[PATCH V2 0/2] doc: board: ti: Cleanup ::prompt usage
Due to the sequence of merges, it looks like many of k3 documentation used code-blocks while the rest of the docs migrated to ::prompt.
Sync all to a common style.
based off: master 07fe79c93c5c Merge tag 'i2cfixes-for-v2024-01-rc2' of https://source.denx.de/u-boot/custodians/u-boot-i2c
Changes since V1: * squashed up the gdb patch to patch#1 * fixedup patch #2 for whitespace indentation miss
v1: https://lore.kernel.org/r/20231103000915.2413501-1-nm@ti.com
Nishanth Menon (2): doc: board: ti: Use prompt prompt_style to simplify documentation doc: board: ti: k3 docs: Use ::prompt
doc/board/ti/am335x_evm.rst | 39 ++++------- doc/board/ti/am62x_beagleplay.rst | 46 ++++++------- doc/board/ti/am62x_sk.rst | 18 +++--- doc/board/ti/am64x_evm.rst | 20 +++--- doc/board/ti/am65x_evm.rst | 104 +++++++++++++++--------------- doc/board/ti/dra7xx_evm.rst | 3 +- doc/board/ti/j7200_evm.rst | 20 +++--- doc/board/ti/j721e_evm.rst | 40 ++++++------ doc/board/ti/j721s2_evm.rst | 18 +++--- doc/board/ti/k3.rst | 44 ++++++------- doc/board/ti/ks2_evm.rst | 15 ++--- 11 files changed, 174 insertions(+), 193 deletions(-)
The sphinx-prompt documentation[0] provides examples on how we can use prompt as a parameter to simplify the description. Use the same.
While at it, ensure to make all relevant prompts clarified such as gdb prompts.
[0] http://sbrunner.github.io/sphinx-prompt/
Signed-off-by: Nishanth Menon nm@ti.com --- Changes since V1: Squashed up gdb prompt as well to this patch.
V1: https://lore.kernel.org/r/20231103000915.2413501-2-nm@ti.com doc/board/ti/am335x_evm.rst | 39 +++++++++++--------------------- doc/board/ti/dra7xx_evm.rst | 3 +-- doc/board/ti/k3.rst | 44 ++++++++++++++++++------------------- doc/board/ti/ks2_evm.rst | 15 +++++-------- 4 files changed, 41 insertions(+), 60 deletions(-)
diff --git a/doc/board/ti/am335x_evm.rst b/doc/board/ti/am335x_evm.rst index 2ba651eb6df9..769362816b78 100644 --- a/doc/board/ti/am335x_evm.rst +++ b/doc/board/ti/am335x_evm.rst @@ -84,8 +84,7 @@ bootable image was not created.
Within the SECDEV package exists an image creation script:
-.. prompt:: bash - :prompts: $ +.. prompt:: bash $
${TI_SECURE_DEV_PKG}/scripts/create-boot-image.sh
@@ -97,8 +96,7 @@ possible. The script is basically the only required interface to the TI SECDEV package for creating a bootable SPL image for secure TI devices.
create-boot-image.sh \ <IMAGE_FLAG> <INPUT_FILE> <OUTPUT_FILE> <SPL_LOAD_ADDR> @@ -184,8 +182,7 @@ The exact details of the how the images are secured is handled by the SECDEV package. Within the SECDEV package exists a script to process an input binary image:
${TI_SECURE_DEV_PKG}/scripts/secure-binary-image.sh
@@ -206,8 +203,7 @@ only accessible when the ARM core is operating in the secure mode). Invoking the secure-binary-image script for Secure Devices ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
secure-binary-image.sh <INPUT_FILE> <OUTPUT_FILE>
@@ -247,8 +243,7 @@ into memory, then written to NAND.
2. Flashing NAND via MMC/SD
-.. prompt:: bash - :prompts: => +.. prompt:: bash =>
# select BOOTSEL to MMC/SD boot and boot from MMC/SD card mmc rescan @@ -334,8 +329,7 @@ had a FAT partition (such as on a Beaglebone Black) it is not enough to write garbage into the area, you must delete it from the partition table first.
# Ensure we are able to talk with this mmc device mmc rescan @@ -366,8 +360,7 @@ the FAT filesystem (only the uImage MUST be for this to function afterwards) along with a Falcon Mode aware MLO and the FAT partition has already been created and marked bootable:
mmc rescan # Load kernel and device tree into memory, perform export @@ -386,8 +379,7 @@ This will print a number of lines and then end with something like:
So then you:
fatwrite mmc 0:1 0x80f80000 args 8928
@@ -400,8 +392,7 @@ already located on the NAND somewhere (such as filesystem or mtd partition) along with a Falcon Mode aware MLO written to the correct locations for booting and mtdparts have been configured correctly for the board:
nand read ${loadaddr} kernel load nand rootfs ${fdtaddr} /boot/am335x-evm.dtb @@ -425,8 +416,7 @@ The output of the 'dm tree' command shows which driver is bound to which device, so the user can easily configure their platform differently from the command line:
dm tree
@@ -444,8 +434,7 @@ the command line: Typically here any network command performed using the usb_ether interface would work, while using other gadgets would fail:
fastboot usb 0
@@ -462,8 +451,7 @@ least from a bootloader point of view). The solution here would be to use the unbind command specifying the class and index parameters (as shown above in the 'dm tree' output) to target the driver to unbind:
unbind ethernet 1
@@ -471,8 +459,7 @@ The output of the 'dm tree' command now shows the availability of the first USB device controller, the fastboot gadget will now be able to bind with it:
dm tree
diff --git a/doc/board/ti/dra7xx_evm.rst b/doc/board/ti/dra7xx_evm.rst index 4503b5e92229..8e5d95535fa0 100644 --- a/doc/board/ti/dra7xx_evm.rst +++ b/doc/board/ti/dra7xx_evm.rst @@ -71,8 +71,7 @@ example we load MLO and u-boot.img from the build into DDR and then use 'mmc bootbus' to set the required rate (see TRM) and 'mmc partconfig' to set boot0 as the boot device.
setenv autoload no usb start diff --git a/doc/board/ti/k3.rst b/doc/board/ti/k3.rst index 89d70db88647..75ee23883aae 100644 --- a/doc/board/ti/k3.rst +++ b/doc/board/ti/k3.rst @@ -197,7 +197,7 @@ All of that to say you will need both a 32bit and 64bit cross compiler .. k3_rst_include_end_common_env_vars_desc
.. k3_rst_include_start_common_env_vars_defn -.. prompt:: bash +.. prompt:: bash $
export CC32=arm-linux-gnueabihf- export CC64=aarch64-linux-gnu- @@ -247,7 +247,7 @@ Building tiboot3.bin uses the split binary flow)
.. k3_rst_include_start_build_steps_spl_r5 -.. prompt:: bash +.. prompt:: bash $
# inside u-boot source make $UBOOT_CFG_CORTEXR @@ -283,7 +283,7 @@ firmware if your device using a split firmware. application cores on the main domain.
.. k3_rst_include_start_build_steps_tfa -.. prompt:: bash +.. prompt:: bash $
# inside trusted-firmware-a source make CROSS_COMPILE=$CC64 ARCH=aarch64 PLAT=k3 SPD=opteed $TFA_EXTRA_ARGS \ @@ -299,7 +299,7 @@ use the `lite` option. using the TrustZone technology built into the core.
.. k3_rst_include_start_build_steps_optee -.. prompt:: bash +.. prompt:: bash $
# inside optee_os source make CROSS_COMPILE=$CC32 CROSS_COMPILE64=$CC64 CFG_ARM64_core=y $OPTEE_EXTRA_ARGS \ @@ -311,7 +311,7 @@ use the `lite` option. 64bit core in the main domain.
.. k3_rst_include_start_build_steps_uboot -.. prompt:: bash +.. prompt:: bash $
# inside u-boot source make $UBOOT_CFG_CORTEXA @@ -410,14 +410,14 @@ and the same can be extended to other platforms be passing to mkimage for signing the fitImage and embedding the key in the u-boot dtb.
- .. prompt:: bash + .. prompt:: bash $
mkimage -r -f fitImage.its -k $UBOOT_PATH/board/ti/keys -K $UBOOT_PATH/build/a72/dts/dt.dtb
For signing a secondary platform, pass the -K parameter to that DTB
mkimage -f fitImage.its -k $UBOOT_PATH/board/ti/keys -K $UBOOT_PATH/build/a72/arch/arm/dts/k3-j721e-sk.dtb @@ -476,8 +476,7 @@ then the saveenv command and can be used across various bootmodes too.
**Writing to MMC/EMMC**
env export -t $loadaddr <list of variables> fatwrite mmc ${mmcdev} ${loadaddr} ${bootenvfile} ${filesize} @@ -490,8 +489,7 @@ mmcdev) and set the environments. If manually needs to be done then the environment can be read from the filesystem and then imported
fatload mmc ${mmcdev} ${loadaddr} ${bootenvfile} env import -t ${loadaddr} ${filesize} @@ -551,7 +549,7 @@ Refer to the release notes corresponding to the `OpenOCD version box support by OpenOCD. The board-specific documentation will cover the details and any adapter/dongle recommendations.
openocd -v
@@ -569,7 +567,7 @@ systems, but equivalent instructions should exist for systems with other package managers. Please refer to the `OpenOCD Documentation https://openocd.org/`_ for more recent installation steps.
# Check the packages to be installed: needs deb-src in sources.list sudo apt build-dep openocd @@ -599,7 +597,7 @@ The step is not necessary if the distribution supports the OpenOCD, but if building from a source, ensure that the udev rules are installed correctly to ensure a sane system.
# Go to the OpenOCD source directory cd openocd @@ -617,7 +615,7 @@ Step 2: Setup GDB
Most systems come with gdb-multiarch package.
# Install gdb-multiarch package sudo apt-get install gdb-multiarch @@ -833,7 +831,7 @@ Startup OpenOCD to debug the platform as follows:
.. k3_rst_include_start_openocd_cfg_XDS110
openocd -f board/{board_of_choice}.cfg
@@ -847,7 +845,7 @@ Startup OpenOCD to debug the platform as follows: https://github.com/openocd-org/openocd/blob/master/tcl/target/ti_k3.cfg#L59`_ to decide if the SoC is supported or not.
openocd -f openocd_connect.cfg
@@ -922,13 +920,13 @@ To debug using this server, use GDB directly or your preferred GDB-based IDE. To start up GDB in the terminal, run the following command.
gdb-multiarch
To connect to your desired core, run the following command within GDB:
-.. code-block:: bash +.. prompt:: bash (gdb)
target extended-remote localhost:{port for desired core}
@@ -945,13 +943,13 @@ To load symbols:
* Prior to relocation:
symbol-file {path to elf file}
* After relocation:
# Drop old symbol file symbol-file @@ -962,7 +960,7 @@ To load symbols:
In the above example of AM625,
target extended-remote localhost:3338 <- R5F (Wakeup Domain) target extended-remote localhost:3334 <- A53 (Main Domain) @@ -982,7 +980,7 @@ breakpoints. To exit the debug loop added above, add any breakpoints needed and run the following GDB commands to step out of the debug loop set in the ``board_init_f`` function.
set x = 0 continue diff --git a/doc/board/ti/ks2_evm.rst b/doc/board/ti/ks2_evm.rst index 0a789037a6a8..c8591484b032 100644 --- a/doc/board/ti/ks2_evm.rst +++ b/doc/board/ti/ks2_evm.rst @@ -122,8 +122,7 @@ Don't forget to add CROSS_COMPILE.
To build u-boot.bin, u-boot-spi.gph, MLO:
make k2hk_evm_defconfig make @@ -197,8 +196,7 @@ instructions: 4. Free Run the target as described earlier (step 4) to get U-Boot prompt 5. At the U-Boot console type following to setup U-Boot environment variables.
setenv addr_uboot 0x87000000 setenv filesize <size in hex of u-boot-spi.gph rounded to hex 0x10000> @@ -226,8 +224,7 @@ instructions: 4. Free Run the target as described earlier (step 4) to get U-Boot prompt 5. At the U-Boot console type following to setup U-Boot environment variables.
setenv filesize <size in hex of MLO rounded to hex 0x10000> run burn_uboot_nand @@ -249,10 +246,10 @@ Open BMC and regular UART terminals. 1. On the regular UART port start xmodem transfer of the u-boot.bin 2. Using BMC terminal set the ARM-UART bootmode and reboot the EVM
-.. prompt:: bash +.. prompt:: bash BMC>
- BMC> bootmode #4 - MBC> reboot + bootmode #4 + reboot
3. When xmodem is complete you should see the U-Boot starts on the UART port
Use prompt instead of code-block to have copy-paste friendly command documentation.
Signed-off-by: Nishanth Menon nm@ti.com --- Changes since v1: minor fixup for whitespace indentation.
V1: https://lore.kernel.org/r/20231103000915.2413501-4-nm@ti.com doc/board/ti/am62x_beagleplay.rst | 46 ++++++------- doc/board/ti/am62x_sk.rst | 18 +++--- doc/board/ti/am64x_evm.rst | 20 +++--- doc/board/ti/am65x_evm.rst | 104 +++++++++++++++--------------- doc/board/ti/j7200_evm.rst | 20 +++--- doc/board/ti/j721e_evm.rst | 40 ++++++------ doc/board/ti/j721s2_evm.rst | 18 +++--- 7 files changed, 133 insertions(+), 133 deletions(-)
diff --git a/doc/board/ti/am62x_beagleplay.rst b/doc/board/ti/am62x_beagleplay.rst index 39913b29ab2c..97ab0a4350ed 100644 --- a/doc/board/ti/am62x_beagleplay.rst +++ b/doc/board/ti/am62x_beagleplay.rst @@ -55,15 +55,15 @@ Set the variables corresponding to this platform: .. include:: k3.rst :start-after: .. k3_rst_include_start_common_env_vars_defn :end-before: .. k3_rst_include_end_common_env_vars_defn -.. code-block:: bash +.. prompt:: bash $
- $ export UBOOT_CFG_CORTEXR="am62x_evm_r5_defconfig beagleplay_r5.config" - $ export UBOOT_CFG_CORTEXA="am62x_evm_a53_defconfig beagleplay_a53.config" - $ export TFA_BOARD=lite - $ # we dont use any extra TFA parameters - $ unset TFA_EXTRA_ARGS - $ export OPTEE_PLATFORM=k3-am62x - $ export OPTEE_EXTRA_ARGS="CFG_WITH_SOFTWARE_PRNG=y" + export UBOOT_CFG_CORTEXR="am62x_evm_r5_defconfig beagleplay_r5.config" + export UBOOT_CFG_CORTEXA="am62x_evm_a53_defconfig beagleplay_a53.config" + export TFA_BOARD=lite + # we dont use any extra TFA parameters + unset TFA_EXTRA_ARGS + export OPTEE_PLATFORM=k3-am62x + export OPTEE_EXTRA_ARGS="CFG_WITH_SOFTWARE_PRNG=y"
.. include:: am62x_sk.rst :start-after: .. am62x_evm_rst_include_start_build_steps @@ -174,24 +174,24 @@ boot1 partition depends on A/B update requirements.
The following are the steps from Linux shell to program eMMC:
-.. code-block:: bash +.. prompt:: bash #
- # # Enable Boot0 boot - # mmc bootpart enable 1 2 /dev/mmcblk0 - # mmc bootbus set single_backward x1 x8 /dev/mmcblk0 - # mmc hwreset enable /dev/mmcblk0 + # Enable Boot0 boot + mmc bootpart enable 1 2 /dev/mmcblk0 + mmc bootbus set single_backward x1 x8 /dev/mmcblk0 + mmc hwreset enable /dev/mmcblk0
- # # Clear eMMC boot0 - # echo '0' >> /sys/class/block/mmcblk0boot0/force_ro - # dd if=/dev/zero of=/dev/mmcblk0boot0 count=32 bs=128k - # # Write tiboot3.bin - # dd if=tiboot3.bin of=/dev/mmcblk0boot0 bs=128k + # Clear eMMC boot0 + echo '0' >> /sys/class/block/mmcblk0boot0/force_ro + dd if=/dev/zero of=/dev/mmcblk0boot0 count=32 bs=128k + # Write tiboot3.bin + dd if=tiboot3.bin of=/dev/mmcblk0boot0 bs=128k
- # # Copy the rest of the boot binaries - # mount /dev/mmcblk0p1 /boot/firmware - # cp tispl.bin /boot/firmware - # cp u-boot.img /boot/firmware - # sync + # Copy the rest of the boot binaries + mount /dev/mmcblk0p1 /boot/firmware + cp tispl.bin /boot/firmware + cp u-boot.img /boot/firmware + sync
.. warning ::
diff --git a/doc/board/ti/am62x_sk.rst b/doc/board/ti/am62x_sk.rst index d7437c6d22f7..25e25fb56ac4 100644 --- a/doc/board/ti/am62x_sk.rst +++ b/doc/board/ti/am62x_sk.rst @@ -76,15 +76,15 @@ Set the variables corresponding to this platform: .. include:: ../ti/k3.rst :start-after: .. k3_rst_include_start_common_env_vars_defn :end-before: .. k3_rst_include_end_common_env_vars_defn -.. code-block:: bash +.. prompt:: bash $
- $ export UBOOT_CFG_CORTEXR=am62x_evm_r5_defconfig - $ export UBOOT_CFG_CORTEXA=am62x_evm_a53_defconfig - $ export TFA_BOARD=lite - $ # we dont use any extra TFA parameters - $ unset TFA_EXTRA_ARGS - $ export OPTEE_PLATFORM=k3-am62x - $ export OPTEE_EXTRA_ARGS="CFG_WITH_SOFTWARE_PRNG=y" + export UBOOT_CFG_CORTEXR=am62x_evm_r5_defconfig + export UBOOT_CFG_CORTEXA=am62x_evm_a53_defconfig + export TFA_BOARD=lite + # we dont use any extra TFA parameters + unset TFA_EXTRA_ARGS + export OPTEE_PLATFORM=k3-am62x + export OPTEE_EXTRA_ARGS="CFG_WITH_SOFTWARE_PRNG=y"
@@ -270,6 +270,6 @@ detailed setup information.
To start OpenOCD and connect to the board
openocd -f board/ti_am625evm.cfg diff --git a/doc/board/ti/am64x_evm.rst b/doc/board/ti/am64x_evm.rst index db27461cb14d..fe661b1f49c8 100644 --- a/doc/board/ti/am64x_evm.rst +++ b/doc/board/ti/am64x_evm.rst @@ -65,16 +65,16 @@ Set the variables corresponding to this platform: .. include:: k3.rst :start-after: .. k3_rst_include_start_common_env_vars_defn :end-before: .. k3_rst_include_end_common_env_vars_defn -.. code-block:: bash - - $ export UBOOT_CFG_CORTEXR=am64x_evm_r5_defconfig - $ export UBOOT_CFG_CORTEXA=am64x_evm_a53_defconfig - $ export TFA_BOARD=lite - $ # we dont use any extra TFA parameters - $ unset TFA_EXTRA_ARGS - $ export OPTEE_PLATFORM=k3-am64x - $ # we dont use any extra TFA parameters - $ unset OPTEE_EXTRA_ARGS +.. prompt:: bash $ + + export UBOOT_CFG_CORTEXR=am64x_evm_r5_defconfig + export UBOOT_CFG_CORTEXA=am64x_evm_a53_defconfig + export TFA_BOARD=lite + # we dont use any extra TFA parameters + unset TFA_EXTRA_ARGS + export OPTEE_PLATFORM=k3-am64x + # we dont use any extra TFA parameters + unset OPTEE_EXTRA_ARGS
.. am64x_evm_rst_include_start_build_steps
diff --git a/doc/board/ti/am65x_evm.rst b/doc/board/ti/am65x_evm.rst index 7cebb1ca62d3..d8c58fad2a5e 100644 --- a/doc/board/ti/am65x_evm.rst +++ b/doc/board/ti/am65x_evm.rst @@ -75,16 +75,16 @@ Set the variables corresponding to this platform: .. include:: k3.rst :start-after: .. k3_rst_include_start_common_env_vars_defn :end-before: .. k3_rst_include_end_common_env_vars_defn -.. code-block:: bash +.. prompt:: bash $
- $ export UBOOT_CFG_CORTEXR=am65x_evm_r5_defconfig - $ export UBOOT_CFG_CORTEXA=am65x_evm_a53_defconfig - $ export TFA_BOARD=generic - $ # we dont use any extra TFA parameters - $ unset TFA_EXTRA_ARGS - $ export OPTEE_PLATFORM=k3-am65x - $ # we dont use any extra OP-TEE parameters - $ unset OPTEE_EXTRA_ARGS + export UBOOT_CFG_CORTEXR=am65x_evm_r5_defconfig + export UBOOT_CFG_CORTEXA=am65x_evm_a53_defconfig + export TFA_BOARD=generic + # we dont use any extra TFA parameters + unset TFA_EXTRA_ARGS + export OPTEE_PLATFORM=k3-am65x + # we dont use any extra OP-TEE parameters + unset OPTEE_EXTRA_ARGS
.. am65x_evm_rst_include_start_build_steps
@@ -159,32 +159,32 @@ The following commands can be used to download tiboot3.bin, tispl.bin, u-boot.img, and sysfw.itb from an SD card and write them to the eMMC boot0 partition at respective addresses.
-.. code-block:: text +.. prompt:: bash =>
- => mmc dev 0 1 - => fatload mmc 1 ${loadaddr} tiboot3.bin - => mmc write ${loadaddr} 0x0 0x400 - => fatload mmc 1 ${loadaddr} tispl.bin - => mmc write ${loadaddr} 0x400 0x1000 - => fatload mmc 1 ${loadaddr} u-boot.img - => mmc write ${loadaddr} 0x1400 0x2000 - => fatload mmc 1 ${loadaddr} sysfw.itb - => mmc write ${loadaddr} 0x3600 0x800 + mmc dev 0 1 + fatload mmc 1 ${loadaddr} tiboot3.bin + mmc write ${loadaddr} 0x0 0x400 + fatload mmc 1 ${loadaddr} tispl.bin + mmc write ${loadaddr} 0x400 0x1000 + fatload mmc 1 ${loadaddr} u-boot.img + mmc write ${loadaddr} 0x1400 0x2000 + fatload mmc 1 ${loadaddr} sysfw.itb + mmc write ${loadaddr} 0x3600 0x800
To give the ROM access to the boot partition, the following commands must be used for the first time:
- => mmc partconf 0 1 1 1 - => mmc bootbus 0 1 0 0 + mmc partconf 0 1 1 1 + mmc bootbus 0 1 0 0
To create a software partition for the rootfs, the following command can be used:
- => gpt write mmc 0 ${partitions} + gpt write mmc 0 ${partitions}
eMMC layout:
@@ -194,11 +194,11 @@ eMMC layout: Kernel image and DT are expected to be present in the /boot folder of rootfs. To boot kernel from eMMC, use the following commands:
- => setenv mmcdev 0 - => setenv bootpart 0 - => boot + setenv mmcdev 0 + setenv bootpart 0 + boot
OSPI: ----- @@ -210,17 +210,17 @@ Below commands can be used to download tiboot3.bin, tispl.bin, u-boot.img, and sysfw.itb over tftp and then flash those to OSPI at their respective addresses.
- => sf probe - => tftp ${loadaddr} tiboot3.bin - => sf update $loadaddr 0x0 $filesize - => tftp ${loadaddr} tispl.bin - => sf update $loadaddr 0x80000 $filesize - => tftp ${loadaddr} u-boot.img - => sf update $loadaddr 0x280000 $filesize - => tftp ${loadaddr} sysfw.itb - => sf update $loadaddr 0x6C0000 $filesize + sf probe + tftp ${loadaddr} tiboot3.bin + sf update $loadaddr 0x0 $filesize + tftp ${loadaddr} tispl.bin + sf update $loadaddr 0x80000 $filesize + tftp ${loadaddr} u-boot.img + sf update $loadaddr 0x280000 $filesize + tftp ${loadaddr} sysfw.itb + sf update $loadaddr 0x6C0000 $filesize
Flash layout for OSPI:
@@ -233,10 +233,10 @@ ospi.rootfs just like in SD card case. U-Boot looks for UBI volume named
To boot kernel from OSPI, at the U-Boot prompt:
- => setenv boot ubi - => boot + setenv boot ubi + boot
UART: ----- @@ -280,19 +280,19 @@ is fully loaded (from sysfw.itb) and started. Example bash script sequence for running on a Linux host PC feeding all boot artifacts needed to the device:
-.. code-block:: text +.. prompt:: bash $
- MCU_DEV=/dev/ttyUSB1 - MAIN_DEV=/dev/ttyUSB0 + MCU_DEV=/dev/ttyUSB1 + MAIN_DEV=/dev/ttyUSB0
- stty -F $MCU_DEV 115200 cs8 -cstopb -parenb - stty -F $MAIN_DEV 115200 cs8 -cstopb -parenb + stty -F $MCU_DEV 115200 cs8 -cstopb -parenb + stty -F $MAIN_DEV 115200 cs8 -cstopb -parenb
- sb --xmodem tiboot3.bin > $MCU_DEV < $MCU_DEV - sb --ymodem sysfw.itb > $MCU_DEV < $MCU_DEV - sb --ymodem tispl.bin > $MAIN_DEV < $MAIN_DEV - sleep 1 - sb --xmodem u-boot.img > $MAIN_DEV < $MAIN_DEV + sb --xmodem tiboot3.bin > $MCU_DEV < $MCU_DEV + sb --ymodem sysfw.itb > $MCU_DEV < $MCU_DEV + sb --ymodem tispl.bin > $MAIN_DEV < $MAIN_DEV + sleep 1 + sb --xmodem u-boot.img > $MAIN_DEV < $MAIN_DEV
Debugging U-Boot ---------------- @@ -314,6 +314,6 @@ detailed setup information.
openocd -f board/ti_am654evm.cfg diff --git a/doc/board/ti/j7200_evm.rst b/doc/board/ti/j7200_evm.rst index bcf8dc1c5f0d..f2c2e7f5db1c 100644 --- a/doc/board/ti/j7200_evm.rst +++ b/doc/board/ti/j7200_evm.rst @@ -64,16 +64,16 @@ Set the variables corresponding to this platform: .. include:: k3.rst :start-after: .. k3_rst_include_start_common_env_vars_defn :end-before: .. k3_rst_include_end_common_env_vars_defn -.. code-block:: bash +.. prompt:: bash $
- $ export UBOOT_CFG_CORTEXR=j7200_evm_r5_defconfig - $ export UBOOT_CFG_CORTEXA=j7200_evm_a72_defconfig - $ export TFA_BOARD=generic - $ # we dont use any extra TFA parameters - $ unset TFA_EXTRA_ARGS - $ export OPTEE_PLATFORM=k3-j7200 - $ # we dont use any extra OP-TEE parameters - $ unset OPTEE_EXTRA_ARGS + export UBOOT_CFG_CORTEXR=j7200_evm_r5_defconfig + export UBOOT_CFG_CORTEXA=j7200_evm_a72_defconfig + export TFA_BOARD=generic + # we dont use any extra TFA parameters + unset TFA_EXTRA_ARGS + export OPTEE_PLATFORM=k3-j7200 + # we dont use any extra OP-TEE parameters + unset OPTEE_EXTRA_ARGS
.. j7200_evm_rst_include_start_build_steps
@@ -225,6 +225,6 @@ detailed setup information.
openocd -f board/ti_j7200evm.cfg diff --git a/doc/board/ti/j721e_evm.rst b/doc/board/ti/j721e_evm.rst index cadaac017811..344a38d37486 100644 --- a/doc/board/ti/j721e_evm.rst +++ b/doc/board/ti/j721e_evm.rst @@ -69,16 +69,16 @@ Set the variables corresponding to this platform: .. include:: k3.rst :start-after: .. k3_rst_include_start_common_env_vars_defn :end-before: .. k3_rst_include_end_common_env_vars_defn -.. code-block:: bash +.. prompt:: bash $
- $ export UBOOT_CFG_CORTEXR=j721e_evm_r5_defconfig - $ export UBOOT_CFG_CORTEXA=j721e_evm_a72_defconfig - $ export TFA_BOARD=generic - $ # we dont use any extra TFA parameters - $ unset TFA_EXTRA_ARGS - $ export OPTEE_PLATFORM=k3-j721e - $ # we dont use any extra OP-TEE parameters - $ unset OPTEE_EXTRA_ARGS + export UBOOT_CFG_CORTEXR=j721e_evm_r5_defconfig + export UBOOT_CFG_CORTEXA=j721e_evm_a72_defconfig + export TFA_BOARD=generic + # we dont use any extra TFA parameters + unset TFA_EXTRA_ARGS + export OPTEE_PLATFORM=k3-j721e + # we dont use any extra OP-TEE parameters + unset OPTEE_EXTRA_ARGS
.. j721e_evm_rst_include_start_build_steps
@@ -202,17 +202,17 @@ Below commands can be used to download tiboot3.bin, tispl.bin, u-boot.img, and sysfw.itb over tftp and then flash those to OSPI at their respective addresses.
@@ -254,6 +254,6 @@ detailed setup information.
openocd -f board/ti_j721eevm.cfg diff --git a/doc/board/ti/j721s2_evm.rst b/doc/board/ti/j721s2_evm.rst index fec2acabe845..6db375a125b3 100644 --- a/doc/board/ti/j721s2_evm.rst +++ b/doc/board/ti/j721s2_evm.rst @@ -75,15 +75,15 @@ Set the variables corresponding to this platform: .. include:: k3.rst :start-after: .. k3_rst_include_start_common_env_vars_defn :end-before: .. k3_rst_include_end_common_env_vars_defn -.. code-block:: bash +.. prompt:: bash $
- $ export UBOOT_CFG_CORTEXR=j721s2_evm_r5_defconfig - $ export UBOOT_CFG_CORTEXA=j721s2_evm_a72_defconfig - $ export TFA_BOARD=generic - $ export TFA_EXTRA_ARGS="K3_USART=0x8" - $ # The following is not a typo, j784s4 is the OP-TEE platform for j721s2 - $ export OPTEE_PLATFORM=k3-j784s4 - $ export OPTEE_EXTRA_ARGS="CFG_CONSOLE_UART=0x8" + export UBOOT_CFG_CORTEXR=j721s2_evm_r5_defconfig + export UBOOT_CFG_CORTEXA=j721s2_evm_a72_defconfig + export TFA_BOARD=generic + export TFA_EXTRA_ARGS="K3_USART=0x8" + # The following is not a typo, j784s4 is the OP-TEE platform for j721s2 + export OPTEE_PLATFORM=k3-j784s4 + export OPTEE_EXTRA_ARGS="CFG_CONSOLE_UART=0x8"
.. j721s2_evm_rst_include_start_build_steps
@@ -296,7 +296,7 @@ Debugging U-Boot on J721S2-EVM
openocd -f board/ti_j721s2evm.cfg
Nishanth Menon
