[U-Boot] [PATCH 0/9 V2]EXYNOS5: Support for Exynos5250 Rev 1.0
This patch set adds support for Exynos5250 Rev 1.0. Exynos5250 Rev 1.0 supports DDR3 Memory configuration and support for LPDDR2 is removed. Exynos5250 Rev 1.0 supports DWMMC driver but the support for same is not yet gone into Mainline. After DWMMC driver is added to Mainline support for generic S5P MMC driver will be removed.
Due to Support of generic S5P MMC driver currently still being there in the Mainline you can see the following error on boot.
mmc_reset: timeout error mmc_change_clock: timeout error mmc_send_cmd: waiting for status update MMC init failed
Changes in V2: - Included Paramateric structure with in #ifndef __ASSEMBLY__.
Rajeshwari Shinde (9): ARCH: SPL: Add parametric board initializer SMDK5250: SPL: Define parametric board initializer SMDK5250: Add smdk5250-uboot-spl.lds EXYNOS5: CLOCK: define additional clock registers for Exynos5250 Rev 1.0 EXYNOS5: CLOCK: Add clock support for Exynos5250 Rev 1.0 Exynos5: DDR3: Adding the DDR3 memory setup for Exynos5250 Rev 1.0 EXYNOS5: CLOCK: Modify MPLL clock out for Exynos5250 Rev 1.0 EXYNOS5 : Modify pinnumx settings as per Exynos5250 Rev 1.0 SMDK5250: Enable UART and MMC for Exynos5250 Rev 1.0
arch/arm/cpu/armv7/exynos/clock.c | 12 +- arch/arm/cpu/armv7/exynos/pinmux.c | 18 +- arch/arm/include/asm/arch-exynos/clock.h | 37 +- arch/arm/include/asm/arch-exynos/dmc.h | 65 +++ arch/arm/include/asm/arch-exynos/spl.h | 95 +++ board/samsung/smdk5250/Makefile | 3 +- board/samsung/smdk5250/clock_init.c | 714 +++++++++++++++++++---- board/samsung/smdk5250/clock_init.h | 149 +++++ board/samsung/smdk5250/dmc_common.c | 199 +++++++ board/samsung/smdk5250/dmc_init.c | 462 --------------- board/samsung/smdk5250/dmc_init_ddr3.c | 228 ++++++++ board/samsung/smdk5250/setup.h | 765 +++++++++++++++---------- board/samsung/smdk5250/smdk5250-uboot-spl.lds | 66 +++ board/samsung/smdk5250/smdk5250.c | 6 +- board/samsung/smdk5250/smdk5250_spl.c | 68 +++ include/configs/smdk5250.h | 7 +- 16 files changed, 1968 insertions(+), 926 deletions(-) create mode 100644 arch/arm/include/asm/arch-exynos/spl.h create mode 100644 board/samsung/smdk5250/clock_init.h create mode 100644 board/samsung/smdk5250/dmc_common.c delete mode 100644 board/samsung/smdk5250/dmc_init.c create mode 100644 board/samsung/smdk5250/dmc_init_ddr3.c create mode 100644 board/samsung/smdk5250/smdk5250-uboot-spl.lds create mode 100644 board/samsung/smdk5250/smdk5250_spl.c
Add a structure for table-driven configuration mechanism such that no recompilation is needed to update the configuration parameters, rather than hard-coding board initialization parameters.
Signed-off-by: Che-Liang Chiou clchiou@chromium.org Signed-off-by: Abhilash Kesavan a.kesavan@samsung.com Signed-off-by: Tom Wai-Hong Tam waihong@chromium.org Signed-off-by: Simon Glass sjg@chromium.org Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes in V2: - Included Paramateric structure with in #ifndef __ASSEMBLY__. arch/arm/include/asm/arch-exynos/spl.h | 97 ++++++++++++++++++++++++++++++++ 1 files changed, 97 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/arch-exynos/spl.h
diff --git a/arch/arm/include/asm/arch-exynos/spl.h b/arch/arm/include/asm/arch-exynos/spl.h new file mode 100644 index 0000000..306b41d --- /dev/null +++ b/arch/arm/include/asm/arch-exynos/spl.h @@ -0,0 +1,97 @@ +/* + * Copyright (c) 2012 The Chromium OS Authors. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_ARCH_EXYNOS_SPL_H__ +#define __ASM_ARCH_EXYNOS_SPL_H__ + +#include <asm/arch-exynos/dmc.h> + +enum boot_mode { + /* + * Assign the OM pin values for respective boot modes. + * Exynos4 does not support spi boot and the mmc boot OM + * pin values are the same across Exynos4 and Exynos5. + */ + BOOT_MODE_MMC = 4, + BOOT_MODE_SERIAL = 20, + /* Boot based on Operating Mode pin settings */ + BOOT_MODE_OM = 32, + BOOT_MODE_USB, /* Boot using USB download */ +}; + +#ifndef __ASSEMBLY__ +/* Parameters of early board initialization in SPL */ +struct spl_machine_param { + /* Add fields as and when required */ + u32 signature; + u32 version; /* Version number */ + u32 size; /* Size of block */ + /** + * Parameters we expect, in order, terminated with \0. Each parameter + * is a single character representing one 32-bit word in this + * structure. + * + * Valid characters in this string are: + * + * Code Name + * v mem_iv_size + * m mem_type + * u uboot_size + * b boot_source + * f frequency_mhz (memory frequency in MHz) + * a ARM clock frequency in MHz + * s serial base address + * i i2c base address for early access (meant for PMIC) + * r board rev GPIO numbers used to read board revision + * (lower halfword=bit 0, upper=bit 1) + * M Memory Manufacturer name + * \0 termination + */ + char params[12]; /* Length must be word-aligned */ + u32 mem_iv_size; /* Memory channel interleaving size */ + enum ddr_mode mem_type; /* Type of on-board memory */ + /* + * U-boot size - The iROM mmc copy function used by the SPL takes a + * block count paramter to describe the u-boot size unlike the spi + * boot copy function which just uses the u-boot size directly. Align + * the u-boot size to block size (512 bytes) when populating the SPL + * table only for mmc boot. + */ + u32 uboot_size; + enum boot_mode boot_source; /* Boot device */ + enum mem_manuf mem_manuf; /* Memory Manufacturer */ + unsigned frequency_mhz; /* Frequency of memory in MHz */ + unsigned arm_freq_mhz; /* ARM Frequency in MHz */ + u32 serial_base; /* Serial base address */ + u32 i2c_base; /* i2c base address */ +} __attribute__((__packed__)); +#endif + +/** + * Validate signature and return a pointer to the parameter table. If the + * signature is invalid, call panic() and never return. + * + * @return pointer to the parameter table if signature matched or never return. + */ +struct spl_machine_param *spl_get_machine_params(void); + +#endif /* __ASM_ARCH_EXYNOS_SPL_H__ */
Define table-driven configuration mechanism for SMDK5250 rather than hard-coding board initialization parameters.
Signed-off-by: Che-Liang Chiou clchiou@chromium.org Signed-off-by: Abhilash Kesavan a.kesavan@samsung.com Signed-off-by: Tom Wai-Hong Tam waihong@chromium.org Signed-off-by: Simon Glass sjg@chromium.org Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Chnages in V2: - None board/samsung/smdk5250/Makefile | 1 + board/samsung/smdk5250/smdk5250_spl.c | 68 +++++++++++++++++++++++++++++++++ 2 files changed, 69 insertions(+), 0 deletions(-) create mode 100644 board/samsung/smdk5250/smdk5250_spl.c
diff --git a/board/samsung/smdk5250/Makefile b/board/samsung/smdk5250/Makefile index 226db1f..3675fad 100644 --- a/board/samsung/smdk5250/Makefile +++ b/board/samsung/smdk5250/Makefile @@ -29,6 +29,7 @@ SOBJS := lowlevel_init.o COBJS := clock_init.o COBJS += dmc_init.o COBJS += tzpc_init.o +COBJS += smdk5250_spl.o
ifndef CONFIG_SPL_BUILD COBJS += smdk5250.o diff --git a/board/samsung/smdk5250/smdk5250_spl.c b/board/samsung/smdk5250/smdk5250_spl.c new file mode 100644 index 0000000..1d453ca --- /dev/null +++ b/board/samsung/smdk5250/smdk5250_spl.c @@ -0,0 +1,68 @@ +/* + * Copyright (c) 2012 The Chromium OS Authors. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/cpu.h> +#include <asm/arch/spl.h> +#include <asm/arch/clk.h> + +#define SIGNATURE 0xdeadbeef + +/* Parameters of early board initialization in SPL */ +static struct spl_machine_param machine_param + __attribute__((section(".machine_param"))) = { + .signature = SIGNATURE, + .version = 1, + .params = "vmubfasirM", + .size = sizeof(machine_param), + + .mem_iv_size = 0x1f, + .mem_type = DDR_MODE_DDR3, + + /* + * Set uboot_size to 0x100000 bytes. + * + * This is an overly conservative value chosen to accommodate all + * possible U-Boot image. You are advised to set this value to a + * smaller realistic size via scripts that modifies the .machine_param + * section of output U-Boot image. + */ + .uboot_size = 0x100000, + + .boot_source = BOOT_MODE_OM, + .frequency_mhz = 800, + .arm_freq_mhz = 1700, + .serial_base = 0x12c30000, + .i2c_base = 0x12c60000, + .mem_manuf = MEM_MANUF_SAMSUNG, +}; + +struct spl_machine_param *spl_get_machine_params(void) +{ + if (machine_param.signature != SIGNATURE) { + /* Will hang if SIGNATURE dont match */ + while (1) + ; + } + + return &machine_param; +}
Default spl/u-boot-spl.lds created by spl/Makefile resolves the spl text load addr to 0x0. As 0x0 belongs to iROM addr so Global variables can not be used.
Adding specific smdk5250-uboot-spl.lds makes possible to use Global Variables in spl.
Signed-off-by: Alim Akhtar alim.akhtar@samsung.com Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Chnages in V2: - None board/samsung/smdk5250/smdk5250-uboot-spl.lds | 66 +++++++++++++++++++++++++ include/configs/smdk5250.h | 5 ++ 2 files changed, 71 insertions(+), 0 deletions(-) create mode 100644 board/samsung/smdk5250/smdk5250-uboot-spl.lds
diff --git a/board/samsung/smdk5250/smdk5250-uboot-spl.lds b/board/samsung/smdk5250/smdk5250-uboot-spl.lds new file mode 100644 index 0000000..d78dd77 --- /dev/null +++ b/board/samsung/smdk5250/smdk5250-uboot-spl.lds @@ -0,0 +1,66 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * Copyright (C) 2012 Samsung Electronics + * + * Based on arch/arm/cpu/armv7/omap-common/u-boot-spl.lds + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +MEMORY { .sram : ORIGIN = CONFIG_SPL_TEXT_BASE, \ + LENGTH = CONFIG_SPL_MAX_SIZE } + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) + +SECTIONS +{ + .text : + { + __start = .; + arch/arm/cpu/armv7/start.o (.text) + *(.text*) + } >.sram + . = ALIGN(4); + + .rodata : { *(SORT_BY_ALIGNMENT(.rodata*)) } >.sram + . = ALIGN(4); + + .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.sram + . = ALIGN(4); + + /* Align .machine_param on 256 byte boundary for easier searching */ + .machine_param ALIGN(0x100) : { *(.machine_param) } >.sram + . = ALIGN(4); + + __image_copy_end = .; + _end = .; + + .bss : + { + . = ALIGN(4); + __bss_start = .; + *(.bss*) + . = ALIGN(4); + __bss_end__ = .; + } >.sram +} diff --git a/include/configs/smdk5250.h b/include/configs/smdk5250.h index 9659f9e..405abd5 100644 --- a/include/configs/smdk5250.h +++ b/include/configs/smdk5250.h @@ -105,6 +105,11 @@ #define CONFIG_SPL #define COPY_BL2_FNPTR_ADDR 0x02020030
+/* specific .lds file */ +#define CONFIG_SPL_LDSCRIPT "board/samsung/smdk5250/smdk5250-uboot-spl.lds" +#define CONFIG_SPL_TEXT_BASE 0x02023400 +#define CONFIG_SPL_MAX_SIZE (14 * 1024) + #define CONFIG_BOOTCOMMAND "mmc read 40007000 451 2000; bootm 40007000"
/* Miscellaneous configurable options */
Rajeshwari Shinde
