[PATCH v2 0/8] An effort to bring DT bindings compliance within U-Boot
Changes in v2: -------------- - Patch #1: excluded gitab CI config check and added commit description. - Patch #3: s/UBOOT_DTSI_LOC/u_boot_dtsi_loc/ - Patch #4: s/DEVICE_TREE_LOC/dt_dir/ and s/U-boot/U-Boot/ - Patch #5: s/U-boot/U-Boot/ - Patch #6 and #7: Picked up review tags
Prerequisite ------------
This patch series requires devicetree-rebasing git repo to be added as a subtree to the main U-Boot repo via:
$ git subtree add --prefix devicetree-rebasing \ git://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasing.git \ v6.6-dts --squash
Background ----------
This effort started while I was reviewing patch series corresponding to Qcom platforms [1] which was about to import modified devicetree source files from Linux kernel. I suppose keeping devicetree files sync with Linux kernel without any DT bindings schema validation has been a pain for U-Boot SoC/platform maintainers. There has been past discussions about a single DT repo but that hasn't come up and Linux kernel remained the place where DT source files as well as bindings are placed and maintained.
However, Linux kernel DT maintainers proposed [2] for U-Boot to rather use devicetree-rebasing repo [3] which is a forked copy from Linux kernel for DT source files as well as bindings. It is tagged at every Linux kernel major release or intermideate release candidates. So here I have tried to reuse that to bring DT bingings compliance as well as a standard way to maintain a regular sync of DT source files with Linux kernel.
In order to maintain devicetree files sync, U-Boot will maintains a Git subtree for devicetee-rebasing repo as `devicetee-rebasing/` sub-directory. It will be regularly updated with every new kernel major release via subtree pull as follows:
$ git subtree pull --prefix devicetree-rebasing \ git://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasing.git \ <release-tag> --squash
The RFC/prototype for this series has been discussed with Linux DT maintainers as well as U-Boot maintainers here [4]. Now we would like to reach out to wider U-Boot community to seek feedback.
[1] https://lore.kernel.org/all/CAFA6WYMLUD9cnkr=R0Uur+1UeTMkKjM2zDdMJtXb3nmrLk+... [2] https://lore.kernel.org/all/CAL_JsqKEjv2tSGmT+0ZiO7_qbBfhTycbGnhJhYpKDFzfO9j... [3] https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasi... [4] https://github.com/u-boot/u-boot/pull/451
Changes -------
Traditionally, U-Boot placed copies of devicetree source files from Linux kernel into `arch/<arch>/dts/<name>.dts`, which can be selected via:
CONFIG_DEFAULT_DEVICE_TREE "<name>"
SoC/board maintainers are encouraged to migrate to using mirrored copies from `devicetree-rebasing/` into `dts/arch/<arch>/<vendor>` via:
CONFIG_OF_UPSTREAM=y CONFIG_DEFAULT_DEVICE_TREE "<vendor>/<name>"
An example have been shown for Amlogic meson-gxbb SoC and corresponding derived boards via patch #7 and #8.
Devicetree bindings schema checks ---------------------------------
With devicetee-rebasing Git subtree, the devicetree bindings are also regularly synced with Linux kernel as `devicetree-rebasing/Bindings/` sub-directory. This allows U-Boot to run devicetree bindings schema checks which will bring compliance to U-Boot core/drivers regarding usage of devicetree.
Dependencies ------------
The DT schema project must be installed in order to validate the DT schema binding documents and validate DTS files using the DT schema. The DT schema project can be installed with pip:
$ pip3 install dtschema
Note that 'dtschema' installation requires 'swig' and Python development files installed first. On Debian/Ubuntu systems:
$ apt install swig python3-dev
Several executables (dt-doc-validate, dt-mk-schema, dt-validate) will be installed. Ensure they are in your PATH (~/.local/bin by default).
Recommended is also to install yamllint (used by dtschema when present).
Running checks --------------
In order to perform validation of DTB files, use the ``dtbs_check`` target:
$ make dtbs_check
It is also possible to run checks with a subset of matching schema files by setting the ``DT_SCHEMA_FILES`` variable to 1 or more specific schema files or patterns (partial match of a fixed string). Each file or pattern should be separated by ':'.
$ make dtbs_check DT_SCHEMA_FILES=trivial-devices.yaml:rtc.yaml $ make dtbs_check DT_SCHEMA_FILES=/gpio/ $ make dtbs_check DT_SCHEMA_FILES=trivial-devices.yaml
Sumit Garg (8): CI: Exclude devicetree-rebasing subtree for CONFIG checks Makefile: Add support for DT bindings schema checks scripts/Makefile.lib: Statically define *-u-boot.dtsi files location dts: Add alternative location for upstream DTB builds doc: devicetree: Updates for devicetree-rebasing subtree MAINTAINERS: Add myself as devicetree-rebasing maintainer dts: meson-gxbb: Switch to using upstream DT dts: meson-gxbb: Drop redundant devicetree files
.azure-pipelines.yml | 3 +- .gitlab-ci.yml | 3 +- MAINTAINERS | 6 + Makefile | 20 +- arch/arm/dts/Makefile | 8 - arch/arm/dts/meson-gxbb-kii-pro.dts | 140 ---- arch/arm/dts/meson-gxbb-nanopi-k2.dts | 415 ------------ arch/arm/dts/meson-gxbb-odroidc2.dts | 418 ------------ arch/arm/dts/meson-gxbb-p200.dts | 100 --- arch/arm/dts/meson-gxbb-p201.dts | 26 - arch/arm/dts/meson-gxbb-p20x.dtsi | 250 ------- arch/arm/dts/meson-gxbb-wetek-hub.dts | 58 -- arch/arm/dts/meson-gxbb-wetek-play2.dts | 119 ---- arch/arm/dts/meson-gxbb-wetek.dtsi | 292 -------- arch/arm/dts/meson-gxbb.dtsi | 856 ------------------------ configs/nanopi-k2_defconfig | 3 +- configs/odroid-c2_defconfig | 3 +- configs/p200_defconfig | 3 +- configs/p201_defconfig | 3 +- configs/videostrong-kii-pro_defconfig | 3 +- configs/wetek-hub_defconfig | 3 +- configs/wetek-play2_defconfig | 3 +- doc/develop/devicetree/control.rst | 108 ++- dts/Kconfig | 11 + dts/Makefile | 17 +- dts/arch/arm64/Makefile | 23 + dts/arch/arm64/amlogic | 1 + scripts/Makefile.lib | 42 +- 28 files changed, 206 insertions(+), 2731 deletions(-) delete mode 100644 arch/arm/dts/meson-gxbb-kii-pro.dts delete mode 100644 arch/arm/dts/meson-gxbb-nanopi-k2.dts delete mode 100644 arch/arm/dts/meson-gxbb-odroidc2.dts delete mode 100644 arch/arm/dts/meson-gxbb-p200.dts delete mode 100644 arch/arm/dts/meson-gxbb-p201.dts delete mode 100644 arch/arm/dts/meson-gxbb-p20x.dtsi delete mode 100644 arch/arm/dts/meson-gxbb-wetek-hub.dts delete mode 100644 arch/arm/dts/meson-gxbb-wetek-play2.dts delete mode 100644 arch/arm/dts/meson-gxbb-wetek.dtsi delete mode 100644 arch/arm/dts/meson-gxbb.dtsi create mode 100644 dts/arch/arm64/Makefile create mode 120000 dts/arch/arm64/amlogic
Since devicetree-rebasing is an external repo with its own coding style, exclude it from Azure and gitlab CI CONFIG checks.
Signed-off-by: Sumit Garg sumit.garg@linaro.org --- .azure-pipelines.yml | 3 ++- .gitlab-ci.yml | 3 ++- 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index d6f3fa423c6..f100c4493e6 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -65,7 +65,8 @@ stages: # have no matches. - script: git grep -E '^#[[:blank:]]*(define|undef)[[:blank:]]*CONFIG_' :^doc/ :^arch/arm/dts/ :^scripts/kconfig/lkc.h - :^include/linux/kconfig.h :^tools/ && exit 1 || exit 0 + :^include/linux/kconfig.h :^tools/ :^devicetree-rebasing/ && + exit 1 || exit 0
- job: docs displayName: 'Build documentation' diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index fee165198ae..96ca9f72bbc 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -161,7 +161,8 @@ check for new CONFIG symbols outside Kconfig: # have no matches. - git grep -E '^#[[:blank:]]*(define|undef)[[:blank:]]*CONFIG_' :^doc/ :^arch/arm/dts/ :^scripts/kconfig/lkc.h - :^include/linux/kconfig.h :^tools/ && exit 1 || exit 0 + :^include/linux/kconfig.h :^tools/ :^devicetree-rebasing/ && + exit 1 || exit 0
# build documentation docs:
This adds the build infrastructure for checking DT binding schema documents and validating dtb files using the binding schema. Here we use devicetree-rebasing directory to provide the DT bindings.
Dependency: -----------
The DT schema project must be installed in order to validate the DT schema binding documents and validate DTS files using the DT schema. The DT schema project can be installed with pip::
Note that 'dtschema' installation requires 'swig' and Python development files installed first. On Debian/Ubuntu systems::
Testing: --------
Build dts files and check using DT binding schema: $ make dtbs_check
Optionally, DT_SCHEMA_FILES can be passed in with a schema file(s) to use for validation. This makes it easier to find and fix errors generated by a specific schema.
Note, at this point dtbs_check is an optional build target as there are many warnings generated due to custom DT properties used by many platforms in u-boot. It is expected with these checks that compliance with DT bindings to take place. Once that's done it can be added to CI builds to remain compliant with DT bindings.
Signed-off-by: Sumit Garg sumit.garg@linaro.org --- Makefile | 20 ++++++++++++++++++-- scripts/Makefile.lib | 17 +++++++++++++++-- 2 files changed, 33 insertions(+), 4 deletions(-)
diff --git a/Makefile b/Makefile index 750bbdb1b71..d8d168cd4c3 100644 --- a/Makefile +++ b/Makefile @@ -1158,12 +1158,28 @@ endif @# disabling OF_BOARD. $(call cmd,ofcheck,$(KCONFIG_CONFIG))
-PHONY += dtbs +PHONY += dtbs dtbs_check dtbs: dts/dt.dtb @: -dts/dt.dtb: u-boot +dts/dt.dtb: dtbs_prepare u-boot $(Q)$(MAKE) $(build)=dts dtbs
+dtbs_prepare: prepare3 + +ifneq ($(filter dtbs_check, $(MAKECMDGOALS)),) +export CHECK_DTBS=y +endif + +ifneq ($(CHECK_DTBS),) +dtbs_prepare: dt_binding_check +endif + +dtbs_check: dt_binding_check dtbs + +DT_BINDING_DIR := devicetree-rebasing/Bindings +dt_binding_check: scripts_dtc + $(Q)$(MAKE) $(build)=$(DT_BINDING_DIR) $(DT_BINDING_DIR)/processed-schema.json + quiet_cmd_copy = COPY $@ cmd_copy = cp $< $@
diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index 16bbc277a9f..27b9437027c 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -356,8 +356,21 @@ endif
dtsi_include_list_deps = $(addprefix $(obj)/,$(subst $(quote),,$(dtsi_include_list)))
-$(obj)/%.dtb: $(src)/%.dts $(DTC) $(dtsi_include_list_deps) FORCE - $(call if_changed_dep,dtc) +ifneq ($(CHECK_DTBS),) +DT_CHECKER ?= dt-validate +DT_CHECKER_FLAGS ?= $(if $(DT_SCHEMA_FILES),-l $(DT_SCHEMA_FILES),-m) +DT_BINDING_DIR := devicetree-rebasing/Bindings +DT_TMP_SCHEMA := $(objtree)/$(DT_BINDING_DIR)/processed-schema.json + +quiet_cmd_dtb = DTC_CHK $@ + cmd_dtb = $(cmd_dtc) ; $(DT_CHECKER) $(DT_CHECKER_FLAGS) -u $(srctree)/$(DT_BINDING_DIR) -p $(DT_TMP_SCHEMA) $@ || true +else +quiet_cmd_dtb = $(quiet_cmd_dtc) + cmd_dtb = $(cmd_dtc) +endif + +$(obj)/%.dtb: $(src)/%.dts $(DTC) $(dtsi_include_list_deps) $(DT_TMP_SCHEMA) FORCE + $(call if_changed_dep,dtb)
pre-tmp = $(subst $(comma),_,$(dot-target).pre.tmp) dtc-tmp = $(subst $(comma),_,$(dot-target).dts.tmp)
Allow u-boot to build DTB from a different directory tree such that *-u-boot.dtsi files can be included from a common location. Currently that location is arch/$(ARCH)/dts/, so statically define that common location.
This is needed for platform owners to start building DTB files from devicetree-rebasing directory but still being able to include *-u-boot.dtsi files.
Signed-off-by: Sumit Garg sumit.garg@linaro.org --- scripts/Makefile.lib | 25 ++++++++++++++----------- 1 file changed, 14 insertions(+), 11 deletions(-)
diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index 27b9437027c..09330421856 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -159,18 +159,20 @@ cpp_flags = -Wp,-MD,$(depfile) $(NOSTDINC_FLAGS) $(UBOOTINCLUDE) \ ld_flags = $(KBUILD_LDFLAGS) $(ldflags-y) $(LDFLAGS_$(@F))
# Try these files in order to find the U-Boot-specific .dtsi include file -u_boot_dtsi_options = $(strip $(wildcard $(dir $<)$(basename $(notdir $<))-u-boot.dtsi) \ - $(wildcard $(dir $<)$(subst $",,$(CONFIG_SYS_SOC))-u-boot.dtsi) \ - $(wildcard $(dir $<)$(subst $",,$(CONFIG_SYS_CPU))-u-boot.dtsi) \ - $(wildcard $(dir $<)$(subst $",,$(CONFIG_SYS_VENDOR))-u-boot.dtsi) \ - $(wildcard $(dir $<)u-boot.dtsi)) +u_boot_dtsi_loc = $(srctree)/arch/$(ARCH)/dts/ + +u_boot_dtsi_options = $(strip $(wildcard $(u_boot_dtsi_loc)$(basename $(notdir $<))-u-boot.dtsi) \ + $(wildcard $(u_boot_dtsi_loc)$(subst $",,$(CONFIG_SYS_SOC))-u-boot.dtsi) \ + $(wildcard $(u_boot_dtsi_loc)$(subst $",,$(CONFIG_SYS_CPU))-u-boot.dtsi) \ + $(wildcard $(u_boot_dtsi_loc)$(subst $",,$(CONFIG_SYS_VENDOR))-u-boot.dtsi) \ + $(wildcard $(u_boot_dtsi_loc)u-boot.dtsi))
u_boot_dtsi_options_raw = $(warning Automatic .dtsi inclusion: options: \ - $(dir $<)$(basename $(notdir $<))-u-boot.dtsi \ - $(dir $<)$(subst $",,$(CONFIG_SYS_SOC))-u-boot.dtsi \ - $(dir $<)$(subst $",,$(CONFIG_SYS_CPU))-u-boot.dtsi \ - $(dir $<)$(subst $",,$(CONFIG_SYS_VENDOR))-u-boot.dtsi \ - $(dir $<)u-boot.dtsi ... \ + $(u_boot_dtsi_loc)$(basename $(notdir $<))-u-boot.dtsi \ + $(u_boot_dtsi_loc)$(subst $",,$(CONFIG_SYS_SOC))-u-boot.dtsi \ + $(u_boot_dtsi_loc)$(subst $",,$(CONFIG_SYS_CPU))-u-boot.dtsi \ + $(u_boot_dtsi_loc)$(subst $",,$(CONFIG_SYS_VENDOR))-u-boot.dtsi \ + $(u_boot_dtsi_loc)u-boot.dtsi ... \ found: $(if $(u_boot_dtsi_options),"$(u_boot_dtsi_options)",nothing!))
# Uncomment for debugging @@ -190,6 +192,7 @@ dtsi_include_list += $(CONFIG_DEVICE_TREE_INCLUDES) dtc_cpp_flags = -Wp,-MD,$(depfile).pre.tmp -nostdinc \ $(UBOOTINCLUDE) \ -I$(dir $<) \ + -I$(u_boot_dtsi_loc) \ -I$(srctree)/arch/$(ARCH)/dts/include \ -I$(srctree)/include \ -D__ASSEMBLY__ \ @@ -328,7 +331,7 @@ cmd_dtc = mkdir -p $(dir ${dtc-tmp}) ; \ echo '$(pound)include "$(f)"' >> $(pre-tmp);) \ $(HOSTCC) -E $(dtc_cpp_flags) -x assembler-with-cpp -o $(dtc-tmp) $(pre-tmp) ; \ $(DTC) -O dtb -o $@ -b 0 \ - -i $(dir $<) $(DTC_FLAGS) \ + -i $(dir $<) -i $(u_boot_dtsi_loc) $(DTC_FLAGS) \ -d $(depfile).dtc.tmp $(dtc-tmp) || \ (echo "Check $(shell pwd)/$(pre-tmp) for errors" && false) \ ; \
Hi Sumit,
This is a v2 patch but I don't see a change log?
On Tue, 26 Dec 2023 at 15:17, Simon Glass sjg@chromium.org wrote:
Hi Sumit,
I usually prefer to keep change logs in the cover letter [1].
[1] https://lore.kernel.org/all/20231222061208.3009970-1-sumit.garg@linaro.org/
Thanks. -Sumit
Hi Sumit,
Hi Sumit,
As a reviewer I much prefer to see the changes with the patch. If you use patman you can have both, I suppose.
Hi Sumit,
Thanks this looks great
$(wildcard $(dir $<)$(subst $\",,$(CONFIG_SYS_SOC))-u-boot.dtsi) \
$(wildcard $(dir $<)$(subst $\",,$(CONFIG_SYS_CPU))-u-boot.dtsi) \
$(wildcard $(dir $<)$(subst $\",,$(CONFIG_SYS_VENDOR))-u-boot.dtsi) \
$(wildcard $(u_boot_dtsi_loc)$(subst $\",,$(CONFIG_SYS_SOC))-u-boot.dtsi) \
$(wildcard $(u_boot_dtsi_loc)$(subst $\",,$(CONFIG_SYS_CPU))-u-boot.dtsi) \
$(wildcard $(u_boot_dtsi_loc)$(subst $\",,$(CONFIG_SYS_VENDOR))-u-boot.dtsi) \
$(dir $<)$(subst $\",,$(CONFIG_SYS_SOC))-u-boot.dtsi \
$(dir $<)$(subst $\",,$(CONFIG_SYS_CPU))-u-boot.dtsi \
$(dir $<)$(subst $\",,$(CONFIG_SYS_VENDOR))-u-boot.dtsi \
$(u_boot_dtsi_loc)$(subst $\",,$(CONFIG_SYS_SOC))-u-boot.dtsi \
$(u_boot_dtsi_loc)$(subst $\",,$(CONFIG_SYS_CPU))-u-boot.dtsi \
$(u_boot_dtsi_loc)$(subst $\",,$(CONFIG_SYS_VENDOR))-u-boot.dtsi \
-- 2.34.1
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Allow platform owners to mirror devicetree files from devitree-rebasing directory into dts/arch/$(ARCH) (special case for dts/arch/arm64). Then build then along with any *-u-boot.dtsi file present in arch/$(ARCH)/dts directory.
This will help easy migration for platforms which currently are compliant with upstream Linux kernel devicetree files.
Signed-off-by: Sumit Garg sumit.garg@linaro.org --- dts/Kconfig | 11 +++++++++++ dts/Makefile | 17 ++++++++++++++--- dts/arch/arm64/Makefile | 14 ++++++++++++++ 3 files changed, 39 insertions(+), 3 deletions(-) create mode 100644 dts/arch/arm64/Makefile
diff --git a/dts/Kconfig b/dts/Kconfig index 00c0aeff893..e58c1c6f2ab 100644 --- a/dts/Kconfig +++ b/dts/Kconfig @@ -85,6 +85,17 @@ config OF_LIVE enables a live tree which is available after relocation, and can be adjusted as needed.
+config OF_UPSTREAM + bool "Enable use of devicetree imported from Linux kernel release" + help + Traditionally, U-Boot platforms used to have their custom devicetree + files or copy devicetree files from Linux kernel which are hard to + maintain and can usually get out-of-sync from Linux kernel. This + option enables platforms to migrate to devicetree-rebasing repo where + a regular sync will be maintained every major Linux kernel release + cycle. However, platforms can still have some custom u-boot specific + bits maintained as part of *-u-boot.dtsi files. + choice prompt "Provider of DTB for DT control" depends on OF_CONTROL diff --git a/dts/Makefile b/dts/Makefile index 3437e54033d..68daaf45ec7 100644 --- a/dts/Makefile +++ b/dts/Makefile @@ -10,10 +10,20 @@ ifeq ($(DEVICE_TREE),) DEVICE_TREE := unset endif
+ifeq ($(CONFIG_OF_UPSTREAM),y) +ifeq ($(CONFIG_ARM64),y) +dt_dir := dts/arch/arm64 +else +dt_dir := dts/arch/$(ARCH) +endif +else +dt_dir := arch/$(ARCH)/dts +endif + ifneq ($(EXT_DTB),) DTB := $(EXT_DTB) else -DTB := arch/$(ARCH)/dts/$(DEVICE_TREE).dtb +DTB := $(dt_dir)/$(DEVICE_TREE).dtb endif
$(obj)/dt-$(SPL_NAME).dtb: dts/dt.dtb $(objtree)/tools/fdtgrep FORCE @@ -41,7 +51,7 @@ $(DTB): arch-dtbs
PHONY += arch-dtbs arch-dtbs: - $(Q)$(MAKE) $(build)=arch/$(ARCH)/dts dtbs + $(Q)$(MAKE) $(build)=$(dt_dir) dtbs
ifeq ($(CONFIG_SPL_BUILD),y) obj-$(CONFIG_OF_EMBED) := dt-spl.dtb.o @@ -65,4 +75,5 @@ clean-files := dt.dtb.S # Let clean descend into dts directories subdir- += ../arch/arc/dts ../arch/arm/dts ../arch/m68k/dts ../arch/microblaze/dts \ ../arch/mips/dts ../arch/nios2/dts ../arch/powerpc/dts ../arch/riscv/dts \ - ../arch/sandbox/dts ../arch/sh/dts ../arch/x86/dts ../arch/xtensa/dts + ../arch/sandbox/dts ../arch/sh/dts ../arch/x86/dts ../arch/xtensa/dts \ + ./arch/arm64 ./arch/$(ARCH) diff --git a/dts/arch/arm64/Makefile b/dts/arch/arm64/Makefile new file mode 100644 index 00000000000..16e9fea622d --- /dev/null +++ b/dts/arch/arm64/Makefile @@ -0,0 +1,14 @@ +# SPDX-License-Identifier: GPL-2.0+ + +include $(srctree)/scripts/Makefile.dts + +targets += $(dtb-y) + +# Add any required device tree compiler flags here +DTC_FLAGS += -a 0x8 + +PHONY += dtbs +dtbs: $(addprefix $(obj)/, $(dtb-y)) + @: + +clean-files := */*.dtb */*.dtbo */*_HS
Encourage SoC/board maintainers to migrate to using devicetree-rebasing subtree and maintain a regular sync with Linux kernel devicetree files and bindings.
Along with that add documentation regarding how to run DT bindings schema checks.
Signed-off-by: Sumit Garg sumit.garg@linaro.org --- doc/develop/devicetree/control.rst | 108 +++++++++++++++++++++++------ 1 file changed, 86 insertions(+), 22 deletions(-)
diff --git a/doc/develop/devicetree/control.rst b/doc/develop/devicetree/control.rst index cbb65c9b177..7c15f6d8c19 100644 --- a/doc/develop/devicetree/control.rst +++ b/doc/develop/devicetree/control.rst @@ -1,5 +1,6 @@ .. SPDX-License-Identifier: GPL-2.0+ .. sectionauthor:: Copyright 2011 The Chromium OS Authors +.. Copyright 2023 Linaro Ltd.
Devicetree Control in U-Boot ============================ @@ -22,12 +23,11 @@ for three reasons: hierarchical format - It is fairly efficient to read incrementally
-The arch/<arch>/dts directories contains a Makefile for building the devicetree -blob and embedding it in the U-Boot image. This is useful since it allows -U-Boot to configure itself according to what it finds there. If you have -a number of similar boards with different peripherals, you can describe -the features of each board in the devicetree file, and have a single -generic source base. +The U-Boot Makefile infrastructure allows for building the devicetree blob +and embedding it in the U-Boot image. This is useful since it allows U-Boot +to configure itself according to what it finds there. If you have a number +of similar boards with different peripherals, you can describe the features +of each board in the devicetree file, and have a single generic source base.
To enable this feature, add CONFIG_OF_CONTROL to your board config file.
@@ -68,8 +68,21 @@ a binary file. U-Boot adds its own `fdtgrep` for creating subsets of the file. Where do I get a devicetree file for my board? ----------------------------------------------
-You may find that the Linux kernel has a suitable file. Look in the -kernel source in arch/<arch>/boot/dts. +Linux kernel Git repository has been the place where devicetree files along +with devicetree bindings are stored and maintained. There is devicetee-rebasing +(dtrepo_) which maintains a forked copy of devicetree files along with bindings +at every Linux kernel major release or intermideate release candidates. + +In order to maintain devicetree files sync, U-Boot maintains a Git subtree for +devicetee-rebasing repo as `devicetee-rebasing/` sub-directory. It is regularly +kept updated with every new kernel major release via subtree pull as follows:: + + git subtree pull --prefix devicetree-rebasing \ + git://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasing.git \ + <release-tag> --squash + +You may find that the `devicetee-rebasing/` sub-directory has a suitable +devicetree file for your board. Look in `devicetree-rebasing/src/<arch>/`.
If not you might find other boards with suitable files that you can modify to your needs. Look in the board directories for files with a @@ -81,18 +94,21 @@ Failing that, you could write one from scratch yourself! Configuration -------------
-Use:: +Traditionally, U-Boot placed copies of devicetree source files from Linux +kernel into `arch/<arch>/dts/<name>.dts` which can be selected via::
- #define CONFIG_DEFAULT_DEVICE_TREE "<name>" + #define CONFIG_DEFAULT_DEVICE_TREE "<name>"
-to set the filename of the devicetree source. Then put your devicetree -file into:: +However, it has become combersome over time for each SoC/board maintainer to +keep devicetree files in sync with Linux kernel. Thereby, SoC/board maintainers +are encouraged to migrate to use mirrored copies from `devicetree-rebasing/` +into `dts/arch/<arch>/<vendor>` via::
- arch/<arch>/dts/<name>.dts + #define CONFIG_OF_UPSTREAM=y + #define CONFIG_DEFAULT_DEVICE_TREE "<vendor>/<name>"
-This should include your CPU or SOC's devicetree file, placed in -`arch/<arch>/dts`, and then make any adjustments required using a u-boot-dtsi -file for your board. +This should include your CPU or SOC's devicetree file. On top of that any U-Boot +specific tweaks (see: dttweaks_) can be made for your board.
If CONFIG_OF_EMBED is defined, then it will be picked up and built into the U-Boot image (including u-boot.bin). This is suitable for debugging @@ -156,8 +172,9 @@ ways: Adding tweaks for U-Boot ------------------------
-It is strongly recommended that devicetree files in U-Boot are an exact copy of -those in Linux, so that it is easy to sync them up from time to time. +With devicetee-rebasing Git subtree, it is ensured that devicetree files in +U-Boot are an exact copy of those in Linux kernel via mirroring into +`dts/arch/<arch>/<vendor>`.
U-Boot is of course a very different project from Linux, e.g. it operates under much more restrictive memory and code-size constraints. Where Linux may use a @@ -170,8 +187,8 @@ constraints are even more extreme and the devicetree is shrunk to remove unwanted nodes, or even turned into C code to avoid access overhead.
U-Boot automatically looks for and includes a file with updates to the standard -devicetree for your board, searching for them in the same directory as the -main file, in this order:: +devicetree for your board, searching for them in `arch/<arch>/dts/` in this +order::
<orig_filename>-u-boot.dtsi <CONFIG_SYS_SOC>-u-boot.dtsi @@ -200,6 +217,52 @@ to specify a list of .dtsi files that will also be included when building .dtb files.
+Devicetree bindings schema checks +--------------------------------- + +With devicetee-rebasing Git subtree, the devicetree bindings are also regularly +synced with Linux kernel as `devicetree-rebasing/Bindings/` sub-directory. This +allows U-Boot to run devicetree bindings schema checks which will bring +compliance to U-Boot core/drivers regarding usage of devicetree. + +Dependencies +~~~~~~~~~~~~ + +The DT schema project must be installed in order to validate the DT schema +binding documents and validate DTS files using the DT schema. The DT schema +project can be installed with pip:: + + pip3 install dtschema + +Note that 'dtschema' installation requires 'swig' and Python development files +installed first. On Debian/Ubuntu systems:: + + apt install swig python3-dev + +Several executables (dt-doc-validate, dt-mk-schema, dt-validate) will be +installed. Ensure they are in your PATH (~/.local/bin by default). + +Recommended is also to install yamllint (used by dtschema when present). + +Running checks +~~~~~~~~~~~~~~ + +In order to perform validation of DTB files, use the ``dtbs_check`` target:: + + make dtbs_check + +It is also possible to run checks with a subset of matching schema files by +setting the ``DT_SCHEMA_FILES`` variable to 1 or more specific schema files or +patterns (partial match of a fixed string). Each file or pattern should be +separated by ':'. + +:: + + make dtbs_check DT_SCHEMA_FILES=trivial-devices.yaml:rtc.yaml + make dtbs_check DT_SCHEMA_FILES=/gpio/ + make dtbs_check DT_SCHEMA_FILES=trivial-devices.yaml + + Relocation, SPL and TPL -----------------------
@@ -261,8 +324,9 @@ used it before Linux (e.g. snow). The two projects developed in parallel and there are still some differences in the bindings for certain boards. While there has been discussion of having a separate repository for devicetree files, in practice the Linux kernel Git repository has become the place where -these are stored, with U-Boot taking copies and adding tweaks with u-boot.dtsi -files. +these are stored, with U-Boot taking copies via devicetree-rebasing repo +(see: dtrepo_) and adding tweaks with u-boot.dtsi files.
.. _dtspec: https://www.devicetree.org/specifications/ .. _dtlist: https://www.spinics.net/lists/devicetree-compiler/ +.. _dtrepo: https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasi...
[snip]
Oh, oof. This never got updated for Kconfig rather than config.h. Can you please include re-wording this to be setting <name> when prompted for DEFAULT_DEVICE_TREE by Kconfig? And the rest of the text you're updating as well to match, thanks.
[snip]
Sure but how about changing it to say via board defconfig as CONFIG_DEFAULT_DEVICE_TREE="<name>", since AFAIK most people use defconfig to configure U-Boot.
-Sumit
-- Tom
[snip]
Well, do kernel docs tell people to modify defconfigs, or to use the config menu/etc?
[snip]
Okay I see your point, I will use wording to select DEFAULT_DEVICE_TREE by Kconfig instead.
-Sumit
-- Tom
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Sumit Garg sumit.garg@linaro.org --- MAINTAINERS | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/MAINTAINERS b/MAINTAINERS index 969514468cb..253092c345c 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -951,6 +951,12 @@ F: cmd/cyclic.c F: common/cyclic.c F: include/cyclic.h
+DEVICETREE REBASING SUBTREE +M: Sumit Garg sumit.garg@linaro.org +S: Maintained +F: devicetree-rebasing/ +F: dts/arch/ + DFU M: Lukasz Majewski lukma@denx.de M: Mattijs Korpershoek mkorpershoek@baylibre.com
DFU M: Lukasz Majewski lukma@denx.de M: Mattijs Korpershoek mkorpershoek@baylibre.com -- 2.34.1
Although there were still some variations in board DTS files based on meson-gxbb SoC but I think those were minor differences from upstream and shouldn't impact boot on these devices.
So switch to upstream DT via mirroring amlogic/ directory from devicetree-rebasing/src/arm64/amlogic/ directory. And thereby directly building DTB from there including *-u-boot.dtsi files from arch/$(ARCH)/dts/ directory.
Reviewed-by: Neil Armstrong neil.armstrong@linaro.org Signed-off-by: Sumit Garg sumit.garg@linaro.org --- configs/nanopi-k2_defconfig | 3 ++- configs/odroid-c2_defconfig | 3 ++- configs/p200_defconfig | 3 ++- configs/p201_defconfig | 3 ++- configs/videostrong-kii-pro_defconfig | 3 ++- configs/wetek-hub_defconfig | 3 ++- configs/wetek-play2_defconfig | 3 ++- dts/arch/arm64/Makefile | 9 +++++++++ dts/arch/arm64/amlogic | 1 + 9 files changed, 24 insertions(+), 7 deletions(-) create mode 120000 dts/arch/arm64/amlogic
diff --git a/configs/nanopi-k2_defconfig b/configs/nanopi-k2_defconfig index 41dbf7981f8..3db296916e9 100644 --- a/configs/nanopi-k2_defconfig +++ b/configs/nanopi-k2_defconfig @@ -6,7 +6,8 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20000000 CONFIG_ENV_SIZE=0x2000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-nanopi-k2" +CONFIG_OF_UPSTREAM=y +CONFIG_DEFAULT_DEVICE_TREE="amlogic/meson-gxbb-nanopi-k2" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_DEBUG_UART_BASE=0xc81004c0 diff --git a/configs/odroid-c2_defconfig b/configs/odroid-c2_defconfig index 5f9f323e06e..65857ff478c 100644 --- a/configs/odroid-c2_defconfig +++ b/configs/odroid-c2_defconfig @@ -6,7 +6,8 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20000000 CONFIG_ENV_SIZE=0x2000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-odroidc2" +CONFIG_OF_UPSTREAM=y +CONFIG_DEFAULT_DEVICE_TREE="amlogic/meson-gxbb-odroidc2" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_DEBUG_UART_BASE=0xc81004c0 diff --git a/configs/p200_defconfig b/configs/p200_defconfig index cd579ef5f14..c1792db51fd 100644 --- a/configs/p200_defconfig +++ b/configs/p200_defconfig @@ -6,7 +6,8 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20000000 CONFIG_ENV_SIZE=0x2000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-p200" +CONFIG_OF_UPSTREAM=y +CONFIG_DEFAULT_DEVICE_TREE="amlogic/meson-gxbb-p200" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_DEBUG_UART_BASE=0xc81004c0 diff --git a/configs/p201_defconfig b/configs/p201_defconfig index b2f0a0ccdb4..202e1da5bcc 100644 --- a/configs/p201_defconfig +++ b/configs/p201_defconfig @@ -7,7 +7,8 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20000000 CONFIG_ENV_SIZE=0x2000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-p201" +CONFIG_OF_UPSTREAM=y +CONFIG_DEFAULT_DEVICE_TREE="amlogic/meson-gxbb-p201" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_DEBUG_UART_BASE=0xc81004c0 diff --git a/configs/videostrong-kii-pro_defconfig b/configs/videostrong-kii-pro_defconfig index 3eda8f14a21..d09333d3b96 100644 --- a/configs/videostrong-kii-pro_defconfig +++ b/configs/videostrong-kii-pro_defconfig @@ -6,7 +6,8 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20000000 CONFIG_ENV_SIZE=0x2000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-kii-pro" +CONFIG_OF_UPSTREAM=y +CONFIG_DEFAULT_DEVICE_TREE="amlogic/meson-gxbb-kii-pro" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_DEBUG_UART_BASE=0xc81004c0 diff --git a/configs/wetek-hub_defconfig b/configs/wetek-hub_defconfig index fd92b041e73..73f3d4aad5d 100644 --- a/configs/wetek-hub_defconfig +++ b/configs/wetek-hub_defconfig @@ -6,7 +6,8 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20000000 CONFIG_ENV_SIZE=0x2000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-wetek-hub" +CONFIG_OF_UPSTREAM=y +CONFIG_DEFAULT_DEVICE_TREE="amlogic/meson-gxbb-wetek-hub" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_DEBUG_UART_BASE=0xc81004c0 diff --git a/configs/wetek-play2_defconfig b/configs/wetek-play2_defconfig index b887419a6ba..26f57b4214a 100644 --- a/configs/wetek-play2_defconfig +++ b/configs/wetek-play2_defconfig @@ -6,7 +6,8 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20000000 CONFIG_ENV_SIZE=0x2000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-wetek-play2" +CONFIG_OF_UPSTREAM=y +CONFIG_DEFAULT_DEVICE_TREE="amlogic/meson-gxbb-wetek-play2" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_DEBUG_UART_BASE=0xc81004c0 diff --git a/dts/arch/arm64/Makefile b/dts/arch/arm64/Makefile index 16e9fea622d..d548584cf5c 100644 --- a/dts/arch/arm64/Makefile +++ b/dts/arch/arm64/Makefile @@ -1,5 +1,14 @@ # SPDX-License-Identifier: GPL-2.0+
+dtb-$(CONFIG_ARCH_MESON) += \ + amlogic/meson-gxbb-kii-pro.dtb \ + amlogic/meson-gxbb-nanopi-k2.dtb \ + amlogic/meson-gxbb-odroidc2.dtb \ + amlogic/meson-gxbb-p200.dtb \ + amlogic/meson-gxbb-p201.dtb \ + amlogic/meson-gxbb-wetek-hub.dtb \ + amlogic/meson-gxbb-wetek-play2.dtb + include $(srctree)/scripts/Makefile.dts
targets += $(dtb-y) diff --git a/dts/arch/arm64/amlogic b/dts/arch/arm64/amlogic new file mode 120000 index 00000000000..73f7c3e7bd0 --- /dev/null +++ b/dts/arch/arm64/amlogic @@ -0,0 +1 @@ +../../../devicetree-rebasing/src/arm64/amlogic/ \ No newline at end of file
Do we need all of the Makefile portions of this? One of the things that works today is that trees listed in ONFIG_DEFAULT_DEVICE_TREE (and a few other variables) will be automatically built. We might just need the new Makefiles to just have: include $(srctree)/scripts/Makefile.dts and then the trees a given config will need will be built.
That sounds fine for Amlogic SoC and many others too with CONFIG_DEFAULT_DEVICE_TREE="" CONFIG_OF_LIST="" options available. However, if in future we have truely generalized U-Boot (like efforts for Qcom platform) then CONFIG_OF_LIST="" may become an overloaded choice.
For now, let me drop the Makefile portions.
-Sumit
-- Tom
I don't object to listing them when needed, I'm just not totally sure on how the use case really works out. But we can cross that when we get there, too.
Agree and I have similar concerns about it.
-Sumit
-- Tom
Since meson-gxbb based boards switched to using upstream DT, so drop redundant files from arch/arm/dts directory. Only *-u-boot.dtsi files kept in arch/arm/dts directory for these boards.
Signed-off-by: Sumit Garg sumit.garg@linaro.org --- arch/arm/dts/Makefile | 8 - arch/arm/dts/meson-gxbb-kii-pro.dts | 140 ---- arch/arm/dts/meson-gxbb-nanopi-k2.dts | 415 ------------ arch/arm/dts/meson-gxbb-odroidc2.dts | 418 ------------ arch/arm/dts/meson-gxbb-p200.dts | 100 --- arch/arm/dts/meson-gxbb-p201.dts | 26 - arch/arm/dts/meson-gxbb-p20x.dtsi | 250 ------- arch/arm/dts/meson-gxbb-wetek-hub.dts | 58 -- arch/arm/dts/meson-gxbb-wetek-play2.dts | 119 ---- arch/arm/dts/meson-gxbb-wetek.dtsi | 292 -------- arch/arm/dts/meson-gxbb.dtsi | 856 ------------------------ 11 files changed, 2682 deletions(-) delete mode 100644 arch/arm/dts/meson-gxbb-kii-pro.dts delete mode 100644 arch/arm/dts/meson-gxbb-nanopi-k2.dts delete mode 100644 arch/arm/dts/meson-gxbb-odroidc2.dts delete mode 100644 arch/arm/dts/meson-gxbb-p200.dts delete mode 100644 arch/arm/dts/meson-gxbb-p201.dts delete mode 100644 arch/arm/dts/meson-gxbb-p20x.dtsi delete mode 100644 arch/arm/dts/meson-gxbb-wetek-hub.dts delete mode 100644 arch/arm/dts/meson-gxbb-wetek-play2.dts delete mode 100644 arch/arm/dts/meson-gxbb-wetek.dtsi delete mode 100644 arch/arm/dts/meson-gxbb.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 5fc888680b3..45bd1166029 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -212,14 +212,6 @@ dtb-$(CONFIG_ARCH_MESON) += \ meson-a1-ad401.dtb \ meson-axg-s400.dtb \ meson-axg-jethome-jethub-j100.dtb \ - meson-gxbb-kii-pro.dtb \ - meson-gxbb-nanopi-k2.dtb \ - meson-gxbb-odroidc2.dtb \ - meson-gxbb-nanopi-k2.dtb \ - meson-gxbb-p200.dtb \ - meson-gxbb-p201.dtb \ - meson-gxbb-wetek-hub.dtb \ - meson-gxbb-wetek-play2.dtb \ meson-gxl-s805x-libretech-ac.dtb \ meson-gxl-s905d-libretech-pc.dtb \ meson-gxl-s905w-jethome-jethub-j80.dtb \ diff --git a/arch/arm/dts/meson-gxbb-kii-pro.dts b/arch/arm/dts/meson-gxbb-kii-pro.dts deleted file mode 100644 index e238f1f1012..00000000000 --- a/arch/arm/dts/meson-gxbb-kii-pro.dts +++ /dev/null @@ -1,140 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 Mohammad Rasim mohammad.rasim96@gmail.com - */ - -/dts-v1/; - -#include "meson-gxbb-p20x.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/sound/meson-aiu.h> - -/ { - compatible = "videostrong,kii-pro", "amlogic,meson-gxbb"; - model = "Videostrong KII Pro"; - - spdif_dit: audio-codec-0 { - #sound-dai-cells = <0>; - compatible = "linux,spdif-dit"; - status = "okay"; - sound-name-prefix = "DIT"; - }; - - leds { - compatible = "gpio-leds"; - led { - gpios = <&gpio_ao GPIOAO_13 GPIO_ACTIVE_LOW>; - color = <LED_COLOR_ID_RED>; - function = LED_FUNCTION_STATUS; - default-state = "off"; - }; - }; - - gpio-keys-polled { - compatible = "gpio-keys-polled"; - poll-interval = <20>; - - button-reset { - label = "reset"; - linux,code = <KEY_POWER>; - gpios = <&gpio_ao GPIOAO_3 GPIO_ACTIVE_HIGH>; - }; - }; - - sound { - compatible = "amlogic,gx-sound-card"; - model = "KII-PRO"; - assigned-clocks = <&clkc CLKID_MPLL0>, - <&clkc CLKID_MPLL1>, - <&clkc CLKID_MPLL2>; - assigned-clock-parents = <0>, <0>, <0>; - assigned-clock-rates = <294912000>, - <270950400>, - <393216000>; - - dai-link-0 { - sound-dai = <&aiu AIU_CPU CPU_I2S_FIFO>; - }; - - dai-link-1 { - sound-dai = <&aiu AIU_CPU CPU_SPDIF_FIFO>; - }; - - dai-link-2 { - sound-dai = <&aiu AIU_CPU CPU_I2S_ENCODER>; - dai-format = "i2s"; - mclk-fs = <256>; - - codec-0 { - sound-dai = <&aiu AIU_HDMI CTRL_I2S>; - }; - }; - - dai-link-3 { - sound-dai = <&aiu AIU_CPU CPU_SPDIF_ENCODER>; - - codec-0 { - sound-dai = <&spdif_dit>; - }; - }; - - dai-link-4 { - sound-dai = <&aiu AIU_HDMI CTRL_OUT>; - - codec-0 { - sound-dai = <&hdmi_tx>; - }; - }; - }; -}; - -&aiu { - status = "okay"; - pinctrl-0 = <&spdif_out_y_pins>; - pinctrl-names = "default"; -}; - -ðmac { - status = "okay"; - pinctrl-0 = <ð_rmii_pins>; - pinctrl-names = "default"; - - phy-handle = <ð_phy0>; - phy-mode = "rmii"; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - - eth_phy0: ethernet-phy@0 { - /* IC Plus IP101GR (0x02430c54) */ - reg = <0>; - reset-assert-us = <10000>; - reset-deassert-us = <10000>; - reset-gpios = <&gpio GPIOZ_14 GPIO_ACTIVE_LOW>; - }; - }; -}; - -&ir { - linux,rc-map-name = "rc-videostrong-kii-pro"; -}; - -&uart_A { - status = "okay"; - pinctrl-0 = <&uart_a_pins>, <&uart_a_cts_rts_pins>; - pinctrl-names = "default"; - uart-has-rtscts; - - bluetooth { - compatible = "brcm,bcm4335a0"; - shutdown-gpios = <&gpio GPIOX_20 GPIO_ACTIVE_HIGH>; - host-wakeup-gpios = <&gpio GPIOX_21 GPIO_ACTIVE_HIGH>; - max-speed = <2000000>; - clocks = <&wifi32k>; - clock-names = "lpo"; - }; -}; diff --git a/arch/arm/dts/meson-gxbb-nanopi-k2.dts b/arch/arm/dts/meson-gxbb-nanopi-k2.dts deleted file mode 100644 index 7273eed5292..00000000000 --- a/arch/arm/dts/meson-gxbb-nanopi-k2.dts +++ /dev/null @@ -1,415 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2017 Andreas Färber - */ - -/dts-v1/; - -#include "meson-gxbb.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/sound/meson-aiu.h> - -/ { - compatible = "friendlyarm,nanopi-k2", "amlogic,meson-gxbb"; - model = "FriendlyARM NanoPi K2"; - - aliases { - serial0 = &uart_AO; - ethernet0 = ðmac; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x0 0x0 0x80000000>; - }; - - leds { - compatible = "gpio-leds"; - - led-stat { - label = "nanopi-k2:blue:stat"; - gpios = <&gpio_ao GPIOAO_13 GPIO_ACTIVE_HIGH>; - default-state = "on"; - panic-indicator; - }; - }; - - vdd_5v: regulator-vdd-5v { - compatible = "regulator-fixed"; - regulator-name = "VDD_5V"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; - - vddio_ao18: regulator-vddio-ao18 { - compatible = "regulator-fixed"; - regulator-name = "VDDIO_AO18"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - vddio_ao3v3: regulator-vddio-ao3v3 { - compatible = "regulator-fixed"; - regulator-name = "VDDIO_AO3.3V"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vddio_tf: regulator-vddio-tf { - compatible = "regulator-gpio"; - - regulator-name = "VDDIO_TF"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio_ao GPIOAO_2 GPIO_ACTIVE_HIGH>; - gpios-states = <0>; - - states = <3300000 0>, - <1800000 1>; - - regulator-settling-time-up-us = <100>; - regulator-settling-time-down-us = <5000>; - }; - - wifi_32k: wifi-32k { - compatible = "pwm-clock"; - #clock-cells = <0>; - clock-frequency = <32768>; - pwms = <&pwm_ef 0 30518 0>; /* PWM_E at 32.768KHz */ - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - reset-gpios = <&gpio GPIOX_6 GPIO_ACTIVE_LOW>; - clocks = <&wifi_32k>; - clock-names = "ext_clock"; - }; - - vcc1v8: regulator-vcc1v8 { - compatible = "regulator-fixed"; - regulator-name = "VCC1.8V"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - vcc3v3: regulator-vcc3v3 { - compatible = "regulator-fixed"; - regulator-name = "VCC3.3V"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - emmc_pwrseq: emmc-pwrseq { - compatible = "mmc-pwrseq-emmc"; - reset-gpios = <&gpio BOOT_9 GPIO_ACTIVE_LOW>; - }; - - /* CVBS is available on CON1 pin 36, disabled by default */ - cvbs-connector { - compatible = "composite-video-connector"; - status = "disabled"; - - port { - cvbs_connector_in: endpoint { - remote-endpoint = <&cvbs_vdac_out>; - }; - }; - }; - - hdmi-connector { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_connector_in: endpoint { - remote-endpoint = <&hdmi_tx_tmds_out>; - }; - }; - }; - - sound { - compatible = "amlogic,gx-sound-card"; - model = "NANOPI-K2"; - assigned-clocks = <&clkc CLKID_MPLL0>, - <&clkc CLKID_MPLL1>, - <&clkc CLKID_MPLL2>; - assigned-clock-parents = <0>, <0>, <0>; - assigned-clock-rates = <294912000>, - <270950400>, - <393216000>; - status = "okay"; - - dai-link-0 { - sound-dai = <&aiu AIU_CPU CPU_I2S_FIFO>; - }; - - dai-link-1 { - sound-dai = <&aiu AIU_CPU CPU_I2S_ENCODER>; - dai-format = "i2s"; - mclk-fs = <256>; - - codec-0 { - sound-dai = <&aiu AIU_HDMI CTRL_I2S>; - }; - }; - - dai-link-2 { - sound-dai = <&aiu AIU_HDMI CTRL_OUT>; - - codec-0 { - sound-dai = <&hdmi_tx>; - }; - }; - }; -}; - -&aiu { - status = "okay"; -}; - -&cec_AO { - status = "okay"; - pinctrl-0 = <&ao_cec_pins>; - pinctrl-names = "default"; - hdmi-phandle = <&hdmi_tx>; -}; - -&cvbs_vdac_port { - cvbs_vdac_out: endpoint { - remote-endpoint = <&cvbs_connector_in>; - }; -}; - -ðmac { - status = "okay"; - pinctrl-0 = <ð_rgmii_pins>; - pinctrl-names = "default"; - - phy-handle = <ð_phy0>; - phy-mode = "rgmii"; - - amlogic,tx-delay-ns = <2>; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - - eth_phy0: ethernet-phy@0 { - /* Realtek RTL8211F (0x001cc916) */ - reg = <0>; - - reset-assert-us = <10000>; - reset-deassert-us = <80000>; - reset-gpios = <&gpio GPIOZ_14 GPIO_ACTIVE_LOW>; - - interrupt-parent = <&gpio_intc>; - /* MAC_INTR on GPIOZ_15 */ - interrupts = <29 IRQ_TYPE_LEVEL_LOW>; - }; - }; -}; - -&hdmi_tx { - status = "okay"; - pinctrl-0 = <&hdmi_hpd_pins>, <&hdmi_i2c_pins>; - pinctrl-names = "default"; -}; - -&hdmi_tx_tmds_port { - hdmi_tx_tmds_out: endpoint { - remote-endpoint = <&hdmi_connector_in>; - }; -}; - -&ir { - status = "okay"; - pinctrl-0 = <&remote_input_ao_pins>; - pinctrl-names = "default"; -}; - -&gpio_ao { - gpio-line-names = "UART TX", "UART RX", "Power Control", "Power Key In", - "VCCK En", "CON1 Header Pin31", - "I2S Header Pin6", "IR In", "I2S Header Pin7", - "I2S Header Pin3", "I2S Header Pin4", - "I2S Header Pin5", "HDMI CEC", "SYS LED", - /* GPIO_TEST_N */ - ""; -}; - -&gpio { - gpio-line-names = /* Bank GPIOZ */ - "Eth MDIO", "Eth MDC", "Eth RGMII RX Clk", - "Eth RX DV", "Eth RX D0", "Eth RX D1", "Eth RX D2", - "Eth RX D3", "Eth RGMII TX Clk", "Eth TX En", - "Eth TX D0", "Eth TX D1", "Eth TX D2", "Eth TX D3", - "Eth PHY nRESET", "Eth PHY Intc", - /* Bank GPIOH */ - "HDMI HPD", "HDMI DDC SDA", "HDMI DDC SCL", - "CON1 Header Pin33", - /* Bank BOOT */ - "eMMC D0", "eMMC D1", "eMMC D2", "eMMC D3", "eMMC D4", - "eMMC D5", "eMMC D6", "eMMC D7", "eMMC Clk", - "eMMC Reset", "eMMC CMD", - "", "", "", "", "eMMC DS", - "", "", - /* Bank CARD */ - "SDCard D1", "SDCard D0", "SDCard CLK", "SDCard CMD", - "SDCard D3", "SDCard D2", "SDCard Det", - /* Bank GPIODV */ - "", "", "", "", "", "", "", "", "", "", "", "", "", - "", "", "", "", "", "", "", "", "", "", "", - "I2C A SDA", "I2C A SCK", "I2C B SDA", "I2C B SCK", - "VDDEE Regulator", "VCCK Regulator", - /* Bank GPIOY */ - "CON1 Header Pin7", "CON1 Header Pin11", - "CON1 Header Pin13", "CON1 Header Pin15", - "CON1 Header Pin18", "CON1 Header Pin19", - "CON1 Header Pin22", "CON1 Header Pin21", - "CON1 Header Pin24", "CON1 Header Pin23", - "CON1 Header Pin26", "CON1 Header Pin29", - "CON1 Header Pin32", "CON1 Header Pin8", - "CON1 Header Pin10", "CON1 Header Pin16", - "CON1 Header Pin12", - /* Bank GPIOX */ - "WIFI SDIO D0", "WIFI SDIO D1", "WIFI SDIO D2", - "WIFI SDIO D3", "WIFI SDIO CLK", "WIFI SDIO CMD", - "WIFI Power Enable", "WIFI WAKE HOST", - "Bluetooth PCM DOUT", "Bluetooth PCM DIN", - "Bluetooth PCM SYNC", "Bluetooth PCM CLK", - "Bluetooth UART TX", "Bluetooth UART RX", - "Bluetooth UART CTS", "Bluetooth UART RTS", - "", "", "", "WIFI 32K", "Bluetooth Enable", - "Bluetooth WAKE HOST", "", - /* Bank GPIOCLK */ - "", "CON1 Header Pin35", "", ""; -}; - -&pwm_ef { - status = "okay"; - pinctrl-0 = <&pwm_e_pins>; - pinctrl-names = "default"; - clocks = <&clkc CLKID_FCLK_DIV4>; - clock-names = "clkin0"; -}; - -&saradc { - status = "okay"; - vref-supply = <&vddio_ao18>; -}; - -/* SDIO */ -&sd_emmc_a { - status = "okay"; - pinctrl-0 = <&sdio_pins>, <&sdio_irq_pins>; - pinctrl-1 = <&sdio_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - #address-cells = <1>; - #size-cells = <0>; - - bus-width = <4>; - cap-sd-highspeed; - max-frequency = <50000000>; - - non-removable; - disable-wp; - - /* WiFi firmware requires power to be kept while in suspend */ - keep-power-in-suspend; - - mmc-pwrseq = <&sdio_pwrseq>; - - vmmc-supply = <&vddio_ao3v3>; - vqmmc-supply = <&vddio_ao18>; - - brcmf: wifi@1 { - compatible = "brcm,bcm4329-fmac"; - reg = <1>; - }; -}; - -/* SD */ -&sd_emmc_b { - status = "okay"; - pinctrl-0 = <&sdcard_pins>; - pinctrl-1 = <&sdcard_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <4>; - cap-sd-highspeed; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-ddr50; - max-frequency = <100000000>; - disable-wp; - - cd-gpios = <&gpio CARD_6 GPIO_ACTIVE_LOW>; - - vmmc-supply = <&vddio_ao3v3>; - vqmmc-supply = <&vddio_tf>; -}; - -/* eMMC */ -&sd_emmc_c { - status = "disabled"; - pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>; - pinctrl-1 = <&emmc_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <8>; - max-frequency = <200000000>; - non-removable; - disable-wp; - cap-mmc-highspeed; - mmc-ddr-1_8v; - mmc-hs200-1_8v; - - mmc-pwrseq = <&emmc_pwrseq>; - vmmc-supply = <&vcc3v3>; - vqmmc-supply = <&vcc1v8>; -}; - -/* DBG_UART */ -&uart_AO { - status = "okay"; - pinctrl-0 = <&uart_ao_a_pins>; - pinctrl-names = "default"; -}; - -/* Bluetooth on AP6212 */ -&uart_A { - status = "disabled"; - pinctrl-0 = <&uart_a_pins>, <&uart_a_cts_rts_pins>; - pinctrl-names = "default"; -}; - -/* 40-pin CON1 */ -&uart_C { - status = "disabled"; - pinctrl-0 = <&uart_c_pins>; - pinctrl-names = "default"; -}; - -&usb0_phy { - status = "okay"; - phy-supply = <&vdd_5v>; -}; - -&usb1_phy { - status = "okay"; -}; - -&usb0 { - status = "okay"; -}; - -&usb1 { - status = "okay"; -}; diff --git a/arch/arm/dts/meson-gxbb-odroidc2.dts b/arch/arm/dts/meson-gxbb-odroidc2.dts deleted file mode 100644 index 201596247fd..00000000000 --- a/arch/arm/dts/meson-gxbb-odroidc2.dts +++ /dev/null @@ -1,418 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016 Andreas Färber - * Copyright (c) 2016 BayLibre, Inc. - * Author: Kevin Hilman khilman@kernel.org - */ - -/dts-v1/; - -#include "meson-gxbb.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/sound/meson-aiu.h> - -/ { - compatible = "hardkernel,odroid-c2", "amlogic,meson-gxbb"; - model = "Hardkernel ODROID-C2"; - - aliases { - serial0 = &uart_AO; - ethernet0 = ðmac; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x0 0x0 0x80000000>; - }; - - usb_otg_pwr: regulator-usb-pwrs { - compatible = "regulator-fixed"; - - regulator-name = "USB_OTG_PWR"; - - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - - /* - * signal name from schematics: PWREN - */ - gpio = <&gpio_ao GPIOAO_5 GPIO_ACTIVE_HIGH>; - enable-active-high; - /* - * signal name from schematics: USB_POWER - */ - vin-supply = <&p5v0>; - }; - - leds { - compatible = "gpio-leds"; - led-blue { - label = "c2:blue:alive"; - gpios = <&gpio_ao GPIOAO_13 GPIO_ACTIVE_LOW>; - linux,default-trigger = "heartbeat"; - default-state = "off"; - }; - }; - - p5v0: regulator-p5v0 { - compatible = "regulator-fixed"; - - regulator-name = "P5V0"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - }; - - hdmi_p5v0: regulator-hdmi_p5v0 { - compatible = "regulator-fixed"; - regulator-name = "HDMI_P5V0"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - /* AP2331SA-7 */ - vin-supply = <&p5v0>; - }; - - tflash_vdd: regulator-tflash_vdd { - compatible = "regulator-fixed"; - - regulator-name = "TFLASH_VDD"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - /* - * signal name from schematics: TFLASH_VDD_EN - */ - gpio = <&gpio GPIOY_12 GPIO_ACTIVE_HIGH>; - enable-active-high; - /* U16 RT9179GB */ - vin-supply = <&vddio_ao3v3>; - }; - - tf_io: gpio-regulator-tf_io { - compatible = "regulator-gpio"; - - regulator-name = "TF_IO"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - /* - * signal name from schematics: TF_3V3N_1V8_EN - */ - gpios = <&gpio_ao GPIOAO_3 GPIO_ACTIVE_HIGH>; - gpios-states = <0>; - - states = <3300000 0>, - <1800000 1>; - /* U12/U13 RT9179GB */ - vin-supply = <&vddio_ao3v3>; - }; - - vcc1v8: regulator-vcc1v8 { - compatible = "regulator-fixed"; - regulator-name = "VCC1V8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - /* U18 RT9179GB */ - vin-supply = <&vddio_ao3v3>; - }; - - vcc3v3: regulator-vcc3v3 { - compatible = "regulator-fixed"; - regulator-name = "VCC3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vddio_ao1v8: regulator-vddio-ao1v8 { - compatible = "regulator-fixed"; - regulator-name = "VDDIO_AO1V8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - /* U17 RT9179GB */ - vin-supply = <&p5v0>; - }; - - vddio_ao3v3: regulator-vddio-ao3v3 { - compatible = "regulator-fixed"; - regulator-name = "VDDIO_AO3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - /* U11 MP2161GJ-C499 */ - vin-supply = <&p5v0>; - }; - - ddr3_1v5: regulator-ddr3_1v5 { - compatible = "regulator-fixed"; - regulator-name = "DDR3_1V5"; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - regulator-always-on; - /* U15 MP2161GJ-C499 */ - vin-supply = <&p5v0>; - }; - - emmc_pwrseq: emmc-pwrseq { - compatible = "mmc-pwrseq-emmc"; - reset-gpios = <&gpio BOOT_9 GPIO_ACTIVE_LOW>; - }; - - hdmi-connector { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_connector_in: endpoint { - remote-endpoint = <&hdmi_tx_tmds_out>; - }; - }; - }; - - sound { - compatible = "amlogic,gx-sound-card"; - model = "ODROID-C2"; - assigned-clocks = <&clkc CLKID_MPLL0>, - <&clkc CLKID_MPLL1>, - <&clkc CLKID_MPLL2>; - assigned-clock-parents = <0>, <0>, <0>; - assigned-clock-rates = <294912000>, - <270950400>, - <393216000>; - status = "okay"; - - dai-link-0 { - sound-dai = <&aiu AIU_CPU CPU_I2S_FIFO>; - }; - - dai-link-1 { - sound-dai = <&aiu AIU_CPU CPU_I2S_ENCODER>; - dai-format = "i2s"; - mclk-fs = <256>; - - codec-0 { - sound-dai = <&aiu AIU_HDMI CTRL_I2S>; - }; - }; - - dai-link-2 { - sound-dai = <&aiu AIU_HDMI CTRL_OUT>; - - codec-0 { - sound-dai = <&hdmi_tx>; - }; - }; - }; -}; - -&aiu { - status = "okay"; -}; - -&cec_AO { - status = "okay"; - pinctrl-0 = <&ao_cec_pins>; - pinctrl-names = "default"; - hdmi-phandle = <&hdmi_tx>; -}; - -ðmac { - status = "okay"; - pinctrl-0 = <ð_rgmii_pins>; - pinctrl-names = "default"; - phy-handle = <ð_phy0>; - phy-mode = "rgmii"; - - amlogic,tx-delay-ns = <2>; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - - eth_phy0: ethernet-phy@0 { - /* Realtek RTL8211F (0x001cc916) */ - reg = <0>; - - reset-assert-us = <10000>; - reset-deassert-us = <80000>; - reset-gpios = <&gpio GPIOZ_14 GPIO_ACTIVE_LOW>; - - interrupt-parent = <&gpio_intc>; - /* MAC_INTR on GPIOZ_15 */ - interrupts = <29 IRQ_TYPE_LEVEL_LOW>; - }; - }; -}; - -&gpio_ao { - /* - * WARNING: The USB Hub on the Odroid-C2 needs a reset signal - * to be turned high in order to be detected by the USB Controller - * This signal should be handled by a USB specific power sequence - * in order to reset the Hub when USB bus is powered down. - */ - hog-0 { - gpio-hog; - gpios = <GPIOAO_4 GPIO_ACTIVE_HIGH>; - output-high; - line-name = "usb-hub-reset"; - }; -}; - -&hdmi_tx { - status = "okay"; - pinctrl-0 = <&hdmi_hpd_pins>, <&hdmi_i2c_pins>; - pinctrl-names = "default"; - hdmi-supply = <&hdmi_p5v0>; -}; - -&hdmi_tx_tmds_port { - hdmi_tx_tmds_out: endpoint { - remote-endpoint = <&hdmi_connector_in>; - }; -}; - -&i2c_A { - status = "okay"; - pinctrl-0 = <&i2c_a_pins>; - pinctrl-names = "default"; -}; - -&ir { - status = "okay"; - pinctrl-0 = <&remote_input_ao_pins>; - pinctrl-names = "default"; - linux,rc-map-name = "rc-odroid"; -}; - -&gpio_ao { - gpio-line-names = "UART TX", "UART RX", "VCCK En", "TF 3V3/1V8 En", - "USB HUB nRESET", "USB OTG Power En", - "J7 Header Pin2", "IR In", "J7 Header Pin4", - "J7 Header Pin6", "J7 Header Pin5", "J7 Header Pin7", - "HDMI CEC", "SYS LED", - /* GPIO_TEST_N */ - ""; -}; - -&gpio { - gpio-line-names = /* Bank GPIOZ */ - "Eth MDIO", "Eth MDC", "Eth RGMII RX Clk", - "Eth RX DV", "Eth RX D0", "Eth RX D1", "Eth RX D2", - "Eth RX D3", "Eth RGMII TX Clk", "Eth TX En", - "Eth TX D0", "Eth TX D1", "Eth TX D2", "Eth TX D3", - "Eth PHY nRESET", "Eth PHY Intc", - /* Bank GPIOH */ - "HDMI HPD", "HDMI DDC SDA", "HDMI DDC SCL", "", - /* Bank BOOT */ - "eMMC D0", "eMMC D1", "eMMC D2", "eMMC D3", "eMMC D4", - "eMMC D5", "eMMC D6", "eMMC D7", "eMMC Clk", - "eMMC Reset", "eMMC CMD", - "", "", "", "", "", "", "", - /* Bank CARD */ - "SDCard D1", "SDCard D0", "SDCard CLK", "SDCard CMD", - "SDCard D3", "SDCard D2", "SDCard Det", - /* Bank GPIODV */ - "", "", "", "", "", "", "", "", "", "", "", "", "", - "", "", "", "", "", "", "", "", "", "", "", - "I2C A SDA", "I2C A SCK", "I2C B SDA", "I2C B SCK", - "PWM D", "PWM B", - /* Bank GPIOY */ - "Revision Bit0", "Revision Bit1", "", - "J2 Header Pin35", "", "", "", "J2 Header Pin36", - "J2 Header Pin31", "", "", "", "TF VDD En", - "J2 Header Pin32", "J2 Header Pin26", "", "", - /* Bank GPIOX */ - "J2 Header Pin29", "J2 Header Pin24", - "J2 Header Pin23", "J2 Header Pin22", - "J2 Header Pin21", "J2 Header Pin18", - "J2 Header Pin33", "J2 Header Pin19", - "J2 Header Pin16", "J2 Header Pin15", - "J2 Header Pin12", "J2 Header Pin13", - "J2 Header Pin8", "J2 Header Pin10", - "", "", "", "", "", - "J2 Header Pin11", "", "J2 Header Pin7", "", - /* Bank GPIOCLK */ - "", "", "", ""; -}; - -&saradc { - status = "okay"; - vref-supply = <&vcc1v8>; -}; - -&scpi_clocks { - status = "disabled"; -}; - -/* SD */ -&sd_emmc_b { - status = "okay"; - pinctrl-0 = <&sdcard_pins>; - pinctrl-1 = <&sdcard_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <4>; - cap-sd-highspeed; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-ddr50; - max-frequency = <100000000>; - disable-wp; - - cd-gpios = <&gpio CARD_6 GPIO_ACTIVE_LOW>; - - vmmc-supply = <&tflash_vdd>; - vqmmc-supply = <&tf_io>; -}; - -/* eMMC */ -&sd_emmc_c { - status = "okay"; - pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>; - pinctrl-1 = <&emmc_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <8>; - max-frequency = <200000000>; - non-removable; - disable-wp; - cap-mmc-highspeed; - mmc-ddr-1_8v; - mmc-hs200-1_8v; - - mmc-pwrseq = <&emmc_pwrseq>; - vmmc-supply = <&vcc3v3>; - vqmmc-supply = <&vcc1v8>; -}; - -&uart_AO { - status = "okay"; - pinctrl-0 = <&uart_ao_a_pins>; - pinctrl-names = "default"; -}; - -&usb0_phy { - status = "disabled"; - phy-supply = <&usb_otg_pwr>; -}; - -&usb1_phy { - status = "okay"; - phy-supply = <&usb_otg_pwr>; -}; - -&usb0 { - status = "disabled"; -}; - -&usb1 { - status = "okay"; -}; diff --git a/arch/arm/dts/meson-gxbb-p200.dts b/arch/arm/dts/meson-gxbb-p200.dts deleted file mode 100644 index 3c93d1898b4..00000000000 --- a/arch/arm/dts/meson-gxbb-p200.dts +++ /dev/null @@ -1,100 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016 Andreas Färber - * Copyright (c) 2016 BayLibre, Inc. - * Author: Kevin Hilman khilman@kernel.org - */ - -/dts-v1/; - -#include "meson-gxbb-p20x.dtsi" -#include <dt-bindings/input/input.h> - -/ { - compatible = "amlogic,p200", "amlogic,meson-gxbb"; - model = "Amlogic Meson GXBB P200 Development Board"; - - avdd18_usb_adc: regulator-avdd18_usb_adc { - compatible = "regulator-fixed"; - regulator-name = "AVDD18_USB_ADC"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - adc_keys { - compatible = "adc-keys"; - io-channels = <&saradc 0>; - io-channel-names = "buttons"; - keyup-threshold-microvolt = <1800000>; - - button-home { - label = "Home"; - linux,code = <KEY_HOME>; - press-threshold-microvolt = <900000>; /* 50% */ - }; - - button-esc { - label = "Esc"; - linux,code = <KEY_ESC>; - press-threshold-microvolt = <684000>; /* 38% */ - }; - - button-up { - label = "Volume Up"; - linux,code = <KEY_VOLUMEUP>; - press-threshold-microvolt = <468000>; /* 26% */ - }; - - button-down { - label = "Volume Down"; - linux,code = <KEY_VOLUMEDOWN>; - press-threshold-microvolt = <252000>; /* 14% */ - }; - - button-menu { - label = "Menu"; - linux,code = <KEY_MENU>; - press-threshold-microvolt = <0>; /* 0% */ - }; - }; -}; - -ðmac { - status = "okay"; - pinctrl-0 = <ð_rgmii_pins>; - pinctrl-names = "default"; - phy-handle = <ð_phy0>; - phy-mode = "rgmii"; - - amlogic,tx-delay-ns = <2>; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - - eth_phy0: ethernet-phy@3 { - /* Micrel KSZ9031 (0x00221620) */ - reg = <3>; - - reset-assert-us = <10000>; - reset-deassert-us = <30000>; - reset-gpios = <&gpio GPIOZ_14 GPIO_ACTIVE_LOW>; - - interrupt-parent = <&gpio_intc>; - /* MAC_INTR on GPIOZ_15 */ - interrupts = <29 IRQ_TYPE_LEVEL_LOW>; - }; - }; -}; - -&i2c_B { - status = "okay"; - pinctrl-0 = <&i2c_b_pins>; - pinctrl-names = "default"; -}; - -&saradc { - status = "okay"; - vref-supply = <&avdd18_usb_adc>; -}; diff --git a/arch/arm/dts/meson-gxbb-p201.dts b/arch/arm/dts/meson-gxbb-p201.dts deleted file mode 100644 index 150a82f3b2d..00000000000 --- a/arch/arm/dts/meson-gxbb-p201.dts +++ /dev/null @@ -1,26 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016 Andreas Färber - * Copyright (c) 2016 BayLibre, Inc. - * Author: Kevin Hilman khilman@kernel.org - */ - -/dts-v1/; - -#include "meson-gxbb-p20x.dtsi" - -/ { - compatible = "amlogic,p201", "amlogic,meson-gxbb"; - model = "Amlogic Meson GXBB P201 Development Board"; -}; - -ðmac { - status = "okay"; - pinctrl-0 = <ð_rmii_pins>; - pinctrl-names = "default"; - phy-mode = "rmii"; - - snps,reset-gpio = <&gpio GPIOZ_14 0>; - snps,reset-delays-us = <0>, <10000>, <1000000>; - snps,reset-active-low; -}; diff --git a/arch/arm/dts/meson-gxbb-p20x.dtsi b/arch/arm/dts/meson-gxbb-p20x.dtsi deleted file mode 100644 index e803a466fe4..00000000000 --- a/arch/arm/dts/meson-gxbb-p20x.dtsi +++ /dev/null @@ -1,250 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016 Andreas Färber - * Copyright (c) 2016 BayLibre, Inc. - * Author: Kevin Hilman khilman@kernel.org - */ - -#include "meson-gxbb.dtsi" - -/ { - aliases { - serial0 = &uart_AO; - ethernet0 = ðmac; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x0 0x0 0x40000000>; - }; - - usb_pwr: regulator-usb-pwrs { - compatible = "regulator-fixed"; - - regulator-name = "USB_PWR"; - - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - - /* signal name in schematic: USB_PWR_EN */ - gpio = <&gpio GPIODV_24 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - vddio_card: gpio-regulator { - compatible = "regulator-gpio"; - - regulator-name = "VDDIO_CARD"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio_ao GPIOAO_5 GPIO_ACTIVE_HIGH>; - gpios-states = <1>; - - /* Based on P200 schematics, signal CARD_1.8V/3.3V_CTR */ - states = <1800000 0>, - <3300000 1>; - - regulator-settling-time-up-us = <10000>; - regulator-settling-time-down-us = <150000>; - }; - - vddio_boot: regulator-vddio_boot { - compatible = "regulator-fixed"; - regulator-name = "VDDIO_BOOT"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - vddao_3v3: regulator-vddao_3v3 { - compatible = "regulator-fixed"; - regulator-name = "VDDAO_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vcc_3v3: regulator-vcc_3v3 { - compatible = "regulator-fixed"; - regulator-name = "VCC_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - emmc_pwrseq: emmc-pwrseq { - compatible = "mmc-pwrseq-emmc"; - reset-gpios = <&gpio BOOT_9 GPIO_ACTIVE_LOW>; - }; - - wifi32k: wifi32k { - compatible = "pwm-clock"; - #clock-cells = <0>; - clock-frequency = <32768>; - pwms = <&pwm_ef 0 30518 0>; /* PWM_E at 32.768KHz */ - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - reset-gpios = <&gpio GPIOX_6 GPIO_ACTIVE_LOW>; - clocks = <&wifi32k>; - clock-names = "ext_clock"; - }; - - cvbs_connector: cvbs-connector { - compatible = "composite-video-connector"; - - port { - cvbs_connector_in: endpoint { - remote-endpoint = <&cvbs_vdac_out>; - }; - }; - }; - - hdmi-connector { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_connector_in: endpoint { - remote-endpoint = <&hdmi_tx_tmds_out>; - }; - }; - }; -}; - -&cec_AO { - status = "okay"; - pinctrl-0 = <&ao_cec_pins>; - pinctrl-names = "default"; - hdmi-phandle = <&hdmi_tx>; -}; - -&cvbs_vdac_port { - cvbs_vdac_out: endpoint { - remote-endpoint = <&cvbs_connector_in>; - }; -}; - -&hdmi_tx { - status = "okay"; - pinctrl-0 = <&hdmi_hpd_pins>, <&hdmi_i2c_pins>; - pinctrl-names = "default"; -}; - -&hdmi_tx_tmds_port { - hdmi_tx_tmds_out: endpoint { - remote-endpoint = <&hdmi_connector_in>; - }; -}; - -&ir { - status = "okay"; - pinctrl-0 = <&remote_input_ao_pins>; - pinctrl-names = "default"; -}; - -&pwm_ef { - status = "okay"; - pinctrl-0 = <&pwm_e_pins>; - pinctrl-names = "default"; - clocks = <&clkc CLKID_FCLK_DIV4>; - clock-names = "clkin0"; -}; - -/* Wireless SDIO Module */ -&sd_emmc_a { - status = "okay"; - pinctrl-0 = <&sdio_pins>; - pinctrl-1 = <&sdio_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - #address-cells = <1>; - #size-cells = <0>; - - bus-width = <4>; - cap-sd-highspeed; - max-frequency = <50000000>; - - non-removable; - disable-wp; - - /* WiFi firmware requires power to be kept while in suspend */ - keep-power-in-suspend; - - mmc-pwrseq = <&sdio_pwrseq>; - - vmmc-supply = <&vddao_3v3>; - vqmmc-supply = <&vddio_boot>; - - brcmf: wifi@1 { - reg = <1>; - compatible = "brcm,bcm4329-fmac"; - }; -}; - -/* SD card */ -&sd_emmc_b { - status = "okay"; - pinctrl-0 = <&sdcard_pins>; - pinctrl-1 = <&sdcard_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <4>; - cap-sd-highspeed; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - max-frequency = <100000000>; - disable-wp; - - cd-gpios = <&gpio CARD_6 GPIO_ACTIVE_LOW>; - - vmmc-supply = <&vddao_3v3>; - vqmmc-supply = <&vddio_card>; -}; - -/* eMMC */ -&sd_emmc_c { - status = "okay"; - pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>; - pinctrl-1 = <&emmc_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <8>; - cap-mmc-highspeed; - max-frequency = <200000000>; - non-removable; - disable-wp; - mmc-ddr-1_8v; - mmc-hs200-1_8v; - - mmc-pwrseq = <&emmc_pwrseq>; - vmmc-supply = <&vcc_3v3>; - vqmmc-supply = <&vddio_boot>; -}; - -/* This UART is brought out to the DB9 connector */ -&uart_AO { - status = "okay"; - pinctrl-0 = <&uart_ao_a_pins>; - pinctrl-names = "default"; -}; - -&usb0_phy { - status = "okay"; - phy-supply = <&usb_pwr>; -}; - -&usb1_phy { - status = "okay"; -}; - -&usb0 { - status = "okay"; -}; - -&usb1 { - status = "okay"; -}; diff --git a/arch/arm/dts/meson-gxbb-wetek-hub.dts b/arch/arm/dts/meson-gxbb-wetek-hub.dts deleted file mode 100644 index 58733017eda..00000000000 --- a/arch/arm/dts/meson-gxbb-wetek-hub.dts +++ /dev/null @@ -1,58 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016 BayLibre, Inc. - * Author: Neil Armstrong narmstrong@baylibre.com - */ - -/dts-v1/; - -#include "meson-gxbb-wetek.dtsi" -#include <dt-bindings/sound/meson-aiu.h> - -/ { - compatible = "wetek,hub", "amlogic,meson-gxbb"; - model = "WeTek Hub"; - - sound { - compatible = "amlogic,gx-sound-card"; - model = "WETEK-HUB"; - assigned-clocks = <&clkc CLKID_MPLL0>, - <&clkc CLKID_MPLL1>, - <&clkc CLKID_MPLL2>; - assigned-clock-parents = <0>, <0>, <0>; - assigned-clock-rates = <294912000>, - <270950400>, - <393216000>; - status = "okay"; - - dai-link-0 { - sound-dai = <&aiu AIU_CPU CPU_I2S_FIFO>; - }; - - dai-link-1 { - sound-dai = <&aiu AIU_CPU CPU_I2S_ENCODER>; - dai-format = "i2s"; - mclk-fs = <256>; - - codec-0 { - sound-dai = <&aiu AIU_HDMI CTRL_I2S>; - }; - }; - - dai-link-2 { - sound-dai = <&aiu AIU_HDMI CTRL_OUT>; - - codec-0 { - sound-dai = <&hdmi_tx>; - }; - }; - }; -}; - -&aiu { - status = "okay"; -}; - -&ir { - linux,rc-map-name = "rc-wetek-hub"; -}; diff --git a/arch/arm/dts/meson-gxbb-wetek-play2.dts b/arch/arm/dts/meson-gxbb-wetek-play2.dts deleted file mode 100644 index 505ffcd8eb7..00000000000 --- a/arch/arm/dts/meson-gxbb-wetek-play2.dts +++ /dev/null @@ -1,119 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016 BayLibre, Inc. - * Author: Neil Armstrong narmstrong@baylibre.com - */ - -/dts-v1/; - -#include "meson-gxbb-wetek.dtsi" -#include <dt-bindings/input/input.h> -#include <dt-bindings/sound/meson-aiu.h> - -/ { - compatible = "wetek,play2", "amlogic,meson-gxbb"; - model = "WeTek Play 2"; - - spdif_dit: audio-codec-0 { - #sound-dai-cells = <0>; - compatible = "linux,spdif-dit"; - status = "okay"; - sound-name-prefix = "DIT"; - }; - - leds { - led-wifi { - label = "wetek-play:wifi-status"; - gpios = <&gpio GPIODV_26 GPIO_ACTIVE_HIGH>; - default-state = "off"; - }; - - led-ethernet { - label = "wetek-play:ethernet-status"; - gpios = <&gpio GPIODV_27 GPIO_ACTIVE_HIGH>; - default-state = "off"; - }; - }; - - gpio-keys-polled { - compatible = "gpio-keys-polled"; - poll-interval = <100>; - - button { - label = "reset"; - linux,code = <KEY_RESTART>; - gpios = <&gpio_ao GPIOAO_3 GPIO_ACTIVE_LOW>; - }; - }; - - sound { - compatible = "amlogic,gx-sound-card"; - model = "WETEK-PLAY2"; - assigned-clocks = <&clkc CLKID_MPLL0>, - <&clkc CLKID_MPLL1>, - <&clkc CLKID_MPLL2>; - assigned-clock-parents = <0>, <0>, <0>; - assigned-clock-rates = <294912000>, - <270950400>, - <393216000>; - status = "okay"; - - dai-link-0 { - sound-dai = <&aiu AIU_CPU CPU_I2S_FIFO>; - }; - - dai-link-1 { - sound-dai = <&aiu AIU_CPU CPU_SPDIF_FIFO>; - }; - - dai-link-2 { - sound-dai = <&aiu AIU_CPU CPU_I2S_ENCODER>; - dai-format = "i2s"; - mclk-fs = <256>; - - codec-0 { - sound-dai = <&aiu AIU_HDMI CTRL_I2S>; - }; - }; - - dai-link-3 { - sound-dai = <&aiu AIU_CPU CPU_SPDIF_ENCODER>; - - codec-0 { - sound-dai = <&spdif_dit>; - }; - }; - - dai-link-4 { - sound-dai = <&aiu AIU_HDMI CTRL_OUT>; - - codec-0 { - sound-dai = <&hdmi_tx>; - }; - }; - }; -}; - -&aiu { - status = "okay"; - pinctrl-0 = <&spdif_out_y_pins>; - pinctrl-names = "default"; -}; - -&i2c_A { - status = "okay"; - pinctrl-0 = <&i2c_a_pins>; - pinctrl-names = "default"; -}; - -&usb1_phy { - status = "okay"; -}; - -&usb1 { - status = "okay"; -}; - -&ir { - linux,rc-map-name = "rc-wetek-play2"; -}; diff --git a/arch/arm/dts/meson-gxbb-wetek.dtsi b/arch/arm/dts/meson-gxbb-wetek.dtsi deleted file mode 100644 index 94dafb95530..00000000000 --- a/arch/arm/dts/meson-gxbb-wetek.dtsi +++ /dev/null @@ -1,292 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016 Andreas Färber - * Copyright (c) 2016 BayLibre, Inc. - * Author: Kevin Hilman khilman@kernel.org - */ - -#include "meson-gxbb.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/leds/common.h> - -/ { - aliases { - serial0 = &uart_AO; - ethernet0 = ðmac; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x0 0x0 0x40000000>; - }; - - leds { - compatible = "gpio-leds"; - - led-power { - /* red in suspend or power-off */ - color = <LED_COLOR_ID_BLUE>; - function = LED_FUNCTION_POWER; - gpios = <&gpio_ao GPIOAO_13 GPIO_ACTIVE_HIGH>; - default-state = "on"; - panic-indicator; - }; - }; - - usb_pwr: regulator-usb-pwrs { - compatible = "regulator-fixed"; - - regulator-name = "USB_PWR"; - - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - - gpio = <&gpio GPIODV_24 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - vddio_boot: regulator-vddio_boot { - compatible = "regulator-fixed"; - regulator-name = "VDDIO_BOOT"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - vddao_3v3: regulator-vddao_3v3 { - compatible = "regulator-fixed"; - regulator-name = "VDDAO_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vddio_ao18: regulator-vddio_ao18 { - compatible = "regulator-fixed"; - regulator-name = "VDDIO_AO18"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - - vcc_3v3: regulator-vcc_3v3 { - compatible = "regulator-fixed"; - regulator-name = "VCC_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - emmc_pwrseq: emmc-pwrseq { - compatible = "mmc-pwrseq-emmc"; - reset-gpios = <&gpio BOOT_9 GPIO_ACTIVE_LOW>; - }; - - wifi32k: wifi32k { - compatible = "pwm-clock"; - #clock-cells = <0>; - clock-frequency = <32768>; - pwms = <&pwm_ef 0 30518 0>; /* PWM_E at 32.768KHz */ - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - reset-gpios = <&gpio GPIOX_6 GPIO_ACTIVE_LOW>; - clocks = <&wifi32k>; - clock-names = "ext_clock"; - }; - - cvbs-connector { - compatible = "composite-video-connector"; - - port { - cvbs_connector_in: endpoint { - remote-endpoint = <&cvbs_vdac_out>; - }; - }; - }; - - hdmi-connector { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_connector_in: endpoint { - remote-endpoint = <&hdmi_tx_tmds_out>; - }; - }; - }; -}; - -&cec_AO { - status = "okay"; - pinctrl-0 = <&ao_cec_pins>; - pinctrl-names = "default"; - hdmi-phandle = <&hdmi_tx>; -}; - -&cvbs_vdac_port { - cvbs_vdac_out: endpoint { - remote-endpoint = <&cvbs_connector_in>; - }; -}; - -ðmac { - status = "okay"; - pinctrl-0 = <ð_rgmii_pins>; - pinctrl-names = "default"; - - phy-handle = <ð_phy0>; - phy-mode = "rgmii"; - - amlogic,tx-delay-ns = <2>; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - - eth_phy0: ethernet-phy@0 { - /* Realtek RTL8211F (0x001cc916) */ - reg = <0>; - - reset-assert-us = <10000>; - reset-deassert-us = <80000>; - reset-gpios = <&gpio GPIOZ_14 GPIO_ACTIVE_LOW>; - - interrupt-parent = <&gpio_intc>; - /* MAC_INTR on GPIOZ_15 */ - interrupts = <29 IRQ_TYPE_LEVEL_LOW>; - }; - }; -}; - -&hdmi_tx { - status = "okay"; - pinctrl-0 = <&hdmi_hpd_pins>, <&hdmi_i2c_pins>; - pinctrl-names = "default"; - hdmi-supply = <&vddio_ao18>; -}; - -&hdmi_tx_tmds_port { - hdmi_tx_tmds_out: endpoint { - remote-endpoint = <&hdmi_connector_in>; - }; -}; - -&ir { - status = "okay"; - pinctrl-0 = <&remote_input_ao_pins>; - pinctrl-names = "default"; -}; - -&pwm_ef { - status = "okay"; - pinctrl-0 = <&pwm_e_pins>; - pinctrl-names = "default"; - clocks = <&clkc CLKID_FCLK_DIV4>; - clock-names = "clkin0"; -}; - -&saradc { - status = "okay"; - vref-supply = <&vddio_ao18>; -}; - -/* Wireless SDIO Module */ -&sd_emmc_a { - status = "okay"; - pinctrl-0 = <&sdio_pins>; - pinctrl-1 = <&sdio_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - #address-cells = <1>; - #size-cells = <0>; - - bus-width = <4>; - cap-sd-highspeed; - max-frequency = <50000000>; - - non-removable; - disable-wp; - - /* WiFi firmware requires power to be kept while in suspend */ - keep-power-in-suspend; - - mmc-pwrseq = <&sdio_pwrseq>; - - vmmc-supply = <&vddao_3v3>; - vqmmc-supply = <&vddio_boot>; - - brcmf: wifi@1 { - reg = <1>; - compatible = "brcm,bcm4329-fmac"; - }; -}; - -/* SD card */ -&sd_emmc_b { - status = "okay"; - pinctrl-0 = <&sdcard_pins>; - pinctrl-1 = <&sdcard_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <4>; - cap-sd-highspeed; - max-frequency = <50000000>; - disable-wp; - - cd-gpios = <&gpio CARD_6 GPIO_ACTIVE_LOW>; - - vmmc-supply = <&vddao_3v3>; - vqmmc-supply = <&vcc_3v3>; -}; - -/* eMMC */ -&sd_emmc_c { - status = "okay"; - pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>; - pinctrl-1 = <&emmc_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <8>; - cap-mmc-highspeed; - max-frequency = <200000000>; - non-removable; - disable-wp; - mmc-ddr-1_8v; - mmc-hs200-1_8v; - - mmc-pwrseq = <&emmc_pwrseq>; - vmmc-supply = <&vcc_3v3>; - vqmmc-supply = <&vddio_boot>; -}; - -/* This is connected to the Bluetooth module: */ -&uart_A { - status = "okay"; - pinctrl-0 = <&uart_a_pins>, <&uart_a_cts_rts_pins>; - pinctrl-names = "default"; - uart-has-rtscts; - - bluetooth { - compatible = "brcm,bcm43438-bt"; - shutdown-gpios = <&gpio GPIOX_20 GPIO_ACTIVE_HIGH>; - }; -}; - -/* This UART is brought out to the DB9 connector */ -&uart_AO { - status = "okay"; - pinctrl-0 = <&uart_ao_a_pins>; - pinctrl-names = "default"; -}; - -&usb0_phy { - status = "okay"; - phy-supply = <&usb_pwr>; -}; - -&usb0 { - status = "okay"; -}; diff --git a/arch/arm/dts/meson-gxbb.dtsi b/arch/arm/dts/meson-gxbb.dtsi deleted file mode 100644 index 7c029f552a2..00000000000 --- a/arch/arm/dts/meson-gxbb.dtsi +++ /dev/null @@ -1,856 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016 Andreas Färber - */ - -#include "meson-gx.dtsi" -#include "meson-gx-mali450.dtsi" -#include <dt-bindings/gpio/meson-gxbb-gpio.h> -#include <dt-bindings/reset/amlogic,meson-gxbb-reset.h> -#include <dt-bindings/clock/gxbb-clkc.h> -#include <dt-bindings/clock/gxbb-aoclkc.h> -#include <dt-bindings/reset/gxbb-aoclkc.h> - -/ { - compatible = "amlogic,meson-gxbb"; - - soc { - usb0_phy: phy@c0000000 { - compatible = "amlogic,meson-gxbb-usb2-phy"; - #phy-cells = <0>; - reg = <0x0 0xc0000000 0x0 0x20>; - resets = <&reset RESET_USB_OTG>; - clocks = <&clkc CLKID_USB>, <&clkc CLKID_USB0>; - clock-names = "usb_general", "usb"; - status = "disabled"; - }; - - usb1_phy: phy@c0000020 { - compatible = "amlogic,meson-gxbb-usb2-phy"; - #phy-cells = <0>; - reg = <0x0 0xc0000020 0x0 0x20>; - resets = <&reset RESET_USB_OTG>; - clocks = <&clkc CLKID_USB>, <&clkc CLKID_USB1>; - clock-names = "usb_general", "usb"; - status = "disabled"; - }; - - usb0: usb@c9000000 { - compatible = "amlogic,meson-gxbb-usb", "snps,dwc2"; - reg = <0x0 0xc9000000 0x0 0x40000>; - interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clkc CLKID_USB0_DDR_BRIDGE>; - clock-names = "otg"; - phys = <&usb0_phy>; - phy-names = "usb2-phy"; - dr_mode = "host"; - status = "disabled"; - }; - - usb1: usb@c9100000 { - compatible = "amlogic,meson-gxbb-usb", "snps,dwc2"; - reg = <0x0 0xc9100000 0x0 0x40000>; - interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clkc CLKID_USB1_DDR_BRIDGE>; - clock-names = "otg"; - phys = <&usb1_phy>; - phy-names = "usb2-phy"; - dr_mode = "host"; - status = "disabled"; - }; - }; -}; - -&aiu { - compatible = "amlogic,aiu-gxbb", "amlogic,aiu"; - clocks = <&clkc CLKID_AIU_GLUE>, - <&clkc CLKID_I2S_OUT>, - <&clkc CLKID_AOCLK_GATE>, - <&clkc CLKID_CTS_AMCLK>, - <&clkc CLKID_MIXER_IFACE>, - <&clkc CLKID_IEC958>, - <&clkc CLKID_IEC958_GATE>, - <&clkc CLKID_CTS_MCLK_I958>, - <&clkc CLKID_CTS_I958>; - clock-names = "pclk", - "i2s_pclk", - "i2s_aoclk", - "i2s_mclk", - "i2s_mixer", - "spdif_pclk", - "spdif_aoclk", - "spdif_mclk", - "spdif_mclk_sel"; - resets = <&reset RESET_AIU>; -}; - -&aobus { - pinctrl_aobus: pinctrl@14 { - compatible = "amlogic,meson-gxbb-aobus-pinctrl"; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - gpio_ao: bank@14 { - reg = <0x0 0x00014 0x0 0x8>, - <0x0 0x0002c 0x0 0x4>, - <0x0 0x00024 0x0 0x8>; - reg-names = "mux", "pull", "gpio"; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pinctrl_aobus 0 0 14>; - }; - - uart_ao_a_pins: uart_ao_a { - mux { - groups = "uart_tx_ao_a", "uart_rx_ao_a"; - function = "uart_ao"; - bias-disable; - }; - }; - - uart_ao_a_cts_rts_pins: uart_ao_a_cts_rts { - mux { - groups = "uart_cts_ao_a", - "uart_rts_ao_a"; - function = "uart_ao"; - bias-disable; - }; - }; - - uart_ao_b_pins: uart_ao_b { - mux { - groups = "uart_tx_ao_b", "uart_rx_ao_b"; - function = "uart_ao_b"; - bias-disable; - }; - }; - - uart_ao_b_cts_rts_pins: uart_ao_b_cts_rts { - mux { - groups = "uart_cts_ao_b", - "uart_rts_ao_b"; - function = "uart_ao_b"; - bias-disable; - }; - }; - - remote_input_ao_pins: remote_input_ao { - mux { - groups = "remote_input_ao"; - function = "remote_input_ao"; - bias-disable; - }; - }; - - i2c_ao_pins: i2c_ao { - mux { - groups = "i2c_sck_ao", - "i2c_sda_ao"; - function = "i2c_ao"; - bias-disable; - }; - }; - - pwm_ao_a_3_pins: pwm_ao_a_3 { - mux { - groups = "pwm_ao_a_3"; - function = "pwm_ao_a_3"; - bias-disable; - }; - }; - - pwm_ao_a_6_pins: pwm_ao_a_6 { - mux { - groups = "pwm_ao_a_6"; - function = "pwm_ao_a_6"; - bias-disable; - }; - }; - - pwm_ao_a_12_pins: pwm_ao_a_12 { - mux { - groups = "pwm_ao_a_12"; - function = "pwm_ao_a_12"; - bias-disable; - }; - }; - - pwm_ao_b_pins: pwm_ao_b { - mux { - groups = "pwm_ao_b"; - function = "pwm_ao_b"; - bias-disable; - }; - }; - - i2s_am_clk_pins: i2s_am_clk { - mux { - groups = "i2s_am_clk"; - function = "i2s_out_ao"; - bias-disable; - }; - }; - - i2s_out_ao_clk_pins: i2s_out_ao_clk { - mux { - groups = "i2s_out_ao_clk"; - function = "i2s_out_ao"; - bias-disable; - }; - }; - - i2s_out_lr_clk_pins: i2s_out_lr_clk { - mux { - groups = "i2s_out_lr_clk"; - function = "i2s_out_ao"; - bias-disable; - }; - }; - - i2s_out_ch01_ao_pins: i2s_out_ch01_ao { - mux { - groups = "i2s_out_ch01_ao"; - function = "i2s_out_ao"; - bias-disable; - }; - }; - - i2s_out_ch23_ao_pins: i2s_out_ch23_ao { - mux { - groups = "i2s_out_ch23_ao"; - function = "i2s_out_ao"; - bias-disable; - }; - }; - - i2s_out_ch45_ao_pins: i2s_out_ch45_ao { - mux { - groups = "i2s_out_ch45_ao"; - function = "i2s_out_ao"; - bias-disable; - }; - }; - - spdif_out_ao_6_pins: spdif_out_ao_6 { - mux { - groups = "spdif_out_ao_6"; - function = "spdif_out_ao"; - }; - }; - - spdif_out_ao_13_pins: spdif_out_ao_13 { - mux { - groups = "spdif_out_ao_13"; - function = "spdif_out_ao"; - bias-disable; - }; - }; - - ao_cec_pins: ao_cec { - mux { - groups = "ao_cec"; - function = "cec_ao"; - bias-disable; - }; - }; - - ee_cec_pins: ee_cec { - mux { - groups = "ee_cec"; - function = "cec_ao"; - bias-disable; - }; - }; - }; -}; - -&cbus { - spifc: spi@8c80 { - compatible = "amlogic,meson-gxbb-spifc"; - reg = <0x0 0x08c80 0x0 0x80>; - #address-cells = <1>; - #size-cells = <0>; - clocks = <&clkc CLKID_SPI>; - status = "disabled"; - }; -}; - -&cec_AO { - clocks = <&clkc_AO CLKID_AO_CEC_32K>; - clock-names = "core"; -}; - -&clkc_AO { - compatible = "amlogic,meson-gxbb-aoclkc", "amlogic,meson-gx-aoclkc"; - clocks = <&xtal>, <&clkc CLKID_CLK81>; - clock-names = "xtal", "mpeg-clk"; -}; - -&efuse { - clocks = <&clkc CLKID_EFUSE>; -}; - -ðmac { - clocks = <&clkc CLKID_ETH>, - <&clkc CLKID_FCLK_DIV2>, - <&clkc CLKID_MPLL2>, - <&clkc CLKID_FCLK_DIV2>; - clock-names = "stmmaceth", "clkin0", "clkin1", "timing-adjustment"; -}; - -&gpio_intc { - compatible = "amlogic,meson-gpio-intc", - "amlogic,meson-gxbb-gpio-intc"; - status = "okay"; -}; - -&hdmi_tx { - compatible = "amlogic,meson-gxbb-dw-hdmi", "amlogic,meson-gx-dw-hdmi"; - resets = <&reset RESET_HDMITX_CAPB3>, - <&reset RESET_HDMI_SYSTEM_RESET>, - <&reset RESET_HDMI_TX>; - reset-names = "hdmitx_apb", "hdmitx", "hdmitx_phy"; - clocks = <&clkc CLKID_HDMI_PCLK>, - <&clkc CLKID_CLK81>, - <&clkc CLKID_GCLK_VENCI_INT0>; - clock-names = "isfr", "iahb", "venci"; -}; - -&sysctrl { - clkc: clock-controller { - compatible = "amlogic,gxbb-clkc"; - #clock-cells = <1>; - clocks = <&xtal>; - clock-names = "xtal"; - }; -}; - -&hwrng { - clocks = <&clkc CLKID_RNG0>; - clock-names = "core"; -}; - -&i2c_A { - clocks = <&clkc CLKID_I2C>; -}; - -&i2c_AO { - clocks = <&clkc CLKID_AO_I2C>; -}; - -&i2c_B { - clocks = <&clkc CLKID_I2C>; -}; - -&i2c_C { - clocks = <&clkc CLKID_I2C>; -}; - -&mali { - compatible = "amlogic,meson-gxbb-mali", "arm,mali-450"; - - clocks = <&clkc CLKID_CLK81>, <&clkc CLKID_MALI>; - clock-names = "bus", "core"; - - assigned-clocks = <&clkc CLKID_GP0_PLL>; - assigned-clock-rates = <744000000>; -}; - -&periphs { - pinctrl_periphs: pinctrl@4b0 { - compatible = "amlogic,meson-gxbb-periphs-pinctrl"; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - gpio: bank@4b0 { - reg = <0x0 0x004b0 0x0 0x28>, - <0x0 0x004e8 0x0 0x14>, - <0x0 0x00520 0x0 0x14>, - <0x0 0x00430 0x0 0x40>; - reg-names = "mux", "pull", "pull-enable", "gpio"; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pinctrl_periphs 0 0 119>; - }; - - emmc_pins: emmc { - mux-0 { - groups = "emmc_nand_d07", - "emmc_cmd"; - function = "emmc"; - bias-pull-up; - }; - - mux-1 { - groups = "emmc_clk"; - function = "emmc"; - bias-disable; - }; - }; - - emmc_ds_pins: emmc-ds { - mux { - groups = "emmc_ds"; - function = "emmc"; - bias-pull-down; - }; - }; - - emmc_clk_gate_pins: emmc_clk_gate { - mux { - groups = "BOOT_8"; - function = "gpio_periphs"; - bias-pull-down; - }; - }; - - nor_pins: nor { - mux { - groups = "nor_d", - "nor_q", - "nor_c", - "nor_cs"; - function = "nor"; - bias-disable; - }; - }; - - spi_pins: spi-pins { - mux { - groups = "spi_miso", - "spi_mosi", - "spi_sclk"; - function = "spi"; - bias-disable; - }; - }; - - spi_ss0_pins: spi-ss0 { - mux { - groups = "spi_ss0"; - function = "spi"; - bias-disable; - }; - }; - - sdcard_pins: sdcard { - mux-0 { - groups = "sdcard_d0", - "sdcard_d1", - "sdcard_d2", - "sdcard_d3", - "sdcard_cmd"; - function = "sdcard"; - bias-pull-up; - }; - - mux-1 { - groups = "sdcard_clk"; - function = "sdcard"; - bias-disable; - }; - }; - - sdcard_clk_gate_pins: sdcard_clk_gate { - mux { - groups = "CARD_2"; - function = "gpio_periphs"; - bias-pull-down; - }; - }; - - sdio_pins: sdio { - mux-0 { - groups = "sdio_d0", - "sdio_d1", - "sdio_d2", - "sdio_d3", - "sdio_cmd"; - function = "sdio"; - bias-pull-up; - }; - - mux-1 { - groups = "sdio_clk"; - function = "sdio"; - bias-disable; - }; - }; - - sdio_clk_gate_pins: sdio_clk_gate { - mux { - groups = "GPIOX_4"; - function = "gpio_periphs"; - bias-pull-down; - }; - }; - - sdio_irq_pins: sdio_irq { - mux { - groups = "sdio_irq"; - function = "sdio"; - bias-disable; - }; - }; - - uart_a_pins: uart_a { - mux { - groups = "uart_tx_a", - "uart_rx_a"; - function = "uart_a"; - bias-disable; - }; - }; - - uart_a_cts_rts_pins: uart_a_cts_rts { - mux { - groups = "uart_cts_a", - "uart_rts_a"; - function = "uart_a"; - bias-disable; - }; - }; - - uart_b_pins: uart_b { - mux { - groups = "uart_tx_b", - "uart_rx_b"; - function = "uart_b"; - bias-disable; - }; - }; - - uart_b_cts_rts_pins: uart_b_cts_rts { - mux { - groups = "uart_cts_b", - "uart_rts_b"; - function = "uart_b"; - bias-disable; - }; - }; - - uart_c_pins: uart_c { - mux { - groups = "uart_tx_c", - "uart_rx_c"; - function = "uart_c"; - bias-disable; - }; - }; - - uart_c_cts_rts_pins: uart_c_cts_rts { - mux { - groups = "uart_cts_c", - "uart_rts_c"; - function = "uart_c"; - bias-disable; - }; - }; - - i2c_a_pins: i2c_a { - mux { - groups = "i2c_sck_a", - "i2c_sda_a"; - function = "i2c_a"; - bias-disable; - }; - }; - - i2c_b_pins: i2c_b { - mux { - groups = "i2c_sck_b", - "i2c_sda_b"; - function = "i2c_b"; - bias-disable; - }; - }; - - i2c_c_pins: i2c_c { - mux { - groups = "i2c_sck_c", - "i2c_sda_c"; - function = "i2c_c"; - bias-disable; - }; - }; - - eth_rgmii_pins: eth-rgmii { - mux { - groups = "eth_mdio", - "eth_mdc", - "eth_clk_rx_clk", - "eth_rx_dv", - "eth_rxd0", - "eth_rxd1", - "eth_rxd2", - "eth_rxd3", - "eth_rgmii_tx_clk", - "eth_tx_en", - "eth_txd0", - "eth_txd1", - "eth_txd2", - "eth_txd3"; - function = "eth"; - bias-disable; - }; - }; - - eth_rmii_pins: eth-rmii { - mux { - groups = "eth_mdio", - "eth_mdc", - "eth_clk_rx_clk", - "eth_rx_dv", - "eth_rxd0", - "eth_rxd1", - "eth_tx_en", - "eth_txd0", - "eth_txd1"; - function = "eth"; - bias-disable; - }; - }; - - pwm_a_x_pins: pwm_a_x { - mux { - groups = "pwm_a_x"; - function = "pwm_a_x"; - bias-disable; - }; - }; - - pwm_a_y_pins: pwm_a_y { - mux { - groups = "pwm_a_y"; - function = "pwm_a_y"; - bias-disable; - }; - }; - - pwm_b_pins: pwm_b { - mux { - groups = "pwm_b"; - function = "pwm_b"; - bias-disable; - }; - }; - - pwm_d_pins: pwm_d { - mux { - groups = "pwm_d"; - function = "pwm_d"; - bias-disable; - }; - }; - - pwm_e_pins: pwm_e { - mux { - groups = "pwm_e"; - function = "pwm_e"; - bias-disable; - }; - }; - - pwm_f_x_pins: pwm_f_x { - mux { - groups = "pwm_f_x"; - function = "pwm_f_x"; - bias-disable; - }; - }; - - pwm_f_y_pins: pwm_f_y { - mux { - groups = "pwm_f_y"; - function = "pwm_f_y"; - bias-disable; - }; - }; - - hdmi_hpd_pins: hdmi_hpd { - mux { - groups = "hdmi_hpd"; - function = "hdmi_hpd"; - bias-disable; - }; - }; - - hdmi_i2c_pins: hdmi_i2c { - mux { - groups = "hdmi_sda", "hdmi_scl"; - function = "hdmi_i2c"; - bias-disable; - }; - }; - - i2sout_ch23_y_pins: i2sout_ch23_y { - mux { - groups = "i2sout_ch23_y"; - function = "i2s_out"; - bias-disable; - }; - }; - - i2sout_ch45_y_pins: i2sout_ch45_y { - mux { - groups = "i2sout_ch45_y"; - function = "i2s_out"; - bias-disable; - }; - }; - - i2sout_ch67_y_pins: i2sout_ch67_y { - mux { - groups = "i2sout_ch67_y"; - function = "i2s_out"; - bias-disable; - }; - }; - - spdif_out_y_pins: spdif_out_y { - mux { - groups = "spdif_out_y"; - function = "spdif_out"; - bias-disable; - }; - }; - }; -}; - -&pwrc { - resets = <&reset RESET_VIU>, - <&reset RESET_VENC>, - <&reset RESET_VCBUS>, - <&reset RESET_BT656>, - <&reset RESET_DVIN_RESET>, - <&reset RESET_RDMA>, - <&reset RESET_VENCI>, - <&reset RESET_VENCP>, - <&reset RESET_VDAC>, - <&reset RESET_VDI6>, - <&reset RESET_VENCL>, - <&reset RESET_VID_LOCK>; - reset-names = "viu", "venc", "vcbus", "bt656", - "dvin", "rdma", "venci", "vencp", - "vdac", "vdi6", "vencl", "vid_lock"; - clocks = <&clkc CLKID_VPU>, - <&clkc CLKID_VAPB>; - clock-names = "vpu", "vapb"; - /* - * VPU clocking is provided by two identical clock paths - * VPU_0 and VPU_1 muxed to a single clock by a glitch - * free mux to safely change frequency while running. - * Same for VAPB but with a final gate after the glitch free mux. - */ - assigned-clocks = <&clkc CLKID_VPU_0_SEL>, - <&clkc CLKID_VPU_0>, - <&clkc CLKID_VPU>, /* Glitch free mux */ - <&clkc CLKID_VAPB_0_SEL>, - <&clkc CLKID_VAPB_0>, - <&clkc CLKID_VAPB_SEL>; /* Glitch free mux */ - assigned-clock-parents = <&clkc CLKID_FCLK_DIV3>, - <0>, /* Do Nothing */ - <&clkc CLKID_VPU_0>, - <&clkc CLKID_FCLK_DIV4>, - <0>, /* Do Nothing */ - <&clkc CLKID_VAPB_0>; - assigned-clock-rates = <0>, /* Do Nothing */ - <666666666>, - <0>, /* Do Nothing */ - <0>, /* Do Nothing */ - <250000000>, - <0>; /* Do Nothing */ -}; - -&saradc { - compatible = "amlogic,meson-gxbb-saradc", "amlogic,meson-saradc"; - clocks = <&xtal>, - <&clkc CLKID_SAR_ADC>, - <&clkc CLKID_SAR_ADC_CLK>, - <&clkc CLKID_SAR_ADC_SEL>; - clock-names = "clkin", "core", "adc_clk", "adc_sel"; -}; - -&sd_emmc_a { - clocks = <&clkc CLKID_SD_EMMC_A>, - <&clkc CLKID_SD_EMMC_A_CLK0>, - <&clkc CLKID_FCLK_DIV2>; - clock-names = "core", "clkin0", "clkin1"; - resets = <&reset RESET_SD_EMMC_A>; -}; - -&sd_emmc_b { - clocks = <&clkc CLKID_SD_EMMC_B>, - <&clkc CLKID_SD_EMMC_B_CLK0>, - <&clkc CLKID_FCLK_DIV2>; - clock-names = "core", "clkin0", "clkin1"; - resets = <&reset RESET_SD_EMMC_B>; -}; - -&sd_emmc_c { - clocks = <&clkc CLKID_SD_EMMC_C>, - <&clkc CLKID_SD_EMMC_C_CLK0>, - <&clkc CLKID_FCLK_DIV2>; - clock-names = "core", "clkin0", "clkin1"; - resets = <&reset RESET_SD_EMMC_C>; -}; - -&simplefb_hdmi { - clocks = <&clkc CLKID_HDMI_PCLK>, - <&clkc CLKID_CLK81>, - <&clkc CLKID_GCLK_VENCI_INT0>; -}; - -&spicc { - clocks = <&clkc CLKID_SPICC>; - clock-names = "core"; - resets = <&reset RESET_PERIPHS_SPICC>; - num-cs = <1>; -}; - -&spifc { - clocks = <&clkc CLKID_SPI>; -}; - -&uart_A { - clocks = <&xtal>, <&clkc CLKID_UART0>, <&xtal>; - clock-names = "xtal", "pclk", "baud"; -}; - -&uart_AO { - clocks = <&xtal>, <&clkc_AO CLKID_AO_UART1>, <&xtal>; - clock-names = "xtal", "pclk", "baud"; -}; - -&uart_AO_B { - clocks = <&xtal>, <&clkc_AO CLKID_AO_UART2>, <&xtal>; - clock-names = "xtal", "pclk", "baud"; -}; - -&uart_B { - clocks = <&xtal>, <&clkc CLKID_UART1>, <&xtal>; - clock-names = "xtal", "pclk", "baud"; -}; - -&uart_C { - clocks = <&xtal>, <&clkc CLKID_UART2>, <&xtal>; - clock-names = "xtal", "pclk", "baud"; -}; - -&vpu { - compatible = "amlogic,meson-gxbb-vpu", "amlogic,meson-gx-vpu"; - power-domains = <&pwrc PWRC_GXBB_VPU_ID>; -}; - -&vdec { - compatible = "amlogic,gxbb-vdec", "amlogic,gx-vdec"; - clocks = <&clkc CLKID_DOS_PARSER>, - <&clkc CLKID_DOS>, - <&clkc CLKID_VDEC_1>, - <&clkc CLKID_VDEC_HEVC>; - clock-names = "dos_parser", "dos", "vdec_1", "vdec_hevc"; - resets = <&reset RESET_PARSER>; - reset-names = "esparser"; -};
- Copyright (c) 2019 Mohammad Rasim mohammad.rasim96@gmail.com
-/dts-v1/;
status = "okay";
- leds {
led {
button-reset {
label = "reset";
- sound {
model = "KII-PRO";
<270950400>,
<393216000>;
dai-link-0 {
dai-link-1 {
dai-link-2 {
dai-format = "i2s";
mclk-fs = <256>;
codec-0 {
dai-link-3 {
codec-0 {
dai-link-4 {
codec-0 {
-&aiu {
- status = "okay";
-ðmac {
- status = "okay";
- mdio {
#size-cells = <0>;
reg = <0>;
-&ir {
-&uart_A {
- status = "okay";
- uart-has-rtscts;
- bluetooth {
- Copyright (c) 2017 Andreas Färber
-/dts-v1/;
- aliases {
serial0 = &uart_AO;
ethernet0 = ðmac;
- chosen {
- memory@0 {
- leds {
led-stat {
panic-indicator;
gpios-states = <0>;
<1800000 1>;
#clock-cells = <0>;
- cvbs-connector {
port {
- hdmi-connector {
type = "a";
port {
- sound {
<270950400>,
<393216000>;
status = "okay";
dai-link-0 {
dai-link-1 {
dai-format = "i2s";
mclk-fs = <256>;
codec-0 {
dai-link-2 {
codec-0 {
-&aiu {
- status = "okay";
-&cec_AO {
- status = "okay";
-&cvbs_vdac_port {
-ðmac {
- status = "okay";
- mdio {
#size-cells = <0>;
reg = <0>;
-&hdmi_tx {
- status = "okay";
-&ir {
- status = "okay";
-&gpio_ao {
/* GPIO_TEST_N */
-&gpio {
/* Bank GPIOH */
/* Bank BOOT */
/* Bank CARD */
/* Bank GPIODV */
/* Bank GPIOY */
/* Bank GPIOX */
/* Bank GPIOCLK */
-&pwm_ef {
- status = "okay";
-&saradc {
- status = "okay";
- status = "okay";
- bus-width = <4>;
- cap-sd-highspeed;
- non-removable;
- disable-wp;
- brcmf: wifi@1 {
reg = <1>;
- status = "okay";
- bus-width = <4>;
- cap-sd-highspeed;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- sd-uhs-ddr50;
- disable-wp;
- bus-width = <8>;
- non-removable;
- disable-wp;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
- status = "okay";
-&usb0_phy {
- status = "okay";
-&usb1_phy {
- status = "okay";
-&usb0 {
- status = "okay";
-&usb1 {
- status = "okay";
- Copyright (c) 2016 Andreas Färber
- Copyright (c) 2016 BayLibre, Inc.
- Author: Kevin Hilman khilman@kernel.org
-/dts-v1/;
- aliases {
serial0 = &uart_AO;
ethernet0 = ðmac;
- chosen {
- memory@0 {
enable-active-high;
- leds {
led-blue {
/* AP2331SA-7 */
enable-active-high;
/* U16 RT9179GB */
gpios-states = <0>;
<1800000 1>;
/* U18 RT9179GB */
/* U17 RT9179GB */
- hdmi-connector {
type = "a";
port {
- sound {
<270950400>,
<393216000>;
status = "okay";
dai-link-0 {
dai-link-1 {
dai-format = "i2s";
mclk-fs = <256>;
codec-0 {
dai-link-2 {
codec-0 {
-&aiu {
- status = "okay";
-&cec_AO {
- status = "okay";
-ðmac {
- status = "okay";
- mdio {
#size-cells = <0>;
reg = <0>;
-&gpio_ao {
- hog-0 {
gpio-hog;
output-high;
-&hdmi_tx {
- status = "okay";
-&i2c_A {
- status = "okay";
-&ir {
- status = "okay";
-&gpio_ao {
/* GPIO_TEST_N */
-&gpio {
/* Bank GPIOH */
/* Bank BOOT */
/* Bank CARD */
/* Bank GPIODV */
"PWM D", "PWM B",
/* Bank GPIOY */
/* Bank GPIOX */
/* Bank GPIOCLK */
-&saradc {
- status = "okay";
-&scpi_clocks {
- status = "okay";
- bus-width = <4>;
- cap-sd-highspeed;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- sd-uhs-ddr50;
- disable-wp;
- status = "okay";
- bus-width = <8>;
- non-removable;
- disable-wp;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
-&uart_AO {
- status = "okay";
-&usb0_phy {
-&usb1_phy {
- status = "okay";
-&usb0 {
-&usb1 {
- status = "okay";
-/dts-v1/;
- adc_keys {
button-home {
label = "Home";
button-esc {
label = "Esc";
button-up {
button-down {
button-menu {
label = "Menu";
-ðmac {
- status = "okay";
- mdio {
#size-cells = <0>;
reg = <3>;
-&i2c_B {
- status = "okay";
-&saradc {
- status = "okay";
-/dts-v1/;
-ðmac {
- status = "okay";
- aliases {
serial0 = &uart_AO;
ethernet0 = ðmac;
- chosen {
- memory@0 {
enable-active-high;
gpios-states = <1>;
<3300000 1>;
#clock-cells = <0>;
port {
- hdmi-connector {
type = "a";
port {
-&cec_AO {
- status = "okay";
-&cvbs_vdac_port {
-&hdmi_tx {
- status = "okay";
-&ir {
- status = "okay";
-&pwm_ef {
- status = "okay";
- status = "okay";
- bus-width = <4>;
- cap-sd-highspeed;
- non-removable;
- disable-wp;
- brcmf: wifi@1 {
reg = <1>;
- status = "okay";
- bus-width = <4>;
- cap-sd-highspeed;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- disable-wp;
- status = "okay";
- bus-width = <8>;
- non-removable;
- disable-wp;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
- status = "okay";
-&usb0_phy {
- status = "okay";
-&usb1_phy {
- status = "okay";
-&usb0 {
- status = "okay";
-&usb1 {
- status = "okay";
- Author: Neil Armstrong narmstrong@baylibre.com
-/dts-v1/;
- sound {
<270950400>,
<393216000>;
status = "okay";
dai-link-0 {
dai-link-1 {
dai-format = "i2s";
mclk-fs = <256>;
codec-0 {
dai-link-2 {
codec-0 {
-&aiu {
- status = "okay";
-&ir {
-/dts-v1/;
status = "okay";
- leds {
led-wifi {
led-ethernet {
button {
label = "reset";
- sound {
<270950400>,
<393216000>;
status = "okay";
dai-link-0 {
dai-link-1 {
dai-link-2 {
dai-format = "i2s";
mclk-fs = <256>;
codec-0 {
dai-link-3 {
codec-0 {
dai-link-4 {
codec-0 {
-&aiu {
- status = "okay";
-&i2c_A {
- status = "okay";
-&usb1_phy {
- status = "okay";
-&usb1 {
- status = "okay";
-&ir {
- aliases {
serial0 = &uart_AO;
ethernet0 = ðmac;
- chosen {
- memory@0 {
- leds {
led-power {
panic-indicator;
enable-active-high;
#clock-cells = <0>;
- cvbs-connector {
port {
- hdmi-connector {
type = "a";
port {
-&cec_AO {
- status = "okay";
-&cvbs_vdac_port {
-ðmac {
- status = "okay";
- mdio {
#size-cells = <0>;
reg = <0>;
-&hdmi_tx {
- status = "okay";
-&ir {
- status = "okay";
-&pwm_ef {
- status = "okay";
-&saradc {
- status = "okay";
- status = "okay";
- bus-width = <4>;
- cap-sd-highspeed;
- non-removable;
- disable-wp;
- brcmf: wifi@1 {
reg = <1>;
- status = "okay";
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- status = "okay";
- bus-width = <8>;
- non-removable;
- disable-wp;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
- status = "okay";
- uart-has-rtscts;
- bluetooth {
- status = "okay";
-&usb0_phy {
- status = "okay";
-&usb0 {
- status = "okay";
- soc {
#phy-cells = <0>;
#phy-cells = <0>;
phys = <&usb0_phy>;
dr_mode = "host";
phys = <&usb1_phy>;
dr_mode = "host";
-&aiu {
"i2s_pclk",
"i2s_aoclk",
"i2s_mclk",
"i2s_mixer",
"spdif_pclk",
"spdif_aoclk",
"spdif_mclk",
"spdif_mclk_sel";
-&aobus {
#size-cells = <2>;
ranges;
gpio_ao: bank@14 {
gpio-controller;
#gpio-cells = <2>;
mux {
bias-disable;
mux {
"uart_rts_ao_a";
bias-disable;
mux {
bias-disable;
mux {
"uart_rts_ao_b";
bias-disable;
mux {
bias-disable;
mux {
"i2c_sda_ao";
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
mux {
bias-disable;
mux {
groups = "ao_cec";
bias-disable;
mux {
groups = "ee_cec";
bias-disable;
-&cbus {
- spifc: spi@8c80 {
#size-cells = <0>;
-&cec_AO {
-&clkc_AO {
-&efuse {
-ðmac {
-&gpio_intc {
- status = "okay";
-&hdmi_tx {
-&sysctrl {
#clock-cells = <1>;
clocks = <&xtal>;
-&hwrng {
-&i2c_A {
-&i2c_AO {
-&i2c_B {
-&i2c_C {
-&mali {
-&periphs {
#size-cells = <2>;
ranges;
gpio: bank@4b0 {
gpio-controller;
#gpio-cells = <2>;
emmc_pins: emmc {
mux-0 {
"emmc_cmd";
function = "emmc";
bias-pull-up;
mux-1 {
function = "emmc";
bias-disable;
mux {
groups = "emmc_ds";
function = "emmc";
bias-pull-down;
mux {
groups = "BOOT_8";
bias-pull-down;
nor_pins: nor {
mux {
groups = "nor_d",
"nor_q",
"nor_c",
"nor_cs";
function = "nor";
bias-disable;
mux {
"spi_mosi",
"spi_sclk";
function = "spi";
bias-disable;
mux {
groups = "spi_ss0";
function = "spi";
bias-disable;
mux-0 {
"sdcard_d1",
"sdcard_d2",
"sdcard_d3",
"sdcard_cmd";
bias-pull-up;
mux-1 {
bias-disable;
mux {
groups = "CARD_2";
bias-pull-down;
sdio_pins: sdio {
mux-0 {
groups = "sdio_d0",
"sdio_d1",
"sdio_d2",
"sdio_d3",
"sdio_cmd";
function = "sdio";
bias-pull-up;
mux-1 {
function = "sdio";
bias-disable;
mux {
groups = "GPIOX_4";
bias-pull-down;
mux {
function = "sdio";
bias-disable;
mux {
"uart_rx_a";
bias-disable;
mux {
"uart_rts_a";
bias-disable;
mux {
"uart_rx_b";
bias-disable;
mux {
"uart_rts_b";
bias-disable;
mux {
"uart_rx_c";
bias-disable;
mux {
"uart_rts_c";
bias-disable;
i2c_a_pins: i2c_a {
mux {
"i2c_sda_a";
function = "i2c_a";
bias-disable;
i2c_b_pins: i2c_b {
mux {
"i2c_sda_b";
function = "i2c_b";
bias-disable;
i2c_c_pins: i2c_c {
mux {
"i2c_sda_c";
function = "i2c_c";
bias-disable;
mux {
"eth_mdc",
"eth_clk_rx_clk",
"eth_rx_dv",
"eth_rxd0",
"eth_rxd1",
"eth_rxd2",
"eth_rxd3",
"eth_rgmii_tx_clk",
"eth_tx_en",
"eth_txd0",
"eth_txd1",
"eth_txd2",
"eth_txd3";
function = "eth";
bias-disable;
mux {
"eth_mdc",
"eth_clk_rx_clk",
"eth_rx_dv",
"eth_rxd0",
"eth_rxd1",
"eth_tx_en",
"eth_txd0",
"eth_txd1";
function = "eth";
bias-disable;
mux {
groups = "pwm_a_x";
bias-disable;
mux {
groups = "pwm_a_y";
bias-disable;
pwm_b_pins: pwm_b {
mux {
groups = "pwm_b";
function = "pwm_b";
bias-disable;
pwm_d_pins: pwm_d {
mux {
groups = "pwm_d";
function = "pwm_d";
bias-disable;
pwm_e_pins: pwm_e {
mux {
groups = "pwm_e";
function = "pwm_e";
bias-disable;
mux {
groups = "pwm_f_x";
bias-disable;
mux {
groups = "pwm_f_y";
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
mux {
bias-disable;
-&pwrc {
<&clkc CLKID_VAPB>;
<666666666>,
<250000000>,
-&saradc {
- clocks = <&xtal>,
-&sd_emmc_a {
-&sd_emmc_b {
-&sd_emmc_c {
-&simplefb_hdmi {
-&spicc {
- num-cs = <1>;
-&spifc {
-&uart_A {
-&uart_AO {
-&uart_AO_B {
-&uart_B {
-&uart_C {
-&vpu {
-&vdec {
<&clkc CLKID_DOS>,
Yeah "code" removal !
Reviewed-by: Neil Armstrong neil.armstrong@linaro.org
Changes in v2:
- Patch #1: excluded gitab CI config check and added commit description.
- Patch #3: s/UBOOT_DTSI_LOC/u_boot_dtsi_loc/
- Patch #4: s/DEVICE_TREE_LOC/dt_dir/ and s/U-boot/U-Boot/
- Patch #5: s/U-boot/U-Boot/
- Patch #6 and #7: Picked up review tags
Prerequisite
This patch series requires devicetree-rebasing git repo to be added as a subtree to the main U-Boot repo via:
$ git subtree add --prefix devicetree-rebasing \ git://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasing.git \ v6.6-dts --squash
Background
This effort started while I was reviewing patch series corresponding to Qcom platforms [1] which was about to import modified devicetree source files from Linux kernel. I suppose keeping devicetree files sync with Linux kernel without any DT bindings schema validation has been a pain for U-Boot SoC/platform maintainers. There has been past discussions about a single DT repo but that hasn't come up and Linux kernel remained the place where DT source files as well as bindings are placed and maintained.
Thanks for doing this.
I really suggest to store information that kernel DTS is directly re-used, thus DTS backward and forward compatibility matters, also in Linux kernel sources. The point is that sub-arch maintainers should be aware of it. I don't think that as DT maintainers we can efficiently keep an eye on it. Maybe create a subsystem profile and include it to maintainer entries of such affected platforms?
Best regards, Krzysztof
On Fri, 22 Dec 2023 at 13:48, Krzysztof Kozlowski krzysztof.kozlowski@linaro.org wrote:
Changes in v2:
Prerequisite
Background
From U-Boot point of view, currently we have the config option:
"CONFIG_OF_UPSTREAM=y" per platform which means directly re-use of kernel DTS. So U-Boot sub-arch maintainers should be aware of platforms which get converted to re-use kernel DTS.
I suppose we have to relay information to kernel sub-arch maintainers who aren't the same as maintaining U-Boot counterparts. How about adding U-Boot ML to CC for whichever DT change gets submitted in the kernel? Otherwise adding U-Boot sub-arch maintainers as reviewers for corresponding kernel DT changes works too if that's acceptable.
-Sumit
Changes in v2:
Prerequisite
Background
From U-Boot point of view, currently we have the config option: "CONFIG_OF_UPSTREAM=y" per platform which means directly re-use of kernel DTS. So U-Boot sub-arch maintainers should be aware of platforms which get converted to re-use kernel DTS.
I was speaking about kernel.
And every other project? Just setup lei filters.
You just entirely ignored my proposal without addressing it... ok let it be. No, CC-ing U-boot maintainers changes nothing because as I said, I want kernel maintainers and contributors to be aware.
Changes in v2:
Prerequisite
Background
I don't think that adding U-Boot platform maintainers as reviewers for the platforms in the kernel is a terrible idea. Certainly kernel platform maintainers for which U-Boot platform maintainers are added to the MAINTAINERS entry will be aware. That said, something like your "strict dts compliance" maintainer profile entry [1] would be helpful I think to denote which platforms' dts are being shared in this manner
1: ARM/SAMSUNG S3C, S5P AND EXYNOS ARM ARCHITECTURES M: Krzysztof Kozlowski krzysztof.kozlowski@linaro.org R: Alim Akhtar alim.akhtar@samsung.com L: linux-arm-kernel@lists.infradead.org (moderated for non-subscribers) L: linux-samsung-soc@vger.kernel.org S: Maintained P: Documentation/process/maintainer-soc-clean-dts.rst Q: https://patchwork.kernel.org/project/linux-samsung-soc/list/
The point is it does not solve my concern here. I did not express problem that U-Boot maintainers are not aware. They can easily be aware by setting simple lei filters.
The problem I want to solve is the kernel maintainers to be aware.
On Fri, 22 Dec 2023 at 21:23, Krzysztof Kozlowski krzysztof.kozlowski@linaro.org wrote:
I thought your major concern was how we can enforce DTS backward and forward compatibility although the DT ABI stability is already documented here [1]. My suggestion was really based on recognising people who really care about DT ABI for particular platforms. I think adding people from other projects would certainly help with DT ABI stability since the kernel is the single point of contribution. There will be DT contributors from other projects too like you may have already seen people contributing bootloader (U-Boot) specific bindings/DTS changes.
[1] https://docs.kernel.org/process/maintainer-soc.html#devicetree-abi-stability
Although Tom has already expressed in the other thread that U-Boot has been a long time user of upstream DT but if we want to make it more formal from an enforcement point of view then I liked Conor's idea. If you agree then I can create maintainer profile entry as per following example for Amlogic platforms to start with:
ARM/Amlogic Meson SoC support M: Neil Armstrong neil.armstrong@linaro.org M: Kevin Hilman khilman@baylibre.com R: Jerome Brunet jbrunet@baylibre.com R: Martin Blumenstingl martin.blumenstingl@googlemail.com L: linux-arm-kernel@lists.infradead.org (moderated for non-subscribers) L: linux-amlogic@lists.infradead.org S: Maintained P: Documentation/process/maintainer-soc-u-boot-dt-abi.rst W: http://linux-meson.com/ F: Documentation/devicetree/bindings/phy/amlogic* F: arch/arm/boot/dts/amlogic/ F: arch/arm/mach-meson/ F: arch/arm64/boot/dts/amlogic/ F: drivers/pmdomain/amlogic/ F: drivers/mmc/host/meson* F: drivers/phy/amlogic/ F: drivers/pinctrl/meson/ F: drivers/rtc/rtc-meson* F: drivers/soc/amlogic/ N: meson
-Sumit
What did I write in my first email?
"Maybe create a subsystem profile and include it to maintainer entries of such affected platforms?"
You really keep ignoring my emails, so I'll stop responding here.
On Tue, 26 Dec 2023 at 14:46, Krzysztof Kozlowski krzysztof.kozlowski@linaro.org wrote:
Apologies, it was a miss on my part. I really thought it was about U-Boot maintainer awareness. I will propose this once this series lands in U-Boot.
-Sumit
Changes in v2:
Prerequisite
Background
Maybe an underlying question is, what kernel maintainers aren't aware, but should have been already? Then we can figure out how to address that. For example, with your Samsung hat on you weren't aware that exynos 4/5/7 DTS files are cared about by U-Boot, but are now aware. Samsung platforms are only recently becoming more active in U-Boot as well, so that's all understandable. On the other hand TI folks know, and I expect the K3 families to switch over to this series ASAP, and STM32 and all of the AMD/Xilinx stuff too.
Changes in v2:
Prerequisite
Background
None of them is aware.
Hm, I am still not aware of this. I mean, you wrote it above, but it is the first time I see using directly usptream DTS for U-Boot on Samsung platforms.
Did anyone test it actually? I certainly did not. I think this patchset did not remove U-Boot-tree Samsung DTS, did it?
Changes in v2:
Prerequisite
Background
With this literal patchset, only the amlogic platforms Sumit is changing have been tested, yes. In general, the U-Boot guideline has been "resync your DTS files from the kernel as often as possible" as well as "start with DTS files from the kernel, not hand-crafted". And some SoCs/vendors have been better about following these rules than others. There's a good number of commits under arch/arm/dts/ today syncing up with various states of v6.6. Which I guess emphasises my question, what kernel maintainers weren't aware that U-Boot has been consuming their DTS files as-is (as much as possible) for a number of years now?
participants (7)
Conor Dooley
Ilias Apalodimas
Krzysztof Kozlowski
Sumit Garg
