[PATCH 0/9] CI: Set up for an arm64 runner
All gitlab runners are currently amd64 machines. This series attempts to create a docker image which can also support arm64 so that sandbox tests can be run on it.
Simon Glass (9): sandbox: efi_loader: Correct use of addresses as pointers test: Adjust print_ut test to use unsigned char docker: Support building for multiple architectures docker: Adjust packages for arm64 docker: Drop grub for arm64 docker: Drop tracing for arm64 docker: Drop coreboot for arm64 docker: Fix LegacyKeyValueFormat warning with PYTHONPATH CI: Add platform variable
.gitlab-ci.yml | 1 + arch/sandbox/cpu/cache.c | 8 +++++- drivers/remoteproc/rproc-elf-loader.c | 18 +++++++----- lib/efi_loader/efi_image_loader.c | 3 +- test/print_ut.c | 6 ++-- tools/docker/Dockerfile | 40 +++++++++++++++++++-------- 6 files changed, 52 insertions(+), 24 deletions(-)
The cache-flush function is incorrect which causes a crash in the remoteproc tests with arm64.
Fix both problems by using map_sysmem() to convert an address to a pointer and map_to_sysmem() to convert a pointer to an address.
Also update the image-loader's cache-flushing logic.
As discussed some time ago, it would be good to update the way EFI_LOADER uses addresses and pointers, particularly around memory allocation. Ideally we would use addresses internally, with pointers only exposed via the external API, even where pointers are in fact u64 values.
Signed-off-by: Simon Glass sjg@chromium.org Fixes: 3286d223fd7 ("sandbox: implement invalidate_icache_all()") ---
arch/sandbox/cpu/cache.c | 8 +++++++- drivers/remoteproc/rproc-elf-loader.c | 18 +++++++++++------- lib/efi_loader/efi_image_loader.c | 3 ++- 3 files changed, 20 insertions(+), 9 deletions(-)
diff --git a/arch/sandbox/cpu/cache.c b/arch/sandbox/cpu/cache.c index c8a5e64214b..96b3da47e8e 100644 --- a/arch/sandbox/cpu/cache.c +++ b/arch/sandbox/cpu/cache.c @@ -4,12 +4,18 @@ */
#include <cpu_func.h> +#include <mapmem.h> #include <asm/state.h>
void flush_cache(unsigned long addr, unsigned long size) { + void *ptr; + + ptr = map_sysmem(addr, size); + /* Clang uses (char *) parameters, GCC (void *) */ - __builtin___clear_cache((void *)addr, (void *)(addr + size)); + __builtin___clear_cache(map_sysmem(addr, size), ptr + size); + unmap_sysmem(ptr); }
void invalidate_icache_all(void) diff --git a/drivers/remoteproc/rproc-elf-loader.c b/drivers/remoteproc/rproc-elf-loader.c index ab1836b3f07..0b3941b7798 100644 --- a/drivers/remoteproc/rproc-elf-loader.c +++ b/drivers/remoteproc/rproc-elf-loader.c @@ -6,6 +6,7 @@ #include <dm.h> #include <elf.h> #include <log.h> +#include <mapmem.h> #include <remoteproc.h> #include <asm/cache.h> #include <dm/device_compat.h> @@ -180,6 +181,7 @@ int rproc_elf32_load_image(struct udevice *dev, unsigned long addr, ulong size) for (i = 0; i < ehdr->e_phnum; i++, phdr++) { void *dst = (void *)(uintptr_t)phdr->p_paddr; void *src = (void *)addr + phdr->p_offset; + ulong dst_addr;
if (phdr->p_type != PT_LOAD) continue; @@ -195,10 +197,11 @@ int rproc_elf32_load_image(struct udevice *dev, unsigned long addr, ulong size) if (phdr->p_filesz != phdr->p_memsz) memset(dst + phdr->p_filesz, 0x00, phdr->p_memsz - phdr->p_filesz); - flush_cache(rounddown((unsigned long)dst, ARCH_DMA_MINALIGN), - roundup((unsigned long)dst + phdr->p_filesz, + dst_addr = map_to_sysmem(dst); + flush_cache(rounddown(dst_addr, ARCH_DMA_MINALIGN), + roundup(dst_addr + phdr->p_filesz, ARCH_DMA_MINALIGN) - - rounddown((unsigned long)dst, ARCH_DMA_MINALIGN)); + rounddown(dst_addr, ARCH_DMA_MINALIGN)); }
return 0; @@ -377,6 +380,7 @@ int rproc_elf32_load_rsc_table(struct udevice *dev, ulong fw_addr, const struct dm_rproc_ops *ops; Elf32_Shdr *shdr; void *src, *dst; + ulong dst_addr;
shdr = rproc_elf32_find_rsc_table(dev, fw_addr, fw_size); if (!shdr) @@ -398,10 +402,10 @@ int rproc_elf32_load_rsc_table(struct udevice *dev, ulong fw_addr, (ulong)dst, *rsc_size);
memcpy(dst, src, *rsc_size); - flush_cache(rounddown((unsigned long)dst, ARCH_DMA_MINALIGN), - roundup((unsigned long)dst + *rsc_size, - ARCH_DMA_MINALIGN) - - rounddown((unsigned long)dst, ARCH_DMA_MINALIGN)); + dst_addr = map_to_sysmem(dst); + flush_cache(rounddown(dst_addr, ARCH_DMA_MINALIGN), + roundup(dst_addr + *rsc_size, ARCH_DMA_MINALIGN) - + rounddown(dst_addr, ARCH_DMA_MINALIGN));
return 0; } diff --git a/lib/efi_loader/efi_image_loader.c b/lib/efi_loader/efi_image_loader.c index 0ddf69a0918..bb58cf1badb 100644 --- a/lib/efi_loader/efi_image_loader.c +++ b/lib/efi_loader/efi_image_loader.c @@ -13,6 +13,7 @@ #include <efi_loader.h> #include <log.h> #include <malloc.h> +#include <mapmem.h> #include <pe.h> #include <sort.h> #include <crypto/mscode.h> @@ -977,7 +978,7 @@ efi_status_t efi_load_pe(struct efi_loaded_image_obj *handle, }
/* Flush cache */ - flush_cache((ulong)efi_reloc, + flush_cache(map_to_sysmem(efi_reloc), ALIGN(virt_size, EFI_CACHELINE_SIZE));
Am 4. November 2024 14:39:45 MEZ schrieb Simon Glass sjg@chromium.org:
No, we should get rid of sandbox virtual addresses where possible, e.g. in LMB.
They are are only relevant for the sandbox's command line interface and device-tree.
This will minimize the number of conversions, which only satisfy the needs of the sandbox and have no relevance on real systems including QEMU.
Do not wag the dog with the tail.
Best regards
Heinrich
- void *ptr;
- ptr = map_sysmem(addr, size);
- /* Clang uses (char *) parameters, GCC (void *) */
- __builtin___clear_cache(map_sysmem(addr, size), ptr + size);
- unmap_sysmem(ptr);
ulong dst_addr;
ulong dst_addr;
/* Flush cache */
Hi Heinrich,
For now I'll just remove that comment from this commit. We use ulong in U-Boot for addresses. Everything works fine and we only get in trouble when we use a ulong as a pointer. Let's discuss this in more detail at some point.
Best regards
Heinrich
Since char is unsigned on arm64, this test currently fails. It seems better to use unsigned anyway, since 0xff is written into the string at the start.
test/print_ut.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/test/print_ut.c b/test/print_ut.c index f5e607b21a3..7e5c015f3a7 100644 --- a/test/print_ut.c +++ b/test/print_ut.c @@ -242,7 +242,7 @@ PRINT_TEST(print_display_buffer, UTF_CONSOLE);
static int print_hexdump_line(struct unit_test_state *uts) { - char *linebuf; + u8 *linebuf; u8 *buf; int i;
@@ -255,10 +255,10 @@ static int print_hexdump_line(struct unit_test_state *uts) linebuf = map_sysmem(0x400, BUF_SIZE); memset(linebuf, '\xff', BUF_SIZE); ut_asserteq(-ENOSPC, hexdump_line(0, buf, 1, 0x10, 0, linebuf, 75)); - ut_asserteq(-1, linebuf[0]); + ut_asserteq(0xff, linebuf[0]); ut_asserteq(0x10, hexdump_line(0, buf, 1, 0x10, 0, linebuf, 76)); ut_asserteq(0, linebuf[75]); - ut_asserteq(-1, linebuf[76]); + ut_asserteq(0xff, linebuf[76]);
unmap_sysmem(buf);
Am 4. November 2024 14:39:46 MEZ schrieb Simon Glass sjg@chromium.org:
- char *linebuf;
- u8 *linebuf; u8 *buf; int i;
- ut_asserteq(0xff, linebuf[0]); ut_asserteq(0x10, hexdump_line(0, buf, 1, 0x10, 0, linebuf, 76)); ut_asserteq(0, linebuf[75]);
Should we add a ut_asserteq_str() here to check all characters?
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
unmap_sysmem(buf);
Hi Heinrich,
char *linebuf;
I believe it is...that's why it checks the \0 at the end of the string. Or are you asking about the bytes after the string?
ut_asserteq(0xff, linebuf[76]); unmap_sysmem(buf);
Add instructions on how to build the file for multiple architectures. Add a message indicating what is happening.
tools/docker/Dockerfile | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/tools/docker/Dockerfile b/tools/docker/Dockerfile index 967ac89fbde..c9d794082c8 100644 --- a/tools/docker/Dockerfile +++ b/tools/docker/Dockerfile @@ -2,6 +2,9 @@ # This Dockerfile is used to build an image containing basic stuff to be used # to build U-Boot and run our test suites.
+# Build with (for example): +# docker buildx build --platform linux/arm64/v8,linux/amd64 --tag sjg20/u-boot-gitlab-ci-runner-multiarch:jammy-20240808-03Nov2024 . + FROM ubuntu:jammy-20240808 LABEL org.opencontainers.image.authors="Tom Rini trini@konsulko.com" LABEL org.opencontainers.image.description=" This image is for building U-Boot inside a container" @@ -9,6 +12,10 @@ LABEL org.opencontainers.image.description=" This image is for building U-Boot i # Make sure apt is happy ENV DEBIAN_FRONTEND=noninteractive
+ARG TARGETPLATFORM +ARG BUILDPLATFORM +RUN echo "Building $BUILDPLATFORM, for target $TARGETPLATFORM" + # Add LLVM repository RUN apt-get update && apt-get install -y gnupg2 wget xz-utils && rm -rf /var/lib/apt/lists/* RUN wget -O - https://apt.llvm.org/llvm-snapshot.gpg.key | apt-key add -
Please update doc/build/docker.rst as well with this change, thanks.
Am 4. November 2024 14:39:47 MEZ schrieb Simon Glass sjg@chromium.org:
Please, add comments describing what these variables are used for.
Best regards
Heinrich
The package names are slightly different for arm64 and we don't seem to have a linux-image-kvm package. Provide a different set for arm64
tools/docker/Dockerfile | 12 +++++++----- 1 file changed, 7 insertions(+), 5 deletions(-)
diff --git a/tools/docker/Dockerfile b/tools/docker/Dockerfile index c9d794082c8..c4c3dc5a901 100644 --- a/tools/docker/Dockerfile +++ b/tools/docker/Dockerfile @@ -39,7 +39,12 @@ RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_ RUN wget -O - https://github.com/foss-xtensa/toolchain/releases/download/2020.07/x86_64-20... | tar -C /opt -xz
# Update and install things from apt now -RUN apt-get update && apt-get install -y \ +RUN if [ "$TARGETPLATFORM" = "linux/arm64" ]; then \ + EXTRA_PACKAGES="grub-efi-arm64-bin linux-image-generic"; \ + else \ + EXTRA_PACKAGES="grub-efi-amd64-bin grub-efi-ia32-bin libc6-i386 linux-image-kvm"; \ + fi; \ + apt-get update && apt-get install -y \ automake \ autopoint \ bc \ @@ -65,13 +70,10 @@ RUN apt-get update && apt-get install -y \ gnu-efi \ gnutls-dev \ graphviz \ - grub-efi-amd64-bin \ - grub-efi-ia32-bin \ help2man \ iasl \ imagemagick \ iputils-ping \ - libc6-i386 \ libconfuse-dev \ libgit2-dev \ libjson-glib-dev \ @@ -89,7 +91,6 @@ RUN apt-get update && apt-get install -y \ libtool \ libudev-dev \ libusb-1.0-0-dev \ - linux-image-kvm \ lzma-alone \ lzop \ mount \ @@ -126,6 +127,7 @@ RUN apt-get update && apt-get install -y \ xilinx-bootgen \ xxd \ zip \ + ${EXTRA_PACKAGES} \ && rm -rf /var/lib/apt/lists/*
# Make kernels readable for libguestfs tools to work correctly
- else \
- fi; \
Lets try using grub-efi (dummy package that should grab the correct architecture one) and see if linux-image-generic provides the vmlinux file we annoyingly need for both architectures. I _think_ we can stop explicitly listing libc6-i386, but may need to list grub-efi-ia32-bin too as grub-efi will only grab the amd64 one.
Am 4. November 2024 14:39:48 MEZ schrieb Simon Glass sjg@chromium.org:
Please, use 'arm64' and not 'linux/arm64' as variable value.
Replace, arm64 by the variable, which may take the value 'riscv64'.
- else \
This 'else' does not work for riscv64.
The exception is amd64 and not arm64. Only amd64 has two GRUB versions.
Best regards
Heinrich
- fi; \
- apt-get update && apt-get install -y \ automake \ autopoint \ bc \
- ${EXTRA_PACKAGES} \ && rm -rf /var/lib/apt/lists/*
Getting back to your previous comment about documenting these variables, I took it that these are NOT free-form but rather what Docker (et al) require for proper multi-architecture containering.
Hi Tom, Heinrich,
Yes, that's my understanding (limited though it is so far)
This doesn't build on arm64 at present, so drop it for now. We only expect to run sandbox tests, so perhaps it isn't needed.
tools/docker/Dockerfile | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/tools/docker/Dockerfile b/tools/docker/Dockerfile index c4c3dc5a901..60106a82801 100644 --- a/tools/docker/Dockerfile +++ b/tools/docker/Dockerfile @@ -134,7 +134,9 @@ RUN if [ "$TARGETPLATFORM" = "linux/arm64" ]; then \ RUN chmod +r /boot/vmlinu*
# Build GRUB UEFI targets for ARM & RISC-V, 32-bit and 64-bit -RUN git clone git://git.savannah.gnu.org/grub.git /tmp/grub && \ +# This fails on arm64 +RUN if [ "$TARGETPLATFORM" = "linux/amd64" ]; then \ + git clone git://git.savannah.gnu.org/grub.git /tmp/grub && \ cd /tmp/grub && \ git checkout grub-2.06 && \ git config --global user.name "GitLab CI Runner" && \ @@ -184,7 +186,8 @@ RUN git clone git://git.savannah.gnu.org/grub.git /tmp/grub && \ lsefisystab loadenv lvm minicmd normal part_msdos part_gpt reboot \ search search_fs_file search_fs_uuid search_label serial sleep test \ true && \ - rm -rf /tmp/grub + rm -rf /tmp/grub; \ + fi
RUN git clone https://gitlab.com/qemu-project/qemu.git /tmp/qemu && \ cd /tmp/qemu && \
What is the build failure? Depending on what other prospects for arm64 build hardware come through I'm hoping to look harder at more build options, not just sandbox (but of course, QEMU shouldn't matter what the host is).
Hi Tom,
field-initializers -Wnonnull -Woverflow -Wvla -Wpointer-to-int-cast -Wstrict-aliasing -Wvariadic-macros -Wvolatile-register-var -Wpointer-sign -Wmissing-include-dirs -Wmissing-prototypes -Wmissing-declarations -Wformat=2 686.0 checking for aarch64-gcc... /opt/gcc-13.2.0-nolibc/aarch64-linux/bin/aarch64-linux-gcc 686.0 checking for aarch64-objcopy... /opt/gcc-13.2.0-nolibc/aarch64-linux/bin/aarch64-linux-objcopy 686.0 checking for aarch64-strip... /opt/gcc-13.2.0-nolibc/aarch64-linux/bin/aarch64-linux-strip 686.0 checking for aarch64-nm... /opt/gcc-13.2.0-nolibc/aarch64-linux/bin/aarch64-linux-nm 686.0 checking for aarch64-ranlib... /opt/gcc-13.2.0-nolibc/aarch64-linux/bin/aarch64-linux-ranlib 686.0 ./configure: line 32517: /opt/gcc-13.2.0-nolibc/aarch64-linux/bin/aarch64-linux-gcc: No such file or directory 686.1 checking which extra warnings work... 689.6 checking if compiling with clang... yes 689.8 checking for options to compile assembly... 689.8 checking whether -freg-struct-return works... no 690.0 checking for options to get soft-float... no 690.8 configure: error: could not force soft-float
I suspect it is just that the toolchains need fiddling. I'd much rather get something running and iterate on it after that.
On Tue, Nov 05, 2024 at 08:15:05AM -0700, Simon Glass wrote:
Hi Tom,
That's the toolchain that should be used to build sandbox, so you should figure out what's going on. And I think you missed fiddling with ~/.buildman so that it sets the sandbox toolchain to the right one and not x86_64.
Hi Tom,
Hi Tom,
sandbox should be built with the host toolchain, right? The one it is complaining about is the amd64-host aarch64 toolchain, which we don't want or need yet.
The grub part (and the cross toolchains) needs more work, but we don't need it for sandbox, or at least the sandbox tests seem to pass without it. Are you wanting to run qemu on arm64 to boot grub?
I believe I've taken a reasonable stab at a good starting point for this work. Do you agree?
Am 4. November 2024 14:39:49 MEZ schrieb Simon Glass sjg@chromium.org:
- git clone git://git.savannah.gnu.org/grub.git /tmp/grub && \ cd /tmp/grub && \ git checkout grub-2.06 && \
Upstream GRUB builds for arm64 and riscv64.
Please, retry with grub-2.12.
Best regards
Heinrich
- rm -rf /tmp/grub
- rm -rf /tmp/grub; \
- fi
Well, lets do that upgrade separately.
This doesn't build on arm64 at present, so drop it for now. This can be revisited if we wish to support arm64 for the sandbox trace-test.
tools/docker/Dockerfile | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/tools/docker/Dockerfile b/tools/docker/Dockerfile index 60106a82801..73fdd1a4302 100644 --- a/tools/docker/Dockerfile +++ b/tools/docker/Dockerfile @@ -240,7 +240,8 @@ RUN git clone https://github.com/stefanberger/swtpm /tmp/swtpm && \ rm -rf /tmp/swtpm
# Build trace-cmd -RUN mkdir /tmp/trace && \ +RUN if [ "$TARGETPLATFORM" = "linux/amd64" ]; then \ + mkdir /tmp/trace && \ git clone https://git.kernel.org/pub/scm/libs/libtrace/libtraceevent.git /tmp/trace/libtraceevent && \ cd /tmp/trace/libtraceevent && \ make -j$(nproc) && \ @@ -253,7 +254,8 @@ RUN mkdir /tmp/trace && \ cd /tmp/trace/trace-cmd && \ make -j$(nproc) && \ sudo make install && \ - rm -rf /tmp/trace + rm -rf /tmp/trace; \ + fi
# Build coreboot RUN wget -O - https://coreboot.org/releases/coreboot-24.08.tar.xz | tar -C /tmp -xJ && \
What's the build error? We may well want to support this, yes.
I had no problems building the trace libraries on Ubuntu 24.04 arm64. So the problem you experienced should be easily fixable.
Best regards
Heinrich
- mkdir /tmp/trace && \ git clone https://git.kernel.org/pub/scm/libs/libtrace/libtraceevent.git /tmp/trace/libtraceevent && \ cd /tmp/trace/libtraceevent && \ make -j$(nproc) && \
- rm -rf /tmp/trace
fi
49.20 /usr/bin/ld: /usr/local/lib64/libtracefs.so: undefined reference to `trace_seq_vprintf'
I agree we probably want to support this, but I think we can sort it out later.
This isn't needed for sandbox builds and coreboot isn't much used on arm64, nor does U-Boot have a build that supports running from coreboot on any ARM target.
So drop it.
diff --git a/tools/docker/Dockerfile b/tools/docker/Dockerfile index 73fdd1a4302..ae3d4685869 100644 --- a/tools/docker/Dockerfile +++ b/tools/docker/Dockerfile @@ -258,7 +258,8 @@ RUN if [ "$TARGETPLATFORM" = "linux/amd64" ]; then \ fi
# Build coreboot -RUN wget -O - https://coreboot.org/releases/coreboot-24.08.tar.xz | tar -C /tmp -xJ && \ +RUN if [ "$TARGETPLATFORM" = "linux/amd64" ]; then \ + wget -O - https://coreboot.org/releases/coreboot-24.08.tar.xz | tar -C /tmp -xJ && \ cd /tmp/coreboot-24.08 && \ make crossgcc-i386 CPUS=$(nproc) && \ make -C payloads/coreinfo olddefconfig && \ @@ -269,7 +270,8 @@ RUN wget -O - https://coreboot.org/releases/coreboot-24.08.tar.xz | tar -C /tmp make olddefconfig && \ make -j $(nproc) && \ sudo mkdir /opt/coreboot && \ - sudo cp build/coreboot.rom build/cbfstool /opt/coreboot/ + sudo cp build/coreboot.rom build/cbfstool /opt/coreboot/; \ + fi
# Create our user/group RUN echo uboot ALL=NOPASSWD: ALL > /etc/sudoers.d/uboot
So drop it.
Fix a warning due to the syntax used for PYTHONPATH:
LegacyKeyValueFormat: "ENV key=value" should be used instead of legacy "ENV key value" format (line 304)
tools/docker/Dockerfile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/docker/Dockerfile b/tools/docker/Dockerfile index ae3d4685869..c42e0890897 100644 --- a/tools/docker/Dockerfile +++ b/tools/docker/Dockerfile @@ -301,4 +301,4 @@ RUN /bin/echo -e "\nx86 = i386" >> ~/.buildman;
# Add mkbootimg tool RUN git clone https://android.googlesource.com/platform/system/tools/mkbootimg /home/uboot/mkbootimg -ENV PYTHONPATH "${PYTHONPATH}:/home/uboot/mkbootimg" +ENV PYTHONPATH="${PYTHONPATH}:/home/uboot/mkbootimg"
Add a list of possible platforms that can be used by gitlab runners.
.gitlab-ci.yml | 1 + 1 file changed, 1 insertion(+)
diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index 0aeda53bc2d..e152060b046 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -3,6 +3,7 @@ variables: DEFAULT_TAG: "" MIRROR_DOCKER: docker.io + PLATFORM: linux/amd64,linux/arm64
default: tags:
Thanks for this
On Mon, 4 Nov 2024 at 13:55, Tom Rini trini@konsulko.com wrote:
Thanks for starting on this.
Tom I'll probably have an arm64 runner available next week. Let me know how/when start testing this
Cheers /Ilias
-- Tom
Ilias Apalodimas
