RE: [U-Boot-Users] Compressed U-Boot image
-----Original Message----- From: u-boot-users-admin@lists.sourceforge.net [mailto:u-boot-users-admin@lists.sourceforge.net] On Behalf Of Terry Barnaby Sent: Wednesday, November 03, 2004 11:39 AM To: Wolfgang Denk Cc: u-boot-users@lists.sourceforge.net Subject: Re: [U-Boot-Users] Compressed U-Boot image
[snip]
In my case I was hoping to use u-boot simply as a network boot loader without all of the debugging options. However I have only 32KByte to store the code in ....
Is there another PPC based network boot loader you know off that would be better at this than u-boot ?
Cheers
Terry
Hi Terry,
You have a significant challenge. I just did a quick gzip --best check which confirmed that my u-boot image compressed ~50% (45% but you will need to add the decompression code). This implies that you need an uncompressed u-boot image smaller than 64K. Since you have all the source, it is do-able, it is just a question of how hard you are willing to work and what you are willing to cut out ;-).
My advice is to... 1) Configure a minimal u-boot by turning off as many commands as possible. 2) See how close you are. My gut feel is that, if you are under 96K, you have a decent chance. 3) Look in the u-boot.map file and see who the heavy hitters are. With some luck, you will be able to minimize or remove enough of them to get under 64K.
As everybody has been saying, this isn't going to be easy. The nice thing is that you are starting from solid code. A _lot_ of people make the mistake of optimizing and then debugging... it is a lot easier to debug and then optimize.
Looking at my u-boot map it is very clear how much memory each .a/.o is taking up (3rd column in the .text section) and what it is used for. I see several decompression libraries (gzip, bzip2, inflate?) that you could remove all-but-one (and possibly all if you can get u-boot to re-use the u-boot image decompression routine that you will need to write). The command parser and commands make up a pretty large chunk -- obviously that can be minimized and possibly eliminated.
Some big hitters that are obviously necessary. These add up to just over 32K. We're still in the game, but this isn't looking very easy. .text 0xff800000 0x3560 cpu/mpc8260/start.o .text 0xff805098 0x1bf4 net/libnet.a(net.o) .text 0xff806c8c 0x6b0 net/libnet.a(tftp.o) .text 0xff80733c 0xae0 net/libnet.a(bootp.o) .text 0xff808018 0x87c net/libnet.a(eth.o) .text 0xff80992c 0xab4 common/libcommon.a(main.o) .text 0xff81248c 0x96c common/libcommon.a(console.o) .text 0xff812fb0 0x1328 common/libcommon.a(dlmalloc.o)
Commands, most or all of which would need to be sacrificed .text 0xff814bb8 0x2674 common/libcommon.a(hush.o) .text 0xff80a3e0 0x1ec common/libcommon.a(cmd_autoscript.o) .text 0xff80a5cc 0x23c common/libcommon.a(cmd_bdinfo.o) .text 0xff80a808 0xbc common/libcommon.a(cmd_boot.o) .text 0xff80a8c4 0x11e8 common/libcommon.a(cmd_bootm.o) .text 0xff80baac 0x1cc common/libcommon.a(cmd_cache.o) .text 0xff80bc78 0x120 common/libcommon.a(cmd_console.o) .text 0xff80bd98 0xb5c common/libcommon.a(cmd_flash.o) .text 0xff80c8f4 0xe18 common/libcommon.a(cmd_immap.o) .text 0xff80d70c 0x424 common/libcommon.a(cmd_itest.o) .text 0xff80db30 0x3b0 common/libcommon.a(cmd_jffs2.o) .text 0xff80dee0 0x1320 common/libcommon.a(cmd_load.o) .text 0xff80f200 0xd04 common/libcommon.a(cmd_mem.o) .text 0xff80ff04 0x820 common/libcommon.a(cmd_mii.o) .text 0xff810724 0xb0 common/libcommon.a(cmd_misc.o) .text 0xff8107d4 0x5b8 common/libcommon.a(cmd_net.o) .text 0xff810d8c 0xca8 common/libcommon.a(cmd_nvedit.o) .text 0xff811a34 0x178 common/libcommon.a(cmd_portio.o)
I _really hope_ that you have a development board that you can create an analog of your compressed u-boot on and debug it before you have to go to a severely memory starved environment.
You have an interesting challenge. Keep us informed and good luck, gvb
****************************************** The following messages are brought to you by the Lawyers' League of IdioSpeak:
****************************************** The information contained in, or attached to, this e-mail, may contain confidential information and is intended solely for the use of the individual or entity to whom they are addressed and may be subject to legal privilege. If you have received this e-mail in error you should notify the sender immediately by reply e-mail, delete the message from your system and notify your system manager. Please do not copy it for any purpose, or disclose its contents to any other person. The views or opinions presented in this e-mail are solely those of the author and do not necessarily represent those of the company. The recipient should check this e-mail and any attachments for the presence of viruses. The company accepts no liability for any damage caused, directly or indirectly, by any virus transmitted in this email. ******************************************
In message 065ACD8E84315E4394C835E398C8D5EB9A601B@COSSMGMBX02.email.corp.tld you wrote:
If you eliminate the command parser I wonder why you don't simply replace U-Boot by a simple "return" instruction - no more than 4 bytes needed for that ;-)
[snip]
Cheers
Terry
Hi Terry,
My advice is to...
- Configure a minimal u-boot by turning off as many commands as
This SF.Net email is sponsored by: Sybase ASE Linux Express Edition - download now for FREE LinuxWorld Reader's Choice Award Winner for best database on Linux. http://ads.osdn.com/?ad_idU88&alloc_id%12065&op%C3%8Ck _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Thanks for the info. I may have a look at doing this, although it may be simpler for me to create a separate simple network bootloader for this particular special case.
Terry
Terry Barnaby
