[PATCH v2 0/2] imx8mn-smm-s2/pro: Add iMX8MN BSH SMM S2 boards
Changes in v2: * Properly added MAINTAINERS entry. * Fixed binman configuration. * Picked device tree from kernel. * Removed CONFIG_SPL_BUILD anti-pattern in board config. * Removed downstream stuff in bootargs. * Added board documentation.
Ariel D'Alessandro (1): bsh: imx8mn-smm-s2/pro: Add iMX8MN BSH SMM S2 boards
Michael Trimarchi (1): imx8m: add regs used by GPMI
arch/arm/dts/Makefile | 2 + arch/arm/dts/imx8mn-bsh-smm-s2-common.dtsi | 423 ++++++++ .../dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi | 225 +++++ arch/arm/dts/imx8mn-bsh-smm-s2-u-boot.dtsi | 15 + arch/arm/dts/imx8mn-bsh-smm-s2.dts | 48 + arch/arm/dts/imx8mn-bsh-smm-s2pro-u-boot.dtsi | 15 + arch/arm/dts/imx8mn-bsh-smm-s2pro.dts | 80 ++ arch/arm/include/asm/arch-imx8m/imx-regs.h | 7 + arch/arm/mach-imx/imx8m/Kconfig | 15 + board/bsh/imx8mn_smm_s2/Kconfig | 38 + board/bsh/imx8mn_smm_s2/MAINTAINERS | 8 + board/bsh/imx8mn_smm_s2/Makefile | 13 + board/bsh/imx8mn_smm_s2/ddr3l_timing_256m.c | 941 ++++++++++++++++++ board/bsh/imx8mn_smm_s2/ddr3l_timing_512m.c | 941 ++++++++++++++++++ board/bsh/imx8mn_smm_s2/imx8mn_smm_s2.c | 23 + board/bsh/imx8mn_smm_s2/imximage-8mn-ddr3.cfg | 10 + board/bsh/imx8mn_smm_s2/spl.c | 93 ++ configs/imx8mn_bsh_smm_s2_defconfig | 92 ++ configs/imx8mn_bsh_smm_s2pro_defconfig | 89 ++ doc/board/bsh/imx8mn_bsh_smm_s2.rst | 62 ++ doc/board/bsh/index.rst | 9 + doc/board/index.rst | 1 + include/configs/imx8mn_bsh_smm_s2.h | 52 + include/configs/imx8mn_bsh_smm_s2_common.h | 62 ++ include/configs/imx8mn_bsh_smm_s2pro.h | 35 + 25 files changed, 3299 insertions(+) create mode 100644 arch/arm/dts/imx8mn-bsh-smm-s2-common.dtsi create mode 100644 arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi create mode 100644 arch/arm/dts/imx8mn-bsh-smm-s2-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mn-bsh-smm-s2.dts create mode 100644 arch/arm/dts/imx8mn-bsh-smm-s2pro-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mn-bsh-smm-s2pro.dts create mode 100644 board/bsh/imx8mn_smm_s2/Kconfig create mode 100644 board/bsh/imx8mn_smm_s2/MAINTAINERS create mode 100644 board/bsh/imx8mn_smm_s2/Makefile create mode 100644 board/bsh/imx8mn_smm_s2/ddr3l_timing_256m.c create mode 100644 board/bsh/imx8mn_smm_s2/ddr3l_timing_512m.c create mode 100644 board/bsh/imx8mn_smm_s2/imx8mn_smm_s2.c create mode 100644 board/bsh/imx8mn_smm_s2/imximage-8mn-ddr3.cfg create mode 100644 board/bsh/imx8mn_smm_s2/spl.c create mode 100644 configs/imx8mn_bsh_smm_s2_defconfig create mode 100644 configs/imx8mn_bsh_smm_s2pro_defconfig create mode 100644 doc/board/bsh/imx8mn_bsh_smm_s2.rst create mode 100644 doc/board/bsh/index.rst create mode 100644 include/configs/imx8mn_bsh_smm_s2.h create mode 100644 include/configs/imx8mn_bsh_smm_s2_common.h create mode 100644 include/configs/imx8mn_bsh_smm_s2pro.h
From: Michael Trimarchi michael@amarulasolutions.com
Add regs used by GPMI
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Ariel D'Alessandro ariel.dalessandro@collabora.com --- arch/arm/include/asm/arch-imx8m/imx-regs.h | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/include/asm/arch-imx8m/imx-regs.h b/arch/arm/include/asm/arch-imx8m/imx-regs.h index b800da13a1..14955d1090 100644 --- a/arch/arm/include/asm/arch-imx8m/imx-regs.h +++ b/arch/arm/include/asm/arch-imx8m/imx-regs.h @@ -58,6 +58,13 @@ #define SRC_DDRC_RCR_ADDR 0x30391000 #define SRC_DDRC2_RCR_ADDR 0x30391004
+#define APBH_DMA_ARB_BASE_ADDR 0x33000000 +#define APBH_DMA_ARB_END_ADDR 0x33007FFF +#define MXS_APBH_BASE APBH_DMA_ARB_BASE_ADDR + +#define MXS_GPMI_BASE (APBH_DMA_ARB_BASE_ADDR + 0x02000) +#define MXS_BCH_BASE (APBH_DMA_ARB_BASE_ADDR + 0x04000) + #define DDRC_DDR_SS_GPR0 0x3d000000 #define DDRC_IPS_BASE_ADDR(X) (0x3d400000 + ((X) * 0x2000000)) #define DDR_CSD1_BASE_ADDR 0x40000000
On Tue, Nov 23, 2021 at 2:43 PM Ariel D'Alessandro ariel.dalessandro@collabora.com wrote:
Reviewed-by: Fabio Estevam festevam@gmail.com
Introduce BSH SystemMaster (SMM) S2 board family, which consists of: iMX8MN SMM S2 and iMX8MN SMM S2 PRO boards.
Add support for iMX8MN BSH SMM S2 board:
- 256 MiB DDR3 RAM - 512MiB Nand - USBOTG1 peripheral - fastboot.
Add support for iMX8MN BSH SMM S2 PRO board:
- 512 MiB DDR3 RAM - 8 GiB eMMC - USBOTG1 peripheral - fastboot.
Signed-off-by: Ariel D'Alessandro ariel.dalessandro@collabora.com Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- arch/arm/dts/Makefile | 2 + arch/arm/dts/imx8mn-bsh-smm-s2-common.dtsi | 423 ++++++++ .../dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi | 225 +++++ arch/arm/dts/imx8mn-bsh-smm-s2-u-boot.dtsi | 15 + arch/arm/dts/imx8mn-bsh-smm-s2.dts | 48 + arch/arm/dts/imx8mn-bsh-smm-s2pro-u-boot.dtsi | 15 + arch/arm/dts/imx8mn-bsh-smm-s2pro.dts | 80 ++ arch/arm/mach-imx/imx8m/Kconfig | 15 + board/bsh/imx8mn_smm_s2/Kconfig | 38 + board/bsh/imx8mn_smm_s2/MAINTAINERS | 8 + board/bsh/imx8mn_smm_s2/Makefile | 13 + board/bsh/imx8mn_smm_s2/ddr3l_timing_256m.c | 941 ++++++++++++++++++ board/bsh/imx8mn_smm_s2/ddr3l_timing_512m.c | 941 ++++++++++++++++++ board/bsh/imx8mn_smm_s2/imx8mn_smm_s2.c | 23 + board/bsh/imx8mn_smm_s2/imximage-8mn-ddr3.cfg | 10 + board/bsh/imx8mn_smm_s2/spl.c | 93 ++ configs/imx8mn_bsh_smm_s2_defconfig | 92 ++ configs/imx8mn_bsh_smm_s2pro_defconfig | 89 ++ doc/board/bsh/imx8mn_bsh_smm_s2.rst | 62 ++ doc/board/bsh/index.rst | 9 + doc/board/index.rst | 1 + include/configs/imx8mn_bsh_smm_s2.h | 52 + include/configs/imx8mn_bsh_smm_s2_common.h | 62 ++ include/configs/imx8mn_bsh_smm_s2pro.h | 35 + 24 files changed, 3292 insertions(+) create mode 100644 arch/arm/dts/imx8mn-bsh-smm-s2-common.dtsi create mode 100644 arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi create mode 100644 arch/arm/dts/imx8mn-bsh-smm-s2-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mn-bsh-smm-s2.dts create mode 100644 arch/arm/dts/imx8mn-bsh-smm-s2pro-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mn-bsh-smm-s2pro.dts create mode 100644 board/bsh/imx8mn_smm_s2/Kconfig create mode 100644 board/bsh/imx8mn_smm_s2/MAINTAINERS create mode 100644 board/bsh/imx8mn_smm_s2/Makefile create mode 100644 board/bsh/imx8mn_smm_s2/ddr3l_timing_256m.c create mode 100644 board/bsh/imx8mn_smm_s2/ddr3l_timing_512m.c create mode 100644 board/bsh/imx8mn_smm_s2/imx8mn_smm_s2.c create mode 100644 board/bsh/imx8mn_smm_s2/imximage-8mn-ddr3.cfg create mode 100644 board/bsh/imx8mn_smm_s2/spl.c create mode 100644 configs/imx8mn_bsh_smm_s2_defconfig create mode 100644 configs/imx8mn_bsh_smm_s2pro_defconfig create mode 100644 doc/board/bsh/imx8mn_bsh_smm_s2.rst create mode 100644 doc/board/bsh/index.rst create mode 100644 include/configs/imx8mn_bsh_smm_s2.h create mode 100644 include/configs/imx8mn_bsh_smm_s2_common.h create mode 100644 include/configs/imx8mn_bsh_smm_s2pro.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 7f622fedbd..25a3a6f713 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -899,6 +899,8 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mm-venice-gw7902.dtb \ imx8mm-verdin.dtb \ phycore-imx8mm.dtb \ + imx8mn-bsh-smm-s2.dtb \ + imx8mn-bsh-smm-s2pro.dtb \ imx8mn-ddr4-evk.dtb \ imx8mq-cm.dtb \ imx8mn-evk.dtb \ diff --git a/arch/arm/dts/imx8mn-bsh-smm-s2-common.dtsi b/arch/arm/dts/imx8mn-bsh-smm-s2-common.dtsi new file mode 100644 index 0000000000..184c715bd3 --- /dev/null +++ b/arch/arm/dts/imx8mn-bsh-smm-s2-common.dtsi @@ -0,0 +1,423 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2021 Collabora Ltd. + * Copyright 2021 BSH Hausgeraete GmbH + */ + +#include "imx8mn.dtsi" + +/ { + chosen { + stdout-path = &uart4; + }; + + fec_supply: fec_supply_en { + compatible = "regulator-fixed"; + regulator-name = "tja1101_en"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio2 20 GPIO_ACTIVE_HIGH>; + vin-supply = <&buck4_reg>; + enable-active-high; + }; + + usdhc2_pwrseq: usdhc2_pwrseq { + compatible = "mmc-pwrseq-simple"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc2_pwrseq>; + reset-gpios = <&gpio4 27 GPIO_ACTIVE_LOW>; + }; +}; + +&A53_0 { + cpu-supply = <&buck2_reg>; +}; + +&A53_1 { + cpu-supply = <&buck2_reg>; +}; + +&A53_2 { + cpu-supply = <&buck2_reg>; +}; + +&A53_3 { + cpu-supply = <&buck2_reg>; +}; + +&ecspi2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_espi2>; + status = "okay"; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec1>; + phy-mode = "rmii"; + phy-handle = <ðphy0>; + phy-supply = <&fec_supply>; + phy-reset-gpios = <&gpio1 29 GPIO_ACTIVE_LOW>; + phy-reset-duration = <20>; + fsl,magic-packet; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + }; + }; +}; + +&i2c1 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; + + bd71847: pmic@4b { + compatible = "rohm,bd71847"; + reg = <0x4b>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pmic>; + interrupt-parent = <&gpio1>; + interrupts = <3 IRQ_TYPE_LEVEL_LOW>; + rohm,reset-snvs-powered; + + #clock-cells = <0>; + clocks = <&osc_32k 0>; + clock-output-names = "clk-32k-out"; + + regulators { + buck1_reg: BUCK1 { + /* PMIC_BUCK1 - VDD_SOC */ + regulator-name = "buck1"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <1250>; + }; + + buck2_reg: BUCK2 { + /* PMIC_BUCK2 - VDD_ARM */ + regulator-name = "buck2"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <1250>; + }; + + buck3_reg: BUCK3 { + /* PMIC_BUCK5 - VDD_DRAM_VPU_GPU */ + regulator-name = "buck3"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1350000>; + regulator-boot-on; + regulator-always-on; + }; + + buck4_reg: BUCK4 { + /* PMIC_BUCK6 - VDD_3V3 */ + regulator-name = "buck4"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + buck5_reg: BUCK5 { + /* PMIC_BUCK7 - VDD_1V8 */ + regulator-name = "buck5"; + regulator-min-microvolt = <1605000>; + regulator-max-microvolt = <1995000>; + regulator-boot-on; + regulator-always-on; + }; + + buck6_reg: BUCK6 { + /* PMIC_BUCK8 - NVCC_DRAM */ + regulator-name = "buck6"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo1_reg: LDO1 { + /* PMIC_LDO1 - NVCC_SNVS_1V8 */ + regulator-name = "ldo1"; + regulator-min-microvolt = <1600000>; + regulator-max-microvolt = <1900000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo2_reg: LDO2 { + /* PMIC_LDO2 - VDD_SNVS_0V8 */ + regulator-name = "ldo2"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <900000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo3_reg: LDO3 { + /* PMIC_LDO3 - VDDA_1V8 */ + regulator-name = "ldo3"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo4_reg: LDO4 { + /* PMIC_LDO4 - VDD_MIPI_0V9 */ + regulator-name = "ldo4"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo6_reg: LDO6 { + /* PMIC_LDO6 - VDD_MIPI_1V2 */ + regulator-name = "ldo6"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; +}; + +&i2c3 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + status = "okay"; +}; + +&i2c4 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c4>; + status = "okay"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + status = "okay"; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + assigned-clocks = <&clk IMX8MN_CLK_UART3>; + assigned-clock-parents = <&clk IMX8MN_SYS_PLL1_80M>; + uart-has-rtscts; + status = "okay"; + + bluetooth { + compatible = "brcm,bcm43438-bt"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_bluetooth>; + shutdown-gpios = <&gpio1 15 GPIO_ACTIVE_HIGH>; + device-wakeup-gpios = <&gpio1 18 GPIO_ACTIVE_HIGH>; + host-wakeup-gpios = <&gpio1 28 GPIO_ACTIVE_HIGH>; + max-speed = <3000000>; + }; +}; + +/* Console */ +&uart4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart4>; + status = "okay"; +}; + +&usbotg1 { + dr_mode = "peripheral"; + disable-over-current; + status = "okay"; +}; + +&usdhc2 { + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>; + mmc-pwrseq = <&usdhc2_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + brcmf: bcrmf@1 { + compatible = "brcm,bcm4329-fmac"; + reg = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wlan>; + interrupt-parent = <&gpio1>; + interrupts = <0 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "host-wake"; + }; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "okay"; +}; + +&iomuxc { + pinctrl_espi2: espi2grp { + fsl,pins = < + MX8MN_IOMUXC_ECSPI2_SCLK_ECSPI2_SCLK 0x082 + MX8MN_IOMUXC_ECSPI2_MOSI_ECSPI2_MOSI 0x082 + MX8MN_IOMUXC_ECSPI2_MISO_ECSPI2_MISO 0x082 + MX8MN_IOMUXC_ECSPI2_SS0_ECSPI2_SS0 0x040 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX8MN_IOMUXC_I2C1_SCL_I2C1_SCL 0x400000c2 + MX8MN_IOMUXC_I2C1_SDA_I2C1_SDA 0x400000c2 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX8MN_IOMUXC_I2C3_SCL_I2C3_SCL 0x400000c2 + MX8MN_IOMUXC_I2C3_SDA_I2C3_SDA 0x400000c2 + >; + }; + + pinctrl_i2c4: i2c4grp { + fsl,pins = < + MX8MN_IOMUXC_I2C4_SCL_I2C4_SCL 0x400000c2 + MX8MN_IOMUXC_I2C4_SDA_I2C4_SDA 0x400000c2 + >; + }; + + pinctrl_pmic: pmicirq { + fsl,pins = < + MX8MN_IOMUXC_GPIO1_IO03_GPIO1_IO3 0x040 + >; + }; + + pinctrl_uart4: uart4grp { + fsl,pins = < + MX8MN_IOMUXC_UART4_RXD_UART4_DCE_RX 0x040 + MX8MN_IOMUXC_UART4_TXD_UART4_DCE_TX 0x040 + >; + }; + + pinctrl_usdhc2_pwrseq: usdhc2pwrseqgrp { + fsl,pins = < + MX8MN_IOMUXC_SAI2_MCLK_GPIO4_IO27 0x040 /* WL_REG_ON */ + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX8MN_IOMUXC_SD2_CLK_USDHC2_CLK 0x090 + MX8MN_IOMUXC_SD2_CMD_USDHC2_CMD 0x0d0 + MX8MN_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x0d0 + MX8MN_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x0d0 + MX8MN_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x0d0 + MX8MN_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x0d0 + >; + }; + + pinctrl_usdhc2_100mhz: usdhc2grp100mhz { + fsl,pins = < + MX8MN_IOMUXC_SD2_CLK_USDHC2_CLK 0x094 + MX8MN_IOMUXC_SD2_CMD_USDHC2_CMD 0x0d4 + MX8MN_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x0d4 + MX8MN_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x0d4 + MX8MN_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x0d4 + MX8MN_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x0d4 + >; + }; + + pinctrl_usdhc2_200mhz: usdhc2grp200mhz { + fsl,pins = < + MX8MN_IOMUXC_SD2_CLK_USDHC2_CLK 0x096 + MX8MN_IOMUXC_SD2_CMD_USDHC2_CMD 0x0d6 + MX8MN_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x0d6 + MX8MN_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x0d6 + MX8MN_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x0d6 + MX8MN_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x0d6 + >; + }; + + pinctrl_wlan: wlangrp { + fsl,pins = < + MX8MN_IOMUXC_GPIO1_IO00_GPIO1_IO0 0x0d6 /* GPIO_0 - WIFI_GPIO_0 */ + MX8MN_IOMUXC_GPIO1_IO08_GPIO1_IO8 0x0d6 /* GPIO_1 - WIFI_GPIO_1 */ + MX8MN_IOMUXC_GPIO1_IO04_GPIO1_IO4 0x0d6 /* BT_GPIO_5 - WIFI_GPIO_5 */ + MX8MN_IOMUXC_SPDIF_RX_GPIO5_IO4 0x0d6 /* I2S_CLK - WIFI_GPIO_6 */ + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX8MN_IOMUXC_UART2_RXD_UART2_DCE_RX 0x040 + MX8MN_IOMUXC_UART2_TXD_UART2_DCE_TX 0x040 + >; + }; + + pinctrl_uart3: uart3grp { + fsl,pins = < + MX8MN_IOMUXC_UART3_TXD_UART3_DCE_TX 0x040 + MX8MN_IOMUXC_UART3_RXD_UART3_DCE_RX 0x040 + MX8MN_IOMUXC_ECSPI1_MISO_UART3_DCE_CTS_B 0x040 + MX8MN_IOMUXC_ECSPI1_SS0_UART3_DCE_RTS_B 0x040 + >; + }; + + pinctrl_bluetooth: bluetoothgrp { + fsl,pins = < + MX8MN_IOMUXC_GPIO1_IO15_GPIO1_IO15 0x044 /* BT_REG_ON */ + MX8MN_IOMUXC_ENET_TD3_GPIO1_IO18 0x046 /* BT_DEV_WAKE */ + MX8MN_IOMUXC_ENET_RD2_GPIO1_IO28 0x090 /* BT_HOST_WAKE */ + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX8MN_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0x046 + >; + }; + + pinctrl_fec1: fec1grp { + fsl,pins = < + MX8MN_IOMUXC_ENET_MDC_ENET1_MDC 0x002 + MX8MN_IOMUXC_ENET_MDIO_ENET1_MDIO 0x002 + MX8MN_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x090 + MX8MN_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x090 + MX8MN_IOMUXC_ENET_RXC_ENET1_RX_ER 0x090 + MX8MN_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x016 + MX8MN_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x016 + MX8MN_IOMUXC_ENET_TD2_ENET1_TX_CLK 0x016 + MX8MN_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x016 + MX8MN_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x090 + MX8MN_IOMUXC_ENET_TXC_ENET1_TX_ER 0x016 + MX8MN_IOMUXC_SD2_CD_B_GPIO2_IO12 0x150 /* RMII_INT - ENET_INT */ + MX8MN_IOMUXC_SD2_WP_GPIO2_IO20 0x150 /* RMII_EN - ENET_EN */ + MX8MN_IOMUXC_SD2_RESET_B_GPIO2_IO19 0x016 /* RMII_WAKE - GPIO_ENET_WAKE */ + MX8MN_IOMUXC_ENET_RD3_GPIO1_IO29 0x016 /* RMII_RESET - GPIO_ENET_RST */ + >; + }; +}; diff --git a/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi b/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi new file mode 100644 index 0000000000..9950946706 --- /dev/null +++ b/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi @@ -0,0 +1,225 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2021 Collabora Ltd. + * Copyright 2021 BSH Hausgeraete GmbH + */ + +/ { + binman: binman { + multiple-images; + }; + + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog1>; + u-boot,dm-spl; + }; +}; + +&{/soc@0} { + u-boot,dm-pre-reloc; + u-boot,dm-spl; +}; + +&{/soc@0/bus@30800000/i2c@30a20000/pmic@4b} { + u-boot,dm-spl; +}; + +&{/soc@0/bus@30800000/i2c@30a20000/pmic@4b/regulators} { + u-boot,dm-spl; +}; + +&aips1 { + u-boot,dm-pre-reloc; + u-boot,dm-spl; +}; + +&aips3 { + u-boot,dm-spl; +}; + +&aips4 { + u-boot,dm-spl; +}; + +&clk { + u-boot,dm-pre-reloc; + u-boot,dm-spl; + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-parents; + /delete-property/ assigned-clock-rates; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&gpio2 { + u-boot,dm-spl; +}; + +&gpio4 { + u-boot,dm-spl; +}; + +&i2c1 { + u-boot,dm-spl; +}; + +&iomuxc { + u-boot,dm-spl; +}; + +&osc_24m { + u-boot,dm-pre-reloc; + u-boot,dm-spl; +}; + +&pinctrl_i2c1 { + u-boot,dm-spl; +}; + +&pinctrl_pmic { + u-boot,dm-spl; +}; + +&pinctrl_uart4 { + u-boot,dm-spl; +}; + +&pinctrl_wdog { + u-boot,dm-spl; +}; + +&uart4 { + u-boot,dm-spl; +}; + +&wdog1 { + u-boot,dm-spl; +}; + +&binman { + u-boot-spl-ddr { + align = <4>; + align-size = <4>; + filename = "u-boot-spl-ddr.bin"; + pad-byte = <0xff>; + + u-boot-spl { + align-end = <4>; + filename = "u-boot-spl.bin"; + }; + + 1d-imem { + filename = "ddr3_imem_1d.bin"; + size = <0x8000>; + type = "blob-ext"; + }; + + 1d_dmem { + filename = "ddr3_dmem_1d.bin"; + size = <0x4000>; + type = "blob-ext"; + }; + }; + + spl { + filename = "spl.bin"; + + mkimage { + args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x912000"; + + blob { + filename = "u-boot-spl-ddr.bin"; + }; + }; + }; + + itb { + filename = "u-boot.itb"; + + fit { + description = "Configuration to load ATF before U-Boot"; + fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; + fit,fdt-list = "of-list"; + #address-cells = <1>; + + images { + uboot { + arch = "arm64"; + compression = "none"; + description = "U-Boot (64-bit)"; + load = <CONFIG_SYS_TEXT_BASE>; + type = "standalone"; + + uboot_blob { + filename = "u-boot-nodtb.bin"; + type = "blob-ext"; + }; + }; + + atf { + arch = "arm64"; + compression = "none"; + description = "ARM Trusted Firmware"; + entry = <0x960000>; + load = <0x960000>; + type = "firmware"; + + atf_blob { + filename = "bl31.bin"; + type = "blob-ext"; + }; + }; + + binman_fip: fip { + arch = "arm64"; + compression = "none"; + description = "Trusted Firmware FIP"; + load = <0x40310000>; + type = "firmware"; + }; + + @fdt-SEQ { + compression = "none"; + description = "NAME"; + type = "flat_dt"; + + uboot_fdt_blob { + filename = "u-boot.dtb"; + type = "blob-ext"; + }; + }; + }; + + configurations { + default = "@config-DEFAULT-SEQ"; + + binman_configuration: @config-SEQ { + description = "NAME"; + fdt = "fdt-SEQ"; + firmware = "uboot"; + loadables = "atf"; + }; + }; + }; + }; + + imx-boot { + filename = "flash.bin"; + pad-byte = <0x00>; + + spl { + filename = "spl.bin"; + offset = <0x0>; + type = "blob-ext"; + }; + + binman_uboot: uboot { + filename = "u-boot.itb"; + offset = <0x58000>; + type = "blob-ext"; + }; + }; +}; diff --git a/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot.dtsi b/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot.dtsi new file mode 100644 index 0000000000..bd4da7d34c --- /dev/null +++ b/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot.dtsi @@ -0,0 +1,15 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2021 Collabora Ltd. + * Copyright 2021 BSH Hausgeraete GmbH + */ + +#include "imx8mn-bsh-smm-s2-u-boot-common.dtsi" + +&pinctrl_gpmi_nand { + u-boot,dm-spl; +}; + +&gpmi { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx8mn-bsh-smm-s2.dts b/arch/arm/dts/imx8mn-bsh-smm-s2.dts new file mode 100644 index 0000000000..33f98582ea --- /dev/null +++ b/arch/arm/dts/imx8mn-bsh-smm-s2.dts @@ -0,0 +1,48 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2021 Collabora Ltd. + * Copyright 2021 BSH Hausgeraete GmbH + */ + +/dts-v1/; + +#include "imx8mn-bsh-smm-s2-common.dtsi" + +/ { + model = "BSH SMM S2"; + compatible = "bsh,imx8mn-bsh-smm-s2", "fsl,imx8mn"; + + memory@40000000 { + device_type = "memory"; + reg = <0x0 0x40000000 0x0 0x10000000>; + }; +}; + +&gpmi { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpmi_nand>; + nand-on-flash-bbt; + status = "okay"; +}; + +&iomuxc { + pinctrl_gpmi_nand: gpmi-nand { + fsl,pins = < + MX8MN_IOMUXC_NAND_ALE_RAWNAND_ALE 0x00000096 + MX8MN_IOMUXC_NAND_CE0_B_RAWNAND_CE0_B 0x00000096 + MX8MN_IOMUXC_NAND_CLE_RAWNAND_CLE 0x00000096 + MX8MN_IOMUXC_NAND_DATA00_RAWNAND_DATA00 0x00000096 + MX8MN_IOMUXC_NAND_DATA01_RAWNAND_DATA01 0x00000096 + MX8MN_IOMUXC_NAND_DATA02_RAWNAND_DATA02 0x00000096 + MX8MN_IOMUXC_NAND_DATA03_RAWNAND_DATA03 0x00000096 + MX8MN_IOMUXC_NAND_DATA04_RAWNAND_DATA04 0x00000096 + MX8MN_IOMUXC_NAND_DATA05_RAWNAND_DATA05 0x00000096 + MX8MN_IOMUXC_NAND_DATA06_RAWNAND_DATA06 0x00000096 + MX8MN_IOMUXC_NAND_DATA07_RAWNAND_DATA07 0x00000096 + MX8MN_IOMUXC_NAND_RE_B_RAWNAND_RE_B 0x00000096 + MX8MN_IOMUXC_NAND_READY_B_RAWNAND_READY_B 0x00000056 + MX8MN_IOMUXC_NAND_WE_B_RAWNAND_WE_B 0x00000096 + MX8MN_IOMUXC_NAND_WP_B_RAWNAND_WP_B 0x00000096 + >; + }; +}; diff --git a/arch/arm/dts/imx8mn-bsh-smm-s2pro-u-boot.dtsi b/arch/arm/dts/imx8mn-bsh-smm-s2pro-u-boot.dtsi new file mode 100644 index 0000000000..b8396a46b8 --- /dev/null +++ b/arch/arm/dts/imx8mn-bsh-smm-s2pro-u-boot.dtsi @@ -0,0 +1,15 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2021 Collabora Ltd. + * Copyright 2021 BSH Hausgeraete GmbH + */ + +#include "imx8mn-bsh-smm-s2-u-boot-common.dtsi" + +&pinctrl_usdhc1 { + u-boot,dm-spl; +}; + +&usdhc1 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx8mn-bsh-smm-s2pro.dts b/arch/arm/dts/imx8mn-bsh-smm-s2pro.dts new file mode 100644 index 0000000000..c6a8ed6745 --- /dev/null +++ b/arch/arm/dts/imx8mn-bsh-smm-s2pro.dts @@ -0,0 +1,80 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2021 Collabora Ltd. + * Copyright 2021 BSH Hausgeraete GmbH + */ + +/dts-v1/; + +#include "imx8mn-bsh-smm-s2-common.dtsi" + +/ { + model = "BSH SMM S2 PRO"; + compatible = "bsh,imx8mn-bsh-smm-s2pro", "fsl,imx8mn"; + + memory@40000000 { + device_type = "memory"; + reg = <0x0 0x40000000 0x0 0x20000000>; + }; +}; + +/* eMMC */ +&usdhc1 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc1>; + pinctrl-1 = <&pinctrl_usdhc1_100mhz>; + pinctrl-2 = <&pinctrl_usdhc1_200mhz>; + bus-width = <8>; + non-removable; + status = "okay"; +}; + +&iomuxc { + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX8MN_IOMUXC_SD1_CLK_USDHC1_CLK 0x40000090 + MX8MN_IOMUXC_SD1_CMD_USDHC1_CMD 0x0d0 + MX8MN_IOMUXC_SD1_DATA0_USDHC1_DATA0 0x0d0 + MX8MN_IOMUXC_SD1_DATA1_USDHC1_DATA1 0x0d0 + MX8MN_IOMUXC_SD1_DATA2_USDHC1_DATA2 0x0d0 + MX8MN_IOMUXC_SD1_DATA3_USDHC1_DATA3 0x0d0 + MX8MN_IOMUXC_SD1_DATA4_USDHC1_DATA4 0x0d0 + MX8MN_IOMUXC_SD1_DATA5_USDHC1_DATA5 0x0d0 + MX8MN_IOMUXC_SD1_DATA6_USDHC1_DATA6 0x0d0 + MX8MN_IOMUXC_SD1_DATA7_USDHC1_DATA7 0x0d0 + MX8MN_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x090 + >; + }; + + pinctrl_usdhc1_100mhz: usdhc1grp100mhz { + fsl,pins = < + MX8MN_IOMUXC_SD1_CLK_USDHC1_CLK 0x40000094 + MX8MN_IOMUXC_SD1_CMD_USDHC1_CMD 0x0d4 + MX8MN_IOMUXC_SD1_DATA0_USDHC1_DATA0 0x0d4 + MX8MN_IOMUXC_SD1_DATA1_USDHC1_DATA1 0x0d4 + MX8MN_IOMUXC_SD1_DATA2_USDHC1_DATA2 0x0d4 + MX8MN_IOMUXC_SD1_DATA3_USDHC1_DATA3 0x0d4 + MX8MN_IOMUXC_SD1_DATA4_USDHC1_DATA4 0x0d4 + MX8MN_IOMUXC_SD1_DATA5_USDHC1_DATA5 0x0d4 + MX8MN_IOMUXC_SD1_DATA6_USDHC1_DATA6 0x0d4 + MX8MN_IOMUXC_SD1_DATA7_USDHC1_DATA7 0x0d4 + MX8MN_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x094 + >; + }; + + pinctrl_usdhc1_200mhz: usdhc1grp200mhz { + fsl,pins = < + MX8MN_IOMUXC_SD1_CLK_USDHC1_CLK 0x40000096 + MX8MN_IOMUXC_SD1_CMD_USDHC1_CMD 0x0d6 + MX8MN_IOMUXC_SD1_DATA0_USDHC1_DATA0 0x0d6 + MX8MN_IOMUXC_SD1_DATA1_USDHC1_DATA1 0x0d6 + MX8MN_IOMUXC_SD1_DATA2_USDHC1_DATA2 0x0d6 + MX8MN_IOMUXC_SD1_DATA3_USDHC1_DATA3 0x0d6 + MX8MN_IOMUXC_SD1_DATA4_USDHC1_DATA4 0x0d6 + MX8MN_IOMUXC_SD1_DATA5_USDHC1_DATA5 0x0d6 + MX8MN_IOMUXC_SD1_DATA6_USDHC1_DATA6 0x0d6 + MX8MN_IOMUXC_SD1_DATA7_USDHC1_DATA7 0x0d6 + MX8MN_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x096 + >; + }; +}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 276b8bd974..c62f73f95f 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -75,6 +75,20 @@ config TARGET_IMX8MM_VENICE select SUPPORT_SPL select IMX8M_LPDDR4
+config TARGET_IMX8MN_BSH_SMM_S2 + bool "imx8mn-bsh-smm-s2" + select BINMAN + select IMX8MN + select SUPPORT_SPL + select IMX8M_DDR3L + +config TARGET_IMX8MN_BSH_SMM_S2PRO + bool "imx8mn-bsh-smm-s2pro" + select BINMAN + select IMX8MN + select SUPPORT_SPL + select IMX8M_DDR3L + config TARGET_KONTRON_MX8MM bool "Kontron Electronics N80xx" select BINMAN @@ -158,6 +172,7 @@ endchoice
source "board/beacon/imx8mm/Kconfig" source "board/beacon/imx8mn/Kconfig" +source "board/bsh/imx8mn_smm_s2/Kconfig" source "board/compulab/imx8mm-cl-iot-gate/Kconfig" source "board/engicam/imx8mm/Kconfig" source "board/freescale/imx8mq_evk/Kconfig" diff --git a/board/bsh/imx8mn_smm_s2/Kconfig b/board/bsh/imx8mn_smm_s2/Kconfig new file mode 100644 index 0000000000..37fe723e29 --- /dev/null +++ b/board/bsh/imx8mn_smm_s2/Kconfig @@ -0,0 +1,38 @@ +config BSH_SMM_S2_DDR3L_256 + bool "BSH SMM S2 DDR3L 256 MiB RAM support" + +config BSH_SMM_S2_DDR3L_512 + bool "BSH SMM S2 DDR3L 512 MiB RAM support" + +config SYS_BOARD + default "imx8mn_smm_s2" + +config SYS_VENDOR + default "bsh" + +config IMX_CONFIG + default "board/bsh/imx8mn_smm_s2/imximage-8mn-ddr3.cfg" + +if TARGET_IMX8MN_BSH_SMM_S2 + +config SYS_CONFIG_NAME + default "imx8mn_bsh_smm_s2" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select BSH_SMM_S2_DDR3L_256 + +endif + +if TARGET_IMX8MN_BSH_SMM_S2PRO + +config SYS_CONFIG_NAME + default "imx8mn_bsh_smm_s2pro" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select BSH_SMM_S2_DDR3L_512 + +endif + +source "board/freescale/common/Kconfig" diff --git a/board/bsh/imx8mn_smm_s2/MAINTAINERS b/board/bsh/imx8mn_smm_s2/MAINTAINERS new file mode 100644 index 0000000000..1de816ca87 --- /dev/null +++ b/board/bsh/imx8mn_smm_s2/MAINTAINERS @@ -0,0 +1,8 @@ +ARM i.MX8MN BSH SMM S2 BOARDS +M: Ariel D'Alessandro ariel.dalessandro@collabora.com +M: Michael Trimarchi michael@amarulasolutions.com +S: Maintained +F: arch/arm/dts/imx8mn-bsh-smm-s2* +F: board/bsh/imx8mn_smm_s2/ +F: configs/imx8mn_bsh_smm_s2* +F: include/configs/imx8mn_bsh_smm_s2* diff --git a/board/bsh/imx8mn_smm_s2/Makefile b/board/bsh/imx8mn_smm_s2/Makefile new file mode 100644 index 0000000000..19d37a723e --- /dev/null +++ b/board/bsh/imx8mn_smm_s2/Makefile @@ -0,0 +1,13 @@ +# +# Copyright 2021 Collabora Ltd. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += imx8mn_smm_s2.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +obj-$(CONFIG_BSH_SMM_S2_DDR3L_256) += ddr3l_timing_256m.o +obj-$(CONFIG_BSH_SMM_S2_DDR3L_512) += ddr3l_timing_512m.o +endif diff --git a/board/bsh/imx8mn_smm_s2/ddr3l_timing_256m.c b/board/bsh/imx8mn_smm_s2/ddr3l_timing_256m.c new file mode 100644 index 0000000000..0da641834d --- /dev/null +++ b/board/bsh/imx8mn_smm_s2/ddr3l_timing_256m.c @@ -0,0 +1,941 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + * + * Generated code from MX8M_DDR_tool + * + * Align with uboot version: + * imx_v2018.03_4.14.78_1.0.0_ga ~ imx_v2018.04_4.19.35_1.1.0_ga + * For imx_v2019.04_5.4.x and above version: + * please replace #include <asm/arch/imx8m_ddr.h> with #include <asm/arch/ddr.h> + */ + +#include <linux/kernel.h> +#include <asm/arch/ddr.h> + +struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + { 0x3d400304, 0x1 }, + { 0x3d400030, 0x20 }, + { 0x3d400000, 0xa1040001 }, + { 0x3d400064, 0x610040 }, + { 0x3d4000d0, 0xc00200c5 }, + { 0x3d4000d4, 0x1000b }, + { 0x3d4000dc, 0x1d700004 }, + { 0x3d4000e0, 0x180000 }, + { 0x3d4000e4, 0x90000 }, + { 0x3d4000f0, 0x0 }, + { 0x3d4000f4, 0xee5 }, + { 0x3d400100, 0xc101b0e }, + { 0x3d400104, 0x30314 }, + { 0x3d400108, 0x4060509 }, + { 0x3d40010c, 0x2006 }, + { 0x3d400110, 0x6020306 }, + { 0x3d400114, 0x4040302 }, + { 0x3d400120, 0x909 }, + { 0x3d400180, 0x40800020 }, + { 0x3d400184, 0xc350 }, + { 0x3d400190, 0x3868203 }, + { 0x3d400194, 0x20303 }, + { 0x3d4001b4, 0x603 }, + { 0x3d400198, 0x7000000 }, + { 0x3d4001b0, 0x11 }, + { 0x3d4001a0, 0x400018 }, + { 0x3d4001a4, 0x5003c }, + { 0x3d4001a8, 0x80000000 }, + { 0x3d4001c4, 0x0 }, + { 0x3d400200, 0x1f }, + { 0x3d400204, 0x80808 }, + { 0x3d400208, 0x0 }, + { 0x3d40020c, 0x0 }, + { 0x3d400210, 0x1f1f }, + { 0x3d400214, 0x7070707 }, + { 0x3d400218, 0xf0f0707 }, + { 0x3d400240, 0x600060c }, + { 0x3d400244, 0x1323 }, + { 0x3d400400, 0x100 }, + { 0x3d400250, 0x7ab50b07 }, + { 0x3d400254, 0x22 }, + { 0x3d40025c, 0x7b00665e }, + { 0x3d400264, 0xb0000040 }, + { 0x3d40026c, 0x50000a0c }, + { 0x3d400300, 0x17 }, + { 0x3d40036c, 0x10000 }, + { 0x3d400404, 0x3051 }, + { 0x3d400408, 0x61d2 }, + { 0x3d400494, 0xe00 }, + { 0x3d400498, 0x7ff }, + { 0x3d40049c, 0xe00 }, + { 0x3d4004a0, 0x7ff }, + { 0x3d402064, 0x28001b }, + { 0x3d4020dc, 0x12200004 }, + { 0x3d4020e0, 0x0 }, + { 0x3d402100, 0x7090b07 }, + { 0x3d402104, 0x20209 }, + { 0x3d402108, 0x3030407 }, + { 0x3d40210c, 0x2006 }, + { 0x3d402110, 0x3020203 }, + { 0x3d402114, 0x3030202 }, + { 0x3d402120, 0x909 }, + { 0x3d402180, 0x40800020 }, + { 0x3d402190, 0x3818200 }, + { 0x3d402194, 0x20303 }, + { 0x3d4021b4, 0x100 }, + { 0x3d402240, 0x6000604 }, + { 0x3d4020f4, 0xee5 }, + { 0x3d400028, 0x1 }, +}; + +/* PHY Initialize Configuration */ +struct dram_cfg_param ddr_ddrphy_cfg[] = { + { 0x1005f, 0x3ff }, + { 0x1015f, 0x3ff }, + { 0x1105f, 0x3ff }, + { 0x1115f, 0x3ff }, + { 0x11005f, 0x3ff }, + { 0x11015f, 0x3ff }, + { 0x11105f, 0x3ff }, + { 0x11115f, 0x3ff }, + { 0x55, 0x3ff }, + { 0x1055, 0x3ff }, + { 0x2055, 0x3ff }, + { 0x3055, 0x3ff }, + { 0x4055, 0xff }, + { 0x5055, 0xff }, + { 0x6055, 0x3ff }, + { 0x7055, 0x3ff }, + { 0x8055, 0x3ff }, + { 0x9055, 0x3ff }, + { 0x200c5, 0xb }, + { 0x1200c5, 0x7 }, + { 0x2002e, 0x1 }, + { 0x12002e, 0x1 }, + { 0x20024, 0x0 }, + { 0x2003a, 0x0 }, + { 0x120024, 0x0 }, + { 0x2003a, 0x0 }, + { 0x20056, 0xa }, + { 0x120056, 0xa }, + { 0x1004d, 0x208 }, + { 0x1014d, 0x208 }, + { 0x1104d, 0x208 }, + { 0x1114d, 0x208 }, + { 0x11004d, 0x208 }, + { 0x11014d, 0x208 }, + { 0x11104d, 0x208 }, + { 0x11114d, 0x208 }, + { 0x10049, 0xe38 }, + { 0x10149, 0xe38 }, + { 0x11049, 0xe38 }, + { 0x11149, 0xe38 }, + { 0x110049, 0xe38 }, + { 0x110149, 0xe38 }, + { 0x111049, 0xe38 }, + { 0x111149, 0xe38 }, + { 0x43, 0x63 }, + { 0x1043, 0x63 }, + { 0x2043, 0x63 }, + { 0x3043, 0x63 }, + { 0x4043, 0x63 }, + { 0x5043, 0x63 }, + { 0x6043, 0x63 }, + { 0x7043, 0x63 }, + { 0x8043, 0x63 }, + { 0x9043, 0x63 }, + { 0x20018, 0x1 }, + { 0x20075, 0x0 }, + { 0x20050, 0x0 }, + { 0x20008, 0x190 }, + { 0x120008, 0xa7 }, + { 0x20088, 0x9 }, + { 0x200b2, 0x32c }, + { 0x10043, 0x581 }, + { 0x10143, 0x581 }, + { 0x11043, 0x581 }, + { 0x11143, 0x581 }, + { 0x1200b2, 0x32c }, + { 0x110043, 0x581 }, + { 0x110143, 0x581 }, + { 0x111043, 0x581 }, + { 0x111143, 0x581 }, + { 0x200fa, 0x1 }, + { 0x1200fa, 0x1 }, + { 0x20019, 0x5 }, + { 0x120019, 0x5 }, + { 0x200f0, 0x5555 }, + { 0x200f1, 0x5555 }, + { 0x200f2, 0x5555 }, + { 0x200f3, 0x5555 }, + { 0x200f4, 0x5555 }, + { 0x200f5, 0x5555 }, + { 0x200f6, 0x5555 }, + { 0x200f7, 0xf000 }, + { 0x20025, 0x0 }, + { 0x2007d, 0x212 }, + { 0x12007d, 0x212 }, + { 0x2007c, 0x61 }, + { 0x12007c, 0x61 }, + { 0x1004a, 0x500 }, + { 0x1104a, 0x500 }, + { 0x2002c, 0x0 }, +}; + +/* ddr phy trained csr */ +struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + {0x0200b2, 0x0}, + {0x1200b2, 0x0}, + {0x2200b2, 0x0}, + {0x0200cb, 0x0}, + {0x010043, 0x0}, + {0x110043, 0x0}, + {0x210043, 0x0}, + {0x010143, 0x0}, + {0x110143, 0x0}, + {0x210143, 0x0}, + {0x011043, 0x0}, + {0x111043, 0x0}, + {0x211043, 0x0}, + {0x011143, 0x0}, + {0x111143, 0x0}, + {0x211143, 0x0}, + {0x000080, 0x0}, + {0x100080, 0x0}, + {0x200080, 0x0}, + {0x001080, 0x0}, + {0x101080, 0x0}, + {0x201080, 0x0}, + {0x002080, 0x0}, + {0x102080, 0x0}, + {0x202080, 0x0}, + {0x003080, 0x0}, + {0x103080, 0x0}, + {0x203080, 0x0}, + {0x004080, 0x0}, + {0x104080, 0x0}, + {0x204080, 0x0}, + {0x005080, 0x0}, + {0x105080, 0x0}, + {0x205080, 0x0}, + {0x006080, 0x0}, + {0x106080, 0x0}, + {0x206080, 0x0}, + {0x007080, 0x0}, + {0x107080, 0x0}, + {0x207080, 0x0}, + {0x008080, 0x0}, + {0x108080, 0x0}, + {0x208080, 0x0}, + {0x009080, 0x0}, + {0x109080, 0x0}, + {0x209080, 0x0}, + {0x010080, 0x0}, + {0x110080, 0x0}, + {0x210080, 0x0}, + {0x010180, 0x0}, + {0x110180, 0x0}, + {0x210180, 0x0}, + {0x010081, 0x0}, + {0x110081, 0x0}, + {0x210081, 0x0}, + {0x010181, 0x0}, + {0x110181, 0x0}, + {0x210181, 0x0}, + {0x010082, 0x0}, + {0x110082, 0x0}, + {0x210082, 0x0}, + {0x010182, 0x0}, + {0x110182, 0x0}, + {0x210182, 0x0}, + {0x010083, 0x0}, + {0x110083, 0x0}, + {0x210083, 0x0}, + {0x010183, 0x0}, + {0x110183, 0x0}, + {0x210183, 0x0}, + {0x011080, 0x0}, + {0x111080, 0x0}, + {0x211080, 0x0}, + {0x011180, 0x0}, + {0x111180, 0x0}, + {0x211180, 0x0}, + {0x011081, 0x0}, + {0x111081, 0x0}, + {0x211081, 0x0}, + {0x011181, 0x0}, + {0x111181, 0x0}, + {0x211181, 0x0}, + {0x011082, 0x0}, + {0x111082, 0x0}, + {0x211082, 0x0}, + {0x011182, 0x0}, + {0x111182, 0x0}, + {0x211182, 0x0}, + {0x011083, 0x0}, + {0x111083, 0x0}, + {0x211083, 0x0}, + {0x011183, 0x0}, + {0x111183, 0x0}, + {0x211183, 0x0}, + {0x0100d0, 0x0}, + {0x1100d0, 0x0}, + {0x2100d0, 0x0}, + {0x0101d0, 0x0}, + {0x1101d0, 0x0}, + {0x2101d0, 0x0}, + {0x0100d1, 0x0}, + {0x1100d1, 0x0}, + {0x2100d1, 0x0}, + {0x0101d1, 0x0}, + {0x1101d1, 0x0}, + {0x2101d1, 0x0}, + {0x0100d2, 0x0}, + {0x1100d2, 0x0}, + {0x2100d2, 0x0}, + {0x0101d2, 0x0}, + {0x1101d2, 0x0}, + {0x2101d2, 0x0}, + {0x0100d3, 0x0}, + {0x1100d3, 0x0}, + {0x2100d3, 0x0}, + {0x0101d3, 0x0}, + {0x1101d3, 0x0}, + {0x2101d3, 0x0}, + {0x0110d0, 0x0}, + {0x1110d0, 0x0}, + {0x2110d0, 0x0}, + {0x0111d0, 0x0}, + {0x1111d0, 0x0}, + {0x2111d0, 0x0}, + {0x0110d1, 0x0}, + {0x1110d1, 0x0}, + {0x2110d1, 0x0}, + {0x0111d1, 0x0}, + {0x1111d1, 0x0}, + {0x2111d1, 0x0}, + {0x0110d2, 0x0}, + {0x1110d2, 0x0}, + {0x2110d2, 0x0}, + {0x0111d2, 0x0}, + {0x1111d2, 0x0}, + {0x2111d2, 0x0}, + {0x0110d3, 0x0}, + {0x1110d3, 0x0}, + {0x2110d3, 0x0}, + {0x0111d3, 0x0}, + {0x1111d3, 0x0}, + {0x2111d3, 0x0}, + {0x010068, 0x0}, + {0x010168, 0x0}, + {0x010268, 0x0}, + {0x010368, 0x0}, + {0x010468, 0x0}, + {0x010568, 0x0}, + {0x010668, 0x0}, + {0x010768, 0x0}, + {0x010868, 0x0}, + {0x010069, 0x0}, + {0x010169, 0x0}, + {0x010269, 0x0}, + {0x010369, 0x0}, + {0x010469, 0x0}, + {0x010569, 0x0}, + {0x010669, 0x0}, + {0x010769, 0x0}, + {0x010869, 0x0}, + {0x01006a, 0x0}, + {0x01016a, 0x0}, + {0x01026a, 0x0}, + {0x01036a, 0x0}, + {0x01046a, 0x0}, + {0x01056a, 0x0}, + {0x01066a, 0x0}, + {0x01076a, 0x0}, + {0x01086a, 0x0}, + {0x01006b, 0x0}, + {0x01016b, 0x0}, + {0x01026b, 0x0}, + {0x01036b, 0x0}, + {0x01046b, 0x0}, + {0x01056b, 0x0}, + {0x01066b, 0x0}, + {0x01076b, 0x0}, + {0x01086b, 0x0}, + {0x011068, 0x0}, + {0x011168, 0x0}, + {0x011268, 0x0}, + {0x011368, 0x0}, + {0x011468, 0x0}, + {0x011568, 0x0}, + {0x011668, 0x0}, + {0x011768, 0x0}, + {0x011868, 0x0}, + {0x011069, 0x0}, + {0x011169, 0x0}, + {0x011269, 0x0}, + {0x011369, 0x0}, + {0x011469, 0x0}, + {0x011569, 0x0}, + {0x011669, 0x0}, + {0x011769, 0x0}, + {0x011869, 0x0}, + {0x01106a, 0x0}, + {0x01116a, 0x0}, + {0x01126a, 0x0}, + {0x01136a, 0x0}, + {0x01146a, 0x0}, + {0x01156a, 0x0}, + {0x01166a, 0x0}, + {0x01176a, 0x0}, + {0x01186a, 0x0}, + {0x01106b, 0x0}, + {0x01116b, 0x0}, + {0x01126b, 0x0}, + {0x01136b, 0x0}, + {0x01146b, 0x0}, + {0x01156b, 0x0}, + {0x01166b, 0x0}, + {0x01176b, 0x0}, + {0x01186b, 0x0}, + {0x01008c, 0x0}, + {0x11008c, 0x0}, + {0x21008c, 0x0}, + {0x01018c, 0x0}, + {0x11018c, 0x0}, + {0x21018c, 0x0}, + {0x01008d, 0x0}, + {0x11008d, 0x0}, + {0x21008d, 0x0}, + {0x01018d, 0x0}, + {0x11018d, 0x0}, + {0x21018d, 0x0}, + {0x01008e, 0x0}, + {0x11008e, 0x0}, + {0x21008e, 0x0}, + {0x01018e, 0x0}, + {0x11018e, 0x0}, + {0x21018e, 0x0}, + {0x01008f, 0x0}, + {0x11008f, 0x0}, + {0x21008f, 0x0}, + {0x01018f, 0x0}, + {0x11018f, 0x0}, + {0x21018f, 0x0}, + {0x01108c, 0x0}, + {0x11108c, 0x0}, + {0x21108c, 0x0}, + {0x01118c, 0x0}, + {0x11118c, 0x0}, + {0x21118c, 0x0}, + {0x01108d, 0x0}, + {0x11108d, 0x0}, + {0x21108d, 0x0}, + {0x01118d, 0x0}, + {0x11118d, 0x0}, + {0x21118d, 0x0}, + {0x01108e, 0x0}, + {0x11108e, 0x0}, + {0x21108e, 0x0}, + {0x01118e, 0x0}, + {0x11118e, 0x0}, + {0x21118e, 0x0}, + {0x01108f, 0x0}, + {0x11108f, 0x0}, + {0x21108f, 0x0}, + {0x01118f, 0x0}, + {0x11118f, 0x0}, + {0x21118f, 0x0}, + {0x0100c0, 0x0}, + {0x1100c0, 0x0}, + {0x2100c0, 0x0}, + {0x0101c0, 0x0}, + {0x1101c0, 0x0}, + {0x2101c0, 0x0}, + {0x0102c0, 0x0}, + {0x1102c0, 0x0}, + {0x2102c0, 0x0}, + {0x0103c0, 0x0}, + {0x1103c0, 0x0}, + {0x2103c0, 0x0}, + {0x0104c0, 0x0}, + {0x1104c0, 0x0}, + {0x2104c0, 0x0}, + {0x0105c0, 0x0}, + {0x1105c0, 0x0}, + {0x2105c0, 0x0}, + {0x0106c0, 0x0}, + {0x1106c0, 0x0}, + {0x2106c0, 0x0}, + {0x0107c0, 0x0}, + {0x1107c0, 0x0}, + {0x2107c0, 0x0}, + {0x0108c0, 0x0}, + {0x1108c0, 0x0}, + {0x2108c0, 0x0}, + {0x0100c1, 0x0}, + {0x1100c1, 0x0}, + {0x2100c1, 0x0}, + {0x0101c1, 0x0}, + {0x1101c1, 0x0}, + {0x2101c1, 0x0}, + {0x0102c1, 0x0}, + {0x1102c1, 0x0}, + {0x2102c1, 0x0}, + {0x0103c1, 0x0}, + {0x1103c1, 0x0}, + {0x2103c1, 0x0}, + {0x0104c1, 0x0}, + {0x1104c1, 0x0}, + {0x2104c1, 0x0}, + {0x0105c1, 0x0}, + {0x1105c1, 0x0}, + {0x2105c1, 0x0}, + {0x0106c1, 0x0}, + {0x1106c1, 0x0}, + {0x2106c1, 0x0}, + {0x0107c1, 0x0}, + {0x1107c1, 0x0}, + {0x2107c1, 0x0}, + {0x0108c1, 0x0}, + {0x1108c1, 0x0}, + {0x2108c1, 0x0}, + {0x0100c2, 0x0}, + {0x1100c2, 0x0}, + {0x2100c2, 0x0}, + {0x0101c2, 0x0}, + {0x1101c2, 0x0}, + {0x2101c2, 0x0}, + {0x0102c2, 0x0}, + {0x1102c2, 0x0}, + {0x2102c2, 0x0}, + {0x0103c2, 0x0}, + {0x1103c2, 0x0}, + {0x2103c2, 0x0}, + {0x0104c2, 0x0}, + {0x1104c2, 0x0}, + {0x2104c2, 0x0}, + {0x0105c2, 0x0}, + {0x1105c2, 0x0}, + {0x2105c2, 0x0}, + {0x0106c2, 0x0}, + {0x1106c2, 0x0}, + {0x2106c2, 0x0}, + {0x0107c2, 0x0}, + {0x1107c2, 0x0}, + {0x2107c2, 0x0}, + {0x0108c2, 0x0}, + {0x1108c2, 0x0}, + {0x2108c2, 0x0}, + {0x0100c3, 0x0}, + {0x1100c3, 0x0}, + {0x2100c3, 0x0}, + {0x0101c3, 0x0}, + {0x1101c3, 0x0}, + {0x2101c3, 0x0}, + {0x0102c3, 0x0}, + {0x1102c3, 0x0}, + {0x2102c3, 0x0}, + {0x0103c3, 0x0}, + {0x1103c3, 0x0}, + {0x2103c3, 0x0}, + {0x0104c3, 0x0}, + {0x1104c3, 0x0}, + {0x2104c3, 0x0}, + {0x0105c3, 0x0}, + {0x1105c3, 0x0}, + {0x2105c3, 0x0}, + {0x0106c3, 0x0}, + {0x1106c3, 0x0}, + {0x2106c3, 0x0}, + {0x0107c3, 0x0}, + {0x1107c3, 0x0}, + {0x2107c3, 0x0}, + {0x0108c3, 0x0}, + {0x1108c3, 0x0}, + {0x2108c3, 0x0}, + {0x0110c0, 0x0}, + {0x1110c0, 0x0}, + {0x2110c0, 0x0}, + {0x0111c0, 0x0}, + {0x1111c0, 0x0}, + {0x2111c0, 0x0}, + {0x0112c0, 0x0}, + {0x1112c0, 0x0}, + {0x2112c0, 0x0}, + {0x0113c0, 0x0}, + {0x1113c0, 0x0}, + {0x2113c0, 0x0}, + {0x0114c0, 0x0}, + {0x1114c0, 0x0}, + {0x2114c0, 0x0}, + {0x0115c0, 0x0}, + {0x1115c0, 0x0}, + {0x2115c0, 0x0}, + {0x0116c0, 0x0}, + {0x1116c0, 0x0}, + {0x2116c0, 0x0}, + {0x0117c0, 0x0}, + {0x1117c0, 0x0}, + {0x2117c0, 0x0}, + {0x0118c0, 0x0}, + {0x1118c0, 0x0}, + {0x2118c0, 0x0}, + {0x0110c1, 0x0}, + {0x1110c1, 0x0}, + {0x2110c1, 0x0}, + {0x0111c1, 0x0}, + {0x1111c1, 0x0}, + {0x2111c1, 0x0}, + {0x0112c1, 0x0}, + {0x1112c1, 0x0}, + {0x2112c1, 0x0}, + {0x0113c1, 0x0}, + {0x1113c1, 0x0}, + {0x2113c1, 0x0}, + {0x0114c1, 0x0}, + {0x1114c1, 0x0}, + {0x2114c1, 0x0}, + {0x0115c1, 0x0}, + {0x1115c1, 0x0}, + {0x2115c1, 0x0}, + {0x0116c1, 0x0}, + {0x1116c1, 0x0}, + {0x2116c1, 0x0}, + {0x0117c1, 0x0}, + {0x1117c1, 0x0}, + {0x2117c1, 0x0}, + {0x0118c1, 0x0}, + {0x1118c1, 0x0}, + {0x2118c1, 0x0}, + {0x0110c2, 0x0}, + {0x1110c2, 0x0}, + {0x2110c2, 0x0}, + {0x0111c2, 0x0}, + {0x1111c2, 0x0}, + {0x2111c2, 0x0}, + {0x0112c2, 0x0}, + {0x1112c2, 0x0}, + {0x2112c2, 0x0}, + {0x0113c2, 0x0}, + {0x1113c2, 0x0}, + {0x2113c2, 0x0}, + {0x0114c2, 0x0}, + {0x1114c2, 0x0}, + {0x2114c2, 0x0}, + {0x0115c2, 0x0}, + {0x1115c2, 0x0}, + {0x2115c2, 0x0}, + {0x0116c2, 0x0}, + {0x1116c2, 0x0}, + {0x2116c2, 0x0}, + {0x0117c2, 0x0}, + {0x1117c2, 0x0}, + {0x2117c2, 0x0}, + {0x0118c2, 0x0}, + {0x1118c2, 0x0}, + {0x2118c2, 0x0}, + {0x0110c3, 0x0}, + {0x1110c3, 0x0}, + {0x2110c3, 0x0}, + {0x0111c3, 0x0}, + {0x1111c3, 0x0}, + {0x2111c3, 0x0}, + {0x0112c3, 0x0}, + {0x1112c3, 0x0}, + {0x2112c3, 0x0}, + {0x0113c3, 0x0}, + {0x1113c3, 0x0}, + {0x2113c3, 0x0}, + {0x0114c3, 0x0}, + {0x1114c3, 0x0}, + {0x2114c3, 0x0}, + {0x0115c3, 0x0}, + {0x1115c3, 0x0}, + {0x2115c3, 0x0}, + {0x0116c3, 0x0}, + {0x1116c3, 0x0}, + {0x2116c3, 0x0}, + {0x0117c3, 0x0}, + {0x1117c3, 0x0}, + {0x2117c3, 0x0}, + {0x0118c3, 0x0}, + {0x1118c3, 0x0}, + {0x2118c3, 0x0}, + {0x010020, 0x0}, + {0x110020, 0x0}, + {0x210020, 0x0}, + {0x011020, 0x0}, + {0x111020, 0x0}, + {0x211020, 0x0}, + {0x02007d, 0x0}, + {0x12007d, 0x0}, + {0x22007d, 0x0}, +}; + +/* P0 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0x640 }, + { 0x54004, 0x2 }, + { 0x54005, 0x283c }, + { 0x54006, 0x140 }, + { 0x54007, 0x1000 }, + { 0x54008, 0x101 }, + { 0x5400b, 0x31f }, + { 0x5400c, 0xc8 }, + { 0x54012, 0x1 }, + { 0x5402f, 0x1d70 }, + { 0x54030, 0x4 }, + { 0x54031, 0x18 }, + { 0x5403a, 0x1323 }, + { 0xd0000, 0x1 }, +}; + +/* P1 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp1_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x1 }, + { 0x54003, 0x29c }, + { 0x54004, 0x2 }, + { 0x54005, 0x283c }, + { 0x54006, 0x140 }, + { 0x54007, 0x1000 }, + { 0x54008, 0x101 }, + { 0x5400b, 0x21f }, + { 0x5400c, 0xc8 }, + { 0x54012, 0x1 }, + { 0x5402f, 0x1220 }, + { 0x54030, 0x4 }, + { 0x5403a, 0x1323 }, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +struct dram_cfg_param ddr_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x2 }, + { 0x90033, 0x10 }, + { 0x90034, 0x139 }, + { 0x90035, 0xb }, + { 0x90036, 0x7c0 }, + { 0x90037, 0x139 }, + { 0x90038, 0x44 }, + { 0x90039, 0x633 }, + { 0x9003a, 0x159 }, + { 0x9003b, 0x14f }, + { 0x9003c, 0x630 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x47 }, + { 0x9003f, 0x633 }, + { 0x90040, 0x149 }, + { 0x90041, 0x4f }, + { 0x90042, 0x633 }, + { 0x90043, 0x179 }, + { 0x90044, 0x8 }, + { 0x90045, 0xe0 }, + { 0x90046, 0x109 }, + { 0x90047, 0x0 }, + { 0x90048, 0x7c8 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x1 }, + { 0x9004c, 0x8 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x45a }, + { 0x9004f, 0x9 }, + { 0x90050, 0x0 }, + { 0x90051, 0x448 }, + { 0x90052, 0x109 }, + { 0x90053, 0x40 }, + { 0x90054, 0x633 }, + { 0x90055, 0x179 }, + { 0x90056, 0x1 }, + { 0x90057, 0x618 }, + { 0x90058, 0x109 }, + { 0x90059, 0x40c0 }, + { 0x9005a, 0x633 }, + { 0x9005b, 0x149 }, + { 0x9005c, 0x8 }, + { 0x9005d, 0x4 }, + { 0x9005e, 0x48 }, + { 0x9005f, 0x4040 }, + { 0x90060, 0x633 }, + { 0x90061, 0x149 }, + { 0x90062, 0x0 }, + { 0x90063, 0x4 }, + { 0x90064, 0x48 }, + { 0x90065, 0x40 }, + { 0x90066, 0x633 }, + { 0x90067, 0x149 }, + { 0x90068, 0x10 }, + { 0x90069, 0x4 }, + { 0x9006a, 0x18 }, + { 0x9006b, 0x0 }, + { 0x9006c, 0x4 }, + { 0x9006d, 0x78 }, + { 0x9006e, 0x549 }, + { 0x9006f, 0x633 }, + { 0x90070, 0x159 }, + { 0x90071, 0xd49 }, + { 0x90072, 0x633 }, + { 0x90073, 0x159 }, + { 0x90074, 0x94a }, + { 0x90075, 0x633 }, + { 0x90076, 0x159 }, + { 0x90077, 0x441 }, + { 0x90078, 0x633 }, + { 0x90079, 0x149 }, + { 0x9007a, 0x42 }, + { 0x9007b, 0x633 }, + { 0x9007c, 0x149 }, + { 0x9007d, 0x1 }, + { 0x9007e, 0x633 }, + { 0x9007f, 0x149 }, + { 0x90080, 0x0 }, + { 0x90081, 0xe0 }, + { 0x90082, 0x109 }, + { 0x90083, 0xa }, + { 0x90084, 0x10 }, + { 0x90085, 0x109 }, + { 0x90086, 0x9 }, + { 0x90087, 0x3c0 }, + { 0x90088, 0x149 }, + { 0x90089, 0x9 }, + { 0x9008a, 0x3c0 }, + { 0x9008b, 0x159 }, + { 0x9008c, 0x18 }, + { 0x9008d, 0x10 }, + { 0x9008e, 0x109 }, + { 0x9008f, 0x0 }, + { 0x90090, 0x3c0 }, + { 0x90091, 0x109 }, + { 0x90092, 0x18 }, + { 0x90093, 0x4 }, + { 0x90094, 0x48 }, + { 0x90095, 0x18 }, + { 0x90096, 0x4 }, + { 0x90097, 0x58 }, + { 0x90098, 0xb }, + { 0x90099, 0x10 }, + { 0x9009a, 0x109 }, + { 0x9009b, 0x1 }, + { 0x9009c, 0x10 }, + { 0x9009d, 0x109 }, + { 0x9009e, 0x5 }, + { 0x9009f, 0x7c0 }, + { 0x900a0, 0x109 }, + { 0x900a1, 0x0 }, + { 0x900a2, 0x8140 }, + { 0x900a3, 0x10c }, + { 0x900a4, 0x10 }, + { 0x900a5, 0x8138 }, + { 0x900a6, 0x10c }, + { 0x900a7, 0x8 }, + { 0x900a8, 0x7c8 }, + { 0x900a9, 0x101 }, + { 0x900aa, 0x8 }, + { 0x900ab, 0x448 }, + { 0x900ac, 0x109 }, + { 0x900ad, 0xf }, + { 0x900ae, 0x7c0 }, + { 0x900af, 0x109 }, + { 0x900b0, 0x47 }, + { 0x900b1, 0x630 }, + { 0x900b2, 0x109 }, + { 0x900b3, 0x8 }, + { 0x900b4, 0x618 }, + { 0x900b5, 0x109 }, + { 0x900b6, 0x8 }, + { 0x900b7, 0xe0 }, + { 0x900b8, 0x109 }, + { 0x900b9, 0x0 }, + { 0x900ba, 0x7c8 }, + { 0x900bb, 0x109 }, + { 0x900bc, 0x8 }, + { 0x900bd, 0x8140 }, + { 0x900be, 0x10c }, + { 0x900bf, 0x0 }, + { 0x900c0, 0x1 }, + { 0x900c1, 0x8 }, + { 0x900c2, 0x8 }, + { 0x900c3, 0x4 }, + { 0x900c4, 0x8 }, + { 0x900c5, 0x8 }, + { 0x900c6, 0x7c8 }, + { 0x900c7, 0x101 }, + { 0x90006, 0x0 }, + { 0x90007, 0x0 }, + { 0x90008, 0x8 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x0 }, + { 0x9000b, 0x0 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x90026, 0x2b }, + { 0x2000b, 0x32 }, + { 0x2000c, 0x64 }, + { 0x2000d, 0x3e8 }, + { 0x2000e, 0x2c }, + { 0x12000b, 0x14 }, + { 0x12000c, 0x26 }, + { 0x12000d, 0x1a1 }, + { 0x12000e, 0x10 }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0xffff }, + { 0x90013, 0x6152 }, + { 0x20089, 0x1 }, + { 0x20088, 0x19 }, + { 0xc0080, 0x0 }, + { 0xd0000, 0x1 } +}; + +struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 1600mts 1D */ + .drate = 1600, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 667mts 1D */ + .drate = 667, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 1600, 667, }, +}; diff --git a/board/bsh/imx8mn_smm_s2/ddr3l_timing_512m.c b/board/bsh/imx8mn_smm_s2/ddr3l_timing_512m.c new file mode 100644 index 0000000000..f845395ad9 --- /dev/null +++ b/board/bsh/imx8mn_smm_s2/ddr3l_timing_512m.c @@ -0,0 +1,941 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + * + * Generated code from MX8M_DDR_tool + * + * Align with uboot version: + * imx_v2018.03_4.14.78_1.0.0_ga ~ imx_v2018.04_4.19.35_1.1.0_ga + * For imx_v2019.04_5.4.x and above version: + * please replace #include <asm/arch/imx8m_ddr.h> with #include <asm/arch/ddr.h> + */ + +#include <linux/kernel.h> +#include <asm/arch/ddr.h> + +struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + { 0x3d400304, 0x1 }, + { 0x3d400030, 0x20 }, + { 0x3d400000, 0xa1040001 }, + { 0x3d400064, 0x610068 }, + { 0x3d4000d0, 0xc00200c5 }, + { 0x3d4000d4, 0x1000b }, + { 0x3d4000dc, 0x1d700004 }, + { 0x3d4000e0, 0x180000 }, + { 0x3d4000e4, 0x90000 }, + { 0x3d4000f0, 0x0 }, + { 0x3d4000f4, 0xee5 }, + { 0x3d400100, 0xc101b0e }, + { 0x3d400104, 0x30314 }, + { 0x3d400108, 0x4060509 }, + { 0x3d40010c, 0x2006 }, + { 0x3d400110, 0x6020306 }, + { 0x3d400114, 0x4040302 }, + { 0x3d400120, 0x909 }, + { 0x3d400180, 0x40800020 }, + { 0x3d400184, 0xc350 }, + { 0x3d400190, 0x3868203 }, + { 0x3d400194, 0x20303 }, + { 0x3d4001b4, 0x603 }, + { 0x3d400198, 0x7000000 }, + { 0x3d4001b0, 0x11 }, + { 0x3d4001a0, 0x400018 }, + { 0x3d4001a4, 0x5003c }, + { 0x3d4001a8, 0x80000000 }, + { 0x3d4001c4, 0x0 }, + { 0x3d400200, 0x1f }, + { 0x3d400204, 0x80808 }, + { 0x3d400208, 0x0 }, + { 0x3d40020c, 0x0 }, + { 0x3d400210, 0x1f1f }, + { 0x3d400214, 0x7070707 }, + { 0x3d400218, 0xf070707 }, + { 0x3d400240, 0x600060c }, + { 0x3d400244, 0x1323 }, + { 0x3d400400, 0x100 }, + { 0x3d400250, 0x7ab50b07 }, + { 0x3d400254, 0x22 }, + { 0x3d40025c, 0x7b00665e }, + { 0x3d400264, 0xb0000040 }, + { 0x3d40026c, 0x50000a0c }, + { 0x3d400300, 0x17 }, + { 0x3d40036c, 0x10000 }, + { 0x3d400404, 0x3051 }, + { 0x3d400408, 0x61d2 }, + { 0x3d400494, 0xe00 }, + { 0x3d400498, 0x7ff }, + { 0x3d40049c, 0xe00 }, + { 0x3d4004a0, 0x7ff }, + { 0x3d402064, 0x28003c }, + { 0x3d4020dc, 0x12200004 }, + { 0x3d4020e0, 0x0 }, + { 0x3d402100, 0x7090b07 }, + { 0x3d402104, 0x20209 }, + { 0x3d402108, 0x3030407 }, + { 0x3d40210c, 0x2006 }, + { 0x3d402110, 0x3020203 }, + { 0x3d402114, 0x3030202 }, + { 0x3d402120, 0x909 }, + { 0x3d402180, 0x40800020 }, + { 0x3d402190, 0x3818200 }, + { 0x3d402194, 0x20303 }, + { 0x3d4021b4, 0x100 }, + { 0x3d402240, 0x6000604 }, + { 0x3d4020f4, 0xee5 }, + { 0x3d400028, 0x1 }, +}; + +/* PHY Initialize Configuration */ +struct dram_cfg_param ddr_ddrphy_cfg[] = { + { 0x1005f, 0x3ff }, + { 0x1015f, 0x3ff }, + { 0x1105f, 0x3ff }, + { 0x1115f, 0x3ff }, + { 0x11005f, 0x3ff }, + { 0x11015f, 0x3ff }, + { 0x11105f, 0x3ff }, + { 0x11115f, 0x3ff }, + { 0x55, 0x3ff }, + { 0x1055, 0x3ff }, + { 0x2055, 0x3ff }, + { 0x3055, 0x3ff }, + { 0x4055, 0xff }, + { 0x5055, 0xff }, + { 0x6055, 0x3ff }, + { 0x7055, 0x3ff }, + { 0x8055, 0x3ff }, + { 0x9055, 0x3ff }, + { 0x200c5, 0xb }, + { 0x1200c5, 0x7 }, + { 0x2002e, 0x1 }, + { 0x12002e, 0x1 }, + { 0x20024, 0x0 }, + { 0x2003a, 0x0 }, + { 0x120024, 0x0 }, + { 0x2003a, 0x0 }, + { 0x20056, 0xa }, + { 0x120056, 0xa }, + { 0x1004d, 0x208 }, + { 0x1014d, 0x208 }, + { 0x1104d, 0x208 }, + { 0x1114d, 0x208 }, + { 0x11004d, 0x208 }, + { 0x11014d, 0x208 }, + { 0x11104d, 0x208 }, + { 0x11114d, 0x208 }, + { 0x10049, 0xe38 }, + { 0x10149, 0xe38 }, + { 0x11049, 0xe38 }, + { 0x11149, 0xe38 }, + { 0x110049, 0xe38 }, + { 0x110149, 0xe38 }, + { 0x111049, 0xe38 }, + { 0x111149, 0xe38 }, + { 0x43, 0x63 }, + { 0x1043, 0x63 }, + { 0x2043, 0x63 }, + { 0x3043, 0x63 }, + { 0x4043, 0x63 }, + { 0x5043, 0x63 }, + { 0x6043, 0x63 }, + { 0x7043, 0x63 }, + { 0x8043, 0x63 }, + { 0x9043, 0x63 }, + { 0x20018, 0x1 }, + { 0x20075, 0x0 }, + { 0x20050, 0x0 }, + { 0x20008, 0x190 }, + { 0x120008, 0xa7 }, + { 0x20088, 0x9 }, + { 0x200b2, 0x32c }, + { 0x10043, 0x581 }, + { 0x10143, 0x581 }, + { 0x11043, 0x581 }, + { 0x11143, 0x581 }, + { 0x1200b2, 0x32c }, + { 0x110043, 0x581 }, + { 0x110143, 0x581 }, + { 0x111043, 0x581 }, + { 0x111143, 0x581 }, + { 0x200fa, 0x1 }, + { 0x1200fa, 0x1 }, + { 0x20019, 0x5 }, + { 0x120019, 0x5 }, + { 0x200f0, 0x5555 }, + { 0x200f1, 0x5555 }, + { 0x200f2, 0x5555 }, + { 0x200f3, 0x5555 }, + { 0x200f4, 0x5555 }, + { 0x200f5, 0x5555 }, + { 0x200f6, 0x5555 }, + { 0x200f7, 0xf000 }, + { 0x20025, 0x0 }, + { 0x2007d, 0x212 }, + { 0x12007d, 0x212 }, + { 0x2007c, 0x61 }, + { 0x12007c, 0x61 }, + { 0x1004a, 0x500 }, + { 0x1104a, 0x500 }, + { 0x2002c, 0x0 }, +}; + +/* ddr phy trained csr */ +struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + {0x0200b2, 0x0}, + {0x1200b2, 0x0}, + {0x2200b2, 0x0}, + {0x0200cb, 0x0}, + {0x010043, 0x0}, + {0x110043, 0x0}, + {0x210043, 0x0}, + {0x010143, 0x0}, + {0x110143, 0x0}, + {0x210143, 0x0}, + {0x011043, 0x0}, + {0x111043, 0x0}, + {0x211043, 0x0}, + {0x011143, 0x0}, + {0x111143, 0x0}, + {0x211143, 0x0}, + {0x000080, 0x0}, + {0x100080, 0x0}, + {0x200080, 0x0}, + {0x001080, 0x0}, + {0x101080, 0x0}, + {0x201080, 0x0}, + {0x002080, 0x0}, + {0x102080, 0x0}, + {0x202080, 0x0}, + {0x003080, 0x0}, + {0x103080, 0x0}, + {0x203080, 0x0}, + {0x004080, 0x0}, + {0x104080, 0x0}, + {0x204080, 0x0}, + {0x005080, 0x0}, + {0x105080, 0x0}, + {0x205080, 0x0}, + {0x006080, 0x0}, + {0x106080, 0x0}, + {0x206080, 0x0}, + {0x007080, 0x0}, + {0x107080, 0x0}, + {0x207080, 0x0}, + {0x008080, 0x0}, + {0x108080, 0x0}, + {0x208080, 0x0}, + {0x009080, 0x0}, + {0x109080, 0x0}, + {0x209080, 0x0}, + {0x010080, 0x0}, + {0x110080, 0x0}, + {0x210080, 0x0}, + {0x010180, 0x0}, + {0x110180, 0x0}, + {0x210180, 0x0}, + {0x010081, 0x0}, + {0x110081, 0x0}, + {0x210081, 0x0}, + {0x010181, 0x0}, + {0x110181, 0x0}, + {0x210181, 0x0}, + {0x010082, 0x0}, + {0x110082, 0x0}, + {0x210082, 0x0}, + {0x010182, 0x0}, + {0x110182, 0x0}, + {0x210182, 0x0}, + {0x010083, 0x0}, + {0x110083, 0x0}, + {0x210083, 0x0}, + {0x010183, 0x0}, + {0x110183, 0x0}, + {0x210183, 0x0}, + {0x011080, 0x0}, + {0x111080, 0x0}, + {0x211080, 0x0}, + {0x011180, 0x0}, + {0x111180, 0x0}, + {0x211180, 0x0}, + {0x011081, 0x0}, + {0x111081, 0x0}, + {0x211081, 0x0}, + {0x011181, 0x0}, + {0x111181, 0x0}, + {0x211181, 0x0}, + {0x011082, 0x0}, + {0x111082, 0x0}, + {0x211082, 0x0}, + {0x011182, 0x0}, + {0x111182, 0x0}, + {0x211182, 0x0}, + {0x011083, 0x0}, + {0x111083, 0x0}, + {0x211083, 0x0}, + {0x011183, 0x0}, + {0x111183, 0x0}, + {0x211183, 0x0}, + {0x0100d0, 0x0}, + {0x1100d0, 0x0}, + {0x2100d0, 0x0}, + {0x0101d0, 0x0}, + {0x1101d0, 0x0}, + {0x2101d0, 0x0}, + {0x0100d1, 0x0}, + {0x1100d1, 0x0}, + {0x2100d1, 0x0}, + {0x0101d1, 0x0}, + {0x1101d1, 0x0}, + {0x2101d1, 0x0}, + {0x0100d2, 0x0}, + {0x1100d2, 0x0}, + {0x2100d2, 0x0}, + {0x0101d2, 0x0}, + {0x1101d2, 0x0}, + {0x2101d2, 0x0}, + {0x0100d3, 0x0}, + {0x1100d3, 0x0}, + {0x2100d3, 0x0}, + {0x0101d3, 0x0}, + {0x1101d3, 0x0}, + {0x2101d3, 0x0}, + {0x0110d0, 0x0}, + {0x1110d0, 0x0}, + {0x2110d0, 0x0}, + {0x0111d0, 0x0}, + {0x1111d0, 0x0}, + {0x2111d0, 0x0}, + {0x0110d1, 0x0}, + {0x1110d1, 0x0}, + {0x2110d1, 0x0}, + {0x0111d1, 0x0}, + {0x1111d1, 0x0}, + {0x2111d1, 0x0}, + {0x0110d2, 0x0}, + {0x1110d2, 0x0}, + {0x2110d2, 0x0}, + {0x0111d2, 0x0}, + {0x1111d2, 0x0}, + {0x2111d2, 0x0}, + {0x0110d3, 0x0}, + {0x1110d3, 0x0}, + {0x2110d3, 0x0}, + {0x0111d3, 0x0}, + {0x1111d3, 0x0}, + {0x2111d3, 0x0}, + {0x010068, 0x0}, + {0x010168, 0x0}, + {0x010268, 0x0}, + {0x010368, 0x0}, + {0x010468, 0x0}, + {0x010568, 0x0}, + {0x010668, 0x0}, + {0x010768, 0x0}, + {0x010868, 0x0}, + {0x010069, 0x0}, + {0x010169, 0x0}, + {0x010269, 0x0}, + {0x010369, 0x0}, + {0x010469, 0x0}, + {0x010569, 0x0}, + {0x010669, 0x0}, + {0x010769, 0x0}, + {0x010869, 0x0}, + {0x01006a, 0x0}, + {0x01016a, 0x0}, + {0x01026a, 0x0}, + {0x01036a, 0x0}, + {0x01046a, 0x0}, + {0x01056a, 0x0}, + {0x01066a, 0x0}, + {0x01076a, 0x0}, + {0x01086a, 0x0}, + {0x01006b, 0x0}, + {0x01016b, 0x0}, + {0x01026b, 0x0}, + {0x01036b, 0x0}, + {0x01046b, 0x0}, + {0x01056b, 0x0}, + {0x01066b, 0x0}, + {0x01076b, 0x0}, + {0x01086b, 0x0}, + {0x011068, 0x0}, + {0x011168, 0x0}, + {0x011268, 0x0}, + {0x011368, 0x0}, + {0x011468, 0x0}, + {0x011568, 0x0}, + {0x011668, 0x0}, + {0x011768, 0x0}, + {0x011868, 0x0}, + {0x011069, 0x0}, + {0x011169, 0x0}, + {0x011269, 0x0}, + {0x011369, 0x0}, + {0x011469, 0x0}, + {0x011569, 0x0}, + {0x011669, 0x0}, + {0x011769, 0x0}, + {0x011869, 0x0}, + {0x01106a, 0x0}, + {0x01116a, 0x0}, + {0x01126a, 0x0}, + {0x01136a, 0x0}, + {0x01146a, 0x0}, + {0x01156a, 0x0}, + {0x01166a, 0x0}, + {0x01176a, 0x0}, + {0x01186a, 0x0}, + {0x01106b, 0x0}, + {0x01116b, 0x0}, + {0x01126b, 0x0}, + {0x01136b, 0x0}, + {0x01146b, 0x0}, + {0x01156b, 0x0}, + {0x01166b, 0x0}, + {0x01176b, 0x0}, + {0x01186b, 0x0}, + {0x01008c, 0x0}, + {0x11008c, 0x0}, + {0x21008c, 0x0}, + {0x01018c, 0x0}, + {0x11018c, 0x0}, + {0x21018c, 0x0}, + {0x01008d, 0x0}, + {0x11008d, 0x0}, + {0x21008d, 0x0}, + {0x01018d, 0x0}, + {0x11018d, 0x0}, + {0x21018d, 0x0}, + {0x01008e, 0x0}, + {0x11008e, 0x0}, + {0x21008e, 0x0}, + {0x01018e, 0x0}, + {0x11018e, 0x0}, + {0x21018e, 0x0}, + {0x01008f, 0x0}, + {0x11008f, 0x0}, + {0x21008f, 0x0}, + {0x01018f, 0x0}, + {0x11018f, 0x0}, + {0x21018f, 0x0}, + {0x01108c, 0x0}, + {0x11108c, 0x0}, + {0x21108c, 0x0}, + {0x01118c, 0x0}, + {0x11118c, 0x0}, + {0x21118c, 0x0}, + {0x01108d, 0x0}, + {0x11108d, 0x0}, + {0x21108d, 0x0}, + {0x01118d, 0x0}, + {0x11118d, 0x0}, + {0x21118d, 0x0}, + {0x01108e, 0x0}, + {0x11108e, 0x0}, + {0x21108e, 0x0}, + {0x01118e, 0x0}, + {0x11118e, 0x0}, + {0x21118e, 0x0}, + {0x01108f, 0x0}, + {0x11108f, 0x0}, + {0x21108f, 0x0}, + {0x01118f, 0x0}, + {0x11118f, 0x0}, + {0x21118f, 0x0}, + {0x0100c0, 0x0}, + {0x1100c0, 0x0}, + {0x2100c0, 0x0}, + {0x0101c0, 0x0}, + {0x1101c0, 0x0}, + {0x2101c0, 0x0}, + {0x0102c0, 0x0}, + {0x1102c0, 0x0}, + {0x2102c0, 0x0}, + {0x0103c0, 0x0}, + {0x1103c0, 0x0}, + {0x2103c0, 0x0}, + {0x0104c0, 0x0}, + {0x1104c0, 0x0}, + {0x2104c0, 0x0}, + {0x0105c0, 0x0}, + {0x1105c0, 0x0}, + {0x2105c0, 0x0}, + {0x0106c0, 0x0}, + {0x1106c0, 0x0}, + {0x2106c0, 0x0}, + {0x0107c0, 0x0}, + {0x1107c0, 0x0}, + {0x2107c0, 0x0}, + {0x0108c0, 0x0}, + {0x1108c0, 0x0}, + {0x2108c0, 0x0}, + {0x0100c1, 0x0}, + {0x1100c1, 0x0}, + {0x2100c1, 0x0}, + {0x0101c1, 0x0}, + {0x1101c1, 0x0}, + {0x2101c1, 0x0}, + {0x0102c1, 0x0}, + {0x1102c1, 0x0}, + {0x2102c1, 0x0}, + {0x0103c1, 0x0}, + {0x1103c1, 0x0}, + {0x2103c1, 0x0}, + {0x0104c1, 0x0}, + {0x1104c1, 0x0}, + {0x2104c1, 0x0}, + {0x0105c1, 0x0}, + {0x1105c1, 0x0}, + {0x2105c1, 0x0}, + {0x0106c1, 0x0}, + {0x1106c1, 0x0}, + {0x2106c1, 0x0}, + {0x0107c1, 0x0}, + {0x1107c1, 0x0}, + {0x2107c1, 0x0}, + {0x0108c1, 0x0}, + {0x1108c1, 0x0}, + {0x2108c1, 0x0}, + {0x0100c2, 0x0}, + {0x1100c2, 0x0}, + {0x2100c2, 0x0}, + {0x0101c2, 0x0}, + {0x1101c2, 0x0}, + {0x2101c2, 0x0}, + {0x0102c2, 0x0}, + {0x1102c2, 0x0}, + {0x2102c2, 0x0}, + {0x0103c2, 0x0}, + {0x1103c2, 0x0}, + {0x2103c2, 0x0}, + {0x0104c2, 0x0}, + {0x1104c2, 0x0}, + {0x2104c2, 0x0}, + {0x0105c2, 0x0}, + {0x1105c2, 0x0}, + {0x2105c2, 0x0}, + {0x0106c2, 0x0}, + {0x1106c2, 0x0}, + {0x2106c2, 0x0}, + {0x0107c2, 0x0}, + {0x1107c2, 0x0}, + {0x2107c2, 0x0}, + {0x0108c2, 0x0}, + {0x1108c2, 0x0}, + {0x2108c2, 0x0}, + {0x0100c3, 0x0}, + {0x1100c3, 0x0}, + {0x2100c3, 0x0}, + {0x0101c3, 0x0}, + {0x1101c3, 0x0}, + {0x2101c3, 0x0}, + {0x0102c3, 0x0}, + {0x1102c3, 0x0}, + {0x2102c3, 0x0}, + {0x0103c3, 0x0}, + {0x1103c3, 0x0}, + {0x2103c3, 0x0}, + {0x0104c3, 0x0}, + {0x1104c3, 0x0}, + {0x2104c3, 0x0}, + {0x0105c3, 0x0}, + {0x1105c3, 0x0}, + {0x2105c3, 0x0}, + {0x0106c3, 0x0}, + {0x1106c3, 0x0}, + {0x2106c3, 0x0}, + {0x0107c3, 0x0}, + {0x1107c3, 0x0}, + {0x2107c3, 0x0}, + {0x0108c3, 0x0}, + {0x1108c3, 0x0}, + {0x2108c3, 0x0}, + {0x0110c0, 0x0}, + {0x1110c0, 0x0}, + {0x2110c0, 0x0}, + {0x0111c0, 0x0}, + {0x1111c0, 0x0}, + {0x2111c0, 0x0}, + {0x0112c0, 0x0}, + {0x1112c0, 0x0}, + {0x2112c0, 0x0}, + {0x0113c0, 0x0}, + {0x1113c0, 0x0}, + {0x2113c0, 0x0}, + {0x0114c0, 0x0}, + {0x1114c0, 0x0}, + {0x2114c0, 0x0}, + {0x0115c0, 0x0}, + {0x1115c0, 0x0}, + {0x2115c0, 0x0}, + {0x0116c0, 0x0}, + {0x1116c0, 0x0}, + {0x2116c0, 0x0}, + {0x0117c0, 0x0}, + {0x1117c0, 0x0}, + {0x2117c0, 0x0}, + {0x0118c0, 0x0}, + {0x1118c0, 0x0}, + {0x2118c0, 0x0}, + {0x0110c1, 0x0}, + {0x1110c1, 0x0}, + {0x2110c1, 0x0}, + {0x0111c1, 0x0}, + {0x1111c1, 0x0}, + {0x2111c1, 0x0}, + {0x0112c1, 0x0}, + {0x1112c1, 0x0}, + {0x2112c1, 0x0}, + {0x0113c1, 0x0}, + {0x1113c1, 0x0}, + {0x2113c1, 0x0}, + {0x0114c1, 0x0}, + {0x1114c1, 0x0}, + {0x2114c1, 0x0}, + {0x0115c1, 0x0}, + {0x1115c1, 0x0}, + {0x2115c1, 0x0}, + {0x0116c1, 0x0}, + {0x1116c1, 0x0}, + {0x2116c1, 0x0}, + {0x0117c1, 0x0}, + {0x1117c1, 0x0}, + {0x2117c1, 0x0}, + {0x0118c1, 0x0}, + {0x1118c1, 0x0}, + {0x2118c1, 0x0}, + {0x0110c2, 0x0}, + {0x1110c2, 0x0}, + {0x2110c2, 0x0}, + {0x0111c2, 0x0}, + {0x1111c2, 0x0}, + {0x2111c2, 0x0}, + {0x0112c2, 0x0}, + {0x1112c2, 0x0}, + {0x2112c2, 0x0}, + {0x0113c2, 0x0}, + {0x1113c2, 0x0}, + {0x2113c2, 0x0}, + {0x0114c2, 0x0}, + {0x1114c2, 0x0}, + {0x2114c2, 0x0}, + {0x0115c2, 0x0}, + {0x1115c2, 0x0}, + {0x2115c2, 0x0}, + {0x0116c2, 0x0}, + {0x1116c2, 0x0}, + {0x2116c2, 0x0}, + {0x0117c2, 0x0}, + {0x1117c2, 0x0}, + {0x2117c2, 0x0}, + {0x0118c2, 0x0}, + {0x1118c2, 0x0}, + {0x2118c2, 0x0}, + {0x0110c3, 0x0}, + {0x1110c3, 0x0}, + {0x2110c3, 0x0}, + {0x0111c3, 0x0}, + {0x1111c3, 0x0}, + {0x2111c3, 0x0}, + {0x0112c3, 0x0}, + {0x1112c3, 0x0}, + {0x2112c3, 0x0}, + {0x0113c3, 0x0}, + {0x1113c3, 0x0}, + {0x2113c3, 0x0}, + {0x0114c3, 0x0}, + {0x1114c3, 0x0}, + {0x2114c3, 0x0}, + {0x0115c3, 0x0}, + {0x1115c3, 0x0}, + {0x2115c3, 0x0}, + {0x0116c3, 0x0}, + {0x1116c3, 0x0}, + {0x2116c3, 0x0}, + {0x0117c3, 0x0}, + {0x1117c3, 0x0}, + {0x2117c3, 0x0}, + {0x0118c3, 0x0}, + {0x1118c3, 0x0}, + {0x2118c3, 0x0}, + {0x010020, 0x0}, + {0x110020, 0x0}, + {0x210020, 0x0}, + {0x011020, 0x0}, + {0x111020, 0x0}, + {0x211020, 0x0}, + {0x02007d, 0x0}, + {0x12007d, 0x0}, + {0x22007d, 0x0}, +}; + +/* P0 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0x640 }, + { 0x54004, 0x2 }, + { 0x54005, 0x283c }, + { 0x54006, 0x140 }, + { 0x54007, 0x1000 }, + { 0x54008, 0x101 }, + { 0x5400b, 0x31f }, + { 0x5400c, 0xc8 }, + { 0x54012, 0x1 }, + { 0x5402f, 0x1d70 }, + { 0x54030, 0x4 }, + { 0x54031, 0x18 }, + { 0x5403a, 0x1323 }, + { 0xd0000, 0x1 }, +}; + +/* P1 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp1_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x1 }, + { 0x54003, 0x29c }, + { 0x54004, 0x2 }, + { 0x54005, 0x283c }, + { 0x54006, 0x140 }, + { 0x54007, 0x1000 }, + { 0x54008, 0x101 }, + { 0x5400b, 0x21f }, + { 0x5400c, 0xc8 }, + { 0x54012, 0x1 }, + { 0x5402f, 0x1220 }, + { 0x54030, 0x4 }, + { 0x5403a, 0x1323 }, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +struct dram_cfg_param ddr_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x2 }, + { 0x90033, 0x10 }, + { 0x90034, 0x139 }, + { 0x90035, 0xb }, + { 0x90036, 0x7c0 }, + { 0x90037, 0x139 }, + { 0x90038, 0x44 }, + { 0x90039, 0x633 }, + { 0x9003a, 0x159 }, + { 0x9003b, 0x14f }, + { 0x9003c, 0x630 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x47 }, + { 0x9003f, 0x633 }, + { 0x90040, 0x149 }, + { 0x90041, 0x4f }, + { 0x90042, 0x633 }, + { 0x90043, 0x179 }, + { 0x90044, 0x8 }, + { 0x90045, 0xe0 }, + { 0x90046, 0x109 }, + { 0x90047, 0x0 }, + { 0x90048, 0x7c8 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x1 }, + { 0x9004c, 0x8 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x45a }, + { 0x9004f, 0x9 }, + { 0x90050, 0x0 }, + { 0x90051, 0x448 }, + { 0x90052, 0x109 }, + { 0x90053, 0x40 }, + { 0x90054, 0x633 }, + { 0x90055, 0x179 }, + { 0x90056, 0x1 }, + { 0x90057, 0x618 }, + { 0x90058, 0x109 }, + { 0x90059, 0x40c0 }, + { 0x9005a, 0x633 }, + { 0x9005b, 0x149 }, + { 0x9005c, 0x8 }, + { 0x9005d, 0x4 }, + { 0x9005e, 0x48 }, + { 0x9005f, 0x4040 }, + { 0x90060, 0x633 }, + { 0x90061, 0x149 }, + { 0x90062, 0x0 }, + { 0x90063, 0x4 }, + { 0x90064, 0x48 }, + { 0x90065, 0x40 }, + { 0x90066, 0x633 }, + { 0x90067, 0x149 }, + { 0x90068, 0x10 }, + { 0x90069, 0x4 }, + { 0x9006a, 0x18 }, + { 0x9006b, 0x0 }, + { 0x9006c, 0x4 }, + { 0x9006d, 0x78 }, + { 0x9006e, 0x549 }, + { 0x9006f, 0x633 }, + { 0x90070, 0x159 }, + { 0x90071, 0xd49 }, + { 0x90072, 0x633 }, + { 0x90073, 0x159 }, + { 0x90074, 0x94a }, + { 0x90075, 0x633 }, + { 0x90076, 0x159 }, + { 0x90077, 0x441 }, + { 0x90078, 0x633 }, + { 0x90079, 0x149 }, + { 0x9007a, 0x42 }, + { 0x9007b, 0x633 }, + { 0x9007c, 0x149 }, + { 0x9007d, 0x1 }, + { 0x9007e, 0x633 }, + { 0x9007f, 0x149 }, + { 0x90080, 0x0 }, + { 0x90081, 0xe0 }, + { 0x90082, 0x109 }, + { 0x90083, 0xa }, + { 0x90084, 0x10 }, + { 0x90085, 0x109 }, + { 0x90086, 0x9 }, + { 0x90087, 0x3c0 }, + { 0x90088, 0x149 }, + { 0x90089, 0x9 }, + { 0x9008a, 0x3c0 }, + { 0x9008b, 0x159 }, + { 0x9008c, 0x18 }, + { 0x9008d, 0x10 }, + { 0x9008e, 0x109 }, + { 0x9008f, 0x0 }, + { 0x90090, 0x3c0 }, + { 0x90091, 0x109 }, + { 0x90092, 0x18 }, + { 0x90093, 0x4 }, + { 0x90094, 0x48 }, + { 0x90095, 0x18 }, + { 0x90096, 0x4 }, + { 0x90097, 0x58 }, + { 0x90098, 0xb }, + { 0x90099, 0x10 }, + { 0x9009a, 0x109 }, + { 0x9009b, 0x1 }, + { 0x9009c, 0x10 }, + { 0x9009d, 0x109 }, + { 0x9009e, 0x5 }, + { 0x9009f, 0x7c0 }, + { 0x900a0, 0x109 }, + { 0x900a1, 0x0 }, + { 0x900a2, 0x8140 }, + { 0x900a3, 0x10c }, + { 0x900a4, 0x10 }, + { 0x900a5, 0x8138 }, + { 0x900a6, 0x10c }, + { 0x900a7, 0x8 }, + { 0x900a8, 0x7c8 }, + { 0x900a9, 0x101 }, + { 0x900aa, 0x8 }, + { 0x900ab, 0x448 }, + { 0x900ac, 0x109 }, + { 0x900ad, 0xf }, + { 0x900ae, 0x7c0 }, + { 0x900af, 0x109 }, + { 0x900b0, 0x47 }, + { 0x900b1, 0x630 }, + { 0x900b2, 0x109 }, + { 0x900b3, 0x8 }, + { 0x900b4, 0x618 }, + { 0x900b5, 0x109 }, + { 0x900b6, 0x8 }, + { 0x900b7, 0xe0 }, + { 0x900b8, 0x109 }, + { 0x900b9, 0x0 }, + { 0x900ba, 0x7c8 }, + { 0x900bb, 0x109 }, + { 0x900bc, 0x8 }, + { 0x900bd, 0x8140 }, + { 0x900be, 0x10c }, + { 0x900bf, 0x0 }, + { 0x900c0, 0x1 }, + { 0x900c1, 0x8 }, + { 0x900c2, 0x8 }, + { 0x900c3, 0x4 }, + { 0x900c4, 0x8 }, + { 0x900c5, 0x8 }, + { 0x900c6, 0x7c8 }, + { 0x900c7, 0x101 }, + { 0x90006, 0x0 }, + { 0x90007, 0x0 }, + { 0x90008, 0x8 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x0 }, + { 0x9000b, 0x0 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x90026, 0x2b }, + { 0x2000b, 0x32 }, + { 0x2000c, 0x64 }, + { 0x2000d, 0x3e8 }, + { 0x2000e, 0x2c }, + { 0x12000b, 0x14 }, + { 0x12000c, 0x26 }, + { 0x12000d, 0x1a1 }, + { 0x12000e, 0x10 }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0xffff }, + { 0x90013, 0x6152 }, + { 0x20089, 0x1 }, + { 0x20088, 0x19 }, + { 0xc0080, 0x0 }, + { 0xd0000, 0x1 } +}; + +struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 1600mts 1D */ + .drate = 1600, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 667mts 1D */ + .drate = 667, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 1600, 667, }, +}; diff --git a/board/bsh/imx8mn_smm_s2/imx8mn_smm_s2.c b/board/bsh/imx8mn_smm_s2/imx8mn_smm_s2.c new file mode 100644 index 0000000000..0ebf208be8 --- /dev/null +++ b/board/bsh/imx8mn_smm_s2/imx8mn_smm_s2.c @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2021 Collabora Ltd. + */ + +#include <common.h> +#include <asm/arch/sys_proto.h> +#include <env.h> + +int board_init(void) +{ + return 0; +} + +int board_late_init(void) +{ + if (is_usb_boot()) { + env_set("bootcmd", "run bootcmd_mfg"); + env_set("bootdelay", "0"); + } + + return 0; +} diff --git a/board/bsh/imx8mn_smm_s2/imximage-8mn-ddr3.cfg b/board/bsh/imx8mn_smm_s2/imximage-8mn-ddr3.cfg new file mode 100644 index 0000000000..2083233e50 --- /dev/null +++ b/board/bsh/imx8mn_smm_s2/imximage-8mn-ddr3.cfg @@ -0,0 +1,10 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2021 Collabora Ltd. + */ + +#define __ASSEMBLY__ + +ROM_VERSION v2 +BOOT_FROM sd +LOADER u-boot-spl-ddr.bin 0x912000 diff --git a/board/bsh/imx8mn_smm_s2/spl.c b/board/bsh/imx8mn_smm_s2/spl.c new file mode 100644 index 0000000000..32703c5f0b --- /dev/null +++ b/board/bsh/imx8mn_smm_s2/spl.c @@ -0,0 +1,93 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2021 Collabora Ltd. + * + */ + +#include <hang.h> +#include <init.h> +#include <spl.h> +#include <asm/arch/clock.h> +#include <asm/arch/ddr.h> +#include <asm/arch/imx8mn_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/boot_mode.h> +#include <asm/mach-imx/gpio.h> +#include <dm/device.h> +#include <dm/uclass.h> + +int spl_board_boot_device(enum boot_device boot_dev_spl) +{ + return BOOT_DEVICE_BOOTROM; +} + +void spl_dram_init(void) +{ + ddr_init(&dram_timing); +} + +void spl_board_init(void) +{ + struct udevice *dev; + int ret; + + debug("Normal Boot\n"); + + ret = uclass_get_device_by_name(UCLASS_CLK, + "clock-controller@30380000", + &dev); + if (ret < 0) + puts("Failed to find clock node. Check device tree\n"); +} + +#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) +#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) + +static const iomux_v3_cfg_t uart_pads[] = { + IMX8MN_PAD_UART4_RXD__UART4_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MN_PAD_UART4_TXD__UART4_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static const iomux_v3_cfg_t wdog_pads[] = { + IMX8MN_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), +}; + +int board_early_init_f(void) +{ + struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; + + imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); + set_wdog_reset(wdog); + + imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); + init_uart_clk(3); + + return 0; +} + +void board_init_f(ulong dummy) +{ + int ret; + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + arch_cpu_init(); + + board_early_init_f(); + + timer_init(); + + preloader_console_init(); + + ret = spl_init(); + if (ret) { + debug("spl_init() failed: %d\n", ret); + hang(); + } + + /* DDR initialization */ + spl_dram_init(); + + board_init_r(NULL, 0); +} diff --git a/configs/imx8mn_bsh_smm_s2_defconfig b/configs/imx8mn_bsh_smm_s2_defconfig new file mode 100644 index 0000000000..3fdd5d4639 --- /dev/null +++ b/configs/imx8mn_bsh_smm_s2_defconfig @@ -0,0 +1,92 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SYS_MALLOC_LEN=0x2000000 +CONFIG_SYS_MALLOC_F_LEN=0x10000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x2000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mn-bsh-smm-s2" +CONFIG_SPL_TEXT_BASE=0x912000 +CONFIG_TARGET_IMX8MN_BSH_SMM_S2=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SPL=y +CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_LOAD_ADDR=0x40480000 +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_DEFAULT_FDT_FILE="freescale/imx8mn-bsh-smm-s2.dtb" +CONFIG_ARCH_MISC_INIT=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_BOOTROM_SUPPORT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_I2C=y +CONFIG_SPL_MTD_SUPPORT=y +CONFIG_SPL_POWER=y +CONFIG_SPL_WATCHDOG=y +CONFIG_SYS_PROMPT="> " +CONFIG_CMD_FUSE=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" +CONFIG_MTDPARTS_DEFAULT="gpmi-nand:64m(nandboot),16m(nandfit),32m(nandkernel),1m(nanddtb),8m(nandtee),-(nandrootfs)" +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +# CONFIG_NET is not set +CONFIG_SPL_DM=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMX8MN=y +CONFIG_CLK_IMX8MN=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x40480000 +CONFIG_FASTBOOT_BUF_SIZE=0x20000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_UUU_SUPPORT=y +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +# CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_USE_FLASH_BBT=y +CONFIG_NAND_MXS=y +CONFIG_NAND_MXS_DT=y +CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_BD71837=y +CONFIG_SPL_DM_PMIC_BD71837=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_MXC_UART=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y +CONFIG_IMX_WATCHDOG=y +CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/imx8mn_bsh_smm_s2pro_defconfig b/configs/imx8mn_bsh_smm_s2pro_defconfig new file mode 100644 index 0000000000..fc86ccf1cd --- /dev/null +++ b/configs/imx8mn_bsh_smm_s2pro_defconfig @@ -0,0 +1,89 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SYS_MALLOC_LEN=0x2000000 +CONFIG_SYS_MALLOC_F_LEN=0x10000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x2000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mn-bsh-smm-s2pro" +CONFIG_SPL_TEXT_BASE=0x912000 +CONFIG_TARGET_IMX8MN_BSH_SMM_S2PRO=y +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SPL=y +CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_LOAD_ADDR=0x40480000 +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_DEFAULT_FDT_FILE="freescale/imx8mn-bsh-smm-s2pro.dtb" +CONFIG_ARCH_MISC_INIT=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_BOOTROM_SUPPORT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y +CONFIG_SPL_WATCHDOG=y +CONFIG_SYS_PROMPT="> " +CONFIG_CMD_FUSE=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +# CONFIG_NET is not set +CONFIG_SPL_DM=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMX8MN=y +CONFIG_CLK_IMX8MN=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x40480000 +CONFIG_FASTBOOT_BUF_SIZE=0x20000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_UUU_SUPPORT=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_FSL_USDHC=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_BD71837=y +CONFIG_SPL_DM_PMIC_BD71837=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_MXC_UART=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y +CONFIG_IMX_WATCHDOG=y +CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/doc/board/bsh/imx8mn_bsh_smm_s2.rst b/doc/board/bsh/imx8mn_bsh_smm_s2.rst new file mode 100644 index 0000000000..7bde26c163 --- /dev/null +++ b/doc/board/bsh/imx8mn_bsh_smm_s2.rst @@ -0,0 +1,62 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +imx8mn_bsh_smm_s2 +================= + +U-Boot for the BSH SystemMaster (SMM) S2 board family. + +Quick Start +----------- + +- Build the ARM Trusted firmware binary +- Get firmware-imx package +- Build U-Boot +- Boot + +Get and Build the ARM Trusted firmware +-------------------------------------- + +Note: srctree is U-Boot source directory +Get ATF from: https://github.com/ARM-software/arm-trusted-firmware +tag: v2.5 + +.. code-block:: bash + + $ make PLAT=imx8mn IMX_BOOT_UART_BASE=0x30a60000 bl31 + $ cp build/imx8mn/release/bl31.bin $(srctree) + +Get the ddr firmware +-------------------- + +.. code-block:: bash + + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.9.bin + $ chmod +x firmware-imx-8.9.bin + $ ./firmware-imx-8.9 + $ cp firmware-imx-8.9/firmware/ddr/synopsys/ddr3*.bin $(srctree) + +Build U-Boot +------------ + +.. code-block:: bash + + $ export CROSS_COMPILE=aarch64-linux-gnu- + $ make imx8mn_bsh_smm_s2_defconfig + $ make + +Burn the flash.bin to MicroSD card offset 32KB: + +.. code-block:: bash + + $ dd if=flash.bin of=/dev/sd[x] bs=1024 seek=32 conv=notrunc + +Boot +---- + +Start the board in USB serial downloader mode, plug-in the USB-OTG port and +load flash.bin using Freescale/NXP UUU tool: + +.. code-block:: bash + + $ uuu -v flash.bin + diff --git a/doc/board/bsh/index.rst b/doc/board/bsh/index.rst new file mode 100644 index 0000000000..570ee4d72e --- /dev/null +++ b/doc/board/bsh/index.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +BSH Hausgeraete GmbH +==================== + +.. toctree:: + :maxdepth: 2 + + imx8mn_bsh_smm_s2 diff --git a/doc/board/index.rst b/doc/board/index.rst index 74ea33e081..148dcd0cdd 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -12,6 +12,7 @@ Board-specific doc amlogic/index apple/index atmel/index + bsh/index congatec/index coreboot/index emulation/index diff --git a/include/configs/imx8mn_bsh_smm_s2.h b/include/configs/imx8mn_bsh_smm_s2.h new file mode 100644 index 0000000000..41cdb15038 --- /dev/null +++ b/include/configs/imx8mn_bsh_smm_s2.h @@ -0,0 +1,52 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2021 Collabora Ltd. + */ + +#ifndef __IMX8MN_BSH_SMM_S2_H +#define __IMX8MN_BSH_SMM_S2_H + +#include <configs/imx8mn_bsh_smm_s2_common.h> + +#define BOOT_TARGET_DEVICES(func) \ + func(NAND, nand, 0) \ + +#include <config_distro_bootcmd.h> + +#define NANDARGS \ + "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \ + "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ + "nandargs=setenv bootargs console=${console} " \ + "${optargs} " \ + "root=${nandroot} " \ + "rootfstype=${nandrootfstype}\0" \ + "nandroot=ubi0:root rw ubi.mtd=nandrootfs\0" \ + "nandrootfstype=ubifs rootwait=1\0" \ + "nandboot=echo Booting from nand ...; " \ + "run nandargs; " \ + "nand read ${fdt_addr_r} nanddtb; " \ + "nand read ${loadaddr} nandkernel; " \ + "booti ${loadaddr} - ${fdt_addr_r}\0" + +#define BOOTENV_DEV_NAND(devtypeu, devtypel, instance) \ + "bootcmd_" #devtypel #instance "=" \ + "run nandboot\0" + +#define BOOTENV_DEV_NAME_NAND(devtypeu, devtypel, instance) \ + #devtypel #instance " " + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + MEM_LAYOUT_ENV_SETTINGS \ + NANDARGS \ + BOOTENV + +#define PHYS_SDRAM_SIZE SZ_256M + +/* NAND */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 + +#define CONFIG_SYS_NAND_BASE 0x20000000 +#define CONFIG_SYS_NAND_5_ADDR_CYCLE + +#endif /* __IMX8MN_BSH_SMM_S2_H */ diff --git a/include/configs/imx8mn_bsh_smm_s2_common.h b/include/configs/imx8mn_bsh_smm_s2_common.h new file mode 100644 index 0000000000..d79914a2d6 --- /dev/null +++ b/include/configs/imx8mn_bsh_smm_s2_common.h @@ -0,0 +1,62 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2021 Collabora Ltd. + */ + +#ifndef __IMX8MN_BSH_SMM_S2_COMMON_H +#define __IMX8MN_BSH_SMM_S2_COMMON_H + +#include <linux/sizes.h> +#include <linux/stringify.h> +#include <asm/arch/imx-regs.h> + +#define CONFIG_SYS_BOOTM_LEN (32 * SZ_1M) + +#define CONFIG_SPL_MAX_SIZE (148 * SZ_1K) +#define CONFIG_SYS_MONITOR_LEN SZ_512K +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 +#define CONFIG_SYS_UBOOT_BASE \ + (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) + +#define CONFIG_SPL_STACK 0x980000 +#define CONFIG_SPL_BSS_START_ADDR 0x950000 +#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K +#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K + + + +#define MEM_LAYOUT_ENV_SETTINGS \ + "scriptaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "ramdisk_addr_r=0x43800000\0" \ + "fdt_addr_r=0x43000000\0" \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "bootcmd_mfg=echo Running fastboot mode; fastboot usb 0\0" \ + +/* Link Definitions */ + +#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 +#define CONFIG_SYS_INIT_RAM_SIZE SZ_512K +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM 0x40000000 + +#define CONFIG_MXC_UART_BASE UART4_BASE_ADDR + +/* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE SZ_2K +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* I2C */ +#define CONFIG_SYS_I2C_SPEED 400000 + +#endif /* __IMX8MN_BSH_SMM_S2_COMMON_H */ diff --git a/include/configs/imx8mn_bsh_smm_s2pro.h b/include/configs/imx8mn_bsh_smm_s2pro.h new file mode 100644 index 0000000000..37fda66f98 --- /dev/null +++ b/include/configs/imx8mn_bsh_smm_s2pro.h @@ -0,0 +1,35 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2021 Collabora Ltd. + */ + +#ifndef __IMX8MN_BSH_SMM_S2PRO_H +#define __IMX8MN_BSH_SMM_S2PRO_H + +#include <configs/imx8mn_bsh_smm_s2_common.h> + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + +#include <config_distro_bootcmd.h> + +#define EMMCARGS \ + "fastboot_partition_alias_all=" \ + __stringify(CONFIG_FASTBOOT_FLASH_MMC_DEV) ".0:0\0" \ + "fastboot_partition_alias_bootloader=" \ + __stringify(CONFIG_FASTBOOT_FLASH_MMC_DEV) ".1:0\0" \ + "emmc_dev=" __stringify(CONFIG_FASTBOOT_FLASH_MMC_DEV) "\0" \ + "emmc_ack=1\0" \ + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + MEM_LAYOUT_ENV_SETTINGS \ + EMMCARGS \ + BOOTENV + +#define PHYS_SDRAM_SIZE SZ_512M + +/* USDHC */ +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +#endif /* __IMX8MN_BSH_SMM_S2PRO_H */
Gentle ping. Can we get this merged?
On 11/23/21 14:42, Ariel D'Alessandro wrote:
Changes in v2:
- Properly added MAINTAINERS entry.
- Fixed binman configuration.
- Picked device tree from kernel.
- Removed CONFIG_SPL_BUILD anti-pattern in board config.
- Removed downstream stuff in bootargs.
- Added board documentation.
Ariel D'Alessandro (1): bsh: imx8mn-smm-s2/pro: Add iMX8MN BSH SMM S2 boards
Michael Trimarchi (1): imx8m: add regs used by GPMI
arch/arm/dts/Makefile | 2 + arch/arm/dts/imx8mn-bsh-smm-s2-common.dtsi | 423 ++++++++ .../dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi | 225 +++++ arch/arm/dts/imx8mn-bsh-smm-s2-u-boot.dtsi | 15 + arch/arm/dts/imx8mn-bsh-smm-s2.dts | 48 + arch/arm/dts/imx8mn-bsh-smm-s2pro-u-boot.dtsi | 15 + arch/arm/dts/imx8mn-bsh-smm-s2pro.dts | 80 ++ arch/arm/include/asm/arch-imx8m/imx-regs.h | 7 + arch/arm/mach-imx/imx8m/Kconfig | 15 + board/bsh/imx8mn_smm_s2/Kconfig | 38 + board/bsh/imx8mn_smm_s2/MAINTAINERS | 8 + board/bsh/imx8mn_smm_s2/Makefile | 13 + board/bsh/imx8mn_smm_s2/ddr3l_timing_256m.c | 941 ++++++++++++++++++ board/bsh/imx8mn_smm_s2/ddr3l_timing_512m.c | 941 ++++++++++++++++++ board/bsh/imx8mn_smm_s2/imx8mn_smm_s2.c | 23 + board/bsh/imx8mn_smm_s2/imximage-8mn-ddr3.cfg | 10 + board/bsh/imx8mn_smm_s2/spl.c | 93 ++ configs/imx8mn_bsh_smm_s2_defconfig | 92 ++ configs/imx8mn_bsh_smm_s2pro_defconfig | 89 ++ doc/board/bsh/imx8mn_bsh_smm_s2.rst | 62 ++ doc/board/bsh/index.rst | 9 + doc/board/index.rst | 1 + include/configs/imx8mn_bsh_smm_s2.h | 52 + include/configs/imx8mn_bsh_smm_s2_common.h | 62 ++ include/configs/imx8mn_bsh_smm_s2pro.h | 35 + 25 files changed, 3299 insertions(+) create mode 100644 arch/arm/dts/imx8mn-bsh-smm-s2-common.dtsi create mode 100644 arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi create mode 100644 arch/arm/dts/imx8mn-bsh-smm-s2-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mn-bsh-smm-s2.dts create mode 100644 arch/arm/dts/imx8mn-bsh-smm-s2pro-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mn-bsh-smm-s2pro.dts create mode 100644 board/bsh/imx8mn_smm_s2/Kconfig create mode 100644 board/bsh/imx8mn_smm_s2/MAINTAINERS create mode 100644 board/bsh/imx8mn_smm_s2/Makefile create mode 100644 board/bsh/imx8mn_smm_s2/ddr3l_timing_256m.c create mode 100644 board/bsh/imx8mn_smm_s2/ddr3l_timing_512m.c create mode 100644 board/bsh/imx8mn_smm_s2/imx8mn_smm_s2.c create mode 100644 board/bsh/imx8mn_smm_s2/imximage-8mn-ddr3.cfg create mode 100644 board/bsh/imx8mn_smm_s2/spl.c create mode 100644 configs/imx8mn_bsh_smm_s2_defconfig create mode 100644 configs/imx8mn_bsh_smm_s2pro_defconfig create mode 100644 doc/board/bsh/imx8mn_bsh_smm_s2.rst create mode 100644 doc/board/bsh/index.rst create mode 100644 include/configs/imx8mn_bsh_smm_s2.h create mode 100644 include/configs/imx8mn_bsh_smm_s2_common.h create mode 100644 include/configs/imx8mn_bsh_smm_s2pro.h
On Mon, Jan 3, 2022 at 6:11 PM Ariel D'Alessandro ariel.dalessandro@collabora.com wrote:
Looks good to me:
Reviewed-by: Fabio Estevam festevam@gmail.com
Hi Fabio
Looks good to me:
Where will it be pick up? I will need even some followup to the patch that write the nand_bcb to avoid to use the kernel tool
Michael
Hi Tom,
Any reason why this is still pending? Please let me know.
Thanks in advance, Ariel
On 1/26/22 08:08, Michael Nazzareno Trimarchi wrote:
Hi Fabio
Looks good to me:
Michael
Ping :-) Can we get this merged?
On 1/31/22 10:39, Ariel D'Alessandro wrote:
Hi Tom,
Hi Fabio
Looks good to me:
Michael
Stefano, are you working on a follow-up PR with more platforms? Thanks!
Hi Tom,
Hi Fabio
Looks good to me:
Michael
Yes, I will apply missing patches in the WE.
Regards, Stefano
Hi Tom,
Hi Fabio
Looks good to me:
Michael
participants (5)
Ariel D'Alessandro
Fabio Estevam
Stefano Babic
