[U-Boot-Users] [PATCH - RFC] Fix printf() format problems with configurable prompts
U-Boot allows for configurable prompt strings using the CONFIG_AUTOBOOT_PROMPT resp. CONFIG_MENUPROMPT definitions. So far, the assumption was that any such user defined problts would contain exactly one "%d" format specifier. But some boards did not.
To allow for flexible boot prompts without adding too complex code we now allow to specify the whole list of printf() arguments in the user definition. This is powerful, but requires a responsible user who really understands what he is doing, as he needs to know for exanple which variables are available in the respective context.
Signed-off-by: Wolfgang Denk wd@denx.de ---
This is an attempt to fix the main.c:215: warning: too many arguments for format main.c:119: warning: too many arguments for format warnings we got for some boards.
I am not exactly happy about providing the complete list of printf() arguments in a #define, but this seems to be the solution that (1) requires the least changes to the code and (2) does not add memory footprint (like we would need if we added some format parsing function).
Comments / critique welcome.
common/main.c | 4 ++-- doc/README.autoboot | 15 +++++++++++---- include/configs/APC405.h | 3 ++- include/configs/AmigaOneG3SE.h | 3 ++- include/configs/CPCI405DT.h | 5 +++-- include/configs/DU440.h | 5 +++-- include/configs/GTH.h | 5 +++-- include/configs/KUP4K.h | 3 ++- include/configs/KUP4X.h | 3 ++- include/configs/MVBLUE.h | 7 ++++--- include/configs/NC650.h | 5 +++-- include/configs/PLU405.h | 5 +++-- include/configs/PMC440.h | 3 ++- include/configs/RPXlite_DW.h | 3 ++- include/configs/SXNI855T.h | 2 +- include/configs/atngw100.h | 4 ++-- include/configs/atstk1002.h | 4 ++-- include/configs/atstk1003.h | 4 ++-- include/configs/atstk1004.h | 4 ++-- include/configs/atstk1006.h | 4 ++-- include/configs/gth2.h | 5 +++-- include/configs/gw8260.h | 3 ++- include/configs/hymod.h | 2 +- include/configs/linkstation.h | 3 ++- include/configs/lwmon.h | 3 ++- include/configs/lwmon5.h | 3 ++- include/configs/m501sk.h | 1 - include/configs/motionpro.h | 2 +- include/configs/mp2usb.h | 3 ++- include/configs/netstar.h | 3 ++- include/configs/ppmc8260.h | 3 ++- include/configs/quantum.h | 3 ++- include/configs/rmu.h | 3 ++- include/configs/sacsng.h | 2 +- include/configs/sbc8260.h | 3 ++- include/configs/sc3.h | 3 ++- include/configs/trab.h | 3 ++- include/configs/utx8245.h | 2 +- 38 files changed, 86 insertions(+), 55 deletions(-)
diff --git a/common/main.c b/common/main.c index 79ad291..187ef8a 100644 --- a/common/main.c +++ b/common/main.c @@ -116,7 +116,7 @@ static __inline__ int abortboot(int bootdelay) u_int i;
# ifdef CONFIG_AUTOBOOT_PROMPT - printf(CONFIG_AUTOBOOT_PROMPT, bootdelay); + printf(CONFIG_AUTOBOOT_PROMPT); # endif
# ifdef CONFIG_AUTOBOOT_DELAY_STR @@ -212,7 +212,7 @@ static __inline__ int abortboot(int bootdelay) int abort = 0;
#ifdef CONFIG_MENUPROMPT - printf(CONFIG_MENUPROMPT, bootdelay); + printf(CONFIG_MENUPROMPT); #else printf("Hit any key to stop autoboot: %2d ", bootdelay); #endif diff --git a/doc/README.autoboot b/doc/README.autoboot index e4c4186..2042fe5 100644 --- a/doc/README.autoboot +++ b/doc/README.autoboot @@ -114,10 +114,17 @@ What they do CONFIG_AUTOBOOT_PROMPT is displayed before the boot delay selected by CONFIG_BOOTDELAY starts. If it is not defined there is no output indicating that autoboot is in progress. - If "%d" is included, it is replaced by the number of seconds - remaining before autoboot will start, but it does not count - down the seconds. "autoboot in %d seconds\n" is a reasonable - prompt. + + Note that CONFIG_AUTOBOOT_PROMPT is used as the (only) + argument to a printf() call, so it may contain '%' format + specifications, provided that it also includes, sepearated by + commas exactly like in a printf statement, the required + arguments. It is the responsibility of the user to select only + such arguments that are valid in the given context. A + reasonable prompt could be defined as + + #define CONFIG_AUTOBOOT_PROMPT \ + "autoboot in %d seconds\n",bootdelay
If CONFIG_AUTOBOOT_DELAY_STR or "bootdelaykey" is specified and this string is received from console input before diff --git a/include/configs/APC405.h b/include/configs/APC405.h index 02f0c76..2f266a2 100644 --- a/include/configs/APC405.h +++ b/include/configs/APC405.h @@ -193,7 +193,8 @@ /* If a long serial cable is connected but */ /* other end is dead, garbage will be read */ #define CONFIG_AUTOBOOT_KEYED 1 -#define CONFIG_AUTOBOOT_PROMPT "Press SPACE to abort autoboot in %d seconds\n" +#define CONFIG_AUTOBOOT_PROMPT \ + "Press SPACE to abort autoboot in %d seconds\n", bootdelay #undef CONFIG_AUTOBOOT_DELAY_STR #define CONFIG_AUTOBOOT_STOP_STR " "
diff --git a/include/configs/AmigaOneG3SE.h b/include/configs/AmigaOneG3SE.h index a992498..84efd2f 100644 --- a/include/configs/AmigaOneG3SE.h +++ b/include/configs/AmigaOneG3SE.h @@ -371,7 +371,8 @@ #define CONFIG_BOOTDELAY 5 /* Boot automatically after five seconds */ #define CONFIG_PREBOOT "" #define CONFIG_BOOTCOMMAND "fdcboot; diskboot" -#define CONFIG_MENUPROMPT "Press any key to interrupt autoboot: %2d " +#define CONFIG_MENUPROMPT \ + "Press any key to interrupt autoboot: %2d ", bootdelay #define CONFIG_MENUKEY ' ' #define CONFIG_MENUCOMMAND "menu" /* #define CONFIG_AUTOBOOT_KEYED */ diff --git a/include/configs/CPCI405DT.h b/include/configs/CPCI405DT.h index 6b585be..c173539 100644 --- a/include/configs/CPCI405DT.h +++ b/include/configs/CPCI405DT.h @@ -152,8 +152,9 @@ #define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */
/* Only interrupt boot if special string is typed */ -#define CONFIG_AUTOBOOT_KEYED 1 -#define CONFIG_AUTOBOOT_PROMPT "Autobooting in %d seconds\n" +#define CONFIG_AUTOBOOT_KEYED 1 +#define CONFIG_AUTOBOOT_PROMPT \ + "Autobooting in %d seconds\n", bootdelay #undef CONFIG_AUTOBOOT_DELAY_STR #undef CONFIG_AUTOBOOT_STOP_STR /* defined via environment var */ #define CONFIG_AUTOBOOT_STOP_STR2 "esdesd" /* esd special for esd access*/ diff --git a/include/configs/DU440.h b/include/configs/DU440.h index 0f5f85c..64c9ac0 100644 --- a/include/configs/DU440.h +++ b/include/configs/DU440.h @@ -345,8 +345,9 @@ int du440_phy_addr(int devnum); #define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ #define CONFIG_VERSION_VARIABLE 1 /* include version env variable */
-#define CONFIG_AUTOBOOT_KEYED 1 -#define CONFIG_AUTOBOOT_PROMPT "Press SPACE to abort autoboot in %d seconds\n" +#define CONFIG_AUTOBOOT_KEYED 1 +#define CONFIG_AUTOBOOT_PROMPT \ + "Press SPACE to abort autoboot in %d seconds\n", bootdelay #define CONFIG_AUTOBOOT_DELAY_STR "d" #define CONFIG_AUTOBOOT_STOP_STR " "
diff --git a/include/configs/GTH.h b/include/configs/GTH.h index 00e09f7..461670a 100644 --- a/include/configs/GTH.h +++ b/include/configs/GTH.h @@ -62,8 +62,9 @@ /* Only interrupt boot if space is pressed */ /* If a long serial cable is connected but */ /* other end is dead, garbage will be read */ -#define CONFIG_AUTOBOOT_KEYED 1 -#define CONFIG_AUTOBOOT_PROMPT "Press space to abort autoboot in %d second\n" +#define CONFIG_AUTOBOOT_KEYED 1 +#define CONFIG_AUTOBOOT_PROMPT \ + "Press space to abort autoboot in %d second\n", bootdelay #define CONFIG_AUTOBOOT_DELAY_STR "d" #define CONFIG_AUTOBOOT_STOP_STR " "
diff --git a/include/configs/KUP4K.h b/include/configs/KUP4K.h index f6c31ea..e52fbfd 100644 --- a/include/configs/KUP4K.h +++ b/include/configs/KUP4K.h @@ -488,7 +488,8 @@
#define CONFIG_AUTOBOOT_KEYED /* use key strings to stop autoboot */ #if 0 -#define CONFIG_AUTOBOOT_PROMPT "Boote in %d Sekunden - stop mit "2"\n" +#define CONFIG_AUTOBOOT_PROMPT \ + "Boote in %d Sekunden - stop mit "2"\n", bootdelay #endif #define CONFIG_AUTOBOOT_STOP_STR "." /* easy to stop for now */ #define CONFIG_SILENT_CONSOLE 1 diff --git a/include/configs/KUP4X.h b/include/configs/KUP4X.h index e558aa4..be0c7af 100644 --- a/include/configs/KUP4X.h +++ b/include/configs/KUP4X.h @@ -454,7 +454,8 @@
#define CONFIG_AUTOBOOT_KEYED /* use key strings to stop autoboot */ #if 0 -#define CONFIG_AUTOBOOT_PROMPT "Boote in %d Sekunden - stop mit "2"\n" +#define CONFIG_AUTOBOOT_PROMPT \ + "Boote in %d Sekunden - stop mit "2"\n", bootdelay #endif #define CONFIG_AUTOBOOT_STOP_STR "." /* easy to stop for now */ #define CONFIG_SILENT_CONSOLE 1 diff --git a/include/configs/MVBLUE.h b/include/configs/MVBLUE.h index d08d795..8e247af 100644 --- a/include/configs/MVBLUE.h +++ b/include/configs/MVBLUE.h @@ -59,17 +59,18 @@
#define CONFIG_CLOCKS_IN_MHZ 1
-#define CONFIG_BOARD_TYPES 1 +#define CONFIG_BOARD_TYPES 1
#define CONFIG_CONS_INDEX 1 #define CONFIG_BAUDRATE 115200 #define CFG_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 }
-#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTDELAY 3 #define CONFIG_BOOT_RETRY_TIME -1
#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT "autoboot in %d seconds (stop with 's')...\n" +#define CONFIG_AUTOBOOT_PROMPT \ + "autoboot in %d seconds (stop with 's')...\n", bootdelay #define CONFIG_AUTOBOOT_STOP_STR "s" #define CONFIG_ZERO_BOOTDELAY_CHECK #define CONFIG_RESET_TO_RETRY 60 diff --git a/include/configs/NC650.h b/include/configs/NC650.h index 0b09482..84c6e9b 100644 --- a/include/configs/NC650.h +++ b/include/configs/NC650.h @@ -65,9 +65,10 @@ #define CFG_MEASURE_CPUCLK #define CFG_8XX_XIN CONFIG_8xx_OSCLK
-#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ +#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ #define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT "\nEnter password - autoboot in %d seconds...\n" +#define CONFIG_AUTOBOOT_PROMPT \ + "\nEnter password - autoboot in %d seconds...\n", bootdelay #define CONFIG_AUTOBOOT_DELAY_STR "ids" #define CONFIG_BOOT_RETRY_TIME 900 #define CONFIG_BOOT_RETRY_MIN 30 diff --git a/include/configs/PLU405.h b/include/configs/PLU405.h index 0bd77c0..a3d1c56 100644 --- a/include/configs/PLU405.h +++ b/include/configs/PLU405.h @@ -154,8 +154,9 @@ /* Only interrupt boot if space is pressed */ /* If a long serial cable is connected but */ /* other end is dead, garbage will be read */ -#define CONFIG_AUTOBOOT_KEYED 1 -#define CONFIG_AUTOBOOT_PROMPT "Press SPACE to abort autoboot in %d seconds\n" +#define CONFIG_AUTOBOOT_KEYED 1 +#define CONFIG_AUTOBOOT_PROMPT \ + "Press SPACE to abort autoboot in %d seconds\n", bootdelay #undef CONFIG_AUTOBOOT_DELAY_STR #define CONFIG_AUTOBOOT_STOP_STR " "
diff --git a/include/configs/PMC440.h b/include/configs/PMC440.h index e8b405a..42f1d8d 100644 --- a/include/configs/PMC440.h +++ b/include/configs/PMC440.h @@ -409,7 +409,8 @@ #define CONFIG_VERSION_VARIABLE 1 /* include version env variable */
diff --git a/include/configs/RPXlite_DW.h b/include/configs/RPXlite_DW.h index 872765c..faae407 100644 --- a/include/configs/RPXlite_DW.h +++ b/include/configs/RPXlite_DW.h @@ -68,7 +68,8 @@ #ifdef DEPLOYMENT #define CONFIG_BOOT_RETRY_TIME -1 #define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT "autoboot in %d seconds (stop with 'st')...\n" +#define CONFIG_AUTOBOOT_PROMPT \ + "autoboot in %d seconds (stop with 'st')...\n", bootdelay #define CONFIG_AUTOBOOT_STOP_STR "st" #define CONFIG_ZERO_BOOTDELAY_CHECK #define CONFIG_RESET_TO_RETRY 1 diff --git a/include/configs/SXNI855T.h b/include/configs/SXNI855T.h index 3aee45c..aefc7ee 100644 --- a/include/configs/SXNI855T.h +++ b/include/configs/SXNI855T.h @@ -465,7 +465,7 @@
#if 1 #define CONFIG_AUTOBOOT_KEYED /* use key strings to stop autoboot */ -#define CONFIG_AUTOBOOT_PROMPT "autoboot in %d seconds\n" +#define CONFIG_AUTOBOOT_PROMPT "autoboot in %d seconds\n", bootdelay #define CONFIG_AUTOBOOT_DELAY_STR "delayabit" #define CONFIG_AUTOBOOT_STOP_STR " " /* easy to stop for now */ #endif diff --git a/include/configs/atngw100.h b/include/configs/atngw100.h index 84d235e..f040b86 100644 --- a/include/configs/atngw100.h +++ b/include/configs/atngw100.h @@ -82,8 +82,8 @@ #define CONFIG_BOOTDELAY 1 #define CONFIG_AUTOBOOT 1 #define CONFIG_AUTOBOOT_KEYED 1 -#define CONFIG_AUTOBOOT_PROMPT \ - "Press SPACE to abort autoboot in %d seconds\n" +#define CONFIG_AUTOBOOT_PROMPT \ + "Press SPACE to abort autoboot in %d seconds\n", bootdelay #define CONFIG_AUTOBOOT_DELAY_STR "d" #define CONFIG_AUTOBOOT_STOP_STR " "
diff --git a/include/configs/atstk1002.h b/include/configs/atstk1002.h index 90910bb..68f0cec 100644 --- a/include/configs/atstk1002.h +++ b/include/configs/atstk1002.h @@ -110,8 +110,8 @@ #define CONFIG_BOOTDELAY 1 #define CONFIG_AUTOBOOT 1 #define CONFIG_AUTOBOOT_KEYED 1 -#define CONFIG_AUTOBOOT_PROMPT \ - "Press SPACE to abort autoboot in %d seconds\n" +#define CONFIG_AUTOBOOT_PROMPT \ + "Press SPACE to abort autoboot in %d seconds\n", bootdelay #define CONFIG_AUTOBOOT_DELAY_STR "d" #define CONFIG_AUTOBOOT_STOP_STR " "
diff --git a/include/configs/atstk1003.h b/include/configs/atstk1003.h index 03472a8..d3a2f69 100644 --- a/include/configs/atstk1003.h +++ b/include/configs/atstk1003.h @@ -110,8 +110,8 @@ #define CONFIG_BOOTDELAY 1 #define CONFIG_AUTOBOOT 1 #define CONFIG_AUTOBOOT_KEYED 1 -#define CONFIG_AUTOBOOT_PROMPT \ - "Press SPACE to abort autoboot in %d seconds\n" +#define CONFIG_AUTOBOOT_PROMPT \ + "Press SPACE to abort autoboot in %d seconds\n", bootdelay #define CONFIG_AUTOBOOT_DELAY_STR "d" #define CONFIG_AUTOBOOT_STOP_STR " "
diff --git a/include/configs/atstk1004.h b/include/configs/atstk1004.h index 07add82..a37ba92 100644 --- a/include/configs/atstk1004.h +++ b/include/configs/atstk1004.h @@ -110,8 +110,8 @@ #define CONFIG_BOOTDELAY 1 #define CONFIG_AUTOBOOT 1 #define CONFIG_AUTOBOOT_KEYED 1 -#define CONFIG_AUTOBOOT_PROMPT \ - "Press SPACE to abort autoboot in %d seconds\n" +#define CONFIG_AUTOBOOT_PROMPT \ + "Press SPACE to abort autoboot in %d seconds\n", bootdelay #define CONFIG_AUTOBOOT_DELAY_STR "d" #define CONFIG_AUTOBOOT_STOP_STR " "
diff --git a/include/configs/atstk1006.h b/include/configs/atstk1006.h index f9af675..a6c5b6e 100644 --- a/include/configs/atstk1006.h +++ b/include/configs/atstk1006.h @@ -110,8 +110,8 @@ #define CONFIG_BOOTDELAY 1 #define CONFIG_AUTOBOOT 1 #define CONFIG_AUTOBOOT_KEYED 1 -#define CONFIG_AUTOBOOT_PROMPT \ - "Press SPACE to abort autoboot in %d seconds\n" +#define CONFIG_AUTOBOOT_PROMPT \ + "Press SPACE to abort autoboot in %d seconds\n", bootdelay #define CONFIG_AUTOBOOT_DELAY_STR "d" #define CONFIG_AUTOBOOT_STOP_STR " "
diff --git a/include/configs/gth2.h b/include/configs/gth2.h index c2d6ca7..7f7190b 100644 --- a/include/configs/gth2.h +++ b/include/configs/gth2.h @@ -54,8 +54,9 @@ /* Only interrupt boot if space is pressed */ /* If a long serial cable is connected but */ /* other end is dead, garbage will be read */ -#define CONFIG_AUTOBOOT_KEYED 1 -#define CONFIG_AUTOBOOT_PROMPT "Press space to abort autoboot in %d second\n" +#define CONFIG_AUTOBOOT_KEYED 1 +#define CONFIG_AUTOBOOT_PROMPT \ + "Press space to abort autoboot in %d second\n", bootdelay #define CONFIG_AUTOBOOT_DELAY_STR "d" #define CONFIG_AUTOBOOT_STOP_STR " "
diff --git a/include/configs/gw8260.h b/include/configs/gw8260.h index 7c2c224..d918782 100644 --- a/include/configs/gw8260.h +++ b/include/configs/gw8260.h @@ -279,7 +279,8 @@ * To stop use: " " */ #define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT "Autobooting in %d seconds, press " " to stop\n" +#define CONFIG_AUTOBOOT_PROMPT \ + "Autobooting in %d seconds, press " " to stop\n", bootdelay #define CONFIG_AUTOBOOT_STOP_STR " " #undef CONFIG_AUTOBOOT_DELAY_STR #define DEBUG_BOOTKEYS 0 diff --git a/include/configs/hymod.h b/include/configs/hymod.h index 01e7970..264192f 100644 --- a/include/configs/hymod.h +++ b/include/configs/hymod.h @@ -224,7 +224,7 @@ */ #define CONFIG_AUTOBOOT_KEYED #define CONFIG_AUTOBOOT_PROMPT "Autobooting in %d seconds, " \ - "press <SPACE> to stop\n" + "press <SPACE> to stop\n", bootdelay #define CONFIG_AUTOBOOT_STOP_STR " " #undef CONFIG_AUTOBOOT_DELAY_STR #define DEBUG_BOOTKEYS 0 diff --git a/include/configs/linkstation.h b/include/configs/linkstation.h index d3908b9..bc64294 100644 --- a/include/configs/linkstation.h +++ b/include/configs/linkstation.h @@ -82,7 +82,8 @@ #undef CONFIG_BOOT_RETRY_TIME
#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT "Boot in %02d seconds ('s' to stop)..." +#define CONFIG_AUTOBOOT_PROMPT \ + "Boot in %02d seconds ('s' to stop)...", bootdelay #define CONFIG_AUTOBOOT_STOP_STR "s"
#define CONFIG_CMD_IDE diff --git a/include/configs/lwmon.h b/include/configs/lwmon.h index 8a82702..87abfba 100644 --- a/include/configs/lwmon.h +++ b/include/configs/lwmon.h @@ -252,7 +252,8 @@ #define CONFIG_POST_KEY_MAGIC "3C+3E" /* press F3 + F5 keys to force POST */ #if 0 #define CONFIG_AUTOBOOT_KEYED /* Enable "password" protection */ -#define CONFIG_AUTOBOOT_PROMPT "\nEnter password - autoboot in %d sec...\n" +#define CONFIG_AUTOBOOT_PROMPT \ + "\nEnter password - autoboot in %d sec...\n", bootdelay #define CONFIG_AUTOBOOT_DELAY_STR " " /* "password" */ #endif /*----------------------------------------------------------------------*/ diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index cf406c8..2f3a066 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -277,7 +277,8 @@ #define CONFIG_POST_KEY_MAGIC "3C+3E" /* press F3 + F5 keys to force POST */ #if 0 #define CONFIG_AUTOBOOT_KEYED /* Enable "password" protection */ -#define CONFIG_AUTOBOOT_PROMPT "\nEnter password - autoboot in %d sec...\n" +#define CONFIG_AUTOBOOT_PROMPT \ + "\nEnter password - autoboot in %d sec...\n", bootdelay #define CONFIG_AUTOBOOT_DELAY_STR " " /* "password" */ #endif
diff --git a/include/configs/m501sk.h b/include/configs/m501sk.h index 095fdaf..fce93f7 100644 --- a/include/configs/m501sk.h +++ b/include/configs/m501sk.h @@ -40,7 +40,6 @@ #define CONFIG_SETUP_MEMORY_TAGS 1 #define CONFIG_INITRD_TAG 1
-#undef CONFIG_AUTOBOOT_PROMPT #define CONFIG_MENUPROMPT "."
/* diff --git a/include/configs/motionpro.h b/include/configs/motionpro.h index b6843af..3d1eafe 100644 --- a/include/configs/motionpro.h +++ b/include/configs/motionpro.h @@ -96,7 +96,7 @@ #undef CONFIG_AUTOBOOT_DELAY_STR #undef CONFIG_BOOTARGS #define CONFIG_AUTOBOOT_PROMPT "Autobooting in %d seconds, " \ - "press "<Esc><Esc>" to stop\n" + "press "<Esc><Esc>" to stop\n", bootdelay
#define CONFIG_ETHADDR 00:50:C2:40:10:00 #define CONFIG_OVERWRITE_ETHADDR_ONCE 1 diff --git a/include/configs/mp2usb.h b/include/configs/mp2usb.h index 2eb4af1..87264fb 100644 --- a/include/configs/mp2usb.h +++ b/include/configs/mp2usb.h @@ -230,7 +230,8 @@ #undef CONFIG_SILENT_CONSOLE /* enable silent startup */
#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT "Press SPACE to abort autoboot in %d seconds\n" +#define CONFIG_AUTOBOOT_PROMPT \ + "Press SPACE to abort autoboot in %d seconds\n", bootdelay #define CONFIG_AUTOBOOT_STOP_STR " " #define CONFIG_AUTOBOOT_DELAY_STR "d"
diff --git a/include/configs/netstar.h b/include/configs/netstar.h index d4deda4..756b7c2 100644 --- a/include/configs/netstar.h +++ b/include/configs/netstar.h @@ -195,7 +195,8 @@
#if 0 /* feel free to disable for development */ #define CONFIG_AUTOBOOT_KEYED /* Enable password protection */ -#define CONFIG_AUTOBOOT_PROMPT "\nNetStar PBX - boot in %d secs...\n" +#define CONFIG_AUTOBOOT_PROMPT \ + "\nNetStar PBX - boot in %d secs...\n", bootdelay #define CONFIG_AUTOBOOT_DELAY_STR "." /* 1st "password" */ #endif
diff --git a/include/configs/ppmc8260.h b/include/configs/ppmc8260.h index 56b4d92..dee6643 100644 --- a/include/configs/ppmc8260.h +++ b/include/configs/ppmc8260.h @@ -228,7 +228,8 @@ * To stop use: " " */ # define CONFIG_AUTOBOOT_KEYED -# define CONFIG_AUTOBOOT_PROMPT "Autobooting in %d seconds, press " " to stop\n" +# define CONFIG_AUTOBOOT_PROMPT \ + "Autobooting in %d seconds, press " " to stop\n", bootdelay # define CONFIG_AUTOBOOT_STOP_STR " " # undef CONFIG_AUTOBOOT_DELAY_STR # define DEBUG_BOOTKEYS 0 diff --git a/include/configs/quantum.h b/include/configs/quantum.h index f49e2b0..cc261c3 100644 --- a/include/configs/quantum.h +++ b/include/configs/quantum.h @@ -116,7 +116,8 @@
#define CONFIG_AUTOBOOT_KEYED /* Enable password protection */ -#define CONFIG_AUTOBOOT_PROMPT "\nEnter password - autoboot in %d sec...\n" +#define CONFIG_AUTOBOOT_PROMPT \ + "\nEnter password - autoboot in %d sec...\n", bootdelay #define CONFIG_AUTOBOOT_DELAY_STR "system" /* * Miscellaneous configurable options diff --git a/include/configs/rmu.h b/include/configs/rmu.h index 28fb7c3..596bf15 100644 --- a/include/configs/rmu.h +++ b/include/configs/rmu.h @@ -111,7 +111,8 @@
/* diff --git a/include/configs/sacsng.h b/include/configs/sacsng.h index 2a398e8..8427752 100644 --- a/include/configs/sacsng.h +++ b/include/configs/sacsng.h @@ -436,7 +436,7 @@ * To stop use: " " */ #define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT "Autobooting...\n" +#define CONFIG_AUTOBOOT_PROMPT "Autobooting...\n" #define CONFIG_AUTOBOOT_STOP_STR " " #undef CONFIG_AUTOBOOT_DELAY_STR #define CONFIG_ZERO_BOOTDELAY_CHECK diff --git a/include/configs/sbc8260.h b/include/configs/sbc8260.h index 7993137..b92344c 100644 --- a/include/configs/sbc8260.h +++ b/include/configs/sbc8260.h @@ -306,7 +306,8 @@ */ #undef CONFIG_AUTOBOOT_KEYED #ifdef CONFIG_AUTOBOOT_KEYED -# define CONFIG_AUTOBOOT_PROMPT "Autobooting in %d seconds, press " " to stop\n" +# define CONFIG_AUTOBOOT_PROMPT \ + "Autobooting in %d seconds, press " " to stop\n", bootdelay # define CONFIG_AUTOBOOT_STOP_STR " " # undef CONFIG_AUTOBOOT_DELAY_STR # define DEBUG_BOOTKEYS 0 diff --git a/include/configs/sc3.h b/include/configs/sc3.h index f6e40de..e1f3342 100644 --- a/include/configs/sc3.h +++ b/include/configs/sc3.h @@ -132,7 +132,8 @@
#if 1 /* feel free to disable for development */ #define CONFIG_AUTOBOOT_KEYED /* Enable password protection */ -#define CONFIG_AUTOBOOT_PROMPT "\nSC3 - booting... stop with ENTER\n" +#define CONFIG_AUTOBOOT_PROMPT \ + "\nSC3 - booting... stop with ENTER\n" #define CONFIG_AUTOBOOT_DELAY_STR "\r" /* 1st "password" */ #define CONFIG_AUTOBOOT_DELAY_STR2 "\n" /* 1st "password" */ #endif diff --git a/include/configs/trab.h b/include/configs/trab.h index de36fca..b0615a0 100644 --- a/include/configs/trab.h +++ b/include/configs/trab.h @@ -289,7 +289,8 @@
#if 1 /* feel free to disable for development */ #define CONFIG_AUTOBOOT_KEYED /* Enable password protection */ -#define CONFIG_AUTOBOOT_PROMPT "\nEnter password - autoboot in %d sec...\n" +#define CONFIG_AUTOBOOT_PROMPT \ + "\nEnter password - autoboot in %d sec...\n", bootdelay #define CONFIG_AUTOBOOT_DELAY_STR "R" /* 1st "password" */ #endif
diff --git a/include/configs/utx8245.h b/include/configs/utx8245.h index 287a618..1675ab7 100644 --- a/include/configs/utx8245.h +++ b/include/configs/utx8245.h @@ -58,7 +58,7 @@ #define CFG_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 }
#define CONFIG_BOOTDELAY 2 -#define CONFIG_AUTOBOOT_PROMPT "autoboot in %d seconds\n" +#define CONFIG_AUTOBOOT_PROMPT "autoboot in %d seconds\n", bootdelay #define CONFIG_BOOTCOMMAND "run nfsboot" /* autoboot command */ #define CONFIG_BOOTARGS "root=/dev/ram console=ttyS0,57600" /* RAMdisk */ #define CONFIG_ETHADDR 00:AA:00:14:00:05 /* UTX5 */
s/exanple/example/
Hi Wolfgang,
It seems a lot simpler to reformat the couple of boards that don't have %d in their string to add the "in %d seconds" type phrase.
The downside (risk!) of this is that some companies may be unhappy if their boot prompt changes (ripple effect through manuals, humans trained to see certain strings, programs expect-ing certain strings, etc.).
I'm OK with doing this to sacsng and Heiko Schocher is OK with sc3 (he published a patch this afternoon). That leaves only three boards at risk: hymod, motionpro, and voiceblue.
$ grep -A 1 CONFIG_AUTOBOOT_PROMPT include/configs/*.h |less | grep -v '%d' | grep -v -- '--' | grep -v CONFIG_AUTOBOOT_DELAY_STR | grep -v CONFIG_AUTOBOOT_STOP_STR
include/configs/hymod.h- "press <SPACE> to stop\n"
include/configs/motionpro.h- "press "<Esc><Esc>" to stop\n"
include/configs/sacsng.h:#define CONFIG_AUTOBOOT_PROMPT "Autobooting...\n"
include/configs/sc3.h:#define CONFIG_AUTOBOOT_PROMPT "\nSC3 - booting... stop with ENTER\n"
include/configs/voiceblue.h:#define CONFIG_AUTOBOOT_PROMPT "\nVoiceBlue Enterprise - booting...\n"
Best regards, gvb
Agreed, that would be much simpler.
That's the exact problem. I know oof at leats one of them who insisted on the specific message, so this will not work.
Yes, Heiko is OK with that, but not so his customer (who is the case I was talking about).
Jerry Van Baren
