[U-Boot] [PATCH v2 0/3] Add Avenger96 board support
Hello,
This patchset adds board support for Avenger96, a 96Boards Consumer Edition board from Arrow Electronics. This board is based on the STM32MP1 MPU and the board support is added under st boards since there are no significance changes required to boot u-boot on this board other than the dts.
More information about this board can be found in 96Boards website: https://www.96boards.org/product/avenger96/
Thanks, Mani
Changes in v2:
* Added missing `u-boot,dm-pre-reloc` property to UART and SDMMC nodes and verified SPL boot.
Manivannan Sadhasivam (3): arm: dts: stm32mp157: Add missing pinctrl definitions board: stm32mp1: Add Avenger96 board support arm: mach-stm32mp: Add newline to the MAC error message
arch/arm/dts/Makefile | 1 + arch/arm/dts/stm32mp157-pinctrl.dtsi | 63 +++ .../arm/dts/stm32mp157a-avenger96-u-boot.dtsi | 191 +++++++++ arch/arm/dts/stm32mp157a-avenger96.dts | 362 ++++++++++++++++++ arch/arm/mach-stm32mp/cpu.c | 2 +- board/st/stm32mp1/README | 23 ++ 6 files changed, 641 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/stm32mp157a-avenger96-u-boot.dtsi create mode 100644 arch/arm/dts/stm32mp157a-avenger96.dts
Add missing pinctrl definitions for STM32MP157.
Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org --- arch/arm/dts/stm32mp157-pinctrl.dtsi | 63 ++++++++++++++++++++++++++++ 1 file changed, 63 insertions(+)
diff --git a/arch/arm/dts/stm32mp157-pinctrl.dtsi b/arch/arm/dts/stm32mp157-pinctrl.dtsi index 0aae69b0a04..200d2c00c5f 100644 --- a/arch/arm/dts/stm32mp157-pinctrl.dtsi +++ b/arch/arm/dts/stm32mp157-pinctrl.dtsi @@ -220,6 +220,16 @@ }; };
+ i2c1_pins_b: i2c1-1 { + pins { + pinmux = <STM32_PINMUX('F', 14, AF5)>, /* I2C1_SCL */ + <STM32_PINMUX('F', 15, AF5)>; /* I2C1_SDA */ + bias-disable; + drive-open-drain; + slew-rate = <0>; + }; + }; + i2c2_pins_a: i2c2-0 { pins { pinmux = <STM32_PINMUX('H', 4, AF4)>, /* I2C2_SCL */ @@ -230,6 +240,16 @@ }; };
+ i2c2_pins_b: i2c2-1 { + pins { + pinmux = <STM32_PINMUX('Z', 0, AF3)>, /* I2C2_SCL */ + <STM32_PINMUX('H', 5, AF4)>; /* I2C2_SDA */ + bias-disable; + drive-open-drain; + slew-rate = <0>; + }; + }; + i2c5_pins_a: i2c5-0 { pins { pinmux = <STM32_PINMUX('A', 11, AF4)>, /* I2C5_SCL */ @@ -375,6 +395,21 @@ }; };
+ spi2_pins_a: spi2-0 { + pins1 { + pinmux = <STM32_PINMUX('B', 10, AF5)>, /* SPI2_SCK */ + <STM32_PINMUX('I', 0, AF5)>, /* SPI2_NSS */ + <STM32_PINMUX('I', 3, AF5)>; /* SPI2_MOSI */ + bias-disable; + drive-push-pull; + slew-rate = <3>; + }; + pins2 { + pinmux = <STM32_PINMUX('I', 2, AF5)>; /* SPI2_MISO */ + bias-disable; + }; + }; + stusb1600_pins_a: stusb1600-0 { pins { pinmux = <STM32_PINMUX('I', 11, ANALOG)>; @@ -395,6 +430,34 @@ }; };
+ uart4_pins_b: uart4-1 { + pins1 { + pinmux = <STM32_PINMUX('D', 1, AF8)>; /* UART4_TX */ + bias-disable; + drive-push-pull; + slew-rate = <0>; + }; + pins2 { + pinmux = <STM32_PINMUX('B', 2, AF8)>; /* UART4_RX */ + bias-disable; + }; + }; + + uart7_pins_a: uart7-0 { + pins1 { + pinmux = <STM32_PINMUX('E', 8, AF7)>; /* UART4_TX */ + bias-disable; + drive-push-pull; + slew-rate = <0>; + }; + pins2 { + pinmux = <STM32_PINMUX('E', 7, AF7)>, /* UART4_RX */ + <STM32_PINMUX('E', 10, AF7)>, /* UART4_CTS */ + <STM32_PINMUX('E', 9, AF7)>; /* UART4_RTS */ + bias-disable; + }; + }; + usbotg_hs_pins_a: usbotg_hs-0 { pins { pinmux = <STM32_PINMUX('A', 10, ANALOG)>; /* OTG_ID */
pins {
bias-disable;
drive-open-drain;
slew-rate = <0>;
pins {
bias-disable;
drive-open-drain;
slew-rate = <0>;
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <3>;
pins2 {
bias-disable;
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins2 {
bias-disable;
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins2 {
bias-disable;
Reviewed-by: Patrice Chotard patrice.chotard@st.com
Thanks
Hi Manivannan,
Reviewed-by: Patrick Delaunay patrick.delaunay@st.com
Thanks
diff --git a/arch/arm/dts/stm32mp157-pinctrl.dtsi b/arch/arm/dts/stm32mp157- pinctrl.dtsi index 0aae69b0a04..200d2c00c5f 100644 --- a/arch/arm/dts/stm32mp157-pinctrl.dtsi +++ b/arch/arm/dts/stm32mp157-pinctrl.dtsi @@ -220,6 +220,16 @@ }; };
pins {
/* I2C1_SDA */
bias-disable;
drive-open-drain;
slew-rate = <0>;
pins {
/* I2C2_SCL */
/* I2C2_SDA */
bias-disable;
drive-open-drain;
slew-rate = <0>;
pins1 {
SPI2_NSS */
SPI2_MOSI */
bias-disable;
drive-push-pull;
slew-rate = <3>;
pins2 {
/* SPI2_MISO */
bias-disable;
pins1 {
/* UART4_TX */
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins2 {
/* UART4_RX */
bias-disable;
pins1 {
/* UART4_TX */
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins2 {
/* UART4_RX */
/* UART4_CTS */
UART4_RTS */
bias-disable;
2.17.1
pins {
bias-disable;
drive-open-drain;
slew-rate = <0>;
pins {
bias-disable;
drive-open-drain;
slew-rate = <0>;
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <3>;
pins2 {
bias-disable;
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins2 {
bias-disable;
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins2 {
bias-disable;
Applied
Thanks
Add support for Avenger96 board from Arrow Electronics based on STM32MP157 MPU. This board is one of the Consumer Edition (CE) boards of the 96Boards family and has the following features:
SoC: STM32MP157AAC PMIC: STPMIC1A RAM: 1024 Mbyte @ 533MHz Storage: eMMC v4.51: 8 Gbyte microSD Socket: UHS-1 v3.01 Ethernet Port: 10/100/1000 Mbit/s, IEEE 802.3 Compliant Wireless: WiFi 5 GHz & 2.4GHz IEEE 802.11a/b/g/n/ac Bluetooth®v4.2 (BR/EDR/BLE) USB: 2x Type A (USB 2.0) Host and 1x Micro B (USB 2.0) OTG Display: HDMI: WXGA (1366x768)@ 60 fps, HDMI 1.4 LED: 4x User LED, 1x WiFi LED, 1x BT LED
Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org --- arch/arm/dts/Makefile | 1 + .../arm/dts/stm32mp157a-avenger96-u-boot.dtsi | 191 +++++++++ arch/arm/dts/stm32mp157a-avenger96.dts | 362 ++++++++++++++++++ board/st/stm32mp1/README | 23 ++ 4 files changed, 577 insertions(+) create mode 100644 arch/arm/dts/stm32mp157a-avenger96-u-boot.dtsi create mode 100644 arch/arm/dts/stm32mp157a-avenger96.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index b4dc57edbd1..97a182f3abc 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -711,6 +711,7 @@ dtb-$(CONFIG_ARCH_STI) += stih410-b2260.dtb
dtb-$(CONFIG_TARGET_STM32MP1) += \ stm32mp157a-dk1.dtb \ + stm32mp157a-avenger96.dtb \ stm32mp157c-dk2.dtb \ stm32mp157c-ed1.dtb \ stm32mp157c-ev1.dtb diff --git a/arch/arm/dts/stm32mp157a-avenger96-u-boot.dtsi b/arch/arm/dts/stm32mp157a-avenger96-u-boot.dtsi new file mode 100644 index 00000000000..1ff681afb87 --- /dev/null +++ b/arch/arm/dts/stm32mp157a-avenger96-u-boot.dtsi @@ -0,0 +1,191 @@ +// SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) +/* + * Copyright : STMicroelectronics 2018 + * + * Copyright (C) Linaro Ltd 2019 - All Rights Reserved + * Author: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + */ + +#include <dt-bindings/clock/stm32mp1-clksrc.h> +#include "stm32mp157-u-boot.dtsi" +#include "stm32mp15-ddr3-2x4Gb-1066-binG.dtsi" + +/ { + aliases { + mmc0 = &sdmmc1; + mmc1 = &sdmmc2; + usb0 = &usbotg_hs; + }; + + config { + u-boot,boot-led = "led1"; + u-boot,error-led = "led4"; + }; +}; + +&i2c4 { + u-boot,dm-pre-reloc; +}; + +&i2c4_pins_a { + u-boot,dm-pre-reloc; + pins { + u-boot,dm-pre-reloc; + }; +}; + +&pmic { + u-boot,dm-pre-reloc; +}; + +&rcc { + st,clksrc = < + CLK_MPU_PLL1P + CLK_AXI_PLL2P + CLK_MCU_PLL3P + CLK_PLL12_HSE + CLK_PLL3_HSE + CLK_PLL4_HSE + CLK_RTC_LSE + CLK_MCO1_DISABLED + CLK_MCO2_DISABLED + >; + + st,clkdiv = < + 1 /*MPU*/ + 0 /*AXI*/ + 0 /*MCU*/ + 1 /*APB1*/ + 1 /*APB2*/ + 1 /*APB3*/ + 1 /*APB4*/ + 2 /*APB5*/ + 23 /*RTC*/ + 0 /*MCO1*/ + 0 /*MCO2*/ + >; + + st,pkcs = < + CLK_CKPER_HSE + CLK_FMC_ACLK + CLK_QSPI_ACLK + CLK_ETH_DISABLED + CLK_SDMMC12_PLL4P + CLK_DSI_DSIPLL + CLK_STGEN_HSE + CLK_USBPHY_HSE + CLK_SPI2S1_PLL3Q + CLK_SPI2S23_PLL3Q + CLK_SPI45_HSI + CLK_SPI6_HSI + CLK_I2C46_HSI + CLK_SDMMC3_PLL4P + CLK_USBO_USBPHY + CLK_ADC_CKPER + CLK_CEC_LSE + CLK_I2C12_HSI + CLK_I2C35_HSI + CLK_UART1_HSI + CLK_UART24_HSI + CLK_UART35_HSI + CLK_UART6_HSI + CLK_UART78_HSI + CLK_SPDIF_PLL4P + CLK_FDCAN_PLL4Q + CLK_SAI1_PLL3Q + CLK_SAI2_PLL3Q + CLK_SAI3_PLL3Q + CLK_SAI4_PLL3Q + CLK_RNG1_LSI + CLK_RNG2_LSI + CLK_LPTIM1_PCLK1 + CLK_LPTIM23_PCLK3 + CLK_LPTIM45_LSE + >; + + /* VCO = 1300.0 MHz => P = 650 (CPU) */ + pll1: st,pll@0 { + cfg = < 2 80 0 0 0 PQR(1,0,0) >; + frac = < 0x800 >; + u-boot,dm-pre-reloc; + }; + + /* VCO = 1066.0 MHz => P = 266 (AXI), Q = 533 (GPU), R = 533 (DDR) */ + pll2: st,pll@1 { + cfg = < 2 65 1 0 0 PQR(1,1,1) >; + frac = < 0x1400 >; + u-boot,dm-pre-reloc; + }; + + /* VCO = 417.8 MHz => P = 209, Q = 24, R = 11 */ + pll3: st,pll@2 { + cfg = < 1 33 1 16 36 PQR(1,1,1) >; + frac = < 0x1a04 >; + u-boot,dm-pre-reloc; + }; + + /* VCO = 480.0 MHz => P = 120, Q = 40, R = 96 */ + pll4: st,pll@3 { + cfg = < 1 39 3 11 4 PQR(1,1,1) >; + u-boot,dm-pre-reloc; + }; +}; + +&sdmmc1 { + u-boot,dm-spl; +}; + +&sdmmc1_b4_pins_a { + u-boot,dm-spl; + pins { + u-boot,dm-spl; + }; +}; + +&sdmmc1_dir_pins_a { + u-boot,dm-spl; + pins { + u-boot,dm-spl; + }; +}; + +&sdmmc2 { + u-boot,dm-spl; +}; + +&sdmmc2_b4_pins_a { + u-boot,dm-spl; + pins { + u-boot,dm-spl; + }; +}; + +&sdmmc2_d47_pins_a { + u-boot,dm-spl; + pins { + u-boot,dm-spl; + }; +}; + +&uart4 { + u-boot,dm-pre-reloc; +}; + +&uart4_pins_b { + u-boot,dm-pre-reloc; + pins1 { + u-boot,dm-pre-reloc; + }; + pins2 { + u-boot,dm-pre-reloc; + }; +}; + +&usbotg_hs { + u-boot,force-b-session-valid; + hnp-srp-disable; +}; + +&v3v3 { + regulator-always-on; +}; diff --git a/arch/arm/dts/stm32mp157a-avenger96.dts b/arch/arm/dts/stm32mp157a-avenger96.dts new file mode 100644 index 00000000000..dd0859769bf --- /dev/null +++ b/arch/arm/dts/stm32mp157a-avenger96.dts @@ -0,0 +1,362 @@ +// SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) +/* + * Copyright (C) STMicroelectronics 2019 - All Rights Reserved + * Author: Alexandre Torgue alexandre.torgue@st.com for STMicroelectronics. + * + * Copyright (C) Linaro Ltd 2019 - All Rights Reserved + * Author: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + */ + +/dts-v1/; + +#include "stm32mp157c.dtsi" +#include "stm32mp157-pinctrl.dtsi" +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/mfd/st,stpmic1.h> + +/ { + model = "Arrow Electronics STM32MP157A Avenger96 board"; + compatible = "st,stm32mp157a-avenger96", "st,stm32mp157"; + + aliases { + ethernet0 = ðernet0; + serial0 = &uart4; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory@c0000000 { + reg = <0xc0000000 0x40000000>; + }; + + led { + compatible = "gpio-leds"; + led1 { + label = "green:user1"; + gpios = <&gpioz 7 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + default-state = "off"; + }; + + led2 { + label = "green:user2"; + gpios = <&gpiof 3 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc0"; + default-state = "off"; + }; + + led3 { + label = "green:user3"; + gpios = <&gpiog 0 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc1"; + default-state = "off"; + }; + + led4 { + label = "green:user3"; + gpios = <&gpiog 1 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "none"; + default-state = "off"; + panic-indicator; + }; + + led5 { + label = "yellow:wifi"; + gpios = <&gpioz 3 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "phy0tx"; + default-state = "off"; + }; + + led6 { + label = "blue:bt"; + gpios = <&gpioz 6 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "bluetooth-power"; + default-state = "off"; + }; + }; +}; + +ðernet0 { + status = "okay"; + pinctrl-0 = <ðernet0_rgmii_pins_a>; + pinctrl-1 = <ðernet0_rgmii_pins_sleep_a>; + pinctrl-names = "default", "sleep"; + phy-mode = "rgmii"; + max-speed = <1000>; + phy-handle = <&phy0>; + + mdio0 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dwmac-mdio"; + phy0: ethernet-phy@7 { + reg = <7>; + }; + }; +}; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins_b>; + i2c-scl-rising-time-ns = <185>; + i2c-scl-falling-time-ns = <20>; + status = "okay"; + /delete-property/dmas; + /delete-property/dma-names; +}; + +&i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_pins_b>; + i2c-scl-rising-time-ns = <185>; + i2c-scl-falling-time-ns = <20>; + status = "okay"; + /delete-property/dmas; + /delete-property/dma-names; +}; + +&i2c4 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c4_pins_a>; + i2c-scl-rising-time-ns = <185>; + i2c-scl-falling-time-ns = <20>; + status = "okay"; + /delete-property/dmas; + /delete-property/dma-names; + + pmic: stpmic@33 { + compatible = "st,stpmic1"; + reg = <0x33>; + interrupts-extended = <&exti 55 IRQ_TYPE_EDGE_FALLING>; + interrupt-controller; + #interrupt-cells = <2>; + status = "okay"; + + st,main-control-register = <0x04>; + st,vin-control-register = <0xc0>; + st,usb-control-register = <0x30>; + + regulators { + compatible = "st,stpmic1-regulators"; + + ldo1-supply = <&v3v3>; + ldo2-supply = <&v3v3>; + ldo3-supply = <&vdd_ddr>; + ldo5-supply = <&v3v3>; + ldo6-supply = <&v3v3>; + pwr_sw1-supply = <&bst_out>; + pwr_sw2-supply = <&bst_out>; + + vddcore: buck1 { + regulator-name = "vddcore"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-initial-mode = <2>; + regulator-over-current-protection; + }; + + vdd_ddr: buck2 { + regulator-name = "vdd_ddr"; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-initial-mode = <2>; + regulator-over-current-protection; + }; + + vdd: buck3 { + regulator-name = "vdd"; + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + regulator-always-on; + st,mask_reset; + regulator-initial-mode = <8>; + regulator-over-current-protection; + }; + + v3v3: buck4 { + regulator-name = "v3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-over-current-protection; + regulator-initial-mode = <8>; + }; + + vdda: ldo1 { + regulator-name = "vdda"; + regulator-min-microvolt = <2900000>; + regulator-max-microvolt = <2900000>; + interrupts = <IT_CURLIM_LDO1 0>; + interrupt-parent = <&pmic>; + }; + + v2v8: ldo2 { + regulator-name = "v2v8"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + interrupts = <IT_CURLIM_LDO2 0>; + interrupt-parent = <&pmic>; + }; + + vtt_ddr: ldo3 { + regulator-name = "vtt_ddr"; + regulator-min-microvolt = <0000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + regulator-over-current-protection; + }; + + vdd_usb: ldo4 { + regulator-name = "vdd_usb"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + interrupts = <IT_CURLIM_LDO4 0>; + interrupt-parent = <&pmic>; + }; + + vdd_sd: ldo5 { + regulator-name = "vdd_sd"; + regulator-min-microvolt = <2900000>; + regulator-max-microvolt = <2900000>; + interrupts = <IT_CURLIM_LDO5 0>; + interrupt-parent = <&pmic>; + regulator-boot-on; + }; + + v1v8: ldo6 { + regulator-name = "v1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + interrupts = <IT_CURLIM_LDO6 0>; + interrupt-parent = <&pmic>; + }; + + vref_ddr: vref_ddr { + regulator-name = "vref_ddr"; + regulator-always-on; + regulator-over-current-protection; + }; + + bst_out: boost { + regulator-name = "bst_out"; + interrupts = <IT_OCP_BOOST 0>; + interrupt-parent = <&pmic>; + }; + + vbus_otg: pwr_sw1 { + regulator-name = "vbus_otg"; + interrupts = <IT_OCP_OTG 0>; + interrupt-parent = <&pmic>; + regulator-active-discharge; + }; + + vbus_sw: pwr_sw2 { + regulator-name = "vbus_sw"; + interrupts = <IT_OCP_SWOUT 0>; + interrupt-parent = <&pmic>; + regulator-active-discharge; + }; + }; + + onkey { + compatible = "st,stpmic1-onkey"; + interrupts = <IT_PONKEY_F 0>, <IT_PONKEY_R 1>; + interrupt-names = "onkey-falling", "onkey-rising"; + status = "okay"; + }; + + watchdog { + compatible = "st,stpmic1-wdt"; + status = "disabled"; + }; + }; +}; + +&iwdg2 { + timeout-sec = <32>; + status = "okay"; +}; + +&pwr { + pwr-supply = <&vdd>; +}; + +&rng1 { + status = "okay"; +}; + +&rtc { + status = "okay"; +}; + +&sdmmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc1_b4_pins_a &sdmmc1_dir_pins_a>; + broken-cd; + st,sig-dir; + st,neg-edge; + st,use-ckin; + bus-width = <4>; + vmmc-supply = <&vdd_sd>; + status = "okay"; +}; + +&sdmmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_d47_pins_a>; + non-removable; + no-sd; + no-sdio; + st,neg-edge; + bus-width = <8>; + vmmc-supply = <&v3v3>; + mmc-ddr-3_3v; + status = "okay"; +}; + +&spi2 { + pinctrl-names = "default"; + pinctrl-0 = <&spi2_pins_a>; + status = "okay"; +}; + +&uart4 { + pinctrl-names = "default"; + pinctrl-0 = <&uart4_pins_b>; + status = "okay"; +}; + +&uart7 { + pinctrl-names = "default"; + pinctrl-0 = <&uart7_pins_a>; + status = "okay"; +}; + +&usbh_ehci { + phys = <&usbphyc_port0>; + phy-names = "usb"; + status = "okay"; +}; + +&usbotg_hs { + dr_mode = "peripheral"; + phys = <&usbphyc_port1 0>; + phy-names = "usb2-phy"; + status = "okay"; +}; + +&usbphyc { + status = "okay"; +}; + +&usbphyc_port0 { + phy-supply = <&vdd_usb>; +}; + +&usbphyc_port1 { + phy-supply = <&vdd_usb>; +}; diff --git a/board/st/stm32mp1/README b/board/st/stm32mp1/README index 1cd3534ae4e..b0c83250612 100644 --- a/board/st/stm32mp1/README +++ b/board/st/stm32mp1/README @@ -37,6 +37,7 @@ Currently the following boards are supported: + stm32mp157c-ed1 + stm32mp157a-dk1 + stm32mp157c-dk2 ++ stm32mp157a-avenger96
3. Boot Sequences ================= @@ -84,6 +85,9 @@ the supported device trees for stm32mp157 are: + dk2: Discovery board = dk1 with a BT/WiFI combo and a DSI panel dts: stm32mp157c-dk2
++ avenger96: Avenger96 board from Arrow Electronics + dts: stm32mp157a-avenger96 + 5. Build Procedure ==================
@@ -140,6 +144,11 @@ the supported device trees for stm32mp157 are: # make stm32mp15_basic_defconfig # make DEVICE_TREE=stm32mp157c-dk2 all
+ d) basic boot on avenger96 + # export KBUILD_OUTPUT=stm32mp15_basic + # make stm32mp15_basic_defconfig + # make DEVICE_TREE=stm32mp157a-avenger96 all + 6. Output files
BootRom and TF-A expect binaries with STM32 image header @@ -182,6 +191,20 @@ You can select the boot mode, on the board ed1 with the switch SW1 SD-Card 1 1 Recovery 0 0
+- Boot mode of Avenger96 can be selected using switch S3 + + ----------------------------------- + Boot Mode BOOT2 BOOT1 BOOT0 + ----------------------------------- + Recovery 0 0 0 + NOR 0 0 1 + SD-Card 1 0 1 + eMMC 0 1 0 + NAND 0 1 1 + Reserved 1 0 0 + Recovery 1 1 0 + SD-Card 1 1 1 + Recovery is a boot from serial link (UART/USB) and it is used with STM32CubeProgrammer tool to load executable in RAM and to update the flash devices available on the board (NOR/NAND/eMMC/SDCARD).
Hi Manivannan
- stm32mp157a-avenger96.dtb \ stm32mp157c-dk2.dtb \ stm32mp157c-ed1.dtb \ stm32mp157c-ev1.dtb
- Copyright : STMicroelectronics 2018
- Copyright (C) Linaro Ltd 2019 - All Rights Reserved
- Author: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org
- aliases {
mmc0 = &sdmmc1;
mmc1 = &sdmmc2;
usb0 = &usbotg_hs;
- config {
+&i2c4 {
- u-boot,dm-pre-reloc;
+&i2c4_pins_a {
- pins {
+&pmic {
+&rcc {
- st,clksrc = <
CLK_MPU_PLL1P
CLK_AXI_PLL2P
CLK_MCU_PLL3P
CLK_PLL12_HSE
CLK_PLL3_HSE
CLK_PLL4_HSE
CLK_RTC_LSE
CLK_MCO1_DISABLED
CLK_MCO2_DISABLED
;- st,clkdiv = <
1 /*MPU*/
0 /*AXI*/
0 /*MCU*/
1 /*APB1*/
1 /*APB2*/
1 /*APB3*/
1 /*APB4*/
2 /*APB5*/
23 /*RTC*/
0 /*MCO1*/
0 /*MCO2*/
;- st,pkcs = <
CLK_CKPER_HSE
CLK_FMC_ACLK
CLK_QSPI_ACLK
CLK_ETH_DISABLED
CLK_SDMMC12_PLL4P
CLK_DSI_DSIPLL
CLK_STGEN_HSE
CLK_USBPHY_HSE
CLK_SPI2S1_PLL3Q
CLK_SPI2S23_PLL3Q
CLK_SPI45_HSI
CLK_SPI6_HSI
CLK_I2C46_HSI
CLK_SDMMC3_PLL4P
CLK_USBO_USBPHY
CLK_ADC_CKPER
CLK_CEC_LSE
CLK_I2C12_HSI
CLK_I2C35_HSI
CLK_UART1_HSI
CLK_UART24_HSI
CLK_UART35_HSI
CLK_UART6_HSI
CLK_UART78_HSI
CLK_SPDIF_PLL4P
CLK_FDCAN_PLL4Q
CLK_SAI1_PLL3Q
CLK_SAI2_PLL3Q
CLK_SAI3_PLL3Q
CLK_SAI4_PLL3Q
CLK_RNG1_LSI
CLK_RNG2_LSI
CLK_LPTIM1_PCLK1
CLK_LPTIM23_PCLK3
CLK_LPTIM45_LSE
;- /* VCO = 1300.0 MHz => P = 650 (CPU) */
- pll1: st,pll@0 {
frac = < 0x800 >;
- /* VCO = 1066.0 MHz => P = 266 (AXI), Q = 533 (GPU), R = 533 (DDR) */
- pll2: st,pll@1 {
frac = < 0x1400 >;
- /* VCO = 417.8 MHz => P = 209, Q = 24, R = 11 */
- pll3: st,pll@2 {
frac = < 0x1a04 >;
- /* VCO = 480.0 MHz => P = 120, Q = 40, R = 96 */
- pll4: st,pll@3 {
+&sdmmc1 {
- u-boot,dm-spl;
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
+&sdmmc2 {
- u-boot,dm-spl;
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
+&uart4 {
+&uart4_pins_b {
- pins1 {
- pins2 {
+&usbotg_hs {
- u-boot,force-b-session-valid;
- hnp-srp-disable;
+&v3v3 {
- regulator-always-on;
- Copyright (C) STMicroelectronics 2019 - All Rights Reserved
- Author: Alexandre Torgue alexandre.torgue@st.com for STMicroelectronics.
+/dts-v1/;
- model = "Arrow Electronics STM32MP157A Avenger96 board";
- compatible = "st,stm32mp157a-avenger96", "st,stm32mp157";
- aliases {
serial0 = &uart4;
- chosen {
- memory@c0000000 {
- led {
led1 {
led2 {
led3 {
led4 {
panic-indicator;
led5 {
led6 {
label = "blue:bt";
+ðernet0 {
- status = "okay";
- pinctrl-0 = <ðernet0_rgmii_pins_a>;
- pinctrl-1 = <ðernet0_rgmii_pins_sleep_a>;
- pinctrl-names = "default", "sleep";
- phy-mode = "rgmii";
- max-speed = <1000>;
- phy-handle = <&phy0>;
- mdio0 {
#size-cells = <0>;
reg = <7>;
+&i2c1 {
- pinctrl-names = "default";
- pinctrl-0 = <&i2c1_pins_b>;
- i2c-scl-rising-time-ns = <185>;
- i2c-scl-falling-time-ns = <20>;
- status = "okay";
- /delete-property/dmas;
- /delete-property/dma-names;
+&i2c2 {
- pinctrl-0 = <&i2c2_pins_b>;
- status = "okay";
+&i2c4 {
- pinctrl-0 = <&i2c4_pins_a>;
- status = "okay";
- pmic: stpmic@33 {
reg = <0x33>;
status = "okay";
regulators {
vddcore: buck1 {
vdd_ddr: buck2 {
vdd: buck3 {
st,mask_reset;
v3v3: buck4 {
vdda: ldo1 {
v2v8: ldo2 {
vtt_ddr: ldo3 {
vdd_usb: ldo4 {
vdd_sd: ldo5 {
regulator-boot-on;
v1v8: ldo6 {
bst_out: boost {
vbus_otg: pwr_sw1 {
vbus_sw: pwr_sw2 {
onkey {
status = "okay";
watchdog {
+&iwdg2 {
- timeout-sec = <32>;
- status = "okay";
+&pwr {
- pwr-supply = <&vdd>;
+&rng1 {
- status = "okay";
+&rtc {
- status = "okay";
+&sdmmc1 {
- pinctrl-0 = <&sdmmc1_b4_pins_a &sdmmc1_dir_pins_a>;
- broken-cd;
- st,sig-dir;
- st,neg-edge;
- st,use-ckin;
- bus-width = <4>;
- vmmc-supply = <&vdd_sd>;
- status = "okay";
+&sdmmc2 {
- pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_d47_pins_a>;
- non-removable;
- no-sd;
- no-sdio;
- st,neg-edge;
- bus-width = <8>;
- vmmc-supply = <&v3v3>;
- mmc-ddr-3_3v;
- status = "okay";
+&spi2 {
- pinctrl-0 = <&spi2_pins_a>;
- status = "okay";
+&uart4 {
- pinctrl-0 = <&uart4_pins_b>;
- status = "okay";
+&uart7 {
- pinctrl-0 = <&uart7_pins_a>;
- status = "okay";
+&usbh_ehci {
- phys = <&usbphyc_port0>;
- phy-names = "usb";
- status = "okay";
+&usbotg_hs {
- dr_mode = "peripheral";
- phys = <&usbphyc_port1 0>;
- phy-names = "usb2-phy";
- status = "okay";
+&usbphyc {
- status = "okay";
+&usbphyc_port0 {
- phy-supply = <&vdd_usb>;
+&usbphyc_port1 {
- stm32mp157c-ed1
- stm32mp157a-dk1
- stm32mp157c-dk2
- Boot Sequences
- dk2: Discovery board = dk1 with a BT/WiFI combo and a DSI panel dts: stm32mp157c-dk2
- dts: stm32mp157a-avenger96
- Build Procedure
- d) basic boot on avenger96
- # export KBUILD_OUTPUT=stm32mp15_basic
- # make stm32mp15_basic_defconfig
- # make DEVICE_TREE=stm32mp157a-avenger96 all
- Output files
- Boot Mode BOOT2 BOOT1 BOOT0
- Recovery 0 0 0
- NOR 0 0 1
- SD-Card 1 0 1
- eMMC 0 1 0
- NAND 0 1 1
- Reserved 1 0 0
- Recovery 1 1 0
- SD-Card 1 1 1
Thanks
Hi Manivannan,
Minor, board added not in alphabetical oder....
dtb-$(CONFIG_TARGET_STM32MP1) += \ stm32mp157a-avenger96.dtb \ stm32mp157a-dk1.dtb \ stm32mp157c-dk2.dtb \ stm32mp157c-ed1.dtb \ stm32mp157c-ev1.dtb
- aliases {
mmc0 = &sdmmc1;
mmc1 = &sdmmc2;
usb0 = &usbotg_hs;
- config {
+&i2c4 {
+&i2c4_pins_a {
- pins {
+&pmic {
+&rcc {
- st,clksrc = <
CLK_MPU_PLL1P
CLK_AXI_PLL2P
CLK_MCU_PLL3P
CLK_PLL12_HSE
CLK_PLL3_HSE
CLK_PLL4_HSE
CLK_RTC_LSE
CLK_MCO1_DISABLED
CLK_MCO2_DISABLED
;- st,clkdiv = <
1 /*MPU*/
0 /*AXI*/
0 /*MCU*/
1 /*APB1*/
1 /*APB2*/
1 /*APB3*/
1 /*APB4*/
2 /*APB5*/
23 /*RTC*/
0 /*MCO1*/
0 /*MCO2*/
;- st,pkcs = <
CLK_CKPER_HSE
CLK_FMC_ACLK
CLK_QSPI_ACLK
CLK_ETH_DISABLED
CLK_SDMMC12_PLL4P
CLK_DSI_DSIPLL
CLK_STGEN_HSE
CLK_USBPHY_HSE
CLK_SPI2S1_PLL3Q
CLK_SPI2S23_PLL3Q
CLK_SPI45_HSI
CLK_SPI6_HSI
CLK_I2C46_HSI
CLK_SDMMC3_PLL4P
CLK_USBO_USBPHY
CLK_ADC_CKPER
CLK_CEC_LSE
CLK_I2C12_HSI
CLK_I2C35_HSI
CLK_UART1_HSI
CLK_UART24_HSI
CLK_UART35_HSI
CLK_UART6_HSI
CLK_UART78_HSI
CLK_SPDIF_PLL4P
CLK_FDCAN_PLL4Q
CLK_SAI1_PLL3Q
CLK_SAI2_PLL3Q
CLK_SAI3_PLL3Q
CLK_SAI4_PLL3Q
CLK_RNG1_LSI
CLK_RNG2_LSI
CLK_LPTIM1_PCLK1
CLK_LPTIM23_PCLK3
CLK_LPTIM45_LSE
- pll1: st,pll@0 {
frac = < 0x800 >;
- pll2: st,pll@1 {
frac = < 0x1400 >;
- pll3: st,pll@2 {
frac = < 0x1a04 >;
- pll4: st,pll@3 {
+&sdmmc1 {
- u-boot,dm-spl;
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
+&sdmmc2 {
- u-boot,dm-spl;
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
+&uart4 {
+&uart4_pins_b {
- pins1 {
- pins2 {
+&usbotg_hs {
- hnp-srp-disable;
+&v3v3 {
STMicroelectronics.
+/dts-v1/;
- aliases {
serial0 = &uart4;
- chosen {
- memory@c0000000 {
- led {
led1 {
led2 {
led3 {
led4 {
panic-indicator;
led5 {
led6 {
label = "blue:bt";
+ðernet0 {
- status = "okay";
- mdio0 {
#size-cells = <0>;
reg = <7>;
+&i2c1 {
- status = "okay";
+&i2c2 {
- status = "okay";
+&i2c4 {
- status = "okay";
- pmic: stpmic@33 {
reg = <0x33>;
status = "okay";
regulators {
vddcore: buck1 {
vdd_ddr: buck2 {
vdd: buck3 {
st,mask_reset;
v3v3: buck4 {
vdda: ldo1 {
v2v8: ldo2 {
vtt_ddr: ldo3 {
vdd_usb: ldo4 {
vdd_sd: ldo5 {
regulator-boot-on;
v1v8: ldo6 {
bst_out: boost {
vbus_otg: pwr_sw1 {
vbus_sw: pwr_sw2 {
onkey {
status = "okay";
watchdog {
+&iwdg2 {
- status = "okay";
+&pwr {
+&rng1 {
- status = "okay";
+&rtc {
- status = "okay";
+&sdmmc1 {
- broken-cd;
- st,sig-dir;
- st,neg-edge;
- st,use-ckin;
- bus-width = <4>;
- status = "okay";
+&sdmmc2 {
- non-removable;
- no-sd;
- no-sdio;
- st,neg-edge;
- bus-width = <8>;
- mmc-ddr-3_3v;
- status = "okay";
+&spi2 {
- status = "okay";
+&uart4 {
- status = "okay";
+&uart7 {
- status = "okay";
+&usbh_ehci {
- status = "okay";
+&usbotg_hs {
- status = "okay";
+&usbphyc {
- status = "okay";
+&usbphyc_port0 {
+&usbphyc_port1 {
- stm32mp157c-ed1
- stm32mp157a-dk1
- stm32mp157c-dk2
- Boot Sequences
- Build Procedure
- Output files
- Recovery 0 0 0
- NOR 0 0 1
- SD-Card 1 0 1
- eMMC 0 1 0
- NAND 0 1 1
- Reserved 1 0 0
- Recovery 1 1 0
- SD-Card 1 1 1
Recovery is a boot from serial link (UART/USB) and it is used with STM32CubeProgrammer tool to load executable in RAM and to update the flash devices available on the board (NOR/NAND/eMMC/SDCARD). -- 2.17.1
Except the minor remarks (because I can update it in the pull request)
Thanks
- aliases {
mmc0 = &sdmmc1;
mmc1 = &sdmmc2;
usb0 = &usbotg_hs;
- config {
+&i2c4 {
+&i2c4_pins_a {
- pins {
+&pmic {
+&rcc {
- st,clksrc = <
CLK_MPU_PLL1P
CLK_AXI_PLL2P
CLK_MCU_PLL3P
CLK_PLL12_HSE
CLK_PLL3_HSE
CLK_PLL4_HSE
CLK_RTC_LSE
CLK_MCO1_DISABLED
CLK_MCO2_DISABLED
;- st,clkdiv = <
1 /*MPU*/
0 /*AXI*/
0 /*MCU*/
1 /*APB1*/
1 /*APB2*/
1 /*APB3*/
1 /*APB4*/
2 /*APB5*/
23 /*RTC*/
0 /*MCO1*/
0 /*MCO2*/
;- st,pkcs = <
CLK_CKPER_HSE
CLK_FMC_ACLK
CLK_QSPI_ACLK
CLK_ETH_DISABLED
CLK_SDMMC12_PLL4P
CLK_DSI_DSIPLL
CLK_STGEN_HSE
CLK_USBPHY_HSE
CLK_SPI2S1_PLL3Q
CLK_SPI2S23_PLL3Q
CLK_SPI45_HSI
CLK_SPI6_HSI
CLK_I2C46_HSI
CLK_SDMMC3_PLL4P
CLK_USBO_USBPHY
CLK_ADC_CKPER
CLK_CEC_LSE
CLK_I2C12_HSI
CLK_I2C35_HSI
CLK_UART1_HSI
CLK_UART24_HSI
CLK_UART35_HSI
CLK_UART6_HSI
CLK_UART78_HSI
CLK_SPDIF_PLL4P
CLK_FDCAN_PLL4Q
CLK_SAI1_PLL3Q
CLK_SAI2_PLL3Q
CLK_SAI3_PLL3Q
CLK_SAI4_PLL3Q
CLK_RNG1_LSI
CLK_RNG2_LSI
CLK_LPTIM1_PCLK1
CLK_LPTIM23_PCLK3
CLK_LPTIM45_LSE
- pll1: st,pll@0 {
frac = < 0x800 >;
- pll2: st,pll@1 {
frac = < 0x1400 >;
- pll3: st,pll@2 {
frac = < 0x1a04 >;
- pll4: st,pll@3 {
+&sdmmc1 {
- u-boot,dm-spl;
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
+&sdmmc2 {
- u-boot,dm-spl;
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
+&uart4 {
+&uart4_pins_b {
- pins1 {
- pins2 {
+&usbotg_hs {
- hnp-srp-disable;
+&v3v3 {
+/dts-v1/;
- aliases {
serial0 = &uart4;
- chosen {
- memory@c0000000 {
- led {
led1 {
led2 {
led3 {
led4 {
panic-indicator;
led5 {
led6 {
label = "blue:bt";
+ðernet0 {
- status = "okay";
- mdio0 {
#size-cells = <0>;
reg = <7>;
+&i2c1 {
- status = "okay";
+&i2c2 {
- status = "okay";
+&i2c4 {
- status = "okay";
- pmic: stpmic@33 {
reg = <0x33>;
status = "okay";
regulators {
vddcore: buck1 {
vdd_ddr: buck2 {
vdd: buck3 {
st,mask_reset;
v3v3: buck4 {
vdda: ldo1 {
v2v8: ldo2 {
vtt_ddr: ldo3 {
vdd_usb: ldo4 {
vdd_sd: ldo5 {
regulator-boot-on;
v1v8: ldo6 {
bst_out: boost {
vbus_otg: pwr_sw1 {
vbus_sw: pwr_sw2 {
onkey {
status = "okay";
watchdog {
+&iwdg2 {
- status = "okay";
+&pwr {
+&rng1 {
- status = "okay";
+&rtc {
- status = "okay";
+&sdmmc1 {
- broken-cd;
- st,sig-dir;
- st,neg-edge;
- st,use-ckin;
- bus-width = <4>;
- status = "okay";
+&sdmmc2 {
- non-removable;
- no-sd;
- no-sdio;
- st,neg-edge;
- bus-width = <8>;
- mmc-ddr-3_3v;
- status = "okay";
+&spi2 {
- status = "okay";
+&uart4 {
- status = "okay";
+&uart7 {
- status = "okay";
+&usbh_ehci {
- status = "okay";
+&usbotg_hs {
- status = "okay";
+&usbphyc {
- status = "okay";
+&usbphyc_port0 {
+&usbphyc_port1 {
- stm32mp157c-ed1
- stm32mp157a-dk1
- stm32mp157c-dk2
- Boot Sequences
- Build Procedure
- Output files
- Recovery 0 0 0
- NOR 0 0 1
- SD-Card 1 0 1
- eMMC 0 1 0
- NAND 0 1 1
- Reserved 1 0 0
- Recovery 1 1 0
- SD-Card 1 1 1
Applied
Thanks
Without newline, the error message appears for non prgrammed OTP boards looks messsy. Hence add it to look more clean.
Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org --- arch/arm/mach-stm32mp/cpu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-stm32mp/cpu.c b/arch/arm/mach-stm32mp/cpu.c index 7b4431c9c75..e1a0a136809 100644 --- a/arch/arm/mach-stm32mp/cpu.c +++ b/arch/arm/mach-stm32mp/cpu.c @@ -481,7 +481,7 @@ static int setup_mac_address(void) enetaddr[i] = ((uint8_t *)&otp)[i];
if (!is_valid_ethaddr(enetaddr)) { - pr_err("invalid MAC address in OTP %pM", enetaddr); + pr_err("invalid MAC address in OTP %pM\n", enetaddr); return -EINVAL; } pr_debug("OTP MAC address = %pM\n", enetaddr);
return -EINVAL; } pr_debug("OTP MAC address = %pM\n", enetaddr);pr_err("invalid MAC address in OTP %pM\n", enetaddr);
Thanks
Hi Manivannan,
Thanks
-- 2.17.1
Applied
Thanks
Patrice CHOTARD
Patrick DELAUNAY
