[U-Boot] [PATCH 00/11] ARM: uniphier: pinctrl and DT fixes/updates
Masahiro Yamada (11): pinctrl: uniphier: remove wrong pin-mux functions for ProXstream2 pinctrl: uniphier: fix NAND pin-mux setting for PH1-LD11/LD20 pinctrl: uniphier: remove unneeded pin group nand_cs1 ARM: dts: uniphier: sync Device Trees with upstream Linux pinctrl: uniphier: allow to have pinctrl node under syscon node pinctrl: uniphier: split pinctrl driver for PH1-LD11 and PH1-LD20 pinctrl: uniphier: support pin configuration for dedicated pins pinctrl: uniphier: avoid building unneeded pin-mux tables for SPL pinctrl: uniphier: add ethernet pin-mux settings ARM: dts: uniphier: add AIDET nodes ARM: uniphier: add external IRQ settings
arch/arm/dts/uniphier-common32.dtsi | 22 ++++- arch/arm/dts/uniphier-ph1-ld11-ref.dts | 13 +-- arch/arm/dts/uniphier-ph1-ld11.dtsi | 50 ++++++++-- arch/arm/dts/uniphier-ph1-ld20-ref.dts | 10 -- arch/arm/dts/uniphier-ph1-ld20.dtsi | 35 +++++-- arch/arm/dts/uniphier-ph1-ld4-ref.dts | 10 -- arch/arm/dts/uniphier-ph1-ld4.dtsi | 7 +- arch/arm/dts/uniphier-ph1-ld6b-ref.dts | 10 -- arch/arm/dts/uniphier-ph1-ld6b.dtsi | 4 +- arch/arm/dts/uniphier-ph1-pro4-ace.dts | 10 -- arch/arm/dts/uniphier-ph1-pro4-ref.dts | 10 -- arch/arm/dts/uniphier-ph1-pro4-sanji.dts | 10 -- arch/arm/dts/uniphier-ph1-pro4.dtsi | 7 +- arch/arm/dts/uniphier-ph1-pro5-4kbox.dts | 10 -- arch/arm/dts/uniphier-ph1-pro5.dtsi | 7 +- arch/arm/dts/uniphier-ph1-sld3.dtsi | 5 + arch/arm/dts/uniphier-ph1-sld8-ref.dts | 10 -- arch/arm/dts/uniphier-ph1-sld8.dtsi | 7 +- arch/arm/dts/uniphier-pinctrl.dtsi | 10 ++ arch/arm/dts/uniphier-proxstream2-gentil.dts | 10 -- arch/arm/dts/uniphier-proxstream2-vodka.dts | 10 -- arch/arm/dts/uniphier-proxstream2.dtsi | 7 +- arch/arm/dts/uniphier-ref-daughter.dtsi | 2 +- arch/arm/mach-uniphier/board_early_init_f.c | 39 ++++++++ arch/arm/mach-uniphier/pinctrl/pinctrl-ld20.c | 5 + drivers/pinctrl/uniphier/Kconfig | 10 +- drivers/pinctrl/uniphier/Makefile | 1 + drivers/pinctrl/uniphier/pinctrl-uniphier-core.c | 15 ++- drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c | 107 +++++++++++++++++++++ drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c | 95 ++++++++++--------- drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c | 93 ++++++++++-------- drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c | 97 ++++++++++--------- drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c | 110 ++++++++++++--------- drivers/pinctrl/uniphier/pinctrl-uniphier-pro5.c | 91 +++++++++--------- drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c | 116 +++++++++++++---------- drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c | 87 +++++++++-------- drivers/pinctrl/uniphier/pinctrl-uniphier.h | 23 ++++- 37 files changed, 712 insertions(+), 453 deletions(-) create mode 100644 drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c
These are pin group names, not function names.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c index cfec877..0dbfdc7 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c @@ -96,11 +96,9 @@ static const char * const uniphier_pxs2_functions[] = { "nand", "sd", "uart0", - "uart0b", "uart1", "uart2", "uart3", - "uart3b", "usb0", "usb1", "usb2",
My mistake in the initial support patch.
drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c index fe154b7..4ddaddc 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c @@ -23,8 +23,8 @@ static const unsigned i2c4_pins[] = {61, 62}; static const unsigned i2c4_muxvals[] = {1, 1}; static const unsigned nand_pins[] = {3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17}; -static const unsigned nand_muxvals[] = {2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2}; +static const unsigned nand_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0}; static const unsigned nand_cs1_pins[] = {}; static const unsigned nand_cs1_muxvals[] = {}; static const unsigned sd_pins[] = {10, 11, 12, 13, 14, 15, 16, 17};
This SoC does not support NAND CS1. This place-holder is no longer necessary.
drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c index 4ddaddc..7bc0b28 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c @@ -25,8 +25,6 @@ static const unsigned nand_pins[] = {3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17}; static const unsigned nand_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}; -static const unsigned nand_cs1_pins[] = {}; -static const unsigned nand_cs1_muxvals[] = {}; static const unsigned sd_pins[] = {10, 11, 12, 13, 14, 15, 16, 17}; static const unsigned sd_muxvals[] = {3, 3, 3, 3, 3, 3, 3, 3}; /* No SDVOLC */ static const unsigned uart0_pins[] = {54, 55}; @@ -54,7 +52,6 @@ static const struct uniphier_pinctrl_group uniphier_ld20_groups[] = { UNIPHIER_PINCTRL_GROUP(i2c3), UNIPHIER_PINCTRL_GROUP(i2c4), UNIPHIER_PINCTRL_GROUP(nand), - UNIPHIER_PINCTRL_GROUP(nand_cs1), UNIPHIER_PINCTRL_GROUP(sd), /* SD does not exist for LD11 */ UNIPHIER_PINCTRL_GROUP(uart0), UNIPHIER_PINCTRL_GROUP(uart1),
I periodically sync Device Trees for better maintainability.
arch/arm/dts/uniphier-common32.dtsi | 22 +++++++++++--- arch/arm/dts/uniphier-ph1-ld11-ref.dts | 13 ++------ arch/arm/dts/uniphier-ph1-ld11.dtsi | 45 +++++++++++++++++++++++----- arch/arm/dts/uniphier-ph1-ld20-ref.dts | 10 ------- arch/arm/dts/uniphier-ph1-ld20.dtsi | 30 ++++++++++++++----- arch/arm/dts/uniphier-ph1-ld4-ref.dts | 10 ------- arch/arm/dts/uniphier-ph1-ld4.dtsi | 2 +- arch/arm/dts/uniphier-ph1-ld6b-ref.dts | 10 ------- arch/arm/dts/uniphier-ph1-ld6b.dtsi | 4 +-- arch/arm/dts/uniphier-ph1-pro4-ace.dts | 10 ------- arch/arm/dts/uniphier-ph1-pro4-ref.dts | 10 ------- arch/arm/dts/uniphier-ph1-pro4-sanji.dts | 10 ------- arch/arm/dts/uniphier-ph1-pro4.dtsi | 2 +- arch/arm/dts/uniphier-ph1-pro5-4kbox.dts | 10 ------- arch/arm/dts/uniphier-ph1-pro5.dtsi | 2 +- arch/arm/dts/uniphier-ph1-sld8-ref.dts | 10 ------- arch/arm/dts/uniphier-ph1-sld8.dtsi | 2 +- arch/arm/dts/uniphier-pinctrl.dtsi | 10 +++++++ arch/arm/dts/uniphier-proxstream2-gentil.dts | 10 ------- arch/arm/dts/uniphier-proxstream2-vodka.dts | 10 ------- arch/arm/dts/uniphier-proxstream2.dtsi | 2 +- arch/arm/dts/uniphier-ref-daughter.dtsi | 2 +- 22 files changed, 98 insertions(+), 138 deletions(-)
diff --git a/arch/arm/dts/uniphier-common32.dtsi b/arch/arm/dts/uniphier-common32.dtsi index 7d59112..b0b2b57 100644 --- a/arch/arm/dts/uniphier-common32.dtsi +++ b/arch/arm/dts/uniphier-common32.dtsi @@ -22,6 +22,7 @@ #size-cells = <1>; ranges; interrupt-parent = <&intc>; + u-boot,dm-pre-reloc;
serial0: serial@54006800 { compatible = "socionext,uniphier-uart"; @@ -65,9 +66,12 @@
system_bus: system-bus@58c00000 { compatible = "socionext,uniphier-system-bus"; + status = "disabled"; reg = <0x58c00000 0x400>; #address-cells = <2>; #size-cells = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_system_bus>; };
smpctrl@59800000 { @@ -109,9 +113,15 @@ interrupt-controller; };
- pinctrl: pinctrl@5f801000 { - /* specify compatible in each SoC DTSI */ - reg = <0x5f801000 0xe00>; + soc-glue@5f800000 { + compatible = "simple-mfd", "syscon"; + reg = <0x5f800000 0x2000>; + u-boot,dm-pre-reloc; + + pinctrl: pinctrl { + /* specify compatible in each SoC DTSI */ + u-boot,dm-pre-reloc; + }; };
sysctrl: sysctrl@61840000 { @@ -124,8 +134,12 @@
nand: nand@68000000 { compatible = "denali,denali-nand-dt"; - reg = <0x68000000 0x20>, <0x68100000 0x1000>; + status = "disabled"; reg-names = "nand_data", "denali_reg"; + reg = <0x68000000 0x20>, <0x68100000 0x1000>; + interrupts = <0 65 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_nand>; }; }; }; diff --git a/arch/arm/dts/uniphier-ph1-ld11-ref.dts b/arch/arm/dts/uniphier-ph1-ld11-ref.dts index b148e9f..4eb7664 100644 --- a/arch/arm/dts/uniphier-ph1-ld11-ref.dts +++ b/arch/arm/dts/uniphier-ph1-ld11-ref.dts @@ -1,7 +1,8 @@ /* * Device Tree Source for UniPhier PH1-LD11 Reference Board * - * Copyright (C) 2016 Masahiro Yamada yamada.masahiro@socionext.com + * Copyright (C) 2016 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ X11 */ @@ -62,20 +63,10 @@ };
/* for U-Boot only */ -/ { - soc { - u-boot,dm-pre-reloc; - }; -}; - &serial0 { u-boot,dm-pre-reloc; };
-&pinctrl { - u-boot,dm-pre-reloc; -}; - &pinctrl_uart0 { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/uniphier-ph1-ld11.dtsi b/arch/arm/dts/uniphier-ph1-ld11.dtsi index e485f90..8901a79 100644 --- a/arch/arm/dts/uniphier-ph1-ld11.dtsi +++ b/arch/arm/dts/uniphier-ph1-ld11.dtsi @@ -1,11 +1,14 @@ /* * Device Tree Source for UniPhier PH1-LD11 SoC * - * Copyright (C) 2016 Masahiro Yamada yamada.masahiro@socionext.com + * Copyright (C) 2016 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ X11 */
+/memreserve/ 0x80000000 0x00000008; /* cpu-release-addr */ + / { compatible = "socionext,ph1-ld11"; #address-cells = <2>; @@ -16,24 +19,41 @@ #address-cells = <2>; #size-cells = <0>;
- cpu@0 { + cpu-map { + cluster0 { + core0 { + cpu = <&cpu0>; + }; + core1 { + cpu = <&cpu1>; + }; + }; + }; + + cpu0: cpu@0 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0 0x000>; enable-method = "spin-table"; - cpu-release-addr = <0 0x80000100>; + cpu-release-addr = <0 0x80000000>; };
- cpu@1 { + cpu1: cpu@1 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0 0x001>; enable-method = "spin-table"; - cpu-release-addr = <0 0x80000100>; + cpu-release-addr = <0 0x80000000>; }; };
clocks { + refclk: ref { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <25000000>; + }; + uart_clk: uart_clk { #clock-cells = <0>; compatible = "fixed-clock"; @@ -60,6 +80,7 @@ #address-cells = <1>; #size-cells = <1>; ranges = <0 0 0 0xffffffff>; + u-boot,dm-pre-reloc;
serial0: serial@54006800 { compatible = "socionext,uniphier-uart"; @@ -183,6 +204,8 @@ reg = <0x58c00000 0x400>; #address-cells = <2>; #size-cells = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_system_bus>; };
smpctrl@59800000 { @@ -226,9 +249,15 @@ #clock-cells = <1>; };
- pinctrl: pinctrl@5f801000 { - compatible = "socionext,ph1-ld11-pinctrl", "syscon"; - reg = <0x5f801000 0xe00>; + soc-glue@5f800000 { + compatible = "simple-mfd", "syscon"; + reg = <0x5f800000 0x2000>; + u-boot,dm-pre-reloc; + + pinctrl: pinctrl { + compatible = "socionext,uniphier-ld11-pinctrl"; + u-boot,dm-pre-reloc; + }; };
gic: interrupt-controller@5fe00000 { diff --git a/arch/arm/dts/uniphier-ph1-ld20-ref.dts b/arch/arm/dts/uniphier-ph1-ld20-ref.dts index 3049016..90c8705 100644 --- a/arch/arm/dts/uniphier-ph1-ld20-ref.dts +++ b/arch/arm/dts/uniphier-ph1-ld20-ref.dts @@ -51,20 +51,10 @@ };
-&pinctrl { - u-boot,dm-pre-reloc; -}; - &pinctrl_uart0 { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/uniphier-ph1-ld20.dtsi b/arch/arm/dts/uniphier-ph1-ld20.dtsi index f9cc3c4..434890d 100644 --- a/arch/arm/dts/uniphier-ph1-ld20.dtsi +++ b/arch/arm/dts/uniphier-ph1-ld20.dtsi @@ -6,6 +6,8 @@ * SPDX-License-Identifier: GPL-2.0+ X11 */
+/memreserve/ 0x80000000 0x00000008; /* cpu-release-addr */ + / { compatible = "socionext,ph1-ld20"; #address-cells = <2>; @@ -41,7 +43,7 @@ compatible = "arm,cortex-a72", "arm,armv8"; reg = <0 0x000>; enable-method = "spin-table"; - cpu-release-addr = <0 0x80000100>; + cpu-release-addr = <0 0x80000000>; };
cpu1: cpu@1 { @@ -49,7 +51,7 @@ compatible = "arm,cortex-a72", "arm,armv8"; reg = <0 0x001>; enable-method = "spin-table"; - cpu-release-addr = <0 0x80000100>; + cpu-release-addr = <0 0x80000000>; };
cpu2: cpu@100 { @@ -57,7 +59,7 @@ compatible = "arm,cortex-a53", "arm,armv8"; reg = <0 0x100>; enable-method = "spin-table"; - cpu-release-addr = <0 0x80000100>; + cpu-release-addr = <0 0x80000000>; };
cpu3: cpu@101 { @@ -65,11 +67,17 @@ compatible = "arm,cortex-a53", "arm,armv8"; reg = <0 0x101>; enable-method = "spin-table"; - cpu-release-addr = <0 0x80000100>; + cpu-release-addr = <0 0x80000000>; }; };
clocks { + refclk: ref { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <25000000>; + }; + uart_clk: uart_clk { #clock-cells = <0>; compatible = "fixed-clock"; @@ -96,6 +104,7 @@ #address-cells = <1>; #size-cells = <1>; ranges = <0 0 0 0xffffffff>; + u-boot,dm-pre-reloc;
serial0: serial@54006800 { compatible = "socionext,uniphier-uart"; @@ -219,6 +228,8 @@ reg = <0x58c00000 0x400>; #address-cells = <2>; #size-cells = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_system_bus>; };
smpctrl@59800000 { @@ -243,9 +254,14 @@ bus-width = <4>; };
- pinctrl: pinctrl@5f801000 { - compatible = "socionext,ph1-ld20-pinctrl", "syscon"; - reg = <0x5f801000 0xe00>; + soc-glue@5f800000 { + compatible = "simple-mfd", "syscon"; + reg = <0x5f800000 0x2000>; + + pinctrl: pinctrl { + compatible = "socionext,uniphier-ld20-pinctrl"; + u-boot,dm-pre-reloc; + }; };
gic: interrupt-controller@5fe00000 { diff --git a/arch/arm/dts/uniphier-ph1-ld4-ref.dts b/arch/arm/dts/uniphier-ph1-ld4-ref.dts index 6cae452..36de7e3 100644 --- a/arch/arm/dts/uniphier-ph1-ld4-ref.dts +++ b/arch/arm/dts/uniphier-ph1-ld4-ref.dts @@ -69,20 +69,10 @@ };
-&pinctrl { - u-boot,dm-pre-reloc; -}; - &pinctrl_uart0 { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/uniphier-ph1-ld4.dtsi b/arch/arm/dts/uniphier-ph1-ld4.dtsi index 5ae029e..5629b7d 100644 --- a/arch/arm/dts/uniphier-ph1-ld4.dtsi +++ b/arch/arm/dts/uniphier-ph1-ld4.dtsi @@ -310,7 +310,7 @@ };
&pinctrl { - compatible = "socionext,ph1-ld4-pinctrl", "syscon"; + compatible = "socionext,uniphier-ld4-pinctrl"; };
&sysctrl { diff --git a/arch/arm/dts/uniphier-ph1-ld6b-ref.dts b/arch/arm/dts/uniphier-ph1-ld6b-ref.dts index e2a2a8c..e29a6ea 100644 --- a/arch/arm/dts/uniphier-ph1-ld6b-ref.dts +++ b/arch/arm/dts/uniphier-ph1-ld6b-ref.dts @@ -71,20 +71,10 @@ };
-&pinctrl { - u-boot,dm-pre-reloc; -}; - &pinctrl_uart0 { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/uniphier-ph1-ld6b.dtsi b/arch/arm/dts/uniphier-ph1-ld6b.dtsi index cf02e62..e8110ee 100644 --- a/arch/arm/dts/uniphier-ph1-ld6b.dtsi +++ b/arch/arm/dts/uniphier-ph1-ld6b.dtsi @@ -17,7 +17,7 @@ compatible = "socionext,ph1-ld6b"; };
-/* UART3 unavilable: the pads are not wired to the package balls */ +/* UART3 unavailable: the pads are not wired to the package balls */ &serial3 { status = "disabled"; }; @@ -27,5 +27,5 @@ * which makes the pinctrl driver unshareable. */ &pinctrl { - compatible = "socionext,ph1-ld6b-pinctrl", "syscon"; + compatible = "socionext,uniphier-ld6b-pinctrl"; }; diff --git a/arch/arm/dts/uniphier-ph1-pro4-ace.dts b/arch/arm/dts/uniphier-ph1-pro4-ace.dts index 37e0853..d8740cc 100644 --- a/arch/arm/dts/uniphier-ph1-pro4-ace.dts +++ b/arch/arm/dts/uniphier-ph1-pro4-ace.dts @@ -90,20 +90,10 @@ };
-&pinctrl { - u-boot,dm-pre-reloc; -}; - &pinctrl_uart0 { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/uniphier-ph1-pro4-ref.dts b/arch/arm/dts/uniphier-ph1-pro4-ref.dts index 5be76e2..4a2de08 100644 --- a/arch/arm/dts/uniphier-ph1-pro4-ref.dts +++ b/arch/arm/dts/uniphier-ph1-pro4-ref.dts @@ -80,20 +80,10 @@ };
-&pinctrl { - u-boot,dm-pre-reloc; -}; - &pinctrl_uart0 { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/uniphier-ph1-pro4-sanji.dts b/arch/arm/dts/uniphier-ph1-pro4-sanji.dts index 82e2bd0..965fe08 100644 --- a/arch/arm/dts/uniphier-ph1-pro4-sanji.dts +++ b/arch/arm/dts/uniphier-ph1-pro4-sanji.dts @@ -85,12 +85,6 @@ };
/* for U-Boot only */ -/ { - soc { - u-boot,dm-pre-reloc; - }; -}; - &serial0 { u-boot,dm-pre-reloc; }; @@ -103,10 +97,6 @@ u-boot,dm-pre-reloc; };
-&pinctrl { - u-boot,dm-pre-reloc; -}; - &pinctrl_uart0 { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/uniphier-ph1-pro4.dtsi b/arch/arm/dts/uniphier-ph1-pro4.dtsi index d5767b6..080fced 100644 --- a/arch/arm/dts/uniphier-ph1-pro4.dtsi +++ b/arch/arm/dts/uniphier-ph1-pro4.dtsi @@ -452,7 +452,7 @@ };
&pinctrl { - compatible = "socionext,ph1-pro4-pinctrl", "syscon"; + compatible = "socionext,uniphier-pro4-pinctrl"; };
&sysctrl { diff --git a/arch/arm/dts/uniphier-ph1-pro5-4kbox.dts b/arch/arm/dts/uniphier-ph1-pro5-4kbox.dts index cbdc3eb..682b795 100644 --- a/arch/arm/dts/uniphier-ph1-pro5-4kbox.dts +++ b/arch/arm/dts/uniphier-ph1-pro5-4kbox.dts @@ -56,20 +56,10 @@ };
/* for U-Boot only */ -/ { - soc { - u-boot,dm-pre-reloc; - }; -}; - &serial1 { u-boot,dm-pre-reloc; };
-&pinctrl { - u-boot,dm-pre-reloc; -}; - &pinctrl_uart1 { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/uniphier-ph1-pro5.dtsi b/arch/arm/dts/uniphier-ph1-pro5.dtsi index bd1b4b1..5b7f6e8 100644 --- a/arch/arm/dts/uniphier-ph1-pro5.dtsi +++ b/arch/arm/dts/uniphier-ph1-pro5.dtsi @@ -431,7 +431,7 @@ };
&pinctrl { - compatible = "socionext,ph1-pro5-pinctrl", "syscon"; + compatible = "socionext,uniphier-pro5-pinctrl"; };
&sysctrl { diff --git a/arch/arm/dts/uniphier-ph1-sld8-ref.dts b/arch/arm/dts/uniphier-ph1-sld8-ref.dts index 8ceb93e..9af012c 100644 --- a/arch/arm/dts/uniphier-ph1-sld8-ref.dts +++ b/arch/arm/dts/uniphier-ph1-sld8-ref.dts @@ -73,20 +73,10 @@ };
-&pinctrl { - u-boot,dm-pre-reloc; -}; - &pinctrl_uart0 { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/uniphier-ph1-sld8.dtsi b/arch/arm/dts/uniphier-ph1-sld8.dtsi index 61e0b45..f07a1d1 100644 --- a/arch/arm/dts/uniphier-ph1-sld8.dtsi +++ b/arch/arm/dts/uniphier-ph1-sld8.dtsi @@ -310,7 +310,7 @@ };
&pinctrl { - compatible = "socionext,ph1-sld8-pinctrl", "syscon"; + compatible = "socionext,uniphier-sld8-pinctrl"; };
&sysctrl { diff --git a/arch/arm/dts/uniphier-pinctrl.dtsi b/arch/arm/dts/uniphier-pinctrl.dtsi index 2d36f98..2810f3b 100644 --- a/arch/arm/dts/uniphier-pinctrl.dtsi +++ b/arch/arm/dts/uniphier-pinctrl.dtsi @@ -47,6 +47,11 @@ function = "nand"; };
+ pinctrl_nand2cs: nand2cs_grp { + groups = "nand", "nand_cs1"; + function = "nand"; + }; + pinctrl_sd: sd_grp { groups = "sd"; function = "sd"; @@ -67,6 +72,11 @@ function = "sd1"; };
+ pinctrl_system_bus: system_bus_grp { + groups = "system_bus", "system_bus_cs1"; + function = "system_bus"; + }; + pinctrl_uart0: uart0_grp { groups = "uart0"; function = "uart0"; diff --git a/arch/arm/dts/uniphier-proxstream2-gentil.dts b/arch/arm/dts/uniphier-proxstream2-gentil.dts index eb1d2bc..61f6164 100644 --- a/arch/arm/dts/uniphier-proxstream2-gentil.dts +++ b/arch/arm/dts/uniphier-proxstream2-gentil.dts @@ -65,12 +65,6 @@ };
/* for U-Boot only */ -/ { - soc { - u-boot,dm-pre-reloc; - }; -}; - &serial2 { u-boot,dm-pre-reloc; }; @@ -83,10 +77,6 @@ u-boot,dm-pre-reloc; };
-&pinctrl { - u-boot,dm-pre-reloc; -}; - &pinctrl_uart2 { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/uniphier-proxstream2-vodka.dts b/arch/arm/dts/uniphier-proxstream2-vodka.dts index e7d5db8..3d5b300 100644 --- a/arch/arm/dts/uniphier-proxstream2-vodka.dts +++ b/arch/arm/dts/uniphier-proxstream2-vodka.dts @@ -50,12 +50,6 @@ };
/* for U-Boot only */ -/ { - soc { - u-boot,dm-pre-reloc; - }; -}; - &serial2 { u-boot,dm-pre-reloc; }; @@ -68,10 +62,6 @@ u-boot,dm-pre-reloc; };
-&pinctrl { - u-boot,dm-pre-reloc; -}; - &pinctrl_uart2 { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/uniphier-proxstream2.dtsi b/arch/arm/dts/uniphier-proxstream2.dtsi index 12968bd..0a8c049 100644 --- a/arch/arm/dts/uniphier-proxstream2.dtsi +++ b/arch/arm/dts/uniphier-proxstream2.dtsi @@ -435,7 +435,7 @@ };
&pinctrl { - compatible = "socionext,proxstream2-pinctrl", "syscon"; + compatible = "socionext,uniphier-pxs2-pinctrl"; };
&sysctrl { diff --git a/arch/arm/dts/uniphier-ref-daughter.dtsi b/arch/arm/dts/uniphier-ref-daughter.dtsi index b8960fd..6d25104 100644 --- a/arch/arm/dts/uniphier-ref-daughter.dtsi +++ b/arch/arm/dts/uniphier-ref-daughter.dtsi @@ -7,7 +7,7 @@ */
&i2c0 { - eeprom { + eeprom@50 { compatible = "microchip,24lc128", "i2c-eeprom"; reg = <0x50>; u-boot,i2c-offset-len = <2>;
Currently, the UniPhier pinctrl driver itself is a syscon, but it turned out much more reasonable to make it a child node of a syscon because our syscon node consists of a bunch of system configuration registers, not only pinctrl, but also phy, and misc registers. It is difficult to split the node. This commit allows to migrate to the new DT structure.
drivers/pinctrl/uniphier/pinctrl-uniphier-core.c | 2 +- drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c | 4 ++-- drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c | 2 +- drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c | 2 +- drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c | 2 +- drivers/pinctrl/uniphier/pinctrl-uniphier-pro5.c | 2 +- drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c | 2 +- drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c | 2 +- drivers/pinctrl/uniphier/pinctrl-uniphier.h | 6 +++--- 9 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c index b8e26d9..fc8bbd2 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c @@ -173,7 +173,7 @@ int uniphier_pinctrl_probe(struct udevice *dev, struct uniphier_pinctrl_priv *priv = dev_get_priv(dev); fdt_addr_t addr;
- addr = dev_get_addr(dev); + addr = dev_get_addr(dev->parent); if (addr == FDT_ADDR_T_NONE) return -EINVAL;
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c index 7bc0b28..a394081 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c @@ -95,8 +95,8 @@ static int uniphier_ld20_pinctrl_probe(struct udevice *dev) }
static const struct udevice_id uniphier_ld20_pinctrl_match[] = { - { .compatible = "socionext,ph1-ld11-pinctrl" }, - { .compatible = "socionext,ph1-ld20-pinctrl" }, + { .compatible = "socionext,uniphier-ld11-pinctrl" }, + { .compatible = "socionext,uniphier-ld20-pinctrl" }, { /* sentinel */ } };
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c index ca66dee..79bc540 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c @@ -115,7 +115,7 @@ static int uniphier_ld4_pinctrl_probe(struct udevice *dev) }
static const struct udevice_id uniphier_ld4_pinctrl_match[] = { - { .compatible = "socionext,ph1-ld4-pinctrl" }, + { .compatible = "socionext,uniphier-ld4-pinctrl" }, { /* sentinel */ } };
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c index 0fd4dc4..861e741 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c @@ -115,7 +115,7 @@ static int uniphier_ld6b_pinctrl_probe(struct udevice *dev) }
static const struct udevice_id uniphier_ld6b_pinctrl_match[] = { - { .compatible = "socionext,ph1-ld6b-pinctrl" }, + { .compatible = "socionext,uniphier-ld6b-pinctrl" }, { /* sentinel */ } };
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c index 9ed7c74..f5194b6 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c @@ -112,7 +112,7 @@ static int uniphier_pro4_pinctrl_probe(struct udevice *dev) }
static const struct udevice_id uniphier_pro4_pinctrl_match[] = { - { .compatible = "socionext,ph1-pro4-pinctrl" }, + { .compatible = "socionext,uniphier-pro4-pinctrl" }, { /* sentinel */ } };
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-pro5.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-pro5.c index 6597f1c..72b9b39 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-pro5.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-pro5.c @@ -126,7 +126,7 @@ static int uniphier_pro5_pinctrl_probe(struct udevice *dev) }
static const struct udevice_id uniphier_pro5_pinctrl_match[] = { - { .compatible = "socionext,ph1-pro5-pinctrl" }, + { .compatible = "socionext,uniphier-pro5-pinctrl" }, { /* sentinel */ } };
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c index 0dbfdc7..a1c4240 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c @@ -120,7 +120,7 @@ static int uniphier_pxs2_pinctrl_probe(struct udevice *dev) }
static const struct udevice_id uniphier_pxs2_pinctrl_match[] = { - { .compatible = "socionext,proxstream2-pinctrl" }, + { .compatible = "socionext,uniphier-pxs2-pinctrl" }, { /* sentinel */ } };
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c index 5a733b3..6f4847a 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c @@ -123,7 +123,7 @@ static int uniphier_sld8_pinctrl_probe(struct udevice *dev) }
static const struct udevice_id uniphier_sld8_pinctrl_match[] = { - { .compatible = "socionext,ph1-sld8-pinctrl" }, + { .compatible = "socionext,uniphier-sld8-pinctrl" }, { /* sentinel */ } };
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier.h b/drivers/pinctrl/uniphier/pinctrl-uniphier.h index 2b43848..200d743 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier.h +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier.h @@ -12,9 +12,9 @@ #include <linux/kernel.h> #include <linux/types.h>
-#define UNIPHIER_PINCTRL_PINMUX_BASE 0x0 -#define UNIPHIER_PINCTRL_LOAD_PINMUX 0x700 -#define UNIPHIER_PINCTRL_IECTRL 0xd00 +#define UNIPHIER_PINCTRL_PINMUX_BASE 0x1000 +#define UNIPHIER_PINCTRL_LOAD_PINMUX 0x1700 +#define UNIPHIER_PINCTRL_IECTRL 0x1d00
#define UNIPHIER_PIN_ATTR_PACKED(iectrl) (iectrl)
PH1-LD11 and PH1-LD20 have much pin controlling in common, so I added a single driver shared between them in the initial commit.
However, the Ethernet pin-mux settings I am going to add are different with each other, and they may diverge more as the progress of development. Split it into two dedicated drivers.
drivers/pinctrl/uniphier/Kconfig | 10 ++- drivers/pinctrl/uniphier/Makefile | 1 + drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c | 103 +++++++++++++++++++++++ drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c | 12 +-- 4 files changed, 118 insertions(+), 8 deletions(-) create mode 100644 drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c
diff --git a/drivers/pinctrl/uniphier/Kconfig b/drivers/pinctrl/uniphier/Kconfig index 1856ff0..7febea2 100644 --- a/drivers/pinctrl/uniphier/Kconfig +++ b/drivers/pinctrl/uniphier/Kconfig @@ -39,9 +39,15 @@ config PINCTRL_UNIPHIER_LD6B default y select PINCTRL_UNIPHIER
+config PINCTRL_UNIPHIER_LD11 + bool "UniPhier PH1-LD11 SoC pinctrl driver" + depends on ARCH_UNIPHIER_LD11 + default y + select PINCTRL_UNIPHIER + config PINCTRL_UNIPHIER_LD20 - bool "UniPhier PH1-LD11/PH1-LD20 SoC pinctrl driver" - depends on ARCH_UNIPHIER_LD11 || ARCH_UNIPHIER_LD20 + bool "UniPhier PH1-LD20 SoC pinctrl driver" + depends on ARCH_UNIPHIER_LD20 default y select PINCTRL_UNIPHIER
diff --git a/drivers/pinctrl/uniphier/Makefile b/drivers/pinctrl/uniphier/Makefile index bea4dd8..4de251b 100644 --- a/drivers/pinctrl/uniphier/Makefile +++ b/drivers/pinctrl/uniphier/Makefile @@ -10,4 +10,5 @@ obj-$(CONFIG_PINCTRL_UNIPHIER_SLD8) += pinctrl-uniphier-sld8.o obj-$(CONFIG_PINCTRL_UNIPHIER_PRO5) += pinctrl-uniphier-pro5.o obj-$(CONFIG_PINCTRL_UNIPHIER_PXS2) += pinctrl-uniphier-pxs2.o obj-$(CONFIG_PINCTRL_UNIPHIER_LD6B) += pinctrl-uniphier-ld6b.o +obj-$(CONFIG_PINCTRL_UNIPHIER_LD11) += pinctrl-uniphier-ld11.o obj-$(CONFIG_PINCTRL_UNIPHIER_LD20) += pinctrl-uniphier-ld20.o diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c new file mode 100644 index 0000000..bf8c693 --- /dev/null +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c @@ -0,0 +1,103 @@ +/* + * Copyright (C) 2016 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <dm/device.h> +#include <dm/pinctrl.h> + +#include "pinctrl-uniphier.h" + +static const unsigned emmc_pins[] = {18, 19, 20, 21, 22, 23, 24, 25}; +static const unsigned emmc_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0}; +static const unsigned emmc_dat8_pins[] = {26, 27, 28, 29}; +static const unsigned emmc_dat8_muxvals[] = {0, 0, 0, 0}; +static const unsigned i2c0_pins[] = {63, 64}; +static const unsigned i2c0_muxvals[] = {0, 0}; +static const unsigned i2c1_pins[] = {65, 66}; +static const unsigned i2c1_muxvals[] = {0, 0}; +static const unsigned i2c3_pins[] = {67, 68}; +static const unsigned i2c3_muxvals[] = {1, 1}; +static const unsigned i2c4_pins[] = {61, 62}; +static const unsigned i2c4_muxvals[] = {1, 1}; +static const unsigned nand_pins[] = {3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, + 15, 16, 17}; +static const unsigned nand_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0}; +static const unsigned uart0_pins[] = {54, 55}; +static const unsigned uart0_muxvals[] = {0, 0}; +static const unsigned uart1_pins[] = {58, 59}; +static const unsigned uart1_muxvals[] = {1, 1}; +static const unsigned uart2_pins[] = {90, 91}; +static const unsigned uart2_muxvals[] = {1, 1}; +static const unsigned uart3_pins[] = {94, 95}; +static const unsigned uart3_muxvals[] = {1, 1}; +static const unsigned usb0_pins[] = {46, 47}; +static const unsigned usb0_muxvals[] = {0, 0}; +static const unsigned usb1_pins[] = {48, 49}; +static const unsigned usb1_muxvals[] = {0, 0}; +static const unsigned usb2_pins[] = {50, 51}; +static const unsigned usb2_muxvals[] = {0, 0}; + +static const struct uniphier_pinctrl_group uniphier_ld11_groups[] = { + UNIPHIER_PINCTRL_GROUP(emmc), + UNIPHIER_PINCTRL_GROUP(emmc_dat8), + UNIPHIER_PINCTRL_GROUP(i2c0), + UNIPHIER_PINCTRL_GROUP(i2c1), + UNIPHIER_PINCTRL_GROUP(i2c3), + UNIPHIER_PINCTRL_GROUP(i2c4), + UNIPHIER_PINCTRL_GROUP(nand), + UNIPHIER_PINCTRL_GROUP(uart0), + UNIPHIER_PINCTRL_GROUP(uart1), + UNIPHIER_PINCTRL_GROUP(uart2), + UNIPHIER_PINCTRL_GROUP(uart3), + UNIPHIER_PINCTRL_GROUP(usb0), + UNIPHIER_PINCTRL_GROUP(usb1), + UNIPHIER_PINCTRL_GROUP(usb2), +}; + +static const char * const uniphier_ld11_functions[] = { + "emmc", + "i2c0", + "i2c1", + "i2c3", + "i2c4", + "nand", + "uart0", + "uart1", + "uart2", + "uart3", + "usb0", + "usb1", + "usb2", +}; + +static struct uniphier_pinctrl_socdata uniphier_ld11_pinctrl_socdata = { + .groups = uniphier_ld11_groups, + .groups_count = ARRAY_SIZE(uniphier_ld11_groups), + .functions = uniphier_ld11_functions, + .functions_count = ARRAY_SIZE(uniphier_ld11_functions), + .caps = UNIPHIER_PINCTRL_CAPS_PERPIN_IECTRL, +}; + +static int uniphier_ld11_pinctrl_probe(struct udevice *dev) +{ + return uniphier_pinctrl_probe(dev, &uniphier_ld11_pinctrl_socdata); +} + +static const struct udevice_id uniphier_ld11_pinctrl_match[] = { + { .compatible = "socionext,uniphier-ld11-pinctrl" }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(uniphier_ld11_pinctrl) = { + .name = "uniphier-ld11-pinctrl", + .id = UCLASS_PINCTRL, + .of_match = of_match_ptr(uniphier_ld11_pinctrl_match), + .probe = uniphier_ld11_pinctrl_probe, + .remove = uniphier_pinctrl_remove, + .priv_auto_alloc_size = sizeof(struct uniphier_pinctrl_priv), + .ops = &uniphier_pinctrl_ops, +}; diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c index a394081..c84f7b1 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c @@ -1,5 +1,6 @@ /* - * Copyright (C) 2016 Masahiro Yamada yamada.masahiro@socionext.com + * Copyright (C) 2016 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -52,7 +53,7 @@ static const struct uniphier_pinctrl_group uniphier_ld20_groups[] = { UNIPHIER_PINCTRL_GROUP(i2c3), UNIPHIER_PINCTRL_GROUP(i2c4), UNIPHIER_PINCTRL_GROUP(nand), - UNIPHIER_PINCTRL_GROUP(sd), /* SD does not exist for LD11 */ + UNIPHIER_PINCTRL_GROUP(sd), UNIPHIER_PINCTRL_GROUP(uart0), UNIPHIER_PINCTRL_GROUP(uart1), UNIPHIER_PINCTRL_GROUP(uart2), @@ -60,7 +61,7 @@ static const struct uniphier_pinctrl_group uniphier_ld20_groups[] = { UNIPHIER_PINCTRL_GROUP(usb0), UNIPHIER_PINCTRL_GROUP(usb1), UNIPHIER_PINCTRL_GROUP(usb2), - UNIPHIER_PINCTRL_GROUP(usb3), /* USB3 does not exist for LD11 */ + UNIPHIER_PINCTRL_GROUP(usb3), };
static const char * const uniphier_ld20_functions[] = { @@ -70,7 +71,7 @@ static const char * const uniphier_ld20_functions[] = { "i2c3", "i2c4", "nand", - "sd", /* SD does not exist for LD11 */ + "sd", "uart0", "uart1", "uart2", @@ -78,7 +79,7 @@ static const char * const uniphier_ld20_functions[] = { "usb0", "usb1", "usb2", - "usb3", /* USB3 does not exist for LD11 */ + "usb3", };
static struct uniphier_pinctrl_socdata uniphier_ld20_pinctrl_socdata = { @@ -95,7 +96,6 @@ static int uniphier_ld20_pinctrl_probe(struct udevice *dev) }
static const struct udevice_id uniphier_ld20_pinctrl_match[] = { - { .compatible = "socionext,uniphier-ld11-pinctrl" }, { .compatible = "socionext,uniphier-ld20-pinctrl" }, { /* sentinel */ } };
PH1-LD4 and PH1-sLD8 SoCs have pins that support pin configuration (pin biasing, drive strength control), but not pin-muxing.
Allow to fill the mux value table with -1 for those pins; pins with mux value -1 will be skipped in the pin-mux set function. The mux value type should be changed from "unsigned" to "int" in order to accommodate -1 as a special case.
[ Linux commit: 363c90e743b50a432a91a211dd8b078d9df446e9 ]
drivers/pinctrl/uniphier/pinctrl-uniphier-core.c | 5 ++- drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c | 29 ++++++++-------- drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c | 33 +++++++++--------- drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c | 37 ++++++++++---------- drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c | 39 +++++++++++---------- drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c | 39 +++++++++++---------- drivers/pinctrl/uniphier/pinctrl-uniphier-pro5.c | 43 ++++++++++++------------ drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c | 43 ++++++++++++------------ drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c | 33 +++++++++--------- drivers/pinctrl/uniphier/pinctrl-uniphier.h | 2 +- 10 files changed, 149 insertions(+), 154 deletions(-)
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c index fc8bbd2..0ad15ab 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c @@ -91,7 +91,7 @@ static void uniphier_pinconf_input_enable(struct udevice *dev, unsigned pin) }
static void uniphier_pinmux_set_one(struct udevice *dev, unsigned pin, - unsigned muxval) + int muxval) { struct uniphier_pinctrl_priv *priv = dev_get_priv(dev); unsigned mux_bits, reg_stride, reg, reg_end, shift, mask; @@ -101,6 +101,9 @@ static void uniphier_pinmux_set_one(struct udevice *dev, unsigned pin, /* some pins need input-enabling */ uniphier_pinconf_input_enable(dev, pin);
+ if (muxval < 0) + return; /* dedicated pin; nothing to do for pin-mux */ + if (priv->socdata->caps & UNIPHIER_PINCTRL_CAPS_DBGMUX_SEPARATE) { /* * Mode offset bit diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c index bf8c693..e7147fc 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c @@ -11,35 +11,34 @@ #include "pinctrl-uniphier.h"
static const unsigned emmc_pins[] = {18, 19, 20, 21, 22, 23, 24, 25}; -static const unsigned emmc_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0}; +static const int emmc_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0}; static const unsigned emmc_dat8_pins[] = {26, 27, 28, 29}; -static const unsigned emmc_dat8_muxvals[] = {0, 0, 0, 0}; +static const int emmc_dat8_muxvals[] = {0, 0, 0, 0}; static const unsigned i2c0_pins[] = {63, 64}; -static const unsigned i2c0_muxvals[] = {0, 0}; +static const int i2c0_muxvals[] = {0, 0}; static const unsigned i2c1_pins[] = {65, 66}; -static const unsigned i2c1_muxvals[] = {0, 0}; +static const int i2c1_muxvals[] = {0, 0}; static const unsigned i2c3_pins[] = {67, 68}; -static const unsigned i2c3_muxvals[] = {1, 1}; +static const int i2c3_muxvals[] = {1, 1}; static const unsigned i2c4_pins[] = {61, 62}; -static const unsigned i2c4_muxvals[] = {1, 1}; +static const int i2c4_muxvals[] = {1, 1}; static const unsigned nand_pins[] = {3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17}; -static const unsigned nand_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, - 0, 0, 0}; +static const int nand_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}; static const unsigned uart0_pins[] = {54, 55}; -static const unsigned uart0_muxvals[] = {0, 0}; +static const int uart0_muxvals[] = {0, 0}; static const unsigned uart1_pins[] = {58, 59}; -static const unsigned uart1_muxvals[] = {1, 1}; +static const int uart1_muxvals[] = {1, 1}; static const unsigned uart2_pins[] = {90, 91}; -static const unsigned uart2_muxvals[] = {1, 1}; +static const int uart2_muxvals[] = {1, 1}; static const unsigned uart3_pins[] = {94, 95}; -static const unsigned uart3_muxvals[] = {1, 1}; +static const int uart3_muxvals[] = {1, 1}; static const unsigned usb0_pins[] = {46, 47}; -static const unsigned usb0_muxvals[] = {0, 0}; +static const int usb0_muxvals[] = {0, 0}; static const unsigned usb1_pins[] = {48, 49}; -static const unsigned usb1_muxvals[] = {0, 0}; +static const int usb1_muxvals[] = {0, 0}; static const unsigned usb2_pins[] = {50, 51}; -static const unsigned usb2_muxvals[] = {0, 0}; +static const int usb2_muxvals[] = {0, 0};
static const struct uniphier_pinctrl_group uniphier_ld11_groups[] = { UNIPHIER_PINCTRL_GROUP(emmc), diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c index c84f7b1..b662ae7 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c @@ -11,39 +11,38 @@ #include "pinctrl-uniphier.h"
static const unsigned emmc_pins[] = {18, 19, 20, 21, 22, 23, 24, 25}; -static const unsigned emmc_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0}; +static const int emmc_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0}; static const unsigned emmc_dat8_pins[] = {26, 27, 28, 29}; -static const unsigned emmc_dat8_muxvals[] = {0, 0, 0, 0}; +static const int emmc_dat8_muxvals[] = {0, 0, 0, 0}; static const unsigned i2c0_pins[] = {63, 64}; -static const unsigned i2c0_muxvals[] = {0, 0}; +static const int i2c0_muxvals[] = {0, 0}; static const unsigned i2c1_pins[] = {65, 66}; -static const unsigned i2c1_muxvals[] = {0, 0}; +static const int i2c1_muxvals[] = {0, 0}; static const unsigned i2c3_pins[] = {67, 68}; -static const unsigned i2c3_muxvals[] = {1, 1}; +static const int i2c3_muxvals[] = {1, 1}; static const unsigned i2c4_pins[] = {61, 62}; -static const unsigned i2c4_muxvals[] = {1, 1}; +static const int i2c4_muxvals[] = {1, 1}; static const unsigned nand_pins[] = {3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17}; -static const unsigned nand_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, - 0, 0, 0}; +static const int nand_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}; static const unsigned sd_pins[] = {10, 11, 12, 13, 14, 15, 16, 17}; -static const unsigned sd_muxvals[] = {3, 3, 3, 3, 3, 3, 3, 3}; /* No SDVOLC */ +static const int sd_muxvals[] = {3, 3, 3, 3, 3, 3, 3, 3}; /* No SDVOLC */ static const unsigned uart0_pins[] = {54, 55}; -static const unsigned uart0_muxvals[] = {0, 0}; +static const int uart0_muxvals[] = {0, 0}; static const unsigned uart1_pins[] = {58, 59}; -static const unsigned uart1_muxvals[] = {1, 1}; +static const int uart1_muxvals[] = {1, 1}; static const unsigned uart2_pins[] = {90, 91}; -static const unsigned uart2_muxvals[] = {1, 1}; +static const int uart2_muxvals[] = {1, 1}; static const unsigned uart3_pins[] = {94, 95}; -static const unsigned uart3_muxvals[] = {1, 1}; +static const int uart3_muxvals[] = {1, 1}; static const unsigned usb0_pins[] = {46, 47}; -static const unsigned usb0_muxvals[] = {0, 0}; +static const int usb0_muxvals[] = {0, 0}; static const unsigned usb1_pins[] = {48, 49}; -static const unsigned usb1_muxvals[] = {0, 0}; +static const int usb1_muxvals[] = {0, 0}; static const unsigned usb2_pins[] = {50, 51}; -static const unsigned usb2_muxvals[] = {0, 0}; +static const int usb2_muxvals[] = {0, 0}; static const unsigned usb3_pins[] = {52, 53}; -static const unsigned usb3_muxvals[] = {0, 0}; +static const int usb3_muxvals[] = {0, 0};
static const struct uniphier_pinctrl_group uniphier_ld20_groups[] = { UNIPHIER_PINCTRL_GROUP(emmc), diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c index 79bc540..f3849b4 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c @@ -24,43 +24,42 @@ static const struct uniphier_pinctrl_pin uniphier_ld4_pins[] = { };
static const unsigned emmc_pins[] = {21, 22, 23, 24, 25, 26, 27}; -static const unsigned emmc_muxvals[] = {0, 1, 1, 1, 1, 1, 1}; +static const int emmc_muxvals[] = {0, 1, 1, 1, 1, 1, 1}; static const unsigned emmc_dat8_pins[] = {28, 29, 30, 31}; -static const unsigned emmc_dat8_muxvals[] = {1, 1, 1, 1}; +static const int emmc_dat8_muxvals[] = {1, 1, 1, 1}; static const unsigned i2c0_pins[] = {102, 103}; -static const unsigned i2c0_muxvals[] = {0, 0}; +static const int i2c0_muxvals[] = {0, 0}; static const unsigned i2c1_pins[] = {104, 105}; -static const unsigned i2c1_muxvals[] = {0, 0}; +static const int i2c1_muxvals[] = {0, 0}; static const unsigned i2c2_pins[] = {108, 109}; -static const unsigned i2c2_muxvals[] = {2, 2}; +static const int i2c2_muxvals[] = {2, 2}; static const unsigned i2c3_pins[] = {108, 109}; -static const unsigned i2c3_muxvals[] = {3, 3}; +static const int i2c3_muxvals[] = {3, 3}; static const unsigned nand_pins[] = {24, 25, 26, 27, 28, 29, 30, 31, 158, 159, 160, 161, 162, 163, 164}; -static const unsigned nand_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, - 0, 0}; +static const int nand_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}; static const unsigned nand_cs1_pins[] = {22, 23}; -static const unsigned nand_cs1_muxvals[] = {0, 0}; +static const int nand_cs1_muxvals[] = {0, 0}; static const unsigned sd_pins[] = {44, 45, 46, 47, 48, 49, 50, 51, 52}; -static const unsigned sd_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0}; +static const int sd_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0}; static const unsigned uart0_pins[] = {85, 88}; -static const unsigned uart0_muxvals[] = {1, 1}; +static const int uart0_muxvals[] = {1, 1}; static const unsigned uart1_pins[] = {155, 156}; -static const unsigned uart1_muxvals[] = {13, 13}; +static const int uart1_muxvals[] = {13, 13}; static const unsigned uart1b_pins[] = {69, 70}; -static const unsigned uart1b_muxvals[] = {23, 23}; +static const int uart1b_muxvals[] = {23, 23}; static const unsigned uart2_pins[] = {128, 129}; -static const unsigned uart2_muxvals[] = {13, 13}; +static const int uart2_muxvals[] = {13, 13}; static const unsigned uart3_pins[] = {110, 111}; -static const unsigned uart3_muxvals[] = {1, 1}; +static const int uart3_muxvals[] = {1, 1}; static const unsigned usb0_pins[] = {53, 54}; -static const unsigned usb0_muxvals[] = {0, 0}; +static const int usb0_muxvals[] = {0, 0}; static const unsigned usb1_pins[] = {55, 56}; -static const unsigned usb1_muxvals[] = {0, 0}; +static const int usb1_muxvals[] = {0, 0}; static const unsigned usb2_pins[] = {155, 156}; -static const unsigned usb2_muxvals[] = {4, 4}; +static const int usb2_muxvals[] = {4, 4}; static const unsigned usb2b_pins[] = {67, 68}; -static const unsigned usb2b_muxvals[] = {23, 23}; +static const int usb2b_muxvals[] = {23, 23};
static const struct uniphier_pinctrl_group uniphier_ld4_groups[] = { UNIPHIER_PINCTRL_GROUP(emmc), diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c index 861e741..4627f2c 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c @@ -21,45 +21,44 @@ static const struct uniphier_pinctrl_pin uniphier_ld6b_pins[] = { };
static const unsigned emmc_pins[] = {36, 37, 38, 39, 40, 41, 42}; -static const unsigned emmc_muxvals[] = {1, 1, 1, 1, 1, 1, 1}; +static const int emmc_muxvals[] = {1, 1, 1, 1, 1, 1, 1}; static const unsigned emmc_dat8_pins[] = {43, 44, 45, 46}; -static const unsigned emmc_dat8_muxvals[] = {1, 1, 1, 1}; +static const int emmc_dat8_muxvals[] = {1, 1, 1, 1}; static const unsigned i2c0_pins[] = {109, 110}; -static const unsigned i2c0_muxvals[] = {0, 0}; +static const int i2c0_muxvals[] = {0, 0}; static const unsigned i2c1_pins[] = {111, 112}; -static const unsigned i2c1_muxvals[] = {0, 0}; +static const int i2c1_muxvals[] = {0, 0}; static const unsigned i2c2_pins[] = {115, 116}; -static const unsigned i2c2_muxvals[] = {1, 1}; +static const int i2c2_muxvals[] = {1, 1}; static const unsigned i2c3_pins[] = {118, 119}; -static const unsigned i2c3_muxvals[] = {1, 1}; +static const int i2c3_muxvals[] = {1, 1}; static const unsigned nand_pins[] = {30, 31, 32, 33, 34, 35, 36, 39, 40, 41, 42, 43, 44, 45, 46}; -static const unsigned nand_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, - 0, 0}; +static const int nand_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}; static const unsigned nand_cs1_pins[] = {37, 38}; -static const unsigned nand_cs1_muxvals[] = {0, 0}; +static const int nand_cs1_muxvals[] = {0, 0}; static const unsigned sd_pins[] = {47, 48, 49, 50, 51, 52, 53, 54, 55}; -static const unsigned sd_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0}; +static const int sd_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0}; static const unsigned uart0_pins[] = {135, 136}; -static const unsigned uart0_muxvals[] = {3, 3}; +static const int uart0_muxvals[] = {3, 3}; static const unsigned uart0b_pins[] = {11, 12}; -static const unsigned uart0b_muxvals[] = {2, 2}; +static const int uart0b_muxvals[] = {2, 2}; static const unsigned uart1_pins[] = {115, 116}; -static const unsigned uart1_muxvals[] = {0, 0}; +static const int uart1_muxvals[] = {0, 0}; static const unsigned uart1b_pins[] = {113, 114}; -static const unsigned uart1b_muxvals[] = {1, 1}; +static const int uart1b_muxvals[] = {1, 1}; static const unsigned uart2_pins[] = {113, 114}; -static const unsigned uart2_muxvals[] = {2, 2}; +static const int uart2_muxvals[] = {2, 2}; static const unsigned uart2b_pins[] = {86, 87}; -static const unsigned uart2b_muxvals[] = {1, 1}; +static const int uart2b_muxvals[] = {1, 1}; static const unsigned usb0_pins[] = {56, 57}; -static const unsigned usb0_muxvals[] = {0, 0}; +static const int usb0_muxvals[] = {0, 0}; static const unsigned usb1_pins[] = {58, 59}; -static const unsigned usb1_muxvals[] = {0, 0}; +static const int usb1_muxvals[] = {0, 0}; static const unsigned usb2_pins[] = {60, 61}; -static const unsigned usb2_muxvals[] = {0, 0}; +static const int usb2_muxvals[] = {0, 0}; static const unsigned usb3_pins[] = {62, 63}; -static const unsigned usb3_muxvals[] = {0, 0}; +static const int usb3_muxvals[] = {0, 0};
static const struct uniphier_pinctrl_group uniphier_ld6b_groups[] = { UNIPHIER_PINCTRL_GROUP(emmc), diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c index f5194b6..7e465b6 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c @@ -13,46 +13,45 @@ static const struct uniphier_pinctrl_pin uniphier_pro4_pins[] = { };
static const unsigned emmc_pins[] = {40, 41, 42, 43, 51, 52, 53}; -static const unsigned emmc_muxvals[] = {1, 1, 1, 1, 1, 1, 1}; +static const int emmc_muxvals[] = {1, 1, 1, 1, 1, 1, 1}; static const unsigned emmc_dat8_pins[] = {44, 45, 46, 47}; -static const unsigned emmc_dat8_muxvals[] = {1, 1, 1, 1}; +static const int emmc_dat8_muxvals[] = {1, 1, 1, 1}; static const unsigned i2c0_pins[] = {142, 143}; -static const unsigned i2c0_muxvals[] = {0, 0}; +static const int i2c0_muxvals[] = {0, 0}; static const unsigned i2c1_pins[] = {144, 145}; -static const unsigned i2c1_muxvals[] = {0, 0}; +static const int i2c1_muxvals[] = {0, 0}; static const unsigned i2c2_pins[] = {146, 147}; -static const unsigned i2c2_muxvals[] = {0, 0}; +static const int i2c2_muxvals[] = {0, 0}; static const unsigned i2c3_pins[] = {148, 149}; -static const unsigned i2c3_muxvals[] = {0, 0}; +static const int i2c3_muxvals[] = {0, 0}; static const unsigned i2c6_pins[] = {308, 309}; -static const unsigned i2c6_muxvals[] = {6, 6}; +static const int i2c6_muxvals[] = {6, 6}; static const unsigned nand_pins[] = {40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54}; -static const unsigned nand_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, - 0, 0}; +static const int nand_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}; static const unsigned nand_cs1_pins[] = {131, 132}; -static const unsigned nand_cs1_muxvals[] = {1, 1}; +static const int nand_cs1_muxvals[] = {1, 1}; static const unsigned sd_pins[] = {150, 151, 152, 153, 154, 155, 156, 157, 158}; -static const unsigned sd_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0}; +static const int sd_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0}; static const unsigned sd1_pins[] = {319, 320, 321, 322, 323, 324, 325, 326, 327}; -static const unsigned sd1_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0}; +static const int sd1_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0}; static const unsigned uart0_pins[] = {127, 128}; -static const unsigned uart0_muxvals[] = {0, 0}; +static const int uart0_muxvals[] = {0, 0}; static const unsigned uart1_pins[] = {129, 130}; -static const unsigned uart1_muxvals[] = {0, 0}; +static const int uart1_muxvals[] = {0, 0}; static const unsigned uart2_pins[] = {131, 132}; -static const unsigned uart2_muxvals[] = {0, 0}; +static const int uart2_muxvals[] = {0, 0}; static const unsigned uart3_pins[] = {88, 89}; -static const unsigned uart3_muxvals[] = {2, 2}; +static const int uart3_muxvals[] = {2, 2}; static const unsigned usb0_pins[] = {180, 181}; -static const unsigned usb0_muxvals[] = {0, 0}; +static const int usb0_muxvals[] = {0, 0}; static const unsigned usb1_pins[] = {182, 183}; -static const unsigned usb1_muxvals[] = {0, 0}; +static const int usb1_muxvals[] = {0, 0}; static const unsigned usb2_pins[] = {184, 185}; -static const unsigned usb2_muxvals[] = {0, 0}; +static const int usb2_muxvals[] = {0, 0}; static const unsigned usb3_pins[] = {186, 187}; -static const unsigned usb3_muxvals[] = {0, 0}; +static const int usb3_muxvals[] = {0, 0};
static const struct uniphier_pinctrl_group uniphier_pro4_groups[] = { UNIPHIER_PINCTRL_GROUP(emmc), diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-pro5.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-pro5.c index 72b9b39..2c6b4f9 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-pro5.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-pro5.c @@ -23,49 +23,48 @@ static const struct uniphier_pinctrl_pin uniphier_pro5_pins[] = { };
static const unsigned emmc_pins[] = {36, 37, 38, 39, 40, 41, 42}; -static const unsigned emmc_muxvals[] = {0, 0, 0, 0, 0, 0, 0}; +static const int emmc_muxvals[] = {0, 0, 0, 0, 0, 0, 0}; static const unsigned emmc_dat8_pins[] = {43, 44, 45, 46}; -static const unsigned emmc_dat8_muxvals[] = {0, 0, 0, 0}; +static const int emmc_dat8_muxvals[] = {0, 0, 0, 0}; static const unsigned i2c0_pins[] = {112, 113}; -static const unsigned i2c0_muxvals[] = {0, 0}; +static const int i2c0_muxvals[] = {0, 0}; static const unsigned i2c1_pins[] = {114, 115}; -static const unsigned i2c1_muxvals[] = {0, 0}; +static const int i2c1_muxvals[] = {0, 0}; static const unsigned i2c2_pins[] = {116, 117}; -static const unsigned i2c2_muxvals[] = {0, 0}; +static const int i2c2_muxvals[] = {0, 0}; static const unsigned i2c3_pins[] = {118, 119}; -static const unsigned i2c3_muxvals[] = {0, 0}; +static const int i2c3_muxvals[] = {0, 0}; static const unsigned i2c5_pins[] = {87, 88}; -static const unsigned i2c5_muxvals[] = {2, 2}; +static const int i2c5_muxvals[] = {2, 2}; static const unsigned i2c5b_pins[] = {196, 197}; -static const unsigned i2c5b_muxvals[] = {2, 2}; +static const int i2c5b_muxvals[] = {2, 2}; static const unsigned i2c5c_pins[] = {215, 216}; -static const unsigned i2c5c_muxvals[] = {2, 2}; +static const int i2c5c_muxvals[] = {2, 2}; static const unsigned i2c6_pins[] = {101, 102}; -static const unsigned i2c6_muxvals[] = {2, 2}; +static const int i2c6_muxvals[] = {2, 2}; static const unsigned nand_pins[] = {19, 20, 21, 22, 23, 24, 25, 28, 29, 30, 31, 32, 33, 34, 35}; -static const unsigned nand_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, - 0, 0}; +static const int nand_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}; static const unsigned nand_cs1_pins[] = {26, 27}; -static const unsigned nand_cs1_muxvals[] = {0, 0}; +static const int nand_cs1_muxvals[] = {0, 0}; static const unsigned sd_pins[] = {250, 251, 252, 253, 254, 255, 256, 257, 258}; -static const unsigned sd_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0}; +static const int sd_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0}; static const unsigned uart0_pins[] = {47, 48}; -static const unsigned uart0_muxvals[] = {0, 0}; +static const int uart0_muxvals[] = {0, 0}; static const unsigned uart0b_pins[] = {227, 228}; -static const unsigned uart0b_muxvals[] = {3, 3}; +static const int uart0b_muxvals[] = {3, 3}; static const unsigned uart1_pins[] = {49, 50}; -static const unsigned uart1_muxvals[] = {0, 0}; +static const int uart1_muxvals[] = {0, 0}; static const unsigned uart2_pins[] = {51, 52}; -static const unsigned uart2_muxvals[] = {0, 0}; +static const int uart2_muxvals[] = {0, 0}; static const unsigned uart3_pins[] = {53, 54}; -static const unsigned uart3_muxvals[] = {0, 0}; +static const int uart3_muxvals[] = {0, 0}; static const unsigned usb0_pins[] = {124, 125}; -static const unsigned usb0_muxvals[] = {0, 0}; +static const int usb0_muxvals[] = {0, 0}; static const unsigned usb1_pins[] = {126, 127}; -static const unsigned usb1_muxvals[] = {0, 0}; +static const int usb1_muxvals[] = {0, 0}; static const unsigned usb2_pins[] = {128, 129}; -static const unsigned usb2_muxvals[] = {0, 0}; +static const int usb2_muxvals[] = {0, 0};
static const struct uniphier_pinctrl_group uniphier_pro5_groups[] = { UNIPHIER_PINCTRL_GROUP(emmc), diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c index a1c4240..9eddd14 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c @@ -17,49 +17,48 @@ static const struct uniphier_pinctrl_pin uniphier_pxs2_pins[] = { };
static const unsigned emmc_pins[] = {36, 37, 38, 39, 40, 41, 42}; -static const unsigned emmc_muxvals[] = {9, 9, 9, 9, 9, 9, 9}; +static const int emmc_muxvals[] = {9, 9, 9, 9, 9, 9, 9}; static const unsigned emmc_dat8_pins[] = {43, 44, 45, 46}; -static const unsigned emmc_dat8_muxvals[] = {9, 9, 9, 9}; +static const int emmc_dat8_muxvals[] = {9, 9, 9, 9}; static const unsigned i2c0_pins[] = {109, 110}; -static const unsigned i2c0_muxvals[] = {8, 8}; +static const int i2c0_muxvals[] = {8, 8}; static const unsigned i2c1_pins[] = {111, 112}; -static const unsigned i2c1_muxvals[] = {8, 8}; +static const int i2c1_muxvals[] = {8, 8}; static const unsigned i2c2_pins[] = {171, 172}; -static const unsigned i2c2_muxvals[] = {8, 8}; +static const int i2c2_muxvals[] = {8, 8}; static const unsigned i2c3_pins[] = {159, 160}; -static const unsigned i2c3_muxvals[] = {8, 8}; +static const int i2c3_muxvals[] = {8, 8}; static const unsigned i2c5_pins[] = {183, 184}; -static const unsigned i2c5_muxvals[] = {11, 11}; +static const int i2c5_muxvals[] = {11, 11}; static const unsigned i2c6_pins[] = {185, 186}; -static const unsigned i2c6_muxvals[] = {11, 11}; +static const int i2c6_muxvals[] = {11, 11}; static const unsigned nand_pins[] = {30, 31, 32, 33, 34, 35, 36, 39, 40, 41, 42, 43, 44, 45, 46}; -static const unsigned nand_muxvals[] = {8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, - 8, 8}; +static const int nand_muxvals[] = {8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8}; static const unsigned nand_cs1_pins[] = {37, 38}; -static const unsigned nand_cs1_muxvals[] = {8, 8}; +static const int nand_cs1_muxvals[] = {8, 8}; static const unsigned sd_pins[] = {47, 48, 49, 50, 51, 52, 53, 54, 55}; -static const unsigned sd_muxvals[] = {8, 8, 8, 8, 8, 8, 8, 8, 8}; +static const int sd_muxvals[] = {8, 8, 8, 8, 8, 8, 8, 8, 8}; static const unsigned uart0_pins[] = {217, 218}; -static const unsigned uart0_muxvals[] = {8, 8}; +static const int uart0_muxvals[] = {8, 8}; static const unsigned uart0b_pins[] = {179, 180}; -static const unsigned uart0b_muxvals[] = {10, 10}; +static const int uart0b_muxvals[] = {10, 10}; static const unsigned uart1_pins[] = {115, 116}; -static const unsigned uart1_muxvals[] = {8, 8}; +static const int uart1_muxvals[] = {8, 8}; static const unsigned uart2_pins[] = {113, 114}; -static const unsigned uart2_muxvals[] = {8, 8}; +static const int uart2_muxvals[] = {8, 8}; static const unsigned uart3_pins[] = {219, 220}; -static const unsigned uart3_muxvals[] = {8, 8}; +static const int uart3_muxvals[] = {8, 8}; static const unsigned uart3b_pins[] = {181, 182}; -static const unsigned uart3b_muxvals[] = {10, 10}; +static const int uart3b_muxvals[] = {10, 10}; static const unsigned usb0_pins[] = {56, 57}; -static const unsigned usb0_muxvals[] = {8, 8}; +static const int usb0_muxvals[] = {8, 8}; static const unsigned usb1_pins[] = {58, 59}; -static const unsigned usb1_muxvals[] = {8, 8}; +static const int usb1_muxvals[] = {8, 8}; static const unsigned usb2_pins[] = {60, 61}; -static const unsigned usb2_muxvals[] = {8, 8}; +static const int usb2_muxvals[] = {8, 8}; static const unsigned usb3_pins[] = {62, 63}; -static const unsigned usb3_muxvals[] = {8, 8}; +static const int usb3_muxvals[] = {8, 8};
static const struct uniphier_pinctrl_group uniphier_pxs2_groups[] = { UNIPHIER_PINCTRL_GROUP(emmc), diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c index 6f4847a..82fe33d 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c @@ -38,39 +38,38 @@ static const struct uniphier_pinctrl_pin uniphier_sld8_pins[] = { };
static const unsigned emmc_pins[] = {21, 22, 23, 24, 25, 26, 27}; -static const unsigned emmc_muxvals[] = {1, 1, 1, 1, 1, 1, 1}; +static const int emmc_muxvals[] = {1, 1, 1, 1, 1, 1, 1}; static const unsigned emmc_dat8_pins[] = {28, 29, 30, 31}; -static const unsigned emmc_dat8_muxvals[] = {1, 1, 1, 1}; +static const int emmc_dat8_muxvals[] = {1, 1, 1, 1}; static const unsigned i2c0_pins[] = {102, 103}; -static const unsigned i2c0_muxvals[] = {0, 0}; +static const int i2c0_muxvals[] = {0, 0}; static const unsigned i2c1_pins[] = {104, 105}; -static const unsigned i2c1_muxvals[] = {0, 0}; +static const int i2c1_muxvals[] = {0, 0}; static const unsigned i2c2_pins[] = {108, 109}; -static const unsigned i2c2_muxvals[] = {2, 2}; +static const int i2c2_muxvals[] = {2, 2}; static const unsigned i2c3_pins[] = {108, 109}; -static const unsigned i2c3_muxvals[] = {3, 3}; +static const int i2c3_muxvals[] = {3, 3}; static const unsigned nand_pins[] = {15, 16, 17, 18, 19, 20, 21, 24, 25, 26, 27, 28, 29, 30, 31}; -static const unsigned nand_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, - 0, 0}; +static const int nand_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}; static const unsigned nand_cs1_pins[] = {22, 23}; -static const unsigned nand_cs1_muxvals[] = {0, 0}; +static const int nand_cs1_muxvals[] = {0, 0}; static const unsigned sd_pins[] = {32, 33, 34, 35, 36, 37, 38, 39, 40}; -static const unsigned sd_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0}; +static const int sd_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0}; static const unsigned uart0_pins[] = {70, 71}; -static const unsigned uart0_muxvals[] = {3, 3}; +static const int uart0_muxvals[] = {3, 3}; static const unsigned uart1_pins[] = {114, 115}; -static const unsigned uart1_muxvals[] = {0, 0}; +static const int uart1_muxvals[] = {0, 0}; static const unsigned uart2_pins[] = {112, 113}; -static const unsigned uart2_muxvals[] = {1, 1}; +static const int uart2_muxvals[] = {1, 1}; static const unsigned uart3_pins[] = {110, 111}; -static const unsigned uart3_muxvals[] = {1, 1}; +static const int uart3_muxvals[] = {1, 1}; static const unsigned usb0_pins[] = {41, 42}; -static const unsigned usb0_muxvals[] = {0, 0}; +static const int usb0_muxvals[] = {0, 0}; static const unsigned usb1_pins[] = {43, 44}; -static const unsigned usb1_muxvals[] = {0, 0}; +static const int usb1_muxvals[] = {0, 0}; static const unsigned usb2_pins[] = {114, 115}; -static const unsigned usb2_muxvals[] = {1, 1}; +static const int usb2_muxvals[] = {1, 1};
static const struct uniphier_pinctrl_group uniphier_sld8_groups[] = { UNIPHIER_PINCTRL_GROUP(emmc), diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier.h b/drivers/pinctrl/uniphier/pinctrl-uniphier.h index 200d743..ff0a368 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier.h +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier.h @@ -46,7 +46,7 @@ struct uniphier_pinctrl_group { const char *name; const unsigned *pins; unsigned num_pins; - const unsigned *muxvals; + const int *muxvals; };
SPL does not use all of the devices, so we can save some memory footprint.
drivers/pinctrl/uniphier/pinctrl-uniphier-core.c | 8 ++++ drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c | 34 ++++++++-------- drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c | 38 +++++++++--------- drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c | 42 ++++++++++---------- drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c | 44 ++++++++++----------- drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c | 46 +++++++++++----------- drivers/pinctrl/uniphier/pinctrl-uniphier-pro5.c | 46 +++++++++++----------- drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c | 50 ++++++++++++------------ drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c | 40 +++++++++---------- drivers/pinctrl/uniphier/pinctrl-uniphier.h | 15 ++++++- 10 files changed, 192 insertions(+), 171 deletions(-)
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c index 0ad15ab..225a05c 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c @@ -14,6 +14,8 @@
+static const char *uniphier_pinctrl_dummy_name = "_dummy"; + static int uniphier_pinctrl_get_groups_count(struct udevice *dev) { struct uniphier_pinctrl_priv *priv = dev_get_priv(dev); @@ -26,6 +28,9 @@ static const char *uniphier_pinctrl_get_group_name(struct udevice *dev, { struct uniphier_pinctrl_priv *priv = dev_get_priv(dev);
+ if (!priv->socdata->groups[selector].name) + return uniphier_pinctrl_dummy_name; + return priv->socdata->groups[selector].name; }
@@ -41,6 +46,9 @@ static const char *uniphier_pinmux_get_function_name(struct udevice *dev, { struct uniphier_pinctrl_priv *priv = dev_get_priv(dev);
+ if (!priv->socdata->functions[selector]) + return uniphier_pinctrl_dummy_name; + return priv->socdata->functions[selector]; }
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c index e7147fc..e2bd9ae 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c @@ -48,29 +48,29 @@ static const struct uniphier_pinctrl_group uniphier_ld11_groups[] = { UNIPHIER_PINCTRL_GROUP(i2c3), UNIPHIER_PINCTRL_GROUP(i2c4), UNIPHIER_PINCTRL_GROUP(nand), - UNIPHIER_PINCTRL_GROUP(uart0), - UNIPHIER_PINCTRL_GROUP(uart1), - UNIPHIER_PINCTRL_GROUP(uart2), - UNIPHIER_PINCTRL_GROUP(uart3), + UNIPHIER_PINCTRL_GROUP_SPL(uart0), + UNIPHIER_PINCTRL_GROUP_SPL(uart1), + UNIPHIER_PINCTRL_GROUP_SPL(uart2), + UNIPHIER_PINCTRL_GROUP_SPL(uart3), UNIPHIER_PINCTRL_GROUP(usb0), UNIPHIER_PINCTRL_GROUP(usb1), UNIPHIER_PINCTRL_GROUP(usb2), };
static const char * const uniphier_ld11_functions[] = { - "emmc", - "i2c0", - "i2c1", - "i2c3", - "i2c4", - "nand", - "uart0", - "uart1", - "uart2", - "uart3", - "usb0", - "usb1", - "usb2", + UNIPHIER_PINMUX_FUNCTION(emmc), + UNIPHIER_PINMUX_FUNCTION(i2c0), + UNIPHIER_PINMUX_FUNCTION(i2c1), + UNIPHIER_PINMUX_FUNCTION(i2c3), + UNIPHIER_PINMUX_FUNCTION(i2c4), + UNIPHIER_PINMUX_FUNCTION(nand), + UNIPHIER_PINMUX_FUNCTION_SPL(uart0), + UNIPHIER_PINMUX_FUNCTION_SPL(uart1), + UNIPHIER_PINMUX_FUNCTION_SPL(uart2), + UNIPHIER_PINMUX_FUNCTION_SPL(uart3), + UNIPHIER_PINMUX_FUNCTION(usb0), + UNIPHIER_PINMUX_FUNCTION(usb1), + UNIPHIER_PINMUX_FUNCTION(usb2), };
static struct uniphier_pinctrl_socdata uniphier_ld11_pinctrl_socdata = { diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c index b662ae7..15ee469 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c @@ -53,10 +53,10 @@ static const struct uniphier_pinctrl_group uniphier_ld20_groups[] = { UNIPHIER_PINCTRL_GROUP(i2c4), UNIPHIER_PINCTRL_GROUP(nand), UNIPHIER_PINCTRL_GROUP(sd), - UNIPHIER_PINCTRL_GROUP(uart0), - UNIPHIER_PINCTRL_GROUP(uart1), - UNIPHIER_PINCTRL_GROUP(uart2), - UNIPHIER_PINCTRL_GROUP(uart3), + UNIPHIER_PINCTRL_GROUP_SPL(uart0), + UNIPHIER_PINCTRL_GROUP_SPL(uart1), + UNIPHIER_PINCTRL_GROUP_SPL(uart2), + UNIPHIER_PINCTRL_GROUP_SPL(uart3), UNIPHIER_PINCTRL_GROUP(usb0), UNIPHIER_PINCTRL_GROUP(usb1), UNIPHIER_PINCTRL_GROUP(usb2), @@ -64,21 +64,21 @@ static const struct uniphier_pinctrl_group uniphier_ld20_groups[] = { };
static const char * const uniphier_ld20_functions[] = { - "emmc", - "i2c0", - "i2c1", - "i2c3", - "i2c4", - "nand", - "sd", - "uart0", - "uart1", - "uart2", - "uart3", - "usb0", - "usb1", - "usb2", - "usb3", + UNIPHIER_PINMUX_FUNCTION(emmc), + UNIPHIER_PINMUX_FUNCTION(i2c0), + UNIPHIER_PINMUX_FUNCTION(i2c1), + UNIPHIER_PINMUX_FUNCTION(i2c3), + UNIPHIER_PINMUX_FUNCTION(i2c4), + UNIPHIER_PINMUX_FUNCTION(nand), + UNIPHIER_PINMUX_FUNCTION(sd), + UNIPHIER_PINMUX_FUNCTION_SPL(uart0), + UNIPHIER_PINMUX_FUNCTION_SPL(uart1), + UNIPHIER_PINMUX_FUNCTION_SPL(uart2), + UNIPHIER_PINMUX_FUNCTION_SPL(uart3), + UNIPHIER_PINMUX_FUNCTION(usb0), + UNIPHIER_PINMUX_FUNCTION(usb1), + UNIPHIER_PINMUX_FUNCTION(usb2), + UNIPHIER_PINMUX_FUNCTION(usb3), };
static struct uniphier_pinctrl_socdata uniphier_ld20_pinctrl_socdata = { diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c index f3849b4..56d9d5b 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c @@ -62,8 +62,8 @@ static const unsigned usb2b_pins[] = {67, 68}; static const int usb2b_muxvals[] = {23, 23};
static const struct uniphier_pinctrl_group uniphier_ld4_groups[] = { - UNIPHIER_PINCTRL_GROUP(emmc), - UNIPHIER_PINCTRL_GROUP(emmc_dat8), + UNIPHIER_PINCTRL_GROUP_SPL(emmc), + UNIPHIER_PINCTRL_GROUP_SPL(emmc_dat8), UNIPHIER_PINCTRL_GROUP(i2c0), UNIPHIER_PINCTRL_GROUP(i2c1), UNIPHIER_PINCTRL_GROUP(i2c2), @@ -71,11 +71,11 @@ static const struct uniphier_pinctrl_group uniphier_ld4_groups[] = { UNIPHIER_PINCTRL_GROUP(nand), UNIPHIER_PINCTRL_GROUP(nand_cs1), UNIPHIER_PINCTRL_GROUP(sd), - UNIPHIER_PINCTRL_GROUP(uart0), - UNIPHIER_PINCTRL_GROUP(uart1), - UNIPHIER_PINCTRL_GROUP(uart1b), - UNIPHIER_PINCTRL_GROUP(uart2), - UNIPHIER_PINCTRL_GROUP(uart3), + UNIPHIER_PINCTRL_GROUP_SPL(uart0), + UNIPHIER_PINCTRL_GROUP_SPL(uart1), + UNIPHIER_PINCTRL_GROUP_SPL(uart1b), + UNIPHIER_PINCTRL_GROUP_SPL(uart2), + UNIPHIER_PINCTRL_GROUP_SPL(uart3), UNIPHIER_PINCTRL_GROUP(usb0), UNIPHIER_PINCTRL_GROUP(usb1), UNIPHIER_PINCTRL_GROUP(usb2), @@ -83,20 +83,20 @@ static const struct uniphier_pinctrl_group uniphier_ld4_groups[] = { };
static const char * const uniphier_ld4_functions[] = { - "emmc", - "i2c0", - "i2c1", - "i2c2", - "i2c3", - "nand", - "sd", - "uart0", - "uart1", - "uart2", - "uart3", - "usb0", - "usb1", - "usb2", + UNIPHIER_PINMUX_FUNCTION_SPL(emmc), + UNIPHIER_PINMUX_FUNCTION(i2c0), + UNIPHIER_PINMUX_FUNCTION(i2c1), + UNIPHIER_PINMUX_FUNCTION(i2c2), + UNIPHIER_PINMUX_FUNCTION(i2c3), + UNIPHIER_PINMUX_FUNCTION(nand), + UNIPHIER_PINMUX_FUNCTION(sd), + UNIPHIER_PINMUX_FUNCTION_SPL(uart0), + UNIPHIER_PINMUX_FUNCTION_SPL(uart1), + UNIPHIER_PINMUX_FUNCTION_SPL(uart2), + UNIPHIER_PINMUX_FUNCTION_SPL(uart3), + UNIPHIER_PINMUX_FUNCTION(usb0), + UNIPHIER_PINMUX_FUNCTION(usb1), + UNIPHIER_PINMUX_FUNCTION(usb2), };
static struct uniphier_pinctrl_socdata uniphier_ld4_pinctrl_socdata = { diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c index 4627f2c..dd4a28c 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c @@ -61,8 +61,8 @@ static const unsigned usb3_pins[] = {62, 63}; static const int usb3_muxvals[] = {0, 0};
static const struct uniphier_pinctrl_group uniphier_ld6b_groups[] = { - UNIPHIER_PINCTRL_GROUP(emmc), - UNIPHIER_PINCTRL_GROUP(emmc_dat8), + UNIPHIER_PINCTRL_GROUP_SPL(emmc), + UNIPHIER_PINCTRL_GROUP_SPL(emmc_dat8), UNIPHIER_PINCTRL_GROUP(i2c0), UNIPHIER_PINCTRL_GROUP(i2c1), UNIPHIER_PINCTRL_GROUP(i2c2), @@ -70,12 +70,12 @@ static const struct uniphier_pinctrl_group uniphier_ld6b_groups[] = { UNIPHIER_PINCTRL_GROUP(nand), UNIPHIER_PINCTRL_GROUP(nand_cs1), UNIPHIER_PINCTRL_GROUP(sd), - UNIPHIER_PINCTRL_GROUP(uart0), - UNIPHIER_PINCTRL_GROUP(uart0b), - UNIPHIER_PINCTRL_GROUP(uart1), - UNIPHIER_PINCTRL_GROUP(uart1b), - UNIPHIER_PINCTRL_GROUP(uart2), - UNIPHIER_PINCTRL_GROUP(uart2b), + UNIPHIER_PINCTRL_GROUP_SPL(uart0), + UNIPHIER_PINCTRL_GROUP_SPL(uart0b), + UNIPHIER_PINCTRL_GROUP_SPL(uart1), + UNIPHIER_PINCTRL_GROUP_SPL(uart1b), + UNIPHIER_PINCTRL_GROUP_SPL(uart2), + UNIPHIER_PINCTRL_GROUP_SPL(uart2b), UNIPHIER_PINCTRL_GROUP(usb0), UNIPHIER_PINCTRL_GROUP(usb1), UNIPHIER_PINCTRL_GROUP(usb2), @@ -83,20 +83,20 @@ static const struct uniphier_pinctrl_group uniphier_ld6b_groups[] = { };
static const char * const uniphier_ld6b_functions[] = { - "emmc", - "i2c0", - "i2c1", - "i2c2", - "i2c3", - "nand", - "sd", - "uart0", - "uart1", - "uart2", - "usb0", - "usb1", - "usb2", - "usb3", + UNIPHIER_PINMUX_FUNCTION_SPL(emmc), + UNIPHIER_PINMUX_FUNCTION(i2c0), + UNIPHIER_PINMUX_FUNCTION(i2c1), + UNIPHIER_PINMUX_FUNCTION(i2c2), + UNIPHIER_PINMUX_FUNCTION(i2c3), + UNIPHIER_PINMUX_FUNCTION(nand), + UNIPHIER_PINMUX_FUNCTION(sd), + UNIPHIER_PINMUX_FUNCTION_SPL(uart0), + UNIPHIER_PINMUX_FUNCTION_SPL(uart1), + UNIPHIER_PINMUX_FUNCTION_SPL(uart2), + UNIPHIER_PINMUX_FUNCTION(usb0), + UNIPHIER_PINMUX_FUNCTION(usb1), + UNIPHIER_PINMUX_FUNCTION(usb2), + UNIPHIER_PINMUX_FUNCTION(usb3), };
static struct uniphier_pinctrl_socdata uniphier_ld6b_pinctrl_socdata = { diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c index 7e465b6..f87a2c6 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c @@ -54,8 +54,8 @@ static const unsigned usb3_pins[] = {186, 187}; static const int usb3_muxvals[] = {0, 0};
static const struct uniphier_pinctrl_group uniphier_pro4_groups[] = { - UNIPHIER_PINCTRL_GROUP(emmc), - UNIPHIER_PINCTRL_GROUP(emmc_dat8), + UNIPHIER_PINCTRL_GROUP_SPL(emmc), + UNIPHIER_PINCTRL_GROUP_SPL(emmc_dat8), UNIPHIER_PINCTRL_GROUP(i2c0), UNIPHIER_PINCTRL_GROUP(i2c1), UNIPHIER_PINCTRL_GROUP(i2c2), @@ -65,10 +65,10 @@ static const struct uniphier_pinctrl_group uniphier_pro4_groups[] = { UNIPHIER_PINCTRL_GROUP(nand_cs1), UNIPHIER_PINCTRL_GROUP(sd), UNIPHIER_PINCTRL_GROUP(sd1), - UNIPHIER_PINCTRL_GROUP(uart0), - UNIPHIER_PINCTRL_GROUP(uart1), - UNIPHIER_PINCTRL_GROUP(uart2), - UNIPHIER_PINCTRL_GROUP(uart3), + UNIPHIER_PINCTRL_GROUP_SPL(uart0), + UNIPHIER_PINCTRL_GROUP_SPL(uart1), + UNIPHIER_PINCTRL_GROUP_SPL(uart2), + UNIPHIER_PINCTRL_GROUP_SPL(uart3), UNIPHIER_PINCTRL_GROUP(usb0), UNIPHIER_PINCTRL_GROUP(usb1), UNIPHIER_PINCTRL_GROUP(usb2), @@ -76,23 +76,23 @@ static const struct uniphier_pinctrl_group uniphier_pro4_groups[] = { };
static const char * const uniphier_pro4_functions[] = { - "emmc", - "i2c0", - "i2c1", - "i2c2", - "i2c3", - "i2c6", - "nand", - "sd", - "sd1", - "uart0", - "uart1", - "uart2", - "uart3", - "usb0", - "usb1", - "usb2", - "usb3", + UNIPHIER_PINMUX_FUNCTION_SPL(emmc), + UNIPHIER_PINMUX_FUNCTION(i2c0), + UNIPHIER_PINMUX_FUNCTION(i2c1), + UNIPHIER_PINMUX_FUNCTION(i2c2), + UNIPHIER_PINMUX_FUNCTION(i2c3), + UNIPHIER_PINMUX_FUNCTION(i2c6), + UNIPHIER_PINMUX_FUNCTION(nand), + UNIPHIER_PINMUX_FUNCTION(sd), + UNIPHIER_PINMUX_FUNCTION(sd1), + UNIPHIER_PINMUX_FUNCTION_SPL(uart0), + UNIPHIER_PINMUX_FUNCTION_SPL(uart1), + UNIPHIER_PINMUX_FUNCTION_SPL(uart2), + UNIPHIER_PINMUX_FUNCTION_SPL(uart3), + UNIPHIER_PINMUX_FUNCTION(usb0), + UNIPHIER_PINMUX_FUNCTION(usb1), + UNIPHIER_PINMUX_FUNCTION(usb2), + UNIPHIER_PINMUX_FUNCTION(usb3), };
static struct uniphier_pinctrl_socdata uniphier_pro4_pinctrl_socdata = { diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-pro5.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-pro5.c index 2c6b4f9..50b41cc 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-pro5.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-pro5.c @@ -67,8 +67,8 @@ static const unsigned usb2_pins[] = {128, 129}; static const int usb2_muxvals[] = {0, 0};
static const struct uniphier_pinctrl_group uniphier_pro5_groups[] = { - UNIPHIER_PINCTRL_GROUP(emmc), - UNIPHIER_PINCTRL_GROUP(emmc_dat8), + UNIPHIER_PINCTRL_GROUP_SPL(emmc), + UNIPHIER_PINCTRL_GROUP_SPL(emmc_dat8), UNIPHIER_PINCTRL_GROUP(i2c0), UNIPHIER_PINCTRL_GROUP(i2c1), UNIPHIER_PINCTRL_GROUP(i2c2), @@ -80,33 +80,33 @@ static const struct uniphier_pinctrl_group uniphier_pro5_groups[] = { UNIPHIER_PINCTRL_GROUP(nand), UNIPHIER_PINCTRL_GROUP(nand_cs1), UNIPHIER_PINCTRL_GROUP(sd), - UNIPHIER_PINCTRL_GROUP(uart0), - UNIPHIER_PINCTRL_GROUP(uart0b), - UNIPHIER_PINCTRL_GROUP(uart1), - UNIPHIER_PINCTRL_GROUP(uart2), - UNIPHIER_PINCTRL_GROUP(uart3), + UNIPHIER_PINCTRL_GROUP_SPL(uart0), + UNIPHIER_PINCTRL_GROUP_SPL(uart0b), + UNIPHIER_PINCTRL_GROUP_SPL(uart1), + UNIPHIER_PINCTRL_GROUP_SPL(uart2), + UNIPHIER_PINCTRL_GROUP_SPL(uart3), UNIPHIER_PINCTRL_GROUP(usb0), UNIPHIER_PINCTRL_GROUP(usb1), UNIPHIER_PINCTRL_GROUP(usb2), };
static const char * const uniphier_pro5_functions[] = { - "emmc", - "i2c0", - "i2c1", - "i2c2", - "i2c3", - "i2c5", - "i2c6", - "nand", - "sd", - "uart0", - "uart1", - "uart2", - "uart3", - "usb0", - "usb1", - "usb2", + UNIPHIER_PINMUX_FUNCTION_SPL(emmc), + UNIPHIER_PINMUX_FUNCTION(i2c0), + UNIPHIER_PINMUX_FUNCTION(i2c1), + UNIPHIER_PINMUX_FUNCTION(i2c2), + UNIPHIER_PINMUX_FUNCTION(i2c3), + UNIPHIER_PINMUX_FUNCTION(i2c5), + UNIPHIER_PINMUX_FUNCTION(i2c6), + UNIPHIER_PINMUX_FUNCTION(nand), + UNIPHIER_PINMUX_FUNCTION(sd), + UNIPHIER_PINMUX_FUNCTION_SPL(uart0), + UNIPHIER_PINMUX_FUNCTION_SPL(uart1), + UNIPHIER_PINMUX_FUNCTION_SPL(uart2), + UNIPHIER_PINMUX_FUNCTION_SPL(uart3), + UNIPHIER_PINMUX_FUNCTION(usb0), + UNIPHIER_PINMUX_FUNCTION(usb1), + UNIPHIER_PINMUX_FUNCTION(usb2), };
static struct uniphier_pinctrl_socdata uniphier_pro5_pinctrl_socdata = { diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c index 9eddd14..70fb168 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c @@ -61,8 +61,8 @@ static const unsigned usb3_pins[] = {62, 63}; static const int usb3_muxvals[] = {8, 8};
static const struct uniphier_pinctrl_group uniphier_pxs2_groups[] = { - UNIPHIER_PINCTRL_GROUP(emmc), - UNIPHIER_PINCTRL_GROUP(emmc_dat8), + UNIPHIER_PINCTRL_GROUP_SPL(emmc), + UNIPHIER_PINCTRL_GROUP_SPL(emmc_dat8), UNIPHIER_PINCTRL_GROUP(i2c0), UNIPHIER_PINCTRL_GROUP(i2c1), UNIPHIER_PINCTRL_GROUP(i2c2), @@ -72,12 +72,12 @@ static const struct uniphier_pinctrl_group uniphier_pxs2_groups[] = { UNIPHIER_PINCTRL_GROUP(nand), UNIPHIER_PINCTRL_GROUP(nand_cs1), UNIPHIER_PINCTRL_GROUP(sd), - UNIPHIER_PINCTRL_GROUP(uart0), - UNIPHIER_PINCTRL_GROUP(uart0b), - UNIPHIER_PINCTRL_GROUP(uart1), - UNIPHIER_PINCTRL_GROUP(uart2), - UNIPHIER_PINCTRL_GROUP(uart3), - UNIPHIER_PINCTRL_GROUP(uart3b), + UNIPHIER_PINCTRL_GROUP_SPL(uart0), + UNIPHIER_PINCTRL_GROUP_SPL(uart0b), + UNIPHIER_PINCTRL_GROUP_SPL(uart1), + UNIPHIER_PINCTRL_GROUP_SPL(uart2), + UNIPHIER_PINCTRL_GROUP_SPL(uart3), + UNIPHIER_PINCTRL_GROUP_SPL(uart3b), UNIPHIER_PINCTRL_GROUP(usb0), UNIPHIER_PINCTRL_GROUP(usb1), UNIPHIER_PINCTRL_GROUP(usb2), @@ -85,23 +85,23 @@ static const struct uniphier_pinctrl_group uniphier_pxs2_groups[] = { };
static const char * const uniphier_pxs2_functions[] = { - "emmc", - "i2c0", - "i2c1", - "i2c2", - "i2c3", - "i2c5", - "i2c6", - "nand", - "sd", - "uart0", - "uart1", - "uart2", - "uart3", - "usb0", - "usb1", - "usb2", - "usb3", + UNIPHIER_PINMUX_FUNCTION_SPL(emmc), + UNIPHIER_PINMUX_FUNCTION(i2c0), + UNIPHIER_PINMUX_FUNCTION(i2c1), + UNIPHIER_PINMUX_FUNCTION(i2c2), + UNIPHIER_PINMUX_FUNCTION(i2c3), + UNIPHIER_PINMUX_FUNCTION(i2c5), + UNIPHIER_PINMUX_FUNCTION(i2c6), + UNIPHIER_PINMUX_FUNCTION(nand), + UNIPHIER_PINMUX_FUNCTION(sd), + UNIPHIER_PINMUX_FUNCTION_SPL(uart0), + UNIPHIER_PINMUX_FUNCTION_SPL(uart1), + UNIPHIER_PINMUX_FUNCTION_SPL(uart2), + UNIPHIER_PINMUX_FUNCTION_SPL(uart3), + UNIPHIER_PINMUX_FUNCTION(usb0), + UNIPHIER_PINMUX_FUNCTION(usb1), + UNIPHIER_PINMUX_FUNCTION(usb2), + UNIPHIER_PINMUX_FUNCTION(usb3), };
static struct uniphier_pinctrl_socdata uniphier_pxs2_pinctrl_socdata = { diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c index 82fe33d..fe4d70d 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c @@ -72,8 +72,8 @@ static const unsigned usb2_pins[] = {114, 115}; static const int usb2_muxvals[] = {1, 1};
static const struct uniphier_pinctrl_group uniphier_sld8_groups[] = { - UNIPHIER_PINCTRL_GROUP(emmc), - UNIPHIER_PINCTRL_GROUP(emmc_dat8), + UNIPHIER_PINCTRL_GROUP_SPL(emmc), + UNIPHIER_PINCTRL_GROUP_SPL(emmc_dat8), UNIPHIER_PINCTRL_GROUP(i2c0), UNIPHIER_PINCTRL_GROUP(i2c1), UNIPHIER_PINCTRL_GROUP(i2c2), @@ -81,30 +81,30 @@ static const struct uniphier_pinctrl_group uniphier_sld8_groups[] = { UNIPHIER_PINCTRL_GROUP(nand), UNIPHIER_PINCTRL_GROUP(nand_cs1), UNIPHIER_PINCTRL_GROUP(sd), - UNIPHIER_PINCTRL_GROUP(uart0), - UNIPHIER_PINCTRL_GROUP(uart1), - UNIPHIER_PINCTRL_GROUP(uart2), - UNIPHIER_PINCTRL_GROUP(uart3), + UNIPHIER_PINCTRL_GROUP_SPL(uart0), + UNIPHIER_PINCTRL_GROUP_SPL(uart1), + UNIPHIER_PINCTRL_GROUP_SPL(uart2), + UNIPHIER_PINCTRL_GROUP_SPL(uart3), UNIPHIER_PINCTRL_GROUP(usb0), UNIPHIER_PINCTRL_GROUP(usb1), UNIPHIER_PINCTRL_GROUP(usb2), };
static const char * const uniphier_sld8_functions[] = { - "emmc", - "i2c0", - "i2c1", - "i2c2", - "i2c3", - "nand", - "sd", - "uart0", - "uart1", - "uart2", - "uart3", - "usb0", - "usb1", - "usb2", + UNIPHIER_PINMUX_FUNCTION_SPL(emmc), + UNIPHIER_PINMUX_FUNCTION(i2c0), + UNIPHIER_PINMUX_FUNCTION(i2c1), + UNIPHIER_PINMUX_FUNCTION(i2c2), + UNIPHIER_PINMUX_FUNCTION(i2c3), + UNIPHIER_PINMUX_FUNCTION(nand), + UNIPHIER_PINMUX_FUNCTION(sd), + UNIPHIER_PINMUX_FUNCTION_SPL(uart0), + UNIPHIER_PINMUX_FUNCTION_SPL(uart1), + UNIPHIER_PINMUX_FUNCTION_SPL(uart2), + UNIPHIER_PINMUX_FUNCTION_SPL(uart3), + UNIPHIER_PINMUX_FUNCTION(usb0), + UNIPHIER_PINMUX_FUNCTION(usb1), + UNIPHIER_PINMUX_FUNCTION(usb2), };
static struct uniphier_pinctrl_socdata uniphier_sld8_pinctrl_socdata = { diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier.h b/drivers/pinctrl/uniphier/pinctrl-uniphier.h index ff0a368..4bb8932 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier.h +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier.h @@ -80,7 +80,7 @@ struct uniphier_pinctrl_socdata { .data = UNIPHIER_PIN_ATTR_PACKED(b), \ }
-#define UNIPHIER_PINCTRL_GROUP(grp) \ +#define __UNIPHIER_PINCTRL_GROUP(grp) \ { \ .name = #grp, \ .pins = grp##_pins, \ @@ -90,6 +90,19 @@ struct uniphier_pinctrl_socdata { ARRAY_SIZE(grp##_muxvals)), \ }
+#define __UNIPHIER_PINMUX_FUNCTION(func) #func + +#ifdef CONFIG_SPL_BUILD +#define UNIPHIER_PINCTRL_GROUP(grp) { .name = NULL } +#define UNIPHIER_PINMUX_FUNCTION(func) NULL +#else +#define UNIPHIER_PINCTRL_GROUP(grp) __UNIPHIER_PINCTRL_GROUP(grp) +#define UNIPHIER_PINMUX_FUNCTION(func) __UNIPHIER_PINMUX_FUNCTION(func) +#endif + +#define UNIPHIER_PINCTRL_GROUP_SPL(grp) __UNIPHIER_PINCTRL_GROUP(grp) +#define UNIPHIER_PINMUX_FUNCTION_SPL(func) __UNIPHIER_PINMUX_FUNCTION(func) + /** * struct uniphier_pinctrl_priv - private data for UniPhier pinctrl driver *
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c | 5 +++++ drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c | 11 +++++++++++ drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c | 12 ++++++++++++ drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c | 12 ++++++++++++ drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c | 23 +++++++++++++++++++++++ drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c | 19 +++++++++++++++++++ drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c | 12 ++++++++++++ 7 files changed, 94 insertions(+)
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c index e2bd9ae..e95870f 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c @@ -14,6 +14,9 @@ static const unsigned emmc_pins[] = {18, 19, 20, 21, 22, 23, 24, 25}; static const int emmc_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0}; static const unsigned emmc_dat8_pins[] = {26, 27, 28, 29}; static const int emmc_dat8_muxvals[] = {0, 0, 0, 0}; +static const unsigned ether_rmii_pins[] = {6, 7, 8, 9, 10, 11, 12, 13, 14, 15, + 16, 17}; +static const int ether_rmii_muxvals[] = {4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4}; static const unsigned i2c0_pins[] = {63, 64}; static const int i2c0_muxvals[] = {0, 0}; static const unsigned i2c1_pins[] = {65, 66}; @@ -43,6 +46,7 @@ static const int usb2_muxvals[] = {0, 0}; static const struct uniphier_pinctrl_group uniphier_ld11_groups[] = { UNIPHIER_PINCTRL_GROUP(emmc), UNIPHIER_PINCTRL_GROUP(emmc_dat8), + UNIPHIER_PINCTRL_GROUP(ether_rmii), UNIPHIER_PINCTRL_GROUP(i2c0), UNIPHIER_PINCTRL_GROUP(i2c1), UNIPHIER_PINCTRL_GROUP(i2c3), @@ -59,6 +63,7 @@ static const struct uniphier_pinctrl_group uniphier_ld11_groups[] = {
static const char * const uniphier_ld11_functions[] = { UNIPHIER_PINMUX_FUNCTION(emmc), + UNIPHIER_PINMUX_FUNCTION(ether_rmii), UNIPHIER_PINMUX_FUNCTION(i2c0), UNIPHIER_PINMUX_FUNCTION(i2c1), UNIPHIER_PINMUX_FUNCTION(i2c3), diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c index 15ee469..e903196 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c @@ -14,6 +14,13 @@ static const unsigned emmc_pins[] = {18, 19, 20, 21, 22, 23, 24, 25}; static const int emmc_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0}; static const unsigned emmc_dat8_pins[] = {26, 27, 28, 29}; static const int emmc_dat8_muxvals[] = {0, 0, 0, 0}; +static const unsigned ether_rgmii_pins[] = {30, 31, 32, 33, 34, 35, 36, 37, 38, + 39, 40, 41, 42, 43, 44, 45}; +static const int ether_rgmii_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0}; +static const unsigned ether_rmii_pins[] = {30, 31, 32, 33, 34, 35, 36, 37, 39, + 41, 42, 45}; +static const int ether_rmii_muxvals[] = {1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1}; static const unsigned i2c0_pins[] = {63, 64}; static const int i2c0_muxvals[] = {0, 0}; static const unsigned i2c1_pins[] = {65, 66}; @@ -47,6 +54,8 @@ static const int usb3_muxvals[] = {0, 0}; static const struct uniphier_pinctrl_group uniphier_ld20_groups[] = { UNIPHIER_PINCTRL_GROUP(emmc), UNIPHIER_PINCTRL_GROUP(emmc_dat8), + UNIPHIER_PINCTRL_GROUP(ether_rgmii), + UNIPHIER_PINCTRL_GROUP(ether_rmii), UNIPHIER_PINCTRL_GROUP(i2c0), UNIPHIER_PINCTRL_GROUP(i2c1), UNIPHIER_PINCTRL_GROUP(i2c3), @@ -65,6 +74,8 @@ static const struct uniphier_pinctrl_group uniphier_ld20_groups[] = {
static const char * const uniphier_ld20_functions[] = { UNIPHIER_PINMUX_FUNCTION(emmc), + UNIPHIER_PINMUX_FUNCTION(ether_rgmii), + UNIPHIER_PINMUX_FUNCTION(ether_rmii), UNIPHIER_PINMUX_FUNCTION(i2c0), UNIPHIER_PINMUX_FUNCTION(i2c1), UNIPHIER_PINMUX_FUNCTION(i2c3), diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c index 56d9d5b..dbb9499 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c @@ -27,6 +27,14 @@ static const unsigned emmc_pins[] = {21, 22, 23, 24, 25, 26, 27}; static const int emmc_muxvals[] = {0, 1, 1, 1, 1, 1, 1}; static const unsigned emmc_dat8_pins[] = {28, 29, 30, 31}; static const int emmc_dat8_muxvals[] = {1, 1, 1, 1}; +static const unsigned ether_mii_pins[] = {32, 33, 34, 35, 36, 37, 38, 39, 40, + 41, 42, 43, 136, 137, 138, 139, 140, + 141, 142}; +static const int ether_mii_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + 4, 4, 4, 4, 4, 4, 4}; +static const unsigned ether_rmii_pins[] = {32, 33, 34, 35, 36, 37, 38, 39, 40, + 41, 42, 43}; +static const int ether_rmii_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}; static const unsigned i2c0_pins[] = {102, 103}; static const int i2c0_muxvals[] = {0, 0}; static const unsigned i2c1_pins[] = {104, 105}; @@ -64,6 +72,8 @@ static const int usb2b_muxvals[] = {23, 23}; static const struct uniphier_pinctrl_group uniphier_ld4_groups[] = { UNIPHIER_PINCTRL_GROUP_SPL(emmc), UNIPHIER_PINCTRL_GROUP_SPL(emmc_dat8), + UNIPHIER_PINCTRL_GROUP(ether_mii), + UNIPHIER_PINCTRL_GROUP(ether_rmii), UNIPHIER_PINCTRL_GROUP(i2c0), UNIPHIER_PINCTRL_GROUP(i2c1), UNIPHIER_PINCTRL_GROUP(i2c2), @@ -84,6 +94,8 @@ static const struct uniphier_pinctrl_group uniphier_ld4_groups[] = {
static const char * const uniphier_ld4_functions[] = { UNIPHIER_PINMUX_FUNCTION_SPL(emmc), + UNIPHIER_PINMUX_FUNCTION(ether_mii), + UNIPHIER_PINMUX_FUNCTION(ether_rmii), UNIPHIER_PINMUX_FUNCTION(i2c0), UNIPHIER_PINMUX_FUNCTION(i2c1), UNIPHIER_PINMUX_FUNCTION(i2c2), diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c index dd4a28c..8b40801 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c @@ -24,6 +24,14 @@ static const unsigned emmc_pins[] = {36, 37, 38, 39, 40, 41, 42}; static const int emmc_muxvals[] = {1, 1, 1, 1, 1, 1, 1}; static const unsigned emmc_dat8_pins[] = {43, 44, 45, 46}; static const int emmc_dat8_muxvals[] = {1, 1, 1, 1}; +static const unsigned ether_rgmii_pins[] = {143, 144, 145, 146, 147, 148, 149, + 150, 151, 152, 153, 154, 155, 156, + 157, 158}; +static const int ether_rgmii_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0}; +static const unsigned ether_rmii_pins[] = {143, 144, 145, 146, 147, 148, 149, + 150, 152, 154, 155, 158}; +static const int ether_rmii_muxvals[] = {0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1}; static const unsigned i2c0_pins[] = {109, 110}; static const int i2c0_muxvals[] = {0, 0}; static const unsigned i2c1_pins[] = {111, 112}; @@ -63,6 +71,8 @@ static const int usb3_muxvals[] = {0, 0}; static const struct uniphier_pinctrl_group uniphier_ld6b_groups[] = { UNIPHIER_PINCTRL_GROUP_SPL(emmc), UNIPHIER_PINCTRL_GROUP_SPL(emmc_dat8), + UNIPHIER_PINCTRL_GROUP(ether_rgmii), + UNIPHIER_PINCTRL_GROUP(ether_rmii), UNIPHIER_PINCTRL_GROUP(i2c0), UNIPHIER_PINCTRL_GROUP(i2c1), UNIPHIER_PINCTRL_GROUP(i2c2), @@ -84,6 +94,8 @@ static const struct uniphier_pinctrl_group uniphier_ld6b_groups[] = {
static const char * const uniphier_ld6b_functions[] = { UNIPHIER_PINMUX_FUNCTION_SPL(emmc), + UNIPHIER_PINMUX_FUNCTION(ether_rgmii), + UNIPHIER_PINMUX_FUNCTION(ether_rmii), UNIPHIER_PINMUX_FUNCTION(i2c0), UNIPHIER_PINMUX_FUNCTION(i2c1), UNIPHIER_PINMUX_FUNCTION(i2c2), diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c index f87a2c6..dace726 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c @@ -16,6 +16,22 @@ static const unsigned emmc_pins[] = {40, 41, 42, 43, 51, 52, 53}; static const int emmc_muxvals[] = {1, 1, 1, 1, 1, 1, 1}; static const unsigned emmc_dat8_pins[] = {44, 45, 46, 47}; static const int emmc_dat8_muxvals[] = {1, 1, 1, 1}; +static const unsigned ether_mii_pins[] = {160, 161, 162, 163, 164, 165, 166, + 167, 168, 169, 170, 171, 172, 173, + 174, 175, 176, 177, 178, 179}; +static const int ether_mii_muxvals[] = {1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0, 0, 0}; +static const unsigned ether_rgmii_pins[] = {160, 161, 162, 163, 164, 165, 167, + 168, 169, 170, 171, 172, 176, 177, + 178, 179}; +static const int ether_rgmii_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0}; +static const unsigned ether_rmii_pins[] = {160, 161, 162, 165, 168, 169, 172, + 173, 176, 177, 178, 179}; +static const int ether_rmii_muxvals[] = {1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}; +static const unsigned ether_rmiib_pins[] = {161, 162, 165, 167, 168, 169, 172, + 173, 176, 177, 178, 179}; +static const int ether_rmiib_muxvals[] = {0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0}; static const unsigned i2c0_pins[] = {142, 143}; static const int i2c0_muxvals[] = {0, 0}; static const unsigned i2c1_pins[] = {144, 145}; @@ -56,6 +72,10 @@ static const int usb3_muxvals[] = {0, 0}; static const struct uniphier_pinctrl_group uniphier_pro4_groups[] = { UNIPHIER_PINCTRL_GROUP_SPL(emmc), UNIPHIER_PINCTRL_GROUP_SPL(emmc_dat8), + UNIPHIER_PINCTRL_GROUP(ether_mii), + UNIPHIER_PINCTRL_GROUP(ether_rgmii), + UNIPHIER_PINCTRL_GROUP(ether_rmii), + UNIPHIER_PINCTRL_GROUP(ether_rmiib), UNIPHIER_PINCTRL_GROUP(i2c0), UNIPHIER_PINCTRL_GROUP(i2c1), UNIPHIER_PINCTRL_GROUP(i2c2), @@ -77,6 +97,9 @@ static const struct uniphier_pinctrl_group uniphier_pro4_groups[] = {
static const char * const uniphier_pro4_functions[] = { UNIPHIER_PINMUX_FUNCTION_SPL(emmc), + UNIPHIER_PINMUX_FUNCTION(ether_mii), + UNIPHIER_PINMUX_FUNCTION(ether_rgmii), + UNIPHIER_PINMUX_FUNCTION(ether_rmii), UNIPHIER_PINMUX_FUNCTION(i2c0), UNIPHIER_PINMUX_FUNCTION(i2c1), UNIPHIER_PINMUX_FUNCTION(i2c2), diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c index 70fb168..9223eeb 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c @@ -20,6 +20,19 @@ static const unsigned emmc_pins[] = {36, 37, 38, 39, 40, 41, 42}; static const int emmc_muxvals[] = {9, 9, 9, 9, 9, 9, 9}; static const unsigned emmc_dat8_pins[] = {43, 44, 45, 46}; static const int emmc_dat8_muxvals[] = {9, 9, 9, 9}; +static const unsigned ether_mii_pins[] = {143, 144, 145, 146, 147, 148, 149, + 150, 151, 152, 153, 154, 155, 156, + 158, 159, 199, 200, 201, 202}; +static const int ether_mii_muxvals[] = {8, 8, 8, 8, 10, 10, 10, 10, 10, 10, 10, + 10, 10, 10, 10, 10, 12, 12, 12, 12}; +static const unsigned ether_rgmii_pins[] = {143, 144, 145, 146, 147, 148, 149, + 150, 151, 152, 153, 154, 155, 156, + 157, 158}; +static const int ether_rgmii_muxvals[] = {8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, + 8, 8, 8, 8}; +static const unsigned ether_rmii_pins[] = {143, 144, 145, 146, 147, 148, 149, + 150, 152, 154, 155, 158}; +static const int ether_rmii_muxvals[] = {8, 8, 8, 8, 9, 9, 9, 9, 9, 9, 9, 9}; static const unsigned i2c0_pins[] = {109, 110}; static const int i2c0_muxvals[] = {8, 8}; static const unsigned i2c1_pins[] = {111, 112}; @@ -63,6 +76,9 @@ static const int usb3_muxvals[] = {8, 8}; static const struct uniphier_pinctrl_group uniphier_pxs2_groups[] = { UNIPHIER_PINCTRL_GROUP_SPL(emmc), UNIPHIER_PINCTRL_GROUP_SPL(emmc_dat8), + UNIPHIER_PINCTRL_GROUP(ether_mii), + UNIPHIER_PINCTRL_GROUP(ether_rgmii), + UNIPHIER_PINCTRL_GROUP(ether_rmii), UNIPHIER_PINCTRL_GROUP(i2c0), UNIPHIER_PINCTRL_GROUP(i2c1), UNIPHIER_PINCTRL_GROUP(i2c2), @@ -86,6 +102,9 @@ static const struct uniphier_pinctrl_group uniphier_pxs2_groups[] = {
static const char * const uniphier_pxs2_functions[] = { UNIPHIER_PINMUX_FUNCTION_SPL(emmc), + UNIPHIER_PINMUX_FUNCTION(ether_mii), + UNIPHIER_PINMUX_FUNCTION(ether_rgmii), + UNIPHIER_PINMUX_FUNCTION(ether_rmii), UNIPHIER_PINMUX_FUNCTION(i2c0), UNIPHIER_PINMUX_FUNCTION(i2c1), UNIPHIER_PINMUX_FUNCTION(i2c2), diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c index fe4d70d..cee0eb1 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c @@ -41,6 +41,14 @@ static const unsigned emmc_pins[] = {21, 22, 23, 24, 25, 26, 27}; static const int emmc_muxvals[] = {1, 1, 1, 1, 1, 1, 1}; static const unsigned emmc_dat8_pins[] = {28, 29, 30, 31}; static const int emmc_dat8_muxvals[] = {1, 1, 1, 1}; +static const unsigned ether_mii_pins[] = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 13, 14, + 61, 63, 64, 65, 66, 67, 68}; +static const int ether_mii_muxvals[] = {13, 13, 13, 13, 13, 13, 13, 13, 13, 13, + 13, 13, 27, 27, 27, 27, 27, 27, 27}; +static const unsigned ether_rmii_pins[] = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 13, + 14}; +static const int ether_rmii_muxvals[] = {13, 13, 13, 13, 13, 13, 13, 13, 13, + 13, 13, 13}; static const unsigned i2c0_pins[] = {102, 103}; static const int i2c0_muxvals[] = {0, 0}; static const unsigned i2c1_pins[] = {104, 105}; @@ -74,6 +82,8 @@ static const int usb2_muxvals[] = {1, 1}; static const struct uniphier_pinctrl_group uniphier_sld8_groups[] = { UNIPHIER_PINCTRL_GROUP_SPL(emmc), UNIPHIER_PINCTRL_GROUP_SPL(emmc_dat8), + UNIPHIER_PINCTRL_GROUP(ether_mii), + UNIPHIER_PINCTRL_GROUP(ether_rmii), UNIPHIER_PINCTRL_GROUP(i2c0), UNIPHIER_PINCTRL_GROUP(i2c1), UNIPHIER_PINCTRL_GROUP(i2c2), @@ -92,6 +102,8 @@ static const struct uniphier_pinctrl_group uniphier_sld8_groups[] = {
static const char * const uniphier_sld8_functions[] = { UNIPHIER_PINMUX_FUNCTION_SPL(emmc), + UNIPHIER_PINMUX_FUNCTION(ether_mii), + UNIPHIER_PINMUX_FUNCTION(ether_rmii), UNIPHIER_PINMUX_FUNCTION(i2c0), UNIPHIER_PINMUX_FUNCTION(i2c1), UNIPHIER_PINMUX_FUNCTION(i2c2),
The AIDET (ARM Interrupt Detector Add-on Circuit) is a kind of syscon block related with the interrupt controller.
arch/arm/dts/uniphier-ph1-ld11.dtsi | 5 +++++ arch/arm/dts/uniphier-ph1-ld20.dtsi | 5 +++++ arch/arm/dts/uniphier-ph1-ld4.dtsi | 5 +++++ arch/arm/dts/uniphier-ph1-pro4.dtsi | 5 +++++ arch/arm/dts/uniphier-ph1-pro5.dtsi | 5 +++++ arch/arm/dts/uniphier-ph1-sld3.dtsi | 5 +++++ arch/arm/dts/uniphier-ph1-sld8.dtsi | 5 +++++ arch/arm/dts/uniphier-proxstream2.dtsi | 5 +++++ 8 files changed, 40 insertions(+)
diff --git a/arch/arm/dts/uniphier-ph1-ld11.dtsi b/arch/arm/dts/uniphier-ph1-ld11.dtsi index 8901a79..ffe04f5 100644 --- a/arch/arm/dts/uniphier-ph1-ld11.dtsi +++ b/arch/arm/dts/uniphier-ph1-ld11.dtsi @@ -260,6 +260,11 @@ }; };
+ aidet@5fc20000 { + compatible = "simple-mfd", "syscon"; + reg = <0x5fc20000 0x200>; + }; + gic: interrupt-controller@5fe00000 { compatible = "arm,gic-v3"; reg = <0x5fe00000 0x10000>, /* GICD */ diff --git a/arch/arm/dts/uniphier-ph1-ld20.dtsi b/arch/arm/dts/uniphier-ph1-ld20.dtsi index 434890d..3d36a26 100644 --- a/arch/arm/dts/uniphier-ph1-ld20.dtsi +++ b/arch/arm/dts/uniphier-ph1-ld20.dtsi @@ -264,6 +264,11 @@ }; };
+ aidet@5fc20000 { + compatible = "simple-mfd", "syscon"; + reg = <0x5fc20000 0x200>; + }; + gic: interrupt-controller@5fe00000 { compatible = "arm,gic-v3"; reg = <0x5fe00000 0x10000>, /* GICD */ diff --git a/arch/arm/dts/uniphier-ph1-ld4.dtsi b/arch/arm/dts/uniphier-ph1-ld4.dtsi index 5629b7d..07f315a 100644 --- a/arch/arm/dts/uniphier-ph1-ld4.dtsi +++ b/arch/arm/dts/uniphier-ph1-ld4.dtsi @@ -274,6 +274,11 @@ pinctrl-0 = <&pinctrl_usb2>; clocks = <&mio 5>, <&mio 6>; }; + + aidet@61830000 { + compatible = "simple-mfd", "syscon"; + reg = <0x61830000 0x200>; + }; };
&refclk { diff --git a/arch/arm/dts/uniphier-ph1-pro4.dtsi b/arch/arm/dts/uniphier-ph1-pro4.dtsi index 080fced..e0b28b8 100644 --- a/arch/arm/dts/uniphier-ph1-pro4.dtsi +++ b/arch/arm/dts/uniphier-ph1-pro4.dtsi @@ -400,6 +400,11 @@ clocks = <&mio 4>, <&mio 6>; };
+ aidet@5fc20000 { + compatible = "simple-mfd", "syscon"; + reg = <0x5fc20000 0x200>; + }; + usb0: usb@65a00000 { compatible = "socionext,uniphier-xhci", "generic-xhci"; status = "disabled"; diff --git a/arch/arm/dts/uniphier-ph1-pro5.dtsi b/arch/arm/dts/uniphier-ph1-pro5.dtsi index 5b7f6e8..05f961f 100644 --- a/arch/arm/dts/uniphier-ph1-pro5.dtsi +++ b/arch/arm/dts/uniphier-ph1-pro5.dtsi @@ -355,6 +355,11 @@ clock-frequency = <400000>; };
+ aidet@5fc20000 { + compatible = "simple-mfd", "syscon"; + reg = <0x5fc20000 0x200>; + }; + emmc: sdhc@68400000 { compatible = "socionext,uniphier-sdhc"; status = "disabled"; diff --git a/arch/arm/dts/uniphier-ph1-sld3.dtsi b/arch/arm/dts/uniphier-ph1-sld3.dtsi index 789713d..c3adaf1 100644 --- a/arch/arm/dts/uniphier-ph1-sld3.dtsi +++ b/arch/arm/dts/uniphier-ph1-sld3.dtsi @@ -349,6 +349,11 @@ clocks = <&mio 7>, <&mio 6>; };
+ aidet@f1830000 { + compatible = "simple-mfd", "syscon"; + reg = <0xf1830000 0x200>; + }; + sysctrl: sysctrl@f1840000 { compatible = "socionext,ph1-sld3-sysctrl"; reg = <0xf1840000 0x4000>; diff --git a/arch/arm/dts/uniphier-ph1-sld8.dtsi b/arch/arm/dts/uniphier-ph1-sld8.dtsi index f07a1d1..e0376a1 100644 --- a/arch/arm/dts/uniphier-ph1-sld8.dtsi +++ b/arch/arm/dts/uniphier-ph1-sld8.dtsi @@ -274,6 +274,11 @@ pinctrl-0 = <&pinctrl_usb2>; clocks = <&mio 5>, <&mio 6>; }; + + aidet@61830000 { + compatible = "simple-mfd", "syscon"; + reg = <0x61830000 0x200>; + }; };
&refclk { diff --git a/arch/arm/dts/uniphier-proxstream2.dtsi b/arch/arm/dts/uniphier-proxstream2.dtsi index 0a8c049..23a6bfa 100644 --- a/arch/arm/dts/uniphier-proxstream2.dtsi +++ b/arch/arm/dts/uniphier-proxstream2.dtsi @@ -383,6 +383,11 @@ bus-width = <4>; };
I will carry this work-around until it is cared in the kernel. This looks up the AIDET node and sets up a register to handle active low interrupt signals.
arch/arm/mach-uniphier/board_early_init_f.c | 39 +++++++++++++++++++++++++++ arch/arm/mach-uniphier/pinctrl/pinctrl-ld20.c | 5 ++++ 2 files changed, 44 insertions(+)
diff --git a/arch/arm/mach-uniphier/board_early_init_f.c b/arch/arm/mach-uniphier/board_early_init_f.c index f853701..d35d38d 100644 --- a/arch/arm/mach-uniphier/board_early_init_f.c +++ b/arch/arm/mach-uniphier/board_early_init_f.c @@ -4,10 +4,47 @@ * SPDX-License-Identifier: GPL-2.0+ */
+#include <common.h> +#include <libfdt.h> +#include <linux/io.h> + #include "init.h" #include "micro-support-card.h" #include "soc-info.h"
+DECLARE_GLOBAL_DATA_PTR; + +static void uniphier_setup_xirq(void) +{ + const void *fdt = gd->fdt_blob; + int soc_node, aidet_node; + const u32 *val; + unsigned long aidet_base; + u32 tmp; + + soc_node = fdt_path_offset(fdt, "/soc"); + if (soc_node < 0) + return; + + aidet_node = fdt_subnode_offset_namelen(fdt, soc_node, "aidet", 5); + if (aidet_node < 0) + return; + + val = fdt_getprop(fdt, aidet_node, "reg", NULL); + if (!val) + return; + + aidet_base = fdt32_to_cpu(*val); + + tmp = readl(aidet_base + 8); /* AIDET DETCONFR2 */ + tmp |= 0x00ff0000; /* Set XIRQ0-7 low active */ + writel(tmp, aidet_base + 8); + + tmp = readl(0x55000090); /* IRQCTL */ + tmp |= 0x000000ff; + writel(tmp, 0x55000090); +} + int board_early_init_f(void) { led_puts("U0"); @@ -81,6 +118,8 @@ int board_early_init_f(void) break; }
+ uniphier_setup_xirq(); + led_puts("U2");
return 0; diff --git a/arch/arm/mach-uniphier/pinctrl/pinctrl-ld20.c b/arch/arm/mach-uniphier/pinctrl/pinctrl-ld20.c index 6066b16..645b901 100644 --- a/arch/arm/mach-uniphier/pinctrl/pinctrl-ld20.c +++ b/arch/arm/mach-uniphier/pinctrl/pinctrl-ld20.c @@ -43,4 +43,9 @@ void uniphier_ld20_pin_init(void) sg_set_pinsel(53, 0, 8, 4); /* USB3OD -> USB3OD */ sg_set_iectrl_range(46, 53); #endif + + sg_set_pinsel(149, 14, 8, 4); /* XIRQ0 -> XIRQ0 */ + sg_set_iectrl(149); + sg_set_pinsel(153, 14, 8, 4); /* XIRQ4 -> XIRQ4 */ + sg_set_iectrl(153); }
2016-06-29 19:38 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Masahiro Yamada (11): pinctrl: uniphier: remove wrong pin-mux functions for ProXstream2 pinctrl: uniphier: fix NAND pin-mux setting for PH1-LD11/LD20 pinctrl: uniphier: remove unneeded pin group nand_cs1 ARM: dts: uniphier: sync Device Trees with upstream Linux pinctrl: uniphier: allow to have pinctrl node under syscon node pinctrl: uniphier: split pinctrl driver for PH1-LD11 and PH1-LD20 pinctrl: uniphier: support pin configuration for dedicated pins pinctrl: uniphier: avoid building unneeded pin-mux tables for SPL pinctrl: uniphier: add ethernet pin-mux settings ARM: dts: uniphier: add AIDET nodes ARM: uniphier: add external IRQ settings
Applied to u-boot-uniphier/master.
Masahiro Yamada
