[U-Boot] [PATCH v2] arc: use more universal prefix for default CROSS_COMPILE
As doc/README.ARC says, pre-build ARC toolchains are available at the Synopsys GitHub page.
The bin files are prefixed with arc(eb)-buildroot-linux- for earlier releases, but with arc(eb)-snps-linux- for the latest releases.
The symbolic links prefixed with arc(eb)-linux- are also available for all the release, so those prefixes can be used as the default CROSS_COMPILE regardless of the toolchains version/variants.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
Changes in v2: - Use "arc(eb)-linux-" rather than "arc(eb)-linux-uclibc-"
arch/arc/config.mk | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arc/config.mk b/arch/arc/config.mk index 04c034b..74943d9 100644 --- a/arch/arc/config.mk +++ b/arch/arc/config.mk @@ -11,13 +11,13 @@ CONFIG_SYS_BIG_ENDIAN = 1 endif
ifdef CONFIG_SYS_LITTLE_ENDIAN -ARC_CROSS_COMPILE := arc-buildroot-linux-uclibc- +ARC_CROSS_COMPILE := arc-linux- PLATFORM_LDFLAGS += -EL PLATFORM_CPPFLAGS += -mlittle-endian endif
ifdef CONFIG_SYS_BIG_ENDIAN -ARC_CROSS_COMPILE := arceb-buildroot-linux-uclibc- +ARC_CROSS_COMPILE := arceb-linux- PLATFORM_LDFLAGS += -EB PLATFORM_CPPFLAGS += -mbig-endian endif
Hello Masahiro-san,
Changes in v2:
Applied!
Thanks, Alexey
Alexey Brodkin
Masahiro Yamada
