[U-Boot] [PATCH] x86: Rename include/asm/ic to include/asm/arch-sc520
Also include some trivial related cleanups
Signed-off-by: Graeme Russ graeme.russ@gmail.com --- arch/x86/cpu/sc520/sc520.c | 2 +- arch/x86/cpu/sc520/sc520_car.S | 2 +- arch/x86/cpu/sc520/sc520_pci.c | 4 ++-- arch/x86/cpu/sc520/sc520_reset.c | 2 +- arch/x86/cpu/sc520/sc520_sdram.c | 2 +- arch/x86/cpu/sc520/sc520_ssi.c | 4 ++-- arch/x86/cpu/sc520/sc520_timer.c | 2 +- arch/x86/include/asm/{ic => arch-sc520}/pci.h | 0 arch/x86/include/asm/{ic => arch-sc520}/sc520.h | 0 arch/x86/include/asm/{ic => arch-sc520}/ssi.h | 0 arch/x86/lib/zimage.c | 1 - board/eNET/eNET.c | 2 +- board/eNET/eNET_pci.c | 2 +- board/eNET/eNET_start16.S | 4 +--- 14 files changed, 12 insertions(+), 15 deletions(-) rename arch/x86/include/asm/{ic => arch-sc520}/pci.h (100%) rename arch/x86/include/asm/{ic => arch-sc520}/sc520.h (100%) rename arch/x86/include/asm/{ic => arch-sc520}/ssi.h (100%)
diff --git a/arch/x86/cpu/sc520/sc520.c b/arch/x86/cpu/sc520/sc520.c index e37c403..4892c01 100644 --- a/arch/x86/cpu/sc520/sc520.c +++ b/arch/x86/cpu/sc520/sc520.c @@ -27,7 +27,7 @@ #include <common.h> #include <asm/io.h> #include <asm/processor-flags.h> -#include <asm/ic/sc520.h> +#include <asm/arch/sc520.h>
DECLARE_GLOBAL_DATA_PTR;
diff --git a/arch/x86/cpu/sc520/sc520_car.S b/arch/x86/cpu/sc520/sc520_car.S index a33f94f..7cac4d1 100644 --- a/arch/x86/cpu/sc520/sc520_car.S +++ b/arch/x86/cpu/sc520/sc520_car.S @@ -23,7 +23,7 @@
#include <config.h> #include <asm/processor-flags.h> -#include <asm/ic/sc520.h> +#include <asm/arch/sc520.h>
.section .text
diff --git a/arch/x86/cpu/sc520/sc520_pci.c b/arch/x86/cpu/sc520/sc520_pci.c index 32d4802..e26793a 100644 --- a/arch/x86/cpu/sc520/sc520_pci.c +++ b/arch/x86/cpu/sc520/sc520_pci.c @@ -28,8 +28,8 @@ #include <pci.h> #include <asm/io.h> #include <asm/pci.h> -#include <asm/ic/pci.h> -#include <asm/ic/sc520.h> +#include <asm/arch/pci.h> +#include <asm/arch/sc520.h>
static struct { u8 priority; diff --git a/arch/x86/cpu/sc520/sc520_reset.c b/arch/x86/cpu/sc520/sc520_reset.c index 18890c3..137af97 100644 --- a/arch/x86/cpu/sc520/sc520_reset.c +++ b/arch/x86/cpu/sc520/sc520_reset.c @@ -26,7 +26,7 @@
#include <common.h> #include <asm/io.h> -#include <asm/ic/sc520.h> +#include <asm/arch/sc520.h>
diff --git a/arch/x86/cpu/sc520/sc520_sdram.c b/arch/x86/cpu/sc520/sc520_sdram.c index f3623f5..57e4e7d 100644 --- a/arch/x86/cpu/sc520/sc520_sdram.c +++ b/arch/x86/cpu/sc520/sc520_sdram.c @@ -24,7 +24,7 @@ #include <common.h> #include <asm/io.h> #include <asm/processor-flags.h> -#include <asm/ic/sc520.h> +#include <asm/arch/sc520.h>
diff --git a/arch/x86/cpu/sc520/sc520_ssi.c b/arch/x86/cpu/sc520/sc520_ssi.c index 47aa80b..3a6a858 100644 --- a/arch/x86/cpu/sc520/sc520_ssi.c +++ b/arch/x86/cpu/sc520/sc520_ssi.c @@ -23,8 +23,8 @@
#include <common.h> #include <asm/io.h> -#include <asm/ic/ssi.h> -#include <asm/ic/sc520.h> +#include <asm/arch/ssi.h> +#include <asm/arch/sc520.h>
int ssi_set_interface(int freq, int lsb_first, int inv_clock, int inv_phase) { diff --git a/arch/x86/cpu/sc520/sc520_timer.c b/arch/x86/cpu/sc520/sc520_timer.c index 5cccda1..05bc9c1 100644 --- a/arch/x86/cpu/sc520/sc520_timer.c +++ b/arch/x86/cpu/sc520/sc520_timer.c @@ -27,7 +27,7 @@ #include <common.h> #include <asm/io.h> #include <asm/interrupt.h> -#include <asm/ic/sc520.h> +#include <asm/arch/sc520.h>
void sc520_timer_isr(void) { diff --git a/arch/x86/include/asm/ic/pci.h b/arch/x86/include/asm/arch-sc520/pci.h similarity index 100% rename from arch/x86/include/asm/ic/pci.h rename to arch/x86/include/asm/arch-sc520/pci.h diff --git a/arch/x86/include/asm/ic/sc520.h b/arch/x86/include/asm/arch-sc520/sc520.h similarity index 100% rename from arch/x86/include/asm/ic/sc520.h rename to arch/x86/include/asm/arch-sc520/sc520.h diff --git a/arch/x86/include/asm/ic/ssi.h b/arch/x86/include/asm/arch-sc520/ssi.h similarity index 100% rename from arch/x86/include/asm/ic/ssi.h rename to arch/x86/include/asm/arch-sc520/ssi.h diff --git a/arch/x86/lib/zimage.c b/arch/x86/lib/zimage.c index 6682e0d..d2dd6fd 100644 --- a/arch/x86/lib/zimage.c +++ b/arch/x86/lib/zimage.c @@ -35,7 +35,6 @@ #include <asm/realmode.h> #include <asm/byteorder.h> #include <asm/bootparam.h> -#include <asm/ic/sc520.h>
/* * Memory lay-out: diff --git a/board/eNET/eNET.c b/board/eNET/eNET.c index 2a5636c..c4ed820 100644 --- a/board/eNET/eNET.c +++ b/board/eNET/eNET.c @@ -23,7 +23,7 @@
#include <common.h> #include <asm/io.h> -#include <asm/ic/sc520.h> +#include <asm/arch/sc520.h> #include <net.h> #include <netdev.h>
diff --git a/board/eNET/eNET_pci.c b/board/eNET/eNET_pci.c index d97387e..29d13d2 100644 --- a/board/eNET/eNET_pci.c +++ b/board/eNET/eNET_pci.c @@ -27,7 +27,7 @@ #include <common.h> #include <pci.h> #include <asm/pci.h> -#include <asm/ic/pci.h> +#include <asm/arch/pci.h>
static void pci_enet_fixup_irq(struct pci_controller *hose, pci_dev_t dev) { diff --git a/board/eNET/eNET_start16.S b/board/eNET/eNET_start16.S index 77e5519..4241f6e 100644 --- a/board/eNET/eNET_start16.S +++ b/board/eNET/eNET_start16.S @@ -27,11 +27,9 @@ * that is used by U-boot to its final destination. */
-/* #include <asm/ic/sc520_defs.h> */ - #include "config.h" #include "hardware.h" -#include <asm/ic/sc520.h> +#include <asm/arch/sc520.h>
.text .section .start16, "ax"
Hi Wolfgang,
I missed the merge window by a day, but since this is a tidy-up that touches only x86, do you mind if I apply it to the x86 repo anyway before I send through a pull request?
It is checkpatch clean in case your wondering
Regards,
Graeme
Dear Graeme Russ,
No problem with that - see http://www.denx.de/wiki/U-Boot/DevelopmentProcess#CornerCases
Graeme Russ
