[PATCH] image: android: fix abootimg support
abootimg creates images where all load addresses are 0.
Android Boot Image Info: * file name = artifacts/fastboot.img * image size = 31381504 bytes (29.93 MB) page size = 2048 bytes * Boot Name = "" * kernel size = 9397406 bytes (8.96 MB) ramdisk size = 21981144 bytes (20.96 MB) * load addresses: kernel: 0x00000000 ramdisk: 0x00000000 tags: 0x00000000
Without this fix we end in a data abort:
Booting kernel at 0x15000000... * kernel: cmdline image address = 0x15000000 Kernel load addr 0x00000000 size 9178 KiB Kernel command line: ip=dhcp console=ttymxc0,115200n8 kernel data at 0x15000800, len = 0x008f649e (9397406) * ramdisk: cmdline image address = 0x15000000 RAM disk load addr 0x00000000 size 21473 KiB ramdisk start = 0x158f7000, ramdisk end = 0x16def35c kernel loaded at 0x00000000, end = 0x00000000 Loading Kernel Image data abort pc : [<8ff8c004>] lr : [<5d7ac70f>] sp : 8f57ed64 ip : 48f17668 fp : 00000000 r10: 00000002 r9 : 8f58aed0 r8 : 03fa4c58 r7 : 5e842497 r6 : fbe73965 r5 : 7c459955 r4 : df020fde r3 : 1b7aa45b r2 : 007f23fe r1 : 15104820 r0 : 00104000 Flags: nzCv IRQs off FIQs off Mode SVC_32 (T) Code: f07c e8b1 51f8 3a20 (e8a0) 51f8 Resetting CPU ... resetting ...
Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- common/image-android.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/common/image-android.c b/common/image-android.c index 6af9baa121..18f7c8db03 100644 --- a/common/image-android.c +++ b/common/image-android.c @@ -33,6 +33,13 @@ static ulong android_image_get_kernel_addr(const struct andr_img_hdr *hdr) if (hdr->kernel_addr == ANDROID_IMAGE_DEFAULT_KERNEL_ADDR) return (ulong)hdr + hdr->page_size;
+ /* + * abootimg creates images where all load addresses are 0 + * and we need to fix them. + */ + if (hdr->kernel_addr == 0 && hdr->ramdisk_addr == 0) + return env_get_ulong("kernel_addr_r", 16, 0); + return hdr->kernel_addr; }
- file name = artifacts/fastboot.img
- image size = 31381504 bytes (29.93 MB) page size = 2048 bytes
- Boot Name = ""
- kernel size = 9397406 bytes (8.96 MB) ramdisk size = 21981144 bytes (20.96 MB)
- load addresses: kernel: 0x00000000 ramdisk: 0x00000000 tags: 0x00000000
- kernel: cmdline image address = 0x15000000
- ramdisk: cmdline image address = 0x15000000
Christian Gmeiner
