CONFIG_EFI_CAPSULE_ON_DISK_EARLY=y because efi_launch_capsules() is called before efi_init_obj_list().
@Sughosh
I think EFI_CAPSULE_ON_DISK_EARLY has to be corrected first. arch_efi_load_capsule_drivers() tries to install protocols on the root handle before the root handle has been created.
Best regards
Heinrich
goto out;
- if (IS_ENABLED(CONFIG_EFI_TCG2_PROTOCOL)) { ret = efi_tcg2_register(); if (ret != EFI_SUCCESS)
- uint32_t fw_type;
+} __packed;
+} __packed;
- Return:
+config EFI_ESRT
- default y
- help
- } else {
* greater.
- } else {
- return esrt_size;
- Return:
- NULL otherwise.
u32 num_entries)
- efi_status_t ret;
size,
return NULL;
- return new_esrt;
- image entries.
- Return:
- efi_status_t ret;
- if (!bt) {
- if (!esrt) {
esrt = old_esrt;
- esrt = new_esrt;
- @img_fw_class.
- Return:
- NULL if:
- u32 max_entries;
- if (!esrt) {
return NULL;
img_fw_class, idx);
return &entry[idx];
efi_status_t ret;
return NULL;
- Return:
- u32 desc_version;
- u8 desc_count;
- size_t desc_size;
- if (!bt) {
- u32 flags = 0;
return ret;
goto out;
if (entry) {
flags);
} else {
continue;
+out:
void *context)
- efi_status_t ret;
- if (!bt) {
return;
NULL,
&handle_buff_size,
&handle
Best regards
Heinrich
return;
(void **)&fmp));
return;
return;
- efi_status_t ret;
- if (!bt) {
- if (!esrt) {
return ret;
ev, ®istration));
return ret;
- return ret;
@Sughosh
I was wrong here. efi_init_obj_list is always called first.
Cf. https://lists.denx.de/pipermail/u-boot/2021-February/441313.html
Best regards
Heinrich
goto out;
- uint32_t fw_type;
+} __packed;
+} __packed;
- Return:
+config EFI_ESRT
Strictly speaking, this can be doubtful: According to "23.4.2 ESRT and Firmware Management Protocol," Although the ESRT does not require firmware to use Firmware Management Protocol for updates it is designed to work with and extend the capabilities of FMP.
But as a matter of fact, the current implementation by Jose surely has some dependency.
-Takahiro Akashi
- default y
- help
- } else {
* greater.
- } else {
- return esrt_size;
- Return:
- NULL otherwise.
u32 num_entries)
- efi_status_t ret;
size,
return NULL;
- return new_esrt;
- image entries.
- Return:
- efi_status_t ret;
- if (!bt) {
- if (!esrt) {
esrt = old_esrt;
- esrt = new_esrt;
- @img_fw_class.
- Return:
- NULL if:
- u32 max_entries;
- if (!esrt) {
return NULL;
img_fw_class, idx);
return &entry[idx];
efi_status_t ret;
return NULL;
- Return:
- u32 desc_version;
- u8 desc_count;
- size_t desc_size;
- if (!bt) {
- u32 flags = 0;
return ret;
goto out;
if (entry) {
flags);
} else {
continue;
+out:
void *context)
- efi_status_t ret;
- if (!bt) {
return;
NULL,
&handle_buff_size,
&handle
Best regards
Heinrich
return;
(void **)&fmp));
return;
return;
- efi_status_t ret;
- if (!bt) {
- if (!esrt) {
return ret;
ev, ®istration));
return ret;
- return ret;
@Sughosh
Best regards
Heinrich
goto out;
This commit exercises the ESRT creation -- introduced in the previous commit.
A fake FMP, controlling TEST_ESRT_NUM_ENTRIES, is installed in the system leading to the corresponding ESRT entries being populated. The ESRT entries are checked against the FMP initialization input datastructure.
--- test/lib/Makefile | 1 + test/lib/efi_esrt.c | 188 ++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 189 insertions(+) create mode 100644 test/lib/efi_esrt.c
diff --git a/test/lib/Makefile b/test/lib/Makefile index 97c11e35a8..687e791db0 100644 --- a/test/lib/Makefile +++ b/test/lib/Makefile @@ -15,3 +15,4 @@ obj-$(CONFIG_UT_LIB_ASN1) += asn1.o obj-$(CONFIG_UT_LIB_RSA) += rsa.o obj-$(CONFIG_AES) += test_aes.o obj-$(CONFIG_GETOPT) += getopt.o +obj-y += efi_esrt.o diff --git a/test/lib/efi_esrt.c b/test/lib/efi_esrt.c new file mode 100644 index 0000000000..3c9d1de731 --- /dev/null +++ b/test/lib/efi_esrt.c @@ -0,0 +1,188 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Test ESRT tables support + * + * Copyright (C) 2021 Arm Ltd. + */ +#include <common.h> +#include <efi_loader.h> +#include <net.h> +#include <test/lib.h> +#include <test/test.h> +#include <test/ut.h> + +#define TEST_ESRT_NUM_ENTRIES 255 + +#if 0x100 < TEST_ESRT_NUM_ENTRIES +#error TEST_ESRT_NUM_ENTRIES must be lower or equal to 255. +#endif + +static +struct efi_firmware_image_descriptor static_img_info[TEST_ESRT_NUM_ENTRIES]; +static const efi_guid_t esrt_guid = EFI_SYSTEM_RESOURCE_TABLE_GUID; + +static void efi_test_esrt_init_info(void) +{ + for (int idx = 0; idx < TEST_ESRT_NUM_ENTRIES; idx++) { + static_img_info[idx].image_index = 1; + + // Note: the 16 byte value present in + // static_img_info[idx].image_type_id is not strictly a GUID. + // The value is used for the sake of code testing. + static_img_info[idx].image_type_id.b[0] = idx; + + static_img_info[idx].image_id = 0; + static_img_info[idx].image_id_name = NULL; + static_img_info[idx].version = 0; + static_img_info[idx].version_name = NULL; + static_img_info[idx].size = 0; + static_img_info[idx].lowest_supported_image_version = 1; + static_img_info[idx].last_attempt_version = 2; + static_img_info[idx].last_attempt_status = 3; + static_img_info[idx].hardware_instance = 1; + } +} + +static efi_status_t +EFIAPI efi_test_fmp_get_image_info(struct efi_firmware_management_protocol *this, + efi_uintn_t *image_info_size, + struct efi_firmware_image_descriptor *image_info, + u32 *descriptor_version, + u8 *descriptor_count, + efi_uintn_t *descriptor_size, + u32 *package_version, + u16 **package_version_name) +{ + efi_status_t ret = EFI_SUCCESS; + + EFI_ENTRY("%p %p %p %p %p %p %p %p\n", this, + image_info_size, image_info, + descriptor_version, descriptor_count, descriptor_size, + package_version, package_version_name); + + if (!image_info_size) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + if (descriptor_version) + *descriptor_version = EFI_FIRMWARE_IMAGE_DESCRIPTOR_VERSION; + if (descriptor_count) + *descriptor_count = TEST_ESRT_NUM_ENTRIES; + if (descriptor_size) + *descriptor_size = sizeof(*image_info); + if (package_version) + *package_version = 0xffffffff; + if (package_version_name) + *package_version_name = NULL; + + if (*image_info_size < sizeof(*image_info)) { + *image_info_size = *descriptor_size * *descriptor_count; + return EFI_EXIT(EFI_BUFFER_TOO_SMALL); + } + + for (int idx = 0; idx < TEST_ESRT_NUM_ENTRIES; idx++) + image_info[idx] = static_img_info[idx]; + + return EFI_EXIT(ret); +} + +struct efi_firmware_management_protocol efi_test_fmp = { + .get_image_info = efi_test_fmp_get_image_info, + .get_image = NULL, + .set_image = NULL, + .check_image = NULL, + .get_package_info = NULL, + .set_package_info = NULL, +}; + +static void *lib_test_get_esrt(void) +{ + for (int idx = 0; idx < systab.nr_tables; idx++) + if (!guidcmp(&esrt_guid, &systab.tables[idx].guid)) + return systab.tables[idx].table; + + return NULL; +} + +static bool lib_test_check_uuid_entry(struct efi_system_resource_table *esrt, + struct efi_firmware_image_descriptor + *img_info) +{ + const u32 filled_entries = esrt->fw_resource_count; + struct efi_system_resource_entry *entry = esrt->entries; + + for (u32 idx = 0; idx < filled_entries; idx++) { + if (!guidcmp(&entry[idx].fw_class, &img_info->image_type_id)) { + if (entry[idx].fw_version != img_info->version) + return false; + + if (entry[idx].lowest_supported_fw_version != + img_info->lowest_supported_image_version) + return false; + + if (entry[idx].last_attempt_version != + img_info->last_attempt_version) + return false; + + if (entry[idx].last_attempt_status != + img_info->last_attempt_status) + return false; + + /* + * The entry with fw_class = img_uuid matches with the + * remainder fmp input. + */ + return true; + } + } + + /* There exists no entry with fw_class equal to img_uuid in the ESRT. */ + return false; +} + +int lib_test_efi_esrt(struct unit_test_state *uts) +{ + struct efi_system_resource_table *esrt; + efi_status_t ret = EFI_SUCCESS; + struct efi_boot_services *bt; + + efi_test_esrt_init_info(); + + ret = efi_init_obj_list(); + + bt = systab.boottime; + ut_asserteq(ret, EFI_SUCCESS); + + assert(bt); + + ret = EFI_CALL(bt->install_multiple_protocol_interfaces + (&efi_root, + &efi_guid_firmware_management_protocol, + &efi_test_fmp, + NULL)); + + ut_asserteq(ret, EFI_SUCCESS); + + esrt = lib_test_get_esrt(); + ut_assert(esrt); + + ut_asserteq(esrt->fw_resource_count, TEST_ESRT_NUM_ENTRIES); + + /* Add the same FMP. */ + efi_esrt_add_from_fmp(&efi_test_fmp); + + /* Verify that the number of images remains the same. */ + ut_asserteq(esrt->fw_resource_count, TEST_ESRT_NUM_ENTRIES); + + for (u32 idx = 0; idx < TEST_ESRT_NUM_ENTRIES; idx++) + ut_assert(lib_test_check_uuid_entry(esrt, &static_img_info[idx])); + + ret = EFI_CALL(bt->uninstall_multiple_protocol_interfaces + (efi_root, &efi_guid_firmware_management_protocol, + &efi_test_fmp, NULL)); + + ut_asserteq(ret, EFI_SUCCESS); + + return ret; +} + +LIB_TEST(lib_test_efi_esrt, 0);
I hope that you will also provide a pytest to make sure that an entry in ESRT is correctly updated after capsule update.
There are already some tests for capsule update.
-Takahiro Akashi
- Test ESRT tables support
- for (int idx = 0; idx < TEST_ESRT_NUM_ENTRIES; idx++) {
- EFI_ENTRY("%p %p %p %p %p %p %p %p\n", this,
- if (!image_info_size)
- if (descriptor_version)
- if (descriptor_count)
- if (descriptor_size)
- if (package_version)
- if (package_version_name)
- if (*image_info_size < sizeof(*image_info)) {
- return EFI_EXIT(ret);
- .get_image_info = efi_test_fmp_get_image_info,
- .get_image = NULL,
- .set_image = NULL,
- .check_image = NULL,
- .get_package_info = NULL,
- .set_package_info = NULL,
- for (int idx = 0; idx < systab.nr_tables; idx++)
- return NULL;
*img_info)
- const u32 filled_entries = esrt->fw_resource_count;
- struct efi_system_resource_entry *entry = esrt->entries;
return false;
return false;
return false;
return false;
return true;
- /* There exists no entry with fw_class equal to img_uuid in the ESRT. */
- return false;
- struct efi_system_resource_table *esrt;
- struct efi_boot_services *bt;
- efi_test_esrt_init_info();
- ret = efi_init_obj_list();
- bt = systab.boottime;
- ut_asserteq(ret, EFI_SUCCESS);
- assert(bt);
- ret = EFI_CALL(bt->install_multiple_protocol_interfaces
(&efi_root,
&efi_test_fmp,
NULL));
- esrt = lib_test_get_esrt();
- ut_assert(esrt);
- ut_asserteq(esrt->fw_resource_count, TEST_ESRT_NUM_ENTRIES);
- /* Add the same FMP. */
- efi_esrt_add_from_fmp(&efi_test_fmp);
- /* Verify that the number of images remains the same. */
- for (u32 idx = 0; idx < TEST_ESRT_NUM_ENTRIES; idx++)
- ret = EFI_CALL(bt->uninstall_multiple_protocol_interfaces
- return ret;
2.17.1
AKASHI Takahiro
Jose Marinho
