[PATCH] dt/bindings: fwu-mdata-mtd: drop changes outside FWU
Any requirement of FWU should not require changes to bindings of other subsystems. For example, for mtd-backed storage we can do without requiring 'fixed-partitions' children to also carry 'uuid', a property which is non-standard and not in the bindings.
There exists no code yet, so we can change the fwu-mtd bindings to contain all properties within the fwu-mdata node.
Signed-off-by: Jassi Brar jaswinder.singh@linaro.org ---
Hi Rob, Hi Krzysztof,
I was suggested, and I agree, it would be a good idea to get your blessings for the location and meta-data (fwu-mdata) bindings for the FWU.
The FWU images can be located in GPT partitions or MTD backed storage. The basic bindings for fwu-mdata has already been merged in uboot (ideally they too should have had your review). Now I am trying to fully support MTD backed storage and hence looking for your review. The proposed bindings are totally self-contained and don't require changes to any other subsystem.
Thanks.
.../firmware/fwu-mdata-mtd.yaml | 105 +++++++++++++++--- 1 file changed, 91 insertions(+), 14 deletions(-)
diff --git a/doc/device-tree-bindings/firmware/fwu-mdata-mtd.yaml b/doc/device-tree-bindings/firmware/fwu-mdata-mtd.yaml index 4f5404f999..6a22aeea30 100644 --- a/doc/device-tree-bindings/firmware/fwu-mdata-mtd.yaml +++ b/doc/device-tree-bindings/firmware/fwu-mdata-mtd.yaml @@ -1,13 +1,13 @@ # SPDX-License-Identifier: (GPL-2.0 OR BSD-2-Clause) %YAML 1.2 --- -$id: http://devicetree.org/schemas/firmware/u-boot,fwu-mdata-sf.yaml# -$schema: http://devicetree.org/meta-schemas/core.yaml# +$id: http://devicetree.org/schemas/firmware/u-boot,fwu-mdata-mtd.yaml# +$schema: http://devicetree.org/meta-schemas/base.yaml#
title: FWU metadata on MTD device without GPT
maintainers: - - Masami Hiramatsu masami.hiramatsu@linaro.org + - Jassi Brar jaswinder.singh@linaro.org
properties: compatible: @@ -15,24 +15,101 @@ properties: - const: u-boot,fwu-mdata-mtd
fwu-mdata-store: - maxItems: 1 - description: Phandle of the MTD device which contains the FWU medatata. + $ref: /schemas/types.yaml#/definitions/phandle + description: Phandle of the MTD device which contains the FWU MetaData and Banks.
- mdata-offsets: + mdata-parts: + $ref: /schemas/types.yaml#/definitions/non-unique-string-array minItems: 2 - description: Offsets of the primary and secondary FWU metadata in the NOR flash. + maxItems: 2 + description: labels of the primary and secondary FWU metadata partitions in the 'fixed-partitions' subnode of the 'jedec,spi-nor' flash device node. + + patternProperties: + "fwu-bank[0-9]": + type: object + description: List of FWU mtd-backed banks. Typically two banks. + + properties: + id: + $ref: /schemas/types.yaml#/definitions/uint32 + description: Index of the bank. + + label: + $ref: /schemas/types.yaml#/definitions/non-unique-string-array + minItems: 1 + maxItems: 1 + description: label of the partition, in the 'fixed-partitions' subnode of the 'jedec,spi-nor' flash device node, that holds this bank. + + patternProperties: + "fwu-image[0-9]": + type: object + description: List of images in the FWU mtd-backed bank. + + properties: + id: + $ref: /schemas/types.yaml#/definitions/uint32 + description: Index of the bank. + + offset: + $ref: /schemas/types.yaml#/definitions/uint32 + description: Offset, from start of the bank, where the image is located. + + size: + $ref: /schemas/types.yaml#/definitions/uint32 + description: Size reserved for the image. + + uuid: + $ref: /schemas/types.yaml#/definitions/non-unique-string-array + minItems: 1 + maxItems: 1 + description: UUID of the image. + + required: + - id + - offset + - size + - uuid + additionalProperties: false + + required: + - id + - label + - fwu-images + additionalProperties: false
required: - compatible - fwu-mdata-store - - mdata-offsets - + - mdata-parts + - fwu-banks additionalProperties: false
examples: - | - fwu-mdata { - compatible = "u-boot,fwu-mdata-mtd"; - fwu-mdata-store = <&spi-flash>; - mdata-offsets = <0x500000 0x530000>; - }; + fwu-mdata { + compatible = "u-boot,fwu-mdata-mtd"; + fwu-mdata-store = <&flash0>; + mdata-parts = "MDATA-Pri", "MDATA-Sec"; + + fwu-bank0 { + id = <0>; + label = "FIP-Bank0"; + fwu-image0 { + id = <0>; + offset = <0x0>; + size = <0x400000>; + uuid = "5a66a702-99fd-4fef-a392-c26e261a2828"; + }; + }; + fwu-bank1 { + id = <1>; + label = "FIP-Bank1"; + fwu-image0 { + id = <0>; + offset = <0x0>; + size = <0x400000>; + uuid = "a8f868a1-6e5c-4757-878d-ce63375ef2c0"; + }; + }; + }; +...
Thanks.
I think we do not review U-Boot bindings usually, except these put in the Linux kernel. There were few targeting U-Boot specifically (e.g. Documentation/devicetree/bindings/mtd/partitions/u-boot.yaml and Documentation/devicetree/bindings/nvmem/u-boot,env.yaml) so if you want our blessing, the bindings should be done in Linux kernel repo.
I am pretty sure that reviewing other project bindings would be too much of work for me.
Best regards, Krzysztof
Thanks.
At least for us our goal is to have be able to share the same dt binding document in U-Boot and Linux.
That's understandable. Pretty much it is more about to find a right location.
Simon added options node for u-boot directly to dt-schema https://github.com/devicetree-org/dt-schema/blob/main/dtschema/schemas/optio...
And if this is the same category it should maybe go directly to dt-schema instead. What about?
options { fwu-mdata { ... }; };
This thread is pretty much asking for suggesting where this can go to be able to pass yaml checking which is required by SR.
Thanks, Michal
Hi Krzysztof,
Thanks.
Sure that makes sense. But an answer here of whether the bindings make sense to the DT maintainers or not would help to move forward.
These bindings are trying to define a standardized interface for A/B *firmware* updates [0] which is not what traditionally goes into a device tree. OTOH we already have some U-Boot specific bindings as you already mentioned. As we move forward we need to be very precise on what is allowed or not on the DT since it's now tested and verified on SystemReady certifications. IOW if we add those binding in U-Boot only, we would need to strip them before handing the DT to linux, otherwise certification would fail. If you do think that having them in the kernel repo makes sense, it would help standardizing other boot loaders (at least it would standardize where that metadata lives) if they want to implement something similar.
Just keep in mind we would need a schema per storage medium. IOW this tries to standardize devices which keep the firmware binary in an mtd. There's also another biding which describes firmware files on a GPT [1].
[0] https://developer.arm.com/documentation/den0118/a [1] https://source.denx.de/u-boot/u-boot/-/blob/master/doc/device-tree-bindings/...
Thanks /Ilias
On 03/05/2023 16:37, Ilias Apalodimas wrote:
Hi Krzysztof,
Thanks.
I am not a DT maintainer of other systems, components etc. Answering anything for these other systems and components means nothing. I will take no responsibility of whatever I say because I will bear no costs of it. :) IOW, to me you can make any invalid binding inside U-Boot and it will not matter for the Linux kernel. It will of course matter to U-Boot in many aspects.
Which you can.
Or propose to add the bindings to the Linux kernel and to the Linux kernel DTS, which then will get our review.
I cannot speak for Rob, but that's the only way I can make a review. I cannot review or try to maintain all possible projects in the world and their bindings. How would this even work in practice?
Hi Krzysztof,
Thanks.
Which you can.
This is one of the bindings that we need to upstream to https://github.com/devicetree-org/dt-schema/ and so in this case there's less likely to be interest from purely Linux kernel centric reviewers. Once it's there, the dts nodes and so forth can be in the trees that end up in the kernel, since they will pass validation. In so far as I understand what the plan for everything is, at least.
Which you can.
Sure, this works as well.
On Wed, May 3, 2023 at 9:37 AM Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Krzysztof,
Thanks.
I have lots of comments on the bindings, but I'm missing what is the problem to solve. Yes, it's 'A/B firmware updates', but what configuration data do you need, why and when do you need it. IOW, give me enough information to understand why a binding is designed the way it is and be able to propose alternatives.
That's easy enough to deduce for the GPT case. It's just needing to know which device has the f/w update GPT? That's easily solved with an alias, a boolean property in the device, or property with the disk GUID. All of those options are much more simple than a whole node and compatible.
I think it is fine if u-boot has things in DT which aren't an ABI, so private and bundled, but I agree those should be stripped before passing. To put it another way, if it's not an ABI nor shared amongst projects, I don't think we need a schema nor to care outside of u-boot.
However, it doesn't seem to me that needs for A/B updates would be unique to u-boot.
I'm assuming it's per partition type rather than storage medium (e.g. SATA, USB, SD, NAND, SPI-NOR)? GPT, 'fixed-partitions', other DT partition bindings, etc. If so, then I'm really wondering why it's a standalone tree rather than integrated into those existing partition bindings.
Rob
Hi Rob,
Hi Krzysztof,
Thanks.
Thanks for taking the time on this. I do have questions for Jassi as well, but let me describe what I have in mind first. What we are trying to do here is standardize how EFI compliant devices (and in extent SystemReady-IR) can reliably perform firmware updates adding capabilities like rollback, brick protection etc.
The high level description of how this is done is described here [0]. The really short version of that document is that you: - Perform a capsule update of the non active partition - Reboot to that partition and launch your OS - If the OS approves the updates (which is implementation defined), then you install an empty capsule indicating the acceptance of the update - If the device for any reason reboots for X amounts of times and the acceptance capsule is not found, it will revert to the primary partition. - If the acceptance capsule is found the device permanently switches over to the new firmware, bumping any rollback counters it might have (that's optional). - All these information along with UUIDs for the storage medium and the image types are stored in the metadata [1], which also has a backup location.
What you fundamentally need to perform an A/B booting is a first stage boot loader (or a masked ROM) that can understand the metadata described here [1].
Ideally we would only require the DT to describe where we can find that metadata -- but the reality is a bit different. Currently we only support of 2 types of devices - metadata lives in a GPT partition - They are located in an specific offset on a SPI-NOR
GPT based devices are straightforward. As you noticed we only need the phandle of the device. There is a defined UUID for the metadata, so we discover them along with the backup partition.
The MTD case is a bit more complicated. The metadata format only defines GUIDs for - UUID identifying the image type (image type GUID) - the UUID of the storage volume where the image is located
Since we now don't have a UUID of the storage volume where the image is located, we somehow need to map the image UUID to a device offset. I think this is what Jassi is trying to define here -- it's worth noting that this has to happen for all non-GPT devices.
As for when the data is needed, since this is backed up by EFI capsule updates, we only need access from the bootloader (and that's where the update agent currently resides, it's part of the u-boot EFI capsule functionality).
Sure you can do that. But wouldn't it be easier for bootloader to 'just' look for a compatible node regardless of where the metadata is stored? Sughosh did the u-boot implementation so maybe he can chime in on the challenges he saw code-wise.
Exactly, we completely agree on this.
Yes. TBH I was reluctant in trying to send the bindings upstream, since they are not related to hardware at all. But as I mentioned the only reason to have them standardized is if people buy in to that update document and want to replicate the functionality.
I think it's per medium, unless I misunderstood something. Sughosh?
Thanks! /Ilias
Rob
[0] https://gitlab.com/Linaro/trustedsubstrate/mbfw/uploads/3d0d7d11ca9874dc9115... [1] https://developer.arm.com/documentation/den0118/a
hi Ilias,
On Thu, 4 May 2023 at 16:15, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Rob,
Hi Krzysztof,
Thanks.
We can indeed have a boolean property in the device which will have the fwu metadata stored. The reason for having the compatible property is that the fwu metadata access functions have been implemented in a driver, and the u-boot driver model requires having a node with a compatible property for the driver's probe function to be called, when the corresponding device is accessed. This was primarily the reason for having a separate node with the compatible property.
The bindings would be required as per the metadata access mechanism. So for example, the MTD bindings would suffice for all the storage mediums which would have MTD based partitioning schemes. Same for all GPT partitioned devices. Again, as for the need for a separate node with the compatible property, it is as per the driver model design. For the other properties, we can indeed have them integrated with the corresponding partition bindings.
-sughosh
Ok, Rob is correct then it really is per partition type.
Thanks /Ilias
-sughosh
On Thu, 4 May 2023 at 07:08, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Originally the fwu related properties were embedded into existing nodes.
As Sughosh already explained, we need a compatible string, and hence a node, for the u-boot driver core to call probe(). I may be wrong, but I see having fwu properties contained within the fwu node is cleaner than having them embedded into existing bindings (potentially different classes in future). So I moved to the current design.
cheers.
DT's purpose is not OS driver instantiation. DT cannot cater to a client's evolving driver structure.
Having all the information related to a device/node in one place is cleaner IMO.
As I said, if u-boot wants private interfaces between the DT and itself, then fine, but that should remain private and be stripped by u-boot. A separate node would certainly be easier for doing that.
Rob
Seems we are on the same page(?). Current implementation does exactly that -- we have a separate fwu node containing all the properties it needs.
thanks.
Well, isn't part of why we're here is that this isn't strictly a U-Boot only thing? My question is can, and then is, this also being used in other projects yet?
Replying to both Jassi and Tom here since it makes more sense,
I think Rob is saying the exact opposite. The way I see it we either - Keep the bindings as an internal u-boot ABI, in which case the current format is fine, but we need to strip it from the DT before handing it over to the OS. - Alternatively, if we want to submit it upstream, we need to change where that data lives and ideally have them under existing partition bindings.
Both would work, with the latter offering a bit more standardization if another bootloader tries to implement something similar.
I am not aware of any other projects currently using it. I'll repeat myself though, it would be useful to have the format standardized in case other bootloaders have similar needs. In any case I am happy with the discussion so far. We (as in u-boot) need to decide which of the above directions suits as best and either send the bindings upstream, or clean then up before we boot.
Cheers /Ilias
-- Tom
On Thu, 4 May 2023 at 11:31, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
I interpreted "Having all the information related to a device/node in one place is cleaner IMO." to suggest this approach. Though the stripping part remains tbd. Where should that be done in u-boot?
Here we may have to add to bindings of various subsystems (as support widens) and still have to strip the property before handover to the kernel. right?
Maybe I am overlooking something, but the kernel should not have anything to do with it. EDK2 may use the node as such and BL1/2 would have the meta-data location info hardcoded into them (?)
thanks.
The one place being where there is already partition information in the partition nodes. This binding adds a 2nd location with pointers to the 1st location.
Yes.
Um, LinuxBoot, kexec?
Certainly not hard to imagine others needing this.
Rob
In dt-schema https://github.com/devicetree-org/dt-schema/blob/main/dtschema/schemas/optio...
description: | The u-boot,config node provides basic configuration information to U-Boot, for use during its execution. It can be used to control U-Boot's behaviour in various ways.
We are preparing patch to add some more properties for u-boot itself. I thought that Simon already solved what should be location for U-Boot only binding by creating this file.
Thanks, Michal
participants (8)
Ilias Apalodimas
Jassi Brar
Krzysztof Kozlowski
Michal Simek
Rob Herring
Sughosh Ganu
