Re: [U-Boot] [PATCH 1/2] Update i386 code (sc520_cdp)
OK, last try then I'm completely giving up :(
Attempt to bring i386 / sc520 inline with master
Signed-off-by: Graeme Russ graeme.russ@gmail.com
diff --git a/board/sc520_cdp/sc520_cdp.c b/board/sc520_cdp/sc520_cdp.c index f21c730..bfb473e 100644 --- a/board/sc520_cdp/sc520_cdp.c +++ b/board/sc520_cdp/sc520_cdp.c @@ -114,7 +114,7 @@ static void irq_init(void)
- +#ifdef CONFIG_PCI /* PCI stuff */ static void pci_sc520_cdp_fixup_irq(struct pci_controller *hose, pci_dev_t dev) { @@ -129,7 +129,7 @@ static void pci_sc520_cdp_fixup_irq(struct pci_controller *hose, pci_dev_t dev) }; static int next_irq_index=0;
- char tmp_pin; + uchar tmp_pin; int pin;
pci_hose_read_config_byte(hose, dev, PCI_INTERRUPT_PIN, &tmp_pin); @@ -193,7 +193,7 @@ void pci_init_board(void) { pci_sc520_init(&sc520_cdp_hose); } - +#endif
static void silence_uart(int port) { @@ -563,12 +563,12 @@ void spi_eeprom_probe(int x) { }
-int spi_eeprom_read(int x, int offset, char *buffer, int len) +int spi_eeprom_read(int x, int offset, uchar *buffer, int len) { return 0; }
-int spi_eeprom_write(int x, int offset, char *buffer, int len) +int spi_eeprom_write(int x, int offset, uchar *buffer, int len) { return 0; } diff --git a/drivers/mtd/mw_eeprom.c b/drivers/mtd/mw_eeprom.c index f32ced4..f7791b5 100644 --- a/drivers/mtd/mw_eeprom.c +++ b/drivers/mtd/mw_eeprom.c @@ -1,7 +1,7 @@ /* Three-wire (MicroWire) serial eeprom driver (for 93C46 and compatibles) */
#include <common.h> -#include <ssi.h> +#include <asm/ic/ssi.h>
/* * Serial EEPROM opcodes, including start bit diff --git a/examples/82559_eeprom.c b/examples/82559_eeprom.c index 1a121d4..d99af26 100644 --- a/examples/82559_eeprom.c +++ b/examples/82559_eeprom.c @@ -51,13 +51,17 @@ static inline unsigned short swap16(unsigned short x) }
-static inline void *memcpy(void *dst, const void *src, unsigned int len) +void * memcpy(void * dest,const void *src,size_t count) { - void * ret = dst; - while (len-- > 0) *((char *)dst)++ = *((char *)src)++; - return ret; + char *tmp = (char *) dest, *s = (char *) src; + + while (count--) + *tmp++ = *s++; + + return dest; }
+ /* The EEPROM commands include the alway-set leading bit. */ #define EE_WRITE_CMD (5) #define EE_READ_CMD (6) @@ -156,7 +160,7 @@ static int reset_eeprom(unsigned long ioaddr, unsigned char *hwaddr) int size_test; int i;
- printf("Resetting i82559 EEPROM @ 0x%08x ... ", ioaddr); + printf("Resetting i82559 EEPROM @ 0x%08lx ... ", ioaddr);
size_test = do_eeprom_cmd(ioaddr, (EE_READ_CMD << 8) << 16, 27); eeprom_addr_size = (size_test & 0xffe0000) == 0xffe0000 ? 8 : 6; @@ -305,7 +309,7 @@ write_config_word(int bus, int dev, int func, int reg, u16 data) int main (int argc, char *argv[]) { unsigned char *eth_addr; - char buf[6]; + uchar buf[6]; int instance;
app_startup(argv); diff --git a/include/asm-i386/byteorder.h b/include/asm-i386/byteorder.h index a9c69d5..7dfeb8b 100644 --- a/include/asm-i386/byteorder.h +++ b/include/asm-i386/byteorder.h @@ -6,7 +6,7 @@ #ifdef __GNUC__
-static __inline__ __const__ __u32 ___arch__swab32(__u32 x) +static __inline__ __u32 ___arch__swab32(__u32 x) { #ifdef CONFIG_X86_BSWAP __asm__("bswap %0" : "=r" (x) : "0" (x)); @@ -20,7 +20,7 @@ static __inline__ __const__ __u32 ___arch__swab32(__u32 x) return x; }
-static __inline__ __const__ __u16 ___arch__swab16(__u16 x) +static __inline__ __u16 ___arch__swab16(__u16 x) { __asm__("xchgb %b0,%h0" /* swap bytes */ \ : "=q" (x) \ diff --git a/include/asm-i386/global_data.h b/include/asm-i386/global_data.h index 5dfb595..f31bac6 100644 --- a/include/asm-i386/global_data.h +++ b/include/asm-i386/global_data.h @@ -58,8 +58,8 @@ typedef struct { #define GD_FLG_POSTSTOP 0x00010 /* POST seqeunce aborted */ #define GD_FLG_LOGINIT 0x00020 /* Log Buffer has been initialized */
-extern gd_t *global_data; +extern gd_t *gd;
-#define DECLARE_GLOBAL_DATA_PTR gd_t *gd = global_data +#define DECLARE_GLOBAL_DATA_PTR
#endif /* __ASM_GBL_DATA_H */ diff --git a/include/asm-i386/ic/ssi.h b/include/asm-i386/ic/ssi.h new file mode 100644 index 0000000..bd48eab --- /dev/null +++ b/include/asm-i386/ic/ssi.h @@ -0,0 +1,34 @@ +/* + * (C) Copyright 2008 + * Graeme Russ graeme.russ@gmail.com. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _ASM_IC_SSI_H_ +#define _ASM_IC_SSI_H_ 1 + +int ssi_set_interface(int, int, int, int); +void ssi_chip_select(int); +u8 ssi_txrx_byte(u8); +void ssi_tx_byte(u8); +u8 ssi_rx_byte(void); + + +#endif diff --git a/include/asm-i386/pci.h b/include/asm-i386/pci.h index bde9550..85f60d7 100644 --- a/include/asm-i386/pci.h +++ b/include/asm-i386/pci.h @@ -31,5 +31,4 @@ int pci_enable_legacy_video_ports(struct pci_controller* hose); int pci_shadow_rom(pci_dev_t dev, unsigned char *dest); void pci_remove_rom_window(struct pci_controller* hose, u32 addr); u32 pci_get_rom_window(struct pci_controller* hose, int size); - #endif diff --git a/include/asm-i386/string.h b/include/asm-i386/string.h index 91a23f9..3643a79 100644 --- a/include/asm-i386/string.h +++ b/include/asm-i386/string.h @@ -5,6 +5,8 @@ * We don't do inline string functions, since the * optimised inline asm versions are not small. */ +#undef __HAVE_ARCH_STRNCPY +extern char *strncpy(char *__dest, __const__ char *__src, __kernel_size_t __n);
#undef __HAVE_ARCH_STRRCHR extern char * strrchr(const char * s, int c); diff --git a/include/configs/sc520_cdp.h b/include/configs/sc520_cdp.h index e29655e..6a73c90 100644 --- a/include/configs/sc520_cdp.h +++ b/include/configs/sc520_cdp.h @@ -28,6 +28,7 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define GRUSS_TESTING /* * High Level Configuration Options * (easy to change) @@ -81,7 +82,11 @@ #include <config_cmd_default.h>
#define CONFIG_CMD_PCI +#ifndef GRUSS_TESTING #define CONFIG_CMD_SATA +#else +#undef CONFIG_CMD_SATA +#endif #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_NET #define CONFIG_CMD_EEPROM @@ -175,10 +180,18 @@ /************************************************************ *SATA/Native Stuff ************************************************************/ +#ifndef GRUSS_TESTING #define CFG_SATA_MAXBUS 2 /*Max Sata buses supported */ #define CFG_SATA_DEVS_PER_BUS 2 /*Max no. of devices per bus/port */ #define CFG_SATA_MAX_DEVICE (CFG_SATA_MAXBUS* CFG_SATA_DEVS_PER_BUS) #define CONFIG_ATA_PIIX 1 /*Supports ata_piix driver */ +#else +#undef CFG_SATA_MAXBUS +#undef CFG_SATA_DEVS_PER_BUS +#undef CFG_SATA_MAX_DEVICE +#undef CONFIG_ATA_PIIX +#endif +
/************************************************************ * DISK Partition support @@ -190,7 +203,11 @@ /************************************************************ * Video/Keyboard support ************************************************************/ +#ifndef GRUSS_TESTING #define CONFIG_VIDEO /* To enable video controller support */ +#else +#undef CONFIG_VIDEO +#endif #define CONFIG_I8042_KBD #define CFG_ISA_IO 0
@@ -203,6 +220,7 @@ /* * PCI stuff */ +#ifndef GRUSS_TESTING #define CONFIG_PCI /* include pci support */ #define CONFIG_PCI_PNP /* pci plug-and-play */ #define CONFIG_PCI_SCAN_SHOW @@ -211,5 +229,11 @@ #define CFG_SECOND_PCI_IRQ 9 #define CFG_THIRD_PCI_IRQ 11 #define CFG_FORTH_PCI_IRQ 15 +#else +#undef CONFIG_PCI +#undef CONFIG_PCI_PNP +#undef CONFIG_PCI_SCAN_SHOW +#endif +
#endif /* __CONFIG_H */ diff --git a/include/image.h b/include/image.h index 9be806e..e095a32 100644 --- a/include/image.h +++ b/include/image.h @@ -40,7 +40,7 @@ #include <lmb.h> #include <linux/string.h> #include <asm/u-boot.h> - +#include <asm/string.h> #else
/* new uImage format support enabled on host */ diff --git a/lib_i386/bios_setup.c b/lib_i386/bios_setup.c index 75f04a0..2018425 100644 --- a/lib_i386/bios_setup.c +++ b/lib_i386/bios_setup.c @@ -140,8 +140,9 @@ int bios_setup(void) { static int done=0; int vector; +#ifdef CONFIG_PCI struct pci_controller *pri_hose; - +#endif if (done) { return 0; } @@ -223,12 +224,13 @@ int bios_setup(void) * (This, ofcause break on multi hose systems, * but our PCI BIOS only support one hose anyway) */ +#ifdef CONFIG_PCI pri_hose = pci_bus_to_hose(0); if (NULL != pri_hose) { /* fill in last pci bus number for use by the realmode * PCI BIOS */ RELOC_16_BYTE(0xf000, pci_last_bus) = pri_hose->last_busno; } - +#endif return 0; } diff --git a/lib_i386/board.c b/lib_i386/board.c index 55fa42a..8103211 100644 --- a/lib_i386/board.c +++ b/lib_i386/board.c @@ -213,7 +213,7 @@ init_fnc_t *init_sequence[] = { NULL, };
-gd_t *global_data; +gd_t *gd;
void start_i386boot (void) { @@ -226,7 +226,7 @@ void start_i386boot (void)
show_boot_progress(0x21);
- gd = global_data = &gd_data; + gd = &gd_data; /* compiler optimization barrier needed for GCC >= 3.4 */ __asm__ __volatile__("": : :"memory");
@@ -266,7 +266,7 @@ void start_i386boot (void) int i; ulong reg; char *s, *e; - uchar tmp[64]; + char tmp[64];
i = getenv_r ("ethaddr", tmp, sizeof (tmp)); s = (i > 0) ? tmp : NULL; @@ -412,7 +412,10 @@ void hang (void) unsigned long do_go_exec (ulong (*entry)(int, char *[]), int argc, char *argv[]) { /* - * Nios function pointers are address >> 1 + * TODO: Test this function - changed to fix compiler error. + * Original code was: + * return (entry >> 1) (argc, argv); + * with a comment about Nios function pointers are address >> 1 */ - return (entry >> 1) (argc, argv); + return (entry) (argc, argv); } diff --git a/lib_i386/bootm.c b/lib_i386/bootm.c index 522d7ad..613e339 100644 --- a/lib_i386/bootm.c +++ b/lib_i386/bootm.c @@ -34,7 +34,7 @@ int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) void *base_ptr; ulong os_data, os_len; image_header_t *hdr; - int ret; + #if defined(CONFIG_FIT) const void *data; size_t len; diff --git a/lib_i386/video_bios.c b/lib_i386/video_bios.c index 45f78e2..02c2166 100644 --- a/lib_i386/video_bios.c +++ b/lib_i386/video_bios.c @@ -136,6 +136,8 @@ static u32 probe_pci_video(void)
#endif
+#ifdef CONFIG_VIDEO + static int probe_isa_video(void) { u32 ptr; @@ -217,3 +219,4 @@ int video_bios_init(void) return 1;
} +#endif
Graeme Russ
