[PATCH 1/3] arm: dts: sync the Rockhip 3399 SoCs from Linux
Sync the rk3399 DTs and associated bits from 5.14-rc1.
Signed-off-by: Peter Robinson pbrobinson@gmail.com --- arch/arm/dts/rk3399-evb.dts | 4 + arch/arm/dts/rk3399-ficus.dts | 29 +- arch/arm/dts/rk3399-firefly.dts | 178 ++++++++++-- arch/arm/dts/rk3399-gru.dtsi | 14 +- arch/arm/dts/rk3399-khadas-edge.dtsi | 40 ++- arch/arm/dts/rk3399-leez-p710.dts | 14 +- arch/arm/dts/rk3399-nanopc-t4.dts | 1 + arch/arm/dts/rk3399-nanopi-r4s.dts | 135 +++++---- arch/arm/dts/rk3399-nanopi4.dtsi | 18 +- arch/arm/dts/rk3399-opp.dtsi | 40 +-- arch/arm/dts/rk3399-orangepi.dts | 72 ++++- arch/arm/dts/rk3399-pinebook-pro.dts | 120 +++++--- arch/arm/dts/rk3399-puma-haikou.dts | 10 +- arch/arm/dts/rk3399-puma.dtsi | 61 +--- arch/arm/dts/rk3399-roc-pc-mezzanine.dts | 22 +- arch/arm/dts/rk3399-roc-pc.dtsi | 59 +++- arch/arm/dts/rk3399-rock-pi-4.dtsi | 29 +- arch/arm/dts/rk3399-rock-pi-4a.dts | 2 +- arch/arm/dts/rk3399-rock-pi-4b.dts | 6 +- arch/arm/dts/rk3399-rock-pi-4c.dts | 6 +- arch/arm/dts/rk3399-rock960.dts | 82 ++---- arch/arm/dts/rk3399-rock960.dtsi | 10 +- arch/arm/dts/rk3399-rockpro64.dtsi | 95 ++++++- arch/arm/dts/rk3399.dtsi | 269 +++++++++++------- arch/arm/dts/rk3399pro-vmarc-som.dtsi | 22 +- .../dts/rockchip-radxa-dalang-carrier.dtsi | 21 ++ 26 files changed, 897 insertions(+), 462 deletions(-)
diff --git a/arch/arm/dts/rk3399-evb.dts b/arch/arm/dts/rk3399-evb.dts index 694b0d08d6..7b717ebec8 100644 --- a/arch/arm/dts/rk3399-evb.dts +++ b/arch/arm/dts/rk3399-evb.dts @@ -11,6 +11,10 @@ model = "Rockchip RK3399 Evaluation Board"; compatible = "rockchip,rk3399-evb", "rockchip,rk3399";
+ aliases { + mmc0 = &sdhci; + }; + backlight: backlight { compatible = "pwm-backlight"; brightness-levels = < diff --git a/arch/arm/dts/rk3399-ficus.dts b/arch/arm/dts/rk3399-ficus.dts index ebe2ee77ba..1ce85a5816 100644 --- a/arch/arm/dts/rk3399-ficus.dts +++ b/arch/arm/dts/rk3399-ficus.dts @@ -27,42 +27,43 @@ leds { compatible = "gpio-leds"; pinctrl-names = "default"; - pinctrl-0 = <&user_led1>, <&user_led2>, <&user_led3>, - <&user_led4>, <&wlan_led>, <&bt_led>; + pinctrl-0 = <&user_led1_pin>, <&user_led2_pin>, + <&user_led3_pin>, <&user_led4_pin>, + <&wlan_led_pin>, <&bt_led_pin>;
- user_led1 { + user_led1: led-1 { label = "red:user1"; gpios = <&gpio4 25 0>; linux,default-trigger = "heartbeat"; };
- user_led2 { + user_led2: led-2 { label = "red:user2"; gpios = <&gpio4 26 0>; linux,default-trigger = "mmc0"; };
- user_led3 { + user_led3: led-3 { label = "red:user3"; gpios = <&gpio4 30 0>; linux,default-trigger = "mmc1"; };
- user_led4 { + user_led4: led-4 { label = "red:user4"; gpios = <&gpio1 0 0>; panic-indicator; linux,default-trigger = "none"; };
- wlan_active_led { + wlan_active_led: led-5 { label = "red:wlan"; gpios = <&gpio1 1 0>; linux,default-trigger = "phy0tx"; default-state = "off"; };
- bt_active_led { + bt_active_led: led-6 { label = "red:bt"; gpios = <&gpio1 4 0>; linux,default-trigger = "hci0-power"; @@ -114,32 +115,32 @@ };
leds { - user_led1: user_led1 { + user_led1_pin: user-led1-pin { rockchip,pins = <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; };
- user_led2: user_led2 { + user_led2_pin: user-led2-pin { rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; };
- user_led3: user_led3 { + user_led3_pin: user-led3-pin { rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>; };
- user_led4: user_led4 { + user_led4_pin: user-led4-pin { rockchip,pins = <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; };
- wlan_led: wlan_led { + wlan_led_pin: wlan-led-pin { rockchip,pins = <1 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; };
- bt_led: bt_led { + bt_led_pin: bt-led-pin { rockchip,pins = <1 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; }; diff --git a/arch/arm/dts/rk3399-firefly.dts b/arch/arm/dts/rk3399-firefly.dts index d63faf38cc..c4dd2a6b48 100644 --- a/arch/arm/dts/rk3399-firefly.dts +++ b/arch/arm/dts/rk3399-firefly.dts @@ -6,6 +6,7 @@ /dts-v1/; #include <dt-bindings/input/linux-event-codes.h> #include <dt-bindings/pwm/pwm.h> +#include <dt-bindings/usb/pd.h> #include "rk3399.dtsi" #include "rk3399-opp.dtsi"
@@ -13,6 +14,12 @@ model = "Firefly-RK3399 Board"; compatible = "firefly,firefly-rk3399", "rockchip,rk3399";
+ aliases { + mmc0 = &sdio0; + mmc1 = &sdmmc; + mmc2 = &sdhci; + }; + chosen { stdout-path = "serial2:1500000n8"; }; @@ -88,18 +95,25 @@ }; };
+ ir-receiver { + compatible = "gpio-ir-receiver"; + gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_LOW>; + pinctrl-0 = <&ir_int>; + pinctrl-names = "default"; + }; + leds { compatible = "gpio-leds"; pinctrl-names = "default"; - pinctrl-0 = <&work_led_gpio>, <&diy_led_gpio>; + pinctrl-0 = <&work_led_pin>, <&diy_led_pin>;
- work-led { + work_led: led-0 { label = "work"; default-state = "on"; gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>; };
- diy-led { + diy_led: led-1 { label = "diy"; default-state = "off"; gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>; @@ -145,6 +159,23 @@ reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; };
+ sound-dit { + compatible = "audio-graph-card"; + label = "SPDIF"; + dais = <&spdif_p0>; + }; + + spdif-dit { + compatible = "linux,spdif-dit"; + #sound-dai-cells = <0>; + + port { + dit_p0_0: endpoint { + remote-endpoint = <&spdif_p0_0>; + }; + }; + }; + /* switched by pmic_sleep */ vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { compatible = "regulator-fixed"; @@ -190,6 +221,17 @@ vin-supply = <&vcc_sys>; };
+ vcc5v0_typec: vcc5v0-typec-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_typec_en>; + regulator-name = "vcc5v0_typec"; + regulator-always-on; + vin-supply = <&vcc_sys>; + }; + vcc_sys: vcc-sys { compatible = "regulator-fixed"; regulator-name = "vcc_sys"; @@ -515,6 +557,53 @@ i2c-scl-falling-time-ns = <20>; status = "okay";
+ fusb0: typec-portc@22 { + compatible = "fcs,fusb302"; + reg = <0x22>; + interrupt-parent = <&gpio1>; + interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&fusb0_int>; + vbus-supply = <&vcc5v0_typec>; + status = "okay"; + + connector { + compatible = "usb-c-connector"; + data-role = "host"; + label = "USB-C"; + op-sink-microwatt = <1000000>; + power-role = "dual"; + sink-pdos = + <PDO_FIXED(5000, 2500, PDO_FIXED_USB_COMM)>; + source-pdos = + <PDO_FIXED(5000, 1400, PDO_FIXED_USB_COMM)>; + try-power-role = "sink"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + usbc_hs: endpoint { + remote-endpoint = + <&u2phy0_typec_hs>; + }; + }; + + port@1 { + reg = <1>; + + usbc_ss: endpoint { + remote-endpoint = + <&tcphy0_typec_ss>; + }; + }; + }; + }; + }; + accelerometer@68 { compatible = "invensense,mpu6500"; reg = <0x68>; @@ -572,12 +661,34 @@ }; };
+ fusb302x { + fusb0_int: fusb0-int { + rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + ir { + ir_int: ir-int { + rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + lcd-panel { lcd_panel_reset: lcd-panel-reset { rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_up>; }; };
+ leds { + work_led_pin: work-led-pin { + rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + diy_led_pin: diy-led-pin { + rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + pcie { pcie_pwr_en: pcie-pwr-en { rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; @@ -589,18 +700,16 @@ };
pmic { - vsel1_gpio: vsel1-gpio { - rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_down>; + pmic_int_l: pmic-int-l { + rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; };
- vsel2_gpio: vsel2-gpio { - rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; + vsel1_pin: vsel1-pin { + rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_down>; }; - };
- sdio-pwrseq { - wifi_enable_h: wifi-enable-h { - rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; + vsel2_pin: vsel2-pin { + rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; }; };
@@ -610,9 +719,15 @@ }; };
- pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; + sdio-pwrseq { + wifi_enable_h: wifi-enable-h { + rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb-typec { + vcc5v0_typec_en: vcc5v0_typec_en { + rockchip,pins = <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; }; };
@@ -627,16 +742,6 @@ rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; }; }; - - leds { - work_led_gpio: work_led-gpio { - rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - diy_led_gpio: diy_led-gpio { - rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; };
&pwm0 { @@ -704,10 +809,29 @@ status = "okay"; };
+&spdif { + pinctrl-0 = <&spdif_bus_1>; + status = "okay"; + + spdif_p0: port { + spdif_p0_0: endpoint { + remote-endpoint = <&dit_p0_0>; + }; + }; +}; + &tcphy0 { status = "okay"; };
+&tcphy0_usb3 { + port { + tcphy0_typec_ss: endpoint { + remote-endpoint = <&usbc_ss>; + }; + }; +}; + &tcphy1 { status = "okay"; }; @@ -731,6 +855,12 @@ phy-supply = <&vcc5v0_host>; status = "okay"; }; + + port { + u2phy0_typec_hs: endpoint { + remote-endpoint = <&usbc_hs>; + }; + }; };
&u2phy1 { diff --git a/arch/arm/dts/rk3399-gru.dtsi b/arch/arm/dts/rk3399-gru.dtsi index f9c5bb607b..b80f19066b 100644 --- a/arch/arm/dts/rk3399-gru.dtsi +++ b/arch/arm/dts/rk3399-gru.dtsi @@ -10,6 +10,11 @@ #include "rk3399-op1-opp.dtsi"
/ { + aliases { + mmc0 = &sdmmc; + mmc1 = &sdhci; + }; + chosen { stdout-path = "serial2:115200n8"; }; @@ -247,8 +252,8 @@ enable-active-high; enable-gpio = <&gpio2 2 GPIO_ACTIVE_HIGH>; gpios = <&gpio2 28 GPIO_ACTIVE_HIGH>; - states = <1800000 0x1 - 3000000 0x0>; + states = <1800000 0x1>, + <3000000 0x0>;
regulator-min-microvolt = <1800000>; regulator-max-microvolt = <3000000>; @@ -342,6 +347,7 @@ cpu-supply = <&ppvar_bigcpu>; };
+ &cru { assigned-clocks = <&cru PLL_GPLL>, <&cru PLL_CPLL>, @@ -515,7 +521,7 @@ ap_i2c_audio: &i2c8 { * configured as SDMMC and not JTAG. */ pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_cd_gpio + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_cd_pin &sdmmc_bus4>;
bus-width = <4>; @@ -766,7 +772,7 @@ ap_i2c_audio: &i2c8 { };
/* This is where we actually hook up CD; has external pull */ - sdmmc_cd_gpio: sdmmc-cd-gpio { + sdmmc_cd_pin: sdmmc-cd-pin { rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; }; }; diff --git a/arch/arm/dts/rk3399-khadas-edge.dtsi b/arch/arm/dts/rk3399-khadas-edge.dtsi index e87a044774..d5c7648c84 100644 --- a/arch/arm/dts/rk3399-khadas-edge.dtsi +++ b/arch/arm/dts/rk3399-khadas-edge.dtsi @@ -11,6 +11,12 @@ #include "rk3399-opp.dtsi"
/ { + aliases { + mmc0 = &sdio0; + mmc1 = &sdmmc; + mmc2 = &sdhci; + }; + chosen { stdout-path = "serial2:1500000n8"; }; @@ -138,18 +144,26 @@ }; };
+ ir-receiver { + compatible = "gpio-ir-receiver"; + gpios = <&gpio1 RK_PB6 GPIO_ACTIVE_LOW>; + linux,rc-map-name = "rc-khadas"; + pinctrl-names = "default"; + pinctrl-0 = <&ir_rx>; + }; + leds { compatible = "gpio-leds"; pinctrl-names = "default"; - pinctrl-0 = <&sys_led_gpio>, <&user_led_gpio>; + pinctrl-0 = <&sys_led_pin>, <&user_led_pin>;
- sys-led { + sys_led: led-0 { label = "sys_led"; linux,default-trigger = "heartbeat"; gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; };
- user-led { + user_led: led-1 { label = "user_led"; default-state = "off"; gpios = <&gpio4 RK_PD0 GPIO_ACTIVE_HIGH>; @@ -585,12 +599,18 @@ }; };
+ ir { + ir_rx: ir-rx { + rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + leds { - sys_led_gpio: sys_led-gpio { + sys_led_pin: sys-led-pin { rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; };
- user_led_gpio: user_led-gpio { + user_led_pin: user-led-pin { rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; }; }; @@ -690,6 +710,16 @@ status = "okay"; };
+&spi1 { + status = "okay"; + + spiflash: flash@0 { + compatible = "winbond,w25q128fw", "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <104000000>; + }; +}; + &tcphy0 { status = "okay"; }; diff --git a/arch/arm/dts/rk3399-leez-p710.dts b/arch/arm/dts/rk3399-leez-p710.dts index 73be38a537..7c93f840bc 100644 --- a/arch/arm/dts/rk3399-leez-p710.dts +++ b/arch/arm/dts/rk3399-leez-p710.dts @@ -13,6 +13,12 @@ model = "Leez RK3399 P710"; compatible = "leez,p710", "rockchip,rk3399";
+ aliases { + mmc0 = &sdio0; + mmc1 = &sdmmc; + mmc2 = &sdhci; + }; + chosen { stdout-path = "serial2:1500000n8"; }; @@ -341,7 +347,7 @@ reg = <0x40>; fcs,suspend-voltage-selector = <1>; pinctrl-names = "default"; - pinctrl-0 = <&vsel1_gpio>; + pinctrl-0 = <&vsel1_pin>; regulator-name = "vdd_cpu_b"; regulator-min-microvolt = <712500>; regulator-max-microvolt = <1500000>; @@ -360,7 +366,7 @@ reg = <0x41>; fcs,suspend-voltage-selector = <1>; pinctrl-names = "default"; - pinctrl-0 = <&vsel2_gpio>; + pinctrl-0 = <&vsel2_pin>; regulator-name = "vdd_gpu"; regulator-min-microvolt = <712500>; regulator-max-microvolt = <1500000>; @@ -447,11 +453,11 @@ rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; };
- vsel1_gpio: vsel1-gpio { + vsel1_pin: vsel1-pin { rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>; };
- vsel2_gpio: vsel2-gpio { + vsel2_pin: vsel2-pin { rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; }; }; diff --git a/arch/arm/dts/rk3399-nanopc-t4.dts b/arch/arm/dts/rk3399-nanopc-t4.dts index e0d75617bb..452728b82e 100644 --- a/arch/arm/dts/rk3399-nanopc-t4.dts +++ b/arch/arm/dts/rk3399-nanopc-t4.dts @@ -95,6 +95,7 @@ };
&pcie0 { + ep-gpios = <&gpio2 RK_PA4 GPIO_ACTIVE_HIGH>; num-lanes = <4>; vpcie3v3-supply = <&vcc3v3_sys>; }; diff --git a/arch/arm/dts/rk3399-nanopi-r4s.dts b/arch/arm/dts/rk3399-nanopi-r4s.dts index 6f2cf17bf1..cef4d18b59 100644 --- a/arch/arm/dts/rk3399-nanopi-r4s.dts +++ b/arch/arm/dts/rk3399-nanopi-r4s.dts @@ -1,13 +1,15 @@ // SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* - * Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd + * FriendlyElec NanoPC-T4 board device tree source * - * Copyright (c) 2018 FriendlyElec Computer Tech. Co., Ltd. + * Copyright (c) 2020 FriendlyElec Computer Tech. Co., Ltd. * (http://www.friendlyarm.com) * * Copyright (c) 2018 Collabora Ltd. - * Copyright (c) 2019 Arm Ltd. - * Copyright (C) 2020 Xiaobo peterwillcn@gmail.com + * + * Copyright (c) 2020 Jensen Huang jensenhuang@friendlyarm.com + * Copyright (c) 2020 Marty Jones mj8263788@gmail.com + * Copyright (c) 2021 Tianling Shen cnsztl@gmail.com */
/dts-v1/; @@ -17,94 +19,87 @@ model = "FriendlyElec NanoPi R4S"; compatible = "friendlyarm,nanopi-r4s", "rockchip,rk3399";
- aliases { - ethernet1 = &r8169; - }; + /delete-node/ display-subsystem;
- vdd_5v: vdd-5v { - compatible = "regulator-fixed"; - regulator-name = "vdd_5v"; - regulator-always-on; - regulator-boot-on; - }; + gpio-leds { + pinctrl-0 = <&lan_led_pin>, <&sys_led_pin>, <&wan_led_pin>;
- fan: pwm-fan { - compatible = "pwm-fan"; - cooling-levels = <0 12 18 255>; - #cooling-cells = <2>; - fan-supply = <&vdd_5v>; - pwms = <&pwm1 0 50000 0>; - }; -}; + /delete-node/ led-0;
-&cpu_thermal { - trips { - cpu_warm: cpu_warm { - temperature = <55000>; - hysteresis = <2000>; - type = "active"; + lan_led: led-lan { + gpios = <&gpio1 RK_PA1 GPIO_ACTIVE_HIGH>; + label = "green:lan"; };
- cpu_hot: cpu_hot { - temperature = <65000>; - hysteresis = <2000>; - type = "active"; + sys_led: led-sys { + gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>; + label = "red:power"; + default-state = "on"; }; - };
- cooling-maps { - map2 { - trip = <&cpu_warm>; - cooling-device = <&fan THERMAL_NO_LIMIT 1>; + wan_led: led-wan { + gpios = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>; + label = "green:wan"; }; + }; + + gpio-keys { + pinctrl-0 = <&reset_button_pin>; + + /delete-node/ power;
- map3 { - trip = <&cpu_hot>; - cooling-device = <&fan 2 THERMAL_NO_LIMIT>; + reset { + debounce-interval = <50>; + gpios = <&gpio1 RK_PC6 GPIO_ACTIVE_LOW>; + label = "reset"; + linux,code = <KEY_RESTART>; }; }; + + vdd_5v: vdd-5v { + compatible = "regulator-fixed"; + regulator-name = "vdd_5v"; + regulator-always-on; + regulator-boot-on; + }; };
&emmc_phy { status = "disabled"; };
-&fusb0 { +&i2c4 { status = "disabled"; };
-&leds { - lan_led: led-1 { - gpios = <&gpio1 RK_PA1 GPIO_ACTIVE_HIGH>; - label = "nanopi-r4s:green:lan"; - }; - - wan_led: led-2 { - gpios = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>; - label = "nanopi-r4s:green:wan"; - }; -}; - -&leds_gpio { - rockchip,pins = - <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>, - <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>, - <1 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; -}; - &pcie0 { max-link-speed = <1>; num-lanes = <1>; vpcie3v3-supply = <&vcc3v3_sys>; +};
- pcie@0 { - reg = <0x00000000 0 0 0 0>; - #address-cells = <3>; - #size-cells = <2>; +&pinctrl { + gpio-leds { + /delete-node/ status-led-pin;
- r8169: pcie@0,0 { - reg = <0x000000 0 0 0 0>; - local-mac-address = [ 00 00 00 00 00 00 ]; + lan_led_pin: lan-led-pin { + rockchip,pins = <1 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + sys_led_pin: sys-led-pin { + rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + wan_led_pin: wan-led-pin { + rockchip,pins = <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + rockchip-key { + /delete-node/ power-key; + + reset_button_pin: reset-button-pin { + rockchip,pins = <1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_up>; }; }; }; @@ -117,10 +112,6 @@ status = "disabled"; };
-&sdmmc { - host-index-min = <1>; -}; - &u2phy0_host { phy-supply = <&vdd_5v>; }; @@ -129,6 +120,10 @@ status = "disabled"; };
+&uart0 { + status = "disabled"; +}; + &usbdrd_dwc3_0 { dr_mode = "host"; }; diff --git a/arch/arm/dts/rk3399-nanopi4.dtsi b/arch/arm/dts/rk3399-nanopi4.dtsi index c88018a0ef..8c0ff6c96e 100644 --- a/arch/arm/dts/rk3399-nanopi4.dtsi +++ b/arch/arm/dts/rk3399-nanopi4.dtsi @@ -17,6 +17,12 @@ #include "rk3399-opp.dtsi"
/ { + aliases { + mmc0 = &sdio0; + mmc1 = &sdmmc; + mmc2 = &sdhci; + }; + chosen { stdout-path = "serial2:1500000n8"; }; @@ -117,9 +123,9 @@ leds: gpio-leds { compatible = "gpio-leds"; pinctrl-names = "default"; - pinctrl-0 = <&leds_gpio>; + pinctrl-0 = <&status_led_pin>;
- status { + status_led: led-0 { gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>; label = "status_led"; linux,default-trigger = "heartbeat"; @@ -182,7 +188,7 @@ #address-cells = <1>; #size-cells = <0>;
- rtl8211e: phy@1 { + rtl8211e: ethernet-phy@1 { reg = <1>; interrupt-parent = <&gpio3>; interrupts = <RK_PB2 IRQ_TYPE_LEVEL_LOW>; @@ -504,8 +510,6 @@ };
&pcie0 { - ep-gpios = <&gpio2 RK_PA4 GPIO_ACTIVE_HIGH>; - max-link-speed = <2>; num-lanes = <2>; vpcie0v9-supply = <&vcca0v9_s3>; vpcie1v8-supply = <&vcca1v8_s3>; @@ -520,12 +524,12 @@ };
gpio-leds { - leds_gpio: leds-gpio { + status_led_pin: status-led-pin { rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; }; };
- phy { + gmac { phy_intb: phy-intb { rockchip,pins = <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>; }; diff --git a/arch/arm/dts/rk3399-opp.dtsi b/arch/arm/dts/rk3399-opp.dtsi index d6f1095abb..da41cd81eb 100644 --- a/arch/arm/dts/rk3399-opp.dtsi +++ b/arch/arm/dts/rk3399-opp.dtsi @@ -10,28 +10,28 @@
opp00 { opp-hz = /bits/ 64 <408000000>; - opp-microvolt = <800000>; + opp-microvolt = <825000 825000 1250000>; clock-latency-ns = <40000>; }; opp01 { opp-hz = /bits/ 64 <600000000>; - opp-microvolt = <800000>; + opp-microvolt = <825000 825000 1250000>; }; opp02 { opp-hz = /bits/ 64 <816000000>; - opp-microvolt = <850000>; + opp-microvolt = <850000 850000 1250000>; }; opp03 { opp-hz = /bits/ 64 <1008000000>; - opp-microvolt = <925000>; + opp-microvolt = <925000 925000 1250000>; }; opp04 { opp-hz = /bits/ 64 <1200000000>; - opp-microvolt = <1000000>; + opp-microvolt = <1000000 1000000 1250000>; }; opp05 { opp-hz = /bits/ 64 <1416000000>; - opp-microvolt = <1125000>; + opp-microvolt = <1125000 1125000 1250000>; }; };
@@ -41,36 +41,36 @@
opp00 { opp-hz = /bits/ 64 <408000000>; - opp-microvolt = <800000>; + opp-microvolt = <825000 825000 1250000>; clock-latency-ns = <40000>; }; opp01 { opp-hz = /bits/ 64 <600000000>; - opp-microvolt = <800000>; + opp-microvolt = <825000 825000 1250000>; }; opp02 { opp-hz = /bits/ 64 <816000000>; - opp-microvolt = <825000>; + opp-microvolt = <825000 825000 1250000>; }; opp03 { opp-hz = /bits/ 64 <1008000000>; - opp-microvolt = <875000>; + opp-microvolt = <875000 875000 1250000>; }; opp04 { opp-hz = /bits/ 64 <1200000000>; - opp-microvolt = <950000>; + opp-microvolt = <950000 950000 1250000>; }; opp05 { opp-hz = /bits/ 64 <1416000000>; - opp-microvolt = <1025000>; + opp-microvolt = <1025000 1025000 1250000>; }; opp06 { opp-hz = /bits/ 64 <1608000000>; - opp-microvolt = <1100000>; + opp-microvolt = <1100000 1100000 1250000>; }; opp07 { opp-hz = /bits/ 64 <1800000000>; - opp-microvolt = <1200000>; + opp-microvolt = <1200000 1200000 1250000>; }; };
@@ -79,27 +79,27 @@
opp00 { opp-hz = /bits/ 64 <200000000>; - opp-microvolt = <800000>; + opp-microvolt = <825000 825000 1150000>; }; opp01 { opp-hz = /bits/ 64 <297000000>; - opp-microvolt = <800000>; + opp-microvolt = <825000 825000 1150000>; }; opp02 { opp-hz = /bits/ 64 <400000000>; - opp-microvolt = <825000>; + opp-microvolt = <825000 825000 1150000>; }; opp03 { opp-hz = /bits/ 64 <500000000>; - opp-microvolt = <875000>; + opp-microvolt = <875000 875000 1150000>; }; opp04 { opp-hz = /bits/ 64 <600000000>; - opp-microvolt = <925000>; + opp-microvolt = <925000 925000 1150000>; }; opp05 { opp-hz = /bits/ 64 <800000000>; - opp-microvolt = <1100000>; + opp-microvolt = <1100000 1100000 1150000>; }; }; }; diff --git a/arch/arm/dts/rk3399-orangepi.dts b/arch/arm/dts/rk3399-orangepi.dts index f9f7246d4d..04b54abea3 100644 --- a/arch/arm/dts/rk3399-orangepi.dts +++ b/arch/arm/dts/rk3399-orangepi.dts @@ -7,6 +7,7 @@
#include "dt-bindings/pwm/pwm.h" #include "dt-bindings/input/input.h" +#include "dt-bindings/usb/pd.h" #include "rk3399.dtsi" #include "rk3399-opp.dtsi"
@@ -14,6 +15,12 @@ model = "Orange Pi RK3399 Board"; compatible = "rockchip,rk3399-orangepi", "rockchip,rk3399";
+ aliases { + mmc0 = &sdio0; + mmc1 = &sdmmc; + mmc2 = &sdhci; + }; + chosen { stdout-path = "serial2:1500000n8"; }; @@ -214,7 +221,7 @@ #address-cells = <1>; #size-cells = <0>;
- rtl8211e: phy@1 { + rtl8211e: ethernet-phy@1 { reg = <1>; interrupt-parent = <&gpio3>; interrupts = <RK_PB2 IRQ_TYPE_LEVEL_LOW>; @@ -531,6 +538,43 @@ pinctrl-names = "default"; pinctrl-0 = <&chg_cc_int_l>; vbus-supply = <&vbus_typec>; + + typec_con: connector { + compatible = "usb-c-connector"; + data-role = "host"; + label = "USB-C"; + op-sink-microwatt = <1000000>; + power-role = "dual"; + sink-pdos = + <PDO_FIXED(5000, 2500, PDO_FIXED_USB_COMM)>; + source-pdos = + <PDO_FIXED(5000, 1400, PDO_FIXED_USB_COMM)>; + try-power-role = "sink"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + typec_hs: endpoint { + remote-endpoint = <&u2phy0_typec_hs>; + }; + }; + port@1 { + reg = <1>; + typec_ss: endpoint { + remote-endpoint = <&tcphy0_typec_ss>; + }; + }; + port@2 { + reg = <2>; + typec_dp: endpoint { + remote-endpoint = <&tcphy0_typec_dp>; + }; + }; + }; + }; }; };
@@ -554,7 +598,7 @@ }; };
- phy { + gmac { phy_intb: phy-intb { rockchip,pins = <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>; }; @@ -717,6 +761,22 @@ status = "okay"; };
+&tcphy0_dp { + port { + tcphy0_typec_dp: endpoint { + remote-endpoint = <&typec_dp>; + }; + }; +}; + +&tcphy0_usb3 { + port { + tcphy0_typec_ss: endpoint { + remote-endpoint = <&typec_ss>; + }; + }; +}; + &tcphy1 { status = "okay"; }; @@ -739,6 +799,12 @@ phy-supply = <&vcc5v0_host>; status = "okay"; }; + + port { + u2phy0_typec_hs: endpoint { + remote-endpoint = <&typec_hs>; + }; + }; };
&u2phy1 { @@ -799,7 +865,7 @@
&usbdrd_dwc3_0 { status = "okay"; - dr_mode = "otg"; + dr_mode = "host"; };
&usbdrd3_1 { diff --git a/arch/arm/dts/rk3399-pinebook-pro.dts b/arch/arm/dts/rk3399-pinebook-pro.dts index 294d21bf45..2b5f001ff4 100644 --- a/arch/arm/dts/rk3399-pinebook-pro.dts +++ b/arch/arm/dts/rk3399-pinebook-pro.dts @@ -18,6 +18,12 @@ model = "Pine64 Pinebook Pro"; compatible = "pine64,pinebook-pro", "rockchip,rk3399";
+ aliases { + mmc0 = &sdio0; + mmc1 = &sdmmc; + mmc2 = &sdhci; + }; + chosen { stdout-path = "serial2:1500000n8"; }; @@ -28,12 +34,19 @@ pwms = <&pwm0 0 740740 0>; };
+ bat: battery { + compatible = "simple-battery"; + charge-full-design-microamp-hours = <9800000>; + voltage-max-design-microvolt = <4350000>; + voltage-min-design-microvolt = <3000000>; + }; + edp_panel: edp-panel { compatible = "boe,nv140fhmn49"; backlight = <&backlight>; enable-gpios = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; - pinctrl-0 = <&panel_en_gpio>; + pinctrl-0 = <&panel_en_pin>; power-supply = <&vcc3v3_panel>;
ports { @@ -60,7 +73,7 @@ gpio-key-lid { compatible = "gpio-keys"; pinctrl-names = "default"; - pinctrl-0 = <&lidbtn_gpio>; + pinctrl-0 = <&lidbtn_pin>;
lid { debounce-interval = <20>; @@ -76,7 +89,7 @@ gpio-key-power { compatible = "gpio-keys"; pinctrl-names = "default"; - pinctrl-0 = <&pwrbtn_gpio>; + pinctrl-0 = <&pwrbtn_pin>;
power { debounce-interval = <20>; @@ -90,9 +103,9 @@ leds { compatible = "gpio-leds"; pinctrl-names = "default"; - pinctrl-0 = <&pwrled_gpio &slpled_gpio>; + pinctrl-0 = <&pwr_led_pin &slp_led_pin>;
- green-led { + green_led: led-0 { color = <LED_COLOR_ID_GREEN>; default-state = "on"; function = LED_FUNCTION_POWER; @@ -100,7 +113,7 @@ label = "green:power"; };
- red-led { + red_led: led-1 { color = <LED_COLOR_ID_RED>; default-state = "off"; function = LED_FUNCTION_STANDBY; @@ -117,7 +130,7 @@ clocks = <&rk808 1>; clock-names = "ext_clock"; pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable_h_gpio>; + pinctrl-0 = <&wifi_enable_h_pin>; post-power-on-delay-ms = <100>; power-off-delay-us = <500000>;
@@ -129,7 +142,7 @@ es8316-sound { compatible = "simple-audio-card"; pinctrl-names = "default"; - pinctrl-0 = <&hp_det_gpio>; + pinctrl-0 = <&hp_det_pin>; simple-audio-card,name = "rockchip,es8316-codec"; simple-audio-card,format = "i2s"; simple-audio-card,mclk-fs = <256>; @@ -213,7 +226,7 @@ enable-active-high; gpio = <&gpio1 RK_PB5 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; - pinctrl-0 = <&pwr_5v_gpio>; + pinctrl-0 = <&pwr_5v_pin>; regulator-name = "vcc5v0_usb"; regulator-always-on; regulator-min-microvolt = <5000000>; @@ -270,7 +283,7 @@ enable-active-high; gpio = <&gpio0 RK_PA1 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_pwr_h_gpio>; + pinctrl-0 = <&sdmmc0_pwr_h_pin>; regulator-name = "vcc3v0_sd"; regulator-always-on; regulator-min-microvolt = <3000000>; @@ -288,7 +301,7 @@ enable-active-high; gpio = <&gpio1 RK_PC6 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; - pinctrl-0 = <&lcdvcc_en_gpio>; + pinctrl-0 = <&lcdvcc_en_pin>; regulator-name = "vcc3v3_panel"; regulator-always-on; regulator-min-microvolt = <3300000>; @@ -317,7 +330,7 @@ enable-active-high; gpio = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_host_en_gpio>; + pinctrl-0 = <&vcc5v0_host_en_pin>; regulator-name = "vcc5v0_otg"; regulator-always-on; regulator-min-microvolt = <5000000>; @@ -336,7 +349,7 @@ enable-active-high; gpio = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_typec0_en_gpio>; + pinctrl-0 = <&vcc5v0_typec0_en_pin>; regulator-name = "vbus_5vout"; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; @@ -368,7 +381,7 @@
/* Also triggered by USB charger */ pinctrl-names = "default"; - pinctrl-0 = <&dc_det_gpio>; + pinctrl-0 = <&dc_det_pin>; }; };
@@ -447,7 +460,7 @@ interrupt-parent = <&gpio3>; interrupts = <10 IRQ_TYPE_LEVEL_LOW>; pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l_gpio>; + pinctrl-0 = <&pmic_int_l_pin>; rockchip,system-power-controller; wakeup-source;
@@ -627,7 +640,7 @@ reg = <0x40>; fcs,suspend-voltage-selector = <1>; pinctrl-names = "default"; - pinctrl-0 = <&vsel1_gpio>; + pinctrl-0 = <&vsel1_pin>; regulator-name = "vdd_cpu_b"; regulator-always-on; regulator-boot-on; @@ -646,7 +659,7 @@ reg = <0x41>; fcs,suspend-voltage-selector = <1>; pinctrl-names = "default"; - pinctrl-0 = <&vsel2_gpio>; + pinctrl-0 = <&vsel2_pin>; regulator-name = "vdd_gpu"; regulator-always-on; regulator-boot-on; @@ -690,9 +703,10 @@ fusb0: fusb30x@22 { compatible = "fcs,fusb302"; reg = <0x22>; - fcs,int_n = <&gpio1 RK_PA2 GPIO_ACTIVE_HIGH>; + interrupt-parent = <&gpio1>; + interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>; pinctrl-names = "default"; - pinctrl-0 = <&fusb0_int_gpio>; + pinctrl-0 = <&fusb0_int_pin>; vbus-supply = <&vbus_typec>;
connector { @@ -740,12 +754,29 @@ }; }; }; + + cw2015@62 { + compatible = "cellwise,cw2015"; + reg = <0x62>; + cellwise,battery-profile = /bits/ 8 < + 0x17 0x67 0x80 0x73 0x6E 0x6C 0x6B 0x63 + 0x77 0x51 0x5C 0x58 0x50 0x4C 0x48 0x36 + 0x15 0x0C 0x0C 0x19 0x5B 0x7D 0x6F 0x69 + 0x69 0x5B 0x0C 0x29 0x20 0x40 0x52 0x59 + 0x57 0x56 0x54 0x4F 0x3B 0x1F 0x7F 0x17 + 0x06 0x1A 0x30 0x5A 0x85 0x93 0x96 0x2D + 0x48 0x77 0x9C 0xB3 0x80 0x52 0x94 0xCB + 0x2F 0x00 0x64 0xA5 0xB5 0x11 0xF0 0x11 + >; + cellwise,monitor-interval-ms = <5000>; + monitored-battery = <&bat>; + power-supplies = <&mains_charger>, <&fusb0>; + }; };
&i2s1 { - #sound-dai-cells = <0>; pinctrl-names = "default"; - pinctrl-0 = <&i2s_8ch_mclk_gpio>, <&i2s1_2ch_bus>; + pinctrl-0 = <&i2s_8ch_mclk_pin>, <&i2s1_2ch_bus>; rockchip,capture-channels = <8>; rockchip,playback-channels = <8>; status = "okay"; @@ -765,7 +796,6 @@ &pcie0 { bus-scan-delay-ms = <1000>; ep-gpios = <&gpio2 RK_PD4 GPIO_ACTIVE_HIGH>; - max-link-speed = <2>; num-lanes = <4>; pinctrl-names = "default"; pinctrl-0 = <&pcie_clkreqn_cpm>; @@ -777,116 +807,116 @@
&pinctrl { buttons { - pwrbtn_gpio: pwrbtn-gpio { + pwrbtn_pin: pwrbtn-pin { rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; };
- lidbtn_gpio: lidbtn-gpio { + lidbtn_pin: lidbtn-pin { rockchip,pins = <1 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>; }; };
dc-charger { - dc_det_gpio: dc-det-gpio { + dc_det_pin: dc-det-pin { rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_up>; }; };
es8316 { - hp_det_gpio: hp-det-gpio { + hp_det_pin: hp-det-pin { rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>; }; };
fusb302x { - fusb0_int_gpio: fusb0-int-gpio { + fusb0_int_pin: fusb0-int-pin { rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; }; };
i2s1 { - i2s_8ch_mclk_gpio: i2s-8ch-mclk-gpio { + i2s_8ch_mclk_pin: i2s-8ch-mclk-pin { rockchip,pins = <4 RK_PA0 1 &pcfg_pull_none>; }; };
lcd-panel { - lcdvcc_en_gpio: lcdvcc-en-gpio { + lcdvcc_en_pin: lcdvcc-en-pin { rockchip,pins = <1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; };
- panel_en_gpio: panel-en-gpio { + panel_en_pin: panel-en-pin { rockchip,pins = <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; };
- lcd_panel_reset_gpio: lcd-panel-reset-gpio { + lcd_panel_reset_pin: lcd-panel-reset-pin { rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_up>; }; };
leds { - pwrled_gpio: pwrled_gpio { + pwr_led_pin: pwr-led-pin { rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; };
- slpled_gpio: slpled_gpio { + slp_led_pin: slp-led-pin { rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; }; };
pmic { - pmic_int_l_gpio: pmic-int-l-gpio { + pmic_int_l_pin: pmic-int-l-pin { rockchip,pins = <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>; };
sdcard { - sdmmc0_pwr_h_gpio: sdmmc0-pwr-h-gpio { + sdmmc0_pwr_h_pin: sdmmc0-pwr-h-pin { rockchip,pins = <0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; };
sdio-pwrseq { - wifi_enable_h_gpio: wifi-enable-h-gpio { + wifi_enable_h_pin: wifi-enable-h-pin { rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; }; };
usb-typec { - vcc5v0_typec0_en_gpio: vcc5v0-typec0-en-gpio { + vcc5v0_typec0_en_pin: vcc5v0-typec0-en-pin { rockchip,pins = <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; }; };
usb2 { - pwr_5v_gpio: pwr-5v-gpio { + pwr_5v_pin: pwr-5v-pin { rockchip,pins = <1 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; };
- vcc5v0_host_en_gpio: vcc5v0-host-en-gpio { + vcc5v0_host_en_pin: vcc5v0-host-en-pin { rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; }; };
wireless-bluetooth { - bt_wake_gpio: bt-wake-gpio { + bt_wake_pin: bt-wake-pin { rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; };
- bt_host_wake_gpio: bt-host-wake-gpio { + bt_host_wake_pin: bt-host-wake-pin { rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; };
- bt_reset_gpio: bt-reset-gpio { + bt_reset_pin: bt-reset-pin { rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; }; }; @@ -1034,7 +1064,7 @@ host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; max-speed = <1500000>; pinctrl-names = "default"; - pinctrl-0 = <&bt_host_wake_gpio &bt_wake_gpio &bt_reset_gpio>; + pinctrl-0 = <&bt_host_wake_pin &bt_wake_pin &bt_reset_pin>; shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; vbat-supply = <&wifi_bat>; vddio-supply = <&vcc_wl>; diff --git a/arch/arm/dts/rk3399-puma-haikou.dts b/arch/arm/dts/rk3399-puma-haikou.dts index d80d6b7268..292bb7e80c 100644 --- a/arch/arm/dts/rk3399-puma-haikou.dts +++ b/arch/arm/dts/rk3399-puma-haikou.dts @@ -10,14 +10,18 @@ model = "Theobroma Systems RK3399-Q7 SoM"; compatible = "tsd,rk3399-puma-haikou", "rockchip,rk3399";
+ aliases { + mmc1 = &sdmmc; + }; + chosen { stdout-path = "serial0:115200n8"; };
leds { - pinctrl-0 = <&led_pin_module>, <&led_sd_haikou>; + pinctrl-0 = <&module_led_pin>, <&sd_card_led_pin>;
- sd-card-led { + sd_card_led: led-1 { label = "sd_card_led"; gpios = <&gpio1 RK_PA2 GPIO_ACTIVE_HIGH>; linux,default-trigger = "mmc0"; @@ -179,7 +183,7 @@ };
leds { - led_sd_haikou: led-sd-gpio { + sd_card_led_pin: sd-card-led-pin { rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; }; diff --git a/arch/arm/dts/rk3399-puma.dtsi b/arch/arm/dts/rk3399-puma.dtsi index 72c06abd27..fb67db4619 100644 --- a/arch/arm/dts/rk3399-puma.dtsi +++ b/arch/arm/dts/rk3399-puma.dtsi @@ -8,12 +8,16 @@ #include "rk3399-opp.dtsi"
/ { + aliases { + mmc0 = &sdhci; + }; + leds { compatible = "gpio-leds"; pinctrl-names = "default"; - pinctrl-0 = <&led_pin_module>; + pinctrl-0 = <&module_led_pin>;
- module-led { + module_led: led-0 { label = "module_led"; gpios = <&gpio2 RK_PD1 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat"; @@ -21,57 +25,6 @@ }; };
- /* - * Overwrite the opp-table for CPUB as this board uses a different - * regulator (FAN53555) that only allows 10mV steps and therefore - * can't reach the operation point target voltages from rk3399-opp.dtsi - */ - /delete-node/ opp-table1; - cluster1_opp: opp-table1 { - compatible = "operating-points-v2"; - opp-shared; - - opp00 { - opp-hz = /bits/ 64 <408000000>; - opp-microvolt = <800000>; - clock-latency-ns = <40000>; - }; - opp01 { - opp-hz = /bits/ 64 <600000000>; - opp-microvolt = <800000>; - }; - opp02 { - opp-hz = /bits/ 64 <816000000>; - opp-microvolt = <830000>; - opp-suspend; - }; - opp03 { - opp-hz = /bits/ 64 <1008000000>; - opp-microvolt = <880000>; - }; - opp04 { - opp-hz = /bits/ 64 <1200000000>; - opp-microvolt = <950000>; - }; - opp05 { - opp-hz = /bits/ 64 <1416000000>; - opp-microvolt = <1030000>; - }; - opp06 { - opp-hz = /bits/ 64 <1608000000>; - opp-microvolt = <1100000>; - }; - opp07 { - opp-hz = /bits/ 64 <1800000000>; - opp-microvolt = <1200000>; - }; - opp08 { - opp-hz = /bits/ 64 <1992000000>; - opp-microvolt = <1230000>; - turbo-mode; - }; - }; - clkin_gmac: external-gmac-clock { compatible = "fixed-clock"; clock-frequency = <125000000>; @@ -450,7 +403,7 @@ };
leds { - led_pin_module: led-module-gpio { + module_led_pin: module-led-pin { rockchip,pins = <2 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; }; diff --git a/arch/arm/dts/rk3399-roc-pc-mezzanine.dts b/arch/arm/dts/rk3399-roc-pc-mezzanine.dts index 2acb3d500f..9447c8724b 100644 --- a/arch/arm/dts/rk3399-roc-pc-mezzanine.dts +++ b/arch/arm/dts/rk3399-roc-pc-mezzanine.dts @@ -11,6 +11,20 @@ model = "Firefly ROC-RK3399-PC Mezzanine Board"; compatible = "firefly,roc-rk3399-pc-mezzanine", "rockchip,rk3399";
+ aliases { + mmc2 = &sdio0; + }; + + /* MP8009 PoE PD */ + poe_12v: poe-12v { + compatible = "regulator-fixed"; + regulator-name = "poe_12v"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + vcc3v3_ngff: vcc3v3-ngff { compatible = "regulator-fixed"; regulator-name = "vcc3v3_ngff"; @@ -22,7 +36,7 @@ regulator-boot-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; - vin-supply = <&dc_12v>; + vin-supply = <&sys_12v>; };
vcc3v3_pcie: vcc3v3-pcie { @@ -34,10 +48,14 @@ pinctrl-0 = <&vcc3v3_pcie_en>; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; - vin-supply = <&dc_12v>; + vin-supply = <&sys_12v>; }; };
+&sys_12v { + vin-supply = <&poe_12v>; +}; + &pcie_phy { status = "okay"; }; diff --git a/arch/arm/dts/rk3399-roc-pc.dtsi b/arch/arm/dts/rk3399-roc-pc.dtsi index 9f225e9c3d..d1aaf8e833 100644 --- a/arch/arm/dts/rk3399-roc-pc.dtsi +++ b/arch/arm/dts/rk3399-roc-pc.dtsi @@ -13,6 +13,11 @@ model = "Firefly ROC-RK3399-PC Board"; compatible = "firefly,roc-rk3399-pc", "rockchip,rk3399";
+ aliases { + mmc0 = &sdmmc; + mmc1 = &sdhci; + }; + chosen { stdout-path = "serial2:1500000n8"; }; @@ -58,30 +63,37 @@ }; };
+ ir-receiver { + compatible = "gpio-ir-receiver"; + gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&ir_int>; + }; + leds { compatible = "gpio-leds"; pinctrl-names = "default"; - pinctrl-0 = <&work_led_gpio>, <&diy_led_gpio>, <&yellow_led_gpio>; + pinctrl-0 = <&work_led_pin>, <&diy_led_pin>, <&yellow_led_pin>;
- work-led { + work_led: led-0 { label = "green:work"; gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>; default-state = "on"; linux,default-trigger = "heartbeat"; };
- diy-led { + diy_led: led-1 { label = "red:diy"; gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>; default-state = "off"; - linux,default-trigger = "mmc1"; + linux,default-trigger = "mmc2"; };
- yellow-led { + yellow_led: led-2 { label = "yellow:yellow-led"; gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>; default-state = "off"; - linux,default-trigger = "mmc0"; + linux,default-trigger = "mmc1"; }; };
@@ -110,6 +122,14 @@ regulator-max-microvolt = <5000000>; };
+ sys_12v: sys-12v { + compatible = "regulator-fixed"; + regulator-name = "sys_12v"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&dc_12v>; + }; + /* switched by pmic_sleep */ vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { compatible = "regulator-fixed"; @@ -141,7 +161,7 @@ regulator-boot-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; - vin-supply = <&dc_12v>; + vin-supply = <&sys_12v>; };
vcca_0v9: vcca-0v9 { @@ -186,7 +206,7 @@ regulator-boot-on; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; - vin-supply = <&dc_12v>; + vin-supply = <&sys_12v>; };
vdd_log: vdd-log { @@ -376,6 +396,7 @@
vcc_sdio: LDO_REG4 { regulator-name = "vcc_sdio"; + regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <3000000>; @@ -456,7 +477,7 @@ reg = <0x40>; fcs,suspend-voltage-selector = <1>; pinctrl-names = "default"; - pinctrl-0 = <&vsel1_gpio>; + pinctrl-0 = <&vsel1_pin>; regulator-name = "vdd_cpu_b"; regulator-min-microvolt = <712500>; regulator-max-microvolt = <1500000>; @@ -475,11 +496,13 @@ reg = <0x41>; fcs,suspend-voltage-selector = <1>; pinctrl-names = "default"; - pinctrl-0 = <&vsel2_gpio>; + pinctrl-0 = <&vsel2_pin>; regulator-name = "vdd_gpu"; regulator-min-microvolt = <712500>; regulator-max-microvolt = <1500000>; regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; vin-supply = <&vcc3v3_sys>;
regulator-state-mem { @@ -588,6 +611,12 @@ }; };
+ ir { + ir_int: ir-int { + rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + lcd-panel { lcd_panel_reset: lcd-panel-reset { rockchip,pins = <4 RK_PD5 RK_FUNC_GPIO &pcfg_pull_up>; @@ -595,25 +624,25 @@ };
leds { - diy_led_gpio: diy_led-gpio { + diy_led_pin: diy-led-pin { rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; };
- work_led_gpio: work_led-gpio { + work_led_pin: work-led-pin { rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; };
- yellow_led_gpio: yellow_led-gpio { + yellow_led_pin: yellow-led-pin { rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; }; };
pmic { - vsel1_gpio: vsel1-gpio { + vsel1_pin: vsel1-pin { rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_down>; };
- vsel2_gpio: vsel2-gpio { + vsel2_pin: vsel2-pin { rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; }; }; diff --git a/arch/arm/dts/rk3399-rock-pi-4.dtsi b/arch/arm/dts/rk3399-rock-pi-4.dtsi index 1c55a4645b..b28888ea92 100644 --- a/arch/arm/dts/rk3399-rock-pi-4.dtsi +++ b/arch/arm/dts/rk3399-rock-pi-4.dtsi @@ -11,6 +11,11 @@ #include "rk3399-opp.dtsi"
/ { + aliases { + mmc0 = &sdmmc; + mmc1 = &sdhci; + }; + chosen { stdout-path = "serial2:1500000n8"; }; @@ -111,10 +116,6 @@ regulator-boot-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; };
vdd_log: vdd-log { @@ -362,8 +363,6 @@ regulator-name = "vcc_cam"; regulator-always-on; regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; regulator-state-mem { regulator-off-in-suspend; }; @@ -373,8 +372,6 @@ regulator-name = "vcc_mipi"; regulator-always-on; regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; regulator-state-mem { regulator-off-in-suspend; }; @@ -387,7 +384,7 @@ reg = <0x40>; fcs,suspend-voltage-selector = <1>; pinctrl-names = "default"; - pinctrl-0 = <&vsel1_gpio>; + pinctrl-0 = <&vsel1_pin>; regulator-name = "vdd_cpu_b"; regulator-min-microvolt = <712500>; regulator-max-microvolt = <1500000>; @@ -406,7 +403,7 @@ reg = <0x41>; fcs,suspend-voltage-selector = <1>; pinctrl-names = "default"; - pinctrl-0 = <&vsel2_gpio>; + pinctrl-0 = <&vsel2_pin>; regulator-name = "vdd_gpu"; regulator-min-microvolt = <712500>; regulator-max-microvolt = <1500000>; @@ -440,8 +437,9 @@ };
&i2s0 { - rockchip,playback-channels = <8>; - rockchip,capture-channels = <8>; + pinctrl-0 = <&i2s0_2ch_bus>; + rockchip,capture-channels = <2>; + rockchip,playback-channels = <2>; status = "okay"; };
@@ -476,7 +474,6 @@
&pcie0 { ep-gpios = <&gpio4 RK_PD3 GPIO_ACTIVE_HIGH>; - max-link-speed = <2>; num-lanes = <4>; pinctrl-0 = <&pcie_clkreqnb_cpm>; pinctrl-names = "default"; @@ -529,11 +526,11 @@ rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; };
- vsel2_gpio: vsel2-gpio { + vsel2_pin: vsel2-pin { rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; }; }; @@ -680,7 +677,7 @@
&usbdrd3_1 { diff --git a/arch/arm/dts/rk3399-rock-pi-4a.dts b/arch/arm/dts/rk3399-rock-pi-4a.dts index d96dd3ebd3..89f2af5e11 100644 --- a/arch/arm/dts/rk3399-rock-pi-4a.dts +++ b/arch/arm/dts/rk3399-rock-pi-4a.dts @@ -9,5 +9,5 @@
/ { model = "Radxa ROCK Pi 4A"; - compatible = "radxa,rockpi4", "rockchip,rk3399"; + compatible = "radxa,rockpi4a", "radxa,rockpi4", "rockchip,rk3399"; }; diff --git a/arch/arm/dts/rk3399-rock-pi-4b.dts b/arch/arm/dts/rk3399-rock-pi-4b.dts index 4ca970acac..6c63e61706 100644 --- a/arch/arm/dts/rk3399-rock-pi-4b.dts +++ b/arch/arm/dts/rk3399-rock-pi-4b.dts @@ -9,7 +9,11 @@
/ { model = "Radxa ROCK Pi 4B"; - compatible = "radxa,rockpi4", "rockchip,rk3399"; + compatible = "radxa,rockpi4b", "radxa,rockpi4", "rockchip,rk3399"; + + aliases { + mmc2 = &sdio0; + }; };
&sdio0 { diff --git a/arch/arm/dts/rk3399-rock-pi-4c.dts b/arch/arm/dts/rk3399-rock-pi-4c.dts index 9d07ebd1ec..99169bcd51 100644 --- a/arch/arm/dts/rk3399-rock-pi-4c.dts +++ b/arch/arm/dts/rk3399-rock-pi-4c.dts @@ -10,7 +10,11 @@
/ { model = "Radxa ROCK Pi 4C"; - compatible = "radxa,rockpi4", "rockchip,rk3399"; + compatible = "radxa,rockpi4c", "radxa,rockpi4", "rockchip,rk3399"; + + aliases { + mmc2 = &sdio0; + }; };
&sdio0 { diff --git a/arch/arm/dts/rk3399-rock960.dts b/arch/arm/dts/rk3399-rock960.dts index 437a75f31a..1a23e8f3cd 100644 --- a/arch/arm/dts/rk3399-rock960.dts +++ b/arch/arm/dts/rk3399-rock960.dts @@ -17,42 +17,43 @@ leds { compatible = "gpio-leds"; pinctrl-names = "default"; - pinctrl-0 = <&user_led1>, <&user_led2>, <&user_led3>, - <&user_led4>, <&wlan_led>, <&bt_led>; + pinctrl-0 = <&user_led1_pin>, <&user_led2_pin>, + <&user_led3_pin>, <&user_led4_pin>, + <&wlan_led_pin>, <&bt_led_pin>;
- user_led1 { + user_led1: led-1 { label = "green:user1"; gpios = <&gpio4 RK_PC2 0>; linux,default-trigger = "heartbeat"; };
- user_led2 { + user_led2: led-2 { label = "green:user2"; gpios = <&gpio4 RK_PC6 0>; linux,default-trigger = "mmc0"; };
- user_led3 { + user_led3: led-3 { label = "green:user3"; gpios = <&gpio4 RK_PD0 0>; linux,default-trigger = "mmc1"; };
- user_led4 { + user_led4: led-4 { label = "green:user4"; gpios = <&gpio4 RK_PD4 0>; panic-indicator; linux,default-trigger = "none"; };
- wlan_active_led { + wlan_active_led: led-5 { label = "yellow:wlan"; gpios = <&gpio4 RK_PD5 0>; linux,default-trigger = "phy0tx"; default-state = "off"; };
- bt_active_led { + bt_active_led: led-6 { label = "blue:bt"; gpios = <&gpio4 RK_PD6 0>; linux,default-trigger = "hci0-power"; @@ -62,38 +63,52 @@
+&cpu_alert0 { + temperature = <65000>; +}; + +&cpu_thermal { + sustainable-power = <1550>; + + cooling-maps { + map0 { + trip = <&cpu_alert1>; + }; + }; +}; + &pcie0 { ep-gpios = <&gpio2 RK_PA2 GPIO_ACTIVE_HIGH>; };
&pinctrl { leds { - user_led1: user_led1 { + user_led1_pin: user-led1-pin { rockchip,pins = <4 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; };
- user_led2: user_led2 { + user_led2_pin: user-led2-pin { rockchip,pins = <4 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; };
- user_led3: user_led3 { + user_led3_pin: user-led3-pin { rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; };
- user_led4: user_led4 { + user_led4_pin: user-led4-pin { rockchip,pins = <4 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; };
- wlan_led: wlan_led { + wlan_led_pin: wlan-led-pin { rockchip,pins = <4 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>; };
- bt_led: bt_led { + bt_led_pin: bt-led-pin { rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>; }; @@ -124,45 +139,6 @@ status = "okay"; };
-&thermal_zones { - cpu_thermal: cpu { - polling-delay-passive = <100>; - polling-delay = <1000>; - thermal-sensors = <&tsadc 0>; - sustainable-power = <1550>; - - trips { - cpu_alert0: cpu_alert0 { - temperature = <65000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu_alert1: cpu_alert1 { - temperature = <75000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu_crit: cpu_crit { - temperature = <95000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - - cooling-maps { - map0 { - - trip = <&cpu_alert1>; - cooling-device = - <&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&cpu_b1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; - }; -}; - &usbdrd_dwc3_0 { dr_mode = "otg"; }; diff --git a/arch/arm/dts/rk3399-rock960.dtsi b/arch/arm/dts/rk3399-rock960.dtsi index ba7c75c9f2..25dc61c26a 100644 --- a/arch/arm/dts/rk3399-rock960.dtsi +++ b/arch/arm/dts/rk3399-rock960.dtsi @@ -9,6 +9,12 @@ #include "rk3399-opp.dtsi"
/ { + aliases { + mmc0 = &sdio0; + mmc1 = &sdmmc; + mmc2 = &sdhci; + }; + sdio_pwrseq: sdio-pwrseq { compatible = "mmc-pwrseq-simple"; clocks = <&rk808 1>; @@ -470,12 +476,12 @@ <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; };
- vsel2_gpio: vsel2-gpio { + vsel2_pin: vsel2-pin { rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; }; diff --git a/arch/arm/dts/rk3399-rockpro64.dtsi b/arch/arm/dts/rk3399-rockpro64.dtsi index 9bca258012..6bff8db7d3 100644 --- a/arch/arm/dts/rk3399-rockpro64.dtsi +++ b/arch/arm/dts/rk3399-rockpro64.dtsi @@ -10,6 +10,12 @@ #include "rk3399-opp.dtsi"
/ { + aliases { + mmc0 = &sdio0; + mmc1 = &sdmmc; + mmc2 = &sdhci; + }; + chosen { stdout-path = "serial2:1500000n8"; }; @@ -36,18 +42,25 @@ }; };
- work-led { + work_led: led-0 { label = "work"; default-state = "on"; gpios = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>; };
- diy-led { + diy_led: led-1 { label = "diy"; default-state = "off"; gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>; @@ -72,10 +85,27 @@
sound { compatible = "audio-graph-card"; - label = "rockchip,rk3399"; + label = "Analog"; dais = <&i2s1_p0>; };
+ sound-dit { + compatible = "audio-graph-card"; + label = "SPDIF"; + dais = <&spdif_p0>; + }; + + spdif-dit { + compatible = "linux,spdif-dit"; + #sound-dai-cells = <0>; + + port { + dit_p0_0: endpoint { + remote-endpoint = <&spdif_p0_0>; + }; + }; + }; + vcc12v_dcin: vcc12v-dcin { compatible = "regulator-fixed"; regulator-name = "vcc12v_dcin"; @@ -96,6 +126,24 @@ vin-supply = <&vcc_1v8>; };
+ /* micro SD card power */ + vcc3v0_sd: vcc3v0-sd { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PA1 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc0_pwr_h>; + regulator-name = "vcc3v0_sd"; + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + vin-supply = <&vcc3v3_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + vcc3v3_pcie: vcc3v3-pcie-regulator { compatible = "regulator-fixed"; enable-active-high; @@ -427,7 +475,7 @@ reg = <0x40>; fcs,suspend-voltage-selector = <1>; pinctrl-names = "default"; - pinctrl-0 = <&vsel1_gpio>; + pinctrl-0 = <&vsel1_pin>; regulator-name = "vdd_cpu_b"; regulator-min-microvolt = <712500>; regulator-max-microvolt = <1500000>; @@ -446,7 +494,7 @@ reg = <0x41>; fcs,suspend-voltage-selector = <1>; pinctrl-names = "default"; - pinctrl-0 = <&vsel2_gpio>; + pinctrl-0 = <&vsel2_pin>; regulator-name = "vdd_gpu"; regulator-min-microvolt = <712500>; regulator-max-microvolt = <1500000>; @@ -569,12 +617,18 @@ }; };
+ ir { + ir_int: ir-int { + rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + leds { - work_led_gpio: work_led-gpio { + work_led_pin: work-led-pin { rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; };
- diy_led_gpio: diy_led-gpio { + diy_led_pin: diy-led-pin { rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; }; }; @@ -594,15 +648,22 @@ rockchip,pins = <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>; };
+ sdcard { + sdmmc0_pwr_h: sdmmc0-pwr-h { + rockchip,pins = <0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + }; + sdio-pwrseq { wifi_enable_h: wifi-enable-h { rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; @@ -661,6 +722,8 @@ max-frequency = <150000000>; pinctrl-names = "default"; pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>; + vmmc-supply = <&vcc3v0_sd>; + vqmmc-supply = <&vcc_sdio>; status = "okay"; };
@@ -671,6 +734,16 @@ status = "okay"; };
+&spdif { + pinctrl-0 = <&spdif_bus_1>; + + spdif_p0: port { + spdif_p0_0: endpoint { + remote-endpoint = <&dit_p0_0>; + }; + }; +}; + &spi1 { status = "okay";
@@ -768,7 +841,7 @@
&usbdrd3_1 { diff --git a/arch/arm/dts/rk3399.dtsi b/arch/arm/dts/rk3399.dtsi index 74f2c3d490..3871c7fd83 100644 --- a/arch/arm/dts/rk3399.dtsi +++ b/arch/arm/dts/rk3399.dtsi @@ -197,38 +197,12 @@ #clock-cells = <0>; };
- amba: bus { - compatible = "simple-bus"; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - dmac_bus: dma-controller@ff6d0000 { - compatible = "arm,pl330", "arm,primecell"; - reg = <0x0 0xff6d0000 0x0 0x4000>; - interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH 0>, - <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH 0>; - #dma-cells = <1>; - clocks = <&cru ACLK_DMAC0_PERILP>; - clock-names = "apb_pclk"; - }; - - dmac_peri: dma-controller@ff6e0000 { - compatible = "arm,pl330", "arm,primecell"; - reg = <0x0 0xff6e0000 0x0 0x4000>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH 0>, - <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH 0>; - #dma-cells = <1>; - clocks = <&cru ACLK_DMAC1_PERILP>; - clock-names = "apb_pclk"; - }; - }; - pcie0: pcie@f8000000 { compatible = "rockchip,rk3399-pcie"; reg = <0x0 0xf8000000 0x0 0x2000000>, <0x0 0xfd000000 0x0 0x1000000>; reg-names = "axi-base", "apb-base"; + device_type = "pci"; #address-cells = <3>; #size-cells = <2>; #interrupt-cells = <1>; @@ -247,15 +221,14 @@ <0 0 0 2 &pcie0_intc 1>, <0 0 0 3 &pcie0_intc 2>, <0 0 0 4 &pcie0_intc 3>; - linux,pci-domain = <0>; max-link-speed = <1>; msi-map = <0x0 &its 0x0 0x1000>; phys = <&pcie_phy 0>, <&pcie_phy 1>, <&pcie_phy 2>, <&pcie_phy 3>; phy-names = "pcie-phy-0", "pcie-phy-1", "pcie-phy-2", "pcie-phy-3"; - ranges = <0x83000000 0x0 0xfa000000 0x0 0xfa000000 0x0 0x1e00000 - 0x81000000 0x0 0xfbe00000 0x0 0xfbe00000 0x0 0x100000>; + ranges = <0x82000000 0x0 0xfa000000 0x0 0xfa000000 0x0 0x1e00000>, + <0x81000000 0x0 0xfbe00000 0x0 0xfbe00000 0x0 0x100000>; resets = <&cru SRST_PCIE_CORE>, <&cru SRST_PCIE_MGMT>, <&cru SRST_PCIE_MGMT_STICKY>, <&cru SRST_PCIE_PIPE>, <&cru SRST_PCIE_PM>, <&cru SRST_P_PCIE>, @@ -326,7 +299,7 @@ status = "disabled"; };
- sdhci: sdhci@fe330000 { + sdhci: mmc@fe330000 { compatible = "rockchip,rk3399-sdhci-5.1", "arasan,sdhci-5.1"; reg = <0x0 0xfe330000 0x0 0x10000>; interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH 0>; @@ -403,7 +376,7 @@ reset-names = "usb3-otg"; status = "disabled";
- usbdrd_dwc3_0: dwc3 { + usbdrd_dwc3_0: usb@fe800000 { compatible = "snps,dwc3"; reg = <0x0 0xfe800000 0x0 0x100000>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH 0>; @@ -439,7 +412,7 @@ reset-names = "usb3-otg"; status = "disabled";
- usbdrd_dwc3_1: dwc3 { + usbdrd_dwc3_1: usb@fe900000 { compatible = "snps,dwc3"; reg = <0x0 0xfe900000 0x0 0x100000>; interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH 0>; @@ -759,7 +732,7 @@ };
thermal_zones: thermal-zones { - cpu_thermal: cpu { + cpu_thermal: cpu-thermal { polling-delay-passive = <100>; polling-delay = <1000>;
@@ -803,7 +776,7 @@ }; };
- gpu_thermal: gpu { + gpu_thermal: gpu-thermal { polling-delay-passive = <100>; polling-delay = <1000>;
@@ -845,135 +818,135 @@ rockchip,grf = <&grf>; rockchip,hw-tshut-temp = <95000>; pinctrl-names = "init", "default", "sleep"; - pinctrl-0 = <&otp_gpio>; + pinctrl-0 = <&otp_pin>; pinctrl-1 = <&otp_out>; - pinctrl-2 = <&otp_gpio>; + pinctrl-2 = <&otp_pin>; #thermal-sensor-cells = <1>; status = "disabled"; };
qos_emmc: qos@ffa58000 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa58000 0x0 0x20>; };
qos_gmac: qos@ffa5c000 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa5c000 0x0 0x20>; };
qos_pcie: qos@ffa60080 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa60080 0x0 0x20>; };
qos_usb_host0: qos@ffa60100 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa60100 0x0 0x20>; };
qos_usb_host1: qos@ffa60180 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa60180 0x0 0x20>; };
qos_usb_otg0: qos@ffa70000 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa70000 0x0 0x20>; };
qos_usb_otg1: qos@ffa70080 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa70080 0x0 0x20>; };
qos_sd: qos@ffa74000 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa74000 0x0 0x20>; };
qos_sdioaudio: qos@ffa76000 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa76000 0x0 0x20>; };
qos_hdcp: qos@ffa90000 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa90000 0x0 0x20>; };
qos_iep: qos@ffa98000 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa98000 0x0 0x20>; };
qos_isp0_m0: qos@ffaa0000 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffaa0000 0x0 0x20>; };
qos_isp0_m1: qos@ffaa0080 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffaa0080 0x0 0x20>; };
qos_isp1_m0: qos@ffaa8000 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffaa8000 0x0 0x20>; };
qos_isp1_m1: qos@ffaa8080 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffaa8080 0x0 0x20>; };
qos_rga_r: qos@ffab0000 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffab0000 0x0 0x20>; };
qos_rga_w: qos@ffab0080 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffab0080 0x0 0x20>; };
qos_video_m0: qos@ffab8000 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffab8000 0x0 0x20>; };
qos_video_m1_r: qos@ffac0000 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffac0000 0x0 0x20>; };
qos_video_m1_w: qos@ffac0080 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffac0080 0x0 0x20>; };
qos_vop_big_r: qos@ffac8000 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffac8000 0x0 0x20>; };
qos_vop_big_w: qos@ffac8080 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffac8080 0x0 0x20>; };
qos_vop_little: qos@ffad0000 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffad0000 0x0 0x20>; };
qos_perihp: qos@ffad8080 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffad8080 0x0 0x20>; };
qos_gpu: qos@ffae0000 { - compatible = "syscon"; + compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffae0000 0x0 0x20>; };
@@ -995,126 +968,146 @@ #size-cells = <0>;
/* These power domains are grouped by VD_CENTER */ - pd_iep@RK3399_PD_IEP { + power-domain@RK3399_PD_IEP { reg = <RK3399_PD_IEP>; clocks = <&cru ACLK_IEP>, <&cru HCLK_IEP>; pm_qos = <&qos_iep>; + #power-domain-cells = <0>; }; - pd_rga@RK3399_PD_RGA { + power-domain@RK3399_PD_RGA { reg = <RK3399_PD_RGA>; clocks = <&cru ACLK_RGA>, <&cru HCLK_RGA>; pm_qos = <&qos_rga_r>, <&qos_rga_w>; + #power-domain-cells = <0>; }; - pd_vcodec@RK3399_PD_VCODEC { + power-domain@RK3399_PD_VCODEC { reg = <RK3399_PD_VCODEC>; clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>; pm_qos = <&qos_video_m0>; + #power-domain-cells = <0>; }; - pd_vdu@RK3399_PD_VDU { + power-domain@RK3399_PD_VDU { reg = <RK3399_PD_VDU>; clocks = <&cru ACLK_VDU>, <&cru HCLK_VDU>; pm_qos = <&qos_video_m1_r>, <&qos_video_m1_w>; + #power-domain-cells = <0>; };
/* These power domains are grouped by VD_GPU */ - pd_gpu@RK3399_PD_GPU { + power-domain@RK3399_PD_GPU { reg = <RK3399_PD_GPU>; clocks = <&cru ACLK_GPU>; pm_qos = <&qos_gpu>; + #power-domain-cells = <0>; };
/* These power domains are grouped by VD_LOGIC */ - pd_edp@RK3399_PD_EDP { + power-domain@RK3399_PD_EDP { reg = <RK3399_PD_EDP>; clocks = <&cru PCLK_EDP_CTRL>; + #power-domain-cells = <0>; }; - pd_emmc@RK3399_PD_EMMC { + power-domain@RK3399_PD_EMMC { reg = <RK3399_PD_EMMC>; clocks = <&cru ACLK_EMMC>; pm_qos = <&qos_emmc>; + #power-domain-cells = <0>; }; - pd_gmac@RK3399_PD_GMAC { + power-domain@RK3399_PD_GMAC { reg = <RK3399_PD_GMAC>; clocks = <&cru ACLK_GMAC>, <&cru PCLK_GMAC>; pm_qos = <&qos_gmac>; + #power-domain-cells = <0>; }; - pd_sd@RK3399_PD_SD { + power-domain@RK3399_PD_SD { reg = <RK3399_PD_SD>; clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>; pm_qos = <&qos_sd>; + #power-domain-cells = <0>; }; - pd_sdioaudio@RK3399_PD_SDIOAUDIO { + power-domain@RK3399_PD_SDIOAUDIO { reg = <RK3399_PD_SDIOAUDIO>; clocks = <&cru HCLK_SDIO>; pm_qos = <&qos_sdioaudio>; + #power-domain-cells = <0>; + }; + power-domain@RK3399_PD_TCPD0 { + reg = <RK3399_PD_TCPD0>; + clocks = <&cru SCLK_UPHY0_TCPDCORE>, + <&cru SCLK_UPHY0_TCPDPHY_REF>; + #power-domain-cells = <0>; + }; + power-domain@RK3399_PD_TCPD1 { + reg = <RK3399_PD_TCPD1>; + clocks = <&cru SCLK_UPHY1_TCPDCORE>, + <&cru SCLK_UPHY1_TCPDPHY_REF>; + #power-domain-cells = <0>; }; - pd_usb3@RK3399_PD_USB3 { + power-domain@RK3399_PD_USB3 { reg = <RK3399_PD_USB3>; clocks = <&cru ACLK_USB3>; pm_qos = <&qos_usb_otg0>, <&qos_usb_otg1>; + #power-domain-cells = <0>; }; - pd_vio@RK3399_PD_VIO { + power-domain@RK3399_PD_VIO { reg = <RK3399_PD_VIO>; + #power-domain-cells = <1>; #address-cells = <1>; #size-cells = <0>;
- pd_hdcp@RK3399_PD_HDCP { + power-domain@RK3399_PD_HDCP { reg = <RK3399_PD_HDCP>; clocks = <&cru ACLK_HDCP>, <&cru HCLK_HDCP>, <&cru PCLK_HDCP>; pm_qos = <&qos_hdcp>; + #power-domain-cells = <0>; }; - pd_isp0@RK3399_PD_ISP0 { + power-domain@RK3399_PD_ISP0 { reg = <RK3399_PD_ISP0>; clocks = <&cru ACLK_ISP0>, <&cru HCLK_ISP0>; pm_qos = <&qos_isp0_m0>, <&qos_isp0_m1>; + #power-domain-cells = <0>; }; - pd_isp1@RK3399_PD_ISP1 { + power-domain@RK3399_PD_ISP1 { reg = <RK3399_PD_ISP1>; clocks = <&cru ACLK_ISP1>, <&cru HCLK_ISP1>; pm_qos = <&qos_isp1_m0>, <&qos_isp1_m1>; + #power-domain-cells = <0>; }; - pd_tcpc0@RK3399_PD_TCPC0 { - reg = <RK3399_PD_TCPD0>; - clocks = <&cru SCLK_UPHY0_TCPDCORE>, - <&cru SCLK_UPHY0_TCPDPHY_REF>; - }; - pd_tcpc1@RK3399_PD_TCPC1 { - reg = <RK3399_PD_TCPD1>; - clocks = <&cru SCLK_UPHY1_TCPDCORE>, - <&cru SCLK_UPHY1_TCPDPHY_REF>; - }; - pd_vo@RK3399_PD_VO { + power-domain@RK3399_PD_VO { reg = <RK3399_PD_VO>; + #power-domain-cells = <1>; #address-cells = <1>; #size-cells = <0>;
- pd_vopb@RK3399_PD_VOPB { + power-domain@RK3399_PD_VOPB { reg = <RK3399_PD_VOPB>; clocks = <&cru ACLK_VOP0>, <&cru HCLK_VOP0>; pm_qos = <&qos_vop_big_r>, <&qos_vop_big_w>; + #power-domain-cells = <0>; }; - pd_vopl@RK3399_PD_VOPL { + power-domain@RK3399_PD_VOPL { reg = <RK3399_PD_VOPL>; clocks = <&cru ACLK_VOP1>, <&cru HCLK_VOP1>; pm_qos = <&qos_vop_little>; + #power-domain-cells = <0>; }; }; }; @@ -1124,8 +1117,6 @@ pmugrf: syscon@ff320000 { compatible = "rockchip,rk3399-pmugrf", "syscon", "simple-mfd"; reg = <0x0 0xff320000 0x0 0x1000>; - #address-cells = <1>; - #size-cells = <1>;
pmu_io_domains: io-domains { compatible = "rockchip,rk3399-pmu-io-voltage-domain"; @@ -1211,7 +1202,6 @@ pinctrl-names = "default"; pinctrl-0 = <&pwm0_pin>; clocks = <&pmucru PCLK_RKPWM_PMU>; - clock-names = "pwm"; status = "disabled"; };
@@ -1222,7 +1212,6 @@ pinctrl-names = "default"; pinctrl-0 = <&pwm1_pin>; clocks = <&pmucru PCLK_RKPWM_PMU>; - clock-names = "pwm"; status = "disabled"; };
@@ -1233,7 +1222,6 @@ pinctrl-names = "default"; pinctrl-0 = <&pwm2_pin>; clocks = <&pmucru PCLK_RKPWM_PMU>; - clock-names = "pwm"; status = "disabled"; };
@@ -1244,7 +1232,6 @@ pinctrl-names = "default"; pinctrl-0 = <&pwm3a_pin>; clocks = <&pmucru PCLK_RKPWM_PMU>; - clock-names = "pwm"; status = "disabled"; };
@@ -1271,6 +1258,17 @@ power-domains = <&power RK3399_PD_VCODEC>; };
+ vdec: video-codec@ff660000 { + compatible = "rockchip,rk3399-vdec"; + reg = <0x0 0xff660000 0x0 0x400>; + interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru ACLK_VDU>, <&cru HCLK_VDU>, + <&cru SCLK_VDU_CA>, <&cru SCLK_VDU_CORE>; + clock-names = "axi", "ahb", "cabac", "core"; + iommus = <&vdec_mmu>; + power-domains = <&power RK3399_PD_VDU>; + }; + vdec_mmu: iommu@ff660480 { compatible = "rockchip,iommu"; reg = <0x0 0xff660480 0x0 0x40>, <0x0 0xff6604c0 0x0 0x40>; @@ -1278,8 +1276,8 @@ interrupt-names = "vdec_mmu"; clocks = <&cru ACLK_VDU>, <&cru HCLK_VDU>; clock-names = "aclk", "iface"; + power-domains = <&power RK3399_PD_VDU>; #iommu-cells = <0>; - status = "disabled"; };
iep_mmu: iommu@ff670800 { @@ -1336,6 +1334,28 @@ }; };
+ dmac_bus: dma-controller@ff6d0000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0x0 0xff6d0000 0x0 0x4000>; + interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH 0>; + #dma-cells = <1>; + arm,pl330-periph-burst; + clocks = <&cru ACLK_DMAC0_PERILP>; + clock-names = "apb_pclk"; + }; + + dmac_peri: dma-controller@ff6e0000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0x0 0xff6e0000 0x0 0x4000>; + interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH 0>; + #dma-cells = <1>; + arm,pl330-periph-burst; + clocks = <&cru ACLK_DMAC1_PERILP>; + clock-names = "apb_pclk"; + }; + pmucru: pmu-clock-controller@ff750000 { compatible = "rockchip,rk3399-pmucru"; reg = <0x0 0xff750000 0x0 0x1000>; @@ -1387,7 +1407,18 @@ status = "disabled"; };
- u2phy0: usb2-phy@e450 { + mipi_dphy_rx0: mipi-dphy-rx0 { + compatible = "rockchip,rk3399-mipi-dphy-rx0"; + clocks = <&cru SCLK_MIPIDPHY_REF>, + <&cru SCLK_DPHY_RX0_CFG>, + <&cru PCLK_VIO_GRF>; + clock-names = "dphy-ref", "dphy-cfg", "grf"; + power-domains = <&power RK3399_PD_VIO>; + #phy-cells = <0>; + status = "disabled"; + }; + + u2phy0: usb2phy@e450 { compatible = "rockchip,rk3399-usb2phy"; reg = <0xe450 0x10>; clocks = <&cru SCLK_USB2PHY0_REF>; @@ -1414,7 +1445,7 @@ }; };
- u2phy1: usb2-phy@e460 { + u2phy1: usb2phy@e460 { compatible = "rockchip,rk3399-usb2phy"; reg = <0xe460 0x10>; clocks = <&cru SCLK_USB2PHY1_REF>; @@ -1513,7 +1544,7 @@ };
watchdog@ff848000 { - compatible = "snps,dw-wdt"; + compatible = "rockchip,rk3399-wdt", "snps,dw-wdt"; reg = <0x0 0xff848000 0x0 0x100>; clocks = <&cru PCLK_WDT>; interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH 0>; @@ -1700,6 +1731,32 @@ status = "disabled"; };
+ isp0: isp0@ff910000 { + compatible = "rockchip,rk3399-cif-isp"; + reg = <0x0 0xff910000 0x0 0x4000>; + interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru SCLK_ISP0>, + <&cru ACLK_ISP0_WRAPPER>, + <&cru HCLK_ISP0_WRAPPER>; + clock-names = "isp", "aclk", "hclk"; + iommus = <&isp0_mmu>; + phys = <&mipi_dphy_rx0>; + phy-names = "dphy"; + power-domains = <&power RK3399_PD_ISP0>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + }; + isp0_mmu: iommu@ff914000 { compatible = "rockchip,iommu"; reg = <0x0 0xff914000 0x0 0x100>, <0x0 0xff915000 0x0 0x100>; @@ -1883,10 +1940,10 @@ gpu: gpu@ff9a0000 { compatible = "rockchip,rk3399-mali", "arm,mali-t860"; reg = <0x0 0xff9a0000 0x0 0x10000>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH 0>, - <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH 0>, - <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH 0>; - interrupt-names = "gpu", "job", "mmu"; + interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH 0>; + interrupt-names = "job", "mmu", "gpu"; clocks = <&cru ACLK_GPU>; #cooling-cells = <2>; power-domains = <&power RK3399_PD_GPU>; @@ -2317,7 +2374,7 @@ }; };
- sleep { + suspend { ap_pwroff: ap-pwroff { rockchip,pins = <1 RK_PA5 1 &pcfg_pull_none>; }; @@ -2475,7 +2532,7 @@ };
tsadc { - otp_gpio: otp-gpio { + otp_pin: otp-pin { rockchip,pins = <1 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; };
diff --git a/arch/arm/dts/rk3399pro-vmarc-som.dtsi b/arch/arm/dts/rk3399pro-vmarc-som.dtsi index 5d087be04a..01d1a75c8b 100644 --- a/arch/arm/dts/rk3399pro-vmarc-som.dtsi +++ b/arch/arm/dts/rk3399pro-vmarc-som.dtsi @@ -12,6 +12,11 @@ / { compatible = "vamrs,rk3399pro-vmarc-som", "rockchip,rk3399pro";
+ aliases { + mmc0 = &sdmmc; + mmc1 = &sdhci; + }; + vcc3v3_pcie: vcc-pcie-regulator { compatible = "regulator-fixed"; enable-active-high; @@ -324,7 +329,6 @@
&pcie0 { ep-gpios = <&gpio0 RK_PB4 GPIO_ACTIVE_HIGH>; - max-link-speed = <2>; num-lanes = <4>; pinctrl-0 = <&pcie_clkreqnb_cpm>; pinctrl-names = "default"; @@ -353,6 +357,12 @@ }; };
+ sdio-pwrseq { + wifi_enable_h: wifi-enable-h { + rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + vbus_host { usb1_en_oc: usb1-en-oc { rockchip,pins = <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_up>; @@ -371,6 +381,16 @@ pmu1830-supply = <&vcc_1v8>; };
+&sdio_pwrseq { + /* + * On the module itself this is one of these (depending + * on the actual card populated): + * - SDIO_RESET_L_WL_REG_ON + * - PDN (power down when low) + */ + reset-gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_LOW>; +}; + &sdhci { bus-width = <8>; mmc-hs400-1_8v; diff --git a/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi b/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi index 26b53eac47..da1d548b73 100644 --- a/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi +++ b/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi @@ -15,6 +15,14 @@ #clock-cells = <0>; };
+ sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&hym8563>; + clock-names = "ext_clock"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_enable_h>; + }; + vcc12v_dcin: vcc12v-dcin-regulator { compatible = "regulator-fixed"; regulator-name = "vcc12v_dcin"; @@ -78,6 +86,19 @@ status = "okay"; };
+&sdio0 { + bus-width = <4>; + cap-sd-highspeed; + cap-sdio-irq; + keep-power-in-suspend; + mmc-pwrseq = <&sdio_pwrseq>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; + sd-uhs-sdr104; + status = "okay"; +}; + &sdmmc { bus-width = <4>; cap-mmc-highspeed;
Sync the rk3328 DTs and associated bits from 5.14-rc1.
Signed-off-by: Peter Robinson pbrobinson@gmail.com --- arch/arm/dts/rk3328-evb.dts | 23 +- arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi | 2 +- arch/arm/dts/rk3328-nanopi-r2s.dts | 51 ++- arch/arm/dts/rk3328-roc-cc-u-boot.dtsi | 2 +- arch/arm/dts/rk3328-roc-cc.dts | 41 +- arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi | 4 +- arch/arm/dts/rk3328-rock-pi-e.dts | 439 +++++++++++++-------- arch/arm/dts/rk3328-rock64-u-boot.dtsi | 2 +- arch/arm/dts/rk3328-rock64.dts | 72 ++-- arch/arm/dts/rk3328.dtsi | 109 ++--- 10 files changed, 487 insertions(+), 258 deletions(-)
diff --git a/arch/arm/dts/rk3328-evb.dts b/arch/arm/dts/rk3328-evb.dts index 6abc6f4a86..ff6b466e0e 100644 --- a/arch/arm/dts/rk3328-evb.dts +++ b/arch/arm/dts/rk3328-evb.dts @@ -10,6 +10,12 @@ model = "Rockchip RK3328 EVB"; compatible = "rockchip,rk3328-evb", "rockchip,rk3328";
+ aliases { + mmc0 = &sdmmc; + mmc1 = &sdio; + mmc2 = &emmc; + }; + chosen { stdout-path = "serial2:1500000n8"; }; @@ -41,7 +47,7 @@ compatible = "regulator-fixed"; gpio = <&gpio0 30 GPIO_ACTIVE_LOW>; pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0m1_gpio>; + pinctrl-0 = <&sdmmc0m1_pin>; regulator-name = "vcc_sd"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; @@ -70,6 +76,18 @@ cpu-supply = <&vdd_arm>; };
+&cpu1 { + cpu-supply = <&vdd_arm>; +}; + +&cpu2 { + cpu-supply = <&vdd_arm>; +}; + +&cpu3 { + cpu-supply = <&vdd_arm>; +}; + &emmc { bus-width = <8>; cap-mmc-highspeed; @@ -82,11 +100,10 @@ &gmac2phy { phy-supply = <&vcc_phy>; clock_in_out = "output"; - assigned-clocks = <&cru SCLK_MAC2PHY_SRC>; assigned-clock-rate = <50000000>; assigned-clocks = <&cru SCLK_MAC2PHY>; assigned-clock-parents = <&cru SCLK_MAC2PHY_SRC>; - + status = "okay"; };
&i2c1 { diff --git a/arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi b/arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi index 9e2ced1541..8db5e55af6 100644 --- a/arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi +++ b/arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi @@ -20,7 +20,7 @@ u-boot,dm-spl; };
-&sdmmc0m1_gpio { +&sdmmc0m1_pin { u-boot,dm-spl; };
diff --git a/arch/arm/dts/rk3328-nanopi-r2s.dts b/arch/arm/dts/rk3328-nanopi-r2s.dts index 5445c5cb3d..3857d487ab 100644 --- a/arch/arm/dts/rk3328-nanopi-r2s.dts +++ b/arch/arm/dts/rk3328-nanopi-r2s.dts @@ -13,6 +13,11 @@ model = "FriendlyElec NanoPi R2S"; compatible = "friendlyarm,nanopi-r2s", "rockchip,rk3328";
+ aliases { + ethernet1 = &rtl8153; + mmc0 = &sdmmc; + }; + chosen { stdout-path = "serial2:1500000n8"; }; @@ -50,6 +55,7 @@ sys_led: led-1 { gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>; label = "nanopi-r2s:red:sys"; + default-state = "on"; };
wan_led: led-2 { @@ -71,15 +77,15 @@ regulator-settling-time-us = <5000>; regulator-type = "voltage"; startup-delay-us = <2000>; - states = <1800000 0x1 - 3300000 0x0>; + states = <1800000 0x1>, + <3300000 0x0>; vin-supply = <&vcc_io_33>; };
vcc_sd: sdmmc-regulator { compatible = "regulator-fixed"; gpio = <&gpio0 RK_PD6 GPIO_ACTIVE_LOW>; - pinctrl-0 = <&sdmmc0m1_gpio>; + pinctrl-0 = <&sdmmc0m1_pin>; pinctrl-names = "default"; regulator-name = "vcc_sd"; regulator-boot-on; @@ -96,6 +102,18 @@ regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; }; + + vdd_5v_lan: vdd-5v-lan { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio2 RK_PC6 GPIO_ACTIVE_HIGH>; + pinctrl-0 = <&lan_vdd_pin>; + pinctrl-names = "default"; + regulator-name = "vdd_5v_lan"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vdd_5v>; + }; };
&cpu0 { @@ -114,6 +132,10 @@ cpu-supply = <&vdd_arm>; };
+&display_subsystem { + status = "disabled"; +}; + &gmac2io { assigned-clocks = <&cru SCLK_MAC2IO>, <&cru SCLK_MAC2IO_EXT>; assigned-clock-parents = <&gmac_clk>, <&gmac_clk>; @@ -134,8 +156,6 @@ #size-cells = <0>;
rtl8211e: ethernet-phy@1 { - compatible = "ethernet-phy-id001c.c915", - "ethernet-phy-ieee802.3-c22"; reg = <1>; pinctrl-0 = <ð_phy_reset_pin>; pinctrl-names = "default"; @@ -282,7 +302,7 @@ }; };
- ethernet-phy { + gmac2io { eth_phy_reset_pin: eth-phy-reset-pin { rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_down>; }; @@ -302,6 +322,12 @@ }; };
+ lan { + lan_vdd_pin: lan-vdd-pin { + rockchip,pins = <2 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + pmic { pmic_int_l: pmic-int-l { rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_up>; @@ -361,6 +387,19 @@ dr_mode = "host"; };
+&usbdrd3 { + dr_mode = "host"; + status = "okay"; + #address-cells = <1>; + #size-cells = <0>; + + /* Second port is for USB 3.0 */ + rtl8153: device@2 { + compatible = "usbbda,8153"; + reg = <2>; + }; +}; + &usb_host0_ehci { status = "okay"; }; diff --git a/arch/arm/dts/rk3328-roc-cc-u-boot.dtsi b/arch/arm/dts/rk3328-roc-cc-u-boot.dtsi index 08806dfc0f..20a62134a0 100644 --- a/arch/arm/dts/rk3328-roc-cc-u-boot.dtsi +++ b/arch/arm/dts/rk3328-roc-cc-u-boot.dtsi @@ -40,7 +40,7 @@ u-boot,dm-spl; };
diff --git a/arch/arm/dts/rk3328-roc-cc.dts b/arch/arm/dts/rk3328-roc-cc.dts index 8d553c9218..aa22a0c222 100644 --- a/arch/arm/dts/rk3328-roc-cc.dts +++ b/arch/arm/dts/rk3328-roc-cc.dts @@ -10,6 +10,11 @@ model = "Firefly roc-rk3328-cc"; compatible = "firefly,roc-rk3328-cc", "rockchip,rk3328";
+ aliases { + mmc0 = &sdmmc; + mmc1 = &emmc; + }; + chosen { stdout-path = "serial2:1500000n8"; }; @@ -34,7 +39,7 @@ compatible = "regulator-fixed"; gpio = <&gpio0 RK_PD6 GPIO_ACTIVE_LOW>; pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0m1_gpio>; + pinctrl-0 = <&sdmmc0m1_pin>; regulator-boot-on; regulator-name = "vcc_sd"; regulator-min-microvolt = <3300000>; @@ -45,8 +50,8 @@ vcc_sdio: sdmmcio-regulator { compatible = "regulator-gpio"; gpios = <&grf_gpio 0 GPIO_ACTIVE_HIGH>; - states = <1800000 0x1 - 3300000 0x0>; + states = <1800000 0x1>, + <3300000 0x0>; regulator-name = "vcc_sdio"; regulator-type = "voltage"; regulator-min-microvolt = <1800000>; @@ -86,7 +91,7 @@ leds { compatible = "gpio-leds";
- power { + power_led: led-0 { label = "firefly:blue:power"; linux,default-trigger = "heartbeat"; gpios = <&rk805 1 GPIO_ACTIVE_LOW>; @@ -94,7 +99,7 @@ mode = <0x23>; };
- user { + user_led: led-1 { label = "firefly:yellow:user"; linux,default-trigger = "mmc1"; gpios = <&rk805 0 GPIO_ACTIVE_LOW>; @@ -104,6 +109,14 @@ }; };
+&analog_sound { + status = "okay"; +}; + +&codec { + status = "okay"; +}; + &cpu0 { cpu-supply = <&vdd_arm>; }; @@ -161,6 +174,10 @@ status = "okay"; };
+&hdmi_sound { + status = "okay"; +}; + &i2c1 { status = "okay";
@@ -270,6 +287,14 @@ }; };
+&i2s0 { + status = "okay"; +}; + +&i2s1 { + status = "okay"; +}; + &io_domains { status = "okay";
@@ -334,6 +359,12 @@ };
&usb20_otg { + dr_mode = "host"; + status = "okay"; +}; + +&usbdrd3 { + dr_mode = "host"; status = "okay"; };
diff --git a/arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi b/arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi index 4fc055eacb..9d557eb988 100644 --- a/arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi +++ b/arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi @@ -37,7 +37,7 @@ u-boot,dm-spl; };
@@ -46,7 +46,7 @@ };
&usb_host0_xhci { - vbus-supply = <&vcc5v0_host_xhci>; + vbus-supply = <&vcc_host_5v>; status = "okay"; };
diff --git a/arch/arm/dts/rk3328-rock-pi-e.dts b/arch/arm/dts/rk3328-rock-pi-e.dts index 4b9f9a8248..018a3a5075 100644 --- a/arch/arm/dts/rk3328-rock-pi-e.dts +++ b/arch/arm/dts/rk3328-rock-pi-e.dts @@ -1,58 +1,118 @@ -// SPDX-License-Identifier: GPL-2.0+ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* - * (C) Copyright 2020 Radxa + * (C) Copyright 2020 Chen-Yu Tsai wens@csie.org + * + * Based on ./rk3328-rock64.dts, which is + * + * Copyright (c) 2017 PINE64 */
/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/pinctrl/rockchip.h> + #include "rk3328.dtsi"
/ { - model = "Radxa Rockpi E"; - compatible = "radxa,rock-pi-e", "rockchip,rk3328"; + model = "Radxa ROCK Pi E"; + compatible = "radxa,rockpi-e", "rockchip,rk3328"; + + aliases { + mmc0 = &sdmmc; + mmc1 = &emmc; + };
chosen { - stdout-path = "serial2:1500000n8"; + stdout-path = "serial2:1500000n8"; + }; + + adc-keys { + compatible = "adc-keys"; + io-channels = <&saradc 0>; + io-channel-names = "buttons"; + keyup-threshold-microvolt = <1750000>; + + /* This button is unpopulated out of the factory. */ + button-recovery { + label = "Recovery"; + linux,code = <KEY_VENDOR>; + press-threshold-microvolt = <10000>; + }; };
gmac_clkin: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "gmac_clkin"; - #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "gmac_clkin"; + #clock-cells = <0>; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-0 = <&led_pin>; + pinctrl-names = "default"; + + led-0 { + color = <LED_COLOR_ID_BLUE>; + gpios = <&gpio3 RK_PA5 GPIO_ACTIVE_LOW>; + linux,default-trigger = "heartbeat"; + }; };
vcc_sd: sdmmc-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio0 RK_PD6 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0m1_gpio>; - regulator-name = "vcc_sd"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc_io>; + compatible = "regulator-fixed"; + gpio = <&gpio0 RK_PD6 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc0m1_pin>; + regulator-name = "vcc_sd"; + regulator-boot-on; + vin-supply = <&vcc_io>; };
- vcc5v0_host_xhci: vcc5v0-host-xhci-drv { - compatible = "regulator-fixed"; - enable-active-high; - regulator-name = "vcc5v0_host_xhci"; - gpio = <&gpio3 RK_PA7 GPIO_ACTIVE_HIGH>; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; + vcc_host_5v: vcc-host-5v-regulator { + compatible = "regulator-fixed"; + gpio = <&gpio3 RK_PA7 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&usb30_host_drv>; + enable-active-high; + regulator-name = "vcc_host_5v"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc_sys>; };
vcc_sys: vcc-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; + compatible = "regulator-fixed"; + regulator-name = "vcc_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vcc_wifi: vcc-wifi-regulator { + compatible = "regulator-fixed"; + gpio = <&gpio0 RK_PA0 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_en>; + regulator-name = "vcc_wifi"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc_io>; }; };
+&analog_sound { + status = "okay"; +}; + +&codec { + status = "okay"; +}; + &cpu0 { cpu-supply = <&vdd_arm>; }; @@ -72,13 +132,11 @@ &emmc { bus-width = <8>; cap-mmc-highspeed; + mmc-ddr-1_8v; mmc-hs200-1_8v; - supports-emmc; - disable-wp; non-removable; - num-slots = <1>; pinctrl-names = "default"; - pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8>; + pinctrl-0 = <&emmc_clk>, <&emmc_cmd>, <&emmc_bus8>; vmmc-supply = <&vcc_io>; vqmmc-supply = <&vcc18_emmc>; status = "okay"; @@ -88,180 +146,245 @@ assigned-clocks = <&cru SCLK_MAC2IO>, <&cru SCLK_MAC2IO_EXT>; assigned-clock-parents = <&gmac_clkin>, <&gmac_clkin>; clock_in_out = "input"; - phy-supply = <&vcc_io>; + phy-handle = <&rtl8211e>; phy-mode = "rgmii"; + phy-supply = <&vcc_io>; pinctrl-names = "default"; pinctrl-0 = <&rgmiim1_pins>; - snps,force_thresh_dma_mode; - snps,reset-gpio = <&gpio1 RK_PC2 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 50000>; + snps,aal; + snps,rxpbl = <0x4>; + snps,txpbl = <0x4>; tx_delay = <0x26>; rx_delay = <0x11>; status = "okay"; + + mdio { + compatible = "snps,dwmac-mdio"; + #address-cells = <1>; + #size-cells = <0>; + + rtl8211e: ethernet-phy@1 { + reg = <1>; + pinctrl-0 = <ð_phy_int_pin>, <ð_phy_reset_pin>; + pinctrl-names = "default"; + interrupt-parent = <&gpio1>; + interrupts = <24 IRQ_TYPE_LEVEL_LOW>; + reset-assert-us = <10000>; + reset-deassert-us = <50000>; + reset-gpios = <&gpio1 RK_PC2 GPIO_ACTIVE_LOW>; + }; + }; };
-&i2c1 { +&gmac2phy { status = "okay"; +};
- rk805: rk805@18 { - compatible = "rockchip,rk805"; +&i2c1 { status = "okay"; - reg = <0x18>; - interrupt-parent = <&gpio2>; - interrupts = <6 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk805-clkout2"; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc_sys>; - vcc2-supply = <&vcc_sys>; - vcc3-supply = <&vcc_sys>; - vcc4-supply = <&vcc_sys>; - vcc5-supply = <&vcc_io>; - vcc6-supply = <&vcc_sys>; - - regulators { - vdd_logic: DCDC_REG1 { - regulator-name = "vdd_logic"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1450000>; - regulator-ramp-delay = <12500>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vdd_arm: DCDC_REG2 { - regulator-name = "vdd_arm"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1450000>; - regulator-ramp-delay = <12500>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <950000>; - }; - };
- vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_io: DCDC_REG4 { - regulator-name = "vcc_io"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc_18: LDO_REG1 { - regulator-name = "vcc_18"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc18_emmc: LDO_REG2 { - regulator-name = "vcc18_emmc"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vdd_10: LDO_REG3 { - regulator-name = "vdd_10"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - }; + rk805: pmic@18 { + compatible = "rockchip,rk805"; + reg = <0x18>; + interrupt-parent = <&gpio2>; + interrupts = <6 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk805-clkout2"; + gpio-controller; + #gpio-cells = <2>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + + vcc1-supply = <&vcc_sys>; + vcc2-supply = <&vcc_sys>; + vcc3-supply = <&vcc_sys>; + vcc4-supply = <&vcc_sys>; + vcc5-supply = <&vcc_io>; + vcc6-supply = <&vcc_sys>; + + regulators { + vdd_log: DCDC_REG1 { + regulator-name = "vdd_log"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1450000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + vdd_arm: DCDC_REG2 { + regulator-name = "vdd_arm"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1450000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <950000>; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_io: DCDC_REG4 { + regulator-name = "vcc_io"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcc_18: LDO_REG1 { + regulator-name = "vcc_18"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc18_emmc: LDO_REG2 { + regulator-name = "vcc18_emmc"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdd_10: LDO_REG3 { + regulator-name = "vdd_10"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + }; }; };
-&io_domains { +&i2s1 { status = "okay"; +};
+&io_domains { + pmuio-supply = <&vcc_io>; vccio1-supply = <&vcc_io>; vccio2-supply = <&vcc18_emmc>; vccio3-supply = <&vcc_io>; vccio4-supply = <&vcc_io>; vccio5-supply = <&vcc_io>; vccio6-supply = <&vcc_io>; - pmuio-supply = <&vcc_io>; + status = "okay"; };
&pinctrl { + ephy { + eth_phy_int_pin: eth-phy-int-pin { + rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + eth_phy_reset_pin: eth-phy-reset-pin { + rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; + + leds { + led_pin: led-pin { + rockchip,pins = <3 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <2 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>; + pmic_int_l: pmic-int-l { + rockchip,pins = <2 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>; + }; }; + + usb3 { + usb30_host_drv: usb30-host-drv { + rockchip,pins = <3 RK_PA7 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + wifi { + wifi_en: wifi-en { + rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; + }; }; };
&sdmmc { bus-width = <4>; - cap-mmc-highspeed; cap-sd-highspeed; - card-detect-delay = <200>; disable-wp; - max-frequency = <150000000>; - num-slots = <1>; pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_clk &sdmmc0_cmd &sdmmc0_dectn &sdmmc0_bus4>; - supports-sd; + pinctrl-0 = <&sdmmc0_clk>, <&sdmmc0_cmd>, <&sdmmc0_dectn>, <&sdmmc0_bus4>; vmmc-supply = <&vcc_sd>; status = "okay"; };
&saradc { + vref-supply = <&vcc_18>; status = "okay"; };
-&uart2 { +&tsadc { status = "okay"; };
-&usb20_otg { +&u2phy { status = "okay"; };
-&usb_host0_ehci { +&u2phy_host { status = "okay"; };
-&usb_host0_ohci { +&uart2 { + status = "okay"; +}; + +&usbdrd3 { + dr_mode = "host"; + status = "okay"; +}; + +&usb_host0_ehci { status = "okay"; }; diff --git a/arch/arm/dts/rk3328-rock64-u-boot.dtsi b/arch/arm/dts/rk3328-rock64-u-boot.dtsi index 2af32aea05..3c3b1370e3 100644 --- a/arch/arm/dts/rk3328-rock64-u-boot.dtsi +++ b/arch/arm/dts/rk3328-rock64-u-boot.dtsi @@ -40,7 +40,7 @@ u-boot,dm-spl; };
diff --git a/arch/arm/dts/rk3328-rock64.dts b/arch/arm/dts/rk3328-rock64.dts index ebf3eb222e..1b0f7e4551 100644 --- a/arch/arm/dts/rk3328-rock64.dts +++ b/arch/arm/dts/rk3328-rock64.dts @@ -10,6 +10,11 @@ model = "Pine64 Rock64"; compatible = "pine64,rock64", "rockchip,rk3328";
+ aliases { + mmc0 = &sdmmc; + mmc1 = &emmc; + }; + chosen { stdout-path = "serial2:1500000n8"; }; @@ -25,7 +30,7 @@ compatible = "regulator-fixed"; gpio = <&gpio0 RK_PD6 GPIO_ACTIVE_LOW>; pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0m1_gpio>; + pinctrl-0 = <&sdmmc0m1_pin>; regulator-name = "vcc_sd"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; @@ -73,45 +78,43 @@ leds { compatible = "gpio-leds";
- power { + power_led: led-0 { gpios = <&rk805 1 GPIO_ACTIVE_LOW>; linux,default-trigger = "mmc0"; };
- standby { + standby_led: led-1 { gpios = <&rk805 0 GPIO_ACTIVE_LOW>; linux,default-trigger = "heartbeat"; }; };
- sound { - compatible = "audio-graph-card"; - label = "rockchip,rk3328"; - dais = <&i2s1_p0 - &spdif_p0>; + spdif_sound: spdif-sound { + compatible = "simple-audio-card"; + simple-audio-card,name = "SPDIF"; + + simple-audio-card,cpu { + sound-dai = <&spdif>; + }; + + simple-audio-card,codec { + sound-dai = <&spdif_dit>; + }; };
- spdif-dit { + spdif_dit: spdif-dit { compatible = "linux,spdif-dit"; #sound-dai-cells = <0>; - - port { - dit_p0_0: endpoint { - remote-endpoint = <&spdif_p0_0>; - }; - }; }; };
+&analog_sound { + status = "okay"; +}; + &codec { mute-gpios = <&grf_gpio 0 GPIO_ACTIVE_LOW>; status = "okay"; - - port@0 { - codec_p0_0: endpoint { - remote-endpoint = <&i2s1_p0_0>; - }; - }; };
&cpu0 { @@ -163,6 +166,10 @@ status = "okay"; };
+&hdmi_sound { + status = "okay"; +}; + &hdmiphy { status = "okay"; }; @@ -278,16 +285,12 @@ }; };
-&i2s1 { +&i2s0 { status = "okay"; +};
- i2s1_p0: port { - i2s1_p0_0: endpoint { - dai-format = "i2s"; - mclk-fs = <256>; - remote-endpoint = <&codec_p0_0>; - }; - }; +&i2s1 { + status = "okay"; };
&io_domains { @@ -337,12 +340,6 @@ &spdif { pinctrl-0 = <&spdifm0_tx>; status = "okay"; - - spdif_p0: port { - spdif_p0_0: endpoint { - remote-endpoint = <&dit_p0_0>; - }; - }; };
&spi0 { @@ -384,6 +381,11 @@ status = "okay"; };
+&usbdrd3 { + dr_mode = "host"; + status = "okay"; +}; + &usb_host0_ehci { status = "okay"; }; diff --git a/arch/arm/dts/rk3328.dtsi b/arch/arm/dts/rk3328.dtsi index 945387e579..27e45d5886 100644 --- a/arch/arm/dts/rk3328.dtsi +++ b/arch/arm/dts/rk3328.dtsi @@ -142,23 +142,6 @@ }; };
- amba: bus { - compatible = "simple-bus"; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - dmac: dmac@ff1f0000 { - compatible = "arm,pl330", "arm,primecell"; - reg = <0x0 0xff1f0000 0x0 0x4000>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_DMAC>; - clock-names = "apb_pclk"; - #dma-cells = <1>; - }; - }; - analog_sound: analog-sound { compatible = "simple-audio-card"; simple-audio-card,format = "i2s"; @@ -305,7 +288,7 @@ status = "disabled"; };
- grf_gpio: grf-gpio { + grf_gpio: gpio { compatible = "rockchip,rk3328-grf-gpio"; gpio-controller; #gpio-cells = <2>; @@ -317,15 +300,18 @@ #address-cells = <1>; #size-cells = <0>;
- pd_hevc@RK3328_PD_HEVC { + power-domain@RK3328_PD_HEVC { reg = <RK3328_PD_HEVC>; + #power-domain-cells = <0>; }; - pd_video@RK3328_PD_VIDEO { + power-domain@RK3328_PD_VIDEO { reg = <RK3328_PD_VIDEO>; + #power-domain-cells = <0>; }; - pd_vpu@RK3328_PD_VPU { + power-domain@RK3328_PD_VPU { reg = <RK3328_PD_VPU>; clocks = <&cru ACLK_VPU>, <&cru HCLK_VPU>; + #power-domain-cells = <0>; }; };
@@ -452,7 +438,7 @@ };
wdt: watchdog@ff1a0000 { - compatible = "snps,dw-wdt"; + compatible = "rockchip,rk3328-wdt", "snps,dw-wdt"; reg = <0x0 0xff1a0000 0x0 0x100>; interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru PCLK_WDT>; @@ -503,6 +489,17 @@ status = "disabled"; };
+ dmac: dmac@ff1f0000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0x0 0xff1f0000 0x0 0x4000>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; + arm,pl330-periph-burst; + clocks = <&cru ACLK_DMAC>; + clock-names = "apb_pclk"; + #dma-cells = <1>; + }; + thermal-zones { soc_thermal: soc-thermal { polling-delay-passive = <20>; @@ -552,9 +549,9 @@ clocks = <&cru SCLK_TSADC>, <&cru PCLK_TSADC>; clock-names = "tsadc", "apb_pclk"; pinctrl-names = "init", "default", "sleep"; - pinctrl-0 = <&otp_gpio>; + pinctrl-0 = <&otp_pin>; pinctrl-1 = <&otp_out>; - pinctrl-2 = <&otp_gpio>; + pinctrl-2 = <&otp_pin>; resets = <&cru SRST_TSADC>; reset-names = "tsadc-apb"; rockchip,grf = <&grf>; @@ -822,7 +819,7 @@ #address-cells = <1>; #size-cells = <1>;
- u2phy: usb2-phy@100 { + u2phy: usb2phy@100 { compatible = "rockchip,rk3328-usb2phy"; reg = <0x100 0x10>; clocks = <&xin24m>; @@ -922,11 +919,12 @@ "mac_clk_tx", "clk_mac_ref", "aclk_mac", "pclk_mac", "clk_macphy"; - resets = <&cru SRST_GMAC2PHY_A>, <&cru SRST_MACPHY>; - reset-names = "stmmaceth", "mac-phy"; + resets = <&cru SRST_GMAC2PHY_A>; + reset-names = "stmmaceth"; phy-mode = "rmii"; phy-handle = <&phy>; snps,txpbl = <0x4>; + clock_in_out = "output"; status = "disabled";
mdio { @@ -934,7 +932,7 @@ #address-cells = <1>; #size-cells = <0>;
- phy: phy@0 { + phy: ethernet-phy@0 { compatible = "ethernet-phy-id1234.d400", "ethernet-phy-ieee802.3-c22"; reg = <0>; clocks = <&cru SCLK_MAC2PHY_OUT>; @@ -966,6 +964,25 @@ status = "disabled"; };
+ usbdrd3: usb@ff600000 { + compatible = "rockchip,rk3328-dwc3", "snps,dwc3"; + reg = <0x0 0xff600000 0x0 0x100000>; + interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru SCLK_USB3OTG_REF>, <&cru SCLK_USB3OTG_SUSPEND>, + <&cru ACLK_USB3OTG>; + clock-names = "ref_clk", "suspend_clk", + "bus_clk"; + dr_mode = "otg"; + phy_type = "utmi_wide"; + snps,dis-del-phy-power-chg-quirk; + snps,dis_enblslpm_quirk; + snps,dis-tx-ipgap-linecheck-quirk; + snps,dis-u2-freeclk-exists-quirk; + snps,dis_u2_susphy_quirk; + snps,dis_u3_susphy_quirk; + status = "disabled"; + }; + /* * U-boot Specific Change * @@ -1163,7 +1180,7 @@ rockchip,pins = <0 RK_PA5 2 &pcfg_pull_none>, <0 RK_PA6 2 &pcfg_pull_none>; }; - i2c3_gpio: i2c3-gpio { + i2c3_pins: i2c3-pins { rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>, <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; @@ -1234,7 +1251,7 @@ };
tsadc { - otp_gpio: otp-gpio { + otp_pin: otp-pin { rockchip,pins = <2 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; };
@@ -1245,8 +1262,8 @@
uart0 { uart0_xfer: uart0-xfer { - rockchip,pins = <1 RK_PB1 1 &pcfg_pull_up>, - <1 RK_PB0 1 &pcfg_pull_none>; + rockchip,pins = <1 RK_PB1 1 &pcfg_pull_none>, + <1 RK_PB0 1 &pcfg_pull_up>; };
uart0_cts: uart0-cts { @@ -1257,15 +1274,15 @@ rockchip,pins = <1 RK_PB2 1 &pcfg_pull_none>; };
- uart0_rts_gpio: uart0-rts-gpio { + uart0_rts_pin: uart0-rts-pin { rockchip,pins = <1 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; }; };
uart1 { uart1_xfer: uart1-xfer { - rockchip,pins = <3 RK_PA4 4 &pcfg_pull_up>, - <3 RK_PA6 4 &pcfg_pull_none>; + rockchip,pins = <3 RK_PA4 4 &pcfg_pull_none>, + <3 RK_PA6 4 &pcfg_pull_up>; };
uart1_cts: uart1-cts { @@ -1276,22 +1293,22 @@ rockchip,pins = <3 RK_PA5 4 &pcfg_pull_none>; };
- uart1_rts_gpio: uart1-rts-gpio { + uart1_rts_pin: uart1-rts-pin { rockchip,pins = <3 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; }; };
uart2-0 { uart2m0_xfer: uart2m0-xfer { - rockchip,pins = <1 RK_PA0 2 &pcfg_pull_up>, - <1 RK_PA1 2 &pcfg_pull_none>; + rockchip,pins = <1 RK_PA0 2 &pcfg_pull_none>, + <1 RK_PA1 2 &pcfg_pull_up>; }; };
uart2-1 { uart2m1_xfer: uart2m1-xfer { - rockchip,pins = <2 RK_PA0 1 &pcfg_pull_up>, - <2 RK_PA1 1 &pcfg_pull_none>; + rockchip,pins = <2 RK_PA0 1 &pcfg_pull_none>, + <2 RK_PA1 1 &pcfg_pull_up>; }; };
@@ -1502,7 +1519,7 @@ rockchip,pins = <2 RK_PA7 1 &pcfg_pull_up_4ma>; };
- sdmmc0m0_gpio: sdmmc0m0-gpio { + sdmmc0m0_pin: sdmmc0m0-pin { rockchip,pins = <2 RK_PA7 RK_FUNC_GPIO &pcfg_pull_up_4ma>; }; }; @@ -1512,7 +1529,7 @@ rockchip,pins = <0 RK_PD6 3 &pcfg_pull_up_4ma>; };
- sdmmc0m1_gpio: sdmmc0m1-gpio { + sdmmc0m1_pin: sdmmc0m1-pin { rockchip,pins = <0 RK_PD6 RK_FUNC_GPIO &pcfg_pull_up_4ma>; }; }; @@ -1545,7 +1562,7 @@ <1 RK_PA3 1 &pcfg_pull_up_8ma>; };
- sdmmc0_gpio: sdmmc0-gpio { + sdmmc0_pins: sdmmc0-pins { rockchip,pins = <1 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up_4ma>, <1 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up_4ma>, @@ -1587,7 +1604,7 @@ <3 RK_PA7 3 &pcfg_pull_up_4ma>; };
- sdmmc0ext_gpio: sdmmc0ext-gpio { + sdmmc0ext_pins: sdmmc0ext-pins { rockchip,pins = <3 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up_4ma>, <3 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up_4ma>, @@ -1632,7 +1649,7 @@ <1 RK_PC1 1 &pcfg_pull_up_8ma>; };
- sdmmc1_gpio: sdmmc1-gpio { + sdmmc1_pins: sdmmc1-pins { rockchip,pins = <1 RK_PB4 RK_FUNC_GPIO &pcfg_pull_up_4ma>, <1 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up_4ma>, @@ -1826,7 +1843,7 @@ tsadc_int: tsadc-int { rockchip,pins = <2 RK_PB5 2 &pcfg_pull_none>; }; - tsadc_gpio: tsadc-gpio { + tsadc_pin: tsadc-pin { rockchip,pins = <2 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; }; };
Peter Robinson pbrobinson@gmail.com 于2021年7月22日周四 下午11:21写道:
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
aliases {
mmc0 = &sdmmc;
mmc1 = &sdio;
mmc2 = &emmc;
+&cpu1 {
+&cpu2 {
+&cpu3 {
status = "okay";
aliases {
mmc0 = &sdmmc;
default-state = "on"; }; wan_led: led-2 {
3300000 0x0>;
<3300000 0x0>; vin-supply = <&vcc_io_33>; }; vcc_sd: sdmmc-regulator { compatible = "regulator-fixed"; gpio = <&gpio0 RK_PD6 GPIO_ACTIVE_LOW>;
enable-active-high;
regulator-boot-on;
ethernet-phy {
lan {
+&usbdrd3 {
dr_mode = "host";
status = "okay";
#size-cells = <0>;
rtl8153: device@2 {
reg = <2>;
aliases {
mmc0 = &sdmmc;
mmc1 = &emmc;
3300000 0x0>;
power {
user {
+&analog_sound {
status = "okay";
+&codec {
status = "okay";
+&hdmi_sound {
status = "okay";
+&i2s0 {
status = "okay";
+&i2s1 {
status = "okay";
&usb20_otg {
dr_mode = "host";
status = "okay";
+&usbdrd3 {
&usb_host0_xhci {
- (C) Copyright 2020 Radxa
- (C) Copyright 2020 Chen-Yu Tsai wens@csie.org
- Based on ./rk3328-rock64.dts, which is
- Copyright (c) 2017 PINE64
/dts-v1/;
aliases {
mmc0 = &sdmmc;
mmc1 = &emmc;
}; chosen {
adc-keys {
button-recovery {
label = "Recovery";
}; }; gmac_clkin: external-gmac-clock {
#clock-cells = <0>;
#clock-cells = <0>;
leds {
led-0 {
}; }; vcc_sd: sdmmc-regulator {
regulator-boot-on;
regulator-boot-on;
enable-active-high;
enable-active-high;
regulator-boot-on;
vin-supply = <&vcc_sys>; }; vcc_sys: vcc-sys {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
+&analog_sound {
status = "okay";
+&codec {
status = "okay";
supports-emmc;
snps,aal;
snps,rxpbl = <0x4>;
mdio {
#size-cells = <0>;
reg = <1>;
rk805: rk805@18 {
reg = <0x18>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_io: DCDC_REG4 {
regulator-boot-on;
vcc_18: LDO_REG1 {
regulator-boot-on;
regulator-boot-on;
vdd_10: LDO_REG3 {
regulator-boot-on;
rk805: pmic@18 {
reg = <0x18>;
#clock-cells = <1>;
gpio-controller;
#gpio-cells = <2>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_io: DCDC_REG4 {
regulator-boot-on;
vcc_18: LDO_REG1 {
regulator-boot-on;
regulator-boot-on;
vdd_10: LDO_REG3 {
regulator-boot-on;
+&io_domains {
status = "okay";
&pinctrl {
ephy {
leds {
led_pin: led-pin {
pmic {
usb3 {
wifi {
wifi_en: wifi-en {
supports-sd;
&saradc {
status = "okay";
+&usbdrd3 {
dr_mode = "host";
status = "okay";
aliases {
mmc0 = &sdmmc;
mmc1 = &emmc;
power {
standby {
sound {
dais = <&i2s1_p0
&spdif_p0>;
spdif-dit {
port {
+&analog_sound {
status = "okay";
port@0 {
+&hdmi_sound {
status = "okay";
i2s1_p0: port {
dai-format = "i2s";
mclk-fs = <256>;
+&i2s1 {
status = "okay";
spdif_p0: port {
+&usbdrd3 {
dr_mode = "host";
status = "okay";
amba: bus {
#size-cells = <2>;
ranges;
#dma-cells = <1>;
#dma-cells = <1>;
clock_in_out = "output"; status = "disabled"; mdio {
phy: phy@0 {
"bus_clk";
dr_mode = "otg";
tsadc {
<1 RK_PB0 1 &pcfg_pull_up>; }; uart0_cts: uart0-cts {
uart0_rts_pin: uart0-rts-pin { rockchip,pins = <1 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; }; }; uart1 { uart1_xfer: uart1-xfer {
<3 RK_PA6 4 &pcfg_pull_up>; }; uart1_cts: uart1-cts {
uart1_rts_pin: uart1-rts-pin { rockchip,pins = <3 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; }; }; uart2-0 { uart2m0_xfer: uart2m0-xfer {
<1 RK_PA1 2 &pcfg_pull_up>; }; }; uart2-1 { uart2m1_xfer: uart2m1-xfer {
-- 2.31.1
Sync the rk3368 DTs and associated bits from 5.14-rc1.
Signed-off-by: Peter Robinson pbrobinson@gmail.com --- arch/arm/dts/rk3368-geekbox.dts | 70 +++-------- arch/arm/dts/rk3368-lion-haikou.dts | 4 + arch/arm/dts/rk3368-lion.dtsi | 21 +--- arch/arm/dts/rk3368-px5-evb.dts | 178 +++++++++++----------------- arch/arm/dts/rk3368.dtsi | 65 +++++----- 5 files changed, 118 insertions(+), 220 deletions(-)
diff --git a/arch/arm/dts/rk3368-geekbox.dts b/arch/arm/dts/rk3368-geekbox.dts index 46cdddfcea..62aa97a0b8 100644 --- a/arch/arm/dts/rk3368-geekbox.dts +++ b/arch/arm/dts/rk3368-geekbox.dts @@ -1,43 +1,6 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Copyright (c) 2016 Andreas Färber - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. */
/dts-v1/; @@ -48,6 +11,10 @@ model = "GeekBox"; compatible = "geekbuying,geekbox", "rockchip,rk3368";
+ aliases { + mmc0 = &emmc; + }; + chosen { stdout-path = "serial2:115200n8"; }; @@ -66,7 +33,7 @@
ir: ir-receiver { compatible = "gpio-ir-receiver"; - gpios = <&gpio3 30 GPIO_ACTIVE_LOW>; + gpios = <&gpio3 RK_PD6 GPIO_ACTIVE_LOW>; pinctrl-names = "default"; pinctrl-0 = <&ir_int>; }; @@ -77,7 +44,7 @@ pinctrl-0 = <&pwr_key>;
power { - gpios = <&gpio0 2 GPIO_ACTIVE_LOW>; + gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_LOW>; label = "GPIO Power"; linux,code = <KEY_POWER>; wakeup-source; @@ -87,14 +54,14 @@ leds: gpio-leds { compatible = "gpio-leds";
- blue { - gpios = <&gpio2 2 GPIO_ACTIVE_HIGH>; + blue_led: led-0 { + gpios = <&gpio2 RK_PA2 GPIO_ACTIVE_HIGH>; label = "geekbox:blue:led"; default-state = "on"; };
- red { - gpios = <&gpio2 3 GPIO_ACTIVE_HIGH>; + red_led: led-1 { + gpios = <&gpio2 RK_PA3 GPIO_ACTIVE_HIGH>; label = "geekbox:red:led"; default-state = "off"; }; @@ -115,10 +82,7 @@ bus-width = <8>; cap-mmc-highspeed; clock-frequency = <150000000>; - disable-wp; - keep-power-in-suspend; non-removable; - num-slots = <1>; vmmc-supply = <&vcc_io>; vqmmc-supply = <&vcc18_flash>; pinctrl-names = "default"; @@ -147,7 +111,7 @@ pinctrl-names = "default"; pinctrl-0 = <&pmic_int>, <&pmic_sleep>; interrupt-parent = <&gpio0>; - interrupts = <5 IRQ_TYPE_LEVEL_LOW>; + interrupts = <RK_PA5 IRQ_TYPE_LEVEL_LOW>; rockchip,system-power-controller; vcc1-supply = <&vcc_sys>; vcc2-supply = <&vcc_sys>; @@ -258,8 +222,6 @@ };
vcc_sd: SWITCH_REG1 { - regulator-always-on; - regulator-boot-on; regulator-name = "vcc_sd"; };
@@ -275,23 +237,23 @@ &pinctrl { ir { ir_int: ir-int { - rockchip,pins = <3 30 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <3 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>; }; };
keys { pwr_key: pwr-key { - rockchip,pins = <0 2 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; }; };
pmic { pmic_sleep: pmic-sleep { - rockchip,pins = <0 0 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <0 RK_PA0 2 &pcfg_pull_none>; };
pmic_int: pmic-int { - rockchip,pins = <0 5 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; }; }; }; diff --git a/arch/arm/dts/rk3368-lion-haikou.dts b/arch/arm/dts/rk3368-lion-haikou.dts index 7fcb1eacea..cae01d35b9 100644 --- a/arch/arm/dts/rk3368-lion-haikou.dts +++ b/arch/arm/dts/rk3368-lion-haikou.dts @@ -10,6 +10,10 @@ model = "Theobroma Systems RK3368-uQ7 Baseboard"; compatible = "tsd,rk3368-lion-haikou", "rockchip,rk3368";
+ aliases { + mmc1 = &sdmmc; + }; + chosen { stdout-path = "serial0:115200n8"; }; diff --git a/arch/arm/dts/rk3368-lion.dtsi b/arch/arm/dts/rk3368-lion.dtsi index 532e6a6828..bcd7977fb0 100644 --- a/arch/arm/dts/rk3368-lion.dtsi +++ b/arch/arm/dts/rk3368-lion.dtsi @@ -7,6 +7,10 @@ #include "rk3368.dtsi"
/ { + aliases { + mmc0 = &emmc; + }; + chosen { stdout-path = "serial0:115200n8"; }; @@ -150,7 +154,6 @@ assigned-clocks = <&cru SCLK_MAC>; assigned-clock-parents = <&ext_gmac>; clock_in_out = "input"; - phy-handle = <&phy0>; phy-supply = <&vcc33_io>; phy-mode = "rgmii"; pinctrl-names = "default"; @@ -161,22 +164,6 @@ tx_delay = <0x10>; rx_delay = <0x10>; status = "okay"; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - - /* Microsemi VSC8531-02 */ - phy0: phy@0 { - compatible = "ethernet-phy-id0007.0570"; - reg = <0>; - vsc8531,clk-out-frequency = <125000000>; - vsc8531,edge-slowdown = <7>; - vsc8531,led-0-mode = <1>; - vsc8531,led-1-mode = <2>; - }; - }; };
&i2c0 { diff --git a/arch/arm/dts/rk3368-px5-evb.dts b/arch/arm/dts/rk3368-px5-evb.dts index e9c5ebad47..5ccaa5f7a3 100644 --- a/arch/arm/dts/rk3368-px5-evb.dts +++ b/arch/arm/dts/rk3368-px5-evb.dts @@ -1,43 +1,6 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* - * Copyright (c) 2017 Rockchip Electronics Co., Ltd - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. + * Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd */
/dts-v1/; @@ -45,30 +8,21 @@ #include <dt-bindings/input/input.h>
/ { - model = "PX5 EVB"; + model = "Rockchip PX5 EVB"; compatible = "rockchip,px5-evb", "rockchip,px5", "rockchip,rk3368";
+ aliases { + mmc0 = &sdmmc; + mmc1 = &emmc; + }; + chosen { stdout-path = "serial4:115200n8"; };
memory@0 { - device_type = "memory"; reg = <0x0 0x0 0x0 0x40000000>; - }; - - ext_gmac: gmac-clk { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "ext_gmac"; - #clock-cells = <0>; - }; - - ir: ir-receiver { - compatible = "gpio-ir-receiver"; - gpios = <&gpio3 30 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&ir_int>; + device_type = "memory"; };
keys: gpio-keys { @@ -77,29 +31,13 @@ pinctrl-0 = <&pwr_key>;
power { - gpios = <&gpio0 2 GPIO_ACTIVE_LOW>; + gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_LOW>; label = "GPIO Power"; linux,code = <KEY_POWER>; wakeup-source; }; };
- leds: gpio-leds { - compatible = "gpio-leds"; - - blue { - gpios = <&gpio2 2 GPIO_ACTIVE_HIGH>; - label = "geekbox:blue:led"; - default-state = "on"; - }; - - red { - gpios = <&gpio2 3 GPIO_ACTIVE_HIGH>; - label = "geekbox:red:led"; - default-state = "off"; - }; - }; - vcc_sys: vcc-sys-regulator { compatible = "regulator-fixed"; regulator-name = "vcc_sys"; @@ -115,27 +53,14 @@ bus-width = <8>; cap-mmc-highspeed; clock-frequency = <150000000>; - disable-wp; - keep-power-in-suspend; + mmc-hs200-1_8v; + no-sdio; + no-sd; non-removable; - num-slots = <1>; - vmmc-supply = <&vcc_io>; - vqmmc-supply = <&vcc18_flash>; pinctrl-names = "default"; pinctrl-0 = <&emmc_clk>, <&emmc_cmd>, <&emmc_bus8>; -}; - -&gmac { - status = "okay"; - phy-supply = <&vcc_lan>; - phy-mode = "rgmii"; - clock_in_out = "input"; - assigned-clocks = <&cru SCLK_MAC>; - assigned-clock-parents = <&ext_gmac>; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - tx_delay = <0x30>; - rx_delay = <0x10>; + vmmc-supply = <&vcc_io>; + vqmmc-supply = <&vcc18_flash>; };
&i2c0 { @@ -144,10 +69,10 @@ rk808: pmic@1b { compatible = "rockchip,rk808"; reg = <0x1b>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PA5 IRQ_TYPE_LEVEL_LOW>; pinctrl-names = "default"; pinctrl-0 = <&pmic_int>, <&pmic_sleep>; - interrupt-parent = <&gpio0>; - interrupts = <5 IRQ_TYPE_LEVEL_LOW>; rockchip,system-power-controller; vcc1-supply = <&vcc_sys>; vcc2-supply = <&vcc_sys>; @@ -202,12 +127,12 @@ regulator-name = "vcc18_flash"; };
- vcc33_lcd: LDO_REG2 { + vcca_33: LDO_REG2 { regulator-always-on; regulator-boot-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; - regulator-name = "vcc33_lcd"; + regulator-name = "vcca_33"; };
vdd_10: LDO_REG3 { @@ -218,11 +143,10 @@ regulator-name = "vdd_10"; };
- vcca_18: LDO_REG4 { - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcca_18"; + avdd_33: LDO_REG4 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "avdd_33"; };
vccio_sd: LDO_REG5 { @@ -258,46 +182,76 @@ };
- vcc_lan: SWITCH_REG2 { + vcc33_lcd: SWITCH_REG2 { regulator-always-on; regulator-boot-on; - regulator-name = "vcc_lan"; + regulator-name = "vcc33_lcd"; }; }; }; };
-&pinctrl { - ir { - ir_int: ir-int { - rockchip,pins = <3 30 RK_FUNC_GPIO &pcfg_pull_none>; - }; +&i2c1 { + status = "okay"; + + accelerometer@18 { + compatible = "bosch,bma250"; + reg = <0x18>; + interrupt-parent = <&gpio2>; + interrupts = <RK_PC1 IRQ_TYPE_LEVEL_LOW>; }; +};
+&i2c2 { + status = "okay"; + + gsl1680: touchscreen@40 { + compatible = "silead,gsl1680"; + reg = <0x40>; + interrupt-parent = <&gpio3>; + interrupts = <RK_PD4 IRQ_TYPE_EDGE_FALLING>; + power-gpios = <&gpio3 RK_PB7 GPIO_ACTIVE_HIGH>; + touchscreen-size-x = <800>; + touchscreen-size-y = <1280>; + silead,max-fingers = <5>; + }; +}; + +&pinctrl { keys { pwr_key: pwr-key { - rockchip,pins = <0 2 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; }; };
-&saradc { +&sdmmc { status = "okay"; + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + card-detect-delay = <200>; + no-sdio; + sd-uhs-sdr12; + sd-uhs-sdr25; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk>, <&sdmmc_cmd>, <&sdmmc_bus4>, <&sdmmc_cd>; + rockchip,default-sample-phase = <90>; + vmmc-supply = <&vcc_sd>; + vqmmc-supply = <&vccio_sd>; };
&tsadc { diff --git a/arch/arm/dts/rk3368.dtsi b/arch/arm/dts/rk3368.dtsi index cd2c322071..4c64fbefb4 100644 --- a/arch/arm/dts/rk3368.dtsi +++ b/arch/arm/dts/rk3368.dtsi @@ -136,37 +136,6 @@ }; };
- amba: bus { - compatible = "simple-bus"; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - dmac_peri: dma-controller@ff250000 { - compatible = "arm,pl330", "arm,primecell"; - reg = <0x0 0xff250000 0x0 0x4000>; - interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - arm,pl330-broken-no-flushp; - arm,pl330-periph-burst; - clocks = <&cru ACLK_DMAC_PERI>; - clock-names = "apb_pclk"; - }; - - dmac_bus: dma-controller@ff600000 { - compatible = "arm,pl330", "arm,primecell"; - reg = <0x0 0xff600000 0x0 0x4000>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - arm,pl330-broken-no-flushp; - arm,pl330-periph-burst; - clocks = <&cru ACLK_DMAC_BUS>; - clock-names = "apb_pclk"; - }; - }; - arm-pmu { compatible = "arm,armv8-pmuv3"; interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>, @@ -399,8 +368,20 @@ status = "disabled"; };
+ dmac_peri: dma-controller@ff250000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0x0 0xff250000 0x0 0x4000>; + interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + arm,pl330-broken-no-flushp; + arm,pl330-periph-burst; + clocks = <&cru ACLK_DMAC_PERI>; + clock-names = "apb_pclk"; + }; + thermal-zones { - cpu { + cpu_thermal: cpu-thermal { polling-delay-passive = <100>; /* milliseconds */ polling-delay = <5000>; /* milliseconds */
@@ -444,7 +425,7 @@ }; };
- gpu { + gpu_thermal: gpu-thermal { polling-delay-passive = <100>; /* milliseconds */ polling-delay = <5000>; /* milliseconds */
@@ -532,6 +513,18 @@ status = "disabled"; };
+ dmac_bus: dma-controller@ff600000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0x0 0xff600000 0x0 0x4000>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + arm,pl330-broken-no-flushp; + arm,pl330-periph-burst; + clocks = <&cru ACLK_DMAC_BUS>; + clock-names = "apb_pclk"; + }; + i2c0: i2c@ff650000 { compatible = "rockchip,rk3368-i2c", "rockchip,rk3288-i2c"; reg = <0x0 0xff650000 0x0 0x1000>; @@ -565,7 +558,6 @@ pinctrl-names = "default"; pinctrl-0 = <&pwm0_pin>; clocks = <&cru PCLK_PWM1>; - clock-names = "pwm"; status = "disabled"; };
@@ -576,7 +568,6 @@ pinctrl-names = "default"; pinctrl-0 = <&pwm1_pin>; clocks = <&cru PCLK_PWM1>; - clock-names = "pwm"; status = "disabled"; };
@@ -585,7 +576,6 @@ reg = <0x0 0xff680020 0x0 0x10>; #pwm-cells = <3>; clocks = <&cru PCLK_PWM1>; - clock-names = "pwm"; status = "disabled"; };
@@ -596,7 +586,6 @@ pinctrl-names = "default"; pinctrl-0 = <&pwm3_pin>; clocks = <&cru PCLK_PWM1>; - clock-names = "pwm"; status = "disabled"; };
@@ -675,6 +664,8 @@ compatible = "rockchip,rk3368-timer", "rockchip,rk3288-timer"; reg = <0x0 0xff810000 0x0 0x20>; interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru PCLK_TIMER0>, <&cru SCLK_TIMER00>; + clock-names = "pclk", "timer"; };
spdif: spdif@ff880000 {
Thanks, - Kever
- Copyright (c) 2016 Andreas Färber
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is free software; you can redistribute it and/or
- Or, alternatively,
- b) Permission is hereby granted, free of charge, to any person
conditions:
aliases {
mmc0 = &emmc;
@@ -66,7 +33,7 @@
power {
blue {
blue_led: led-0 {
red {
red_led: led-1 {
disable-wp;
rockchip,pins = <3 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>; }; }; keys { pwr_key: pwr-key {
rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; }; }; pmic { pmic_sleep: pmic-sleep {
rockchip,pins = <0 RK_PA0 2 &pcfg_pull_none>; }; pmic_int: pmic-int {
aliases {
mmc1 = &sdmmc;
aliases {
mmc0 = &emmc;
mdio {
#size-cells = <0>;
phy0: phy@0 {
reg = <0>;
- Copyright (c) 2017 Rockchip Electronics Co., Ltd
- whole.
conditions:
- Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd
model = "PX5 EVB";
aliases {
mmc0 = &sdmmc;
mmc1 = &emmc;
chosen { stdout-path = "serial4:115200n8"; }; memory@0 {
#clock-cells = <0>;
ir: ir-receiver {
device_type = "memory"; }; keys: gpio-keys {
power {
leds: gpio-leds {
blue {
red {
disable-wp;
mmc-hs200-1_8v;
no-sdio;
num-slots = <1>;
-&gmac {
status = "okay";
phy-mode = "rgmii";
tx_delay = <0x30>;
rx_delay = <0x10>;
regulator-name = "vcca_33"; }; vdd_10: LDO_REG3 {
vcca_18: LDO_REG4 {
regulator-boot-on;
avdd_33: LDO_REG4 {
regulator-name = "avdd_33"; }; vccio_sd: LDO_REG5 {
-&pinctrl {
ir {
ir_int: ir-int {
+&i2c1 {
status = "okay";
accelerometer@18 {
reg = <0x18>;
+&i2c2 {
status = "okay";
reg = <0x40>;
bus-width = <4>;
cap-mmc-highspeed;
cap-sd-highspeed;
no-sdio;
sd-uhs-sdr12;
sd-uhs-sdr25;
amba: bus {
#size-cells = <2>;
ranges;
#dma-cells = <1>;
#dma-cells = <1>;
#dma-cells = <1>;
thermal-zones {
cpu {
gpu {
#dma-cells = <1>;
clock-names = "pclk", "timer"; }; spdif: spdif@ff880000 {
-- 2.31.1
Sync the rk3399 DTs and associated bits from 5.14-rc1.
Thanks, - Kever
arch/arm/dts/rk3399-evb.dts | 4 + arch/arm/dts/rk3399-ficus.dts | 29 +- arch/arm/dts/rk3399-firefly.dts | 178 ++++++++++-- arch/arm/dts/rk3399-gru.dtsi | 14 +- arch/arm/dts/rk3399-khadas-edge.dtsi | 40 ++- arch/arm/dts/rk3399-leez-p710.dts | 14 +- arch/arm/dts/rk3399-nanopc-t4.dts | 1 + arch/arm/dts/rk3399-nanopi-r4s.dts | 135 +++++---- arch/arm/dts/rk3399-nanopi4.dtsi | 18 +- arch/arm/dts/rk3399-opp.dtsi | 40 +-- arch/arm/dts/rk3399-orangepi.dts | 72 ++++- arch/arm/dts/rk3399-pinebook-pro.dts | 120 +++++--- arch/arm/dts/rk3399-puma-haikou.dts | 10 +- arch/arm/dts/rk3399-puma.dtsi | 61 +--- arch/arm/dts/rk3399-roc-pc-mezzanine.dts | 22 +- arch/arm/dts/rk3399-roc-pc.dtsi | 59 +++- arch/arm/dts/rk3399-rock-pi-4.dtsi | 29 +- arch/arm/dts/rk3399-rock-pi-4a.dts | 2 +- arch/arm/dts/rk3399-rock-pi-4b.dts | 6 +- arch/arm/dts/rk3399-rock-pi-4c.dts | 6 +- arch/arm/dts/rk3399-rock960.dts | 82 ++---- arch/arm/dts/rk3399-rock960.dtsi | 10 +- arch/arm/dts/rk3399-rockpro64.dtsi | 95 ++++++- arch/arm/dts/rk3399.dtsi | 269 +++++++++++------- arch/arm/dts/rk3399pro-vmarc-som.dtsi | 22 +- .../dts/rockchip-radxa-dalang-carrier.dtsi | 21 ++ 26 files changed, 897 insertions(+), 462 deletions(-)
diff --git a/arch/arm/dts/rk3399-evb.dts b/arch/arm/dts/rk3399-evb.dts index 694b0d08d6..7b717ebec8 100644 --- a/arch/arm/dts/rk3399-evb.dts +++ b/arch/arm/dts/rk3399-evb.dts @@ -11,6 +11,10 @@ model = "Rockchip RK3399 Evaluation Board"; compatible = "rockchip,rk3399-evb", "rockchip,rk3399";
aliases {
mmc0 = &sdhci;
backlight: backlight { compatible = "pwm-backlight"; brightness-levels = <
diff --git a/arch/arm/dts/rk3399-ficus.dts b/arch/arm/dts/rk3399-ficus.dts index ebe2ee77ba..1ce85a5816 100644 --- a/arch/arm/dts/rk3399-ficus.dts +++ b/arch/arm/dts/rk3399-ficus.dts @@ -27,42 +27,43 @@ leds { compatible = "gpio-leds"; pinctrl-names = "default";
pinctrl-0 = <&user_led1>, <&user_led2>, <&user_led3>,
<&user_led4>, <&wlan_led>, <&bt_led>;
pinctrl-0 = <&user_led1_pin>, <&user_led2_pin>,
<&user_led3_pin>, <&user_led4_pin>,
<&wlan_led_pin>, <&bt_led_pin>;
user_led1 {
user_led1: led-1 { label = "red:user1"; gpios = <&gpio4 25 0>; linux,default-trigger = "heartbeat"; };
user_led2 {
user_led2: led-2 { label = "red:user2"; gpios = <&gpio4 26 0>; linux,default-trigger = "mmc0"; };
user_led3 {
user_led3: led-3 { label = "red:user3"; gpios = <&gpio4 30 0>; linux,default-trigger = "mmc1"; };
user_led4 {
user_led4: led-4 { label = "red:user4"; gpios = <&gpio1 0 0>; panic-indicator; linux,default-trigger = "none"; };
wlan_active_led {
wlan_active_led: led-5 { label = "red:wlan"; gpios = <&gpio1 1 0>; linux,default-trigger = "phy0tx"; default-state = "off"; };
bt_active_led {
bt_active_led: led-6 { label = "red:bt"; gpios = <&gpio1 4 0>; linux,default-trigger = "hci0-power";
@@ -114,32 +115,32 @@ };
leds {
user_led1: user_led1 {
user_led1_pin: user-led1-pin { rockchip,pins = <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; };
user_led2: user_led2 {
user_led2_pin: user-led2-pin { rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; };
user_led3: user_led3 {
user_led3_pin: user-led3-pin { rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>; };
user_led4: user_led4 {
user_led4_pin: user-led4-pin { rockchip,pins = <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; };
wlan_led: wlan_led {
wlan_led_pin: wlan-led-pin { rockchip,pins = <1 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; };
bt_led: bt_led {
bt_led_pin: bt-led-pin { rockchip,pins = <1 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; };
diff --git a/arch/arm/dts/rk3399-firefly.dts b/arch/arm/dts/rk3399-firefly.dts index d63faf38cc..c4dd2a6b48 100644 --- a/arch/arm/dts/rk3399-firefly.dts +++ b/arch/arm/dts/rk3399-firefly.dts @@ -6,6 +6,7 @@ /dts-v1/; #include <dt-bindings/input/linux-event-codes.h> #include <dt-bindings/pwm/pwm.h> +#include <dt-bindings/usb/pd.h> #include "rk3399.dtsi" #include "rk3399-opp.dtsi"
@@ -13,6 +14,12 @@ model = "Firefly-RK3399 Board"; compatible = "firefly,firefly-rk3399", "rockchip,rk3399";
aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
@@ -88,18 +95,25 @@ }; };
ir-receiver {
gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&work_led_gpio>, <&diy_led_gpio>;
pinctrl-0 = <&work_led_pin>, <&diy_led_pin>;
work-led {
work_led: led-0 { label = "work"; default-state = "on"; gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>; };
diy-led {
diy_led: led-1 { label = "diy"; default-state = "off"; gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>;
@@ -145,6 +159,23 @@ reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; };
sound-dit {
label = "SPDIF";
dais = <&spdif_p0>;
spdif-dit {
port {
/* switched by pmic_sleep */ vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { compatible = "regulator-fixed";
@@ -190,6 +221,17 @@ vin-supply = <&vcc_sys>; };
vcc5v0_typec: vcc5v0-typec-regulator {
enable-active-high;
gpio = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc5v0_typec_en>;
regulator-name = "vcc5v0_typec";
vcc_sys: vcc-sys { compatible = "regulator-fixed"; regulator-name = "vcc_sys";
@@ -515,6 +557,53 @@ i2c-scl-falling-time-ns = <20>; status = "okay";
fusb0: typec-portc@22 {
compatible = "fcs,fusb302";
reg = <0x22>;
interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>;
pinctrl-0 = <&fusb0_int>;
vbus-supply = <&vcc5v0_typec>;
status = "okay";
connector {
compatible = "usb-c-connector";
data-role = "host";
label = "USB-C";
op-sink-microwatt = <1000000>;
power-role = "dual";
sink-pdos =
<PDO_FIXED(5000, 2500, PDO_FIXED_USB_COMM)>;
source-pdos =
<PDO_FIXED(5000, 1400, PDO_FIXED_USB_COMM)>;
try-power-role = "sink";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
usbc_hs: endpoint {
remote-endpoint =
<&u2phy0_typec_hs>;
port@1 {
reg = <1>;
usbc_ss: endpoint {
remote-endpoint =
<&tcphy0_typec_ss>;
accelerometer@68 { compatible = "invensense,mpu6500"; reg = <0x68>;
@@ -572,12 +661,34 @@ }; };
fusb302x {
fusb0_int: fusb0-int {
rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>;
ir {
ir_int: ir-int {
rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>;
lcd-panel { lcd_panel_reset: lcd-panel-reset { rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_up>; }; };
leds {
work_led_pin: work-led-pin {
diy_led_pin: diy-led-pin {
rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>;
pcie { pcie_pwr_en: pcie-pwr-en { rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>;
@@ -589,18 +700,16 @@ };
pmic {
vsel1_gpio: vsel1-gpio {
rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; };
vsel2_gpio: vsel2-gpio {
rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>;
vsel1_pin: vsel1-pin {
sdio-pwrseq {
rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>;
vsel2_pin: vsel2-pin {
rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; }; };
@@ -610,9 +719,15 @@ }; };
pmic {
sdio-pwrseq {
usb-typec {
vcc5v0_typec_en: vcc5v0_typec_en {
rockchip,pins = <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; }; };
@@ -627,16 +742,6 @@ rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; }; };
leds {
work_led_gpio: work_led-gpio {
diy_led_gpio: diy_led-gpio {
&pwm0 { @@ -704,10 +809,29 @@ status = "okay"; };
+&spdif {
pinctrl-0 = <&spdif_bus_1>;
status = "okay";
spdif_p0: port {
&tcphy0 { status = "okay"; };
+&tcphy0_usb3 {
port {
tcphy0_typec_ss: endpoint {
remote-endpoint = <&usbc_ss>;
&tcphy1 { status = "okay"; }; @@ -731,6 +855,12 @@ phy-supply = <&vcc5v0_host>; status = "okay"; };
port {
u2phy0_typec_hs: endpoint {
remote-endpoint = <&usbc_hs>;
&u2phy1 { diff --git a/arch/arm/dts/rk3399-gru.dtsi b/arch/arm/dts/rk3399-gru.dtsi index f9c5bb607b..b80f19066b 100644 --- a/arch/arm/dts/rk3399-gru.dtsi +++ b/arch/arm/dts/rk3399-gru.dtsi @@ -10,6 +10,11 @@ #include "rk3399-op1-opp.dtsi"
aliases {
mmc0 = &sdmmc;
mmc1 = &sdhci;
@@ -247,8 +252,8 @@ enable-active-high; enable-gpio = <&gpio2 2 GPIO_ACTIVE_HIGH>; gpios = <&gpio2 28 GPIO_ACTIVE_HIGH>;
3000000 0x0>;
<3000000 0x0>; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <3000000>;
@@ -342,6 +347,7 @@ cpu-supply = <&ppvar_bigcpu>; };
&cru { assigned-clocks = <&cru PLL_GPLL>, <&cru PLL_CPLL>, @@ -515,7 +521,7 @@ ap_i2c_audio: &i2c8 { * configured as SDMMC and not JTAG. */ pinctrl-names = "default";
pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_cd_gpio
pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_cd_pin &sdmmc_bus4>; bus-width = <4>;
@@ -766,7 +772,7 @@ ap_i2c_audio: &i2c8 { };
/* This is where we actually hook up CD; has external pull */
sdmmc_cd_gpio: sdmmc-cd-gpio {
sdmmc_cd_pin: sdmmc-cd-pin { rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; }; };
diff --git a/arch/arm/dts/rk3399-khadas-edge.dtsi b/arch/arm/dts/rk3399-khadas-edge.dtsi index e87a044774..d5c7648c84 100644 --- a/arch/arm/dts/rk3399-khadas-edge.dtsi +++ b/arch/arm/dts/rk3399-khadas-edge.dtsi @@ -11,6 +11,12 @@ #include "rk3399-opp.dtsi"
aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
@@ -138,18 +144,26 @@ }; };
ir-receiver {
gpios = <&gpio1 RK_PB6 GPIO_ACTIVE_LOW>;
linux,rc-map-name = "rc-khadas";
pinctrl-0 = <&ir_rx>;
pinctrl-0 = <&sys_led_gpio>, <&user_led_gpio>;
pinctrl-0 = <&sys_led_pin>, <&user_led_pin>;
sys-led {
sys_led: led-0 { label = "sys_led"; linux,default-trigger = "heartbeat"; gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; };
user-led {
user_led: led-1 { label = "user_led"; default-state = "off"; gpios = <&gpio4 RK_PD0 GPIO_ACTIVE_HIGH>;
@@ -585,12 +599,18 @@ }; };
ir {
ir_rx: ir-rx {
rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_none>;
leds {
sys_led_gpio: sys_led-gpio {
sys_led_pin: sys-led-pin { rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; };
user_led_gpio: user_led-gpio {
user_led_pin: user-led-pin { rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; }; };
@@ -690,6 +710,16 @@ status = "okay"; };
+&spi1 {
status = "okay";
spiflash: flash@0 {
compatible = "winbond,w25q128fw", "jedec,spi-nor";
reg = <0>;
spi-max-frequency = <104000000>;
&tcphy0 { status = "okay"; }; diff --git a/arch/arm/dts/rk3399-leez-p710.dts b/arch/arm/dts/rk3399-leez-p710.dts index 73be38a537..7c93f840bc 100644 --- a/arch/arm/dts/rk3399-leez-p710.dts +++ b/arch/arm/dts/rk3399-leez-p710.dts @@ -13,6 +13,12 @@ model = "Leez RK3399 P710"; compatible = "leez,p710", "rockchip,rk3399";
aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
@@ -341,7 +347,7 @@ reg = <0x40>; fcs,suspend-voltage-selector = <1>; pinctrl-names = "default";
pinctrl-0 = <&vsel1_gpio>;
pinctrl-0 = <&vsel1_pin>; regulator-name = "vdd_cpu_b"; regulator-min-microvolt = <712500>; regulator-max-microvolt = <1500000>;
@@ -360,7 +366,7 @@ reg = <0x41>; fcs,suspend-voltage-selector = <1>; pinctrl-names = "default";
pinctrl-0 = <&vsel2_gpio>;
pinctrl-0 = <&vsel2_pin>; regulator-name = "vdd_gpu"; regulator-min-microvolt = <712500>; regulator-max-microvolt = <1500000>;
@@ -447,11 +453,11 @@ rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; };
vsel1_pin: vsel1-pin { rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>; };
vsel2_pin: vsel2-pin { rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; }; };
diff --git a/arch/arm/dts/rk3399-nanopc-t4.dts b/arch/arm/dts/rk3399-nanopc-t4.dts index e0d75617bb..452728b82e 100644 --- a/arch/arm/dts/rk3399-nanopc-t4.dts +++ b/arch/arm/dts/rk3399-nanopc-t4.dts @@ -95,6 +95,7 @@ };
&pcie0 {
ep-gpios = <&gpio2 RK_PA4 GPIO_ACTIVE_HIGH>; num-lanes = <4>; vpcie3v3-supply = <&vcc3v3_sys>;
}; diff --git a/arch/arm/dts/rk3399-nanopi-r4s.dts b/arch/arm/dts/rk3399-nanopi-r4s.dts index 6f2cf17bf1..cef4d18b59 100644 --- a/arch/arm/dts/rk3399-nanopi-r4s.dts +++ b/arch/arm/dts/rk3399-nanopi-r4s.dts @@ -1,13 +1,15 @@ // SPDX-License-Identifier: (GPL-2.0+ OR MIT) /*
- FriendlyElec NanoPC-T4 board device tree source
- Copyright (c) 2018 FriendlyElec Computer Tech. Co., Ltd.
- Copyright (c) 2020 FriendlyElec Computer Tech. Co., Ltd.
- (http://www.friendlyarm.com)
- Copyright (c) 2018 Collabora Ltd.
- Copyright (c) 2019 Arm Ltd.
- Copyright (C) 2020 Xiaobo peterwillcn@gmail.com
- Copyright (c) 2020 Jensen Huang jensenhuang@friendlyarm.com
- Copyright (c) 2020 Marty Jones mj8263788@gmail.com
- Copyright (c) 2021 Tianling Shen cnsztl@gmail.com
/dts-v1/; @@ -17,94 +19,87 @@ model = "FriendlyElec NanoPi R4S"; compatible = "friendlyarm,nanopi-r4s", "rockchip,rk3399";
aliases {
ethernet1 = &r8169;
/delete-node/ display-subsystem;
vdd_5v: vdd-5v {
regulator-name = "vdd_5v";
regulator-boot-on;
gpio-leds {
pinctrl-0 = <&lan_led_pin>, <&sys_led_pin>, <&wan_led_pin>;
fan: pwm-fan {
compatible = "pwm-fan";
cooling-levels = <0 12 18 255>;
#cooling-cells = <2>;
fan-supply = <&vdd_5v>;
pwms = <&pwm1 0 50000 0>;
/delete-node/ led-0;
-&cpu_thermal {
trips {
cpu_warm: cpu_warm {
temperature = <55000>;
hysteresis = <2000>;
type = "active";
lan_led: led-lan {
gpios = <&gpio1 RK_PA1 GPIO_ACTIVE_HIGH>;
label = "green:lan"; };
cpu_hot: cpu_hot {
temperature = <65000>;
type = "active";
sys_led: led-sys {
label = "red:power";
cooling-maps {
map2 {
trip = <&cpu_warm>;
cooling-device = <&fan THERMAL_NO_LIMIT 1>;
wan_led: led-wan {
gpios = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>;
label = "green:wan"; };
gpio-keys {
pinctrl-0 = <&reset_button_pin>;
/delete-node/ power;
map3 {
trip = <&cpu_hot>;
cooling-device = <&fan 2 THERMAL_NO_LIMIT>;
reset {
debounce-interval = <50>;
gpios = <&gpio1 RK_PC6 GPIO_ACTIVE_LOW>;
label = "reset";
linux,code = <KEY_RESTART>; }; };
vdd_5v: vdd-5v {
regulator-boot-on;
&emmc_phy { status = "disabled"; };
-&fusb0 { +&i2c4 { status = "disabled"; };
-&leds {
lan_led: led-1 {
label = "nanopi-r4s:green:lan";
wan_led: led-2 {
label = "nanopi-r4s:green:wan";
-&leds_gpio {
rockchip,pins =
<0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>,
<1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>,
&pcie0 { max-link-speed = <1>; num-lanes = <1>; vpcie3v3-supply = <&vcc3v3_sys>; +};
pcie@0 {
reg = <0x00000000 0 0 0 0>;
#address-cells = <3>;
#size-cells = <2>;
+&pinctrl {
gpio-leds {
/delete-node/ status-led-pin;
r8169: pcie@0,0 {
reg = <0x000000 0 0 0 0>;
local-mac-address = [ 00 00 00 00 00 00 ];
lan_led_pin: lan-led-pin {
wan_led_pin: wan-led-pin {
rockchip-key {
/delete-node/ power-key;
reset_button_pin: reset-button-pin {
rockchip,pins = <1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_up>; }; };
}; @@ -117,10 +112,6 @@ status = "disabled"; };
-&sdmmc {
host-index-min = <1>;
&u2phy0_host { phy-supply = <&vdd_5v>; }; @@ -129,6 +120,10 @@ status = "disabled"; };
+&uart0 {
&usbdrd_dwc3_0 { dr_mode = "host"; }; diff --git a/arch/arm/dts/rk3399-nanopi4.dtsi b/arch/arm/dts/rk3399-nanopi4.dtsi index c88018a0ef..8c0ff6c96e 100644 --- a/arch/arm/dts/rk3399-nanopi4.dtsi +++ b/arch/arm/dts/rk3399-nanopi4.dtsi @@ -17,6 +17,12 @@ #include "rk3399-opp.dtsi"
aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
@@ -117,9 +123,9 @@ leds: gpio-leds { compatible = "gpio-leds"; pinctrl-names = "default";
pinctrl-0 = <&leds_gpio>;
pinctrl-0 = <&status_led_pin>;
status {
status_led: led-0 { gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>; label = "status_led"; linux,default-trigger = "heartbeat";
@@ -182,7 +188,7 @@ #address-cells = <1>; #size-cells = <0>;
rtl8211e: phy@1 {
rtl8211e: ethernet-phy@1 { reg = <1>; interrupt-parent = <&gpio3>; interrupts = <RK_PB2 IRQ_TYPE_LEVEL_LOW>;
@@ -504,8 +510,6 @@ };
&pcie0 {
max-link-speed = <2>; num-lanes = <2>; vpcie0v9-supply = <&vcca0v9_s3>; vpcie1v8-supply = <&vcca1v8_s3>;
@@ -520,12 +524,12 @@ };
gpio-leds {
leds_gpio: leds-gpio {
status_led_pin: status-led-pin { rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; }; };
phy {
gmac { phy_intb: phy-intb { rockchip,pins = <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>; };
diff --git a/arch/arm/dts/rk3399-opp.dtsi b/arch/arm/dts/rk3399-opp.dtsi index d6f1095abb..da41cd81eb 100644 --- a/arch/arm/dts/rk3399-opp.dtsi +++ b/arch/arm/dts/rk3399-opp.dtsi @@ -10,28 +10,28 @@
opp00 { opp-hz = /bits/ 64 <408000000>;
opp-microvolt = <800000>;
opp-microvolt = <825000 825000 1250000>; clock-latency-ns = <40000>; }; opp01 { opp-hz = /bits/ 64 <600000000>;
opp-microvolt = <825000 825000 1250000>; }; opp02 { opp-hz = /bits/ 64 <816000000>;
opp-microvolt = <850000>;
opp-microvolt = <850000 850000 1250000>; }; opp03 { opp-hz = /bits/ 64 <1008000000>;
opp-microvolt = <925000>;
opp-microvolt = <925000 925000 1250000>; }; opp04 { opp-hz = /bits/ 64 <1200000000>;
opp-microvolt = <1000000>;
opp-microvolt = <1000000 1000000 1250000>; }; opp05 { opp-hz = /bits/ 64 <1416000000>;
opp-microvolt = <1125000>;
opp-microvolt = <1125000 1125000 1250000>; }; };
@@ -41,36 +41,36 @@
opp-microvolt = <825000>;
opp-microvolt = <825000 825000 1250000>; }; opp03 { opp-hz = /bits/ 64 <1008000000>;
opp-microvolt = <875000>;
opp-microvolt = <875000 875000 1250000>; }; opp04 { opp-hz = /bits/ 64 <1200000000>;
opp-microvolt = <950000>;
opp-microvolt = <950000 950000 1250000>; }; opp05 { opp-hz = /bits/ 64 <1416000000>;
opp-microvolt = <1025000>;
opp-microvolt = <1025000 1025000 1250000>; }; opp06 { opp-hz = /bits/ 64 <1608000000>;
opp-microvolt = <1100000>;
opp-microvolt = <1100000 1100000 1250000>; }; opp07 { opp-hz = /bits/ 64 <1800000000>;
opp-microvolt = <1200000>;
opp-microvolt = <1200000 1200000 1250000>; }; };
@@ -79,27 +79,27 @@
opp00 { opp-hz = /bits/ 64 <200000000>;
opp-microvolt = <825000 825000 1150000>; }; opp01 { opp-hz = /bits/ 64 <297000000>;
opp-microvolt = <825000 825000 1150000>; }; opp02 { opp-hz = /bits/ 64 <400000000>;
opp-microvolt = <825000 825000 1150000>; }; opp03 { opp-hz = /bits/ 64 <500000000>;
opp-microvolt = <875000 875000 1150000>; }; opp04 { opp-hz = /bits/ 64 <600000000>;
opp-microvolt = <925000 925000 1150000>; }; opp05 { opp-hz = /bits/ 64 <800000000>;
opp-microvolt = <1100000 1100000 1150000>; }; };
}; diff --git a/arch/arm/dts/rk3399-orangepi.dts b/arch/arm/dts/rk3399-orangepi.dts index f9f7246d4d..04b54abea3 100644 --- a/arch/arm/dts/rk3399-orangepi.dts +++ b/arch/arm/dts/rk3399-orangepi.dts @@ -7,6 +7,7 @@
#include "dt-bindings/pwm/pwm.h" #include "dt-bindings/input/input.h" +#include "dt-bindings/usb/pd.h" #include "rk3399.dtsi" #include "rk3399-opp.dtsi"
@@ -14,6 +15,12 @@ model = "Orange Pi RK3399 Board"; compatible = "rockchip,rk3399-orangepi", "rockchip,rk3399";
aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
@@ -214,7 +221,7 @@ #address-cells = <1>; #size-cells = <0>;
rtl8211e: phy@1 {
@@ -531,6 +538,43 @@ pinctrl-names = "default"; pinctrl-0 = <&chg_cc_int_l>; vbus-supply = <&vbus_typec>;
typec_con: connector {
data-role = "host";
label = "USB-C";
sink-pdos =
source-pdos =
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
remote-endpoint = <&u2phy0_typec_hs>;
port@1 {
reg = <1>;
remote-endpoint = <&tcphy0_typec_ss>;
port@2 {
reg = <2>;
typec_dp: endpoint {
remote-endpoint = <&tcphy0_typec_dp>;
@@ -554,7 +598,7 @@ }; };
phy {
@@ -717,6 +761,22 @@ status = "okay"; };
+&tcphy0_dp {
port {
tcphy0_typec_dp: endpoint {
remote-endpoint = <&typec_dp>;
+&tcphy0_usb3 {
port {
remote-endpoint = <&typec_ss>;
&tcphy1 { status = "okay"; }; @@ -739,6 +799,12 @@ phy-supply = <&vcc5v0_host>; status = "okay"; };
port {
remote-endpoint = <&typec_hs>;
&u2phy1 { @@ -799,7 +865,7 @@
&usbdrd_dwc3_0 { status = "okay";
dr_mode = "otg";
dr_mode = "host";
&usbdrd3_1 { diff --git a/arch/arm/dts/rk3399-pinebook-pro.dts b/arch/arm/dts/rk3399-pinebook-pro.dts index 294d21bf45..2b5f001ff4 100644 --- a/arch/arm/dts/rk3399-pinebook-pro.dts +++ b/arch/arm/dts/rk3399-pinebook-pro.dts @@ -18,6 +18,12 @@ model = "Pine64 Pinebook Pro"; compatible = "pine64,pinebook-pro", "rockchip,rk3399";
aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
@@ -28,12 +34,19 @@ pwms = <&pwm0 0 740740 0>; };
bat: battery {
compatible = "simple-battery";
charge-full-design-microamp-hours = <9800000>;
voltage-max-design-microvolt = <4350000>;
voltage-min-design-microvolt = <3000000>;
edp_panel: edp-panel { compatible = "boe,nv140fhmn49"; backlight = <&backlight>; enable-gpios = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>; pinctrl-names = "default";
pinctrl-0 = <&panel_en_gpio>;
pinctrl-0 = <&panel_en_pin>; power-supply = <&vcc3v3_panel>; ports {
@@ -60,7 +73,7 @@ gpio-key-lid { compatible = "gpio-keys"; pinctrl-names = "default";
pinctrl-0 = <&lidbtn_gpio>;
pinctrl-0 = <&lidbtn_pin>; lid { debounce-interval = <20>;
@@ -76,7 +89,7 @@ gpio-key-power { compatible = "gpio-keys"; pinctrl-names = "default";
pinctrl-0 = <&pwrbtn_gpio>;
pinctrl-0 = <&pwrbtn_pin>; power { debounce-interval = <20>;
@@ -90,9 +103,9 @@ leds { compatible = "gpio-leds"; pinctrl-names = "default";
pinctrl-0 = <&pwrled_gpio &slpled_gpio>;
pinctrl-0 = <&pwr_led_pin &slp_led_pin>;
green-led {
green_led: led-0 { color = <LED_COLOR_ID_GREEN>; default-state = "on"; function = LED_FUNCTION_POWER;
@@ -100,7 +113,7 @@ label = "green:power"; };
red-led {
red_led: led-1 { color = <LED_COLOR_ID_RED>; default-state = "off"; function = LED_FUNCTION_STANDBY;
@@ -117,7 +130,7 @@ clocks = <&rk808 1>; clock-names = "ext_clock"; pinctrl-names = "default";
pinctrl-0 = <&wifi_enable_h_gpio>;
pinctrl-0 = <&wifi_enable_h_pin>; post-power-on-delay-ms = <100>; power-off-delay-us = <500000>;
@@ -129,7 +142,7 @@ es8316-sound { compatible = "simple-audio-card"; pinctrl-names = "default";
pinctrl-0 = <&hp_det_gpio>;
pinctrl-0 = <&hp_det_pin>; simple-audio-card,name = "rockchip,es8316-codec"; simple-audio-card,format = "i2s"; simple-audio-card,mclk-fs = <256>;
@@ -213,7 +226,7 @@ enable-active-high; gpio = <&gpio1 RK_PB5 GPIO_ACTIVE_HIGH>; pinctrl-names = "default";
pinctrl-0 = <&pwr_5v_gpio>;
pinctrl-0 = <&pwr_5v_pin>; regulator-name = "vcc5v0_usb"; regulator-always-on; regulator-min-microvolt = <5000000>;
@@ -270,7 +283,7 @@ enable-active-high; gpio = <&gpio0 RK_PA1 GPIO_ACTIVE_HIGH>; pinctrl-names = "default";
pinctrl-0 = <&sdmmc0_pwr_h_gpio>;
pinctrl-0 = <&sdmmc0_pwr_h_pin>; regulator-name = "vcc3v0_sd"; regulator-always-on; regulator-min-microvolt = <3000000>;
@@ -288,7 +301,7 @@ enable-active-high; gpio = <&gpio1 RK_PC6 GPIO_ACTIVE_HIGH>; pinctrl-names = "default";
pinctrl-0 = <&lcdvcc_en_gpio>;
pinctrl-0 = <&lcdvcc_en_pin>; regulator-name = "vcc3v3_panel"; regulator-always-on; regulator-min-microvolt = <3300000>;
@@ -317,7 +330,7 @@ enable-active-high; gpio = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>; pinctrl-names = "default";
pinctrl-0 = <&vcc5v0_host_en_gpio>;
pinctrl-0 = <&vcc5v0_host_en_pin>; regulator-name = "vcc5v0_otg"; regulator-always-on; regulator-min-microvolt = <5000000>;
@@ -336,7 +349,7 @@ enable-active-high; gpio = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>; pinctrl-names = "default";
pinctrl-0 = <&vcc5v0_typec0_en_gpio>;
pinctrl-0 = <&vcc5v0_typec0_en_pin>; regulator-name = "vbus_5vout"; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>;
@@ -368,7 +381,7 @@
/* Also triggered by USB charger */ pinctrl-names = "default";
pinctrl-0 = <&dc_det_gpio>;
pinctrl-0 = <&dc_det_pin>; };
@@ -447,7 +460,7 @@ interrupt-parent = <&gpio3>; interrupts = <10 IRQ_TYPE_LEVEL_LOW>; pinctrl-names = "default";
pinctrl-0 = <&pmic_int_l_gpio>;
pinctrl-0 = <&pmic_int_l_pin>; rockchip,system-power-controller; wakeup-source;
@@ -627,7 +640,7 @@ reg = <0x40>; fcs,suspend-voltage-selector = <1>; pinctrl-names = "default";
pinctrl-0 = <&vsel1_pin>; regulator-name = "vdd_cpu_b"; regulator-always-on; regulator-boot-on;
@@ -646,7 +659,7 @@ reg = <0x41>; fcs,suspend-voltage-selector = <1>; pinctrl-names = "default";
pinctrl-0 = <&vsel2_pin>; regulator-name = "vdd_gpu"; regulator-always-on; regulator-boot-on;
@@ -690,9 +703,10 @@ fusb0: fusb30x@22 { compatible = "fcs,fusb302"; reg = <0x22>;
fcs,int_n = <&gpio1 RK_PA2 GPIO_ACTIVE_HIGH>;
interrupt-parent = <&gpio1>;
interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>; pinctrl-names = "default";
pinctrl-0 = <&fusb0_int_gpio>;
pinctrl-0 = <&fusb0_int_pin>; vbus-supply = <&vbus_typec>; connector {
@@ -740,12 +754,29 @@ }; }; };
cw2015@62 {
compatible = "cellwise,cw2015";
reg = <0x62>;
cellwise,battery-profile = /bits/ 8 <
0x17 0x67 0x80 0x73 0x6E 0x6C 0x6B 0x63
0x77 0x51 0x5C 0x58 0x50 0x4C 0x48 0x36
0x15 0x0C 0x0C 0x19 0x5B 0x7D 0x6F 0x69
0x69 0x5B 0x0C 0x29 0x20 0x40 0x52 0x59
0x57 0x56 0x54 0x4F 0x3B 0x1F 0x7F 0x17
0x06 0x1A 0x30 0x5A 0x85 0x93 0x96 0x2D
0x48 0x77 0x9C 0xB3 0x80 0x52 0x94 0xCB
0x2F 0x00 0x64 0xA5 0xB5 0x11 0xF0 0x11
cellwise,monitor-interval-ms = <5000>;
monitored-battery = <&bat>;
power-supplies = <&mains_charger>, <&fusb0>;
&i2s1 {
#sound-dai-cells = <0>; pinctrl-names = "default";
pinctrl-0 = <&i2s_8ch_mclk_gpio>, <&i2s1_2ch_bus>;
pinctrl-0 = <&i2s_8ch_mclk_pin>, <&i2s1_2ch_bus>; rockchip,capture-channels = <8>; rockchip,playback-channels = <8>; status = "okay";
@@ -765,7 +796,6 @@ &pcie0 { bus-scan-delay-ms = <1000>; ep-gpios = <&gpio2 RK_PD4 GPIO_ACTIVE_HIGH>;
max-link-speed = <2>; num-lanes = <4>; pinctrl-names = "default"; pinctrl-0 = <&pcie_clkreqn_cpm>;
@@ -777,116 +807,116 @@
&pinctrl { buttons {
pwrbtn_gpio: pwrbtn-gpio {
pwrbtn_pin: pwrbtn-pin { rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; };
lidbtn_gpio: lidbtn-gpio {
lidbtn_pin: lidbtn-pin { rockchip,pins = <1 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>; }; }; dc-charger {
dc_det_gpio: dc-det-gpio {
dc_det_pin: dc-det-pin { rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_up>; }; }; es8316 {
hp_det_gpio: hp-det-gpio {
hp_det_pin: hp-det-pin { rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>; }; }; fusb302x {
fusb0_int_gpio: fusb0-int-gpio {
fusb0_int_pin: fusb0-int-pin { rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; }; }; i2s1 {
i2s_8ch_mclk_gpio: i2s-8ch-mclk-gpio {
i2s_8ch_mclk_pin: i2s-8ch-mclk-pin { rockchip,pins = <4 RK_PA0 1 &pcfg_pull_none>; }; }; lcd-panel {
lcdvcc_en_gpio: lcdvcc-en-gpio {
lcdvcc_en_pin: lcdvcc-en-pin { rockchip,pins = <1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; };
panel_en_gpio: panel-en-gpio {
panel_en_pin: panel-en-pin { rockchip,pins = <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; };
lcd_panel_reset_gpio: lcd-panel-reset-gpio {
lcd_panel_reset_pin: lcd-panel-reset-pin { rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_up>; }; }; leds {
pwrled_gpio: pwrled_gpio {
pwr_led_pin: pwr-led-pin { rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; };
slpled_gpio: slpled_gpio {
slp_led_pin: slp-led-pin { rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; }; }; pmic {
pmic_int_l_gpio: pmic-int-l-gpio {
pmic_int_l_pin: pmic-int-l-pin { rockchip,pins = <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>; };
vsel2_pin: vsel2-pin { rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; }; }; sdcard {
sdmmc0_pwr_h_gpio: sdmmc0-pwr-h-gpio {
sdmmc0_pwr_h_pin: sdmmc0-pwr-h-pin { rockchip,pins = <0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; }; }; sdio-pwrseq {
wifi_enable_h_gpio: wifi-enable-h-gpio {
wifi_enable_h_pin: wifi-enable-h-pin { rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; }; }; usb-typec {
vcc5v0_typec0_en_gpio: vcc5v0-typec0-en-gpio {
vcc5v0_typec0_en_pin: vcc5v0-typec0-en-pin { rockchip,pins = <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; }; }; usb2 {
pwr_5v_gpio: pwr-5v-gpio {
pwr_5v_pin: pwr-5v-pin { rockchip,pins = <1 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; };
vcc5v0_host_en_gpio: vcc5v0-host-en-gpio {
vcc5v0_host_en_pin: vcc5v0-host-en-pin { rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; }; }; wireless-bluetooth {
bt_wake_gpio: bt-wake-gpio {
bt_wake_pin: bt-wake-pin { rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; };
bt_host_wake_gpio: bt-host-wake-gpio {
bt_host_wake_pin: bt-host-wake-pin { rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; };
bt_reset_gpio: bt-reset-gpio {
bt_reset_pin: bt-reset-pin { rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; }; };
@@ -1034,7 +1064,7 @@ host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; max-speed = <1500000>; pinctrl-names = "default";
pinctrl-0 = <&bt_host_wake_gpio &bt_wake_gpio &bt_reset_gpio>;
pinctrl-0 = <&bt_host_wake_pin &bt_wake_pin &bt_reset_pin>; shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; vbat-supply = <&wifi_bat>; vddio-supply = <&vcc_wl>;
diff --git a/arch/arm/dts/rk3399-puma-haikou.dts b/arch/arm/dts/rk3399-puma-haikou.dts index d80d6b7268..292bb7e80c 100644 --- a/arch/arm/dts/rk3399-puma-haikou.dts +++ b/arch/arm/dts/rk3399-puma-haikou.dts @@ -10,14 +10,18 @@ model = "Theobroma Systems RK3399-Q7 SoM"; compatible = "tsd,rk3399-puma-haikou", "rockchip,rk3399";
aliases {
mmc1 = &sdmmc;
chosen { stdout-path = "serial0:115200n8"; }; leds {
pinctrl-0 = <&led_pin_module>, <&led_sd_haikou>;
pinctrl-0 = <&module_led_pin>, <&sd_card_led_pin>;
sd-card-led {
sd_card_led: led-1 { label = "sd_card_led"; gpios = <&gpio1 RK_PA2 GPIO_ACTIVE_HIGH>; linux,default-trigger = "mmc0";
@@ -179,7 +183,7 @@ };
leds {
led_sd_haikou: led-sd-gpio {
sd_card_led_pin: sd-card-led-pin { rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; };
diff --git a/arch/arm/dts/rk3399-puma.dtsi b/arch/arm/dts/rk3399-puma.dtsi index 72c06abd27..fb67db4619 100644 --- a/arch/arm/dts/rk3399-puma.dtsi +++ b/arch/arm/dts/rk3399-puma.dtsi @@ -8,12 +8,16 @@ #include "rk3399-opp.dtsi"
aliases {
mmc0 = &sdhci;
pinctrl-0 = <&led_pin_module>;
pinctrl-0 = <&module_led_pin>;
module-led {
module_led: led-0 { label = "module_led"; gpios = <&gpio2 RK_PD1 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat";
@@ -21,57 +25,6 @@ }; };
* Overwrite the opp-table for CPUB as this board uses a different
* regulator (FAN53555) that only allows 10mV steps and therefore
* can't reach the operation point target voltages from rk3399-opp.dtsi
/delete-node/ opp-table1;
cluster1_opp: opp-table1 {
compatible = "operating-points-v2";
opp-shared;
opp00 {
opp01 {
opp02 {
opp-microvolt = <830000>;
opp-suspend;
opp03 {
opp-microvolt = <880000>;
opp04 {
opp05 {
opp-microvolt = <1030000>;
opp06 {
opp07 {
opp08 {
opp-hz = /bits/ 64 <1992000000>;
opp-microvolt = <1230000>;
turbo-mode;
clkin_gmac: external-gmac-clock { compatible = "fixed-clock"; clock-frequency = <125000000>;
@@ -450,7 +403,7 @@ };
leds {
led_pin_module: led-module-gpio {
module_led_pin: module-led-pin { rockchip,pins = <2 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; };
diff --git a/arch/arm/dts/rk3399-roc-pc-mezzanine.dts b/arch/arm/dts/rk3399-roc-pc-mezzanine.dts index 2acb3d500f..9447c8724b 100644 --- a/arch/arm/dts/rk3399-roc-pc-mezzanine.dts +++ b/arch/arm/dts/rk3399-roc-pc-mezzanine.dts @@ -11,6 +11,20 @@ model = "Firefly ROC-RK3399-PC Mezzanine Board"; compatible = "firefly,roc-rk3399-pc-mezzanine", "rockchip,rk3399";
aliases {
mmc2 = &sdio0;
/* MP8009 PoE PD */
poe_12v: poe-12v {
regulator-name = "poe_12v";
regulator-boot-on;
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
vcc3v3_ngff: vcc3v3-ngff { compatible = "regulator-fixed"; regulator-name = "vcc3v3_ngff";
@@ -22,7 +36,7 @@ regulator-boot-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>;
vin-supply = <&dc_12v>;
vin-supply = <&sys_12v>; }; vcc3v3_pcie: vcc3v3-pcie {
@@ -34,10 +48,14 @@ pinctrl-0 = <&vcc3v3_pcie_en>; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>;
+&sys_12v {
vin-supply = <&poe_12v>;
&pcie_phy { status = "okay"; }; diff --git a/arch/arm/dts/rk3399-roc-pc.dtsi b/arch/arm/dts/rk3399-roc-pc.dtsi index 9f225e9c3d..d1aaf8e833 100644 --- a/arch/arm/dts/rk3399-roc-pc.dtsi +++ b/arch/arm/dts/rk3399-roc-pc.dtsi @@ -13,6 +13,11 @@ model = "Firefly ROC-RK3399-PC Board"; compatible = "firefly,roc-rk3399-pc", "rockchip,rk3399";
aliases {
mmc0 = &sdmmc;
mmc1 = &sdhci;
chosen { stdout-path = "serial2:1500000n8"; };
@@ -58,30 +63,37 @@ }; };
ir-receiver {
pinctrl-0 = <&work_led_gpio>, <&diy_led_gpio>, <&yellow_led_gpio>;
pinctrl-0 = <&work_led_pin>, <&diy_led_pin>, <&yellow_led_pin>;
work-led {
work_led: led-0 { label = "green:work"; gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>; default-state = "on"; linux,default-trigger = "heartbeat"; };
diy-led {
diy_led: led-1 { label = "red:diy"; gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>; default-state = "off";
linux,default-trigger = "mmc2"; };
yellow-led {
yellow_led: led-2 { label = "yellow:yellow-led"; gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>; default-state = "off";
linux,default-trigger = "mmc1"; }; };
@@ -110,6 +122,14 @@ regulator-max-microvolt = <5000000>; };
sys_12v: sys-12v {
regulator-name = "sys_12v";
regulator-boot-on;
@@ -141,7 +161,7 @@ regulator-boot-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>;
vin-supply = <&sys_12v>; }; vcca_0v9: vcca-0v9 {
@@ -186,7 +206,7 @@ regulator-boot-on; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>;
vin-supply = <&sys_12v>; }; vdd_log: vdd-log {
@@ -376,6 +396,7 @@
vcc_sdio: LDO_REG4 { regulator-name = "vcc_sdio";
regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <3000000>;
@@ -456,7 +477,7 @@ reg = <0x40>; fcs,suspend-voltage-selector = <1>; pinctrl-names = "default";
@@ -475,11 +496,13 @@ reg = <0x41>; fcs,suspend-voltage-selector = <1>; pinctrl-names = "default";
pinctrl-0 = <&vsel2_pin>; regulator-name = "vdd_gpu"; regulator-min-microvolt = <712500>; regulator-max-microvolt = <1500000>; regulator-ramp-delay = <1000>;
regulator-boot-on; vin-supply = <&vcc3v3_sys>; regulator-state-mem {
@@ -588,6 +611,12 @@ }; };
ir {
ir_int: ir-int {
lcd-panel { lcd_panel_reset: lcd-panel-reset { rockchip,pins = <4 RK_PD5 RK_FUNC_GPIO &pcfg_pull_up>;
@@ -595,25 +624,25 @@ };
leds {
diy_led_pin: diy-led-pin { rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; };
work_led_pin: work-led-pin { rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; };
yellow_led_gpio: yellow_led-gpio {
yellow_led_pin: yellow-led-pin { rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; }; }; pmic {
vsel1_pin: vsel1-pin { rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_down>; };
diff --git a/arch/arm/dts/rk3399-rock-pi-4.dtsi b/arch/arm/dts/rk3399-rock-pi-4.dtsi index 1c55a4645b..b28888ea92 100644 --- a/arch/arm/dts/rk3399-rock-pi-4.dtsi +++ b/arch/arm/dts/rk3399-rock-pi-4.dtsi @@ -11,6 +11,11 @@ #include "rk3399-opp.dtsi"
aliases {
mmc0 = &sdmmc;
mmc1 = &sdhci;
@@ -111,10 +116,6 @@ regulator-boot-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>;
regulator-off-in-suspend;
}; }; vdd_log: vdd-log {
@@ -362,8 +363,6 @@ regulator-name = "vcc_cam"; regulator-always-on; regulator-boot-on;
regulator-max-microvolt = <3300000>; regulator-state-mem { regulator-off-in-suspend; };
@@ -373,8 +372,6 @@ regulator-name = "vcc_mipi"; regulator-always-on; regulator-boot-on;
@@ -387,7 +384,7 @@ reg = <0x40>; fcs,suspend-voltage-selector = <1>; pinctrl-names = "default";
@@ -406,7 +403,7 @@ reg = <0x41>; fcs,suspend-voltage-selector = <1>; pinctrl-names = "default";
@@ -440,8 +437,9 @@ };
&i2s0 {
pinctrl-0 = <&i2s0_2ch_bus>;
rockchip,capture-channels = <2>;
rockchip,playback-channels = <2>; status = "okay";
@@ -476,7 +474,6 @@
&pcie0 { ep-gpios = <&gpio4 RK_PD3 GPIO_ACTIVE_HIGH>;
max-link-speed = <2>; num-lanes = <4>; pinctrl-0 = <&pcie_clkreqnb_cpm>; pinctrl-names = "default";
@@ -529,11 +526,11 @@ rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; };
@@ -680,7 +677,7 @@
dr_mode = "otg";
dr_mode = "host";
&usbdrd3_1 { diff --git a/arch/arm/dts/rk3399-rock-pi-4a.dts b/arch/arm/dts/rk3399-rock-pi-4a.dts index d96dd3ebd3..89f2af5e11 100644 --- a/arch/arm/dts/rk3399-rock-pi-4a.dts +++ b/arch/arm/dts/rk3399-rock-pi-4a.dts @@ -9,5 +9,5 @@
/ { model = "Radxa ROCK Pi 4A";
compatible = "radxa,rockpi4", "rockchip,rk3399";
compatible = "radxa,rockpi4a", "radxa,rockpi4", "rockchip,rk3399";
}; diff --git a/arch/arm/dts/rk3399-rock-pi-4b.dts b/arch/arm/dts/rk3399-rock-pi-4b.dts index 4ca970acac..6c63e61706 100644 --- a/arch/arm/dts/rk3399-rock-pi-4b.dts +++ b/arch/arm/dts/rk3399-rock-pi-4b.dts @@ -9,7 +9,11 @@
/ { model = "Radxa ROCK Pi 4B";
compatible = "radxa,rockpi4b", "radxa,rockpi4", "rockchip,rk3399";
aliases {
mmc2 = &sdio0;
&sdio0 { diff --git a/arch/arm/dts/rk3399-rock-pi-4c.dts b/arch/arm/dts/rk3399-rock-pi-4c.dts index 9d07ebd1ec..99169bcd51 100644 --- a/arch/arm/dts/rk3399-rock-pi-4c.dts +++ b/arch/arm/dts/rk3399-rock-pi-4c.dts @@ -10,7 +10,11 @@
/ { model = "Radxa ROCK Pi 4C";
compatible = "radxa,rockpi4c", "radxa,rockpi4", "rockchip,rk3399";
aliases {
mmc2 = &sdio0;
&sdio0 { diff --git a/arch/arm/dts/rk3399-rock960.dts b/arch/arm/dts/rk3399-rock960.dts index 437a75f31a..1a23e8f3cd 100644 --- a/arch/arm/dts/rk3399-rock960.dts +++ b/arch/arm/dts/rk3399-rock960.dts @@ -17,42 +17,43 @@ leds { compatible = "gpio-leds"; pinctrl-names = "default";
user_led1 {
user_led1: led-1 { label = "green:user1"; gpios = <&gpio4 RK_PC2 0>; linux,default-trigger = "heartbeat"; };
user_led2 {
user_led2: led-2 { label = "green:user2"; gpios = <&gpio4 RK_PC6 0>; linux,default-trigger = "mmc0"; };
user_led3 {
user_led3: led-3 { label = "green:user3"; gpios = <&gpio4 RK_PD0 0>; linux,default-trigger = "mmc1"; };
user_led4 {
user_led4: led-4 { label = "green:user4"; gpios = <&gpio4 RK_PD4 0>; panic-indicator; linux,default-trigger = "none"; };
wlan_active_led {
wlan_active_led: led-5 { label = "yellow:wlan"; gpios = <&gpio4 RK_PD5 0>; linux,default-trigger = "phy0tx"; default-state = "off"; };
bt_active_led {
bt_active_led: led-6 { label = "blue:bt"; gpios = <&gpio4 RK_PD6 0>; linux,default-trigger = "hci0-power";
@@ -62,38 +63,52 @@
+&cpu_alert0 {
+&cpu_thermal {
sustainable-power = <1550>;
cooling-maps {
map0 {
trip = <&cpu_alert1>;
&pcie0 { ep-gpios = <&gpio2 RK_PA2 GPIO_ACTIVE_HIGH>; };
&pinctrl { leds {
user_led1_pin: user-led1-pin { rockchip,pins = <4 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; };
user_led2_pin: user-led2-pin { rockchip,pins = <4 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; };
user_led3_pin: user-led3-pin { rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; };
user_led4_pin: user-led4-pin { rockchip,pins = <4 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; };
wlan_led_pin: wlan-led-pin { rockchip,pins = <4 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>; };
bt_led: bt_led {
bt_led_pin: bt-led-pin { rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>; };
@@ -124,45 +139,6 @@ status = "okay"; };
-&thermal_zones {
cpu_thermal: cpu {
polling-delay = <1000>;
thermal-sensors = <&tsadc 0>;
trips {
cpu_alert0: cpu_alert0 {
type = "passive";
cpu_alert1: cpu_alert1 {
temperature = <75000>;
type = "passive";
cpu_crit: cpu_crit {
temperature = <95000>;
type = "critical";
cooling-maps {
map0 {
cooling-device =
<&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu_b1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>;
&usbdrd_dwc3_0 { dr_mode = "otg"; }; diff --git a/arch/arm/dts/rk3399-rock960.dtsi b/arch/arm/dts/rk3399-rock960.dtsi index ba7c75c9f2..25dc61c26a 100644 --- a/arch/arm/dts/rk3399-rock960.dtsi +++ b/arch/arm/dts/rk3399-rock960.dtsi @@ -9,6 +9,12 @@ #include "rk3399-opp.dtsi"
aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
sdio_pwrseq: sdio-pwrseq { compatible = "mmc-pwrseq-simple"; clocks = <&rk808 1>;
@@ -470,12 +476,12 @@ <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; };
diff --git a/arch/arm/dts/rk3399-rockpro64.dtsi b/arch/arm/dts/rk3399-rockpro64.dtsi index 9bca258012..6bff8db7d3 100644 --- a/arch/arm/dts/rk3399-rockpro64.dtsi +++ b/arch/arm/dts/rk3399-rockpro64.dtsi @@ -10,6 +10,12 @@ #include "rk3399-opp.dtsi"
aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
@@ -36,18 +42,25 @@ }; };
ir-receiver {
work-led {
work_led: led-0 { label = "work"; default-state = "on"; gpios = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>; };
diy-led {
diy_led: led-1 { label = "diy"; default-state = "off"; gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>;
@@ -72,10 +85,27 @@
sound { compatible = "audio-graph-card";
label = "rockchip,rk3399";
label = "Analog"; dais = <&i2s1_p0>; };
sound-dit {
label = "SPDIF";
dais = <&spdif_p0>;
spdif-dit {
compatible = "linux,spdif-dit";
port {
dit_p0_0: endpoint {
remote-endpoint = <&spdif_p0_0>;
vcc12v_dcin: vcc12v-dcin { compatible = "regulator-fixed"; regulator-name = "vcc12v_dcin";
@@ -96,6 +126,24 @@ vin-supply = <&vcc_1v8>; };
/* micro SD card power */
vcc3v0_sd: vcc3v0-sd {
enable-active-high;
pinctrl-0 = <&sdmmc0_pwr_h>;
vcc3v3_pcie: vcc3v3-pcie-regulator { compatible = "regulator-fixed"; enable-active-high;
@@ -427,7 +475,7 @@ reg = <0x40>; fcs,suspend-voltage-selector = <1>; pinctrl-names = "default";
@@ -446,7 +494,7 @@ reg = <0x41>; fcs,suspend-voltage-selector = <1>; pinctrl-names = "default";
@@ -569,12 +617,18 @@ }; };
ir {
ir_int: ir-int {
leds {
work_led_pin: work-led-pin { rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; };
diy_led_pin: diy-led-pin { rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; }; };
@@ -594,15 +648,22 @@ rockchip,pins = <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>; };
sdcard {
sdmmc0_pwr_h: sdmmc0-pwr-h {
sdio-pwrseq { wifi_enable_h: wifi-enable-h { rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>;
@@ -661,6 +722,8 @@ max-frequency = <150000000>; pinctrl-names = "default"; pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>;
vmmc-supply = <&vcc3v0_sd>;
vqmmc-supply = <&vcc_sdio>; status = "okay";
@@ -671,6 +734,16 @@ status = "okay"; };
+&spdif {
spdif_p0: port {
spdif_p0_0: endpoint {
remote-endpoint = <&dit_p0_0>;
&spi1 { status = "okay";
@@ -768,7 +841,7 @@
dr_mode = "otg";
dr_mode = "host";
&usbdrd3_1 { diff --git a/arch/arm/dts/rk3399.dtsi b/arch/arm/dts/rk3399.dtsi index 74f2c3d490..3871c7fd83 100644 --- a/arch/arm/dts/rk3399.dtsi +++ b/arch/arm/dts/rk3399.dtsi @@ -197,38 +197,12 @@ #clock-cells = <0>; };
amba: bus {
#size-cells = <2>;
ranges;
dmac_bus: dma-controller@ff6d0000 {
reg = <0x0 0xff6d0000 0x0 0x4000>;
interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH 0>;
#dma-cells = <1>;
clocks = <&cru ACLK_DMAC0_PERILP>;
dmac_peri: dma-controller@ff6e0000 {
reg = <0x0 0xff6e0000 0x0 0x4000>;
interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH 0>;
#dma-cells = <1>;
clocks = <&cru ACLK_DMAC1_PERILP>;
pcie0: pcie@f8000000 { compatible = "rockchip,rk3399-pcie"; reg = <0x0 0xf8000000 0x0 0x2000000>, <0x0 0xfd000000 0x0 0x1000000>; reg-names = "axi-base", "apb-base";
device_type = "pci"; #address-cells = <3>; #size-cells = <2>; #interrupt-cells = <1>;
@@ -247,15 +221,14 @@ <0 0 0 2 &pcie0_intc 1>, <0 0 0 3 &pcie0_intc 2>, <0 0 0 4 &pcie0_intc 3>;
linux,pci-domain = <0>; max-link-speed = <1>; msi-map = <0x0 &its 0x0 0x1000>; phys = <&pcie_phy 0>, <&pcie_phy 1>, <&pcie_phy 2>, <&pcie_phy 3>; phy-names = "pcie-phy-0", "pcie-phy-1", "pcie-phy-2", "pcie-phy-3";
ranges = <0x83000000 0x0 0xfa000000 0x0 0xfa000000 0x0 0x1e00000
0x81000000 0x0 0xfbe00000 0x0 0xfbe00000 0x0 0x100000>;
ranges = <0x82000000 0x0 0xfa000000 0x0 0xfa000000 0x0 0x1e00000>,
<0x81000000 0x0 0xfbe00000 0x0 0xfbe00000 0x0 0x100000>; resets = <&cru SRST_PCIE_CORE>, <&cru SRST_PCIE_MGMT>, <&cru SRST_PCIE_MGMT_STICKY>, <&cru SRST_PCIE_PIPE>, <&cru SRST_PCIE_PM>, <&cru SRST_P_PCIE>,
@@ -326,7 +299,7 @@ status = "disabled"; };
sdhci: sdhci@fe330000 {
sdhci: mmc@fe330000 { compatible = "rockchip,rk3399-sdhci-5.1", "arasan,sdhci-5.1"; reg = <0x0 0xfe330000 0x0 0x10000>; interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH 0>;
@@ -403,7 +376,7 @@ reset-names = "usb3-otg"; status = "disabled";
usbdrd_dwc3_0: dwc3 {
usbdrd_dwc3_0: usb@fe800000 { compatible = "snps,dwc3"; reg = <0x0 0xfe800000 0x0 0x100000>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH 0>;
@@ -439,7 +412,7 @@ reset-names = "usb3-otg"; status = "disabled";
usbdrd_dwc3_1: dwc3 {
usbdrd_dwc3_1: usb@fe900000 { compatible = "snps,dwc3"; reg = <0x0 0xfe900000 0x0 0x100000>; interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH 0>;
@@ -759,7 +732,7 @@ };
thermal_zones: thermal-zones {
cpu_thermal: cpu {
cpu_thermal: cpu-thermal { polling-delay-passive = <100>; polling-delay = <1000>;
@@ -803,7 +776,7 @@ }; };
gpu_thermal: gpu {
gpu_thermal: gpu-thermal { polling-delay-passive = <100>; polling-delay = <1000>;
@@ -845,135 +818,135 @@ rockchip,grf = <&grf>; rockchip,hw-tshut-temp = <95000>; pinctrl-names = "init", "default", "sleep";
pinctrl-0 = <&otp_gpio>;
pinctrl-0 = <&otp_pin>; pinctrl-1 = <&otp_out>;
pinctrl-2 = <&otp_gpio>;
pinctrl-2 = <&otp_pin>; #thermal-sensor-cells = <1>; status = "disabled"; }; qos_emmc: qos@ffa58000 {
compatible = "syscon";
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa58000 0x0 0x20>; }; qos_gmac: qos@ffa5c000 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa5c000 0x0 0x20>; }; qos_pcie: qos@ffa60080 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa60080 0x0 0x20>; }; qos_usb_host0: qos@ffa60100 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa60100 0x0 0x20>; }; qos_usb_host1: qos@ffa60180 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa60180 0x0 0x20>; }; qos_usb_otg0: qos@ffa70000 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa70000 0x0 0x20>; }; qos_usb_otg1: qos@ffa70080 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa70080 0x0 0x20>; }; qos_sd: qos@ffa74000 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa74000 0x0 0x20>; }; qos_sdioaudio: qos@ffa76000 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa76000 0x0 0x20>; }; qos_hdcp: qos@ffa90000 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa90000 0x0 0x20>; }; qos_iep: qos@ffa98000 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffa98000 0x0 0x20>; }; qos_isp0_m0: qos@ffaa0000 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffaa0000 0x0 0x20>; }; qos_isp0_m1: qos@ffaa0080 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffaa0080 0x0 0x20>; }; qos_isp1_m0: qos@ffaa8000 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffaa8000 0x0 0x20>; }; qos_isp1_m1: qos@ffaa8080 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffaa8080 0x0 0x20>; }; qos_rga_r: qos@ffab0000 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffab0000 0x0 0x20>; }; qos_rga_w: qos@ffab0080 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffab0080 0x0 0x20>; }; qos_video_m0: qos@ffab8000 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffab8000 0x0 0x20>; }; qos_video_m1_r: qos@ffac0000 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffac0000 0x0 0x20>; }; qos_video_m1_w: qos@ffac0080 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffac0080 0x0 0x20>; }; qos_vop_big_r: qos@ffac8000 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffac8000 0x0 0x20>; }; qos_vop_big_w: qos@ffac8080 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffac8080 0x0 0x20>; }; qos_vop_little: qos@ffad0000 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffad0000 0x0 0x20>; }; qos_perihp: qos@ffad8080 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffad8080 0x0 0x20>; }; qos_gpu: qos@ffae0000 {
compatible = "rockchip,rk3399-qos", "syscon"; reg = <0x0 0xffae0000 0x0 0x20>; };
@@ -995,126 +968,146 @@ #size-cells = <0>;
/* These power domains are grouped by VD_CENTER */
pd_iep@RK3399_PD_IEP {
power-domain@RK3399_PD_IEP { reg = <RK3399_PD_IEP>; clocks = <&cru ACLK_IEP>, <&cru HCLK_IEP>; pm_qos = <&qos_iep>;
#power-domain-cells = <0>; };
pd_rga@RK3399_PD_RGA {
power-domain@RK3399_PD_RGA { reg = <RK3399_PD_RGA>; clocks = <&cru ACLK_RGA>, <&cru HCLK_RGA>; pm_qos = <&qos_rga_r>, <&qos_rga_w>;
pd_vcodec@RK3399_PD_VCODEC {
power-domain@RK3399_PD_VCODEC { reg = <RK3399_PD_VCODEC>; clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>; pm_qos = <&qos_video_m0>;
pd_vdu@RK3399_PD_VDU {
power-domain@RK3399_PD_VDU { reg = <RK3399_PD_VDU>; clocks = <&cru ACLK_VDU>, <&cru HCLK_VDU>; pm_qos = <&qos_video_m1_r>, <&qos_video_m1_w>;
#power-domain-cells = <0>; }; /* These power domains are grouped by VD_GPU */
pd_gpu@RK3399_PD_GPU {
power-domain@RK3399_PD_GPU { reg = <RK3399_PD_GPU>; clocks = <&cru ACLK_GPU>; pm_qos = <&qos_gpu>;
#power-domain-cells = <0>; }; /* These power domains are grouped by VD_LOGIC */
pd_edp@RK3399_PD_EDP {
power-domain@RK3399_PD_EDP { reg = <RK3399_PD_EDP>; clocks = <&cru PCLK_EDP_CTRL>;
pd_emmc@RK3399_PD_EMMC {
power-domain@RK3399_PD_EMMC { reg = <RK3399_PD_EMMC>; clocks = <&cru ACLK_EMMC>; pm_qos = <&qos_emmc>;
pd_gmac@RK3399_PD_GMAC {
power-domain@RK3399_PD_GMAC { reg = <RK3399_PD_GMAC>; clocks = <&cru ACLK_GMAC>, <&cru PCLK_GMAC>; pm_qos = <&qos_gmac>;
pd_sd@RK3399_PD_SD {
power-domain@RK3399_PD_SD { reg = <RK3399_PD_SD>; clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>; pm_qos = <&qos_sd>;
pd_sdioaudio@RK3399_PD_SDIOAUDIO {
power-domain@RK3399_PD_SDIOAUDIO { reg = <RK3399_PD_SDIOAUDIO>; clocks = <&cru HCLK_SDIO>; pm_qos = <&qos_sdioaudio>;
power-domain@RK3399_PD_TCPD0 {
reg = <RK3399_PD_TCPD0>;
clocks = <&cru SCLK_UPHY0_TCPDCORE>,
<&cru SCLK_UPHY0_TCPDPHY_REF>;
power-domain@RK3399_PD_TCPD1 {
reg = <RK3399_PD_TCPD1>;
clocks = <&cru SCLK_UPHY1_TCPDCORE>,
<&cru SCLK_UPHY1_TCPDPHY_REF>;
pd_usb3@RK3399_PD_USB3 {
power-domain@RK3399_PD_USB3 { reg = <RK3399_PD_USB3>; clocks = <&cru ACLK_USB3>; pm_qos = <&qos_usb_otg0>, <&qos_usb_otg1>;
pd_vio@RK3399_PD_VIO {
power-domain@RK3399_PD_VIO { reg = <RK3399_PD_VIO>;
#power-domain-cells = <1>; #address-cells = <1>; #size-cells = <0>;
pd_hdcp@RK3399_PD_HDCP {
power-domain@RK3399_PD_HDCP { reg = <RK3399_PD_HDCP>; clocks = <&cru ACLK_HDCP>, <&cru HCLK_HDCP>, <&cru PCLK_HDCP>; pm_qos = <&qos_hdcp>;
pd_isp0@RK3399_PD_ISP0 {
power-domain@RK3399_PD_ISP0 { reg = <RK3399_PD_ISP0>; clocks = <&cru ACLK_ISP0>, <&cru HCLK_ISP0>; pm_qos = <&qos_isp0_m0>, <&qos_isp0_m1>;
pd_isp1@RK3399_PD_ISP1 {
power-domain@RK3399_PD_ISP1 { reg = <RK3399_PD_ISP1>; clocks = <&cru ACLK_ISP1>, <&cru HCLK_ISP1>; pm_qos = <&qos_isp1_m0>, <&qos_isp1_m1>;
pd_tcpc0@RK3399_PD_TCPC0 {
pd_tcpc1@RK3399_PD_TCPC1 {
pd_vo@RK3399_PD_VO {
power-domain@RK3399_PD_VO { reg = <RK3399_PD_VO>;
pd_vopb@RK3399_PD_VOPB {
power-domain@RK3399_PD_VOPB { reg = <RK3399_PD_VOPB>; clocks = <&cru ACLK_VOP0>, <&cru HCLK_VOP0>; pm_qos = <&qos_vop_big_r>, <&qos_vop_big_w>;
pd_vopl@RK3399_PD_VOPL {
power-domain@RK3399_PD_VOPL { reg = <RK3399_PD_VOPL>; clocks = <&cru ACLK_VOP1>, <&cru HCLK_VOP1>; pm_qos = <&qos_vop_little>;
#power-domain-cells = <0>; }; }; };
@@ -1124,8 +1117,6 @@ pmugrf: syscon@ff320000 { compatible = "rockchip,rk3399-pmugrf", "syscon", "simple-mfd"; reg = <0x0 0xff320000 0x0 0x1000>;
#size-cells = <1>; pmu_io_domains: io-domains { compatible = "rockchip,rk3399-pmu-io-voltage-domain";
@@ -1211,7 +1202,6 @@ pinctrl-names = "default"; pinctrl-0 = <&pwm0_pin>; clocks = <&pmucru PCLK_RKPWM_PMU>;
@@ -1222,7 +1212,6 @@ pinctrl-names = "default"; pinctrl-0 = <&pwm1_pin>; clocks = <&pmucru PCLK_RKPWM_PMU>;
@@ -1233,7 +1222,6 @@ pinctrl-names = "default"; pinctrl-0 = <&pwm2_pin>; clocks = <&pmucru PCLK_RKPWM_PMU>;
@@ -1244,7 +1232,6 @@ pinctrl-names = "default"; pinctrl-0 = <&pwm3a_pin>; clocks = <&pmucru PCLK_RKPWM_PMU>;
@@ -1271,6 +1258,17 @@ power-domains = <&power RK3399_PD_VCODEC>; };
vdec: video-codec@ff660000 {
compatible = "rockchip,rk3399-vdec";
reg = <0x0 0xff660000 0x0 0x400>;
interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru ACLK_VDU>, <&cru HCLK_VDU>,
<&cru SCLK_VDU_CA>, <&cru SCLK_VDU_CORE>;
clock-names = "axi", "ahb", "cabac", "core";
iommus = <&vdec_mmu>;
power-domains = <&power RK3399_PD_VDU>;
vdec_mmu: iommu@ff660480 { compatible = "rockchip,iommu"; reg = <0x0 0xff660480 0x0 0x40>, <0x0 0xff6604c0 0x0 0x40>;
@@ -1278,8 +1276,8 @@ interrupt-names = "vdec_mmu"; clocks = <&cru ACLK_VDU>, <&cru HCLK_VDU>; clock-names = "aclk", "iface";
power-domains = <&power RK3399_PD_VDU>; #iommu-cells = <0>;
status = "disabled"; }; iep_mmu: iommu@ff670800 {
@@ -1336,6 +1334,28 @@ }; };
#dma-cells = <1>;
#dma-cells = <1>;
pmucru: pmu-clock-controller@ff750000 { compatible = "rockchip,rk3399-pmucru"; reg = <0x0 0xff750000 0x0 0x1000>;
@@ -1387,7 +1407,18 @@ status = "disabled"; };
u2phy0: usb2-phy@e450 {
mipi_dphy_rx0: mipi-dphy-rx0 {
compatible = "rockchip,rk3399-mipi-dphy-rx0";
clocks = <&cru SCLK_MIPIDPHY_REF>,
<&cru SCLK_DPHY_RX0_CFG>,
<&cru PCLK_VIO_GRF>;
clock-names = "dphy-ref", "dphy-cfg", "grf";
power-domains = <&power RK3399_PD_VIO>;
#phy-cells = <0>;
u2phy0: usb2phy@e450 { compatible = "rockchip,rk3399-usb2phy"; reg = <0xe450 0x10>; clocks = <&cru SCLK_USB2PHY0_REF>;
@@ -1414,7 +1445,7 @@ }; };
u2phy1: usb2-phy@e460 {
u2phy1: usb2phy@e460 { compatible = "rockchip,rk3399-usb2phy"; reg = <0xe460 0x10>; clocks = <&cru SCLK_USB2PHY1_REF>;
@@ -1513,7 +1544,7 @@ };
watchdog@ff848000 {
compatible = "snps,dw-wdt";
compatible = "rockchip,rk3399-wdt", "snps,dw-wdt"; reg = <0x0 0xff848000 0x0 0x100>; clocks = <&cru PCLK_WDT>; interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH 0>;
@@ -1700,6 +1731,32 @@ status = "disabled"; };
isp0: isp0@ff910000 {
compatible = "rockchip,rk3399-cif-isp";
reg = <0x0 0xff910000 0x0 0x4000>;
interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru SCLK_ISP0>,
<&cru ACLK_ISP0_WRAPPER>,
<&cru HCLK_ISP0_WRAPPER>;
clock-names = "isp", "aclk", "hclk";
iommus = <&isp0_mmu>;
phys = <&mipi_dphy_rx0>;
phy-names = "dphy";
power-domains = <&power RK3399_PD_ISP0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
#size-cells = <0>;
isp0_mmu: iommu@ff914000 { compatible = "rockchip,iommu"; reg = <0x0 0xff914000 0x0 0x100>, <0x0 0xff915000 0x0 0x100>;
@@ -1883,10 +1940,10 @@ gpu: gpu@ff9a0000 { compatible = "rockchip,rk3399-mali", "arm,mali-t860"; reg = <0x0 0xff9a0000 0x0 0x10000>;
interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH 0>;
interrupt-names = "gpu", "job", "mmu";
interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH 0>;
interrupt-names = "job", "mmu", "gpu"; clocks = <&cru ACLK_GPU>; #cooling-cells = <2>; power-domains = <&power RK3399_PD_GPU>;
@@ -2317,7 +2374,7 @@ }; };
sleep {
suspend { ap_pwroff: ap-pwroff { rockchip,pins = <1 RK_PA5 1 &pcfg_pull_none>; };
@@ -2475,7 +2532,7 @@ };
tsadc {
otp_gpio: otp-gpio {
otp_pin: otp-pin { rockchip,pins = <1 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; };
diff --git a/arch/arm/dts/rk3399pro-vmarc-som.dtsi b/arch/arm/dts/rk3399pro-vmarc-som.dtsi index 5d087be04a..01d1a75c8b 100644 --- a/arch/arm/dts/rk3399pro-vmarc-som.dtsi +++ b/arch/arm/dts/rk3399pro-vmarc-som.dtsi @@ -12,6 +12,11 @@ / { compatible = "vamrs,rk3399pro-vmarc-som", "rockchip,rk3399pro";
aliases {
mmc0 = &sdmmc;
mmc1 = &sdhci;
vcc3v3_pcie: vcc-pcie-regulator { compatible = "regulator-fixed"; enable-active-high;
@@ -324,7 +329,6 @@
&pcie0 { ep-gpios = <&gpio0 RK_PB4 GPIO_ACTIVE_HIGH>;
@@ -353,6 +357,12 @@ }; };
sdio-pwrseq {
vbus_host { usb1_en_oc: usb1-en-oc { rockchip,pins = <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_up>;
@@ -371,6 +381,16 @@ pmu1830-supply = <&vcc_1v8>; };
+&sdio_pwrseq {
* On the module itself this is one of these (depending
* on the actual card populated):
* - SDIO_RESET_L_WL_REG_ON
* - PDN (power down when low)
reset-gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_LOW>;
&sdhci { bus-width = <8>; mmc-hs400-1_8v; diff --git a/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi b/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi index 26b53eac47..da1d548b73 100644 --- a/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi +++ b/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi @@ -15,6 +15,14 @@ #clock-cells = <0>; };
clocks = <&hym8563>;
pinctrl-0 = <&wifi_enable_h>;
vcc12v_dcin: vcc12v-dcin-regulator { compatible = "regulator-fixed"; regulator-name = "vcc12v_dcin";
@@ -78,6 +86,19 @@ status = "okay"; };
+&sdio0 {
bus-width = <4>;
cap-sd-highspeed;
cap-sdio-irq;
keep-power-in-suspend;
mmc-pwrseq = <&sdio_pwrseq>;
non-removable;
pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>;
sd-uhs-sdr104;
status = "okay";
&sdmmc { bus-width = <4>; cap-mmc-highspeed; -- 2.31.1
Signed-off-by: Peter Robinson pbrobinson@gmail.com
- aliases {
mmc0 = &sdhci;
- backlight: backlight { compatible = "pwm-backlight"; brightness-levels = <
user_led1 {
};user_led1: led-1 { label = "red:user1"; gpios = <&gpio4 25 0>; linux,default-trigger = "heartbeat";
user_led2 {
};user_led2: led-2 { label = "red:user2"; gpios = <&gpio4 26 0>; linux,default-trigger = "mmc0";
user_led3 {
};user_led3: led-3 { label = "red:user3"; gpios = <&gpio4 30 0>; linux,default-trigger = "mmc1";
user_led4 {
};user_led4: led-4 { label = "red:user4"; gpios = <&gpio1 0 0>; panic-indicator; linux,default-trigger = "none";
wlan_active_led {
};wlan_active_led: led-5 { label = "red:wlan"; gpios = <&gpio1 1 0>; linux,default-trigger = "phy0tx"; default-state = "off";
bt_active_led {
leds {
};user_led1_pin: user-led1-pin { rockchip,pins = <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>;
};user_led2_pin: user-led2-pin { rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>;
};user_led3_pin: user-led3-pin { rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>;
};user_led4_pin: user-led4-pin { rockchip,pins = <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>;
};wlan_led_pin: wlan-led-pin { rockchip,pins = <1 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>;
bt_led: bt_led {
};bt_led_pin: bt-led-pin { rockchip,pins = <1 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>;
- aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
- chosen { stdout-path = "serial2:1500000n8"; };
- ir-receiver {
compatible = "gpio-ir-receiver";
pinctrl-0 = <&ir_int>;
- leds { compatible = "gpio-leds"; pinctrl-names = "default";
work-led {
};work_led: led-0 { label = "work"; default-state = "on"; gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>;
diy-led {
- sound-dit {
label = "SPDIF";
dais = <&spdif_p0>;
- spdif-dit {
port {
- /* switched by pmic_sleep */ vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { compatible = "regulator-fixed";
- vcc5v0_typec: vcc5v0-typec-regulator {
enable-active-high;
- vcc_sys: vcc-sys { compatible = "regulator-fixed"; regulator-name = "vcc_sys";
- fusb0: typec-portc@22 {
reg = <0x22>;
status = "okay";
connector {
data-role = "host";
label = "USB-C";
sink-pdos =
source-pdos =
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
usbc_hs: endpoint {
remote-endpoint =
<&u2phy0_typec_hs>;
port@1 {
reg = <1>;
usbc_ss: endpoint {
remote-endpoint =
<&tcphy0_typec_ss>;
- accelerometer@68 { compatible = "invensense,mpu6500"; reg = <0x68>;
fusb302x {
ir {
ir_int: ir-int {
leds {
pmic {
pmic_int_l: pmic-int-l {
};rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>;
};rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_down>;
sdio-pwrseq {
}; };rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>;
- pmic {
- sdio-pwrseq {
- usb-typec {
}; };rockchip,pins = <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>;
leds {
&pwm0 {
+&spdif {
- pinctrl-0 = <&spdif_bus_1>;
- status = "okay";
- spdif_p0: port {
- &tcphy0 { status = "okay"; };
+&tcphy0_usb3 {
- port {
- &tcphy1 { status = "okay"; };
port {
&u2phy1 {
- aliases {
mmc0 = &sdmmc;
mmc1 = &sdhci;
- chosen { stdout-path = "serial2:115200n8"; };
states = <1800000 0x1
3000000 0x0>;
states = <1800000 0x1>,
<3000000 0x0>;
- &cru { assigned-clocks = <&cru PLL_GPLL>, <&cru PLL_CPLL>,
- pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_cd_gpio
bus-width = <4>;
}; };sdmmc_cd_pin: sdmmc-cd-pin { rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>;
- aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
- ir-receiver {
sys-led {
};sys_led: led-0 { label = "sys_led"; linux,default-trigger = "heartbeat"; gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>;
user-led {
- ir {
ir_rx: ir-rx {
- leds {
};sys_led_pin: sys-led-pin { rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>;
}; };user_led_pin: user-led-pin { rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>;
+&spi1 {
- status = "okay";
- spiflash: flash@0 {
reg = <0>;
- aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
regulator-name = "vdd_cpu_b"; regulator-min-microvolt = <712500>; regulator-max-microvolt = <1500000>;pinctrl-0 = <&vsel1_pin>;
regulator-name = "vdd_gpu"; regulator-min-microvolt = <712500>; regulator-max-microvolt = <1500000>;pinctrl-0 = <&vsel2_pin>;
};vsel1_pin: vsel1-pin { rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>;
}; };vsel2_pin: vsel2-pin { rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>;
&pcie0 {
- ep-gpios = <&gpio2 RK_PA4 GPIO_ACTIVE_HIGH>; num-lanes = <4>; vpcie3v3-supply = <&vcc3v3_sys>; };
- Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd
/dts-v1/;
- aliases {
ethernet1 = &r8169;
- /delete-node/ display-subsystem;
- vdd_5v: vdd-5v {
regulator-boot-on;
- gpio-leds {
- fan: pwm-fan {
-&cpu_thermal {
- trips {
type = "active";
lan_led: led-lan {
};label = "green:lan";
cpu_hot: cpu_hot {
type = "active";
sys_led: led-sys {
};default-state = "on";
cooling-maps {
map2 {
trip = <&cpu_warm>;
wan_led: led-wan {
};label = "green:wan";
- gpio-keys {
map3 {
trip = <&cpu_hot>;
reset {
label = "reset";
vdd_5v: vdd-5v {
regulator-boot-on;
-&leds {
- lan_led: led-1 {
- wan_led: led-2 {
-&leds_gpio {
- rockchip,pins =
- &pcie0 { max-link-speed = <1>; num-lanes = <1>; vpcie3v3-supply = <&vcc3v3_sys>;
- pcie@0 {
#size-cells = <2>;
+&pinctrl {
- gpio-leds {
r8169: pcie@0,0 {
- rockchip-key {
}; }; };rockchip,pins = <1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_up>;
-&sdmmc {
- host-index-min = <1>;
- &u2phy0_host { phy-supply = <&vdd_5v>; };
+&uart0 {
- status = "disabled";
- &usbdrd_dwc3_0 { dr_mode = "host"; };
- aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
status {
rtl8211e: phy@1 {
&pcie0 {
- max-link-speed = <2>; num-lanes = <2>; vpcie0v9-supply = <&vcca0v9_s3>; vpcie1v8-supply = <&vcca1v8_s3>;
gpio-leds {
}; };status_led_pin: status-led-pin { rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>;
- phy {
- gmac { phy_intb: phy-intb { rockchip,pins = <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>; };
}; opp01 { opp-hz = /bits/ 64 <600000000>;opp-microvolt = <825000 825000 1250000>; clock-latency-ns = <40000>;
}; opp02 { opp-hz = /bits/ 64 <816000000>;opp-microvolt = <825000 825000 1250000>;
}; opp03 { opp-hz = /bits/ 64 <1008000000>;opp-microvolt = <850000 850000 1250000>;
}; opp04 { opp-hz = /bits/ 64 <1200000000>;opp-microvolt = <925000 925000 1250000>;
}; opp05 { opp-hz = /bits/ 64 <1416000000>;opp-microvolt = <1000000 1000000 1250000>;
}; };opp-microvolt = <1125000 1125000 1250000>;
@@ -41,36 +41,36 @@
}; opp03 { opp-hz = /bits/ 64 <1008000000>;opp-microvolt = <825000 825000 1250000>;
}; opp04 { opp-hz = /bits/ 64 <1200000000>;opp-microvolt = <875000 875000 1250000>;
}; opp05 { opp-hz = /bits/ 64 <1416000000>;opp-microvolt = <950000 950000 1250000>;
}; opp06 { opp-hz = /bits/ 64 <1608000000>;opp-microvolt = <1025000 1025000 1250000>;
}; opp07 { opp-hz = /bits/ 64 <1800000000>;opp-microvolt = <1100000 1100000 1250000>;
}; };opp-microvolt = <1200000 1200000 1250000>;
@@ -79,27 +79,27 @@
}; opp01 { opp-hz = /bits/ 64 <297000000>;opp-microvolt = <825000 825000 1150000>;
}; opp02 { opp-hz = /bits/ 64 <400000000>;opp-microvolt = <825000 825000 1150000>;
}; opp03 { opp-hz = /bits/ 64 <500000000>;opp-microvolt = <825000 825000 1150000>;
}; opp04 { opp-hz = /bits/ 64 <600000000>;opp-microvolt = <875000 875000 1150000>;
}; opp05 { opp-hz = /bits/ 64 <800000000>;opp-microvolt = <925000 925000 1150000>;
}; }; };opp-microvolt = <1100000 1100000 1150000>;
- aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
rtl8211e: phy@1 {
data-role = "host";
label = "USB-C";
sink-pdos =
source-pdos =
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
port@2 {
reg = <2>;
- phy {
+&tcphy0_dp {
- port {
+&tcphy0_usb3 {
- port {
port {
&u2phy1 {
@@ -799,7 +865,7 @@
- dr_mode = "otg";
&usbdrd3_1 {
- aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
- bat: battery {
- edp_panel: edp-panel { compatible = "boe,nv140fhmn49"; backlight = <&backlight>; enable-gpios = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>; pinctrl-names = "default";
ports {
green-led {
red-led {
post-power-on-delay-ms = <100>; power-off-delay-us = <500000>;pinctrl-0 = <&wifi_enable_h_pin>;
simple-audio-card,name = "rockchip,es8316-codec"; simple-audio-card,format = "i2s"; simple-audio-card,mclk-fs = <256>;pinctrl-0 = <&hp_det_pin>;
regulator-name = "vcc5v0_usb"; regulator-always-on; regulator-min-microvolt = <5000000>;pinctrl-0 = <&pwr_5v_pin>;
regulator-name = "vcc3v0_sd"; regulator-always-on; regulator-min-microvolt = <3000000>;pinctrl-0 = <&sdmmc0_pwr_h_pin>;
regulator-name = "vcc3v3_panel"; regulator-always-on; regulator-min-microvolt = <3300000>;pinctrl-0 = <&lcdvcc_en_pin>;
regulator-name = "vcc5v0_otg"; regulator-always-on; regulator-min-microvolt = <5000000>;pinctrl-0 = <&vcc5v0_host_en_pin>;
regulator-name = "vbus_5vout"; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>;pinctrl-0 = <&vcc5v0_typec0_en_pin>;
@@ -368,7 +381,7 @@
}; };pinctrl-0 = <&dc_det_pin>;
rockchip,system-power-controller; wakeup-source;pinctrl-0 = <&pmic_int_l_pin>;
regulator-name = "vdd_cpu_b"; regulator-always-on; regulator-boot-on;pinctrl-0 = <&vsel1_pin>;
regulator-name = "vdd_gpu"; regulator-always-on; regulator-boot-on;pinctrl-0 = <&vsel2_pin>;
pinctrl-names = "default";interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>;
connector {
cw2015@62 {
reg = <0x62>;
&i2s1 {
- #sound-dai-cells = <0>; pinctrl-names = "default";
- pinctrl-0 = <&i2s_8ch_mclk_gpio>, <&i2s1_2ch_bus>;
- pinctrl-0 = <&i2s_8ch_mclk_pin>, <&i2s1_2ch_bus>; rockchip,capture-channels = <8>; rockchip,playback-channels = <8>; status = "okay";
- max-link-speed = <2>; num-lanes = <4>; pinctrl-names = "default"; pinctrl-0 = <&pcie_clkreqn_cpm>;
};pwrbtn_pin: pwrbtn-pin { rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>;
dc-charger {
es8316 {
fusb302x {
i2s1 {
lcd-panel {
};lcdvcc_en_pin: lcdvcc-en-pin { rockchip,pins = <1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>;
};panel_en_pin: panel-en-pin { rockchip,pins = <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>;
leds {
};pwr_led_pin: pwr-led-pin { rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>;
pmic {
};pmic_int_l_pin: pmic-int-l-pin { rockchip,pins = <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>;
sdcard {
sdio-pwrseq {
usb-typec {
usb2 {
};pwr_5v_pin: pwr-5v-pin { rockchip,pins = <1 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>;
};bt_wake_pin: bt-wake-pin { rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>;
};bt_host_wake_pin: bt-host-wake-pin { rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>;
}; };bt_reset_pin: bt-reset-pin { rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>;
shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; vbat-supply = <&wifi_bat>; vddio-supply = <&vcc_wl>;pinctrl-0 = <&bt_host_wake_pin &bt_wake_pin &bt_reset_pin>;
aliases {
mmc1 = &sdmmc;
leds {
sd-card-led {
leds {
};sd_card_led_pin: sd-card-led-pin { rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>;
- aliases {
mmc0 = &sdhci;
module-led {
- /delete-node/ opp-table1;
- cluster1_opp: opp-table1 {
opp-shared;
opp00 {
opp01 {
opp02 {
opp-suspend;
opp03 {
opp04 {
opp05 {
opp06 {
opp07 {
opp08 {
turbo-mode;
- clkin_gmac: external-gmac-clock { compatible = "fixed-clock"; clock-frequency = <125000000>;
leds {
};module_led_pin: module-led-pin { rockchip,pins = <2 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>;
- aliases {
mmc2 = &sdio0;
- /* MP8009 PoE PD */
- poe_12v: poe-12v {
regulator-boot-on;
- vcc3v3_ngff: vcc3v3-ngff { compatible = "regulator-fixed"; regulator-name = "vcc3v3_ngff";
}; };vin-supply = <&sys_12v>;
+&sys_12v {
- vin-supply = <&poe_12v>;
- &pcie_phy { status = "okay"; };
- aliases {
mmc0 = &sdmmc;
mmc1 = &sdhci;
- ir-receiver {
gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_LOW>;
work-led {
};work_led: led-0 { label = "green:work"; gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>; default-state = "on"; linux,default-trigger = "heartbeat";
diy-led {
};linux,default-trigger = "mmc2";
yellow-led {
}; };linux,default-trigger = "mmc1";
- sys_12v: sys-12v {
regulator-boot-on;
vdd_log: vdd-log {
@@ -376,6 +396,7 @@
regulator-boot-on;
- ir {
ir_int: ir-int {
- lcd-panel { lcd_panel_reset: lcd-panel-reset { rockchip,pins = <4 RK_PD5 RK_FUNC_GPIO &pcfg_pull_up>;
leds {
diy_led_gpio: diy_led-gpio {
};diy_led_pin: diy-led-pin { rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>;
work_led_gpio: work_led-gpio {
};work_led_pin: work-led-pin { rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>;
pmic {
vsel1_gpio: vsel1-gpio {
};vsel1_pin: vsel1-pin { rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_down>;
vsel2_gpio: vsel2-gpio {
- aliases {
mmc0 = &sdmmc;
mmc1 = &sdhci;
vdd_log: vdd-log {
&i2s0 {
- rockchip,playback-channels = <8>;
- rockchip,capture-channels = <8>;
- pinctrl-0 = <&i2s0_2ch_bus>;
- rockchip,capture-channels = <2>;
- rockchip,playback-channels = <2>; status = "okay"; };
@@ -476,7 +474,6 @@
- max-link-speed = <2>; num-lanes = <4>; pinctrl-0 = <&pcie_clkreqnb_cpm>; pinctrl-names = "default";
@@ -680,7 +677,7 @@
- dr_mode = "otg";
&usbdrd3_1 {
- compatible = "radxa,rockpi4", "rockchip,rk3399";
- compatible = "radxa,rockpi4a", "radxa,rockpi4", "rockchip,rk3399"; };
aliases {
mmc2 = &sdio0;
&sdio0 {
aliases {
mmc2 = &sdio0;
&sdio0 {
pinctrl-0 = <&user_led1>, <&user_led2>, <&user_led3>,
<&user_led4>, <&wlan_led>, <&bt_led>;
pinctrl-0 = <&user_led1_pin>, <&user_led2_pin>,
<&user_led3_pin>, <&user_led4_pin>,
<&wlan_led_pin>, <&bt_led_pin>;
user_led1 {
};user_led1: led-1 { label = "green:user1"; gpios = <&gpio4 RK_PC2 0>; linux,default-trigger = "heartbeat";
user_led2 {
};user_led2: led-2 { label = "green:user2"; gpios = <&gpio4 RK_PC6 0>; linux,default-trigger = "mmc0";
user_led3 {
};user_led3: led-3 { label = "green:user3"; gpios = <&gpio4 RK_PD0 0>; linux,default-trigger = "mmc1";
user_led4 {
};user_led4: led-4 { label = "green:user4"; gpios = <&gpio4 RK_PD4 0>; panic-indicator; linux,default-trigger = "none";
wlan_active_led {
};wlan_active_led: led-5 { label = "yellow:wlan"; gpios = <&gpio4 RK_PD5 0>; linux,default-trigger = "phy0tx"; default-state = "off";
bt_active_led {
@@ -62,38 +63,52 @@
+&cpu_alert0 {
- temperature = <65000>;
+&cpu_thermal {
- sustainable-power = <1550>;
- cooling-maps {
map0 {
&pinctrl { leds {
user_led1: user_led1 {
};user_led1_pin: user-led1-pin { rockchip,pins = <4 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>;
user_led2: user_led2 {
};user_led2_pin: user-led2-pin { rockchip,pins = <4 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>;
user_led3: user_led3 {
};user_led3_pin: user-led3-pin { rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>;
user_led4: user_led4 {
};user_led4_pin: user-led4-pin { rockchip,pins = <4 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>;
wlan_led: wlan_led {
};wlan_led_pin: wlan-led-pin { rockchip,pins = <4 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>;
bt_led: bt_led {
};bt_led_pin: bt-led-pin { rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>;
-&thermal_zones {
- cpu_thermal: cpu {
trips {
type = "passive";
type = "passive";
type = "critical";
cooling-maps {
map0 {
cooling-device =
- &usbdrd_dwc3_0 { dr_mode = "otg"; };
- aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
- sdio_pwrseq: sdio-pwrseq { compatible = "mmc-pwrseq-simple"; clocks = <&rk808 1>;
- aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
- ir-receiver {
pinctrl-0 = <&work_led_gpio>, <&diy_led_gpio>;
pinctrl-0 = <&work_led_pin>, <&diy_led_pin>;
work-led {
};work_led: led-0 { label = "work"; default-state = "on"; gpios = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>;
diy-led {
@@ -72,10 +85,27 @@
label = "Analog";
sound-dit {
label = "SPDIF";
dais = <&spdif_p0>;
spdif-dit {
port {
- /* micro SD card power */
- vcc3v0_sd: vcc3v0-sd {
enable-active-high;
- vcc3v3_pcie: vcc3v3-pcie-regulator { compatible = "regulator-fixed"; enable-active-high;
pinctrl-0 = <&vsel1_gpio>;
pinctrl-0 = <&vsel2_gpio>;
- ir {
ir_int: ir-int {
- leds {
};work_led_pin: work-led-pin { rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>;
}; };diy_led_pin: diy-led-pin { rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>;
sdcard {
- vmmc-supply = <&vcc3v0_sd>;
- vqmmc-supply = <&vcc_sdio>; status = "okay"; };
+&spdif {
- spdif_p0: port {
- &spi1 { status = "okay";
@@ -768,7 +841,7 @@
- dr_mode = "otg";
&usbdrd3_1 {
- amba: bus {
compatible = "simple-bus";
#address-cells = <2>;
#size-cells = <2>;
ranges;
compatible = "arm,pl330", "arm,primecell";
#dma-cells = <1>;
clock-names = "apb_pclk";
#dma-cells = <1>;
- pcie0: pcie@f8000000 { compatible = "rockchip,rk3399-pcie"; reg = <0x0 0xf8000000 0x0 0x2000000>, <0x0 0xfd000000 0x0 0x1000000>; reg-names = "axi-base", "apb-base";
#address-cells = <3>; #size-cells = <2>; #interrupt-cells = <1>;device_type = "pci";
max-link-speed = <1>; msi-map = <0x0 &its 0x0 0x1000>; phys = <&pcie_phy 0>, <&pcie_phy 1>, <&pcie_phy 2>, <&pcie_phy 3>; phy-names = "pcie-phy-0", "pcie-phy-1", "pcie-phy-2", "pcie-phy-3";linux,pci-domain = <0>;
resets = <&cru SRST_PCIE_CORE>, <&cru SRST_PCIE_MGMT>, <&cru SRST_PCIE_MGMT_STICKY>, <&cru SRST_PCIE_PIPE>, <&cru SRST_PCIE_PM>, <&cru SRST_P_PCIE>,<0x81000000 0x0 0xfbe00000 0x0 0xfbe00000 0x0 0x100000>;
- sdhci: sdhci@fe330000 {
- sdhci: mmc@fe330000 { compatible = "rockchip,rk3399-sdhci-5.1", "arasan,sdhci-5.1"; reg = <0x0 0xfe330000 0x0 0x10000>; interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH 0>;
cpu_thermal: cpu {
gpu_thermal: gpu {
pinctrl-1 = <&otp_out>;pinctrl-0 = <&otp_pin>;
reg = <0x0 0xffae0000 0x0 0x20>; };compatible = "rockchip,rk3399-qos", "syscon";
#size-cells = <1>;
status = "disabled"; };clock-names = "pwm";
- vdec: video-codec@ff660000 {
- vdec_mmu: iommu@ff660480 { compatible = "rockchip,iommu"; reg = <0x0 0xff660480 0x0 0x40>, <0x0 0xff6604c0 0x0 0x40>;
#iommu-cells = <0>;power-domains = <&power RK3399_PD_VDU>;
- dmac_bus: dma-controller@ff6d0000 {
#dma-cells = <1>;
arm,pl330-periph-burst;
- dmac_peri: dma-controller@ff6e0000 {
#dma-cells = <1>;
- pmucru: pmu-clock-controller@ff750000 { compatible = "rockchip,rk3399-pmucru"; reg = <0x0 0xff750000 0x0 0x1000>;
#phy-cells = <0>;
watchdog@ff848000 {
reg = <0x0 0xff848000 0x0 0x100>; clocks = <&cru PCLK_WDT>; interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH 0>;compatible = "rockchip,rk3399-wdt", "snps,dw-wdt";
- isp0: isp0@ff910000 {
phy-names = "dphy";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
#size-cells = <0>;
- isp0_mmu: iommu@ff914000 { compatible = "rockchip,iommu"; reg = <0x0 0xff914000 0x0 0x100>, <0x0 0xff915000 0x0 0x100>;
clocks = <&cru ACLK_GPU>; #cooling-cells = <2>; power-domains = <&power RK3399_PD_GPU>;interrupt-names = "job", "mmu", "gpu";
sleep {
tsadc {
- aliases {
mmc0 = &sdmmc;
mmc1 = &sdhci;
- vcc3v3_pcie: vcc-pcie-regulator { compatible = "regulator-fixed"; enable-active-high;
@@ -324,7 +329,6 @@
- sdio-pwrseq {
- vbus_host { usb1_en_oc: usb1-en-oc { rockchip,pins = <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_up>;
+&sdio_pwrseq {
- reset-gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_LOW>;
- &sdhci { bus-width = <8>; mmc-hs400-1_8v;
This file is also used by rk3288, 'hym8563 ' and 'wifi_enable_h' are no defined in rk3288 platform.
I will remove this part and apply others.
Thanks,
- Kever
- vcc12v_dcin: vcc12v-dcin-regulator { compatible = "regulator-fixed"; regulator-name = "vcc12v_dcin";
+&sdio0 {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- keep-power-in-suspend;
- mmc-pwrseq = <&sdio_pwrseq>;
- non-removable;
- pinctrl-names = "default";
- pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>;
- sd-uhs-sdr104;
- status = "okay";
- &sdmmc { bus-width = <4>; cap-mmc-highspeed;
Kever Yang
Peter Robinson
