[U-Boot] [PATCH] armv8: Enable all 8 DPMAC ports in LS2080A Personality
LS2080A has support for 8 DPMAC ports out of which only 5 ports can be used at a time. Enabling all 8 DPMAC ports of LS2080A personality.
Signed-off-by: Pratiyush Mohan Srivastava pratiyush.srivastava@freescale.com --- arch/arm/cpu/armv8/fsl-layerscape/ls2080a_serdes.c | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls2080a_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/ls2080a_serdes.c index 8ef4f1c..ea3114c 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/ls2080a_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls2080a_serdes.c @@ -28,12 +28,7 @@ static struct serdes_config serdes1_cfg_tbl[] = { SGMII1 } }, {0x26, {SGMII8, SGMII7, SGMII6, SGMII5, SGMII4, SGMII3, XFI2, XFI1 } }, {0x28, {SGMII8, SGMII7, SGMII6, SGMII5, XFI4, XFI3, XFI2, XFI1 } }, -#ifdef CONFIG_LS2080A - {0x2A, {NONE, NONE, NONE, XFI5, XFI4, XFI3, XFI2, XFI1 } }, -#endif -#ifdef CONFIG_LS2085A {0x2A, {XFI8, XFI7, XFI6, XFI5, XFI4, XFI3, XFI2, XFI1 } }, -#endif {0x2B, {SGMII8, SGMII7, SGMII6, SGMII5, XAUI1, XAUI1, XAUI1, XAUI1 } }, {0x32, {XAUI2, XAUI2, XAUI2, XAUI2, XAUI1, XAUI1, XAUI1, XAUI1 } }, {0x33, {PCIE2, PCIE2, PCIE2, PCIE2, QSGMII_C, QSGMII_D, QSGMII_A,
-----Original Message----- From: Pratiyush Srivastava Sent: Tuesday, December 22, 2015 4:48 PM To: u-boot@lists.denx.de Cc: Yusong Sun yorksun@freescale.com; Prabhakar Kushwaha prabhakar@freescale.com; Pratiyush Srivastava pratiyush.srivastava@freescale.com Subject: [PATCH] armv8: Enable all 8 DPMAC ports in LS2080A Personality
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls2080a_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/ls2080a_serdes.c index 8ef4f1c..ea3114c 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/ls2080a_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls2080a_serdes.c @@ -28,12 +28,7 @@ static struct serdes_config serdes1_cfg_tbl[] = { SGMII1 } }, {0x26, {SGMII8, SGMII7, SGMII6, SGMII5, SGMII4, SGMII3, XFI2, XFI1 } }, {0x28, {SGMII8, SGMII7, SGMII6, SGMII5, XFI4, XFI3, XFI2, XFI1 } }, - #ifdef CONFIG_LS2080A
-#endif -#ifdef CONFIG_LS2085A {0x2A, {XFI8, XFI7, XFI6, XFI5, XFI4, XFI3, XFI2, XFI1 } }, -#endif {0x2B, {SGMII8, SGMII7, SGMII6, SGMII5, XAUI1, XAUI1, XAUI1, XAUI1 } }, {0x32, {XAUI2, XAUI2, XAUI2, XAUI2, XAUI1, XAUI1, XAUI1, XAUI1 } }, {0x33, {PCIE2, PCIE2, PCIE2, PCIE2, QSGMII_C, QSGMII_D, QSGMII_A, --
Acked-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com
Applied to u-boot-fsl-qoriq master. Awaiting upstream.
Thanks.
York
Prabhakar Kushwaha
york sun
