[PATCH] dt-bindings: mtd: partitions: add UBI binding
UBI is often used on embedded devices to store UBI volumes with device configuration / calibration data. Such volumes may need to be documented and referenced for proper boot & setup.
Some examples: 1. U-Boot environment variables 2. Device calibration data 3. Default setup (e.g. initial password)
Signed-off-by: Rafał Miłecki rafal@milecki.pl --- .../bindings/mtd/partitions/ubi.yaml | 67 +++++++++++++++++++ 1 file changed, 67 insertions(+) create mode 100644 Documentation/devicetree/bindings/mtd/partitions/ubi.yaml
diff --git a/Documentation/devicetree/bindings/mtd/partitions/ubi.yaml b/Documentation/devicetree/bindings/mtd/partitions/ubi.yaml new file mode 100644 index 000000000000..cd081f06d4cb --- /dev/null +++ b/Documentation/devicetree/bindings/mtd/partitions/ubi.yaml @@ -0,0 +1,67 @@ +# SPDX-License-Identifier: GPL-2.0-only OR BSD-2-Clause +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/mtd/partitions/ubi.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: UBI (Unsorted Block Images) device + +description: | + UBI is a layer providing logical volumes (consisting of logical blocks) on top + of raw flash devices. It deals with low-level flash issues (bit-flips, bad + physical eraseblocks, wearing) providing a reliable data storage. + + UBI device is built and stored in a single flash partition. + + Some (usually embedded) devices use UBI volumes of specific names or indexes + to store setup / configuration data. This binding allows describing such + volumes so they can be identified and referenced by consumers. + +maintainers: + - Rafał Miłecki rafal@milecki.pl + +allOf: + - $ref: partition.yaml# + +properties: + compatible: + const: ubi + +patternProperties: + "^volume-[0-9a-f]+$": + type: object + description: UBI volume + properties: + volume-name: + $ref: /schemas/types.yaml#/definitions/string + volume-id: + $ref: /schemas/types.yaml#/definitions/uint32 + anyOf: + - required: + - volume-name + - required: + - volume-id + +unevaluatedProperties: false + +examples: + - | + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + compatible = "ubi"; + reg = <0x0000000 0x1000000>; + label = "filesystem"; + + env: volume-0 { + volume-name = "u-boot-env"; + }; + + calibration: volume-1 { + volume-id = <99>; + }; + }; + };
Some examples:
- U-Boot environment variables
- Device calibration data
- Default setup (e.g. initial password)
+description: |
- UBI is a layer providing logical volumes (consisting of logical blocks) on top
- of raw flash devices. It deals with low-level flash issues (bit-flips, bad
- physical eraseblocks, wearing) providing a reliable data storage.
- UBI device is built and stored in a single flash partition.
- Some (usually embedded) devices use UBI volumes of specific names or indexes
- to store setup / configuration data. This binding allows describing such
- volumes so they can be identified and referenced by consumers.
+maintainers:
+allOf:
+properties:
- compatible:
- const: ubi
+patternProperties:
- "^volume-[0-9a-f]+$":
- type: object
- description: UBI volume
- properties:
volume-name:
volume-id:
- anyOf:
- required:
- volume-name
- required:
- volume-id
+examples:
- partitions {
#size-cells = <1>;
partition@0 {
compatible = "ubi";
env: volume-0 {
Why not do 'compatible = "u-boot,env";' to align with normal partitions?
Or 'label'?
We have enough ways to identify things, I don't think we need another.
Are 0 and 1 meaningful or just made up indexing?
volume-id = <99>;
-- 2.34.1
Some examples:
+description: |
+maintainers:
+allOf:
+properties:
- compatible:
- const: ubi
+patternProperties:
- type: object
- properties:
volume-name:
volume-id:
- anyOf:
- required:
- volume-name
- required:
- volume-id
+examples:
- partitions {
#size-cells = <1>;
partition@0 {
compatible = "ubi";
env: volume-0 {
I mean to reserve "compatible" for describing UBI volume content.
If I manage to get [PATCH V3] dt-bindings: nvmem: add U-Boot environment variables binding https://patchwork.ozlabs.org/project/devicetree-bindings/patch/2022022813125... accepted, it'll allow me to later work on something like:
env: volume-0 { compatible = "u-boot,env"; volume-name = "u-boot-env"; };
(I believe) I'll need (in the final shape) two properties: 1. One for describing UBI volume ("compatible") 2. One for identifying UBI volume ("volume-name" / "volume-id")
It's similar design to the "compatible" vs. "reg" in IO hw blocks.
Or 'label'?
I could replace "volume-name" with "label" but someone once told me that:
'label' is supposed to correspond to a sticker on a port or something human identifiable
;) https://patchwork.ozlabs.org/comment/2812214/
So I don't want to abuse "label" here.
Made up indexing. I need unique nodenames but @[0-9a-f] doesn't appply here.
volume-id = <99>;
-- 2.34.1
Hi Rob, could you re-review my patch as I provided answers (see below), please?
Some examples:
- One for describing UBI volume ("compatible")
- One for identifying UBI volume ("volume-name" / "volume-id")
Or 'label'?
2.34.1
Some examples:
+description: |
+maintainers:
+allOf:
+properties:
- compatible:
- const: ubi
+patternProperties:
- type: object
- properties:
volume-name:
volume-id:
- anyOf:
- required:
- volume-name
- required:
- volume-id
+examples:
- partitions {
#size-cells = <1>;
partition@0 {
compatible = "ubi";
env: volume-0 {
That's what it is vs. what instance. You need a better example if that's what you are trying to show. I guess if you were doing A/B updates you'd have something like 'volume-name = "u-boot-env-b"'?
Or 'label'?
Yes, it could be a human wanting to identify it. The question is whether s/w does too.
The other aspect is there's also filesystem/partition label's. Those are generally set by humans and opaque to the s/w. If the use is aligned with how those labels are used, then I'd be okay with the DT 'label' here.
Maybe use "volume-$volumename" or "volume-$volumeid" instead?
Rob
Some examples:
This is very useful and can replace the downstream hacks we are currently using for this purpose in OpenWrt.
Reviewed-by: Daniel Golle daniel@makrotopia.org
+description: |
+maintainers:
+allOf:
+properties:
- compatible:
- const: ubi
+patternProperties:
- type: object
- properties:
volume-name:
volume-id:
- anyOf:
- required:
- volume-name
- required:
- volume-id
+examples:
- partitions {
#size-cells = <1>;
partition@0 {
compatible = "ubi";
env: volume-0 {
volume-id = <99>;
-- 2.34.1
Daniel Golle
Rafał Miłecki
Rob Herring
