[U-Boot] [PATCH 1/3] imx6ul: opos6ul: migrate to DM_ETH
Migrate to DM_ETH and remove code that is no longer necessary.
Signed-off-by: Sébastien Szymanski sebastien.szymanski@armadeus.com --- arch/arm/mach-imx/mx6/opos6ul.c | 76 +++------------------------------ configs/opos6uldev_defconfig | 2 + include/configs/opos6uldev.h | 8 ---- 3 files changed, 8 insertions(+), 78 deletions(-)
diff --git a/arch/arm/mach-imx/mx6/opos6ul.c b/arch/arm/mach-imx/mx6/opos6ul.c index c5fafb9f8e..50aec5171c 100644 --- a/arch/arm/mach-imx/mx6/opos6ul.c +++ b/arch/arm/mach-imx/mx6/opos6ul.c @@ -6,11 +6,7 @@ #include <asm/arch/clock.h> #include <asm/arch/crm_regs.h> #include <asm/arch/imx-regs.h> -#include <asm/arch/iomux.h> -#include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> -#include <asm/gpio.h> -#include <asm/mach-imx/iomux-v3.h> #include <asm/io.h> #include <common.h> #include <env.h> @@ -20,43 +16,6 @@ DECLARE_GLOBAL_DATA_PTR; #ifdef CONFIG_FEC_MXC #include <miiphy.h>
-#define MDIO_PAD_CTRL ( \ - PAD_CTL_HYS | PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm \ -) - -#define ENET_PAD_CTRL_PU ( \ - PAD_CTL_HYS | PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm \ -) - -#define ENET_PAD_CTRL_PD ( \ - PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm \ -) - -#define ENET_CLK_PAD_CTRL ( \ - PAD_CTL_HYS | PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_LOW | \ - PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST \ -) - -static iomux_v3_cfg_t const fec1_pads[] = { - MX6_PAD_GPIO1_IO06__ENET1_MDIO | MUX_PAD_CTRL(MDIO_PAD_CTRL), - MX6_PAD_GPIO1_IO07__ENET1_MDC | MUX_PAD_CTRL(MDIO_PAD_CTRL), - MX6_PAD_ENET1_RX_ER__ENET1_RX_ER | MUX_PAD_CTRL(ENET_PAD_CTRL_PD), - MX6_PAD_ENET1_RX_EN__ENET1_RX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL_PD), - MX6_PAD_ENET1_RX_DATA1__ENET1_RDATA01 | MUX_PAD_CTRL(ENET_PAD_CTRL_PD), - MX6_PAD_ENET1_RX_DATA0__ENET1_RDATA00 | MUX_PAD_CTRL(ENET_PAD_CTRL_PD), - MX6_PAD_ENET1_TX_DATA0__ENET1_TDATA00 | MUX_PAD_CTRL(ENET_PAD_CTRL_PU), - MX6_PAD_ENET1_TX_DATA1__ENET1_TDATA01 | MUX_PAD_CTRL(ENET_PAD_CTRL_PU), - MX6_PAD_ENET1_TX_EN__ENET1_TX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL_PU), - /* PHY Int */ - MX6_PAD_NAND_DQS__GPIO4_IO16 | MUX_PAD_CTRL(ENET_PAD_CTRL_PU), - /* PHY Reset */ - MX6_PAD_NAND_DATA00__GPIO4_IO02 | MUX_PAD_CTRL(ENET_PAD_CTRL_PD), - MX6_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 | MUX_PAD_CTRL(ENET_CLK_PAD_CTRL), -}; - int board_phy_config(struct phy_device *phydev) { phy_write(phydev, MDIO_DEVAD_NONE, 0x1f, 0x8190); @@ -67,43 +26,16 @@ int board_phy_config(struct phy_device *phydev) return 0; }
-int board_eth_init(bd_t *bis) +static int setup_fec(void) { struct iomuxc *const iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR; - struct gpio_desc rst; - int ret;
/* Use 50M anatop loopback REF_CLK1 for ENET1, * clear gpr1[13], set gpr1[17] */ clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC1_MASK, IOMUX_GPR1_FEC1_CLOCK_MUX1_SEL_MASK);
- ret = enable_fec_anatop_clock(0, ENET_50MHZ); - if (ret) - return ret; - - enable_enet_clk(1); - - imx_iomux_v3_setup_multiple_pads(fec1_pads, ARRAY_SIZE(fec1_pads)); - - ret = dm_gpio_lookup_name("GPIO4_2", &rst); - if (ret) { - printf("Cannot get GPIO4_2\n"); - return ret; - } - - ret = dm_gpio_request(&rst, "phy-rst"); - if (ret) { - printf("Cannot request GPIO4_2\n"); - return ret; - } - - dm_gpio_set_dir_flags(&rst, GPIOD_IS_OUT); - dm_gpio_set_value(&rst, 0); - udelay(1000); - dm_gpio_set_value(&rst, 1); - - return fecmxc_initialize(bis); + return enable_fec_anatop_clock(0, ENET_50MHZ); } #endif /* CONFIG_FEC_MXC */
@@ -112,6 +44,10 @@ int board_init(void) /* Address of boot parameters */ gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
+#ifdef CONFIG_FEC_MXC + setup_fec(); +#endif + return 0; }
diff --git a/configs/opos6uldev_defconfig b/configs/opos6uldev_defconfig index 5eef6527cd..44236e99bc 100644 --- a/configs/opos6uldev_defconfig +++ b/configs/opos6uldev_defconfig @@ -73,6 +73,8 @@ CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y diff --git a/include/configs/opos6uldev.h b/include/configs/opos6uldev.h index b13e476027..b10071eaaf 100644 --- a/include/configs/opos6uldev.h +++ b/include/configs/opos6uldev.h @@ -41,14 +41,6 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #endif
-/* Ethernet */ -#ifdef CONFIG_FEC_MXC -#define IMX_FEC_BASE ENET_BASE_ADDR -#define CONFIG_FEC_MXC_PHYADDR 0x1 -#define CONFIG_FEC_XCV_TYPE RMII -#define CONFIG_ETHPRIME "FEC" -#endif - /* LCD */ #ifndef CONFIG_SPL_BUILD #ifdef CONFIG_VIDEO
Migrate to DM_VIDEO, update the device tree and remove code that is no longer necessary.
Signed-off-by: Sébastien Szymanski sebastien.szymanski@armadeus.com --- arch/arm/dts/imx6ul-opos6uldev-u-boot.dtsi | 10 ++++++ arch/arm/dts/imx6ul-opos6uldev.dts | 4 +-- board/armadeus/opos6uldev/board.c | 36 ---------------------- configs/opos6uldev_defconfig | 3 +- include/configs/opos6uldev.h | 6 +++- 5 files changed, 19 insertions(+), 40 deletions(-)
diff --git a/arch/arm/dts/imx6ul-opos6uldev-u-boot.dtsi b/arch/arm/dts/imx6ul-opos6uldev-u-boot.dtsi index da8b0392ef..3f351ef0c4 100644 --- a/arch/arm/dts/imx6ul-opos6uldev-u-boot.dtsi +++ b/arch/arm/dts/imx6ul-opos6uldev-u-boot.dtsi @@ -7,6 +7,12 @@
#include "imx6ul-opos6ul-u-boot.dtsi"
+/ { + aliases { + display0 = &lcdif; + }; +}; + &aips1 { u-boot,dm-spl;
@@ -15,6 +21,10 @@ }; };
+&lcdif { + u-boot,dm-pre-proper; +}; + &pinctrl_uart1 { u-boot,dm-spl; }; diff --git a/arch/arm/dts/imx6ul-opos6uldev.dts b/arch/arm/dts/imx6ul-opos6uldev.dts index 0e59ee57fd..4a541be6b0 100644 --- a/arch/arm/dts/imx6ul-opos6uldev.dts +++ b/arch/arm/dts/imx6ul-opos6uldev.dts @@ -187,7 +187,7 @@ status = "okay";
display0: display0 { - bits-per-pixel = <32>; + bits-per-pixel = <18>; bus-width = <18>;
display-timings { @@ -202,7 +202,7 @@ hsync-len = <64>; vsync-len = <4>; de-active = <1>; - pixelclk-active = <0>; + pixelclk-active = <1>; }; }; }; diff --git a/board/armadeus/opos6uldev/board.c b/board/armadeus/opos6uldev/board.c index cbf40d5c4a..ade155c5ad 100644 --- a/board/armadeus/opos6uldev/board.c +++ b/board/armadeus/opos6uldev/board.c @@ -3,53 +3,17 @@ * Copyright (C) 2018 Armadeus Systems */
-#include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> #include <asm/gpio.h> -#include <asm/mach-imx/iomux-v3.h> #include <asm/io.h> #include <common.h>
#ifdef CONFIG_VIDEO_MXS -#define LCD_PAD_CTRL ( \ - PAD_CTL_HYS | PAD_CTL_PUS_100K_UP | PAD_CTL_PUE | \ - PAD_CTL_PKE | PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm \ -) - -static iomux_v3_cfg_t const lcd_pads[] = { - MX6_PAD_LCD_CLK__LCDIF_CLK | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_ENABLE__LCDIF_ENABLE | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_HSYNC__LCDIF_HSYNC | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_VSYNC__LCDIF_VSYNC | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA00__LCDIF_DATA00 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA01__LCDIF_DATA01 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA02__LCDIF_DATA02 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA03__LCDIF_DATA03 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA04__LCDIF_DATA04 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA05__LCDIF_DATA05 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA06__LCDIF_DATA06 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA07__LCDIF_DATA07 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA08__LCDIF_DATA08 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA09__LCDIF_DATA09 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA10__LCDIF_DATA10 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA11__LCDIF_DATA11 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA12__LCDIF_DATA12 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA13__LCDIF_DATA13 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA14__LCDIF_DATA14 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA15__LCDIF_DATA15 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA16__LCDIF_DATA16 | MUX_PAD_CTRL(LCD_PAD_CTRL), - MX6_PAD_LCD_DATA17__LCDIF_DATA17 | MUX_PAD_CTRL(LCD_PAD_CTRL), - - MX6_PAD_NAND_ALE__GPIO4_IO10 | MUX_PAD_CTRL(NO_PAD_CTRL) -}; - int setup_lcd(void) { struct gpio_desc backlight; int ret;
- imx_iomux_v3_setup_multiple_pads(lcd_pads, ARRAY_SIZE(lcd_pads)); - /* Set Brightness to high */ ret = dm_gpio_lookup_name("GPIO4_10", &backlight); if (ret) { diff --git a/configs/opos6uldev_defconfig b/configs/opos6uldev_defconfig index 44236e99bc..352d10a0d8 100644 --- a/configs/opos6uldev_defconfig +++ b/configs/opos6uldev_defconfig @@ -95,6 +95,7 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_VIDEO=y +CONFIG_DM_VIDEO=y +CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_OF_LIBFDT_OVERLAY=y # CONFIG_EFI_LOADER is not set diff --git a/include/configs/opos6uldev.h b/include/configs/opos6uldev.h index b10071eaaf..11face21a1 100644 --- a/include/configs/opos6uldev.h +++ b/include/configs/opos6uldev.h @@ -43,7 +43,7 @@
/* LCD */ #ifndef CONFIG_SPL_BUILD -#ifdef CONFIG_VIDEO +#ifdef CONFIG_DM_VIDEO #define CONFIG_VIDEO_LOGO #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN @@ -51,6 +51,8 @@ #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_BMP_16BPP +#define CONFIG_BMP_24BPP +#define CONFIG_BMP_32BPP #define CONFIG_VIDEO_MXS #define MXS_LCDIF_BASE MX6UL_LCDIF1_BASE_ADDR #endif @@ -87,6 +89,8 @@ "mmcroot=/dev/mmcblk0p2 ro\0" \ "mmcrootfstype=ext4 rootwait\0" \ "kernelimg=" __stringify(CONFIG_BOARD_NAME) "-linux.bin\0" \ + "splashpos=0,0\0" \ + "splashimage=" __stringify(CONFIG_LOADADDR) "\0" \ "videomode=video=ctfb:x:800,y:480,depth:18,pclk:33033,le:96,ri:96,up:20,lo:21,hs:64,vs:4,sync:0,vmode:0\0" \ "check_env=if test -n ${flash_env_version}; " \ "then env default env_version; " \
Subject: [PATCH 2/3] opos6uldev: migrate to DM_VIDEO
- aliases {
display0 = &lcdif;
+&lcdif {
- u-boot,dm-pre-proper;
bus-width = <18>;
display-timings {
}; };pixelclk-active = <1>; };
- Copyright (C) 2018 Armadeus Systems
"splashpos=0,0\0" \
0,lo:21,hs:64,vs:4,sync:0,vmode:0\0" \ "check_env=if test -n ${flash_env_version}; " \ "then env default env_version; " \ --
Reviewed-by: Peng Fan peng.fan@nxp.com
2.21.0
Set gd->fb_base so it can be shown with bdinfo command.
Signed-off-by: Sébastien Szymanski sebastien.szymanski@armadeus.com --- drivers/video/mxsfb.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/video/mxsfb.c b/drivers/video/mxsfb.c index 6922a130c6..ce67f3f32b 100644 --- a/drivers/video/mxsfb.c +++ b/drivers/video/mxsfb.c @@ -367,6 +367,7 @@ static int mxs_video_probe(struct udevice *dev) mmu_set_region_dcache_behaviour(fb_start, fb_end - fb_start, DCACHE_WRITEBACK); video_set_flush_dcache(dev, true); + gd->fb_base = fb_start;
return ret; }
Subject: [PATCH 3/3] video: mxsfb: set gd->fb_base
- gd->fb_base = fb_start;
Should this be gd->fb_base = plat->base?
Regards, Peng.
return ret; } -- 2.21.0
Subject: [PATCH 1/3] imx6ul: opos6ul: migrate to DM_ETH
- /* PHY Int */
- /* PHY Reset */
int ret;
- clear gpr1[13], set gpr1[17] */
if (ret)
return ret;
enable_enet_clk(1);
- if (ret) {
return ret;
- if (ret) {
return ret;
- udelay(1000);
- return enable_fec_anatop_clock(0, ENET_50MHZ);
- setup_fec();
-- 2.21.0
Anatolij Gustschin
Peng Fan
Sébastien Szymanski
