[U-Boot] [RESEND PATCH v2 0/6] MIPS Boston updates and fixes
This series is a resend of selected MIPS Boston updates/fixes from the original patch series [1] which was blocked by rejected PCI core changes and the series for converting CONFIG_SYS_SDRAM_BASE on MIPS from a virtual address to a physical one. At least the patches not affected by the blocking patch series should be finally applied.
[1] https://lists.denx.de/pipermail/u-boot/2016-September/268137.html
Changes in v2: - also patch ARM specific code to get a consistent behaviour - move to menu "General setup" - set default value for Boston in arch/mips/Kconfig - rebased to current mainline - rebased to current mainline
Paul Burton (6): image: Use ram_top, not bi_memsize, in getenv_bootm_size MIPS: Make CM GCR base configurable boston: Move CM GCRs away from flash boston: Setup memory ranges in FDT provided to Linux boston: Bump CONFIG_SYS_BOOTM_LEN to 64MiB boston: Enable CONFIG_DISTRO_DEFAULTS in defconfigs
arch/mips/Kconfig | 21 ++++++++++++--------- board/imgtec/boston/Makefile | 1 + board/imgtec/boston/dt.c | 27 +++++++++++++++++++++++++++ common/image.c | 3 +-- configs/boston32r2_defconfig | 7 +------ configs/boston32r2el_defconfig | 7 +------ configs/boston64r2_defconfig | 7 +------ configs/boston64r2el_defconfig | 7 +------ include/configs/boston.h | 5 +++++ 9 files changed, 50 insertions(+), 35 deletions(-) create mode 100644 board/imgtec/boston/dt.c
When determining the region of memory to allow for use by bootm, using bi_memstart & adding bi_memsize can cause problems if that leads to an integer overflow. For example on some MIPS systems bi_memstart would be 0xffffffff80000000 (ie. the start of the MIPS ckseg0 region) and if the system has 2GB of memory then the addition would wrap around to 0.
The maximum amount of memory to be used by U-Boot is already accounted for by the ram_top field of struct global_data, so make use of that for the calculation instead.
Signed-off-by: Paul Burton paul.burton@imgtec.com Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
common/image.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/common/image.c b/common/image.c index 0f88984f2d..160c4c6fbc 100644 --- a/common/image.c +++ b/common/image.c @@ -494,11 +494,10 @@ phys_size_t getenv_bootm_size(void)
#if defined(CONFIG_ARM) && defined(CONFIG_NR_DRAM_BANKS) start = gd->bd->bi_dram[0].start; - size = gd->bd->bi_dram[0].size; #else start = gd->bd->bi_memstart; - size = gd->bd->bi_memsize; #endif + size = gd->ram_top - start;
s = getenv("bootm_low"); if (s)
Hi Daniel,
On 30 April 2017 at 13:22, Daniel Schwierzeck daniel.schwierzeck@gmail.com wrote:
Changes in v2:
#endif
I'm a little nervous about this change. For ARM we might have discontinuous DRAM segments. Can you not set bd->bi_memsize insead?
-- 2.11.0
Am 04.05.2017 um 18:49 schrieb Simon Glass:
Hi Daniel,
Changes in v2:
#endif
after reviewing again I think this patch is wrong. Maybe we have to fix the MIPS specific problem instead, where CONFIG_SYS_SDRAM_BASE is used as a virtual address instead of a physical one. Actually this causes the wrap around. Thus I withdraw this patch.
Without adding a prompt for CONFIG_MIPS_CM_BASE, Kconfig doesn't allow defconfigs to set it. Provide the prompt in order to allow for that.
Changes in v2: - move to menu "General setup"
arch/mips/Kconfig | 19 ++++++++++--------- 1 file changed, 10 insertions(+), 9 deletions(-)
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index c97ea4156b..77d1ac65d2 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -221,6 +221,16 @@ config ROM_EXCEPTION_VECTORS Disable this, if the U-Boot image is booted from DRAM (e.g. by SPL). In that case the image size will be reduced by 0x500 bytes.
+config MIPS_CM_BASE + hex "MIPS CM GCR Base Address" + depends on MIPS_CM + default 0x1fbf8000 + help + The physical base address at which to map the MIPS Coherence Manager + Global Configuration Registers (GCRs). This should be set such that + the GCRs occupy a region of the physical address space which is + otherwise unused, or at minimum that software doesn't need to access. + endmenu
menu "OS boot interface" @@ -393,15 +403,6 @@ config MIPS_CM wish U-Boot to configure it or make use of it to retrieve system information such as cache configuration.
-config MIPS_CM_BASE - hex - default 0x1fbf8000 - help - The physical base address at which to map the MIPS Coherence Manager - Global Configuration Registers (GCRs). This should be set such that - the GCRs occupy a region of the physical address space which is - otherwise unused, or at minimum that software doesn't need to access. - endif
endmenu
Changes in v2:
Signed-off-by: Paul Burton paul.burton@imgtec.com Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com Reviewed-by: Simon Glass sjg@chromium.org
Changes in v3: - fix build error if CONFIG_MIPS_CM is not selected
arch/mips/Kconfig | 19 ++++++++++--------- arch/mips/lib/cache.c | 2 ++ 2 files changed, 12 insertions(+), 9 deletions(-)
endmenu diff --git a/arch/mips/lib/cache.c b/arch/mips/lib/cache.c index bd14ba6ea7..91b037f87d 100644 --- a/arch/mips/lib/cache.c +++ b/arch/mips/lib/cache.c @@ -7,7 +7,9 @@
#include <common.h> #include <asm/cacheops.h> +#ifdef CONFIG_MIPS_L2_CACHE #include <asm/cm.h> +#endif #include <asm/mipsregs.h>
DECLARE_GLOBAL_DATA_PTR;
Am 12.05.2017 um 13:26 schrieb Daniel Schwierzeck:
Changes in v3:
Changes in v2:
applied to u-boot-mips/master, thanks.
Move the MIPS Coherence Manager (CM) Global Configuration Registers (GCRs) away from the region of the physical address space which the Boston board's parallel flash is found in, such that we can access all of flash without clobbering GCRs.
Changes in v2: - set default value for Boston in arch/mips/Kconfig
arch/mips/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 77d1ac65d2..07488fe651 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -224,6 +224,7 @@ config ROM_EXCEPTION_VECTORS config MIPS_CM_BASE hex "MIPS CM GCR Base Address" depends on MIPS_CM + default 0x16100000 if TARGET_BOSTON default 0x1fbf8000 help The physical base address at which to map the MIPS Coherence Manager
Changes in v2:
Am 30.04.2017 um 21:22 schrieb Daniel Schwierzeck:
Changes in v2:
The boston memory map isn't suited to the simple "all memory starting from 0" approach that the MIPS arch_fixup_fdt() implementation takes. Instead we need to indicate the first 256MiB of DDR from 0 and the rest from 0x90000000. Implement ft_board_setup to do that.
Signed-off-by: Paul Burton paul.burton@imgtec.com Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com ---
Changes in v2: None
arch/mips/Kconfig | 1 + board/imgtec/boston/Makefile | 1 + board/imgtec/boston/dt.c | 27 +++++++++++++++++++++++++++ 3 files changed, 29 insertions(+) create mode 100644 board/imgtec/boston/dt.c
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 07488fe651..d07b92d1b4 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -97,6 +97,7 @@ config TARGET_BOSTON select MIPS_CM select MIPS_L1_CACHE_SHIFT_6 select MIPS_L2_CACHE + select OF_BOARD_SETUP select SUPPORTS_BIG_ENDIAN select SUPPORTS_LITTLE_ENDIAN select SUPPORTS_CPU_MIPS32_R1 diff --git a/board/imgtec/boston/Makefile b/board/imgtec/boston/Makefile index deda457f3c..d3fd49d285 100644 --- a/board/imgtec/boston/Makefile +++ b/board/imgtec/boston/Makefile @@ -6,4 +6,5 @@
obj-y += checkboard.o obj-y += ddr.o +obj-y += dt.o obj-y += lowlevel_init.o diff --git a/board/imgtec/boston/dt.c b/board/imgtec/boston/dt.c new file mode 100644 index 0000000000..b34f9bc205 --- /dev/null +++ b/board/imgtec/boston/dt.c @@ -0,0 +1,27 @@ +/* + * Copyright (C) 2016 Imagination Technologies + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <fdt_support.h> + +int ft_board_setup(void *blob, bd_t *bd) +{ + DECLARE_GLOBAL_DATA_PTR; + u64 mem_start[2], mem_size[2]; + int mem_regions; + + mem_start[0] = 0; + mem_size[0] = min_t(u64, 256llu << 20, gd->ram_size); + mem_regions = 1; + + if (gd->ram_size > mem_size[0]) { + mem_start[1] = 0x80000000 + mem_size[0]; + mem_size[1] = gd->ram_size - mem_size[0]; + mem_regions++; + } + + return fdt_fixup_memory_banks(blob, mem_start, mem_size, mem_regions); +}
Changes in v2: None
Changes in v2: None
The default value of CONFIG_SYS_BOOTM_LEN is too small for typical boston Linux kernels. Increase the limit to 64MB, which covers current kernels with plenty of breathing room.
Changes in v2: - rebased to current mainline
include/configs/boston.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/include/configs/boston.h b/include/configs/boston.h index 1915ad5249..50aaa7be8c 100644 --- a/include/configs/boston.h +++ b/include/configs/boston.h @@ -8,6 +8,11 @@ #define __CONFIGS_BOSTON_H__
/* + * General board configuration + */ +#define CONFIG_SYS_BOOTM_LEN (64 * 1024 * 1024) + +/* * CPU */ #define CONFIG_SYS_MIPS_TIMER_FREQ 30000000
Changes in v2:
Changes in v2:
CONFIG_DISTRO_DEFAULTS selects a number of things we want for Boston defconfigs & generally describes what we want - to be able to boot an arbitrary Linux distribution. Enable it in order to shorten the defconfigs & to automatically keep up with any changes in the choice of Kconfig symbols selected.
configs/boston32r2_defconfig | 7 +------ configs/boston32r2el_defconfig | 7 +------ configs/boston64r2_defconfig | 7 +------ configs/boston64r2el_defconfig | 7 +------ 4 files changed, 4 insertions(+), 24 deletions(-)
diff --git a/configs/boston32r2_defconfig b/configs/boston32r2_defconfig index 05095bf160..6d93edc358 100644 --- a/configs/boston32r2_defconfig +++ b/configs/boston32r2_defconfig @@ -4,11 +4,11 @@ CONFIG_TARGET_BOSTON=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y CONFIG_DEFAULT_DEVICE_TREE="img,boston" +CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_BEST_MATCH=y CONFIG_OF_STDOUT_VIA_ALIAS=y -CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="boston # " # CONFIG_CMD_ELF is not set # CONFIG_CMD_IMLS is not set @@ -17,16 +17,11 @@ CONFIG_CMD_MEMTEST=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y CONFIG_CMD_LINK_LOCAL=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y # CONFIG_DOS_PARTITION is not set # CONFIG_ISO_PARTITION is not set CONFIG_OF_EMBED=y diff --git a/configs/boston32r2el_defconfig b/configs/boston32r2el_defconfig index 244c688c5f..9e494eee10 100644 --- a/configs/boston32r2el_defconfig +++ b/configs/boston32r2el_defconfig @@ -5,11 +5,11 @@ CONFIG_SYS_LITTLE_ENDIAN=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y CONFIG_DEFAULT_DEVICE_TREE="img,boston" +CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_BEST_MATCH=y CONFIG_OF_STDOUT_VIA_ALIAS=y -CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="boston # " # CONFIG_CMD_ELF is not set # CONFIG_CMD_IMLS is not set @@ -18,16 +18,11 @@ CONFIG_CMD_MEMTEST=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y CONFIG_CMD_LINK_LOCAL=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y # CONFIG_DOS_PARTITION is not set # CONFIG_ISO_PARTITION is not set CONFIG_OF_EMBED=y diff --git a/configs/boston64r2_defconfig b/configs/boston64r2_defconfig index 8cc0bee44c..6913d2ba62 100644 --- a/configs/boston64r2_defconfig +++ b/configs/boston64r2_defconfig @@ -5,11 +5,11 @@ CONFIG_CPU_MIPS64_R2=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y CONFIG_DEFAULT_DEVICE_TREE="img,boston" +CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_BEST_MATCH=y CONFIG_OF_STDOUT_VIA_ALIAS=y -CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="boston # " # CONFIG_CMD_ELF is not set # CONFIG_CMD_IMLS is not set @@ -18,16 +18,11 @@ CONFIG_CMD_MEMTEST=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y CONFIG_CMD_LINK_LOCAL=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y # CONFIG_DOS_PARTITION is not set # CONFIG_ISO_PARTITION is not set CONFIG_OF_EMBED=y diff --git a/configs/boston64r2el_defconfig b/configs/boston64r2el_defconfig index c427d43091..10ccc5427c 100644 --- a/configs/boston64r2el_defconfig +++ b/configs/boston64r2el_defconfig @@ -6,11 +6,11 @@ CONFIG_CPU_MIPS64_R2=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y CONFIG_DEFAULT_DEVICE_TREE="img,boston" +CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_BEST_MATCH=y CONFIG_OF_STDOUT_VIA_ALIAS=y -CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="boston # " # CONFIG_CMD_ELF is not set # CONFIG_CMD_IMLS is not set @@ -19,16 +19,11 @@ CONFIG_CMD_MEMTEST=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y CONFIG_CMD_LINK_LOCAL=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y # CONFIG_DOS_PARTITION is not set # CONFIG_ISO_PARTITION is not set CONFIG_OF_EMBED=y
Changes in v2:
Changes in v2:
Daniel Schwierzeck
