[PATCH 1/1] imx: mx7: clock: use correct format strings
Use %u and not %d for unsigned values. Print kHz and not khz.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- arch/arm/mach-imx/mx7/clock.c | 22 +++++++++++----------- 1 file changed, 11 insertions(+), 11 deletions(-)
diff --git a/arch/arm/mach-imx/mx7/clock.c b/arch/arm/mach-imx/mx7/clock.c index aba9461d92..6a1bad855e 100644 --- a/arch/arm/mach-imx/mx7/clock.c +++ b/arch/arm/mach-imx/mx7/clock.c @@ -916,7 +916,7 @@ void mxs_set_lcdclk(uint32_t base_addr, uint32_t freq) }
if (5 == i) { - printf("Fail to set rate to %dkhz", freq); + printf("Fail to set rate to %u kHz", freq); return; } } @@ -936,7 +936,7 @@ void mxs_set_lcdclk(uint32_t base_addr, uint32_t freq) }
if (best == 0) { - printf("Fail to set rate to %dkhz", freq); + printf("Fail to set rate to %u kHz", freq); return; }
@@ -1115,17 +1115,17 @@ int do_mx7_showclocks(struct cmd_tbl *cmdtp, int flag, int argc,
printf("\n");
- printf("IPG %8d kHz\n", mxc_get_clock(MXC_IPG_CLK) / 1000); - printf("UART %8d kHz\n", mxc_get_clock(MXC_UART_CLK) / 1000); + printf("IPG %8u kHz\n", mxc_get_clock(MXC_IPG_CLK) / 1000); + printf("UART %8u kHz\n", mxc_get_clock(MXC_UART_CLK) / 1000); #ifdef CONFIG_MXC_SPI - printf("CSPI %8d kHz\n", mxc_get_clock(MXC_CSPI_CLK) / 1000); + printf("CSPI %8u kHz\n", mxc_get_clock(MXC_CSPI_CLK) / 1000); #endif - printf("AHB %8d kHz\n", mxc_get_clock(MXC_AHB_CLK) / 1000); - printf("AXI %8d kHz\n", mxc_get_clock(MXC_AXI_CLK) / 1000); - printf("DDR %8d kHz\n", mxc_get_clock(MXC_DDR_CLK) / 1000); - printf("USDHC1 %8d kHz\n", mxc_get_clock(MXC_ESDHC_CLK) / 1000); - printf("USDHC2 %8d kHz\n", mxc_get_clock(MXC_ESDHC2_CLK) / 1000); - printf("USDHC3 %8d kHz\n", mxc_get_clock(MXC_ESDHC3_CLK) / 1000); + printf("AHB %8u kHz\n", mxc_get_clock(MXC_AHB_CLK) / 1000); + printf("AXI %8u kHz\n", mxc_get_clock(MXC_AXI_CLK) / 1000); + printf("DDR %8u kHz\n", mxc_get_clock(MXC_DDR_CLK) / 1000); + printf("USDHC1 %8u kHz\n", mxc_get_clock(MXC_ESDHC_CLK) / 1000); + printf("USDHC2 %8u kHz\n", mxc_get_clock(MXC_ESDHC2_CLK) / 1000); + printf("USDHC3 %8u kHz\n", mxc_get_clock(MXC_ESDHC3_CLK) / 1000);
return 0; } -- 2.29.2
Subject: [PATCH 1/1] imx: mx7: clock: use correct format strings
Reviewed-by: Peng Fan peng.fan@nxp.com
if (5 == i) {
} }printf("Fail to set rate to %u kHz", freq); return;
if (best == 0) {
return; }printf("Fail to set rate to %u kHz", freq);
printf("\n");
1000);
- printf("IPG %8u kHz\n", mxc_get_clock(MXC_IPG_CLK) / 1000);
- printf("UART %8u kHz\n", mxc_get_clock(MXC_UART_CLK) /
1000);
- printf("CSPI %8u kHz\n", mxc_get_clock(MXC_CSPI_CLK) /
1000); #endif
1000);
1000);
1000);
1000);
1000);
- printf("AHB %8u kHz\n", mxc_get_clock(MXC_AHB_CLK) /
1000);
- printf("AXI %8u kHz\n", mxc_get_clock(MXC_AXI_CLK) / 1000);
- printf("DDR %8u kHz\n", mxc_get_clock(MXC_DDR_CLK) /
1000);
- printf("USDHC1 %8u kHz\n", mxc_get_clock(MXC_ESDHC_CLK) /
1000);
- printf("USDHC2 %8u kHz\n", mxc_get_clock(MXC_ESDHC2_CLK) /
1000);
- printf("USDHC3 %8u kHz\n", mxc_get_clock(MXC_ESDHC3_CLK) /
1000);
Use %u and not %d for unsigned values. Print kHz and not khz. Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de Reviewed-by: Peng Fan peng.fan@nxp.com
Best regards, Stefano Babic
Peng Fan
sbabic@denx.de
