[U-Boot] Please pull u-boot-staging/trini@ti.com
Hello Albert and Wolfgang,
To try and ease the backlog of ARM changes, I've taken the liberty of grabbing the Snowball and Raspberry Pi model B board support patches and putting them into the staging tree. Both of these series have been posted for some time and been reviewed. Wolfgang, if you would like to wait for Albert to pick up this request, that's fine. I just wanted to make sure the submitters weren't left waiting. Thanks!
The following changes since commit 4d3c95f5ea7c737a21cd6b9c59435ee693b3f127:
zfs: Add ZFS filesystem support (2012-08-09 23:42:20 +0200)
git://git.denx.de/u-boot-staging trini@ti.com
for you to fetch changes up to bcf2c9ef2877440033e3032fbd597be32728020c:
ARM: add Raspberry Pi model B board, using BCM2835 SoC (2012-08-10 08:57:29 -0700)
---------------------------------------------------------------- John Rigby (1): u8500: Separating mmc config parameters from driver
Mathieu J. Poirier (10): snowball: Add support for ux500 based snowball board u8500: Moving prcmu to cpu directory snowball: Adding architecture dependent initialisation snowball: Adding CPU clock initialisation snowball: Moving to ux500.v2 addess scheme for PRCMU access snowball: applying power to LAN and GBF controllers u8500: Moving processor-specific functions to cpu area. u8500: Enabling power to MMC device on AB8500 V2 armv7: Adding cpu specific cache managmenent snowball: Adding board specific cache cleanup routine
Stephen Warren (4): README: fix references to config_cmd_default.h ARM: arm1176: enable instruction cache in arch_cpu_init() ARM: add basic support for the Broadcom BCM2835 SoC ARM: add Raspberry Pi model B board, using BCM2835 SoC
MAINTAINERS | 8 + README | 4 +- arch/arm/cpu/arm1176/bcm2835/Makefile | 37 + arch/arm/cpu/arm1176/bcm2835/config.mk | 19 + arch/arm/cpu/arm1176/bcm2835/lowlevel_init.S | 19 + arch/arm/cpu/arm1176/bcm2835/reset.c | 35 + arch/arm/cpu/arm1176/bcm2835/timer.c | 55 ++ arch/arm/cpu/arm1176/cpu.c | 7 + arch/arm/cpu/armv7/cpu.c | 8 + arch/arm/cpu/armv7/u8500/Makefile | 2 +- arch/arm/cpu/armv7/u8500/clock.c | 34 + arch/arm/cpu/armv7/u8500/cpu.c | 192 +++++ .../arm/cpu/armv7}/u8500/prcmu.c | 128 +++- arch/arm/include/asm/arch-bcm2835/gpio.h | 66 ++ arch/arm/include/asm/arch-bcm2835/timer.h | 37 + arch/arm/include/asm/arch-bcm2835/wdog.h | 36 + arch/arm/include/asm/arch-u8500/clock.h | 5 +- arch/arm/include/asm/arch-u8500/db8500_gpio.h | 42 ++ arch/arm/include/asm/arch-u8500/db8500_pincfg.h | 170 +++++ arch/arm/include/asm/arch-u8500/hardware.h | 33 +- .../arm/include/asm/arch-u8500/prcmu.h | 35 +- arch/arm/include/asm/arch-u8500/sys_proto.h | 1 + board/armltd/vexpress/ca9x4_ct_vxp.c | 21 +- board/raspberrypi/rpi_b/Makefile | 34 + board/raspberrypi/rpi_b/rpi_b.c | 34 + board/st-ericsson/snowball/Makefile | 49 ++ board/st-ericsson/snowball/db8500_pins.h | 745 ++++++++++++++++++++ board/st-ericsson/snowball/snowball.c | 348 +++++++++ board/st-ericsson/u8500/Makefile | 2 +- board/st-ericsson/u8500/u8500_href.c | 99 +-- boards.cfg | 2 + drivers/gpio/Makefile | 2 + drivers/gpio/bcm2835_gpio.c | 89 +++ drivers/gpio/db8500_gpio.c | 221 ++++++ drivers/mmc/arm_pl180_mmci.c | 131 ++-- drivers/mmc/arm_pl180_mmci.h | 27 +- drivers/serial/serial_pl01x.c | 2 + include/configs/rpi_b.h | 104 +++ include/configs/snowball.h | 266 +++++++ 39 files changed, 2937 insertions(+), 212 deletions(-) create mode 100644 arch/arm/cpu/arm1176/bcm2835/Makefile create mode 100644 arch/arm/cpu/arm1176/bcm2835/config.mk create mode 100644 arch/arm/cpu/arm1176/bcm2835/lowlevel_init.S create mode 100644 arch/arm/cpu/arm1176/bcm2835/reset.c create mode 100644 arch/arm/cpu/arm1176/bcm2835/timer.c create mode 100644 arch/arm/cpu/armv7/u8500/cpu.c rename {board/st-ericsson => arch/arm/cpu/armv7}/u8500/prcmu.c (58%) create mode 100644 arch/arm/include/asm/arch-bcm2835/gpio.h create mode 100644 arch/arm/include/asm/arch-bcm2835/timer.h create mode 100644 arch/arm/include/asm/arch-bcm2835/wdog.h create mode 100644 arch/arm/include/asm/arch-u8500/db8500_gpio.h create mode 100644 arch/arm/include/asm/arch-u8500/db8500_pincfg.h rename board/st-ericsson/u8500/prcmu-fw.h => arch/arm/include/asm/arch-u8500/prcmu.h (55%) create mode 100644 board/raspberrypi/rpi_b/Makefile create mode 100644 board/raspberrypi/rpi_b/rpi_b.c create mode 100644 board/st-ericsson/snowball/Makefile create mode 100644 board/st-ericsson/snowball/db8500_pins.h create mode 100644 board/st-ericsson/snowball/snowball.c create mode 100644 drivers/gpio/bcm2835_gpio.c create mode 100644 drivers/gpio/db8500_gpio.c create mode 100644 include/configs/rpi_b.h create mode 100644 include/configs/snowball.h
Dear Tom,
Thanks, highly appreciated.
As this contains a lot of ARM, indeed I would like to wait for Albert's ACK or pulling (whichever he prefers).
Hi Tom,
On Fri, 10 Aug 2012 22:06:59 +0200, Wolfgang Denk wd@denx.de wrote:
Dear Tom,
Applied to u-boot-arm/master, thanks!
Amicalement,
Hi Albert,
On Tue, 14 Aug 2012 02:04:15 +0200, Albert ARIBAUD (U-Boot) albert.u.boot@aribaud.net wrote:
Hi Tom,
Dear Tom,
But I might hold this a little, as commit "snowball: Adding architecture dependent initialisation" 7e2b895eb5aa10890910eed8921d042d13b828c0 seems to play bad with my stock Ubuntu 12.04 GCC on u8500_href:
uboot@lilith:~/src/u-boot-arm$ git checkout f917361b988f69ddc0dbe2bd2beb93b296065b70^ HEAD is now at 1b5d8d5... u8500: Moving prcmu to cpu directory uboot@lilith:~/src/u-boot-arm$ LANG=C ./MAKEALL u8500_href Configuring for u8500_href board... text data bss dec hex filename 139584 4408 221728 365720 59498 ./u-boot
--------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- uboot@lilith:~/src/u-boot-arm$ git checkout f917361b988f69ddc0dbe2bd2beb93b296065b70 Previous HEAD position was 1b5d8d5... u8500: Moving prcmu to cpu directory HEAD is now at f917361... snowball: Adding architecture dependent initialisation uboot@lilith:~/src/u-boot-arm$ LANG=C ./MAKEALL u8500_href Configuring for u8500_href board... text data bss dec hex filename 139744 4408 221696 365848 59518 ./u-boot u8500_href.c:45:0: warning: "PRCMU_BASE" redefined [enabled by default] /home/uboot/src/u-boot-arm/include/asm/arch/prcmu.h:30:0: note: this is the location of the previous definition
--------------------- SUMMARY ---------------------------- Boards compiled: 1 Boards with warnings but no errors: 1 ( u8500_href ) ----------------------------------------------------------
Granted, this is only a warning, but I'd like to see it fixed.
Amicalement,
I will fix this right away.
Mathieu.
On 12-08-13 07:06 PM, Albert ARIBAUD (U-Boot) wrote:
Hi Albert,
Hi Tom,
Dear Tom,
Amicalement,
On Tue, Aug 14, 2012 at 03:06:17AM +0200, Albert ARIBAUD wrote:
Hi Albert,
Hi Tom,
Dear Tom,
I've taken Mathieu's updated patch and pushed the series again to u-boot-staging/trini@ti.com. A git reset --hard a1cd53c6b6e2e7fbf4ffa20d3548646e4c94efe5 and then pull of my tree will get things back in shape. I've done a MAKEALL -s u8500 and it's fine now and I'm kicking off a -a arm.
Albert ARIBAUD
Mathieu Poirier
