[U-Boot] [PATCH v2] mtd: zynq: nand: Move board_nand_init() function to board.c
Putting board_nand_init() function inside NAND driver was not appropriate due to it doesn't allow board vendor to customise their NAND initialization code such as adding NAND lock/unlock code.
This commit was to move the board_nand_init() function from NAND driver to board.c file. This allow customization of board_nand_init() function.
Signed-off-by: Wilson Lee wilson.lee@ni.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Keng Soon Cheah keng.soon.cheah@ni.com Cc: Chen Yee Chew chen.yee.chew@ni.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com Cc: Scott Wood oss@buserror.net --- arch/arm/mach-zynq/include/mach/nand.h | 9 +++++++++ drivers/mtd/nand/zynq_nand.c | 6 ++++-- 2 files changed, 13 insertions(+), 2 deletions(-) create mode 100644 arch/arm/mach-zynq/include/mach/nand.h
diff --git a/arch/arm/mach-zynq/include/mach/nand.h b/arch/arm/mach-zynq/include/mach/nand.h new file mode 100644 index 0000000..61ef45f --- /dev/null +++ b/arch/arm/mach-zynq/include/mach/nand.h @@ -0,0 +1,9 @@ +/* + * Copyright (C) 2017 National Instruments Corp. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <nand.h> + +void zynq_nand_init(void); diff --git a/drivers/mtd/nand/zynq_nand.c b/drivers/mtd/nand/zynq_nand.c index dec2c41..076b878 100644 --- a/drivers/mtd/nand/zynq_nand.c +++ b/drivers/mtd/nand/zynq_nand.c @@ -1006,7 +1006,7 @@ static int zynq_nand_device_ready(struct mtd_info *mtd) return 0; }
-static int zynq_nand_init(struct nand_chip *nand_chip, int devnum) +int zynq_nand_init(struct nand_chip *nand_chip, int devnum) { struct zynq_nand_info *xnand; struct mtd_info *mtd; @@ -1192,12 +1192,14 @@ fail: return err; }
+#ifdef CONFIG_SYS_NAND_SELF_INIT static struct nand_chip nand_chip[CONFIG_SYS_MAX_NAND_DEVICE];
-void board_nand_init(void) +void __weak board_nand_init(void) { struct nand_chip *nand = &nand_chip[0];
if (zynq_nand_init(nand, 0)) puts("ZYNQ NAND init failed\n"); } +#endif
- Copyright (C) 2017 National Instruments Corp.
+#include <nand.h>
Applied. Michal
+#include <nand.h>
Just found this patch while debugging a NAND problem using current U-Boot upstream, on a custom board. In fact, I wrote a patch which is an exact revert of this one, until I noticed the board_nand_init is exported on purpose.
A few observations:
1) The driver selects CONFIG_SYS_NAND_SELF_INIT, which makes this ifdef a no-op. I'm guessing vendors are using the driver without the self-init mode. Is that the case?
2) This driver looks broken in upstream, refusing to initalize properly. The reason is that get_nand_dev_by_index() was being called before nand_register(), thus returning a pointer into uninitialized memory. In other words, the struct mtd_info used by the driver is total junk.
The fix is simple, I cooked a patch for it:
diff --git a/drivers/mtd/nand/zynq_nand.c b/drivers/mtd/nand/zynq_nand.c index 6494196049f1..9f6ff3d045c2 100644 --- a/drivers/mtd/nand/zynq_nand.c +++ b/drivers/mtd/nand/zynq_nand.c @@ -1025,7 +1025,7 @@ int zynq_nand_init(struct nand_chip *nand_chip, int devnum) }
xnand->nand_base = (void __iomem *)ZYNQ_NAND_BASEADDR; - mtd = get_nand_dev_by_index(0); + mtd = nand_to_mtd(nand_chip);
However, I am not sure about sending this patch upstream, because it assumes the driver is used on self-init mode only.
Any hints on how this should be fixed properly? Perhaps we should find a cleaner path into a lock/unlock hook in upstream.
2.7.4
Ezequiel Garcia
Michal Simek
Wilson Lee
