[U-Boot] [PATCH] common: cli_simple: use strncpy instead of strcpy
Report Coverity log: Destination buffer too small (STRING_OVERFLOW) string_overflow: You might overrun the 1024 byte destination string lastcommand by writing 1025 bytes from console_buffer
Signed-off-by: Peng Fan van.freenix@gmail.com Cc: Heiko Schocher hs@denx.de Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- common/cli_simple.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/common/cli_simple.c b/common/cli_simple.c index 9c3d073..c51f963 100644 --- a/common/cli_simple.c +++ b/common/cli_simple.c @@ -276,7 +276,8 @@ void cli_simple_loop(void)
flag = 0; /* assume no special flags for now */ if (len > 0) - strcpy(lastcommand, console_buffer); + strncpy(lastcommand, console_buffer, + CONFIG_SYS_CBSIZE + 1); else if (len == 0) flag |= CMD_FLAG_REPEAT; #ifdef CONFIG_BOOT_RETRY_TIME
else if (len == 0) flag |= CMD_FLAG_REPEAT;CONFIG_SYS_CBSIZE + 1);
So, long term I would like to see use move to using strlcpy for the normal case (it might not make sense when working with various defined protocols, etc). Thanks!
Thanks. Just read this, https://www.sudo.ws/todd/papers/strlcpy.html. strlcpy is a better choice.
Thanks, Peng.
-- Tom
Peng Fan
