[U-Boot] [PATCH 4/6 v2] 8xx, mgsuvd: Coding Style cleanup config file
Signed-off-by: Heiko Schocher hs@denx.de --- include/configs/mgsuvd.h | 57 +++++++++++++++++++++++++--------------------- 1 files changed, 31 insertions(+), 26 deletions(-)
diff --git a/include/configs/mgsuvd.h b/include/configs/mgsuvd.h index 9ec24f4..c8679e7 100644 --- a/include/configs/mgsuvd.h +++ b/include/configs/mgsuvd.h @@ -44,12 +44,14 @@
#define CONFIG_SYS_SMC_UCODE_PATCH 1 /* Relocate SMC1 */ #define CONFIG_SYS_SMC_DPMEM_OFFSET 0x1fc0 -#define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ +#define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ #define CONFIG_SYS_SMC_RXBUFLEN 128 #define CONFIG_SYS_MAXIDLE 10
-#define CONFIG_SYS_CPM_BOOTCOUNT_ADDR 0x1eb0 /* In case of SMC relocation, the - * default value is not working */ +#define CONFIG_SYS_CPM_BOOTCOUNT_ADDR 0x1eb0 /* In case of SMC relocation, + * the default value is not + * working + */
#define BOOTFLASH_START F0000000 #define CONFIG_PRAM 512 /* protected RAM [KBytes] */ @@ -96,7 +98,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ +#define CONFIG_SYS_GBL_DATA_SIZE 64 #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
@@ -107,34 +109,35 @@ */ #define CONFIG_SYS_SDRAM_BASE 0x00000000 #define CONFIG_SYS_FLASH_BASE 0xf0000000 -#define CONFIG_SYS_MONITOR_LEN (384 << 10) /* Reserve 384 kB for Monitor */ +#define CONFIG_SYS_MONITOR_LEN (384 << 10) /* 384 kB for Monitor */ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MALLOC_LEN (256 << 10) /* Reserve 256 kB for malloc() */ +#define CONFIG_SYS_MALLOC_LEN (256 << 10) /* 256 kB for malloc() */
/* * For booting Linux, the board info and command line data * have to be in the first 8 MB of memory, since this is * the maximum mapped by the Linux kernel during initialization. */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ +#define CONFIG_SYS_BOOTMAPSZ (8 << 20)
/*----------------------------------------------------------------------- * FLASH organization */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ +/* max number of memory banks */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_FLASH_SIZE 32 #define CONFIG_SYS_FLASH_CFI #define CONFIG_FLASH_CFI_DRIVER -#define CONFIG_SYS_MAX_FLASH_SECT 256 /* max num of sects on one chip */ +/* max num of sects on one chip */ +#define CONFIG_SYS_MAX_FLASH_SECT 256
- -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* (in ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* (in ms) */
#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_OFFSET CONFIG_SYS_MONITOR_LEN -#define CONFIG_ENV_SIZE 0x04000 /* Total Size of Environment Sector */ -#define CONFIG_ENV_SECT_SIZE 0x20000 /* Total Size of Environment Sector */ +#define CONFIG_ENV_SIZE 0x04000 /* Total Size of Environment Sector */ +#define CONFIG_ENV_SECT_SIZE 0x20000 /* Total Size of Environment Sector */
/* Address and size of Redundant Environment Sector */ #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET+CONFIG_ENV_SECT_SIZE) @@ -144,9 +147,9 @@ /*----------------------------------------------------------------------- * Cache Configuration */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ +#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ #if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ +#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
/*----------------------------------------------------------------------- @@ -216,7 +219,7 @@ #define SDRAM_BASE1_PRELIM 0x00000000 /* SDRAM bank #0 */ #define SDRAM_MAX_SIZE (64 << 20) /* max 64 MB per bank */
-/* SDRAM timing: Multiplexed addresses, GPL5 output to GPL5_A (don't care) */ +/* SDRAM timing: Multiplexed addresses, GPL5 output to GPL5_A (don't care) */ #define CONFIG_SYS_OR_TIMING_SDRAM 0x00000A00
#define CONFIG_SYS_OR1_PRELIM 0xfc000800 @@ -248,8 +251,8 @@ * * Boot Flags */ -#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ -#define BOOTFLAG_WARM 0x02 /* Software reboot */ +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */
#define CONFIG_SCC3_ENET #define CONFIG_ETHPRIME "SCC ETHERNET" @@ -262,9 +265,10 @@ #define OF_STDOUT_PATH "/soc/cpm/serial@a80"
/* enable I2C and select the hardware/software driver */ -#undef CONFIG_HARD_I2C /* I2C with hardware support */ -#define CONFIG_SOFT_I2C 1 /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SPEED 50000 /* I2C speed and slave address */ +#undef CONFIG_HARD_I2C /* I2C with hardware support */ +#define CONFIG_SOFT_I2C 1 /* I2C bit-banged */ +/* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SPEED 50000 #define CONFIG_SYS_I2C_SLAVE 0x7F #define I2C_SOFT_DECLARATIONS
@@ -298,9 +302,9 @@
#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1
-/* I2C SYSMON (LM75, AD7414 is almost compatible) */ -#define CONFIG_DTT_LM75 1 /* ON Semi's LM75 */ -#define CONFIG_DTT_SENSORS {0, 2, 4, 6} /* Sensor addresses */ +/* I2C SYSMON (LM75, AD7414 is almost compatible) */ +#define CONFIG_DTT_LM75 1 /* ON Semi's LM75 */ +#define CONFIG_DTT_SENSORS {0, 2, 4, 6} /* Sensor addresses */ #define CONFIG_SYS_DTT_MAX_TEMP 70 #define CONFIG_SYS_DTT_LOW_TEMP -30 #define CONFIG_SYS_DTT_HYSTERESIS 3 @@ -309,6 +313,7 @@ #define MTDIDS_DEFAULT "nor0=app" #define MTDPARTS_DEFAULT ( \ "mtdparts=app:384k(u-boot),128k(env),128k(envred),128k(free)," \ - "1536k(esw0),8704k(rootfs0),1536k(esw1),2432k(rootfs1),640k(var),768k(cfg)") + "1536k(esw0),8704k(rootfs0),1536k(esw1),2432k(rootfs1),640k(var)," \ + "768k(cfg)")
#endif /* __CONFIG_H */
Dear Heiko Schocher,
Applied, thanks.
Heiko Schocher
