[U-Boot] [PATCH] spi: ignore set speed and mode if not available
Some cores, such as Altera SPI and QuadSPI, can not change speed and mode at runtime. Ignore the operation which is not available.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- drivers/spi/spi-uclass.c | 6 +----- 1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/drivers/spi/spi-uclass.c b/drivers/spi/spi-uclass.c index d666272..5298073 100644 --- a/drivers/spi/spi-uclass.c +++ b/drivers/spi/spi-uclass.c @@ -21,13 +21,11 @@ DECLARE_GLOBAL_DATA_PTR; static int spi_set_speed_mode(struct udevice *bus, int speed, int mode) { struct dm_spi_ops *ops; - int ret; + int ret = 0;
ops = spi_get_ops(bus); if (ops->set_speed) ret = ops->set_speed(bus, speed); - else - ret = -EINVAL; if (ret) { printf("Cannot set speed (err=%d)\n", ret); return ret; @@ -35,8 +33,6 @@ static int spi_set_speed_mode(struct udevice *bus, int speed, int mode)
if (ops->set_mode) ret = ops->set_mode(bus, mode); - else - ret = -EINVAL; if (ret) { printf("Cannot set mode (err=%d)\n", ret); return ret;
Acked-by: Marek Vasut marex@denx.de
Thanks!
Best regards, Marek Vasut
Reviewed-by: Jagan Teki jteki@openedev.com
Pick this one as well.
-- Jagan.
Hi Thomas,
This looks OK, but can you please update the method documentation for set_speed() and set_mode() to indicate that they are optional in the case where the hardware does not support it.
Please add a comment to this function indicated that missing set_speed() and set_mode() methods are OK.
int ret;
int ret = 0; ops = spi_get_ops(bus); if (ops->set_speed) ret = ops->set_speed(bus, speed);
else
else
-- 2.1.4
Hi Simon,
On 10/03/2015 10:28 PM, Simon Glass wrote:
Hi Thomas,
Thanks a lot for your review. The comments will be added.
Best regards, Thomas Chou
Signed-off-by: Thomas Chou thomas@wytron.com.tw Acked-by: Marek Vasut marex@denx.de Reviewed-by: Jagan Teki jteki@openedev.com --- v2 add comments as Simon sugggested.
drivers/spi/spi-uclass.c | 7 ++----- include/spi.h | 5 +++++ 2 files changed, 7 insertions(+), 5 deletions(-)
diff --git a/drivers/spi/spi-uclass.c b/drivers/spi/spi-uclass.c index d666272..50e3553 100644 --- a/drivers/spi/spi-uclass.c +++ b/drivers/spi/spi-uclass.c @@ -21,13 +21,12 @@ DECLARE_GLOBAL_DATA_PTR; static int spi_set_speed_mode(struct udevice *bus, int speed, int mode) { struct dm_spi_ops *ops; - int ret; + int ret = 0;
ops = spi_get_ops(bus); + /* missing get_speed() and set_mode() methods are OK */ if (ops->set_speed) ret = ops->set_speed(bus, speed); - else - ret = -EINVAL; if (ret) { printf("Cannot set speed (err=%d)\n", ret); return ret; @@ -35,8 +34,6 @@ static int spi_set_speed_mode(struct udevice *bus, int speed, int mode)
if (ops->set_mode) ret = ops->set_mode(bus, mode); - else - ret = -EINVAL; if (ret) { printf("Cannot set mode (err=%d)\n", ret); return ret; diff --git a/include/spi.h b/include/spi.h index 51fdfd6..a418509 100644 --- a/include/spi.h +++ b/include/spi.h @@ -451,6 +451,9 @@ struct dm_spi_ops { /** * Set transfer speed. * This sets a new speed to be applied for next spi_xfer(). + * + * It is optional in the case where the hardware does not support it. + * * @bus: The SPI bus * @hz: The transfer speed * @return 0 if OK, -ve on error @@ -463,6 +466,8 @@ struct dm_spi_ops { * It is unclear if we want to set speed and mode together instead * of separately. * + * It is optional in the case where the hardware does not support it. + * * @bus: The SPI bus * @mode: Requested SPI mode (SPI_... flags) * @return 0 if OK, -ve on error
Jagan Teki
Thomas Chou
